- H3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
- 01-Login Configuration
- 02-VLAN Configuration
- 03-IP Addressing and IP Performance Configuration
- 04-QinQ-BPDU Tunneling Configuration
- 05-Port Correlation Configuration
- 06-Link Aggregation Configuration
- 07-MAC Address Table Management Configuration
- 08-Port Security Configuration
- 09-MSTP Configuration
- 10-IP Routing-GR Overview Configuration
- 11-IPv4 Routing Configuration
- 12-IP Source Guard Configuration
- 13-DLDP Configuration
- 14-Multicast Configuration
- 15-LLDP Configuration
- 16-sFlow Configuration
- 17-ARP Configuration
- 18-DHCP Configuration
- 19-ACL Configuration
- 20-QoS Configuration
- 21-Port Mirroring Configuration
- 22-UDP Helper Configuration
- 23-SNMP-RMON Configuration
- 24-NTP Configuration
- 25-DNS Configuration
- 26-File System Management Configuration
- 27-Information Center Configuration
- 28-System Maintaining and Debugging Configuration
- 29-NQA Configuration
- 30-SSH Configuration
- 31-SSL-HTTPS Configuration
- 32-PKI Configuration
- 33-Track Configuration
- 34-Acronyms
- 35-Index
17-ARP Configuration | 138.83 KB |
ARP Address Resolution Process
Configuring a Static ARP Entry
Configuring the Maximum Number of ARP Entries for a VLAN Interface
Setting Aging Time for Dynamic ARP Entries
Introduction to Gratuitous ARP
Displaying and Maintaining ARP
Displaying and Maintaining Proxy ARP
Proxy ARP Configuration Examples
Local Proxy ARP Configuration Example in Case of Port Isolation
When configuring ARP, go to these sections for information you are interested in:
l Displaying and Maintaining ARP
The term switch in this document refers to a switch in a generic sense or an access controller configured with the switching function unless otherwise specified.
ARP Overview
ARP Function
Address Resolution Protocol (ARP) is used to resolve an IP address into a data link layer address.
An IP address is the address of a host at the network layer. To send a network layer packet to a destination host, the device must know the data link layer address (such as the MAC address) of the destination host. To this end, the IP address must be resolved into the corresponding data link layer address.
Unless otherwise stated, the data link layer addresses that appear in this chapter refer to the 48-bit Ethernet MAC addresses.
ARP Message Format
The following explains the fields in Figure 1-1.
l Hardware type: This field specifies the hardware address type. The value “1” represents Ethernet.
l Protocol type: This field specifies the type of the protocol address to be mapped. The hexadecimal value “0x0800” represents IP.
l Hardware address length and protocol address length: They respectively specify the length of a hardware address and a protocol address, in bytes. For an Ethernet address, the value of the hardware address length field is "6”. For an IP(v4) address, the value of the protocol address length field is “4”.
l OP: Operation code. This field specifies the type of ARP message. The value “1” represents an ARP request and “2” represents an ARP reply.
l Sender hardware address: This field specifies the hardware address of the device sending the message.
l Sender protocol address: This field specifies the protocol address of the device sending the message.
l Target hardware address: This field specifies the hardware address of the device the message is being sent to.
l Target protocol address: This field specifies the protocol address of the device the message is being sent to.
Suppose that Host A and Host B are on the same subnet and that Host A sends a message to Host B, as show in Figure 1-2. The resolution process is as follows:
1) Host A looks in its ARP mapping table to see whether there is an ARP entry for Host B. If Host A finds it, Host A uses the MAC address in the entry to encapsulate the IP packet into a data link layer frame and sends the frame to Host B.
2) If Host A finds no entry for Host B, Host A buffers the packet and broadcasts an ARP request, in which the source IP address and source MAC address are respectively the IP address and MAC address of Host A and the destination IP address and MAC address are respectively the IP address of Host B and an all-zero MAC address. Because the ARP request is sent in broadcast mode, all hosts on this subnet can receive the request, but only the requested host (namely, Host B) will process the request.
3) Host B compares its own IP address with the destination IP address in the ARP request. If they are the same, Host B saves the source IP address and source MAC address into its ARP mapping table, encapsulates its MAC address into an ARP reply, and unicasts the reply to Host A.
4) After receiving the ARP reply, Host A adds the MAC address of Host B into its ARP mapping table for subsequent packet forwarding. Meanwhile, Host A encapsulates the IP packet and sends it out.
Figure 1-2 ARP address resolution process
When Host A and Host B are not on the same subnet, Host A first sends an ARP request to the gateway. The destination IP address in the ARP request is the IP address of the gateway. After obtaining the MAC address of the gateway from an ARP reply, Host A encapsulates the packet and sends it to the gateway. Subsequently, the gateway broadcasts the ARP request, in which the destination IP address is the one of Host B. After obtaining the MAC address of Host B from another ARP reply, the gateway sends the packet to Host B.
