12-EVPN命令参考
01-EVPN命令
本章节下载 01-EVPN命令  (959.86 KB)
01-EVPN命令
  录
1 EVPN
1.1 EVPN配置命令
1.1.1 ac interface
1.1.2 address-family evpn (public instance view)
1.1.3 address-family evpn (VPN instance view)
1.1.4 address-family ipv4 (public instance view)
1.1.5 address-family l2vpn evpn (BGP instance view)
1.1.6 advertise l2vpn evpn
1.1.7 arp mac-learning disable
1.1.8 arp proxy-send enable
1.1.9 arp-advertising disable
1.1.10 bestroute ipv6-nexthop
1.1.11 display bgp l2vpn evpn
1.1.12 display bgp l2vpn evpn inlabel
1.1.13 display evpn auto-discovery
1.1.14 display evpn df-election
1.1.15 display evpn es
1.1.16 display evpn instance
1.1.17 display evpn ipv6 auto-discovery
1.1.18 display evpn route arp
1.1.19 display evpn route arp suppression
1.1.20 display evpn route arp-mobility
1.1.21 display evpn route mac
1.1.22 display evpn route mac-mobility
1.1.23 display evpn route nd
1.1.24 display evpn route nd suppression
1.1.25 display evpn route nd-mobility
1.1.26 display evpn route xconnect-group
1.1.27 display evpn routing-table
1.1.28 display l2vpn forwarding evpn split-horizon
1.1.29 e-tree enable
1.1.30 esi
1.1.31 evpn encapsulation
1.1.32 evpn global-mac
1.1.33 evpn df-election ac-influence enable
1.1.34 evpn df-election algorithm (interface view)
1.1.35 evpn df-election algorithm (system view)
1.1.36 evpn df-election preference
1.1.37 evpn df-election preference non-revertive
1.1.38 evpn irb asymmetric
1.1.39 evpn local-service-id remote-service-id
1.1.40 evpn mac-ip advertise distributed-gateway
1.1.41 evpn mpls routing-enable
1.1.42 evpn multihoming advertise disable
1.1.43 evpn multihoming advertise ignore-ethernet-tag
1.1.44 evpn multihoming timer df-delay
1.1.45 evpn route arp-mobility suppression
1.1.46 evpn route mac-mobility suppression
1.1.47 evpn route nd-mobility suppression
1.1.48 evpn span-segment disable
1.1.49 evpn timer es-delay
1.1.50 evpn timer es-recovery
1.1.51 evpn track peer
1.1.52 export route-policy
1.1.53 igp-metric inherit
1.1.54 import evpn mac-ip
1.1.55 import route-policy
1.1.56 ip public-instance
1.1.57 ipv6 nd ra tunnel-broadcast global enable
1.1.58 l3-vni
1.1.59 mac-advertising disable
1.1.60 nd-advertising enable
1.1.61 nd mac-learning disable
1.1.62 peer advertise encap-type mpls
1.1.63 peer advertise vpn-reoriginate ibgp (BGP EVPN address family view)
1.1.64 peer default-gateway no-advertise
1.1.65 peer re-originated
1.1.66 peer suppress original-route
1.1.67 policy vpn-target
1.1.68 pw-class
1.1.69 reset evpn route arp-mobility suppression
1.1.70 reset evpn route mac-mobility suppression
1.1.71 reset evpn route nd-mobility suppression
1.1.72 route-distinguisher
1.1.73 rr-filter
1.1.74 snmp-agent trap enable evpn
1.1.75 tunnel-policy
1.1.76 vpn-route cross multipath
1.1.77 vpn-target
1 EVPN
设备不支持VXLAN数据中心互联组网、EVPN数据中心互联组网、以太网服务实例的AC、EVPN实例视图。
1.1  EVPN配置命令
1.1.1  ac interface
ac interface命令用来指定交叉连接关联的接口。
undo ac interface命令用来取消接口与交叉连接的关联。
ac interface interface-type interface-number [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-15> ]
undo ac interface interface-type interface-number
交叉连接未关联接口。
交叉连接视图
access-mode:指定接入模式。当AC为三层接口或三层子接口时,缺省接入模式如下:
¡     对于VLAN接口,缺省接入模式为VLAN;对于其他三层接口,缺省接入模式为Ethernet。
¡     对于三层子接口,缺省接入模式为VLAN。
ethernet:指定接入模式为Ethernet。
vlan:指定接入模式为VLAN。
track track-entry-number&<1-15>:配置AC(三层接口)与指定Track项联动。track-entry-number为Track项的序号,取值范围为1~1024;&<1-15>表示前面的参数最多可以输入15次。指定本参数后,仅当关联的Track项中至少有一个状态为positive时,AC的状态才会up;否则,AC的状态为down。
在交叉连接视图/自动发现交叉连接视图下执行本命令后,从关联接口接收到的所有报文,将通过与该交叉连接关联的PW或另一条AC转发。
接入模式是PE对从CE收到的以太网帧携带的外层VLAN Tag的理解方式,以及PE向CE发送以太网帧的方式。接入模式分为两种:
·     VLAN接入模式:CE发送给PE的以太网帧头需要带有一个VLAN Tag,该Tag被称为P-Tag,即服务提供商网络为了区分用户而添加的“服务定界符”。PE发送以太网帧给CE时,也需要携带P-Tag。
·     Ethernet接入模式:CE发送给PE的以太网帧头中如果带有VLAN Tag,则该Tag被称为U-Tag,即用户网络的内部VLAN Tag,对于PE设备没有意义。PE发送以太网帧给CE时,不需要携带P-Tag。
# 在交叉连接组vpna的交叉连接aaa中关联接口GigabitEthernet2/0/1,使该接口接收到的所有报文都通过与该交叉连接关联的PW或另一条AC转发。
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] connection aaa
[Sysname-xcg-vpna-aaa] ac interface gigabitethernet 2/0/1
·     connection(MPLS命令参考/MPLS L2VPN)
·     display l2vpn interface(MPLS命令参考/MPLS L2VPN)
·     encapsulation(MPLS命令参考/MPLS L2VPN)
·     pw-type(MPLS命令参考/MPLS L2VPN)
address-family evpn命令用来进入公网实例EVPN视图。
undo address-family evpn命令用来删除公网实例EVPN视图下的所有配置。
address-family evpn
公网实例视图
在公网实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入公网实例EVPN视图。
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
address-family evpn命令用来进入VPN实例EVPN视图。
undo address-family evpn命令用来删除VPN实例EVPN视图下的所有配置。
address-family evpn
VPN实例视图
在VPN实例EVPN视图下可以配置EVPN的参数,如EVPN的RT属性、应用的出方向路由策略等。
# 进入VPN实例EVPN视图。
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
address-family ipv4命令用来进入公网实例IPv4地址族视图。
undo address-family ipv4命令用来删除公网实例IPv4地址族视图下的所有配置。
address-family ipv4
公网实例视图
# 进入公网实例IPv4地址族视图。
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
address-family l2vpn evpn命令用来创建BGP EVPN地址族,并进入BGP EVPN地址族视图。如果BGP EVPN地址族已经存在,直接进入BGP EVPN地址族视图。
undo address-family l2vpn evpn命令用来删除BGP EVPN地址族,及相应地址族视图下的所有配置。
不存在BGP EVPN地址族。
BGP实例视图
BGP EVPN地址族视图下的配置,只对公网BGP EVPN地址族的路由和对等体生效。
# 创建BGP EVPN地址族,并进入BGP EVPN地址族视图。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise l2vpn evpn命令用来配置允许对外发布 BGP EVPN路由。
undo advertise l2vpn evpn命令用来禁止对外发布 BGP EVPN路由。
允许对外发布BGP EVPN路由。
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
配置允许对外发布 BGP EVPN路由后,设备接收到BGP EVPN路由,并将其添加到某个VPN实例路由表后,会将该路由(私网路由)发布到本地站点。
# 配置允许BGP VPN实例vpn1对外发布BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
arp mac-learning disable命令用来配置禁止EVPN从ARP信息中学习MAC地址表项。
undo arp mac-learning disable命令用来恢复缺省情况。
EVPN可以从ARP信息中学习MAC地址表项。
EVPN实例视图
VSI实例下的EVPN实例视图
本端VTEP或PE可能会同时接收到远端设备通告的MAC地址信息和ARP信息。其中,ARP信息中包含MAC地址信息。为了避免重复,可以在本端设备上执行本命令禁止EVPN从ARP信息中学习MAC地址表项,EVPN仅通过MAC地址信息学习远端MAC地址表项。
# 配置禁止EVPN从ARP信息中学习MAC地址表项。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] arp mac-learning disable
arp proxy-send enable命令用来开启ARP请求代理发送功能。
undo arp proxy-send enable命令用来关闭ARP请求代理发送功能。
ARP请求代理发送功能处于关闭状态。
VSI虚接口视图
EVPN VXLAN组网中,VM 1连接VTEP 1,VM 2连接VTEP 2,VM 1和VM 2属于同一网段。VTEP 1和VTEP 2分别配置VSI虚接口作为VM 1和VM 2的网关,VTEP 1和VTEP 2均配置如下功能:
·     VTEP 1和VTEP 2建立BGP EVPN邻居
·     禁止EVPN从ARP信息中学习MAC地址表项
