- 11-Network Management and Monitoring Configuration Examples
- 01-EAA Configuration Examples
- 02-NetStream Configuration Examples
- 03-NQA Configuration Examples
- 04-NTP Configuration Examples
- 05-PTP Configuration Examples
- 06-sFlow Configuration Examples
- 07-SNMP Configuration Examples
- 08-VCF Fabric Configuration Examples
- 09-Mirroring Configuration Examples
05-PTP Configuration Examples | 306.38 KB |
Example: Configuring Layer 2 IEEE 1588v2 PTP
Example: Configuring Layer 3 IEEE 1588v2 PTP in multicast mode
Example: Configuring Layer 3 IEEE 1588v2 PTP in unicast mode
Example: Configuring IEEE 802.1AS PTP
Example: Configuring SMPTE ST 2059-2 PTP in multicast mode
Example: Configuring SMPTE ST 2059-2 PTP in unicast mode
Introduction
This document provides PTP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of PTP.
As shown in Figure 1, a PTP domain contains Device A, Device B, and Device C. Configure Layer 2 IEEE 1588v2 PTP as follows for time synchronization:
· Specify the IEEE 1588v2 PTP profile for the devices.
· Specify the OC clock node type for Device A and Device C, and E2ETC clock node type for Device B. These clock nodes elect a GM through BMC based on their respective default GM attributes.
Hardware |
Software version |
S12500G-AF |
Release 7639P01 and later |
S10500X |
S10500 |
Not supported |
S7500E-X |
Not supported |
S7500E |
Not supported |
S7500X |
Procedures
Configuring Device A
# Specify the IEEE 1588v2 PTP profile.
[DeviceA] ptp profile 1588v2
# Specify the OC clock node type.
[DeviceA] ptp mode oc
# Specify a PTP domain.
[DeviceA] ptp domain 0
# Enable PTP globally.
[DeviceA] ptp global enable
# Specify PTP for obtaining the time on the default MDC.
[DeviceA] clock protocol ptp mdc 1
# Enable PTP on Ten-GigabitEthernet 1/0/1.
[DeviceA] interface ten-gigabitEthernet1/0/1
[DeviceA-Ten-GigabitEthernet1/0/1] ptp enable
Configuring Device B
[DeviceB] ptp profile 1588v2
# Specify the E2ETC clock node type.
[DeviceB] ptp mode e2etc
[DeviceB] ptp domain 0
[DeviceB] ptp global enable
[DeviceB] clock protocol ptp mdc 1
[DeviceB] interface ten-gigabitEthernet1/0/1
[DeviceB-Ten-GigabitEthernet1/0/1] ptp enable
# Enable PTP on Ten-GigabitEthernet 1/0/2.
[DeviceB] interface ten-gigabitEthernet1/0/2
[DeviceB-Ten-GigabitEthernet1/0/2] ptp enable
[DeviceB-Ten-GigabitEthernet1/0/2] quit
Configuring Device C
<DeviceC> system-view
[DeviceC] ptp profile 1588v2
[DeviceC] ptp mode oc
[DeviceC] ptp domain 0
[DeviceC] ptp global enable
[DeviceC] clock protocol ptp mdc 1
[DeviceC] interface ten-gigabitEthernet1/0/1
[DeviceC-Ten-GigabitEthernet1/0/1] ptp enable
[DeviceC-Ten-GigabitEthernet1/0/1] quit
When the network topology is stable, perform the following tasks to verify the PTP configuration:
· Use the display ptp clock command to display PTP clock information.
· Use the display ptp interface brief command to display brief information about PTP interfaces.
# Display PTP clock information on Device A.
[DeviceA] display ptp clock
PTP global state : Enabled
PTP profile : IEEE 1588 Version 2
PTP mode : OC
Slave only : No
Lock status : Locked
Clock ID : 000FE2-FFFE-FF0000
Clock type : Local
Clock domain : 0
Number of PTP ports : 1
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Offset (log variance) : 65535
Offset from master : 0 (ns)
Mean path delay : 0 (ns)
