07-Layer 2 - WAN Access
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10007-Layer 2 - WAN Access
02-HH3C-L2TP-MIB
02-HH3C-L2TP-MIB 162.86 KB
HH3C-L2TP-MIB
About this MIB
Use this MIB to obtain the L2TP module information.
MIB file name
hh3c-l2tp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cL2tp(139)
Scalar objects
hh3cL2tpTUpOrDownLocalTID
(1.3.6.1.4.1.25506.2.139.1.5.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
Integer32
Standard MIB values.
Local L2TP tunnel ID
As per the MIB.
hh3cL2tpTUpOrDownTRemoteName
(1.3.6.1.4.1.25506.2.139.1.5.2)
Object (OID)
Access
Value range
Implementation
SnmpAdminString
SIZE(0..31)
Peer L2TP tunnel name
As per the MIB.
hh3cL2tpTUpOrDownTPeerIPAdd
(1.3.6.1.4.1.25506.2.139.1.5.3)
Object (OID)
Access
Value range
Implementation
IpAddress
Peer L2TP tunnel IP address
As per the MIB.
hh3cL2tpTUpOrDownTStatus
(1.3.6.1.4.1.25506.2.139.1.5.4)
Object (OID)
Access
Value range
Implementation
INTEGER
established(1)
stopping(2)
L2TP tunnel state
As per the MIB.
hh3cL2tpTUpOrDownTDownReason
(1.3.6.1.4.1.25506.2.139.1.5.5)
Object (OID)
Access
Value range
Implementation
SnmpAdminString
SIZE(0..63)
L2TP tunnel disconnection reason
As per the MIB.
hh3cL2tpTUpOrDownRemoteTID
(1.3.6.1.4.1.25506.2.139.1.5.6)
Object (OID)
Access
Value range
Implementation
Integer32
Peer L2TP tunnel ID
As per the MIB.
hh3cL2tpTUpOrDownSessCount
(1.3.6.1.4.1.25506.2.139.1.5.7)
Object (OID)
Access
Value range
Implementation
Integer32
Total number of L2TP tunnel sessions
As per the MIB.
Tabular objects
hh3cL2tpScalar
About this table
Use this table to obtain the L2TP scalar status and statistics.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
No table index.
Object (OID)
Access
Value range
Implementation
hh3cL2tpStatsTotalTunnels (1.3.6.1.4.1.25506.2.139.1.1.1.1)
read-only
Counter32
Total number of L2TP tunnels.
As per the MIB.
hh3cL2tpStatsTotalSessions (1.3.6.1.4.1.25506.2.139.1.1.1.2)
read-only
Counter32
Total number of L2TP sessions.
As per the MIB.
hh3cL2tpSessionRate (1.3.6.1.4.1.25506.2.139.1.1.1.3)
read-only
Integer32
Number of L2TP sessions generated per second in real time.
As per the MIB.
hh3cL2tpStatsTemporarySessions (1.3.6.1.4.1.25506.2.139.1.1.1.4)
read-only
Unsigned32
Total number of temporary L2TP sessions.
As per the MIB.
hh3cL2tpStatsMaxSessions (1.3.6.1.4.1.25506.2.139.1.1.1.5)
read-only
Counter32
Maximum number of L2TP sessions.
As per the MIB.
hh3cL2tpProtocolVersions (1.3.6.1.4.1.25506.2.139.1.1.1.6)
read-only
OCTET STRING
OCTET STRING
(2..256)
Local protocol version
As per the MIB.
hh3cL2tpVendorName (1.3.6.1.4.1.25506.2.139.1.1.1.7)
read-only
SnmpAdminString
Protocol stack vendor
As per the MIB.
hh3cL2tpFirmwareRev (1.3.6.1.4.1.25506.2.139.1.1.1.8)
read-only
Integer32
Protocol stack firmware version
As per the MIB.