·     禁止通告MAC地址信息,并撤销已经通告的MAC地址信息
·     关闭远端MAC地址自动学习功能
·     VSI虚接口开启本地代理ARP功能
·     VTEP 1和VTEP 2的VSI虚接口的IP地址、MAC地址均不同
在该组网中,VM 1希望访问VM 2时,VM 1发送ARP请求报文,VTEP 1学习VM 1的MAC地址并代理应答VM 1的ARP请求报文。同时VTEP 1发送ARP请求报文请求VM 2的MAC地址。VM 2单播应答VTEP 1的ARP请求。VTEP 2不会从VM 2的ARP应答报文中学习VM 2的MAC地址,由于VTEP 1关闭了远端MAC地址自动学习功能,也不会学习VM 2的MAC地址,无法形成表项,导致VM 1无法访问VM 2。
为解决上述问题,可在VTEP 2上配置本命令,使VTEP 2收到VTEP 1的ARP请求报文时,生成以VSI虚接口IP地址为源的ARP请求,并同时广播两个ARP请求。VM 2分别应答VTEP 1和VTEP 2的ARP请求。VTEP 2从VM 2发给自己的ARP应答报文中学习VM 2的MAC地址,并通过EVPN路由发布给VTEP 1。VTEP 1和VTEP 2均获得VM 1和VM 2的MAC地址信息后,VM 1和VM 2可以互相访问。
# 在VSI虚接口100上开启ARP代理发送请求功能。
[Sysname] interface vsi-interface 100
[Sysname-vsi-interface100] arp proxy-send enable
·     local-proxy-arp enable(三层技术-IP业务命令参考/代理ARP)
arp-advertising disable命令用来配置禁止通告ARP信息,并撤销已经通告的ARP信息。
undo arp-advertising disable命令用来恢复缺省情况。
允许通告ARP信息。
EVPN实例视图
VSI实例下的EVPN实例视图
在EVPN VXLAN分布式网关组网中,如果同一个VXLAN网络内的所有用户终端都部署在同一台EVPN网关下,则EVPN不需要通告该VXLAN网络的ARP信息(同时携带MAC和IP地址的MAC/IP发布路由),只需通告IP前缀路由,其他VXLAN网络内的用户终端通过IP前缀路由即可访问该VXLAN网络。此时,可以配置本命令禁止EVPN通告ARP信息,以减少占用的设备和网络资源。执行本命令后,设备还会撤销已经发布的ARP信息。
# 在EVPN VXLAN分布式网关组网中,配置EVPN实例禁止通告ARP信息,并撤销已经通告的ARP信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] arp-advertising disable
bestroute ipv6-nexthop命令用来配置BGP选择最优路由时,优选下一跳地址为IPv6地址的路由。
undo bestroute ipv6-nexthop命令用来恢复缺省情况。
BGP选择最优路由时,优选下一跳地址为IPv4地址的路由。
BGP EVPN地址族视图
在EVPN组网中,Underlay网络可能由IPv4网络和IPv6网络共同组成。当网络中同时存在下一跳为IPv4地址和IPv6地址的多条路由时,BGP会优先选择下一跳地址为IPv4地址的路由,使得VXLAN报文优先通过IPv4 Underlay网络转发。若想优先通过IPv6 Underlay网络转发VXLAN报文,则可以执行本命令,配置BGP优选下一跳地址为IPv6地址的路由。
# 在BGP EVPN地址族视图下,配置路由优选时优先选择下一跳地址为IPv6地址的路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] bestroute ipv6-nexthop
display bgp l2vpn evpn命令用来显示BGP EVPN路由信息。
display bgp [ instance instance-name ] l2vpn evpn [ peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { auto-discovery | es | igmp-js | igmp-ls | imet | ip-prefix | mac-ip | smet } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info | as-path | cluster-list | community | ext-community ] | ipv4-address | ipv6-address | mac-address ] | statistics ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] community-list { basic-community-list-number | comm-list-name | adv-community-list-number } [ whole-match ]
display bgp [ instance instance-name ] l2vpn evpn [ route-distinguisher route-distinguisher ] [ statistics ] ext-community [ bandwidth link-bandwidth-value | rt route-target | soo site-of-origin | color color ]&<1-32> [ whole-match ]
peer { ipv4-address | ipv6-address }:显示向指定对等体发布或者从指定对等体收到的BGP EVPN路由。ipv4-address表示对等体的IPv4地址;ipv6-address为对等体的IPv6地址。
advertised-routes:显示向指定对等体发布的BGP EVPN路由信息。
received-routes:显示从指定对等体接收到的BGP EVPN路由信息。
statistics:显示BGP EVPN路由的统计信息。
route-distinguisher route-distinguisher:显示指定路由标识符的BGP EVPN路由信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
route-type:显示指定类型的BGP EVPN路由。
auto-discovery:显示以太网自动发现路由(Ethernet auto-discovery route)。
es:显示以太网段路由(Ethernet segment route)。
igmp-js:显示IGMP加入同步路由(IGMP join synch route)。
igmp-ls:显示IGMP离开同步路由(IGMP leave synch route)。
imet:显示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route),
ip-prefix:显示IP前缀路由(IP prefix advertisement route)。
mac-ip:显示MAC/IP发布路由(MAC/IP advertisement route)。
smet:显示选择性组播以太网标签路由(Selective multicast Ethernet tag route)。
evpn-route:显示指定BGP EVPN路由的详细信息。evpn-route表示EVPN路由信息,为1~512个字符的字符串。
route-length:BGP EVPN路由信息的长度,取值范围为0~65535,单位为比特。
evpn-prefix:显示指定BGP EVPN路由的详细信息。evpn-prefix包含EVPN路由信息和路由信息长度,组成格式为evpn-route/route-length,为1~512个字符的字符串,不区分大小写。
advertise-info:显示BGP EVPN路由的通告信息。
as-path:显示指定BGP EVPN路由的AS_PATH属性信息。
cluster-list:显示指定BGP EVPN路由的集群ID列表属性信息。
community:显示指定BGP EVPN路由的团体属性信息,或显示匹配指定团体号的BGP EVPN路由信息。
ext-community:显示BGP EVPN路由的扩展团体属性信息,或显示匹配指定扩展团体属性的BGP EVPN路由信息。
ipv4-address:显示包含指定IPv4地址的EVPN路由信息。
ipv6-address:显示包含指定IPv6地址的EVPN路由信息。
mac-address:显示包含指定MAC地址的MAC/IP发布路由信息。执行本命令时,如果指定了route-type参数,则只有指定路由类型为mac-ip时,才可以指定本参数。
aa:nn&<1-32>:团体号,aann的取值范围为0~65535。&<1-32>表示前面的参数可以输入1~32次。
internet:表示预定义的团体属性。缺省情况下,所有的路由都具有internet团体属性,可以被通告给所有的BGP对等体。
no-advertise:表示NO_ADVERTISE团体属性。具有此属性的路由在收到后,不能被通告给任何其他的BGP对等体。
no-export:表示NO_EXPORT团体属性。具有此属性的路由在收到后,不能被发布到本地AS之外。如果使用了联盟,则不能被发布到联盟之外,但可以发布给联盟中的其他子AS。
no-export-subconfed:表示NO_EXPORT_SUBCONFED团体属性。具有此属性的路由在收到后,不能被发布到本地AS之外,也不能发布到联盟中的其他子AS。
whole-match:精确匹配。如果指定了本参数,则只有路由的团体属性列表/团体号/扩展团体属性与指定的团体属性列表/团体号/扩展团体属性完全相同时,才显示该路由的信息;如果未指定本参数,则只要路由的团体属性列表/团体号/扩展团体属性中包含指定的团体属性列表/团体号/扩展团体属性,就显示该路由的信息。
communit-list:显示匹配指定BGP团体列表的BGP EVPN单播路由信息。
basic-community-list-number:基本团体列表号,取值范围为1~99。
comm-list-name:团体属性列表名,为1~63个字符的字符串,区分大小写。
adv-community-list-number:高级团体列表号,取值范围为100~199。
bandwidth link-bandwidth-value:链路带宽扩展团体属性,link-bandwidth-value为3~16个字符的字符串,形式为16位自治系统号:32位用户自定义数,例如:100:3。其中,自治系统号的取值范围为0~65535,用户自定义数的取值范围为0~4294967295。
color color:Color扩展团体属性,color为4~13个字符的字符串,形式为CO(Color-Only)标记位:color-value,例如:10:3。其中,CO标记位取值为二进制数00~11,color-value取值范围为0~4294967295。
rt route-target:RT(Route Target,路由目标)扩展团体属性,route-target为3~24个字符的字符串。
soo site-of-origin:SoO(Site of Origin,源站点)扩展团体属性,site-of-origin为3~24个字符的字符串。site-of-origin有五种形式:
·     16位自治系统号:32位用户自定义数,例如:101:3。其中,自治系统号取值范围为0~65535,用户自定义数取值范围为0~4294967295。
·     32位IP地址:16位用户自定义数,例如:192.168.122.15:1。其中,用户自定义数取值范围为0~65535。
·     32位自治系统号:16位用户自定义数,例如:70000:3。其中,自治系统号取值范围为65536~4294967295,用户自定义数取值范围为0~65535。
·     32位IP地址/IPv4地址掩码:16位用户自定义数。例如:192.168.122.15/24:1。
·     32位自治系统号的点分方式:16位用户自定义数。例如:65535.65535:1。
&<1-32>:表示前面的参数可以输入1~32次。
如果未指定任何参数,则显示所有BGP EVPN路由的简要信息。
不指定community-numberaa:nninternetno-advertiseno-exportno-export-subconfed参数时,显示携带任意团体属性的BGP路由信息,且此时指定的whole-match参数不生效。
不指定bandwidthcolorrtsoo参数时,显示携带任意扩展团体属性的BGP路由信息,且此时指定的whole-match参数不生效。
# 显示所有BGP EVPN路由的简要信息。
<Sysname> display bgp l2vpn evpn
 BGP local router ID is 1.1.1.9
               a – additional-path
 Total number of routes from all PEs: 6
 Route distinguisher: 100:1
 Total number of routes: 3
* >  [2][0][48][00aa.00bb.00cc][4][0.0.0.0]/136
                       10.1.1.2        0                   32768   ?
*  e                   10.1.1.1        0                   0       65410?
* >  [3][300][16][::ffff:1.1.1.1]/176
                       127.0.0.1       0                   32768   ?