ARP Mapping Table
After obtaining the destination MAC address, the device adds the IP-to-MAC mapping into its own ARP mapping table. This mapping is used for forwarding packets with the same destination in future.
An ARP mapping table contains ARP entries, which fall into two categories: dynamic and static.
1) A dynamic entry is automatically created and maintained by ARP. It can get aged, be updated by a new ARP packet, or be overwritten by a static ARP entry. When the aging timer expires or the port goes down, the corresponding dynamic ARP entry will be removed.
2) A static ARP entry is manually configured and maintained. It cannot get aged or be overwritten by a dynamic ARP entry. It can be permanent or non-permanent.
l A permanent static ARP entry can be directly used to forward packets. When configuring a permanent static ARP entry, you must configure a VLAN and outbound port for the entry besides the IP address and MAC address.
l A non-permanent static ARP entry cannot be directly used for forwarding data. When configuring a non-permanent static ARP entry, you only need to configure the IP address and MAC address. When forwarding IP packets, the device sends an ARP request. If the source IP and MAC addresses in the received ARP reply are the same as the configured IP and MAC addresses, the device adds the port receiving the ARP reply into the static ARP entry. Now the entry can be used for forwarding IP packets.
Usually ARP dynamically implements and automatically seeks mappings from IP addresses to MAC addresses, without manual intervention.
Configuring ARP
A static ARP entry is effective when the device works normally. However, when a VLAN or VLAN interface to which a static ARP entry corresponds is deleted, the entry, if permanent, will be deleted, and if non-permanent and resolved, will become unresolved.
Follow these steps to configure a static ARP entry:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure a permanent static ARP entry |
arp static ip-address mac-address vlan-id interface-type interface-number |
Required No permanent static ARP entry is configured by default. |
Configure a non-permanent static ARP entry |
arp static ip-address mac-address |
Required No non-permanent static ARP entry is configured by default. |
The vlan-id argument must be the ID of an existing VLAN which corresponds to the ARP entries. In addition, the Ethernet port following the argument must belong to that VLAN. A VLAN interface must be created for the VLAN.
Follow these steps to set the maximum number of dynamic ARP entries that a VLAN interface can learn:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter VLAN interface view |
interface Vlan-interface vlan-id |
Set the maximum number of dynamic ARP entries that a VLAN interface can learn |
arp max-learning-num number |
Optional 2048 by default. |
After dynamic ARP entries expire, the system will delete them from the ARP mapping table. You can adjust the aging time for dynamic ARP entries according to the actual network condition.
Follow these steps to set aging time for dynamic ARP entries:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Set aging time for dynamic ARP entries |
arp timer aging aging-time |
Optional 20 minutes by default. |
Enabling the ARP Entry Check
The ARP entry check can control the device to learn multicast MAC addresses. With the ARP entry check enabled, the device cannot learn any ARP entry with a multicast MAC address. Configuring such a static ARP entry is not allowed either; otherwise, the system prompts error information.
After the ARP entry check is disabled, the device can learn the ARP entry with a multicast MAC address, and you can also configure such a static ARP entry on the device.
Follow these steps to enable the ARP entry check:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable the ARP entry check |
arp check enable |
Optional Enabled by default. |
Network requirements
l Enable the ARP entry check.
l Set the aging time for dynamic ARP entries to 10 minutes.
l Set the maximum number of dynamic ARP entries that VLAN-interface 10 can learn to 1000.
l Add a static ARP entry, with the IP address being 192.168.1.1/24, the MAC address being 000f-e201-0000, and the outbound port being GigabitEthernet 0/0/10 of VLAN 10.
Configuration procedure
[Sysname] arp check enable
[Sysname] arp timer aging 10
[Sysname] vlan 10
[Sysname-vlan10] port gigabitethernet 0/0/10
[Sysname-vlan10] quit
[Sysname-vlan-interface10] arp max-learning-num 1000
[Sysname-vlan-interface10] quit
[Sysname] arp static 192.168.1.1 000f-e201-0000 10 gigabitethernet0/0/10
Configuring Gratuitous ARP
A gratuitous ARP packet is a special ARP packet, in which the source IP address and destination IP address are both the IP address of the sender, the source MAC address is the MAC address of the sender, and the destination MAC address is a broadcast address.
A device can implement the following functions by sending gratuitous ARP packets:
l Determining whether its IP address is already used by another device.
l Informing other devices of its MAC address change so that they can update their ARP entries.
A device receiving a gratuitous ARP packet can add the information carried in the packet to its own dynamic ARP mapping table if it finds no corresponding ARP entry for the ARP packet in the cache.
