HomeSupportSwitchesH3C S9500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guide-Release1728-6W17001-Fundamentals Configuration Guide
01-CLI Configuration
01-CLI Configuration 228.19 KB
At the command-line interface (CLI), you can enter text commands to configure, manage, and monitor your switch.
Figure 1 CLI example
The output information depends on the switch.
Logging in to the CLI
You can log in to the CLI in a variety of ways. For example, you can log in through the console port, or by using Telnet or SSH. For more information about login methods, see the chapter “Logging in to the CLI.”
Command conventions
Command conventions help you understand the syntax of commands. Commands in product manuals comply with the conventions listed in Table 1.
Table 1 Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
Command keywords are case insensitive.
The following example analyzes the syntax of the clock datetime time date command according to Table 1.
Figure 2 Understanding command-line parameters
For example, to set the system time to 10:30:20, February 23, 2010, enter the following command line at the CLI and press Enter:
<Sysname> clock datetime 10:30:20 2/23/2010
Using the undo form of a command
Most configuration commands have an undo form for canceling a configuration, restoring the default, or disabling a feature. For example, the info-center enable command enables the information center, and the undo info-center enable command disables the information center.
CLI views
Commands are grouped in different views by function. To use a command, you must enter the view of the command.
CLI views are organized in a hierarchical structure, as shown in Figure 3. Each view has a unique prompt, from which you can identify where you are and what you can do. For example, the prompt [Sysname-vlan100] shows that you are in the view of VLAN 100 and can configure attributes for the VLAN.
You are placed in user view immediately after you are logged in to the CLI. The user view prompt is <Device-name>, where the Device-name argument can be changed by using the sysname command. In user view, you can perform displaying, debugging, file management, FTP, and Telnet operations, set the system time, and restart your switch. For more information about the sysname command, see Fundamentals Command Reference.
From user view, you can enter system view to configure global settings, including the daylight saving time, banners, and short-cut keys. The system view prompt is [Device-name].
From system view, you can enter different function views. For example, you can enter interface view to configure interface parameters, enter VLAN view to add ports to the specific VLAN, enter user interface view to configure login user attributes, or create a local user and enter local user view to configure attributes for the local user.
To display all commands available in a view, enter a question mark (?) at the view prompt.
Figure 3 CLI view hierarchy
Entering system view
To enter system view:
Remarks
Enter system view from user view.
Available in user view
Returning to the upper-level view
To return to the upper-level view:
Remarks
Return to the upper-level view from any view.
Available in any view
·       Executing the quit command in user view terminates your connection to the switch.
·       In public key code view, use the public-key-code end command to return to the upper-level view (public key view). In public key view, use the peer-public-key end command to return to system view.
Returning to user view
You can return to user view from any other view by using the return command, instead of using the quit command repeatedly. Pressing Ctrl+Z has the same effect.
To return to user view directly:
Remarks
Return to user view.
return
Available in any view except user view
Accessing the CLI online help
To access the CLI online help, use one of the following methods:
·           Enter a question mark at a view prompt to display the first keywords of all commands available in the view. For example:
<Sysname> ?
User view commands:
  cfd      Connectivity fault detection (IEEE 802.1ag)
  display  Display current system information
  ping     Ping function
  quit     Exit from current command view
  ssh2     Establish a secure shell client connection
  super    Set the current user priority level
  telnet   Establish one TELNET connection
  tracert  Trace route function
·           Enter some keywords of a command and a question mark separated by a space to display available keywords and arguments.
¡  Example 1: The question mark is in the place of a keyword, and the CLI displays all possible keywords with a brief description for each keyword.
<Sysname> terminal ?
  debugging  Send debug information to terminal
  logging    Send log information to terminal
  monitor    Send information output to current terminal
  trapping   Send trap information to terminal
¡  Example 2: The question mark is in the place of an argument, and the CLI displays the description of the argument.
[Sysname] interface vlan-interface ?
  <1-4094>  VLAN interface number
[Sysname] interface vlan-interface 1 ?
  <cr>
The string <cr> indicates that the command is complete, and you can press Enter to execute the command.
·           Enter an incomplete keyword string followed by a question mark to display all keywords starting with the string. For example:
<Sysname> f?
   fdisk
   fixdisk
   format
   free
   ftp
<Sysname> display ftp?
   ftp
   ftp-server
   ftp-user
Entering a command
Editing a command line
You can use the keys listed in Table 2 or the hotkeys listed in Table 3 to edit a command line.
