11-IPsec Commands | 286.50 KB |
ike-peer (IPsec policy view/IPsec policy template view)
ike next-payload check disabled
ike sa keepalive-timer interval
ike sa keepalive-timer timeout
ike sa nat-keepalive-timer interval
ah authentication-algorithm
Use ah authentication-algorithm to specify authentication algorithms for the AH protocol.
Use undo ah authentication-algorithm to restore the default.
ah authentication-algorithm { md5 | sha1 } *
AH uses no authentication algorithm.
IPsec transform set view
Default command level
2: System level
md5: Uses MD5.
sha1: Uses SHA1.
You must use the transform command to specify the AH security protocol or both AH and ESP before you specify authentication algorithms for AH.
# Configure IPsec transform set prop1 to use AH and SHA1.
[Sysname] ipsec transform-set prop1
[Sysname-ipsec-transform-set-prop1] transform ah
[Sysname-ipsec-transform-set-prop1] ah authentication-algorithm sha1
· ipsec transform-set
· transform
connection-name
Use connection-name to configure an IPsec connection name. This name functions only as a description of the IPsec policy.
Use undo connection-name to restore the default.
connection-name name
No IPsec connection name is configured.
IPsec policy view, IPsec policy template view
2: System level
name: IPsec connection name, a case-insensitive string of 1 to 32 characters.
Example
# Set IPsec connection name to CenterToA.
[Sysname] ipsec policy policy1 1 isakmp
[Sysname-ipsec-policy-isakmp-policy1-1] connection-name CenterToA
display ipsec policy
Use display ipsec policy to display information about IPsec policies.
display ipsec policy [ brief | name policy-name [ seq-number ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
brief: Displays brief information about all IPsec policies.
name: Displays detailed information about a specified IPsec policy or IPsec policy group.
policy-name: Name of the IPsec policy, a string of 1 to 15 characters.
seq-number: Sequence number of the IPsec policy, in the range 1 to 65535.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If you do not specify any parameters, the command displays detailed information about all IPsec policies.
If you specify the name policy-name option but leave the seq-number argument, the command displays detailed information about the specified IPsec policy group.
# Display brief information about all IPsec policies.
<Sysname> display ipsec policy brief
IPsec-Policy-Name Mode acl ike-peer name Mapped Template
bbbbbbbbbbbbbbb-1 template aaaaaaaaaaaaaaa
man-1 manual 3400
map-1 isakmp 3000 peer
nat-1 isakmp 3500 nat
test-1 isakmp 3200 test
toccccc-1 isakmp 3003 tocccc
IPsec-Policy-Name Mode acl Local-Address Remote-Address
man-1 manual 3400 3.3.3.1 3.3.3.2
IPsec-Policy-Name |
Name and sequence number of the IPsec policy separated by hyphen. |
Mode |
Negotiation mode of the IPsec policy: · manual—Manual mode. · isakmp—IKE negotiation mode. · template—IPsec policy template mode. |
acl |
ACL referenced by the IPsec policy. |
ike-peer name |
IKE peer name. |
Mapped Template |
Referenced IPsec policy template. |
Local-Address |
IP address of the local end. |
Remote-Address |
IP address of the remote end. |
# Display detailed information about all IPsec policies.
IPsec Policy Group: "policy_isakmp"
Interface: Cellular-Ethernet 1/0/1
IPsec policy name: "policy_isakmp"
sequence number: 10
acl version: IPv4
mode: isakmp
security data flow : 3000
selector mode: standard
ike-peer name: per
perfect forward secrecy:
transform-set name: prop1
IPsec sa local duration(time based): 3600 seconds
IPsec sa local duration(traffic based): 1843200 kilobytes
policy enable: True
security data flow |
Interface to which the IPsec policy is applied. |
sequence number |
Sequence number of the IPsec policy. |
acl version |
ACL version: IPv4. If no ACL is referenced, this field displays None. |
mode |
selector mode |
Data flow protection mode of the IPsec policy: standard, aggregation, or per-host. |
ike-peer name |
IKE peer referenced by the IPsec policy. |
tunnel local address |
Local IP address of the tunnel. |
tunnel remote address |
Remote IP address of the tunnel. |
perfect forward secrecy |
Whether PFS is enabled. |
DH group |
DH group used: 1, 2, 5, or 14. If no DH group is used, this field is not displayed. |
transform-set name |
Transform set referenced by the IPsec policy. |
policy enable |
Whether the IPsec policy is enabled or not. |
inbound/outbound AH/ESP setting |
AH/ESP settings in the inbound/outbound direction, including the SPI and keys. |
ipsec policy (system view)
display ipsec policy-template
Use display ipsec policy-template to display information about IPsec policy templates.
display ipsec policy-template [ brief | name template-name [ seq-number ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
brief: Displays brief information about all IPsec policy templates.
name: Displays detailed information about a specified IPsec policy template or IPsec policy template group.
template-name: Name of the IPsec policy template, a string of 1 to 15 characters.
seq-number: Sequence number of the IPsec policy template, in the range 1 to 65535.
If you do not specify any parameters, the command displays detailed information about all IPsec policy templates.
If you specify the name template-name option but leave the seq-number argument, the command displays information about the specified IPsec policy template group.
# Display brief information about all IPsec policy templates.
<Sysname> display ipsec policy-template brief
Policy-template-Name acl Remote-Address
test-tplt300 2200
Policy-template-Name |
Name and sequence number of the IPsec policy template separated by hyphen. |
acl |
ACL referenced by the IPsec policy template. |
Remote Address |
Remote IP address. |
# Display detailed information about all IPsec policy templates.
IPsec Policy Template Group: "test"
Policy template name: "test"
sequence number: 1
ACL's Version: acl4
ike-peer name: per
perfect forward secrecy: DH group 5
transform-set name: testprop
ACL's Version |
ACL version: acl4. |
ike-peer name |
IKE peer referenced by the IPsec policy template. |
DH group |
transport-set name |
IPsec transform set referenced by the IPsec policy template. |
IPsec sa local duration(time based) |
Time-based lifetime of the IPsec SAs at the local end. |
IPsec sa local duration(traffic based) |
Traffic-based lifetime of the IPsec SAs at the local end. |
display ipsec sa
Use display ipsec sa to display information about IPsec SAs.
display ipsec sa [ brief | policy policy-name [ seq-number ] | remote ip-address ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
brief: Displays brief information about all IPsec SAs.
policy: Displays detailed information about IPsec SAs created by using a specified IPsec policy.
policy-name: Name of the IPsec policy, a string 1 to 15 characters.
remote: Displays detailed information about the IPsec SA with a specified remote address.
ip-address: Remote address.
If you do not specify any parameters, the command displays information about all IPsec SAs.
# Display brief information about all IPsec SAs.
<Sysname> display ipsec sa brief
Src Address Dst Address SPI Protocol Algorithm
10.1.1.1 10.1.1.2 300 ESP E:DES;
A:HMAC-MD5-96
10.1.1.2 10.1.1.1 400 ESP E:DES;
A:HMAC-MD5-96
Table 5 Command output
Src Address |
Local IP address. |
Dst Address |
SPI |
Security parameter index. |
Protocol |
Security protocol used by IPsec. |
Algorithm |
Authentication algorithm and encryption algorithm used by the security protocol, where E indicates the encryption algorithm and A indicates the authentication algorithm. A value of NULL means that type of algorithm is not specified. |
