06-Layer 3 - IP Routing Configuration Guides
HomeSupportSwitchesS10500X SeriesConfigure & DeployConfiguration GuidesH3C S10500X Switch Series Configuration Guides-Release7634Pxx-6W10006-Layer 3 - IP Routing Configuration Guides
08-IPv6 static routing configuration
08-IPv6 static routing configuration 166.89 KB
Configuring IPv6 static routing
Static routes are manually configured and cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually. IPv6 static routing works well in a simple IPv6 network.
Configuring an IPv6 static route
Before you configure an IPv6 static route, complete the following tasks:
·     Configure parameters for the related interfaces.
·     Configure link layer attributes for the related interfaces.
·     Make sure the neighboring nodes can reach each other.
If you configure only VPN instance settings without specifying a next hop for an IPv6 static route, you must also configure service loopback group settings for the IPv6 static route to take effect.
To configure service loopback group settings for an IPv6 static route:
1.     Create a service loopback group of the inter-VPN forwarding service type.
2.     Add any Layer 2 Ethernet interface to the service loopback group. To ensure that the IPv6 static route can correctly guide traffic forwarding, do not add the Layer 2 Ethernet interfaces on the following cards to the service loopback group:
¡     EC interface modules.
¡     SA interface modules.
¡     SE interface modules.
For more information about service loopback group configuration, see Layer 2—LAN Switching Configuration Guide.
To configure an IPv6 static route:
Step
Remarks
N/A
2.     Configure an IPv6 static route.
·     Method 1:
ipv6 route-static ipv6-address prefix-length interface-type interface-number [ next-hop-address ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static ipv6-address prefix-length { next-hop-address [ recursive-lookup host-route ] | vpn-instance d-vpn-instance-name nexthop-address [ recursive-lookup host-route ] } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static ipv6-address prefix-length vpn-instance d-vpn-instance-name [ preference preference ] [ tag tag-value ] [ description text ]
·     Method 2:
ipv6 route-static
vpn-instance s-vpn-instance-name ipv6-address prefix-length interface-type interface-number [ next-hop-address ] [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { nexthop-address [ recursive-lookup host-route ] [ public ] | vpn-instance d-vpn-instance-name nexthop-address [ recursive-lookup host-route ] } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { public | vpn-instance d-vpn-instance-name } [ preference preference ] [ tag tag-value ] [ description text ]
By default, no IPv6 static route is configured.
The recursive-lookup host-route and recursive-lookup keywords are mutually exclusive.
If you specify a destination VPN instance without specifying a next hop address, the destination VPN instance cannot be the same as the source VPN instance.
3.     (Optional.) Set the default preference for IPv6 static routes.
ipv6 route-static default-preference default-preference
The default setting is 60.
4.     (Optional.) Delete all IPv6 static routes, including the default route.
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
The undo ipv6 route-static command deletes one IPv6 static route.
CAUTION CAUTION:
Deleting all IPv6 static routes might cause network connectivity failure and packet forwarding failure. Perform this operation with caution.
Configuring IPv6 floating static routes
Perform this task to configure route backup to improve network reliability.
When an IPv6 static or dynamic route to a destination address already exists on the device, you configure another IPv6 static route with a lower priority as the backup route to improve the network reliability. This backup IPv6 static route is called an IPv6 floating static route and is activated only when the primary route fails. After the primary route recovers from failure, the IPv6 floating static route becomes inactive and data forwarding switches back to the primary route.
An IPv6 floating static route can be configured in either of the following ways
·     Configure different priorities for multiple IPv6 static routes to the same destination address. The route with the lower priority automatically becomes the IPv6 floating static route.
·     When an IPv6 route to a destination address already exists on the device, configure an IPv6 static route with a lower priority to the same destination address.
When you configure an IPv6 floating static route, the priority value of the route must be larger than then priority value of the primary route. For more information, see "Configuring an IPv6 static route."
Configuring BFD for IPv6 static routes
Overview
BFD provides a general purpose, standard, and medium- and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols and MPLS. For more information about BFD, see High Availability Configuration Guide.
When you configure BFD for IPv6 static routes, follow these restrictions and guidelines:
·     If you specify a source IPv6 address for BFD packets on the local device, you must specify that IPv6 address as the next hop IPv6 address on the peer device.
·     If you specify a non-P2P output interface and a direct next hop, specify the bfd-source ipv6-address option as a best practice. Make sure the source IPv6 address of BFD packets meets the following requirements:
¡     The address is the same as the IPv6 address of the output interface.
¡     The address is on the same network segment as the next hop IPv6 address of the same type.
