07-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesS9500E SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guides-Release1828P04-6W18207-Layer 3 - IP Routing Configuration Guide
05-IS-IS Configuration
05-IS-IS Configuration 720.18 KB
Configuring IS-IS· 1
Overview·· 1
Terminology· 1
IS-IS address format 1
NET· 2
IS-IS area· 3
IS-IS network type· 5
IS-IS PDU·· 6
Supported IS-IS features 12
Protocols and standards 14
IS-IS configuration task list 15
Configuring basic IS-IS· 16
Configuration prerequisites 16
Enabling IS-IS· 16
Configuring the IS level and circuit level 16
Configuring the network type of an interface as P2P· 17
Configuring IS-IS routing information control 17
Configuration prerequisites 17
Configuring IS-IS link cost 18
Specifying a priority for IS-IS· 19
Configuring the maximum number of ECMP routes 19
Configuring IS-IS route summarization· 20
Advertising a default route· 20
Configuring IS-IS route redistribution· 21
Configuring IS-IS route filtering· 21
Configuring IS-IS route leaking· 22
Tuning and optimizing IS-IS networks 23
Configuration prerequisites 23
Specifying intervals for sending IS-IS hello and CSNP packets 23
Specifying the IS-IS hello multiplier 23
Configuring a DIS priority for an interface· 23
Disabling an interface from sending/receiving IS-IS packets 24
Disabling hello source address check for a PPP interface· 24
Enabling an interface to send small hello packets 25
Configuring LSP parameters 25
Configuring SPF parameters 28
Assigning a high priority to IS-IS routes 28
Setting the LSDB overload bit 29
Configuring system ID to host name mappings 29
Enabling the logging of neighbor state changes 30
Enhancing IS-IS network security· 31
Configuration prerequisites 31
Configuring neighbor relationship authentication· 31
Configuring area authentication· 31
Configuring routing domain authentication· 32
Configuring IS-IS GR· 32
Configuring IS-IS NSR· 33
Configuring IS-IS FRR· 34
Enabling IS-IS SNMP trap· 35
Binding an IS-IS process with MIBs 35
Configuring BFD for IS-IS· 35
Displaying and maintaining IS-IS· 36
IS-IS configuration examples 37
Basic IS-IS configuration· 37
DIS election configuration· 41
Configuring IS-IS route redistribution· 45
IS-IS Graceful Restart configuration example· 49
IS-IS NSR configuration example· 51
IS-IS FRR configuration example· 53
IS-IS authentication configuration example· 55
Configuring BFD for IS-IS· 57
This chapter describes how to configure IS-IS for an IPv4 network.
Overview
Intermediate System-to-Intermediate System (IS-IS) is a dynamic routing protocol designed by the International Organization for Standardization (ISO) to operate on the connectionless network protocol (CLNP).
IS-IS was modified and extended in RFC 1195 by the IETF for application in both TCP/IP and OSI reference models, and the new one is called "Integrated IS-IS" or "Dual IS-IS."
IS-IS is an IGP used within an AS and adopts the SPF algorithm for route calculation.
Terminology
·     Intermediate system (IS)—An IS, similar to a router in TCP/IP, is the basic unit in IS-IS to generate and propagate routing information. In the following text, an IS refers to a router.
·     End system (ES)—An ES refers to a host system in TCP/IP. ISO defines the ES-IS protocol for communication between an ES and an IS; therefore, an ES does not participate in the IS-IS processing.
·     Routing domain (RD)—An RD is a group of ISs exchanges routing information with each other using the same routing protocol in a routing domain.
·     Area—An area is a unit in a routing domain. The IS-IS protocol allows a routing domain to be divided into multiple areas.
·     Link State Database (LSDB)—All link states in the network forms the LSDB. There is at least one LSDB in each IS. The IS uses the SPF algorithm and LSDB to generate its own routes.
·     Link State Protocol Data Unit (LSPDU) or Link State Packet (LSP)—Each IS can generate an LSP, which contains all the link state information of the IS.
·     Network Protocol Data Unit (NPDU)—An NPDU is a network layer protocol packet in OSI, which is equivalent to an IP packet in TCP/IP.
·     Designated IS—On a broadcast network, the designated router is also known as the designated IS.
·     Network service access point (NSAP)—An NSAP is an OSI network layer address. It identifies an abstract network service access point and describes the network address in the OSI reference model.
NSAP
As shown in Figure 1, an NSAP address comprises the initial domain part (IDP) and the domain specific part (DSP). The IDP is equal to the network ID of an IP address, and the DSP is equal to the subnet and host ID.
The IDP includes the authority and format identifier (AFI) and the initial domain identifier (IDI).
The DSP includes the High Order Part of DSP (HO-DSP), System ID, and SEL, where the HO-DSP identifies the area, the System ID identifies the host, and the SEL identifies the type of service.
The IDP and DSP are variable in length. The length of an NSAP address varies from 8 bytes to 20 bytes.
Figure 1 NSAP address format
Area address
The area address comprises the IDP and the HO-DSP of the DSP, which identify the area and the routing domain. Different routing domains cannot have the same area address.
Generally, a router only needs one area address, and all nodes in the same routing domain must share the same area address. However, a router can have a maximum of three area addresses to support smooth area merging, partitioning, and switching.
System ID
A system ID uniquely identifies a host or router. It has a fixed length of 48 bits (6 bytes).
The system ID of a switch can be generated from the router ID. For example, a router uses the IP address 168.10.1.1 of Loopback 0 as the router ID, and the system ID in IS-IS can be obtained in the following way:
1.     Extend each decimal number of the IP address to 3 digits by adding 0s from the left, such as 168.010.001.001;
2.     Divide the extended IP address into three sections with 4 digits in each section to get the system ID 1680.1000.1001.
There are other methods to define a system ID. The principle is to ensure it can uniquely identify a host or router.
SEL
The NSAP selector (SEL), or the N-SEL, is similar to the protocol identifier in IP. Different transport layer protocols correspond to different SELs. All SELs in IP are 00.
Routing method
The area information is identified in IS-IS addresses, so a Level-1 router can easily identify packets destined to other areas.
·     A Level-1 router makes routing decisions based on the system ID. If the destination is not in the area, the packet is forwarded to the nearest Level-1-2 router.
·     A Level-2 router routes packets across areas according to the area address.
NET
A network entity title (NET) indicates the network layer information of an IS, and does not include transport layer information. It is a special NSAP address with the SEL being 0; therefore, the length of the NET is equal to the NSAP, and is in the range of 8 bytes to 20 bytes.
A NET comprises the following parts:
·     Area ID—Its length is in the range of 1 to 13 bytes.
·     System ID—A system ID uniquely identifies a host or router in the area and has a fixed 6-byte length.
·     SEL—It has a value of 0 and a fixed 1-byte length.
For example, a NET is ab.cdef.1234.5678.9abc.00, where area ID is ab.cdef, system ID is 1234.5678.9abc, and SEL is 00.
Generally, a router only needs one NET, but it can have a maximum of three NETs for smooth area merging and partitioning. When you configure multiple NETs, make sure their system IDs are the same.
IS-IS area
IS-IS has a 2-level hierarchy to support large-scale networks. A large-scale routing domain is divided into multiple areas. Typically, a Level-1 router is deployed within an area, a Level-2 router is deployed between areas, and a Level-1-2 router is deployed between Level-1 and Level-2 routers.
Level-1 and Level-2
·     Level-1 router—A Level-1 router establishes neighbor relationships with Level-1 and Level-1-2 routers in the same area. The LSDB maintained by the Level-1 router contains the local area routing information. It directs the packets destined for an outside area to the nearest Level-1-2 router.
·     Level-2 router—A Level-2 router establishes neighbor relationships with the Level-2 and Level-1-2 routers in the same or in different areas. It maintains a Level-2 LSDB containing inter-area routing information. All the Level-2 and Level-1-2 routers must be contiguous to form the backbone of a routing domain.
·     Level-1-2 router—A router with both Level-1 and Level-2 router functions is a Level-1-2 router. It can establish Level-1 neighbor relationships with the Level-1 and Level-1-2 routers in the same area, or establish Level-2 neighbor relationships with the Level-2 and Level-1-2 routers in different areas. A Level-1 router must be connected to other areas through a Level-1-2 router. The Level-1-2 router maintains two LSDBs, where the Level-1 LSDB is for routing within the area, and the Level-2 LSDB is for routing between areas.
Level-1 routers in different areas cannot establish neighbor relationships. Whether Level-2 routers establish neighbor relationships does not depend on areas.
Figure 2 shows one IS-IS network topology, where Area 1 comprises a set of Level-2 routers and is the backbone. The other four areas are non-backbone areas connected to the backbone through Level-1-2 routers.
Figure 2 IS-IS topology 1
Figure 3 shows another IS-IS topology. The Level-1-2 routers connect to the Level-1 and Level-2 routers, and form the IS-IS backbone together with the Level-2 routers. There is no area defined as the backbone in this topology. The backbone comprises all contiguous Level-2 and Level-1-2 routers, which can reside in different areas.
Figure 3 IS-IS topology 2
The IS-IS backbone does not need to be a specific area.
Both the IS-IS Level-1 and Level-2 routers use the SPF algorithm to generate the shortest path tree (SPT).
Route leaking
An IS-IS routing domain is comprised of only one Level-2 area and multiple Level-1 areas. A Level-1 area consists of a group of Level-1 routers, and is connected with a Level-2 area rather than other Level-1 areas.
The routing information of a Level-1 area is sent to the Level-2 area through the Level-1-2 router. Therefore, the Level-2 router knows the routing information of the entire IS-IS routing domain. But the Level-1-2 router does not share the information of other Level-1 areas and the Level-2 area with the Level-1 area by default.
