06-Comware 7 CLI-based configuration examples (AP standalone deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10206-Comware 7 CLI-based configuration examples (AP standalone deployment)
01-WPA2-PSK Encryption Configuration Examples
01-WPA2-PSK Encryption Configuration Examples 81.78 KB
H3C Access Points
Comware 7 WPA2-PSK Encryption
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example for configuring WPA2-PSK encryption.
This document applies to Comware 7-based access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access points.
This document assumes that you have basic knowledge of WLAN access and WLAN security.
Example: Configuring WPA2-PSK encryption
As shown in Figure 1, the clients access the WLAN provided by the AP. The AP obtains IP addresses from a DHCP server in the IP network.
·     Configure the AP to act as a DHCP server to assign IP addresses to the clients.
·     Configure WPA2-PSK encryption on the AP.
·     Configure open-system authentication and bypass authentication.
·     Set the AKM mode to PSK to protect client data transmission.
·     Set the CCMP cipher suite for frame encryption, and enable the RSN IE in beacon and probe responses.
Figure 1 Network diagram
Procedures
1.     Configure AP interfaces:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AP will use this IP address to communicate with clients.
<AP> system-view
[AP] vlan 100
[AP -vlan100] quit
[AP] interface vlan-interface 100
[AP-Vlan-interface100] ip address 192.1.1.1 24
[AP-Vlan-interface100] quit
# Configure uplink interface VLAN-interface 1 to obtain IP addresses through DHCP.
[AP-Vlan-interface1] undo ip address
[AP-Vlan-interface1] ip address dhcp-alloc
[AP-Vlan-interface1] quit
2.     Configure wireless services:
# Create service template service and enter its view.
[AP] wlan service-template service
# Configure the SSID as service.
[AP-wlan-st-service] ssid service
# Specify VLAN 100 for clients to access the WLAN defined by the service template.
[AP-wlan-st-service] vlan 100
# Set the AKM mode to PSK and configure simple character string 12345678 as the PSK.
[AP-wlan-st-service] akm mode psk
[AP-wlan-st-service] preshared-key pass-phrase simple 12345678
# Set the CCMP cipher suite for frame encryption, and enable the RSN IE in beacon and probe responses.
[AP-wlan-st-service] cipher-suite ccmp
[AP-wlan-st-service] security-ie rsn
# Enable the service template.
[AP-wlan-st-service] service-template enable
[AP-wlan-st-service] quit
3.     Bind the service template to interface WLAN-Radio 1/0/1.
[AP] interface wlan-radio 1/0/1
[AP-WLAN-Radio1/0/1] service-template service
[AP-WLAN-Radio1/0/1] quit
4.     Configure the DHCP service:
# Enable DHCP.
[AP] dhcp enable
# Create a DHCP address pool named vlan100, specify subnet 192.1.1.0/24, and specify gateway address 192.1.1.1.
[AP] dhcp server ip-pool vlan100
[AP-dhcp-pool-vlan100] network 192.1.1.0 mask 255.255.255.0
[AP-dhcp-pool-vlan100] gateway-list 192.1.1.1
[AP-dhcp-pool-vlan100] quit
# Verify that the clients can access the WLAN through PSK authentication.
[AP] display wlan client verbose
Total number of clients: 1
 MAC address                       : 502b-73dc-603a
 IPv4 address                      : 192.1.1.2
 IPv6 address                      : N/A
 Username                          : N/A
 AID                               : 1
 Radio ID                          : 1
 Channel                           : 36
 SSID                              : service
 BSSID                             : 743a-2013-6ba4
 VLAN ID                           : 100
 Service VLAN ID                   : N/A
 Sleep count                       : 3
 Wireless mode                     : 802.11ac
 Channel bandwidth                 : 80MHz
 SM power save                     : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Supported
 Short GI for 80MHz                : Supported
 Short GI for 160/80+80MHz         : Not supported
 STBC RX capability                : Not supported
 STBC TX capability                : Not supported
 LDPC RX capability                : Not supported
 Beamformee STS capability         : N/A
 Number of Sounding Dimensions     : N/A
 SU beamformee capability          : Not supported
 MU beamformee capability          : Not supported
 Block Ack                         : TID 0  Both
                                     TID 6  Out
 Supported VHT-MCS set             : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
 Supported HT MCS set              : 0, 1, 2, 3, 4, 5, 6, 7
 Supported rates                   : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
 QoS mode                          : WMM
 Listen interval                   : 1
 RSSI                              : 8
 Rx/Tx rate                        : 6.5/21.7 Mbps
 Speed                             : 0.544/0.216Kbps
 Authentication method             : Open system
 Security mode                     : RSN
 AKM mode                          : PSK
 Cipher suite                      : CCMP
 User authentication mode          : Bypass
 WPA3 status                       : Disabled
 Authorization CAR                 : N/A
 Authorization user group name     : N/A
 Authorization ACL ID              : N/A
 Authorization user profile        : N/A
 Roam status                       : N/A
 Key derivation                    : SHA1
 PMF status                        : N/A
 Forwarding policy name            : Not configured
 Online time                       : 0days 0hours 4minutes 26seconds
 FT status                         : Inactive
 BTM mode                          : Inactive
Configuration files
 dhcp enable
vlan 1
vlan 100
 ssid service
 vlan 100
 akm mode psk
 preshared-key pass-phrase cipher $c$3$7hZ2DNiI+h/ajPE7DhZbD6Y7py9vqf4721sp
 cipher-suite ccmp
 security-ie rsn
interface NULL0
interface Vlan-interface1
interface Vlan-interface100
 ip address 192.1.1.1 255.255.255.0
interface WLAN-Radio1/0/1
return
Related documentation
·     WLAN Access Command Reference in H3C Access Points Command References
·     WLAN Access Configuration Guide in H3C Access Points Configuration Guides
·     WLAN Security Command Reference in H3C Access Points Command References
·     WLAN Security Configuration Guide in H3C Access Points Configuration Guides
