H3C Fixed Port Campus Switches Configuration Examples-6W104
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W104
Table of Contents
Related Documents
29-GTS and Rate Limiting Configuration Examples
29-GTS and Rate Limiting Configuration Examples 138.76 KB
Introduction
This document provides GTS and rate limiting configuration examples.
This document assumes that you have basic knowledge of GTS and rate limiting.
Example: Configuring GTS and rate limiting
As shown in Figure 1, the 15-Mbps dedicated line transmits the FTP traffic, business-specific application traffic, and IP voice traffic between the headquarters and branch of a company.
The following traffic policing settings have been configured on the edge device (Switch B) of the headquarters:
·     CIR of 10 Mbps for IP voice traffic.
·     CIR of 3 Mbps for business-specific application traffic.
·     CIR of 7 Mbps for FTP traffic.
Configure traffic shaping on the edge device (Switch A) of the branch to buffer excess traffic of each traffic type.
Configure rate limiting on Switch A to limit the outgoing traffic rate to 15 Mbps.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To implement GTS, first determine the queue that transmits a type of traffic. In this example, the priorities of these types of traffic are not provided. You need to use priority marking to manually assign packets to different queues.
·     You can manually assign packets to queues by marking DSCP values, 802.1p priority values, or local precedence values. To keep the contents of packets unchanged, mark local precedence values for packets.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6525XE-HI switch series
S5850 switch series
Release 8005 and later
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
The port link-mode command is not supported on the following switches and the port link-mode bridge command does not appear in their configuration files.
·     S5130S-HI series.
·     S5130S-EI series.
·     S3100V3-EI series.
·     E128C switch.
·     E152C switch.
·     E500C series.
·     E500D series.
·     IE4300-12P-AC switch
·     IE4300-12P-PWR switch.
·     IE4300-M series.
·     IE4320 series.
Procedures
Before configuring GTS and rate limiting, make sure there is network connectivity between the branch and headquarters.
This section does not describe the configurations for enabling network connectivity.
Configuring priority marking
1.     Create three traffic classes to match the three traffic types:
# Configure basic IPv4 ACL 2000 to match IP voice traffic (traffic from subnet 192.168.3.0/24).
[SwitchA] acl basic 2000
[SwitchA-acl-ipv4-basic-2000] rule permit source 192.168.3.0 0.0.0.255
# Create a class named voice, and use ACL 2000 as the match criterion.
[SwitchA] traffic classifier voice
[SwitchA-classifier-voice] if-match acl 2000
[SwitchA-classifier-voice] quit
# Configure basic IPv4 ACL 2001 to match application traffic (traffic from subnet 192.168.2.0/24).
[SwitchA] acl basic 2001
[SwitchA-acl-ipv4-basic-2001] rule permit source 192.168.2.0 0.0.0.255
[SwitchA-acl-ipv4-basic-2001] quit
# Create a class named service, and use ACL 2001 as the match criterion.
[SwitchA] traffic classifier service
[SwitchA-classifier-service] if-match acl 2001
[SwitchA-classifier-service] quit
# Configure advanced IPv4 ACL 3000 to match FTP traffic (traffic from subnet 192.168.1.0/24 and with destination port number 20).
[SwitchA] acl advanced 3000
[SwitchA-acl-ipv4-adv-3000] rule permit tcp destination-port eq 20 source 192.168.1.0 0.0.0.255
[SwitchA-acl-ipv4-adv-3000] quit
# Create a class named ftp, and use ACL 3000 as the match criterion.
[SwitchA] traffic classifier ftp
[SwitchA-classifier-ftp] if-match acl 3000
[SwitchA-classifier-ftp] quit
2.     Create three traffic behaviors:
# Create a behavior named voice, and configure the behavior to mark packets with local precedence 6 (corresponding to queue 6).
[SwitchA] traffic behavior voice
[SwitchA-behavior-voice] remark local-precedence 6
[SwitchA-behavior-voice] quit
# Create a behavior named service, and configure the behavior to mark packets with local precedence 4 (corresponding to queue 4).
[SwitchA] traffic behavior service
[SwitchA-behavior-service] remark local-precedence 4
[SwitchA-behavior-service] quit
# Create a behavior named ftp, and configure the behavior to mark packets with local precedence 2 (corresponding to queue 2).
[SwitchA] traffic behavior ftp
[SwitchA-behavior-ftp] remark local-precedence 2
[SwitchA-behavior-ftp] quit
3.     Configure and apply a QoS policy:
# Create a QoS policy named shaping, and associate the three classes with their respective behaviors in the QoS policy.
[SwitchA] qos policy shaping
[SwitchA-qospolicy-shaping] classifier voice behavior voice
[SwitchA-qospolicy-shaping] classifier service behavior service
[SwitchA-qospolicy-shaping] classifier ftp behavior ftp
[SwitchA-qospolicy-shaping] quit
# Apply the QoS policy shaping to the inbound direction of GigabitEthernet 1/0/2.
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] qos apply policy shaping inbound
[SwitchA-GigabitEthernet1/0/2] quit
Configuring GTS
# Configure GTS on GigabitEthernet 1/0/1 to set the CIR to 10 Mbps for queue 6 (IP voice traffic).
[SwitchA-GigabitEthernet1/0/1] qos gts queue 6 cir 10240
# Configure GTS on GigabitEthernet 1/0/1 to set the CIR to 3 Mbps for queue 4 (application traffic).
[SwitchA-GigabitEthernet1/0/1] qos gts queue 4 cir 3072
# Configure GTS on GigabitEthernet 1/0/1 to set the CIR to 7 Mbps for queue 2 (FTP traffic).
[SwitchA-GigabitEthernet1/0/1] qos gts queue 2 cir 7168
Configuring rate limiting
# Configure rate limiting on GigabitEthernet 1/0/1 to set the CIR to 15 Mbps for outgoing traffic.
[SwitchA-GigabitEthernet1/0/1] qos lr outbound cir 15360
# Verify the priority marking settings of GigabitEthernet 1/0/2.
<Sysname> display qos policy interface inbound
  Direction: Inbound
  Policy: shaping
   Classifier: voice
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: voice
      Marking:
        Remark local-precedence 6
   Classifier: service
     Operator: AND
     Rule(s) :
      If-match acl 2001
     Behavior: service
      Marking:
        Remark local-precedence 4
   Classifier: ftp
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: ftp
      Marking:
        Remark local-precedence 2
# Verify the GTS settings on GigabitEthernet 1/0/1.
 Rule: If-match queue 6
  CIR 10240 (kbps), CBS 640000 (Bytes)
 Rule: If-match queue 4
  CIR 3072 (kbps), CBS 192000 (Bytes)
 Rule: If-match queue 2
  CIR 7168 (kbps), CBS 448000 (Bytes)
# Verify the rate limiting settings on GigabitEthernet 1/0/1.
Direction: Outbound
 CIR 15360 (kbps), CBS 960000 (Bytes)
Configuration files
acl basic 2000
 rule 0 permit source 192.168.3.0 0.0.0.255
acl basic 2001
 rule 0 permit source 192.168.2.0 0.0.0.255
acl advanced 3000
 rule 0 permit tcp source 192.168.1.0 0.0.0.255 destination-port eq ftp-data
traffic classifier ftp operator and
 if-match acl 3000
traffic classifier service operator and
 if-match acl 2001
traffic classifier voice operator and
 if-match acl 2000
qos policy shaping
 qos lr outbound cir 15360 cbs 960000
 qos gts queue 6 cir 10240 cbs 640000
 qos gts queue 4 cir 3072 cbs 192000
 qos gts queue 2 cir 7168 cbs 448000
return