# Display the global SA lifetime settings.
<Sysname> display ipsec sa duration
IPsec sa global duration (traffic based): 1843200 kilobytes
IPsec sa global duration (time based): 3600 seconds
# Display detailed information about all IPsec SAs.
path MTU: 1500
IPsec policy name: "r2"
sequence number: 1
acl version: ACL4
mode: isakmp
connection id: 3
encapsulation mode: tunnel
tunnel:
local address: 2.2.2.2
remote address: 1.1.1.2
flow:
sour addr: 192.168.2.0/255.255.255.0 port: 0 protocol: IP
dest addr: 192.168.1.0/255.255.255.0 port: 0 protocol: IP
[inbound ESP SAs]
spi: 3564837569 (0xd47b1ac1)
transform-set: ESP-ENCRYPT-DES ESP-AUTH-MD5
sa duration (kilobytes/sec): 4294967295/604800
sa remaining duration (kilobytes/sec): 1843200/2686
max received sequence-number: 5
anti-replay check enable: Y
anti-replay window size: 32
udp encapsulation used for nat traversal: N
[outbound ESP SAs]
spi: 801701189 (0x2fc8fd45)
max sent sequence-number: 6
Table 6 Command output
Interface referencing the IPsec policy. |
path MTU |
Maximum IP packet length supported by the interface. |
IPsec policy name |
Name of IPsec policy used. |
sequence number |
acl version |
ACL version: ACL4. If no ACL is referenced, this field displays None. |
mode |
IPsec negotiation mode. |
connection id |
IPsec tunnel identifier. |
encapsulation mode |
Encapsulation mode, transport or tunnel. |
Whether the PFS feature is enabled. |
DH group |
tunnel |
IPsec tunnel. |
local address |
Local IP address of the IPsec tunnel. |
remote address |
Remote IP address of the IPsec tunnel. |
flow |
Data flow. |
sour addr |
Source IP address of the data flow. |
dest addr |
Destination IP address of the data flow. |
port |
Port number. |
protocol |
Protocol type. |
inbound |
Information of the inbound SA. |
spi |
transform-set |
Security protocol and algorithms used by the IPsec transform set. |
sa duration |
Lifetime of the IPsec SA. |
sa remaining key duration |
Remaining lifetime of the SA. |
max received sequence-number |
Maximum sequence number of the received packets (relevant to the anti-replay function provided by the security protocol). |
udp encapsulation used for nat traversal |
Whether NAT traversal is enabled for the SA. |
outbound |
Information of the outbound SA. |
max sent sequence-number |
Maximum sequence number of the sent packets (relevant to the anti-replay function provided by the security protocol). |
anti-replay check enable |
Whether IPsec anti-replay checking is enabled. |
anti-replay window size |
Size of the anti-replay window. |
· reset ipsec sa
· ipsec sa global-duration
display ipsec statistics
Use display ipsec statistics to display IPsec packet statistics.
display ipsec statistics [ tunnel-id integer ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
tunnel-id integer: Specifies an IPsec tunnel by its ID, which is in the range 1 to 2000000000.
If you do not specify any parameters, the command displays the statistics for all IPsec packets.
# Display statistics on all IPsec packets.
<Sysname> display ipsec statistics
the security packet statistics:
input/output security packets: 47/62
input/output security bytes: 3948/5208
input/output dropped security packets: 0/45
dropped security packet detail:
not enough memory: 0
can't find SA: 45
queue is full: 0
authentication has failed: 0
wrong length: 0
replay packet: 0
packet too long: 0
wrong SA: 0
# Display IPsec packet statistics for Tunnel 3.
<Sysname> display ipsec statistics tunnel-id 3
Connection ID : 3
input/output security packets: 5124/8231
input/output security bytes: 52348/64356
input/output dropped security packets: 0/0
queue is full: 0
wrong length: 0
replay packet: 0
packet too long: 0
wrong SA: 0
Table 7 Command output
Connection ID |
ID of the tunnel. |
input/output security packets |
Counts of inbound and outbound IPsec protected packets. |
input/output security bytes |
Counts of inbound and outbound IPsec protected bytes. |
input/output dropped security packets |
Counts of inbound and outbound IPsec protected packets that are discarded by the device. |
dropped security packet detail |
Detailed information about inbound/outbound packets that get dropped. |
not enough memory |
Number of packets dropped due to lack of memory. |
can't find SA |
Number of packets dropped due to finding no security association. |
queue is full |
Number of packets dropped due to full queues. |
authentication has failed |
Number of packets dropped due to authentication failure. |
wrong length |
Number of packets dropped due to wrong packet length. |
replay packet |
Number of packets replayed. |
packet too long |
Number of packets dropped due to excessive packet length. |
wrong SA |
Number of packets dropped due to improper SA. |
reset ipsec statistics
display ipsec transform-set
Use display ipsec transform-set to display information about IPsec transform sets.
display ipsec transform-set [ transform-set-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
transform-set-name: Name of an IPsec transform set, a string of 1 to 15 characters. If you do not specify an IPsec transform set, the command displays information about all IPsec transform sets.
If you do not specify any parameters, the command displays information about all IPsec transform sets.
# Display information about all IPsec transform sets.
<Sysname> display ipsec transform-set
IPsec transform-set name: tran1
transform: esp-new
ESP protocol:
Integrity: md5-hmac-96
Encryption: des
IPsec transform-set name: tran2
encapsulation mode: transport
transform: esp-new
ESP protocol:
Table 8 Command output
IPsec transform-set name |
Name of the IPsec transform set. |
Encapsulation mode used by the IPsec transform set, transport or tunnel. |
transform |
Security protocols used by the IPsec transform set: AH, ESP, or both. If both protocols are configured, IPsec uses ESP before AH. |
AH protocol |
Authentication algorithm used by AH. |
ESP protocol |
Authentication algorithm and encryption algorithm used by ESP. |
ipsec transform-set
display ipsec tunnel
Use display ipsec tunnel to display information about IPsec tunnels.
display ipsec tunnel [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If you do not specify any parameters, the command displays information about all IPsec tunnels.
# Display information about IPsec tunnels.
<Sysname> display ipsec tunnel
total tunnel : 2
connection id: 3
SA's SPI:
inbound: 187199087 (0xb286e6f) [ESP]
outbound: 3562274487 (0xd453feb7) [ESP]
tunnel:
local address: 44.44.44.44
remote address : 44.44.44.55
flow:
sour addr : 44.44.44.0/255.255.255.0 port: 0 protocol : IP
dest addr : 44.44.44.0/255.255.255.0 port: 0 protocol : IP
current Encrypt-card:
connection id: 5
SA's SPI:
inbound: 12345 (0x3039) [ESP]
outbound: 12345 (0x3039) [ESP]
tunnel:
flow:
# Display information about IPsec tunnels in aggregation mode.
total tunnel: 2
connection id: 4
SA's SPI:
inbound : 2454606993 (0x924e5491) [ESP]
outbound : 675720232 (0x2846ac28) [ESP]
tunnel :
remote address : 44.44.44.45
flow :
as defined in acl 3001
current Encrypt-card :
Table 9 Command output
connection id |
Connection ID, used to uniquely identify an IPsec Tunnel. |
Perfect forward secrecy, indicating which DH group is to be used for fast negotiation mode in IKE phase 2. |
SA's SPI |
SPIs of the inbound and outbound SAs. |
tunnel |
Local and remote addresses of the tunnel. |
flow |
Data flow protected by the IPsec tunnel, including source IP address, destination IP address, source port, destination port and protocol. |
as defined in acl 3001 |
The IPsec tunnel protects all data flows defined by ACL 3001. |
current Encrypt-card |
Encryption card interface used by the current tunnel. If no encryption card is used, this field displays nothing. |
encapsulation-mode
Use encapsulation-mode to set the encapsulation mode that the security protocol uses to encapsulate IP packets.
Use undo encapsulation-mode to restore the default.
encapsulation-mode { transport | tunnel }
A security protocol encapsulates IP packets in tunnel mode.
IPsec transform set view, IPsec policy view, IPsec policy template view
2: System level
transport: Uses transport mode.
tunnel: Uses tunnel mode.
When IPsec uses IKEv1, this command can be used only in IPsec transform set view, and its related commands include only ipsec transform-set.
# When IPsec uses IKEv1, configure IPsec transform set tran1 to use the transport encapsulation mode.
[Sysname] ipsec transform-set tran1
[Sysname-ipsec-transform-set-tran1] encapsulation-mode transport
esp authentication-algorithm
Use esp authentication-algorithm to specify authentication algorithms for ESP.
Use undo esp authentication-algorithm to restore the default.
esp authentication-algorithm { md5 | sha1 } *
ESP uses no authentication algorithm.
2: System level
md5: Uses the MD5 algorithm, which uses a 128-bit key.
sha1: Uses the SHA1 algorithm, which uses a 160-bit key.
Compared with SHA1, MD5 is faster but less secure. MD5 is sufficient for most networks. To deploy a highly secure network, use SHA1.
For ESP, you must specify an encryption algorithm, an authentication algorithm, or both. The undo esp authentication-algorithm command takes effect only if one or more encryption algorithms are specified for ESP.
# Configure IPsec transform set prop1 to use ESP and specify SHA1 as the authentication algorithm for ESP.
[Sysname-ipsec-transform-set-prop1] transform esp
[Sysname-ipsec-transform-set-prop1] esp authentication-algorithm sha1
· esp encryption-algorithm
Use esp encryption-algorithm to specify encryption algorithms for ESP.
Use undo esp encryption-algorithm to restore the default.
esp encryption-algorithm { 3des | aes-cbc-128 | aes-cbc-192 | aes-cbc-256 | des } *
ESP uses no encryption algorithm.
