06-Comware 7 CLI-based configuration examples (AP standalone deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10206-Comware 7 CLI-based configuration examples (AP standalone deployment)
03-NAT Configuration Examples
03-NAT Configuration Examples 80.84 KB
H3C Access Points
Comware 7 NAT Configuration Examples
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring NAT.
This document applies to Comware 7-based APs. Procedures and information in the examples might be slightly different depending on the software or hardware version of the APs.
This document assumes that you have basic knowledge of NAT.
Example: Configuring NAT
As shown in Figure 1, the wireless clients access the network through the AP. The AP obtains an IP address through a DHCP server in the IP network.
To allow the internal wireless clients to access the external network, it is required to perform the following configuration:
·     Configure the AP to act as the DHCP server to assign IP addresses to the wireless clients.
·     Configure outbound NAT on the AP to perform address translation for wireless clients.
Figure 1 Network diagram
Procedures
Configuring AP
1.     Configure VLANs and VLAN interfaces on the AP:
# Create VLAN 100 and VLAN interface, and assign an IP address to the VLAN interface.
<AP> system-view
[AP] vlan 100
[AP-vlan100] quit
[AP] interface vlan-interface 100
[AP-Vlan-interface100] ip address 192.1.0.1 24
[AP-Vlan-interface100] quit
# Configure the upstream interface VLAN-interface 1 to obtain an IP address through DHCP.
[AP-Vlan-interface1] ip address dhcp-alloc
[AP-Vlan-interface1] quit
2.     Configure the wireless service template:
# Create service template service and enter its view.
[AP] wlan service-template service
# Configure service as the SSID.
[AP-wlan-st-service] ssid service
# Assign clients coming online through service template 100 to VLAN 100.
[AP-wlan-st-service] vlan 100
# Configure the PSK AKM mode and the 12345678 plaintext key.
[AP-wlan-st-service] akm mode psk
[AP-wlan-st-service] preshared-key pass-phrase simple 12345678
# Configure CCMP as the cipher suite and RSN as the security IE.
[AP-wlan-st-service] cipher-suite ccmp
[AP-wlan-st-service] security-ie rsn
# Enable the service template.
[AP-wlan-st-service] service-template enable
[AP-wlan-st-service] quit
# Enter interface view of WLAN-Radio 1/0/1.
[AP] interface wlan-radio 1/0/1
# Bind service template service to interface WLAN-Radio 1/0/1.
[AP-WLAN-Radio1/0/1] service-template service
[AP-WLAN-Radio1/0/1] quit
3.     Configure the DHCP server:
# Configure DHCP address pool 100 for address allocation to the wireless clients.
[AP] dhcp server ip-pool 100
[AP-dhcp-pool-100] network 192.1.0.0 mask 255.255.255.0
[AP-dhcp-pool-100] gateway-list 192.1.0.1
[AP-dhcp-pool-100] quit
# Enable the DHCP service.
[AP] dhcp enable
4.     Configure NAT:
# Configure ACL 2000 to identify packets source from 192.1.0.0.
[AP] acl basic 2000
[AP-acl-ipv4-basic-2000] rule 0 permit source 192.1.0.0 0.0.0.255
[AP-acl-ipv4-basic-2000] quit
# Configure an outbound dynamic PAT rule on VLAN-interface 1 to translate the source IP addresses permitted by ACL 2000
[AP-Vlan-interface1] nat outbound 2000
# Display client information on the AP.
[AP] display wlan client
Total number of clients: 1
MAC address    User name                                  R IP address      VLAN
bc6c-2213-7cb7 N/A                                        1 192.1.0.2       100
# Verify that VLAN-interface 1 has obtained an IP address through DHCP.
[AP] display dhcp client interface vlan-interface 1
Vlan-interface1 DHCP client information:
  Current state: BOUND
  Allocated IP: 2.2.2.2 255.255.255.0
  Allocated lease: 86400 seconds, T1: 36532 seconds, T2: 75600 seconds
  DHCP server: 2.2.2.1
# Ping the DHCP server at 2.2.2.1 from a client. On the AP, display NAT session information.
[AP] display nat session verbose
Initiator:
  Source      IP/port: 192.1.0.2/768
  Destination IP/port: 2.2.2.1/2048
  DS-Lite tunnel peer: -
  Protocol: ICMP(1)
  Inbound interface: Vlan-interface100
Responder:
  Source      IP/port: 2.2.2.1/1
  Destination IP/port: 2.2.2.2/0
  Protocol: ICMP(1)
State: ICMP_REPLY
Application: ICMP
Rule ID: -/-/-
Rule name:
Start time: 2016-01-01 05:27:35  TTL: 7s
Initiator->Responder:            0 packets          0 bytes
Responder->Initiator:            0 packets          0 bytes
Total sessions found: 1
Configuration files
 dhcp enable
vlan 1
vlan 100
 ssid service
 vlan 100
 akm mode psk
 preshared-key pass-phrase cipher $c$3$7hZ2DNiI+h/ajPE7DhZbD6Y7py9vqf4721sp
 cipher-suite ccmp
 security-ie rsn
interface Vlan-interface1
 nat outbound 2000
interface Vlan-interface100
 ip address 192.1.0.1 255.255.255.0
interface WLAN-Radio1/0/1
acl basic 2000
return
Related documentation
·     Network Connectivity Command Reference in H3C Access Points Command References
·     Network Connectivity Configuration Guide in H3C Access Points Configuration Guides
·     WLAN Access Command Reference in H3C Access Points Command References
·     WLAN Access Configuration Guide in H3C Access Points Configuration Guides
