- 05-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-M-LAG commands
- 04-VLAN commands
- 05-MVRP commands
- 06-VLAN mapping commands
- 07-VLAN termination commands
- 08-Loop detection commands
- 09-Spanning tree commands
- 10-LLDP commands
- 11-PFC commands
- 12-Service loopback group commands
- 13-Cut-through Layer 2 forwarding commands
00-Preface | 110.75 KB |
Preface
This command reference describes the Layer 2 LAN switching commands in the following aspects:
· Layer 2 traffic control and load sharing.
· Eliminating Layer 2 loops.
· Isolating users within a VLAN and dividing VLANs.
· Modifying VLAN tags of packets.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