2: System level
3des: Uses the triple Data Encryption Standard (3DES) in CBC mode, which uses a 168-bit key.
aes-cbc-128: Uses the Advanced Encryption Standard (AES) in CBC mode that uses a 128- bit key.
aes-cbc-192: Uses AES in CBC mode that uses a 192-bit key.
aes-cbc-256: Uses AES in CBC mode that uses a 256-bit key.
des: Uses the DES in cipher block chaining (CBC) mode, which uses a 56-bit key.
ESP supports three IP packet protection schemes: encryption only, authentication only, or both encryption and authentication. For ESP, you must specify an encryption algorithm, an authentication algorithm, or both. The undo esp encryption-algorithm command takes effect only if one or more authentication algorithms are specified for ESP.
# Configure IPsec transform set prop1 to use ESP and specify 3DES as the encryption algorithm for ESP.
[Sysname-ipsec-transform-set-prop1] esp encryption-algorithm 3des
· display ipsec transform-set
· esp authentication-algorithm
Use ike-peer to reference an IKE peer in an IPsec policy or IPsec policy template configured through IKE negotiation.
Use undo ike peer to remove the reference.
This command applies only to IKE negotiation mode.
ike-peer peer-name
undo ike-peer peer-name
2: System level
peer-name: IKE peer name, a string of 1 to 32 characters.
# Configure a reference to an IKE peer in an IPsec policy.
[Sysname] ipsec policy policy1 10 isakmp
[Sysname-ipsec-policy-isakmp-policy1-10] ike-peer peer1
ipsec policy
ipsec policy (interface view)
Use ipsec policy to apply an IPsec policy group to an interface.
Use undo ipsec policy to remove the application.
ipsec policy policy-name
undo ipsec policy [ policy-name ]
Interface view
2: System level
policy-name: Name of the existing IPsec policy group to be applied to the interface, a string of 1 to 15 characters.
Only one IPsec policy group can be applied to an interface. To apply another IPsec policy group to the interface, remove the original application first. An IPsec policy group can be applied to more than one interface.
With an IPsec policy group applied to an interface, the system uses each IPsec policy in the group to protect certain data flows.
For each packet to be sent out an IPsec protected interface, the system checks the IPsec policies of the IPsec policy group in the ascending order of sequence numbers. If it finds an IPsec policy whose ACL matches the packet, it uses the IPsec policy to protect the packet. If it finds no ACL of the IPsec policies matches the packet, it does not provide IPsec protection for the packet and sends the packet out directly.
# Apply IPsec policy group pg1 to interface Cellular-Ethernet 1/0/1.
[Sysname] interface Cellular-Ethernet 1/0/1
[Sysname-Cellular-Ethernet1/0/1] ipsec policy pg1
Use ipsec policy to create an IPsec policy and enter its view.
Use undo ipsec policy to delete the specified IPsec policies.
ipsec policy policy-name seq-number [ isakmp | manual ]
undo ipsec policy policy-name [ seq-number ]
No IPsec policy exists.
2: System level
policy-name: Name for the IPsec policy, a case-insensitive string of 1 to 15 characters. No hyphen (-) can be included.
seq-number: Sequence number for the IPsec policy, in the range 1 to 65535.
isakmp: Sets up SAs through IKE negotiation.
manual: Sets up SAs manually.
When creating an IPsec policy, you must specify the generation mode.
You cannot change the generation mode of an existing IPsec policy; you can only delete the policy and then re-create it with the new mode.
IPsec policies with the same name constitute an IPsec policy group. An IPsec policy is identified uniquely by its name and sequence number. In an IPsec policy group, an IPsec policy with a smaller sequence number has a higher priority.
The undo ipsec policy command without the seq-number argument deletes an IPsec policy group.
# Create an IPsec policy with the name policy1 and sequence number 100, and specify to set up SAs through IKE negotiation.
[Sysname] ipsec policy policy1 100 isakmp
[Sysname-ipsec-policy-isakmp-policy1-100]
# Create an IPsec policy with the name policy1 and specify the manual mode for it.
[Sysname] ipsec policy policy1 101 manual
[Sysname-ipsec-policy-manual-policy1-101]
· ipsec policy (interface view)
· display ipsec policy
ipsec policy isakmp template
Use ipsec policy isakmp template to create an IPsec policy by referencing an existing IPsec policy template, so that IKE can use the IPsec policy for SA negotiation.
Use undo ipsec policy with the seq-number argument to delete an IPsec policy.
Use undo ipsec policy without the seq-number argument to delete an IPsec policy group.
ipsec policy policy-name seq-number isakmp template template-name
2: System level
seq-number: Sequence number for the IPsec policy, in the range of 1 to 65535.
isakmp template template-name: Name of the IPsec policy template to be referenced.
After you create an IPsec policy by referencing an IPsec policy template, to modify the configuration for the IPsec policy, you must enter the IPsec policy template view instead of the IPsec policy view.
You cannot change the negotiation mode of an IPsec policy. To do so, you must delete the IPsec policy and then re-create it.
· ipsec policy (system view)
· ipsec policy-template
# Create an IPsec policy with the name policy2 and sequence number 200 by referencing IPsec policy template temp1.
[Sysname] ipsec policy policy2 200 isakmp template temp1
Use ipsec policy-template to create an IPsec policy template and enter the IPsec policy template view.
Use undo ipsec policy-template to delete the specified IPsec policy templates.
ipsec policy-template template-name seq-number
undo ipsec policy-template template-name [ seq-number ]
No IPsec policy template exists.
2: System level
template-name: Name for the IPsec policy template, a case-insensitive string of 1 to 41 characters. No hyphen (-) can be included.
seq-number: Sequence number for the IPsec policy template, in the range 1 to 65535.
Using the undo command without the seq-number argument deletes an IPsec policy template group.
In an IPsec policy template group, an IPsec policy template with a smaller sequence number has a higher priority.
# Create an IPsec policy template with the name template1 and the sequence number 100.
[Sysname] ipsec policy-template template1 100
[Sysname-ipsec-policy-template-template1-100]
display ipsec policy template
Use ipsec sa global-duration to configure the global SA lifetime.
Use undo ipsec sa global-duration to restore the default.
ipsec sa global-duration { time-based seconds | traffic-based kilobytes }
undo ipsec sa global-duration { time-based | traffic-based }
The time-based global SA lifetime is 3600 seconds, and the traffic-based global SA lifetime is 1843200 kilobytes.
2: System level
seconds: Time-based global SA lifetime in seconds, in the range 180 to 604800.
kilobytes: Traffic-based global SA lifetime in kilobytes, in the range 2560 to 4294967295.
When negotiating to set up an SA, IKE prefers the lifetime of the IPsec policy that it uses. If the IPsec policy is not configured with its own lifetime, IKE uses the global SA lifetime.
When negotiating to set up an SA, IKE prefers the shorter one of the local lifetime and that proposed by the remote.
You can configure both a time-based and a traffic-based global SA lifetime. An SA is aged out when it has existed for the specified time period or has processed the specified volume of traffic.
The SA lifetime applies to only IKE negotiated SAs; it is not effective for manually configured SAs.
· sa duration
· display ipsec sa duration
# Set the time-based global SA lifetime to 7200 seconds (2 hours).
[Sysname] ipsec sa global-duration time-based 7200
# Set the traffic-based global SA lifetime to 10240 kilobytes (10 Mbytes).
[Sysname] ipsec sa global-duration traffic-based 10240
ipsec transform-set
Use ipsec transform-set to create an IPsec transform set and enter IPsec transform set view.
Use undo ipsec transform-set to delete an IPsec transform set.
ipsec transform-set transform-set-name
undo ipsec transform-set transform-set-name
No IPsec transform set exists.
2: System level
transform-set-name: Name of an IPsec transform set, a case-insensitive string of 1 to 32 characters.
# Create an IPsec transform set named tran1 and enter its view.
local-address
Use local-address to configure the local gateway IP address.
Use undo local-address to restore the default.
local-address ipv4-address
undo local-address
The IP address of the interface to which the IPsec policy is applied is used as the local gateway IP address.
2: System level
ipv4-address: IPv4 address of the local security gateway.
# Use 1.1.1.1 as the local gateway IP address.
[Sysname] ipsec policy map 1 isakmp
[Sysname-ipsec-policy-isakmp-map-1] local-address 1.1.1.1
pfs
Use pfs to enable and configure the perfect forward secrecy (PFS) feature so that the system uses the feature when employing the IPsec policy to initiate a negotiation.
Use undo pfs to remove the configuration.
pfs { dh-group1 | dh-group2 | dh-group5 | dh-group14 }
undo pfs
The PFS feature is not used for negotiation.
2: System level
dh-group1: Uses 768-bit Diffie-Hellman group.
dh-group2: Uses 1024-bit Diffie-Hellman group.
dh-group5: Uses 1536-bit Diffie-Hellman group.
dh-group14: Uses 2048-bit Diffie-Hellman group.