hh3cL2tpDrainingTunnels (1.3.6.1.4.1.25506.2.139.1.1.1.9)
read-only
TruthValue
Whether the local end blocks L2TP sessions from other tunnels
As per the MIB.
hh3cL2tpAdminState (1.3.6.1.4.1.25506.2.139.1.1.2.1)
read-write
INTEGER
enabled(1)
disabled(2)
Whether to enable L2TP
As per the MIB.
hh3cL2tpAging (1.3.6.1.4.1.25506.2.139.1.1.2.2)
read-write
Integer32
Integer32
(1..3600)
LNS down aging time
As per the MIB.
hh3cL2tpTunnelTable
About this table
Use this table to obtain the L2TP tunnel information.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cL2tpTunnelType, hh3cL2tpLocalIpAddress, and hh3cL2tpLocalTunnelID.
Object (OID)
Access
Value range
Implementation
hh3cL2tpTunnelType (1.3.6.1.4.1.25506.2.139.1.2.1.1.1)
not-accessible
INTEGER
global(1)
instance(2)
L2TP tunnel type.
As per the MIB.
hh3cL2tpLocalIpAddress (1.3.6.1.4.1.25506.2.139.1.2.1.1.2)
not-accessible
IpAddress
Local L2TP tunnel IP address.
As per the MIB.
hh3cL2tpLocalTunnelID (1.3.6.1.4.1.25506.2.139.1.2.1.1.3)
not-accessible
Unsigned32
Unsigned32 (1..65535)
Local L2TP tunnel ID.
As per the MIB.
hh3cL2tpSessions (1.3.6.1.4.1.25506.2.139.1.2.1.1.4)
read-only
Unsigned32
As per the MIB.
hh3cL2tpRemoteIpAddress (1.3.6.1.4.1.25506.2.139.1.2.1.1.5)
read-only
IpAddress
Peer L2TP tunnel IP address.
As per the MIB.
hh3cL2tpRemoteTunnelID (1.3.6.1.4.1.25506.2.139.1.2.1.1.6)
read-only
Unsigned32
Peer L2TP tunnel ID.
As per the MIB.
hh3cL2tpRemotePort (1.3.6.1.4.1.25506.2.139.1.2.1.1.7)
read-only
Unsigned32
Unsigned32 (0..65535)
Peer L2TP tunnel port.
As per the MIB.
hh3cL2tpRemoteName (1.3.6.1.4.1.25506.2.139.1.2.1.1.8)
read-only
DisplayString
OCTET STRING (0..255)
Peer L2TP tunnel name.
As per the MIB.
hh3cL2tpTunnelState (1.3.6.1.4.1.25506.2.139.1.2.1.1.9)
read-only
INTEGER
idle(0)
waitReply(1)
established(2)
stopping(3)
Current L2TP tunnel state.
As per the MIB.
hh3cL2tpGroupConfigTable
About this table
Use this table to obtain and modify the L2TP group configuration.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cL2tpGroupConfigGroupID.
Object (OID)
Access
Value range
Implementation
hh3cL2tpGroupConfigGroupID (1.3.6.1.4.1.25506.2.139.1.3.1.1.1)
read-only
Interger32
Interger32
(1..65535)
L2TP group index
As per the MIB.
hh3cL2tpGroupConfigDomainId (1.3.6.1.4.1.25506.2.139.1.3.1.1.2)
read-create
SnmpAdminString
OCTET STRING
(0..80)
Domain name of the L2TP tunnel
Read-only in the current software version
hh3cL2tpGroupConfigHelloInterval (1.3.6.1.4.1.25506.2.139.1.3.1.1.3)
read-create
Interger32
Interger32 (60..1000)
Interval of sending Hello packets to the peer end
As per the MIB.
hh3cL2tpGroupConfigIdleTimeout (1.3.6.1.4.1.25506.2.139.1.3.1.1.4)
read-create
Interger32
Interger32 (-1..86400)
Idle time for disconnecting a connection without sessions
hh3cL2tpGroupConfigCtrlRWS (1.3.6.1.4.1.25506.2.139.1.3.1.1.5)
read-create
Interger32
Interger32 (1..5000)
Receiving window size for a control channel
As per the MIB.