Table 2 Keys for editing a command line
Key
Function
Common keys
If the edit buffer is not full, pressing a common key inserts the character at the position of the cursor and moves the cursor to the right.
Backspace
Deletes the character to the left of the cursor and moves the cursor back one character.
Left arrow key or Ctrl+B
Moves the cursor one character to the left.
Right arrow key or Ctrl+F
Moves the cursor one character to the right.
Tab
If you press Tab after entering part of a keyword, the system automatically completes the keyword:
·       If a unique match is found, the system substitutes the complete keyword for the incomplete one and displays what you entered in the next line.
·       If there is more than one match, you can press Tab repeatedly to choose the keyword you want to enter.
·       If there is no match, the system does not modify what you entered but displays it again in the next line.
Abbreviating commands
You can enter a command line quickly by entering incomplete keywords that can uniquely identify the complete command. In user view, for example, commands starting with an s include startup saved-configuration and system-view. To enter system view, you only need to enter sy. To set the configuration file to be used at the next startup, you can enter st s.
You can also press Tab to have an incomplete keyword automatically completed.
Configuring and using command keyword aliases
The command keyword alias function allows you to replace the first keyword of a non-undo command or the second keyword of an undo command with your preferred keyword when you execute the command. For example, if you configure show as the alias for the display keyword, you can enter show to execute a display command.
·           After you successfully execute a command by using a keyword alias, the system saves the keyword, instead of its alias, to the running configuration.
·           If you press Tab after entering part of an alias, the keyword is displayed.
·           If a string you entered partially matches a keyword and an alias, the command indicated by the alias is executed. To execute the command indicated by the keyword, enter the complete keyword.
·           If you enter a string that partially matches multiple aliases, the system gives you a prompt.
Configuration procedure
To configure a command keyword alias:
Step
Remarks
1.     Enter system view.
N/A
2.     Enable the command keyword alias function.
command-alias enable
By default, the command keyword alias function is disabled.
3.     Configure a command keyword alias.
command-alias mapping cmdkey alias
By default, no command keyword alias is configured.
You must enter the cmdkey and alias arguments in their complete form.
Configuring and using hotkeys
To facilitate CLI operation, the system defines some hotkeys and provides five configurable command hotkeys. Pressing a command hotkey equals entering a command. For system-reserved hotkeys, see Table 3.
To configure hotkeys:
Step
Remarks
N/A
2.     Configure hotkeys.
hotkey { CTRL_G | CTRL_L | CTRL_O | CTRL_T | CTRL_U } command
Optional.
The Ctrl+G, Ctrl+L and Ctrl+O hotkeys are specified at the CLI by default.
3.     Display hotkeys.
display hotkey [ | { begin | exclude | include } regular-expression ]
Available in any view. See Table 3 for hotkeys reserved by the system.
By default, the Ctrl+G, Ctrl+L and Ctrl+O hotkeys are associated with pre-defined commands and the Ctrl+T and Ctrl+U hotkeys are not.
·       Ctrl+G corresponds to the display current-configuration command.
·       Ctrl+L corresponds to the display ip routing-table command.
·       Ctrl+O corresponds to the undo debugging all command.
Table 3 Hotkeys reserved by the system
Hotkey
Function
Ctrl+A
Moves the cursor to the beginning of the line.
Ctrl+B
Ctrl+C
Stops the current command.
Ctrl+D
Deletes the character at the cursor.
Ctrl+E
Moves the cursor to the end of the line.
Ctrl+F
Ctrl+H
Deletes the character to the left of the cursor.
Ctrl+K
Aborts the connection request.
Ctrl+N
Displays the next command in the command history buffer.
Ctrl+P
Displays the previous command in the command history buffer.
Ctrl+R
Redisplays the current line.
Ctrl+V
Pastes text from the clipboard.
Ctrl+W
Deletes the word to the left of the cursor.
Ctrl+X
Deletes all characters to the left of the cursor.
Ctrl+Y
Deletes all characters to the right of the cursor.
Ctrl+Z
Returns to user view.
Ctrl+]
Terminates an incoming connection or a redirect connection.
Esc+B
Moves the cursor back one word.