 Route distinguisher: 200:1
 Total number of routes: 2
* >i [2][0][48][00aa.00cc.00dd][4][1.1.1.1]/136
                       3.3.3.9         0         100       0       ?
* >i [3][300][16][::ffff:2.2.2.2]/176
                       3.3.3.9         0         100       0       65420?
Route distinguisher of public instance: 1:15
Total number of routes: 1
* >e [2][0][48][0011.0022.0033][32][11.22.33.55]/136
                        30.30.1.2       0                     0       100i
# 显示所有具有团体属性的BGP EVPN路由信息。
<Sysname> display bgp l2vpn evpn community
               a – additional-path
     Network         NextHop         MED      LocPrf   PrefVal  Path/Ogn  Community
                     10.1.1.2        0                 32768   ?         <1:2>
*  e                 10.1.1.1        0                 0       65410?    <2:3>
                     127.0.0.1       0                 32768   ?         <3:4>
# 显示所有具有扩展团体属性的BGP EVPN路由信息。
<Sysname> display bgp l2vpn evpn ext-community
               a – additional-path
     Network         NextHop        MED      LocPrf   PrefVal  Path/Ogn  Ext-Community
                     10.1.1.2       0                 32768    ?        <RT 1:2>
*  e                 10.1.1.1       0                 0        65410?   <RT 2:3>
                     127.0.0.1      0                 32768    ?        <RT 3:4>
表1-1 display bgp l2vpn evpn命令简要显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     s - suppressed:聚合抑制路由
·     S - stale:过期路由
·     a - additional-path:Add-Path优选路由
Origin
路由信息的来源,取值包括:
·     i – IGP:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
·     ? - incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
来自所有PE设备且符合命令行过滤条件的BGP EVPN路由总数
Route distinguisher
路由标识符
公网实例的路由标识符
路由标识符为指定值的BGP EVPN路由总数
Network
BGP EVPN路由/路由长度,例如,Network取值为[2][0][48][1485-247c-0506][32][10.1.2.20]/136时,[2][0][48][1485-247c-0506][32][10.1.2.20]为BGP EVPN路由,136表示该路由的长度为136比特
BGP EVPN路由取值包括:
·     [1][ESI][EthernetTagID]:
¡     1:表示以太网自动发现路由(Ethernet auto-discovery route)
¡     ESI:以太网段标识
¡     EthernetTagID:以太网标签
·     [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress]
¡     2:表示MAC/IP发布路由(MAC/IP advertisement route)
¡     MACLength:MAC地址长度
¡     MAC:MAC地址
¡     IPAddressLength:IP地址长度
¡     IPAddress:IP地址
·     [3][EthernetTagID][IPAddressLength][IPAddress]
¡     3:表示包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)
¡     IPAddress:始发路由器的IP地址
·     [4][ESI][IPAddressLength][IPAddress]
¡     4:表示以太网段路由(Ethernet segment route)
¡     ESI:以太网段标识
·     [5][EthernetTagID][IPAddressLength][IPAddress]
¡     5:表示IP前缀路由(IP prefix advertisement route)
·     [6][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP]
¡     6:表示选择性组播以太网标签路由(Selective multicast Ethernet tag route)
¡     Source Len:组播源IP地址长度,(*,G)情况下设置为0
¡     Source IP:IGMP成员报告的源IP地址,(*,G)情况下该字段不存在
¡     Group Len:组播组IP地址长度
¡     Group IP:IGMP成员报告的组IP地址
¡     Originator Len:始发路由器IP地址长度
¡     Originator IP:始发路由器IP地址
·     [7][ESI][EthernetTagID][Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP]
¡     7:表示IGMP加入同步路由(IGMP join synch route)
¡     ESI:以太网标识段
·     [8][ESI][EthernetTagID] [Source Len][Source IP][Group Len][Group IP][Originator Len][Originator IP][ [LeaveGroup Synchronization]
¡     8:表示IGMP离开同步路由(IGMP leave synch route)
¡     ESI:以太网标识段
¡     LeaveGroup Synchronization:离开组播组的同步序列号值
NextHop
下一跳IP地址
MED
MED(Multi-Exit Discriminator,多出口区分)属性值
LocPrf
本地优先级
PrefVal
路由首选值
Path/Ogn
路由的AS路径(AS_PATH)属性和路由信息的来源(ORIGIN)属性
Community
团体属性
Ext-Community
扩展团体属性
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[1][00:01:02:03:04:05:06:07:08:09][5]/120的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [1][00:01:02:03:04:05:06:07:08:09][5] 120
 BGP local router ID: 172.16.250.133
 Local AS number: 100
 Route distinguisher: 1.1.1.1:100
 Paths:   1 available, 1 best
 BGP routing table information of [1][00:01:02:03:04:05:06:07:08:09][5]/120:
 Rely nexthop    : 10.1.1.2
 Original nexthop: 10.1.1.2
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN >, <ESI Label: Flag 0,
                   Label 1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet auto-discovery route
 ESI             : 00:01:02:03:04:05:06:07:08:09
 Ethernet tag ID : 5
 MPLS label      : 10
表1-2 display bgp l2vpn evpn命令中Ethernet auto-discovery route详细显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
路由数信息
·     available:有效路由数目
·     best:最佳路由数目
From
发布该路由的BGP对等体的IP地址
Rely nexthop
路由迭代后的下一跳IP地址,如果没有迭代出下一跳地址,则显示为“not resolved”
Original nexthop
路由的原始下一跳地址,如果是从BGP更新消息中获得的路由,则该地址为接收到的消息中的下一跳IP地址
OutLabel
路由的出标签值
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Encapsulation Type:封装类型
·     ESI Label:ESI标签
RxPathID
接收到的路由的Add-Path ID值
BGP EVPN地址族暂不支持本字段
TxPathID
发送的路由的Add-Path ID值
BGP EVPN地址族暂不支持本字段
AS-path
路由的AS路径(AS_PATH)属性,记录了此路由经过的所有AS,可以避免路由环路的出现
Origin
路由信息的来源,取值包括:
·     igp:表示路由产生于本AS内。通过network命令发布路由的路由信息来源为IGP
·     egp:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的。
·     incomplete:表示路由的来源无法确定。从IGP协议引入路由的路由信息来源为incomplete
Attribute value
BGP路由属性信息,包括:
·     MED:与目的网络关联的MED值
·     localpref:本地优先级
·     pref-val:路由首选值
·     pre:协议优先级
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
·     localredist:从本地其他VPN实例或公网实例引入到当前VPN实例的路由
·     reoriginated:重生成路由
IP precedence
路由的IP优先级,取值范围为0~7,N/A表示无效值
QoS local ID
路由的Qos-Local-ID属性,取值范围为1~4095,N/A表示无效值
Traffic index
流量索引值,取值范围为1~64,N/A表示无效值
EVPN route type
BGP EVPN路由类型,取值为Ethernet auto-discovery route,表示以太网自动发现路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
MPLS label
MPLS标签,目前此字段无意义
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[2][5][48][0001-0203-0405][32][4.5.5.5]/136的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
 BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
                   >, <Encapsulation Type: VXLAN>, <Router's Mac: 0006-0708-0910
                   >, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>, <MicroSegment-id:
                   Type 0x83fe, ID 1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : MAC/IP advertisement route
 Ethernet tag ID : 5
 MAC address     : 0001-0203-0405