In terms of security and necessary calculation time, the following four groups are in the descending order: 2048-bit Diffie-Hellman group (dh-group14), 1536-bit Diffie-Hellman group (dh-group5), 1024-bit Diffie-Hellman group (dh-group2) and 768-bit Diffie-Hellman group (dh-group1).
This command allows IPsec to perform an additional key exchange process during the negotiation phase 2, providing an additional level of security.
The local Diffie-Hellman group must be the same as that of the peer.
This command can be used only when the SAs are to be set up through IKE negotiation.
# Enable and configure PFS for IPsec policy policy1.
[Sysname] ipsec policy policy1 200 isakmp
[Sysname-ipsec-policy-isakmp-policy1-200] pfs dh-group1
policy enable
Use policy enable to enable the IPsec policy.
Use undo policy enable to disable the IPsec policy.
policy enable
undo policy enable
The IPsec policy is enabled.
2: System level
The command is not applicable to manual IPsec policies.
If the IPsec policy is not enabled for the IKE peer, the peer cannot take part in the IKE negotiation.
# Enable the IPsec policy with the name policy1 and sequence number 100.
[Sysname-ipsec-policy-isakmp-policy1-100] policy enable
remote-address
Use remote-address to configure the remote gateway IP address.
Use undo remote-address to restore the default.
remote-address { host-name [ dynamic ] | ipv4-address }
undo remote-address { host-name [ dynamic ] | ipv4-address }
No remote gateway IP address is configured.
2: System level
hostname: Host name of the remote security gateway, a case-insensitive string of 1 to 255 characters. The host name uniquely identifies the remote IPsec peer and can be resolved to an IP address by the DNS server.
dynamic: Uses dynamic address resolution for the remote gateway host name. If you do not provide this keyword, the local end has the remote host name resolved only once after you configure the remote gateway host name.
ipv4-address: IPv4 address of the remote security gateway.
# Use 1.1.1.1 as the remote gateway IP address.
[Sysname-ipsec-policy-isakmp-map-1] remote-address 1.1.1.1
reset ipsec sa
Use reset ipsec sa to clear IPsec SAs.
reset ipsec sa [ parameters dest-address protocol spi | policy policy-name [ seq-number ] | remote ip-address ]
2: System level
parameters: Specifies IPsec SAs that use the specified destination address, security protocol, and SPI.
dest-address: Destination address, in dotted decimal notation.
protocol: Security protocol, which can be keyword ah or esp, case insensitive.
spi: Security parameter index, in the range 256 to 4294967295.
policy: Specifies IPsec SAs that use an IPsec policy.
policy-name: Name of the IPsec policy, a case-sensitive string of 1 to 15 alphanumeric characters.
seq-number: Sequence number of the IPsec policy, in the range 1 to 65535. If no seq-number is specified, all the policies in the IPsec policy group named policy-name are specified.
remote: Specifies SAs to or from a remote address, in dotted decimal notation.
Immediately after a manually set up SA is cleared, the system automatically sets up a new SA based on the parameters of the IPsec policy. After IKE negotiated SAs are cleared, the system sets up new SAs only when IKE negotiation is triggered by interesting packets.
IPsec SAs appear in pairs. If you specify the parameters keyword to clear an IPsec SA, the IPsec SA in the other direction is also automatically cleared.
If you do not specify any parameter, the command clears all IPsec SAs.
# Clear all IPsec SAs.
<Sysname> reset ipsec sa
# Clear the IPsec SA with a remote IP address of 10.1.1.2.
<Sysname> reset ipsec sa remote 10.1.1.2
# Clear all IPsec SAs of IPsec policy template policy1.
<Sysname> reset ipsec sa policy policy1
# Clear the IPsec SA of the IPsec policy with the name of policy1 and sequence number of 10.
<Sysname> reset ipsec sa policy policy1 10
# Clear the IPsec SA with a remote IP address of 10.1.1.2, security protocol of AH, and SPI of 10000.
<Sysname> reset ipsec sa parameters 10.1.1.2 ah 10000
display ipsec sa
Use reset ipsec statistics to clear IPsec packet statistics.
1: Monitor level
# Clear IPsec packet statistics.
<Sysname> reset ipsec statistics
sa authentication-hex
Use sa authentication-hex to configure an authentication key for an SA.
Use undo sa authentication-hex to remove the configuration.
sa authentication-hex { inbound | outbound } { ah | esp } [ cipher string-key | simple hex-key ]
undo sa authentication-hex { inbound | outbound } { ah | esp }
IPsec policy view
2: System level
inbound: Specifies the inbound SA through which IPsec processes the received packets.
outbound: Specifies the outbound SA through which IPsec processes the packets to be sent.
ah: Uses AH.
esp: Uses ESP.
cipher string-key: Sets a ciphertext authentication key. The string-key argument is a case-sensitive ciphertext string of 1 to 117 characters.
simple hex-key: Sets a plaintext authentication key. The hex-key argument is case insensitive and must be a 16-byte hexadecimal string for MD5 or a 20-byte hexadecimal string for SHA1.
If neither cipher nor simple is specified, you set a plaintext authentication key string.
For secrecy, all keys, including keys configured in plain text, are saved in cipher text.
This command applies to only manual IPsec policies.
When configuring a manual IPsec policy, you must set the parameters of both the inbound and outbound SAs.
The authentication key for the inbound SA at the local end must be the same as that for the outbound SA at the remote end, and the authentication key for the outbound SA at the local end must be the same as that for the inbound SA at the remote end.
At each end of an IPsec tunnel, the keys for the inbound and outbound SAs must be in the same format (both in hexadecimal format or both in string format), and the keys must be specified in the same format for both ends of the tunnel.
# Configure the authentication key for the inbound and outbound SAs that use AH as a plaintext string of 0x112233445566778899aabbccddeeff00 and 0xaabbccddeeff001100aabbccddeeff00, respectively.
[Sysname] ipsec policy policy1 100 manual
[Sysname-ipsec-policy-manual-policy1-100] sa authentication-hex inbound ah simple 112233445566778899aabbccddeeff00
[Sysname-ipsec-policy-manual-policy1-100] sa authentication-hex outbound ah simple aabbccddeeff001100aabbccddeeff00
sa duration
Use sa duration to set an SA lifetime for the IPsec policy.
Use undo sa duration to restore the default.
sa duration { time-based seconds | traffic-based kilobytes }
undo sa duration { time-based | traffic-based }
The SA lifetime of an IPsec policy equals the current global SA lifetime.
The time-based global SA lifetime is 3600 seconds, and traffic-based SA lifetime is 1843200 kilobytes.
2: System level
seconds: Time-based SA lifetime in seconds, in the range 180 to 604800.
kilobytes: Traffic-based SA lifetime in kilobytes, in the range 2560 to 4294967295.
When negotiating to set up an SA, IKE prefers the lifetime settings of the IPsec policy that it uses. If the IPsec policy is not configured with its own lifetime settings, IKE uses the global SA lifetime settings, which are configured with the ipsec sa global-duration command.
When negotiating to set up an SA, IKE prefers the shorter ones of the local lifetime settings and those proposed by the remote.
The SA lifetime applies to only IKE negotiated SAs. It is not effective for manually configured SAs.
# Set the SA lifetime for IPsec policy1 to 7200 seconds (two hours).
[Sysname-ipsec-policy-isakmp-policy1-100] sa duration time-based 7200
# Set the SA lifetime for IPsec policy policy1 to 20480 kilobytes (20 Mbytes).
[Sysname-ipsec-policy-isakmp-policy1-100] sa duration traffic-based 20480
sa encryption-hex
Use sa encryption-hex to configure an encryption key for an SA.
Use undo sa encryption-hex to remove the configuration.
sa encryption-hex { inbound | outbound } esp [ cipher string-key | simple hex-key ]
undo sa encryption-hex { inbound | outbound } esp
IPsec policy view
2: System level
esp: Uses ESP.
cipher string-key: Sets a ciphertext encryption key. The string-key argument is case sensitive and must be a ciphertext string of 1 to 117 characters.
simple hex-key: Sets a plaintext encryption key. The hex-key argument is case insensitive, and must be an 8-byte hexadecimal string for DES-CBC, a 16-byte hexadecimal string for AES128-CBC and camellia128-CBC, a 20-byte hexadecimal string for AESCTR-128, a 24-byte hexadecimal string for 3DES-CBC, AES192-CBC, and camellia192-CBC, or a 32-byte hexadecimal string for AES256-CBC and camellia256-CBC.
If neither cipher nor simple is specified, you set a plaintext encryption key string.