Esc+D
Deletes all characters from the cursor to the end of the word.
Esc+F
Moves the cursor forward one word.
Esc+N
Moves the cursor down one line (available before you press Enter)
Esc+P
Moves the cursor up one line (available before you press Enter)
Esc+<
Moves the cursor to the beginning of the clipboard.
Esc+>
Moves the cursor to the ending of the clipboard.
The hotkeys in this table are defined by the switch. If a hotkey is also defined by the terminal software that you are using to interact with the switch, the definition of the terminal software takes effect.
Enabling redisplaying entered-but-not-submitted commands
After you enable redisplaying entered-but-not-submitted commands:
·           If you entered nothing at the command-line prompt before the system outputs system information such as logs, the system does not display the command-line prompt after the output.
·           If you entered some information (except Yes or No for confirmation), the system displays a line break and then display what you have entered after the output.
To enable redisplaying entered-but-not-submitted commands:
Step
Remarks
N/A
2.     Enable redisplaying entered-but-not-submitted commands.
info-center synchronous
Disabled by default
For more information about the info-center synchronous command, see Network Management and Monitoring Command Reference.
Understanding command-line errors
If a command line fails the syntax checking, the CLI displays error messages.
Table 4 Common command-line error messages
Error message
Cause
% Unrecognized command found at '^' position.
The command was not found.
% Incomplete command found at '^' position.
Incomplete command.
% Ambiguous command found at '^' position.
Ambiguous command.
Too many parameters
Too many parameters.
% Wrong parameter found at '^' position.
Wrong parameters.
Using the command history function
The system can automatically save successfully executed commands to the command history buffer for the current user interface. You can view them and execute them again, or set the maximum number of commands that can be saved in the command history buffer.
A command is saved to the command history buffer in the exact format as it was entered. For example, if you enter an incomplete command, the command saved in the command history buffer is also incomplete; if you enter a command by using a command keyword alias, the command saved in the command history buffer also uses the alias.
If you execute the same command repeatedly, the switch saves the earliest record. However, if you execute the same command in different formats, the system saves them as different commands. For example, if you execute the display cu command repeatedly, the system saves only one command in the command history buffer. If you execute the command in the format of display cu and display current-configuration respectively, the system saves them as two commands.
By default, the command history buffer can save up to 10 commands for each user. To set the capacity of the command history buffer for the current user interface, use the history-command max-size command. For more information about the history-command max-size command, see Fundamentals Command Reference.
Viewing history commands
Display all commands in the command history buffer.
display history-command [ | { begin | exclude | include } regular-expression ]
Display the previous history command.
Up arrow key or Ctrl+P
Display the next history command.
Down arrow key or Ctrl+N
You can use arrow keys to access history commands in Windows 200X and XP Terminal or Telnet. In Windows 9X HyperTerminal, the arrow keys are invalid and you must use Ctrl+P and Ctrl+N instead.
Setting the command history buffer size for user interfaces
To set the command history buffer size for user interfaces:
Step
Remarks
N/A
2.     Enter user interface view.
user-interface { first-num1 [ last-num1 ] | { aux | console | vty } first-num2 [ last-num2 ] }
N/A
3.     Set the maximum number of commands that can be saved in the command history buffer.
history-command max-size size-value
Optional.
By default, the command history buffer can save up to 10 commands.
For more information about the user-interface and history-command max-size commands, see Fundamentals Command Reference.
Controlling the CLI output
Pausing between screens of output
If the output information is more than one screen, the system automatically pauses after displaying a screen. By default, up to 24 lines can be displayed on a screen. To change the screen length, use the screen-length command. For more information about the screen-length command, see Fundamentals Command Reference.
Keys for controlling output
Table 5 Keys for controlling output
Keys
Function
Space
Displays the next screen.
Enter
Displays the next line.
Ctrl+C
Stops the displaying and aborts the command execution.
<PageUp>
Displays the previous page.
<PageDown>
Displays the next page.
Disabling pausing between screens of output
Use the following command to disable pausing between screens of output for the current session. Then, all output information is displayed at one time and the screen is refreshed continuously until the last screen is displayed.
To disable pausing between screens of output for the current session:
Remarks
Disable pausing between screens of output for the current session.
screen-length disable
The default for a session depends the setting of the screen-length command in the user interface view. The default of the screen-length command is pausing between screens of output and displaying up to 24 lines on a screen.