Steps removed : 0
Local clock time : Sun Jan 15 20:57:29 2011
# Display brief information about PTP interfaces on Device A.
[DeviceA] display ptp interface brief
Name InstID State Delay mechanism Clock step Asymmetry correction
XGE1/0/1 0 Master E2E Two 0
# Display PTP clock information on Device B.
[DeviceB] display ptp clock
PTP mode : E2ETC
Slave only : No
Clock ID : 000FE2-FFFE-FF0001
Clock type : Local
Clock domain : 0
Number of PTP ports : 2
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Offset from master : N/A
Mean path delay : N/A
Steps removed : N/A
# Display brief information about PTP interfaces on Device B.
[DeviceB] display ptp interface brief
XGE1/0/1 0 N/A E2E Two 0
XGE1/0/2 1 N/A E2E Two 0
# Display PTP clock information on Device C.
[DeviceC] display ptp clock
PTP mode : OC
Slave only : No
Clock ID : 000FE2-FFFE-FF0002
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : 0
Local clock time : Sun Jan 15 20:57:29 2019
# Display brief information about PTP interfaces on Device C.
[DeviceC] display ptp interface brief
Name State Delay mechanism Clock step Asymmetry correction
XGE1/0/1 Slave E2E Two 0
The command outputs show that Device A is elected as the GM and Ten-GigabitEthernet 1/0/1 on Device A is the master port.
Configuration files
· Device A and Device C:
ptp profile 1588v2
ptp mode oc
ptp domain 0
ptp global enable
interface Ten-gigabitEthernet1/0/1
ptp enable
· Device B:
ptp profile 1588v2
ptp mode e2etc
ptp domain 0
ptp global enable
ptp enable
interface Ten-gigabitEthernet1/0/2
ptp enable
As shown in Figure 2, a PTP domain contains Device A, Device B, and Device C. Configure Layer 3 IEEE 1588v2 PTP in multicast mode as follows for time synchronization:
· Specify the OC clock node type for Device A and Device C, and the P2PTC clock node type for Device B. These clock nodes elect a GM through BMC based on their respective default GM attributes.
· Configure the multicast PTP transport mode and UDP (IPv4) transport protocol for the devices.
· Configure the peer delay measurement mechanism (p2p) for Device A and Device C.
Hardware |
Software version |
S12500G-AF |
S10500X |
S10500 |
Not supported |
S7500E-X |
Not supported |
S7500E |
Not supported |
S7500X |
Procedures
# Configure the source IP address for multicast PTP transport.
[DeviceA] ptp source 10.10.10.1
# On Ten-GigabitEthernet 1/0/1, specify the UDP (IPv4) transport protocol and the peer delay measurement mechanism (p2p) and enable PTP.
[DeviceA-Ten-GigabitEthernet1/0/1] ptp transport-protocol udp
[DeviceA-Ten-GigabitEthernet1/0/1] ptp delay-mechanism p2p
# Specify the P2PTC clock node type.
[DeviceB] ptp mode p2ptc
[DeviceB] ptp source 10.10.10.2
# On Ten-GigabitEthernet 1/0/1, specify the UDP (IPv4) transport protocol and enable PTP.
[DeviceB-Ten-GigabitEthernet1/0/1] ptp transport-protocol udp
# On Ten-GigabitEthernet 1/0/2, specify the UDP transport protocol and enable PTP.
[DeviceB-Ten-GigabitEthernet1/0/2] ptp transport-protocol udp
[DeviceC] ptp source 11.10.10.1
[DeviceC-Ten-GigabitEthernet1/0/1] ptp transport-protocol udp
[DeviceC-Ten-GigabitEthernet1/0/1] ptp delay-mechanism p2p
PTP mode : OC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : 0
XGE1/0/1 0 Master P2P Two 0
PTP mode : P2PTC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : N/A
XGE1/0/1 0 N/A P2P Two 0
XGE1/0/2 1 N/A P2P Two 0
PTP mode : OC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : 0
XGE1/0/1 0 Slave P2P Two 0
Configuration files
· Device A:
ptp profile 1588v2
ptp mode oc
ptp domain 0
ptp global enable
ptp enable
· Device B:
ptp profile 1588v2
ptp mode p2ptc
ptp domain 0
ptp global enable
ptp enable
ptp enable
· Device C:
ptp profile 1588v2
ptp mode oc
ptp domain 0
ptp global enable
ptp enable
As shown in Figure 3, configure PTP (IEEE 1588 version 2, IPv4 UDP transport, and unicast transmission) to enable Device A, Device B, Device C, and the base station to synchronize the time with the ToD clock source.
· Specify the IEEE 1588 version 2 PTP profile and unicast IPv4 UDP transport of PTP messages for Device A, Device B, and Device C.