The encryption key for the inbound SA at the local end must be the same as that for the outbound SA at the remote end, and the encryption key for the outbound SA at the local end must be the same as that for the inbound SA at the remote end.
# Configure the encryption key for the inbound and outbound SAs that use ESP as a plaintext string of 0x1234567890abcdef and 0xabcdefabcdef1234, respectively.
[Sysname-ipsec-policy-manual-policy1-100] sa encryption-hex inbound esp simple 1234567890abcdef
[Sysname-ipsec-policy-manual-policy1-100] sa encryption-hex outbound esp simple abcdefabcdef1234
sa spi
Use sa spi to configure an SPI for an SA.
Use undo sa spi to remove the configuration.
sa spi { inbound | outbound } { ah | esp } spi-number
undo sa spi { inbound | outbound } { ah | esp }
No SPI is configured for an SA.
IPsec policy view
2: System level
ah: Uses AH.
esp: Uses ESP.
spi-number: Security parameters index (SPI) in the SA triplet, in the range 256 to 4294967295.
When configuring a manual IPsec policy, you must configure parameters for both inbound and outbound SAs. For an ACL-based manual IPsec policy, specify different SPIs for different SAs.
The local inbound SA must use the same SPI and keys as the remote outbound SA. The same is true of the local outbound SA and remote inbound SA.
# Set the SPI for the inbound SA to 10000 and that for the outbound SA to 20000 in a manual IPsec policy.
[Sysname-ipsec-policy-manual-policy1-100] sa spi inbound ah 10000
[Sysname-ipsec-policy-manual-policy1-100] sa spi outbound ah 20000
sa string-key
Use sa string-key to set a key string for an SA.
Use undo sa string-key to remove the configuration.
sa string-key { inbound | outbound } { ah | esp } [ cipher | simple ] string-key
undo sa string-key { inbound | outbound } { ah | esp }
IPsec policy view
2: System level
ah: Uses AH.
esp: Uses ESP.
cipher: Sets a ciphertext key.
simple: Sets a plaintext key.
string-key: Specifies the key string. This argument is case sensitive. If cipher is specified, it must be a ciphertext string of 1 to 373 characters. If simple is specified, it must be a string of 1 to 255 characters. If neither cipher nor simple is specified, you set a plaintext key string. For different algorithms, enter strings of any length in the specified range. Using this key string, the system automatically generates keys meeting the algorithm requirements. When the protocol is ESP, the system generates the keys for the authentication algorithm and encryption algorithm respectively.
When configuring a manual IPsec policy, you must set parameters for both inbound and outbound SAs.
Enter keys in the same format for the local and remote inbound and outbound SAs. For example, if the local inbound SA uses a key in characters, the local outbound SA and remote inbound and outbound SAs must use keys in characters.
# Configure the inbound and outbound SAs that use AH to use the plaintext keys abcdef and efcdab, respectively.
[Sysname-ipsec-policy-manual-policy1-100] sa string-key inbound ah simple abcdef
[Sysname-ipsec-policy-manual-policy1-100] sa string-key outbound ah simple efcdab
security acl
Use security acl to specify the ACL for the IPsec policy to reference.
Use undo security acl to remove the configuration.
security acl acl-number [ aggregation | per-host ]
undo security acl
An IPsec policy references no ACL.
2: System level
acl-number: Number of the ACL for the IPsec policy to reference, in the range 3000 to 3999.
aggregation: Specifies the data flow protection mode as aggregation. This mode is configurable only in IPsec policies that use IKE negotiation.
per-host: Specifies the data flow protection mode as per-host. This mode is configurable only in IPsec policies that use IKE negotiation.
With an IKE-dependent IPsec policy configured, data flows can be protected in the following modes:
· Standard mode—One tunnel protects one data flow. The data flow permitted by an ACL rule is protected by one tunnel that is established solely for it.
· Aggregation mode—One tunnel protects all data flows permitted by all the rules of an ACL.
· Per-host mode—One tunnel protects one host-to-host data flow. One host-to-host data flow is identified by one ACL rule and protected by one tunnel established solely for it.
If you specify neither the aggregation nor the per-host mode, the standard mode is used.
To use the per-host mode, you only need to specify an ACL in per-host mode in the IPsec policy of the IPsec initiator. You do not need to specify the per-host keyword in the IPsec policy of the responder.
Use the per-host mode with caution. If the number of hosts to be protected is large, IPsec using the per-host mode will establish a large number of SAs, exhausting the system resources quickly.
When your device works with an old-version device, use the aggregation mode on both devices.
An IPsec policy references only one ACL. If you specify more than one ACL for an IPsec policy, the IPsec policy references the one last specified.
# Configure IPsec policy policy1 to reference ACL 3001.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit tcp source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[Sysname-acl-adv-3001] quit
[Sysname-ipsec-policy-manual-policy1-100] security acl 3001
# Configure IPsec policy policy2 to reference ACL 3002, and set the data flow protection mode to aggregation.
[Sysname] acl number 3002
[Sysname-acl-adv-3002] rule 0 permit ip source 10.1.2.1 0.0.0.255 destination 10.1.2.2 0.0.0.255
[Sysname-acl-adv-3002] rule 1 permit ip source 10.1.3.1 0.0.0.255 destination 10.1.3.2 0.0.0.255
[Sysname] ipsec policy policy2 1 isakmp
[Sysname-ipsec-policy-isakmp-policy2-1] security acl 3002 aggregation
# Configure IPsec policy policy3 to reference ACL 3003, and set the data flow protection mode to per-host.
[Sysname] acl number 3003
[Sysname-acl-adv-3003] rule permit ip source 10.1.1.0 0.0.0.255 destination 10.1.2.0 0.0.0.255
[Sysname-acl-adv-3003] quit
[Sysname] ipsec policy policy3 10 isakmp
[Sysname-ipsec-policy-isakmp-policy3-10] security acl 3003 per-host
transform
Use transform to specify a security protocol for an IPsec transform set.
Use undo transform to restore the default.
transform { ah | ah-esp | esp }
undo transform
The ESP protocol is used.
2: System level
ah: Uses the AH protocol.
ah-esp: Uses ESP first and then AH.
esp: Uses the ESP protocol.
The IPsec transform sets at the two ends of an IPsec tunnel must use the same security protocol.
# Configure IPsec transform set prop1 to use AH.
ipsec transform-set
transform-set
Use transform-set to specify an IPsec transform set for the IPsec policy to reference.
Use undo transform-set to remove an IPsec transform set referenced by the IPsec policy.
transform-set transform-set-name&<1-6>
undo transform-set [ transform-set-name ]
An IPsec policy references no IPsec transform set.
2: System level
transform-set-name&<1-6>: Name of the IPsec transform set, a string of 1 to 32 characters. &<1-6> means that you can specify up to six transform sets, which are separated by space.
The specified IPsec transform sets must already exist.
A manual IPsec policy can reference only one IPsec transform set. To replace a referenced IPsec transform set, use the undo transform-set command to remove the original transform set binding and then use the transform-set command to reconfigure one.
An IKE negotiated IPsec policy can reference up to six IPsec transform sets. The IKE negotiation process will search for and use the exactly matched transform set.
# Configure IPsec policy policy1 to reference IPsec transform set tran1.
[Sysname-ipsec-transform-set-tran1] quit
[Sysname-ipsec-policy-manual-policy1-100] transform-set tran1
tunnel local
Use tunnel local to configure the local address of an IPsec tunnel.
Use undo tunnel local to remove the configuration.
tunnel local ip-address
undo tunnel local
No local address is configured for an IPsec tunnel.
IPsec policy view
2: System level
ip-address: Local address for the IPsec tunnel.
The local address, if not configured, will be the address of the interface to which the IPsec policy is applied.
# Set the local address of the IPsec tunnel to the address of Loopback 0, 10.0.0.1.
[Sysname] interface loopback 0
[Sysname-LoopBack0] ip address 10.0.0.1 32
[Sysname-LoopBack0] quit
[Sysname-ipsec-policy-manual-policy1-100] tunnel local 10.0.0.1
tunnel remote
Use tunnel remote to configure the remote address of an IPsec tunnel.
Use undo tunnel remote to remove the configuration.
tunnel remote ip-address
undo tunnel remote [ ip-address ]
No remote address is configured for the IPsec tunnel.
IPsec policy view
2: System level
ip-address: Remote address for the IPsec tunnel.
If you configure the remote address repeatedly, the last one takes effect.
An IPsec tunnel is established between the local and remote ends. The remote IP address of the local end must be the same as that of the local IP address of the remote end.
