06-Layer 3 - IP Routing Configuration Guides
HomeSupportSwitchesS10500X SeriesConfigure & DeployConfiguration GuidesH3C S10500X Switch Series Configuration Guides-Release7634Pxx-6W10006-Layer 3 - IP Routing Configuration Guides
06-BGP configuration
06-BGP configuration 2.24 MB
Configuring BGP·· 1
Overview· 1
BGP speaker and BGP peer 1
BGP message types· 1
BGP path attributes· 2
BGP route selection· 6
BGP route advertisement rules· 6
BGP load balancing· 7
Settlements for problems in large-scale BGP networks· 8
MP-BGP· 11
BGP multi-instance· 12
BGP configuration views· 12
Protocols and standards· 15
Licensing requirements· 16
BGP configuration task list 16
Configuring basic BGP· 20
Enabling BGP· 20
Configuring a BGP peer 21
Configuring dynamic BGP peers· 26
Configuring a BGP peer group· 29
Specifying the source address of TCP connections· 48
Generating BGP routes· 49
Injecting a local network· 49
Redistributing IGP routes· 51
Redistributing the local network specified in the public instance or a VPN instance· 54
Controlling route distribution and reception· 55
Configuring BGP route summarization· 55
Advertising optimal routes in the IP routing table· 57
Advertising a default route to a peer or peer group· 58
Enabling prioritized advertisement of default-route withdrawal messages· 60
Enabling prioritized withdrawal of specific routes· 60
Limiting routes received from a peer or peer group· 62
Configuring BGP route filtering policies· 64
Enabling first-AS-number check for EBGP route advertisement 75
Setting the BGP route sending rate· 76
Configuring BGP to delay sending route updates on reboot 77
Configuring BGP route advertisement delay· 77
Configuring a startup policy for BGP route updates· 78
Configuring BGP route dampening· 79
Controlling BGP path selection· 80
Setting a preferred value for routes received· 80
Configuring preferences for BGP routes· 82
Configuring the default local preference· 83
Configuring the MED attribute· 85
Configuring the NEXT_HOP attribute· 89
Configuring the AS_PATH attribute· 93
Minimizing the priority of BGP routes advertised to peers· 99
Ignoring IGP metrics during optimal route selection· 109
Ignoring router IDs during optimal route selection· 110
Preferring routes with an IPv6 next hop during optimal route selection· 110
Associating a track entry with a BGP peer or peer group· 111
Configuring the SoO attribute· 112
Tuning and optimizing BGP networks· 114
Setting the TCP MSS for TCP connections· 114
Configuring the keepalive interval and hold time· 115
Setting the session retry timer 116
Configuring the interval for sending updates for the same route· 118
Enabling BGP to establish an EBGP session over multiple hops· 119
Enabling immediate re-establishment of direct EBGP connections upon link failure· 120
Enabling BGP ORF capabilities· 120
Enabling 4-byte AS number suppression· 123
Enabling MD5 authentication for BGP peers· 124
Enabling keychain authentication for BGP peers· 125
Configuring BGP load balancing· 126
Configuring IPsec for IPv6 BGP· 129
Disabling BGP session establishment 130
Configuring GTSM for BGP· 131
Configuring BGP soft-reset 132
Configuring the BGP additional path feature· 138
Protecting an EBGP peer when memory usage reaches level 2 threshold· 140
Configuring an update delay for local MPLS labels· 141
Flushing the suboptimal BGP route to the RIB· 142
Enabling BGP to not flush specific routes to the routing table· 142
Setting a DSCP value for outgoing BGP packets· 143
Disabling route recursion policy control for routes received from a peer or peer group· 144
Specifying a label allocation mode· 145
Disabling optimal route selection for labeled routes without tunnel information· 145
Configuring BGP optimal route selection delay· 145
Specifying the longest match principle for next hop recursion· 148
Enabling fast host route update upon user migration· 150
Enabling conversational remote host route learning· 151
Enabling peer unreachability detection· 152
Configuring a large-scale BGP network· 153
Configuring BGP community· 153
Configuring BGP route reflection· 157
Configuring a route server 161
Configuring BGP confederation settings· 163
Configuring BGP GR· 163
Configuring BGP NSR· 166
Enabling SNMP notifications for BGP· 167
Enabling logging for session state changes· 167
Enabling logging for BGP route flapping· 168
Configuring BFD for BGP· 170
Configuring BGP FRR· 171
Configuring BGP maintenance features· 174
About BGP maintenance features· 174
Configuring BGP isolation· 174
Configuring BGP shutdown· 175
Configuring 6PE· 176
Configuring basic 6PE· 176
Configuring optional 6PE capabilities· 177
Configuring BGP LS· 179
Configuring basic BGP LS· 179
Configuring BGP LS route reflection· 179
Specifying an AS number and a router ID for BGP LS messages· 180
Configuring BMP· 180
Configuring BGP RPKI 186
Configuring RPKI connection parameters· 186
Enabling BGP RPKI validation· 188
Applying the BGP RPKI validation state to optimal route selection· 188
Advertising BGP RPKI validation state to a peer or peer group· 190
Configuring BGP dedicated routes· 191
About BGP dedicated routes· 191
Configuring basic BGP dedicated route settings· 192
Configuring BGP dedicated route reflection· 192
Resetting BGP sessions in dedicated address family· 193
Displaying and maintaining BGP· 193
Displaying BGP· 193
Resetting BGP sessions· 199
Clearing BGP information· 200
IPv4 BGP configuration examples· 201
Basic BGP configuration example· 201
BGP and IGP route redistribution configuration example· 205
BGP route summarization configuration example· 208
BGP load balancing configuration example· 211
BGP additional path configuration example· 214
BGP community configuration example· 217
BGP route reflector configuration example· 220
BGP confederation configuration example· 222
BGP path selection configuration example· 226
BGP GR configuration example· 229
BFD for BGP configuration example· 231
BGP FRR configuration example· 234
Multicast BGP configuration example· 238
Dynamic BGP peer configuration example· 242
BGP LS configuration example· 244
BGP RPKI configuration example· 246
BGP dedicated routes configuration example· 249
IPv6 BGP configuration examples· 252
IPv6 BGP basic configuration example· 252
IPv6 BGP route reflector configuration example· 256
6PE configuration example· 258
BFD for IPv6 BGP configuration example· 261
IPsec for IPv6 BGP packets configuration example· 265
IPv6 BGP FRR configuration example· 270
IPv6 multicast BGP configuration example· 274
BGP RPKI configuration example· 277
Troubleshooting BGP· 280
Symptom·· 280
Analysis· 280
Solution· 280
Configuring BGP
Overview
Border Gateway Protocol (BGP) is an exterior gateway protocol (EGP). It is called internal BGP (IBGP) when it runs within an AS and called external BGP (EBGP) when it runs between ASs.
The current version in use is BGP-4 (RFC 4271).
BGP has the following characteristics:
·     Focuses on route control and selection rather than route discovery and calculation.
·     Uses TCP to enhance reliability.
·     Measures the distance of a route by using a list of ASs that the route must travel through to reach the destination. BGP is also called a path-vector protocol.
·     Supports CIDR.
·     Reduces bandwidth consumption by advertising only incremental updates. BGP is very suitable to advertise large numbers of routes on the Internet.
·     Eliminates routing loops by adding AS path information to BGP route updates.
·     Uses policies to implement flexible route filtering and selection.
·     Has good scalability.
A router running BGP is a BGP speaker. A BGP speaker establishes peer relationships with other BGP speakers to exchange routing information over TCP connections.
Based on the AS, a BGP peer can be either of the following types:
·     IBGP peer—Resides in the same AS as the local router.
·     EBGP peer—Resides in different ASs from the local router.
Based on the IP version, a BGP peer can be either of the following types:
·     IPv4 peer—Uses an IPv4 address to establish a peer relationship with the local router.
·     IPv6 peer—Uses an IPv6 address to establish a peer relationship with the local router.
BGP message types
BGP uses the following message types:
·     Open—After establishing a TCP connection, BGP sends an Open message to establish a session to the peer.
·     Update—BGP sends update messages to exchange routing information between peers. Each update message can advertise a group of feasible routes with identical attributes and multiple withdrawn routes.
·     Keepalive—BGP sends Keepalive messages between peers to maintain connectivity.
·     Route-refresh—BGP sends a Route-refresh message to request the routing information for a specific address family from a peer.
·     Notification—BGP sends a Notification message upon detecting an error and immediately closes the connection.
BGP path attributes
BGP uses the following path attributes in update messages for route filtering and selection:
·     ORIGIN
The ORIGIN attribute specifies the origin of BGP routes. This attribute has the following types:
¡     IGP—Has the highest priority. Routes generated in the local AS have the IGP attribute.
¡     EGP—Has the second highest priority. Routes obtained through EGP have the EGP attribute.
¡     INCOMPLETE—Has the lowest priority. The source of routes with this attribute is unknown. Routes redistributed from other routing protocols have the INCOMPLETE attribute.
·     AS_PATH
The AS_PATH attribute identifies the ASs through which a route has passed. Before advertising a route to another AS, BGP adds the local AS number into the AS_PATH attribute, so the receiver can determine ASs to route the message back.
The AS_PATH attribute has the following types:
¡     AS_SEQUENCE—Arranges AS numbers in sequence. As shown in Figure 1, the number of the AS closest to the receiver's AS is leftmost.
¡     AS_SET—Arranges AS numbers randomly.
Figure 1 AS_PATH attribute
BGP uses the AS_PATH attribute to implement the following functions:
¡     Avoid routing loops—A BGP router does not receive routes containing the local AS number to avoid routing loops.
¡     Affect route selection—BGP gives priority to the route with the shortest AS_PATH length if other factors are the same. As shown in Figure 1, the BGP router in AS 50 gives priority to the route passing AS 40 for sending data to the destination 8.0.0.0. In some applications, you can apply a routing policy to control BGP route selection by modifying the AS_PATH length. For more information about routing policy, see "Configuring routing policies."
¡     Filter routes—By using an AS path list, you can filter routes based on AS numbers contained in the AS_PATH attribute. For more information about AS path list, see "Configuring routing policies."
·     NEXT_HOP
The NEXT_HOP attribute may not be the IP address of a directly connected router. Its value is determined as follows:
¡     When a BGP speaker advertises a self-originated route to a BGP peer, it sets the address of the sending interface as the NEXT_HOP.
¡     When a BGP speaker sends a received route to an EBGP peer, it sets the address of the sending interface as the NEXT_HOP.
¡     When a BGP speaker sends a route received from an EBGP peer to an IBGP peer, it does not modify the NEXT_HOP attribute. If load balancing is configured, BGP modifies the NEXT_HOP attribute for the equal-cost routes. For load balancing information, see "BGP load balancing."
Figure 2 NEXT_HOP attribute
·     MED (MULTI_EXIT_DISC)
BGP advertises the MED attribute between two neighboring ASs, each of which does not advertise the attribute to any other AS.
Similar to metrics used by IGPs, MED is used to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it considers the route with the smallest MED value as the optimal route. As shown in Figure 3, traffic from AS 10 to AS 20 travels through Router B that is selected according to MED.
Figure 3 MED attribute
Generally BGP only compares MEDs of routes received from the same AS. You can also use the compare-different-as-med command to force BGP to compare MED values of routes received from different ASs.
·     LOCAL_PREF
The LOCAL_PREF attribute is exchanged between IBGP peers only, and is not advertised to any other AS. It indicates the priority of a BGP router.
BGP uses LOCAL_PREF to determine the optimal route for traffic leaving the local AS. When a BGP router obtains multiple routes to the same destination but with different next hops, it considers the route with the highest LOCAL_PREF value as the optimal route. As shown in Figure 4, traffic from AS 20 to AS 10 travels through Router C that is selected according to LOCAL_PREF.
Figure 4 LOCAL_PREF attribute
·     COMMUNITY
The COMMUNITY attribute identifies the community of BGP routes. A BGP community is a group of routes with the same characteristics. It has no geographical boundaries. Routes of different ASs can belong to the same community.
A route can carry one or more COMMUNITY attribute values (each of which is represented by a 4-byte integer). A router uses the COMMUNITY attribute to determine whether to advertise the route and the advertising scope without using complex filters such as ACLs. This mechanism simplifies routing policy configuration, management, and maintenance.
Well-known COMMUNITY attributes involve the following:
¡     INTERNET—By default, all routes belong to the Internet community. Routes with this attribute can be advertised to all BGP peers.
¡     NO_EXPORT—Routes with this attribute cannot be advertised out of the local AS or out of the local confederation, but can be advertised to other sub-ASs in the confederation. For confederation information, see "Settlements for problems in large-scale BGP networks."
¡     No_ADVERTISE—Routes with this attribute cannot be advertised to other BGP peers.
¡     No_EXPORT_SUBCONFED—Routes with this attribute cannot be advertised out of the local AS or other sub-ASs in the local confederation.
You can configure BGP community lists to filter BGP routes based on the BGP COMMUNITY attribute.
·     Extended community attribute
To meet new demands, BGP defines the extended community attribute. The extended community attribute has the following advantages over the COMMUNITY attribute:
¡     Provides more attribute values by extending the attribute length to eight bytes.
¡     Allows for using different types of extended community attributes in different scenarios to enhance route filtering and control and simplify configuration and management.
The device supports the route target and Site of Origin (SoO) extended community attributes. For information about route target, see MPLS Configuration Guide.
The SoO attribute specifies the site where the route originated. It prevents advertising a route back to the originating site. If the AS-path attribute is lost, the router can use the SoO attribute to avoid routing loops.
The SoO attribute has the following formats:
¡     16-bit AS number:32-bit user-defined number. For example, 100:3.
¡     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
¡     32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
BGP route selection
BGP discards routes with unreachable NEXT_HOPs. If multiple routes to the same destination are available, BGP selects the optimal route in the following sequence:
1.     The route with the highest Preferred_value.
2.     The route with the highest LOCAL_PREF.
3.     The route generated by the network command, the route redistributed by the import-route command, or the summary route in turn.
4.     The route with the shortest AS_PATH.
5.     The IGP, EGP, or INCOMPLETE route in turn.
6.     The route with the lowest MED value.
7.     The route learned from EBGP, confederation EBGP, confederation IBGP, or IBGP in turn.
8.     The route with the smallest IGP metric.
9.     The route with the smallest recursion depth.
10.     If a route received from an EBGP peer is the current optimal route, BGP does not change the optimal route when it receives routes from other EBGP peers.
11.     The route advertised by the router with the smallest router ID.
If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routers. Then, BGP selects the route with the smallest ID as the optimal route.
12.     The route with an IPv4 next hop.
13.     The route with the shortest CLUSTER_LIST.
14.     The route advertised by the peer with the lowest IP address.
The CLUSTER_IDs of route reflectors form a CLUSTER_LIST. If a route reflector receives a route that contains its own CLUSTER ID in the CLUSTER_LIST, the router discards the route to avoid routing loops.
If load balancing is configured, the system selects available routes to implement load balancing.
BGP follows these rules for route advertisement:
·     When multiple feasible routes to a destination exist, BGP advertises only the optimal route to its peers. If the advertise-rib-active command is configured, BGP advertises the optimal route in the IP routing table. If not, BGP advertises the optimal route in the BGP routing table.
·     BGP advertises only routes that it uses.
·     BGP advertises routes learned from an EBGP peer to all BGP peers, including both EBGP and IBGP peers.
·     BGP advertises routes learned from an IBGP peer to EBGP peers, rather than other IBGP peers.
·     After establishing a session to a new BGP peer, BGP advertises all the routes matching the above rules to the peer. After that, BGP advertises only incremental updates to the peer.
BGP load balancing
BGP load balancing is applicable between EBGP peers, between IBGP peers, and between confederations.
BGP implements load balancing through route recursion and route selection.
BGP load balancing through route recursion
The next hop of a BGP route might not be directly connected. One of the reasons is that the next hop information exchanged between IBGP peers is not modified. The BGP router must find the directly connected next hop through IGP. The matching route with the direct next hop is called the recursive route. The process of finding a recursive route is route recursion.
If multiple recursive routes to the same destination are load balanced, BGP generates the same number of next hops to forward packets.
BGP load balancing based on route recursion is always enabled in the system.
BGP load balancing through route selection
IGP routing protocols, such as RIP and OSPF, can use route metrics as criteria to load balance between routes that have the same metric. BGP cannot load balance between routes by route metrics as an IGP protocol does, because BGP does not have a route computation algorithm.
BGP uses the following load balancing criteria to determine load balanced routes:
·     The routes have the same ORIGIN, LOCAL_PREF, and MED attributes.
·     The routes meet the following requirements on the AS_PATH attribute:
¡     If the balance as-path-neglect command is configured, the routes can have different AS_PATH attributes.
¡     If only the balance as-path-relax command is configured, the routes can have different AS_PATH attributes, but the length of the AS_PATH attributes must be the same.
¡     If neither the balance as-path-neglect nor the balance as-path-relax command is configured, the routes must have the same AS_PATH attribute.
·     The next hops of the routes meet the following requirements on IGP metrics:
¡     If the bestroute igp-metric-ignore command is not configured, the next hops of the routes must have the same IGP metric value.
¡     If the bestroute igp-metric-ignore command is configured, the next hops of the routes can have different IGP metric values.
·     The routes have the same MPLS label assignment status (labeled or not labeled).
BGP does not use the route selection rules described in "BGP route selection" for load balancing.
As shown in Figure 5, Router A and Router B are IBGP peers of Router C. Router C allows a maximum number of two ECMP routes for load balancing.
Router D and Router E both advertise a route 9.0.0.0 to Router C. Router C installs the two routes to its routing table for load balancing if the routes meet the BGP load balancing criteria. After that, Router C forwards to Router A and Router B a single route whose attributes are changed as follows:
·     AS_PATH attribute:
¡     If the balance as-path-neglect and balance as-path-relax commands are not configured, the AS_PATH attribute does not change.
¡     If the balance as-path-neglect or balance as-path-relax command is configured, the AS_PATH attribute is changed to the attribute of the optimal route.
·     The NEXT_HOP attribute is changed to the IP address of Router C.
·     Other attributes are changed to be the same as the optimal route.
Figure 5 Network diagram
You can use the following methods to facilitate management and improve route distribution efficiency on a large-scale BGP network.
·     Route summarization
Route summarization can reduce the BGP routing table size by advertising summary routes rather than more specific routes.
The system supports both manual and automatic route summarization. Manual route summarization allows you to determine the attribute of a summary route and whether to advertise more specific routes.
·     Route dampening
Route flapping (a route comes up and disappears in the routing table frequently) causes BGP to send many routing updates. It can consume too many resources and affect other operations.
In most cases, BGP runs in complex networks where route changes are more frequent. To solve the problem caused by route flapping, you can use BGP route dampening to suppress unstable routes.
BGP route dampening uses a penalty value to judge the stability of a route. The bigger the value, the less stable the route. Each time a route state changes from reachable to unreachable, or a reachable route's attribute changes, BGP adds a penalty value of 1000 to the route. When the penalty value of the route exceeds the suppress value, the route is suppressed and cannot become the optimal route. When the penalty value reaches the upper limit, no penalty value is added.
If the suppressed route does not flap, its penalty value gradually decreases to half of the suppress value after a period of time. This period is called "Half-life." When the value decreases to the reusable threshold value, the route is usable again.
Figure 6 BGP route dampening
·     Peer group
You can organize BGP peers with the same attributes into a group to simplify their configurations.
When a peer joins the peer group, the peer obtains the same configuration as the peer group. If the configuration of the peer group is changed, the configuration of group members is changed.
·     Community
You can apply a community list or an extended community list to a routing policy for route control. For more information, see "BGP path attributes."
·     Route reflector
IBGP peers must be fully meshed to maintain connectivity. If n routers exist in an AS, the number of IBGP connections is n(n-1)/2. If a large number of IBGP peers exist, large amounts of network and CPU resources are consumed to maintain sessions.
Using route reflectors can solve this issue. In an AS, a router acts as a route reflector, and other routers act as clients connecting to the route reflector. The route reflector forwards routing information received from a client to other clients. In this way, all clients can receive routing information from one another without establishing BGP sessions.
A router that is neither a route reflector nor a client is a non-client, which, as shown in Figure 7, must establish BGP sessions to the route reflector and other non-clients.
Figure 7 Network diagram for a route reflector
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the Cluster_ID. You can configure more than one route reflector in a cluster to improve availability, as shown in Figure 8. The configured route reflectors must have the same Cluster_ID to avoid routing loops.
Figure 8 Network diagram for route reflectors
When the BGP routers in an AS are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use commands to disable route reflection instead of modifying network configuration or changing network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
·     Confederation
Confederation is another method to manage growing IBGP connections in an AS. It splits an AS into multiple sub-ASs. In each sub-AS, IBGP peers are fully meshed. As shown in Figure 9, intra-confederation EBGP connections are established between sub-ASs in AS 200.
Figure 9 Confederation network diagram
A non-confederation BGP speaker does not need to know sub-ASs in the confederation. It considers the confederation as one AS, and the confederation ID as the AS number. In the above figure, AS 200 is the confederation ID.
Confederation has a deficiency. When you change an AS into a confederation, you must reconfigure the routers, and the topology will be changed.
In large-scale BGP networks, you can use both route reflector and confederation.
MP-BGP
BGP-4 can only advertise IPv4 unicast routing information. Multiprotocol Extensions for BGP-4 (MP-BGP) can advertise routing information for the following address families:
·     IPv6 unicast address family.
·     IPv4 multicast and IPv6 multicast address families.
PIM uses static and dynamic unicast routes to perform RPF check before creating multicast routing entries. When the multicast and unicast topologies are different, you can use MP-BGP to advertise the routes for RPF check. MP-BGP stores the routes in the BGP multicast routing table. For more information about PIM and RPF check, see IP Multicast Configuration Guide.
·     VPNv4 and VPNv6 address families.
For more information about VPNv4 and VPNv6, see MPLS Configuration Guide.
·     Labeled IPv4 unicast and IPv6 unicast address families.
MP-BGP advertises IPv4 unicast/IPv6 unicast routes and MPLS labels assigned for the routes. Labeled IPv4 unicast routes apply to inter-AS Option C for MPLS L3VPN. Labeled IPv6 unicast routes apply to 6PE and inter-AS Option C for MPLS L3VPN. For more information about inter-AS Option C, see MPLS Configuration Guide.
·     L2VPN address family.
L2VPN information includes label block information and remote peer information. For more information about L2VPN and VPLS, see MPLS Configuration Guide.
·     EVPN address family.
MP-BGP advertises EVPN routes to implement automatic VTEP discovery, VXLAN tunnel establishment and assignment, and MAC and ARP information advertisement. For more information about EVPN, see EVPN Configuration Guide.
·     IPv4 MDT address family.
MP-BGP advertises MDT information including the PE address and default group so that multicast VPN can create a default MDT that uses the PE as the root on the public network. For more information about multicast VPN, see IP Multicast Configuration Guide.
MP-BGP extended attributes
Prefixes and next hops are key routing information. BGP-4 uses update messages to carry the following information:
·     Feasible route prefixes in the Network Layer Reachability Information (NLRI) field.
·     Unfeasible route prefixes in the withdrawn routes field.
·     Next hops in the NEXT_HOP attribute.
BGP-4 cannot carry routing information for multiple network layer protocols.
To support multiple network layer protocols, MP-BGP defines the following path attributes:
·     MP_REACH_NLRI—Carries feasible route prefixes and next hops for multiple network layer protocols.
·     MP_UNREACH_NLRI—Carries unfeasible route prefixes for multiple network layer protocols.
MP-BGP uses these two attributes to advertise feasible and unfeasible routes for different network layer protocols. BGP speakers not supporting MP-BGP ignore updates containing these attributes and do not forward them to its peers.
Address family
MP-BGP uses address families and subsequent address families to identify different network layer protocols for routes contained in the MP_REACH_NLRI and MP_UNREACH_NLRI attributes. For example, an Address Family Identifier (AFI) of 2 and a Subsequent Address Family Identifier (SAFI) of 1 identify IPv6 unicast routing information carried in the MP_REACH_NLRI attribute. For address family values, see RFC 1700.
Exchanging IPv4 and IPv6 routes in both IPv4 and IPv6 address families
MP-BGP supports IPv4 route exchange between IPv6 peers and IPv6 route exchange between IPv4 peers as follows:
·     When the next hop of an IPv6 route is an IPv4 address, MP-BGP maps the IPv4 address to an IPv6 address encapsulated in the NEXT_HOP attribute of update messages. In this scenario, you must specify a routing policy to change the next hop of the IPv6 route to the IPv6 address of the peer.
·     When the next hop of an IPv4 route is an IPv6 address, BGP negotiates the extended next hop encoding capability with its peer. Then, BGP encapsulates the IPv4 NLRI in the MP_REACH_NLRI attribute of update messages. In this scenario, you must specify a routing policy to change the next hop of the IPv4 route to the IPv4 address of the peer.
Figure 10 Exchanging IPv4 and IPv6 routes in both IPv4 and IPv6 address families
As shown in Figure 10, an IPv6 BGP peer relationship is established between Device A and Device B, between Device B and Device C, and between Device C and Device D. An IPv4 BGP peer relationship is established between Device A and Device B and between Device C and Device D. Device A and Device D can learn both IPv4 and IPv6 routes from each other and traffic is forwarded correctly in both IPv4 and IPv6 address families. For Device C to correctly receive IPv4 routes using the IPv6 address of Device B as the next hop, configure a routing policy on Device C. Use the routing policy to change the next hop of these routes to the IPv4 address of Device B.
BGP multi-instance
A BGP router can run multiple BGP processes. Each BGP process corresponds to a BGP instance. BGP maintains an independent routing table for each BGP instance.
You can create multiple public address families for a BGP instance. However, each public address family (except for IPv4 unicast address family, IPv6 unicast address family, VPNv4 address family, VPNv6 address family, and IPv4 RT-filter address family) can belong to only one BGP instance.
You can create multiple VPN instances for a BGP instance, and each VPN instance can have multiple address families. A VPN instance can belong to only one BGP instance.
The IPv4 and IPv6 multicast address families must belong to the same BGP instance.
Different BGP instances can have the same AS number but cannot have the same name.
BGP uses different views to manage routing information for different BGP instances, address families, and VPN instances. Most BGP commands are available in all BGP views. BGP supports multiple VPN instances by establishing a separate routing table for each VPN instance.
Table 1 describes different BGP configuration views.
Table 1 BGP configuration views
View names
Ways to enter the views
Remarks
BGP instance view
[Sysname-bgp-abc]
You can create a BGP instance and enter its view by specifying the instance keyword in the bgp command.
Configurations in this view apply to all public address families for the specified BGP instance and all VPN instances (such as confederation, GR, and logging configurations), or apply to all public address families for the specified BGP instance.
BGP IPv4 unicast address family view
[Sysname-bgp-abc] address-family ipv4 unicast
[Sysname-bgp-abc-ipv4]
Configurations in this view apply to public IPv4 unicast routes and peers of the specified BGP instance.
BGP IPv6 unicast address family view
[Sysname-bgp-abc] address-family ipv6 unicast
[Sysname-bgp-abc-ipv6]
Configurations in this view apply to public IPv6 unicast routes and peers of the specified BGP instance.
BGP IPv4 multicast address family view
[Sysname-bgp-abc] address-family ipv4 multicast
[Sysname-bgp-abc-mul-ipv4]
Configurations in this view apply to IPv4 multicast routes and peers of the specified BGP instance.
BGP IPv6 multicast address family view
[Sysname-bgp-abc] address-family ipv6 multicast
[Sysname-bgp-abc-mul-ipv6]
Configurations in this view apply to IPv6 multicast routes and peers of the specified BGP instance.
BGP VPNv4 address family view
[Sysname-bgp-abc] address-family vpnv4
[Sysname-bgp-abc-vpnv4]
Configurations in this view apply to VPNv4 routes and peers of the specified BGP instance.
For more information about BGP VPNv4 address family view, see MPLS Configuration Guide.
BGP VPNv6 address family view
[Sysname-bgp-abc] address-family vpnv6
[Sysname-bgp-abc-vpnv6]
Configurations in this view apply to VPNv6 routes and peers of the specified BGP instance.
For more information about BGP VPNv6 address family view, see MPLS Configuration Guide.
BGP L2VPN address family view
[Sysname-bgp-abc] address-family l2vpn
[Sysname-bgp-abc-l2vpn]
Configurations in this view apply to L2VPN information and L2VPN peers of the specified BGP instance.
For more information about BGP L2VPN address family view, see MPLS Configuration Guide.
BGP EVPN address family view
[Sysname-bgp-abc] address-family l2vpn evpn
[Sysname-bgp-abc-evpn]
Configurations in this view apply to EVPN routes and peers of the specified BGP instance.
For more information about BGP EVPN address family view, see EVPN Configuration Guide.
BGP-VPN instance view
[Sysname-bgp-abc] ip vpn-instance vpn1
[Sysname-bgp-abc-vpn1]
Configurations in this view apply to all address families in the specified VPN instance of the specified BGP instance.
BGP-VPN IPv4 unicast address family view
[Sysname-bgp-abc-vpn1] address-family ipv4 unicast
[Sysname-bgp-abc-ipv4-vpn1]
Configurations in this view apply to IPv4 unicast routes and peers in the specified VPN instance of the specified BGP instance.
BGP-VPN IPv6 unicast address family view
[Sysname-bgp-abc-vpn1] address-family ipv6 unicast
[Sysname-bgp-abc-ipv6-vpn1]
Configurations in this view apply to IPv6 unicast routes and peers in the specified VPN instance of the specified BGP instance.
BGP-VPN VPNv4 address family view
[Sysname-bgp-abc-vpn1] address-family vpnv4
[Sysname-bgp-abc-vpnv4-vpn1]
Configurations in this view apply to VPNv4 routes and peers in the specified VPN instance of the specified BGP instance.
For more information about BGP-VPN VPNv4 address family view, see MPLS Configuration Guide.
BGP MDT address family view
[Sysname-bgp-abc] address-family ipv4 mdt
[Sysname-bgp-abc-mdt]
Configurations in this view apply to MDT routes and peers of the specified BGP instance.
For more information about BGP MDT address family view, see IP Multicast Configuration Guide.
BGP LS address family view
[Sysname-bgp-abc] address-family link-state
[Sysname-bgp-abc-ls]
Configurations in this view apply to LS messages and peers of the specified BGP instance.
BGP IPv4 RT filter address family view
[Sysname-bgp-abc] address-family ipv4 rtfilter
[Sysname-bgp-abc-rtf-ipv4]
Configurations in this view apply to IPv4 RT filter routes and peers of the specified BGP instance.
For more information about BGP IPv4 RT filter address family view, see MPLS Configuration Guide.
·     RFC 1700, ASSIGNED NUMBERS
·     RFC 1997, BGP Communities Attribute
·     RFC 2439, BGP Route Flap Damping
·     RFC 2545, Use of BGP-4 Multiprotocol Extensions for IPv6 Inter-Domain Routing
·     RFC 2918, Route Refresh Capability for BGP-4
·     RFC 3107, Carrying Label Information in BGP-4
·     RFC 4271, A Border Gateway Protocol 4 (BGP-4)
·     RFC 4275, BGP-4 MIB Implementation Survey
·     RFC 4277, Experience with the BGP-4 Protocol
·     RFC 4360, BGP Extended Communities Attribute
·     RFC 4364, BGP/MPLS IP Virtual Private Networks (VPNs)
·     RFC 4382, MPLS/BGP Layer 3 Virtual Private Network (VPN) Management
·     RFC 4451, BGP MULTI_EXIT_DISC (MED) Consideration
·     RFC 4456, BGP Route Reflection: An Alternative to Full Mesh Internal BGP
·     RFC 4486, Subcodes for BGP Cease Notification Message
·     RFC 4659, BGP-MPLS IP Virtual Private Network (VPN) Extension for IPv6 VPN
·     RFC 4684, Constrained Route Distribution for Border Gateway Protocol/MultiProtocol Label Switching (BGP/MPLS) Internet Protocol (IP) Virtual Private Networks (VPNs)
·     RFC 4724, Graceful Restart Mechanism for BGP
·     RFC 4760, Multiprotocol Extensions for BGP-4
·     RFC 4781, Graceful Restart Mechanism for BGP with MPLS
·     RFC 5004, Avoid BGP Best Path Transitions from One External to Another
·     RFC 5065, Autonomous System Confederations for BGP
·     RFC 5082, The Generalized TTL Security Mechanism (GTSM)
·     RFC 5291, Outbound Route Filtering Capability for BGP-4
·     RFC 5292, Address-Prefix-Based Outbound Route Filter for BGP-4
·     RFC 5549, Advertising IPv4 Network Layer Reachability Information with an IPv6 Next Hop
·     RFC 5492, Capabilities Advertisement with BGP-4
·     RFC 5668, 4-Octet AS Specific BGP Extended Community
·     RFC 6037, Cisco Systems' Solution for Multicast in BGP MPLS IP VPNs
·     RFC 6198, Requirements for the Graceful Shutdown of BGP Sessions
·     RFC 6368, Internal BGP as the Provider/Customer Edge Protocol for BGP/MPLS IP
·     RFC 6513, Multicast in MPLS/BGP IP VPNs
·     RFC 6514, BGP Encodings and Procedures for Multicast in MPLS/BGP IP VPNs
·     RFC 6515, IPv4 and IPv6 Infrastructure Addresses in BGP Updates for Multicast VPN
·     RFC 6624, Layer 2 Virtual Private Networks Using BGP for Auto-Discovery and Signaling
·     RFC 6793, BGP Support for Four-Octet Autonomous System (AS) Number Space
·     RFC 7432, BGP MPLS-Based Ethernet VPN
·     RFC 7752, North-Bound Distribution of Link-State and Traffic Engineering (TE) Information Using BGP
·     RFC 7854, BGP Monitoring Protocol (BMP)
·     RFC 7911, Advertisement of Multiple Paths in BGP
·     RFC 7947, Internet Exchange BGP Route Server
You can install a license to increase the maximum number of BGP routes supported by the device, if the default settings are not sufficient. For more information about licensing, see Fundamentals Configuration Guide.
On a basic BGP network, perform the following configuration tasks:
·     Enable BGP.
·     Configure BGP peers or peer groups. If you configure a BGP setting at both the peer group and the peer level, the most recent configuration takes effect on the peer.
·     Control BGP route generation.
To control BGP route distribution and path selection, you must perform additional configuration tasks.
To configure BGP, perform the following tasks (IPv4 unicast/IPv4 multicast):
Tasks at a glance
Remarks
Configuring basic BGP:
·     (Required.) Enabling BGP
·     (Required.) Perform one of the following tasks:
¡     Configuring a BGP peer
¡     Configuring dynamic BGP peers
¡     Configuring a BGP peer group
·     (Optional.) Specifying the source address of TCP connections
As a best practice, configure BGP peer groups on large scale BGP networks for easy configuration and maintenance.
Perform at least one of the following tasks to generate BGP routes:
·     Injecting a local network
·     Redistributing IGP routes
·     Redistributing the local network specified in the public instance or a VPN instance
N/A
(Optional.) Controlling route distribution and reception:
·     Configuring BGP route summarization
·     Advertising optimal routes in the IP routing table
·     Advertising a default route to a peer or peer group
·     Enabling prioritized advertisement of default-route withdrawal messages
·     Enabling prioritized withdrawal of specific routes
·     Limiting routes received from a peer or peer group
·     Configuring BGP route filtering policies
·     Setting the BGP route sending rate
·     Configuring BGP to delay sending route updates on reboot
·     Configuring BGP route advertisement delay
·     Configuring a startup policy for BGP route updates
·     Configuring BGP route dampening
BGP cannot advertise optimal routes in the IP routing table for IPv4 multicast address family.
(Optional.) Controlling BGP path selection:
·     Setting a preferred value for routes received
·     Configuring preferences for BGP routes
·     Configuring the default local preference
·     Configuring the MED attribute
·     Configuring the NEXT_HOP attribute
·     Configuring the AS_PATH attribute
·     Ignoring IGP metrics during optimal route selection
·     Ignoring router IDs during optimal route selection
·     Preferring routes with an IPv6 next hop during optimal route selection
·     Configuring the SoO attribute
Only the BGP EVPN address family supports preferring routes with an IPv6 next hop during optimal route selection.
(Optional.) Tuning and optimizing BGP networks:
·     Setting the TCP MSS for TCP connections
·     Configuring the keepalive interval and hold time
·     Setting the session retry timer
·     Configuring the interval for sending updates for the same route
·     Enabling BGP to establish an EBGP session over multiple hops
·     Enabling immediate re-establishment of direct EBGP connections upon link failure
·     Enabling BGP ORF capabilities
·     Enabling 4-byte AS number suppression
·     Enabling MD5 authentication for BGP peers
·     Enabling keychain authentication for BGP peers
·     Configuring BGP load balancing
·     Configuring IPsec for IPv6 BGP
·     Disabling BGP session establishment
·     Configuring GTSM for BGP
·     Configuring BGP soft-reset
·     Configuring the BGP additional path feature
·     Protecting an EBGP peer when memory usage reaches level 2 threshold
·     Configuring an update delay for local MPLS labels
·     Flushing the suboptimal BGP route to the RIB
·     Enabling BGP to not flush specific routes to the routing table
·     Setting a DSCP value for outgoing BGP packets
·     Disabling route recursion policy control for routes received from a peer or peer group
·     Specifying a label allocation mode
·     Disabling optimal route selection for labeled routes without tunnel information
·     Configuring BGP optimal route selection delay
·     Enabling fast host route update upon user migration
·     Enabling conversational remote host route learning
N/A
(Optional.) Configuring a large-scale BGP network:
·     Configuring BGP community
·     Configuring BGP route reflection
·     Configuring a route server
·     Configuring BGP confederation settings
N/A
(Optional.) Configuring BGP GR
N/A
(Optional.) Configuring BGP NSR
N/A
(Optional.) Enabling SNMP notifications for BGP
N/A
(Optional.) Enabling logging for session state changes
N/A
(Optional.) Enabling logging for BGP route flapping
N/A
(Optional.) Configuring BFD for BGP
N/A
(Optional.) Configuring BGP FRR
BGP does not support FRR for IPv4 multicast routes.
(Optional.) Configuring BGP maintenance features
N/A
(Optional.) Configuring 6PE
N/A
(Optional.) Configuring BGP LS
N/A
(Optional.) Configuring BMP
N/A
(Optional.) Configuring BGP RPKI
N/A
(Optional.) Configuring BGP dedicated routes
N/A
To configure BGP, perform the following tasks (IPv6 unicast/IPv6 multicast):
Tasks at a glance
Remarks
N/A
BGP cannot advertise optimal routes in the IP routing table for IPv6 multicast address family.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
BGP does not support FRR for IPv6 multicast routes.
N/A
IPv6 multicast does not support 6PE.
