H3C Fixed Port Campus Switches Configuration Examples-6W104
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W104
Table of Contents
Related Documents
77-ARP Attack Protection Configuration Examples
Introduction
This document provides configuration examples of ARP attack protection.
ARP is easy to use but it does not have any security mechanisms. Attackers can easily attack the network by sending forged ARP packets. The device provides various ARP attack protection measures to prevent, detect, and resolve ARP attacks and ARP viruses on LANs.
This document assumes that you have basic knowledge of ARP attack protection.
Example: Configuring ARP attack protection
As shown in Figure 1, the device connects to the server through GE1/0/3 as a gateway and connects to Host A and Host B in VLAN 10, and Host C and Host D in VLAN 20 through GE1/0/1 and GE1/0/2, respectively.
Configure ARP attack protection on the device to prevent the following ARP threats:
·     Host A sends forged ARP packets and forged gratuitous ARP packets to the device to edit the ARP entries on the device maliciously. As a result, other users cannot receive data packets normally.
·     Host C sends a large number of unresolvable IP packets to attack the device, causing the following results:
¡     The device CPU is busy, affecting normal service processing.
¡     The device sends a large number of ARP requests, overloading the target subnets.
·     Host D launches ARP flood attacks by sending a large number of ARP packets with different source IP addresses but fixed MAC address. Such attacks run out the ARP table resources on the device and cause a busy CPU, affecting normal service processing.
Besides, Host B might send a large number of ARP packets to the device. This is normal ARP behavior required by services. Do not filter out packets sent from Host B when you configure ARP attack protection.
Figure 1 Network diagram
Analysis
To meet the network requirements, configure the device as follows:
·     To prevent forged ARP packets sent by Host A from updating the ARP entries on the device, configure ARP blackhole routing and ARP active acknowledgement in strict mode.
·     To prevent the forged gratuitous ARP packets sent by Host A from updating the ARP entries on the device, disable gratuitous ARP packet learning.
·     To avoid unresolvable packets sent by Host C, enable ARP source suppression and set the maximum number of unresolvable packets that the device can process per source IP address within 5 seconds.
·     To avoid ARP flood attacks caused by ARP packets with the same IP address, enable ARP packet rate limit and set the limit rate. When Host C launches ARP flood attacks on the device by sending a large number of ARP packets with the same source IP address, the device discards the packets that exceed the limit rate to avoid a busy CPU.
·     To avoid ARP flood attacks caused by ARP packets with different IP addresses but fixed MAC address sent by Host D, configure source MAC-based ARP attack detection. If you fail to configure this feature, the ARP table resources run out and the CPU is busy. To avoid filtering out packets sent by Host B, exclude the MAC address of Host B from this detection.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6525XE-HI switch series
S5850 switch series
Release 8005 and later
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Release 63xx
S5500V3-SI switch series (excluding the S5500V3-24P-SI and S5500V3-48P-SI switches)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Release 11xx
S5120V3-SI switch series (excluding the S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI switches)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
When you configure ARP attack protection, follow these restrictions and guidelines:
·     When you configure ARP active acknowledgement in strict mode, make sure ARP blackhole routing is enabled.
·     After you disable gratuitous ARP packet learning, the device does not create ARP entries when receiving gratuitous ARP packets, but updates the existing corresponding ARP entries. If you do not want the device to create ARP entries for gratuitous ARP packets, disable gratuitous ARP packet learning to save ARP entry resources.