# Set the remote address of the IPsec tunnel to 10.1.1.2.
[Sysname] ipsec policy policy1 10 manual
[Sysname-ipsec-policy-policy1-10] tunnel remote 10.1.1.2
Use authentication-algorithm to specify an authentication algorithm for an IKE proposal.
Use undo authentication-algorithm to restore the default.
authentication-algorithm { md5 | sha | sha256 }
An IKE proposal uses the SHA1 authentication algorithm.
IKE proposal view
2: System level
md5: Uses HMAC-MD5.
sha: Uses HMAC-SHA1.
sha256: Uses HMAC-SHA256.
# Set MD5 as the authentication algorithm for IKE proposal 10.
[Sysname] ike proposal 10
[Sysname-ike-proposal-10] authentication-algorithm md5
· ike proposal
· display ike proposal
authentication-method
Use authentication-method to specify an authentication method for an IKE proposal.
Use undo authentication-method to restore the default.
authentication-method { pre-share | rsa-signature }
An IKE proposal uses the pre-shared key authentication method.
IKE proposal view
2: System level
pre-share: Uses the pre-shared key method.
rsa-signature: Uses the RSA digital signature method.
# Specify that IKE proposal 10 uses the pre-shared key authentication method.
[Sysname-ike-proposal-10] authentication-method pre-share
· ike proposal
certificate domain
Use certificate domain to configure the PKI domain of the certificate when IKE uses digital signature as the authentication mode.
Use undo certificate domain to remove the configuration.
certificate domain domain-name
IKE peer view
2: System level
domain-name: Name of the PKI domain, a string of 1 to 15 characters.
# Configure the PKI domain as abcde for IKE negotiation.
[Sysname] ike peer peer1
[Sysname-ike-peer-peer1] certificate domain abcde
· authentication-method
· pki domain
dh
Use dh to specify the DH group to be used in key negotiation phase 1 for an IKE proposal.
Use undo dh to restore the default.
dh { group1 | group2 | group5 | group14 }
undo dh
Group1, the 768-bit Diffie-Hellman group, is used.
IKE proposal view
2: System level
group1: Uses the 768-bit Diffie-Hellman group for key negotiation in phase 1
group2: Uses the 1024-bit Diffie-Hellman group for key negotiation in phase 1.
group5: Uses the 1536-bit Diffie-Hellman group for key negotiation in phase 1.
group14: Uses the 2048-bit Diffie-Hellman group for key negotiation in phase 1.
# Specify 768-bit Diffie-Hellman for IKE proposal 10.
[Sysname-ike-proposal-10] dh group1
· ike proposal
display ike dpd
Use display ike dpd to display information about Dead Peer Detection (DPD) detectors.
display ike dpd [ dpd-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
dpd-name: DPD name, a string of 1 to 15 characters.
If you do not specify any parameters, the command displays information about all DPD detectors.
# Display information about all DPD detectors.
<Sysname> display ike dpd
IKE dpd: dpd1
references: 1
interval-time: 10
time_out: 5
Table 10 Command output
references |
Number of IKE peers that use the DPD detector. |
Interval-time |
DPD query trigging interval in seconds. |
time_out |
DPD packet retransmission interval in seconds. |
ike dpd
display ike peer
Use display ike peer to display information about IKE peers.
display ike peer [ peer-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
peer-name: Name of the IKE peer, a string of 1 to 15 characters.
If you do not specify any parameters, the command displays information about all IKE peers.
# Display information about all IKE peers.
<Sysname> display ike peer
IKE Peer: rtb4tunn
exchange mode: main on phase 1
pre-shared-key ******
peer id type: ip
peer ip address: 44.44.44.55
local ip address:
peer name:
nat traversal: disable
dpd: dpd1
exchange mode |
IKE negotiation mode in phase 1. |
pre-shared-key |
Pre-shared key used in phase 1, displayed as ******. |
peer id type |
ID type used in phase 1. |
peer ip address |
IP address of the remote security gateway. |
local ip address |
IP address of the local security gateway. |
peer name |
Name of the remote security gateway. |
nat traversal |
Whether NAT traversal is enabled. |
dpd |
Name of the peer DPD detector. |
ike peer
Use display ike proposal to view the settings of all IKE proposals.
display ike proposal [ | { begin | exclude | include } regular-expression ]
1: Monitor level
This command displays the configuration information of all IKE proposals in the descending order of proposal priorities.
# Display the settings of all IKE proposals.
<Sysname> display ike proposal
priority authentication authentication encryption Diffie-Hellman duration
method algorithm algorithm group (seconds)
10 PRE_SHARED SHA DES_CBC MODP_1024 5000
11 PRE_SHARED MD5 DES_CBC MODP_768 50000
default PRE_SHARED SHA DES_CBC MODP_768 86400
Table 12 Command output
priority |
Priority of the IKE proposal. |
authentication method |
Authentication method used by the IKE proposal. |
authentication algorithm |
Authentication algorithm used by the IKE proposal. |
encryption algorithm |
Encryption algorithm used by the IKE proposal. |
Diffie-Hellman group |
DH group used in IKE negotiation phase 1. |
duration (seconds) |
ISAKMP SA lifetime (in seconds) of the IKE proposal. |
· ike proposal
· encryption-algorithm
· authentication-algorithm
· dh
· sa duration
display ike sa
Use display ike sa to display information about the current IKE SAs.
display ike sa [ verbose [ connection-id connection-id | remote-address remote-address ] ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
verbose: Displays detailed information.
connection-id connection-id: Displays detailed information about IKE SAs by connection ID, in the range 1 to 2000000000.
remote: Displays detailed information about IKE SAs with a specified remote address.
If you do not specify any parameters or keywords, the command displays brief information about the current IKE SAs.
# Display brief information about the current IKE SAs.
<Sysname> display ike sa
total phase-1 SAs: 1
connection-id peer flag phase doi
1 202.38.0.2 RD|ST 1 IPSEC
2 202.38.0.2 RD|ST 2 IPSEC
flag meaning
RD--READY ST--STAYALIVE RL--REPLACED FD—FADING TO—TIMEOUT
Table 13 Command output
total phase-1 SAs |
Total number of SAs for phase 1. |
connection-id |
Identifier of the ISAKMP SA. |
peer |
Remote IP address of the SA. |
flag |
Status of the SA: · RD (READY)—The SA has been established. · ST (STAYALIVE)—This end is the initiator of the tunnel negotiation. · RL (REPLACED)—The tunnel has been replaced by a new one and will be deleted later. · FD (FADING)—The soft lifetime is over but the tunnel is still in use. The tunnel will be deleted when the hard lifetime is over. · TO (TIMEOUT)—The SA has received no keepalive packets after the last keepalive timeout. If no keepalive packets are received before the next keepalive timeout, the SA will be deleted. |
phase |
The phase the SA belongs to: · Phase 1—The phase for establishing the ISAKMP SA. · Phase 2—The phase for negotiating the security service. IPsec SAs are established in this phase. |
doi |
Interpretation domain the SA belongs to. |
# Display detailed information about the current IKE SAs.
<Sysname> display ike sa verbose
connection id: 2
vpn-instance: 1
transmitting entity: initiator
local ip: 4.4.4.4
local id type: IPV4_ADDR
local id: 4.4.4.4
remote ip: 4.4.4.5
remote id type: IPV4_ADDR
remote id: 4.4.4.5
authentication-method: PRE-SHARED-KEY
authentication-algorithm: HASH-SHA1
encryption-algorithm: DES-CBC
life duration(sec): 86400
remaining key duration(sec): 86379
exchange-mode: MAIN
diffie-hellman group: GROUP1
nat traversal: NO
# Display detailed information about the IKE SA with the connection ID of 2.
<Sysname> display ike sa verbose connection-id 2
connection id: 2
vpn-instance: vpn1
local ip: 4.4.4.4
local id: 4.4.4.4
remote ip: 4.4.4.5
remote id: 4.4.4.5
remaining key duration(sec): 82480
exchange-mode: MAIN
nat traversal: NO
# Display detailed information about the IKE SA with the remote address of 4.4.4.5.
<Sysname> display ike sa verbose remote-address 4.4.4.5
connection id: 2
vpn-instance: vpn1
local ip: 4.4.4.4
local id: 4.4.4.4
remote ip: 4.4.4.5
remote id: 4.4.4.5
remaining key duration(sec): 82236
exchange-mode: MAIN
nat traversal: NO
Table 14 Command output
connection id |
vpn-instance |
VPN that the protected data belongs to. |
transmitting entity |
Entity in the IKE negotiation. |
local ip |
IP address of the local gateway. |
local id type |
Identifier type of the local gateway. |
local id |
Identifier of the local gateway. |
remote ip |
IP address of the remote gateway. |
remote id type |
Identifier type of the remote gateway. |
remote id |
Identifier of the remote security gateway. |
authentication-method |
authentication-algorithm |
encryption-algorithm |
life duration(sec) |
Lifetime of the ISAKMP SA in seconds. |
remaining key duration(sec) |
Remaining lifetime of the ISAKMP SA in seconds. |
exchange-mode |
diffie-hellman group |
DH group used for key negotiation in IKE phase 1. |
nat traversal |
· ike proposal
· ike peer
dpd
Use dpd to apply a DPD detector to an IKE peer.
