05-Layer 3—IP Routing Configuration Guide
HomeSupportSwitchesS6300 SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10005-Layer 3—IP Routing Configuration Guide
04-OSPF configuration
04-OSPF configuration 713.01 KB
Configuring OSPF· 1
Overview· 1
OSPF packets· 1
LSA types· 1
OSPF areas· 2
Router types· 4
Route types· 5
Route calculation· 5
OSPF network types· 6
DR and BDR· 6
Protocols and standards· 7
OSPF configuration task list 7
Enabling OSPF· 9
Configuration prerequisites· 9
Configuration guidelines· 9
Enabling OSPF on a network· 9
Enabling OSPF on an interface· 10
Configuring OSPF areas· 10
Configuring a stub area· 11
Configuring an NSSA area· 11
Configuring a virtual link· 12
Configuring OSPF network types· 12
Configuration prerequisites· 13
Configuring the broadcast network type for an interface· 13
Configuring the NBMA network type for an interface· 13
Configuring the P2MP network type for an interface· 14
Configuring the P2P network type for an interface· 14
Configuring OSPF route control 15
Configuration prerequisites· 15
Configuring OSPF route summarization· 15
Configuring received OSPF route filtering· 16
Configuring Type-3 LSA filtering· 17
Configuring an OSPF cost for an interface· 17
Configuring the maximum number of ECMP routes· 18
Configuring OSPF preference· 18
Configuring OSPF route redistribution· 18
Advertising a host route· 20
Tuning and optimizing OSPF networks· 20
Configuration prerequisites· 20
Configuring OSPF timers· 20
Specifying LSA transmission delay· 21
Specifying SPF calculation interval 21
Specifying the LSA arrival interval 22
Specifying the LSA generation interval 22
Disabling interfaces from receiving and sending OSPF packets· 23
Configuring stub routers· 23
Configuring OSPF authentication· 24
Adding the interface MTU into DD packets· 25
Configuring a DSCP value for OSPF packets· 25
Configuring the maximum number of external LSAs in LSDB· 25
Configuring OSPF exit overflow interval 26
Enabling compatibility with RFC 1583· 26
Logging neighbor state changes· 26
Configuring OSPF network management 27
Configuring the LSU transmit rate· 28
Enabling OSPF ISPF· 28
Configuring prefix suppression· 28
Configuring OSPF PIC· 29
Configuring the number of OSPF logs· 30
Configuring OSPF GR· 30
Configuring OSPF GR restarter 30
Configuring OSPF GR helper 31
Triggering OSPF GR· 32
Configuring OSPF NSR· 32
Configuring BFD for OSPF· 33
Configuring bidirectional control detection· 33
Configuring single-hop echo detection· 33
Configuring OSPF FRR· 33
Configuration prerequisites· 34
Configuration guidelines· 34
Configuration procedure· 34
Displaying and maintaining OSPF· 35
OSPF configuration examples· 36
Basic OSPF configuration example· 36
OSPF route redistribution configuration example· 39
OSPF route summarization configuration example· 41
OSPF stub area configuration example· 44
OSPF NSSA area configuration example· 46
OSPF DR election configuration example· 48
OSPF virtual link configuration example· 52
OSPF GR configuration example· 54
OSPF NSR configuration example· 57
BFD for OSPF configuration example· 59
OSPF FRR configuration example· 61
Troubleshooting OSPF configuration· 63
No OSPF neighbor relationship established· 63
Incorrect routing information· 64
Configuring OSPF
Overview
Open Shortest Path First (OSPF) is a link-state IGP developed by the OSPF working group of the IETF. OSPF version 2 is used for IPv4. OSPF refers to OSPFv2 throughout this chapter.
OSPF has the following features:
·           Wide scope—Supports multiple network sizes and several hundred routers in an OSPF routing domain.
·           Fast convergenceAdvertises routing updates instantly upon network topology changes.
·           Loop free—Computes routes with the SPF algorithm to avoid routing loops.
·           Area-based network partition—Splits an AS into multiple areas to facilitate management. This feature reduces the LSDB size on routers to save memory and CPU resources, and reduces route updates transmitted between areas to save bandwidth.
·           ECMP routing—Supports multiple equal-cost routes to a destination.
·           Routing hierarchy—Supports a 4-level routing hierarchy that prioritizes routes into intra-area, inter-area, external Type-1, and external Type-2 routes.
·           Authentication—Supports area- and interface-based packet authentication to ensure secure packet exchange.
·           Support for multicasting—Multicasts protocol packets on some types of links to avoid impacting other devices.
OSPF packets
OSPF messages are carried directly over IP. The protocol number is 89.
OSPF uses the following packet types:
·           Hello—Periodically sent to find and maintain neighbors, containing timer values, information about the DR, BDR, and known neighbors.
·           Database description (DD)—Describes the digest of each LSA in the LSDB, exchanged between two routers for data synchronization.
·           Link state request (LSR)—Requests needed LSAs from a neighbor. After exchanging the DD packets, the two routers know which LSAs of the neighbor are missing from their LSDBs. They then exchange LSR packets requesting the missing LSAs. LSR packets contain the digest of the missing LSAs.
·           Link state update (LSU)—Transmits the requested LSAs to the neighbor.
·           Link state acknowledgment (LSAck)—Acknowledges received LSU packets. It contains the headers of received LSAs (an LSAck packet can acknowledge multiple LSAs).
LSA types
OSPF advertises routing information in Link State Advertisements (LSAs). The following LSAs are commonly used:
·           Router LSA—Type-1 LSA, originated by all routers and flooded throughout a single area only. This LSA describes the collected states of the router's interfaces to an area.
·           Network LSA—Type-2 LSA, originated for broadcast and NBMA networks by the designated router, and flooded throughout a single area only. This LSA contains the list of routers connected to the network.
·           Network Summary LSA—Type-3 LSA, originated by Area Border Routers (ABRs), and flooded throughout the LSA's associated area. Each summary-LSA describes a route to a destination outside the area, yet still inside the AS (an inter-area route).
·           ASBR Summary LSA—Type-4 LSA, originated by ABRs and flooded throughout the LSA's associated area. Type 4 summary-LSAs describe routes to Autonomous System Boundary Router (ASBR).
·           AS External LSA—Type-5 LSA, originated by ASBRs, and flooded throughout the AS (except stub and NSSA areas). Each AS-external-LSA describes a route to another AS.
·           NSSA LSA—Type-7 LSA, as defined in RFC 1587, originated by ASBRs in NSSAs and flooded throughout a single NSSA. NSSA LSAs describe routes to other ASs.
·           Opaque LSA—A proposed type of LSA. Its format consists of a standard LSA header and application specific information. Opaque LSAs are used by the OSPF protocol or by some applications to distribute information into the OSPF routing domain. The opaque LSA includes Type 9, Type 10, and Type 11. The Type 9 opaque LSA is flooded into the local subnet, the Type 10 is flooded into the local area, and the Type 11 is flooded throughout the AS.
OSPF areas
In large OSPF routing domains, SPF route computations consume too many storage and CPU resources, and enormous OSPF packets generated for route synchronization occupy excessive bandwidth.
To resolve these issues, OSPF splits an AS into multiple areas. Each area is identified by an area ID. The boundaries between areas are routers rather than links. A network segment (or a link) can only reside in one area as shown in Figure 1.
You can configure route summarization on ABRs to reduce the number of LSAs advertised to other areas and minimize the effect of topology changes.
Figure 1 Area-based OSPF network partition
Backbone area and virtual links
Each AS has a backbone area that distributes routing information between non-backbone areas. Routing information between non-backbone areas must be forwarded by the backbone area. OSPF has the following requirements:
·           All non-backbone areas must maintain connectivity to the backbone area.
·           The backbone area must maintain connectivity within itself.
In practice, these requirements might not be met due to lack of physical links. OSPF virtual links can solve this issue.
A virtual link is established between two ABRs through a non-backbone area. It must be configured on both ABRs to take effect. The non-backbone area is called a transit area.
As shown in Figure 2, Area 2 has no direct physical link to the backbone Area 0. You can configure a virtual link between the two ABRs to connect Area 2 to the backbone area.
Figure 2 Virtual link application 1
Virtual links can also be used to provide redundant links. If the backbone area cannot maintain internal connectivity because of the failure of a physical link, you can configure a virtual link to replace the failed physical link, as shown in Figure 3.
Figure 3 Virtual link application 2
The virtual link between the two ABRs acts as a point-to-point connection. You can configure interface parameters, such as hello interval, on the virtual link as they are configured on a physical interface.
The two ABRs on the virtual link unicast OSPF packets to each other, and the OSPF routers in between convey these OSPF packets as normal IP packets.
Stub area and totally stub area
A stub area does not distribute Type-5 LSAs to reduce the routing table size and LSAs advertised within the area. The ABR of the stub area advertises a default route in a Type-3 LSA so that the routers in the area can reach external networks through the default route.
To further reduce the routing table size and advertised LSAs, you can configure the stub area as a totally stub area. The ABR of a totally stub area does not advertise inter-area routes or external routes. It advertises a default route in a Type-3 LSA so that the routers in the area can reach external networks through the default route.
NSSA area and totally NSSA area
An NSSA area does not import AS external LSAs (Type-5 LSAs) but can import Type-7 LSAs generated by the NSSA ASBR. The NSSA ABR translates Type-7 LSAs into Type-5 LSAs and advertises the Type-5 LSAs to other areas.
As shown in Figure 4, the OSPF AS contains Area 1, Area 2, and Area 0. The other two ASs run RIP. Area 1 is an NSSA area where the ASBR redistributes RIP routes in Type-7 LSAs into Area 1. Upon receiving the Type-7 LSAs, the NSSA ABR translates them to Type-5 LSAs, and advertises the Type-5 LSAs to Area 0.
The ASBR of Area 2 redistributes RIP routes in Type-5 LSAs into the OSPF routing domain. However, Area 1 does not receive Type-5 LSAs because it is an NSSA area.
Figure 4 NSSA area
Router types
OSPF routers are classified into the following types based on their positions in the AS:
·           Internal routerAll interfaces on an internal router belong to one OSPF area.
·           ABRBelongs to more than two areas, one of which must be the backbone area. ABR connects the backbone area to a non-backbone area. An ABR and the backbone area can be connected through a physical or logical link.
·           Backbone router—At least one interface of a backbone router must reside in the backbone area. All ABRs and internal routers in Area 0 are backbone routers.
·           ASBR—Exchanges routing information with another AS is an ASBR. An ASBR might not reside on the border of the AS. It can be an internal router or an ABR.
Figure 5 OSPF router types
Route types
OSPF prioritizes routes into the following route levels:
·           Intra-area route.
·           Inter-area route.
·           Type-1 external route.
·           Type-2 external route.