 IP address      : 5.5.5.5/32
 MPLS label1     : 10
 MPLS label2     : 0
 Re-origination  : Enable
 Route distinguisher: 2.2.2.2:100
 OutLabel        : 0
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 State           : valid, external, best, reoriginated, remoteredist
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 ESI             : 0001.0203.0405.0607.0809
 Ethernet tag ID : 5
 MPLS label1     : 200
 MPLS label2     : 300
表1-3 display bgp l2vpn evpn命令中MAC/IP advertisement route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Router's Mac:路由器MAC
·     MAC Mobility:MAC迁移属性。Flags表示是否为固定MAC地址,1为固定不可移动MAC,0为可以移动MAC;SeqNum用来标识最新的一次迁移
·     Default GateWay:默认网关路由
路由当前状态,取值包括:
·     valid:有效路由
·     internal:内部路由
·     external:外部路由
·     local:本地产生路由
·     synchronize:同步路由
·     best:最佳路由
·     remoteredist:远端路由生成的MAC/IP发布路由
EVPN route type
BGP EVPN路由类型,取值为MAC/IP advertisement route,表示MAC/IP发布路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
MAC address
MAC地址
IP address
IP地址
MPLS label1
用于二层转发的VXLAN ID
MPLS label2
用于三层转发的VXLAN ID,即L3VNI
Re-origination
是否开启了修改路由信息的功能,取值包括:
·     Enable:开启修改路由信息功能
·     Disable:关闭修改路由信息功能
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[3][0][32][5.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
 BGP routing table information of [3][0][32][4.5.5.5]/80:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 Attribute value : MED 0,pref-val 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Inclusive multicast Ethernet tag route
 Ethernet tag ID : 0
 Origin address  : 5.5.5.5/32
表1-4 display bgp l2vpn evpn命令中Inclusive multicast Ethernet tag route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
EVPN route type
BGP EVPN路由类型,取值为Inclusive multicast Ethernet tag route,表示包含性组播以太网标签路由
Ethernet tag ID
以太网标签
Origin address
始发路由器地址
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的详细信息。
<Sysname>  display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128
 BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a][32] [4.5.5
.5]/128:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, <ES-Import RT: 1:1>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Ethernet segment route
 ESI             : 00:00:00:00:00:00:00:00:00:0a
 Origin address  : 4.5.5.5/32
表1-5 display bgp l2vpn evpn命令中Ethernet segment route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     ES-Import RT:ES-Import Route Target属性
EVPN route type
BGP EVPN路由类型,取值为Ethernet segment route,表示以太网段路由
ESI
以太网段标识
Origin address
始发路由器地址
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[5][10][32][4.5.5.5]/80的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
 BGP routing table information of [5][10][32][4.5.5.5]/80:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
                   0006-0708-0910>, <Priority-Color: (1:10:10)>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IP prefix advertisement route
 Ethernet tag ID : 10
 IP address      : 4.5.5.5/32
 Gateway address : 0.0.0.0
 MPLS Label      : 1
表1-6 display bgp l2vpn evpn命令中IP prefix advertisement route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     Priority-Color:Priority-Color扩展团体属性
EVPN route type
BGP EVPN路由类型,取值为IP prefix advertisement route,表示IP前缀路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
IP address
IP网络前缀
Gateway address
网关地址
MPLS Label
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1] 160
 BGP routing table information of [6][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/160:
 OutLabel        : NULL
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Selective multicast Ethernet tag route
 Ethernet tag ID : 0
 Source length   : 32
 Source address  : 10.1.1.1
 Group length    : 32
 Group address   : 224.224.224.224
 Origin address  : 192.168.3.1
 IGMP flags      : v3, include
表1-7 display bgp l2vpn evpn命令中Selective multicast Ethernet tag route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
EVPN route type
BGP EVPN路由类型,取值为Selective multicast Ethernet tag route,表示SMET路由
Ethernet tag ID
以太网标签
Source length
组播源地址长度
Source address
组播源地址
Group length
组播组地址长度
Group address
组播组地址
Origin address
始发路由器地址
IGMP flags
IGMP标记位信息
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][16][224.224.224.224][32][192.168.3.1] 240
 BGP routing table information of [7][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1]/240:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 0:0>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IGMP join synch route
 ESI             : 0000.0000.0000.0000.0000
 Ethernet tag ID : 0
 Source length   : 32
 Group length    : 32
表1-8 display bgp l2vpn evpn命令中IGMP join synch route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     EVI-RT:与EVI关联的Route Target属性
EVPN route type
BGP EVPN路由类型,取值为IGMP join synch route,表示IGMP-JS路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
Source length
组播源地址长度
Source address
组播源地址
Group length
组播组地址长度
Group address
组播组地址
Origin address
始发路由器地址
IGMP flags
IGMP 标记位信息
# 显示路由标识符为1.1.1.1:100的BGP EVPN路由[8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272的详细信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [8][0000.0000.0000.0000.0000][0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0] 272
 BGP routing table information of [8][0000.0000.0000.0000.0000]  [0][32][10.1.1.1][32][224.224.224.224][32][192.168.3.1][0]/272:
 OutLabel        : NULL
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, < ESI-RT: 1:200>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IGMP leave synch route
 Ethernet tag ID : 0
 Source length   : 32
 Group length    : 32
 Leave group sync: 0
 Max ResponseTime: 2500ms
 Max ResponseCode: 25
表1-9 display bgp l2vpn evpn命令中IGMP leave synch route详细显示信息描述表
Ext-Community
扩展团体属性值,包括:
·     RT:Route Target属性
·     ESI-RT:与ESI关联的Route Target属性
EVPN route type
BGP EVPN路由类型,取值为IGMP leave synch route,表示IGMP-LS路由
ESI
以太网段标识
Ethernet tag ID
以太网标签
Source length
组播源地址长度
Source address
组播源地址
Group length
组播组地址长度
Group address
组播组地址
Origin address
始发路由器地址
Leave group sync
离开组播组的同步序列号值
Max ResponseTime
最大响应时间,单位为毫秒
Max ResponseCode
接收到的报文中携带的最大响应值,单位为十分之一秒
IGMP flags
IGMP标记位信息