Because a Level-1 router simply sends packets destined for other areas to the nearest Level-1-2 router, the best paths might not be selected. To resolve this problem, route leaking was introduced. A Level-2 router can advertise Level-2 routing information to a specified Level-1 area. By having the routing information of other areas, a Level-1 router in the area can make a better routing decision for a packet to another area.
IS-IS network type
Network type
IS-IS supports the following network types:
·     Broadcast network, such as Ethernet and Token-Ring.
·     Point-to-point network, such as PPP and HDLC.
For a Non-Broadcast Multi-Access (NBMA) interface, such as an ATM interface, you need to configure subinterfaces for it and configure the interface type for the subinterfaces as point-to-point or broadcast. IS-IS cannot run on point to multipoint (P2MP) links.
DIS and pseudonodes
On an IS-IS broadcast network, a router is elected as the Designated Intermediate System (DIS).
The Level-1 and Level-2 DISs are elected. You can assign different priorities to different level DIS elections. The higher the router's priority is, the more likelihood the router becomes the DIS. If there are multiple routers with the same highest DIS priority, the one with the highest SNPA (Subnetwork Point of Attachment) address (MAC address on a broadcast network) will be elected. A router can be the DIS for different levels.
IS-IS DIS election differs from OSPF DIS election in the following ways:
·     A router with priority 0 can also participate in the DIS election.
·     When a router is added to the network and becomes the new DIS, an LDP flooding process is triggered.
As shown in Figure 4, the same level routers on a network, including non-DIS routers, establish adjacencies with each other.
Figure 4 DIS in the IS-IS broadcast network
The DIS creates and updates pseudonodes, as well as generates their LSPs, to describe all routers on the network.
A pseudonode represents a virtual node on the broadcast network. It is not a real router. In IS-IS, it is identified by the system ID of the DIS and a 1-byte Circuit ID (a non-zero value).
Using pseudonodes can reduce the resources consumed by SPF and simplify network topology.
On IS-IS broadcast networks, all routers are adjacent with each other. However, the DIS is responsible for the synchronization of their LSDBs.
IS-IS PDU
PDU
IS-IS packets are encapsulated into link layer frames. An IS-IS PDU has two parts, the headers and the variable length fields, where the headers comprise the PDU common header and the PDU specific header. All PDUs have the same PDU common header, while the specific headers vary by PDU type.
Figure 5 PDU format
Common header format
Figure 6 PDU common header format
Major fields of the PDU common header are as follows:
·     Intradomain routing protocol discriminator—Set to 0x83.
·     Length indicator—Length of the PDU header in bytes, including both common and specific headers.
·     Version/Protocol ID extension—Set to 1(0x01).
·     ID length—Length of the NSAP address and NET ID.
·     R(Reserved)—Set to 0.
·     PDU type—For detailed information, see Table 1.
·     Version—Set to 1(0x01).
·     Maximum area address—Maximum number of area addresses supported.
Table 1 PDU type
PDU Type
Acronym
15
Level-1 LAN IS-IS hello PDU
L1 LAN IIH
16
Level-2 LAN IS-IS hello PDU
L2 LAN IIH
17
Point-to-Point IS-IS hello PDU
P2P IIH
18
Level-1 Link State PDU
L1 LSP
20
Level-2 Link State PDU
L2 LSP
24
Level-1 Complete Sequence Numbers PDU
L1 CSNP
25
Level-2 Complete Sequence Numbers PDU
L2 CSNP
26
Level-1 Partial Sequence Numbers PDU
L1 PSNP
27
Level-2 Partial Sequence Numbers PDU
L2 PSNP
Hello PDU
Hello packets are used by routers to establish and maintain neighbor relationships. A hello packet is also called an IS-to-IS hello PDU (IIH). For broadcast networks, the Level-1 routers use the Level-1 LAN IIHs; and the Level-2 routers use the Level-2 LAN IIHs. The P2P IIHs are used on point-to-point networks.
Figure 7 illustrates the hello packet format in broadcast networks, where the blue fields are the common header.
Figure 7 L1/L2 LAN IIH format
Major fields of the L1/L2 LAN IIH are as follows:
·     Reserved/Circuit type—The first 6 bits are reserved with a value of 0. The last 2 bits indicate the router type—00 means reserved, 01 indicates L1, 10 indicates L2, and 11 indicates L1/2.
·     Source ID—System ID of the router advertising the hello packet.
·     Holding time—If no hello packets are received from the neighbor within the holding time, the neighbor is considered down.
·     PDU length—Total length of the PDU in bytes.
·     Priority—DIS priority.
·     LAN ID—Includes the system ID and a 1-byte pseudonode ID.
Figure 8 shows the hello packet format on the point-to-point networks.
Figure 8 P2P IIH format
Instead of the priority and LAN ID fields in the LAN IIH, the P2P IIH has a Local Circuit ID field.
LSP
The Link State PDUs (LSP) carry link state information. LSP involves two types: Level-1 LSP and Level-2 LSP. The Level-2 LSPs are sent by the Level-2 routers, and the Level-1 LSPs are sent by the Level-1 routers. The Level-1-2 router can send both types of LSPs.
The two types of LSPs have the same format, as shown in Figure 9.
Figure 9 L1/L2 LSP format
Major fields of the L1/L2 LSP are as follows:
·     Remaining lifetime—LSP remaining lifetime in seconds.
·     LSP ID—Consists of the system ID, the pseudonode ID (1 byte) and the LSP fragment number (1 byte).
·     Sequence number—LSP sequence number.
·     Checksum—LSP checksum.
·     P (Partition Repair)—Only for L2 LSPs; it indicates whether the router supports partition repair.
·     ATT (Attachment)—Generated by a L1/L1 router for L1 LSPs only; it indicates that the router generating the LSP is connected to multiple areas.
·     OL (LSDB Overload)—Indicates that the LSDB is not complete because the router runs out of memory. In this case, other routers will not send packets to the overloaded router, except packets destined to the networks directly connected to the router. For example, in Figure 10, Router A forwards packets to Router C through Router B. Once other routers know the OL field of LSPs from Router B is set to 1, Router A will send packets to Router C through Router D and Router E, but still send to Router B packets destined to the network directly connected to Router B.
·     IS type—Type of the router generating the LSP.
Figure 10 LSDB overload
SNP format
A sequence number PDU (SNP) acknowledges the latest received LSPs. It is similar to an Acknowledge packet, but more efficient.
SNP involves Complete SNP (CSNP) and Partial SNP (PSNP), which are further divided into Level-1 CSNP, Level-2 CSNP, Level-1 PSNP and Level-2 PSNP.
CSNP covers the summary of all LSPs in the LSDB to synchronize the LSDB between neighboring routers. On broadcast networks, CSNP is sent by the DIS periodically (10 seconds by default). On point-to-point networks, CSNP is only sent during the first adjacency establishment.
Figure 11 L1/L2 CSNP format
PSNP only contains the sequence numbers of one or multiple latest received LSPs. It can acknowledge multiple LSPs at one time. When LSDBs are not synchronized, a PSNP is used to request new LSPs from neighbors.
Figure 12 L1/L2 PSNP format
CLV
The variable fields of PDU comprise multiple Code-Length-Value (CLV) triplets. CLV format
Table 2 CLV name and the corresponding PDU type
CLV Code
Name
PDU Type
1
Area Addresses
IIH, LSP
2
IS Neighbors (LSP)
LSP
4
Partition Designated Level 2 IS
L2 LSP
6
IS Neighbors (MAC Address)
LAN IIH
7
IS Neighbors (SNPA Address)
LAN IIH
8
Padding
IIH
9
LSP Entries
SNP
10
Authentication Information
IIH, LSP, SNP
128
IP Internal Reachability Information
LSP
129
Protocols Supported
IIH, LSP
130
IP External Reachability Information
L2 LSP
131
Inter-Domain Routing Protocol Information
L2 LSP
132
IP Interface Address
IIH, LSP
Code 1 to 10 of CLV are defined in ISO 10589 (code 3 and 5 are not shown in the table), and others are defined in RFC 1195.
Multiple instances and processes
IS-IS supports multiple instances and processes. Multiple processes allow an IS-IS process to work in concert with a group of interfaces. This means that a router can run multiple IS-IS processes, and each process corresponds to a unique group of interfaces.
For routers supporting VPN, each IS-IS process is associated with a VPN instance, which means the VPN instance is also associated with interfaces corresponding to the process.
Active/Standby failover
IS-IS backs up necessary data from the active main processing unit (MPU) to the standby MPU. Whenever the active MPU is down, the standby MPU can switch to the active status to run IS-IS.
The backup modes are as follows:
·     Nonstop routing (NSR)—Backs up all IS-IS data. After active/standby failover, IS-IS can work immediately.
·     Graceful restart (GR)—Backs up only the configuration of IS-IS. After active/standby failover, IS-IS performs graceful restart (GR) to synchronize the LSDB with neighbors.
Graceful Restart (GR) ensures the continuity of packet forwarding when a routing protocol restarts or an active/standby switchover occurs:
·     GR restarter—Graceful restarting router. It must be GR capable.
·     GR helper—A neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
After an IS-IS GR restarter restarts, it must complete the following tasks to synchronize the LSDB with its neighbors:
·     Obtain IS-IS neighbor information without changing adjacencies.
·     Obtain the LSDB.
To complete these tasks, the GR restarter sends an IS-IS GR signal to GR helpers so that the GR helpers keep their adjacencies with the GR restarter, and then restores the neighbor table after receiving responses from neighbors.
After that, the GR restarter synchronizes the LSDB with all GR-capable neighbors, calculates routes, updates its routing table and forwarding table, and removes stale routes. The IS-IS routing convergence is then complete.
IS-IS NSR
NSR is a new feature that overcomes the application limit of GR. It backs up IS-IS link state information from the active MPU to the standby MPU. Upon an active/standby switchover, NSR can complete link state recovery and route re-generation without requiring the cooperation of other devices.