· Assign Device A, Device B, Device C, and the base station to PTP domain 0. Specify the BC clock node type for Device A, Device B, and Device C.
· Connect Device A to the ToD clock source and Device C to the base station.
· Use the default Request_Response delay measurement mechanism on all clock nodes in the PTP domain.
Hardware |
Software version |
S12500G-AF |
S10500X |
S10500 |
Not supported |
S7500E-X |
Not supported |
S7500E |
Not supported |
S7500X |
As shown in Figure 3, assign IP addresses to the interfaces and make sure the devices can reach each other. (Details not shown.)
Procedures
# Specify the BC clock node type.
[DeviceA] ptp mode bc
# Configure the device to receive ToD clock signals and set the delay time correction to 1000 nanoseconds.
[DeviceA] ptp tod0 input delay 1000
# Set priority 1 to 0 for the ToD clock.
[DeviceA] ptp priority clock-source tod0 priority1 0
# On Ten-GigabitEthernet 1/0/1, specify the UDP (IPv4) transport protocol and a unicast destination IP address for PTP messages and enable PTP.
[DeviceA-Ten-GigabitEthernet1/0/1] ptp unicast-destination 10.10.10.2
[DeviceB] ptp mode bc
[DeviceB-Ten-GigabitEthernet1/0/1] ptp unicast-destination 10.10.10.1
# On Ten-GigabitEthernet 1/0/2, specify the UDP (IPv4) transport protocol and a unicast destination IP address for PTP messages and enable PTP.
[DeviceB-Ten-GigabitEthernet1/0/2] ptp unicast-destination 11.10.10.1
[DeviceC] ptp mode bc
[DeviceC-Ten-GigabitEthernet1/0/1] ptp unicast-destination 11.10.10.2
# On GigabitEthernet 1/0/2, specify the UDP (IPv4) transport protocol and a unicast destination IP address for PTP messages and enable PTP.
[DeviceC] interface ten-gigabitEthernet1/0/2
[DeviceC-Ten-GigabitEthernet1/0/2] ptp transport-protocol udp
[DeviceC-Ten-GigabitEthernet1/0/2] ptp unicast-destination 12.10.10.1
[DeviceC-Ten-GigabitEthernet1/0/2] ptp enable
[DeviceC-Ten-GigabitEthernet1/0/2] quit
Configuring the base station
# Specify PTP domain 0.
# Specify IPv4 UDP transport of PTP messages.
# Set the destination IP address of unicast PTP messages to 12.10.10.2.
# Specify the Request_Response delay measurement mechanism.
For more information, see the configuration guide for the base station.
PTP mode : BC
Slave only : No
Clock type : ToD0
ToD direction : In
ToD delay time : 1000 (ns)
Clock domain : 0
Priority1 : 0
Priority2 : 128
Clock quality :
Class : 6
Accuracy : 32
Steps removed : 0
PTP mode : BC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : N/A
PTP mode : BC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : 0
XGE1/0/1 0 Slave E2E Two 0
XGE1/0/2 1 Master E2E Two 0
Configuration files
· Device A:
ptp profile 1588v2
ptp mode bc
ptp domain 0
ptp global enable
ptp enable
· Device B:
ptp profile 1588v2
ptp mode bc
ptp domain 0
ptp global enable
ptp enable
ptp enable
· Device C:
ptp profile 1588v2
ptp mode bc
ptp domain 0
ptp global enable
ptp enable
# interface Ten-GigabitEthernet1/0/1
ptp enable
As shown in Figure 4, a PTP domain contains Device A, Device B, and Device C. Configure IEEE 802.1AS PTP as follows for time synchronization:
· Specify the IEEE 802.1AS PTP profile for the devices.
Hardware |
Software version |
S12500G-AF |
S10500X |
S10500 |
Not supported |
S7500E-X |
Not supported |
S7500E |
Not supported |
S7500X |
Procedures
# Specify the IEEE 802.1AS PTP profile.
[DeviceA] ptp profile 802.1AS
[DeviceA] interface ten-gigabitEthernet 1/0/1
[DeviceB] ptp profile 802.1AS
# Specify the IEEE 1588 802.1AS PTP profile.
[DeviceC] ptp profile 802.1AS
PTP profile : IEEE 802.1AS
PTP mode : OC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 246
Priority2 : 248
Clock quality :
Class : 248
Accuracy : 254
Offset (log variance) : 16640
Steps removed : 0
PTP mode : P2PTC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 246
Priority2 : 248
Clock quality :
Class : 248
Accuracy : 254
Steps removed : N/A
PTP mode : OC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : 0
Configuration files
ptp profile 8021as
ptp mode oc
ptp domain 0
ptp global enable
ptp enable
· Device B:
ptp profile 8021as
ptp mode p2ptc
ptp domain 0
ptp global enable
ptp enable
ptp enable
As shown in Figure 5, Device A, Device B, and Device C are in a PTP domain. Configure SMPTE ST 2059-2 PTP in multicast mode as follows for time synchronization:
· Specify the SMPTE ST 2059-2 PTP profile for the devices.
