09-Security Command Reference
HomeSupportSwitchesS6812 & S6813 SeriesReference GuidesCommand ReferencesH3C S6812 & S6813 Switch Series Command Reference-R6615Pxx-6W10009-Security Command Reference
20-uRPF commands
20-uRPF commands 40.46 KB
IPv4 uRPF commands
display ip urpf
Use display ip urpf to display uRPF configuration.
display ip urpf [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays uRPF configuration for all member devices.
# Display uRPF configuration for the specified slot.
<Sysname> display ip urpf slot 1
Global uRPF configuration information(failed):
   Check type: strict
(failed)
The system failed to deliver the uRPF configuration to the forwarding chip because of insufficient chip resources.
This field is not displayed if the delivery is successful.
Check type
uRPF check mode: loose or strict.
ip urpf
Use ip urpf to enable uRPF.
Use undo ip urpf to disable uRPF.
ip urpf { loose | strict }
undo ip urpf
uRPF is disabled.
loose: Enables loose uRPF check. To pass loose uRPF check, the source address of a packet must match the destination address of a FIB entry.
strict: Enables strict uRPF check. To pass strict uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of a FIB entry.
uRPF can be deployed on a PE connected to a CE or an ISP, or on a CE.
# Enable strict uRPF check globally.
[Sysname] ip urpf strict
display ip urpf