IS-IS TE
IS-IS traffic engineering (TE) creates and maintains the Label Switched Path (LSP).
When creating the Constraint-based Routed LSP (CR LSP), MPLS must get the traffic attribute information of all links in the local area. The TE information of links is obtained from IS-IS. For detailed configuration of the IS-IS TE, see MPLS Configuration Guide.
Management tag
Management tag simplifies routing information management by carrying the management information of the IP address prefixes (to control route redistribution from other routing protocols) and BGP community and extended community attributes.
LSP fragment extension
IS-IS advertises link state information by flooding LSPs. One LSP carries a limited amount of link state information; therefore, IS-IS fragments LSPs. Each LSP fragment is uniquely identified by a combination of the System ID, Pseudonode ID (0 for a common LSP or a non-zero value for a Pseudonode LSP), and LSP Number (LSP fragment number) of the node or pseudo node that generated the LSP. The 1-byte LSP Number field, allowing a maximum of only 256 fragments to be generated by an IS-IS router, limits the amount of link information the IS-IS router can advertise.
The LSP fragment extension feature allows an IS-IS router to generate more LSP fragments. Up to 50 additional virtual systems can be configured on the router, and each virtual system is capable of generating 256 LSP fragments to enable the IS-IS router to generate up to 13056 LSP fragments.
·     Terms
¡     Originating system—The router actually running IS-IS. After LSP fragment extension is enabled, additional virtual systems can be configured for the router. Originating system is the IS-IS process that originally runs.
¡     System ID—The system ID of the originating system.
¡     Additional system ID—Additional virtual system IDs are configured for the IS-IS router after LSP fragment extension is enabled. Each additional system ID can generate 256 LSP fragments. Both the additional system ID and the system ID must be unique in the entire routing domain.
¡     Virtual system—A virtual system is identified by an additional system ID and generates extended LSP fragments.
¡     Original LSP—The LSP generated by the originating system. The system ID in its LSP ID field is the system ID of the originating system.
¡     Extended LSP—Extended LSPs are generated by virtual systems. The system ID in its LSP ID field is the virtual system ID. After additional system IDs are configured, an IS-IS router can advertise more link state information in extended LSP fragments. Each virtual system can be considered a virtual router. An extended LSP fragment is advertised by a virtual system identified by an additional system ID.
·     Operation modes
The LSP fragment extension feature operates in the following modes:
¡     Mode-1—Applicable to a network where some routers do not support LSP fragment extension. In this mode, adjacencies are formed between the originating system and virtual systems, with the link cost from the originating system to each virtual system as 0. Thus, each virtual system acts as a router connected to the originating system in the network, but the virtual systems are reachable through the originating system only. Therefore, the IS-IS routers not supporting LSP fragment extension can operate correctly without modifying the extended LSP fragments received, but some limitation is imposed on the link state information in the extended LSP fragments advertised by the virtual systems.
¡     Mode-2—Applicable to a network where all the routers support LSP fragment extension. In this mode, all the IS-IS routers know which virtual system belongs to which originating system; therefore, no limitation is imposed on the link state information of the extended LSP fragments advertised by the virtual systems.
The operation mode of LSP fragment extension is configured based on area and routing level. Mode-1 allows the routers supporting and not supporting LSP fragment extension to interoperate with each other, but it restricts the link state information in the extended fragments. Mode-2 does not restrict the link state information in the extended fragments, and is recommended for an area where all the routers are at the same routing level and support LSP fragment extension.
Dynamic host name mapping mechanism
The dynamic host name mapping mechanism provides the mappings between the host names and the system IDs for the IS-IS routers. The dynamic host name information is announced in the dynamic host name CLV of an LSP.
This mechanism also provides the mapping between a host name and the DIS of a broadcast network, which is announced in the dynamic host name TLV of a pseudonode LSP.
A host name is easier to remember than a system ID. After enabling this feature on the router, you can see the host names instead of system IDs using the display command.
BFD
Bidirectional forwarding detection (BFD) provides a single mechanism to quickly detect and monitor the connectivity of links between IS-IS neighbors, reducing network convergence time. For more information about BFD, see High Availability Configuration Guide.
·     ISO 10589 ISO IS-IS Routing Protocol
·     ISO 9542 ES-IS Routing Protocol
·     ISO 8348/Ad2 Network Services Access Points
·     RFC 1195, Use of OSI IS-IS for Routing in TCP/IP and Dual Environments
·     RFC 2763, Dynamic Hostname Exchange Mechanism for IS-IS
·     RFC 2966, Domain-wide Prefix Distribution with Two-Level IS-IS
·     RFC 2973, IS-IS Mesh Groups
·     RFC 3277, IS-IS Transient Blackhole Avoidance
·     RFC 3358, Optional Checksums in ISIS
·     RFC 3373, Three-Way Handshake for IS-IS Point-to-Point Adjacencies
·     RFC 3567, Intermediate System to Intermediate System (IS-IS) Cryptographic Authentication
·     RFC 3719, Recommendations for Interoperable Networks using IS-IS
·     RFC 3786, Extending the Number of IS-IS LSP Fragments Beyond the 256 Limit
·     RFC 3787, Recommendations for Interoperable IP Networks using IS-IS
·     RFC 3784, IS-IS extensions for Traffic Engineering
·     RFC 3847, Restart signaling for IS-IS
Remarks
Enabling IS-IS
Required.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
Optional.
This section describes the basic settings required for an IS-IS network to run.
Before the configuration, complete the following tasks:
·     Configure the link layer protocol.
·     Configure IP addresses for interfaces to ensure IP connectivity between neighboring nodes.
Enabling IS-IS
Step
Remarks
N/A
2.     Enable the IS-IS routing process and enter its view.
Not enabled by default.
3.     Assign a network entity title (NET).
network-entity net
Not assigned by default.
4.     Return to system view.
N/A
5.     Enter interface view.
N/A
6.     Enable an IS-IS process on the interface.
isis enable [ process-id ]
Disabled by default.
If only one area is available, H3C recommends performing the following operations:
·     Configure the IS level of all routers as Level-1 or Level-2 rather than different levels because the routers do not need to maintain two identical LSDBs.
·     Configure the IS level as Level-2 on all routers in an IP network for scalability.
For an interface of a Level-1 (or Level-2) router, the circuit level can only be Level-1 (or Level-2). For an interface of a Level-1-2 router, the default circuit level is Level-1-2; if the router only needs to form Level-1 (or Level-2) neighbor relationships, configure the circuit level for its interfaces as Level-1 (or Level-2) to limit neighbor relationship establishment.
To configure the IS level and circuit level:
Step
Remarks
N/A
2.     Enter IS-IS view.
N/A
3.     Specify the IS level.
is-level { level-1 | level-1-2 | level-2 }
Optional.
The default is Level-1-2.
N/A
N/A
6.     Specify the circuit level.
isis circuit-level [ level-1 | level-1-2 | level-2 ]
Optional.
By default, an interface can establish either the Level-1 or Level-2 adjacency.
Perform this task only for a broadcast network that has up to two attached routers.
Interfaces with different network types operate differently. For example, broadcast interfaces on a network must elect the DIS and flood CSNP packets to synchronize the LSDBs, while P2P interfaces on a network need not elect the DIS, and have a different LSDP synchronization mechanism.
If there are only two routers on a broadcast network, configure the network type of attached interfaces as P2P to avoid DIS election and CSNP flooding, saving network bandwidth and speeding up network convergence.
To configure the network type of an interface:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Configure the network type for the interface as P2P.
isis circuit-type p2p
Optional.
By default, the network type of an interface depends on the physical media. The network type of a VLAN interface is broadcast.
Perform the tasks in this section to affect IS-IS route selection.
·     Configure network layer addresses for interfaces to ensure IP connectivity between neighboring nodes.
·     Enable IS-IS.
The IS-IS cost of an interface is determined in the following order:
1.     IS-IS cost specified in interface view.
2.     IS-IS cost specified in system view. The cost is applied to the interfaces associated with the IS-IS process.
3.     Automatically calculated cost. If the cost style is wide or wide-compatible, IS-IS automatically calculates the cost using the formula: interface cost = (bandwidth reference value/interface bandwidth) × 10. For other cost styles, Table 3 applies.
Table 3 Automatic cost calculation scheme for cost styles other than wide and wide-compatible
Interface bandwidth
Interface cost
≤ 10 Mbps
60
≤ 100 Mbps
50
≤ 155 Mbps
40
≤ 622 Mbps
30
≤ 2500 Mbps
20
> 2500 Mbps
10
4.     If none of the above costs is used, a default cost of 10 applies.
Configuring an IS-IS cost for an interface
Step
Remarks
N/A
N/A
3.     Specify an IS-IS cost style.
Optional.
narrow by default.
N/A
N/A
6.     Specify a cost for the interface.
isis [ ipv6-unicast ] cost value [ level-1 | level-2 ]
By default, no cost is specified for the interface.
Configuring a global IS-IS cost
Step
Remarks
N/A
N/A
Optional.
narrow by default.
4.     Specify a global IS-IS cost.
circuit-cost value [ level-1 | level-2 ]
By default, no global cost is specified.
Enabling automatic IS-IS cost calculation
Step
Remarks
N/A
N/A
cost-style { wide | wide-compatible }
narrow by default.
4.     Enable automatic IS-IS cost calculation.
auto-cost enable
5.     Configure a bandwidth reference value for automatic IS-IS cost calculation.
bandwidth-reference value
Optional.
100 Mbps by default.
A router can run multiple routing protocols. When routes to the same destination are found by multiple routing protocols, the route learned by the protocol with the highest priority is adopted. You can reference a routing policy to specify a priority for specific routes. For information about routing policy, see "Configuring routing policies."
To configure the priority of IS-IS:
Step
Remarks
N/A
N/A
3.     Specify a priority for IS-IS.
preference { route-policy route-policy-name | preference } *
15 by default.
