20-Network Management and Monitoring
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10020-Network Management and Monitoring
04-HH3C-INQA-MIB
04-HH3C-INQA-MIB 85.44 KB
HH3C-INQA-MIB
About this MIB
Use this MIB to configure device INQA.
MIB file name
hh3c-inqa.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cInqa(252)
Scalar objects
hh3cInqaForwardLossRatio (1.3.6.1.4.1.25506.2.252.1.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
Standard MIB values.
Packet loss rate of the forward flow.
As per the MIB.
hh3cInqaBackwardLossRatio (1.3.6.1.4.1.25506.2.252.1.1.2)
Object (OID)
Access
Value range
Implementation
OCTET STRING
Packet loss rate of the backward flow.
As per the MIB.
Tabular objects
hh3cInqaAnalyzerInstTable
About this table
Use this table to obtain information about the Analyzer configuration instance.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadNot supported
Columns
The table index is hh3cInqaAnalyzerInstID.
Object (OID)
Access
Value range
Implementation
hh3cInqaAnalyzerInstID(1.3.6.1.4.1.25506.2.252.2.1.1.1.1)
Unsigned32
Unsigned32(1.. 8355838)
Analyzer ID.
As per the MIB.
hh3cInqaAnalyzerInstDesc(1.3.6.1.4.1.25506.2.252.2.1.1.1.2)
read-only
OCTET STRING
OCTET STRING(1..64)
Description of the Analyzer instance.
As per the MIB.
hh3cInqaAnalyzerAmsTable
About this table
Use this table to obtain the Atomic Measurement Span (AMS) information of the Analyzer.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
The table index is hh3cInqaAnalyzerInstID and hh3cInqaAmsID.
Object (OID)
Access
Value range
Implementation
hh3cInqaAmsID(1.3.6.1.4.1.25506.2.252.2.1.2.1.1)
Unsigned32
Unsigned32(1.. 2147483647)
AMS ID.
As per the MIB.
hh3cInqaAmsFlowDir(1.3.6.1.4.1.25506.2.252.2.1.2.1.2)
read-only
INTEGER
forward (1), backward (2), bidirection (3)
Target flow direction.
As per the MIB.
hh3cInqaAnalyzerLossThresTable
About this table
Use this table to obtain the packet loss log parameters for the Analyzer instance.
CreateNot supported
DeleteNot supported
ReadNot supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cInqaLossUpperLimit (1.3.6.1.4.1.25506.2.252.2.1.3.1.1)
read-only
OCTET STRING
OCTET STRING(1..10)
Packet loss alarm threshold, in the range of 0.000001 to 100.
As per the MIB.
hh3cInqaLossLowerLimit(1.3.6.1.4.1.25506.2.252.2.1.3.1.2)
read-only
OCTET STRING
OCTET STRING(1..10)
Packet loss recovery threshold, in the range of 0.000001 to 100.
As per the MIB.
Notifications
hh3cInqaLossRatioExceed
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.252.1.0.1
The packet loss rate exceeds the alarm threshold.
Error
Warning
1.3.6.1.4.1.25506.2.252.1.0.2 (hh3cInqaLossRatioRecover)
OFF
Notification triggers
When packet loss statistics collection is enabled, iNQA periodically calculates the packet loss rate. If the packet loss rate is greater than or equal to the packet loss alarm threshold for five consecutive periods, it indicates that too many packets are lost in the instance. Then, the Analyzer generates a packet loss alarm.
Possible reasons include:
Abnormal traffic causes network congestion.
The link state is unstable.
System impact
The packet loss rate is high and may be unable to meet service requirements on packet loss. Services might be affected.
Status control
ON
CLI: loss-measure alarm upper-limit upper-limit lower-limit lower-limit
OFF
CLI: undo loss-measure alarm
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.252.2.1.1.1.1 (hh3cInqaAnalyzerInstID)
Analyzer ID.
Unsigned32
Unsigned32 (1.. 8355838)
1.3.6.1.4.1.25506.2.252.2.1.1.1.2 (hh3cInqaAnalyzerInstDesc)
OCTET STRING
OCTET STRING(1..64)
1.3.6.1.4.1.25506.2.252.2.1.2.1.1 (hh3cInqaAmsID)
AMS ID.
hh3cInqaAmsID
Unsigned32
Unsigned32 (1.. 2147483647)
1.3.6.1.4.1.25506.2.252.2.1.2.1.2 (hh3cInqaAmsFlowDir)
Target traffic direction.
hh3cInqaAmsID
INTEGER
N/A
OCTET STRING
OCTET STRING(1..10)
N/A
OCTET STRING
OCTET STRING(1..10)
1.3.6.1.4.1.25506.2.252.2.1.3.1.1 (hh3cInqaLossUpperLimit)
OCTET STRING
OCTET STRING(1..10)
1.3.6.1.4.1.25506.2.252.2.1.3.1.2 (hh3cInqaLossLowerLimit)
OCTET STRING
OCTET STRING(1..10)
Recommended action
To resolve the issue:
1.Verify if abnormal traffic exists in the network.
2.Verify if the link state is stable during the alarming periods. Troubleshoot and resolve issues that causes link instability.
3.If the issue persists, collect alarm and configuration information, and contact Technical Support.
Basic information
OID
Event
Severity
Default status
Packet loss rate recovered.
Recovery
Warning
N/A (N/A)
OFF
If the packet loss rate is lower than or equal to the packet loss recovery threshold for five consecutive periods, it indicates that the packet loss rate in the instance has dropped to the normal range. Then, the Analyzer generates a packet loss recovery notification.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Analyzer ID.
Unsigned32
OCTET STRING
OCTET STRING(1..64)
AMS ID.
hh3cInqaAmsID
Unsigned32
hh3cInqaAmsID
INTEGER
N/A
OCTET STRING
OCTET STRING(1..10)
N/A
OCTET STRING
OCTET STRING(1..10)
OCTET STRING
OCTET STRING(1..10)
OCTET STRING
OCTET STRING(1..10)
Recommended action
No action is required.