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的通告信息。
<Sysname> display bgp l2vpn  evpn  route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a] [32][4.5.5.5] 128 advertise-info
 Paths:   1 best
 BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128:
    10.2.1.2
 Inlabel         : 1279
表1-10 display bgp l2vpn evpn advertise-info命令显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
到达指定目的网络的优选路由数目
BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a] [32] [4.5.5.5]/128
BGP EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的通告信息
该路由已经向哪些BGP EVPN对等体发送,以及对等体的数目
Inlabel
入标签值,即本地PE为EVPN路由分配的私网标签
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的团体属性信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 community
 BGP local router ID: 1.1.1.9
 Community: no-export
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的扩展团体属性信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 ext-community
 Ext-Community: <RT 1:1>
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的AS_PATH属性信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 as-path
 As-path: 80
# 显示路由标识符为1.1.1.1:100的EVPN路由[4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128的集群ID列表属性信息。
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5] 128 cluster-list
 Cluster list: 80
表1-11 display bgp l2vpn evpn命令路由属性显示信息描述表
BGP local router ID
本地的路由器ID
Local AS number
本地的AS号
Route distinguisher
路由标识符
Paths
路由数信息:
·     available:有效路由数目
·     best:最佳路由数目
指定BGP EVPN路由的属性信息
Community
路由的团体属性
Ext-Community
路由的扩展团体属性
As-path
路由的AS_PATH属性
Cluster-list
路由的集群ID列表属性
# 显示具有团体属性的BGP EVPN路由统计信息。
<Sysname> display bgp l2vpn evpn statistics community
 Total number of routes from all PEs: 1
 Route distinguisher: 100:1(vpn1)
 Total number of routes: 4
表1-12 display bgp l2vpn evpn statistics命令显示信息描述表
来自所有PE设备且符合命令行过滤条件的EVPN路由总数
Route distinguisher
路由标识符
路由标识符为指定值的EVPN路由总数
display bgp l2vpn evpn inlabel命令用来显示BGP EVPN的IP前缀路由的入标签信息。
display bgp [ instance instance-name ] l2vpn evpn inlabel
可通过本命令显示本地PE为EVPN的IP前缀路由分配的私网标签。
# 显示BGP EVPN IP前缀路由的入标签信息。
<Sysname> display bgp l2vpn evpn inlabel
               a - additional-path
       Origin: i - IGP, e - EGP, ? – incomplete
 Route distinguisher: 100:2
     Network            NextHop         OutLabel        InLabel
* >e [5][0][24][192.168.1.0]/80
                        192.168.1.10    NULL            1151
表1-13 display bgp l2vpn evpn inlabel命令显示信息描述表
BGP local router ID
BGP本地路由器ID
Status codes
路由状态代码:
·     * - valid:合法路由
·     > - best:普通优选路由
·     d - damped:震荡抑制路由
·     h - history:历史路由
·     i - internal:内部路由
·     e - external:外部路由
·     S - Stale:过期路由
Origin
路由信息的来源,取值包括:
·     e – EGP:表示路由是通过EGP(Exterior Gateway Protocol,外部网关协议)学到的
Route distinguisher
路由标识符
公网实例的路由标识符
Network
BGP EVPN路由/路由长度,BGP EVPN路由取值为[5][EthernetTagID][IPAddressLength][IPAddress]
·     5:表示IP前缀路由(IP prefix advertisement route)
·     EthernetTagID:以太网标签
·     IPAddressLength:IP地址长度
·     IPAddress:始发路由器的IP地址
NextHop
下一跳IP地址
OutLabel
出标签值,即对端PE为EVPN路由分配的私网标签,取值为NULL表示空标签
InLabel
·     evpn mpls routing-enable
·     peer advertise encap-type mpls
display evpn auto-discovery命令用来显示EVPN通过BGP自动发现的邻居信息。
display evpn auto-discovery { { imet [ vxlan ] | mac-ip [ vxlan ] } [ peer peer-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet:显示通过包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)发现的邻居信息。
mac-ip:显示通过MAC/IP发布路由发现的邻居。
peer peer-address:显示指定邻居的自动发现相关信息。peer-address为邻居的IPv4地址或IPv6地址。如果未指定本参数,则显示自动发现的所有邻居的信息。
vsi vsi-name:显示指定VSI内自动发现的邻居信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI内自动发现的邻居信息。
macip-prefix:显示通过MAC/IP发布路由和IP前缀路由发现的邻居信息。
nexthop next-hop:显示从指定路由下一跳学习到的邻居信息。next-hop next-hop为路由下一跳的IPv4地址或IPv6地址。如果未指定本参数,则显示从所有路由下一跳学习到的邻居信息。
count:显示自动发现的邻居数目。如果未指定本参数,则显示邻居的具体信息。
如果执行本命令时,没有指定mplsvxlansrv6参数,则同时显示所有类型组网中EVPN通过BGP自动发现的邻居信息。
# EVPN VXLAN组网下显示通过包含性组播以太网标签路由发现的邻居信息。
<Sysname> display evpn auto-discovery imet vxlan
Total number of automatically discovered peers: 2
VSI name: vpna
EVPN instance: -
RD                    PE_address      Tunnel_address  Tunnel mode VXLAN ID
1:10                  2.2.2.2         2.2.2.2         VXLAN       10
2:100                 3.3.3.3         3.3.3.3         VXLAN       10
表1-14 display evpn auto-discovery imet命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
EVPN instance
EVPN实例名称。显示为“-”时,表示VSI实例下创建的EVPN实例
RD
路由标识符
PE_address
远端VTEP在VSI内的标识
Tunnel_address
隧道的目的端地址
Tunnel mode
隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     VXLAN-DCI:表示VXLAN数据中心互联隧道
·     PW:表示PW
·     SRv6:表示SRv6隧道
In/Out label
PW的入标签和出标签,当标签无效时显示为“-”
VXLAN ID
VXLAN编号
In SID
入SID
Out SID
出SID
# EVPN VXLAN组网下显示通过MAC/IP发布路由发现的IPv4邻居信息。
<Sysname> display evpn auto-discovery mac-ip vxlan
Total number of automatically discovered peers: 1
VSI name: vpna
EVPN instance: -
Destination IP  Source IP       VXLAN ID    Tunnel mode     Tunnel name
6.6.6.6         1.1.1.9         100         VXLAN           Tunnel1
表1-15 display evpn auto-discovery mac-ip命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
EVPN instance
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
VXLAN ID
VXLAN编号
Tunnel mode
VXLAN隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     PW:表示PW
·     SRv6:表示SRv6隧道
Tunnel name
隧道名称
In/Out label
In SID
入SID
Out SID
出SID
# 显示通过MAC/IP发布路由和IP前缀路由发现的邻居信息。
<Sysname> display evpn auto-discovery macip-prefix
Destination IP  Source IP       L3VNI           Tunnel mode Outgoing interface
1.1.1.1         3.3.3.3         200             VXLAN       Vsi-interface3
2.2.2.2         3.3.3.3         200             VXLAN       Vsi-interface3
# 显示通过MAC/IP发布路由和IP前缀路由发现的邻居总数。
<Sysname> display evpn auto-discovery macip-prefix count
Total number of entries: 2
表1-16 display evpn auto-discovery macip-prefix命令显示信息描述表
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
L3VNI
用于三层转发的VXLAN ID
Tunnel mode
隧道的模式,取值包括
·     VXLAN:表示VXLAN隧道
Outgoing interface
出接口,即与L3VNI关联的VSI虚接口
邻接表项的总数
display evpn df-election命令用来显示DF选举的信息。
display evpn df-election [ vsi vsi-name | xconnect-group group-name ] [ esi esi-id ]
vsi vsi-name:显示指定VSI的DF选举信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name:显示指定交叉连接组的DF选举信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。
