06-PKI Commands | 152.15 KB |
display pki certificate access-control-policy
display pki certificate attribute-group
pki request-certificate domain
attribute
Use attributeto configure the attribute rules of the certificate issuer name, certificate subject name and alternative certificate subject name.
Use undo attributeto delete the attribute rules of one or all certificates.
attributeid { alt-subject-name { fqdn | ip } | { issuer-name | subject-name} { dn | fqdn | ip } } { ctn | equ | nctn | nequ} attribute-value
undo attribute { id | all }
No restriction exists on the issuer name, subject name, and alternative subject name of a certificate.
Certificate attribute group view
Default command level
2: System level
id: Sequencenumber of the certificate attribute rule, in the range of 1 to 16.
alt-subject-name: Specifies the name of the alternative certificate subject.
fqdn: Specifies the FQDN of the entity.
ip: Specifies the IP address of the entity.
issuer-name: Specifies the name of the certificate issuer.
subject-name: Specifies the name of the certificate subject.
dn: Specifies the distinguishedname of the entity.
ctn: Specifies the contain operation.
equ: Specifies the equal operation.
nctn: Specifies the not-contain operation.
nequ: Specifies the not-equal operation.
attribute-value: Value of the certificate attribute, a case-insensitive string of 1 to 128 characters.
all: Specifies all certificate attributes.
The attribute of the alternative certificate subject name does not appear as a distinguished name, and therefore thednkeyword is not available for the attribute.
# Create a certificate attribute rule, specifyingthat the DNinthe subject name includes thestring of abc.
[Sysname] pki certificate attribute-group mygroup
[Sysname-pki-cert-attribute-group-mygroup] attribute1 subject-name dn ctnabc
# Create a certificate attribute rule, specifyingthat the FQDN inthe issuer name cannotbe the string of abc.
[Sysname-pki-cert-attribute-group-mygroup] attribute2issuer-name fqdn nequabc
# Create a certificate attribute rule, specifying that the IP address inthe alternative subject name cannot be 10.0.0.1.
[Sysname-pki-cert-attribute-group-mygroup] attribute 3alt-subject-name ip nequ 10.0.0.1
ca identifier
Use ca identifier to specify the trusted CA and bind the device with the CA.
Use undo ca identifier to remove the configuration.
ca identifiername
undo ca identifier
No trusted CA is specified for a PKI domain.
PKI domain view
2: System level
name: Nameof the trusted CA,a case-sensitive string of 1 to 63 characters.
Certificate request, retrieval, revocation, and querydepend on the trusted CA.
# Specify the trusted CA as new-ca.
[Sysname]pki domain 1
[Sysname-pki-domain-1]ca identifier new-ca
certificate request entity
Use certificate request entityto specify the entity for certificate request.
Use undo certificate request entityto remove the configuration.
certificate request entityentity-name
undocertificate request entity
No entity is specified for certificate request.
PKI domain view
2: System level
entity-name: Name of the entity for certificate request, a case-insensitive string of 1 to 15 characters.
# Specify the entity for certificate request as entity1.
[Sysname-pki-domain-1] certificate request entity entity1
pki entity
certificate request from
Use certificate request from to specify the authority for certificate request.
Use undocertificate request from to remove the configuration.
certificate request from { ca | ra }
undo certificate request from
No authority is specified for certificate request.
PKI domain view
2: System level
ca: Indicates that the entity requests a certificate from a CA.
ra: Indicates that the entity requests a certificate from an RA.
# Specify that the entity requests a certificate from the CA.
[Sysname-pki-domain-1]certificaterequest from ca
certificate request mode
Use certificate request modeto set the certificate request mode.
Use undo certificate request modeto restore the default.
certificate request mode { auto[ key-length key-length| password {cipher |simple }password]*| manual}
Manual mode is used.
PKI domain view
2: System level
auto: Requests a certificate in auto mode.
key-length: Length of the RSA keys in bits, in the range of 512 to 2048. It is 1024 bits by default.
cipher: Setsaciphertext password for certificate revocation.
simple: Setsaplaintext password for certificate revocation.
password: Specifies the password string.This argument is case sensitive. If simple is specified, it must be a string of 1 to 31 characters. If cipher is specified, it must be a ciphertext string of 1 to 73 characters.
manual: Requests a certificate in manual mode.
In auto mode, an entity automatically requests a certificate from an RA or CA when it has no certificate. However,if the certificate will expire or has expired, the entity does not initiate a re-request automatically, in which case you need to request a new one manually. In manual mode, all operations associated with certificate request are performed manually.