hh3cL2tpGroupConfigCtrlMaxRetx (1.3.6.1.4.1.25506.2.139.1.3.1.1.6)
read-create
Interger32
Interger32 (0..32)
Maximum retransmissions of an L2TP tunnel
hh3cL2tpGroupConfigCtrlMaxRetxTO (1.3.6.1.4.1.25506.2.139.1.3.1.1.7)
read-create
Interger32
Interger32 (1..32)
Maximum retransmission timeout timer
hh3cL2tpGroupConfigAuthentication (1.3.6.1.4.1.25506.2.139.1.3.1.1.8)
read-create
TruthValue
Whether to perform L2TP tunnel authentication
As per the MIB.
hh3cL2tpGroupConfigAvpHidden (1.3.6.1.4.1.25506.2.139.1.3.1.1.9)
read-create
TruthValue
Whether to transfer AVP data in hidden mode
As per the MIB.
hh3cL2tpGroupConfigLoadsharing (1.3.6.1.4.1.25506.2.139.1.3.1.1.10)
read-create
TruthValue
Whether to implement load balancing
As per the MIB.
hh3cL2tpGroupConfigTunnelName (1.3.6.1.4.1.25506.2.139.1.3.1.1.11)
read-create
DisplayString
OCTET STRING
(0..31)
Local L2TP tunnel name
As per the MIB.
hh3cL2tpGroupConfigLnsIP1 (1.3.6.1.4.1.25506.2.139.1.3.1.1.13)
read-create
IpAddress
LNS IP address 1 for load balancing
As per the MIB.
hh3cL2tpGroupConfigLnsWeight1 (1.3.6.1.4.1.25506.2.139.1.3.1.1.14)
read-create
Interger32
Interger32 (1..10)
LNS weight 1 for load balancing
As per the MIB.
hh3cL2tpGroupConfigLnsIP2 (1.3.6.1.4.1.25506.2.139.1.3.1.1.15)
read-create
IpAddress
LNS IP address 2 for load balancing
As per the MIB.
hh3cL2tpGroupConfigLnsWeight2 (1.3.6.1.4.1.25506.2.139.1.3.1.1.16)
read-create
Interger32
Interger32 (1..10)
LNS weight 2 for load balancing
As per the MIB.
hh3cL2tpGroupConfigLnsIP3 (1.3.6.1.4.1.25506.2.139.1.3.1.1.17)
read-create
IpAddress
LNS IP address 3 for load balancing
As per the MIB.
hh3cL2tpGroupConfigLnsIP4 (1.3.6.1.4.1.25506.2.139.1.3.1.1.19)
read-create
IpAddress
LNS IP address 4 for load balancing
As per the MIB.
hh3cL2tpGroupConfigLnsWeight4 (1.3.6.1.4.1.25506.2.139.1.3.1.1.20)
read-create
Interger32
Interger32 (1..10)
LNS weight 4 for load balancing
As per the MIB.
hh3cL2tpGroupConfigLnsIP5 (1.3.6.1.4.1.25506.2.139.1.3.1.1.21)
read-create
IpAddress
LNS IP address 5 for load balancing
As per the MIB.
hh3cL2tpGroupConfigLnsWeight5 (1.3.6.1.4.1.25506.2.139.1.3.1.1.22)
read-create
Interger32
Interger32 (1..10)
LNS weight 5 for load balancing
As per the MIB.
hh3cL2tpGroupConfigGroupName (1.3.6.1.4.1.25506.2.139.1.3.1.1.23)
read-create
DisplayString
OCTET STRING
(0::32)
L2TP group name
As per the MIB.
hh3cL2tpGroupConfigRemoteName (1.3.6.1.4.1.25506.2.139.1.3.1.1.24)
read-create
DisplayString
OCTET STRING
(0::31)
Accepted peer L2TP tunnel name
As per the MIB.
