HomeSupportSwitchesH3C S9500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guide-Release1728-6W17001-Fundamentals Configuration Guide
08-Device Management Configuration
08-Device Management Configuration 260.6 KB
Device management includes monitoring the operating status of devices and configuring their running parameters.
·       The switch operates in IRF or standalone (the default) mode. For more information about the IRF mode, see IRF Configuration Guide.
·       Storage media include Flash, compact Flash (CF), and universal serial bus (USB). Flash is exemplified in this document.
·       The configuration tasks in this document are all optional and independent from one another.
Configuring the device name
A device name identifies a device in a network and works as the user view prompt at the CLI. For example, if the device name is Sysname, the user view prompt is <Sysname>.
To configure the device name:
Step
Remarks
1.     Enter system view.
N/A
2.     Configure the device name.
sysname sysname
Optional.
By default, the device name is H3C.
Changing and displaying the system time
Changing the system time
The system time, displayed by system time stamp, is determined by the configured relative time, time zone, and daylight saving time. To view the system time, use the display clock command. The system time should be precise to make sure that the switch can work with other devices.
To configure the system time:
Step
Remarks
1.     Set the time and date.
clock datetime time date
Optional.
Available in user view.
2.     Enter system view.
N/A
3.     Set the time zone.
Optional.
Universal time coordinated (UTC) time zone by default.
4.     Set a daylight saving time scheme.
·       Set a non-recurring scheme:
clock summer-time zone-name one-off start-time start-date end-time end-date add-time
·       Set a recurring scheme:
clock summer-time.zone-name repeating start-time start-date end-time end-date add-time
Optional.
Use either command.
By default, daylight saving time is disabled and the UTC time zone applies.
Displaying the system time
The system time is determined by the commands clock datetime, clock timezone and clock summer-time. If these three commands are not configured, the display clock command displays the original system time. If you combine these three commands in different ways, the system time is displayed in the ways as shown in Table 1. The following describes the parameters in the configuration column:
·           1 indicates date-time has been configured with the clock datetime command.
·           2 indicates time-zone has been configured with the clock timezone command and the offset time is zone-offset.
·           3 indicates daylight saving time has been configured with the clock summer-time command and the offset time is summer-offset.
·           [1] indicates the clock datetime command is an optional configuration, which can be either executed or not executed.
·           The default system time is 2005/1/1 1:00:00 in the example.
Table 1 System time configuration
Configuration
System time configured
Example
1
date-time
Configure: clock datetime 1:00 2007/1/1
System time configured: 01:00:00 UTC Mon 01/01/2007
2
The original system time ± “zone-offset
Configure: clock timezone zone-time add 1
System time configured: 02:00:00 zone-time Sat 01/01/2005
1 and 2
date-time ± zone-offset
Configure: clock datetime 2:00 2007/2/2 and clock timezone zone-time add 1
System time configured: 03:00:00 zone-time Fri 02/02/2007
[1], 2 and 1
date-time
Configure: clock timezone zone-time add 1 and clock datetime 3:00 2007/3/3
System time configured: 03:00:00 zone-time Sat 03/03/2007
3
If the original system time is not in the daylight saving time range, the system time configured is the original system time.
Configure: clock summer-time ss one-off 1:00 2006/1/1 1:00 2006/8/8 2
System time configured: 01:00:00 UTC Sat 01/01/2005
If the original system time is in the daylight saving time range, the system time configured is the original system time + “summer-offset”.
Configure: clock summer-time ss one-off 00:30 2005/1/1 1:00 2005/8/8 2
System time configured: 03:00:00 ss Sat 01/01/2005
If the original system time + “summer-offset” is not in the daylight saving time range, the system time configured is the original system time. After this configuration, if you disable the daylight saving, the system time becomes the system time minus “summer-offset”.
1 and 3
If “date-time” is not in the daylight saving time range, the system time configured is “date-time”.
Configure: clock datetime 1:00 2007/1/1 and clock summer-time ss one-off 1:00 2006/1/1 1:00 2006/8/8 2
If “date-time” is in the daylight saving time range, the system time configured is “date-time + “summer-offset”.
Configure: clock datetime 8:00 2007/1/1 and clock summer-time ss one-off 1:00 2007/1/1 1:00 2007/8/8 2
System time configured: 10:00:00 ss Mon 01/01/2007
If “date-time + “summer-offset” is not in the daylight saving time range, the system time configured is “date-time”. After this configuration, if you disable the daylight saving, the system time becomes the system time minus “summer-offset”.
[1], 3 and 1
Configure: clock summer-time ss one-off 1:00 2007/1/1 1:00 2007/8/8 2 and clock datetime 1:00 2008/1/1
System time configured: 01:00:00 UTC Tue 01/01/2008
date-time” is in the daylight saving time range:
If the value of “date-time - summer-offset” is not in the summer-time range, the system time configured is “date-time - summer-offset”;
If the value of “date-time- summer-offset” is in the summer-time range, the system time configured is “date-time”.
Configure: clock summer-time ss one-off 1:00 2007/1/1 1:00 2007/8/8 2 and clock datetime 1:30 2007/1/1
System time configured: 23:30:00 UTC Sun 12/31/2006
Configure: clock summer-time ss one-off 1:00 2007/1/1 1:00 2007/8/8 2 and clock datetime 3:00 2007/1/1
System time configured: 03:00:00 ss Mon 01/01/2007
2 and 3 or 3 and 2
If the value of the original system time ± “zone-offset” is not in the summer-time range, the system time configured is the original system time ± “zone-offset”.
