07-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesS9500E SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guides-Release1828P04-6W18207-Layer 3 - IP Routing Configuration Guide
15-Routing Policy Configuration
15-Routing Policy Configuration 195.27 KB
Routing policy in this chapter involves both IPv4 routing policy and IPv6 routing policy.
Introduction to routing policy
A routing policy is used to filter routes when they are received, advertised, or redistributed and modify the attributes of some routes.
Routing policy application
A routing policy has the following applications:
·     Filter advertised routes.
·     Filter received routes.
·     Filter redistributed routes.
·     Modify or set the attributes of some routes.
Routing policy implementation
To configure a routing policy, you must do the following:
1.     Define some filters based on the attributes of routing information, such as destination address, and the advertising router's address.
2.     Then apply the filters to the routing policy.
You can use multiple filters flexibly to define match criteria. For detailed information, see "Filters."
Filters
There are several types of filters: ACL, IP prefix list, AS path list, community list, extended community list, and routing policy.
ACL
ACL involves IPv4 ACL and IPv6 ACL. An ACL is configured to match the destinations or next hops of routing information.
For more information about ACL, see ACL and QoS Configuration Guide.
IP prefix list
IP prefix list involves IPv4 prefix list and IPv6 prefix list.
An IP prefix list is configured to match the destination address of routing information. Moreover, you can use the gateway option to allow only routing information from certain routers to be received. For gateway option information, see Layer 3—IP Routing Command Reference.
An IP prefix list, identified by name, can comprise multiple items. Each item, identified by an index number, can specify a prefix range to match. An item with a smaller index number is matched first. If one item is matched, the IP prefix list is passed, and the packet will not go to the next item.
AS path list
An AS path list, configured based on the BGP AS_PATH attribute, can only be used to match BGP routing information.
For more information about AS path list, see "Configuring BGP."
Community list
A community list, configured based on the BGP COMMUNITY attribute, can only be used to match BGP routing information.
For more information about community list, see "Configuring BGP."
Extended community list
An extended community list, configured based on the BGP extended community attribute (Route-Target for VPN and Source of Origin), can only be used to match BGP routing information.
For more information about extended community list, see MPLS Configuration Guide.
Routing policy
A routing policy is used to match routing information and to modify the attributes of permitted routes. It can reference the previously mentioned filters to define its own match criteria.
A routing policy can comprise multiple nodes, which are in a logical OR relationship. Each routing policy node is a match unit, and a node with a smaller number is matched first. Once a node is matched, the routing policy is passed and the packet will not go to the next node.
A routing policy node comprises a set of if-match, apply, and continue clauses:
·     The if-match clauses define the match criteria. The matching objects are some attributes of routing information. The if-match clauses of a routing policy node is in a logical AND relationship. That is, a packet must match all the if-match clauses of the node to pass it.
·     The apply clauses of the node specify the actions to be taken on the permitted packets, such as route attribute modification.
·     The continue clause specifies the next policy node to be matched. With this clause configured, when a route matches the current policy node, it continues to match against the specified next node in the same routing policy. The continue clause thus combines the if-match and apply clauses of the two nodes to improve flexibility of the routing policy.
When you configure if-match, apply, and continue clauses, follow these guidelines:
·     If you want to implement route filtering only, you do not need to configure apply clauses.
·     If you do not configure any if-match clauses for a permit-mode node, the node permits all routes to pass.
·     Configure a permit-mode node containing no if-match or apply clauses behind multiple deny-mode nodes to allow unmatched routes to pass.
Defining filters
Configuration prerequisites
Before you configure this task, you must determine the following items:
·     IP prefix list name
·     Matching address range
·     Extcommunity list sequence number
Defining an IP prefix list
Defining an IPv4 prefix list
Identified by name, an IPv4 prefix list can comprise multiple items. Each item specifies a prefix range to match, and is identified by an index number.
An item with a smaller index number is matched first. If one item is matched, the IP prefix list is passed, and the routing information will not go to the next item.
To define an IPv4 prefix list:
Step
Remarks
N/A
2.     Define an IPv4 prefix list.
ip ip-prefix ip-prefix-name [ index index-number ] { deny | permit } ip-address mask-length [ greater-equal min-mask-length ] [ less-equal max-mask-length ]
Not defined by default.
If all the items are set to the deny mode, no routes can pass the IPv4 prefix list. Therefore, H3C recommends defining the permit 0.0.0.0 0 less-equal 32 item following multiple deny items to allow other IPv4 routing information to pass.
