12-Security Command Reference
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command Reference-R8530Pxx-6W10112-Security Command Reference
01-DAE proxy commands
01-DAE proxy commands 84.53 KB
DAE proxy commands
client
Use client to configure a DAE client.
Use undo client to remove a DAE client.
client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
undo client { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
No DAE clients are configured.
DAE proxy view
ip ipv4-address: Specifies the IPv4 address of a DAE client. It cannot be an all 0s address, all 1s address, type D address, type E address, or loopback address.
ipv6 ipv6-address: Specifies the IPv6 address of a DAE client. It must be a unicast address and cannot be a loopback address or local link address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the DAE client belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the DAE client belongs to the public network, do not specify this option.
key: Specifies the shared key for authenticating the DAE client. It must be the same as the shared key configured on the DAE client.
simple: Specifies a key in plaintext form. For security purposes, the key in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 64 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
The DAE proxy forwards DAE requests from only DAE clients that are configured by using this command.
Upon receiving a DAE request, the DAE proxy searches the configured client information for a shared key by the source IP address and VPN instance in the request. If a shared key is found, the DAE proxy uses the shared key to verify the Authenticator field of the request. If no shared key is found or the Authenticator field verification fails, the DAE proxy discards the request.
To configure multiple DAE clients, execute this command multiple times.
# Configure a DAE client in VPN instance vpn1 that uses IP address 192.168.0.1 and plaintext shared key 123456.
[Sysname] radius dynamic-author proxy
[Sysname-radius-da-proxy] client ip 192.168.0.1 vpn-instance vpn1 key simple 123456
display radius dynamic-author proxy
Use display radius dynamic-author proxy to display DAE proxy settings and statistics.
# Display DAE proxy settings and statistics.
<Sysname> display radius dynamic-author proxy
Status: Enabled
Listening port: 2000
RADIUS DAE clients:
  IP address                                     VPN instance
  192.168.0.244                                  VPN1
  192:168::0:244                                 N/A
RADIUS DAE servers:
  192.168.1.10                                   VPN1
  192:168::1:10                                  N/A
RADIUS DAE packet statistics (DAE proxy<--->DAE client):
  Invalid packets: 0
  PacketName   DM_REQ      DM_ACK     DM_NAK     COA_REQ    COA_ACK    COA_NAK
  Received     5           0          0          6          0          0
  Duplicated   1           0          0          0          0          0
  CheckError   0           0          0          0          0          0
  NASNotFound  0           0          0          0          0          0
  Sent         0           3          2          0          6          0
  FailedToSend 0           0          0          0          0          0
RADIUS DAE packet statistics (DAE proxy<--->DAE server):
  Invalid packets: 0
  Sent         10          0          0          12         0          0
  Received     0           8          2          0          12         0
  NoContext    0           0          0          0          0          0
Status
Whether DAE proxy is enabled or disabled.
Listening port
Port used to listen for DAE requests from DAE clients.
RADIUS DAE clients
IP addresses of DAE clients and VPN instances to which DAE clients belong.
RADIUS DAE servers
IP addresses of DAE servers and VPN instances to which DAE servers belong.
IP address
IP addresses of DAE clients or servers.
VPN instance
VPN instances to which DAE clients or servers belong.
PacketName
Type of the DAE packet:
·     DM_REQ—DM request packet.
·     COA_REQ—CoA request packet.
·     DM_ACK—DM acknowledgment packet.
·     DM_NAK—DM negative acknowledgment packet.
·     COA_ACK—CoA acknowledgment packet.
·     COA_NAK—CoA negative acknowledgment packet.
RADIUS DAE packet statistics (DAE proxy <---> DAE client)
Statistics of DAE packets between the DAE proxy and DAE clients.
RADIUS DAE packet statistics (DAE proxy <---> DAE server)
Statistics of DAE packets between the DAE proxy and DAE servers.
Invalid packets
The number of invalid packets received, the packet length or type of which are incorrect.
Received
The number of received valid DAE packets. Retransmitted packets are counted as one packet.