Configure: clock timezone zone-time add 1 and clock summer-time ss one-off 1:00 2007/1/1 1:00 2007/8/8 2
If the value of the original system time ± “zone-offset” is in the summer-time range, the system time configured is the original system time ± “zone-offset” + “summer-offset”.
Configure: clock timezone zone-time add 1 and clock summer-time ss one-off 1:00 2005/1/1 1:00 2005/8/8 2
System time configured: 04:00:00 ss Sat 01/01/2005
1, 2 and 3 or 1, 3 and 2
If the value of “date-time”±”zone-offset” is not in the summer-time range, the system time configured is “date-time”±”zone-offset”.
Configure: clock datetime 1:00 2007/1/1, clock timezone zone-time add 1 and clock summer-time ss one-off 1:00 2008/1/1 1:00 2008/8/8 2
System time configured: 02:00:00 zone-time Mon 01/01/2007
If the value of “date-time”±”zone-offset” is in the summer-time range, the system time configured is “date-time”±”zone-offset”+”summer-offset”.
Configure: clock datetime 1:00 2007/1/1, clock timezone zone-time add 1 and clock summer-time ss one-off 1:00 2007/1/1 1:00 2007/8/8 2
System time configured: 04:00:00 ss Mon 01/01/2007
[1], 2, 3 and 1 or [1], 3, 2 and 1
Configure: clock timezone zone-time add 1, clock summer-time ss one-off 1:00 2008/1/1 1:00 2008/8/8 2 and clock datetime 1:00 2007/1/1
System time configured: 01:00:00 zone-time Mon 01/01/2007
If the value of “date-time-summer-offset” is not in the summer-time range, the system time configured is “date-time-summer-offset”;
If the value of “date-time-summer-offset” is in the summer-time range, the system time configured is “date-time”.
Configure: clock timezone zone-time add 1, clock summer-time ss one-off 1:00 2008/1/1 1:00 2008/8/8 2 and clock datetime 1:30 2008/1/1
System time configured: 23:30:00 zone-time Mon 12/31/2007
Configure: clock timezone zone-time add 1, clock summer-time ss one-off 1:00 2008/1/1 1:00 2008/8/8 2 and clock datetime 3:00 2008/1/1
System time configured: 03:00:00 ss Tue 01/01/2008
Enabling displaying the copyright statement
The device by default displays the copyright statement when a Telnet or SSH user logs in, or when a console user quits user view. You can disable or enable the function as needed. The following is a sample copyright statement:
* Copyright (c) 2004-2011 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
* no decompiling or reverse-engineering shall be allowed.                    * **************************************************************************
To enable displaying the copyright statement:
Step
Remarks
N/A
2.     Enable displaying copyright statement.
copyright-info enable
Optional
Enabled by default
Configuring banners
Introduction to banners
Banners are messages that the system displays when a user connects to the device to perform login authentication, and start interactive configuration.
Banner types
The system supports the following types of banners:
·           Legal banner appears after the system displays the copyright or license statement for a user attempting to log in. To continue authentication or login, the user must enter Y or press Enter. To quit the process, the user must enter N. Y and N are case-insensitive.
·           Message of the Day (MOTD) banner displays the greeting message, and appears after the legal banner and before the login banner. Support for this banner depends on the device model.
·           Login banner appears only when password or scheme login authentication has been configured.
·           Incoming banner appears for Modem dial-in users and the shell banner appears for users that use any other access method to access the CLI.
Message input modes
The system supports single-line input and multiple-line input for configuring a banner.
·           Single-line input:
In single-line input mode, all banner information comes after the command keywords in the same line. The start and end characters of the input text must be the same but are not part of the banner information. The input text, together with the command keywords, cannot exceed 510 characters. In this mode, do not press Enter after typing the banner information. For example, to configure a banner like “Have a nice day.” use the following command:
<System> system-view
[System] header shell %Have a nice day.%
·           Multiple-line input:
In multiple-line input mode, you can press Enter to separate the banner information in multiple lines. In this case, up to 2000 characters can be typed.
Use one of the following methods to implement multi-line input mode:
¡  Method I—Press the Enter key after the command keywords, type the banner information, and finish with the % character. The % character is not part of the banner information. For example, to configure a banner like “Have a nice day. Please input the Password.”, use the following commands:
Please input banner content, and quit with the character '%'.――System prompt
Have a nice day.
Please input the Password.%
¡  Method II—Type a character after the command keywords at the first line, and press Enter. Type the banner information, and finish with the character you typed at the first line. The start character and the end character are not part of the banner information. For example, to configure a banner like “Have a nice day. Please input the Password.”, use the following commands:
[System] header shell A
Please input banner content, and quit with the character 'A'.――System prompt
Have a nice day.
Please input the Password.A
¡  Method III—Type multiple characters after the command keywords at the first line (with the first and last characters being different), and press the Enter key. Type the banner information, and finish with the first character you typed at the first line. The first input character at the first line and the end character are not part of the banner information. For example, to configure a banner like “Have a nice day. Please input the Password.”, use the following commands:
[System] header shell AHave a nice day.