Follow these steps to configure gratuitous ARP:
Use the command… |
Remarks |
Enter system view |
system-view |
Enable the device to send gratuitous ARP packets when receiving ARP requests from another network segment |
gratuitous-arp-sending enable |
Required By default, a device cannot send gratuitous ARP packets when receiving ARP requests from another network segment. |
Enable the gratuitous ARP packet learning function |
gratuitous-arp-learning enable |
Required Enabled by default. |
To do… |
Use the command… |
Remarks |
Display the ARP entries in the ARP mapping table |
display arp { { all | dynamic | static } | vlan vlan-id | interface interface-type interface-number } [ | { begin | exclude | include } string | count ] |
Available in any view |
Display the ARP entries for a specified IP address |
display arp ip-address [ | { begin | exclude | include } string ] |
Display the aging time for dynamic ARP entries |
display arp timer aging |
Clear ARP entries from the ARP mapping table |
reset arp { all | dynamic | static | interface interface-type interface-number } |
Available in user view |
Executing the reset arp interface interface-type interface-number command only removes dynamic ARP entries of the specified port. To remove specified static ARP entries, you need to use the undo arp ip-address command.
When configuring proxy ARP, go to these sections for information you are interested in:
l Displaying and Maintaining Proxy ARP
Proxy ARP Overview
For an ARP request of a host on a network to be forwarded to an interface that is on the same network but isolated at Layer 2 or a host on another network, the device connecting the two physical or virtual networks must be able to respond to the request. This is achieved by proxy ARP.
Proxy ARP implements Layer 3 communication between VLAN interfaces isolated at Layer 2 or located on different networks.
In one of the following cases, you need to enable the local proxy ARP:
l Devices connected to different isolated Layer 2 ports in the same VLAN on a switch need to implement Layer 3 communication.
l With the isolate-user-vlan function enabled on a device attached to a switch, devices in different secondary VLANs need to implement Layer 3 communication.
Enabling Proxy ARP
Follow these steps to enable proxy ARP or enable local proxy ARP in VLAN interface view:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Required |
Enable proxy ARP |
proxy-arp enable |
Required Disabled by default. |
Enable local proxy ARP |
local-proxy-arp enable |
To do… |
Use the command… |
Remarks |
Display whether proxy ARP is enabled |
display proxy-arp [ interface Vlan-interface vlan-id ] |
Display whether local proxy ARP is enabled |
display local-proxy-arp [ interface Vlan-interface vlan-id ] |
Host A and Host D have IP addresses of the same network segment. Host A belongs to VLAN 1, and Host D belongs to VLAN 2. Configure proxy ARP on AC to enable the communication between the two hosts.
Network diagram
Figure 2-1 Network diagram for proxy ARP
# Configure proxy ARP on AC to enable the communication between Host A and Host D.
<AC> system-view
[AC] vlan 2
[AC-vlan2] quit
[AC] interface vlan-interface 1
[AC-Vlan-interface1] ip address 192.168.10.99 255.255.255.0
[AC-Vlan-interface1] proxy-arp enable
[AC-Vlan-interface1] quit
[AC] interface vlan-interface 2
[AC-Vlan-interface2] ip address 192.168.20.99 255.255.255.0
[AC-Vlan-interface2] proxy-arp enable
[AC-Vlan-interface2] quit
l Host A and Host B belong to the same VLAN, and are connected to GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 of Switch respectively.
l Switch is connected to AC via GigabitEthernet 0/0/1.
l GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 isolated at Layer 2 can implement Layer 3 communication.
Network diagram
Figure 2-2 Network diagram for local proxy ARP between isolated ports
1) Configure Switch
# Create VLAN 2 on Switch, on which GigabitEthernet 0/0/1, GigabitEthernet 0/0/2, and GigabitEthernet 0/0/3 belong to VLAN 2. Host A and Host B are isolated and unable to exchange Layer 2 packets.
<Switch> system-view
[Switch] vlan 2
[Switch-vlan2] port gigabitethernet 0/0/1
[Switch-vlan2] port gigabitethernet 0/0/2
[Switch-vlan2] port gigabitethernet 0/0/3
[Switch-vlan2] quit
[Switch] interface gigabitethernet 0/0/2
[Switch-GigabitEthernet0/0/2] port-isolate enable
[Switch-GigabitEthernet0/0/2] quit
[Switch] interface gigabitethernet 0/0/3
[Switch-GigabitEthernet0/0/3] port-isolate enable
[Switch-GigabitEthernet0/0/3] quit
2) Configure AC
# Configure an IP address of VLAN-interface 2.
[AC] vlan 2
[AC-vlan2] port gigabitethernet 0/0/2
[AC-vlan2] quit
[AC-Vlan-interface2] ip address 192.168.10.100 255.255.0.0
Ping Host B on Host A to verify that the two hosts cannot be pinged through, which indicates they are isolated at Layer 2.
# Configure local proxy ARP to let Host A and Host B communicate at Layer 3.
[AC-Vlan-interface2] local-proxy-arp enable
Ping Host B on Host A to verify that the two hosts can be pinged through, which indicates Layer 3 communication is implemented.
