- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-User profile commands
- 08-Password control commands
- 09-Keychain commands
- 10-Public key management commands
- 11-PKI commands
- 12-IPsec commands
- 13-SSH commands
- 14-SSL commands
- 15-Attack detection and prevention commands
- 16-TCP attack prevention commands
- 17-IP source guard commands
- 18-ARP attack protection commands
- 19-ND attack defense commands
- 20-uRPF commands
- 21-SAVI commands
- 22-SAVA commands
- 23-MFF commands
- 24-Crypto engine commands
- 25-FIPS commands
- 26-802.1X client commands
- 27-Microsegmentation commands
| 24-Crypto engine commands | 40.67 KB |
display crypto-engine
Use display crypto-engine to display crypto engine information.
# Display crypto engine information.
<Sysname> display crypto-engine
Crypto engine name: Software crypto engine
Crypto engine state: Enabled
Crypto engine type: Software
Slot ID: 1
CPU ID:0
Crypto engine ID: 0
Symmetric algorithms: des-cbc des-ecb 3des-cbc aes-cbc aes-ecb aes-ctr camellia_cbc md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc aes-xcbc-hmac
Asymmetric algorithms:
Random number generation function: Supported
Crypto engine state |
This field always displays Enabled for software crypto engines. |
Crypto engine type |
The value is Software for this field. |
CPU ID |
ID of the CPU on the device. |
Symmetric algorithms |
Supported symmetric algorithms. |
Asymmetric algorithms |
Supported asymmetric algorithms. |
Random number generation function |
Whether random number generation function is supported: · Supported. · Not supported. |
display crypto-engine statistics
Use display crypto-engine statistics to display crypto engine statistics.
display crypto-engine statistics [ engine-id engine-id slot slot-number ]
engine-id engine-id: Specifies a crypto engine by its ID. The switch supports only one software crypto engine, and the engine ID can only be 0.
slot slot-number: Specifies an IRF member device by its member ID.
If you do not specify any parameters, this command displays crypto engine statistics for all member devices.
# Display all crypto engine statistics.
<Sysname> display crypto-engine statistics
Slot ID: 1
CPU ID: 0
Crypto engine ID: 0
Submitted sessions: 0
Failed sessions: 0
Symmetric operations: 0
Symmetric errors: 0
Asymmetric operations: 0
Asymmetric errors: 0
Get-random operations: 0
Get-random errors: 0
# Display statistics for crypto engine 1 on the specified slot.
<Sysname> display crypto-engine statistics engine-id 1 slot 1
Failed sessions: 0
Symmetric errors: 0
Submitted sessions |
Number of established sessions. |
Failed sessions |
Number of failed sessions. |
Symmetric operations |
Number of operations using symmetric algorithms. |
Symmetric errors |
Number of failed operations using symmetric algorithms. |
Asymmetric operations |
Number of operations using asymmetric algorithms. |
Asymmetric errors |
Number of failed operations using asymmetric algorithms. |
Get-random operations |
Number of operations for obtaining random numbers. |
Get-random errors |
Number of failed operations for obtaining random numbers. |
reset crypto-engine statistics
Use reset crypto-engine statistics to clear crypto engine statistics.
reset crypto-engine statistics [ engine-id engine-id slot slot-number ]
If you do not specify any parameters, this command clears crypto engine statistics for all member devices.
# Clear statistics for all crypto engines.
<Sysname> reset crypto-engine statistics