Configuration procedure
To configure a banner:
Step
Remarks
N/A
2.     Configure the incoming banner.
header incoming text
Optional
3.     Configure the login banner.
header login text
Optional
4.     Configure the legal banner.
header legal text
Optional
5.     Configure the shell banner.
header shell text
Optional
6.     Configure the MOTD banner.
header motd text
Optional
Configuring the exception handling method
In standalone mode, when the system detects any software abnormality on the active main processing unit (MPU), it handles the situation with one of the following methods:
·           reboot—The device automatically reboots the failed active MPU to recover from the error condition.
·           maintain—The device stays in the error condition so you can collect complete data, including error messages, for diagnosis. In this approach, you must manually reboot the device.
To configure the exception handling method:
Step
Remarks
N/A
2.     Configure the exception handling method of the MPUs.
system-failure { maintain | reboot }
Optional.
By default, an MPU reboots when an exception occurs to it.
The system always reboots a line processing unit (LPU) or the auxiliary CPU system when an exception occurs to them.
In IRF mode, when the system detects any software abnormality on the active MPU on an IRF member device, it handles the situation with one of the following two methods:
Step
Remarks
N/A
·       The system always reboots an LPU or the auxiliary CPU system when an exception occurs to them.
·       The exception handling method is effective only for the failed card, and does not influence the functions of other cards or the IRF fabric.
Rebooting the switch
You can reboot the switch in one of the following ways to recover from an error condition:
·           Reboot the switch immediately at the CLI.
·           At the CLI, schedule a reboot to occur at a specific time and date or after a delay.
·           Power off and then re-power on the switch. This method might cause data loss and hardware damage, and is the least preferred method.
Reboot at the CLI enables easy remote device maintenance.
CAUTION
CAUTION:
·       Device reboot can interrupt network services.
·       To avoid data loss, use the save command to save the current configuration before a reboot.
·       Use the display startup and display boot-loader commands to check that you have correctly set the startup configuration file and the main system software image file. If the main system software image file has been corrupted or does not exist, the device cannot reboot. You must re-specify a main system software image file, or power off the device and then power it on so the system can reboot with the backup system software image file.
To reboot a switch, perform one of these commands in user view:
Remarks
Reboot a switch.
·       Reboot a card, or the whole system immediately (in standalone mode):
reboot
[ slot slot-number ]
·       Reboot a card, a member switch, or the whole system immediately (IRF mode):
reboot [ chassis chassis-number [ slot slot-number ] ]
Use either command.
To schedule a device reboot, perform one of the following commands in user view:
Remarks
Schedule a reboot.
·       Schedule a reboot to occur at a specific time and date:
schedule reboot at hh:mm [ date ]
·       Schedule a reboot to occur after a delay:
schedule reboot delay { hh:mm | mm }
Use either approach.
The scheduled reboot function is disabled by default.
·       The system displays the alert “REBOOT IN ONE MINUTE” one minute before the reboot.
·       If the device has only one MPU, rebooting the MPU causes the device to reboot. If the device has two MPUs, rebooting the active MPU causes the active MPU to reboot and an active/standby switchover. You cannot use the reboot command to reboots a standby MPU. To reboot a standby MPU, use the slave restart command (see High Availability Command Reference).
·       For data security, if you are performing file operations at the reboot time, the system does not reboot.
Configuring the system working mode
In different system working modes, the system adjusts the hardware resources to meet the requirements of different services. The switch has the following system working modes:
·           advance—Advanced mode
·           bridgee—Enhanced L2 mode
·           routee—Enhanced L3 mode
·           standard—Standard mode
·           advance hybrid—Advanced hybrid mode
·           bridgee hybrid—Enhanced L2 hybrid mode
·           routee hybrid—Enhanced L3 hybrid mode
·           standard hybrid—Standard hybrid mode
Among the working modes, advance hybrid, bridgee hybrid, routee hybrid, and standard hybrid can be called the hybrid mode.
To configure the system working mode:
Step
Remarks
N/A
2.     Configure the system working mode.
system working mode { { advance | bridgee | routee | standard } [ hybrid ] }
By default, the system working mode is standard.
·       H3C recommends you to restart the switch immediately to make this configuration take effect.
·       An IRF member switch cannot operate in hybrid mode; meanwhile, a switch operating in hybrid mode can operate in standalone mode instead of IRF mode.
Support for the system working mode depends on the card type. The following table illustrates the correspondence.
System working mode
EB card
EC card
EF card
Service base card
OAA card
standard
Supported
Supported
Supported
Not supported
Supported
bridgee
Not supported
Supported
Supported
Not supported
Supported
routee
Not supported
Supported
Supported
Not supported
Supported
advance
Not supported
Not supported
Supported
Not supported
Not supported
standard hybrid
Supported
Supported
Supported
Supported
Supported
bridgee hybrid
Not supported
Supported
Supported
Supported
Supported
routee hybrid
Not supported
Supported
Supported
Supported
Supported
advance hybrid
Not supported
Not supported
Supported
Supported
Not supported
·       An EB card has a silkscreen ended with EB, for example, LSR1GP48LEB1. An EC or EF card has a silkscreen ended with EC or EF.