N/A
N/A
N/A
N/A
This section describes the basic settings required for a BGP network to run.
Enabling BGP
A router ID is the unique identifier of a BGP router in an AS.
·     To ensure the uniqueness of a router ID and enhance availability, specify in BGP instance view the IP address of a local loopback interface as the router ID. Different BGP instances can have the same router ID.
·     If no router ID is specified in BGP instance view, the global router ID is used.
·     To modify a non-zero router ID of a BGP instance , use the router-id command in BGP instance view, rather than the router id command in system view.
·     If you specify a router ID in BGP instance view and then remove the interface that owns the router ID, the router does not select a new router ID. To select a new router ID, use the undo router-id command in BGP instance view.
To enable BGP:
Step
Remarks
N/A
2.     Configure a global router ID.
router id router-id
By default, no global router ID is configured, and BGP uses the highest loopback interface IP address—if any—as the router ID. If no loopback interface IP address is available, BGP uses the highest physical interface IP address as the route ID regardless of the interface status.
3.     Enable BGP and enter BGP instance view.
By default, BGP is disabled and no BGP instances exist.
4.     (Optional.) Configure an SNMP context for the BGP instance.
By default, no SNMP context is configured for a BGP instance.
5.     (Optional.) Configure a router ID for the BGP instance.
router-id router-id
By default, no router ID is configured for a BGP instance, and the BGP instance uses the global router ID configured by the router-id command in system view.
6.     (Optional.) Enter BGP-VPN instance view.
The specified VPN instance must have been created and have an RD. For more information about VPN instances, see MPLS Configuration Guide.
7.     (Optional.) Configure a router ID for the BGP VPN instance.
By default, no router ID is configured for a BGP VPN instance, and the BGP VPN instance uses the router ID configured in BGP instance view. If no router ID is configured in BGP instance view, the BGP VPN instance uses the global router ID configured in system view.
You can configure BGP peers for the local device by using one of the following methods:
·     Specify a BGP peer by its global unicast address.
·     Specify a BGP peer by its link-local address. A BGP peer at an IPv6 link-local address must be directly connected to the local router. If you do not specify the interface connected to the peer, you must specify the interface directly connected to the BGP peer as the source interface of TCP connections on the local router.
·     Specify a local interface and establish peer relationships with link-local addresses that the interface learned in ND entries.
To exchange IPv4 routes with an IPv6 peer or exchange IPv6 routes with an IPv4 peer, you must configure a routing policy to perform the following tasks:
·     Change the next hop of IPv4 routes received from the IPv6 peer to the IPv4 address of the interface that connects the IPv6 peer to the local router.
·     Change the next hop of IPv6 routes received from the IPv4 peer to the IPv6 address of the interface that connects the IPv4 peer to the local router.
Configuring a BGP peer (exchanging IPv4 unicast routes with IPv4 peers)
Step
Remarks
N/A
2.     Enter BGP instance view or BGP-VPN instance view.
·     Enter BGP instance view:
·     Enter BGP-VPN instance view:
a.     bgp as-number [ instance instance-name ]
b.     ip vpn-instance vpn-instance-name
N/A
3.     Create an IPv4 BGP peer and specify its AS number.
By default, no IPv4 BGP peers exist.
4.     (Optional.) Configure a description for a peer.
By default, no description is configured for a peer.
5.     Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
By default, no BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family exists.
6.     Enable the router to exchange IPv4 unicast routing information with the specified peer.
peer ipv4-address enable
By default, the router cannot exchange IPv4 unicast routing information with the peer.
Configuring a BGP peer (exchanging IPv6 unicast routes with IPv4 peers)
Step
Remarks
N/A
N/A
By default, no IPv4 peers exist.
4.     (Optional.) Configure a description for the IPv4 peer.
By default, no description is configured for an IPv4 peer.
5.     Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
By default, the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family does not exist.
6.     Enable BGP to exchange IPv6 unicast routing information with the IPv4 peer.
By default, BGP cannot exchange IPv6 unicast routing information with an IPv4 peer.
7.     Use a routing policy to modify the next hop of routes received from the IPv4 peer.
peer ipv4-address route-policy route-policy-name import
N/A
Configuring a BGP peer (exchanging IPv6 unicast routes with IPv6 peers)
Step
Remarks
N/A
N/A
3.     Create an IPv6 BGP peer and specify its AS number.
peer { ipv6-address | link-local-address interface interface-type interface-number } as-number as-number
By default, no IPv6 BGP peers exist.
peer { ipv6-address | link-local-address interface interface-type interface-number } description text
By default, no BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family exists.
6.     Enable the router to exchange IPv6 unicast routing information with the specified peer.
peer { ipv6-address | link-local-address interface interface-type interface-number } enable
By default, the router cannot exchange IPv6 unicast routing information with the peer.
Configuring a BGP peer (exchanging IPv6 unicast routes with IPv6 peers created by specifying an interface)
Step
Remarks
N/A
N/A
3.     Create peer relationships with link-local addresses that the specified interface learned in ND entries, and specify an AS number for the peers.
interface-peer interface-type interface-number as-number as-number
interface-peer interface-type interface-number description text
interface-peer interface-type interface-number enable
Configuring a BGP peer (exchanging IPv4 unicast routes with IPv6 peers)
Step
Remarks
N/A
N/A
By default, no IPv6 peers exist.
4.     (Optional.) Configure a description for the IPv6 peer.
By default, no description is configured for an IPv6 peer.
By default, the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family does not exist.
6.     Enable BGP to exchange IPv4 unicast routing information with the IPv6 peer.
peer ipv6-address enable
By default, BGP cannot exchange IPv4 unicast routing information with an IPv6 peer.
7.     Use a routing policy to modify the next hop of routes received from the IPv6 peer.
peer ipv6-address route-policy route-policy-name import
N/A
Configuring a BGP peer (exchanging IPv4 unicast routes with IPv6 peers created by specifying an interface)
Step
Remarks
N/A
N/A
interface-peer interface-type interface-number route-policy route-policy-name import
N/A
Configuring a BGP peer (exchanging IPv4 multicast routes with IPv4 peers)
Step
Remarks
N/A
N/A
4.     (Optional.) Configure a description for the peer.
5.     Create the BGP IPv4 multicast address family and enter its view.
By default, no BGP IPv4 multicast address family exists.
6.     Enable the router to exchange IPv4 unicast routing information used for RPF check with the specified peer.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peer.
Configuring a BGP peer (exchanging IPv6 multicast routes with IPv6 peers)
Step
Remarks
N/A
N/A
peer { ipv6-address prefix-length | link-local-address interface interface-type interface-number } as-number as-number
peer { ipv6-address prefix-length | link-local-address interface interface-type interface-number } description text
5.     Create the BGP IPv6 multicast address family and enter its view.
By default, no BGP IPv6 multicast address family exist.
6.     Enable the router to exchange IPv6 unicast routing information used for RPF check with the specified peer.
peer { ipv6-address prefix-length | link-local-address interface interface-type interface-number } enable
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peer.
This feature enables BGP to establish dynamic BGP peer relationships with devices in a network. BGP accepts connection requests from the network but it does not initiate connection requests to the network.
After a device in the network initiates a connection request, BGP establishes a dynamic peer relationship with the device.
If multiple BGP peers reside in the same network, you can use this feature to simplify BGP peer configuration.
For a remote device to establish a peer relationship with the local device, you must specify the IP address of the local device on the remote device.
Configuring dynamic BGP peers (exchanging IPv4 unicast routes with dynamic IPv4 peers)
Step
Remarks
N/A
N/A
3.     Specify devices in a network as dynamic BGP peers and specify an AS number for the peers.
By default, no dynamic BGP peers exist.
4.     (Optional.) Configure a description for dynamic BGP peers.
By default, no description is configured for dynamic BGP peers.
6.     Enable BGP to exchange IPv4 unicast routing information with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv4 unicast routing information with dynamic BGP peers.
Configuring dynamic BGP peers (exchanging IPv6 unicast routes with dynamic IPv4 peers)
Step
Remarks
N/A
N/A
3.     Specify devices in an IPv4 network as dynamic IPv4 BGP peers and specify an AS number for the peers.
By default, no dynamic IPv4 BGP peers exist.
4.     (Optional.) Configure a description for the dynamic IPv4 peers.
By default, no description is configured for dynamic IPv4 peers.
5.     Create the BGP IPv6 unicast address family and enter its view.
By default, the BGP IPv6 unicast address family does not exist.
6.     Enable BGP to exchange IPv6 unicast routing information with the dynamic IPv4 peers.
By default, BGP cannot exchange IPv6 unicast routing information with dynamic IPv4 peers.
7.     Use a routing policy to modify the next hop of routes received from the dynamic IPv4 peers.
peer ipv4-address mask-length route-policy route-policy-name import
N/A
Configuring dynamic BGP peers (exchanging IPv6 unicast routes with dynamic IPv6 peers)
Step
Remarks
N/A
N/A
6.     Enable BGP to exchange IPv6 unicast routing information with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv6 unicast routing information with dynamic BGP peers.
Configuring dynamic BGP peers (exchanging IPv4 unicast routes with dynamic IPv6 peers)
Step
Remarks
N/A
N/A
3.     Specify devices in an IPv6 network as dynamic IPv6 BGP peers and specify an AS number for the peers.
peer ipv6-address mask-length as-number as-number
By default, no dynamic IPv6 BGP peers exist.
4.     (Optional.) Configure a description for the dynamic IPv6 peers.
peer ipv6-address mask-length description text
By default, no description is configured for dynamic IPv6 peers.
5.     Create the BGP IPv4 unicast address family and enter its view.
By default, the BGP IPv4 unicast address family does not exist.
6.     Enable BGP to exchange IPv4 unicast routing information with the dynamic IPv6 peers.
peer ipv6-address mask-length enable
By default, BGP cannot exchange IPv4 unicast routing information with dynamic IPv6 peers.
7.     Use a routing policy to modify the next hop of routes received from the dynamic IPv6 peers.
peer ipv6-address mask-length route-policy route-policy-name import
N/A
Configuring dynamic BGP peers (exchanging IPv4 multicast routes with dynamic IPv4 peers)
Step
Remarks
N/A
N/A
6.     Enable BGP to exchange IPv4 unicast routing information used for RPF check with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv4 unicast routing information used for RPF check with dynamic BGP peers.
Configuring dynamic BGP peers (exchanging IPv6 multicast routes with dynamic IPv6 peers)
Step
Remarks
N/A
N/A
By default, no BGP IPv6 multicast address family exists.
6.     Enable BGP to exchange IPv6 unicast routing information used for RPF check with dynamic BGP peers in the specified network.
By default, BGP cannot exchange IPv6 unicast routing information used for RPF check with dynamic BGP peers.
The peers in a peer group use the same route selection policy.
In a large-scale network, many peers can use the same route selection policy. You can configure a peer group and add these peers into this group. When you change the policy for the group, the modification also applies to the peers in the group.
A peer group is an IBGP peer group if peers in it belong to the local AS, and is an EBGP peer group if peers in it belong to different ASs.
Configuring an IBGP peer group
After you create an IBGP peer group and then add a peer into it, the system creates the peer in BGP instance view and specifies the local AS number for the peer.
To configure an IBGP peer group (exchange IPv4 unicast routes with IPv4 peers):
Step
Remarks
N/A
N/A
3.     Create an IBGP peer group.
group group-name [ internal ]
By default, no IBGP peer groups exist.
4.     Add a peer into the IBGP peer group.
By default, no peer exists in the peer group.
The as-number as-number option must specify the local AS number.
5.     (Optional.) Configure a description for the peer group.
By default, no description is configured for the peer group.
6.     Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
7.     Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
peer group-name enable
By default, the router cannot exchange IPv4 unicast routing information with the peers.
To configure an IBGP peer group (exchange IPv6 unicast routes with IPv4 peers):
Step
Remarks
N/A
N/A
By default, no peer groups exist.
4.     Add an IPv4 peer into the IBGP peer group.
By default, no peers exist in a peer group.
By default, no description is configured for a peer group.
6.     Create the BGP IPv6 unicast address family and enter its view.
7.     Enable BGP to exchange IPv6 unicast routing information with peers in the peer group.
By default, BGP cannot exchange IPv6 unicast routing information with peers in a peer group.
8.     Use a routing policy to modify the next hop of routes received from peers in the peer group.
peer group-name route-policy route-policy-name import
N/A
To configure an IBGP peer group (exchange IPv6 unicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
4.     Add a peer into the IBGP peer group. Choose the options to configure as needed:
·     Specify a peer by its address.
peer { ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } group group-name [ as-number as-number ]
·     Specify peers established through link-local addresses that the specified interface learned in ND entries.
interface-peer interface-type interface-number group group-name [ as-number as-number ]
6.     Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
7.     Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information with the peers.
To configure an IBGP peer group (exchange IPv4 unicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
4.     Add an IPv6 peer into the IBGP peer group. Choose the options to configure as needed:
·     Specify peers that are established through link-local addresses that the specified interface learned in ND entries.
7.     Enable BGP to exchange IPv4 unicast routing information with peers in the peer group.
By default, BGP cannot exchange IPv4 unicast routing information with peers in a peer group.
N/A
To configure an IBGP peer group (exchange IPv4 multicast routes with IPv4 peers):
Step
Remarks
N/A
N/A
6.     Create the BGP IPv4 multicast address family and enter its view.
7.     Enable the router to exchange IPv4 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers in the peer group.
To configure an IBGP peer group (exchange IPv6 multicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
6.     Create the BGP IPv6 multicast address family and enter its view.
7.     Enable the router to exchange IPv6 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peers in the peer group.
Configuring an EBGP peer group
If peers in an EBGP group belong to the same external AS, the EBGP peer group is a pure EBGP peer group. If not, it is a mixed EBGP peer group.
Use one of the following methods to configure an EBGP peer group:
·     Method 1—Create an EBGP peer group, specify its AS number, and add peers into it. All the added peers have the same AS number. All peers in the peer group have the same AS number as the peer group. You can specify an AS number for a peer before adding it into the peer group. The AS number must be the same as that of the peer group.
·     Method 2—Create an EBGP peer group, specify an AS number for a peer, and add the peer into the peer group. Peers added in the group can have different AS numbers.
·     Method 3—Create an EBGP peer group and add a peer with an AS number into it. Peers added in the group can have different AS numbers.
To configure an EBGP peer group by using Method 1 (exchange IPv4 unicast routes with IPv4 peers):
Step
Remarks
N/A
N/A
3.     Create an EBGP peer group.
group group-name external
By default, no EBGP peer groups exist.
4.     Specify the AS number of the group.
By default, no AS number is specified.
If a peer group contains peers, you cannot remove or change its AS number.
5.     Add a peer into the EBGP peer group.
By default, no peers exist in the peer group.
The as-number as-number option, if used, must specify the same AS number as the peer group-name as-number as-number command.
6.     (Optional.) Configure a description for the peer group.
7.     Create the BGP IPv4 unicast address family or BGP-VPN IPv4 unicast address family and enter its view.
8.     Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
To configure an EBGP peer group by using Method 1 (exchange IPv6 unicast routes with IPv4 peers):
Step
Remarks
N/A
N/A
4.     Specify an AS number for the peer group.
By default, no AS number is specified for a peer group.
5.     Add an IPv4 peer into the EBGP peer group.
The as-number as-number option must specify the same AS number as the peer group-name as-number as-number command.
7.     Create the BGP IPv6 unicast address family or BGP-VPN IPv6 unicast address family and enter its view.
8.     Enable BGP to exchange IPv6 unicast routing information with peers in the peer group.
9.     Use a routing policy to modify the next hop of routes received from peers in the peer group.
N/A
To configure an EBGP peer group by using Method 1 (exchange IPv6 unicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
5.     Add a peer into the EBGP peer group. Choose the options to configure as needed:
8.     Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
To configure an EBGP peer group by using Method 1 (exchange IPv4 unicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
5.     Add an IPv6 peer into the EBGP peer group. Choose the options to configure as needed:
7.     Create the BGP IPv4 unicast address family and enter its view.
8.     Enable BGP to exchange IPv4 unicast routing information with peers in the peer group.
N/A
To configure an EBGP peer group by using Method 1 (exchange IPv4 multicast routes with IPv4 peers ):
Step
Remarks
N/A
N/A
5.     Add an IPv4 BGP peer into the EBGP peer group.
7.     Create the BGP IPv4 multicast address family and enter its view.
8.     Enable the router to exchange IPv4 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers in the group.
To configure an EBGP peer group by using Method 1 (exchange IPv6 multicast routes with IPv6 peers ):
Step
Remarks
N/A
N/A
5.     Add an IPv6 BGP peer into the EBGP peer group.
7.     Create the BGP IPv6 multicast address family and enter its view.
8.     Enable the router to exchange IPv6 unicast routing information used for RPF check with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information used for RPF check with the peers in the group.
To configure an EBGP peer group by using Method 2 (exchange IPv4 unicast routes with IPv4 peers ):
Step
Remarks
N/A
N/A
4.     Create an IPv4 BGP peer and specify its AS number.
5.     Add the peer into the EBGP peer group.
The as-number as-number option, if used, must specify the same AS number as the peer ipv4-address [ mask-length ] as-number as-number command.
To configure an EBGP peer group by using Method 2 (exchange IPv6 unicast routes with IPv4 peers):
Step
Remarks
N/A
N/A
5.     Add the IPv4 peer into the EBGP peer group.
The as-number as-number option must specify the same AS number as the peer ipv4-address [ mask-length ] as-number as-number command.
N/A
To configure an EBGP peer group by using Method 2 (exchange IPv6 unicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
4.     Create an IPv6 BGP peer and specify its AS number.
peer { ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } as-number as-number
·     Specify a peer by its directly connected interface. The address of the peer is the link-local address on an ND entry learned by the interface.
5.     Add the peer into the EBGP peer group. Choose the options to configure as needed:
The as-number as-number option must specify the same AS number as the interface-peer interface-type interface-number as-number as-number command.
To configure an EBGP peer group by using Method 2 (exchange IPv4 unicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
4.     Create an IPv6 BGP peer and specify its AS number. Choose the options to configure as needed:
peer ipv6-address [ prefix-length ] as-number as-number
5.     Add the IPv6 peer into the EBGP peer group. Choose the options to configure based on the configuration of the above step:
peer
N/A
To configure an EBGP peer group by using Method 2 (exchange IPv4 multicast routes with IPv4 peers):
Step
Remarks
N/A
N/A
To configure an EBGP peer group by using Method 2 (exchange IPv6 multicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
The as-number as-number option, if used, must specify the same AS number as the peer ipv6-address [ prefix-length ] as-number as-number command.
To configure an EBGP peer group by using Method 3 (exchange IPv4 unicast routes with IPv4 peers ):
Step
Remarks
N/A
N/A
4.     Add a peer into the EBGP peer group.
To configure an EBGP peer group by using Method 3 (exchange IPv6 unicast routes with IPv4 peers):
Step
Remarks
N/A
N/A
4.     Add an IPv4 peer into the EBGP peer group.
N/A
To configure an EBGP peer group by using Method 3 (exchange IPv6 unicast routes with IPv6 peers ):
Step
Remarks
N/A
N/A
4.     Add a peer into the EBGP peer group. Choose the options to configure as needed:
peer { ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } group group-name as-number as-number
To configure an EBGP peer group by using Method 3 (exchange IPv4 unicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
4.     Add an IPv6 peer into the EBGP peer group. Choose the options to configure as needed:
interface-peer interface-type interface-number group group-name as-number as-number
N/A
To configure an EBGP peer group by using Method 3 (exchange IPv4 multicast routes with IPv4 peers):
Step
Remarks
N/A
N/A
4.     Add an IPv4 BGP peer into the EBGP peer group.
By default, the router cannot exchange IPv4 unicast routing information used for RPF check with the peers.
To configure an EBGP peer group by using Method 3 (exchange IPv6 multicast routes with IPv6 peers):
Step
Remarks
N/A
N/A
4.     Add an IPv6 BGP peer into the EBGP peer group.
By default, BGP uses the primary IPv4/IPv6 address of the output interface in the optimal route to a peer or peer group as the source address of TCP connections to the peer or peer group. You can change the source address in the following scenarios:
·     If the peer's IPv4/IPv6 address belongs to an interface indirectly connected to the local router, specify that interface as the source interface for TCP connections on the peer. For example, interface A on the local end is directly connected to interface B on the peer. If you use the peer x.x.x.x as-number as-number command on the local end, and x.x.x.x is not the IPv4 address of interface B, you must do the following:
a.     Use the peer connect-interface command on the peer.
b.     Specify the interface whose IPv4 address is x.x.x.x as the source interface.
·     A BGP peer at an IPv6 link-local address must be directly connected to the local router. If you do not specify the interface connected to the peer, you must specify the interface directly connected to the BGP peer as the source interface of TCP connections on the local router.
·     If the source interface fails on a BGP router that has multiple links to a peer, BGP must re-establish TCP connections. To avoid this problem, use a loopback interface as the source interface or use the IP address of a loopback interface as the source address.
·     If the BGP sessions use the IP addresses of different interfaces, specify a source address or source interface for each peer to establish multiple BGP sessions to a router. Specify a source address for each peer if the BGP sessions use the different addresses of the same interface. Otherwise, the local BGP router might fail to establish a TCP connection to a peer when it uses the optimal route to determine the source address.
BGP immediately tears down the session to an IBGP peer or peer group when the following conditions exist:
·     The source interface of TCP connections to the IBGP peer or peer group is a physical interface.
·     The source interface fails and the link to the IBGP peer or peer group goes down.
To specify the source address of TCP connections (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Specify the source address of TCP connections to a peer or peer group.
By default, BGP uses the primary IPv4 address of the output interface in the optimal route to a peer or peer group as the source address of TCP connections to the peer or peer group.
4.     Specify the source interface of TCP connections to a peer or peer group.
To specify the source address of TCP connections (IPv6 peers):
Step
Remarks
N/A
N/A
3.     Specify the source IPv6 address of TCP connections to a peer or peer group.
By default, BGP uses the IPv6 address of the output interface in the optimal route to the BGP peer or peer group as the source address of TCP connections to the peer or peer group.
Generating BGP routes
BGP can generate routes in the following ways:
·     Advertise local networks.
·     Redistribute IGP routes.
Perform this task to inject a network in the local routing table to the BGP routing table, so BGP can advertise the network to BGP peers. The ORIGIN attribute of BGP routes advertised in this way is IGP. You can also use a routing policy to control route advertisement.
The specified network must be available and active in the local IP routing table.
To inject a local network (IPv4 unicast/multicast address family):
Step
Remarks
N/A
2.     Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
·     Enter BGP IPv4 unicast address family view:
b.     address-family ipv4 [ unicast ]
·     Enter BGP-VPN IPv4 unicast address family view:
c.     address-family ipv4 [ unicast ]
·     Enter BGP IPv4 multicast address family view:
b.     address-family ipv4 multicast
N/A
3.     Configure BGP to advertise a local network.
By default, BGP does not advertise local networks.
To inject a local network (IPv6 unicast/multicast address family):
Step
Remarks
N/A
2.     Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
·     Enter BGP IPv6 unicast address family view:
b.     address-family ipv6 [ unicast ]
·     Enter BGP-VPN IPv6 unicast address family view:
c.     address-family ipv6 [ unicast ]
·     Enter BGP IPv6 multicast address family view:
b.     address-family ipv6 multicast
N/A
Perform this task to configure route redistribution from an IGP to BGP.
By default, BGP does not redistribute default IGP routes. You can use the default-route imported command to redistribute default IGP routes into the BGP routing table.
Only active routes can be redistributed. To view route state information, use the display ip routing-table protocol or display ipv6 routing-table protocol command.
The ORIGIN attribute of BGP routes redistributed from IGPs is INCOMPLETE.
To configure BGP to redistribute IGP routes (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Enable route redistribution from the specified IGP into BGP.
·     Redistributes IS-IS, OSPF, or RIP routes:
import-route
{ isis | ospf | rip } [ { process-id | all-processes } [ allow-direct | med med-value | route-policy route-policy-name ] * ]
·     Redistributes direct or static routes:
import-route { direct | static } [ med med-value | route-policy route-policy-name ] *
By default, BGP does not redistribute IGP routes.
4.     (Optional.) Redistribute all routes with the same destination address.
import-route multipath
This command is not supported in BGP IPv4 multicast address family view.
By default, BGP redistributes only the optimal routes to its routing table when multiple routes with the same destination address exist.
This command takes effect only on the routes redistributed by the import-route command in the same address family.
5.     (Optional.) Enable default route redistribution into BGP.
By default, BGP does not redistribute default routes.
To configure BGP to redistribute IGP routes (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     Redistributes IPv6 IS-IS, OSPFv3, or RIPng routes:
This command is not supported in BGP IPv6 multicast address family view.
Perform this task to redistribute the local network specified in the public instance or a VPN instance to the BGP routing table, so BGP can advertise the network. The ORIGIN attribute is IGP for BGP routes advertised in this way.
The local network must exist and be active in the routing table of the public instance or VPN instance.
To redistribute the local network specified in the public instance or a VPN instance:
Step
Remarks
N/A
2.     Enter public instance IPv4 address family view or VPN instance IPv4 address family view.
·     Enter public instance IPv4 address family view:
a.     ip public-instance
·     Enter VPN instance IPv4 address family view:
a.     ip vpn-instance vpn-instance-name
N/A
3.     Specify a local network in the public instance or VPN instance.
By default, no local network is specified in the public instance or VPN instance.
For more information about this command, see MPLS L3VPN in MPLS Command Reference.
4.     Return to system view.
Execute the quit command twice to return to system view.
5.     Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view
N/A
6.     Redistribute the local network specified in the public instance or VPN instance.
import-route local-aggregate [ route-policy route-policy-name ]
By default, BGP does not redistribute the local network specified in the public instance or any VPN instances.
This section describes how to control route distribution and reception.
Route summarization can reduce the number of redistributed routes and the routing table size. IPv4 BGP supports automatic route summarization and manual route summarization. Manual summarization takes precedence over automatic summarization. IPv6 BGP supports only manual route summarization.
The output interface of a BGP summary route is Null 0 on the originating router. Therefore, a summary route must not be an optimal route on the originating router. Otherwise, BGP will fail to forward packets matching the route. If a summarized specific route has the same mask as the summary route, but has a lower priority, the summary route becomes the optimal route. To ensure correct packet forwarding, change the priority of the summary or specific route to make the specific route the optimal route.
Configuring automatic route summarization
Automatic route summarization enables BGP to summarize IGP subnet routes redistributed by the import-route command so BGP advertises only natural network routes.
To configure automatic route summarization (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Configure automatic route summarization.
summary automatic
By default, automatic route summarization is not configured.
Configuring manual route summarization
By configuring manual route summarization, you can do the following:
·     Summarize both redistributed routes and routes injected using the network command.
·     Determine the mask length for a summary route.
To configure BGP manual route summarization (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Create a summary route in the BGP routing table.
By default, no summary routes are configured.
To configure BGP manual route summarization (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Create a summary route in the IPv6 BGP routing table.
By default, BGP advertises optimal routes in the BGP routing table, which may not be optimal in the IP routing table. This task allows you to advertise BGP routes that are optimal in the IP routing table.
To enable BGP to advertise optimal routes in the IP routing table (IPv4 unicast):
Step
Remarks
N/A
N/A
3.     Enable BGP to advertise optimal routes in the IP routing table.
advertise-rib-active
By default, BGP advertises optimal routes in the BGP routing table.
4.     Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
N/A
5.     Enable BGP to advertise optimal routes in the IP routing table of the address family in the VPN instance.
By default, the setting is the same as that in BGP instance view.
To enable BGP to advertise optimal routes in the IPv6 routing table (IPv6 unicast):
Step
Remarks
N/A
N/A
3.     Enable BGP to advertise optimal routes in the IPv6 routing table.
4.     Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
N/A
5.     Enable BGP to advertise optimal routes in the IPv6 routing table of the address family in the VPN instance.
Perform this task to advertise a default BGP route with the next hop being the advertising router to a peer or peer group.
To advertise a default route to a peer or peer group (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Advertise a default route to a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-route-advertise [ route-policy route-policy-name ]
·     interface-peer interface-type interface-number default-route-advertise [ route-policy route-policy-name ]
By default, no default route is advertised.
The ipv6-address [ prefix-length ] argument and the interface-peer command are not supported in BGP IPv4 multicast address family view.
To advertise a default route to a peer or peer group (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } default-route-advertise [ route-policy route-policy-name ]
The ipv4-address [ mask-length ] and link-local-address interface interface-type interface-number options and the interface-peer command are not supported in BGP IPv6 multicast address family view.
Typically a BGP router does not send withdrawal messages of the default route prior to other routes to its peers. If the peer relationship is down, the default route cannot be withdrawn first. Traffic interruption might occur. Perform this task to configure BGP to send the withdrawal messages of the default route prior to other routes. This can reduce the traffic interruption time when the peer relationship is down.
To enable prioritized advertisement of default-route withdrawal messages:
Step
Remarks
N/A
N/A
3.     Enable prioritized advertisement of default-route withdrawal messages.
default-route update-first
Perform this task to configure BGP to send the withdrawal messages of the specified routes prior to other routes. This can achieve fast route switchover and reduce the traffic interruption time.
To enable prioritized withdrawal of specific routes (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Enable prioritized withdrawal of specific routes.
To enable prioritized withdrawal of specific routes (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
This feature can prevent attacks that send a large number of BGP routes to the router.
If the number of routes received from a peer or peer group exceeds the upper limit, the router takes one of the following actions based on your configuration:
·     Tears down the BGP session to the peer or peer group and does not attempt to re-establish the session.
·     Continues to receive routes from the peer or peer group and generates a log message.
·     Retains the session to the peer or peer group, but it discards excess routes and generates a log message.
·     Tears down the BGP session to the peer or peer group and, after a specific period of time, re-establishes a BGP session to the peer or peer group.
You can specify a percentage threshold for the router to generate a log message. When the ratio of the number of received routes to the maximum number reaches the percentage value, the router generates a log message.
To limit routes that a router can receive from a peer or peer group (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Specify the maximum number of routes that a router can receive from a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
·     interface-peer interface-type interface-number route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
By default, the number of routes that a router can receive from a peer or peer group is not limited.
To limit routes that a router can receive from a peer or peer group (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-limit prefix-number [ { alert-only | discard | reconnect reconnect-time } | percentage-value ] *
When you specify an ACL, prefix list, or routing policy as a filtering policy to filter BGP routing information, follow these guidelines:
·     If the specified ACL, prefix list, or routing policy does not exist, all BGP routes can pass the filtering policy.
·     When you specify an ACL or prefix list as a BGP route filtering policy (for example, use the filter-policy export command to specify an ACL for route filtering), the following rules apply:
¡     BGP routes can pass the filtering policy only when one of the following conditions exists:
-     They match a permit rule in the specified ACL.
-     They match a permit item in the specified prefix list.
When the ACL has only deny rules or the prefix list has only deny items, no BGP routes can pass the filtering policy.
¡     When the ACL match order is config, BGP routes match against rules in ascending order of rule ID. When BGP routes match against the items of the prefix list, an item with a smaller index number is matched first.
In either of the match modes above, a BGP route does not match against the next ACL rule or prefix list item when it already matches the current ACL rule or prefix list item. To avoid wasting filter resources, set a small match range for each ACL rule or prefix list item when you configure multiple ACL rules or prefix list items for an ACL or prefix list.
¡     You can use the rule [ rule-id ] permit ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to create a rule for an advanced ACL to match specific routes. The source sour-addr option represents the destination network address and the destination dest-addr option represents the mask in dotted decimal notation. For example, to match route 3.3.3.0/24, the rule configuration should be rule [ rule-id ] permit ip source 3.3.3.0 0.0.0.255 destination 255.255.255.0 0.0.0.255.
·     When you specify a routing policy as a BGP route filtering policy, the following rules apply:
¡     BGP routes can pass the filtering policy only when they match a permit node in the routing policy.
¡     A BGP route matches against the nodes of the routing policy in ascending order of node number. It does not match against the next node when it already matches the current node (unless a continue clause exists).
¡     When a BGP route matches against a node that has an ACL or prefix-list if-match clause, it can pass the filtering policy only when the following conditions exist:
i     The route matches a permit rule in the ACL or a permit item in the prefix list.
ii     The route matches a permit node in the routing policy.
Configuration prerequisites
Before you configure BGP routing filtering policies, configure the following filters used for route filtering as needed:
·     ACL (see ACL and QoS Configuration Guide).
·     Prefix list (see "Configuring routing policies").
·     Routing policy (see "Configuring routing policies").
·     AS path list (see "Configuring routing policies").
Configuring BGP route distribution filtering policies
To configure BGP route distribution filtering policies, use the following methods:
·     Use an ACL or prefix list to filter routing information advertised to all peers.
·     Use a routing policy, conditional advertisement policy (existent policy or nonexistent policy), ACL, AS path list, or prefix list to filter routing information advertised to a peer or peer group.
If you configure multiple filtering policies, apply them in the following sequence:
1.     peer prefix-list export
2.     peer as-path-acl export
3.     filter-policy export
4.     peer filter-policy export
5.     peer advertise-policy exist-policy
6.     peer advertise-policy non-exist-policy
7.     peer route-policy export
Only routes passing all the configured policies can be advertised.
To configure BGP route distribution filtering policies (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Configure BGP route distribution filtering policies. Choose the options to configure as needed:
·     Reference an ACL or IP prefix list to filter advertised BGP routes:
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list ipv4-prefix-list-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ]
·     Specify a routing policy as the existent policy to control route advertisement. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-policy advertise-policy-name exist-policy exist-policy-name
¡     interface-peer interface-type interface-number advertise-policy advertise-policy-name exist-policy exist-policy-name
·     Specify a routing policy as the nonexistent policy to control route advertisement. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-policy advertise-policy-name non-exist-policy non-exist-policy-name
¡     interface-peer interface-type interface-number advertise-policy advertise-policy-name non-exist-policy non-exist-policy-name
·     Reference a routing policy to filter BGP routes advertised to a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name export
¡     interface-peer interface-type interface-number route-policy route-policy-name export
·     Reference an ACL to filter BGP routes advertised to a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv4-acl-number | name ipv4-acl-name } export
¡     interface-peer interface-type interface-number filter-policy { ipv4-acl-number | name ipv4-acl-name } export
·     Reference an AS path list to filter BGP routes advertised to a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } export
¡     interface-peer interface-type interface-number as-path-acl { as-path-acl-number | as-path-acl-name } export
·     Reference an IPv4 prefix list to filter BGP routes advertised to a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name export
¡     interface-peer interface-type interface-number prefix-list ipv4-prefix-list-name export
Use at least one method.
By default, no BGP distribution filtering policy is configured.
The following commands are available only in BGP IPv4 unicast address family view:
·     peer advertise-policy exist-policy
·     interface-peer advertise-policy exist-policy
·     peer advertise-policy non-exist-policy
·     interface-peer advertise-policy non-exist-policy
To configure BGP route distribution filtering policies (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     Reference an ACL or IPv6 prefix list to filter advertised BGP routes:
filter-policy { ipv6-acl-number | name ipv6-acl-name | prefix-list ipv6-prefix-list-name } export [ direct | isisv6 process-id | ospfv3 process-id | ripng process-id | static ]
¡     peer { group-name | ipv4-address [ mask-length ] } | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-policy advertise-policy-name exist-policy exist-policy-name
¡     peer { group-name | ipv4-address [ mask-length ] } | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-policy advertise-policy-name non-exist-policy non-exist-policy-name
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-policy route-policy-name export
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } filter-policy { ipv6-acl-number | name ipv6-acl-name } export
¡     interface-peer interface-type interface-number filter-policy { ipv6-acl-number | name ipv6-acl-name } export
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } as-path-acl { as-path-acl-number | as-path-acl-name } export
·     Reference an IPv6 prefix list to filter BGP routes advertised to a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } prefix-list ipv6-prefix-list-name export
¡     interface-peer interface-type interface-number prefix-list ipv6-prefix-list-name export
The following commands are available only in BGP IPv6 unicast address family view:
Configuring BGP route reception filtering policies
You can use the following methods to configure BGP route reception filtering policies:
·     Use an ACL or prefix list to filter routing information received from all peers.
·     Use a routing policy, ACL, AS path list, or prefix list to filter routing information received from a peer or peer group.
1.     filter-policy import
2.     peer filter-policy import
3.     peer as-path-acl import
4.     peer prefix-list import
5.     peer route-policy import
Only routes passing all the configured policies can be received.
To configure BGP route reception filtering policies (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Configure BGP route reception filtering policies. Choose the options to configure as needed:
·     Reference an ACL or IP prefix list to filter BGP routes received from all peers:
·     Reference a routing policy to filter BGP routes received from a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name import
¡     interface-peer interface-type interface-number route-policy route-policy-name import
·     Reference an ACL to filter BGP routes received from a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } filter-policy { ipv4-acl-number | name ipv4-acl-name } import
¡     interface-peer interface-type interface-number filter-policy { ipv4-acl-number | name ipv4-acl-name } import
·     Reference an AS path list to filter BGP routes received from a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } import
¡     interface-peer interface-type interface-number as-path-acl { as-path-acl-number | as-path-acl-name } import
·     Reference an IPv4 prefix list to filter BGP routes received from a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } prefix-list ipv4-prefix-list-name import
¡     interface-peer interface-type interface-number prefix-list ipv4-prefix-list-name import
By default, no route reception filtering is configured.
To configure BGP route reception filtering policies (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     Reference ACL or IPv6 prefix list to filter BGP routes received from all peers:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-policy route-policy-name import
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } filter-policy { ipv6-acl-number | name ipv6-acl-name } import
¡     interface-peer interface-type interface-number filter-policy { ipv6-acl-number | name ipv6-acl-name } import
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } as-path-acl { as-path-acl-number | as-path-acl-name } import
·     Reference an IPv6 prefix list to filter BGP routes received from a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } prefix-list ipv6-prefix-list-name import
¡     interface-peer interface-type interface-number prefix-list ipv6-prefix-list-name import
Enabling first-AS-number check for EBGP route advertisement
By default, BGP does not check the first AS number of a received EBGP route and directly advertises it to all peers except the source peer. The default setting for EBGP route advertisement brings about a large number of BGP routes and is not friendly to network maintenance.
To resolve this issue, perform this task. When the first AS number of an EBGP route to be advertised is the same as that of an EBGP peer, BGP does not advertise the route to that peer. This can reduce the number of routes received by EBGP peers.
To enable first-AS-number check for EBGP route advertisement (IPv4 unicast):
Step
Remarks
N/A
2.     Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
·     Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
·     Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
N/A
3.     Enable BGP to perform first-AS-number check for EBGP routes before route advertisement.
peer-as-check enable
To enable first-AS-number check for EBGP route advertisement (IPv6 unicast):
Step
Remarks
N/A
2.     Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
·     Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
·     Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
N/A
If a device sends many new routes within a short time period, it might be unable to add the routes to the FIB before the peer device adds them. This might result in traffic forwarding failure. To avoid this problem, you can perform this task to set an appropriate route sending rate for the device.