This command is executed in user view, and takes effect for the current session only. When you relog in to the switch, the default is restored.
Filtering the output information of a display command
Introduction
You can filter output information of a display command by using the following methods:
·           Following the display command, enter a vertical bar (|), the begin, exclude, or include keyword, and a regular expression.
·           When the system pauses after displaying a screen of output information, use /, - or + plus a regular expression to filter subsequent output information. / equals the keyword begin, - equals the keyword exclude, and + equals the keyword include.
The following definitions apply to the begin, exclude, and include keywords:
·           beginDisplays the first line that matches the specified regular expression and all lines that follow.
·           excludeDisplays all lines that do not match the specified regular expression.
·           includeDisplays all lines that match the specified regular expression.
A regular expression is a case-sensitive string of 1 to 256 characters, and supports some special characters.
Table 6 Special characters supported in a regular expression
Character
Meaning
Remarks
^string
Starting sign. Matches a line that starts with string.
For example, regular expression “^user” matches a line beginning with “user”, not “Auser”.
string$
Ending sign. Matches a line that ends with string.
For example, regular expression "user$” only matches a line ending with “user”, not “userA”.
Matches any single character, such as a single character, a special character, and a blank.
For example, “.s” matches both “as” and “bs”.
Matches the preceding character or character group zero or multiple times.
For example, “zo*” matches “z” and “zoo”; “(zo)*” matches “zo” and “zozo”.
Matches the preceding character or character group one or multiple times
For example, “zo+” matches “zo” and “zoo”, but not “z”.
Matches the preceding or succeeding character string
For example, “def|int” only matches a character string containing “def” or “int”.
_
If it is at the beginning or the end of a regular expression, it equals ^ or $. In other cases, it equals comma, space, round bracket, or curly bracket.
For example, “a_b” matches “a b” or “a(b”; “_ab” only matches a line starting with “ab”; “ab_” only matches a line ending with “ab”.
It connects two values (the smaller one before it and the bigger one after it) to indicate a range together with [ ].
For example, “1-9” means 1 to 9 (inclusive); “a-h” means a to h (inclusive).
Matches a single character contained within the brackets.
For example, [16A] matches a string containing any character among 1, 6, and A; [1-36A] matches a string containing any character among 1, 2, 3, 6, and A (- is a hyphen).
“]” can be matched as a common character only when it is put at the beginning of characters within the brackets, for example [ ]string]. There is no such limit on “[”.
A character group. It is usually used with “+” or “*”.
For example, (123A) means a character group “123A”; “408(12)+” matches 40812 or 408121212. But it does not match 408.
\index
Repeats the character string specified by the index. A character string refers to the string within () before \. index refers to the sequence number (starting from 1 from left to right) of the character group before \. If only one character group appears before \, index can only be 1; if n character groups appear before index, index can be any integer from 1 to n.
For example, (string)\1 repeats string, and a matching string must contain stringstring. (string1)(string2)\2 repeats string2, and a matching string must contain string1string2string2. (string1)(string2)\1\2 repeats string1 and string2 respectively, and a matching string must contain string1string2string1string2.
Matches a single character not contained within the brackets.
For example, [^16A] means to match a string containing any character except 1, 6 or A, and the matching string can also contain 1, 6 or A, but cannot contain these three characters only. For example, [^16A] matches “abc” and “m16”, but not 1, 16, or 16A.
\<string
Matches a character string starting with string.
For example, “\<do” matches word “domain” and string “doa”.
string\>
Matches a character string ending with string.
For example, “do\>” matches word “undo” and string “abcdo”.
\bcharacter2
Matches character1character2. character1 can be any character except number, letter or underline, and \b equals [^A-Za-z0-9_].
For example, “\ba” matches “-a” with “-“ being character1, and “a” being character2, but it does not match “2a” or “ba”.
\Bcharacter
Matches a string containing character, and no space is allowed before character.
For example, “\Bt” matches “t” in “install”, but not “t” in “big top”.
character1\w
Matches character1character2. character2 must be a number, letter, or underline, and \w equals [A-Za-z0-9_].
For example, “v\w” matches “vlan” (“v” is character1 and “l” is character2) and “service” ( “i” is character2).
\W
Equals \b.
For example, “\Wa” matches “-a”, with “-” being character1, and “a” being character2, but does not match “2a” or “ba”.