Perform this task to implement load sharing over ECMP routes.
To configure the maximum number of ECMP routes:
Step
Remarks
N/A
N/A
3.     Specify the maximum number of ECMP routes for load balancing.
maximum load-balancing number
By default, the maximum number of ECMP routes depends on the system operating mode:
·     The maximum number of ECMP routes is 32 when the switch operates in standard mode, enhanced Layer 2 mode, enhanced Layer 3 mode, or advanced mode.
·     The maximum number of ECMP routes is 16 when the switch operates in standard hybrid mode, enhanced Layer 2 hybrid mode, enhanced Layer 3 hybrid mode, or advanced hybrid mode.
For more information about system operating modes, see Fundamentals Configuration Guide.
This task is to configure a summary route, so routes within the network range of the summary route are summarized into one route for advertisement. Doing so can reduce the size of routing tables, as well as the scale of LSP and LSDB. Both IS-IS routes and redistributed routes can be summarized.
The router summarizes only the routes in the locally generated LSPs. The cost of the summary route is the lowest one among the costs of summarized routes.
To configure route summarization:
Step
Remarks
N/A
N/A
3.     Configure IS-IS route summarization.
summary ip-address { mask | mask-length } [ avoid-feedback | generate_null0_route | tag tag | [ level-1 | level-1-2 | level-2 ] ] *
By default, no route summarization is configured.
A router running IS-IS cannot redistribute any default routes or advertise a default route to other neighbors. Perform this task to advertise a default route of 0.0.0.0/0 to the same level neighbors.
The default route is only advertised to routers at the same level. You can use a routing policy to generate the default route only when a local routing entry is matched by the policy.
To advertise a default route:
Step
Remarks
N/A
N/A
3.     Advertise a default route.
default-route-advertise [ route-policy route-policy-name | [ level-1 | level-1-2 | level-2 ] ] *
By default, the function is disabled.
Redistributing large numbers of routes on a switch might affect the performance of other devices in the network. In that case, you can configure a limit on the number of redistributed routes to limit the number of routes to be advertised.
Only active routes can be redistributed. To verify route state, use the display ip routing-table protocol command.
To configure IS-IS route redistribution from other routing protocols:
Step
Remarks
N/A
N/A
3.     Redistribute routes from another routing protocol.
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, no route is redistributed.
By default, if no level is specified, routes are redistributed into the Level-2 routing table.
4.     Configure the maximum number of redistributed Level 1/Level 2 IPv4 routes.
import-route limit number
Optional.
You can reference a configured ACL, IP prefix list, or routing policy to filter routes calculated from the received LSPs and the routes redistributed from other routing protocols.
Filtering routes calculated from received LSPs
IS-IS saves the LSPs received from neighbors in the LSDB, uses the SPF algorithm to calculate the shortest path tree with itself as the root, and installs the routes into the IS-IS routing table.
By reference a configured ACL, IP prefix list or routing policy, you can filter the calculated routes and only the routes matching the filter can be added into the IS-IS routing table.
To filter routes calculated from received LSPs:
Step
Remarks
N/A
N/A
3.     Filter routes calculated from received LSPs.
filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } import
By default, no filtering is configured.
Filtering redistributed routes
IS-IS can redistribute routes from other routing protocols or other IS-IS processes, add them into the IS-IS routing table, and advertise them in LSPs.
By reference a configured ACL, IP prefix list, or routing policy, you can filter redistributed routes and only the routes matching the filter can be added into the IS-IS routing table and advertised to neighbors.
To configure the filtering of redistributed routes:
Step
Remarks
N/A
N/A
3.     Configure the filtering of routes redistributed from another routing protocol or IS-IS process.
filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
Not configured by default.
With IS-IS route leaking enabled, the Level-1-2 router can advertise the routing information of other Level-1 areas and Level-2 area routing information to Level-1 routers.
If a filter policy is specified, only routes passing it can be advertised into Level-1 area.
You can specify a routing policy in the import-route isis level-2 into level-1 command to filter routes from Level-2 to Level-1. Other routing policies specified for route reception and redistribution does not affect the route leaking.
To configure IS-IS route leaking:
Step
Remarks
N/A
N/A
3.     Enable IS-IS route leaking.
import-route isis level-2 into level-1 [ filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } | tag tag ] *
·     Enable IS-IS.
Step
Remarks
N/A
N/A
3.     Specify the interval for sending hello packets.
isis timer hello seconds
Optional.
10 seconds by default.
4.     Specify the interval for sending CSNP packets on the DIS of a broadcast network.
isis timer csnp seconds [ level-1 | level-2 ]
Optional.
The interval between hello packets sent by the DIS is 1/3 the hello interval set with the isis timer hello command.
If a neighbor receives no hello packets from the router within the advertised hold time, it considers the router down and recalculates the routes. The hold time is the hello multiplier times the hello interval.
To specify the IS-IS hello multiplier:
Step
Remarks
N/A
N/A
3.     Specify the number of hello packets a neighbor must miss before declaring the router is down.
isis timer holding-multiplier value [ level-1 | level-2 ]
Optional.
3 by default.
On an IS-IS broadcast network, you must elect a router as the DIS at a routing level. You can specify a DIS priority at a level for an interface. The greater the interface's priority, the more likely it becomes the DIS. If multiple routers in the broadcast network have the same highest DIS priority, the router with the highest MAC address becomes the DIS.
To specify a DIS priority for an interface:
Step
Remarks
N/A
N/A
3.     Specify a DIS priority for the interface.
isis dis-priority value [ level-1 | level-2 ]
Optional.
64 by default.
After being disabled from sending and receiving hello packets, an interface cannot form any neighbor relationship, but can advertise directly connected networks in LSPs through other interfaces. By doing so, you can save bandwidth and CPU resources while ensuring other routers know networks directly connected to the interface.
To disable an interface from sending and receiving IS-IS packets:
Step
Remarks
N/A
N/A
3.     Disable the interface from sending and receiving IS-IS packets.
isis silent
Not disabled by default.
On a P2P link, IS-IS verifies the source IP address of the incoming hello packets is in the same network segment as the IP address of the receiving interface. If not, it discards the hello packets, and no neighbor relationship can be established with the peer router.
For a PPP interface, the peer's IP address might reside on a different network segment. In this case, you can disable the hello source address check for the PPP interface to establish the neighbor relationship with the peer.
To enable neighbor relationships over different network segments:
Step
Remarks
N/A
N/A
3.     Disable hello source address check for the PPP interface.
isis peer-ip-ignore
The command only applies to the PPP interface.
By default, hello source address check is enabled.
IS-IS messages cannot be fragmented at the IP layer because they are directly encapsulated into frames. Therefore, any two IS-IS neighboring routers must negotiate a common MTU. To avoid sending big hellos for saving bandwidth, you can enable the interface to send small hello packets without CLVs.
To enable an interface to send small hello packets:
Step
Remarks
N/A
N/A
3.     Enable the interface to send small hello packets without CLVs.
isis small-hello
By default, standard hello packets are sent.
Configuring LSP timers
1.     Specify the maximum age of LSPs
Each LSP has an age that decreases in the LSDB. Any LSP with an age of 0 is deleted from the LSDB. You can adjust the age value based on the scale of a network.
To specify the maximum age of LSPs:
Step
Remarks
N/A
N/A
3.     Specify the maximum LSP age.
timer lsp-max-age seconds
Optional.
1200 seconds by default.
2.     Specify the LSP refresh interval and generation interval
Each router needs to refresh LSPs generated by itself at a configurable interval and send them to other routers to prevent valid routes from being aged out. A smaller refresh interval speeds up network convergence but consumes more bandwidth.
When the network topology changes, for example, a neighbor is down or up, or the interface metric, system ID, or area ID is changed, the router generates an LSP after a configurable interval. If such a change occurs frequently, excessive LSPs are generated, consuming a large amount of router resources and bandwidth; in this case, you can adjust the LSP generation interval.
To specify the LSP refresh interval and generation interval:
Step
Remarks
N/A
N/A
3.     Specify the LSP refresh interval.
timer lsp-refresh seconds
Optional.
900 seconds by default.
4.     Specify the LSP generation interval.
timer lsp-generation maximum-interval [ initial-interval [ second-wait-interval ] ] [ level-1 | level-2 ]
Optional.
2 seconds by default.
3.     Specify LSP sending intervals
If a change occurs in the LSDB, IS-IS advertises the changed LSP to neighbors. You can specify the minimum interval for sending such LSPs.
On a P2P link, IS-IS requires an advertised LSP be acknowledged. If no acknowledgement is received within a configurable interval, IS-IS will retransmit the LSP.
To configure LSP sending intervals:
Step
Remarks
N/A
N/A
3.     Specify the minimum interval for sending LSPs and the maximum LSP number that can be sent at a time.
isis timer lsp time [ count count ]
Optional.
By default, the minimum interval is 33 milliseconds, and the maximum LSP number that can be sent at a time is 5.
4.     Specify the LSP retransmission interval on a P2P link.
isis timer retransmit seconds
Optional.
5 seconds by default.
Configure a proper LSP retransmission interval to avoid unnecessary retransmissions.
Specifying LSP lengths
IS-IS messages cannot be fragmented at the IP layer because they are directly encapsulated in frames. Therefore, IS-IS routers in an area must send LSPs smaller than the smallest interface MTU in this area.
If the IS-IS routers have different interface MTUs, H3C recommends configuring the maximum size of generated LSP packets to be smaller than the smallest interface MTU in this area. Otherwise, the routers must dynamically adjust the LSP packet size to fit the smallest interface MTU, which takes time and affects other services.
To specify LSP lengths:
Step
Remarks
N/A
N/A
3.     Specify the maximum length of generated Level-1 LSPs or Level-2 LSPs.
lsp-length originate size [ level-1 | level-2 ]
Optional.
