- 06-Network
- 01-VRF
- 02-Interface
- 03-Interface pairs
- 04-Interface collaboration
- 05-4G
- 06-Security zones
- 07-VLAN
- 08-MAC
- 09-DNS
- 10-ARP
- 11-ND
- 12-GRE
- 13-IPsec
- 14-ADVPN
- 15-L2TP
- 16-SSL VPN
- 17-Routing table
- 18-Static routing
- 19-Policy-based routing
- 20-OSPF
- 21-BGP
- 22-RIP
- 23-IP multicast routing
- 24-PIM
- 25-IGMP
- 26-DHCP
- 27-HTTP
- 28-SSH
- 29-NTP
- 30-FTP
- 31-Telnet
- 32-MAC authentication
- 33-MAC address whitelist
- 34-MAC access silent MAC info
- 35-MAC access advanced settings
- 36-IP authentication
- 37-IPv4 whitelist
- 38-IPv6 whitelist
- 39-Wireless
| 39-Wireless | 36.24 KB |
Wireless
This help contains the following topics:
¡ Configure the client blacklist or whitelist
Introduction
The Wireless menu displays wireless device information and wireless client statistics and allows you to configure wireless settings.
Wireless information
You can view the following information on the Wireless Info page:
· Wireless client statistics—Displays the total client quantity and the number of clients for each radio mode. Radio modes include 802.11a, 802.11b, 802.11g, 802.11n (2.4 GHz), 802.11n (5GHz), and 802.11ac.
· Wireless services—Displays summary information about wireless services, including SSID, VLAN interface, and the number of associated clients. You can click the Details button to view detailed information.
· SNR distribution—Displays distribution of clients by SNR. A larger SNR value indicates a higher WLAN quality.
· Rate distribution—Displays distribution of clients by transmission rate. A higher transmission rate indicates a higher WLAN quality.
· Online clients—Displays information about online clients, including MAC address, IP address, and SSID. To log off a client, click Log Off. To add a client to the blacklist, click Add to Blacklist.
Wireless settings
You can configure the following settings on the Wireless Settings page:
· Wireless services—Create, edit, or delete wireless services and configure WLAN features such as SSID hidden, Layer 2 isolation, and local authentication.
· APs—Configure the working frequencies and power modes for the AP.
· Client blacklist and whitelist—Configure the client blacklist or whitelist to forbid specific clients to access the WLANs or allow only the specified clients to access the WLANs.
Configure wireless settings
Create a wireless service
1. Select Networks > Wireless > Wireless Settings.
2. In the Configure Wireless Service area, click Create.
3. Configure wireless settings.
Table 1 Wireless service configuration items
Item |
SSID |
Enter the SSID. |
VLAN interface |
Select the VLAN interface. |
Password |
Specify the password for clients to access the WLAN. |
SSID hidden |
Select whether to enable the SSID hidden feature. With this feature enabled, a user must manually specify the SSID for a client to access the WLAN. |
Layer 2 isolation |
Select whether to enable Layer 2 isolation. With this feature enabled, clients cannot communicate with each other directly at Layer 2. |
Local auth |
Select whether to enable the AP to authenticate clients. |
Portal server |
Specify the IP address of the portal Web server for client authentication. This field is available only when local authentication is enabled. |
ISP domain |
Specify the ISP domain to which clients accessing the WLAN belong. This field is available only when local authentication is enabled. |
4. Click OK.
Configure an AP
1. Select Network > Wireless > Wireless Settings.
2. Configure AP settings.
Table 2 AP configuration items
Item |
AP Name |
Edit the AP name. |
5 GHz state |
Enable or disable the 5 GHz band. |
5 GHz power mode |
Select the 5 GHz power mode. Options include: · Power save—Low transmit power. This mode is applicable to scenarios that require a small coverage and low radiation. · Normal—Normal transmit power. · Strong—High transmit power. This mode is applicable to scenarios that require a large coverage but do not have high requirements on radiation. |
2.4 GHz |
Enable or disable the 2.4 GHz band. |
2.4 GHz power mode |
Select the 2.4 GHz power mode. Options include: · Power save—Low transmit power. This mode is applicable to scenarios that require a small coverage and low radiation. · Normal—Normal transmit power. · Strong—High transmit power. This mode is applicable to scenarios that require a large coverage but do not have high requirements on radiation. |
2. In the Client Blacklist or Client Whitelist area, click Add.
3. Enter a client MAC address.
4. Click OK.