For a device with high performance, you can set a high BGP route sending rate as needed. For a device without high performance, set a relatively low BGP route sending rate as a best practice.
As a best practice to avoid route withdrawal failures, do not set the BGP route sending rate to 0 or a small value when network flapping occurs.
This task applies only to IPv4 unicast routes and IPv6 unicast routes.
To set the BGP route sending rate:
Step
Remarks
N/A
N/A
3.     Set the BGP route sending rate.
route-rate-limit rate
By default, the BGP route sending rate is not set.
This task reduces traffic loss. With this task performed, BGP delays sending route updates when it restores after a device reboot. During the delay time, BGP learns all routes from other neighbors, and then selects the optimal route. After the delay time elapses, BGP will advertise the optimal route.
You can specify a prefix list and enable BGP to immediately send route updates for routes that match the prefix list.
For BGP EVPN routes, this feature takes effect only on IP prefix routes and MAC/IP advertisement routes that carry IP routing information.
To configure BGP route update delay:
Step
Remarks
N/A
N/A
3.     Configure BGP to delay sending route updates when it restores after a device reboot.
By default, BGP immediately sends route updates to BGP peers in established state when it restores after a device reboot.
4.     (Optional.) Configure BGP to immediately send route updates for routes that match an IPv4 prefix list.
By default, no IPv4 prefix list is specified to filter routes.
Use this command when the updates for the specified routes must be sent immediately.
5.     (Optional.) Configure BGP to immediately send route updates for routes that match an IPv6 prefix list.
bgp update-delay on-startup ipv6-prefix-list ipv6-prefix-list-name
By default, no IPv6 prefix list is specified to filter routes.
Configuring BGP route advertisement delay
BGP sends update messages to peers when route changes occur or peer relationship establishment is complete. If a large number of routes need to be updated within a short period, BGP might send update messages to peers before issuing the updated routes to the FIB. As a result, some packets might be discarded because BGP cannot find the forwarding path for the packets. To resolve this issue, perform this task to enable BGP route advertisement delay and set a delay timer. When route changes occur or peer relationship establishment is complete, BGP cannot send any update messages unless the delay timer expires.
BGP compares the timer values specified for a BGP peer by using the route-update-delay command and the peer route-update-interval command. Only the larger timer value takes effect. If you did not execute the peer route-update-interval command, BGP compares the BGP route advertisement delay timer with the default value of the peer route-update-interval command.
This feature applies to only the following routes:
·     BGP IPv4 unicast routes.
·     BGP IPv6 unicast routes.
·     BGP VPNv4 routes.
·     BGP VPNv6 routes.
To configure BGP route advertisement delay:
Step
Remarks
N/A
N/A
3.     Enable BGP route advertisement delay and set a delay timer.
route-update-delay delay-value
By default, BGP route advertisement delay is disabled.
Configuring a startup policy for BGP route updates
About startup policy for BGP route updates
Perform this task to configure BGP to send route updates with the specified attributes within the specified period after reboot.
As shown in Figure 11, if Router B restarts and sends route updates before route convergence completes, traffic sent from Router A through Router B might be lost. This feature enables Router B to send route updates with the specified attribute values within the specified period after reboot, so that Router A can forward traffic through Router C.
Figure 11 Network diagram
To configure a startup policy for BGP route updates:
Step
Remarks
N/A
N/A
3.     Specify the period after reboot within which the startup policy takes effect.
By default, the startup policy does not take effect.
4.     Specify a MED attribute.
By default, the MED attribute is 4294967295.
Configuring BGP route dampening
Route dampening enables BGP to not select unstable routes as optimal routes. This feature applies to EBGP routes but not to IBGP routes.
If an EBGP peer goes down after you configure this feature, routes coming from the peer are not deleted and they are dampened.
To configure BGP route dampening (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Configure BGP route dampening.
By default, BGP route dampening is not configured.
To configure BGP route dampening (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Configure IPv6 BGP route dampening.
By default, IPv6 BGP route dampening is not configured.
Controlling BGP path selection
By configuring BGP path attributes, you can control BGP path selection.
Setting a preferred value for routes received
Perform this task to set a preferred value for specific routes to control BGP path selection.
Among multiple routes that have the same destination/mask and are learned from different peers, the one with the greatest preferred value is selected as the optimal route.
To set a preferred value for routes from a peer or peer group (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Set a preferred value for routes received from a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } preferred-value value
·     interface-peer interface-type interface-number preferred-value value
The default preferred value is 0.
To set a preferred value for routes from a peer or peer group (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } preferred-value value
Configuring preferences for BGP routes
Routing protocols each have a default preference. If they find multiple routes destined for the same network, the route found by the routing protocol with the highest preference is selected as the optimal route.
You can use the preference command to modify preferences for EBGP, IBGP, and local BGP routes, or use a routing policy to set a preference for matching routes. For routes not matching the routing policy, the default preference applies.
If a device has an EBGP route and a local BGP route to reach the same destination, it does not select the EBGP route because the EBGP route has a lower preference than the local BGP route by default. You can use the network short-cut command to configure the EBGP route as a shortcut route that has the same preference as the local BGP route. The EBGP route will more likely become the optimal route.
To configure preferences for BGP routes (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Configure preferences for EBGP, IBGP, and local BGP routes.
The default preferences for EBGP, IBGP, and local BGP routes are 255, 255, and 130.
4.     Configure an EBGP route as a shortcut route.
By default, an EBGP route has a preference of 255.
To configure preferences for BGP routes (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
Configuring the default local preference
The local preference is used to determine the optimal route for traffic leaving the local AS. When a BGP router obtains from several IBGP peers multiple routes to the same destination, but with different next hops, it considers the route with the highest local preference as the optimal route.
This task allows you to specify the default local preference for routes sent to IBGP peers.
To specify the default local preference (IPv4 unicast/multicast address family):
Step
Remarks
N/A
a.     bgp as-number [ instance instance-name ]
b.     ip vpn-instance vpn-instance-name
N/A
3.     Configure the default local preference.
The default local preference is 100.
To specify the default local preference (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
Configuring the MED attribute
BGP uses MED to determine the optimal route for traffic going into an AS. When a BGP router obtains multiple routes with the same destination but with different next hops, it considers the route with the smallest MED value as the optimal route if other conditions are the same.
Configuring the default MED value
To configure the default MED value (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Configure the default MED value.
default med med-value
The default MED value is 0.
To configure the default MED value (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
Enabling MED comparison for routes from different ASs
This task enables BGP to compare the MEDs of routes from different ASs.
To enable MED comparison for routes from different ASs:
Step
Remarks
N/A
2.     Enter BGP instance view or BGP-VPN instance view.
·     Enter BGP instance view:
·     Enter BGP-VPN instance view:
N/A
3.     Enable MED comparison for routes from different ASs.
compare-different-as-med
By default, MED comparison for routes from different ASs is disabled.
Enabling MED comparison for routes on a per-AS basis
This task enables BGP to compare the MEDs of routes from an AS.
Figure 12 Route selection based on MED (in an IPv4 network)
As shown in Figure 12, Device D establishes indirect EBGP peer relationships with Device A, Device B, and Device C, and learns addresses 1.1.1.1/32, 2.2.2.2/32, and 3.3.3.3/32 through OSPF. The following output shows the routing information on Device D.
1.1.1.1/32         O_INTRA 10  10          11.1.1.2        Interface D1
2.2.2.2/32         O_INTRA 10  20          12.1.1.2        Interface D2
3.3.3.3/32         O_INTRA 10  30          13.1.1.2        Interface D3
Device D learns network 10.0.0.0 from both Device A and Device B. Because the route learned from Device B has a smaller IGP metric, the route is optimal. The following output shows the BGP routing table on Device D.
 *>e  10.0.0.0          2.2.2.2         50                    0       300 400e
 * e                    3.3.3.3         50                    0       200 400e
When Device D learns network 10.0.0.0 from Device C, it compares the route with the optimal route in its routing table. Because Device C and Device B reside in different ASs, BGP does not compare the MEDs of the two routes. The route from Device C has a smaller IGP metric than the route from Device B, so the route from Device C becomes optimal. The following output shows the BGP routing table on Device D.
 *>e  10.0.0.0          1.1.1.1         60                    0       200 400e
 * e  10.0.0.0          2.2.2.2         50                    0       300 400e
However, Device C and Device A reside in the same AS, and Device C has a greater MED, so network 10.0.0.0 learned from Device C should not be optimal.
To avoid this problem, you can configure the bestroute compare-med command to enable MED comparison for routes from the same AS on Device D. After that, Device D puts the routes received from each AS into a group, selects the route with the lowest MED from each group, and compares routes from different groups. Network 10.0.0.0 learned from Device B is the optimal route. The following output shows the BGP routing table on Device D.
 * e                    1.1.1.1         60                    0       200 400e
To enable MED comparison for routes on a per-AS basis:
Step
Remarks
N/A
N/A
3.     Enable MED comparison for routes on a per-AS basis.
By default, MED comparison for routes on a per-AS basis is disabled.
Enabling MED comparison for routes from confederation peers
This task enables BGP to compare the MEDs of routes received from confederation peers. However, if a route received from a confederation peer has an AS number that does not belong to the confederation, BGP does not compare the route with other routes. For example, a confederation has three AS numbers 65006, 65007, and 65009. BGP receives three routes from different confederation peers. The AS_PATH attributes of these routes are 65006 65009, 65007 65009, and 65008 65009, and the MED values of them are 2, 3, and 1. Because the third route's AS_PATH attribute contains AS number 65008 that does not belong to the confederation, BGP does not compare it with other routes. As a result, the first route becomes the optimal route.
To enable MED comparison for routes from confederation peers:
Step
Remarks
N/A
N/A
3.     Enable MED comparison for routes from confederation peers.
bestroute med-confederation
By default, MED comparison for routes from confederation peers is disabled.
Configuring the NEXT_HOP attribute
Setting the local router as the next hop
By default, a BGP router does not set itself as the next hop for routes advertised to an IBGP peer or peer group. In some cases, however, you must configure the advertising router as the next hop to ensure that the BGP peer can find the correct next hop.
For example, as shown in Figure 13, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. If Router C has no route destined for IP address 1.1.1.1/24, you must configure Router B to set itself 3.1.1.1/24 as the next hop for the network 2.1.1.1/24 advertised to Router C.
Figure 13 NEXT_HOP attribute configuration
If a BGP router has two peers on a broadcast network, it does not set itself as the next hop for routes sent to an EBGP peer by default. As shown in Figure 14, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. They are on the same broadcast network 1.1.1.0/24. When Router B sends EBGP routes to Router A, it does not set itself as the next hop by default. However, you can configure Router B to set it (1.1.1.2/24) as the next hop for routes sent to Router A by using the peer next-hop-local command as needed.
Figure 14 NEXT_HOP attribute configuration
IMPORTANT:
If you have configured BGP load balancing, the router sets itself as the next hop for routes sent to an IBGP peer or peer group regardless of whether the peer next-hop-local command is configured.
To configure the NEXT_HOP attribute (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Specify the device as the next hop for routes sent to a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } next-hop-local
·     interface-peer interface-type interface-number next-hop-local
By default, the device sets itself as the next hop for routes sent to an EBGP peer or peer group. However, it does not set itself as the next hop for routes sent to an IBGP peer or peer group. When the device sends ECMP routes to IBGP peers, it sets the local device IP as the next hop of the optimal route among these routes.
To configure the NEXT_HOP attribute (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } next-hop-local
Advertising only the global unicast address in the NEXT_HOP attribute
A directly-connected IPv6 EBGP peer might fail to learn routes if it cannot parse a route update that contains both the link-local address and the global unicast address. To resolve this issue, perform this task to enable the local device to advertise only the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
IMPORTANT
IMPORTANT:
This feature might not apply to EBGP peers established through directly connected broadcast interfaces. If the next hop of the advertised route and the directly connected broadcast interfaces belong to the same subnet, this feature does not take effect.
To enable the device to advertise only the global unicast address in the NEXT_HOP attribute (IPv4 unicast address family):
Step
Remarks
N/A
N/A
3.     Enable the device to advertise only the global unicast address in the NEXT_HOP attribute to its IPv6 peers.
nexthop global-address-only
By default, if the local device has a link-local address, it advertises both the link-local address and the global unicast address in the NEXT_HOP attribute to the directly-connected IPv6 EBGP peers established with its global unicast address.
To enable the device to advertise only the global unicast address in the NEXT_HOP attribute (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
Configuring the AS_PATH attribute
Permitting local AS number to appear in routes from a peer or peer group
In general, BGP checks whether the AS_PATH attribute of a route from a peer contains the local AS number. If yes, it discards the route to avoid routing loops.
In certain network environments (for example, a Hub&Spoke network in MPLS L3VPN), however, the AS_PATH attribute of a route from a peer must be allowed to contain the local AS number. Otherwise, the route cannot be advertised correctly.
To permit the local AS number to appear in routes from a peer or peer group and specify the appearance times (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Permit the local AS number to appear in routes from a peer or peer group and set the appearance times. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } allow-as-loop [ number ]
·     interface-peer interface-type interface-number allow-as-loop [ number ]
By default, the local AS number is not allowed in routes from a peer or peer group.
To permit the local AS number to appear in routes from a peer or peer group and specify the appearance times (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } allow-as-loop [ number ]
Ignoring the AS_PATH attribute during optimal route selection
Step
Remarks
N/A
N/A
3.     Configure BGP to ignore the AS_PATH attribute during optimal route selection
bestroute as-path-neglect
By default, BGP considers AS_PATH during optimal route selection.
Advertising a fake AS number to a peer or peer group
After you move a BGP router from an AS to another AS (from AS 2 to AS 3 for example), you have to modify the AS number of the router on all its EBGP peers. To avoid such modifications, you can configure the router to advertise a fake AS number 2 to its EBGP peers so that the EBGP peers still think that Router A is in AS 2.
To advertise a fake AS number to a peer or peer group (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Advertise a fake AS number to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } fake-as as-number
By default, no fake AS number is advertised to a peer or peer group.
This command applies only to EBGP peers or EBGP peer groups.
To advertise a fake AS number to a peer or peer group (IPv6 peers):
Step
Remarks
N/A
N/A
3.     Advertise a fake AS number to a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } fake-as as-number
·     interface-peer interface-type interface-number fake-as as-number
Configuring AS number substitution
IMPORTANT:
Do not configure AS number substitution in normal circumstances. Otherwise, routing loops might occur.
To use EBGP between PE and CE in MPLS L3VPN, VPN sites in different geographical areas should have different AS numbers. Otherwise, BGP discards route updates containing the local AS number. If two CEs connected to different PEs use the same AS number, you must configure AS number substitution on each PE. This substitution can replace the AS number in route updates originated by the remote CE as its own AS number before advertising them to the connected CE.
Figure 15 AS number substitution configuration (in an IPv4 network)
As shown in Figure 15, CE 1 and CE 2 use the same AS number 800. To ensure bidirectional communication between the two sites, configure AS number substitution on PE 2. PE 2 replaces AS 800 with AS 100 for the BGP route update originated from CE 1 before advertising it to CE 2. Perform the same configuration on PE 1.
To configure AS number substitution for a peer or peer group (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Configure AS number substitution for a peer or peer group.
By default, AS number substitution is not configured.
To configure AS number substitution for a peer or peer group (IPv6 peers):
Step
Remarks
N/A
N/A
3.     Configure AS number substitution for a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } substitute-as
·     interface-peer interface-type interface-number substitute-as
Removing or replacing private AS numbers from updates sent to an EBGP peer or peer group
Private AS numbers are typically used in test networks, and should not be transmitted in public networks. The range of private AS numbers is from 64512 to 65535.
To remove or replace private AS numbers from updates sent to an EBGP peer or peer group (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Configure BGP to remove private AS numbers from the AS_PATH attribute of updates sent to an EBGP peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
·     interface-peer interface-type interface-number public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
This command is applicable only to EBGP peers or peer groups.
To remove private AS numbers from updates sent to an EBGP peer or peer group (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
Ignoring the first AS number of EBGP route updates
By default, BGP checks the first AS number of a received EBGP route update. If the first AS number is neither the AS number of the BGP peer nor a private AS number, the BGP router disconnects the BGP session to the peer.
To ignore the first AS number of EBGP route updates:
Step
Remarks
N/A
N/A
3.     Configure BGP to ignore the first AS number of EBGP route updates.
ignore-first-as
By default, BGP checks the first AS number of EBGP route updates.
To ignore the first AS number of EBGP route updates received from a peer or peer group (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Enable BGP to ignore the first AS number of EBGP route updates received from the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } ignore-first-as
By default, BGP checks the first AS number of route updates learned from EBGP peers or peer groups.
To ignore the first AS number of EBGP route updates received from a peer or peer group (IPv6 peers):
Step
Remarks
N/A
N/A
3.     Enable BGP to ignore the first AS number of EBGP route updates received from a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore-first-as
·     interface-peer interface-type interface-number ignore-first-as
Minimizing the priority of BGP routes advertised to peers
Minimizing the priority of BGP routes advertised to peers with a DOWN-to-UP state change
By default, the device sends BGP routes immediately to a peer when the peer state changes to UP. If the device advertises routes before completing ARP or ND table convergence, the traffic matching these advertised routes might not be forwarded correctly, which causes traffic loss.
To resolve this issue, use this feature to minimize the priority of the routes to be advertised after the state of a peer changes from DOWN to UP. The peer will not select the routes received from the device as the optimal routes. After the device completes ARP or ND table convergence and the specified wait time elapses, the device restores the priority of the routes advertised to the peer.
After you use this feature, the device performs the following tasks when the state of a peer changes from DOWN to UP:
1.     Set the local preference value to the minimum (zero) and the MED value to the maximum (4294967295) for the routes to be advertised.
2.     After the specified wait time elapses, restore the local preference value and the MED value for the advertised routes, and then advertise these routes immediately.
For the device to restore the priority of the advertised routes before the specified wait time elapses, use one of the following commands:
¡     reset bgp advertise lowest-priority on-peer-up
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to the peer. If the state of a peer changes from DOWN to UP later, the device still minimizes the priority of the routes advertised to that peer.
¡     undo advertise lowest-priority on-peer-up duration
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to the peer. The device does not change the original local preference value and MED value for the subsequent routes advertised to peers.
You can use the advertise lowest-priority on-peer-up duration command in BGP instance view or BGP address family view:
·     If you use this command in the view of a BGP instance, this command takes effect on all address families in the instance.
·     If you use this command in the view of a BGP address family, this command takes effect only on the address family.
·     For a BGP address family, the configuration of this command in BGP address family view takes precedence over that in BGP instance view.
You can use this command multiple times to change the wait time. After you change the wait time, the following rules apply:
·     If the original wait time setting is taking effect, the new wait time setting will immediately take over and the device will update the time to wait for route priority restoration.
For example, you can set the wait time to 10 seconds by using the advertise lowest-priority on-peer-up duration 10 command. Then, you use the advertise lowest-priority on-peer-up duration 6 command to set a new wait time six seconds after the state of a peer changes from DOWN to UP. The device will still minimize the priority of the routes advertised to the peer during the following six seconds.
·     If the original wait time is not taking effect, the new wait time will take effect after the state of a peer changes from DOWN to UP.
The following commands can influence each other:
·     advertise lowest-priority on-peer-up duration
·     advertise lowest-priority on-startup duration
·     bgp update-delay on-startup
·     route-update-delay
When you use two of the commands above together, the configuration result varies by command as follows:
Table 2 Configuration results
Command A
Command B
advertise lowest-priority on-startup duration in BGP instance view
Command A and command B overwrite each other. The command used at last takes effect.
advertise lowest-priority on-peer-up duration in BGP instance view
Provided that the delay time specified in command A is TA and the wait time specified in command B is TB, the two commands take effect as follows after the device restarts and the BGP process recovers:
·     If TA ≥ TB, only command A takes effect.
·     If TA < TB, the device performs the following tasks:
a.     The device does not send any BGP routes to peers within TA.
b.     After TA elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TA).
c.     After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers.
route-update-delay
Both command A and command B take effect after the device restarts and the BGP process recovers.
Provided that the delay time specified in command A is TA, the device can advertise BGP routes to a peer only after TA plus TS elapses.
TS represents the larger interval among the intervals specified in the peer route-update-interval command and command B. If you did not execute the peer route-update-interval command for the peer, the device uses the default value of this command to compare with the interval configured in command B.
advertise lowest-priority on-startup duration in the view of a BGP address family
·     In the address family configured with command B, only command B takes effect.
·     In the address families not configured with command B, command A takes effect.
advertise lowest-priority on-peer-up duration in the view of a BGP address family
Provided that the delay time specified in command A is TA and the wait time specified in command B is TB, the following rules apply:
·     In the address families not configured with command B, only command A takes effect.
·     In the address family configured with command B, the two commands take effect as follows after the device restarts and the BGP process recovers:
¡     If TA ≥ TB, only command A takes effect.
¡     If TA < TB, the device performs the following tasks:
i. The device does not send any BGP routes to peers within TA.
ii. The device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TA).
iii. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to peers. The device does not minimize the priority of the subsequent routes advertised to peers.
route-update-delay
The following description applies to BGP IPv4 unicast address family, BGP-VPN IPv4 unicast address family, BGP IPv6 unicast address family, and BGP-VPN IPv6 unicast address family.
Provided that the wait time specified in command B is TB, the two commands take effect as follows after the device restarts and the BGP process recovers:
·     If TS ≥ TB, only command A takes effect.
·     If TS < TB, the device performs the following tasks:
a.     The device does not send any BGP routes to peers within TS.
b.     After TS elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TS).
TS represents the larger interval among the intervals specified in the peer route-update-interval command and command A. If you did not execute the peer route-update-interval command for the peers, the device uses the default value of this command to compare with the interval configured in command A.
Provided that the wait time specified in command B is TB, the two commands take effect as follows when the state of a peer changes from DOWN to UP:
a.     The device does not send any BGP routes to the peer within TS.
b.     After TS elapses, the device sends BGP routes to the peer and minimizes the priority of these routes during the remaining time (TB minus TS).
c.     After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to the peer. The device does not minimize the priority of the subsequent routes advertised to the peer.
TS represents the larger interval among the intervals specified in the peer route-update-interval command and command A. If you did not execute the peer route-update-interval command for the peer, the device uses the default value of this command to compare with the interval configured in command A.
advertise lowest-priority on-startup duration in BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv6 unicast address family view, or BGP-VPN IPv6 unicast address family view
Provided that the wait time specified in command B is TB, the following rules apply:
¡     If TS ≥ TB, only command A takes effect.
¡     If TS < TB, the device performs the following tasks:
i. The device does not send any BGP routes to peers within TS.
ii. After TS elapses, the device sends BGP routes to peers and minimizes the priority of these routes during the remaining time (TB minus TS).
advertise lowest-priority on-peer-up duration in BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, BGP IPv6 unicast address family view, or BGP-VPN IPv6 unicast address family view
·     In the address family configured with command B, the two commands take effect as follows when the state of a peer changes from DOWN to UP:
i. The device does not send any BGP routes to the peer within TS.
ii. After TS elapses, the device sends BGP routes to the peer and minimizes the priority of these routes during the remaining time (TB minus TS).
iii. After TB elapses, the device restores the priority of the advertised routes, and then immediately sends them to the peer. The device does not minimize the priority of the subsequent routes advertised to the peer.
Command A is mutually exclusive with command B.
Command A is mutually exclusive with command B in the same address family.
To minimize the priority of BGP routes advertised to a peer with a DOWN-to-UP state change (BGP instance view):
Step
Remarks
N/A
N/A
3.     Minimize the priority of the routes advertised to a peer after the peer state changes from DOWN to UP.
advertise lowest-priority on-peer-up duration seconds
By default, BGP does not change the priority of the routes advertised to its peers.
To minimize the priority of BGP routes advertised to a peer with a DOWN-to-UP state change (BGP IPv4 unicast):
Step
Remarks
N/A
b.     address-family ipv4 [ unicast ]
c.     address-family ipv4 [ unicast ]
N/A
To minimize the priority of BGP routes advertised to a peer with a DOWN-to-UP state change (BGP IPv6 unicast):
Step
Remarks
N/A
b.     address-family ipv6 [ unicast ]
c.     address-family ipv6 [ unicast ]
N/A
Minimizing the priority of BGP routes advertised to peers after a device reboot
By default, the device sends BGP routes immediately to peers after the device restarts and the BGP process recovers. If the device advertises routes before completing ARP or ND table convergence, the traffic matching these advertised routes might not be forwarded correctly, which causes traffic loss.
To resolve this issue, use this feature to minimize the priority of the routes to be advertised after the device restarts and the BGP process recovers. Peers will not select the routes received from the device as the optimal routes. After the device completes ARP or ND table convergence and the specified wait time elapses, the device restores the priority of the routes advertised to the peers.
After you use this feature, the device performs the following tasks after the device restarts and the BGP process recovers:
¡     reset bgp advertise lowest-priority on-startup
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to peers. The device does not minimize the priority of the subsequent routes advertised to the peers unless the device restarts again.
¡     undo advertise lowest-priority on-startup duration
After you use this command, the device immediately sends BGP routes with the original local preference value and MED value to peers. The device does not change the original local preference value and MED value for the subsequent routes advertised to the peers.
When you use the advertise lowest-priority on-startup duration command, follows these guidelines:
·     You can use this command in BGP instance view or BGP address family view:
¡     If you use this command in the view of a BGP instance, this command takes effect on all address families in the instance.
¡     If you use this command in the view of a BGP address family, this command takes effect only on the address family.
¡     For a BGP address family, the configuration of this command in BGP address family view takes precedence over that in BGP instance view.
·     The configuration of this command does not take effect immediately. It takes effect only after the device restarts.
The following commands can influence the configuration of each other:
When you use two of the commands above together, the configuration result varies by command. For more information, see Table 2.
To minimize the priority of BGP routes advertised to peers after a device reboot (BGP instance view):
Step
Remarks
N/A
N/A
3.     Minimize the priority of the routes advertised to peers after the device restarts and the BGP process recovers.
advertise lowest-priority on-startup duration seconds
To minimize the priority of BGP routes advertised to peers after a device reboot (BGP IPv4 unicast):
Step
Remarks
N/A
N/A
To minimize the priority of BGP routes advertised to peers after a device reboot (BGP IPv6 unicast):
Step
Remarks
N/A
N/A
Restoring the priority of advertised BGP routes
Before performing this task, make sure the following conditions exist:
·     The device has completed ARP or ND table convergence and is ready to advertise routes with original priority.
·     The advertise lowest-priority on-peer-up duration or advertise lowest-priority on-startup duration command still takes effect after a peer comes up or the device restarts.
After you perform this task, the device immediately sends BGP routes with the original local preference value and MED value to peers.
·     If the state of a peer changes from DOWN to UP later, the device still minimizes the priority of the routes advertised to that peer.
·     If the device restarts again later, the device still minimizes the priority of the routes advertised to peers.
To restore the priority of the advertised BGP routes:
Remarks
Restore the priority of the advertised BGP routes in user view.
reset bgp [ instance instance-name ] advertise lowest-priority { on-peer-up | on-startup }
N/A
Ignoring IGP metrics during optimal route selection
Step
Remarks
N/A
N/A
3.     Configure BGP to ignore IGP metrics during optimal route selection.
bestroute igp-metric-ignore
By default, BGP considers IGP metrics during optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest IGP metric as the optimal route.
Ignoring router IDs during optimal route selection
Step
Remarks
N/A
N/A
3.     Configure BGP to ignore router IDs during optimal route selection.
bestroute router-id-ignore
By default, BGP compares router IDs during optimal route selection. If multiple routes to the same destination are available, BGP selects the route with the smallest router ID as the optimal route.
Preferring routes with an IPv6 next hop during optimal route selection
Configure this feature for the VXLAN packets in an EVPN network to be forwarded through IPv6 routes when both IPv4 and IPv6 routes exist.
To prefer routes with an IPv6 next hop during optimal route selection:
Step
Remarks
N/A
N/A
3.     Enter BGP EVPN address family view.
address-family l2vpn evpn
N/A
4.     Enable BGP to prefer routes with an IPv6 next hop during optimal route selection.
bestroute ipv6-nexthop
By default, BGP prefers routes with an IPv4 next hop during optimal route selection.
Associating a track entry with a BGP peer or peer group
This feature enables BGP to monitor the session to each peer, such as the link state of a peer interface. BGP can adjust the priority of routes received from a peer or peer group based on the track entry state. If a network state change occurs, BGP can response quickly to avoid traffic loss due to network issues, such as link failures.
After BGP associates a track entry with a peer, BGP adjusts the priority of routes received from the peer as follows:
·     When the state of the associated track entry becomes negative, BGP increases the MED value of the routes to the maximum and set the local preference of the routes to the lowest.
·     When the state of the associated track entry restores to positive, BGP restores the MED value and the local preference to the original values.
When you specify a track entry to be associated with a peer, the track entry must have been created. As a best practice, use a track entry associated with the link state of the peer interface. The track feature can obtain the link state of the peer interface easily and notify BGP to adjust the route priority when the link state changes to down.
For more information about track entries, see track configuration in High Availability Configuration Guide.
Procedure (IPv4 unicast)
Step
Remarks
N/A
N/A
3.     Associate a track entry with a BGP peer or peer group for route priority adjustment.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-priority-track track-entry-number
By default, BGP does not use track entries for route priority adjustment.
Procedure (IPv6 unicast)
Step
Remarks
N/A
N/A
Configuring the SoO attribute
After you configure the SoO attribute for a BGP peer or peer group, BGP adds the SoO attribute into the route updates received from the BGP peer or peer group. In addition, before advertising route updates to the peer or peer group, BGP checks the SoO attribute of the route update against the configured SoO attribute. If they are the same, BGP does not advertise the route updates to the BGP peer or peer group.
To configure the SoO attribute (IPv4 unicast/multicast address family):
Step
Remarks
N/A
2.     Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
·     Enter BGP IPv4 unicast address family view:
·     Enter BGP-VPN IPv4 unicast address family view:
·     Enter BGP IPv4 multicast address family view:
b.     address-family ipv4 multicast
N/A
3.     Configure the SoO attribute for a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } soo site-of-origin
·     interface-peer interface-type interface-number soo site-of-origin
By default, no SoO attribute is configured for a peer or peer group.
The ipv6-address [ prefix-length ] argument and the interface-peer command not supported in BGP IPv4 multicast address family view.
To configure the SoO attribute (IPv6 unicast/multicast address family):
Step
Remarks
N/A
2.     Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
·     Enter BGP IPv6 unicast address family view:
·     Enter BGP-VPN IPv6 unicast address family view:
·     Enter BGP IPv6 multicast address family view:
b.     address-family ipv6 multicast
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } soo site-of-origin
The ipv4-address [ mask-length ] and link-local-address interface interface-type interface-number options and the interface-peer command are not supported in BGP IPv6 multicast address family view.
Tuning and optimizing BGP networks
This section describes how to tune and optimize BGP networks.
Setting the TCP MSS for TCP connections
BGP typically establishes a multihop TCP connection with a peer. Multiple intermediate devices might fragment BGP packets due to their MTU settings, resulting in frequent packet encapsulations and decapsulations that reduce forwarding efficiency.
To resolve this issue, you can perform this task to set the TCP maximum segment size (MSS) for TCP connections with a peer or peer group. TCP segments sent by the source will not be re-fragmented along the path to the destination.
During TCP connection establishment, the minimum of the following MSSs takes effect:
·     The MSS calculated according to the IPv4 MTU set by the ip mtu command.
·     The interface MSS set by the tcp mss command.
·     The MSS calculated according to the path MTU detected by TCP path MTU discovery (enabled with the tcp path-mtu-discovery command).
·     The MSS set by the peer tcp-mss command.
The MSS is calculated by using the following formular:
MSS = path MTU (or interface MTU) – IP header length – TCP header length
For more information about MTU and MSS, see IP performance optimization configuration in Layer 3—IP Services Configuration Guide.
This task might cause BGP session re-establishment. Make sure you understand the potential impact before performing this task.
To set the TCP MSS for TCP connections with a peer or peer group:
Step
Remarks
N/A
N/A
3.     Set the TCP MSS for TCP connections with a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tcp-mss mss-value
By default, the TCP MSS is not set.
Configuring the keepalive interval and hold time
BGP sends keepalive messages regularly to keep the BGP session between two routers.
If a router receives no keepalive or update message from a peer within the hold time, it tears down the session.
You can configure the keepalive interval and hold time globally or for a peer or peer group. The individual settings take precedence over the global settings.
The actual keepalive interval and hold time are determined as follows:
·     If the hold time settings on the local and peer routers are different, the smaller setting is used. If the hold time is 0, BGP does not send keepalive messages to its peers and never tears down the session.
·     If the keepalive interval is not 0, the actual keepalive interval is the smaller one between 1/3 of the hold time and the keepalive interval.
The hold time must be a minimum of three times the keepalive interval.
You can perform this task for all BGP peers or for a specific BGP peer or peer group. For a BGP peer or peer group, the configuration of the peer timer command takes precedence over that of the timer command. If you do not configure the peer timer command for the peer or peer group, the configuration of the timer command takes effect on the peer or peer group.
Procedure (IPv4 peers)
Step
Remarks
N/A
N/A
3.     Configure the keepalive interval and hold time.
·     Configure the global keepalive interval and hold time:
·     Configure the keepalive interval and hold time for a peer or peer group:
peer { group-name | ipv4-address [ mask-length ] } timer keepalive keepalive hold holdtime
By default, the keepalive interval is 60 seconds, and hold time is 180 seconds.
The timer command takes effect for new BGP sessions and does not affect existing sessions.
The timers configured with the timer and peer timer commands do not take effect until a session is re-established (for example, a session is reset).
The hold time must be at least three times the keepalive interval.
Procedure (IPv6 peers)
Step
Remarks
N/A
N/A
·     Configure the keepalive interval and hold time for a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } timer keepalive keepalive hold holdtime
¡     interface-peer interface-type interface-number timer keepalive keepalive hold holdtime
Setting the session retry timer
To speed up session establishment to a peer or peer group, set a small session retry timer. If the BGP session flaps, you can set a large session retry timer to reduce the impact and speed up route convergence.
The timer set by the peer timer connect-retry command takes precedence over the timer set by the timer connect-retry command.
To set the session retry timer (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Set the session retry timer.
·     Set the session retry timer for all peers or peer groups:
·     Set the session retry timer for a peer or peer group:
peer { group-name | ipv4-address [ mask-length ] } timer connect-retry retry-time
By default, the session retry timer is 32 seconds for a peer or peer group.
To set the session retry timer (IPv6 peers):
Step
Remarks
N/A
N/A
·     Set the session retry timer for a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } timer connect-retry retry-time
¡     interface-peer interface-type interface-number timer connect-retry retry-time
Configuring the interval for sending updates for the same route
A BGP router sends an update message to its peers when a route is changed. If the route changes frequently, the BGP router keeps sending update or withdrawal messages for the same route, resulting route flapping. To prevent this situation, perform this task to configure the interval for sending updates for the same route to a peer or peer group.
This feature takes effect on withdrawn routes only after you apply the route update interval setting to withdrawn routes.
BGP compares the intervals specified for a BGP peer by using the peer route-update-interval and route-update-delay commands. Only the larger interval takes effect. If you did not execute the peer route-update-interval command, BGP uses the default value of this command to compare with the interval configured by the route-update-delay command.
To configure the interval for sending the same update to a peer or peer group (IPv4 peers):
Step
Remarks
N/A
2.     Enter BGP instance.
N/A
3.     (Optional.) Apply route update interval setting to withdrawn routes.
route-update-interval withdrawn enable
By default, route update interval setting does not apply to withdrawn routes. BGP sends withdrawal messages for withdrawn routes immediately.
4.     (Optional.) Enter BGP-VPN instance view.
N/A
5.     Configure the interval for sending updates for the same route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } route-update-interval interval
By default, the interval is 15 seconds for an IBGP peer and 30 seconds for an EBGP peer.
To configure the interval for sending the same update to a peer or peer group (IPv6 peers):
Step
Remarks
N/A
N/A
N/A
5.     Configure the interval for sending updates for the same route to a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-update-interval interval
·     interface-peer interface-type interface-number route-update-interval interval
Enabling BGP to establish an EBGP session over multiple hops
To establish an EBGP session, two routers must have a direct physical link and use directly connected interfaces. If no direct link is available, you must use the peer ebgp-max-hop command to enable BGP to establish an EBGP session over multiple hops and specify the maximum hops.
When the BGP GTSM feature is enabled, two peers can establish an EBGP session after passing GTSM check, regardless of whether the maximum number of hops is reached.
To enable BGP to establish an indirect EBGP session (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Enable BGP to establish an EBGP session to an indirectly connected peer or peer group and specify the maximum hop count.
peer { group-name | ipv4-address [ mask-length ] } ebgp-max-hop [ hop-count ]
By default, BGP cannot establish an EBGP session to an indirectly connected peer or peer group.
To enable BGP to establish an indirect EBGP session (IPv6 peers):
Step
Remarks
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } ebgp-max-hop [ hop-count ]
Enabling immediate re-establishment of direct EBGP connections upon link failure
When the link to a directly connected EBGP peer goes down, the router does not re-establish a session to the peer until the hold time timer expires. This feature enables BGP to immediately recreate the session in that situation. When this feature is disabled, route flapping does not affect EBGP session state.
To enable immediate re-establishment of direct EBGP connections:
Step
Remarks
N/A
N/A
3.     Enable immediate re-establishment of direct EBGP connections upon link failure.
ebgp-interface-sensitive
By default, immediate re-establishment of direct EBGP connections is enabled.
Enabling BGP ORF capabilities
About BGP ORF
BGP Outbound Route Filtering (ORF) saves the system resources by reducing the route updates that are sent between BGP peers.
The BGP peers negotiate the ORF capabilities through Open messages. After completing the negotiation process, the BGP peers can exchange ORF information (local route reception filtering policy) through route refresh messages. Then, only routes that pass both the local route distribution filtering policy and the received route reception filtering policy can be advertised.
You can enable the ORF information sending, receiving, or both sending and receiving capabilities on a BGP router. For two BGP peers to successfully negotiate the ORF capabilities, make sure one end has the sending capability and the other end has the receiving capability.
To enable BGP ORF capabilities (IPv4 unicast/IPv4 multicast):
Step
Remarks
N/A
N/A
3.     Enable BGP ORF capabilities. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf prefix-list { both | receive | send }
·     interface-peer interface-type interface-number capability-advertise orf prefix-list { both | receive | send }
By default, BGP ORF capabilities are disabled.