·       A service base card refers to the card with the silkscreen LSR1LN1BNL1 or LSR1LN2BNL1.
·       For more information about OAA card models, see OAA Configuration Guide.
The default values of some commands vary with system working modes. The following table illustrates the details.
Working mode and default value
standard
bridgee
routee
advance
standard hybrid
bridgee hybrid
routee hybrid
advance hybrid
multicast-vlan ipv6 entry-limit limit
511
4095
4095
4095
511
1024
1024
1024
multicast-vlan entry-limit limit
2047
4096
16384
30720
2047
4096
16384
16384
mac-table limit mac-limit-num
Not supported
131072
65536
131072
Not supported
131072
65536
131072
multicast forwarding-table route-limit limit
2047
4096
16384
30720
2047
4096
13824
13824
mld group-limit limit
2048
8192
8192
8192
2048
8192
8192
8192
ip verify source max-entries number
1536
7680 (without the acl ipv6 enable command)
3584 (with the acl ipv6 enable command)
32256 (without the acl ipv6 enable command)
15872 (with the acl ipv6 enable command)
1536
1536
3584
3584
15872
1536
3584
3584
15872
The default parameters that do not vary with different system working modes are not listed in the above table.
Scheduling jobs
You can schedule a job to automatically run a command or a set of commands without administrative interference. The commands in a job are polled every minute. When the scheduled time for a command is reached, the job automatically executes the command. If a confirmation is required while the command is running, the system automatically enters Y or Yes. If characters are required, the system automatically enters a default character string or an empty character string when no default character string is available.
Job configuration approaches
You can configure jobs in a non-modular or modular approach. Use the non-modular approach for a one-time command execution and use non-modular approach for complex maintenance work.
Table 2 A comparison of non-modular and modular approaches
Comparison item
Scheduling a job in the non-modular approach
Scheduling a job in the modular approach
Configuration method
Configure all elements in one command
Separate job, view, and time settings
Can multiple scheduled jobs be configured?
No
Yes
Can a job contain multiple commands?
No
If you use the schedule job command repeatedly, only the last configuration takes effect.
Yes
You can use the time command in job view to configure commands to be executed at different time points.
Supported views
User view and system view. In the schedule job command, shell represents user view, and system represents system view.
All views. In the time command, monitor represents user view.
Supported commands
Commands in user view and system view
Commands in all views
Can a job be repeatedly executed?
No
Yes
Can a job be saved?
No
Yes
Can a job be backed up to the standby MPUs?
No
Yes
Configuration guidelines
·           To have a job successfully run a command, check that the specified view and command are valid. The system does not verify their validity.
·           The configuration interface, view, and user status that you have before job execution restores even if the job has run a command that changes the user interface (for example, telnet, ftp, and ssh2), the view (for example, system-view and quit), or the user status (for example, super).
·           The jobs run in the background without displaying any messages except log, trap and debugging messages.
·           In the modular approach:
¡  Every job can have only one view and up to 10 commands. If you specify multiple views, the one specified last takes effect.
¡  Input a view name in its complete form. Most commonly used view names include monitor for user view, system for system view, GigabitEthernetx/x/x for Ethernet interface view, and Vlan-interfacex for VLAN interface view.
¡  The time ID (time-id) must be unique in a job. If two time and command bindings have the same time ID, the one configured last takes effect.
To schedule a job, perform one of the following commands in user view:
Remarks
Schedule a job.
·       Schedule a job to run a command at a specific time:
schedule job at time [ date ] view view command
·       Schedule a job to run a command after a delay:
schedule job delay time view view command
Use either command.
·       If you execute the schedule job command repeatedly, the last configuration takes effect.
·       Changing the system time can affect the execution time of the job set by the schedule job at command but not the schedule job delay command.
To configure a scheduled job:
Step
Remarks
N/A
2.     Create a job and enter job view.
job job-name
N/A
3.     Specify the view in which the commands in the job run.
view view-name
You can specify only one view for a job. The job executes all commands in the specified view.
4.     Add commands to the job.
·       Configure a command to run at a specific time and date:
time time-id at time date command command
·       Configure a command to run at a specific time:
time
time-id { one-off | repeating } at time [ month-date month-day | week-day week-daylist ] command command
·       Configure a command to run after a delay:
time
time-id { one-off | repeating } delay time command command
Use any of the commands.
Changing the system time can affect the execution time of the job set by the time at command but not the time delay command.
Scheduled job configuration example
Network requirements
Configure scheduled jobs on the device to enable interfaces GigabitEthernet 3/0/1, GigabitEthernet 3/0/2, and GigabitEthernet 3/0/3 at 8:00 and disabled them at 18:00 on working days every week, to control the access of the PCs connected to these interfaces.