For secrecy, all keys, including keys configured in plain text, are saved in cipher text.
# Specify to request a certificate in auto mode.
[Sysname-pki-domain-1]certificaterequest mode auto
certificate request polling
Use certificate request pollingto specify the certificate request polling interval and attempt limit.
Use undo certificate request pollingto restorethe defaults.
certificate request polling { countcount | intervalminutes}
undo certificate request polling { count| interval}
The polling is executed every 20 minutes for up to 50 times.
PKI domain view
2: System level
countcount: Specifies the maximum number of attempts to pollthe status of the certificate request, in the range of 1 to 100.
intervalminutes: Specifies the polling interval in minutes, in the range of 5 to 168.
After an applicantmakes a certificate request, the CA mightneed a long period of time if it verifies the certificate request manually. During this period, the applicant needs to query the status of the request periodically to get the certificate as soon as possible after the certificate is signed.
# Setthe polling interval to15 minutes and the maximum number of attemptsto40.
[Sysname-pki-domain-1]certificaterequest polling interval 15
[Sysname-pki-domain-1]certificaterequest polling count 40
certificate request url
Use certificate request urlto specify the URL of the server for certificate request through SCEP.
Use undo certificate request urlto remove the configuration.
certificate request urlurl-string
No URL is specified for a PKI domain.
PKI domain view
2: System level
url-string: URL of the server for certificate request, a case-insensitive string of 1 to 127 characters. It comprises the location of the server and the location of CGI command interface script in the format ofhttp://server_location/ca_script_location, whereserver_locationmust beanIP address and does not support domain name resolution.
# Specify the URL ofthe server for certificate request.
[Sysname-pki-domain-1]certificaterequest urlhttp://169.254.0.100/certsrv/mscep/mscep.dll
common-name
Use common-nameto configure the common name of an entity, which can be, for example, the user name.
Use undo common-name to remove the configuration.
common-name name
undo common-name
No common name is specified.
PKI entity view
2: System level
name: Common name of an entity, a case-insensitivestring of 1 to 31 characters. No comma can be included.
# Configure the common name of an entity as test.
[Sysname]pki entity 1
[Sysname-pki-entity-1]common-name test
country
Use country to specify the code of the country to which an entity belongs. It is a standard 2-character code, for example, CN for China.
Use undo country to remove the configuration.
country country-code-str
undo country
No country code is specified.
PKI entity view
2: System level
country-code-str: Country code for the entity, a 2-character case-insensitive string.
# Set the country code of an entityto CN.
[Sysname-pki-entity-1]country CN
crl check
Use crl check to enable or disable CRL checking.
crl check{ disable |enable}
CRL checking is enabled.
PKI domain view
2: System level
disable:Disables CRL checking.
enable:Enables CRL checking.
CRLsarefiles issued by the CA to publishallcertificatesthat have been revoked. Revocation of a certificate might occur before the certificate expires. CRL checking is intended for checking whether a certificate has been revoked. A revoked certificate is no longer trusted.
# Disable CRL checking.
[Sysname-pki-domain-1] crl check disable
crl update-period
Use crl update-periodto set the CRLupdate period, that is, the interval at which a PKI entity witha certificate downloadsthe latest CRL from the LDAP server.
Use undo crl update-periodto restore the default.
crl update-periodhours
The CRL update period depends on the next update field in the CRL file.
PKI domain view
2: System level
hours: CRL update period in hours, in the range of 1 to 720.
# Set the CRL update period to 20 hours.
[Sysname-pki-domain-1]crl update-period 20
crl url
Use crlurlto specify the URL ofthe CRLdistribution point.
Use undo crlurl to remove the configuration.
crlurl url-string
undo crlurl
No CRL distribution pointURL is specified.
PKI domain view
2: System level
url-string: URL of the CRL distribution point, a case-insensitive string of 1 to 125characters in the format of ldap://server_location or http://server_location,whereserver_locationmust bean IP addressora domain name.
When the URL of the CRL distribution point is not set, you should acquire the CA certificate and a local certificate, and then acquire a CRL through SCEP.
# Specify the URL of the CRL distribution point.
[Sysname-pki-domain-1]crl url ldap://169.254.0.30
Use display pki certificateto display the contents or request status of a certificate.
display pki certificate{{ca| local}domain domain-name| request-status } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ca: Displaysthe CA certificate.
local: Displaysthe local certificate.
domain-name: Name of the PKI domain, a string of 1 to 15 characters.
request-status: Displays the status of acertificate request.
|: Filters command output by specifying a regular expression. For more information about regular expressions, seeFundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the local certificate.