Duplicated
The number of duplicate DAE packets received from DAE clients. This field is available only for COA_REQ and DM_REQ packets.
CheckError
The number of packets received, in which the Authenticator field verification fails. This field is available only for COA_REQ and DM_REQ packets.
NASNotFound
The number of DAE packets for which the DAE server (acting as the NAS) cannot be found.
Sent
The number of DAE packets that were sent to the DAE clients or servers.
FailedToSend
The number of DAE packets that failed to be sent to the DAE server.
Duplicated
The number of duplicate DAE packets received. This field is available only for COA_REQ and DM_REQ packets.
NoContext
The number of packets received from the DAE servers, the context of which cannot be found.
client
listen-port
server
listen-port
Use listen-port to specify the UDP port used to listen for DAE requests from DAE clients.
Use undo listen-port to restore the default.
listen-port port-number
undo listen-port
The listening port for DAE requests is 3799.
DAE proxy view
port-number: Specifies a UDP port number in the range of 1 to 65535.
The port configured by using this command must be the same as the destination port of DAE requests sent by DAE clients.
To prevent loss of DAE requests, disable DAE proxy before you change the listening port.
The device can act as both the DAE proxy and a DAE server at the same time, and both roles use UDP port 3799 as the default listening port. To use the device as the DAE proxy and a DAE server at the same time, specify different listening ports for the two features.
# Set the listening port for DAE requests to 3798.
[Sysname-radius-da-proxy] listen-port 3798
Use radius dynamic-author proxy to enable DAE proxy and enter DAE proxy view.
Use undo radius dynamic-author proxy to disable DAE proxy.
radius dynamic-author proxy [ listen-port port-number ]
DAE proxy is disabled.
listen-port port-number: Specifies the UDP port used to listen for DAE requests from DAE clients. The value range is 1 to 65535, and the default is 3799.
The DAE proxy feature enables the device to act as the DAE proxy to forward DAE requests and responses between a DAE client and a DAE server.
Disabling DAE proxy also performs the following operations:
·     Deletes DAE proxy view and all DAE proxy settings.
·     Disables the configured and ephemeral UDP ports used to listen for DAE packets.
You can specify the DAE proxy listening port number by using this command in system view or using the listen-port port-number command in DAE proxy view. The configurations have the same priority, and the most recent configuration takes effect.
# Enable DAE proxy and enter DAE proxy view.
listen-port
reset radius dynamic-author proxy statistics
Use reset radius dynamic-author proxy statistics to clear DAE proxy statistics.
# Clear DAE proxy statistics.
<Sysname> reset radius dynamic-author proxy statistics
server
Use server to configure a DAE server.
Ues undo server to remove a DAE server.
server { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo server { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
No DAE servers are configured.
DAE proxy view
ip ipv4-address: Specifies the IPv4 address of a DAE server. It cannot be an all 0s address, all 1s address, class D address, class E address, or loopback address.
ipv6 ipv6-address: Specifies the IPv6 address of a DAE server. It must be a unicast address and cannot be a loopback address or local link address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the DAE server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the DAE server belongs to the public network, do not specify this option.
The DAE proxy forwards DAE requests to and receives DAE responses from only DAE servers that are configured by using this command.
To configure multiple DAE servers, execute this command multiple times.
# Configure a DAE server that uses IPv4 address 10.1.1.1.
[Sysname-radius-da-proxy] server ip 10.1.1.1
server port
Use server port to configure the DAE server listening port.
Use undo server port to restore the default.
server port dest-port
undo server port
The DAE server listening port is 3799.
DAE proxy view
dest-port: Specifies a port number in the range of 1 to 65535.
The DAE proxy uses the configured port as the destination port in a DAE request that is forwarded to DAE servers.
The port configured by using this command must be the same as the listening port configured on DAE servers by using the port command in RADIUS DAS view.
To prevent loss of DAE responses, disable DAE proxy before you modify this port setting.
# Set the DAE server listening port to 30000.
[Sysname-radius-da-proxy] server port 30000
port (BRAS Services Command Reference)