For example, if the next hop IPv6 address is a link-local address, the source IPv6 address of BFD packets must also be a link-local address.
·     Enabling BFD for a flapping route could worsen the situation.
Configuring BFD control packet mode
This mode uses BFD control packets to detect the status of a link bidirectionally at a millisecond level.
BFD control packet mode can be applied to IPv6 static routes with a direct next hop or with an indirect next hop.
If you configure BFD control packet mode at the local end, you must also configure this mode at the peer end.
To configure BFD control packet mode for an IPv6 static route (direct next hop):
Step
Remarks
N/A
2.     Configure BFD control packet mode for an IPv6 static route.
ipv6 route-static [ vpn-instance s-vpn-instance-name ] ipv6-address prefix-length interface-type interface-number next-hop-address bfd control-packet [ bfd-source ipv6-address ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD control packet mode for an IPv6 static route is not configured.
To configure BFD control packet mode for an IPv6 static route (indirect next hop):
Step
Remarks
N/A
ipv6 route-static [ vpn-instance s-vpn-instance-name ] ipv6-address prefix-length [ vpn-instance d-vpn-instance-name ] { next-hop-address [ recursive-lookup host-route ] bfd control-packet bfd-source ipv6-address } [ preference preference ] [ tag tag-value ] [ description text ]
Configuring BFD echo packet mode
With BFD echo packet mode enabled for a static route, the output interface sends BFD echo packets to the destination device, which loops the packets back to test the link reachability.
You do not need to configure BFD echo packet mode at the peer end.
Do not use BFD for a static route with the output interface in spoofing state.
Configuration procedure
To configure BFD echo packet mode for an IPv6 static route:
Step
Remarks
N/A
2.     Configure the source address of echo packets.
By default, the source address of echo packets is not configured.
The source address of echo packets must be a global unicast address.
For more information about this command, see High Availability Command Reference.
3.     Configure BFD echo packet mode for an IPv6 static route.
ipv6 route-static [ vpn-instance s-vpn-instance-name ] ipv6-address prefix-length interface-type interface-number next-hop-address bfd echo-packet [ bfd-source ipv6-address ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD echo packet mode for an IPv6 static route is not configured.
The next hop IPv6 address must be a global unicast address.
Enabling periodic sending of ND requests to the next hops of IPv6 static routes
When the following conditions exist, a recursive IPv6 static route becomes inactive:
·     The IPv6 static route uses a host route to reach its direct next hop.
·     The host route is obtained either by specifying the recursive-lookup host-route keyword in the ipv6 route-static command or by routing policy-based recursive lookup.
·     The host route is unavailable because no ND entry exists for that host route on the device.
To resolve this issue, you can perform this task to enable the device to periodically send ND requests to the direct next hop. When the device receives an ND response from the direct next hop, it stops sending ND requests and activates the recursive IPv6 static route.
This task applies only to a recursive IPv6 static route that meets the following requirements:
·     The IPv6 static route has no output interface specified.
·     The IPv6 static route fails the next-hop recursion.
For more information about ND, see IPv6 neighbor discovery in Layer 3—IP Services Configuration Guide.
To enable periodic sending of ND requests to the next hops of IPv6 static routes:
Step
Remarks
N/A
2.     Enable periodic sending of ND requests to the next hops of IPv6 static routes.
ipv6 route-static nd-request [ interval interval ]
By default, periodic sending of ND requests to the next hops of IPv6 static routes is disabled.
Displaying and maintaining IPv6 static routes
Display IPv6 static route information.
display ipv6 routing-table protocol static [ inactive | verbose ]
Display IPv6 static route next hop information.
display ipv6 route-static nib [ nib-id ] [ verbose ]
Display IPv6 static routing table information.
display ipv6 route-static routing-table [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ]
IPv6 static routing configuration examples
Basic IPv6 static route configuration example
Network requirements
As shown in Figure 1, configure IPv6 static routes so that hosts can reach one another.
Figure 1 Network diagram
1.     Configure the IPv6 addresses for all VLAN interfaces. (Details not shown.)
2.     Configure IPv6 static routes:
# Configure a default IPv6 static route on Switch A.
[SwitchA] ipv6 route-static :: 0 4::2
# Configure two IPv6 static routes on Switch B.
[SwitchB] ipv6 route-static 1:: 64 4::1
[SwitchB] ipv6 route-static 3:: 64 5::1
# Configure a default IPv6 static route on Switch C.
[SwitchC] ipv6 route-static :: 0 5::2
3.     Configure the IPv6 addresses for all the hosts and configure the default gateway of Host A, Host B, and Host C as 1::1, 2::1, and 3::1.