<Sysname>display pki certificate local domain 1
Certificate:
Data:
Version: 3 (0x2)
Serial Number:
10B7D4E3 00010000 0086
Signature Algorithm: md5WithRSAEncryption
Issuer:
emailAddress=myca@aabbcc.net
C=CN
ST=Country A
L=City X
O=abc
OU=bjs
CN=new-ca
Validity
Not Before: Jan 13 08:57:21 2013 GMT
Not After : Jan 20 09:07:21 2014GMT
Subject:
C=CN
ST=Country B
L=City Y
CN=pki test
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
RSA Public Key: (512 bit)
Modulus (512 bit):
00D41D1F …
Exponent: 65537 (0x10001)
X509v3 extensions:
X509v3 Subject Alternative Name:
DNS: hyf.xxyyzz.net
X509v3 CRL Distribution Points:
URI:http://1.1.1.1:447/myca.crl
A3A5A447 4D08387D …
Version |
Version of the certificate. |
Serial Number |
Serial number of the certificate. |
Signature Algorithm |
Signature algorithm. |
Issuer |
Issuer of the certificate. |
Validity |
Validity period of the certificate. |
Subject |
Entityholdingthe certificate. |
Subject Public Key Info |
Public key information of the entity. |
X509v3 extensions |
Extensions of the X.509 (version 3) certificate. |
X509v3 CRL Distribution Points |
Distribution points of X.509 (version 3) CRLs. |
· certificate request polling
· pki domain
· pki retrieval-certificate
Use display pki certificate access-control-policyto display information about one or all certificate attribute-based access control policies.
display pki certificate access-control-policy { policy-name | all } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
policy-name: Name of the certificate attribute-basedaccess control policy, a string of 1 to 16 characters.
all: Specifies all certificate attribute-basedaccess control policies.
# Display information aboutthe certificate attribute-basedaccess control policy named mypolicy.
<Sysname>display pki certificate access-control-policymypolicy
access-control-policy name: mypolicy
rule 1 deny mygroup1
rule 2 permit mygroup2
access-control-policy |
Name of thecertificate attribute-basedaccess control policy. |
rule number |
Number of the access control rule. |
Use display pki certificate attribute-groupto display information aboutone or all certificate attribute groups.
display pki certificate attribute-group { group-name| all } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
group-name: Name of a certificate attribute group, a string of 1 to 16 characters.
all: Specifies all certificate attribute groups.
# Display information aboutthe certificate attribute group mygroup.
<Sysname> display pki certificate attribute-group mygroup
attribute group name: mygroup
attribute 1 subject-name dn ctn abc
attribute 2 issuer-name fqdn nctn app
attribute group name |
Name of thecertificate attribute group. |
attribute number |
Number of the attribute rule. |
subject-name |
Name of the certificate subject. |
dn |
DNof the entity. |
ctn |
Contain operations. |
abc |
Value of attribute 1. |
issuer-name |
Name of the certificate issuer. |
fqdn |
FQDN of the entity. |
nctn |
Not-contain operations. |
app |
Value of attribute 2. |
display pki crl domain
Use display pki crl domainto display the locally saved CRLs.
display pki crldomaindomain-name [| { begin | exclude | include } regular-expression ]
1: Monitor level
domain-name: Name of thePKI domain, a string of 1 to 15 characters.
# Display the locally savedCRLs.
<Sysname>display pki crl domain 1
Certificate Revocation List (CRL):
Version 2 (0x1)
Signature Algorithm: sha1WithRSAEncryption
Issuer:
C=CN
O=abc
OU=soft
CN=A Test Root
Last Update: Jan 5 08:44:19 2004 GMT
Next Update: Jan 5 21:42:13 2004 GMT
CRL extensions:
X509v3 Authority Key Identifier:
keyid:0F71448E E075CAB8 ADDB3A12 0B747387 45D612EC
Revoked Certificates:
Serial Number:05a234448E…
Revocation Date: Sep612:33:22 2004 GMT
CRL entry extensions:…
Serial Number:05a278445E…
Revocation Date: Sep712:33:22 2004 GMT
Version |
Version of the CRL. |
Signature algorithm used bythe CRLs. |
Issuer |
CA issuing the CRLs. |
Last Update |
Last update time. |
Next Update |
Next update time. |
CRL extensions |
Extensions of CRL. |
X509v3Authority Key Identifier |
CA issuing the CRLs.The certificate version is X.509v3. |
keyid |
ID of the public key. A CA might have multiple key pairs. This field indicates the key pair used by the CRL's signature. |
Revoked Certificates |
Revoked certificates. |
Serial Number |
Serial number of therevoked certificate. |
Revocation Date |
Revocation date of the certificate. |
· pki domain
· pki retrieval-crl
fqdn
Use fqdnto configure the FQDN of an entity.