esi esi-id:显示指定ESI的DF选举信息。esi-id表示以太网链路网段标识符的值,格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。如果未指定本参数,则显示所有ESI的DF选举信息。
执行本命令时,如果未指定vsi vsi-namexconnect-group group-name参数,则显示所有VSI和交叉连接组的DF选举信息。
# 显示所有VSI和交叉连接组的DF选举信息。
<Sysname> display evpn df-election
Status codes : * - invalid
VSI name: 1
  ESI : 0021.1001.1001.1001.1002
  Interface : GigabitEthernet2/0/1
  Service instance ID : 1000
  Link ID             : 1
  Ethernet tag ID     : 12
  DF state            : Primary
  FSM                 : DF_DONE
  Number of member devices : 2
    Originating IP   DF state   Algorithm   Preference Capability
    100.100.100.100  Primary    Preference  65535      DP
    100.100.100.200  Backup     Preference  200        DP
  ESI : 0002.0002.0002.0002.0002
  Interface : GigabitEthernet2/0/2
  Link ID             : 0
  Ethernet tag ID     : 0
  DF state            : -
  FSM                 : DF_CALC
    1.1.1.1          -          Preference  32767      -
    2.2.2.2          -          Preference  32767      -
Xconnect-group name : 1
 Connection name : 1
  ESI : 0001.0001.0001.0001.0001
  Interface : GigabitEthernet2/0/3
  Link ID             : 1
  Ethernet tag ID     : 0
  DF state            : -
  FSM                 : DF_CALC
  Number of member devices : 1
表1-17 display evpn df-election命令显示信息描述表
Status codes
DF选举候选列表中的设备状态,如果DF状态取值中带有符号“*”,则表示该设备不能参与DF选举
VSI name
VSI名称
ESI
ES标识符
接口名称
Service instance ID
以太网服务实例的ID
Link ID
AC在VSI内的链路标识符
Ethernet tag ID
以太网标签
DF state
当前设备的DF(Designated Forwarder)选举结果,取值包括:
·     Backup:选举设备作为BDF(Backup DF)角色
·     Primary:选举设备作为DF角色
·     -:未选举出结果
FSM
DF选举状态机的状态,取值包括:
·     INIT:初始化状态
·     DF_WAIT:DF选举等待状态,即在启动DF选举定时器后,定时器超时前的状态
·     DF_CALC:正在进行DF选举
·     DF_DONE:DF选举完成状态
参与DF选举的成员设备的数目
Originating IP
参与DF选举的成员设备的IP地址
DF state
Originating IP所代表的设备的DF选举结果,取值包括:
·     -:未选举出结果
Algorithm
DF选举使用的算法,取值包括:
·     modulus:基于VALN Tag的DF选举算法
·     Preference:基于优先级的DF选举算法
Preference
DF选举优先级
Capability
支持的DF选举能力,取值包括:
·     AC-DF:表示AC状态影响DF选举
·     DP:表示DF选举不回切能力
·     -:表示不支持任何DF选举能力
display evpn es命令用来显示EVPN的ES信息。
display evpn es { local [ count | [ vsi vsi-name ] [ esi esi-id ] [ verbose ] ] | remote [ vsi vsi-name ] [ esi esi-id ] [ nexthop next-hop ] [ verbose ] }
local:显示本地多归属成员ES信息。
count:显示本地多归属成员ES的数目。
vsi vsi-name:显示指定VSI的ES信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ES信息。
esi esi-id:显示指定ESI的ES信息。esi-id表示以太网链路网段标识符的值,格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。如果未指定本参数,则显示VSI的所有ES信息。
verbose:显示ES的详细信息。如果不指定本参数,则显示ES的简要信息。
remote:显示远端多归属成员ES信息。
nexthop next-hop:显示从指定路由下一跳接收到的ES信息。next-hop为路由下一跳的IPv4地址或IPv6地址。如果不指定本参数,则显示从所有路由下一跳收到的ES信息。
# 显示本地ES的数目。
<Sysname> display evpn es local count
 Total number of ES entries: 1
表1-18 display evpn es local命令显示信息描述表
VSI name
VSI名称
EVPN instance
ESI
ES标识符
Tag ID
以太网标签ID
DF address
被选为DF的VTEP或PE的Router ID
Mode
ES的冗余备份模式,取值包括:
·     A:表示ES的冗余备份模式为all-active模式
·     S:表示ES的冗余备份模式为single-active模式
当前ES的状态,取值包括Up和Down
ESI label
ESI标签
# 显示所有VSI内本地ES的详细信息。
<Sysname> display evpn es local verbose
VSI name : v1
EVPN instance: -
  VSI ESI                  : 0001.0001.0001.0001.0003
  Redundancy mode          : All-active
  ES state                 : Up
  AD-delay remaining time  : 10
  ESI                      : 0003.0003.0003.0003.0003
  State                    : Up
  ACs                      :
    Link ID     Service instance ID   Tag ID      DF address        ESI label
    0           1                     1           1.1.1.1           1001
    1           3                     3           3.3.3.3           1002
    2           10                    10          2.2.2.2           1003
VSI name : vpna
EVPN instance: -
  ESI                      : 0001.0002.0002.0002.0002
  State                    : Up
  ACs                      :
    1           -                     0           1.1.1.1           -
VSI name : vpnb
EVPN instance: -
  Interface                : GE2/0/3
  State                    : Down
  ACs                      :
    Link ID                : 0
    Service instance ID    : -
    Tag ID                 : 0
    DF address             : 1.1.1.1
    Argument               : ::1
表1-19 display evpn es local verbose命令显示信息描述表
VSI name
VSI名称
EVPN instance
VSI ESI
VSI实例的ES标识符
ESI
ES标识符
接口名称
AC
与交叉连接关联的接入电路,取值为:
·     三层接口名称:表示交叉连接关联三层接口
·     二层接口名称和以太网服务实例:表示交叉连接关联以太网服务实例
Redundancy mode
ES的冗余备份模式,取值包括:
ES state
当前VSI对应ES的状态,取值包括Up、Down和“-”。其中,“-”表示未手动配置ESI
当前接口对应ES的状态,取值包括Up、Down和“-”。其中,“-”表示未手动配置ESI
以太网自动发现路由延迟发布定时器的剩余时间,单位为秒
ACs
VSI在当前ES下的AC列表
Link ID
AC在VSI内的链路ID
Service instance ID
以太网服务实例ID
Tag ID
以太网标签ID
DF address
被选为DF的VTEP或PE的Router ID,取值为“-”表示当前设备未被选举为该AC的DF
ESI label
ESI标签;在EVPN VXLAN组网中ESI label无效,显示为“-”
Argument
标识Leaf AC的Argument值
# 显示远端ES的简要信息。
<Sysname> display evpn es remote
Control Flags: P - Primary, B - Backup, C - Control word
VSI name : vpna
EVPN instance: -
  ESI                     : 0001.0000.0000.0000.0001
  Ethernet segment routes :
    1.1.1.1
    3.3.3.3
  A-D per ES routes       :
    Peer IP             Remote Redundancy mode
    1.1.1.1             All-active
    3.3.3.3             All-active
  A-D per EVI routes      :
    Tag ID      Peer IP
    -           1.1.1.1
    -           3.3.3.3
  ESI                     : 0001.0002.0003.0004.0005
    1.1.1.1
  A-D per ES routes       :
    1.1.1.1             All-active
    Tag ID      Peer IP
    -           1.1.1.1
Xconnect group name : a
    123.123.123.123
    3.3.3.3
  A-D per ES routes       :
    123.123.123.123     All-active
    3.3.3.3             All-active
    Tag ID      Peer IP          Control Flags
    2           3.3.3.3          P
    4           123.123.123.123  PC
# 显示远端ES的详细信息。
VSI name : vpna
EVPN instance: -
  A-D per ES routes       :
    Peer IP               : 2::2
    Remote Redundancy mode: All-active
    Argument              : ::1
    Tag ID                : 1
    Peer IP               : 2::2
Xconnect group name : vpna
    2::2
  A-D per ES routes       :
    Peer IP               : 2::2
    Tag ID                : 1
    Control Flags         : P
