- 05-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-IPv6 static routing configuration
- 08-RIPng configuration
- 09-OSPFv3 configuration
- 10-IPv6 IS-IS configuration
| 00-Preface | 83.34 KB |
Preface
This configuration guide describes the routing fundamentals and configuration procedures. It covers the mainstream routing protocols for IPv4 and IPv6 networks, and describes how to use policies to filter routes and affect routing decisions.
· Audience
Audience
· Network planners.
· Network administrators working with the S6300 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
service@h3c.com
Documentation feedback
We appreciate your comments.