The intra-area and inter-area routes describe the network topology of the AS. The external routes describe routes to external ASs.
A Type-1 external route has high credibility. The cost from a router to the destination of a Type-1 external route = the cost from the router to the corresponding ASBR + the cost from the ASBR to the destination of the external route.
A Type-2 external route has low credibility. OSPF considers that the cost from the ASBR to the destination of a Type-2 external route is much greater than the cost from the ASBR to an OSPF internal router. The cost from the internal router to the destination of the Type-2 external route = the cost from the ASBR to the destination of the Type-2 external route. If two Type-2 routes to the same destination have the same cost, OSPF takes the cost from the router to the ASBR into consideration to determine the best route.
Route calculation
OSPF computes routes in an area as follows:
·           Each router generates LSAs based on the network topology around itself, and sends them to other routers in update packets.
·           Each OSPF router collects LSAs from other routers to compose an LSDB. An LSA describes the network topology around a router, and the LSDB describes the entire network topology of the area.
·           Each router transforms the LSDB to a weighted directed graph that shows the topology of the area. All the routers within the area have the same graph.
·           Each router uses the SPF algorithm to compute a shortest path tree that shows the routes to the nodes in the area. The router itself is the root of the tree.
OSPF network types
OSPF classifies networks into the following types, depending on different link layer protocols:
·           Broadcast—If the link layer protocol is Ethernet or FDDI, OSPF considers the network type as broadcast by default. On a broadcast network, hello, LSU, and LSAck packets are multicast to 224.0.0.5 that identifies all OSPF routers or to 224.0.0.6 that identifies the DR and BDR. DD packets and LSR packets are unicast.
·           NBMA—If the link layer protocol is Frame Relay, ATM, or X.25, OSPF considers the network type as NBMA by default. OSPF packets are unicast on an NBMA network.
·           P2MPNo link is P2MP type by default. P2MP must be a conversion from other network types such as NBMA. On a P2MP network, OSPF packets are multicast to 224.0.0.5.
·           P2P—If the link layer protocol is PPP or HDLC, OSPF considers the network type as P2P. On a P2P network, OSPF packets are multicast to 224.0.0.5.
The following are the differences between NBMA and P2MP networks:
·           NBMA networks are fully meshed. P2MP networks are not required to be fully meshed.
·           NBMA networks require DR and BDR election. P2MP networks do not have DR or BDR.
·           On an NBMA network, OSPF packets are unicast, and neighbors are manually configured. On a P2MP network, OSPF packets are multicast by default, and you can configure OSPF to unicast protocol packets.
DR and BDR
DR and BDR mechanism
On a broadcast or NBMA network, any two routers must establish an adjacency to exchange routing information with each other. If n routers are present on the network, n(n-1)/2 adjacencies are established. Any topology change on the network results in an increase in traffic for route synchronization, which consumes a large amount of system and bandwidth resources.
Using the DR and BDR mechanisms can solve this problem.
·           DR—Elected to advertise routing information among other routers. If the DR fails, routers on the network must elect another DR and synchronize information with the new DR. Using this mechanism without BDR is time-consuming and is prone to route calculation errors.
·           BDR—Elected along with the DR to establish adjacencies with all other routers. If the DR fails, the BDR immediately becomes the new DR, and other routers elect a new BDR.
Routers other than the DR and BDR are called DR Others. They do not establish adjacencies with one another, so the number of adjacencies is reduced.
The role of a router is subnet (or interface) specific. It might be a DR on one interface and a BDR or DR Other on another interface.
As shown in Figure 6, solid lines are Ethernet physical links, and dashed lines represent OSPF adjacencies. With the DR and BDR, only seven adjacencies are established.
Figure 6 DR and BDR in a network
In OSPF, neighbor and adjacency are different concepts. After startup, OSPF sends a hello packet on each OSPF interface. A receiving router checks parameters in the packet. If the parameters match its own, the receiving router considers the sending router an OSPF neighbor. Two OSPF neighbors establish an adjacency relationship after they synchronize their LSDBs through exchange of DD packets and LSAs.
DR and BDR election
DR election is performed on broadcast or NBMA networks but not on P2P and P2MP networks.
Routers in a broadcast or NBMA network elect the DR and BDR by router priority and ID. Routers with a router priority value higher than 0 are candidates for DR and BDR election.
The election votes are hello packets. Each router sends the DR elected by itself in a hello packet to all the other routers. If two routers on the network declare themselves as the DR, the router with the higher router priority wins. If router priorities are the same, the router with the higher router ID wins.
If a router with a higher router priority is added to the network after DR and BDR election, the router cannot become the DR or BDR immediately because no DR election is performed for it. Therefore, the DR of a network might not be the router with the highest priority, and the BDR might not be the router with the second highest priority.
·           RFC 1765, OSPF Database Overflow
·           RFC 2328, OSPF Version 2
·           RFC 3101, OSPF Not-So-Stubby Area (NSSA) Option
·           RFC 3137, OSPF Stub Router Advertisement
·           RFC 4811, OSPF Out-of-Band LSDB Resynchronization
·           RFC 4812, OSPF Restart Signaling
·           RFC 4813, OSPF Link-Local Signaling
To run OSPF, you must first enable OSPF on the router. Make a proper configuration plan to avoid incorrect settings that can result in route blocking and routing loops.
To configure OSPF, perform the following tasks:
Tasks at a glance
(Required.) Enabling OSPF
(Optional.) Configuring OSPF areas:
·          Configuring a stub area
·          Configuring an NSSA area
·          Configuring a virtual link
(Optional.) Configuring OSPF network types:
·          Configuring the broadcast network type for an interface
·          Configuring the NBMA network type for an interface
·          Configuring the P2MP network type for an interface
·          Configuring the P2P network type for an interface
(Optional.) Configuring OSPF route control:
·          Configuring OSPF route summarization
¡  Configuring route summarization on an ABR
¡  Configuring route summarization on an ASBR
¡  Configuring discard routes for summary networks
·          Configuring received OSPF route filtering
·          Configuring Type-3 LSA filtering
·          Configuring an OSPF cost for an interface
·          Configuring the maximum number of ECMP routes
·          Configuring OSPF preference
·          Configuring OSPF route redistribution
¡  Redistributing routes from another routing protocol
¡  Redistributing a default route
¡  Configuring default parameters for redistributed routes
·          Advertising a host route
(Optional.) Tuning and optimizing OSPF networks:
·          Configuring OSPF timers
·          Specifying LSA transmission delay
·          Specifying SPF calculation interval
·          Specifying the LSA arrival interval
·          Specifying the LSA generation interval
·          Disabling interfaces from receiving and sending OSPF packets
·          Configuring stub routers
·          Configuring OSPF authentication
·          Adding the interface MTU into DD packets
·          Configuring a DSCP value for OSPF packets
·          Configuring the maximum number of external LSAs in LSDB
·          Configuring OSPF exit overflow interval
·          Enabling compatibility with RFC 1583
·          Logging neighbor state changes
·          Configuring OSPF network management
·          Configuring the LSU transmit rate
·          Enabling OSPF ISPF
·          Configuring prefix suppression
·          Configuring OSPF PIC
·          Configuring the number of OSPF logs
(Optional.) Configuring OSPF GR
·          Configuring OSPF GR restarter
·          Configuring OSPF GR helper
·          Triggering OSPF GR
(Optional.) Configuring OSPF NSR
(Optional.) Configuring BFD for OSPF
(Optional.) Configuring OSPF FRR
Enabling OSPF
Enable OSPF before you perform other OSPF configuration tasks.
Configure the link layer protocol and IP addresses for interfaces to ensure IP connectivity between neighboring nodes.
To enable OSPF on an interface, you can enable OSPF on the network where the interface resides or directly enable OSPF on that interface. If you configure both, the latter takes precedence.
You can specify a global router ID, or specify a router ID when you create an OSPF process.
·           If you specify a router ID when you create an OSPF process, any two routers in an AS must have different router IDs. A common practice is to specify the IP address of an interface as the router ID.
·           If you specify no router ID when you create the OSPF process, the global router ID is used. As a best practice, specify a router ID when you create the OSPF process.
OSPF supports multiple processes and VPNs.
·           To run multiple OSPF processes, you must specify an ID for each process. The process IDs take effect locally and has no influence on packet exchange between routers. Two routers with different process IDs can exchange packets.
·           You can configure an OSPF process to run in a specified VPN instance. For more information about VPN, see MCE Configuration Guide.
Step
Remarks
1.      Enter system view.
N/A
1.      (Optional.) Configure a global router ID.
router id router-id
By default, no global router ID is configured.
If no global router ID is configured, the highest loopback interface IP address, if any, is used as the router ID. If no loopback interface IP address is available, the highest physical interface IP address is used, regardless of the interface status (up or down).
2.      Enable an OSPF process and enter OSPF view.
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ] *
By default, OSPF is disabled.
3.      (Optional.) Configure a description for the OSPF process.
description description
By default, no description is configured for the OSPF process.
As a best practice, configure a description for each OSPF process.
4.      Create an OSPF area and enter OSPF area view.
area area-id
By default, no OSPF area is created.
5.      (Optional.) Configure a description for the area.
By default, no description is configured for the area.
As a best practice, configure a description for each OSPF area.
6.      Specify a network to enable the interface attached to the network to run the OSPF process in the area.
By default, no network is specified.
A network can be added to only one area.
Step
Remarks
N/A
2.      Enter interface view.
N/A
3.      Enable an OSPF process on the interface.
By default, OSPF is disabled on an interface.
If the specified OSPF process and area do not exist, the command creates the OSPF process and area. Disabling an OSPF process on an interface does not delete the OSPF process or the area.
Before you configure an OSPF area, complete the following tasks:
·           Configure IP addresses for interfaces to ensure IP connectivity between neighboring nodes.
·           Enable OSPF.
You can configure a non-backbone area at an AS edge as a stub area. To do so, execute the stub command on all routers attached to the area. The routing table size is reduced because Type-5 LSAs will not be flooded within the stub area. The ABR generates a default route into the stub area so all packets destined outside of the AS are sent through the default route.
To further reduce the routing table size and routing information exchanged in the stub area, configure a totally stub area by using the stub [ no-summary ] command on the ABR. AS external routes and inter-area routes will not be distributed into the area. All the packets destined outside of the AS or area will be sent to the ABR for forwarding.
A stub or totally stub area cannot have an ASBR because external routes cannot be distributed into the area.
To configure an OSPF stub area:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enter area view.
area area-id
N/A
4.      Configure the area as a stub area.
By default, no stub area is configured.
5.      (Optional.) Specify a cost for the default route advertised to the stub area.
default-cost cost
The default setting is 1.
The default-cost cost command takes effect only on the ABR of a stub area or totally stub area.