    Peer IP               : 2::2
# 显示VSI实例vpna内,从下一跳3.3.3.3接收到的远端ES的信息。
<Sysname> display evpn es remote vsi vpna nexthop 3.3.3.3
VSI name : vpna
EVPN instance: -
    3.3.3.3
  A-D per ES routes       :
    3.3.3.3
    Tag ID      Peer IP
    -           3.3.3.3
表1-20 display evpn es remote命令显示信息描述表
VSI name
VSI名称
EVPN instance
ESI
ES标识符
Redundancy mode
ES的冗余备份模式,取值包括:
·     All-active:表示ES的冗余备份模式为多活模式
·     Single-active:表示ES的冗余备份模式为单活模式
Argument
标识Leaf AC的Argument值
与该ES关联的以太网段路由
A-D per Ethernet segment routes
与该ES关联的A-D per ES路由
A-D per EVI routes
与该ES关联的A-D per EVI路由
Tag ID
以太网标签ID
Peer IP
远端设备的IP地址
远端ES的冗余备份模式,取值包括:
Control Flags
远端路由二层属性控制标识,取值包括:
·     P:接收到的路由携带了Primary标识
·     B:接收到的路由携带了Backup标识
·     C:接收到的路由携带了Control word标识
display evpn instance命令用来显示EVPN实例的相关信息。
display evpn instance [ name instance-name | vsi vsi-name | xconnect-group group-name ]
name instance-name:显示指定EVPN实例的信息。instance-name表示EVPN实例名称,为1~31个字符的字符串,区分大小写。
vsi vsi-name:显示指定VSI对应EVPN实例的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
xconnect-group group-name:显示指定交叉连接组对应EVPN实例的信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。
执行本命令时,如果没有指定name instance-namevsi vsi-namexconnect-group group-name参数,则显示所有EVPN实例的信息。
# 显示所有EVPN实例的信息。
<Sysname> display evpn instance
Total number of EVPN instances: 3
EVPN instance : abc
  Route distinguisher    : -
  Export VPN targets     : -
  Import VPN targets     : -
  MAC advertisement      : Enabled
  ARP advertisement      : Enabled
  ND advertising         : Disabled
  ARP-based MAC learning : Enabled
  ND-based MAC learning  : Enabled
  Local fast-reroute     : Inherit
  Tunnel policy          : -
  PW class               : -
  Dt2uLocatorName        : -
  Dt2ulLocatorName       : -
  Dt2mLocatorName        : -
  E-Tree                 : Disabled
  Best-Effort            : Disabled
  Traffic-Engineering    : Disabled
  Import routing policy  : -
  Export routing policy  : -
  VSI binding list:
    VSI name                                Tag ID
    vpna                                    3
    vpnb                                    5
EVPN instance : - (created on vsi abc)
  Encapsulation          : VXLAN
  VXLAN ID               : -
EVPN instance : - (created on vsi aaa)
  Encapsulation          : MPLS
  MPLS label             : -
  IMET MPLS label        : -
  Tunnel policy          : -
  PW class               : -
  Control Word           : Disabled
  E-Tree                 : Disabled
  PW type                : VLAN
  Sequencing             : -
  Flow label             : -
  Default color          : -
EVPN instance : - (created on Xconnect-group xcga)
  Import Route Policy    : -
  Export Route Policy    : -
表1-21 display evpn instance命令显示信息描述表
EVPN实例总数
EVPN instances
EVPN实例名称,显示方式如下:
·     instance-name:表示系统视图下创建的EVPN实例
·     - (created on VSI vsi-name):表示VSI实例vsi-name下创建的EVPN实例
·     -(created on Xconnect-group xconnect-group-name):表示交叉连接组xconnect-group-name下创建的EVPN实例
Encapsulation
EVPN的封装类型,取值包括:
·     VXLAN:表示EVPN的封装类型为VXLAN
·     MPLS:表示EVPN的封装类型为MPLS
·     SRv6:表示EVPN的封装类型为SRv6
Route distinguisher
EVPN实例的RD
Export VPN targets
EVPN实例的Export Target
Import VPN targets
EVPN实例的Import Target
MAC advertisement
是否允许通告MAC地址信息,取值包括:
·     Enabled:允许通告MAC地址信息
·     Disabled:禁止通告MAC地址信息
ARP advertisement
是否允许通告ARP信息,取值包括:
·     Enabled:允许通告ARP信息
·     Disabled:禁止通告ARP信息
ND advertising
是否允许通告ND信息,取值包括:
·     Enabled:允许通告ND信息
·     Disabled:禁止通告ND信息
是否允许EVPN从ARP信息中学习MAC地址表项,取值包括:
·     Enabled:允许EVPN从ARP信息中学习MAC地址表项
·     Disabled:禁止EVPN从ARP信息中学习MAC地址表项
是允许EVPN从ND信息中学习MAC地址表项功能,取值包括:
·     Enabled:允许EVPN从ND信息中学习MAC地址表项
·     Disabled:禁止EVPN从ND信息中学习MAC地址表项
MPLS label
MPLS标签
IMET MPLS label
IMET路由携带的MPLS标签
Local fast-reroute
EVPN实例FRR功能的状态,取值包括:
·     Enabled:在EVPN实例视图下开启EVPN实例的FRR功能
·     Disabled:在EVPN实例视图下关闭EVPN实例的FRR功能
·     Inherit:在EVPN实例视图下未配置EVPN实例FRR功能,继承系统视图下的配置
Tunnel policy
EVPN实例引用的隧道策略
PW class
EVPN实例引用的PW模板
Control word
是否开启控制字功能,取值包括:
·     Enabled:PW开启控制字功能
·     Disabled:PW关闭控制字功能
E-Tree
是否开启EVPN E-Tree功能,取值包括:
·     Enabled:开启EVPN E-Tree功能
·     Disabled:关闭EVPN E-Tree功能
PW type
PW类型,取值包括:
·     Ethernet:以太网类型
·     VLAN:VLAN类型
Sequencing
PW的排序处理,取值包括:
·     Both:表示对PW收发两个方向的报文均进行排序处理
·     -:表示未配置PW的排序处理,即不对PW上传输的报文进行排序
VXLAN ID
VXLAN编号
Flow label
流标签能力,取值包括:
·     Both:具有发送和接收能力
·     Send:具有发送能力
·     Recv:具有接收能力
·     -:未开启流标签能力
Dt2uLocatorName
用于申请DT2U SID的Locator段名称
若禁止动态分配SID,则显示auto-sid-disable;否则,不显示
Dt2ulLocatorName
用于申请DT2UL SID的Locator段名称
Dt2mLocatorName
用于申请DT2M SID的Locator段名称
Best-Effort
是否根据SRv6 SID进行SR-BE路由迭代,取值包括:
·     Enabled:根据SRv6 SID进行SR-BE路由迭代
·     Disabled:不会根据SRv6 SID进行SR-BE路由迭代
Traffic-Engineering
是否根据下一跳地址进行SR-TE路由迭代,取值包括:
·     Enabled:根据下一跳地址进行SR-TE路由迭代
·     Disabled:不会根据下一跳地址进行SR-TE路由迭代
EVPN实例引用的入方向路由策略,如果未引用入方向路由策略,则显示为“-”。只有报文封装类型为MPLS或SRv6时才显示本字段
EVPN实例引用的出方向路由策略,如果未引用出方向路由策略,则显示为“-”。只有报文封装类型为MPLS或SRv6时才显示本字段
VSI binding list
绑定EVPN实例的VSI列表
VSI name
VSI名称
Tag ID
VSI的Tag ID
·     evpn encapsulation
·     vsi
display evpn ipv6 auto-discovery命令用来显示EVPN通过BGP自动发现的IPv6邻居信息。
display evpn ipv6 auto-discovery { { imet | mac-ip } [ vxlan ] [ peer ipv6-address ] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet:显示通过包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)发现的IPv6邻居信息。
mac-ip:显示通过MAC/IP发布路由(MAC/IP Advertisement route)发现的IPv6邻居信息。
peer ipv6-address:显示指定IPv6邻居的自动发现相关信息。ipv6-address为邻居的IPv6地址。如果未指定本参数,则显示所有IPv6邻居的自动发现相关信息。
vsi vsi-name:显示指定VSI内自动发现的IPv6邻居信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI内自动发现的IPv6邻居信息。
macip-prefix:显示通过携带L3VNI的MAC/IP发布路由或IP前缀路由发现的IPv6邻居信息。
nexthop next-hop:显示从指定路由下一跳学习到的邻居信息。如果未指定本参数,则显示从所有路由下一跳学习到的IPv6邻居信息。
count:显示自动发现的IPv6邻居数目。如果未指定本参数,则显示IPv6邻居的具体信息。
# EVPN VXLAN组网中显示通过包含性组播以太网标签路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery imet
VSI name: vpna
EVPN instance  : -
RD             : 1:10
PE address     : 11::8
Tunnel address : 11::8
Tunnel mode    : VXLAN
VXLAN ID       : 10
RD             : 2:100
PE address     : 12::8
Tunnel address : 12::8
Tunnel mode    : VXLAN
VXLAN ID       : 10
表1-22 display evpn ipv6 auto-discovery imet命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