Use undo fqdn to remove the configuration.
fqdn name-str
undo fqdn
No FQDN is specified for an entity.
PKI entity view
2: System level
name-str: Fully qualified domain name (FQDN) of an entity, a case-insensitive string of 1 to 127 characters.
An FQDN is the unique identifier of an entity on a network. It consists of a host name and a domain name and can be resolved into an IP address.
# Configure the FQDN of an entity as pki.domain-name.com.
[Sysname-pki-entity-1]fqdn pki.domain-name.com
ip (PKI entity view)
Use ipto configure the IP address of an entity.
Use undo ip to remove the configuration.
ip ip-address
undo ip
No IP address is specified for an entity.
PKI entity view
2: System level
ip-address: IP address foran entity.
# Configure the IP address of an entity as 11.0.0.1.
[Sysname-pki-entity-1]ip 11.0.0.1
ldap-server
Use ldap-serverto specify an LDAP server for a PKI domain.
Use undo ldap-server to remove the configuration.
ldap-serveripip-address [ portport-number] [ versionversion-number]
undo ldap-server
No LDP server is specified for a PKI domain.
PKI domain view
2: System level
ip-address: IP address of the LDAP server,in dotted decimal format.
port-number: Port number of the LDAP server, in the rangeof 1 to 65535. Thedefault is 389.
version-number: LDAP version number, either2 or 3. The default is 2.
# Specify anLDAP server for PKI domain 1.
[Sysname-pki-domain-1]ldap-server ip 169.254.0.30
locality
Use localityto configure the geographical locality of an entity, which can be, for example, a city name.
Use undo localityto remove the configuration.
locality locality-name
undo locality
No geographical locality is specified for an entity.
PKI entity view
2: System level
locality-name: Name forthe geographical locality, a case-insensitive string of 1 to 31 characters. No comma can be included.
# Configure the locality of an entity as city.
[Sysname-pki-entity-1]locality city
organization
Use organizationto configure the name of the organization to which the entity belongs.
Use undo organization to remove the configuration.
organization org-name
undo organization
No organization name is specified for an entity.
PKI entity view
2: System level
org-name: Organization name, a case-insensitive string of 1 to 31 characters. No comma can be included.
# Configurethe name of the organization to which an entity belongs as test-lab.
[Sysname-pki-entity-1]organization test-lab
organization-unit
Use organization-unit to specify the name of the organization unit to which this entity belongs.
Use undo organization-unit to remove the configuration.
organization-unit org-unit-name
No organization unit name is specified for an entity.
PKI entity view
2: System level
org-unit-name: Organization unit name for distinguishing different units in an organization, a case-insensitive string of 1 to 31 characters. No comma can be included.
# Configure the name of the organization unit to which an entity belongs as group1.
[Sysname-pki-entity-1]organization-unit group1
Use pki certificate access-control-policyto create a certificate attribute-based access control policy and enter its view.
Use undo pki certificate access-control-policyto remove one or all certificate attribute-based access control policies.
pki certificate access-control-policypolicy-name
undo pki certificate access-control-policy {policy-name | all }
No access control policy exists by default.
2: System level
policy-name: Name of the certificate attribute-basedaccess control policy, a case-insensitive string of 1 to 16 characters.It cannot be"a", "al",or"all".
all: Specifies all certificate attribute-based access control policies.
# Configure an access control policy named mypolicy and enter its view.
[Sysname] pki certificate access-control-policymypolicy
[Sysname-pki-cert-acp-mypolicy]
Use pki certificate attribute-groupto create a certificate attribute group and enter its view.
Use undo pki certificate attribute-groupto delete one or all certificate attribute groups.
pki certificate attribute-group group-name
undo pki certificate attribute-group { group-name | all }
No certificate attribute group exists.
2: System level
group-name: Name for the certificate attribute group, a case-insensitive string of 1 to 16 characters.It cannot be"a", "al",or"all".
all: Specifies all certificate attributegroups.