The ipv6-address [ prefix-length ] argument and the interface-peer command are not supported in BGP IPv4 multicast address family view.
To enable BGP ORF capabilities (IPv6 unicast/IPv6 multicast):
Step
Remarks
N/A
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } capability-advertise orf prefix-list { both | receive | send }
Enabling nonstandard BGP ORF capabilities
Step
Remarks
N/A
N/A
3.     Enable nonstandard BGP ORF capabilities.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise orf non-standard
By default, nonstandard BGP ORF capabilities are disabled.
To enable the BGP peers to exchange nonstandard ORF information, you must configure this command together with the peer capability-advertise orf prefix-list command.
Enabling 4-byte AS number suppression
BGP supports 4-byte AS numbers. The 4-byte AS number occupies four bytes, in the range of 1 to 4294967295. By default, a device sends an Open message to the peer device for session establishment. The Open message indicates that the device supports 4-byte AS numbers. If the peer device supports 2-byte AS numbers instead of 4-byte AS numbers, the session cannot be established. To resolve this issue, enable the 4-byte AS number suppression feature. The device then sends an Open message to inform the peer that it does not support 4-byte AS numbers, so the BGP session can be established.
If the peer device supports 4-byte AS numbers, do not enable the 4-byte AS number suppression feature. Otherwise, the BGP session cannot be established.
To enable 4-byte AS number suppression (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Enable 4-byte AS number suppression.
peer { group-name | ipv4-address [ mask-length ] } capability-advertise suppress-4-byte-as
By default, 4-byte AS number suppression is disabled.
To enable 4-byte AS number suppression (IPv6 peers):
Step
Remarks
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } capability-advertise suppress-4-byte-as
Enabling MD5 authentication for BGP peers
MD5 authentication provides the following benefits:
·     Peer authentication ensures that only BGP peers that have the same password can establish TCP connections.
·     Integrity check ensures that BGP packets exchanged between peers are intact.
To enable MD5 authentication for BGP peers (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Enable MD5 authentication for a BGP peer group or peer.
peer { group-name | ipv4-address [ mask-length ] } password { cipher | simple } password
By default, MD5 authentication is disabled.
To enable MD5 authentication for BGP peers (IPv6 peers):
Step
Remarks
N/A
N/A
3.     Enable MD5 authentication for a BGP peer group or peer. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } password { cipher | simple } password
·     interface-peer interface-type interface-number password { cipher | simple } password
Enabling keychain authentication for BGP peers
Keychain authentication enhances the security of TCP connection establishment between BGP peers. It allows BGP peers to establish TCP connections only when the following conditions are met:
·     Keychain authentication is enabled on both BGP peers.
·     The keys used by the BGP peers at the same time must have the same ID.
·     The keys with the same ID must use the same authentication algorithm and key string.
Before configuring keychain authentication, make sure the specified keychain has been created.
For more information about keychains, see Security Configuration Guide.
Follow these restrictions and guidelines when you configure the algorithm and key ID in keychain authentication:
·     BGP supports the HMAC-MD5 and MD5 algorithms. To configure an algorithm, execute the authentication-algorithm command.
·     BGP supports key IDs in the range of 0 to 63. To configure a key ID, execute the key command.
To enable keychain authentication for BGP peers (IPv4 peers):
Step
Remarks
N/A
2.     Enter BGP instance view of BGP-VPN instance view.
N/A
3.     Enable keychain authentication for a BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } keychain keychain-name
By default, keychain authentication is disabled.
To enable keychain authentication for BGP peers (IPv6 peers):
Step
Remarks
N/A
N/A
3.     Enable keychain authentication for a BGP peer or peer group. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } keychain keychain-name
·     interface-peer interface-type interface-number keychain keychain-name
Configuring BGP load balancing
Perform this task to specify the maximum number of BGP ECMP routes for load balancing.
When you use the balance command, follow these guidelines:
·     If you specify the ecmp-nexthop-local keyword, BGP sets the local device IP as the next hop of each load balancing route.
·     If you specify the ecmp-nexthop-unchanged keyword, BGP does not change the next hop of each load balancing route.
·     If you specify neither the ecmp-nexthop-local keyword nor the ecmp-nexthop-unchanged keyword, BGP advertises the routes used for load balancing to IBGP peers as follows:
¡     Without the Add-Path feature configured, BGP advertises only the optimal route among the routes used for load balancing and sets the local device IP as the next hop of that optimal route.
¡     With the Add-Path feature configured, BGP performs the following tasks:
-     Advertises the routes used for load balancing. The number of routes that BGP can advertise equals the maximum number of Add-Path optimal routes that can be advertised.
-     Sets the local device IP as the next hop of the optimal route among the advertised routes.
To specify the maximum number of BGP ECMP routes for load balancing (IPv4 unicast/multicast address family):
Step
Remarks
N/A
·     Enter BGP instance view.
·     Execute the following commands in sequence to enter BGP-VPN instance view:
N/A
3.     (Optional.) Enable BGP to ignore IGP metrics during optimal route selection.
By default, BGP compares IGP metrics during optimal route selection, and selects the route with the smallest IGP metric as the optimal route.
BGP cannot use routes with different IGP metrics to implement load balancing. To resolve this issue, you can use this command.
4.     Return to system view.
·     In BGP instance view:
a.     quit
·     In BGP-VPN instance view:
a.     quit
b.     quit
N/A
5.     Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
N/A
6.     Specify the maximum number of BGP ECMP routes for load balancing.
balance [ ebgp | eibgp | ibgp ] number [ ecmp-nexthop-local | ecmp-nexthop-unchanged ]
By default, load balancing is disabled.
7.     (Optional.) Enable BGP to ignore the AS_PATH attribute when it implements load balancing.
balance as-path-neglect
By default, BGP does not ignore the AS_PATH attribute when it implements load balancing.
8.     (Optional.) Enable load balancing for routes that have different AS_PATH attributes of the same length.
balance as-path-relax [ ebgp | ibgp ]
By default, BGP cannot perform load balancing for routes that have different AS_PATH attributes of the same length.
To specify the maximum number of BGP ECMP routes for load balancing (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
a.     quit
a.     quit
b.     quit
N/A
5.     Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
c.     bgp as-number [ instance instance-name ]
d.     ip vpn-instance vpn-instance-name
e.     address-family ipv6 [ unicast ]
f.     bgp as-number [ instance instance-name ]
g.     address-family ipv6 multicast
N/A
Configuring IPsec for IPv6 BGP
Perform this task to configure IPsec for IPv6 BGP. IPsec can provide privacy, integrity, and authentication for IPv6 BGP packets exchanged between BGP peers.
When two IPv6 BGP peers are configured with IPsec (for example, Device A and Device B), Device A encapsulates an IPv6 BGP packet with IPsec before sending it to Device B. If Device B successfully receives and de-encapsulates the packet, it establishes an IPv6 BGP peer relationship with Device A and learns IPv6 BGP routes from Device A. If Device B receives but fails to de-encapsulate the packet, or receives a packet not protected by IPsec, it discards the packet.
To configure IPsec for IPv6 BGP packets (IPv6 unicast/multicast address family):
Step
Remarks
N/A
2.     Configure an IPsec transform set and a manual IPsec profile.
See Security Configuration Guide.
By default, no IPsec transform set or manual IPsec profile exists.
3.     Enter BGP instance view or BGP-VPN instance view.
N/A
4.     Apply the IPsec profile to an IPv6 BGP peer or peer group. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ipsec-profile profile-name
·     interface-peer interface-type interface-number ipsec-profile profile-name
By default, no IPsec profile is configured for any IPv6 BGP peer or peer group.
This command supports only IPsec profiles in manual mode.
Disabling BGP session establishment
This task enables you to temporarily tear down BGP sessions to a peer/peer group or all peers/peer groups. You can perform network upgrade and maintenance without needing to delete and reconfigure the peers and peer groups. To recover the sessions, execute the undo peer ignore or undo ignore all-peers command.
If you specify the graceful keyword in the peer ignore command, BGP performs the following tasks:
·     Gracefully shuts down the session to the specified peer or peer group in the specified graceful shutdown period of time.
·     Advertises all routes to the specified peer or peer group and changes the attribute of the advertised routes to the specified value.
·     Advertises routes from the specified peer or peer group to other IBGP peers and peer groups and changes the attribute of the advertised routes to the specified value.
If you specify the graceful keyword in the ignore all-peers command, BGP performs the following tasks:
·     Gracefully shuts down the sessions to all peers and peer groups in the specified graceful shutdown period of time.
·     Advertises all routes to all peers and peer groups and changes the attribute of the advertised routes to the specified value.
For a BGP peer or peer group, the configuration made by the peer ignore command takes precedence over the configuration made by the ignore all-peers command.
·     If the session to a peer or peer group has been established, executing the peer ignore command disables the session and clears all related routing information.
·     If sessions have been established to peers and peer groups, executing the ignore all-peers command disables all sessions and clears all related routing information.
To disable BGP session establishment with a peer or peer group (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Disable BGP to establish a session to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } ignore [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
By default, BGP can establish a session to a peer or peer group.
To disable BGP session establishment with a peer or peer group (IPv6 peers):
Step
Remarks
N/A
N/A
3.     Disable BGP to establish a session to a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
·     interface-peer interface-type interface-number ignore [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } * ]
By default, BGP can establish a session to a peer.
To disable BGP session establishment with all peers or peer groups:
Step
Remarks
N/A
N/A
3.     Disable BGP session establishment with all peers or peer groups.
ignore all-peers [ graceful graceful-time { community { community-number | aa:nn } | local-preference preference | med med } *]
By default, BGP can establish sessions to all peers and peer groups.
Configuring GTSM for BGP
The Generalized TTL Security Mechanism (GTSM) protects a BGP session by comparing the TTL value in the IP header of incoming BGP packets against a valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded.
The valid TTL range is from 255 – the configured hop count + 1 to 255.
When GTSM is configured, the BGP packets sent by the device have a TTL of 255.
GTSM provides best protection for directly connected EBGP sessions, but not for multihop EBGP or IBGP sessions because the TTL of packets might be modified by intermediate devices.
IMPORTANT
IMPORTANT:
·     When GTSM is configured, the local device can establish an EBGP session to the peer after both devices pass GTSM check, regardless of whether the maximum number of hops is reached.
·     To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values for them.
To configure GTSM for BGP (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Configure GTSM for the specified BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } ttl-security hops hop-count
By default, GTSM is disabled.
To configure GTSM for BGP (IPv6 peers):
Step
Remarks
N/A
N/A
peer { group-name | ipv6-address [ prefix-length ] } ttl-security hops hop-count
Configuring BGP soft-reset
After you modify the route selection policy, for example, modify the preferred value, you must reset BGP sessions to apply the new policy. The reset operation tears down and re-establishes BGP sessions.
To avoid tearing down BGP sessions, you can use one of the following soft-reset methods to apply the new policy:
·     Enabling route-refresh—The BGP router advertises a route-refresh message to the specified peer, and the peer resends its routing information to the router. After receiving the routing information, the router filters the routing information by using the new policy.
This method requires that both the local router and the peer support route refresh.
·     Saving updates—Use the peer keep-all-routes command to save all route updates from the specified peer. After modifying the route selection policy, filter routing information by using the new policy.
This method does not require that the local router and the peer support route refresh but it uses more memory resources to save routes.
·     Manual soft-reset—Use the refresh bgp command to enable BGP to send local routing information or advertise a route-refresh message to the specified peer. The peer then resends its routing information. After receiving the routing information, the router filters the routing information by using the new policy.
To enable BGP route refresh for a peer or peer group (IPv4 peers):
Step
Remarks
N/A
a.     bgp as-number [ instance instance-name ]
b.     ip vpn-instance vpn-instance-name
N/A
3.     Enable BGP route refresh for a peer or peer group.
·     Enable BGP route refresh for the specified peer or peer group:
peer { group-name | ipv4-address [ mask-length ] } capability-advertise route-refresh
·     Enable the BGP route refresh, multi-protocol extension, and 4-byte AS number features for the specified peer or peer group:
undo peer { group-name | ipv4-address [ mask-length ] } capability-advertise conventional
By default, the BGP route refresh, multi-protocol extension, and 4-byte AS number features are enabled.
To enable BGP route refresh for a peer or peer group (IPv6 peers):
Step
Remarks
N/A
2.     Enter BGP instance view or BGP-VPN instance view.
·     Enter BGP instance view:
·     Enter BGP-VPN instance view:
N/A
peer { group-name | ipv6-address [ prefix-length ] } capability-advertise route-refresh
undo peer { group-name | ipv6-address [ prefix-length ] } capability-advertise conventional
Saving updates
To save all route updates from the specified peer or peer group (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Save all route updates from the peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } keep-all-routes
·     interface-peer interface-type interface-number keep-all-routes
By default, the routes are not saved.
This command takes effect only for the routes received after this command is executed.
To save all route updates from the specified peer or peer group (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } keep-all-routes
Configuring manual soft-reset
To configure manual soft-reset (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
4.     Return to user view.
return
N/A
5.     Perform manual soft-reset on IPv4 sessions in BGP IPv4 address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 { multicast | [ unicast ] [ vpn-instance vpn-instance-name ] }
N/A
6.     Perform manual soft-reset on IPv6 sessions in BGP IPv4 address family.
refresh bgp [ instance instance-name ] { ipv6-address [ prefix-length ] | [ link-local-address ] interface interface-type interface-number } { export | import } ipv4 [ unicast ]
N/A
To configure manual soft-reset (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
return
N/A
5.     Perform manual soft-reset on IPv6 sessions in BGP IPv6 address family.
refresh bgp [ instance instance-name ] { ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number | all | external | group group-name | internal } { export | import } ipv6 { multicast | [ unicast ] [ vpn-instance vpn-instance-name ] }
N/A
6.     Perform manual soft-reset on IPv4 sessions in BGP IPv6 address family.
refresh bgp [ instance instance-name ] ipv4-address [ mask-length ] { export | import } ipv6 [ unicast ]
N/A
To configure manual soft-reset (LS address family):
Step
Remarks
N/A
N/A
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise route-refresh
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } capability-advertise conventional
return
N/A
5.     Perform manual soft-reset.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } link-state
N/A
Configuring the BGP additional path feature
On a large-scale network, a route reflector can receive multiple BGP routes with the same prefix. By default, BGP advertises only one optimal route. When the optimal route fails, traffic forwarding will be interrupted until route convergence completes.
To resolve this issue, configure the BGP Additional Paths (Add-Path) feature on the route reflector. This feature enables the device to advertise multiple routes with the same prefix to a peer or peer group. On receipt of these routes, the peer generates multiple links to the same destination network. You can use these links to implement load balancing with the balance command or use them as backup routes. When the optimal link fails, another link can take over to forward traffic, which enhances the reliability of data transmission.
You can enable the BGP additional path sending, receiving, or both sending and receiving capabilities on a BGP peer. For two BGP peers to successfully negotiate the additional path capabilities, make sure one end has the sending capability and the other end has the receiving capability.
To configure the BGP additional path feature (IPv4 unicast/multicast address family):
Step
Remarks
N/A
2.     Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
N/A
3.     Configure the BGP additional path capabilities. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } additional-paths { receive | send } *
·     interface-peer interface-type interface-number additional-paths { receive | send } *
By default, no BGP additional path capabilities are configured.
4.     Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise additional-paths best number
·     interface-peer interface-type interface-number advertise additional-paths best number
By default, a maximum of one Add-Path optimal route can be advertised to a peer or peer group.
5.     Set the maximum total number of Add-Path optimal routes that can be advertised to all peers.
By default, a maximum of one Add-Path optimal route can be advertised to all peers.
To configure the BGP additional path feature (IPv6 unicast/multicast address family):
Step
Remarks
N/A
2.     Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
N/A
·     peer { group-name | ipv6-address [ prefix-length ] ipv4-address [ mask-length ] | link-local-address interface interface-type interface-number } additional-paths { receive | send } *
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise additional-paths best number
Protecting an EBGP peer when memory usage reaches level 2 threshold
Memory usage includes the following threshold levels: normal, level 1, level 2, and level 3. When the level 2 threshold is reached, BGP periodically tears down an EBGP session to release memory resources until the memory usage falls below the level 2 threshold. You can configure this feature to avoid tearing down the EBGP session to an EBGP peer when the memory usage reaches the level 2 threshold.
For more information about memory usage thresholds, see Fundamentals Configuration Guide.
To configure BGP to protect an EBGP peer or peer group when the memory usage reaches level 2 threshold (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Configure BGP to protect an EBGP peer or peer group when the memory usage reaches level 2 threshold.
peer { group-name | ipv4-address [ mask-length ] } low-memory-exempt
By default, BGP periodically tears down an EBGP session to release memory resources when level 2 threshold is reached.
To configure BGP to protect an EBGP peer or peer group when the memory usage reaches level 2 threshold (IPv6 peers):
Step
Remarks
N/A
N/A
3.     Configure BGP to protect an EBGP peer or peer group when the memory usage reaches level 2 threshold. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } low-memory-exempt
·     interface-peer interface-type interface-number low-memory-exempt
By default, BGP tears down an EBGP session to release memory resources periodically when level 2 threshold is reached.
Configuring an update delay for local MPLS labels
BGP includes local MPLS labels in advertised VPNv4 routes, VPNv6 routes, labeled IPv4 unicast routes, and labeled IPv6 unicast routes.
When a local label is changed, BGP removes the old label and advertises the new label. Traffic interruption occurs if BGP peers use the old label to forward packets before they learn the new label. To resolve this issue, configure an update delay for local MPLS labels. BGP does not remove the old label before the update delay timer expires.
To configure an update delay for local MPLS labels:
Step
Remarks
N/A
N/A
3.     Configure an update delay for local MPLS labels.
retain local-label retain-time
By default, the update delay is 60 seconds.
Flushing the suboptimal BGP route to the RIB
This feature flushes the suboptimal BGP route to the RIB when the following conditions are met:
·     The optimal route is generated by the network command or is redistributed by the import-route command.
·     The suboptimal route is received from a BGP peer.
After the suboptimal route is flushed to the RIB on a network, BGP immediately switches traffic to the suboptimal route when the optimal route fails.
For example, the device has a static route to the subnet 1.1.1.0/24 that has a higher priority than a BGP route. BGP redistributes the static route and receives a route to 1.1.1.0/24 from a peer. After the flush suboptimal-route command is executed, BGP flushes the received BGP route to the RIB as the suboptimal route. When the static route fails, BGP immediately switches traffic to the suboptimal route if inter-protocol FRR is enabled. For more information about inter-protocol FRR, see "Configuring basic IP routing."
To flush the suboptimal BGP route to the RIB:
Step
Remarks
N/A
N/A
3.     Flush the suboptimal BGP route to the RIB.
By default, BGP is disabled from flushing the suboptimal BGP route to the RIB, and only the optimal route is flushed to the RIB.
Enabling BGP to not flush specific routes to the routing table
Perform this task to enable BGP to not flush routes matching the specified routing policy to the routing table.
This feature applies to the following scenarios:
·     In an MPLS L3VPN network, all the optimal private BGP routes will be flushed to the routing table of a PE by default. You can configure this feature to prevent unnecessary routes from being flushed to the IP routing table and improve the forwarding performance of the PE.
·     In a route reflection network, configure this feature to not flush specific BGP routes to the routing table of the RR. Then, the RR only advertises and receives routes but does not forward service traffic, which saves the system resources of the RR.
To enable BGP to not flush specific routes to the routing table (IPv4 unicast):
Step
Remarks
N/A
N/A
3.     Enable BGP to not flush routes matching the specified routing policy to the routing table.
routing-table bgp-rib-only [ all ] [ route-policy route-policy-name ]
By default, BGP flushes the optimal routes to the routing table.
To enable BGP to not flush specific routes to the routing table (IPv6 unicast):
Step
Remarks
N/A
N/A
Setting a DSCP value for outgoing BGP packets
The DSCP value of an IP packet specifies the priority level of the packet and affects the transmission priority of the packet.
To set a DSCP value for outgoing BGP packets:
Step
Remarks
N/A
N/A
3.     Set a DSCP value for outgoing BGP packets. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } dscp dscp-value
·     interface-peer interface-type interface-number dscp dscp-value
By default, the DSCP value for outgoing BGP packets is 48.
Disabling route recursion policy control for routes received from a peer or peer group
If you configure routing policy-based recursive lookup for BGP routes, this route recursion policy applies to BGP routes learned from all peers. This task allows you to disable route recursion policy control for routes learned from certain peers, for example, direct EBGP peers.
To disable route recursion policy control for routes received from a peer or peer group:
Step
Remarks
N/A
N/A
3.     Disable route recursion policy control for routes received from the specified peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } nexthop-recursive-policy disable
·     interface-peer interface-type interface-number nexthop-recursive-policy disable
By default, the route recursion policy applies to routes received from the peer or peer group.
Specifying a label allocation mode
CAUTION
CAUTION:
A change to the label allocation mode enables BGP to re-advertise all routes, which will cause service interruption. Use this command with caution.
BGP supports the following label allocation modes:
·     Per-prefix—Allocates a label to each route prefix.
·     Per-next-hop—Allocates a label to each next hop. This mode is applicable when the number of labels required by the per-prefix mode exceeds the maximum number of labels supported by the device.
·     Per-VPN-instance—Allocates a label to each VPN instance. This mode is applicable when the number of labels required by the per-next-hop mode exceeds the maximum number of labels supported by the device.
When you specify the per-prefix or per-next-hop label allocation mode, you can execute the vpn popgo command to specify the POPGO forwarding mode on an egress PE. The egress PE will pop the label for each packet and forward the packet out of the interface corresponding to the label.
When you specify the per-VPN instance label allocation mode, do not execute the vpn popgo command because it is mutually exclusive with the label-allocation-mode per-vrf command. The egress PE will pop the label for each packet and forward the packet through the FIB table.
To specify a label allocation mode:
Step
Remarks
N/A
N/A
3.     Specify a label allocation mode.
label-allocation-mode { per-prefix | per-vrf }
By default, BGP allocates labels on a per-next-hop basis.
Disabling optimal route selection for labeled routes without tunnel information
Step
Remarks
N/A
N/A
3.     Disable optimal route selection for labeled routes without tunnel information.
labeled-route ignore-no-tunnel
By default, labeled routes without tunnel information can participate in optimal route selection.
Configuring BGP optimal route selection delay
Typically BGP optimal route selection is triggered in real time by the events such as attribute change, configuration change, and route recursion. To avoid packet loss upon switchover between redundant links, you can perform this task to delay optimal route selection.
As shown in Figure 16, BGP runs on all devices in the network. Device A and Device D uses the primary path for communication. When the primary path fails, Device A and Device D switch to the backup path for communication and then back to the primary path after the primary path recovers. In such case, traffic loss might occur if Device A forwards packets through Device B before Device B completes route convergence. You can configure optimal route selection delay on Device A to resolve the problem.
Figure 16 Network diagram
Follow these restrictions and guidelines when you configure this feature:
·     The optimal route selection delay setting applies only when multiple effective routes with the same prefix exist after a route change occurs.
·     For routes being delayed for optimal route selection, modifying the optimal route selection delay timer has the following effects:
¡     If you modify the delay timer to a non-zero value, the routes are not affected, and they still use the original delay timer.
¡     If you execute the undo form of the route-select delay command or modify the delay timer to 0, the device performs optimal route selection immediately.
·     If you configure this feature multiple times for an address family, the most recent configuration takes effect.
·     The optimal route selection delay configuration does not apply to the following conditions:
¡     A route change is caused by execution of a command or by route withdrawal.
¡     After a route change occurs, only one route exists for a specific destination network.
¡     An active/standby process switchover occurs.
¡     A route change occurs among equal-cost routes.
¡     Only the optimal and suboptimal routes exist when FRR is configured.
¡     Optimal route selection is triggered by a redistributed route.
To configure BGP optimal route selection delay (IPv4 unicast/multicast address family):
Step
Remarks
N/A
N/A
3.     Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
To configure BGP optimal route selection delay (IPv6 unicast/multicast address family):
Step
Remarks
N/A
N/A
Specifying the longest match principle for next hop recursion
By default, BGP first looks up in its directly connected routes for a recursive route during a route recursion. If no matching routes exist, BGP will look up in routes generated by all routing protocols based on the longest match principle. The device considers the next hop of a received BGP route as directly connected when the next hop belongs to the same subnet as a direct route. As a result, packet forwarding failure will occur when the device uses this BGP route to forward matching packets.
As shown in Figure 17, Device B has established an IBGP session to Device A and Device C respectively. All devices use a loopback interface as the source port for TCP connection. On receipt of BGP route 8.0.0.0/24 from Device C, Device B reflects the route to Device A. The addresses of the interfaces that connect Device A and Device B belong to subnet 3.3.0.0/16.
If the next hop information exchanged between IBGP peers remains unchanged, the next hop of BGP route 8.0.0.0/24 is 3.3.3.3. Device A considers 3.3.3.3 as a directly connected next hop because 3.3.3.3 belongs to subnet 3.3.0.0/16 and a direct route to 3.3.0.0/16 exists. Packet forwarding failure will occur if Device A forwards packets destined for subnet 8.0.0.0/24 over 3.3.3.3.
Figure 17 Next hop recursion error
To resolve this issue, you can specify the longest match principle for next hop recursion to ensure the recursive route is reachable. BGP will directly look up in routes generated by all routing protocols and select a matching route based on the longest match principle.
Step
Remarks
N/A
·     Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
·     Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
N/A
3.     Specify the longest match principle for BGP next hop recursion.
nexthop recursive-lookup longest-match [ route-policy route-policy-name ]
By default, BGP first looks up in its directly connected routes for a recursive route during route recursion.
This command applies to all BGP routes received from peers in one of the following scenarios:
·     The route-policy route-policy-name option is not specified.
·     The specified routing policy does not exist.
Step
Remarks
N/A
·     Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
·     Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
N/A
Enabling fast host route update upon user migration
As shown in Figure 18, the host roams between AP 1 and AP 2 frequently, and both Device A and Device C save the host route. The host route entries on Device A and Device C are not updated in real time, so traffic forwarding might be affected. To resolve this issue, perform this task to enable fast host route update upon user migration.
Figure 18 Network diagram
As shown in Figure 18, after you enable fast host route update upon user migration on Device A and Device C, Device A and Device C process the host route as follows:
1.     When the host comes online on AP 1 for the first time, Device A generates a route for the host and advertises the route to Device C through Device B.
2.     When the host roams to AP 2, Device C generates a route for the host, and it has two routes for the host. In this case, BGP selects the locally generated route as the optimal route, increases the host migration serial number by one, and then advertises the optimal route to Device A through Device B.
3.     After receiving the host route advertised by Device C, Device B compares the host migration serial number carried in the routes advertised by Device C and Device A. Device B selects the route with the larger host migration serial number as the optimal route and advertises the optimal route to Device A.
4.     After receiving the host route from Device B, Device A checks whether the ARP or ND entry corresponding to the received route exists. If the ARP or ND entry does not exist, Device A deletes the local ARP or ND entry and the direct route, and then advertises the received route to all peers. If the ARP or ND entry exists, Device A determines that the host has migrated to it. Then, Device A takes the following actions:
a.     Compares the host migration serial number in the received route with that in the local host route.
b.     Increases the larger host migration serial number by one.
c.     Advertises the local route with the new host migration serial number to its peers.
When the host roams frequently, devices in the network might receive host routes with the same host migration serial number. In this case, a device selects the optimal route as follows:
·     When the device receives multiple host routes with the same serial number, it selects the route received from the peer with the smallest route ID as the optimal route.
·     When the device receives a host route with the same serial number as that in the local host route, it selects the optimal route based on the ARP or ND entry, as described in step 4.
Host migration serial numbers are advertised through the extended community attribute. Enabling this feature also enables BGP to advertise the extended community attribute to all peers and peer groups.
Procedure (IPv4 unicast address family)
Step
Remarks
N/A
N/A
3.     Enter BGP IPv4 unicast address family view.
N/A
4.     Enable fast host route update upon user migration.
user-move fast-update
By default, fast host route update upon user migration is disabled.
Procedure (IPv6 unicast address family)
Step
Remarks
N/A
N/A
3.     Enter BGP IPv6 unicast address family view.
N/A
Enabling conversational remote host route learning
By default, BGP generates FIB entries for all host routes received from peers (remote host routes) and issues the routes to the FIB. To conserve device resources, you can enable conversational remote host route learning. This feature enables BGP to issue a remote host route to the FIB only if it is required for forwarding a packet.
This feature takes effect only on remote host routes generated based on ARP or ND entries and does not take effect on local host routes and other BGP routes. Host routes generated based on ARP or ND entries carry a special mark advertised through the extended community attribute. Enabling this feature also enables BGP to advertise the extended community attribute to all peers and peer groups.
This feature takes effect only when you execute the ip forwarding-conversational-learning command.
Step
Remarks
N/A
N/A
N/A
4.     Enable conversational remote host route learning.
forwarding-conversational-learning [ route-policy route-policy-name ]
By default, conversational remote host route learning is disabled.
Step
Remarks
N/A
N/A
N/A
Enabling peer unreachability detection
Peer unreachability detection enables BGP to discover link failures quickly. With this feature enabled, BGP will disconnect from the specified peer or peer group if that peer or peer group is detected unreachable.
BGP considers a peer unreachable if one of the following conditions exists:
·     BGP cannot find a route to that peer in the current routing table.
·     BGP finds the route to that peer in the current routing table is a blackhole route.
If you do not set the delay time of peer disconnection, BGP disconnects from the specified peer or peer group immediately if that peer or peer group is detected unreachable.
When you set the delay time of peer disconnection, follow these guidelines to improve network stability:
·     To avoid BGP session flappings caused by unstable traffic, make sure the delay time of peer disconnection is longer than the convergence time of IGP routes.
·     With peer unreachability detection enabled, the GR helper can detect whether the GR restarter is reachable. To ensure successful GR, make sure the delay time of peer disconnection is longer than the GR timer plus the extra timer to wait.
Step
Remarks
N/A
bgp
N/A
3.     Enable peer unreachability detection for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } tracking [ delay delay-time ]
By default, peer unreachability detection is disabled.
This command does not take effect if you enter a link-local address for the ipv6-address argument.
Configuring a large-scale BGP network
In a large network, the number of BGP connections is huge and BGP configuration and maintenance are complicated. To simply BGP configuration, you can use the peer group, community, route reflector, and confederation features as needed. For more information about configuring peer groups, see "Configuring a BGP peer group."
Configuring BGP community
By default, a router does not advertise the COMMUNITY or extended community attribute to its peers or peer groups. When the router receives a route carrying the COMMUNITY or extended community attribute, it removes the attribute before advertising the route to other peers or peer groups.
Perform this task to enable a router to advertise the COMMUNITY or extended community attribute to its peers for route filtering and control. You can also use a routing policy to add or modify the COMMUNITY or extended community attribute for specific routes. For more information about routing policy, see "Configuring routing policies."
To configure BGP community (IPv4 unicast/multicast address family):
Step
Remarks
N/A
2.     Create a routing policy and a node, and enter routing policy node view.
3.     Configure if-match clauses as BGP route match criteria.
For more information about if-match clauses, see routing policy configuration in Layer 3—IP Routing Configuration Guide.
The routing policy can configure the COMMUNITY attribute of BGP routes only when these routes match a permit node.
4.     Configure the COMMUNITY attribute and the extended community attributes of BGP routes.
·     Set the COMMUNITY attribute for BGP routes:
·     Delete COMMUNITY attribute values from BGP routes:
·     Set the RT extended community attribute for BGP routes:
·     Set the SoO extended community attribute for BGP routes:
For more information about these commands, see routing policy commands in Layer 3—IP Routing Command Reference.
5.     Return to system view.
N/A
6.     Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
b.     address-family ipv4 [ unicast ]
c.     address-family ipv4 [ unicast ]
N/A
7.     Advertise the COMMUNITY attribute or the extended community attributes to a peer or peer group.
·     Advertise the COMMUNITY attribute to a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-community
¡     interface-peer interface-type interface-number advertise-community
·     Advertise the extended community attributes to a peer or peer group. Choose one command as needed:
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise-ext-community
¡     interface-peer interface-type interface-number advertise-ext-community
By default, the COMMUNITY attribute or the extended community attributes is not advertised.
8.     Apply a routing policy to routes advertised to a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-policy route-policy-name export
·     interface-peer interface-type interface-number route-policy route-policy-name export
By default, no routing policy is applied.
To configure BGP community (IPv6 unicast/multicast address family):
Step
Remarks
N/A
4.     Configure the COMMUNITY attribute and extended community attribute of BGP routes.
N/A
6.     Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
b.     address-family ipv6 [ unicast ]
c.     address-family ipv6 [ unicast ]
N/A
¡     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-community
¡     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-ext-community
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } route-policy route-policy-name export
Configuring BGP route reflection
Perform this task to configure a BGP route reflector and its clients. The route reflector and its clients automatically form a cluster identified by the router ID of the route reflector. The route reflector forwards route updates among its clients.
To improve availability, you can specify multiple route reflectors for a cluster. The route reflectors in the cluster must have the same cluster ID to avoid routing loops.
When a route reflector is connected to multiple clusters in the network, you can specify different cluster IDs for different peers and peer groups to control route reflection.
You only need to configure BGP route reflection on the device that acts as a route reflector. Other devices do not need to know the role of the local device in route reflection.
After you configure a device as a route reflector, it advertises routes as follows:
·     Advertises routes received from a non-client IBGP peer to all clients.
·     Advertises routes received from an IBGP peer that acts as a client to all peers.
·     Advertises routes received from an EBGP peer to all peers.
By default, the route reflector does not change the attributes of routes before route reflection to avoid routing loops. When you replan network traffic, you can perform this task to allow the route reflector to change the attributes of the routes to be reflected.
After using the reflect change-path-attribute command, you can use the peer route-policy export command to apply a routing policy that can change the attributes of the routes to be reflected. The following apply commands can define how the routing policy modifies route attributes:
·     Use apply origin to change the ORIGIN attribute of routes.
·     Use apply ip-address next-hop or apply ipv6 next-hop to change the NEXT_HOP attribute of routes.
·     Use apply cost to change the MED attribute of routes.
·     Use apply local-preference to change the local preference for routes.
·     Use apply community to configure the COMMUNITY attribute of routes. For BGP to advertise the COMMUNITY attribute to a peer or peer group, use the peer advertise-community command.
·     Use apply comm-list delete to delete COMMUNITY attribute values from routes.
·     Use apply extcommunity to configure the RT extended community attribute of routes. For BGP to advertise the extended community attributes to a peer or peer group, use the peer advertise-ext-community command.
·     Use apply extcommunity soo to configure the SoO extended community attribute of routes.
For more information about the apply commands, see routing policy commands in Layer 3—IP Routing Command Reference.
 Procedure (IPv4 unicast/multicast address family)
Step
Remarks
N/A
N/A
3.     Configure the router as a route reflector and specify a peer or peer group as its client. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } reflect-client
·     interface-peer interface-type interface-number reflect-client
By default, no route reflector or client is configured.
4.     Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
5.     (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
6.     (Optional.) Enable the route reflector to change the attributes of routes to be reflected.
By default, the route reflector cannot change the attributes of routes to be reflected.
Procedure (IPv6 unicast/multicast address family)
Step
Remarks
N/A
2.     Enter BGP IPv6 unicast address family view, or BGP IPv6 multicast address family view.
N/A
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } reflect-client
Ignoring the ORIGINATOR_ID attribute
By default, BGP drops incoming route updates whose ORIGINATOR_ID attribute is the same as the local router ID. Some special networks require BGP to accept such route updates. To meet the requirement, you must configure BGP to ignore the ORIGINATOR_ID attribute.
To ignore the ORIGINATOR_ID attribute (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Ignore the ORIGINATOR_ID attribute.
By default, BGP does not ignore the ORIGINATOR_ID attribute.
Make sure this command does not result in a routing loop.
After you execute this command, BGP also ignores the CLUSTER_LIST attribute.
To ignore the ORIGINATOR_ID attribute (IPv6 peers):
Step
Remarks
N/A
N/A
3.     Ignore the ORIGINATOR_ID attribute. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } ignore-originatorid
·     interface-peer interface-type interface-number ignore-originatorid
Configuring a route server
Some networks require the border devices in multiple ASs to establish full mesh connections, which consumes many network resources and reduces device performance. To resolve this issue, configure a device as a route server and the border devices in different ASs as its clients as needed.
The route server advertises routes to the clients without changing their AS path, next hop, and MED attributes. The clients can exchange routes without establishing EBGP connections and forward traffic to each other without the participation of the route server.
The route server does not add its AS number in the EBGP routes advertised to a peer. To avoid peer establishment failures, execute the peer ignore-first-as command on the clients.
If you do not specify the external keyword, the route server advertises IBGP routes to its clients without changing the routes' AS path, next hop, and MED attributes. As a result, these routes might be unusable for EBGP peers. To resolve this issue, specify the external keyword when you use the peer route-server-client command. The route server can change the AS path, next hop, and MED attributes of IBGP routes before advertising them to the clients.
Procedure (IPv4 unicast)
Step
Remarks
N/A
·     Enter BGP IPv4 unicast address family view:
·     Enter BGP-VPN IPv4 unicast address family view:
N/A
3.     Configure the device as a route server and specify a peer or peer group as a client.
peer { group-name | ipv4-address [ mask-length ] } route-server-client [ external ]
By default, neither the route server nor the client is configured.
Procedure (IPv6 unicast)
Step
Remarks
N/A
·     Enter BGP IPv6 unicast address family view:
·     Enter BGP-VPN IPv6 unicast address family view:
N/A
peer { group-name | ipv6-address [ prefix-length ] } route-server-client [ external ]
Configuring BGP confederation settings
BGP confederation provides another way to reduce IBGP connections in an AS.
A confederation contains sub-ASs. In each sub-AS, IBGP peers are fully meshed. Sub-ASs establish EBGP connections in between.
Configuring a BGP confederation
After you split an AS into multiple sub-ASs, configure a router in a sub-AS as follows:
1.     Enable BGP and specify the AS number of the router. For more information, see "Enabling BGP."
2.     Specify the confederation ID. From an outsider's perspective, the sub-ASs of the confederation is a single AS, which is identified by the confederation ID.
3.     If the router needs to establish EBGP connections to other sub-ASs, you must specify the peering sub-ASs in the confederation.
A confederation can contain a maximum of 32 sub-ASs. The AS number of a sub-AS is effective only in the confederation.
To configure a BGP confederation:
Step
Remarks
N/A
N/A
3.     Configure a confederation ID.
confederation id as-number
By default, no confederation ID is configured.
4.     Specify confederation peer sub-ASs in the confederation.
By default, no confederation peer sub-ASs are specified.
Configuring confederation compatibility
If any routers in the confederation do not comply with RFC 3065, enable confederation compatibility to allow the router to work with those routers.
