| 04-HH3C-MP-V2-MIB | 98.60 KB |
HH3C-MP-V2-MIB
About this MIB
Use this MIB to configure MP.
MIB file name
hh3c-mp-v2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMultilinkPPPV2(140)
Tabular objects
hh3cMpMultilinkV2Table
About this table
Use this table to obtain the MP link information.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMpMultilinkDescrV2 (1.3.6.1.4.1.25506.2.140.1.1.1.1) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Interface name of the father interface on which child channels are bundled. |
As per the MIB. |
hh3cMpBundleNameV2 (1.3.6.1.4.1.25506.2.140.1.1.1.2) |
read-only |
DisplayString |
Bundle name of the MP link. |
For an MP-group interface, the value is Multilink. |
hh3cMpBundledSlotV2 (1.3.6.1.4.1.25506.2.140.1.1.1.3) |
read-only |
Integer32 |
Standard MIB values. |
Slot on which child channels are bundled. |
As per the MIB. |
hh3cMpBundledMemberCntV2 (1.3.6.1.4.1.25506.2.140.1.1.1.4) |
read-only |
Integer32 |
Number of child channels of the MP link. |
As per the MIB. |
hh3cMpLostFragmentsV2 (1.3.6.1.4.1.25506.2.140.1.1.1.5) |
read-only |
Counter32 |
Number of fragments of the MP link discarded. |
As per the MIB. |
hh3cMpReorderedPktsV2 (1.3.6.1.4.1.25506.2.140.1.1.1.6) |
read-only |
Counter32 |
Number of reordered incoming packets of the MP link |
As per the MIB. |
hh3cMpUnassignedPktsV2 (1.3.6.1.4.1.25506.2.140.1.1.1.7) |
read-only |
Counter32 |
Number of received packets of the MP link waiting for reordering. |
As per the MIB. |
hh3cMpInterleavedPktsV2 (1.3.6.1.4.1.25506.2.140.1.1.1.8) |
read-only |
Counter32 |
Number of received interleaved packets of the MP link. |
As per the MIB. |
hh3cMpRcvdSequenceV2 (1.3.6.1.4.1.25506.2.140.1.1.1.9) |
read-only |
Integer32 |
Sequence number for the MP link to receive. |
As per the MIB. |
hh3cMpSentSequenceV2 (1.3.6.1.4.1.25506.2.140.1.1.1.10) |
read-only |
Integer32 |
Sequence number for the MP link to send. |
As per the MIB. |
hh3cMpMemberlinkV2Table
About this table
Use this table to configure the child channels of an MP link.
Read:Supported
Columns
The table indexes are ifIndex and hh3cMpMemberlinkSeqNumberV2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMpMemberlinkSeqNumberV2 (1.3.6.1.4.1.25506.2.140.1.2.1.1) |
read-only |
Integer32 |
Sequence number of a child channel of the MP link. |
As per the MIB. |
hh3cMpMemberlinkIfIndexV2 (1.3.6.1.4.1.25506.2.140.1.2.1.2) |
read-only |
Integer32 |
Interface index of a child channel of the MP link. |
As per the MIB. |
hh3cMpMemberlinkDescrV2 (1.3.6.1.4.1.25506.2.140.1.2.1.3) |
read-only |
DisplayString |
Interface name of a child channel of the MP link. |
As per the MIB. |
hh3cMpMemberlinkMpStatusV2 (1.3.6.1.4.1.25506.2.140.1.2.1.4) |
read-only |
INTEGER |
active(1) inactive(2) |
State of a child channel of the MP link. |
As per the MIB. |
Notifications
hh3cMpRxLossPktAlarm
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.140.1.4.0.1 |
Incoming packet loss rate exceeding alarm |
Error |
Warning |
1.3.6.1.4.1.25506.2.140.1.4.0.2 (hh3cMpRxLossPktAlarmResume) |
OFF |
Notification triggers
The notification is generated when the incoming packet loss rate on an MP group exceeds the user-configured threshold.
Possible reasons are:
Signal quality degrades on members in the MP group.
Both large packets and small packets exist on the MP group, and fragmentation is disabled on the MP group.
System impact
Packet loss occurs on the MP group, and the service performance is affected.
Status control
ON
CLI: snmp-agent trap enable ppp mp
OFF
CLI: undo snmp-agent trap enable ppp mp
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.140.1.3.1 (hh3cMpRxLossAlarmIfName) |
Name of the interface where packet loss occurs. |
N/A |
DisplayString |
SIZE(1..31) |
1.3.6.1.4.1.25506.2.140.1.3.2 (hh3cMpRxLossCurValueString) |
Current packet loss rate. |
N/A |
DisplayString |
SIZE(1..31) |
1.3.6.1.4.1.25506.2.140.1.3.3 (hh3cMpRxLossAlarmValueString) |
Alarm threshold. |
N/A |
DisplayString |
SIZE(1..31) |
1.3.6.1.4.1.25506.2.140.1.3.4 (hh3cMpRxLossResumeValueString) |
Alarm recovery threshold. |
N/A |
DisplayString |
SIZE(1..31) |
Recommended action
1.Verify that the configuration is correct.
2.Add sublinks.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.140.1.4.0.2 |
Incoming packet loss rate alarm recovery |
Recovery |
Warning |
N/A (N/A) |
OFF |
The notification is generated when the incoming packet loss rate on the MP group exceeds the user-configured threshold and then drops below the threshold.
The incoming packet loss rate on the MP group drops below the user-configured threshold.
System impact
The incoming packet loss rate on the MP group drops below the user-configured threshold, and then the performance improves.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
DisplayString |
SIZE(1..31) |
N/A |
DisplayString |
SIZE(1..31) |
Alarm threshold. |
N/A |
DisplayString |
SIZE(1..31) |
N/A |
DisplayString |
SIZE(1..31) |
Recommended action
No action is required.