hh3cL2tpGroupConfigForceChap (1.3.6.1.4.1.25506.2.139.1.3.1.1.25)
read-create
TruthValue
Whether to perform CHAP authentication by force
As per the MIB.
hh3cL2tpGroupConfigVTNumber (1.3.6.1.4.1.25506.2.139.1.3.1.1.27)
read-create
Interger32
Interger32
(0..65535)
Bound virtual template interface
As per the MIB.
hh3cL2tpGroupConfigMode (1.3.6.1.4.1.25506.2.139.1.3.1.1.28)
read-create
INTEGER
lac(1)
lns(2)
L2TP group mode
As per the MIB.
hh3cL2tpGroupConfigRowStatus (1.3.6.1.4.1.25506.2.139.1.3.1.1.29)
read-create
RowStatus
Adding/deleting/modifying/querying flag
As per the MIB.
hh3cL2tpTunnelStatsTable
About this table
Use this table to obtain L2TP performance parameters of an access server.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cL2tpTStatsUpID and hh3cL2tpTStatsLocalTID.
Object (OID)
Access
Value range
Implementation
hh3cL2tpTStatsUpID (1.3.6.1.4.1.25506.2.139.1.4.1.1.1)
not-accessible
Interger32
Interger32
(0..2047)
UP index ID
As per the MIB.
hh3cL2tpTStatsLocalTID (1.3.6.1.4.1.25506.2.139.1.4.1.1.2)
not-accessible
Interger32
Interger32 (1..65535)
As per the MIB.
hh3cL2tpTStatsRemoteTID (1.3.6.1.4.1.25506.2.139.1.4.1.1.3)
read-only
Interger32
Peer L2TP tunnel ID
As per the MIB.
hh3cL2tpTStatsState (1.3.6.1.4.1.25506.2.139.1.4.1.1.4)
read-only
INTEGER
idle(1)
connecting(2)
established(3)
disconnecting(4)
Control L2TP tunnel status
As per the MIB.
hh3cL2tpTStatsInitiated (1.3.6.1.4.1.25506.2.139.1.4.1.1.5)
read-only
INTEGER
locally(1)
remotely(2)
Indicates the L2TP tunnel is initiated by the local end or peer end
As per the MIB.
hh3cL2tpTStatsRemoteHostName (1.3.6.1.4.1.25506.2.139.1.4.1.1.6)
read-only
SnmpAdminString
OCTET STRING
(1..31)
Peer host name
As per the MIB.
hh3cL2tpTStatsRemoteVendorName (1.3.6.1.4.1.25506.2.139.1.4.1.1.7)
read-only
SnmpAdminString
OCTET STRING
(1..256)
Provider name of the peer L2TP
As per the MIB.
hh3cL2tpTStatsRemoteFirmwareRev (1.3.6.1.4.1.25506.2.139.1.4.1.1.8)
read-only
Interger32
Firmware version of the peer L2TP
As per the MIB.
hh3cL2tpTStatsRemoteProtocolVer (1.3.6.1.4.1.25506.2.139.1.4.1.1.9)
read-only
OCTET STRING
OCTET STRING
(2)
Protocol version of the peer L2TP
As per the MIB.
hh3cL2tpTStatsBearerCaps (1.3.6.1.4.1.25506.2.139.1.4.1.1.10)
read-only
INTEGER
none(1)
digital(2)
analog(3)
digitalAnalog(4)
Bearing capability of the L2TP tunnel
As per the MIB.
hh3cL2tpTStatsFramingCaps (1.3.6.1.4.1.25506.2.139.1.4.1.1.11)
read-only
INTEGER
none(1)
sync(2)
async(3)
syncAsync(4)
Framing capability of the L2TP tunnel
As per the MIB.
hh3cL2tpTStatsControlRxPkts (1.3.6.1.4.1.25506.2.139.1.4.1.1.12)
read-only
Counter32
Number of control packets received
As per the MIB.