# Create a certificate attribute group named mygroup and enter its view.
pki delete-certificate
Use pki delete-certificateto delete the certificatelocally stored for a PKI domain.
pki delete-certificate { ca | local} domain domain-name
2: System level
ca: Deletes the locally stored CA certificate.
local: Deletes the locally stored local certificate.
domain-name: Specifies aPKI domain by its name, a string of 1 to 15 characters.
# Delete the localcertificate forPKI domain cer.
[Sysname] pki delete-certificate local domain cer
pki domain
Use pki domain to create a PKI domain and enter PKI domain view or enter the view of an existing PKI domain.
Use undopki domainto remove a PKI domain.
pki domain domain-name
undo pki domain domain-name
No PKI domain exists.
Systemview
2: System level
domain-name: PKI domain name, a case-insensitive string of 1 to 15 characters.
You can create up to 32 PKI domains on a device.
# Create a PKI domain and enter its view.
pki entity
Use pki entity to create a PKI entity and enter its view.
Use undo pki entityto removea PKI entity.
pki entity entity-name
undo pki entityentity-name
No entity exists.
Systemview
2: System level
entity-name: Name for the entity, a case-insensitive string of 1 to 15 characters.
You can configure a variety of attributes for an entity in PKI entity view. An entity is intendedonly for convenience of reference by other commands.
#Create a PKI entity named en and enter its view.
[Sysname]pki entity en
[Sysname-pki-entity-en]
pki import-certificate
Use pki import-certificateto import a CA certificate or local certificate from a file and save it locally.
pki import-certificate { ca | local}domain domain-name{der|p12|pem}[filename filename ]
2: System level
ca: SpecifiestheCA certificate.
local: Specifiesthelocal certificate.
der: Specifies the certificate format ofDER.
p12: Specifies the certificate format ofP12.
pem: Specifies the certificate format ofPEM.
filenamefilename: Specifies the name of the certificate file to import, a case-insensitive string of 1 to 127 characters. If no file is specified, the system uses the default file name that is used when the certificate is retrieved, that is domain-name_ca.cer ordomain-name_local.cer.
# Import the CA certificate forPKI domain cer in the format ofPEM.
[Sysname] pki import-certificate cadomain cer pem
pki domain
Use pki request-certificate domainto request a local certificate from a CA through SCEP. If SCEP fails, you can use the pkcs10keyword to print the request information in BASE64 format, or use the pkcs10 filenamefilenameoption to save the request informationto a local file and send the file to the CA by an out-of-band means.
pki request-certificate domain domain-name [ password ] [ pkcs10[ filename filename]]
The retrieved certificate is stored in the root directory with the filename domain-name_ca.cer or domain-name_local.cer.
2: System level
domain-name: Name of the PKI domain name, a string of 1 to 15 characters.
password: Password for certificate revocation, a case-sensitive string of 1 to 31 characters.
pkcs10: Displays the BASE64-encoded PKCS#10 certificate request information, which can be used to request a certification by an out-of-band means, like phone, disk, or email.
filenamefilename: Specifies the name of the local file for saving the PKCS#10 certificate request, a case-insensitive string of 1 to 127 characters.
This operation willnot be saved inthe configuration file.
# Display the PKCS#10certificate request information.
[Sysname] pki request-certificate domain 1 pkcs10
-----BEGIN CERTIFICATE REQUEST-----
MIIBTDCBtgIBADANMQswCQYDVQQDEwJqajCBnzANBgkqhkiG9w0BAQEFAAOBjQAw
gYkCgYEAw5Drj8ofs9THA4ezkDcQPBy8pvH1kumampPsJmx8sGG52NFtbrDTnTT5
ALx3LJijB3d/ndKpcHT/DfbJVDCn5gdw32tBZyCkEwMHZN3ol2z7Nvdu5TED6iN8
4m+hfp1QWoV6lty3o9pxAXuQl8peUDcfN6WV3LBXYyl1WCtkLkECAwEAAaAAMA0G
CSqGSIb3DQEBBAUAA4GBAA8E7BaIdmT6NVCZgv/I/1tqZH3TS4e4H9Qo5NiCKiEw
R8owVmA0XVtGMbyqBNcDTG0f5NbHrXZQT5+MbFJOnm5K/mn1ro5TJKMTKV46PlCZ
JUjsugaY02GBY0BVcylpC9iIXLuXNIqjh1MBIqVsa1lQOHS7YMvnop6hXAQlkM4c
-----END CERTIFICATE REQUEST-----
pki domain
Use pki retrieval-certificate to retrieve a certificate from the server for certificate distribution.
pki retrieval-certificate {ca| local} domaindomain-name
2: System level
ca: RetrievestheCA certificate.
local: Retrievesthelocal certificate.
domain-name: Name of the PKI domain used for certificate request.