A stub area cannot import external routes, but an NSSA area can import external routes into the OSPF routing domain while retaining other stub area characteristics.
Do not configure the backbone area as an NSSA area or totally NSSA area.
To configure an NSSA area, configure the nssa command on all the routers attached to the area.
To configure a totally NSSA area, configure the nssa command on all the routers attached to the area and configure the nssa no-summary command on the ABR. The ABR of a totally NSSA area does not advertise inter-area routes into the area.
To configure an NSSA area:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enter area view.
area area-id
N/A
4.      Configure the area as an NSSA area.
nssa [ default-route-advertise [ cost cost | nssa-only | type type ] * | no-import-route | no-summary | suppress-fa | [ [ [ translate-always ] [ translate-ignore-checking-backbone ] ] | translate-never ] | translator-stability-interval value ] *
By default, no area is configured as an NSSA area.
5.      (Optional.) Specify a cost for the default route advertised to the NSSA area.
default-cost cost
This command takes effect only on the ABR/ASBR of an NSSA or totally NSSA area.
Virtual links are configured for connecting backbone area routers that have no direct physical links.
To configure a virtual link:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enter area view.
area area-id
N/A
4.      Configure a virtual link.
vlink-peer router-id [ dead seconds | hello seconds | { { hmac-md5 | md5 } key-id { cipher cipher-string | plain plain-string } | simple { cipher cipher-string | plain plain-string } } | retransmit seconds | trans-delay seconds ] *
By default, no virtual link is configured.
Configure this command on both ends of a virtual link. The hello and dead intervals must be identical on both ends of the virtual link.
OSPF classifies networks into the following types based on the link layer protocol:
·           BroadcastWhen the link layer protocol is Ethernet or FDDI, OSPF classifies the network type as broadcast by default.
·           NBMAWhen the link layer protocol is Frame Relay, ATM, or X.25, OSPF classifies the network type as NBMA by default.
·           P2PWhen the link layer protocol is PPP, LAPB, or HDLC, OSPF classifies the network type as P2P by default.
When you change the network type of an interface, follow these guidelines:
·           When an NBMA network becomes fully meshed, change the network type to broadcast to avoid manual configuration of neighbors.
·           If any routers in a broadcast network do not support multicasting, change the network type to NBMA.
·           An NBMA network must be fully meshed. OSPF requires that an NBMA network be fully meshed. If a network is partially meshed, change the network type to P2MP.
·           If a router on an NBMA network has only one neighbor, you can change the network type to P2P to save costs.
Two broadcast-, NBMA-, and P2MP-interfaces can establish a neighbor relationship only when they are on the same network segment.
Before you configure OSPF network types, complete the following tasks:
·           Enable OSPF.
Step
Remarks
N/A
N/A
3.      Configure the OSPF network type for the interface as broadcast.
ospf network-type broadcast
By default, the network type of an interface depends on the link layer protocol.
4.      (Optional.) Configure a router priority for the interface.
ospf dr-priority priority
The default router priority is 1.
After you configure the network type as NBMA, you must specify neighbors and their router priorities because NBMA interfaces cannot find neighbors by broadcasting hello packets.
To configure the NBMA network type for an interface:
Step
Remarks
N/A
N/A
3.      Configure the OSPF network type for the interface as NBMA.
ospf network-type nbma
The router priority configured with this command is for DR election.
5.      Return to system view.
N/A
6.      Enter OSPF view.
N/A
7.      Specify a neighbor and its router priority.
peer ip-address [ dr-priority dr-priority ]
By default, no neighbor is specified.
The priority configured with this command indicates whether a neighbor has the election right or not. If you configure the router priority for a neighbor as 0, the local router determines the neighbor has no election right, and does not send hello packets to this neighbor. However, if the local router is the DR or BDR, it still sends hello packets to the neighbor for neighbor relationship establishment.
Step
Remarks
N/A
N/A
3.      Configure the OSPF network type for the interface as P2MP.
ospf network-type p2mp [ unicast ]
After you configure the OSPF network type for an interface as P2MP unicast, all packets are unicast over the interface. The interface cannot broadcast hello packets to discover neighbors, so you must manually specify the neighbors.
4.      Return to system view.
N/A
5.      Enter OSPF view.
N/A
6.      (Optional.) Specify a neighbor and its router priority.
peer ip-address [ cost value ]
This step must be performed if the network type is P2MP unicast, and is optional if the network type is P2MP.
Step
Remarks
N/A
N/A
3.      Configure the OSPF network type for the interface as P2P.
ospf network-type p2p [ peer-address-check ]
This section describes how to control the advertisement and reception of OSPF routing information, as well as route redistribution from other protocols.
Before you configure OSPF route control, complete the following tasks:
·           Enable OSPF.
·           Configure filters if routing information filtering is needed.
Route summarization enables an ABR or ASBR to summarize contiguous networks into a single network and advertise the network to other areas.
Route summarization reduces the routing information exchanged between areas and the size of routing tables, and improves routing performance. For example, three internal networks 19.1.1.0/24, 19.1.2.0/24, and 19.1.3.0/24 are available within an area. You can summarize the three networks into network 19.1.0.0/16, and advertise the summary network to other areas.
After you configure a summary route on an ABR, the ABR generates a summary LSA instead of specific LSAs. The scale of LSDBs on routers in other areas and the influence of topology changes are reduced.
To configure route summarization on an ABR:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enter OSPF area view.
area area-id
N/A
4.      Configure ABR route summarization.
abr-summary ip-address { mask-length | mask } [ advertise | not-advertise ] [ cost cost ]
By default, route summarization is not configured on an ABR.
Perform this task to enable an ASBR to summarize external routes within the specified address range into a single route. The ASBR advertises only the summary route to reduce the number of LSAs in the LSDB.
An ASBR can summarize routes in the following LSAs:
·           Type-5 LSAs.
·           Type-7 LSAs in an NSSA area.
·           Type-5 LSAs translated by the ASBR (also an ABR) from Type-7 LSAs in an NSSA area.
If the ASBR (ABR) is not a translator, it cannot summarize routes in Type-5 LSAs translated from Type-7 LSAs.
To configure route summarization on an ASBR:
Step
Remarks
N/A
2.      Enter OSPF view.
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ]*
N/A
3.      Configure ASBR route summarization.
asbr-summary ip-address { mask-length | mask } [ cost cost | not-advertise | nssa-only | tag tag ] *
By default, route summarization is not configured on an ASBR.
Discard routes help prevent routing black holes when route summarization is configured on ABRs and ASBRs.
During route summarization, an ABR or ASBR generates a discard route for the summary network. The destination and output interface of the discard route is the summary network and interface Null 0. When receiving packets destined for a nonexistent network that is a part of the summary network, the ABR or ASBR discards the packets according to the discard route.
For example, Router A summarizes networks 19.1.1.0/24, 19.1.2.0/24, and 19.1.3.0/24 into network 19.1.0.0/16, and advertises the summary network to Router B. When Router B receives a packet destined for 19.1.4.0/24, Router B forwards the packet to Router A according to the summary route. Because no specific route to 19.1.4.0/24 exists, Router A discards the packet according to the discard route.
To configure discard routes for summary networks:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure discard routes for summary networks.
discard-route { external { external-preference | suppression } | internal { internal-preference | suppression } } *
By default:
·          The ABR or ASBR generates discard routes for summary networks.
·          The preference of discard routes is 255.
Perform this task to use an ACL to filter routes (calculated by using received LSAs) by destination address.
To configure OSPF to filter routes calculated using received LSAs:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure OSPF to filter routes calculated using received LSAs.
filter-policy acl-number import
By default, OSPF accepts all routes calculated using received LSAs.
Perform this task to filter Type-3 LSAs advertised to an area on an ABR.
To configure Type-3 LSA filtering:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enter area view.
area area-id
N/A
4.      Configure Type-3 LSA filtering.
filter acl-number { export | import }
By default, the ABR does not filter Type-3 LSAs.
Configure an OSPF cost for an interface by using either of the following methods:
·           Configure the cost value in interface view.
·           Configure a bandwidth reference value for the interface. OSPF computes the cost with this formula: Interface OSPF cost = Bandwidth reference value (100 Mbps) / Expected interface bandwidth (Mbps). The expected bandwidth of an interface is configured with the bandwidth command (see Interface Command Reference).
¡  If the calculated cost is greater than 65535, the value of 65535 is used. If the calculated cost is less than 1, the value of 1 is used.
¡  If no cost or bandwidth reference value is configured for an interface, OSPF computes the interface cost based on the interface bandwidth and default bandwidth reference value.
To configure an OSPF cost for an interface:
Step
Remarks
N/A
N/A
3.      Configure an OSPF cost for the interface.
ospf cost value
By default, the OSPF cost is calculated according to the interface bandwidth. For a loopback interface, the OSPF cost is 0 by default.
To configure a bandwidth reference value:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure a bandwidth reference value.
bandwidth-reference value
The default setting is 100 Mbps.
Perform this task to implement load sharing over ECMP routes.
To configure the maximum number of ECMP routes:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure the maximum number of ECMP routes.
maximum load-balancing maximum
By default, the maximum number of OSPF ECMP routes is 8.
A router can run multiple routing protocols, and each protocol is assigned a preference. If multiple routes are available to the same destination, the one with the highest protocol preference is selected as the best route.
To configure OSPF preference:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure a preference for OSPF.
preference [ ase ] value
By default, the preference of OSPF internal routes is 10 and the preference of OSPF external routes is 150.
On a router running OSPF and other routing protocols, you can configure OSPF to redistribute routes from other protocols, such as RIP, IS-IS, BGP, static, and direct, and advertise them in Type-5 LSAs or Type-7 LSAs. In addition, you can configure OSPF to filter redistributed routes so that OSPF advertises only permitted routes.
IMPORTANT
IMPORTANT:
The import-route bgp command redistributes only EBGP routes. Because the import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes, and might cause routing loops, use it with caution.
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure OSPF to redistribute routes from another routing protocol.
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | nssa-only | tag tag | type type ] *
By default, no route redistribution is configured.
This command redistributes only active routes. To view information about active routes, use the display ip routing-table protocol command.
4.      (Optional.) Configure OSPF to filter redistributed routes.
filter-policy acl-number export [ protocol [ process-id ] ]
By default, OSPF accepts all redistributed routes.
The import-route command cannot redistribute a default external route. Perform this task to redistribute a default route.
To redistribute a default route:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Redistribute a default route.
default-route-advertise [ [ [ always | permit-calculate-other ] | cost cost | type type ] * | summary cost cost ]
By default, no default route is redistributed.
This command is applicable only to VPNs. The PE router advertises a default route in a Type-3 LSA to a CE router.