# Display the IPv6 static route information on Switch A.
[SwitchA] display ipv6 routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 1
Destination: ::/0                                        Protocol  : Static
NextHop    : 4::2                                        Preference: 60
Interface  : Vlan200                                     Cost      : 0
Static Routing table status : <Inactive>
Summary count : 0
# Display the IPv6 static route information on Switch B.
[SwitchB] display ipv6 routing-table protocol static
Summary count : 2
Summary count : 2
Destination: 1::/64                                      Protocol  : Static
NextHop    : 4::1                                        Preference: 60
Destination: 3::/64                                      Protocol  : Static
NextHop    : 5::1                                        Preference: 60
Interface  : Vlan300                                     Cost      : 0
Summary count : 0
# Use the ping command to test the reachability.
[SwitchA] ping ipv6 3::1
Ping6(56 data bytes) 4::1 --> 3::1, press CTRL+C to break
56 bytes from 3::1, icmp_seq=0 hlim=62 time=0.700 ms
56 bytes from 3::1, icmp_seq=1 hlim=62 time=0.351 ms
56 bytes from 3::1, icmp_seq=2 hlim=62 time=0.338 ms
56 bytes from 3::1, icmp_seq=3 hlim=62 time=0.373 ms
56 bytes from 3::1, icmp_seq=4 hlim=62 time=0.316 ms
--- Ping6 statistics for 3::1 ---
round-trip min/avg/max/std-dev = 0.316/0.416/0.700/0.143 ms
BFD for IPv6 static routes configuration example (direct next hop)
As shown in Figure 2:
·     Configure an IPv6 static route to subnet 120::/64 on Switch A.
·     Configure an IPv6 static route to subnet 121::/64 on Switch B.
·     Enable BFD for both routes.
·     Configure an IPv6 static route to subnet 120::/64 and an IPv6 static route to subnet 121::/64 on Switch C.
When the link between Switch A and Switch B through the Layer 2 switch fails, BFD can detect the failure immediately, and Switch A and Switch B can communicate through Switch C.
Figure 2 Network diagram
Device
IPv6 address
Switch A
Vlan-int10
12::1/64
Switch A
Vlan-int11
10::102/64
Switch B
Vlan-int10
12::2/64
Switch B
Vlan-int13
13::1/64
Switch C
Vlan-int11
10::100/64
Switch C
Vlan-int13
13::2/64
1.     Configure IPv6 addresses for interfaces. (Details not shown.)
2.     Configure IPv6 static routes and BFD:
# Configure IPv6 static routes on Switch A and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[SwitchA-vlan-interface10] bfd min-transmit-interval 500
[SwitchA-vlan-interface10] bfd min-receive-interval 500
[SwitchA-vlan-interface10] bfd detect-multiplier 9
[SwitchA-vlan-interface10] quit
[SwitchA] ipv6 route-static 120:: 64 vlan-interface 10 12::2 bfd control-packet
[SwitchA] ipv6 route-static 120:: 64 10::100 preference 65
[SwitchA] quit
# Configure IPv6 static routes on Switch B and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[SwitchB-vlan-interface10] bfd min-transmit-interval 500
[SwitchB-vlan-interface10] bfd min-receive-interval 500
[SwitchB-vlan-interface10] bfd detect-multiplier 9
[SwitchB-vlan-interface10] quit
[SwitchB] ipv6 route-static 121:: 64 vlan-interface 10 12::1 bfd control-packet
[SwitchB] ipv6 route-static 121:: 64 vlan-interface 13 13::2 preference 65
[SwitchB] quit
# Configure IPv6 static routes on Switch C.
[SwitchC] ipv6 route-static 120:: 64 13::1
[SwitchC] ipv6 route-static 121:: 64 10::102
# Display the BFD sessions on Switch A.
<SwitchA> display bfd session
 IPv6 session working in control packet mode:
       Local Discr: 513                 Remote Discr: 33
         Source IP: 12::1
    Destination IP: 12::2
     Session State: Up                      Interface: Vlan10
         Hold Time: 2012ms
The output shows that the BFD session has been created.
# Display IPv6 static routes on Switch A.
<SwitchA> display ipv6 routing-table protocol static
Summary count : 1
Summary count : 1
Destination: 120::/64                                    Protocol  : Static
NextHop    : 12::2                                       Preference: 60
Interface  : Vlan10                                      Cost      : 0
Direct Routing table status : <Inactive>
Summary count : 0
The output shows that Switch A communicates with Switch B through VLAN-interface 10. The link over VLAN-interface 10 fails.
