12-Security Command Reference
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command Reference-R8530Pxx-6W10112-Security Command Reference
17-SAVA commands
17-SAVA commands 81.27 KB
SAVA commands
display ipv6 sava
Use display ipv6 sava to display SAVA entries.
In standalone mode:
display ipv6 sava [ interface interface-type interface-number | slot slot-number ]
In IRF mode:
display ipv6 sava [ interface interface-type interface-number | chassis chassis-number slot slot-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays SAVA entries for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays SAVA entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays SAVA entries on the global active MPU. (In IRF mode.)
# Display SAVA entries.
<Sysname> display ipv6 sava
IPv6 SAVA entry count: 2
Destination: 2011::                    Prefix length: 64
Interface: XGE3/1/1                    Flags: L
VPN instance: --
Destination: 2012::                    Prefix length: 64
Interface: XGE3/1/2                    Flags: L
VPN instance: --
Number of SAVA entries.
Destination
Destination IPv6 address.
Prefix length
Prefix length of the IPv6 address.
Interface name.
Flag
Flag of the SAVA entry:
·     L—Local entry.
·     R—Remote entry.
·     G—Access group entry.
VPN instance
Name of the VPN instance associated with the interface in the SAVA entry. If the interface is not associated with a VPN instance, this field displays two hyphens (--).
display ipv6 sava packet-drop statistics
Use display ipv6 sava packet-drop statistics to display SAVA packet drop statistics.
display ipv6 sava packet-drop statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays SAVA packet drop statistics for all interfaces.
# Display SAVA packet drop statistics.
<Sysname> display ipv6 sava packet-drop statistics
Ten-GigabitEthernet3/1/1:
  Packets:0               Bytes: 0
Ten-GigabitEthernet3/1/2:
  Packets:10              Bytes: 1500
Packets
Number of packets dropped by SAVA.
Bytes
Number of bytes dropped by SAVA.
reset ipv6 sava packet-drop statistics
ipv6 sava access-group
Use ipv6 sava access-group to add an interface to an access group.
Use undo ipv6 sava access-group to remove an interface from an access group.
ipv6 sava access-group group-name
An interface does not belong to any access group.
Interface view
group-name: Specifies an access group by its name, a case-sensitive string of 1 to 255 characters.
If the device has multiple interfaces connected to the same LAN, the device might receive packets from users in the LAN on different interfaces. However, each interface creates SAVA entries only based on its local routes. When an interface receives a packet from the LAN for which the interface has no matching SAVA entry, the packet will be discarded.
To resolve this issue, you can add the interfaces to a SAVA access group. The interfaces in the SAVA access group will synchronize SAVA entries that are created based on local routes with each other. This avoids unexpected packet drop caused by asymmetric routing.
All interfaces in a SAVA access group must belong to the public network or the same VPN instance.
An interface can be added only to one SAVA access group. If you execute this command multiple times, the most recent configuration takes effect.
A SAVA access group can contain a maximum of eight interfaces.
# Add Ten-GigabitEthernet3/1/1 10 to SAVA access group aaa.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] ipv6 sava access-group aaa
ipv6 sava enable
ipv6 sava enable
Use ipv6 sava enable to enable SAVA.
Use undo ipv6 sava enable to disable SAVA.
ipv6 sava enable
SAVA is disabled.
Interface view
SAVA is mutually exclusive with uPRF and microsegmentation. Do not configure SAVA together with uRPF or microsegmentation.
If the device has a large number of routing entries, it might take a long time for the device to complete SAVA entry creation. Before SAVA entry creation completes, valid IPv6 packets might be dropped.
# Enable Ten-GigabitEthernet3/1/1 on VLAN-interface 10.
[Sysname-Ten-GigabitEthernet3/1/1] ipv6 sava enable
display ipv6 sava
ipv6 sava log enable spoofing-packet
Use ipv6 sava log enable spoofing-packet to enable SAVA logging.
Use undo ipv6 sava log enable spoofing-packet to disable SAVA logging.
ipv6 sava log enable spoofing-packet [ interval interval | number number ]*
SAVA logging is disabled.
interval interval: Specifies the interval at which the device outputs SAVA logs, in seconds. The value can be 0 or in the range of 5 to 3600, and the default is 60. If you set the interval to 0 seconds, the device outputs a SAVA log immediately after detecting an IPv6 source address spoofed packet.
number number: Specifies the maximum number of SAVA logs that can be outputted each time, in the range of 1 to 128. The default is 128.
To identify and troubleshoot issues, enable SAVA logging.
This feature enables the device to output SAVA logs when SAVA detects spoofed packets.
With the information center, you can configure log destinations and output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
Due to hardware performance, the device still generates SAVA logs for a short time after you disable SAVA logging.
Outputting a large number of SAVA logs might degrade device performance and cause inconvenience for fault location. You can limit the number of SAVA logs that the device outputs each time.
A card can output a maximum of 128 SAVA logs each time. (In standalone mode.) (In IRF mode.)
# Enable SAVA logging.
[Sysname] ipv6 sava log enable spoofing-packet
ipv6 sava import remote-route-tag
Use ipv6 sava import remote-route-tag to enable an interface to create SAVA entries based on synchronized remote routes.
Use undo ipv6 sava import remote-route-tag to restore the default.
ipv6 sava import remote-route-tag tag
An interface does not create SAVA entries based on synchronized remote routes.
Interface view
tag: Specifies a tag of synchronized remote routes, in the range of 1 to 4294967295.
This command enables an interface to create SAVA entries based on synchronized remote entries with the specified route tag.
Use this command if the LAN connects to the backbone network through multiple access devices and LAN-side interfaces on the border devices do not have prefix information of all users in the LAN. This task ensures that the border devices have the same SAVA entries to avoid mistaken packet drop.
Each border device adds a route tag to local routes based on which SAVA entries are created and then advertises the tagged local routes to the other border devices through a routing protocol. The other border devices will create SAVA entries upon receiving the tagged routes advertised by other border devices.
# Configure the device to create SAVA entries based on synchronized remote entries with tag 10 on Ten-GigabitEthernet3/1/1.
[Sysname-Ten-GigabitEthernet3/1/1] ipv6 sava import remote-route-tag 100
ipv6 sava packet-drop enable
Use ipv6 sava enable to enable dropping of SAVA-detected spoofed packets.
Use undo ipv6 sava enable to disable dropping of SAVA-detected spoofed packets.
undo ipv6 sava packet-drop enable
Dropping of SAVA-detected spoofed packets is enabled.
By default, when a SAVA-enabled interface receives an IPv6 packet and no matching SAVA entry containing the packet's source IPv6 address exists on the device, the packet is dropped. The device creates SAVA entries based on corresponding routing entries. If the device has a large number of routing entries, it might take a long time for the device to complete SAVA entry creation. Before SAVA entry creation completes, valid IPv6 packets might be dropped. To resolve this issue, use the undo ipv6 sava packet-drop enable command to disable dropping of SAVA-detected spoofed packets. In this way, before enabling dropping of SAVA-detected spoofed packets, you can analyze and adjust network configurations according to the output spoofed packet logs.
# Disable dropping of SAVA-detected spoofed packets.
[Sysname] undo ipv6 sava packet-drop enable
Use reset ipv6 sava packet-drop statistics to clear SAVA packet drop statistics.
reset ipv6 sava packet-drop statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears SAVA packet drop statistics for all interfaces.
# Clear SAVA packet drop statistics.
<Sysname> reset ipv6 sava packet-drop statistics