Figure 1 Network diagram
# Enter system view.
# Create scheduled job pc1, and enter its view.
[Sysname] job pc1
# Configure the job to be executed in the view of GigabitEthernet 3/0/1.
[Sysname-job-pc1] view GigabitEthernet 3/0/1
# Configure the device to start GigabitEthernet 3/0/1 at 8:00 on working days every week.
[Sysname-job-pc1] time 1 repeating at 8:00 week-day mon tue wed thu fri command undo shutdown
# Configure the device to shut down GigabitEthernet 3/0/1 at 18:00 on working days every week.
[Sysname-job-pc1] time 2 repeating at 18:00 week-day mon tue wed thu fri command shutdown
[Sysname-job-pc1] quit
# Create scheduled job pc2, and enter its view.
[Sysname] job pc2
# Configure the job to be executed in the view of GigabitEthernet 3/0/2.
[Sysname-job-pc2] view GigabitEthernet 3/0/2
# Configure the device to start GigabitEthernet 3/0/2 at 8:00 on working days every week.
[Sysname-job-pc2] time 1 repeating at 8:00 week-day mon tue wed thu fri command undo shutdown
# Configure the device to shut down GigabitEthernet 3/0/2 at 18:00 on working days every week.
[Sysname-job-pc2] time 2 repeating at 18:00 week-day mon tue wed thu fri command shutdown
[Sysname-job-pc2] quit
# Create scheduled job pc3, and enter its view.
[Sysname] job pc3
# Configure the job to be executed in the view of GigabitEthernet 3/0/3.
[Sysname-job-pc3] view GigabitEthernet 3/0/3
# Configure the device to start GigabitEthernet 3/0/3 at 8:00 on working days every week.
[Sysname-job-pc3] time 1 repeating at 8:00 week-day mon tue wed thu fri command undo shutdown
# Configure the device to shut down GigabitEthernet 3/0/3 at 18:00 on working days every week.
[Sysname-job-pc3] time 2 repeating at 18:00 week-day mon tue wed thu fri command shutdown
[Sysname-job-pc3] quit
# Display information about scheduled jobs.
[Sysname] display job
Job name: pc1
  Specified view: GigabitEthernet3/0/1
  Time 1: Execute command undo shutdown at 08:00 Mondays Tuesdays Wednesdays Thursdays Fridays
  Time 2: Execute command shutdown at 18:00 Mondays Tuesdays Wednesdays Thursdays Fridays
Job name: pc2
  Specified view: GigabitEthernet3/0/2
Job name: pc3
  Specified view: GigabitEthernet3/0/3
Configuring a detection interval
Some protocols may shut down ports under specific circumstances. For example, MSTP automatically shuts down a port that receives configuration messages after the BPDU guard function is enabled on the port. Then, the switch enables a detection timer and detects the status of the port. If the port is still down when the detection timer times out, the switch will automatically bring up the port.
To configure a detection interval:
Step
Remarks
N/A
2.     Configure a detection interval.
shutdown-interval time
Optional
30 seconds by default
Configuring temperature thresholds for a card
You can set the temperature threshold to monitor the temperature of a card.
The switch supports lower temperature threshold, warning temperature threshold, and alarming temperature threshold.
·           When the card temperature drops below the lower temperature threshold, the device logs the event and outputs a log message and a trap.
·           When the card temperature reaches the warning threshold, the device logs the event and outputs a log message and a trap.
·           When the card temperature reaches the alarming threshold, the device logs the event and outputs a log message and a trap repeatedly, and alerts users through the LED on the device panel.
To configure temperature thresholds for a card:
Step
Remarks
N/A
2.     Configure temperature thresholds for a card.
·       In standalone mode:
temperature-limit slot slot-number { inflow | hotspot | outflow } sensor-num LowerLimit WarningLimit  [ AlarmLimit ]
·       In IRF mode:
temperature-limit chassis chassis-number slot slot-number { inflow | hotspot | outflow } sensor-num LowerLimit WarningLimit  [ AlarmLimit ]
Optional.
Use either command.
Isolating and diagnosing a card
When the switch detects a card failure or upgrades the logic of the CPU daughter card on an LPU, you can isolate the faulty card or the CPU daughter card to prevent it from forwarding data packets. This operation allows for convenient on-site diagnosis or upgrading while causing no interference on the operation of the system and services of other cards.
After isolating a card, you can use the test diag-offline command to collect the diagnosis information of the card.
To isolate and diagnose a card:
Step
Remarks
N/A
2.     Isolate a card.
board-offline slot slot-number
·       In IRF mode:
board-offline chassis chassis-number slot slot-number
Use either command.
No card is isolated by default.
3.     Diagnose the card problem.
test diag-offline slot slot-number
·       In IRF mode:
test diag-offline chassis chassis-number slot slot-number
Use either command.
The diagnosis information will be displayed and saved in logs under the root directory of the flash. Each log is named in the format of diag_slot_time, where slot indicates the location of the card and time indicates when the diagnosis operation is performed.
CAUTION
CAUTION:
·       The active MPU cannot be isolated. If the standby MPU is isolated, the load mode of the active MPU becomes load-single.
·       Before upgrading the logic of an LPU, keep the LPU offline.
·       No other commands but the test diag-offline command can be executed for an isolated card. Otherwise, the configuration cannot take effect.
·       You can use the display device command to view whether a card is isolated, that is, whether the card is in the offline state.
·       When you execute the test diag-offline command, the path where the diagnosis information is saved is also displayed following the diagnosis information on the terminal. For example, you can see flash:/diag_slot3_20080522_103458.txt.
·       H3C recommends you to send the diagnosis information to qualified engineers for analysis.
Powering on/off a card
When the power supply is not sufficient, the switch automatically adjusts power supply to the cards according to a specific mechanism. You can also use the display power-supply command to view the power supply conditions of the cards, and power on or power off some cards to adjust the available power according to the actual network services.