· Configure the multicast PTP transport mode for the devices.
· Specify the OC clock node type for Device A and Device C, and the P2PTC clock node type for Device B. All clock nodes elect a GM through BMC based on their respective default GM attributes.
Hardware |
Software version |
S12500G-AF |
S10500X |
S10500 |
Not supported |
S7500E-X |
Not supported |
S7500E |
Not supported |
S7500X |
Procedures
# Specify the SMPTE ST 2059-2 PTP profile.
[DeviceA] ptp profile st2059-2
# On Ten-GigabitEthernet 1/0/1, specify the peer delay measurement mechanism (p2p) and enable PTP.
[DeviceB] ptp profile st2059-2
[DeviceC] ptp profile st2059-2
[DeviceC] interface ten-gigabitEthernet 1/0/1
PTP profile : SMPTE ST 2059-2
PTP mode : OC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : 0
PTP mode : P2PTC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : N/A
PTP mode : OC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : 0
The output shows that Device A is elected as the GM and Ten-GigabitEthernet 1/0/1 on Device A is the master port.
Configuration files
· Device A:
ptp mode oc
ptp domain 0
ptp global enable
ptp enable
· Device B:
ptp mode p2ptc
ptp domain 0
ptp global enable
ptp enable
ptp enable
· Device C:
ptp mode oc
ptp domain 0
ptp global enable
ptp enable
As shown in Figure 6, configure PTP (SMPTE ST 2059-2, IPv4 UDP transport, unicast transmission) to enable Device A, Device B, Device C, and the base station to synchronize time with the ToD clock source .
· Specify the SMPTE ST 2059-2 PTP profile and unicast IPv4 UDP transport of PTP messages for Device A, Device B, and Device C.
Hardware |
Software version |
S12500G-AF |
S10500X |
S10500 |
Not supported |
S7500E-X |
Not supported |
S7500E |
Not supported |
S7500X |
As shown in Figure 6, assign IP addresses to the interfaces, and make sure the devices can reach each other. (Details not shown.)
Procedures
IMPORTANT: The SMPTE ST 2059-2 PTP profile supports IPv4 UDP transport rather than IEEE 802.3/Ethernet transport of PTP messages. It supports both multicast and unicast transmission of PTP messages. |
# Configure the device to receive ToD clock signals and set the delay correction value to 1000 nanoseconds.
# On Ten-GigabitEthernet 1/0/1, specify a unicast destination IP address for PTP messages and enable PTP.
# On Ten-GigabitEthernet 1/0/2, specify a unicast destination IP address for PTP messages and enable PTP.
# On Ten-GigabitEthernet 1/0/2, configure the destination IP address for unicast PTP messages and enable PTP. (The SMPTE ST 2059-2 PTP profile transports PTP messages over IPv4 UDP by default.)
[DeviceC] interface ten-gigabitEthernet 1/0/2
Configure the base station.
PTP mode : BC
Slave only : No
Clock type : ToD0
ToD direction : In
Clock domain : 0
Priority1 : 0
Priority2 : 128
Clock quality :
Class : 6
Accuracy : 32
Steps removed : 0
# Display brief Information about PTP interfaces on Device A.
PTP mode : BC
Slave only : No
Clock type : ToD0
ToD direction : In
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : N/A
# Display brief Information about PTP interfaces on Device B.
PTP mode : OC
Slave only : No
Clock type : Local
Clock domain : 0
Priority1 : 128
Priority2 : 128
Clock quality :
Class : 248
Accuracy : 254
Steps removed : 0
Configuration files
· Device A:
ptp mode bc
ptp domain 0
ptp global enable
ptp enable
· Device B:
ptp mode bc
ptp domain 0
ptp global enable
ptp enable
ptp enable
· Device C
ptp mode bc
ptp domain 0
ptp global enable
ptp enable
ptp enable