hh3cL2tpTStatsControlRxZLB (1.3.6.1.4.1.25506.2.139.1.4.1.1.13)
read-only
Counter32
Number of ZLB control packets received
As per the MIB.
hh3cL2tpTStatsControlTxPkts (1.3.6.1.4.1.25506.2.139.1.4.1.1.14)
read-only
Counter32
Number of control packets sent to the peer entity
As per the MIB.
hh3cL2tpTStatsControlTxZLB (1.3.6.1.4.1.25506.2.139.1.4.1.1.15)
read-only
Counter32
Number of ZLB control packets sent to the peer entity
As per the MIB.
hh3cL2tpTStatsControlAckTO (1.3.6.1.4.1.25506.2.139.1.4.1.1.16)
read-only
Counter32
Number of control packets that time out because ACK packets are not timely received
As per the MIB.
hh3cL2tpTStatsCurrentRemoteRWS (1.3.6.1.4.1.25506.2.139.1.4.1.1.17)
read-only
Gauge32
Gauge32
(0..65535)
Receiving window size of the current peer
As per the MIB.
hh3cL2tpTStatsTxSeq (1.3.6.1.4.1.25506.2.139.1.4.1.1.18)
read-only
Interger32
Interger32 (0..65535)
Next sequence number sent by the control channel
As per the MIB.
hh3cL2tpTStatsTxSeqAck (1.3.6.1.4.1.25506.2.139.1.4.1.1.19)
read-only
Interger32
Sending sequence number of a received ACK
As per the MIB.
hh3cL2tpTStatsRxSeq (1.3.6.1.4.1.25506.2.139.1.4.1.1.20)
read-only
Interger32
Next receiving sequence number of the control channel
As per the MIB.
hh3cL2tpTStatsTotalSessions (1.3.6.1.4.1.25506.2.139.1.4.1.1.21)
read-only
Counter32
As per the MIB.
hh3cL2tpTStatsFailedSessions (1.3.6.1.4.1.25506.2.139.1.4.1.1.22)
read-only
Counter32
Number of L2TP sessions initiated but not established
As per the MIB.
hh3cL2tpTStatsActiveSessions (1.3.6.1.4.1.25506.2.139.1.4.1.1.23)
read-only
Gauge32
Number of established L2TP sessions
As per the MIB.
Notifications
hh3cL2tpSessionFail
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.139.1.8.0.1
Failure of session addtion.
Informational
Warning
OFF
Notification triggers
This notification is generated when an L2TP user fails to come online.
Possible reasons include:
The number of L2TP sessions has reached the maximum limit.
Negotiation fails during the online process.
During the online process, the tunnel's carrier port goes down.
System impact
When the number of L2TP users on the device exceeds the device's capacity, subsequent L2TP user online attempts fail.
User traffic is interrupted.
Status control
ON
CLI: snmp-agent trap enable l2tp session-add-fail
OFF
CLI: undo snmp-agent trap enable l2tp session-add-fail
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.139.1.7.1
 (hh3cL2tpSessFailChassisID)
Chassis ID
N/A
Integer32
1.3.6.1.4.1.25506.2.139.1.7.2 (hh3cL2tpSessFailSlotID)
Slot ID
N/A
Integer32
1.3.6.1.4.1.25506.2.139.1.7.3 (hh3cL2tpSessFailLocalTID)
Local tunnel ID
N/A
Integer32
1.3.6.1.4.1.25506.2.139.1.7.4 (hh3cL2tpSessFailLocalSID)
Local session ID
N/A
Integer32
1.3.6.1.4.1.25506.2.139.1.7.5 (hh3cL2tpSessFailPeerIPAdd)
Peer address
N/A
IpAddress
1.3.6.1.4.1.25506.2.139.1.7.6 (hh3cL2tpSessFailLocalIPAdd)
Local address
N/A
IpAddress
Recommended action
1.Replace the card or use a new device.
2.Check if the carrier port status of the tunnel is normal.
