20-Network Management and Monitoring
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10020-Network Management and Monitoring
21-SNMPv2-MIB
21-SNMPv2-MIB 97.81 KB
SNMPv2-MIB
About this MIB
Use this MIB to configure SNMPv2 basic settings and obtain SNMP packet statistics.
MIB file name
rfc3418-snmpv2.mib
Root object
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpMIB(1)
Scalar objects
snmpTrapEnterprise (1.3.6.1.6.3.1.1.4.3)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OBJECT IDENTIFIER
Standard MIB values.
OID of the enterprise associated with the trap currently being sent.
As per the MIB.
snmpSetSerialNo (1.3.6.1.6.3.1.1.6.1)
Object (OID)
Access
Value range
Implementation
read-write
TestAndIncr
An advisory lock used to allow several cooperating command generator applications to coordinate their use of the SNMP set operation.
As per the MIB.
snmpInPkts (1.3.6.1.2.1.11.1)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of SNMP messages received on the SNMP agent.
As per the MIB.
snmpOutPkts (1.3.6.1.2.1.11.2)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of SNMP messages sent by the SNMP agent.
As per the MIB.
snmpInBadVersions (1.3.6.1.2.1.11.3)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of received SNMP messages not supported by the SNMP version.
As per the MIB.
snmpInBadCommunityNames (1.3.6.1.2.1.11.4)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of received SNMP messages which used an SNMP community name unknown to the SNMP entity.
As per the MIB.
snmpInBadCommunityUses (1.3.6.1.2.1.11.5)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of messages carrying an operation that the community has no right to perform.
As per the MIB.
snmpInASNParseErrs (1.3.6.1.2.1.11.6)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of received SNMP messages that had ASN.1 or BER errors during decoding.
As per the MIB.
snmpInTooBigs (1.3.6.1.2.1.11.8)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of received SNMP PDUs with a TooBig error.
When read, this object always returns 0.
snmpInNoSuchNames (1.3.6.1.2.1.11.9)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of received SNMP PDUs with a NoSuchName error.
snmpInBadValues (1.3.6.1.2.1.11.10)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of received SNMP PDUs with a BadValue error.
snmpInReadOnlys (1.3.6.1.2.1.11.11)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of received SNMP PDUs with a readOnly error.
snmpInGenErrs (1.3.6.1.2.1.11.12)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of received SNMP PDUs with a genErr error.
snmpInTotalReqVars (1.3.6.1.2.1.11.13)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of MIB objects that have been successfully retrieved.
As per the MIB.
snmpInTotalSetVars (1.3.6.1.2.1.11.14)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of MIB objects that have been successfully modified.
As per the MIB.
snmpInGetRequests (1.3.6.1.2.1.11.15)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of GetRequest requests that have been received and processed.
As per the MIB.
snmpInGetNexts (1.3.6.1.2.1.11.16)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of getNext requests that have been received and processed.
As per the MIB.
snmpInSetRequests (1.3.6.1.2.1.11.17)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of set requests that have been received and processed.
As per the MIB.
snmpOutTooBigs (1.3.6.1.2.1.11.20)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of sent SNMP PDUs with a TooBig error.
As per the MIB.
snmpOutNoSuchNames (1.3.6.1.2.1.11.21)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of sent SNMP PDUs with a NoSuchName error.
As per the MIB.
snmpOutBadValues (1.3.6.1.2.1.11.22)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of sent SNMP PDUs with a BadValues error.
As per the MIB.
snmpOutGenErrs (1.3.6.1.2.1.11.24)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of sent SNMP PDUs with a genErr error.
As per the MIB.
snmpOutGetRequests (1.3.6.1.2.1.11.25)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of sent SNMP Get-Request PDUs.
As per the MIB.
snmpOutGetNexts (1.3.6.1.2.1.11.26)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of sent SNMP Get-Next PDUs.
As per the MIB.
snmpOutSetRequests (1.3.6.1.2.1.11.27)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of sent SNMP Set-Request PDUs.
As per the MIB.
snmpOutGetResponses (1.3.6.1.2.1.11.28)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of sent SNMP Get-Response PDUs.
As per the MIB.
snmpOutTraps (1.3.6.1.2.1.11.29)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of notifications sent by the SNMP entity.
As per the MIB.
snmpEnableAuthenTraps (1.3.6.1.2.1.11.30)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
enabled(1),
disabled(2)
Whether authenticationFailure traps are enabled.
The default value is enabled(1).
snmpSilentDrops (1.3.6.1.2.1.11.31)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of packets delivered to but dropped by the SNMP entity because the response packet size exceeded the limit.
As per the MIB.
snmpProxyDrops (1.3.6.1.2.1.11.32)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Total number of packets delivered to but dropped by the SNMP entity because transmission of the message to a proxy target failed.
Notifications
coldStart
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.6.3.1.1.5.1
SNMP agent cold start
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the SNMP agent is initialized for the first time after the device is started.
System impact
No negative impact on the system.
Status control
ON
CLI: snmp-agent trap enable standard coldstart
OFF
CLI: undo snmp-agent trap enable standard coldstart
Object
OID (object name)
Index
Value range
N/A (N/A)
N/A
N/A
N/A
N/A
Recommended action
No action is required.
warmStart
Basic information
OID
Event
Severity
Default status
1.3.6.1.6.3.1.1.5.2
SNMP agent warm start
Informational
Warning
N/A (N/A)
ON
This notification is generated when the SNMP agent is initialized for the non-first time after the device is started.
System impact
Status control
ON
CLI: snmp-agent trap enable standard warmstart
OFF
CLI: undo snmp-agent trap enable standard warmstart
Object
OID (object name)
Index
Value range
N/A (N/A)
N/A
N/A
N/A
N/A
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.6.3.1.1.5.5
SNMP authentication failure
Informational
Warning
N/A (N/A)
ON
This notification is generated when an NMS uses a wrong community name or SNMPv3 username to connect to the device and fails to be authenticated.
System impact
If SNMP silence is enabled, illegitimate NMSs might fail to access the device.
Status control
ON
CLI: snmp-agent trap enable standard authentication
OFF
CLI: undo snmp-agent trap enable standard authentication
Object
OID (object name)
Index
Value range
N/A (N/A)
N/A
N/A
N/A
N/A
Recommended action
1.Verify that the agent and NMS are configured with the same SNMP settings.
  - To view the SNMP settings, execute the display current-configuration | include snmp-agent command in user view.
  - If the community name is configured incorrectly, execute the snmp-agent community command in system view to change the community name.
  - If the SNMPv3 user settings are configured incorrectly, execute the snmp-agent user command in system view to change the SNMPv3 user settings.
2.Identify whether a network attack has occurred. You can configure ACLs to allow access only from illegitimate NMSs.
3.If the issue persists, collect alarm information and configuration data and then contact H3C Support for help.