# Retrieve the CAcertificate from the certificate issuing server.
[Sysname] pki retrieval-certificate ca domain 1
pki domain
pki retrieval-crl domain
Use pki retrieval-crl domainto retrieve the latest CRLs from the server for CRL distribution.
pki retrieval-crl domaindomain-name
2: System level
CRLs help verify the validity of certificates.
# Retrieve CRLs.
[Sysname] pki retrieval-crl domain 1
pki domain
pki validate-certificate
Use pki validate-certificateto verify the validity of a certificate.
pki validate-certificate { ca| local} domaindomain-name
2: System level
ca: Verifies the CA certificate.
local: Verifies the local certificate.
domain-name: Name of the PKI domain to which the certificate to be verifiedbelongs, a string of 1 to 15 characters.
The focus of certificate validity verification will check that the certificate is signed by the CAand that the certificate has neither expirednorbeen revoked.
# Verify the validity of thelocal certificate.
[Sysname] pki validate-certificatelocal domain 1
pki domain
root-certificate fingerprint
Use root-certificate fingerprintto configure the fingerprint to be used for verifying the validity of the CA root certificate.
Use undo root-certificate fingerprintto remove the configuration.
root-certificate fingerprint{ md5 | sha1 } string
No fingerprint is configured for verifying the validity of the CA root certificate.
PKI domain view
2: System level
md5: Usesan MD5 fingerprint.
sha1: Usesa SHA1 fingerprint.
string: Fingerprint to be used. An MD5 fingerprint must be a string of 32 characters in hexadecimal. ASHA1 fingerprint must be a stringof 40 characters in hexadecimal.
# Configure an MD5 fingerprint for verifying the validity ofthe CA root certificate.
[Sysname-pki-domain-1] root-certificate fingerprint md5 12EF53FA355CD23E12EF53FA355CD23E
# Configure a SHA1 fingerprint for verifying the validity ofthe CA root certificate.
[Sysname-pki-domain-1] root-certificate fingerprint sha1 D1526110AAD7527FB093ED7FC037B0B3CDDDAD93
rule (PKI CERT ACP view)
Use ruleto create a certificate attributeaccess control rule.
Use undo ruleto delete one or all access control rules.
rule [id ] {deny | permit} group-name
undo rule {id| all }
No access control rule exists.
PKI certificate access control policy view
2: System level
id: Number of the certificate attribute access control rule, in the range of 1 to 16. The default is the smallestunused number in this range.
deny: Indicates that acertificate whose attributes match an attribute rule in the specified attribute groupis considered invalid and denied.
permit: Indicates that a certificate whose attributes match an attribute rule in the specified attribute groupis considered valid and permitted.
group-name: Name of the certificate attribute group to be associated with the rule, a case-insensitive string of 1 to 16 characters.It cannot be"a", "al",or"all".
all: Specifies all access control rules.
Acertificate attribute group must exist to be associated with a rule.
# Create an access control rule, specifying that a certificate is considered valid when it matchesan attribute rule in the certificateattribute group mygroup.
[Sysname-pki-cert-acp-mypolicy] rule 1 permit mygroup
signature-algorithm
Use signature-algorithmto specify the certificatesignature algorithm.
Use undo signature-algorithmto restore the default.
signature-algorithm { ecdsa | rsa }
The RSA algorithm is used as the certificatesignature algorithm.
PKI domain view
2: System level
ecdsa: Uses ECDSA as the certificate signature algorithm.
rsa: Uses RSA as the certificate signature algorithm.
# Specify to use the ECDSA algorithm as the certificate signature algorithm.
[Sysname] pki domain 1
[Sysname-pki-domain-1] signature-algorithm ecdsa
state
Use state to specify the name of the state or province where an entity resides.
Use undo stateto remove the configuration.
state state-name
undo state
No state or province is specified.
PKI entity view
2: System level
state-name: State or province name,a case-insensitive string of 1 to 31 characters. No comma can be included.
# Specify the state where an entity resides.
[Sysname-pki-entity-1]state country