To configure confederation compatibility:
Step
Remarks
N/A
N/A
3.     Enable confederation compatibility.
confederation nonstandard
By default, confederation compatibility is disabled.
Configuring BGP GR
Graceful Restart (GR) ensures forwarding continuous when a routing protocol restarts or an active/standby switchover occurs. Two routers are required to complete a GR process. The following are router roles in a GR process:
·     GR restarter—Performs GR upon a BGP restart or active/standby switchover.
·     GR helper—Helps the GR restarter to complete the GR process.
A device can act as a GR restarter and GR helper at the same time.
BGP GR works as follows:
1.     The BGP GR restarter and helper exchange Open messages for GR capability negotiation. If both parties have the GR capability, they establish a GR-capable session. The GR restarter sends the GR timer set by the graceful-restart timer restart command to the GR helper in an Open message.
2.     When an active/standby switchover occurs or BGP restarts, the GR restarter does not remove existing BGP routes from Routing Information Base (RIB) and Forwarding Information Base (FIB). It still uses these routes for packet forwarding, and it starts the RIB purge timer (set by the graceful-restart timer purge-time command). The GR helper marks all routes learned from the GR restarter as stale instead of deleting them. It continues to use these routes for packet forwarding. During the GR process, packet forwarding is not interrupted.
3.     After the active/standby switchover or BGP restart completes, the GR restarter re-establishes a BGP session to the GR helper. If the BGP session fails to be established after both the GR timer and the extra timer to wait expire, the GR helper removes the stale routes. To set the extra timer to wait after the restart timer expires, execute the peer graceful-restart timer restart extra command.
4.     If the BGP session is established, routing information is exchanged for the GR restarter to retrieve route entries and for the GR helper to recover stale routes.
5.     Both the GR restarter and the GR helper start the End-Of-RIB marker waiting timer.
The End-Of-RIB marker waiting time is set by the graceful-restart timer wait-for-rib command.
¡     If routing information exchange is completed within the waiting timer, the GR restarter and the GR helper act as follows:
-     The GR restarter updates its routing table with learned BGP routes, removes the aged routes from the RIB, and quits the GR process.
-     The GR helper removes the stale routes and quits the GR process.
¡     If routing information exchange is not completed within the waiting timer, the GR restarter and the GR helper act as follows:
-     The GR restarter updates the RIB with the BGP routes already learned, removes the aged routes from the RIB, and quits the GR process.
The End-Of-RIB marker is an update message that does not contain any NLRI or withdrawn NLRI. After the GR restarter and the GR helper complete route exchange, they additionally send an End-Of-RIB marker to each other. The marker indicates the completion of route update.
6.     The GR restarter quits the GR process if routing information exchange is not completed within the RIB purge timer. It updates the RIB with the BGP routes already learned, and removes the aged routes.
When the TCP connection goes down, the hold timer expires, or the support for a new address family is added, BGP tears down and then re-establishes the peer sessions, which will cause traffic interruption. To avoid traffic interruption in these cases, enable BGP to reset peer sessions gracefully.
After BGP completes GR, it advertises updated routes as follows:
·     If the routes rely on other protocols, for example, redistributed OSPF routes and routes with MPLS labels, BGP starts a wait timer for these protocols to complete GR. This ensures that incorrect and unreachable routes are not advertised.
¡     If the protocols complete GR and notify BGP before the wait timer expires, BGP cancels the wait timer and advertises the routes.
¡     After the wait timer expires, BGP immediately advertises the routes.
·     If the routes do not rely on other protocols, BGP immediately advertises the routes.
Follow these guidelines when you configure BGP GR:
·     The maximum time to wait for the End-of-RIB marker configured on the local end is not advertised to the peer. It controls the time for the local end to receive updates from the peer. Set a large value for the maximum time to wait for the End-of-RIB marker when a large number of routes need to be exchanged. When you use the peer graceful-restart timer restart extra command, you can specify the no-limit keyword. In this situation, the GR helper does not start the End-of-RIB marker waiting timer after a BGP session re-establishment and keeps waiting for the End-of-RIB marker from the GR restarter.
·     As a best practice, perform the BGP GR configuration on both the GR restarter and GR helper.
·     When the following conditions exist, BGP might advertise incomplete routes after completing GR:
¡     The routes rely on other protocols, for example, redistributed OSPF routes.
¡     BGP maintains a large amount of routing information. In this case, BGP and the protocols take a long time to complete GR.
For BGP to correctly advertise the routes after BGP and the protocols complete GR, set a longer wait timer for BGP.
Step
Remarks
N/A
N/A
3.     Enable GR capability for BGP.
graceful-restart
By default, GR capability is disabled for BGP.
4.     Configure the GR timer.
The default setting is 150 seconds.
The time that a peer waits to re-establish a session must be less than the hold time.
5.     (Optional.) Set the extra time to wait after the restart timer expires. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } graceful-restart timer restart extra { time | no-limit }
·     interface-peer interface-type interface-number graceful-restart timer restart extra { time | no-limit }
By default, the extra time to wait after the restart timer expires is 0 seconds.
6.     Configure the maximum time to wait for the End-of-RIB marker.
The default setting is 600 seconds.
7.     Configure the RIB purge timer.
The default setting is 480 seconds.
8.     (Optional.) Configure the time that BGP must wait for other protocols to complete GR after BGP completes GR.
bgp update-delay wait-other-protocol seconds
By default, after BGP completes GR, it must wait a maximum of 300 seconds for other protocols to complete GR.
9.     (Optional.) Enable BGP to reset peer sessions gracefully.
graceful-restart peer-reset [ all ]
By default, BGP does not reset peer sessions gracefully.
Configuring BGP NSR
To use BGP nonstop routing (NSR), the system must have a minimum of two MPUs.
NSR ensures nonstop services when BGP has redundant processes on multiple MPUs. In contrast to GR, NSR does not require a neighbor device to recover routing information.
BGP NSR backs up BGP state and data information from the active BGP process to the standby BGP process. The standby BGP process takes over when any of the following events occurs:
·     The active BGP process restarts.
·     The MPU that runs the active BGP process fails.
·     An ISSU starts on the MPU that runs the active BGP process.
After BGP completes NSR, it advertises updated routes as follows:
·     If the routes rely on other protocols, for example, redistributed OSPF routes and routes with MPLS labels, BGP starts a wait timer for these protocols to complete NSR. This ensures that incorrect and unreachable routes are not advertised.
¡     If the protocols complete NSR and notify BGP before the wait timer expires, BGP cancels the wait timer and advertises the routes.
When both GR and NSR are configured for BGP, NSR has a higher priority than GR. The device will not act as the GR restarter. If the device acts as a GR helper, it cannot help the restarter to complete GR.
To use BGP NSR in MPLS L3VPN, you must enable RIB NSR. For information about RIB NSR, see IP routing basics configuration in Layer 3—IP Routing Configuration Guide.
When the following conditions exist, BGP might advertise incomplete routes after completing NSR:
·     The routes rely on other protocols, for example, redistributed OSPF routes.
·     BGP maintains a large amount of routing information. In this case, BGP and the protocols take a long time to complete NSR.
To ensure BGP advertises the routes after BGP and the protocols complete NSR, set a longer wait timer for BGP.
Step
Remarks
N/A
N/A
3.     Enable BGP NSR.
non-stop-routing
By default, BGP NSR is disabled.
4.     (Optional.) Configure the time that BGP must wait for other protocols to complete NSR after BGP completes NSR.
By default, after BGP completes NSR, it must wait a maximum of 300 seconds for other protocols to complete NSR.
Enabling SNMP notifications for BGP
After you enable SNMP notifications for BGP, the device generates a notification when a BGP neighbor state change occurs. The notification includes the neighbor address, the error code and subcode of the most recent error, and the current neighbor state.
For BGP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
To enable SNMP notifications for BGP:
Step
Remarks
N/A
2.     Enable SNMP notifications for BGP.
snmp-agent trap enable bgp [ instance instance-name ]
By default, SNMP notifications for BGP are enabled.
Enabling logging for session state changes
Perform this task to enable BGP to log BGP session establishment and disconnection events. To display the log information, use the display bgp peer ipv4 unicast log-info command or the display bgp peer ipv6 unicast log-info command. The logs are sent to the information center. The output rules of the logs (whether to output the logs and where to output) are determined by the information center configuration.
For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
To enable logging for session state changes (IPv4 peers):
Step
Remarks
N/A
N/A
3.     Enable logging for session state changes globally.
log-peer-change
By default, logging for session state changes is enabled globally.
4.     (Optional.) Enter BGP-VPN instance view.
N/A
5.     Enable logging for session state changes for a peer or peer group.
By default, logging for session state changes is enabled for all peers or peer groups.
To enable logging for session state changes (IPv6 peers):
Step
Remarks
N/A
N/A
log-peer-change
N/A
5.     Enable logging for session state changes for a peer or peer group. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } log-change
·     interface-peer interface-type interface-number log-change
Enabling logging for BGP route flapping
This feature enables BGP to generate logs for BGP route flappings that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
To enable logging for BGP route flapping (IPv4 unicast/IPv4 multicast):
Step
Remarks
N/A
2.     Enter BGP IPv4 unicast address family view, BGP-VPN IPv4 unicast address family view, or BGP IPv4 multicast address family view.
·     Enter BGP IPv4 multicast address family view:
b.     address-family ipv4 multicast
N/A
3.     Enable logging for BGP route flapping.
By default, logging for BGP route flapping is disabled.
To enable logging for BGP route flapping (IPv6 unicast/IPv6 multicast):
Step
Remarks
N/A
2.     Enter BGP IPv6 unicast address family view, BGP-VPN IPv6 unicast address family view, or BGP IPv6 multicast address family view.
·     Enter BGP IPv6 multicast address family view:
b.     address-family ipv6 multicast
N/A
Configuring BFD for BGP
BGP maintains neighbor relationships based on the keepalive timer and hold timer in seconds. It requires that the hold time must be at least three times the keepalive interval. This mechanism slows down link failure detection. Once a failure occurs on a high-speed link, a large quantity of packets will be dropped before routing convergence completes. BFD for BGP can solve this problem by fast detecting link failures to reduce convergence time.
Before you enable BFD for a BGP peer or peer group, you must establish a BGP session between the local router and the peer or peer group.
For more information about BFD, see High Availability Configuration Guide.
Follow these restrictions and guidelines when you configure echo packet mode BFD:
·     Echo packet mode BFD is applicable only to directly connected BGP peers.
·     Echo packet mode BFD is not applicable to BGP peers established through loopback interfaces.
·     For successful BFD session establishment, make sure a source address has been specified for echo packets by using the bfd echo-source-ip or bfd echo-source-ipv6 command.
To detect the link to a BGP peer established through link-local addresses, you must configure single-hop BFD in control packet mode.
To establish a control packet mode BFD session to a BGP peer, you must configure the same BFD detection mode (multi-hop or single-hop) on the local device and the BGP peer.
If you have enabled GR, use BFD with caution because BFD might detect a failure before the system performs GR, which will result in GR failure. If you have enabled both BFD and GR for BGP, do not disable BFD during a GR process to avoid GR failure.
Procedure (IPv4 peers)
Step
Remarks
N/A
N/A
3.     Enable BFD to detect the link to the specified IPv4 BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bfd [ echo | multi-hop | single-hop ]
By default, BFD is disabled.
Procedure (IPv6 peers)
Step
Remarks
N/A
N/A
3.     Enable BFD to detect the link to the specified IPv6 BGP peer or peer group. Choose one command as needed:
·     peer { group-name | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } bfd [ echo | multi-hop | single-hop ]
·     interface-peer interface-type interface-number bfd [ multi-hop | single-hop ]
The link-local-address interface interface-type interface-number option and the echo keyword are mutually exclusive.
Configuring BGP FRR
When a link fails, the packets on the link are discarded, and a routing loop might occur until BGP completes routing convergence based on the new network topology.
You can enable BGP fast reroute (FRR) to resolve this issue.
Figure 19 Network diagram for BGP FRR
After you configure FRR on Router B as shown in Figure 19, BGP generates a backup next hop Router C for the primary route. BGP uses ARP (for IPv4), echo-mode BFD (for IPv4), or ND (for IPv6) to detect the connectivity to Router D. When the link to Router D fails, BGP directs packets to the backup next hop. At the same time, BGP calculates a new optimal route, and forwards packets over the optimal route.
You can use the following methods to configure BGP FRR:
·     Method 1—Execute the pic command in BGP address family view. BGP calculates a backup next hop for each BGP route in the address family if there are two or more unequal-cost routes that reach the destination.
·     Method 2—Execute the fast-reroute route-policy command to use a routing policy in which a backup next hop is specified by using the command apply [ ipv6 ] fast-reroute backup-nexthop. The backup next hop calculated by BGP must be the same as the specified backup next hop. Otherwise, BGP does not generate a backup next hop for the primary route. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
BGP supports FRR for IPv4 and IPv6 unicast routes, but not for IPv4 and IPv6 multicast routes.
To configure BGP FRR (IPv4 unicast address family):
Step
Remarks
N/A
2.     Configure the source address of echo packets.
bfd echo-source-ip ipv4-address
By default, no source address is specified for echo packets.
This step is required when echo-mode BFD is used to detect the connectivity to the next hop of the primary route.
Specify a source IP address that does not belong to any local network.
For more information about this command, see High Availability Command Reference.
3.     Create a routing policy and enter routing policy view.
route-policy route-policy-name permit node node-number
By default, no routing policies exist.
This step is required when Method 2 is used to enable BGP FRR.
For more information about this command, see Layer 3—IP Routing Command Reference.
4.     Set the backup next hop for FRR.
apply fast-reroute backup-nexthop ipv4-address
By default, no backup next hop is set.
N/A
6.     Enter BGP instance view.
N/A
7.     (Optional.) Use BFD to detect the connectivity to the next hop of the primary route.
primary-path-detect bfd { ctrl | echo }
By default, ARP is used to detect the connectivity to the next hop.
8.     (Optional.) Enter BGP-VPN instance view.
N/A
9.     Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
N/A
10.     Enable BGP FRR.
·     (Method 1) Enable BGP FRR for the address family:
pic
·     (Method 2) Apply a routing policy to FRR for the address family:
By default, BGP FRR is disabled.
Method 1 might result in routing loops. Use it with caution.
The apply fast-reroute backup-nexthop and apply ipv6 fast-reroute backup-nexthop commands can take effect in the applied routing policy. Other apply commands do not take effect.
To configure BGP FRR (IPv6 unicast address family):
Step
Remarks
N/A
2.     Create a routing policy and enter routing policy view.
3.     Set the backup next hop for FRR.
apply ipv6 fast-reroute backup-nexthop ipv6-address
4.     Return to system view.
N/A
5.     Enter BGP instance view or BGP-VPN instance view.
N/A
6.     Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
N/A
7.     Enable BGP FRR.
pic
Configuring BGP maintenance features
About BGP maintenance features
For maintenance purposes, you can use either BGP isolation or BGP shutdown to remove the device from the network. The device will not be used for forwarding traffic from its peers after they reselect an optimal route. Both BGP isolation and BGP shutdown retain the device configuration to facilitate maintenance workload.
After maintenance, you can disable BGP isolation or BGP shutdown to add the device back to the network.
Configuring BGP isolation
To maintain a BGP network device, you can use BGP isolation to remove the device from the network. This feature reduces configuration workload and impact on the network by retaining the device configuration during the maintenance. After maintenance, you can disable BGP isolation to add the device back to the network.
BGP isolation works as follows:
1.     BGP withdraws all routes advertised by the device except for the directly-connected routes.
2.     BGP keeps all routes learned from its peers.
3.     Each peer of the device reselects an optimal route and updates the FIB table. During optimal route selection, the peers can still use the routes advertised by the device to forward traffic.
4.     After an optimal route is selected and the FIB table is updated, the peers stop forwarding packets except for those destined for the device to the device. The device is fully isolated from the network and you can upgrade it.
5.     After the maintenance, disable BGP isolation on the device to gracefully add it back to the network. After returning to the network, the device advertises and learns routes as follows:
¡     Advertises routes to its peers.
¡     Learns routes if BGP was reset during the isolation.
IMPORTANT
IMPORTANT:
To avoid isolation failure, do not use this feature when GR or NSR is enabled for the device.
To configure BGP isolation:
Step
Remarks
N/A
N/A
3.     Configure BGP isolation.
·     Enable BGP isolation to gracefully remove the device from the network:
isolate enable
·     Disable BGP isolation to gracefully add the device to the network:
undo isolate enable
By default, BGP isolation is disabled.
Configuring BGP shutdown
For maintenance purposes, you can use this feature to temporarily tear down all BGP sessions. After maintenance, you can disable this feature to restore these sessions.
With this feature enabled, the device tears down all sessions and clears all routing information.
The device cannot establish BGP sessions in one of the following conditions:
·     BGP shutdown is configured.
·     BGP session establishment is disabled. For more information about disabling BGP session establishment, see "Disabling BGP session establishment."
To configure BGP shutdown:
Step
Remarks
N/A
N/A
3.     Configure BGP shutdown.
·     Tear down BGP sessions to all peers and peer groups:
shutdown process
·     Restore the BGP sessions to add the device back to the network:
undo shutdown process
By default, BGP can establish sessions with all peers and peer groups.
Configuring 6PE
IPv6 provider edge (6PE) is a transition technology that uses MPLS to connect sparsely populated IPv6 networks through an existing IPv4 backbone network. It is an efficient solution for ISP IPv4/MPLS networks to provide IPv6 traffic switching capability.
Figure 20 Network diagram for 6PE
6PE mainly performs the following operations:
·     6PE assigns a label to IPv6 routing information received from a CE router, and sends the labeled IPv6 routing information to the peer 6PE device through an MP-BGP session. The peer 6PE device then forwards the IPv6 routing information to the attached customer site.
·     6PE provides tunnels over the IPv4 backbone so the IPv4 backbone can forward packets for IPv6 networks. The tunnels can be GRE tunnels, MPLS LSPs, or MPLS TE tunnels.
·     Upon receiving an IPv6 packet, 6PE adds an inner tag (corresponding to the IPv6 packet) and then an outer tag (corresponding to the public network tunnel) to the IPv6 packet. Devices in the IPv4 backbone network forwards the packet based on the outer tag. When the peer 6PE device receives the packet, it removes the outer and inner tags and forwards the original IPv6 packet to the attached customer site.
To implement exchange of IPv6 routing information, you can configure IPv6 static routing, an IPv6 IGP protocol, or IPv6 BGP between CE and 6PE devices.
For more information about MPLS, MPLS TE, CE, and P, see MPLS Configuration Guide. For more information about GRE, see Layer 3—IP Services Configuration Guide.
Configuring basic 6PE
Before you configure 6PE, perform the following tasks:
·     Establish tunnels in the IPv4 backbone network (see Layer 3—IP Services Configuration Guide).
·     Configure basic MPLS on 6PE devices (see MPLS Configuration Guide).
·     Configure BGP on 6PE devices so that they can advertise tagged IPv6 routing information through BGP sessions. The following describes only BGP configurations on 6PE devices.
To configure basic 6PE:
Step
Remarks
N/A
N/A
3.     Specify a 6PE peer or peer group and its AS number.
No 6PE peer is specified by default.
4.     Enter BGP IPv6 unicast address family view.
N/A
5.     Enable BGP to exchange IPv6 unicast routing information with the 6PE peer or peer group.
This feature is disabled by default.
6.     Enable BGP to exchange labeled IPv6 routes with the 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } label-route-capability
Configuring optional 6PE capabilities
CAUTION
CAUTION:
Resetting a BGP session will cause temporary session interruption.
Step
Remarks
N/A
N/A
N/A
4.     Advertise COMMUNITY attribute to the 6PE peer or peer group.
By default, the COMMUNITY attribute is not advertised.
5.     Advertise extended community attribute to the 6PE peer or peer group.
By default, the extended community attribute is not advertised.
6.     Allow the local AS number to appear in routes from the 6PE peer or peer group and specify the repeat times.
By default, the local AS number is not allowed to appear in routes from the 6PE peer or peer group.
7.     Specify an AS path list to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } as-path-acl { as-path-acl-number | as-path-acl-name } { export | import }
By default, no AS path list is specified.
8.     Specify an IPv6 ACL to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } filter-policy { ipv6-acl-number | name ipv6-acl-name } { export | import }
By default, no ACL is specified.
9.     Specify an IPv6 prefix list to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } prefix-list ipv6-prefix-list-name { export | import }
By default, no IPv6 prefix list is specified.
10.     Specify a routing policy to filter routes advertised to or received from the 6PE peer or peer group.
By default, no routing policy is specified.
11.     Advertise a default route to the 6PE peer or peer group.
By default, no default route is advertised.
12.     Save all routes from the 6PE peer or peer group.
By default, routes from a peer or peer group are not saved.
13.     Configure BGP updates sent to the 6PE peer or peer group to carry only public AS numbers.
peer { group-name | ipv4-address [ mask-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
By default, BGP updates sent to a 6PE peer or peer group can carry both public and private AS numbers.
14.     Specify the maximum number of routes that BGP can receive from the 6PE peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } route-limit prefix-number [ { alert-only discard | reconnect reconnect-time } | percentage-value ] *
By default, the number of routes that a router can receive from the 6PE peer or peer group is not limited.
15.     Specify a preferred value for routes received from the 6PE peer or peer group.
By default, the preferred value is 0.
16.     Configure the device as a route reflector and the 6PE peer or peer group as a client.
17.     Configure the SoO attribute for a peer or peer group.
By default, no SoO attribute is configured for a peer or peer group.
18.     Return to user view.
return
N/A
19.     Display information about the 6PE peer or peer group.
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
Available in any view.
20.     Display routing information advertised to or received from the 6PE peer or peer group.
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] peer ipv4-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ]
21.     Soft-reset a BGP 6PE connection.
refresh bgp [ instance instance-name ] ipv4-address [ mask-length ] { export | import } ipv6 [ unicast ]
Available in user view.
22.     Reset a BGP 6PE connection.
reset bgp [ instance instance-name ] ipv4-address [ mask-length ] ipv6 [ unicast ]
Configuring BGP LS
The BGP Link State (LS) feature implements inter-domain and inter-AS advertisement of link state database (LSDB) and TE database (TEDB) information.
The device sends the collected link state information to the controller, which implements end-to-end traffic management and scheduling, and meets the requirements of intended applications.
Configuring basic BGP LS
Step
Remarks
N/A
N/A
3.     Specify an AS number for an LS peer or peer group.
peer { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } as-number as-number
By default, no AS number is specified.
4.     Create the BGP LS address family and enter its view.
address-family link-state
N/A
5.     Enable the device to exchange LS information with the peer or peer group.
By default, the device cannot exchange LS information with the peer or peer group.
6.     (Optional.) Set the optimal route selection delay timer.
Configuring BGP LS route reflection
To configure BGP LS route reflection:
Step
Remarks
N/A
N/A
3.     Enter BGP LS address family view.
N/A
4.     Configure the device as a route reflector and specify a peer or peer group as its client.
5.     Enable route reflection between clients.
6.     (Optional.) Configure the cluster ID of the route reflector.
Specifying an AS number and a router ID for BGP LS messages
Perform this task to ensure that LS messages sent by devices in the same AS have the same AS number and router ID.
To specify an AS number and a router ID for BGP LS messages:
Step
Remarks
N/A
N/A
N/A
4.     Specify an AS number and a router ID for BGP LS messages.
domain-distinguisher as-number:router-id
By default, the AS number and router ID of the current BGP process are used.
Configuring BMP
BGP monitors only the real-time states of BGP sessions and BGP routes. It cannot directly monitor session state change and route update processes. To resolve this issue, configure the BGP monitoring protocol (BMP) feature. BMP enables a BGP router (BMP client) to send session state information of the specified peers to BMP servers for monitoring. The session status information includes peer relationship establishment and termination as well as routing information.
BMP benefits
·     BMP uses TCP as its transmission layer protocol, which ensures the transmission reliability.
·     As an extended feature of BGP, BMP collects the required information through a simple work mechanism.
·     All BMP settings are configured on the BMP client, which simplifies the configuration and management.
·     To implement BMP, the BMP client only needs to send BMP packets to the BMP server. It does not require any BMP packets from the BMP server, which barely affects the current network.
BMP components
BMP contains the following components:
·     Client—Device configured with the BMP feature. You must specify the IP address and port number of the BMP server on the BMP client to enable them to establish a TCP connection. A BMP client can connect to multiple BMP servers.
·     Server— Monitoring server.
·     Monitored peer—Device being monitored. It must be a peer of the BMP client.
As shown in Figure 21, Device A, Device B, and Device C have established a BGP session with one another. You can configure BMP on Device B (BMP client) to enable the BMP server to monitor the running state changes and route updates of Device A and Device C (monitored peers).
Figure 21 BMP components
BMP messages
BMP defines the following messages:
·     Initiation—After establishing a TCP connection to the BMP server, the BMP client sends an initiation message to the BMP server to report its software version and vendor.
·     Termination—Reports TCP connection down causes to the BMP server. After sending a termination message to the BMP server, the BMP client terminates the TCP connection and stops sending messages to the BMP server through the TCP connection.
·     Peer Up Notification—Reports information about BGP sessions between the BMP client and monitored peers to the BMP server. A peer up notification contains information in the open messages exchanged with a monitored peer and TCP connection information. The BMP client will send a peer up notification for each BGP session in established state.
·     Peer Down Notification—Reports BGP session down events and causes to the BMP server. The BMP client sends a peer down notification when the state of a monitored peer changes from Established to another value.
·     Stats Reports—Reports BGP running statistics information to the BMP server. The statistics information includes number of routes discarded because of duplicated AS path attributes, number of routes received from peers, and number of duplicated up messages.
·     Route Monitoring—Reports BGP routes (including initial, updated, and withdrawal routes) exchanged between the BMP client and monitored peers to the BMP server.
BMP mechanism
BMP works as follows:
1.     The BMP client establishes a TCP connection with the BMP server.
2.     The BMP client sends an initiation message to the BMP server to advertise its information.
3.     The BMP client sends a peer up notification and a route monitoring message to the BMP server to advertise the initial state and routing information of the monitored peer.
4.     The BMP client sends peer up notifications, peer down notifications, route monitoring messages, and stats reports to the BMP server to report state changes and route updates of the monitored peers.
The BMP client sends a termination message to the BMP server and tears down the TCP connection to terminate the monitoring.
Establishing a TCP connection between the BMP client and BMP server
Step
Remarks
N/A
2.     Create a BMP server and enter BMP server view.
bmp server server-number
By default, no BMP servers exist.
3.     Configure an IP address and port number for the BMP server.
server address { ipv4-address | ipv6-address } port port-number
By default, no IP address and port number are configured for the BMP server.
4.     (Optional.) Specify a VPN instance for the BMP server.
server vpn-instance vpn-instance-name
By default, no VPN instance is specified for the BMP server. The BMP server belongs to the public network.
5.     (Optional.) Specify the source interface of TCP connections to the BMP server.
server connect-interface interface-type interface-number
By default, BGP uses the primary IPv4 or IPv6 address of the output interface in the optimal route to the BMP server as the source address of TCP connections to the BMP server.
This command does not take effect if the specified interface's VPN instance is different from that configured in the server vpn-instance command for the same server.
6.     (Optional.) Specify the source address of TCP connections to the BMP server.
server source-address { ipv4-address | ipv6-address }
If you execute both this command and the server connect-interface command for a BMP server, the configuration of this command takes effect.
7.     (Optional.) Specify the authentication mode and key for the local device to establish TCP connections to the BMP server.
server password { keychain keychain-name | md5 { cipher | simple } string }
By default, the local device establishes TCP connections to the BMP server without authentication.
Enabling a BMP server to monitor a peer or peer group
You can execute one of the following commands to enable a BMP server to monitor BGP peers:
·     Execute the peer bmp server command to enable the specified BMP server to monitor the specified peer or peer group.
·     Execute the bmp server monitor current-instance command to enable the specified BMP server to monitor all peers in the current instance.
·     Execute the bmp server monitor all-vpn-instance command to enable the specified BMP server to monitor all peers in all BGP-VPN instances.
For a BGP peer, the following rules apply:
·     The BMP server specified by the peer bmp server command takes precedence over that specified by the bmp server monitor current-instance command.
·     The BMP server specified by the bmp server monitor current-instance command takes precedence over that specified by the bmp server monitor all-vpn-instance command.
To enable a BMP server to monitor a peer or peer group:
Step
Remarks
N/A
2.     Enter BGP instance view or BGP-VPN instance view.
·     Enter BGP instance view:
·     Enter BGP-VPN instance view:
a.     bgp as-number [ instance instance-name ]
b.     ip vpn-instance vpn-instance-name
N/A
3.     Enable a BMP server to monitor a peer or peer group. Choose the options to configure as needed:
·     Enable the specified BMP server to monitor the specified peer or peer group:
a.     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } bmp server server-number-list
b.     interface-peer interface-type interface-number bmp server server-number-list
By default, a BMP server cannot monitor a peer or peer group.
·     Enable the specified BMP server to monitor all peers in the current instance:
bmp server server-number monitor current-instance [ route-mode { adj-rib-in { pre-policy | post-policy | both } | adj-rib-out { pre-policy | post-policy | both } } * ]
By default, a BMP server cannot monitor the peers in the current instance.
·     Enable the specified BMP server to monitor all peers in all BGP-VPN instances:
bmp server server-number monitor all-vpn-instance [ route-mode { adj-rib-in { pre-policy | post-policy | both } | adj-rib-out { pre-policy | post-policy | both } } * ]
By default, a BMP server cannot monitor the peers in a BGP-VPN instance.
This command is not supported in BGP-VPN instance view.
Sending routes to the BMP server
For a peer or peer group, the following rules apply when BGP determines the type of routes to send to the BMP server:
·     The route type specified by the peer route-mode command takes precedence over that specified by the bmp server monitor current-instance route-mode command.
·     The route type specified by the bmp server monitor current-instance route-mode command takes precedence over that specified by the bmp server monitor all-vpn-instance route-mode command.
·     The route type specified by the bmp server monitor all-vpn-instance route-mode command takes precedence over that specified by the route-mode adj-rib-out or route-mode adj-rib-out command.
You can execute the route-mode loc-rib command to configure BGP to send the optimal routes in the routing table to the BMP server.
To send routes to the BMP server:
Step
Remarks
N/A
2.     Enter BMP server view.
N/A
3.     Enable BGP to send routes to the BMP server globally. Choose the following options to configure as needed:
·     Enable BGP to send routes advertised to all the monitored peers and peer groups to the BMP server:
route-mode adj-rib-out [ pre-policy | post-policy | both ]
By default, BGP does not send routes advertised to a monitored peer or peer group to the BMP server.
·     Enable BGP to send routes received from all the monitored peers and peer groups to the BMP server:
route-mode adj-rib-in [ pre-policy | post-policy | both ]
By default, BGP does not send routes received from a monitored peer or peer group to the BMP server.
·     Configure BGP to send the optimal routes in the routing table to the BMP server:
route-mode loc-rib
By default, BGP does not send the optimal routes in the routing table to the BMP server.
With this feature configured, BGP sends all routes to the BMP server first. If routes update later, BGP sends only the optimal routes to the server.
N/A
N/A
6.     Enable BGP to send routes exchanged with a monitored peer or peer group to the BMP server. Choose the following options to configure as needed:
·     Enable BGP to send routes exchanged with the specified monitored peer or peer group to the BMP server:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } route-mode { adj-rib-in { pre-policy | post-policy | both } | adj-rib-out { pre-policy | post-policy | both } } *
·     Enable BGP to send routes exchanged with all the monitored peers and peer groups in the current instance to the BMP server:
bmp server server-number monitor current-instance route-mode { adj-rib-in { pre-policy | post-policy | both } | adj-rib-out { pre-policy | post-policy | both } } *
·     Enable BGP to send routes exchanged with all the monitored peers and peer groups in all BGP-VPN instances to the BMP server:
bmp server server-number monitor all-vpn-instance route-mode { adj-rib-in { pre-policy | post-policy | both } | adj-rib-out { pre-policy | post-policy | both } } *
By default, BGP determines whether to send routes exchanged with a peer or peer group to the BMP server based on the following configurations:
·     Configuration of the route-mode adj-rib-in command in BMP server view.
·     Configuration of the route-mode adj-rib-out command in BMP server view.
Configuring the BMP client to send notifications with mode flags to the BMP server
Perform this task to configure the BMP client to send peer up/down notifications with the following flags:
·     Adj-RIB-In—The BMP client sends routes received from monitored peers to the BMP server.
·     Adj-RIB-Out—The BMP client sends routes advertised to monitored peers to the BMP server.
·     pre-policy—The BMP client sends routes to the BMP server without filtering.
·     post-policy—The BMP client sends routes to the BMP server after filtering.
By default, the BMP client sends peer up/down notifications with the Adj-RIB-In and pre-policy flags to the BMP server after you configure this feature.
·     After you add a route sending mode by executing the route-mode adj-rib-in, route-mode adj-rib-out, or peer route-mode command, the BMP client will send peer up notifications with the new mode flag to the BMP server.
·     After you delete the route sending mode by executing the route-mode adj-rib-in, route-mode adj-rib-out, or peer route-mode command, the BMP client will send peer down notifications with the new mode flag to the BMP server.
For example, if you execute the route-mode adj-rib-out post-policy command after executing the route-mode adj-rib-out pre-policy command, the BMP client sends routes to the BMP server after filtering. The BMP client will send both peer up and peer down notifications with the new mode flags to the BMP server.
To configure the BMP client to send notifications with mode flags to the BMP server:
Step
Remarks
N/A
N/A
3.     Configure the BMP client to send notifications with mode flags to the BMP server. Choose a minimum of one task:
·     Configure the BMP client to send peer up notifications with mode flags to the BMP server:
pu-monitor-mode enable
·     Configure the BMP client to send peer down notifications with mode flags to the BMP server:
pd-monitor-mode enable
By default, the BMP client sends peer up/down notifications without mode flags to the BMP server.
Sending statistics information to the BMP server
The BMP client uses stats reports to report statistics information to the BMP server. Perform this task to set the interval at which the BMP client sends stats reports to the BMP server.
To send statistics information to the BMP server:
Step
Remarks
N/A
N/A
3.     Set the interval at which the BMP client sends statistics information to the BMP server.
statistics-interval value
By default, the BMP client does not send statistics information to the BMP server.
Configuring BGP RPKI
The AS_PATH attribute identifies the ASs through which a route has passed, and the AS that originated the route is the origin AS of the route. If the origin AS number of a route is incorrect, traffic transmission failure or even network collapse might occur.
To avoid this problem, you can configure the BGP Resource Public Key Infrastructure (RPKI) feature. It enables BGP to validate the origin AS of a route and determine whether to use and advertise the route based on the validation state.
Configuring RPKI connection parameters
A router establishes a TCP connection with an RPKI server to obtain the Route Origin Authorization (ROA) information used for RPKI validation. The router checks the connection to the RPKI server at the specified interval. If the router does not receive a response from the RPKI server within the specified time period, it tears down the connection to the RPKI server.
When the connection between a router and an RPKI server goes down (except when the shutdown command is executed), the router takes the following actions:
·     Attempts to reconnect to the server.
·     Places the ROA information obtained from the server in aging state, and starts the aging timer for the ROA information.
If the router reconnects to the server before the aging timer expires, it releases the ROA information from the aging state. If the router fails to reconnect to the server when the aging timer expires, it deletes the ROA information obtained from the server.
Follow these restrictions and guidelines when you configure RPKI connection parameters:
·     As a best practice, set an ROA information aging time longer than the time to wait for the response from the RPKI server.
·     To tear down the connection to an RPKI server, execute the undo port command in RPKI server view.
·     If you execute the undo rpki command, all configurations in RPKI view are removed.
To configure RPKI connection parameters:
Step
Remarks
N/A
N/A
3.     Enter BGP RPKI view.
rpki
N/A
4.     Specify an RPKI server by its IP address and enter RPKI server view.
server [ vpn-instance vpn-instance-name ] tcp { ipv4-address | ipv6-address }
By default, no RPKI server is specified.
5.     Specify the port number of the RPKI server.
port port-number
By default, the port number of the RPKI server is not specified.
To enable a router to establish a TCP connection with the RPKI server, you must configure the port number of the RPKI server on the router.
6.     (Optional.) Specify the MD5 authentication password.
passwords { cipher | simple } string
By default, the RPKI server does not perform MD5 authentication.
The MD5 authentication password must be the same as the authentication password configured on the RPKI server.
MD5 authentication ensures the validity of the RPKI server and the security of BGP RPKI packets.
7.     (Optional.) Set the RPKI connection check interval.
refresh-time refresh-time
By default, the RPKI connection check interval is 600 seconds.
8.     (Optional.) Set the time to wait for the response from the RPKI server.
response-time response-time
By default, the time to wait for the response from the RPKI server is 30 seconds.
9.     (Optional.) Set the aging time for the ROA information.
purge-time purge-time
By default, the aging time for the ROA information is 60 seconds.
Enabling BGP RPKI validation
After you configure this feature, BGP validates the prefix and origin AS number of a received route and places the route to one of the following validation states:
·     Not-found—No ROA matches the prefix.
·     Valid—One or multiple ROAs match both the prefix and origin AS number.
·     Invalid—One or multiple ROAs match the prefix, but none of the ROAs matches the origin AS number.
If you configure this feature, BGP uses the local RPKI validation states. If you do not configure this feature, BGP uses the validation states in the received BGP routes.
To enable BGP RPKI validation:
Step
Remarks
N/A
N/A
rpki
N/A
4.     Enable BGP RPKI validation.
check-origin-validation
By default, BGP RPKI validation is disabled.
Applying the BGP RPKI validation state to optimal route selection
If multiple routes to the same destination are available, BGP first discards routes with unreachable next hops, and then selects the optimal route according to the following rules:
·     Routes with a BGP RPKI validation state of Valid takes precedence over routes with a validation state of Not-found or Invalid.
·     Routes with a BGP RPKI validation state of Not-found takes precedence over routes with a validation state of Invalid.
·     Routes without a BGP RPKI validation state have the same priority as routes with a BGP RPKI validation state of Not-found.
·     For routes that have the same BGP RPKI validation state, BGP selects the optimal route according to the rules in "BGP route selection."
You can configure a routing policy to filter routes based on the BGP RPKI validation state. For more information about routing policies, see "Configuring routing policies."
To apply the BGP RPKI validation state to optimal route selection (IPv4 unicast):
Step
Remarks
N/A
2.     Enter BGP IPv4 unicast address family view or BGP-VPN IPv4 unicast address family view.
N/A
3.     Apply the BGP RPKI validation state to optimal route selection.
bestroute origin-as-validation [ allow-invalid ]
By default, BGP ignores the BGP RPKI validation state during optimal route selection.