1497 bytes by default.
4.     Specify the maximum length of received LSPs.
lsp-length receive size
Optional.
Enabling LSP flash flooding
Changed LSPs can trigger SPF recalculation. To advertise the changed LSPs before the router recalculates routes for faster network convergence, enable LSP flash flooding.
To enable LSP flash flooding:
Step
Remarks
N/A
N/A
3.     Enable LSP flash flooding.
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
Enabling LSP fragment extension
After LSP fragment extension is enabled for an IS-IS process, the MTUs of all the interfaces running the IS-IS process must not be less than 512; otherwise, LSP fragment extension will not take effect.
At least one virtual system must be configured for the router to generate extended LSP fragments. An IS-IS process allows a maximum of 50 virtual systems.
To enable LSP fragment extension:
Step
Remarks
N/A
N/A
3.     Enable LSP fragment extension and specify the working mode.
lsp-fragments-extend [ [ level-1 | level-1-2 | level-2 ] | [ mode-1 | mode-2 ] ] *
4.     Configure a virtual system ID.
virtual-system virtual-system-id
Limiting LSP flooding
In well-connected NBMA networks, many P2P links exist. In this case, LSP flooding consumes extra bandwidth.
To avoid this, configure some interfaces as a mesh group, configure the blocked interfaces, or both.
·     After receiving an LSP, a member interface in a mesh group floods it out of the interfaces that do not belong to the mesh group.
·     If an interface is blocked, it does not send LSPs unless the neighbor sends LSP requests to it.
Before you configure this task, you must consider redundancy for interfaces to avoid the fact that LSP packets cannot be flooded due to link failures.
To add an interface into a mesh group and block an interface:
Step
Remarks
N/A
N/A
3.     Add the interface to a mesh group or block the interface.
·     Add the interface to a mesh group:
isis mesh-group mesh-group-number
·     block the interface:
isis mesh-group mesh-blocked
Use either method.
By default, the interface neither belongs to any mesh group nor is it blocked.
The mesh group feature takes effect only on P2P interfaces.
When the LSDB changes on a router, a route calculation starts. Frequent route calculations consume a lot of system resources, while route calculations at a proper interval improve efficiency. You can set an appropriate interval for SPF calculations as needed.
To configure the SPF parameters:
Step
Remarks
N/A
N/A
3.     Configure the SPF calculation interval.
timer spf maximum-interval [ initial-interval [ second-wait-interval ] ]
Optional.
The default SPF calculation interval is 10 seconds.
An IS-IS topology change causes network convergence. By assigning a high priority to specific IS-IS routes, you can achieve faster network convergence.
To assign a high priority to IS-IS routes:
Step
Remarks
N/A
N/A
3.     Assign a high priority to IS-IS routes.
priority high { ip-prefix prefix-name | tag tag-value }
Optional.
If no IS-IS route is assigned a high priority, IS-IS host routes are processed first in network convergence because they have higher priority than other types of IS-IS routes.
By setting the overload bit in sent LSPs, a router informs other routers of a failure that makes it incapable of routing and forwarding packets.
When an IS-IS router cannot record the complete LSDP due to running out of memory or some other reasons, it will calculate wrong routes. To make troubleshooting easier in this case, temporarily isolate the router from the IS-IS network by setting the overload bit.
To set the LSDB overload bit:
Step
Remarks
N/A
N/A
3.     Set the overload bit.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 ] [ allow { external | interlevel } * ]
Not set by default.
In IS-IS, a system ID identifies a router or host uniquely. A system ID has a fixed length of 6 bytes. When an administrator needs to view IS-IS neighbor information, routing table, or LSDB information, using the system IDs in dotted decimal notation is not convenient. To solve it, configure the mappings between system IDs and host names, as host names are easier to remember and use.
Such mappings can be configured manually or dynamically. Note the following:
·     When you use the display isis lsdb command on a router configured with dynamic system ID to host name mapping, router names rather than system IDs are displayed.
·     If you configure both dynamic and static system ID to host name mappings on a router, the host name for dynamic system ID to host name mapping applies.
Configuring a static system ID to host name mapping
Step
Remarks
N/A
N/A
3.     Configure a system ID to host name mapping for a remote IS.
is-name map sys-id map-sys-name
A system ID can only correspond to a host name.
Configuring dynamic system ID to host name mapping
You must configure a static system ID to host name mapping for any other router in a network. When a new router is added into the network or a mapping must be modified, perform configuration on all routers.
In this case, you can configure dynamic system ID to host name mapping. To do so, you must configure a host name for each router in the network. Each router advertises the host name in dynamic host name CLVs to other routers. All routers in the network then have all the mappings to generate a mapping table.
To help check the origin of LSPs in the LSDB, you can configure a name for the DIS in a broadcast network.
To configure dynamic system ID to host name mapping:
Step
Remarks
N/A
N/A
3.     Specify a host name for the router.
is-name sys-name
Not specified by default.
N/A
N/A
6.     Configure a DIS name.
isis dis-name symbolic-name
Optional.
This command takes effect only on a router with dynamic system ID to host name mapping configured.
This command is not supported on P2P interfaces.
Logging of neighbor state changes enables the router to output neighbor state changes to the console terminal.
To enable the logging of neighbor state changes:
Step
Remarks
N/A
N/A
3.     Enable the logging of neighbor state changes.
log-peer-change
Enabled by default.
To enhance the security of an IS-IS network, you can configure IS-IS authentication. IS-IS authentication involves neighbor relationship authentication, area authentication, and routing domain authentication.
Complete the following tasks before this configuration:
·     Enable IS-IS.
With neighbor relationship authentication configured, an interface adds the password in the specified mode into hello packets to the peer and checks the password in the received hello packets. If the authentication succeeds, it forms the neighbor relationship with the peer.
Follow these guidelines when you configure neighbor relationship authentication:
·     The authentication mode and password at both ends must be identical.
·     The level-1 and level-2 keywords are configurable on an interface that has had IS-IS enabled with the isis enable command.
·     If you configure an authentication mode and a password without specifying a level, the authentication mode and password apply to both Level-1 and Level-2.
·     If neither ip nor osi is specified, the OSI related fields in LSPs are checked.
To configure neighbor relationship authentication:
Step
Remarks
N/A
N/A
3.     Specify the authentication mode and password.
isis authentication-mode { md5 | simple } [ cipher ] password [ level-1 | level-2 ] [ ip | osi ]
By default, no authentication is configured.
Area authentication enables a router not to install routing information from untrusted routers into the Level-1 LSDB. The router encapsulates the authentication password in the specified mode into Level-1 packets (LSP, CSNP, and PSNP) and check the password in received Level-1 packets.
Routers in a common area must have the same authentication mode and password.
To configure area authentication:
Step
Remarks
N/A
N/A
3.     Specify the area authentication mode and password.
area-authentication-mode { md5 | simple } password [ ip | osi ]
By default, no area authentication is configured.
Routing domain authentication prevents untrusted routing information from entering into a routing domain. A router with the authentication configured encapsulates the password in the specified mode into Level-2 packets (LSP, CSNP, and PSNP) and check the password in received Level-2 packets.
All the routers in the backbone must have the same authentication mode and password.
To configure routing domain authentication:
Step
Remarks
N/A
N/A
3.     Specify the routing domain authentication mode and password.
domain-authentication-mode { md5 | simple } [ cipher ] password [ ip | osi ]
By default, no routing domain authentication is configured.
IMPORTANT:
·     The IS-IS GR and IS-IS NSR features are mutually exclusive.
·     Before performing a master/backup switchover between IRF member switches, configure the irf mac-address persistent always command to prevent bridge MAC address changes that can cause IS-IS GR failure after the switchover.
Restarting IS-IS on a router causes transient network disconnection and route reconvergence.
With the Graceful Restart (GR) feature, the restarting router—known as the GR restarter—can notify the event to its GR capable neighbors, GR capable neighbors—known as the "GR helpers"—will keep their adjacencies with the router within a configurable GR interval. After the restart, the router contacts its neighbors to retrieve its routing table.
During this process, the network keeps stable.
To configure GR on the GR restarter and GR helper:
Step
Remarks
N/A
2.     Enable IS-IS, and enter IS-IS view.
3.     Enable the GR capability for IS-IS.
graceful-restart
4.     Set the Graceful Restart interval.
graceful-restart interval timer
300 seconds by default.
The Graceful Restart interval is set as the holding time in the hello PDUs. Within the interval, the neighbors will keep their adjacency with the GR restarter.
5.     Suppress the SA bit during restart.
graceful-restart suppress-sa
Optional.
By default, the SA bit is not suppressed.
By enabling the GR restarter to suppress the Suppress-Advertisement (SA) bit in the hello PDUs, the neighbors will still advertise their adjacency with the GR restarter.
IMPORTANT:
·     The IS-IS NSR and IS-IS GR features are mutually exclusive.
·     Before performing a master/backup switchover between IRF member switches, configure the irf mac-address persistent always command to prevent bridge MAC address changes that can cause IS-IS NSR failure after the switchover.
According to the GR feature, after an active/standby switchover, the GR restarter obtains routing information from its neighbors, and the IS-IS process must learn all routes. If the network topology has changed during the switchover period, removed routes cannot be updated to the switch, which might cause black hole routes.
NSR is introduced to solve the problem, as it backs up IS-IS link state information from the AMB to the SMB. After an active/standby switchover, NSR can complete link state recovery and route regeneration without requiring the cooperation of other devices.
To configure IS-IS NSR:
Step
Remarks
N/A
N/A
3.     Enable IS-IS NSR.
non-stop-routing
4.     Set the NSR interval.
non-stop-routing interval interval-value
Optional.
0 seconds by default, that is, no NSR interval is configured.
When a link or a router on an IS-IS network fails, the packets on the path are discarded, or a routing loop occurs until IS-IS completes routing convergence based on the new network topology.