Procedures
Configuring VLANs and interface IP addresses
# (Optional.) Configure the operating mode of GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 as Layer 2.
[Device-GigabitEthernet1/0/1] port link-mode bridge
[Device-GigabitEthernet1/0/2] port link-mode bridge
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] port link-mode bridge
[Device-GigabitEthernet1/0/3] quit
# Create VLAN 10, and assign GigabitEthernet 1/0/1 to the VLAN.
[Device] vlan 10
[Device-vlan10] port gigabitethernet 1/0/1
[Device-vlan10] quit
# Create VLAN-interface 10, and assign IP address 10.1.1.1/24 to it.
[Device] interface vlan-interface 10
[Device-Vlan-interface10] ip address 10.1.1.1 255.255.255.0
[Device-Vlan-interface10] quit
# Create VLAN 20, and assign GigabitEthernet 1/0/2 to the VLAN.
[Device] vlan 20
[Device-vlan20] port gigabitethernet 1/0/2
[Device-vlan20] quit
# Create VLAN-interface 20, and assign IP address 10.1.2.1/24 to it.
[Device] interface vlan-interface 20
[Device-Vlan-interface20] ip address 10.1.2.1 255.255.255.0
[Device-Vlan-interface20] quit
# Create VLAN 30, and assign GigabitEthernet 1/0/3 to the VLAN.
[Device] vlan 30
[Device-vlan30] port gigabitethernet 1/0/3
[Device-vlan30] quit
# Create VLAN-interface 30, and assign IP address 10.1.3.1/24 to it.
[Device] interface vlan-interface 30
[Device-Vlan-interface30] ip address 10.1.3.1 255.255.255.0
Enabling ARP blackhole routing
[Device] arp resolving-route enable
Enabling ARP active acknowledgment in strict mode
[Device] arp active-ack strict enable
Disabling gratuitous ARP packet learning
[Device] undo gratuitous-arp-learning enable
Enabling ARP packet rate limit and setting the limit rate
[Device-GigabitEthernet1/0/1] arp rate-limit 50
[Device-GigabitEthernet1/0/2] arp rate-limit 50
Configuring ARP source suppression
[Device] arp source-suppression enable
[Device] arp source-suppression limit 40
Configuring source MAC-based ARP attack detection
The following switch series in R661x version do not support this feature:
·     S6520X-HI switch series.
·     S6520X-EI switch series.
·     S6520X-SI switch series.
·     S6520-SI switch series.
·     S5000-EI switch series.
·     MS4600 switch series.
·     S5560X-EI switch series.
·     S5560X-HI switch series.
·     S5500V2-EI switch series.
·     MS4520V2 switch series.
·     ES5500 switch series.
# Enable source MAC-based ARP attack detection, and specify the handling method as filter.
[Device] arp source-mac filter
# Set the threshold to 30.
[Device] arp source-mac threshold 30
# Set the lifetime for ARP attack entries to 60 seconds.
[Device] arp source-mac aging-time 60
# Exclude MAC address 0c68-d691-0606 from this detection.
[Device] arp source-mac exclude-mac 0c68-d691-0606
# Display the current configuration information about ARP source suppression. ARP source suppression is enabled and the maximum number of unresolvable packets that can be processed per source IP address within 5 seconds is 40.
<Device> display arp source-suppression
 Current suppression limit: 40
# Display the ARP attack entries for Host D when Host D sends more than 30 ARP requests to the device within 5 seconds. The command output shows that an ARP attack entry has been generated for Host D. With this ARP attack entry, the device cannot create ARP entries for Host D.
<Device> display arp source-mac slot 1
Source-MAC     VLAN ID Interface                Aging time (sec) Packets dropped
0c68-be82-0206 20      GE1/0/2                  10               244
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address      MAC address    VLAN/VSI name Interface                Aging Type
# Display the ARP attack entries when Host B sends more than 30 ARP requests to the device within 5 seconds. No ARP attack entries for Host B exist, so the device can create ARP entries for Host B.
10.1.1.3        0c68-d691-0606 10            GE1/0/1                  1197  D
# Stop sending ARP packets from Host D to the device and wait the lifetime of the ARP attack entry for Host D expires. Then, configure Host D to send ARP packets to the device. Use the following command to display ARP entries on the device. The output shows that the device has created ARP entries for Host D.
10.1.1.3        0c68-d691-0606 10            GE1/0/1                  944   D
10.1.2.3        0c68-be82-0206 20            GE1/0/2                  1195  D
Configuration files
IMPORTANT
IMPORTANT:
Support for the port link-mode bridge command depends on the device model.
vlan 1
vlan 10
vlan 20
vlan 30
interface Vlan-interface10
interface Vlan-interface20
interface Vlan-interface30
 port access vlan 10
 arp rate-limit 50
 port access vlan 20
 arp rate-limit 50
 port access vlan 30