Perform this task to configure default parameters for redistributed routes, including cost, tag, and type. Tags indicate information about protocols. For example, when redistributing BGP routes, OSPF uses tags to identify AS IDs.
To configure the default parameters for redistributed routes:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure the default parameters for redistributed routes (cost, upper limit, tag, and type).
default { cost cost | tag tag | type type } *
By default, the cost is 1, the tag is 1, and the type is Type-2.
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enter area view.
area area-id
N/A
4.      Advertise a host route.
host-advertise ip-address cost
By default, no host route is advertised.
You can use one of the following methods to optimize an OSPF network:
·           Change OSPF packet timers to adjust the convergence speed and network load. On low-speed links, consider the delay time for sending LSAs.
·           Change the SPF calculation interval to reduce resource consumption caused by frequent network changes.
·           Configure OSPF authentication to improve security.
Before you configure OSPF network optimization, complete the following tasks:
·           Enable OSPF.
An OSPF interface includes the following timers:
·           Hello timerInterval for sending hello packets. It must be identical on OSPF neighbors.
·           Poll timerInterval for sending hello packets to a neighbor that is down on the NBMA network.
·           Dead timerInterval within which if the interface does not receive any hello packet from the neighbor, it declares the neighbor is down.
·           LSA retransmission timerInterval within which if the interface does not receive any acknowledgment packets after sending an LSA to the neighbor, it retransmits the LSA.
To configure OSPF timers:
Step
Remarks
N/A
N/A
3.      Specify the hello interval.
ospf timer hello seconds
By default:
·          The hello interval on P2P and broadcast interfaces is 10 seconds.
·          The hello interval on P2MP and NBMA interfaces is 30 seconds.
The default hello interval is restored when the network type for an interface is changed.
4.      Specify the poll interval.
ospf timer poll seconds
The default setting is 120 seconds.
The poll interval is at least four times the hello interval.
5.      Specify the dead interval.
ospf timer dead seconds
By default:
·          The dead interval on P2P and broadcast interfaces is 40 seconds.
·          The dead interval on P2MP and NBMA interfaces is 120 seconds.
The dead interval must be at least four times the hello interval on an interface.
The default dead interval is restored when the network type for an interface is changed.
6.      Specify the retransmission interval.
ospf timer retransmit interval
The default setting is 5 seconds.
A retransmission interval setting that is too small can cause unnecessary LSA retransmissions. This interval is typically set bigger than the round-trip time of a packet between two neighbors.
To avoid LSAs from aging out during transmission, set an LSA retransmission delay especially for low speed links.
To specify the LSA transmission delay on an interface:
Step
Remarks
N/A
N/A
3.      Specify the LSA transmission delay.
ospf trans-delay seconds
The default setting is 1 second.
LSDB changes result in SPF calculations. When the topology changes frequently, a large amount of network and router resources are occupied by SPF calculation. You can adjust the SPF calculation interval to reduce the impact.
For a stable network, the minimum interval is used. If network changes become frequent, the SPF calculation interval is incremented by the incremental interval × 2n-2 for each calculation until the maximum interval is reached. The value n is the number of calculation times.
To configure the SPF calculation interval:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Specify the SPF calculation interval.
By default:
·          The maximum interval is 5 seconds.
·          The minimum interval is 50 milliseconds.
·          The incremental interval is 200 milliseconds.
If OSPF receives an LSA that has the same LSA type, LS ID, and router ID as the previously received LSA within the LSA arrival interval, OSPF discards the LSA to save bandwidth and route resources.
To configure the LSA arrival interval:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure the LSA arrival interval.
lsa-arrival-interval interval
The default setting is 1000 milliseconds.
Make sure this interval is smaller than or equal to the interval set with the lsa-generation-interval command.
Adjust the LSA generation interval to protect network resources and routers from being overwhelmed by LSAs at the time of frequent network changes.
For a stable network, the minimum interval is used. If network changes become frequent, the LSA generation interval is incremented by the incremental interval × 2n-2 for each generation until the maximum interval is reached. The value n is the number of generation times.
To configure the LSA generation interval:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure the LSA generation interval.
By default:
To enhance OSPF adaptability and reduce resource consumption, you can set an OSPF interface to "silent." A silent OSPF interface blocks OSPF packets and cannot establish any OSPF neighbor relationship. However, other interfaces on the router can still advertise direct routes of the interface in Router LSAs.
To disable interfaces from receiving and sending routing information:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Disable interfaces from receiving and sending OSPF packets.
By default, an OSPF interface can receive and send OSPF packets.
The silent-interface command disables only the interfaces associated with the current process rather than other processes. Multiple OSPF processes can disable the same interface from receiving and sending OSPF packets.
A stub router is used for traffic control. It reports its status as a stub router to neighboring OSPF routers. The neighboring routers can have a route to the stub router, but they do not use the stub router to forward data.
Router LSAs from the stub router might contain different link type values. A value of 3 means a link to a stub network, and the cost of the link will not be changed by default. To set the cost of the link to 65535, specify the include-stub keyword in the stub-router command. A value of 1, 2 or 4 means a point-to-point link, a link to a transit network, or a virtual link. On such links, a maximum cost value of 65535 is used. Neighbors do not send packets to the stub router as long as they have a route with a smaller cost.
To configure a router as a stub router:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure the router as a stub router.
stub-router [ external-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } | summary-lsa [ max-metric-value ] ] *
By default, the router is not configured as a stub router.
A stub router is not related to a stub area.
Perform this task to configure OSPF area and interface authentication.
OSPF adds the configured password into sent packets, and uses the password to authenticate received packets. Only packets that pass the authentication can be received. If a packet fails the authentication, the OSPF neighbor relationship cannot be established.
If you configure OSPF authentication for both an area and an interface in that area, the interface uses the OSPF authentication configured on it.
Configuring OSPF area authentication
You must configure the same authentication mode and password on all the routers in an area.
To configure OSPF area authentication:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enter area view.
area area-id
N/A
4.      Configure area authentication mode.
·          Configure MD5 authentication:
authentication-mode { hmac-md5 | md5 } key-id { cipher | plain } password
·          Configure simple authentication:
authentication-mode simple { cipher | plain } password
By default, no authentication is configured.
Configuring OSPF interface authentication
You must configure the same authentication mode and password on both the local interface and its peer interface.
To configure OSPF interface authentication:
Step
Remarks
N/A
N/A
3.      Configure interface authentication mode.
ospf authentication-mode simple { cipher cipher-string | plain plain-string }
ospf authentication-mode { hmac-md5 | md5 } key-id { cipher cipher-string | plain plain-string }
By default, an OSPF interface adds a value of 0 into the interface MTU field of a DD packet rather than the actual interface MTU. You can enable an interface to add its MTU into DD packets.
To add the interface MTU into DD packets:
Step
Remarks
N/A
N/A
3.      Enable the interface to add its MTU into DD packets.
ospf mtu-enable
By default, the interface adds an MTU value of 0 into DD packets.
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure a DSCP value for OSPF packets.
dscp dscp-value
By default, the DSCP value for OSPF packets is 48.
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Specify the maximum number of external LSAs in the LSDB.
lsdb-overflow-limit number
By default, the maximum number of external LSAs in the LSDB is not limited.
When the number of LSAs in the LSDB exceeds the upper limit, the LSDB is in an overflow state. To save resources, OSPF does not receive any external LSAs and deletes the external LSAs generated by itself when in this state.
Perform this task to configure the interval that OSPF exits overflow state.
To configure the OSPF exit overflow interval:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure the OSPF exit overflow interval.
The default setting is 300 seconds.
The value of 0 indicates that OSPF does not exit overflow state.
RFC 1583 specifies a different method than RFC 2328 for selecting the optimal route to a destination in another AS. When multiple routes are available to the ASBR, OSPF selects the optimal route by using the following procedure:
1.      Selects the route with the highest preference.
¡  If RFC 2328 is compatible with RFC 1583, all these routes have equal preference.
¡  If RFC 2328 is not compatible with RFC 1583, the intra-area route in a non-backbone area is preferred to reduce the burden of the backbone area. The inter-area route and intra-area route in the backbone area have equal preference.
2.      Selects the route with lower cost if two routes have equal preference.
3.      Selects the route with larger originating area ID if two routes have equal cost.
To avoid routing loops, set identical RFC 1583-compatibility on all routers in a routing domain.
To enable compatibility with RFC 1583:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enable compatibility with RFC 1583.
rfc1583 compatible
By default, this feature is enabled.
Perform this task to enable output of neighbor state change logs to the information center. The information center processes the logs according to user-defined output rules (whether and where to output logs). For more information about the information center, see Network Management and Monitoring Configuration Guide.
To enable the logging of neighbor state changes:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enable the logging of neighbor state changes.
log-peer-change
This task involves the following configurations:
·           Bind an OSPF process to MIB so that you can use network management software to manage the specified OSPF process.
·           Enable SNMP notifications for OSPF to report important events.
·           Configure the maximum number of output SNMP notifications within a specified time interval.
SNMP notifications are sent to the SNMP module, which outputs SNMP notifications according to the configured output rules. For more information about SNMP notifications, see Network Management and Monitoring Configuration Guide.
To configure OSPF network management:
Step
Remarks
N/A
2.      Bind OSPF MIB to an OSPF process.
ospf mib-binding process-id
By default, OSPF MIB is bound to the process with the smallest process ID.
3.      Enable SNMP notifications for OSPF.
snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | grhelper-status-change | grrestarter-status-change | if-state-change | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
By default, SNMP notifications for OSPF is enabled.
4.      Enter OSPF view.
N/A
5.      Configure the maximum number of output SNMP notifications within a specified time interval.
By default, OSPF outputs a maximum of seven SNMP notifications within 10 seconds.
Sending large numbers of LSU packets affects router performance and consumes too much network bandwidth. You can configure the router to send LSU packets at a proper interval and limit the maximum number of LSU packets sent out of an OSPF interface each time.
To configure the LSU transmit rate:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure the LSU transmit rate.
By default, an OSPF interface sends a maximum of three LSU packets every 20 milliseconds.
Enabling OSPF ISPF
When the topology changes, Incremental Shortest Path First (ISPF) computes only the affected part of the SPT, instead of the entire SPT.
To enable OSPF ISPF:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enable OSPF ISPF.
ispf enable
By default, OSPF ISPF is enabled.
By default, an OSPF interface advertises all of its prefixes in LSAs. To speed up OSPF convergence, you can suppress interfaces from advertising all of their prefixes. This function helps improve network security by preventing IP routing to the suppressed networks.
When prefix suppression is enabled:
·           On P2P and P2MP networks, OSPF does not advertise Type-3 links in Type-1 LSAs. Other routing information can still be advertised to ensure traffic forwarding.