For example, the following configuration filters routes 10.1.0.0/16, 10.2.0.0/16, and 10.3.0.0/16, but allows other routes to pass.
[Sysname] ip ipv6-prefix abc index 10 deny 10.1.0.0 16
[Sysname] ip ipv6-prefix abc index 20 deny 10.2.0.0 16
[Sysname] ip ipv6-prefix abc index 30 deny 10.3.0.0 16
[Sysname] ip ipv6-prefix abc index 40 permit 0.0.0.0 0 less-equal 32
Defining an IPv6 prefix list
Identified by name, each IPv6 prefix list can comprise multiple items. Each item specifies a prefix range to match, and is identified by an index number.
An item with a smaller index number is matched first. If one item is matched, the IPv6 prefix list is passed, and the routing information will not go to the next item.
To define an IPv6 prefix list:
Step
Remarks
N/A
2.     Define an IPv6 prefix list.
ip ipv6-prefix ipv6-prefix-name [ index index-number ] { deny | permit } ipv6-address prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ]
If all items are set to the deny mode, no routes can pass the IPv6 prefix list. H3C recommends defining the permit :: 0 less-equal 128 item following multiple deny items to allow other IPv6 routing information to pass.
For example, the following configuration filters routes 2000:1::/48, 2000:2::/48, and 2000:3::/48, but allows other routes to pass.
[Sysname] ip ip-prefix abc index 10 deny 2000:1:: 48
[Sysname] ip ip-prefix abc index 20 deny 2000:2:: 48
[Sysname] ip ip-prefix abc index 30 deny 2000:3:: 48
[Sysname] ip ip-prefix abc index 40 permit :: 0 less-equal 128
Defining an AS path list
You can define multiple items for an AS path list that is identified by number. The relationship between items is logical OR. If a route matches one of these items, it passes the AS path list.
To define an AS path list:
Step
Remarks
N/A
2.     Define an AS path list.
ip as-path as-path-number { deny | permit } regular-expression
Defining a community list
You can define multiple items for a community list that is identified by number. During matching, the relationship between items is logic OR. If routing information matches one of these items, it passes the community list.
To define a community list:
Step
Remarks
N/A
2.     Define a community list.
·     Define a basic community list:
ip community-list { basic-comm-list-num | basic comm-list-name } { deny | permit } [ community-number-list ] [ internet | no-advertise | no-export | no-export-subconfed ] *
·     Define an advanced community list:
ip community-list { adv-comm-list-num | advanced comm-list-name } { deny | permit } regular-expression
Use either method.
Defining an extended community list
You can define multiple items for an extended community list that is identified by number. During matching, the relationship between items is logic OR. If routing information matches one of these items, it passes the extended community list.
To define an extended community list:
Step
Remarks
N/A
2.     Define an extended community list.
ip extcommunity-list ext-comm-list-number { deny | permit } { rt route-target | soo site-of-origin }&<1-16>
Configuring a routing policy
A routing policy is used to filter routing information and modify attributes of matching routing information. The match criteria of a routing policy can be configured by referencing filters mentioned in the previous sections.
A routing policy can comprise multiple nodes, and each routing policy node can contain the following clauses:
·     if-match clauses—Define the criteria that routing information must match. The matching objects are some attributes of routing information.
·     apply clauses—Specify the actions to be taken on routing information that has matched the criteria, such as route attribute modification.
·     continue clauses—Specify the next routing policy node to be matched. With this clause configured, when a route matches the current routing policy node, it continues to match against the specified next node in the same routing policy.
Before you configure this task, you must configure the following:
·     Filters
·     Routing protocols
You must also decide on the following:
·     Name of the routing policy and node numbers
·     Match criteria
·     Attributes to be modified
Creating a routing policy
Follow these guidelines when you create a routing policy:
·     If a routing policy node has the permit keyword specified, routing information matching all the if-match clauses of the node is handled using the apply clauses of this node, without needing to match against the next node. If routing information does not match the node, it goes to the next node for a match.
·     If a routing policy node has the deny keyword specified, the apply clauses of the node are not executed. When routing information matches all the if-match clauses of the node, it cannot pass the node, or go to the next node. If route information cannot match all the if-match clauses of the node, it goes to the next node for a match.
·     When a routing policy has more than one node, configure at least one node with the permit keyword. If the routing policy is used to filter routing information, routing information that does not meet any node cannot pass the routing policy. If all nodes of the routing policy are set with the deny keyword, no routing information can pass it.