To allow routes with a validation state of Invalid to participate in optimal route selection, you must specify the allow-invalid keyword.
To apply the BGP RPKI validation state to optimal route selection (IPv6 unicast):
Step
Remarks
N/A
2.     Enter BGP IPv6 unicast address family view or BGP-VPN IPv6 unicast address family view.
N/A
Advertising BGP RPKI validation state to a peer or peer group
BGP advertises the BGP RPKI validation state to a peer or peer group through the extended community attribute. To enable this feature, you must first enable BGP to advertise the extended community attribute to the peer or peer group and make sure RPKI settings are correct.
In the current software version, BGP can advertise the BGP RPKI validation state only to IBGP peers and peer groups.
To advertise the BGP RPKI validation state to a peer or peer group (IPv4 unicast):
Step
Remarks
N/A
N/A
3.     Advertise the extended community attribute to a peer or peer group.
By default, BGP does not advertise the extended community attribute.
4.     Advertise the BGP RPKI validation state to the specified peer or peer group. Choose one command as needed:
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise origin-as-validation
·     interface-peer interface-type interface-number advertise origin-as-validation
By default, BGP does not advertise the BGP RPKI validation state.
To advertise the BGP RPKI validation state to a peer or peer group (IPv6 unicast):
Step
Remarks
N/A
N/A
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise-ext-community
·     peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number } advertise origin-as-validation
Configuring BGP dedicated routes
About BGP dedicated routes
As shown in Figure 22, Device B and Device C are EBGP peers of both Device A and Device D, and the EBGP peers can exchange dedicated routes. Both Device A and Device D are enabled with IPSG. When a client accesses Device A through AP 1, Device A generates an IPSG binding for the client based on the DHCP, DHCPv6, or ND snooping entry. Then, Device B and Device C synchronize the IPSG binding of the client through BGP dedicated routes, and they synchronize the IPSG binding to Device D. When the client migrates from Device A to Device D, the client can quickly come online based on the synchronized IPSG binding. For more information about IPSG and IPSG bindings, see IP source guard configuration in Security Configuration Guide.
Figure 22 Network diagram
Configuring basic BGP dedicated route settings
Step
Remarks
N/A
N/A
3.     Specify an AS number for a peer or peer group.
By default, no AS number is specified for a peer or peer group.
4.     Create the BGP dedicated address family and enter its view.
address-family dedicated
N/A
5.     Enable BGP to exchange dedicated routes with a peer or peer group.
By default, BGP cannot exchange dedicated routes with a peer or peer group.
6.     (Optional.) Specify the router as the next hop for routes sent to a peer or peer group.
By default, the router sets itself as the next hop for routes sent to an EBGP peer or peer group. It does not set itself as the next hop for routes sent to an IBGP peer or peer group.
7.     (Optional.) Permit the local AS number to appear in routes from a peer or peer group and set the appearance times.
By default, the local AS number is not allowed in routes from a peer or peer group.
Configuring BGP dedicated route reflection
Perform this task to configure a BGP route reflector and its clients. The route reflector and its clients automatically form a cluster identified by the router ID of the route reflector. The route reflector forwards route updates among its clients.
Step
Remarks
N/A
N/A
3.     Enter BGP dedicated address family view.
N/A
5.     (Optional.) Enable route reflection between clients.
This command can reduce the number of IBGP connections in an AS.
Resetting BGP sessions in dedicated address family
Execute one command in user view.
·     Perform manual soft-reset on BGP sessions of the dedicated address family.
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } { export | import } dedicated
·     Reset BGP sessions of the dedicated address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } dedicated
Displaying and maintaining BGP
Displaying BGP
Execute display commands in any view (IPv4 unicast address family).
Display BGP NSR status information.
display bgp [ instance instance-name ] non-stop-routing status
Display BGP IPv4 unicast peer group information.
display bgp [ instance instance-name ] group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ]
Display information about a peer or peer group in BGP IPv4 unicast address family.
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer ipv4 [ unicast ] vpn-instance-all [ verbose ]
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ ipv6-address prefix-length | interface interface-type interface-number | ipv6-address [ interface interface-type interface-number ] { log-info | verbose } ]
Display BGP IPv4 unicast routing information.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl { as-path-acl-number | as-path-acl-name } | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer { ipv4-address | ipv6-address [ interface interface-type interface-number ] } { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
Display information about BGP peer relationship down events.
display bgp [ instance instance-name ] troubleshooting [ event-count ] [ reverse ]
Display dampened BGP IPv4 unicast routing information.
display bgp [ instance instance-name ] routing-table dampened ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP dampening parameter information.
display bgp [ instance instance-name ] dampening parameter ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP IPv4 unicast routing flap statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ]
Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command.
display bgp [ instance instance-name ] network ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP path attribute information.
Restore the priority of the routes to be advertised during the time to wait for route priority restoration.
reset bgp [ instance instance-name ] advertise lowest-priority { on-peer-up | on-startup }
Display BGP IPv4 unicast address family update group information.
display bgp [ instance instance-name ] update-group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address ]
display bgp [ instance instance-name ] update-group ipv4 [ unicast ] [ ipv6-address ]
Display information about all BGP instances.
display bgp instance-info
Display BMP server information.
display bgp [ instance instance-name ] bmp server server-number
Display information about BGP peers monitored by the specified BMP server for the specified BGP instance.
display bgp [ instance instance-name ] bmp server server-number monitor-peer all
display bgp [ instance instance-name ] bmp server server-number monitor-peer [ vpn-instance vpn-instance-name ] ipv4 { ipv4-address | ipv6-address }
Display ORF prefix information received by a peer.
display bgp [ instance instance-name ] peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] ipv4-address received prefix-list
display bgp [ instance instance-name ] peer ipv4 [ unicast ] ipv6-address [ interface interface-type interface-number ] received prefix-list
Display information about connections to RPKI servers.
display bgp [ instance instance-name ] rpki server [ [ vpn-instance vpn-instance-name ] ipv4-address ]
Display the ROA information obtained from RPKI servers.
display bgp [ instance instance-name ] rpki table ipv4 [ ipv4-address min min-length max max-length ]
Execute display commands in any view (IPv6 unicast address family).
Display BGP IPv6 unicast peer group information.
display bgp [ instance instance-name ] group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name group-name ]
Display information about a peer or peer group in BGP IPv6 unicast address family.
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ]
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ [ link-local-address ] interface interface-type interface-number |link-local-address interface interface-type interface-number { log-info | verbose } ]
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ ipv4-address mask-length | ipv4-address log-info | [ ipv4-address ] verbose ]
display bgp [ instance instance-name ] peer ipv6 [ unicast ] vpn-instance-all [ verbose ]
Display BGP IPv6 unicast routing information.
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl { as-path-acl-number | as-path-acl-name } | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] peer { ipv4-address | [ link-local-address ] interface interface-type interface-number  } { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ]
Display dampened BGP IPv6 unicast routing information.
display bgp [ instance instance-name ] routing-table dampened ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
display bgp [ instance instance-name ] dampening parameter ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP IPv6 unicast routing flap statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ]
Display incoming labels for BGP IPv6 unicast routes.
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] inlabel
Display outgoing labels of BGP IPv6 unicast routes.
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] outlabel
display bgp [ instance instance-name ] network ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP IPv6 unicast address family update group information.
display bgp [ instance instance-name ] update-group ipv6 [ unicast ] [ ipv4-address | ipv6-address ]
display bgp [ instance instance-name ] update-group ipv6 [ unicast ] vpn-instance vpn-instance-name [ ipv6-address ]
display bgp [ instance instance-name ] bmp server server-number monitor-peer [ vpn-instance vpn-instance-name ] ipv6 { ipv4-address | ipv6-address }
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] ipv6-address received prefix-list
display bgp [ instance instance-name ] peer ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] { ipv4-address | [ link-local-address ] interface interface-type interface-number } received prefix-list
display bgp [ instance instance-name ] rpki server [ [ vpn-instance vpn-instance-name ] ipv6-address ]
display bgp [ instance instance-name ] rpki table ipv6 [ ipv6-address min min-length max max-length
Execute display commands in any view (IPv4 multicast address family).
Display BGP IPv4 multicast peer group information.
display bgp [ instance instance-name ] group ipv4 multicast [ group-name group-name ]
Display BGP IPv4 multicast peer or peer group information.
display bgp [ instance instance-name ] peer ipv4 multicast [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ]
Display BGP IPv4 multicast routing information.
display bgp [ instance instance-name ] routing-table ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl { as-path-acl-number | as-path-acl-name } | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
Display dampened BGP IPv4 multicast routing information.
display bgp [ instance instance-name ] routing-table dampened ipv4 multicast
display bgp [ instance instance-name ] dampening parameter ipv4 multicast
Display BGP IPv4 multicast routing flap statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv4 multicast [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } ]
display bgp [ instance instance-name ] network ipv4 multicast
Display BGP IPv4 multicast address family update group information.
display bgp [ instance instance-name ] update-group ipv4 multicast [ ipv4-address ]
display bgp [ instance instance-name ] peer ipv4 multicast ipv4-address received prefix-list
Execute display commands in any view (IPv6 multicast address family).
Display BGP IPv6 multicast peer group information.
display bgp [ instance instance-name ] group ipv6 multicast [ group-name group-name ]
Display BGP IPv6 multicast peer or peer group information.
display bgp [ instance instance-name ] peer ipv6 multicast [ ipv6-address prefix-length | { ipv6-address | group-name group-name } log-info | [ ipv6-address ] verbose ]
Display BGP IPv6 multicast routing information.
display bgp [ instance instance-name ] routing-table ipv6 multicast [ ipv6-address prefix-length [ advertise-info ] | as-path-acl { as-path-acl-number | as-path-acl-name } | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
Display dampened BGP IPv6 multicast routing information.
display bgp [ instance instance-name ] routing-table dampened ipv6 multicast
display bgp [ instance instance-name ] dampening parameter ipv6 multicast
Display BGP IPv6 multicast routing flap statistics.
display bgp [ instance instance-name ] routing-table flap-info ipv6 multicast [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ]
display bgp [ instance instance-name ] network ipv6 multicast
Display BGP IPv6 multicast address family update group information.
display bgp [ instance instance-name ] update-group ipv6 multicast [ ipv6-address ]
display bgp [ instance instance-name ] peer ipv6 multicast ipv6-address received prefix-list
Execute display commands in any view (LS address family).
Display BGP LS peer group information.
display bgp [ instance instance-name ] group link-state [ group-name group-name ]
Display BGP LS information.
display bgp [ instance instance-name ] link-state [ ls-prefix [ advertise-info ] | peer { ipv4-address | ipv6-address } { advertised | received } [ statistics ] | statistics ]
Display BGP LS peer or peer group information.
display bgp [ instance instance-name ] peer link-state [ ipv4-address mask-length | ipv6-address prefix-length | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
Display BGP LS address family update group information.
display bgp [ instance instance-name ] update-group link-state [ ipv4-address | ipv6-address ]
Execute display commands in any view (IPv4 RT filter address family).
Display BGP IPv4 RT filter routing information.
display bgp [ instance instance-name ] routing-table ipv4 rtfilter [ default-rt [ advertise-info ] | [ origin-as as-number ] [ route-target [ advertise-info ] ] | peer ipv4-address { advertised-routes | received-routes } [ default-rt | [ origin-as as-number ] [ route-target ] | statistics ] | statistics ]
Execute display commands in any view (dedicated address family).
Display BGP dedicated peer group information.
display bgp [ instance instance-name ] group dedicated [ group-name group-name ]
Display BGP dedicated peer or peer group information.
display bgp [ instance instance-name ] peer dedicated [ { ipv4-address mask-length | ipv6-address prefix-length } | { ipv4-address | ipv6-address | group-name group-name } log-info | [ ipv4-address | ipv6-address ] verbose ]
Display BGP dedicated address family update group information.
display bgp [ instance instance-name ] update-group dedicated [ ipv4-address | ipv6-address ]
Execute display commands in any view (VPNv4 address family).
display bgp [ instance instance-name ] server server-number monitor-peer vpnv4 { ipv4-address | ipv6-address }
display bgp [ instance instance-name ] bmp server server-number monitor-peer vpn-instance vpn-instance-name vpnv4 ipv4-address
Execute display commands in any view (VPNv6 address family).
display bgp [ instance instance-name ] bmp server server-number monitor-peer vpnv6 { ipv4-address | ipv6-address }
Execute display commands in any view (EVPN address family).
display bgp [ instance instance-name ] bmp server server-number monitor-peer l2vpn evpn { ipv4-address | ipv6-address }
CAUTION
CAUTION:
·     Resetting a BGP session will cause temporary session interruption.
·     Executing the reset bgp rpki server command will cause temporary RPKI session interruption, because the device will delete the specified BGP RPKI session, and then re-establish the session.
Execute reset commands in user view.
Reset all BGP sessions.
Reset BGP sessions for IPv4 unicast address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp { ipv6-address [ prefix-length ] | interface interface-type interface-number } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp [ instance instance-name ] ipv6-address [ prefix-length ] | interface interface-type interface-number } ipv4 [ unicast ]
Reset BGP sessions for IPv6 unicast address family.
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | link-local-address interface interface-type interface-number | all | external | group group-name | internal } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
reset bgp ipv4-address [ mask-length ] ipv6 [ unicast ]
Reset BGP sessions for LS address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] | all | external | group group-name | internal } link-state
Reset BGP sessions for IPv4 multicast address family.
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | group group-name | internal } ipv4 multicast
Reset BGP sessions for IPv6 multicast address family.
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 multicast
Reset BGP RPKI sessions.
reset bgp [ instance instance-name ] rpki server [ vpn-instance vpn-instance-name ] tcp { ipv4 address | ipv6 address }
Reset BGP sessions for dedicated address family.
Clearing BGP information
Clear dampening information for BGP IPv4 unicast routes and release suppressed BGP IPv4 unicast routes.
reset bgp [ instance instance-name ] dampening ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] ]
Clear flap information for BGP IPv4 unicast routes.
reset bgp [ instance instance-name ] flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv4-address [ mask-length | mask ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv4-address [ mask-length ] ]
Clear dampening information for BGP IPv6 unicast routes and release suppressed BGP IPv6 unicast routes.
reset bgp [ instance instance-name ] dampening ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ]
Clear flap information for BGP IPv6 unicast routes.
reset bgp [ instance instance-name ] flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv6-address [ prefix-length ] ]
Clear dampening information for BGP IPv4 multicast routes and release suppressed BGP IPv4 multicast routes.
reset bgp [ instance instance-name ] dampening ipv4 multicast [ ipv4-address [ mask-length | mask] ]
Clear flap information for BGP IPv4 multicast routes.
reset bgp [ instance instance-name ] flap-info ipv4 multicast [ ipv4-address [ mask-length | mask ] | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv4-address [ mask-length ] ]
Clear dampening information for BGP IPv6 multicast routes and release suppressed BGP IPv6 multicast routes.
reset bgp [ instance instance-name ] dampening ipv6 multicast [ ipv6-address prefix-length ]
Clear flap information for BGP IPv6 multicast routes.
reset bgp [ instance instance-name ] flap-info ipv6 multicast [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } | peer ipv6-address [ prefix-length ] ]
Clear BMP server statistics.
reset bgp [ instance instance-name ] bmp server server-number statistics
Reset the connection to a BMP server and clear statistics information.
reset bgp [ instance instance-name ] bmp server { server-number | all }
IPv4 BGP configuration examples
Basic BGP configuration example
Network requirements
As shown in Figure 23, all switches run BGP. Run EBGP between Switch A and Switch B, and run IBGP between Switch B and Switch C to allow Switch C to access network 8.1.1.0/24 connected to Switch A.
Figure 23 Network diagram
Requirements analysis
To prevent route flapping caused by port state changes, this example uses loopback interfaces to establish IBGP connections. Loopback interfaces are virtual interfaces. Therefore, use the peer connect-interface command to specify the loopback interface as the source interface for establishing BGP connections. Enable OSPF in AS 65009 to ensure that Switch B can communicate with Switch C through loopback interfaces.
The EBGP peers, Switch A and Switch B (usually belong to different carriers), are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so directly connected interfaces are used for establishing EBGP sessions. To enable Switch C to access the network 8.1.1.0/24 connected directly to Switch A, inject network 8.1.1.0/24 to the BGP routing table of Switch A.
Configuration procedure
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure IBGP:
# Configure Switch B.
[SwitchB] bgp 65009
[SwitchB-bgp-default] quit
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1] quit
# Configure Switch C.
[SwitchC] bgp 65009
[SwitchC-bgp-default] peer 2.2.2.2 as-number 65009
[SwitchC-bgp-default] quit
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1] quit
 BGP local router ID : 3.3.3.3
 Local AS number : 65009
 Total number of peers : 1                 Peers in established state : 1
  * - Dynamically created peer
  ^ - Peer created through link-local address
  2.2.2.2              65009        2        2    0       0 00:00:13 Established
The output shows that Switch C has established an IBGP peer relationship with Switch B.
3.     Configure EBGP:
# Configure Switch A.
[SwitchA] bgp 65008
[SwitchA-bgp-default] quit
[SwitchB] bgp 65009
# Display BGP peer information on Switch B.
 BGP local router ID : 2.2.2.2
 Total number of peers : 2                 Peers in established state : 2
  3.3.3.3              65009        4        4    0       0 00:02:49 Established
  3.1.1.2              65008        2        2    0       0 00:00:05 Established
The output shows that Switch B has established an IBGP peer relationship with Switch C and an EBGP peer relationship with Switch A.
# Display the BGP routing table on Switch A.
 Total number of routes: 1
               a – additional-path
* >  8.1.1.0/24         8.1.1.1         0                     32768   i
# Display the BGP routing table on Switch B.
               a – additional-path
* >e 8.1.1.0/24         3.1.1.2         0                     0       65008i
# Display the BGP routing table on Switch C.
               a – additional-path
   i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
The outputs show that Switch A has learned no route to AS 65009, and Switch C has learned network 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
4.     Redistribute direct routes:
Configure BGP to redistribute direct routes on Switch B, so that Switch A can obtain the route to 9.1.1.0/24, and Switch C can obtain the route to 3.1.1.0/24.
[SwitchB] bgp 65009
[SwitchB-bgp-default-ipv4] import-route direct
 Total number of routes: 4
               a – additional-path
* >e 2.2.2.2/32         3.1.1.1         0                     0       65009?
* >e 3.1.1.0/24         3.1.1.1         0                     0       65009?
* >e 9.1.1.0/24         3.1.1.1         0                     0       65009?
Two routes, 2.2.2.2/32 and 9.1.1.0/24, have been added in Switch A's routing table.
               a – additional-path
* >i 2.2.2.2/32         2.2.2.2         0          100        0       ?
* >i 3.1.1.0/24         2.2.2.2         0          100        0       ?
* >i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
* >i 9.1.1.0/24         2.2.2.2         0          100        0       ?
The output shows that the route 8.1.1.0 becomes valid with the next hop as Switch A.
# Verify that Switch C can ping 8.1.1.1.
[SwitchC] ping 8.1.1.1
Ping 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL+C to break
BGP and IGP route redistribution configuration example
As shown in Figure 24, all devices of company A belong to AS 65008, and all devices of company B belong to AS 65009.
Configure BGP and IGP route redistribution to allow Switch A to access network 9.1.2.0/24 in AS 65009, and Switch C to access network 8.1.1.0/24 in AS 65008.
Figure 24 Network diagram
Configuration considerations
Configure BGP to redistribute routes from OSPF on Switch B, so Switch A can obtain the route to 9.1.2.0/24. Configure OSPF to redistribute routes from BGP on Switch B, so Switch C can obtain the route to 8.1.1.0/24.
2.     Configure OSPF:
Enable OSPF in AS 65009, so Switch B can obtain the route to 9.1.2.0/24.
[SwitchB] ospf 1
[SwitchC] ospf 1
3.     Configure the EBGP connection:
Configure the EBGP connection and inject network 8.1.1.0/24 to the BGP routing table of Switch A, so that Switch B can obtain the route to 8.1.1.0/24.
[SwitchA] bgp 65008
[SwitchB] bgp 65009
4.     Configure BGP and IGP route redistribution:
# Configure route redistribution between BGP and OSPF on Switch B.
[SwitchB] ospf 1
 Total number of routes: 3
               a – additional-path
* >e 3.3.3.3/32         3.1.1.1         1                     0       65009?
* >e 9.1.2.0/24         3.1.1.1         1                     0       65009?
# Display the OSPF routing table on Switch C.
                   Routing Table
 Routing for Network
 9.1.1.0/24         1        Transit 9.1.1.2         3.3.3.3         0.0.0.0
 2.2.2.2/32         1        Stub    9.1.1.1         2.2.2.2         0.0.0.0
 Routing for ASEs
 Destination        Cost     Type    Tag         NextHop         AdvRouter
 8.1.1.0/24         1        Type2   1           9.1.1.1         2.2.2.2
 Total Nets: 3
 Intra Area: 2  Inter Area: 0  ASE: 1  NSSA: 0
# Use ping for verification.
Ping 9.1.2.1 (9.1.2.1) from 8.1.1.1: 56 data bytes, press CTRL+C to break
Ping 8.1.1.1 (8.1.1.1) from 9.1.2.1: 56 data bytes, press CTRL+C to break
BGP route summarization configuration example
As shown in Figure 25, run EBGP between Switch C and Switch D, so the internal network and external network can communicate with each other.
·     In AS 65106, perform the following configurations so the devices in the internal network can communicate:
¡     Configure static routing between Switch A and Switch B.
¡     Configure OSPF between Switch B and Switch C.
¡     Configure OSPF to redistribute static routes.
·     Configure route summarization on Switch C so BGP advertises a summary route instead of advertising routes to the 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 networks to Switch D.
Figure 25 Network diagram
2.     Configure static routing between Switch A and Switch B:
# Configure a default route with the next hop 192.168.212.1 on Switch A.
[SwitchA] ip route-static 0.0.0.0 0 192.168.212.1
# Configure static routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 with the same next hop 192.168.212.161 on Switch B.
[SwitchB] ip route-static 192.168.64.0 24 192.168.212.161
[SwitchB] ip route-static 192.168.74.0 24 192.168.212.161
[SwitchB] ip route-static 192.168.99.0 24 192.168.212.161
3.     Configure OSPF between Switch B and Switch C and configure OSPF on Switch B to redistribute static routes:
# Configure OSPF to advertise the local network and enable OSPF to redistribute static routes on Switch B.
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[SwitchB-ospf-1] import-route static
# Configure OSPF to advertise the local networks on Switch C.
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 10.220.2.0 0.0.0.255
# Display the IP routing table on Switch C.
[SwitchC] display ip routing-table protocol ospf
Summary count : 5
Summary count : 3
Destination/Mask   Proto   Pre  Cost         NextHop         Interface
192.168.64.0/24    O_ASE2  150  1            172.17.100.1    Vlan100
192.168.74.0/24    O_ASE2  150  1            172.17.100.1    Vlan100
192.168.99.0/24    O_ASE2  150  1            172.17.100.1    Vlan100
Summary count : 2
10.220.2.0/24      O_INTRA  10   1            10.220.2.16     Vlan200
172.17.100.0/24    O_INTRA  10   1            172.17.100.2    Vlan100
The output shows that Switch C has learned routes to 192.168.64.0/24, 192.168.99.0/24, and 192.168.64.0/18 through OSPF.
4.     Configure BGP between Switch C and Switch D and configure BGP on Switch C to redistribute OSPF routes:
# On Switch C, enable BGP, specify Switch D as an EBGP peer, and configure BGP to redistribute OSPF routes.
[SwitchC] bgp 65106
[SwitchC-bgp-default] peer 10.220.2.217 as-number 64631
[SwitchC-bgp-default-ipv4] peer 10.220.2.217 enable
[SwitchC-bgp-default-ipv4] import-route ospf
# Enable BGP, and configure Switch C as an EBGP peer on Switch D.
[SwitchD] bgp 64631
[SwitchD-bgp-default] peer 10.220.2.16 as-number 65106
[SwitchD-bgp-default] address-family ipv4 unicast
[SwitchD-bgp-default-ipv4] peer 10.220.2.16 enable
[SwitchD-bgp-default-ipv4] quit
[SwitchD-bgp-default] quit
# Display the IP routing table on Switch D.
[SwitchD] display ip routing-table protocol bgp
Summary count : 3
Summary count : 3
192.168.64.0/24     BGP    255  1            10.220.2.16     Vlan200
192.168.74.0/24     BGP    255  1            10.220.2.16     Vlan200
192.168.99.0/24     BGP    255  1            10.220.2.16     Vlan200
Summary count : 0
The output shows that Switch D has learned routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 through BGP.
# Verify that Switch D can ping hosts on networks 192.168.74.0/24, 192.168.99.0/24, and 192.168.64.0/18. (Details not shown.)
5.     Configure route summarization on Switch C to summarize 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 into a single route 192.168.64.0/18, and disable advertisement of specific routes.
[SwitchC-bgp-default-ipv4] aggregate 192.168.64.0 18 detail-suppressed
# Display IP routing table on Switch C.
[SwitchC] display ip routing-table | include 192.168
192.168.64.0/18    BGP     130  0            127.0.0.1       NULL0
The output shows that Switch C has a summary route 192.168.64.0/18 with the output interface Null0.
# Display IP routing table on Switch D.
Summary count : 1
Summary count : 1
192.168.64.0/18     BGP    255  0            10.220.2.16     Vlan200
Summary count : 0
The output shows that Switch D has only one route 192.168.64.0/18 to AS 65106.
# Verify that Switch D can ping the hosts on networks 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24. (Details not shown.)
BGP load balancing configuration example
As shown in Figure 26, run EBGP between Switch A and Switch B, and between Switch A and Switch C. Run IBGP between Switch B and Switch C. Configure load balancing over the two EBGP links on Switch A.
Figure 26 Network diagram
On Switch A:
·     Establish EBGP connections with Switch B and Switch C.
·     Configure BGP to advertise network 8.1.1.0/24 to Switch B and Switch C, so that Switch B and Switch C can access the internal network connected to Switch A.
On Switch B:
·     Establish an EBGP connection with Switch A and an IBGP connection with Switch C.
·     Configure BGP to advertise network 9.1.1.0/24 to Switch A, so that Switch A can access the intranet through Switch B.
·     Configure a static route to interface loopback 0 on Switch C (or use a routing protocol like OSPF) to establish the IBGP connection.
On Switch C:
·     Establish an EBGP connection with Switch A and an IBGP connection with Switch B.
·     Configure BGP to advertise network 9.1.1.0/24 to Switch A, so that Switch A can access the intranet through Switch C.
·     Configure a static route to interface loopback 0 on Switch B (or use another protocol like OSPF) to establish the IBGP connection.
Configure load balancing on Switch A.
2.     Configure BGP connections:
[SwitchA] bgp 65008
[SwitchA-bgp-default] peer 3.1.2.1 as-number 65009
[SwitchA-bgp-default-ipv4] peer 3.1.2.1 enable
[SwitchB] bgp 65009
[SwitchB-bgp-default-ipv4] network 9.1.1.0 24
[SwitchB] ip route-static 3.3.3.3 32 9.1.1.2
[SwitchC] bgp 65009
[SwitchC-bgp-default] peer 3.1.2.2 as-number 65008
[SwitchC-bgp-default-ipv4] peer 3.1.2.2 enable
[SwitchC-bgp-default-ipv4] network 9.1.1.0 24
[SwitchC] ip route-static 2.2.2.2 32 9.1.1.1
               a – additional-path
* >e 9.1.1.0/24         3.1.1.1         0                     0       65009i
*  e                    3.1.2.1         0                     0       65009i
¡     The output shows two valid routes to destination 9.1.1.0/24. The route with next hop 3.1.1.1 is marked with a greater-than sign (>), indicating that it is the optimal route (because the ID of Switch B is smaller). The route with next hop 3.1.2.1 is marked with an asterisk (*), indicating that it is a valid route, but not the optimal route.
¡     By using the display ip routing-table command, you can find only one route to 9.1.1.0/24 with next hop 3.1.1.1 and output interface VLAN-interface 200.
3.     Configure loading balancing:
Because Switch A has two routes to reach AS 65009, configuring load balancing over the two BGP routes on Switch A can improve link usage.
[SwitchA] bgp 65008
[SwitchA-bgp-default-ipv4] balance 2
               a – additional-path
* >e                    3.1.2.1         0                     0       65009i
·     The route 9.1.1.0/24 has two next hops, 3.1.1.1 and 3.1.2.1, both of which are marked with a greater-than sign (>), indicating that they are the optimal routes.
·     By using the display ip routing-table command, you can find two routes to 9.1.1.0/24. One has next hop 3.1.1.1 and output interface VLAN-interface 200, and the other has next hop 3.1.2.1 and output interface VLAN-interface 300.
BGP additional path configuration example
As shown in Figure 27, all switches run BGP. EBGP runs between Switch A and Switch B, and between Switch A and Switch C. IBGP runs between Switch B and Switch D, between Switch C and Switch D, and between Switch D and Switch E. Switch D is a route reflector and Switch E is its client.
Configure the BGP additional path feature to enable Switch E to learn routes with the same prefix and different next hops from Switch B and Switch C.
Figure 27 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int100
10.1.1.1/24
Switch D
Vlan-int300
30.1.1.1/24
Vlan-int200
20.1.1.1/24
Vlan-int400
40.1.1.1/24
Switch B
Vlan-int100
10.1.1.2/24
Vlan-int500
50.1.1.1/24
Vlan-int300
30.1.1.2/24
Switch E
Vlan-int500
50.1.1.2/24
Switch C
Vlan-int200
20.1.1.2/24
Vlan-int400
40.1.1.2/24
[SwitchA] bgp 10
[SwitchA-bgp-default] peer 10.1.1.2 as-number 20
[SwitchA-bgp-default] peer 20.1.1.2 as-number 20
[SwitchA-bgp-default-ipv4] peer 10.1.1.2 enable
[SwitchA-bgp-default-ipv4] peer 20.1.1.2 enable
[SwitchB] bgp 20
[SwitchB-bgp-default] peer 10.1.1.1 as-number 10
[SwitchB-bgp-default] peer 30.1.1.1 as-number 20
[SwitchB-bgp-default-ipv4] peer 10.1.1.1 enable
[SwitchB-bgp-default-ipv4] peer 30.1.1.1 enable
[SwitchC] bgp 20
[SwitchC-bgp-default] peer 20.1.1.1 as-number 10
[SwitchC-bgp-default] peer 40.1.1.1 as-number 20
[SwitchC-bgp-default-ipv4] peer 20.1.1.1 enable
[SwitchC-bgp-default-ipv4] peer 40.1.1.1 enable
# Configure Switch D.
<SwitchD> system-view
[SwitchD] bgp 20
[SwitchD-bgp-default] peer 30.1.1.2 as-number 20
[SwitchD-bgp-default] peer 40.1.1.2 as-number 20
[SwitchD-bgp-default] peer 50.1.1.2 as-number 20
[SwitchD-bgp-default-ipv4] peer 30.1.1.2 enable
[SwitchD-bgp-default-ipv4] peer 40.1.1.2 enable
[SwitchD-bgp-default-ipv4] peer 50.1.1.2 enable
# Configure Switch E.
<SwitchE> system-view
[SwitchE] bgp 20
[SwitchE-bgp-default] peer 50.1.1.1 as-number 20
[SwitchE-bgp-default] address-family ipv4 unicast
[SwitchE-bgp-default-ipv4] peer 50.1.1.1 enable
3.     Configure Switch A to advertise network 10.1.1.0/24.
[SwitchA-bgp-default-ipv4] network 10.1.1.0 24
4.     Set the local switch as the next hop for routes sent to a peer
[SwitchB-bgp-default-ipv4] peer 30.1.1.1 next-hop-local
[SwitchC-bgp-default-ipv4] peer 40.1.1.1 next-hop-local
5.     Configure Switch D as a route reflector.
 [SwitchD-bgp-default-ipv4] peer 50.1.1.2 reflect-client
6.     Configure the additional path feature:
# Enable the additional path sending capability on Switch D.
[SwitchD-bgp-default-ipv4] peer 50.1.1.2 additional-paths send
# Set the maximum total number to 2 for Add-Path optimal routes that can be advertised.
[SwitchD-bgp-default-ipv4] additional-paths select-best 2
# Set the maximum number to 2 for Add-Path optimal routes that can be advertised to peer 50.1.1.2.
[SwitchD-bgp-default-ipv4] peer 50.1.1.2 advertise additional-paths best 2
# Enable the additional path receiving capability on Switch E.
[SwitchE-bgp-default-ipv4] peer 50.1.1.1 additional-paths receive
# Display BGP routing information on Switch E.
[Switch E] display bgp routing-table ipv4
 Total number of routes: 2
 BGP local Switch ID is 50.1.1.2
               a - additional-path
   i 10.1.1.0/24        30.1.1.2        0          100        0       10i
   i                    40.1.1.2        0          100        0       10i
The output shows that Switch D has learned two routes with the same prefix and different next hops.
BGP community configuration example
As shown in Figure 28, Switch B establishes EBGP connections with Switch A and Switch C. Configure NO_EXPORT community attribute on Switch A to make routes from AS 10 not advertised by AS 20 to any other AS.
Figure 28 Network diagram
2.     Configure EBGP connections:
[SwitchA] bgp 10
[SwitchA-bgp-default] peer 200.1.2.2 as-number 20
[SwitchA-bgp-default-ipv4] peer 200.1.2.2 enable
[SwitchA-bgp-default-ipv4] network 9.1.1.0 255.255.255.0
[SwitchB] bgp 20
[SwitchB-bgp-default] peer 200.1.2.1 as-number 10
[SwitchB-bgp-default] peer 200.1.3.2 as-number 30
[SwitchB-bgp-default-ipv4] peer 200.1.2.1 enable
[SwitchB-bgp-default-ipv4] peer 200.1.3.2 enable
[SwitchC] bgp 30
[SwitchC-bgp-default] peer 200.1.3.1 as-number 20
[SwitchC-bgp-default-ipv4] peer 200.1.3.1 enable
[SwitchB] display bgp routing-table ipv4 9.1.1.0
 BGP local router ID: 2.2.2.2
 Local AS number: 20
 Paths:   1 available, 1 best
 Rely nexthop    : 200.1.2.1
 Original nexthop: 200.1.2.1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 10
 Origin          : igp
 Attribute value : pref-val 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
# Display advertisement information of network 9.1.1.0 on Switch B.
[SwitchB] display bgp routing-table ipv4 9.1.1.0 advertise-info
 Local AS number: 20
 Paths:   1 best
    200.1.3.2
The output shows that Switch B can advertise the route with the destination 9.1.1.0/24 to other ASs through BGP.
               a – additional-path
* >e 9.1.1.0/24         200.1.3.1                             0       20 10i
The output shows that Switch C has learned route 9.1.1.0/24 from Switch B.
3.     Configure BGP community:
# Configure a routing policy.
[SwitchA] route-policy comm_policy permit node 0
[SwitchA-route-policy-comm_policy-0] apply community no-export
[SwitchA-route-policy-comm_policy-0] quit
# Apply the routing policy.
[SwitchA] bgp 10
[SwitchA-bgp-default-ipv4] peer 200.1.2.2 route-policy comm_policy export
[SwitchA-bgp-default-ipv4] peer 200.1.2.2 advertise-community
# Display the routing table on Switch B.
 Local AS number: 20
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 Community       : No-Export
 AS-path         : 10
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
# Display advertisement information for the route 9.1.1.0 on Switch B.
 Local AS number: 20
 Paths:   1 best
 Total number of routes: 0
The output shows that BGP has not learned any route.
BGP route reflector configuration example
As shown in Figure 29, all switches run BGP. Run EBGP between Switch A and Switch B, and run IBGP between Switch C and Switch B, and between Switch C and Switch D.
Configure Switch C as a route reflector with clients Switch B and Switch D to allow Switch D to learn route 20.0.0.0/8 from Switch C.
Figure 29 Network diagram
1.     Configure IP addresses for interfaces and configure OSPF in AS 200. (Details not shown.)
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 192.1.1.2 as-number 200
[SwitchA-bgp-default-ipv4] peer 192.1.1.2 enable
# Inject network 20.0.0.0/8 to the BGP routing table.
[SwitchA-bgp-default-ipv4] network 20.0.0.0
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 192.1.1.1 as-number 100
[SwitchB-bgp-default] peer 193.1.1.1 as-number 200
[SwitchB-bgp-default-ipv4] peer 192.1.1.1 enable
[SwitchB-bgp-default-ipv4] peer 193.1.1.1 enable
[SwitchB-bgp-default-ipv4] peer 193.1.1.1 next-hop-local
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 193.1.1.2 as-number 200
[SwitchC-bgp-default] peer 194.1.1.2 as-number 200
[SwitchC-bgp-default-ipv4] peer 193.1.1.2 enable
[SwitchC-bgp-default-ipv4] peer 194.1.1.2 enable
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 194.1.1.1 as-number 200
[SwitchD-bgp-default-ipv4] peer 194.1.1.1 enable
3.     Configure Switch C as the route reflector.
[SwitchC] bgp 200
[SwitchC-bgp-default-ipv4] peer 193.1.1.2 reflect-client
[SwitchC-bgp-default-ipv4] peer 194.1.1.2 reflect-client
               a – additional-path
* >e 20.0.0.0           192.1.1.1       0                     0       100i
# Display the BGP routing table on Switch D.
[SwitchD] display bgp routing-table ipv4
               a – additional-path
* >i 20.0.0.0           193.1.1.2       0          100        0       100i
The output shows that Switch D has learned route 20.0.0.0/8 from Switch C.
BGP confederation configuration example
As shown in Figure 30, split AS 200 into three sub-ASs (AS 65001, AS 65002, and AS 65003) to reduce IBGP connections. Switches in AS 65001 are fully meshed.