·           On broadcast and NBMA networks, the DR generates Type-2 LSAs with a mask length of 32 to suppress network routes. Other routing information can still be advertised to ensure traffic forwarding. If no neighbors exist, the DR does not advertise the primary IP addresses of interfaces in Type-1 LSAs.
IMPORTANT
IMPORTANT:
As a best practice, configure prefix suppression on all OSPF routers if you want to use prefix suppression.
Configuring prefix suppression for an OSPF process
Enabling prefix suppression for an OSPF process does not suppress the prefixes of secondary IP addresses, loopback interfaces, and passive interfaces. To suppress the prefixes of loopback and passive interfaces, enable prefix suppression on the interfaces.
To configure prefix suppression for an OSPF process:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enable prefix suppression for the OSPF process.
prefix-suppression
By default, prefix suppression is disabled for an OSPF process.
Configuring prefix suppression for an interface
Interface prefix suppression does not suppress prefixes of secondary IP addresses.
To configure interface prefix suppression:
Step
Remarks
N/A
N/A
3.      Enable prefix suppression for the interface.
By default, prefix suppression is disabled on an interface.
Prefix Independent Convergence (PIC) enables the device to speed up network convergence by ignoring the number of prefixes.
When both OSPF PIC and OSPF FRR are configured, OSPF FRR takes effect.
OSPF PIC applies only to inter-area routes and external routes.
Enabling OSPF PIC
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Enable PIC for OSPF.
By default, OSPF PIC is enabled.
Configuring BFD for OSPF PIC
By default, OSPF PIC does not use BFD to detect primary link failures. To speed up OSPF convergence, enable BFD single-hop echo detection for OSPF PIC to detect the primary link failures.
To configure BFD for OSPF PIC:
Step
Remarks
N/A
2.      Configure the source IP address of BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address of BFD echo packets is not configured.
3.      Enter interface view.
N/A
4.      Enable BFD for OSPF PIC.
ospf primary-path-detect bfd echo
By default, BFD for OSPF PIC is disabled.
OSPF logs include route calculation logs and neighbor logs.
To configure the number of OSPF logs:
Step
Remarks
N/A
2.      Enter OSPF view.
N/A
3.      Configure the number of OSPF logs.
event-log { lsa-flush | peer | spf } size count
By default, the number of both route calculation logs and neighbor logs is 10.
Configuring OSPF GR
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process:
·           GR restarter—Graceful restarting router. It must have GR capability.
·           GR helper—A neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
OSPF GR has the following types:
·           IETF GR—Uses Opaque LSAs to implement GR.
·           Non-IETF GR—Uses link local signaling (LLS) to advertise GR capability and uses out of band synchronization to synchronize the LSDB.
A device can act as a GR restarter and GR helper at the same time.
You can configure the IETF or non-IETF OSPF GR restarter.
IMPORTANT
IMPORTANT:
You cannot enable OSPF NSR on a device that acts as GR restarter.
Configuring the IETF OSPF GR restarter
Step
Remarks
N/A
2.      Enable OSPF and enter its view.
N/A
3.      Enable opaque LSA reception and advertisement capability.
opaque-capability enable
By default, opaque LSA reception and advertisement capability is enabled.
4.      Enable the IETF GR.
graceful-restart ietf [ global | planned-only ] *
By default, the IETF GR capability is disabled.
5.      (Optional.) Configure the GR interval.
graceful-restart interval interval-value
By default, the GR interval is 120 seconds.
Configuring the non-IETF OSPF GR restarter
Step
Remarks
N/A
N/A
3.      Enable the link-local signaling capability.
enable link-local-signaling
By default, the link-local signaling capability is disabled.
4.      Enable the out-of-band re-synchronization capability.
enable out-of-band-resynchronization
By default, the out-of-band re-synchronization capability is disabled.
5.      Enable non-IETF GR.
graceful-restart [ nonstandard ] [ global | planned-only ] *
By default, non-IETF GR capability is disabled.
6.      (Optional.) Configure the GR interval.
You can configure the IETF or non-IETF OSPF GR helper.
Configuring the IETF OSPF GR helper
Step
Remarks
N/A
N/A
4.      (Optional.) Enable GR helper capability.
By default, GR helper capability is enabled.
5.      (Optional.) Enable strict LSA checking for the GR helper.
graceful-restart helper strict-lsa-checking
By default, strict LSA checking for the GR helper is disabled.
Configuring the non-IETF OSPF GR helper
Step
Remarks
N/A
N/A
5.      (Optional.) Enable GR helper.
By default, GR helper is enabled.
6.      (Optional.) Enable strict LSA checking for the GR helper.
Triggering OSPF GR
OSPF GR is triggered by an active/standby switchover or when the following command is executed.
To trigger OSPF GR, perform the following command in user view:
Trigger OSPF GR.
reset ospf [ process-id ] process graceful-restart
Nonstop routing (NSR) backs up OSPF link state information from the active process to the standby process. After an active/standby switchover, NSR can complete link state recovery and route regeneration without tearing down adjacencies or impacting forwarding services.
NSR does not require the cooperation of neighboring devices to recover routing information, and is used more often than GR.
IMPORTANT
IMPORTANT:
A device that has OSPF NSR enabled cannot act as GR restarter.
To enable OSPF NSR:
Step
Remarks
N/A
2.      Enter OSPF view.
ospf [process-id | router-id router-id | vpn-instance vpn-instance-name ] *
N/A
3.      Enable OSPF NSR.
non-stop-routing
By default, OSPF NSR is disabled.
BFD provides a single mechanism to quickly detect and monitor the connectivity of links between OSPF neighbors, which improves the network convergence speed. For more information about BFD, see High Availability Configuration Guide.
OSPF supports the following BFD detection modes:
·           Bidirectional control detection—Requires BFD configuration to be made on both OSPF routers on the link.
·           Single-hop echo detection—Requires BFD configuration to be made on one OSPF router on the link.
Step
Remarks
N/A
N/A
3.      Enable BFD bidirectional control detection.
ospf bfd enable
By default, BFD bidirectional control detection is disabled.
Both ends of a BFD session must be on the same network segment and in the same area.
Step
Remarks
N/A
2.      Configure the source address of echo packets.
By default, the source address of echo packets is not configured.
N/A
4.      Enable BFD single-hop echo detection.
ospf bfd enable echo
By default, BFD single-hop echo detection is disabled.
A link or router failure on a path can cause packet loss and even routing loop until OSPF completes routing convergence based on the new network topology. FRR uses BFD to detect failures and enables fast rerouting to minimize the impact of link or node failures.
Figure 7 Network diagram for OSPF FRR
As shown in Figure 7, configure OSPF FRR on Router B to use the LFA algorithm to calculate a backup next hop. When the primary link fails, OSPF directs packets to the backup next hop. At the same time, OSPF calculates the shortest path based on the new network topology. It forwards packets over the path after network convergence.
You can configure OSPF FRR to calculate a backup next hop by using the loop free alternate (LFA) algorithm.
Before you configure OSPF FRR, complete the following tasks:
·           Enable OSPF.
·           Do not use FRR and BFD at the same time. Otherwise, FRR might fail to take effect.
·           Do not use the fast-reroute lfa command together with the vlink-peer command.
·           When both OSPF PIC and OSPF FRR are configured, OSPF FRR takes effect.
Step
Remarks
N/A
N/A
4.      Enable LFA calculation on an interface.
ospf fast-reroute lfa-backup
By default, the interface on which LFA calculation is enabled can be selected as a backup interface.
N/A
6.      Enter OSPF view.
N/A
7.      Enable OSPF FRR to calculate a backup next hop by using the LFA algorithm.
fast-reroute lfa [ abr-only ]
By default, OSPF FRR is not configured.
If abr-only is specified, the route to the ABR is selected as the backup path.
Configuring BFD for OSPF FRR
By default, OSPF FRR does not use BFD to detect primary link failures. To speed up OSPF convergence, enable BFD single-hop echo detection for OSPF FRR to detect primary link failures.
To configure BFD for OSPF FRR:
Step
Remarks
N/A
N/A
4.      Enable BFD for OSPF FRR.
By default, BFD for OSPF FRR is disabled.
Display OSPF process information.
display ospf [ process-id ] [ verbose ] [ standby slot slot-number ]
Display OSPF GR information.
Display OSPF FRR backup next hop information.
Display OSPF LSDB information.
display ospf [ process-id ] lsdb [ area area-id | brief | [ { asbr | ase | network | nssa | opaque-area | opaque-as | opaque-link | router | summary } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ] [ standby slot slot-number ]
Display OSPF next hop information.
Display OSPF neighbor information.
display ospf [ process-id ] peer [ verbose ] [ interface-type interface-number ] [ neighbor-id ]
Display neighbor statistics for OSPF areas.
Display OSPF routing table information.
display ospf [ process-id ] routing [ ip-address { mask-length | mask } ] [ interface interface-type interface-number ] [ nexthop nexthop-address ] [ verbose ]
Display OSPF topology information.
Display OSPF statistics.
display ospf [ process-id ] statistics [ error | packet [ interface-type interface-number ] ]
Display OSPF virtual link information.
Display OSPF request queue information.
Display OSPF retransmission queue information.
Display OSPF ABR and ASBR information.
Display summary route information on the OSPF ABR.
Display OSPF interface information.
display ospf [ process-id ] interface [ interface-type interface-number | verbose ]
Display OSPF route calculation log information.
display ospf [ process-id ] event-log { lsa-flush | peer | spf }
Display OSPF ASBR route summarization information.
Display the global route ID.
display router id
Clear OSPF statistics.
Clear OSPF log information.
reset ospf [ process-id ] event-log [ lsa-flush | peer | spf ]
Reset an OSPF process.
Re-enable OSPF route redistribution.
These configuration examples only cover commands for OSPF configuration.
Network requirements
As shown in Figure 8:
·           Enable OSPF on all switches, and split the AS into three areas.
·           Configure Switch A and Switch B as ABRs.