To create a routing policy:
Step
Remarks
N/A
2.     Create a routing policy, specify a node for it, and enter routing policy view.
By default, no routing policy is created.
Defining if-match clauses
Follow these guidelines when you define if-match clauses for a routing policy:
·     The if-match clauses of a routing policy node are in a logical AND relationship. Routing information must match all of its if-match clauses before being executed with its apply clauses. If an if-match command exceeds the maximum length, multiple identical if-match clauses are generated. These clauses are in logical OR relationship. Routing information only needs to match one of them.
·     You can specify no or multiple if-match clauses for a routing policy node. If no if-match clause is specified, and the routing policy node is in permit mode, all routing information can pass the node. If it is in deny mode, no routing information can pass it.
·     If the ACL referenced by an if-match clause does not exist, the clause is always matched; if no rules of the referenced ACL are matched or the matching rule is inactive, the clause is not matched.
·     An ACL specified in an if-match clause must be a non-VPN ACL.
·     The if-match commands for matching an IPv4 destination, next hop, and source address are different from those for matching IPv6 ones.
·     BGP does not support criteria for matching against outbound interfaces of routing information.
To define if-match clauses for a routing policy:
Step
Remarks
N/A
2.     Enter routing policy view.
N/A
3.     Define match criteria for IPv4 routes.
·     Match IPv4 routing information specified in the ACL:
if-match acl acl-number
·     Match IPv4 routing information specified in the IP prefix list:
if-match ip-prefix ip-prefix-name
·     Match IPv4 routing information whose next hop or source is specified in the ACL or IP prefix list:
if-match ip { next-hop | route-source } { acl acl-number | ip-prefix ip-prefix-name }
Optional.
Not configured by default.
4.     Match IPv6 routing information whose next hop or source is specified in the ACL or IP prefix list.
if-match ipv6 { address | next-hop | route-source } { acl acl-number | prefix-list ipv6-prefix-name }
Optional.
5.     Match BGP routing information whose AS path attribute is specified in the AS path lists.
if-match as-path AS-PATH-number&<1-16>
Optional.
6.     Match BGP routing information whose COMMUNITY attribute is specified in the community lists.
if-match community { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }&<1-16>
Optional.
7.     Match routes having the specified cost.
if-match cost value
Optional.
8.     Match BGP routing information whose extended community attribute is specified in the extended community lists.
if-match extcommunity ext-comm-list-number&<1-16>
Optional.
9.     Match routing information having specified outbound interfaces.
Optional.
10.     Match routing information having MPLS labels.
if-match mpls-label
Optional.
11.     Match routing information having the specified route type.
if-match route-type { external-type1 | external-type1or2 | external-type2 | internal | is-is-level-1 | is-is-level-2 | nssa-external-type1 | nssa-external-type1or2 | nssa-external-type2 } *
Optional.
12.     Match RIP, OSPF, and IS-IS routing information having the specified tag value.
if-match tag value
Optional.
Defining apply clauses
The difference between IPv4 and IPv6 apply clauses is the command for setting the next hop for routing information.
To define apply clauses:
Step
Remarks
N/A
Not created by default.
3.     Set the AS_PATH attribute for BGP routing information.
apply as-path as-number&<1-10> [ replace ]
Optional.
Not set by default.
4.     Delete the COMMUNITY attribute of BGP routing information using the community list.
Optional.
5.     Set the COMMUNITY attribute for BGP routing information.
apply community { none | additive | { community-number&<1-16> | aa:nn&<1-16> | internet | no-advertise | no-export | no-export-subconfed } * [ additive ] }
Optional.
Not set by default.
6.     Set a cost for routing information.
apply cost [ + | - ] value
Optional.
Not set by default.
7.     Set a cost type for routing information.
apply cost-type [ external | internal | type-1 | type-2 ]
Optional.
Not set by default.
8.     Set the extended community attribute for BGP routing.
apply extcommunity { { rt route-target }&<1-16> [ additive ] | soo site-of-origin additive }
Optional.
Not set by default.
9.     Set the next hop.
·     Set the next hop and specify the VPN instance of the next hop for IPv4 routes:
apply ip-address next-hop ip-address [ vpn-instance vpn-instance-name | public ]
·     Set the next hop for IPv6 routes:
Optional.
Not set by default.
The apply ip-address next-hop and apply ipv6 next-hop commands do not apply to redistributed IPv4 and IPv6 routes.
10.     Inject routing information to a specified ISIS level.
Optional.
11.     Set the local preference for BGP routing information.
Optional.