Figure 30 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int100
200.1.1.1/24
Switch D
Vlan-int200
10.1.5.1/24
Vlan-int200
10.1.1.1/24
Vlan-int400
10.1.3.2/24
Vlan-int300
10.1.2.1/24
Switch E
Vlan-int200
10.1.5.2/24
Vlan-int400
10.1.3.1/24
Vlan-int500
10.1.4.2/24
Vlan-int500
10.1.4.1/24
Switch F
Vlan-int100
200.1.1.2/24
Switch B
Vlan-int200
10.1.1.2/24
Vlan-int600
9.1.1.1/24
Switch C
Vlan-int300
10.1.2.2/24
2.     Configure BGP confederation:
[SwitchA] bgp 65001
[SwitchA-bgp-default] confederation id 200
[SwitchA-bgp-default] confederation peer-as 65002 65003
[SwitchA-bgp-default] peer 10.1.1.2 as-number 65002
[SwitchA-bgp-default] peer 10.1.2.2 as-number 65003
[SwitchA-bgp-default-ipv4] peer 10.1.1.2 next-hop-local
[SwitchA-bgp-default-ipv4] peer 10.1.2.2 next-hop-local
[SwitchB] bgp 65002
[SwitchB-bgp-default] confederation id 200
[SwitchB-bgp-default] confederation peer-as 65001 65003
[SwitchB-bgp-default] peer 10.1.1.1 as-number 65001
[SwitchC] bgp 65003
[SwitchC-bgp-default] confederation id 200
[SwitchC-bgp-default] confederation peer-as 65001 65002
[SwitchC-bgp-default] peer 10.1.2.1 as-number 65001
3.     Configure IBGP connections in AS 65001:
[SwitchA] bgp 65001
[SwitchA-bgp-default] peer 10.1.3.2 as-number 65001
[SwitchA-bgp-default] peer 10.1.4.2 as-number 65001
[SwitchA-bgp-default-ipv4] peer 10.1.3.2 enable
[SwitchA-bgp-default-ipv4] peer 10.1.4.2 enable
[SwitchA-bgp-default-ipv4] peer 10.1.3.2 next-hop-local
[SwitchA-bgp-default-ipv4] peer 10.1.4.2 next-hop-local
[SwitchD] bgp 65001
[SwitchD-bgp-default] confederation id 200
[SwitchD-bgp-default] peer 10.1.3.1 as-number 65001
[SwitchD-bgp-default] peer 10.1.5.2 as-number 65001
[SwitchD-bgp-default-ipv4] peer 10.1.3.1 enable
[SwitchD-bgp-default-ipv4] peer 10.1.5.2 enable
[SwitchE] bgp 65001
[SwitchE-bgp-default] router-id 5.5.5.5
[SwitchE-bgp-default] confederation id 200
[SwitchE-bgp-default] peer 10.1.4.1 as-number 65001
[SwitchE-bgp-default] peer 10.1.5.1 as-number 65001
[SwitchE-bgp-default-ipv4] peer 10.1.4.1 enable
[SwitchE-bgp-default-ipv4] peer 10.1.5.1 enable
[SwitchE-bgp-default-ipv4] quit
[SwitchE-bgp-default] quit
4.     Configure the EBGP connection between AS 100 and AS 200:
[SwitchA] bgp 65001
[SwitchA-bgp-default] peer 200.1.1.2 as-number 100
[SwitchA-bgp-default-ipv4] peer 200.1.1.2 enable
# Configure Switch F.
<SwitchF> system-view
[SwitchF] bgp 100
[SwitchF-bgp-default] router-id 6.6.6.6
[SwitchF-bgp-default] peer 200.1.1.1 as-number 200
[SwitchF-bgp-default] address-family ipv4 unicast
[SwitchF-bgp-default-ipv4] peer 200.1.1.1 enable
[SwitchF-bgp-default-ipv4] network 9.1.1.0 255.255.255.0
[SwitchF-bgp-default-ipv4] quit
[SwitchF-bgp-default] quit
               a – additional-path
* >i 9.1.1.0/24         10.1.1.1        0          100        0       (65001)
        100i
 Local AS number: 65002
 Rely nexthop    : 10.1.1.1
 Original nexthop: 10.1.1.1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (65001) 100
 Origin          : igp
 State           : valid, external-confed, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
               a – additional-path
* >i 9.1.1.0/24         10.1.3.1        0          100        0       100i
[SwitchD] display bgp routing-table ipv4 9.1.1.0
 BGP local router ID: 4.4.4.4
 Local AS number: 65001
 Rely nexthop    : 10.1.3.1
 Original nexthop: 10.1.3.1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 100
 Origin          : igp
 State           : valid, internal-confed, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
·     Switch F can send route information to Switch B and Switch C through the confederation by establishing only an EBGP connection with Switch A.
·     Switch B and Switch D are in the same confederation, but belong to different sub-ASs. They obtain external route information from Switch A, and generate identical BGP route entries although they have no direct connection in between.
BGP path selection configuration example
As shown in Figure 31, all switches run BGP.
·     EBGP runs between Switch A and Switch B, and between Switch A and Switch C.
·     IBGP runs between Switch B and Switch D, and between Switch D and Switch C. OSPF is the IGP protocol in AS 200.
Configure routing policies, making Switch D use the route 1.0.0.0/8 from Switch C as the optimal.
Figure 31 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int101
1.0.0.1/8
Switch D
Vlan-int400
195.1.1.1/24
Vlan-int100
192.1.1.1/24
Vlan-int300
194.1.1.1/24
Vlan-int200
193.1.1.1/24
Switch C
Vlan-int400
195.1.1.2/24
Switch B
Vlan-int100
192.1.1.2/24
Vlan-int200
193.1.1.2/24
Vlan-int300
194.1.1.2/24
2.     Configure OSPF on Switch B, Switch C, and Switch D:
[SwitchB] ospf
[SwitchB-ospf] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[SwitchC] ospf
[SwitchC-ospf] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 193.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[SwitchD] ospf
[SwitchD-ospf] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[SwitchD-ospf-1] quit
3.     Configure BGP connections:
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 193.1.1.2 as-number 200
[SwitchA-bgp-default-ipv4] peer 193.1.1.2 enable
# Inject network 1.0.0.0/8 to the BGP routing table on Switch A.
[SwitchA-bgp-default-ipv4] network 1.0.0.0 8
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 194.1.1.1 as-number 200
[SwitchB-bgp-default-ipv4] peer 194.1.1.1 enable
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 193.1.1.1 as-number 100
[SwitchC-bgp-default] peer 195.1.1.1 as-number 200
[SwitchC-bgp-default-ipv4] peer 193.1.1.1 enable
[SwitchC-bgp-default-ipv4] peer 195.1.1.1 enable
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 194.1.1.2 as-number 200
[SwitchD-bgp-default] peer 195.1.1.2 as-number 200
[SwitchD-bgp-default-ipv4] peer 194.1.1.2 enable
[SwitchD-bgp-default-ipv4] peer 195.1.1.2 enable
4.     Configure local preference for route 1.0.0.0/8, making Switch D give priority to the route learned from Switch C:
# Define IPv4 basic ACL 2000 on Switch C to permit route 1.0.0.0/8.
[SwitchC] acl basic 2000
[SwitchC-acl-ipv4-basic-2000] rule permit source 1.0.0.0 0.255.255.255
[SwitchC-acl-ipv4-basic-2000] quit
# Configure a routing policy named localpref on Switch C, setting the local preference of route 1.0.0.0/8 to 200 (the default is 100).
[SwitchC] route-policy localpref permit node 10
[SwitchC-route-policy-localpref-10] if-match ip address acl 2000
[SwitchC-route-policy-localpref-10] apply local-preference 200
[SwitchC-route-policy-localpref-10] quit
# Apply routing policy localpref to routes from peer 193.1.1.1.
[SwitchC] bgp 200
[SwitchC-bgp-default-ipv4] peer 193.1.1.1 route-policy localpref import
               a – additional-path
* >i 1.0.0.0            193.1.1.1                  200        0       100i
*  i                    192.1.1.1                  100        0       100i
Route 1.0.0.0/8 learned from Switch C is the optimal.
BGP GR configuration example
As shown in Figure 32, all switches run BGP. EBGP runs between Switch A and Switch B. IBGP runs between Switch B and Switch C.
Enable GR capability for BGP so that the communication between Switch A and Switch C is not affected when an active/standby switchover occurs on Switch B.
Figure 32 Network diagram
1.     Configure Switch A:
# Configure IP addresses for interfaces. (Details not shown.)
# Configure the EBGP connection.
[SwitchA] bgp 65008
[SwitchA-bgp-default] peer 200.1.1.1 as-number 65009
# Enable GR capability for BGP.
[SwitchA-bgp-default] graceful-restart
# Inject network 8.0.0.0/8 to the BGP routing table.
[SwitchA-bgp-default-ipv4] network 8.0.0.0
# Enable Switch A to exchange IPv4 unicast routing information with Switch B.
[SwitchA-bgp-default-ipv4] peer 200.1.1.1 enable
2.     Configure Switch B:
[SwitchB] bgp 65009
[SwitchB-bgp-default] peer 200.1.1.2 as-number 65008
# Configure the IBGP connection.
[SwitchB-bgp-default] peer 9.1.1.2 as-number 65009
[SwitchB-bgp-default] graceful-restart
# Inject networks 200.1.1.0/24 and 9.1.1.0/24 to the BGP routing table.
[SwitchB-bgp-default-ipv4] network 200.1.1.0 24
# Enable Switch B to exchange IPv4 unicast routing information with Switch A and Switch C.
[SwitchB-bgp-default-ipv4] peer 200.1.1.2 enable
[SwitchB-bgp-default-ipv4] peer 9.1.1.2 enable
3.     Configure Switch C:
[SwitchC] bgp 65009
[SwitchC-bgp-default] peer 9.1.1.1 as-number 65009
[SwitchC-bgp-default] graceful-restart
# Enable Switch C to exchange IPv4 unicast routing information with Switch B.
[SwitchC-bgp-default-ipv4] peer 9.1.1.1 enable
Ping Switch C on Switch A. Meanwhile, perform an active/standby switchover on Switch B. The ping operation is successful during the whole switchover process. (Details not shown.)
BFD for BGP configuration example
As shown in Figure 33, configure OSPF as the IGP in AS 200.
·     Establish two IBGP connections between Switch A and Switch C. When both paths operate correctly, Switch C uses the path Switch A<—>Switch B<—>Switch C to exchange packets with network 1.1.1.0/24.
·     Configure BFD over the path. When the path fails, BFD can quickly detect the failure and notify it to BGP. Then, the path Switch A<—>Switch D<—>Switch C takes effect immediately.
Figure 33 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
3.0.1.1/24
Switch C
Vlan-int101
3.0.2.2/24
Vlan-int200
2.0.1.1/24
Vlan-int201
2.0.2.2/24
Switch B
Vlan-int100
3.0.1.2/24
Switch D
Vlan-int200
2.0.1.2/24
Vlan-int101
3.0.2.1/24
Vlan-int201
2.0.2.1/24
2.     Configure OSPF to ensure that Switch A and Switch C are reachable to each other. (Details not shown.)
3.     Configure BGP on Switch A:
# Establish two IBGP connections to Switch C.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 3.0.2.2 as-number 200
[SwitchA-bgp-default] peer 2.0.2.2 as-number 200
[SwitchA-bgp-default-ipv4] peer 3.0.2.2 enable
[SwitchA-bgp-default-ipv4] peer 2.0.2.2 enable
# Create IPv4 basic ACL 2000 to permit 1.1.1.0/24 to pass.
[SwitchA] acl basic 2000
[SwitchA-acl-ipv4-basic-2000] rule permit source 1.1.1.0 0.0.0.255
# Create two routing policies to set the MED for route 1.1.1.0/24. The policy apply_med_50 sets the MED to 50, and the policy apply_med_100 sets the MED to 100.
[SwitchA] route-policy apply_med_50 permit node 10
[SwitchA-route-policy-apply_med_50-10] if-match ip address acl 2000
[SwitchA-route-policy-apply_med_50-10] apply cost 50
[SwitchA-route-policy-apply_med_50-10] quit
[SwitchA] route-policy apply_med_100 permit node 10
[SwitchA-route-policy-apply_med_100-10] if-match ip address acl 2000
[SwitchA-route-policy-apply_med_100-10] apply cost 100
[SwitchA-route-policy-apply_med_100-10] quit
# Apply routing policy apply_med_50 to routes outgoing to peer 3.0.2.2, and apply routing policy apply_med_100 to routes outgoing to peer 2.0.2.2.
[SwitchA] bgp 200
[SwitchA-bgp-default-ipv4] peer 3.0.2.2 route-policy apply_med_50 export
[SwitchA-bgp-default-ipv4] peer 2.0.2.2 route-policy apply_med_100 export
# Enable BFD for peer 3.0.2.2.
[SwitchA-bgp-default] peer 3.0.2.2 bfd
4.     Configure BGP on Switch C:
# Establish two IBGP connections to Switch A.
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 3.0.1.1 as-number 200
[SwitchC-bgp-default] peer 2.0.1.1 as-number 200
[SwitchC-bgp-default-ipv4] peer 3.0.1.1 enable
[SwitchC-bgp-default-ipv4] peer 2.0.1.1 enable
# Enable BFD for peer 3.0.1.1.
[SwitchC-bgp-default] peer 3.0.1.1 bfd
[SwitchC] quit
# Display detailed BFD session information on Switch C.
<SwitchC> display bfd session verbose
 IPv4 Session Working in control packet mode:
       Local Discr: 513                  Remote Discr: 513
         Source IP: 3.0.2.2            Destination IP: 3.0.1.1
     Session State: Up                      Interface: N/A
      Min Tx Inter: 500ms                Act Tx Inter: 500ms
      Min Rx Inter: 500ms                Detect Inter: 2500ms
          Rx Count: 135                      Tx Count: 135
      Connect Type: Indirect           Running Up for: 00:00:58
         Hold Time: 2457ms                  Auth mode: None
       Detect Mode: Async                        Slot: 0
          Protocol: BGP
           Version: 1
         Diag Info: No Diagnostic
The output shows that a BFD session has been established between Switch A and Switch C.
# Display BGP peer information on Switch C.
<SwitchC> display bgp peer ipv4
 BGP local router ID: 3.3.3.3
 Local AS number: 200
 Total number of peers: 2                  Peers in established state: 2
  2.0.1.1                200        4        5    0       0 00:01:55 Established
  3.0.1.1                200        4        5    0       0 00:01:52 Established
The output shows that Switch C has established two BGP connections with Switch A, and both connections are in Established state.
# Display route 1.1.1.0/24 on Switch C.
<SwitchC> display ip routing-table 1.1.1.0 24 verbose
Summary count : 1
Destination: 1.1.1.0/24
   Protocol: BGP             Process ID: 0
  SubProtID: 0x1                    Age: 00h00m09s
       Cost: 50              Preference: 255
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active Adv
  OrigTblID: 0x1                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x15000001          LastAs: 0
     AttrID: 0x1               Neighbor: 3.0.1.1
      Flags: 0x10060        OrigNextHop: 3.0.1.1
      Label: NULL           RealNextHop: 3.0.2.1
    BkLabel: NULL             BkNextHop: N/A
    SRLabel: NULL             BkSRLabel: NULL
   SIDIndex: NULL               InLabel: NULL
  Tunnel ID: Invalid          Interface: Vlan-interface101
BkTunnel ID: Invalid        BkInterface: N/A
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A                 PathID: 0x0
   LinkCost: 0               MicroSegID: 0
The output shows that Switch C communicates with network 1.1.1.0/24 through the path Switch C<—>Switch B<—>Switch A.
# Break down the path Switch C<—>Switch B<—>Switch A and then display route 1.1.1.0/24 on Switch C.
Summary count : 1
  SubProtID: 0x1                    Age: 00h03m08s
       Cost: 100             Preference: 255
      NibID: 0x15000000          LastAs: 0
     AttrID: 0x0               Neighbor: 2.0.1.1
      Flags: 0x10060        OrigNextHop: 2.0.1.1
      Label: NULL           RealNextHop: 2.0.2.1
  Tunnel ID: Invalid          Interface: Vlan-interface201
The output shows that Switch C communicates with network 1.1.1.0/24 through the path Switch C<—>Switch D<—>Switch A.
BGP FRR configuration example
As shown in Figure 34, configure BGP FRR so that when Link B fails, BGP uses Link A to forward traffic.
Figure 34 Network diagram
2.     Configure OSPF in AS 200 to ensure connectivity among Switch B, Switch C, and Switch D. (Details not shown.)
# Configure Switch A to establish EBGP sessions to Switch B and Switch C, and advertise network 1.1.1.1/32.
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 10.1.1.2 as-number 200
[SwitchA-bgp-default] peer 30.1.1.3 as-number 200
[SwitchA-bgp-default-ipv4] peer 30.1.1.3 enable
[SwitchA-bgp-default-ipv4] network 1.1.1.1 32
# Configure Switch B to establish an EBGP session to Switch A, and an IBGP session to Switch D.
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 10.1.1.1 as-number 100
[SwitchB-bgp-default] peer 4.4.4.4 as-number 200
[SwitchB-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchB-bgp-default-ipv4] peer 4.4.4.4 enable
[SwitchB-bgp-default-ipv4] peer 4.4.4.4 next-hop-local
# Configure Switch C to establish an EBGP session to Switch A, and an IBGP session to Switch D.
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 30.1.1.1 as-number 100
[SwitchC-bgp-default] peer 4.4.4.4 as-number 200
[SwitchC-bgp-default] peer 4.4.4.4 connect-interface loopback 0
[SwitchC-bgp-default-ipv4] peer 30.1.1.1 enable
[SwitchC-bgp-default-ipv4] peer 4.4.4.4 enable
[SwitchC-bgp-default-ipv4] peer 4.4.4.4 next-hop-local
# Configure Switch D to establish IBGP sessions to Switch B and Switch C, and advertise network 4.4.4.4/32.
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 2.2.2.2 as-number 200
[SwitchD-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchD-bgp-default] peer 3.3.3.3 as-number 200
[SwitchD-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchD-bgp-default-ipv4] peer 2.2.2.2 enable
[SwitchD-bgp-default-ipv4] peer 3.3.3.3 enable
[SwitchD-bgp-default-ipv4] network 4.4.4.4 32
4.     Configure preferred values so Link B is used to forward traffic between Switch A and Switch D:
# Configure Switch A to set the preferred value to 100 for routes received from Switch B.
[SwitchA-bgp-default-ipv4] peer 10.1.1.2 preferred-value 100
# Configure Switch D to set the preferred value to 100 for routes received from Switch B.
[SwitchD-bgp-default-ipv4] peer 2.2.2.2 preferred-value 100
5.     Configure BGP FRR:
# On Switch A, set the source address of BFD echo packets to 11.1.1.1.
[SwitchA] bfd echo-source-ip 11.1.1.1
# Create routing policy frr to set a backup next hop 30.1.1.3 (Switch C) for the route destined for 4.4.4.4/32.
[SwitchA-route-policy] if-match ip address prefix-list abc
[SwitchA-route-policy] apply fast-reroute backup-nexthop 30.1.1.3
[SwitchA-route-policy] quit
# Use echo-mode BFD to detect the connectivity to Switch D.
[SwitchA] bgp 100
[SwitchA-bgp-default] primary-path-detect bfd echo
# Apply the routing policy to BGP FRR for BGP IPv4 unicast address family.
[SwitchA-bgp-default-ipv4] fast-reroute route-policy frr
# On Switch D, set the source address of BFD echo packets to 44.1.1.1.
[SwitchD] bfd echo-source-ip 44.1.1.1
# Create routing policy frr to set a backup next hop 3.3.3.3 (Switch C) for the route destined for 1.1.1.1/32.
[SwitchD] ip prefix-list abc index 10 permit 1.1.1.1 32
[SwitchD-route-policy] if-match ip address prefix-list abc
[SwitchD-route-policy] apply fast-reroute backup-nexthop 3.3.3.3
[SwitchD-route-policy] quit
# Use echo-mode BFD to detect the connectivity to Switch A.
[SwitchD] bgp 200
[SwitchD-bgp-default] primary-path-detect bfd echo
[SwitchD-bgp-default-ipv4] fast-reroute route-policy frr
# Display detailed information about the route to 4.4.4.4/32 on Switch A. The output shows the backup next hop for the route.
[SwitchA] display ip routing-table 4.4.4.4 32 verbose
Summary count : 1
Destination: 4.4.4.4/32
  SubProtID: 0x2                    Age: 00h01m52s
       Cost: 0               Preference: 255
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 200
      NibID: 0x15000003          LastAs: 200
     AttrID: 0x5               Neighbor: 10.1.1.2
      Flags: 0x10060        OrigNextHop: 10.1.1.2
      Label: NULL           RealNextHop: 10.1.1.2
    BkLabel: NULL             BkNextHop: 30.1.1.3
  Tunnel ID: Invalid          Interface: Vlan-interface 100
BkTunnel ID: Invalid        BkInterface: Vlan-interface 200
# Display detailed information about the route to 1.1.1.1/32 on Switch D. The output shows the backup next hop for the route.
[SwitchD] display ip routing-table 1.1.1.1 32 verbose
Summary count : 1
Destination: 1.1.1.1/32
  SubProtID: 0x1                    Age: 00h00m36s
    TableID: 0x2                 OrigAs: 100
      NibID: 0x15000003          LastAs: 100
     AttrID: 0x1               Neighbor: 2.2.2.2
      Flags: 0x10060        OrigNextHop: 2.2.2.2
      Label: NULL           RealNextHop: 20.1.1.2
    BkLabel: NULL             BkNextHop: 40.1.1.3
  Tunnel ID: Invalid          Interface: Vlan-interface 101
BkTunnel ID: Invalid        BkInterface: Vlan-interface 201
Multicast BGP configuration example
As shown in Figure 35, OSPF runs within AS 100 and AS 200 to ensure intra-AS connectivity. MBGP runs between the two ASs to exchange IPv4 unicast routes used for RPF check.
·     Configure the Loopback 0 interface of Switch A and Switch B as the C-BSR and C-RP.
·     Configure Switch A and Switch B to establish a Multicast Source Discovery Protocol (MSDP) peer relationship through MBGP, so that the receiver can receive multicast traffic from the source.
Figure 35 Network diagram
Table 7 Interface and IP address assignment
Device
IP address
Device
IP address
Source
N/A
10.110.1.100/24
Switch C
Vlan-int200
10.110.2.1/24
Switch A
Vlan-int100
10.110.1.1/24
Vlan-int102
192.168.2.2/24
Vlan-int101
192.168.1.1/24
Vlan-int104
192.168.4.1/24
Loop0
1.1.1.1/32
Loop0
3.3.3.3/32
Switch B
Vlan-int101
192.168.1.2/24
Switch D
Vlan-int103
192.168.3.2/24
Vlan-int102
192.168.2.1/24
Vlan-int104
192.168.4.2/24
Vlan-int103
192.168.3.1/24
Loop0
4.4.4.4/32
Loop0
2.2.2.2/32
1.     Configure IP addresses for interfaces and configure OSPF (this example uses OSPF process 1) in AS 200 to ensure intra-AS connectivity. (Details not shown.)
2.     Enable IP multicast routing, PIM-SM, and IGMP, and configure BSR boundaries:
# On Switch A, enable multicast routing globally, and enable PIM-SM on interfaces.
[SwitchA] multicast routing
[SwitchA-mrib] quit
# Configure Switch B and Switch D in the same way that Switch A was configured.
# On Switch C, enable multicast routing globally.
[SwitchC] multicast routing
[SwitchA-mrib] quit
# Enable PIM-SM on interfaces, and enable IGMP on VLAN-interface 200.
[SwitchC] interface vlan-interface 104
[SwitchC-Vlan-interface104] pim sm
[SwitchC-Vlan-interface104] quit
[SwitchC-Vlan-interface200] pim sm
# Configure the BSR boundary on Switch A.
[SwitchA-Vlan-interface101] pim bsr-boundary
# Configure the BSR boundary on Switch B.
[SwitchB-Vlan-interface101] pim bsr-boundary
3.     Configure Loopback 0, C-BSR, and C-RP:
# Configure the Loopback 0 interface and specify it as the C-BSR and C-RP on Switch A.
[SwitchA-LoopBack0] ip address 1.1.1.1 32
[SwitchA-LoopBack0] pim sm
[SwitchA-LoopBack0] quit
[SwitchA] pim
[SwitchA-pim] c-bsr 1.1.1.1
[SwitchA-pim] c-rp 1.1.1.1
[SwitchA-pim] quit
# Configure the Loopback 0 interface and specify it as the C-BSR and C-RP on Switch B.
[SwitchB-LoopBack0] ip address 2.2.2.2 32
[SwitchB-LoopBack0] pim sm
[SwitchB-LoopBack0] quit
[SwitchB] pim
[SwitchB-pim] c-bsr 2.2.2.2
[SwitchB-pim] c-rp 2.2.2.2
[SwitchB-pim] quit
4.     Configure BGP to establish BGP IPv4 multicast peers and redistribute routes:
# On Switch A, establish an EBGP session to Switch B.
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 192.168.1.2 as-number 200
# Enable exchange of IPv4 unicast routes used for RPF check with Switch B.
[SwitchA-bgp-default] address-family ipv4 multicast
[SwitchA-bgp-default-mul-ipv4] peer 192.168.1.2 enable
# Redistribute direct routes into BGP.
[SwitchA-bgp-default-mul-ipv4] import-route direct
[SwitchA-bgp-default-mul-ipv4] quit
# On Switch B, establish an EBGP session to Switch A.
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 192.168.1.1 as-number 100
[SwitchB-bgp-default] address-family ipv4 multicast
[SwitchB-bgp-default-mul-ipv4] peer 192.168.1.1 enable
# Redistribute OSPF routes into BGP.
[SwitchB-bgp-default-mul-ipv4] import-route ospf 1
[SwitchB-bgp-default-mul-ipv4] quit
5.     Configure MSDP peers:
# Configure an MSDP peer on Switch A.
[SwitchA] msdp
[SwitchA-msdp] peer 192.168.1.2 connect-interface vlan-interface 101
[SwitchA-msdp] quit
# Configure an MSDP peer on Switch B.
[SwitchB] msdp
[SwitchB-msdp] peer 192.168.1.1 connect-interface vlan-interface 101
[SwitchB-msdp] quit
# Verify the BGP IPv4 multicast peer information on Switch B.
[SwitchB] display bgp peer ipv4 multicast
 Local AS number : 200
 Total number of peers : 3                 Peers in established state : 3
  192.168.1.1    100       56       56     0       0 00:40:54 Established
# Verify the MSDP peer information on Switch B.
[SwitchB] display msdp brief
Configured   Established  Listen       Connect      Shutdown     Disabled
1            1            0            0            0            0
Peer address    State       Up/Down time    AS         SA count   Reset count
192.168.1.1     Established 00:07:17        100        1          0
Dynamic BGP peer configuration example
As shown in Figure 36, Switch A needs to establish IBGP peer relationships with Switch B, Switch C, and Switch D in network 10.1.0.0/16. Configure dynamic BGP peers to simplify the configuration.
Configure Switch A as the route reflector, and configure Switch B, Switch C, and Switch D as its clients.
Figure 36 Network diagram
2.     Configure IBGP peer relationship:
# Configure Switch A to establish dynamic BGP peer relationships with switches in network 10.1.0.0/16.
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 10.1.0.0 16 as-number 200
[SwitchA-bgp-default-ipv4] peer 10.1.0.0 16 enable
# Configure Switch B to establish an IBGP peer relationship with Switch A.
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 10.1.1.1 as-number 200
# Configure Switch C to establish an IBGP peer relationship with Switch A.
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 10.1.2.1 as-number 200
# Configure Switch D to establish an IBGP peer relationship with Switch A.
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 10.1.3.1 as-number 200
# Display BGP peer information on Switch A. The output shows that Switch A has established IBGP peer relationships with Switch B, Switch C, and Switch D.
[SwitchA] display bgp peer ipv4
 BGP local router ID : 1.1.1.1
*10.1.1.2               200        7       10    0       0 00:06:09 Established
*10.1.2.2               200        7       10    0       0 00:06:09 Established
*10.1.3.2               200        7       10    0       0 00:06:09 Established
3.     Configure Switch A as the route reflector, and configure peers in network 10.1.0.0/16 as its clients.
[SwitchA-bgp-default-ipv4] peer 10.1.0.0 16 reflect-client
4.     Configure Switch C to advertise network 9.1.1.0/24.
# Verify that route 9.1.1.0/24 exists in the BGP routing table on Switch A, Switch B, and Switch D. This example uses Switch A.
[SwitchA-bgp-default] display bgp routing-table ipv4
 Total Number of Routes: 1
               a – additional-path
  * i 9.1.1.0/24        10.1.2.2        0          100        0       ?
BGP LS configuration example
As shown in Figure 37, all switches run BGP. Run IBGP between Switch A and Switch B, between Switch B and Switch C, and between Switch B and Switch D.
Configure Switch B as a route reflector with client Switch A to allow Switch A to learn LS information advertised by Switch C and Switch D.
Figure 37 Network diagram
1.     Configure IP addresses for interfaces and configure OSPF on Switch C and Switch D. (Details not shown.)
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 192.1.1.2 as-number 100
[SwitchA-bgp-default] address-family link-state
[SwitchA-bgp-default-ls] peer 192.1.1.2 enable
[SwitchA-bgp-default-ls] quit
[SwitchB] bgp 100
[SwitchB-bgp-default] peer 193.1.1.1 as-number 100
[SwitchB-bgp-default] peer 194.1.1.1 as-number 100
[SwitchB-bgp-default] address-family link-state
[SwitchB-bgp-default-ls] peer 192.1.1.1 enable
[SwitchB-bgp-default-ls] peer 193.1.1.1 enable
[SwitchB-bgp-default-ls] peer 194.1.1.1 enable
[SwitchB-bgp-default-ls] quit
[SwitchC] bgp 100
[SwitchC-bgp-default] peer 193.1.1.2 as-number 100
[SwitchC-bgp-default] address-family link-state
[SwitchC-bgp-default-ls] peer 193.1.1.2 enable
[SwitchC-bgp-default-ls] quit
[SwitchC] ospf
[SwitchC-ospf-1] distribute bgp-ls
[SwitchC-ospf-1-area-0.0.0.0] network 0.0.0.0 0.0.0.0
[SwitchD] bgp 100
[SwitchD-bgp-default] peer 194.1.1.2 as-number 100
[SwitchD-bgp-default] address-family link-state
[SwitchD-bgp-default-ls] peer 194.1.1.2 enable
[SwitchD-bgp-default-ls] quit
[SwitchD] ospf
[SwitchD-ospf-1] distribute bgp-ls
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 0.0.0.0 0.0.0.0
3.     Configure Switch B as the route reflector.
[SwitchB] bgp 100
[SwitchB-bgp-default-ls] peer 192.1.1.1 reflect-client
# Verify that Switch A has learned LS information advertised by Switch C and Switch D.
[SwitchA] display bgp link-state
 BGP local Switch ID is 192.1.1.1
               a – additional-path
 Prefix codes: E link, V node, T IP reacheable route, u/U unknown,
               I Identifier, N local node, R remote node, L link, P prefix,
               L1/L2 ISIS level-1/level-2, O OSPF, D direct, S static, B BGP
               a area-ID, , l link-ID, t topology-ID, s ISO-ID,
               c confed-ID/ASN, b bgp-identifier, r Switch-ID,
               i if-address, n nbr-address, o OSPF Route-type, p IP-prefix
               d designated Switch address
i Network : [V][O][I0x0][N[c100][b193.1.1.1][a0.0.0.0][r193.1.1.1]]/376
    NextHop : 193.1.1.1                                LocPrf    : 100
    MED     :
    Path/Ogn: i
i Network : [V][O][I0x0][N[c100][b194.1.1.1][a0.0.0.0][r194.1.1.1]]/376
    NextHop : 194.1.1.1                                LocPrf    : 100
    MED     :
    Path/Ogn: i
i Network : [T][O][I0x0][N[c100][b193.1.1.1][a0.0.0.0][r193.1.1.1]][P[o0x1][p193.1.1.0/24]]/480
    MED     :
    Path/Ogn: i
i Network : [T][O][I0x0][N[c100][b194.1.1.1][a0.0.0.0][r194.1.1.1]][P[o0x1][p194.1.1.0/24]]/480
    MED     :
    Path/Ogn: i
BGP RPKI configuration example
As shown in Figure 38, all switches run BGP. Establish a TCP connection between Switch A and the RPKI server, and establish an IBGP connection between Switch A and Switch B.
Configure Switch A to advertise the BGP RPKI validation state to Switch B, and configure a routing policy to filter routes based on the validation state for Switch B.
Figure 38 Network diagram
1.     Configure IP addresses for interfaces and establish an IBGP connection between Switch A and Switch B. (Details not shown.)
2.     Configure Switch A to establish a TCP connection to the RPKI server.
[SwitchA] bgp 100
[SwitchA-bgp-default] rpki
[SwitchA-bgp-default-rpki] server tcp 1.1.1.2
[SwitchA-bgp-default-rpki-server] port 1234
[SwitchA-bgp-default-rpki-server] quit
3.     Enable BGP RPKI validation on Switch A.
[SwitchA-bgp-default-rpki] check-origin-validation
[SwitchA-bgp-default-rpki] quit
4.     Apply the BGP RPKI validation state to optimal route selection.
[SwitchA-bgp-default-ipv4] bestroute origin-as-validation
5.     Configure Switch A to advertise the BGP RPKI validation state to peer 1.2.3.2.
[SwitchA-bgp-default-ipv4] peer 1.2.3.2 advertise-ext-community
[SwitchA-bgp-default-ipv4] peer 1.2.3.2 advertise origin-as-validation
6.     Configure Switch B to permit routes with a BGP RPKI validation state of Valid:
[SwitchB] route-policy rpki_policy permit node 0
[SwitchB-route-policy-rpki_policy-0] if-match rpki valid
[SwitchB-route-policy-rpki_policy-0] quit
[SwitchB] bgp 100
[SwitchB-bgp-default-ipv4] peer 1.2.3.1 route-policy rpki_policy import
# Display information about the connection between Switch A and the RPKI server.
[SwitchA] display bgp rpki server
  Server          VPN-index  Port        State      Time       ROAs(IPv4/IPv6)
  1.1.1.2         0          1234        Establish  00:04:43   5/4
The output shows that Switch A has established a TCP connection to the RPKI server.
# Display the ROA information on Switch A.
[SwitchA] display bgp rpki table ipv4
 Total number of entries: 5
 Status codes: S - stale, U - used
  Network         Mask-range    Origin-AS    Server       Status
  1.2.3.4         8-24          100          1.1.1.2      U
  2.2.3.6         8-32          100          1.1.1.2      U
  2.2.3.6         10-24         4294967295   1.1.1.2      U
  2.2.3.9         20-24         4294967295   1.1.1.2      U
  3.2.3.5         8-26          200          1.1.1.2      U
The output shows that Switch A has obtained the ROA information from the RPKI server.
# Display the BGP RPKI validation state on Switch A.
[SwitchA] display bgp routing-table ipv4 1.2.3.0
 Local AS number: 100
 BGP routing table information of 1.2.3.0/24:
 Imported route.
 Original nexthop: 0.0.0.0
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 Org-validation  : Valid
 AS-path         : (null)
 Origin          : incomplete
 Attribute value : MED 0, pref-val 32768
 State           : valid, local, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
The route to 1.2.3.0 matches the ROA with a prefix of 1.2.3.4, a mask length range of 8 to 24, and an origin AS number of 100. Therefore, the BGP RPKI validation state of the route to 1.2.3.0 is Valid.
# On Switch B, display detailed information about the BGP IPv4 unicast route to 1.2.3.0.
[SwitchB] display bgp routing-table ipv4 1.2.3.0
RR-client route.
 Rely nexthop    : 1.2.3.1
 Original nexthop: 1.2.3.1
 OutLabel        : NULL
 Ext-Community   : <Origin Valid State: Valid >
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : incomplete
 State           : valid, internal, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
The output displays information about the BGP IPv4 unicast route to 1.2.3.0 because Switch B permits routes with a BGP RPKI validation state of Valid.
BGP dedicated routes configuration example
As shown in Figure 39, all switches run BGP. Configure Switch B and Switch C as EBGP peers of both Switch A and Switch D. Switch A and Switch D provide access services to clients through AP 1 and AP 2. To ensure that a client can quickly come online on the access devices after migration, perform the following tasks:
·     Configure IPSG on Switch A and Switch D to enable Switch A and Switch D to generate an IPSG binding for the client after the client comes online.
·     Enable BGP to exchange dedicated routes with its peers and peer groups. Then, Switch B and Switch C can synchronize IPSG bindings from Switch A and Switch D, and Switch A and Switch D can withdraw expired IPSG bindings.
Figure 39 Network diagram
Table 8 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int11
11.11.11.11/24
Switch C
Vlan-int12
22.22.22.22/24
Vlan-int12
22.22.22.11/24
Vlan-int11
44.44.44.11/24
Switch B
Vlan-int11
11.11.11.22/24
Switch D
Vlan-int11
44.44.44.22/24
Vlan-int12
33.33.33.11/24
Vlan-int12
33.33.33.22/24
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 11.11.11.22 as-number 200
[SwitchA-bgp-default] peer 22.22.22.22 as-number 200
[SwitchA-bgp-default] address-family dedicated
[SwitchA-bgp-default-dedicated] peer 11.11.11.22 enable
[SwitchA-bgp-default-dedicated] peer 22.22.22.22 enable
[SwitchA-bgp-default-dedicated] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 11.11.11.11 as-number 100
[SwitchB-bgp-default] peer 33.33.33.22 as-number 100
[SwitchB-bgp-default] address-family dedicated
[SwitchB-bgp-default-dedicated] peer 11.11.11.11 enable
[SwitchB-bgp-default-dedicated] peer 33.33.33.22 enable
[SwitchB-bgp-default-dedicated] quit
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 22.22.22.11 as-number 100
[SwitchC-bgp-default] peer 44.44.44.22 as-number 100
[SwitchC-bgp-default] address-family dedicated
[SwitchC-bgp-default-dedicated] peer 22.22.22.11 enable
[SwitchC-bgp-default-dedicated] peer 44.44.44.22 enable
[SwitchC-bgp-default-dedicated] quit
[SwitchD] bgp 100
[SwitchD-bgp-default] peer 33.33.33.11 as-number 200
[SwitchD-bgp-default] peer 44.44.44.11 as-number 200
[SwitchD-bgp-default] address-family dedicated
[SwitchD-bgp-default-dedicated]peer 33.33.33.11 enable
[SwitchD-bgp-default-dedicated]peer 44.44.44.11 enable
# On Switch D, enable BGP to permit the local AS number to appear in routes from Switch A.
[SwitchD-bgp-default-dedicated] peer 33.33.33.11 allow-as-loop 1
[SwitchD-bgp-default-dedicated] peer 44.44.44.11 allow-as-loop 1
[SwitchD-bgp-default-dedicated] quit
3.     Configure IPv4SG on Switch A and Switch D.
[SwitchA] interface vlan-interface 13
[SwitchA-Vlan-interface13] ip verify source ip-address mac-address
[SwitchD] interface vlan-interface 13
[SwitchD-Vlan-interface13] ip verify source ip-address mac-address
# View IPv4SG bindings on Switch A.
[SwitchA] display ip source binding
Total entries found: 3
IP Address      MAC Address    Interface                VLAN Type
192.168.100.4   1234-5678-9abc Vlan-interface14         N/A  DHCP relay
192.168.100.5   1234-5678-9abd Vlan-interface14         N/A  DHCP relay
192.168.100.6   1234-5678-9abe Vlan-interface14         N/A  DHCP relay
# View BGP dedicated routes on Switch A.
[SwitchA] display bgp routing-table dedicated
 BGP local Switch ID is 1.1.1.1
               a - additional-path
* >  Network : [1][48][1234-5678-9abc][32][192.168.100.1][3]/120
     NextHop : 0.0.0.0                                  LocPrf    : 100
     PrefVal : 32768                                    OutLabel  : NULL
     MED     : 0
     Path/Ogn: i
* >  Network : [1][48][1234-5678-9abd][32][192.168.100.2][3]/120
     MED     : 0
     Path/Ogn: i
* >  Network : [1][48][1234-5678-9abe][32][192.168.100.3][3]/120
     MED     : 0
     Path/Ogn: i
# View BGP dedicated routes on Switch D.
[SwitchD] display bgp routing-table dedicated
 Total number of routes: 6
 BGP local Switch ID is 4.4.4.4
               a - additional-path
* >e Network : [1][48][1234-5678-9abc][32][192.168.100.1][3]/120
     NextHop : 33.33.33.11                              LocPrf    :
     MED     :
     Path/Ogn: 200 100i
*  e Network : [1][48][1234-5678-9abc][32][192.168.100.1][3]/120
     NextHop : 44.44.44.11                              LocPrf    :
     MED     :
     Path/Ogn: 200 100i
* >e Network : [1][48][1234-5678-9abd][32][192.168.100.2][3]/120
     MED     :
     Path/Ogn: 200 100i
*  e Network : [1][48][1234-5678-9abd][32][192.168.100.2][3]/120
     MED     :
     Path/Ogn: 200 100i
* >e Network : [1][48][1234-5678-9abe][32][192.168.100.3][3]/120
     MED     :
     Path/Ogn: 200 100i
*  e Network : [1][48][1234-5678-9abe][32][192.168.100.3][3]/120
     MED     :
     Path/Ogn: 200 100i
# View IPv4SG bindings on Switch D.
[SwitchD] display ip source binding remote
IP Address      MAC Address    Router ID                VLAN Type
192.168.100.1   1234-5678-9abc 1.1.1.1                  N/A  DHCP relay
192.168.100.2   1234-5678-9abd 1.1.1.1                  N/A  DHCP relay
192.168.100.3   1234-5678-9abe 1.1.1.1                  N/A  DHCP relay
The output shows that Switch D has synchronized IPv4SG bindings from Switch A.