In such cases, you can enable IS-IS fast reroute (FRR) to reduce recovery time.
Figure 13 Network diagram
In Figure 13, after you enable FRR on Router B, IS-IS automatically calculates or designates a backup next hop when a network failure is detected. In this way, packets are directed to the backup next hop to reduce traffic recovery time. Meanwhile, IS-IS calculates the shortest path based on the new network topology, and forwards packets over the path after network convergence.
You can either enable IS-IS FRR to calculate a backup next hop automatically, or designate a backup next hop with a routing policy for routes matching specific criteria.
Before you configure IS-IS FRR, complete the following tasks:
·     Configure IP addresses for interfaces, and make sure that all neighboring nodes can reach each other at the network layer.
·     Enable IS-IS.
Configuration guidelines
·     Do not use FRR and BFD at the same time. Otherwise, FRR might fail to take effect.
·     The automatic backup next hop calculation of FRR and that of TE are mutually exclusive.
Configuring IS-IS FRR to automatically calculate a backup next hop
Step
Remarks
N/A
2.     Configure the source address of echo packets.
bfd echo-source-ip ip-address
3.     Enter IS-IS view.
N/A
4.     Enable IS-IS FRR to automatically calculate a backup next hop.
fast-reroute auto
Configuring IS-IS FRR to designate a backup next hop with a routing policy
You can use the apply fast-reroute backup-interface command to specify a backup next hop in a routing policy for routes matching specified criteria. For details about the apply fast-reroute backup-interface command and routing policy configurations, see "Configuring routing policies."
To configure IS-IS FRR:
Step
Remarks
N/A
N/A
4.     Enable IS-IS FRR to designate a backup next hop by using a routing policy.
Step
Remarks
N/A
N/A
3.     Enable SNMP trap.
is-snmp-traps enable
Enabled by default.
Step
Remarks
N/A
N/A
3.     Bind the IS-IS process with MIBs.
isis mib-binding process-id
By default, MIBs are bound with IS-IS process 1.
Step
Remarks
N/A
N/A
3.     Enable IS-IS on the interface.
4.     Enable BFD on the IS-IS interface.
isis bfd enable
Remarks
Display brief IS-IS configuration information.
display isis brief [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display the status of IS-IS debug switches.
display isis debug-switches { process-id | vpn-instance vpn-instance-name } [ | { begin | exclude | include } regular-expression ]
Display the IS-IS GR state.
display isis graceful-restart status [ level-1 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display information about IS-IS enabled interfaces.
display isis interface [ statistics | [ interface-type interface-number ] [ verbose ] ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display IS-IS LSDB information.
display isis lsdb [ [ l1 | l2 | level-1 | level-2 ] | [ lsp-id lspid | lsp-name lspname ] | local | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display IS-IS mesh group information.
display isis mesh-group [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display the host-name-to-system-ID mapping table.
display isis name-table [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display IS-IS neighbor information.
display isis peer [ statistics | verbose ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display IS-IS IPv4 routing information.
display isis route [ ipv4 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id [ ipv4-unicast topology-name ] | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display IS-IS SPF calculation log information.
display isis spf-log [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Display IS-IS statistics.
display isis statistics [ level-1 | level-1-2 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
Clear IS-IS process data structure information.
reset isis all [ process-id | vpn-instance vpn-instance-name ]
Available in user view.
Clear the data structure information of an IS-IS neighbor.
reset isis peer system-id [ process-id | vpn-instance vpn-instance-name ]
By default, Ethernet, VLAN, and aggregate interfaces are down. Before configuring these interfaces, bring them up by using the undo shutdown command.
Network requirements
As shown in Figure 14, Switch A, B, C, and D reside in an IS-IS AS. Switch A and B are Level-1 switches, Switch D is a Level-2 switch, and Switch C is a Level-1-2 switch. Switch A, B, and C are in Area 10, while Switch D is in Area 20.
Figure 14 Network diagram
Configuration procedure
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure IS-IS:
# Configure Switch A.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.0000.0000.0001.00
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface100] isis enable 1
# Configure Switch B.
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.0000.0000.0002.00
[SwitchB-isis-1] quit
[SwitchB-Vlan-interface200] isis enable 1
# Configure Switch C.
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 10.0000.0000.0003.00
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface100] isis enable 1
[SwitchC-Vlan-interface200] isis enable 1
[SwitchC-Vlan-interface300] isis enable 1
[SwitchC-Vlan-interface300] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.0000.0000.0004.00
[SwitchD-isis-1] quit
[SwitchD] interface vlan-interface 100
[SwitchD-Vlan-interface100] isis enable 1
[SwitchD-Vlan-interface100] quit
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] isis enable 1
[SwitchD-Vlan-interface300] quit
3.     Verify the configuration:
# Display the IS-IS LSDB of each switch to check the LSP integrity.
[SwitchA] display isis lsdb
                        Database information for ISIS(1)
                          Level-1 Link State Database
LSPID                 Seq Num      Checksum   Holdtime   Length  ATT/P/OL
0000.0000.0001.00-00* 0x00000004   0xdf5e     1096       68      0/0/0
0000.0000.0002.00-00  0x00000004   0xee4d     1102       68      0/0/0
0000.0000.0002.01-00  0x00000001   0xdaaf     1102       55      0/0/0
0000.0000.0003.00-00  0x00000009   0xcaa3     1161       111     1/0/0
0000.0000.0003.01-00  0x00000001   0xadda     1112       55      0/0/0
[SwitchB] display isis lsdb
0000.0000.0001.00-00  0x00000006   0xdb60     988         68      0/0/0
0000.0000.0002.00-00* 0x00000008   0xe651     1189        68      0/0/0
0000.0000.0002.01-00* 0x00000005   0xd2b3     1188        55      0/0/0
0000.0000.0003.00-00  0x00000014   0x194a     1190        111     1/0/0
0000.0000.0003.01-00  0x00000002   0xabdb     995         55      0/0/0
[SwitchC] display isis lsdb
0000.0000.0001.00-00  0x00000006   0xdb60     847         68      0/0/0
0000.0000.0002.00-00  0x00000008   0xe651     1053        68      0/0/0
0000.0000.0002.01-00  0x00000005   0xd2b3     1052        55      0/0/0
0000.0000.0003.00-00* 0x00000014   0x194a     1051        111     1/0/0
0000.0000.0003.01-00* 0x00000002   0xabdb     854         55      0/0/0
                          Level-2 Link State Database
0000.0000.0003.00-00* 0x00000012   0xc93c     842         100     0/0/0
0000.0000.0004.00-00  0x00000026   0x331      1173        84      0/0/0
0000.0000.0004.01-00  0x00000001   0xee95     668         55      0/0/0
[SwitchD] display isis lsdb
0000.0000.0003.00-00  0x00000013   0xc73d        1003          100     0/0/0
0000.0000.0004.00-00* 0x0000003c   0xd647        1194          84      0/0/0
0000.0000.0004.01-00* 0x00000002   0xec96        1007          55      0/0/0
# Display the IS-IS routing information of each switch. Level-1 switches must have a default route with the next hop being the Level-1-2 switch. The Level-2 switch must have both routing information of Level-1 and Level-2.
[SwitchA] display isis route
                         Route information for ISIS(1)
                     ISIS(1) IPv4 Level-1 Forwarding Table
 IPV4 Destination     IntCost   ExtCost ExitInterface   NextHop      Flags
 10.1.1.0/24          10        NULL    Vlan100         Direct       D/L/-
 10.1.2.0/24          20        NULL    Vlan100         10.1.1.1     R/-/-
 192.168.0.0/24       20        NULL    Vlan100         10.1.1.1     R/-/-
 0.0.0.0/0            10        NULL    Vlan100         10.1.1.1     R/-/-
      Flags: D-Direct, R-Added to RM, L-Advertised in LSPs, U-Up/Down Bit Set
[SwitchC] display isis route
 192.168.0.0/24       10         NULL    Vlan300        Direct       D/L/-
 10.1.2.0/24          10         NULL    Vlan200        Direct       D/L/-
                     ISIS(1) IPv4 Level-2 Forwarding Table
 172.16.0.0/16        20        NULL    Vlan300         192.168.0.2  R/-/-
[SwitchD] display isis route
 10.1.1.0/24          20        NULL    Vlan300         192.168.0.1  R/-/-
 10.1.2.0/24          20        NULL    Vlan300         192.168.0.1  R/-/-
 172.16.0.0/16        10        NULL    Vlan100         Direct       D/L/-
DIS election configuration
As shown in Figure 15, Switch A, B, C, and D reside in IS-IS area 10 on a broadcast network (Ethernet). Switch A and Switch B are Level-1-2 switches, Switch C is a Level-1 switch, and Switch D is a Level-2 switch.
Change the DIS priority of Switch A to make it elected as the Level-1-2 DIS router.
Figure 15 Network diagram
2.     Enable IS-IS:
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchB-Vlan-interface100] isis enable 1
[SwitchC] isis 1
[SwitchC-isis-1] is-level level-1
[SwitchD] isis 1
[SwitchD-isis-1] network-entity 10.0000.0000.0004.00
# Display information about IS-IS neighbors of Switch A.
[SwitchA] display isis peer
                          Peer information for ISIS(1)
  System Id: 0000.0000.0002
  Interface: Vlan-interface100       Circuit Id: 0000.0000.0003.01
  State: Up     HoldTime: 21s        Type: L1(L1L2)     PRI: 64
  System Id: 0000.0000.0003
  State: Up     HoldTime: 27s        Type: L1           PRI: 64
  Interface: Vlan-interface100       Circuit Id: 0000.0000.0004.01
  State: Up     HoldTime: 28s        Type: L2(L1L2)     PRI: 64
  System Id: 0000.0000.0004
  State: Up     HoldTime: 30s        Type: L2          PRI: 64
# Display information about IS-IS interfaces of Switch A.
[SwitchA] display isis interface
                       Interface information for ISIS(1)
Id      IPV4.State      IPV6.State    MTU    Type    DIS
001        Up             Down       1497    L1/L2   No/No
# Display information about IS-IS interfaces of Switch C.
[SwitchC] display isis interface
001         Up            Down        1497   L1/L2   Yes/No
# Display information about IS-IS interfaces of Switch D.
[SwitchD] display isis interface
001        Up              Down       1497    L1/L2    No/Yes
By using the default DIS priority, Switch C is the Level-1 DIS, and Switch D is the Level-2 DIS. The pseudonodes of Level-1 and Level-2 are 0000.0000.0003.01 and 0000.0000.0004.01.