# Display IPv6 static routes on Switch A again.
Summary count : 1
Summary count : 1
NextHop    : 10::100                                     Preference: 65
Interface  : Vlan11                                      Cost      : 0
Static Routing table status : < Inactive>
Summary count : 0
The output shows that Switch A communicates with Switch B through VLAN-interface 11.
BFD for IPv6 static routes configuration example (indirect next hop)
As shown in Figure 3:
·     Switch A has a route to interface Loopback 1 (2::9/128) on Switch B, and the output interface is VLAN-interface 10.
·     Switch B has a route to interface Loopback 1 (1::9/128) on Switch A, and the output interface is VLAN-interface 12.
·     Switch D has a route to 1::9/128, and the output interface is VLAN-interface 10. It also has a route to 2::9/128, and the output interface is VLAN-interface 12.
Configure the following:
·     Configure an IPv6 static route to subnet 120::/64 and an IPv6 static route to subnet 121::/64 on both Switch C and Switch D.
When the link between Switch A and Switch B through Switch D fails, BFD can detect the failure immediately and Switch A and Switch B can communicate through Switch C.
Figure 3 Network diagram
Device
IPv6 address
Switch A
Vlan-int10
12::1/64
Switch A
Vlan-int11
10::102/64
Switch A
Loop1
1::9/128
Switch B
Vlan-int12
11::2/64
Switch B
Vlan-int13
13::1/64
Switch B
Loop1
2::9/128
Switch C
Vlan-int11
10::100/64
Switch C
Vlan-int13
13::2/64
Switch D
Vlan-int10
12::2/64
Switch D
Vlan-int12
11::1/64
# Configure IPv6 static routes on Switch A and enable BFD control packet mode for the IPv6 static route that traverses Switch D.
[SwitchA] bfd multi-hop min-transmit-interval 500
[SwitchA] bfd multi-hop min-receive-interval 500
[SwitchA] bfd multi-hop detect-multiplier 9
[SwitchA] ipv6 route-static 120:: 64 2::9 bfd control-packet bfd-source 1::9
[SwitchA] ipv6 route-static 2::9 128 12::2
[SwitchA] quit
# Configure IPv6 static routes on Switch B and enable BFD control packet mode for the static route that traverses Switch D.
[SwitchB] bfd multi-hop min-transmit-interval 500
[SwitchB] bfd multi-hop min-receive-interval 500
[SwitchB] bfd multi-hop detect-multiplier 9
[SwitchB] ipv6 route-static 121:: 64 1::9 bfd control-packet bfd-source 2::9
[SwitchB] ipv6 route-static 121:: 64 13::2 preference 65
[SwitchB] ipv6 route-static 1::9 128 11::1
[SwitchB] quit
# Configure IPv6 static routes on Switch D.
<SwitchD> system-view
[SwitchD] ipv6 route-static 120:: 64 11::2
[SwitchD] ipv6 route-static 121:: 64 12::1
[SwitchD] ipv6 route-static 2::9 128 11::2
[SwitchD] ipv6 route-static 1::9 128 12::1
         Source IP: 1::9
    Destination IP: 2::9
     Session State: Up                      Interface: N/A
         Hold Time: 2012ms
# Display the IPv6 static routes on Switch A.
Summary count : 1
Summary count : 1
NextHop    : 2::9                                        Preference: 60
Summary count : 0
The output shows that Switch A communicates Switch B through VLAN-interface 10. The link over VLAN-interface 10 fails.
Summary count : 1
Summary count : 1
Summary count : 0
Configuring an IPv6 default route
A default IPv6 route is used to forward packets that match no entry in the routing table.
A default IPv6 route can be configured in either of the following ways:
·     The network administrator can configure a default route with a destination prefix of ::/0. For more information, see "Configuring IPv6 static routing."
·     Some dynamic routing protocols, such as OSPFv3, IPv6 IS-IS, and RIPng, can generate a default IPv6 route. For example, an upstream router running OSPFv3 can generate a default IPv6 route and advertise it to other routers. These routers install the default IPv6 route with the next hop being the upstream router. For more information, see the respective chapters on those routing protocols in this configuration guide.
As shown in Figure 4, Device B is the next hop for packets from Device A to Device C, Device D, and Device E. You can configure a default route on Device A to replace the three IPv6 static routes from Device A to Device C, Device D, and Device E, respectively.
The next hop address, destination address, and subnet mask of the IPv6 default route configured on Device A are 1::2, ::, and 0, respectively.
Figure 4 Configuring a default route