To power on a card, perform one of these commands in user view:
Remarks
Power on a card.
power-supply on slot slot-number
·       In IRF mode:
power-supply on chassis chassis-number slot slot-number
Optional.
Use either command.
The specified card cannot be the MPU.
To power off a card, perform one of these commands in user view:
Remarks
Power off a card.
power-supply off slot slot-number
·       In IRF mode:
power-supply off chassis chassis-number slot slot-number
Optional.
Use either command.
Configuring in-service hardware failure diagnosis and failure protection
A hardware failure may cause traffic forwarding failures and service interruption. To improve the automatic failure detection and handling capabilities of the switch, you can configure in-service hardware failure diagnosis and failure protection.
The in-service hardware failure diagnosis and failure protection feature covers:
·           In-service hardware failure detection for chips, cards, and the forwarding service, and automatic fix actions taken for the detected failures.
·           Failure protection for ports. When a hardware failure is detected on a port, the switch automatically shuts down the port.
·           Failure protection for aggregation groups. When a hardware failure is detected on a member port of an aggregation group, if the member port is not configured with the hardware-failure-protection auto-down command but it is not the last up port in the aggregation group, the port is shut down automatically; if the member port is not configured with the command and it is the last UP port in the aggregation group, the port will not be shut down; if the member port is configured with the command, the port is shut down automatically no matter whether it is the last UP port in the aggregation group.
Because hardware failure protection is enabled on member ports of an aggregation group, use the undo hardware-failure-protection auto-down command to disable this feature for the member ports of all aggregation groups before you enable hardware failure protection for the aggregation groups.
To configure in-service hardware failure diagnosis and failure protection:
Step
Remarks
N/A
2.     Enable in-service hardware failure detection and configure fix actions taken in case of hardware failures..
hardware-failure-detection { chip | board | forwarding } { off | warning | reset | isolate }
The fix actions taken in case of hardware failures include:
·       off—Takes no action.
·       warning—Sends warning messages.
·       reset—Resets the failed card.
·       isolate—Shuts down the failed port, isolates the failed card, prohibits the failed card from loaded, or powers off the failed card to reduce the impact of the failure to the system.
By default, the fix action taken for all hardware failures is warning.
3.     Enable hardware failure protection for aggregation groups.
hardware-failure-protection aggregation
Optional.
Disabled by default.
This command is effective only when the fix action is configured as isolate.
4.     Enter Ethernet interface view.
N/A
5.     Configure hardware failure protection for the port.
Optional.
Enabled by default.
CAUTION
CAUTION:
Before configuring the hardware-failure-protection auto-down command on a port, make sure that a backup link exists to avoid service interruption in case the port is shut down.
The hardware-failure-protection aggregation and hardware-failure-protection auto-down command do not take effect on a port in either of the following cases:
·           The port is configured with the loopback { external | internal } command.
·           The port is configured with the port up-mode command.
·           The port is configured as an IRF physical port.
·       If a port is automatically shut down due to hardware failure protection, its status displayed with the display interface command is Protect DOWN. To bring up the port, use the undo shutdown command on the port.
·       If a card is isolated or its software is not allowed to be loaded due to hardware failure fix operations, you can unplug the card and then plug it in to recover the card status.
·       After configuring in-service diagnosis and failure protection, you can use the display hardware-failure-detection command to check the running information of the feature.
·       For information about IRF physical ports, see IRF Configuration Guide.
Configuring the load mode for the active MPU and the standby MPU
The following load modes are available for the active MPU and standby MPU:
·           load-balance mode: Load ( for processing and forwarding packets) is balanced between the active MPU and standby MPU.
·           load-single mode: The active MPU processes and forwards packets, whereas the standby MPU only backs up data and monitors the state of the active MPU.
To configure the load mode for the active MPU and standby MPU:
Step
Remarks
N/A
2.     Configure the load mode.
·       Configure the load mode for the active MPU and standby MPU (in standalone mode):
xbar { load-balance | load-single }
·       Configure the load mode for the active MPUs and standby MPUs on member devices (in IRF mode):
xbar chassis chassis-number { load-balance | load-single }
Optional
Use either command.
load-balance mode by default
·       The load-balance mode is valid only when both the active MPU and standby MPU are in their slots. If only the active MPU is available, the active MPU will automatically switch to the load-single mode after the load-balance mode is configured.
·       The models of the active MPU and standby MPU must be consistent; otherwise, the standby MPU cannot start normally.
Configuring the size of the buffer shared by all interfaces on a service card
A service card uses a buffer with a fixed size to buffer the packets received and sent. A buffer comprises multiple storage units. It is divided into two areas: fixed buffer and shared buffer. The fixed buffer is allocated to the interfaces according to a certain algorithm, and the shared buffer is shared by all interfaces. When the traffic of an interface becomes heavy, and the fixed buffer cannot provide sufficient memory, the shared buffer provides temporary memory for the interface.