3.     Configure the DIS priority:
# Configure the DIS priority on Switch A.
[SwitchA-Vlan-interface100] isis dis-priority 100
# Display IS-IS neighbors of Switch A.
  Interface: Vlan-interface100       Circuit Id: 0000.0000.0001.01
001         Up             Down         1497   L1/L2  Yes/Yes
After the DIS priority configuration, Switch A becomes the Level-1-2 DIS, and the pseudonode is 0000.0000.0001.01.
# Display information about IS-IS neighbors and interfaces of Switch C.
[SwitchC] display isis peer
  State: Up     HoldTime: 25s        Type: L1           PRI: 64
  System Id: 0000.0000.0001
  State: Up     HoldTime: 7s         Type: L1           PRI: 100
# Display information about IS-IS neighbors and interfaces of Switch D.
[SwitchD] display isis peer
  State: Up     HoldTime: 9s         Type: L2           PRI: 100
  State: Up     HoldTime: 28s        Type: L2           PRI: 64
Configuring IS-IS route redistribution
As shown in Figure 16, Switch A, B, C, and D reside in the same AS. They use IS-IS to interconnect. Switch A and Switch B are Level-1 routers, Switch D is a Level-2 router, and Switch C is a Level-1-2 router.
It is required to redistribute RIP routes into IS-IS on Switch D.
Figure 16 IS-IS route redistribution
2.     Configure basic IS-IS:
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
[SwitchD] interface interface vlan-interface 300
# Display IS-IS routing information on each switch.
 10.1.1.0/24          10       NULL    VLAN100        Direct        D/L/-
 10.1.2.0/24          20       NULL    VLAN100        10.1.1.1      R/-/-
 192.168.0.0/24       20       NULL    VLAN100        10.1.1.1      R/-/-
 0.0.0.0/0            10       NULL    VLAN100        10.1.1.1      R/-/-
 10.1.2.0/24          10        NULL    VLAN200         Direct      D/L/-
 192.168.0.0/24       10        NULL    VLAN300         Direct      D/L/-
 10.1.1.0/24          20        NULL    VLAN300        192.168.0.1  R/-/-
 10.1.2.0/24          20        NULL    VLAN300        192.168.0.1  R/-/-
3.     Configure RIPv2 on Switch D and Switch E, and configure route redistribution from RIP to IS-IS on Switch D:
# Configure RIPv2 on Switch D.
[SwitchD] rip 1
[SwitchD-rip-1] network 10.0.0.0
[SwitchD-rip-1] version 2
[SwitchD-rip-1] undo summary
# Configure RIPv2 on Switch E.
[SwitchE] rip 1
[SwitchE-rip-1] network 10.0.0.0
[SwitchE-rip-1] version 2
[SwitchE-rip-1] undo summary
# Configure route redistribution from RIP to IS-IS on Switch D.
[SwitchD-rip-1] quit
[SwitchD] isis 1
[SwitchD–isis-1] import-route rip level-2
# Display IS-IS routing information on Switch C.
 10.1.4.0/24          10        NULL    VLAN300        192.168.0.2  R/L/-
 10.1.5.0/24          20        NULL    VLAN300        192.168.0.2  R/L/-
 10.1.6.0/24          20        NULL    VLAN300        192.168.0.2  R/L/-
IS-IS Graceful Restart configuration example
Switch A, Switch B, and Switch C belong to the same IS-IS routing domain, as illustrated in Figure 17.
Figure 17 Network diagram
1.     Configure the IP addresses and subnet masks for interfaces. (Details not shown.)
2.     Configure IS-IS on the switches to make sure that Switch A, Switch B, and Switch C can communicate with each other at layer 3 and dynamic route update can be implemented among them with IS-IS. (Details not shown.)
3.     Configure IS-IS Graceful Restart:
# Enable IS-IS Graceful Restart on Switch A and configure the Graceful Restart Interval.
[SwitchA] isis 1
[SwitchA-isis-1] graceful-restart
[SwitchA-isis-1] graceful-restart interval 150
[SwitchA-isis-1] return
# Configure Graceful Restart on Switch B and Switch C in the same way as Switch A. (Details not shown.)
4.     Verify the configuration:
After Switch A establishes adjacencies with Switch B and Switch C, they begin to exchange routing information. Restart IS-IS on Switch A, which enters into the restart state and sends connection requests to its neighbors through the Graceful Restart mechanism to synchronize the LSDB. Using the display isis graceful-restart status command can display the IS-IS GR status on Switch A.
# Restart the IS-IS process on Switch A.
<SwitchA> reset isis all 1
Warning : Reset ISIS process? [Y/N]:y
# Check the Graceful Restart status of IS-IS on Switch A.
<SwitchA> display isis graceful-restart status
IS-IS(1) Level-1 Restart Status
Restart Interval: 150
SA Bit Supported
  Total Number of Interfaces = 1
  Restart Status: RESTARTING
  Number of LSPs Awaited: 3
  T3 Timer Status:
    Remaining Time: 140
  T2 Timer Status:
    Remaining Time: 59
IS-IS(1) Level-2 Restart Status
SA Bit Supported
  T3 Timer Status:
    Remaining Time: 140
  T2 Timer Status:
Remaining Time: 59
IS-IS NSR configuration example
Switch S, Switch A, and Switch B belong to the same IS-IS routing domain as illustrated in Figure 18. Enable IS-IS NSR on Switch S to ensure correct routing when an active/standby switchover occurs on Switch S.
Figure 18 Network diagram
1.     Configure IP addresses and subnet masks for interfaces on the switches. (Details not shown.)
2.     Configure IS-IS on the switches to make sure that Switch S, Switch A, and Switch B can communicate with each other at Layer 3, and dynamic route update can be implemented among them with IS-IS. (Details not shown.)
3.     Enable IS-IS NSR on Switch S.
<SwitchS> system-view
[SwitchS] isis 1
[SwitchS-isis-1] non-stop-routing
[SwitchS-isis-1] non-stop-routing interval 30
[SwitchS-isis-1] return
After Switch S establishes neighbor relationships with Switch A and Switch B, they start to exchange routing information. After network convergence, perform an active/standby switchover on Switch S. During the switchover period, use the display isis peer command to check the neighbor relationship between Switch A and Switch S and between Switch B and Switch S; use the display isis route command to check if there are routes from Switch A to the loopback interface on Switch B and from Switch B to the loopback interface on Switch A.
# Perform an active/standby switchover on Switch S.
[SwitchS] slave switchover enable
Caution!!! Confirm to switch slave to master? [Y/N]:Y
# Display IS-IS neighbors and routes on Switch A.
<SwitchA> display isis peer
  Interface: vlan100                 Circuit Id: 0000.0000.0001.01
  State: Up     HoldTime: 25s        Type: L1(L1L2)     PRI: 64
  State: Up     HoldTime: 27s        Type: L2(L1L2)     PRI: 64
<SwitchA> display isis route
 12.12.12.0/24       10         NULL    vlan100         Direct          D/L/-
 22.22.22.22/32      10         NULL    Loop0           Direct          D/-/-
 14.14.14.0/32       10         NULL    vlan100         12.12.12.2      R/L/-
 44.44.44.44/32      10         NULL    vlan100         12.12.12.2      R/L/-
# Display IS-IS neighbors and routes on Switch B.
<SwitchB> display isis peer
  Interface: vlan200                 Circuit Id: 0000.0000.0001.01
<SwitchB> display isis route
 14.14.14.0/24       10         NULL    vlan200         Direct          D/L/-
 44.44.44.44/32      10         NULL    Loop0           Direct          D/-/-
 12.12.12.0/32       10         NULL    vlan200         14.14.14.4      R/L/-
 22.22.22.22/32      10         NULL    vlan200         14.14.14.4      R/L/-
The output shows that the neighbor relationships and routing information on Switch A and Switch B have not changed, which means the neighbors cannot sense the switchover on Switch S.
IS-IS FRR configuration example
Switch S, Switch A, and Switch D belong to the same IS-IS routing domain, as illustrated in Figure 19. Configure IS-IS FRR so that when Link A between Switch S and Switch D fails, traffic is switched to Link B immediately.
Figure 19 Network diagram
1.     Configure IP addresses and subnet masks for interface on the switches. (Details not shown.)
2.     Configure IS-IS on the switches to make sure that Switch A, Switch D, and Switch S can communicate with each other at Layer 3, and dynamic route update can be implemented among them with IS-IS.
3.     Configure IS-IS FRR:
Enable IS-IS FRR to either automatically calculate a backup next hop, or designate a backup next hop by using a routing policy.
¡     (Method 1.) Enable IS-IS FRR to automatically calculate a backup next hop:
# Configure Switch S.
[SwitchS] bfd echo-source-ip 1.1.1.1
[SwitchS] isis 1
[SwitchS-isis-1] fast-reroute auto
[SwitchS-isis-1] quit
[SwitchD] bfd echo-source-ip 4.4.4.4
[SwitchD] isis 1
[SwitchD-isis-1] fast-reroute auto
¡     (Method 2.) Enable IS-IS FRR to designate a backup next hop by using a routing policy.