Escape character. If a special character listed in this table follows \, the specific meaning of the character is removed.
For example, “\\” matches a string containing “\”, “\^” matches a string containing “^”, and “\\b” matches a string containing “\b”.
Output information filtering examples
1.      Example for using the begin keyword
# Display the configuration from the line containing “user-interface” to the last line in the running configuration (the output information depends on the running configuration).
<Sysname> display current-configuration | begin user-interface
user-interface con 0
user-interface aux 0
user-interface vty 0 4
 authentication-mode none
 user privilege level 3
return
2.      Example for using the exclude keyword
# Display the non-direct routes in the routing table (the output depends on the running configuration).
<Sysname> display ip routing-table | exclude Direct
Routing Tables: Public
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
1.1.1.0/24          Static 60   0            192.168.0.0     Vlan1
3.      Example for using the include keyword
# Display the route entries that contain Vlan in the routing table (the output depends on the running configuration).
<Sysname> display ip routing-table | include Vlan
192.168.1.0/24      Direct 0    0            192.168.1.42    Vlan999
Configuring user privilege and command levels
To avoid unauthorized access, the switch defines user privilege levels and command levels. User privilege levels correspond to command levels. When a user at a specific privilege level logs in, the user can only use commands at that level, or lower levels.
All the commands are categorized into four levels: visit, monitor, system, and manage, and are identified from low to high, respectively by 0 through 3.
Table 7 Default command levels
Level
Privilege
0
Visit
Involves commands for network diagnosis and commands for accessing an external switch. Configuration of commands at this level cannot survive a switch restart. Upon switch restart, the commands at this level will be restored to the default settings.
Commands at this level include ping, tracert, telnet and ssh2.
1
Monitor
Involves commands for system maintenance and service fault diagnosis. Commands at this level are not saved after being configured. After the switch is restarted, the commands at this level will be restored to the default settings.
Commands at this level include debugging, terminal, refresh, and send.
2
System
Provides service configuration commands, including routing configuration commands and commands for configuring services at different network levels.
By default, commands at this level include all configuration commands except for those at manage level.
3
Manage
Involves commands that influence the basic operation of the system and commands for configuring system support modules.
By default, commands at this level involve the configuration commands of file system, FTP, TFTP, Xmodem download, user management, level setting, and parameter settings within a system (which are not defined by any protocols or  RFCs).
Configuring a user privilege level
A user privilege level can be configured by using AAA authentication parameters or under a user interface.
Configure a user privilege level by using AAA authentication parameters
If the authentication mode of a user interface is scheme, the user privilege level of users logging into the user interface is specified in AAA authentication configuration.
To configure the user privilege level by using AAA authentication parameters:
Step
Remarks
N/A
N/A
3.     Specify the scheme authentication mode.
authentication-mode scheme
By default, the authentication mode for VTY and AUX users is password, and no authentication is needed for console users.
4.     Return to system view.
N/A
5.     Configure the authentication mode for SSH users as password.
For more information, see Security Configuration Guide.
Required if users use SSH to log in, and username and password are needed at authentication.
6.     Configure the user privilege level by using AAA authentication parameters.
·       To use local authentication:
a.   Use the local-user command to create a local user and enter local user view.
b.   Use the level keyword in the authorization-attribute command to configure the user privilege level.
·       To use remote authentication (RADIUS, HWTACACS, or LDAP):
Configure the user privilege level on the authentication server
User either approach.
For local authentication, if you do not configure the user privilege level, the user privilege level is 0.
For remote authentication, if you do not configure the user privilege level, the user privilege level depends on the default configuration of the authentication server.
·       For more information about commands user-interface, authentication-mode, and user privilege level, see Fundamentals Command Reference.
·       For more information about SSH and AAA, see Security Configuration Guide.
Example for configuring the user privilege level by using AAA authentication parameters
# Configure the switch to use local authentication for a user who telnets to VTY 1. Set the user privilege level to 3.
[Sysname] user-interface vty 1
[Sysname-ui-vty1] authentication-mode scheme
[Sysname-ui-vty1] quit
[Sysname] local-user test
[Sysname-luser-test] password cipher 123
[Sysname-luser-test] service-type telnet
When users telnet to the switch through VTY 1, they must enter username test and password 12345678. After passing the authentication, the users can only use the commands of level 0. If the users want to use commands of levels 0, 1, 2 and 3, the following configuration is required:
[Sysname-luser-test] authorization-attribute level 3
Configure the user privilege level under a user interface
·           If the authentication mode of a user interface is scheme, and SSH publickey authentication type (only username is needed for this authentication type) is adopted, the user privilege level of users logging into the user interface is the user interface level.