Not set by default.
12.     Set MPLS label.
apply mpls-label
Optional.
Not set by default.
13.     Set the origin attribute for BGP routing information.
Optional.
Not set by default.
14.     Set the preference for the routing protocol.
apply preference preference
Optional.
Not set by default.
15.     Set a preferred value for BGP routing information.
Optional.
Not set by default.
16.     Set a tag value for RIP, OSPF or IS-IS routing information.
apply tag value
Optional.
Not set by default.
17.     Configure FRR.
Optional.
Defining a continue clause
Follow these guidelines when you define a continue clause:
·     If you configure the same type of apply clauses that set different values (including the apply community and apply extcommunity clauses with the additive keyword) on nodes that are combined by the continue clause, the apply clause configured on the last matching node takes effect.
·     If you configure the apply community clause for multiple nodes that are combined by the continue clause, the apply comm-list delete clause configured on the current node cannot delete the COMMUNITY attributes of preceding nodes.
To define a continue clause:
Step
Remarks
N/A
2.     Create a routing policy and enter routing policy view.
3.     Specify the next policy node to be matched.
continue [ node-number ]
Optional.
The node number specified must be larger than the current node number.
Displaying and maintaining the routing policy
Remarks
Display BGP AS path list information.
display ip as-path [ as-path-number ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display BGP community list information.
display ip community-list [ basic-community-list-number | adv-community-list-number | comm-list-name ] [ | { begin | exclude | include } regular-expression ]
Display BGP extended community list information.
display ip extcommunity-list [ ext-comm-list-number ] [ | { begin | exclude | include } regular-expression ]
Display IPv4 prefix list statistics.
display ip ip-prefix [ ip-prefix-name ] [ | { begin | exclude | include } regular-expression ]
Display IPv6 prefix list statistics.
display ip ipv6-prefix [ ipv6-prefix-name ] [ | { begin | exclude | include } regular-expression ]
Display routing policy information.
display route-policy [ route-policy-name ] [ | { begin | exclude | include } regular-expression ]
Clear IPv4 prefix list statistics.
reset ip ip-prefix [ ip-prefix-name ]
Available in user view.
Clear IPv6 prefix list statistics.
reset ip ipv6-prefix [ ipv6-prefix-name ]
Routing policy configuration examples
By default, Ethernet, VLAN, and aggregate interfaces are down. Before configuring these interfaces, bring them up by using the undo shutdown command.
Applying a routing policy to IPv4 route redistribution
Network requirements
In Figure 1, Switch B exchanges routing information with Switch A using OSPF, and with Switch C using IS-IS.
On Switch B, enable route redistribution from IS-IS to OSPF, and apply a routing policy to set the cost of route 172.17.1.0/24 to 100 and the tag of route 172.17.2.0/24 to 20.