[SwitchS] ip ip-prefix abc index 10 permit 4.4.4.4 32
[SwitchS] route-policy frr permit node 10
[SwitchS-route-policy] if-match ip-prefix abc
[SwitchS-route-policy] apply fast-reroute backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchS-route-policy] quit
[SwitchS] isis 1
[SwitchS-isis-1] fast-reroute route-policy frr
[SwitchD] ip ip-prefix abc index 10 permit 1.1.1.1 32
[SwitchD-route-policy] if-match ip-prefix abc
[SwitchD-route-policy] apply fast-reroute backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchD-route-policy] quit
[SwitchD] isis 1
[SwitchD-isis-1] fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Switch S to view the backup next hop information.
[SwitchS] display ip routing-table 4.4.4.4 verbose
Routing Table : Public
Summary Count : 1
  Destination: 4.4.4.4/32
     Protocol: ISIS            Process ID: 1
   Preference: 10                    Cost: 10
 IpPrecedence:                    QosLcId:
      NextHop: 13.13.13.2       Interface: Vlan-interface200
    BkNextHop: 12.12.12.2     BkInterface: Vlan-interface100
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
  BKTunnel ID: 0x0                BKLabel: NULL
        State: Active Adv             Age: 00h01m27s
          Tag: 0
# Display route 1.1.1.1/32 on Switch D to view the backup next hop information.
[SwitchD] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
  Destination: 1.1.1.1/32
      NextHop: 13.13.13.1       Interface: Vlan-interface200
    BkNextHop: 24.24.24.2     BkInterface: Vlan-interface101
          Tag: 0
IS-IS authentication configuration example
As shown in Figure 20, Switch A, Switch B, Switch C, and Switch D reside in the same IS-IS routing domain.
Switch A, Switch B, and Switch C belong to Area 10, and Switch D belongs to Area 20.
Configure neighbor relationship authentication between neighbors. Configure area authentication in Area 10 to prevent untrusted routes from entering into the area. Configure routing domain authentication on Switch C and Switch D to prevent untrusted routes from entering the routing domain.
Figure 20 IS-IS authentication configuration
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
[SwitchD-isis-1] network-entity 20.0000.0000.0001.00
3.     Configure neighbor relationship authentication between neighbors:
# Specify the MD5 authentication mode and password eRq on VLAN-interface 100 of Switch A and on VLAN-interface 100 of Switch C.
[SwitchA-Vlan-interface100] isis authentication-mode md5 eRg
[SwitchC-Vlan-interface100] isis authentication-mode md5 eRg
# Specify the MD5 authentication mode and password t5Hr on VLAN-interface 200 of Switch B and on VLAN-interface 200 of Switch C.
[SwitchB-Vlan-interface200] isis authentication-mode md5 t5Hr
[SwitchC-Vlan-interface200] isis authentication-mode md5 t5Hr
# Specify the MD5 authentication mode and password hSec on VLAN-interface 300 of Switch D and on VLAN-interface 300 of Switch C.
[SwitchC-Vlan-interface300] isis authentication-mode md5 hSec
[SwitchD-Vlan-interface300] isis authentication-mode md5 hSec
4.     Configure area authentication. Specify the MD5 authentication mode and password 10Sec on Switch A, Switch B, and Switch C.
[SwitchA] isis 1
[SwitchA-isis-1] area-authentication-mode md5 10Sec
[SwitchB] isis 1
[SwitchB-isis-1] area-authentication-mode md5 10Sec
[SwitchC] isis 1
[SwitchC-isis-1] area-authentication-mode md5 10Sec
5.     Configure routing domain authentication. Specify the MD5 authentication mode and password 1020Sec on Switch C and Switch D.
[SwitchC] isis 1
[SwitchC-isis-1] domain-authentication-mode md5 1020Sec
[SwitchD] isis 1
[SwitchD-isis-1] domain-authentication-mode md5 1020Sec
Configuring BFD for IS-IS
As shown in Figure 21, IS-IS is enabled on Switch A, Switch B and Switch C that are reachable to each other at the network layer.
After the link over which Switch A and Switch B communicate through the Layer-2 switch fails, BFD can quickly detect the failure and notify IS-IS of the failure. Then Switch A and Switch B communicate through Switch C.
Figure 21 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int10
10.1.0.102/24
Switch B
Vlan-int10
10.1.0.100/24
Vlan-int11
11.1.1.1/24
Vlan-int13
13.1.1.1/24
Switch C
Vlan-int11
11.1.1.2/24
Vlan-int13
13.1.1.2/24
[SwitchA] isis
[SwitchA-Vlan-interface10] isis enable
[SwitchA-Vlan-interface11] isis enable
[SwitchB] isis
[SwitchB-Vlan-interface10] isis enable
[SwitchB] interface vlan-interface 13
[SwitchB-Vlan-interface13] isis enable
[SwitchB-Vlan-interface13] quit
[SwitchC] isis
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] isis enable
[SwitchC-Vlan-interface11] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] isis enable
[SwitchC-Vlan-interface13] quit
3.     Configure BFD parameters:
# Enable BFD on Switch A and configure BFD parameters.
[SwitchA-Vlan-interface10] isis bfd enable
[SwitchA-Vlan-interface10] bfd min-receive-interval 500
[SwitchA-Vlan-interface10] bfd min-transmit-interval 500
[SwitchA-Vlan-interface10] bfd detect-multiplier 7
# Enable BFD on Switch B and configure BFD parameters.
[SwitchB] bfd session init-mode active
[SwitchB-Vlan-interface10] isis bfd enable
[SwitchB-Vlan-interface10] bfd min-receive-interval 500
[SwitchB-Vlan-interface10] bfd min-transmit-interval 500
[SwitchB-Vlan-interface10] bfd detect-multiplier 8
[SwitchB-Vlan-interface10] return
The following configurations are made on Switch A. Configurations for Switch B are similar. (Details not shown.)
# Display the BFD information on Switch A.
<SwitchA> display bfd session
 Total Session Num: 1            Init Mode: Active
 Session Working Under Ctrl Mode:
 LD/RD         SourceAddr      DestAddr        State Holdtime Interface
 3/1           10.1.0.102      10.1.0.100      Up    1700ms   vlan10
# Display routes destined for 120.1.1.0/24 on Switch A.
<SwitchA> display ip routing-table 120.1.1.0 verbose
Summary Count : 2
  Destination: 120.1.1.0/24
     Protocol: ISIS            Process ID: 0
   Preference: 0                     Cost: 2
      NextHop: 192.168.0.100    Interface: Vlan-interface10
    BkNextHop: 0.0.0.0        BkInterface:
        State: Active Adv             Age: 00h58m10s
          Tag: 0
   Preference: 10                    Cost: 4
      NextHop: 10.1.1.100       Interface: Vlan-interface11
        State: Invalid Adv            Age: 00h58m05s
          Tag: 0
The output shows that Switch A and Switch B communicate through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
# Enable debugging on Switch A.
<SwitchA> debugging isis bfd-event
<SwitchA> terminal debugging
#Aug  8 14:54:05:362 2008 SwitchA IFNET/4/INTERFACE UPDOWN:
 Trap 1.3.6.1.6.3.1.1.5.3<linkDown>: Interface 983041 is Down, ifAdminStatus is 1, ifOperStatus is 2
#Aug  8 14:54:05:363 2008 SwitchA ISIS/4/ADJ_CHANGE:TrapID(1.3.6.1.2.1.138.0.17<isisAdjacencyChange>), ISIS Level-2 Adjencency IN Circuit-983041 State Change.
#Aug  8 14:54:05:364 2008 SwitchA ISIS/4/ADJ_CHANGE:TrapID(1.3.6.1.2.1.138.0.17<isisAdjacencyChange>), ISIS Level-1 Adjencency IN Circuit-983041 State Change.
%Aug  8 14:54:05:365 2008 SwitchA IFNET/4/LINK UPDOWN: Vlan-interface10 link status is DOWN
%Aug  8 14:54:05:366 2008 SwitchA IFNET/4/UPDOWN: Line protocol on the interface Vlan-interface10 is DOWN
%Aug  8 14:54:05:367 2008 SwitchA ISIS/4/ADJLOG:ISIS-1-ADJCHANGE: Adjacency To 0000.0000.0002 (vlan10) DOWN, Level-2 Circuit Down.
%Aug  8 14:54:05:367 2008 SwitchA ISIS/4/ADJLOG:ISIS-1-ADJCHANGE: Adjacency To 0000.0000.0002 (vlan10) DOWN, Level-2 Adjacency clear.
%Aug  8 14:54:05:368 2008 SwitchA ISIS/4/ADJLOG:ISIS-1-ADJCHANGE: Adjacency To 0000.0000.0002 (vlan10) DOWN, Level-1 Circuit Down.
%Aug  8 14:54:05:369 2008 SwitchA ISIS/4/ADJLOG:ISIS-1-ADJCHANGE: Adjacency To 0000.0000.0002 (vlan10) DOWN, Level-1 Adjacency clear.
*Aug  8 14:54:05:370 2008 SwitchA ISIS/6/ISIS:
 ISIS-1-BFD: Success to send msg. Msg type 1 delete session. IfPhyIndex: 5 ,DstIPAddr: 10.1.0.100 , SrcIPAddr:10.1.0.102. NeighborType:Level-2.
 ISIS-1-BFD: Success to send msg. Msg type 1 delete session. IfPhyIndex: 5 ,DstIPAddr: 10.1.0.100 , SrcIPAddr:10.1.0.102. NeighborType:Level-1.
The output shows that Switch A can quickly detect the link state change.
The output shows that Switch A has deleted the BFD session on VLAN-interface 10 to Switch B and displays no output.
Summary Count : 2
          Tag: 0
The output shows that Switch A and Switch B communicate through VLAN-interface 11.