·           If the authentication mode of a user interface is none or password, the user privilege level of users logging into the user interface is the user interface level.
To configure the user privilege level under a user interface (SSH publickey authentication type):
Step
Remarks
1.     Configure the authentication type for SSH users as publickey.
Required if the SSH login mode is adopted, and only the username is needed during authentication.
You must also set the authentication mode of the user interfaces to scheme.
2.     Enter system view.
N/A
3.     Enter user interface view.
user-interface { first-num1 [ last-num1 ] | vty first-num2 [ last-num2 ] }
N/A
4.     Configure the authentication mode for any user that uses the current user interface to log in to the switch.
5.     Configure the privilege level for users that log in through the current user interface.
user privilege level level
Optional.
By default, the user privilege level for users logged in through the console user interface is 3, and that for users logged in through the other user interfaces is 0.
To configure the user privilege level under a user interface (none or password authentication mode):
Step
Remarks
N/A
N/A
3.     Configure the authentication mode for any user that uses the current user interface to log in to the switch.
authentication-mode { none | password }
Optional.
By default, the authentication mode for VTY and AUX user interfaces is password, and no authentication is needed for console users.
4.     Configure the privilege level of users logged in through the current user interface.
Optional.
Example for configuring the user privilege level under a user interface
# Display the commands that a Telnet user can use after login by default.
<Sysname> ?
User view commands:
  ping     Ping function
# Configure the switch to perform no authentication for Telnet users, and to authorize authenticated Telnet users to use the commands of privilege levels 0 and 1. (Use no authentication mode only in a secure network environment.)
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] authentication-mode none
[Sysname-ui-vty0-4] user privilege level 1
# Display the commands that a Telnet user can use after login. Because the user privilege level is 1, a Telnet user can use more commands now.
<Sysname> ?
User view commands:
  debugging         Enable system debugging functions
  graceful-restart  Graceful restart
  ipc               Interprocess communication
  oap               Open application platform operation
  ping              Ping function
  refresh           Do soft reset
  reset             Reset operation
  screen-length     Specify the lines displayed on one screen
  send              Send information to other user terminal interface
  terminal          Set the terminal line characteristics
  undo              Cancel current setting
# Configure the switch to perform password authentication for Telnet users, and to authorize authenticated Telnet users to use the commands of privilege levels 0, 1. and 2.
[Sysname-ui-vty1] authentication-mode password
[Sysname-ui-vty0-4] set authentication password cipher 123
[Sysname-ui-vty0-4] user privilege level 2
After the configuration, when users telnet to the switch, they must enter the password 12345678. After passing authentication, they can use commands of levels 0, 1, and 2.
·       For more information about user login authentication, see the chapter “Logging in to the CLI.” For more information about the user-interface, authentication-mode, and user privilege level commands, see Fundamentals Command Reference.
·       For more information about AAA authentication, see Security Configuration Guide. For more information about the local-user and authorization-attribute commands, see Security Command Reference.
·       For more information about SSH, see Security Configuration Guide.
Switching the user privilege level
Users can switch to a different user privilege level without logging out and terminating the current connection. After the privilege level switching, users can continue to manage the switch without relogging in, but the commands that they can execute have changed. For example, with the user privilege level 3, a user can configure system parameters. After switching to user privilege level 0, the user can only execute simple commands like ping and tracert and use a few display commands. The switching operation is effective for the current login. After the user relogs in, the user privilege restores to the original level.
·           To avoid problems, H3C recommends that administrators log in to the switch by using a lower privilege level to view switch operating parameters, and switch to a higher level temporarily only when they have to maintain the switch,
·           When an administrator needs to leave for a while or ask someone else to manage the switch temporarily, they can switch to a lower privilege level before they leave to restrict the operation by others.
Setting the authentication mode for user privilege level switching
A user can switch to a privilege level equal to or lower than the current one unconditionally and is not required to enter a password (if any).