Figure 8 Network diagram
Configuration procedure
1.      Configure IP addresses for interfaces. (Details not shown.)
2.      Enable OSPF:
# Configure Switch A.
[SwitchA] router id 10.2.1.1
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1] area 1
[SwitchA-ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.1] quit
[SwitchA-ospf-1] quit
# Configure Switch B.
[SwitchB] router id 10.3.1.1
[SwitchB] ospf
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1] area 2
[SwitchB-ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.2] quit
[SwitchB-ospf-1] quit
# Configure Switch C.
[SwitchC] router id 10.4.1.1
[SwitchC] ospf
[SwitchC-ospf-1] area 1
[SwitchC-ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.1] network 10.4.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.1] quit
[SwitchC-ospf-1] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] router id 10.5.1.1
[SwitchD] ospf
[SwitchD-ospf-1] area 2
[SwitchD-ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.2] network 10.5.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.2] quit
[SwitchD-ospf-1] quit
# Display information about neighbors on Switch A.
[SwitchA] display ospf peer verbose
          OSPF Process 1 with Router ID 10.2.1.1
                  Neighbors
 Area 0.0.0.0 interface 10.1.1.1(Vlan-interface100)'s neighbors
 Router ID: 10.3.1.1         Address: 10.1.1.2         GR State: Normal
   State: Full  Mode: Nbr is Master  Priority: 1
   DR: 10.1.1.1  BDR: 10.1.1.2  MTU: 0
   Dead timer due in 37  sec
   Neighbor is up for 06:03:59
   Neighbor state change count: 5
   BFD status: Disabled
 Area 0.0.0.1 interface 10.2.1.1(Vlan-interface200)'s neighbors
 Router ID: 10.4.1.1         Address: 10.2.1.2         GR State: Normal
   DR: 10.2.1.1  BDR: 10.2.1.2  MTU: 0
   Dead timer due in 32  sec
   Neighbor is up for 06:03:12
# Display OSPF routing information on Switch A.
[SwitchA] display ospf routing
                   Routing Tables
 Routing for Network
 10.2.1.0/24        1        Transit 10.2.1.1        10.2.1.1        0.0.0.1
 10.3.1.0/24        2        Inter   10.1.1.2        10.3.1.1        0.0.0.0
 10.4.1.0/24        2        Stub    10.2.1.2        10.4.1.1        0.0.0.1
 10.5.1.0/24        3        Inter   10.1.1.2        10.3.1.1        0.0.0.0
 10.1.1.0/24        1        Transit 10.1.1.1        10.2.1.1        0.0.0.0
 Total Nets: 5
 Intra Area: 3  Inter Area: 2  ASE: 0  NSSA: 0
# Display OSPF routing information on Switch D.
[SwitchD] display ospf routing
          OSPF Process 1 with Router ID 10.5.1.1
                   Routing Tables
 Routing for Network
 10.2.1.0/24        3        Inter   10.3.1.1        10.3.1.1        0.0.0.2
 10.3.1.0/24        1        Transit 10.3.1.2        10.3.1.1        0.0.0.2
 10.4.1.0/24        4        Inter   10.3.1.1        10.3.1.1        0.0.0.2
 10.5.1.0/24        1        Stub    10.5.1.1        10.5.1.1        0.0.0.2
 10.1.1.0/24        2        Inter   10.3.1.1        10.3.1.1        0.0.0.2
 Total Nets: 5
 Intra Area: 2  Inter Area: 3  ASE: 0  NSSA: 0
# On Switch D, ping the IP address 10.4.1.1 to test reachability.
[SwitchD] ping 10.4.1.1
Ping 10.4.1.1 (10.4.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.4.1.1: icmp_seq=0 ttl=253 time=1.549 ms
56 bytes from 10.4.1.1: icmp_seq=1 ttl=253 time=1.539 ms
56 bytes from 10.4.1.1: icmp_seq=2 ttl=253 time=0.779 ms
56 bytes from 10.4.1.1: icmp_seq=3 ttl=253 time=1.702 ms
56 bytes from 10.4.1.1: icmp_seq=4 ttl=253 time=1.471 ms
--- Ping statistics for 10.4.1.1 ---
round-trip min/avg/max/std-dev = 0.779/1.408/1.702/0.323 ms
OSPF route redistribution configuration example
As shown in Figure 9:
·           Enable OSPF on all the switches.
·           Split the AS into three areas.
·           Configure Switch C as an ASBR to redistribute external routes (static routes).
Figure 9 Network diagram
2.      Enable OSPF (see "Basic OSPF configuration example").
3.      Configure OSPF to redistribute routes:
# On Switch C, configure a static route destined for network 3.1.2.0/24.
[SwitchC] ip route-static 3.1.2.1 24 10.4.1.2
# On Switch C, configure OSPF to redistribute static routes.
[SwitchC] ospf 1
[SwitchC-ospf-1] import-route static
# Display the ABR/ASBR information of Switch D.
<SwitchD> display ospf abr-asbr
                  Routing Table to ABR and ASBR
 Type        Destination     Area            Cost  Nexthop         RtType
 Intra       10.3.1.1        0.0.0.2         10    10.3.1.1        ABR
 Inter       10.4.1.1        0.0.0.2         22    10.3.1.1        ASBR
# Display the OSPF routing table on Switch D.
<SwitchD> display ospf routing
                   Routing Tables
 Routing for Network
 10.2.1.0/24        22       Inter   10.3.1.1        10.3.1.1        0.0.0.2
 10.3.1.0/24        10       Transit 10.3.1.2        10.3.1.1        0.0.0.2
 10.4.1.0/24        25       Inter   10.3.1.1        10.3.1.1        0.0.0.2
 10.5.1.0/24        10       Stub    10.5.1.1        10.5.1.1        0.0.0.2
 10.1.1.0/24        12       Inter   10.3.1.1        10.3.1.1        0.0.0.2
 Routing for ASEs
 Destination        Cost     Type    Tag         NextHop         AdvRouter
 3.1.2.0/24         1        Type2   1           10.3.1.1        10.4.1.1
 Total Nets: 6
 Intra Area: 2  Inter Area: 3  ASE: 1  NSSA: 0
OSPF route summarization configuration example
As shown in Figure 10:
·           Configure OSPF on Switch A and Switch B in AS 200.
·           Configure OSPF on Switch C, Switch D, and Switch E in AS 100.
·           Configure an EBGP connection between Switch B and Switch C. Configure Switch B and Switch C to redistribute OSPF routes and direct routes into BGP and BGP routes into OSPF.
·           Configure Switch B to advertise only summary route 10.0.0.0/8 to Switch A.
Figure 10 Network diagram
2.      Enable OSPF:
[SwitchA] router id 11.2.1.2
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[SwitchB] router id 11.2.1.1
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[SwitchC] router id 11.1.1.2
[SwitchC] ospf
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[SwitchD] router id 10.3.1.1
[SwitchD] ospf
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 10.3.1.0 0.0.0.255
# Configure Switch E.
<SwitchE> system-view
[SwitchE] router id 10.4.1.1
[SwitchE] ospf
[SwitchE-ospf-1] area 0
[SwitchE-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] network 10.4.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] quit
[SwitchE-ospf-1] quit
3.      Configure BGP to redistribute OSPF routes and direct routes:
[SwitchB] bgp 200
[SwitchB-bgp] peer 11.1.1.2 as 100
[SwitchB-bgp] address-family ipv4 unicast
[SwitchB-bgp-ipv4] import-route ospf
[SwitchB-bgp-ipv4] import-route direct
[SwitchB-bgp ipv4] quit
[SwitchB-bgp] quit
[SwitchC] bgp 100
[SwitchC-bgp] peer 11.1.1.1 as 200
[SwitchC-bgp] address-family ipv4 unicast
[SwitchC-bgp-ipv4] import-route ospf
[SwitchC-bgp-ipv4]import-route direct
[SwitchC-bgp-ipv4] quit
[SwitchC-bgp] quit
4.      Configure Switch B and Switch C to redistribute BGP routes into OSPF:
# Configure OSPF to redistribute routes from BGP on Switch B.
[SwitchB] ospf
# Configure OSPF to redistribute routes from BGP on Switch C.
[SwitchC] ospf
[SwitchC-ospf-1] import-route bgp
# Display the OSPF routing table on Switch A.
         Destinations : 16        Routes : 16
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
10.1.1.0/24         OSPF   150  1            11.2.1.1        Vlan100
10.2.1.0/24         OSPF   150  1            11.2.1.1        Vlan100
10.3.1.0/24         OSPF   150  1            11.2.1.1        Vlan100
10.4.1.0/24         OSPF   150  1            11.2.1.1        Vlan100
11.2.1.0/24         Direct 0    0            11.2.1.2        Vlan100
11.2.1.0/32         Direct 0    0            11.2.1.2        Vlan100
11.2.1.2/32         Direct 0    0            127.0.0.1       InLoop0
11.2.1.255/32       Direct 0    0            11.2.1.2        Vlan100
127.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
5.      Configure route summarization:
# Configure route summarization on Switch B to advertise a summary route 10.0.0.0/8.
[SwitchB-ospf-1] asbr-summary 10.0.0.0 8
# Display the IP routing table on Switch A.
         Destinations : 13        Routes : 13
10.0.0.0/8          OSPF   150  2            11.2.1.1        Vlan100
The output shows that routes 10.1.1.0/24, 10.2.1.0/24, 10.3.1.0/24 and 10.4.1.0/24 are summarized into a single route 10.0.0.0/8.
OSPF stub area configuration example
As shown in Figure 11:
·           Configure Switch A and Switch B as ABRs to forward routing information between areas.
·           Configure Switch D as the ASBR to redistribute static routes.
·           Configure Area 1 as a stub area to reduce advertised LSAs without influencing reachability.
Figure 11 Network diagram
3.      Configure route redistribution:
# Configure Switch D to redistribute static routes.
[SwitchD] ip route-static 3.1.2.1 24 10.5.1.2
[SwitchD] ospf
[SwitchD-ospf-1] import-route static
# Display ABR/ASBR information on Switch C.
<SwitchC> display ospf abr-asbr
          OSPF Process 1 with Router ID 10.4.1.1
 Intra       10.2.1.1        0.0.0.1         3     10.2.1.1        ABR
 Inter       10.5.1.1        0.0.0.1         7     10.2.1.1        ASBR
# Display OSPF routing table on Switch C.
<SwitchC> display ospf routing
                   Routing Tables
 Routing for Network
 10.2.1.0/24        3        Transit 10.2.1.2        10.2.1.1        0.0.0.1
 10.3.1.0/24        7        Inter   10.2.1.1        10.2.1.1        0.0.0.1
 10.4.1.0/24        3        Stub    10.4.1.1        10.4.1.1        0.0.0.1
 10.5.1.0/24        17       Inter   10.2.1.1        10.2.1.1        0.0.0.1
 10.1.1.0/24        5        Inter   10.2.1.1        10.2.1.1        0.0.0.1
 Routing for ASEs
 3.1.2.0/24         1        Type2   1           10.2.1.1        10.5.1.1
 Total Nets: 6
The output shows that Switch C's routing table contains an AS external route.
4.      Configure Area 1 as a stub area:
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.1] stub
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.1] stub
# Display OSPF routing information on Switch C
                   Routing Tables
 Routing for Network
 0.0.0.0/0          4        Inter   10.2.1.1        10.2.1.1        0.0.0.1
 Total Nets: 6
 Intra Area: 2  Inter Area: 4  ASE: 0  NSSA: 0
The output shows that a default route replaces the AS external route.