Use undo dpd to remove the application.
dpd dpd-name
undo dpd
No DPD detector is applied to an IKE peer.
IKE peer view
2: System level
dpd-name: DPD detector name, a string of 1 to 32 characters.
# Apply dpd1 to IKE peer peer1.
[Sysname-ike-peer-peer1] dpd dpd1
Use encryption-algorithm to specify an encryption algorithm for an IKE proposal.
Use undo encryption-algorithm to restore the default.
encryption-algorithm { aes-cbc [ key-length ] | des-cbc }
An IKE proposal uses the 56-bit DES encryption algorithm in CBC mode.
IKE proposal view
2: System level
aes-cbc: Uses the AES algorithm in CBC mode as the encryption algorithm. The AES algorithm uses 128-bit, 192-bit, or 256-bit keys for encryption.
key-length: Key length for the AES algorithm, which can be 128, 192 or 256 bits and is defaulted to 128 bits.
des-cbc: Uses the DES algorithm in CBC mode as the encryption algorithm. The DES algorithm uses 56-bit keys for encryption.
# Use 56-bit DES in CBC mode as the encryption algorithm for IKE proposal 10.
[Sysname-ike-proposal-10] encryption-algorithm des-cbc
· ike proposal
exchange-mode
Use exchange-mode to select an IKE negotiation mode.
Use undo exchange-mode to restore the default.
exchange-mode { aggressive | main }
undo exchange-mode
Main mode is used.
IKE peer view
2: System level
aggressive: Aggressive mode.
main: Main mode.
When the user (for example, a dial-up user) at the remote end of an IPsec tunnel obtains an IP address automatically and pre-shared key authentication is used, H3C recommends setting the IKE negotiation mode to aggressive at the local end.
# Specify that IKE negotiation operates in main mode.
[Sysname-ike-peer-peer1] exchange-mode main
id-type
id-type
Use id-type to select the type of the ID for IKE negotiation.
Use undo id-type to restore the default.
id-type { ip | name | user-fqdn }
undo id-type
The ID type is IP address.
IKE peer view
2: System level
ip: Uses an IP address as the ID during IKE negotiation.
name: Uses a name of the Fully Qualified Domain Name (FQDN) type as the ID during IKE negotiation.
user-fqdn: Uses a name of the user FQDN type as the ID during IKE negotiation.
In main mode, only the ID type of IP address can be used in IKE negotiation and SA creation. In aggressive mode, either type can be used.
If the ID type of FQDN is used, configure a name without any at sign (@) for the local security gateway, for example, foo.bar.com. If the ID type of user FQDN is used, configure a name with an at sign (@) for the local security gateway, for example, test@foo.bar.com.
# Use the ID type of name during IKE negotiation.
[Sysname-ike-peer-peer1] id-type name
· local-name
· ike local-name
· remote-name
· remote-address
· local-address
· exchange-mode
ike dpd
Use ike dpd to create a DPD detector and enter IKE DPD view.
Use undo ike dpd to remove a DPD detector.
ike dpd dpd-name
undo ike dpd dpd-name
2: System level
dpd-name: Name for the DPD detector, a string of 1 to 32 characters.
DPD irregularly detects dead IKE peers. It works as follows:
1. When the local end sends an IPsec packet, it checks the time the last IPsec packet was received from the peer.
2. If the time interval exceeds the DPD interval, it sends a DPD hello to the peer.
3. If the local end receives no DPD acknowledgement within the DPD packet retransmission interval, it retransmits the DPD hello.
4. If the local end still receives no DPD acknowledgement after having made the maximum number of retransmission attempts (two by default), it considers the peer already dead, and clears the IKE SA and the IPsec SAs based on the IKE SA.
DPD enables an IKE entity to check the liveliness of its peer only when necessary. It generates less traffic than the keepalive mechanism, which exchanges messages periodically.
# Create a DPD detector named dpd2.
[Sysname] ike dpd dpd2
· display ike dpd
· interval-time
· time-out
ike local-name
Use ike local-name to configure a name for the local security gateway.
Use undo ike local-name to restore the default.
ike local-name name
undo ike local-name
The device name is used as the name of the local security gateway.
Default command level
2: System level
name: Name of the local security gateway for IKE negotiation, a case-sensitive string of 1 to 32 characters.
If you configure the id-type name or id-type user-fqdn command on the initiator, the IKE negotiation peer uses the security gateway name as its ID to initiate IKE negotiation, and you must configure the ike local-name command in system view or the local-name command in IKE peer view on the local device. If you configure both the ike local-name command and the local-name command, the name configured by the local-name command is used.
The IKE negotiation initiator sends its security gateway name as its ID to the peer, and the peer uses the security gateway name configured with the remote-name command to authenticate the initiator. Make sure the local gateway name matches the remote gateway name configured on the peer.
# Configure the local security gateway name as app.
[Sysname] ike local-name app
· remote-name
· id-type
ike next-payload check disabled
Use ike next-payload check disabled to disable the checking of the Next payload field in the last payload of an IKE message during IKE negotiation, gaining interoperation with products assigning the field a value other than zero.
Use undo ike next-payload check disabled to restore the default.
The Next payload field is checked.
2: System level
# Disable Next payload field checking for the last payload of an IKE message.
[Sysname] ike next-payload check disabled
ike peer (system view)
Use ike peer to create an IKE peer and enter IKE peer view.
Use undo ike peer to delete an IKE peer.
ike peer peer-name
undo ike peer peer-name
2: System level
# Create an IKE peer named peer1 and enter IKE peer view.
ike proposal
Use ike proposal to create an IKE proposal and enter IKE proposal view.
Use undo ike proposal to delete an IKE proposal.
ike proposal proposal-number
undo ike proposal proposal-number
2: System level
proposal-number: IKE proposal number, in the range 1 to 65535. The lower the number, the higher the priority of the IKE proposal. During IKE negotiation, a high priority IKE proposal is matched before a low priority IKE proposal.
The system provides a default IKE proposal, which has the lowest priority and uses these settings:
· Encryption algorithm DES-CBC
· Authentication algorithm HMAC-SHA1
· Authentication method Pre-shared key
· DH group MODP_768
· SA lifetime 86400 seconds
# Create IKE proposal 10 and enter IKE proposal view.
ike sa keepalive-timer interval
Use ike sa keepalive-timer interval to set the ISAKMP SA keepalive interval.
Use undo ike sa keepalive-timer interval to disable the ISAKMP SA keepalive transmission function.
ike sa keepalive-timer interval seconds
No keepalive packet is sent.
2: System level
seconds: Transmission interval of ISAKMP SA keepalives in seconds, in the range 20 to 28,800.
The keepalive interval configured at the local end must be shorter than the keepalive timeout configured at the remote end.
# Set the keepalive interval to 200 seconds.
[Sysname] ike sa keepalive-timer interval 200
ike sa keepalive-timer timeout
Use ike sa keepalive-timer timeout to set the ISAKMP SA keepalive timeout.
Use undo ike sa keepalive-timer timeout to disable the function.
ike sa keepalive-timer timeout seconds
2: System level
seconds: ISAKMP SA keepalive timeout in seconds, in the range 20 to 28,800.
The keepalive timeout configured at the local end must be longer than the keepalive interval configured at the remote end. Since it seldom occurs that more than three consecutive packets are lost on a network, the keepalive timeout can be configured to be three times of the keepalive interval.
# Set the keepalive timeout to 20 seconds.
[Sysname] ike sa keepalive-timer timeout 20
ike sa nat-keepalive-timer interval
Use ike sa nat-keepalive-timer interval to set the NAT keepalive interval.
Use undo ike sa nat-keepalive-timer interval to disable the function.
ike sa nat-keepalive-timer interval seconds
The NAT keepalive interval is 20 seconds.
2: System level
seconds: NAT keepalive interval in seconds, in the range 5 to 300.
# Set the NAT keepalive interval to 5 seconds.
[Sysname] ike sa nat-keepalive-timer interval 5
interval-time
Use interval-time to set the DPD query triggering interval for a DPD detector.
Use undo interval-time to restore the default.
interval-time interval-time
undo interval-time
The default DPD interval is 10 seconds.