For security, a user is required to enter the password (if any) to switch to a higher privilege level. The authentication falls into one of the following four categories:
Authentication mode
Meaning
local
Local password authentication
The switch authenticates a user by using the privilege level switching password entered by the user.
To use this mode, you must set the password for privilege level switching by using the super password command.
scheme
Remote AAA authentication through HWTACACS or RADIUS
The switch sends the username and password for privilege level switching to the HWTACACS or RADIUS server for remote authentication.
To use this mode, you must perform the following configurations:
·       Configure the required HWTACACS or RADIUS schemes and configure the ISP domain to use the schemes for users. For more information, see Security Configuration Guide.
·       Add user accounts and specify the user passwords on the HWTACACS or RADIUS server.
local scheme
Performs the local password authentication first and then the remote AAA authentication
The switch authenticates a user by using the local password first, and if no password for privilege level switching is set, for the user logged in from the console port, the privilege level is switched directly; for the user logged in from any of the AUX or VTY user interfaces, the AAA authentication is performed.
scheme local
Performs remote AAA authentication first and then the local password authentication
AAA authentication is performed first, and if the remote HWTACACS or RADIUS server does not respond or AAA configuration on the switch is invalid, the local password authentication is performed.
To set the authentication mode for user privilege level switching:
Step
Remarks
N/A
2.     Set the authentication mode for user privilege level switching.
super authentication-mode { local | scheme } *
Optional.
local by default.
3.     Configure the password for user privilege level switching.
super password [ level user-level ] { simple | cipher } password
Required if the authentication mode is set to local (specify the local keyword when setting the authentication mode)
By default, no privilege level switching password is configured.
CAUTION
CAUTION:
·       If no user privilege level is specified when you configure the password for switching the user privilege level with the super password command, the user privilege level defaults to 3.
·       If you specify the simple keyword, the password is saved in the configuration file in plain text, and is easy to be stolen. If you specify the cipher keyword, the password is saved in the configuration file in cipher text and is safer.
·       If the user logs in from the console user interface (the console port or the AUX port used as the console port), the privilege level can be switched to a higher level, although the authentication mode is local, and no user privilege level password is configured.
To switch the user privilege level:
Remarks
Switch the user privilege level.
super [ level ]
When logging in to the switch, a user has a user privilege level, which depends on user interface or authentication user level.
Available in user view.
When you switch the user privilege level, the information you must provide varies with combinations of the user interface authentication mode and the super authentication mode.
Table 8 Information entered for user privilege level switching
User interface authentication mode
User privilege level switching authentication mode
Information entered for the first authentication mode
Information entered after the authentication mode changes
none/password
local
Local user privilege level switching password (configured on the switch)
N/A
local scheme
Username and password for privilege level switching (configured on the AAA server).
scheme
N/A
scheme local
Local user privilege level switching password.
scheme
local
N/A
local scheme
Password for privilege level switching (configured on the AAA server). The system uses the username used for logging in as the privilege level switching username.
scheme
N/A
scheme local
CAUTION
CAUTION:
·       When the authentication mode is set to local, configure the local password before switching to a higher user privilege level.
·       When the authentication mode is set to scheme, configure AAA related parameters before switching to a higher user privilege level.
·       The privilege level switching fails after three consecutive unsuccessful password attempts.
·       For more information about user interface authentication, see the chapter “Logging in to the CLI.”
Modifying the level of a command
All the commands in a view default to different levels. The administrator can change the default level of a command to a lower level or a higher level as needed.
To modify the command level:
Step
Remarks
N/A
2.     Configure the command level in a specified view.
command-privilege level level view view command
See Table 7 for the default settings.
CAUTION
CAUTION:
H3C recommends that you use the default command level or modify the command level under the guidance of professional staff. An improper change of the command level may bring inconvenience to your maintenance and operation, or even potential security problems.
Saving the running configuration
You can enter the save command in any view to save all the submitted and executed commands into the configuration file. Commands saved in the configuration file can survive a reboot. The save command does not take effect on one-time commands, such as display commands, which display specified information, and the reset commands, which clear specified information. The one-time commands executed are never saved.
Displaying and maintaining CLI
Remarks
Display configuration information about the command keyword alias function.
display command-alias [ | { begin | exclude | include } regular-expression ]
Display the clipboard information.
display clipboard [ | { begin | exclude | include } regular-expression ]