IPv6 BGP configuration examples
IPv6 BGP basic configuration example
Network requirements
As shown in Figure 40, all switches run BGP. Run EBGP between Switch A and Switch B, and run IBGP between Switch B and Switch C to allow Switch C to access network 50::/64 connected to Switch A.
Figure 40 Network diagram
2.     Configure IBGP:
[SwitchB] bgp 65009
[SwitchB-bgp-default] peer 9::2 as-number 65009
[SwitchB-bgp-default] address-family ipv6
[SwitchB-bgp-default-ipv6] peer 9::2 enable
[SwitchB-bgp-default-ipv6] quit
[SwitchC] bgp 65009
[SwitchC-bgp-default] peer 9::1 as-number 65009
[SwitchC-bgp-default] address-family ipv6
[SwitchC-bgp-default-ipv6] peer 9::1 enable
3.     Configure EBGP:
[SwitchA] bgp 65008
[SwitchA-bgp-default] peer 10::1 as-number 65009
[SwitchA-bgp-default] address-family ipv6
[SwitchA-bgp-default-ipv6] peer 10::1 enable
[SwitchB-bgp-default] peer 10::2 as-number 65008
[SwitchB-bgp-default-ipv6] peer 10::2 enable
4.     Inject network routes to the BGP routing table:
[SwitchA-bgp-default-ipv6] network 10:: 64
[SwitchA-bgp-default-ipv6] network 50:: 64
[SwitchA-bgp-default-ipv6] quit
# Configure Switch B.
[SwitchB-bgp-default-ipv6] network 10:: 64
[SwitchB-bgp-default-ipv6] network 9:: 64
[SwitchC-bgp-default-ipv6] network 9:: 64
[SwitchC-bgp-default-ipv6] quit
# Display IPv6 BGP peer information on Switch B.
[SwitchB] display bgp peer ipv6
 Local AS number: 65009
  9::2                 65009       41       43    0       1 00:29:00 Established
  10::2                65008       38       38    0       2 00:27:20 Established
The output shows that Switch A and Switch B have established an EBGP connection, and Switch B and Switch C have established an IBGP connection.
# Display IPv6 BGP routing table information on Switch A.
[SwitchA] display bgp routing-table ipv6
               a – additional-path
* >e Network : 9::                                      PrefixLen : 64
     NextHop : 10::1                                    LocPrf    :
     MED     : 0
     Path/Ogn: 65009i
* >  Network : 10::                                     PrefixLen : 64
     NextHop : ::                                       LocPrf    :
     MED     : 0
     Path/Ogn: i
*  e Network : 10::                                     PrefixLen : 64
     MED     : 0
     Path/Ogn: 65009i
* >  Network : 50::                                     PrefixLen : 64
     MED     : 0
     Path/Ogn: i
The output shows that Switch A has learned routing information of AS 65009.
# Display IPv6 BGP routing table information on Switch C.
[SwitchC] display bgp routing-table ipv6
               a – additional-path
* >  Network : 9::                                      PrefixLen : 64
     MED     : 0
     Path/Ogn: i
*  i Network : 9::                                      PrefixLen : 64
     NextHop : 9::1                                     LocPrf    : 100
     MED     : 0
     Path/Ogn: i
* >i Network : 10::                                     PrefixLen : 64
     MED     : 0
     Path/Ogn: i
* >i Network : 50::                                     PrefixLen : 64
     NextHop : 10::2                                    LocPrf    : 100
     MED     : 0
     Path/Ogn: 65008i
The output shows that Switch C has learned the route 50::/64.
# Verify that Switch C can ping hosts on network 50::/64. (Details not shown.)
IPv6 BGP route reflector configuration example
As shown in Figure 41, run EBGP between Switch A and Switch B, run IBGP between Switch C and Switch B, and between Switch C and Switch D.
Configure Switch C as a route reflector with clients Switch B and Switch D.
Figure 41 Network diagram
Configuration procedure
1.     Configure IPv6 addresses for interfaces and IPv4 addresses for loopback interfaces. (Details not shown.)
2.     Configure IBGP and EBGP connections and advertise network routes through IPv6 BGP:
# Configure Switch A.
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 100::2 as-number 200
[SwitchA-bgp-default-ipv6] peer 100::2 enable
[SwitchA-bgp-default-ipv6] network 1:: 64
[SwitchA-bgp-default-ipv6] network 100:: 96
[SwitchA-bgp-default] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 100::1 as-number 100
[SwitchB-bgp-default] peer 101::1 as-number 200
[SwitchB-bgp-default-ipv6] peer 100::1 enable
[SwitchB-bgp-default-ipv6] peer 101::1 enable
[SwitchB-bgp-default-ipv6] peer 101::1 next-hop-local
[SwitchB-bgp-default-ipv6] network 100:: 96
[SwitchB-bgp-default-ipv6] network 101:: 96
[SwitchB-bgp-default] quit
# Configure Switch C.
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 101::2 as-number 200
[SwitchC-bgp-default] peer 102::2 as-number 200
[SwitchC-bgp-default-ipv6] peer 101::2 enable
[SwitchC-bgp-default-ipv6] peer 102::2 enable
[SwitchC-bgp-default-ipv6] network 101:: 96
[SwitchC-bgp-default-ipv6] network 102:: 96
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 102::1 as-number 200
[SwitchD-bgp-default] address-family ipv6
[SwitchD-bgp-default-ipv6] peer 102::1 enable
[SwitchD-bgp-default-ipv6] network 102:: 96
3.     Configure Switch C as a route reflector, and configure Switch B and Switch D as its clients.
[SwitchC-bgp-default-ipv6] peer 101::2 reflect-client
[SwitchC-bgp-default-ipv6] peer 102::2 reflect-client
[SwitchC-bgp-default] quit
# Execute the display bgp routing-table ipv6 command on Switch D.
[SwitchD] display bgp routing-table ipv6
 Total number of routes: 5
               a – additional-path
* >i Network : 1::                                      PrefixLen : 64
     NextHop : 101::2                                   LocPrf    : 100
     MED     : 0
     Path/Ogn: 100i
* >i Network : 100::                                    PrefixLen : 96
     MED     : 0
     Path/Ogn: i
* >i Network : 101::                                    PrefixLen : 96
     NextHop : 102::1                                   LocPrf    : 100
     MED     : 0
     Path/Ogn: i
* >  Network : 102::                                    PrefixLen : 96
     MED     : 0
     Path/Ogn: i
*  i Network : 102::                                    PrefixLen : 96
     MED     : 0
     Path/Ogn: i
The output shows that Switch D has learned the network 1::/64 from Switch C through route reflection.
6PE configuration example
As shown in Figure 42, use 6PE to connect two isolated IPv6 networks over an IPv4/MPLS network.
·     The ISP uses OSPF as the IGP.
·     PE 1 and PE 2 are edge devices of the ISP, and establish an IPv4 IBGP connection between them.
·     CE 1 and CE 2 are edge devices of the IPv6 networks, and they connect the IPv6 networks to the ISP.
·     A CE and a PE exchange IPv6 packets through IPv6 static routing.
Figure 42 Network diagram
1.     Configure IPv6 addresses and IPv4 addresses for interfaces. (Details not shown.)
2.     Configure PE 1:
# Enable LDP globally, and configure the LSP generation policy.
<PE1> system-view
[PE1] mpls lsr-id 2.2.2.2
[PE1] mpls ldp
[PE1-ldp] lsp-trigger all
[PE1-ldp] quit
# Enable MPLS and LDP on VLAN-interface 30.
[PE1] interface vlan-interface 30
[PE1-Vlan-interface30] mpls enable
[PE1-Vlan-interface30] mpls ldp enable
[PE1-Vlan-interface30] quit
# Configure IBGP, enable the peer's 6PE capabilities, and redistribute IPv6 direct and static routes.
[PE1] bgp 65100
[PE1-bgp-default] router-id 2.2.2.2
[PE1-bgp-default] peer 3.3.3.3 as-number 65100
[PE1-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[PE1-bgp-default] address-family ipv6
[PE1-bgp-default-ipv6] import-route direct
[PE1-bgp-default-ipv6] import-route static
[PE1-bgp-default-ipv6] peer 3.3.3.3 enable
[PE1-bgp-default-ipv6] peer 3.3.3.3 label-route-capability
[PE1-bgp-default-ipv6] quit
[PE1-bgp-default] quit
# Configure a static route to CE 1.
[PE1] ipv6 route-static 1::1 128 10::1
# Configure OSPF for the ISP.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 1.1.0.0 0.0.255.255
[PE1-ospf-1] quit
3.     Configure PE 2:
<PE2> system-view
[PE2] mpls lsr-id 3.3.3.3
[PE2] mpls ldp
[PE2-mpls-ldp] lsp-trigger all
[PE2-mpls-ldp] quit
[PE2] interface vlan-interface 30
[PE2-Vlan-interface30] mpls enable
[PE2-Vlan-interface30] mpls ldp enable
[PE2-Vlan-interface30] quit
[PE2] bgp 65100
[PE2-bgp-default] router-id 3.3.3.3
[PE2-bgp-default] peer 2.2.2.2 as-number 65100
[PE2-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE2-bgp-default] address-family ipv6
[PE2-bgp-default-ipv6] import-route direct
[PE2-bgp-default-ipv6] import-route static
[PE2-bgp-default-ipv6] peer 2.2.2.2 enable
[PE2-bgp-default-ipv6] peer 2.2.2.2 label-route-capability
[PE2-bgp-default-ipv6] quit
[PE2-bgp-default] quit
# Configure the static route to CE 2.
[PE2] ipv6 route-static 4::4 128 20::1
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.0.0 0.0.255.255
[PE2-ospf-1] quit
4.     Configure a static route on CE 1, with PE 1 as the default next hop.
<CE1> system-view
[CE1] ipv6 route-static :: 0 10::2
5.     Configure a static route on CE 2, with PE 2 as the default next hop.
<CE2> system-view
[CE2] ipv6 route-static :: 0 20::2
# Display the IPv6 BGP routing tables on PE 1 and PE 2. The output shows that each of them has two IPv6 network routes. The following shows the output on PE 1:
[PE1] display bgp routing-table ipv6
               a – additional-path
* >  Network : 1::1                                     PrefixLen : 128
     MED     : 0
     Path/Ogn: ?
* >i Network : 4::4                                     PrefixLen : 128
     NextHop : ::FFFF:3.3.3.3                           LocPrf    : 100
     PrefVal : 0                                        OutLabel  : 1279
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
* >  Network : 10::2                                    PrefixLen : 128
     NextHop : ::1                                      LocPrf    :
     MED     : 0
     Path/Ogn: ?
* >i Network : 20::                                     PrefixLen : 64
     PrefVal : 0                                        OutLabel  : 1278
     MED     : 0
     Path/Ogn: ?
# Verify that CE 1 can ping the IPv6 address 4::4 (loopback interface address) of CE 2. (Details not shown.)
BFD for IPv6 BGP configuration example
As shown in Figure 43, configure OSPFv3 as the IGP in AS 200.
·     Establish two IBGP connections between Switch A and Switch C. When both paths operate correctly, Switch C uses the path Switch A<—>Switch B<—>Switch C to exchange packets with network 1200::0/64.
·     Configure BFD over the path. When the path fails, BFD can quickly detect the failure and notify it to IPv6 BGP. Then, the path Switch A<—>Switch D<—>Switch C takes effect immediately.
Figure 43 Network diagram
Table 9 Interface and IP address assignment
Device
IP address
Device
IP address
Switch A
Vlan-int100
3000::1/64
Switch C
Vlan-int101
3001::3/64
Vlan-int200
2000::1/64
Vlan-int201
2001::3/64
Switch B
Vlan-int100
3000::2/64
Switch D
Vlan-int200
2000::2/64
Vlan-int101
3001::2/64
Vlan-int201
2001::2/64
1.     Configure IPv6 addresses for interfaces. (Details not shown.)
2.     Configure OSPFv3 so that Switch A and Switch C can reach each other. (Details not shown.)
3.     Configure IPv6 BGP on Switch A:
[SwitchA] bgp 200
[SwitchA-bgp-default] peer 3001::3 as-number 200
[SwitchA-bgp-default] peer 2001::3 as-number 200
[SwitchA-bgp-default-ipv6] peer 3001::3 enable
[SwitchA-bgp-default-ipv6] peer 2001::3 enable
# Create IPv6 basic ACL 2000 to permit 1200::0/64 to pass.
[SwitchA] acl ipv6 basic 2000
[SwitchA-acl-ipv6-basic-2000] rule permit source 1200:: 64
[SwitchA-acl-ipv6-basic-2000] quit
# Create two routing policies to set the MED for route 1200::0/64. The policy apply_med_50 sets the MED to 50, and the policy apply_med_100 sets the MED to 100.
[SwitchA-route-policy-apply_med_50-10] if-match ipv6 address acl 2000
[SwitchA-route-policy-apply_med_100-10] if-match ipv6 address acl 2000
# Apply routing policy apply_med_50 to routes outgoing to peer 3001::3, and apply routing policy apply_med_100 to routes outgoing to peer 2001::3.
[SwitchA] bgp 200
[SwitchA-bgp-default] address-family ipv6 unicast
[SwitchA-bgp-default-ipv6] peer 3001::3 route-policy apply_med_50 export
[SwitchA-bgp-default-ipv6] peer 2001::3  route-policy apply_med_100 export
# Enable BFD for peer 3001::3.
[SwitchA-bgp-default] peer 3001::3 bfd
4.     Configure IPv6 BGP on Switch C:
[SwitchC] bgp 200
[SwitchC-bgp-default] peer 3000::1 as-number 200
[SwitchC-bgp-default] peer 2000::1 as-number 200
[SwitchC-bgp-default-ipv6] peer 3000::1 enable
[SwitchC-bgp-default-ipv6] peer 2000::1 enable
# Enable BFD for peer 3001::1.
[SwitchC-bgp-default] peer 3000::1 bfd
[SwitchC] quit
 IPv6 Session Working in control packet mode:
         Source IP: 3001::3
    Destination IP: 3000::1
          Rx Count: 13                       Tx Count: 14
      Connect Type: Indirect           Running Up for: 00:00:05
         Hold Time: 2243ms                  Auth mode: None
          Protocol: BGP4+
           Version:1
<SwitchC> display bgp peer ipv6
  * - Dynamically created peer
  ^ - Peer created through link-local address
  2000::1                200        8        8    0       0 00:04:45 Established
  3000::1                200        5        4    0       0 00:01:53 Established
# Display route 1200::0/64 on Switch C.
<SwitchC> display ipv6 routing-table 1200::0 64 verbose
Summary count : 1
Destination: 1200::/64
   Protocol: BGP4+           Process ID: 0
  SubProtID: 0x1                    Age: 00h01m07s
    TableID: 0xa                 OrigAs: 0
      NibID: 0x25000001          LastAs: 0
     AttrID: 0x1               Neighbor: 3000::1
      Flags: 0x10060        OrigNextHop: 3000::1
      Label: NULL           RealNextHop: FE80::20C:29FF:FE4A:3873
The output shows that Switch C communicates with network 1200::0/64 through the path Switch C<—>Switch B<—>Switch A.
# Break down the path Switch C<—>Switch B<—>Switch A and then display route 1200::0/64 on Switch C.
Summary count : 1
  SubProtID: 0x1                    Age: 00h00m57s
      NibID: 0x25000000          LastAs: 0
     AttrID: 0x0               Neighbor: 2000::1
      Flags: 0x10060        OrigNextHop: 2000::1
      Label: NULL           RealNextHop: FE80::20C:29FF:FE40:715
The output shows that Switch C communicates with network 1200::0/64 through the path Switch C<—>Switch D<—>Switch A.
IPsec for IPv6 BGP packets configuration example
As shown in Figure 44, all switches run IPv6 BGP. Establish an IBGP connection between Switch A and Switch B, and establish an EBGP connection between Switch B and Switch C.
To enhance security, configure IPsec to protect IPv6 BGP packets.
Figure 44 Network diagram
2.     Establish an IBGP connection between Switch A and Switch B:
[SwitchA] bgp 65008
[SwitchA-bgp-default] group ibgp internal
[SwitchA-bgp-default] peer 1::2 group ibgp
[SwitchA-bgp-default-ipv6] peer ibgp enable
[SwitchB] bgp 65008
[SwitchB-bgp-default] group ibgp internal
[SwitchB-bgp-default] peer 1::1 group ibgp
[SwitchB-bgp-default] address-family ipv6 unicast
[SwitchB-bgp-default-ipv6] peer ibgp enable
3.     Establish an EBGP connection between Switch B and Switch C:
[SwitchC] bgp 65009
[SwitchC-bgp-default] group ebgp external
[SwitchC-bgp-default] peer 3::1 as-number 65008
[SwitchC-bgp-default] peer 3::1 group ebgp
[SwitchC-bgp-default] address-family ipv6 unicast
[SwitchC-bgp-default-ipv6] peer ebgp enable
[SwitchB-bgp-default] group ebgp external
[SwitchB-bgp-default] peer 3::2 as-number 65009
[SwitchB-bgp-default] peer 3::2 group ebgp
[SwitchB-bgp-default-ipv6] peer ebgp enable
4.     Configure IPsec transform sets and IPsec profiles:
# On Switch A, create an IPsec transform set named tran1.
[SwitchA] ipsec transform-set tran1
# Set the encapsulation mode to transport mode.
[SwitchA-ipsec-transform-set-tran1] encapsulation-mode transport
# Set the security protocol to ESP, the encryption algorithm to DES, and authentication algorithm to SHA1.
[SwitchA-ipsec-transform-set-tran1] esp encryption-algorithm des
[SwitchA-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[SwitchA-ipsec-transform-set-tran1] quit
# Create an IPsec profile named policy001, and specify the manual mode for it.
[SwitchA] ipsec profile policy001 manual
# Use IPsec transform set tran1.
[SwitchA-ipsec-profile-policy001-manual] transform-set tran1
# Set the SPIs of the inbound and outbound SAs to 12345.
[SwitchA-ipsec-profile-policy001-manual] sa spi outbound esp 12345
[SwitchA-ipsec-profile-policy001-manual] sa spi inbound esp 12345
# Set the keys for the inbound and outbound SAs using ESP to abcdefg.
[SwitchA-ipsec-profile-policy001-manual] sa string-key outbound esp simple abcdefg
[SwitchA-ipsec-profile-policy001-manual] sa string-key inbound esp simple abcdefg
[SwitchA-ipsec-profile-policy001-manual] quit
# On Switch B, create an IPsec transform set named tran1.
[SwitchB] ipsec transform-set tran1
[SwitchB-ipsec-transform-set-tran1] encapsulation-mode transport
[SwitchB-ipsec-transform-set-tran1] esp encryption-algorithm des
[SwitchB-ipsec-transform-set-tran1] esp authentication-algorithm sha1
[SwitchB-ipsec-transform-set-tran1] quit
# Create IPsec profile named policy001, and specify the manual mode for it.
[SwitchB] ipsec profile policy001 manual
[SwitchB-ipsec-profile-policy001-manual] transform-set tran1
[SwitchB-ipsec-profile-policy001-manual] sa spi outbound esp 12345
[SwitchB-ipsec-profile-policy001-manual] sa spi inbound esp 12345
[SwitchB-ipsec-profile-policy001-manual] sa string-key outbound esp simple abcdefg
[SwitchB-ipsec-profile-policy001-manual] sa string-key inbound esp simple abcdefg
[SwitchB-ipsec-profile-policy001-manual] quit
# Create an IPsec transform set named tran2.
[SwitchB] ipsec transform-set tran2
[SwitchB-ipsec-transform-set-tran2] encapsulation-mode transport
[SwitchB-ipsec-transform-set-tran2] esp encryption-algorithm des
[SwitchB-ipsec-transform-set-tran2] esp authentication-algorithm sha1
[SwitchB-ipsec-transform-set-tran2] quit
# Create IPsec profile named policy002, and specify the manual mode for it.
[SwitchB] ipsec profile policy002 manual
# Use IPsec transform set tran2.
[SwitchB-ipsec-profile-policy002-manual] transform-set tran2
# Set the SPIs of the inbound and outbound SAs to 54321.
[SwitchB-ipsec-profile-policy002-manual] sa spi outbound esp 54321
[SwitchB-ipsec-profile-policy002-manual] sa spi inbound esp 54321
# Set the keys for the inbound and outbound SAs using ESP to gfedcba.
[SwitchB-ipsec-profile-policy002-manual] sa string-key outbound esp simple gfedcba
[SwitchB-ipsec-profile-policy002-manual] sa string-key inbound esp simple gfedcba
[SwitchB-ipsec-profile-policy002-manual] quit
# On Switch C, create an IPsec transform set named tran2.
[SwitchC] ipsec transform-set tran2
[SwitchC-ipsec-transform-set-tran2] encapsulation-mode transport
[SwitchC-ipsec-transform-set-tran2] esp encryption-algorithm des
[SwitchC-ipsec-transform-set-tran2] esp authentication-algorithm sha1
[SwitchC-ipsec-transform-set-tran2] quit
[SwitchC] ipsec profile policy002 manual
[SwitchC-ipsec-profile-policy002-manual] transform-set tran2
[SwitchC-ipsec-profile-policy002-manual] sa spi outbound esp 54321
[SwitchC-ipsec-profile-policy002-manual] sa spi inbound esp 54321
[SwitchC-ipsec-profile-policy002-manual] sa string-key outbound esp simple gfedcba
[SwitchC-ipsec-profile-policy002-manual] sa string-key inbound esp simple gfedcba
[SwitchC-ipsec-profile-policy002-manual] quit
5.     Configure IPsec to protect IPv6 BGP packets between Switch A and Switch B:
[SwitchA] bgp 65008
[SwitchA-bgp-default] peer 1::2 ipsec-profile policy001
[SwitchB] bgp 65008
[SwitchB-bgp-default] peer 1::1 ipsec-profile policy001
6.     Configure IPsec to protect IPv6 BGP packets between Router B and Switch C:
[SwitchC] bgp 65009
[SwitchC-bgp-default] peer ebgp ipsec-profile policy002
[SwitchB] bgp 65008
[SwitchB-bgp-default] peer ebgp ipsec-profile policy002
# Display detailed information about IPv6 BGP peers on Switch B.
[SwitchB] display bgp peer ipv6 verbose
         Peer: 1::1      Local: 2.2.2.2
         Type: IBGP link
         BGP version 4, remote router ID 1.1.1.1
         BGP current state: Established, Up for 00h05m54s
         BGP last state: OpenConfirm
         Port:  Local - 24896    Remote - 179
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Peer optional capabilities:
         Peer supports BGP multi-protocol extension
         Peer supports BGP route refresh capability
         Peer supports BGP route AS4 capability
InQ updates: 0, OutQ updates: 0
 NLRI statistics:
         Rcvd:   UnReach NLRI          0,       Reach NLRI          0
         Sent:   UnReach NLRI          0,       Reach NLRI          3
 Message statistics:
 Msg type     Last rcvd time/      Current rcvd count/      History rcvd count/
              Last sent time       Current sent count       History sent count
 Open         18:59:15-2019.4.24   1                        1
              18:59:15-2019.4.24   1                        2
 Update       -                    0                        0
              18:59:16-2019.4.24   1                        1
 Notification -                    0                        0
              18:59:15-2019.4.24   0                        1
 Keepalive    18:59:15-2019.4.24   1                        1
 RouteRefresh -                    0                        0
              -                    0                        0
 Total        -                    2                        2
              -                    3                        5
 Threshold: 75%
 Minimum time between advertisements is 15 seconds
 Optional capabilities:
 Peer preferred value: 0
 IPsec profile name: policy001
 Routing policy configured:
         Peer: 3::2      Local: 2.2.2.2
         Type: EBGP link
         BGP version 4, remote router ID 3.3.3.3
         BGP current state: Established, Up for 00h05m00s
         Port:  Local - 24897    Remote - 179
 Received: Total 8 messages, Update messages 1
 Sent: Total 8 messages, Update messages 1
 Threshold: 75%
 IPsec profile name: policy002
IPv6 BGP FRR configuration example
As shown in Figure 45, configure BGP FRR so that when Link B fails, BGP uses Link A to forward traffic.
Figure 45 Network diagram
2.     Configure OSPFv3 in AS 200 to ensure connectivity among Switch B, Switch C, and Switch D. (Details not shown.)
# Configure Switch A to establish EBGP sessions to Switch B and Switch C, and advertise network 1::/64.
[SwitchA] bgp 100
[SwitchA] router-id 1.1.1.1
[SwitchA-bgp-default] peer 3001::2 as-number 200
[SwitchA-bgp-default] peer 2001::2 as-number 200
[SwitchA-bgp-default-ipv6] peer 3001::2 enable
[SwitchA-bgp-default-ipv6] peer 2001::2 enable
[SwitchB] bgp 200
[SwitchB] router-id 2.2.2.2
[SwitchB-bgp-default] peer 3001::1 as-number 100
[SwitchB-bgp-default] peer 3002::2 as-number 200
[SwitchB-bgp-default-ipv6] peer 3001::1 enable
[SwitchB-bgp-default-ipv6] peer 3002::2 enable
[SwitchB-bgp-default-ipv6] peer 3002::2 next-hop-local
[SwitchC] bgp 200
[SwitchC] router-id 3.3.3.3
[SwitchC-bgp-default] peer 2001::1 as-number 100
[SwitchC-bgp-default] peer 2002::2 as-number 200
[SwitchC-bgp-default-ipv6] peer 2001::1 enable
[SwitchC-bgp-default-ipv6] peer 2002::2 enable
[SwitchC-bgp-default-ipv6] peer 2002::2 next-hop-local
# Configure Switch D to establish IBGP sessions to Switch B and Switch C, and advertise network 4::/64.
<SwitchD> system-view
[SwitchD] bgp 200
[SwitchD-bgp-default] peer 3002::1 as-number 200
[SwitchD-bgp-default] peer 2002::1 as-number 200
[SwitchD-bgp-default] address-family ipv6 unicast
[SwitchD-bgp-default-ipv6] peer 3002::1 enable
[SwitchD-bgp-default-ipv6] peer 2002::1 enable
[SwitchD-bgp-default-ipv6] network 4:: 64
[SwitchD-bgp-default-ipv6] quit
[SwitchD-bgp-default] quit
[SwitchA-bgp-default-ipv6] peer 3001::2 preferred-value 100
[SwitchD-bgp-default-ipv6] peer 3002::1 preferred-value 100
# On Switch A, create routing policy frr to set a backup next hop 2001::2 (Switch C) for the route destined for 4::/64.
[SwitchA] ipv6 prefix-list abc index 10 permit 4:: 64
[SwitchA-route-policy] if-match ipv6 address prefix-list abc
[SwitchA-route-policy] apply ipv6 fast-reroute backup-nexthop 2001::2
# Apply the routing policy to BGP FRR for BGP IPv6 unicast address family.
[SwitchA] bgp 100
[SwitchA-bgp-default-ipv6] fast-reroute route-policy frr
# On Switch D, create routing policy frr to set a backup next hop 2002::1 (Switch C) for the route destined for 1::/64.
[SwitchD] ipv6 prefix-list abc index 10 permit 1:: 64
[SwitchD-route-policy] if-match ipv6 address prefix-list abc
[SwitchD-route-policy] apply ipv6 fast-reroute backup-nexthop 2002::1
[SwitchD] bgp 200
[SwitchD-bgp-default-ipv6] fast-reroute route-policy frr
# Display detailed information about the route to 4::/64 on Switch A. The output shows the backup next hop for the route.
[SwitchA] display ipv6 routing-table 4:: 64 verbose
Summary count : 1
Destination: 4::/64
  SubProtID: 0x2                    Age: 00h00m58s
    TableID: 0xa                 OrigAs: 200
      NibID: 0x25000003          LastAs: 200
     AttrID: 0x3               Neighbor: 3001::2
      Flags: 0x10060        OrigNextHop: 3001::2
      Label: NULL           RealNextHop: 3001::2
    BkLabel: NULL             BkNextHop: 2001::2
# Display detailed information about the route to 1::/64 on Switch D. The output shows the backup next hop for the route.
[SwitchD] display ipv6 routing-table 1:: 64 verbose
Summary count : 1
Destination: 1::/64
  SubProtID: 0x1                    Age: 00h03m24s
    TableID: 0xa                 OrigAs: 100
      NibID: 0x25000003          LastAs: 100
     AttrID: 0x4               Neighbor: 3002::1
      Flags: 0x10060        OrigNextHop: 3002::1
      Label: NULL           RealNextHop: 3002::1
    BkLabel: NULL             BkNextHop: 2002::1
IPv6 multicast BGP configuration example
As shown in Figure 46, OSPFv3 runs within AS 100 and AS 200 to ensure intra-AS connectivity. IPv6 MBGP runs between the two ASs to exchange IPv6 unicast routes used for RPF check.
Enable Anycast RP on Switch A and Switch B.
Figure 46 Network diagram
Table 10 Interface and IP address assignment
Device
IP address
Device
IP address
Source
1002::100/64
Switch B
Vlan-int101
1001::2/64
Switch A
Vlan-int100
1002::1/64
Vlan-int102
2001::1/64
Vlan-int101
1001::1/64
Vlan-int103
2002::1/64
Loop0
1:1::1/128
Loop0
1:1::1/128
Loop1
1:1::2/128
Loop1
2:2::2/128
Switch C
Vlan-int200
3002::1/64
Switch D
Vlan-int103
2002::2/64
Vlan-int102
2001::2/64
Vlan-int104
3001::2/64
Vlan-int104
3001::1/64
1.     Configure IPv6 addresses for interfaces and configure OSPFv3 (this example uses OSPFv3 process 1) in AS 200 to ensure intra-AS connectivity. (Details not shown.)
2.     Enable IPv6 multicast routing, IPv6 PIM-SM, and MLD, and configure BSR boundaries:
# On Switch A, enable IPv6 multicast routing globally, and enable IPv6 PIM-SM on interfaces.
[SwitchA-mrib6] quit
[SwitchA-LoopBack0] ipv6 pim sm
# On Switch C, enable IPv6 multicast routing globally.
[SwitchC-mrib6] quit
# Enable IPv6 PIM-SM on interfaces, and enable MLD on VLAN-interface 200.
[SwitchC-Vlan-interface102] ipv6 pim sm
[SwitchC-Vlan-interface104] ipv6 pim sm
[SwitchC-Vlan-interface200] ipv6 pim sm
[SwitchA-Vlan-interface101] ipv6 pim bsr-boundary
[SwitchB-Vlan-interface101] ipv6 pim bsr-boundary
3.     Enable Anycast RP, and specify C-BSR and C-RP:
[SwitchA] ipv6 pim
[SwitchA-pim6] anycast-rp 1:1::1 1:1::2
[SwitchA-pim6] anycast-rp 1:1::1 2:2::2
[SwitchA-pim6] c-bsr 1:1::1
[SwitchA-pim6] c-rp 1:1::1
[SwitchA-pim6] quit
[SwitchB] ipv6 pim
[SwitchB-pim6] anycast-rp 1:1::1 1:1::2
[SwitchB-pim6] anycast-rp 1:1::1 2:2::2
[SwitchB-pim6] c-bsr 1:1::1
[SwitchB-pim6] c-rp 1:1::1
[SwitchB-pim6] quit
4.     Configure BGP to establish BGP IPv6 multicast peers and redistribute routes:
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 1001::2 as-number 200
# Enable exchange of IPv6 unicast routes used for RPF check with Switch B.
[SwitchA-bgp-default] address-family ipv6 multicast
[SwitchA-bgp-default-mul-ipv6] peer 1001::2 enable
[SwitchA-bgp-default-mul-ipv6] import-route direct
[SwitchA-bgp-default-mul-ipv6] quit
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 1001::1 as-number 100
[SwitchB-bgp-default] address-family ipv6 multicast
[SwitchB-bgp-default-mul-ipv6] peer 1001::1 enable
# Redistribute OSPFv3 routes into BGP.
[SwitchB-bgp-default-mul-ipv6] import-route ospfv3 1
[SwitchB-bgp-default-mul-ipv6] quit
5.     Establish BGP IPv6 unicast peer relationships between Switch A and Switch B and redistribute routes:
# On Switch A, enable BGP to exchange IPv6 unicast routes with Switch B, and redistribute direct routes into BGP.
[SwitchA-bgp-default-ipv6] peer 1001::2 enable
[SwitchA-bgp-default-ipv6] import-route direct
# On Switch B, enable BGP to exchange IPv6 unicast routes with Switch A, and redistribute direct routes into BGP.
[SwitchB-bgp-default-ipv6] peer 1001::1 enable
[SwitchB-bgp-default-ipv6] import-route direct
# Verify the BGP IPv6 multicast peer information on Switch B.
[SwitchB] display bgp peer ipv6 multicast
 BGP local router ID : 2.2.2.2
  1001::1     100       56       56      0        0 00:40:54 Established
# Verify the RPF information for the multicast source on Switch B.
[SwitchB] display ipv6 multicast rpf-info 1002::1
 RPF information about source 1002::1:
     RPF interface: Vlan-interface101, RPF neighbor: 1001::1
     Referenced prefix/prefix length: 1002::/64
     Referenced route type: mbgp
     Load splitting rule: disable
As shown in Figure 47, all switches run IPv6 BGP. Establish a TCP connection between Switch A and the RPKI server, and establish an IBGP connection between Switch A and Switch B.
Figure 47 Network diagram
1.     Configure IPv6 addresses for interfaces and establish an IBGP connection between Switch A and Switch B. (Details not shown.)
[SwitchA] bgp 100
[SwitchA-bgp-default-rpki] server tcp 1::2
[RouterA-bgp-default-rpki-server] port 1234
[RouterA-bgp-default-rpki-server] quit
[SwitchA-bgp-default-ipv6] bestroute origin-as-validation
5.     Configure Switch A to advertise the BGP RPKI validation state to peer 2001::2.
[SwitchA-bgp-default-ipv6] peer 2001::2 advertise-ext-community
[SwitchA-bgp-default-ipv6] peer 2001::2 advertise origin-as-validation
# Configure a routing policy.
# Apply the routing policy.
[SwitchB] bgp 100
[SwitchB-bgp-default-ipv6] peer 2001::1 route-policy rpki_policy import
  1::2            0          1234        Establish  00:04:43   5/5
[SwitchA] display bgp rpki table ipv6
  2001:4860::     32-32         100          1::2         U
  2404:6800::     32-32         100          1::2         U
  2607:F8B0::     28-28         4294967295   1::2         U
  2A03:ACE0::     40-40         4294967295   1::2         U
  2001::1         64-64         200          1::2         U
The output shows that Switch A has obtained ROAs from the RPKI server.
[SwitchA] display bgp routing-table ipv6 2001::1 64
 BGP local router ID: 2.2.2.2
 Paths:   1 available, 1 best
 BGP routing table information of 2001::1/64:
 Imported route.
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
The route to 2001::1 matches the ROA with a prefix of 2001::1, a prefix length range of 64 to 64, and an origin AS number of 200. Therefore, the BGP RPKI validation state of the route to 2001::1 is Valid.
# On Switch B, display detailed information about the BGP IPv6 unicast route to network 2001::1.
[SwitchB] display bgp routing-table ipv6 2001::1 64
RR-client route.
 Rely nexthop    : 2001::1
 Original nexthop: 2001::1
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 Org-validation  : Invalid
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
The output displays information about the BGP IPv6 unicast route to 2001::1 because Switch B permits routes with a BGP RPKI validation state of Valid.
Troubleshooting BGP
Symptom
The display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command output shows that the state of the connection to a peer cannot become established.
Analysis
To become BGP peers, any two routers must establish a TCP connection using port 179 and exchange Open messages successfully.
Solution
1.     To resolve the problem:
a.     Use the display current-configuration command to verify the current configuration, and verify that the peer's AS number is correct.
b.     Use the display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command to verify that the peer's IP/IPv6 address is correct.
c.     If a loopback interface is used, verify that the loopback interface is specified with the peer connect-interface command.
d.     If the peer is a non-direct EBGP peer, verify that the peer ebgp-max-hop command is configured.
e.     If the peer ttl-security hops command is configured, verify that the command is configured on the peer. Verify that the hop-count values configured on them are greater than the number of hops between them.
f.     Verify that a valid route to the peer is available.
g.     Use the ping command to verify the connectivity to the peer.
h.     Use the display tcp verbose or display ipv6 tcp verbose command to verify the TCP connection.
i.     Verify that no ACL rule is applied to disable TCP port 179.
2.     If the problem persists, contact H3C Support.