Figure 1 Network diagram
Configuration procedure
1.     Specify IP addresses for interfaces. (Details not shown.)
2.     Configure IS-IS:
# Configure Switch C.
[SwitchC] isis
[SwitchC-isis-1] is-level level-2
[SwitchC-isis-1] network-entity 10.0000.0000.0001.00
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface200] isis enable
[SwitchC] interface vlan-interface 201
[SwitchC-Vlan-interface201] isis enable
[SwitchC-Vlan-interface201] quit
[SwitchC] interface vlan-interface 202
[SwitchC-Vlan-interface202] isis enable
[SwitchC-Vlan-interface202] quit
[SwitchC] interface vlan-interface 203
[SwitchC-Vlan-interface203] isis enable
[SwitchC-Vlan-interface203] quit
# Configure Switch B.
[SwitchB] isis
[SwitchB-isis-1] is-level level-2
[SwitchB-isis-1] network-entity 10.0000.0000.0002.00
[SwitchB-isis-1] quit
[SwitchB-Vlan-interface200] isis enable
3.     Configure OSPF and route redistribution:
# Configure OSPF on Switch A.
[SwitchA] ospf
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchA-ospf-1] quit
# On Switch B, configure OSPF and enable route redistribution from IS-IS.
[SwitchB] ospf
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 192.168.1.0 0.0.0.255
[SwitchB-ospf-1] import-route isis 1
[SwitchB-ospf-1] quit
# Display the OSPF routing table on Switch A to view redistributed routes.
[SwitchA] display ospf routing
          OSPF Process 1 with Router ID 192.168.1.1
                   Routing Tables
 Routing for Network
 Destination        Cost     Type    NextHop        AdvRouter     Area
 192.168.1.0/24     1562     Stub    192.168.1.1    192.168.1.1   0.0.0.0
 Routing for ASEs
 Destination        Cost     Type    Tag        NextHop        AdvRouter
 172.17.1.0/24      1        Type2   1          192.168.1.2    192.168.2.2
 172.17.2.0/24      1        Type2   1          192.168.1.2    192.168.2.2
 172.17.3.0/24      1        Type2   1          192.168.1.2    192.168.2.2
 192.168.2.0/24     1        Type2   1          192.168.1.2    192.168.2.2
 Total Nets: 5
 Intra Area: 1  Inter Area: 0  ASE: 4  NSSA: 0
4.     Configure filtering lists:
# Configure ACL 2002 to permit route 172.17.2.0/24.
[SwitchB] acl number 2002
[SwitchB-acl-basic-2002] rule permit source 172.17.2.0 0.0.0.255
[SwitchB-acl-basic-2002] quit
# Configure IP prefix list prefix-a to permit route 172.17.1.0/24.
[SwitchB] ip ip-prefix prefix-a index 10 permit 172.17.1.0 24
5.     Configure a routing policy.
[SwitchB] route-policy isis2ospf permit node 10
[SwitchB-route-policy] if-match ip-prefix prefix-a
[SwitchB-route-policy] apply cost 100
[SwitchB-route-policy] quit
[SwitchB] route-policy isis2ospf permit node 20
[SwitchB-route-policy] if-match acl 2002
[SwitchB-route-policy] apply tag 20
[SwitchB] route-policy isis2ospf permit node 30
6.     Apply the routing policy to route redistribution:
# On Switch B, apply the routing policy when redistributing routes.
[SwitchB] ospf
[SwitchB-ospf-1] import-route isis 1 route-policy isis2ospf
# Display the OSPF routing table on Switch A. The cost of route 172.17.1.0/24 is 100; the tag of route 172.17.1.0/24 is 20.
                   Routing Tables
 Routing for Network
 192.168.1.0/24       1      Transit 192.168.1.1     192.168.1.1   0.0.0.0
 Routing for ASEs
 172.17.1.0/24      100      Type2   1           192.168.1.2   192.168.2.2
 172.17.2.0/24      1        Type2   20          192.168.1.2   192.168.2.2
 Total Nets: 5
Applying a routing policy to IPv6 route redistribution
In Figure 2, enable RIPng on Switch A and Switch B.
Configure three static routes on Switch A, and apply a routing policy to static route redistribution to permit routes 20::0/32 and 40::0/32 and deny route 30::0/32.
Display RIPng routing table information on Switch B to verify the configuration.
Figure 2 Network diagram
1.     Configure Switch A:
# Configure IPv6 addresses for VLAN-interface 100 and VLAN-interface 200.
[SwitchA] ipv6
[SwitchA-Vlan-interface100] ipv6 address 10::1 32
[SwitchA-Vlan-interface200] ipv6 address 11::1 32
# Enable RIPng on VLAN-interface 100.
[SwitchA-Vlan-interface100] ripng 1 enable
# Configure three static routes with next hop 11::2, and make sure that the static routes are active.
[SwitchA] ipv6 route-static 20:: 32 11::2
[SwitchA] ipv6 route-static 30:: 32 11::2
[SwitchA] ipv6 route-static 40:: 32 11::2
# Configure a routing policy.
[SwitchA] ip ipv6-prefix a index 10 permit 30:: 32
[SwitchA] route-policy static2ripng deny node 0
[SwitchA-route-policy] if-match ipv6 address prefix-list a
[SwitchA-route-policy] quit
[SwitchA] route-policy static2ripng permit node 10
# Enable RIPng and apply the routing policy to static route redistribution.
[SwitchA] ripng
[SwitchA-ripng-1] import-route static route-policy static2ripng
2.     Configure Switch B:
# Configure the IPv6 address for VLAN-interface 100.
[SwitchB] ipv6
[SwitchB-Vlan-interface100] ipv6 address 10::2 32
[SwitchB-Vlan-interface100] ripng 1 enable
# Enable RIPng.
[SwitchB] ripng
# Display RIPng routing table information.
[SwitchB-ripng-1] display ripng 1 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::7D58:0:CA03:1  on Vlan-interface 100
 Dest 10::/32,
     via FE80::7D58:0:CA03:1, cost  1, tag 0, A, 18 Sec
 Dest 20::/32,
     via FE80::7D58:0:CA03:1, cost  1, tag 0, A, 8 Sec
 Dest 40::/32,
     via FE80::7D58:0:CA03:1, cost  1, tag 0, A, 3 Sec
Applying a routing policy to filter received BGP routes
All the switches in Figure 3 run BGP. Switch C establishes EBGP connections with other switches.
