- H3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
- 01-Login Configuration
- 02-VLAN Configuration
- 03-IP Addressing and IP Performance Configuration
- 04-QinQ-BPDU Tunneling Configuration
- 05-Port Correlation Configuration
- 06-Link Aggregation Configuration
- 07-MAC Address Table Management Configuration
- 08-Port Security Configuration
- 09-MSTP Configuration
- 10-IP Routing-GR Overview Configuration
- 11-IPv4 Routing Configuration
- 12-IP Source Guard Configuration
- 13-DLDP Configuration
- 14-Multicast Configuration
- 15-LLDP Configuration
- 16-sFlow Configuration
- 17-ARP Configuration
- 18-DHCP Configuration
- 19-ACL Configuration
- 20-QoS Configuration
- 21-Port Mirroring Configuration
- 22-UDP Helper Configuration
- 23-SNMP-RMON Configuration
- 24-NTP Configuration
- 25-DNS Configuration
- 26-File System Management Configuration
- 27-Information Center Configuration
- 28-System Maintaining and Debugging Configuration
- 29-NQA Configuration
- 30-SSH Configuration
- 31-SSL-HTTPS Configuration
- 32-PKI Configuration
- 33-Track Configuration
- 34-Acronyms
- 35-Index
00-Preface | 93.32 KB |
Preface
The H3C WX6103 Access Controller Switch Interface Board Configuration Guide describes the software features for the H3C WX6103 access controller switch Interface board and guides you through the software configuration procedures. It also provides configuration examples to help you apply software features to different network scenarios.
This preface includes:
l Audience
l About the H3C WX6103 Documentation Set
Audience
l Network planners
l Field technical support and servicing engineers
l Network administrators working with the H3C WX6103 access controller switch interface board
Document Organization
The H3C WX6103 Access Controller Switch Interface Board Configuration Guide comprises these parts:
Content |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
Means an action or information that needs special attention to ensure successful configuration or good performance. |
Means a complementary description. |
Means techniques helpful for you to make configuration with ease. |
Network topology icons
Convention |
The H3C WX6103 documentation set includes:
Manual |
H3C WX6103 Access Controller Switch Interface Board Command Reference |
Elaborates on the operation commands for the WX6103 access controller switch interface board. It covers the configuration commands for CLI, VLAN, MSTP, system maintaining and debugging, port basic configurations, multicast protocol, 802.1x, AAA, SSH, ACL, QoS, and a command index of the whole reference. |
It introduces the installation process, startup, hardware and software maintenance, and monitoring of the WX6103 access controller. |
Provides a guide to the operation of H3C series access controllers. It covers configurations of CLI, VLAN, system maintenance and debugging, WLAN, IPv4, IPv6, port basic configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, and description of the acronyms used throughout the guide. |
Elaborates on the operation commands for H3C series access controllers. It covers the configuration commands for VLAN, system maintenance and debugging, WLAN, IPv4, IPv6, port basic configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, and a command index of the whole reference. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