By default, the fixed buffer and the shared buffer contain a fixed number of storage units. You can configure the number of storage units in the shared buffer as needed. Because the total number of storage units in a buffer is fixed, the number of storage units in the fixed buffer will change after your configuration. You can tune the shared buffer area depending on traffic patterns. If transient large traffic bursts occur on some interfaces, you can expand the shared buffer to accommodate the bursts to prevent traffic loss. If transient small traffic bursts often occur on the interfaces, you can decrease the shared buffer so that each port can get more dedicated buffer memory.
To set the size in blocks of the receive or transmit buffer shared by all interfaces on a service card:
Step
Remarks
N/A
2.     Set the size in blocks of the receive or transmit buffer shared by all interfaces on a service card.
buffer-manage { ingress | egress } slot slot-number share-size size-value
·       In IRF mode:
buffer-manage { ingress | egress } chassis chassis-number slot slot-number share-size size-value
Optional.
By default, the size in blocks of the shared receive buffer is 1024, and that of the shared transmit buffer is 4608.
Configuring automatic speed adjustment mode for fans
You can configure either of the following automatic speed adjustment modes for fans as required:
·           Low temperature mode: In this mode, the fans operate at a high speed to ensure low temperature for the switch.
·           Silent mode: In this mode, the fans operate at a low speed with low noise, but the temperature is a little higher than that in lower temperature mode. This mode is suitable for a noise-sensitive environment.
To configure the automatic speed adjustment mode, perform one of these commands in system view:
Remarks
Configure the automatic speed adjustment mode.
fan auto-control-mode { low-temperature-mode | silence-mode }
·       In IRF mode:
fan auto-control-mode { low-temperature-mode | silence-mode } chassis chassis-number
Use either command.
The switch operates in low temperature mode by default.
Clearing unused 16-bit interface indexes
The device must maintain persistent 16-bit interface indexes and keep one interface index match one interface name for network management. After deleting a logical interface, the device retains its 16-bit interface index so the same index can be assigned to the interface at interface re-creation.
To avoid index depletion causing interface creation failures, you can clear all 16-bit indexes that have been assigned but not in use. The operation does not affect the interface indexes of the interfaces that have been created but the indexes assigned to re-recreated interfaces might change.
To clear unused 16-bit interface indexes:
Remarks
Clear unused 16-bit interface indexes.
reset unused porttag
CAUTION
CAUTION:
A confirmation is required when you execute this command. If you fail to make a confirmation within 30 seconds or enter N to cancel the operation, the command is executed.
Enabling automatic forwarding path check
When the switch is operating, traffic forwarding exceptions might occur due to hardware failures or other reasons. You can enable automatic forwarding path check so that the switch gives prompts when a forwarding exception occurs. According to the prompts, you can troubleshoot the problem.
To enable automatic forwarding path check:
Step
Remarks
N/A
2.     Enable automatic forwarding path check.
forward-path check { enable | disable }
Enabled by default
Above the configuration, if a forwarding exception occurs, the switch gives prompts, for example:
%Aug 20 14:55:54:973 2010 H3C DIAG/3/ERROR: -Slot=8; Forwarding fault: slot 5 to slot 8
%Aug 20 14:55:55:084 2010 H3C DIAG/3/ERROR: -Slot=6; Forwarding fault: slot 6 to slot 6
The output shows that a forwarding exception exists between the cards in slot 8 and slot 5, and an exception in internal data forwarding exists on the card in slot 6.
Verifying and diagnosing transceiver modules
Introduction to transceiver modules
Table 3 lists the commonly used transceiver modules. They can be further divided into optical transceivers and electrical transceivers based on transmission medium.
Table 3 Commonly used transceiver modules
Transceiver type
Application environment
Whether can be an optical transceiver
Whether can be an electrical transceiver
SFP (Small Form-factor Pluggable)
Generally used for 100M/1000M Ethernet interfaces or POS 155M/622M/2.5G interfaces
Yes
Yes
SFP+ (Enhanced 8.5 and 10 Gigabit Small Form-factor Pluggable)
Generally used for 10G Ethernet interfaces
Yes
Yes
XFP (10-Gigabit small Form-factor Pluggable)
Yes
No
Verifying transceiver modules
You can verify the genuineness of a transceiver module in the following ways:
·           Display the key parameters of a transceiver module, including its transceiver type, connector type, central wavelength of the transmit laser, transfer distance and vendor name.
·           Display its electronic label. The electronic label is a profile of the transceiver module and contains the permanent configuration including the serial number, manufacturing date, and vendor name. The data is written to the storage component during debugging or testing.
To identify transceiver modules:
Remarks
Display key parameters of the transceiver modules.
display transceiver interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Available for all transceiver modules
Display transceiver modules’ electrical label information.
display transceiver manuinfo interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Available for H3C customized transceiver modules only
If the Vendor Name field in the prompt information of the display transceiver command is H3C, it indicates that is the module is an H3C-customized transceiver module.
Diagnosing transceiver modules
The device provides the alarm function and digital diagnosis function for transceiver modules. When a transceiver module fails or inappropriately work, you can check for alarms present on the transceiver module to identify the fault source or examine the key parameters monitored by the digital diagnosis function, including the temperature, voltage, laser bias current, TX power, and RX power.
To diagnose transceiver modules:
Remarks
Display alarms present on transceiver modules.
display transceiver alarm interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Display the present measured values of the digital diagnosis parameters for transceiver modules.
display transceiver diagnosis interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Displaying and maintaining device management
For diagnosis or troubleshooting, you can use separate display commands to collect running status data module by module, or use the display diagnostic-information command to bulk collect running data for multiple modules.