IKE DPD view
2: System level
interval-time: Sets DPD interval in seconds, in the range of 1 to 300 seconds. When the local end sends an IPsec packet, it checks the time the last IPsec packet was received from the peer. If the time interval exceeds the DPD interval, it sends a DPD hello to the peer.
# Set the DPD interval to 1 second for dpd2.
[Sysname-ike-dpd-dpd2] interval-time 1
local
Use local to set the subnet type of the local security gateway for IKE negotiation.
Use undo local to restore the default.
local { multi-subnet | single-subnet }
undo local
The subnet is a single one.
IKE peer view
2: System level
multi-subnet: Sets the subnet type to multiple.
single-subnet: Sets the subnet type to single.
Use this command to enable interoperability with a NetScreen device.
# Set the subnet type of the local security gateway to multiple.
[Sysname] ike peer xhy
[Sysname-ike-peer-xhy] local multi-subnet
local-address
Use local-address to configure the IP address of the local security gateway in IKE negotiation.
Use undo local-address to remove the configuration.
local-address ip-address
undo local-address
The primary address of the interface referencing the IPsec policy is used as the local security gateway IP address for IKE negotiation. Use this command if you want to specify a different address for the local security gateway.
IKE peer view
2: System level
ip-address: IP address of the local security gateway to be used in IKE negotiation.
# Set the IP address of the local security gateway to 1.1.1.1.
[Sysname-ike-peer-xhy] local-address 1.1.1.1
local-name
Use local-name to configure a name for the local security gateway to be used in IKE negation.
Use undo local-name to restore the default.
local-name name
undo local-name
The device name is used as the name of the local security gateway view.
IKE peer view
2: System level
name: Name for the local security gateway to be used in IKE negotiation, a case-sensitive string of 1 to 32 characters.
# Set the name of the local security gateway to localgw in IKE peer view of peer1.
[Sysname-ike-peer-peer1] local-name localgw
· remote-name
· id-type
nat traversal
Use nat traversal to enable the NAT traversal function of IKE/IPsec.
Use undo nat traversal to disable the NAT traversal function of IKE/IPsec.
nat traversal
undo nat traversal
The NAT traversal function is disabled.
IKE peer view
2: System level
# Enable the NAT traversal function for IKE peer peer1.
[Sysname-ike-peer-peer1] nat traversal
peer
Use peer to set the subnet type of the peer security gateway for IKE negotiation.
Use undo peer to restore the default.
peer { multi-subnet | single-subnet }
undo peer
IKE peer view
2: System level
# Set the subnet type of the peer security gateway to multiple.
[Sysname-ike-peer-xhy] peer multi-subnet
pre-shared-key
Use pre-shared-key to configure the pre-shared key to be used in IKE negotiation.
Use undo pre-shared-key to remove the configuration.
pre-shared-key [ cipher | simple ] key
undo pre-shared-key
IKE peer view
2: System level
cipher: Sets a ciphertext pre-shared key.
simple: Sets a plaintext pre-shared key.
key: Specifies the key string. This argument is case sensitive. If cipher is specified, it must be a ciphertext string of 1 to 201 characters. If simple is specified, it must be a string of 1 to 128 characters. If neither cipher nor simple is specified, you set a plaintext key string.
# Set the pre-shared key used in IKE negotiation to plaintext string abcde.
[Sysname-ike-peer-peer1] pre-shared-key simple abcde
proposal (IKE peer view)
Use proposal to specify the IKE proposals for the IKE peer to reference.
Use undo proposal to remove one or all IKE proposals referenced by the IKE peer.
proposal proposal-number&<1-6>
undo proposal [ proposal-number ]
An IKE peer references no IKE proposals and, when initiating IKE negotiation, it uses the IKE proposals configured in system view.
IKE peer view
2: System level
proposal-number&<1-6>: Sequence number of the IKE proposal for the IKE peer to reference, in the range 1 to 65535. &<1-6> means that you can specify the proposal-number argument for up to six times. An IKE proposal with a smaller sequence number has a higher priority.
In the IKE negotiation phase 1, the local end uses the IKE proposals specified for it, if any.
An IKE peer can reference up to six IKE proposals.
The responder uses the IKE proposals configured in system view for negotiation.
# Configure IKE peer peer1 to reference IKE proposal 10.
[Sysname-ike-peer-peer1] proposal 10
· ike proposal
· ike peer (system view)
remote-address
Use remote-address to configure the IP address of the IPsec remote security gateway.
Use undo remote-address to remove the configuration.
remote-address { hostname [ dynamic ] | low-ip-address [ high-ip-address ] }
undo remote-address
IKE peer view
2: System level
hostname: Host name of the IPsec remote security gateway, a case-insensitive string of 1 to 255 characters. The host name uniquely identifies the remote IPsec peer and can be resolved to an IP address by the DNS server.
dynamic: Specifies to use dynamic address resolution for the IPsec remote peer name. If you do not provide this keyword, the local end has the remote host name resolved only once after you configure the remote host name.
low-ip-address: IP address of the IPsec remote security gateway. It is the lowest address in the address range if you want to specify a range of addresses.
high-ip-address: Highest address in the address range if you want to specify a range of addresses.
The IP address configured with the remote-address command must match the local security gateway IP address that the remote security gateway uses for IKE negotiation, which is the IP address configured with the local-address command or, if the local-address command is not configured, the primary IP address of the interface to which the policy is applied.
The local end can be the initiator of IKE negotiation if the remote address is a host IP address or a host name. The local end can only be the responder of IKE negotiation if the remote address is an address range that the local end can respond to.
If the IP address of the remote address changes frequently, configure the host name of the remote gateway with the dynamic keyword so that the local end can use the up-to-date remote IP address to initiate IKE negotiation.
· id-type ip
· local-address
# Configure the IP address of the remote security gateway as 10.0.0.1.
[Sysname-ike-peer-peer1] remote-address 10.0.0.1
# Configure the host name of the remote gateway as test.com, and specify the local end to dynamically update the remote IP address.
[Sysname] ike peer peer2
[Sysname-ike-peer-peer2] remote-address test.com dynamic
remote-name
Use remote-name to configure the name of the remote gateway.
Use undo remote-name to remove the configuration.
remote-name name
undo remote-name
IKE peer view
2: System level
name: Name of the peer security gateway for IKE negotiation, a string of 1 to 32 characters.
If you configure the id-type name or id-type user-fqdn command on the initiator, the IKE negotiation initiator sends its security gateway name as its ID for IKE negotiation, and the peer uses the security gateway name configured with the remote-name command to authenticate the initiator. Make sure the local gateway name matches the remote gateway name configured on the peer.
· id-type
· local-name
· ike local-name
# Configure the remote security gateway name as apple for IKE peer peer1.
[Sysname-ike-peer-peer1] remote-name apple
reset ike sa
Use reset ike sa to clear IKE SAs.
reset ike sa [ connection-id ]
2: System level
connection-id: Connection ID of the IKE SA to be cleared, in the range 1 to 2000000000.
If you do not specify any parameter, the command clears all ISAKMP SAs.
When you clear a local IPsec SA, its ISAKMP SA can transmit the Delete message to notify the remote end to delete the paired IPsec SA. If the ISAKMP SA has been cleared, the local end cannot notify the remote end to clear the paired IPsec SA, and you must manually clear the remote IPsec SA.
# Clear the IKE SA that uses connection ID 2.
flag meaning
RD--READY ST--STAYALIVE RL--REPLACED FD—FADING TO--TIMEOUT
<Sysname> reset ike sa 2
flag meaning
display ike sa
sa duration
Use sa duration to set the ISAKMP SA lifetime for an IKE proposal.
sa duration seconds
undo sa duration
The ISAKMP SA lifetime is 86400 seconds.
IKE proposal view
2: System level
Seconds: Specifies the ISAKMP SA lifetime in seconds, in the range 60 to 604800.
Before an SA expires, IKE negotiates a new SA. The new SA takes effect immediately after being set up, and the old one will be cleared automatically when it expires.
# Specify the ISAKMP SA lifetime for IKE proposal 10 as 600 seconds (10 minutes).
[Sysname-ike-proposal-10] sa duration 600
· ike proposal
time-out
Use time-out to set the DPD packet retransmission interval for a DPD detector.
Use undo time-out to restore the default.
time-out time-out
undo time-out
IKE DPD view
2: System level
time-out: DPD packet retransmission interval in seconds, in the range 1 to 60.
The default DPD packet retransmission interval is 5 seconds.
# Set the DPD packet retransmission interval to 1 second for dpd2.
[Sysname-ike-dpd-dpd2] time-out 1