# Configure Area 1 as a totally stub area.
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.1] stub no-summary
# Display OSPF routing information on Switch C.
                   Routing Tables
 Routing for Network
 10.2.1.0/24        3        Transit 10.2.1.2        10.4.1.1        0.0.0.1
 Total Nets: 3
 Intra Area: 2  Inter Area: 1  ASE: 0  NSSA: 0
The output shows that inter-area routes are removed, and only one external route (a default route) exists on Switch C.
OSPF NSSA area configuration example
As shown in Figure 12:
·           Configure OSPF on all switches and split AS into three areas.
·           Configure Area 1 as an NSSA area and configure Switch C as an ASBR to redistribute static routes into the AS.
Figure 12 Network diagram
3.      Configure Area 1 as an NSSA area:
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.1] nssa
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.1] nssa
                   Routing Tables
 Routing for Network
 Total Nets: 5
4.      Configure route redistribution:
# Configure Switch C to redistribute static routes.
[SwitchC] ip route-static 3.1.3.1 24 10.4.1.2
[SwitchC] ospf
                   Routing Tables
 Routing for Network
 Routing for ASEs
 3.1.3.0/24         1        Type2   1           10.3.1.1        10.2.1.1
 Total Nets: 6
The output shows that an external route imported from the NSSA area exists on Switch D.
OSPF DR election configuration example
As shown in Figure 13:
·           Enable OSPF on Switches A, B, C, and D on the same network.
·           Configure Switch A as the DR, and configure Switch C as the BDR.
Figure 13 Network diagram
2.      Enable OSPF:
[SwitchA] router id 1.1.1.1
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchB] router id 2.2.2.2
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchC] router id 3.3.3.3
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchD] router id 4.4.4.4
[SwitchD] ospf
[SwitchD-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchD-ospf-1] return
# Display OSPF neighbor information of Switch A.
                  Neighbors
 Area 0.0.0.0 interface 192.168.1.1(Vlan-interface1)'s neighbors
 Router ID: 2.2.2.2          Address: 192.168.1.2      GR State: Normal
   State: 2-Way  Mode: None  Priority: 1
   DR: 192.168.1.4  BDR: 192.168.1.3  MTU: 0
   Dead timer due in 38  sec
   Neighbor is up for 00:01:31
 Router ID: 3.3.3.3          Address: 192.168.1.3      GR State: Normal
   Dead timer due in 31  sec
   Neighbor is up for 00:01:28
 Router ID: 4.4.4.4          Address: 192.168.1.4      GR State: Normal
The output shows that Switch D is the DR and Switch C is the BDR.
3.      Configure router priorities on interfaces:
[SwitchA-Vlan-interface1] ospf dr-priority 100
[SwitchB] interface vlan-interface 1
[SwitchB-Vlan-interface1] ospf dr-priority 0
[SwitchB-Vlan-interface1] quit
[SwitchC] interface vlan-interface 1
[SwitchC-Vlan-interface1] ospf dr-priority 2
[SwitchC-Vlan-interface1] quit
# Display neighbor information of Switch D.
<SwitchD> display ospf peer verbose
          OSPF Process 1 with Router ID 4.4.4.4
                  Neighbors
 Area 0.0.0.0 interface 192.168.1.4(Vlan-interface1)'s neighbors
 Router ID: 1.1.1.1      Address: 192.168.1.1      GR State: Normal
   State: Full  Mode:Nbr is  Slave  Priority: 100
   Neighbor is up for 00:11:17
   State: Full  Mode:Nbr is  Slave  Priority: 0
   Dead timer due in 35  sec
   Neighbor is up for 00:11:19
   State: Full  Mode:Nbr is  Slave  Priority: 2
   Dead timer due in 33  sec
   Neighbor is up for 00:11:15
The output shows that the DR and BDR are not changed, because the priority settings do not take effect immediately.
4.      Restart OSPF process:
# Restart the OSPF process of Switch D.
<SwitchD> reset ospf 1 process
Warning : Reset OSPF process? [Y/N]:y
                  Neighbors
   State: Full  Mode: Nbr is Slave  Priority: 100
   DR: 192.168.1.1  BDR: 192.168.1.3  MTU: 0
   Dead timer due in 39  sec
   Neighbor is up for 00:01:40
   State: 2-Way  Mode: None  Priority: 0
   Neighbor is up for 00:01:44
   State: Full  Mode: Nbr is Slave  Priority: 2
   Neighbor is up for 00:01:41
If the neighbor state is full, Switch D has established an adjacency with the neighbor. If the neighbor state is 2-way, the two switches are not the DR or the BDR, and they do not exchange LSAs.
# Display OSPF interface information.
[SwitchA] display ospf interface
                  Interfaces
 Area: 0.0.0.0
 IP Address      Type      State   Cost  Pri   DR             BDR
 192.168.1.1     Broadcast DR      1     100   192.168.1.1    192.168.1.3
[SwitchB] display ospf interface
                  Interfaces
 Area: 0.0.0.0
 192.168.1.2     Broadcast DROther  1     0     192.168.1.1   192.168.1.3
The interface state DROther means the interface is not the DR or BDR.
OSPF virtual link configuration example
As shown in Figure 14, configure a virtual link between Switch B and Switch C to connect Area 2 to the backbone area. After configuration, Switch B can learn routes to Area 2.
Figure 14 Network diagram
2.      Enable OSPF:
[SwitchA] ospf 1 router-id 1.1.1.1
[SwitchB] ospf 1 router-id 2.2.2.2
[SwitchB-ospf-1] area 1
[SwitchB–ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[SwitchB–ospf-1-area-0.0.0.1] quit
[SwitchC] ospf 1 router-id 3.3.3.3
[SwitchC-ospf-1] area 2
[SwitchC–ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[SwitchC–ospf-1-area-0.0.0.2] quit
[SwitchD] ospf 1 router-id 4.4.4.4
# Display the OSPF routing table on Switch B.
[SwitchB] display ospf routing
                   Routing Tables
 Routing for Network
 10.2.1.0/24        2        Transit 10.2.1.1        3.3.3.3         0.0.0.1
 10.1.1.0/24        2        Transit 10.1.1.2        2.2.2.2         0.0.0.0
 Total Nets: 2
 Intra Area: 2  Inter Area: 0  ASE: 0  NSSA: 0
Area 0 has no direct connection to Area 2, so the routing table of Switch B has no route to Area 2.
3.      Configure a virtual link:
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.1] vlink-peer 3.3.3.3
[SwitchB-ospf-1-area-0.0.0.1] quit
[SwitchC] ospf 1
[SwitchC-ospf-1-area-0.0.0.1] vlink-peer 2.2.2.2
                   Routing Tables
 Routing for Network
 10.3.1.0/24        5        Inter   10.2.1.2        3.3.3.3         0.0.0.0
 Total Nets: 3
The output shows that Switch B has learned the route 10.3.1.0/24 to Area 2.
OSPF GR configuration example
As shown in Figure 15:
·           Switch A, Switch B, and Switch C that belong to the same AS and the same OSPF routing domain are GR capable.
·           Switch A acts as the non-IETF GR restarter. Switch B and Switch C are the GR helpers, and synchronize their LSDBs with Switch A through OOB communication of GR.
Figure 15 Network diagram
2.      Enable OSPF:
[SwitchA] ospf 100
[SwitchA-ospf-100] area 0
[SwitchA-ospf-100-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[SwitchA-ospf-100-area-0.0.0.0] quit
[SwitchB] ospf 100
[SwitchB-ospf-100] area 0
[SwitchB-ospf-100-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[SwitchB-ospf-100-area-0.0.0.0] quit
[SwitchC] ospf 100
[SwitchC-ospf-100] area 0
[SwitchC-ospf-100-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[SwitchC-ospf-100-area-0.0.0.0] quit
3.      Configure OSPF GR:
# Configure Switch A as the non-IETF OSPF GR restarter: enable the link-local signaling capability, the out-of-band re-synchronization capability, and non-IETF GR capability for OSPF process 100.
[SwitchA-ospf-100] enable link-local-signaling
[SwitchA-ospf-100] enable out-of-band-resynchronization
[SwitchA-ospf-100] graceful-restart
[SwitchA-ospf-100] return
# Configure Switch B as the GR helper: enable the link-local signaling capability and the out-of-band re-synchronization capability for OSPF process 100.
[SwitchB-ospf-100] enable link-local-signaling
[SwitchB-ospf-100] enable out-of-band-resynchronization
# Configure Switch C as the GR helper: enable the link-local signaling capability and the out-of-band re-synchronization capability for OSPF process 100.
[SwitchC-ospf-100] enable link-local-signaling
[SwitchC-ospf-100] enable out-of-band-resynchronization
# Enable OSPF GR event debugging and restart the OSPF process by using GR on Switch A.
<SwitchA> debugging ospf event graceful-restart
<SwitchA> terminal monitor
<SwitchA> terminal logging level 7
<SwitchA> reset ospf 100 process graceful-restart
%Oct 21 15:29:28:727 2011 SwitchA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.2(Vlan-interface100) from Full to Down.
%Oct 21 15:29:28:729 2011 SwitchA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.3(Vlan-interface100) from Full to Down.
*Oct 21 15:29:28:735 2011 SwitchA OSPF/7/DEBUG:
OSPF 100 nonstandard GR Started for OSPF Router
OSPF 100 created GR wait timer,timeout interval is 40(s).
OSPF 100 created GR Interval timer,timeout interval is 120(s).
*Oct 21 15:29:28:758 2011 SwitchA OSPF/7/DEBUG:
OSPF 100 created OOB Progress timer for neighbor 192.1.1.3.
*Oct 21 15:29:28:766 2011 SwitchA OSPF/7/DEBUG:
OSPF 100 created OOB Progress timer for neighbor 192.1.1.2.
%Oct 21 15:29:29:902 2011 SwitchA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.2(Vlan-interface100) from Loading to Full.
*Oct 21 15:29:29:902 2011 SwitchA OSPF/7/DEBUG:
OSPF 100 deleted OOB Progress timer for neighbor 192.1.1.2.
%Oct 21 15:29:30:897 2011 SwitchA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.3(Vlan-interface100) from Loading to Full.
*Oct 21 15:29:30:897 2011 SwitchA OSPF/7/DEBUG:
OSPF 100 deleted OOB Progress timer for neighbor 192.1.1.3.
*Oct 21 15:29:30:911 2011 SwitchA OSPF/7/DEBUG:
OSPF GR: Process 100 Exit Restart,Reason : DR or BDR change,for neighbor : 192.1.1.3.
OSPF 100 deleted GR Interval timer.
*Oct 21 15:29:30:912 2011 SwitchA OSPF/7/DEBUG:
OSPF 100 deleted GR wait timer.
%Oct 21 15:29:30:920 2011 SwitchA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.2(Vlan-interface100) from Full to Down.