Remarks
Display alarm information (standalone mode).
display alarm [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display alarm information (IRF mode).
display alarm [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the system version information.
display version [ | { begin | exclude | include } regular-expression ]
Display the system time information.
display clock [ | { begin | exclude | include } regular-expression ]
Display clipboard information.
display clipboard [ | { begin | exclude | include } regular-expression ]
Display or save statistics of the running status of multiple modules.
display diagnostic-information [ | { begin | exclude | include } regular-expression ]
Display the configuration of the shared buffer on a service card (standalone mode).
display buffer-manage configuration [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the configuration of the shared buffer on a service card (IRF mode).
display buffer-manage configuration [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the statistics of the CPU usage (standalone mode).
display cpu-usage [ slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
display cpu-usage entry-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ] [ from-device ] [ | { begin | exclude | include } regular-expression ]
Display the statistics of the CPU usage (IRF mode).
display cpu-usage [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
display cpu-usage entry-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ from-device ] [ | { begin | exclude | include } regular-expression ]
Display history statistics of the CPU usage in a chart (standalone mode).
display cpu-usage history [ task task-id ] [ slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
Display history statistics of the CPU usage in a chart (IRF mode).
display cpu-usage history [ task task-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display device information (standalone mode).
display device [ cf-card ] [ slot slot-number [ subslot subslot-number ] | verbose ] [ | { begin | exclude | include } regular-expression ]
Display device information (IRF mode).
display device [ cf-card ] [ [ chassis chassis-number ] [ slot slot-number ] [ subslot subslot-number ] | verbose ] [ | { begin | exclude | include } regular-expression ]
Display electrical label information of the switch (standalone mode).
display device manuinfo [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display electrical label information of an member switch (IRF mode).
display device manuinfo [ chassis chassis-number [ slot slot-number ] ] [ | { begin | exclude | include } regular-expression ]
Display the electrical label information of the specified chassis backplane (standalone mode).
display device manuinfo chassis-only [ | { begin | exclude | include } regular-expression ]
Display the electrical label information of the specified chassis backplane (IRF mode).
display device manuinfo chassis chassis-number chassis-only [ | { begin | exclude | include } regular-expression ]
Display the electrical label information of the specified fan (standalone mode).
display device manuinfo fan fan-id [ | { begin | exclude | include } regular-expression ]
Display the electrical label information of the specified fan (IRF mode).
display device manuinfo chassis chassis-number fan fan-id [ | { begin | exclude | include } regular-expression ]
Display the electrical label information of the specified power module (standalone mode).
display device manuinfo power power-id [ | { begin | exclude | include } regular-expression ]
Display the electrical label information of the specified power module (IRF mode).
display device manuinfo chassis chassis-number power power-id [ | { begin | exclude | include } regular-expression ]
Display the temperature information of the switch (standalone mode).
display environment [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the temperature information of an member switch (IRF mode).
display environment [ chassis chassis-number [ slot slot-number ] ] [ | { begin | exclude | include } regular-expression ]
Display the operating state of fans in the switch (standalone mode).
display fan [ fan-id ] [ | { begin | exclude | include } regular-expression ]
Display the operating state of fans in an IRF member switch (IRF mode).
display fan [ chassis chassis-number ] [ fan-id ] [ | { begin | exclude | include } regular-expression ]
Display the automatic speed adjustment mode of fans in the switch (standalone mode).
display fan auto-control-mode [ | { begin | exclude | include } regular-expression ]
Display the automatic speed adjustment mode of fans in an IRF member switch (IRF mode).
display fan auto-control-mode chassis chassis-number [ | { begin | exclude | include } regular-expression ]
Display hardware failure detection and fix operation records.
display hardware-failure-detection [ | { begin | exclude | include } regular-expression ]
Display hardware failure protection information.
display hardware-failure-protection [ | { begin | exclude | include } regular-expression ]
Display the usage of the memory of the switch (standalone mode).
display memory [ slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
Display the usage of the memory of an IRF member switch (IRF mode).
display memory [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
Display the power state of the switch  (standalone mode).
display power-supply [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display the power state of an IRF member switch (IRF mode).
display power-supply [ chassis chassis-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display the configuration of the scheduled job configured by the schedule job command.
display schedule job [ | { begin | exclude | include } regular-expression ]
Display the reboot time of the switch.
display schedule reboot [ | { begin | exclude | include } regular-expression ]
Display brief information about the hardware configuration file.
display system config file [ file-url ] [ | { begin | exclude | include } regular-expression ]
Display the system working mode.
display system working mode [ | { begin | exclude | include } regular-expression ]
Display the configuration of scheduled jobs configured by the job command.
display job [ job-name ] [ | { begin | exclude | include } regular-expression ]
Display the load mode of the current active MPU and standby MPU (standalone mode).
display xbar [ | { begin | exclude | include } regular-expression ]
Display the load mode of the current active MPU and standby MPU (IRF mode).
display xbar [ chassis chassis-number ] [ | { begin | exclude | include } regular-expression ]
The display commands discussed above are for the global configuration. For the display command for specific protocol and interface, see corresponding sections.