Configure a routing policy on Switch D to reject routes from AS 200.
Figure 3 Network diagram
1.     Configure IP addresses for the interfaces. (Details not shown.)
2.     Configure BGP:
# Configure Switch A.
[SwitchA] bgp 100
[SwitchA-bgp] router-id 1.1.1.1
[SwitchA-bgp] peer 1.1.1.2 as-number 300
[SwitchB] bgp 200
[SwitchB-bgp] router-id 2.2.2.2
[SwitchB-bgp] peer 1.1.2.2 as-number 300
[SwitchC] bgp 300
[SwitchC-bgp] router-id 3.3.3.3
[SwitchC-bgp] peer 1.1.1.1 as-number 100
[SwitchC-bgp] peer 1.1.2.1 as-number 200
[SwitchC-bgp] peer 1.1.3.2 as-number 400
# Configure Switch D.
<SwitchD> system-view
[SwitchD] bgp 400
[SwitchD-bgp] router-id 4.4.4.4
[SwitchD-bgp] peer 1.1.3.1 as-number 300
[SwitchD-bgp] quit
# On Switch A, inject routes 4.4.4.4/24, 5.5.5.5/24, and 6.6.6.6/24 to BGP.
[SwitchA-bgp] network 4.4.4.4 24
[SwitchA-bgp] network 5.5.5.5 24
[SwitchA-bgp] network 6.6.6.6 24
# On Switch B, inject routes 7.7.7.7/24, 8.8.8.8/24, and 9.9.9.9/24 to BGP.
[SwitchB-bgp] network 7.7.7.7 24
[SwitchB-bgp] network 8.8.8.8 24
[SwitchB-bgp] network 9.9.9.9 24
# Display the BGP routing table information of Switch D.
[SwitchD-bgp] display bgp routing-table
 Total Number of Routes: 6
 BGP Local router ID is 4.4.4.4
 Status codes: * - valid, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
 *>  4.4.4.0/24         1.1.3.1                               0       300 100i
 *>  5.5.5.0/24         1.1.3.1                               0       300 100i
 *>  6.6.6.0/24         1.1.3.1                               0       300 100i
 *>  7.7.7.0/24         1.1.3.1                               0       300 200i
 *>  8.8.8.0/24         1.1.3.1                               0       300 200i
 *>  9.9.9.0/24         1.1.3.1                               0       300 200i
The output shows that Switch D has learned routes 4.4.4.0/24, 5.5.5.0/24, and 6.6.6.0/24 from AS 100 and 7.7.7.0/24, 8.8.8.0/24, and 9.9.9.0/24 from AS 200.
3.     Configure Switch D to reject routes from AS 200:
# Configure AS_PATH list 1 on Switch D.
[SwitchD] ip as-path 1 permit .*200.*
# Create routing policy rt1 with node 1, and specify the match mode as deny to deny routes from AS 200.
[SwitchD] route-policy rt1 deny node 1
[SwitchD-route-policy] if-match as-path 1
[SwitchD-route-policy] quit
# Create routing policy rt1 with node 10, and specify the match mode as permit to permit routes from other ASs.
[SwitchD] route-policy rt1 permit node 10
# On Switch D, specify routing policy rt1 to filter routes received from peer 1.1.3.1.
[SwitchD] bgp 400
[SwitchD-bgp] peer 1.1.3.1 route-policy rt1 import
 Total Number of Routes: 3
The output shows that Switch D has learned only routes 4.4.4.0/24, 5.5.5.0/24, and 6.6.6.0/24 from AS 100.
Troubleshooting routing policy configuration
IPv4 routing information filtering failure
Symptom
Filtering routing information failed, while the routing protocol runs correctly.
Analysis
At least one item of the IP prefix list must be configured as permit mode, and at least one node in the routing policy must be configured as permit mode.
Solution
1.     Use the display ip ip-prefix command to display IP prefix list information.
2.     Use the display route-policy command to display routing policy information.
IPv6 routing information filtering failure
Symptom
Analysis
At least one item of the IPv6 prefix list must be configured as permit mode, and at least one node of the routing policy must be configured as permit mode.
Solution
1.     Use the display ip ipv6-prefix command to display IP prefix list information.