%Oct 21 15:29:30:921 2011 SwitchA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.3(Vlan-interface100) from Full to Down.
%Oct 21 15:29:33:815 2011 SwitchA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.3(Vlan-interface100) from Loading to Full.
%Oct 21 15:29:35:578 2011 SwitchA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.2(Vlan-interface100) from Loading to Full.
The output shows that Switch A completes GR.
OSPF NSR configuration example
As shown in Figure 16, Switch S, Switch A, and Switch B belong to the same OSPF routing domain. Enable OSPF NSR on Switch S to ensure correct routing when an active/standby switchover occurs on Switch S.
Figure 16 Network diagram
1.      Configure IP addresses and subnet masks for interfaces on the switches. (Details not shown.)
2.      Configure OSPF on the switches to ensure the following: (Details not shown.)
¡  Switch S, Switch A, and Switch B can communicate with each other at Layer 3.
¡  Dynamic route update can be implemented among them with OSPF.
3.      Enable OSPF NSR on Switch S.
<SwitchS> system-view
[SwitchS] ospf 100
[SwitchS-ospf-100] non-stop-routing
[SwitchS-ospf-100] quit
# Perform an active/standby switchover on Switch S.
[SwitchS] placement reoptimize
Program                           Current location       New location
lb                                0/0                    0/0
lsm                               0/0                    0/0
slsp                              0/0                    0/0
rib6                              0/0                    0/0
routepolicy                       0/0                    0/0
rib                               0/0                    0/0
staticroute6                      0/0                    0/0
staticroute                       0/0                    0/0
ospf                              0/0                    1/0
Continue? [y/n]:y
Re-optimization of the placement start. You will be notified on completion
Re-optimization of the placement complete. Use 'display placement' to view the new placement
# During the switchover period, display OSPF neighbors on Switch A to verify the neighbor relationship between Switch A and Switch S.
<SwitchA> display ospf peer
          OSPF Process 1 with Router ID 2.2.2.1
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  Interface         State
 3.3.3.1         12.12.12.2      1   37         Vlan100           Full/BDR
# Display OSPF routes on Switch A to verify if Switch A has a route to the loopback interface on Switch B.
<SwitchA> display ospf routing
                   Routing Tables
 Routing for Network
 44.44.44.44/32     2        Stub    12.12.12.2      4.4.4.1         0.0.0.0
 14.14.14.0/24      2        Transit 12.12.12.2      4.4.4.1         0.0.0.0
 22.22.22.22/32     0        Stub    22.22.22.22     2.2.2.1         0.0.0.0
 12.12.12.0/24      1        Transit 12.12.12.1      2.2.2.1         0.0.0.0
 Total Nets: 4
 Intra Area: 4  Inter Area: 0  ASE: 0  NSSA: 0
# Display OSPF neighbors on Switch B to verify the neighbor relationship between Switch B and Switch S.
<SwitchB> display ospf peer
          OSPF Process 1 with Router ID 4.4.4.1
 Area: 0.0.0.0
 3.3.3.1         14.14.14.2      1   39         Vlan100           Full/BDR
# Display OSPF routes on Switch B to verify if Switch B has a route to the loopback interface on Switch A.
<SwitchB> display ospf routing
                   Routing Tables
 Routing for Network
 44.44.44.44/32     0        Stub    44.44.44.44     4.4.4.1         0.0.0.0
 14.14.14.0/24      1        Transit 14.14.14.1      4.4.4.1         0.0.0.0
 22.22.22.22/32     2        Stub    14.14.14.2      2.2.2.1         0.0.0.0
 12.12.12.0/24      2        Transit 14.14.14.2      2.2.2.1         0.0.0.0
 Total Nets: 4
The output shows that when an active/standby switchover occurs on Switch S, the neighbor relationships and routing information on Switch A and Switch B have not changed, and the traffic from Switch A to Switch B has not been impacted.
BFD for OSPF configuration example
As shown in Figure 17, run OSPF on Switch A, Switch B, and Switch C so that they are reachable to each other at the network layer.
·           When the link over which Switch A and Switch B communicate through a Layer 2 switch fails, BFD can quickly detect the failure and notify OSPF of the failure.
·           Switch A and Switch B then communicate through Switch C.
Figure 17 Network diagram
Device
IP address
Switch A
Vlan-int10
192.168.0.102/24
Switch A
Vlan-int11
10.1.1.102/24
Switch A
Loop0
121.1.1.1/32
Switch B
Vlan-int10
192.168.0.100/24
Switch B
Vlan-int13
13.1.1.1/24
Switch B
Loop0
120.1.1.1/32
Switch C
Vlan-int11
10.1.1.100/24
Switch C
Vlan-int13
13.1.1.2/24
2.      Enable OSPF:
[SwitchA] ospf
[SwitchA-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[SwitchA-ospf-1-area-0.0.0.0] network 121.1.1.1 0.0.0.0
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[SwitchB-ospf-1-area-0.0.0.0] network 120.1.1.1 0.0.0.0
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
3.      Configure BFD:
# Enable BFD on Switch A and configure BFD parameters.
[SwitchA-Vlan-interface10] ospf bfd enable
[SwitchA-Vlan-interface10] bfd min-transmit-interval 500
[SwitchA-Vlan-interface10] bfd min-receive-interval 500
[SwitchA-Vlan-interface10] bfd detect-multiplier 7
[SwitchA] quit
# Enable BFD on Switch B and configure BFD parameters.
[SwitchB] bfd session init-mode active
[SwitchB-Vlan-interface10] ospf bfd enable
[SwitchB-Vlan-interface10] bfd min-transmit-interval 500
[SwitchB-Vlan-interface10] bfd min-receive-interval 500
[SwitchB-Vlan-interface10] bfd detect-multiplier 6
# Display the BFD information on Switch A.
<SwitchA> display bfd session
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 3/1            192.168.0.102   192.168.0.100   Up       1700ms      Vlan10
# Display routes destined for 120.1.1.1/32 on Switch A.
<SwitchA> display ip routing-table 120.1.1.0 verbose
Summary Count : 1
Destination: 120.1.1.0/24
   Protocol: OSPF            Process ID: 1
  SubProtID: 0x1                    Age: 04h20m37s
       Cost: 2               Preference: 10
        Tag: 0                    State: Active Adv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x26000002          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
      Flags: 0x1008c        OrigNextHop: 192.168.0.100
      Label: NULL           RealNextHop: 192.168.0.100
    BkLabel: NULL             BkNextHop: N/A
  Tunnel ID: Invalid          Interface: Vlan-interface10
BkTunnel ID: Invalid        BkInterface: N/A
The output shows that Switch A communicates with Switch B through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
Summary Count : 1
       Cost: 4               Preference: 10
      Flags: 0x1008c        OrigNextHop: 10.1.1.100
      Label: NULL           RealNextHop: 10.1.1.100
  Tunnel ID: Invalid          Interface: Vlan-interface11
The output shows that Switch A communicates with Switch B through VLAN-interface 11.
OSPF FRR configuration example
As shown in Figure 18, Switch A, Switch B, and Switch C reside in the same OSPF domain. Configure OSPF FRR so that when the link between Switch A and Switch B fails, traffic is immediately switched to Link B.
Figure 18 Network diagram
Device
IP address
Switch A
Vlan-int100
12.12.12.1/24
Switch A
Vlan-int200
13.13.13.1/24
Switch A
Loop0
1.1.1.1/32
Switch B
Vlan-int101
24.24.24.4/24
Switch B
Vlan-int200
13.13.13.2/24
Switch B
Loop0
4.4.4.4/32
Switch C
Vlan-int100
12.12.12.2/24
Switch C
Vlan-int101
24.24.24.2/24
2.      Configure OSPF on the switches to ensure that Switch A, Switch B, and Switch C can communicate with each other at the network layer. (Details not shown.)
3.      Configure OSPF FRR.
[SwitchA] bfd echo-source-ip 2.2.2.2
[SwitchA] ospf 1
[SwitchA-ospf-1] fast-reroute lfa
[SwitchB] bfd echo-source-ip 3.3.3.3
[SwitchB] ospf 1
[SwitchB-ospf-1] fast-reroute lfa
# Display route 4.4.4.4/32 on Switch A to view the backup next hop information.
[SwitchA] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
       Cost: 1               Preference: 10
      NBRID: 0x26000002          LastAs: 0
      Flags: 0x1008c        OrigNextHop: 13.13.13.2
      Label: NULL           RealNextHop: 13.13.13.2
    BkLabel: NULL             BkNextHop: 12.12.12.2
  Tunnel ID: Invalid          Interface: Vlan-interface200
BkTunnel ID: Invalid        BkInterface: Vlan-interface100
# Display route 1.1.1.1/32 on Switch B to view the backup next hop information.
[SwitchB] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
Destination: 1.1.1.1/32
      Flags: 0x1008c        OrigNextHop: 13.13.13.1
      Label: NULL           RealNextHop: 13.13.13.1
    BkLabel: NULL             BkNextHop: 24.24.24.2
BkTunnel ID: Invalid        BkInterface: Vlan-interface101
Troubleshooting OSPF configuration
No OSPF neighbor relationship established
Symptom
No OSPF neighbor relationship can be established.
Analysis
If the physical link and lower-layer protocols work correctly, verify OSPF parameters configured on interfaces. Two neighbors must have the same parameters, such as the area ID, network segment, and mask. (A P2P or virtual link can have different network segments and masks.)
Solution
To resolve the problem:
1.      Use the display ospf peer command to verify OSPF neighbor information.
2.      Use the display ospf interface command to verify OSPF interface information.
3.      Ping the neighbor router's IP address to verify that the connectivity is normal.
4.      Verify OSPF timers. The dead interval on an interface must be at least four times the hello interval.
5.      On an NBMA network, use the peer ip-address command to manually specify the neighbor.
6.      At least one interface must have a router priority higher than 0 on an NBMA or a broadcast network.
7.      If the problem persists, contact H3C Support.
Incorrect routing information
Symptom
OSPF cannot find routes to other areas.
Analysis
The backbone area must maintain connectivity to all other areas. If a router connects to more than one area, at least one area must be connected to the backbone. The backbone cannot be configured as a stub area.
In a stub area, all routers cannot receive external routes, and all interfaces connected to the stub area must belong to the stub area.
Solution
1.      Use the display ospf peer command to verify neighbor information.
3.      Use the display ospf lsdb command to verify the LSDB.
4.      Use the display current-configuration configuration ospf command to verify area configuration. If more than two areas are configured, at least one area is connected to the backbone.
5.      In a stub area, all routers attached are configured with the stub command. In an NSSA area, all routers attached are configured with the nssa command.
6.      If a virtual link is configured, use the display ospf vlink command to verify the state of the virtual link.
