- 06-Network
- 01-VRF
- 02-Interface
- 03-Interface pairs
- 04-Interface collaboration
- 05-4G
- 06-Security zones
- 07-VLAN
- 08-MAC
- 09-DNS
- 10-ARP
- 11-ND
- 12-GRE
- 13-IPsec
- 14-ADVPN
- 15-L2TP
- 16-SSL VPN
- 17-Routing table
- 18-Static routing
- 19-Policy-based routing
- 20-OSPF
- 21-BGP
- 22-RIP
- 23-IP multicast routing
- 24-PIM
- 25-IGMP
- 26-DHCP
- 27-HTTP
- 28-SSH
- 29-NTP
- 30-FTP
- 31-Telnet
- 32-MAC authentication
- 33-MAC address whitelist
- 34-MAC access silent MAC info
- 35-MAC access advanced settings
- 36-IP authentication
- 37-IPv4 whitelist
- 38-IPv6 whitelist
- 39-Wireless
| 29-NTP | 19.91 KB |
NTP
This help contains the following topics:
Introduction
Network Time Protocol (NTP) is used to synchronize system clocks among distributed time servers and clients on a network.
NTP uses stratums 1 to 15 to define clock accuracy. A lower stratum value represents higher accuracy.
If devices on a network cannot synchronize to an authoritative time source, you can perform the following tasks to achieve NTP synchronization on the network:
1. Select a device that has a relatively accurate clock on the network.
2. Configure the local clock of the device as its reference source.
3. Configure the device as a time server to synchronize other devices on the network.
You can configure a local clock as the reference source from the Web interface.
Before configuring a local clock as the reference source, adjust the time on the local clock to ensure that it is accurate.