EVPN instance
EVPN实例名称,如果未创建则显示“-”
RD
路由标识符
PE address
远端VTEP在VSI内的标识
Tunnel address
隧道的目的端地址
Tunnel mode
隧道的模式,取值包括:
·     VXLAN:表示VXLAN隧道
·     SRv6:表示SRv6隧道
VXLAN ID
VXLAN编号
In SID
SRv6隧道的入SID
Out SID
SRv6隧道的出SID
# EVPN VXLAN组网中显示通过MAC/IP发布路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery mac-ip
VSI name: vpna
Destination IP : 6:6::6:8
Source IP      : 1:1::1:7
VXLAN ID       : 100
Tunnel mode    : VXLAN
Tunnel name    : Tunnel1
表1-23 display evpn ipv6 auto-discovery mac-ip命令显示信息描述表
自动发现的邻居数目
VSI name
VSI名称
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
VXLAN ID
VXLAN编号
Tunnel mode
隧道模式,取值包括:
·     VXLAN,表示VXLAN隧道
·     SRv6:表示SRv6隧道
Tunnel name
隧道名称
In SID
SRv6隧道的入SID
Out SID
SRv6隧道的出SID
# 显示通过MAC/IP发布路由和IP前缀路由发现的IPv6邻居信息。
<Sysname> display evpn ipv6 auto-discovery macip-prefix
L3VNI              : 100
Tunnel mode        : VXLAN
OutInterface       : Vsi-interface3
# 显示通过MAC/IP发布路由和IP前缀路由发现的IPv6邻居总数。
<Sysname> display evpn ipv6 auto-discovery macip-prefix count
Total number of entries: 1
表1-24 display evpn ipv6 auto-discovery macip-prefix命令显示信息描述表
Destination IP
隧道的目的端地址
Source IP
隧道的源端地址
L3VNI
用于三层转发的VXLAN ID
Tunnel mode
隧道的模式,取值包括
·     VXLAN:表示VXLAN隧道
OutInterface
邻接表项的总数
display evpn route arp命令用来显示EVPN的ARP信息。
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ip ipv4-address ] [ count ]
local:显示本地ARP信息。
remote:显示远端ARP信息。
public-instance:显示公网实例的ARP信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ARP信息。vpn-instance-name表示 MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ip ipv4-address:显示指定IPv4地址的ARP信息。ipv4-address表示IPv4地址,为点分十进制格式。如果不指定本参数,则显示公网或VPN实例的所有ARP信息。
count:显示ARP表项的数目。如果不指定本参数,则显示ARP表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端ARP信息。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则显示公网实例和所有VPN实例的ARP信息。
# 显示所有EVPN的ARP信息。
<Sysname> display evpn route arp
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping        I - Invalid
       E - Multihoming ES sync    F - Leaf
VPN instance: vpn1                            Interface: Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
10.1.1.1        0003-0003-0003  a0ce-7e40-0400  0           GL
10.1.1.11       0001-0001-0001  a0ce-7e40-0400  0           DL
10.1.1.12       0001-0001-0011  a0ce-7e41-0401  0           B
10.1.1.13       0001-0001-0021  a0ce-7e42-0402  0           B
Public instance                               Interface: Vsi-interface2
11.1.1.1        0033-0033-0033  a0ce-7e40-0400  0           GL
11.1.1.11       0011-0011-0011  a0ce-7e40-0400  0           DL
# 显示EVPN的ARP表项总数。
<Sysname> display evpn route arp count
Total number of entries: 6
表1-25 display evpn route arp命令显示信息描述表
VPN instance name
VPN实例名称
Public instance
公网实例
VSI虚接口
IP address
IP地址
MAC address
MAC地址
Router MAC
设备的Router MAC
在SRv6分布式网关组网中,本字段显示为“-”
VSI index
VSI索引
Flags
ARP表项类型,取值包括:
·     D:表示存在动态学习的ARP表项
·     B:表示存在通过BGP EVPN路由学习的ARP表项
·     L:表示本地ARP表项生效,未设置该标志表示通过BGP EVPN路由学习的ARP表项生效
·     G:表示生效的ARP表项是网关的ARP表项
·     S:表示生效的ARP表项是静态配置的ARP表项
·     M:表示生效的ARP表项是来自映射的远端VXLAN的ARP表项
·     I:表示该ARP表项无效,原因如下:
¡     通过shutdown命令手工关闭VSI
¡     出方向Tunnel接口不存在
·     E:表示多归属成员同步的ARP表项
·     F:表示EVPN E-tree组网中从Leaf上学习到的ARP表项
ARP表项的总数
display evpn route arp suppression命令用来显示EVPN的ARP泛洪抑制信息。
display evpn route arp suppression [ vxlan ] [ local | remote ] [ vsi vsi-name ] [ ip ipv4-address ] [ count ]
vxlan:显示EVPN VXLAN组网中的ARP泛洪抑制信息。
local:显示本地ARP泛洪抑制信息。
remote:显示远端ARP泛洪抑制信息。
vsi vsi-name:显示指定VSI的ARP泛洪抑制信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ARP泛洪抑制信息。
ip ipv4-address:显示指定IP地址的ARP泛洪抑制信息。ipv4-address表示IPv4地址,为点分十进制格式。如果不指定本参数,则显示所有ARP泛洪抑制信息。
count:显示ARP泛洪抑制表项的数目。如果不指定本参数,则显示ARP泛洪抑制表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端的ARP泛洪抑制信息;如果没有指定mplssrv6vxlan参数,则显示所有组网环境下的ARP泛洪抑制信息。
# 显示所有EVPN的ARP泛洪抑制信息。
<Sysname> display evpn route arp suppression
VSI name: vpna
EVPN instance: -
IP address      MAC address       Flags           Encap
10.1.1.12       0002-0002-0002    B               VXLAN
10.1.1.13       0002-0002-0002    BI              VXLAN
10.1.1.101      0001-0011-0101    BS              VXLAN
10.1.1.102      0001-0011-0102    DL              VXLAN
# 显示EVPN的ARP泛洪抑制表项总数。
<Sysname> display evpn route arp suppression count
表1-26 display evpn route arp suppression命令显示信息描述表
VSI name
VSI名称
EVPN instance
IP address
IP地址
MAC address
MAC地址
Flags
ARP泛洪抑制表项类型,取值包括:
·     D:表示存在动态学习的ARP泛洪抑制表项
·     B:表示存在通过BGP EVPN路由学习的ARP泛洪抑制表项
·     L:表示本地ARP泛洪抑制表项生效,未设置该标志表示通过BGP EVPN路由学习的ARP泛洪抑制表项生效
·     G:表示生效的ARP泛洪抑制表项是网关的ARP表项
·     S:表示生效的ARP泛洪抑制表项是静态配置的ARP表项
·     M:表示生效的ARP泛洪抑制表项是来自映射的远端VXLAN的ARP表项
·     I:表示该ARP泛洪抑制表项无效,原因如下:
¡     出方向Tunnel接口不存在
·     E:表示多归属成员同步的ARP泛洪抑制表项
·     F:表示EVPN E-tree组网中从Leaf上学习到的ARP泛洪抑制表项
Encap
报文封装类型,取值包括:
·     MPLS:报文封装类型为MPLS
·     VXLAN:报文封装类型为VXLAN
ARP泛洪抑制表项的总数
display evpn route arp-mobility命令用来显示EVPN的ARP迁移信息。
display evpn route arp-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ip ip-address ] [ verbose ]
public-instance:显示公网实例的ARP迁移信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ARP迁移信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ip ip-address:显示指定IP地址的ARP迁移信息。ip-address表示IPv4地址,为点分十进制格式。如果不指定本参数,则显示公网或VPN实例的所有ARP迁移信息。
verbose:显示ARP迁移的详细信息。如果不指定本参数,则显示ARP迁移的简要信息。
配置本命令时,如果不指定public-instancevpn-instance vpn-instance-name参数,则显示公网和所有VPN实例的ARP迁移信息。
# 显示所有EVPN的ARP迁移信息。
<Sysname> display evpn route arp-mobility
Flags: S - Suppressed, N - Not suppressed
VPN instance : vpn1
Interface    : Vsi-interface1
  IP address      Move count Moved from                Flags Suppressed at
  192.168.156.120 5          GE2/0/1                   S     17:24:33 2018/04/01
  192.168.56.20   -          -                         N     -
Public instance
Interface    : Vsi-interface2
  192.168.156.120 5          GE2/0/2                   S     17:24:33 2018/04/01
  192.168.56.20   5          2.2.2.2                   S     17:24:33 2018/04/01
表1-27 display evpn route arp-mobility命令显示信息描述表
VPN instance
VPN实例
Public instance
公网实例
IP address
IP地址
Move count
迁出次数
Moved from
表示ARP上一次迁移到的AC接口名称或所在VTEP/PE的IP地址
Flags
ARP是否被抑制迁移,取值包括:
·     S:表示抑制迁移
·     N:表示未抑制迁移
Suppressed at
迁移抑制发生的时间
# 显示所有EVPN的ARP迁移详细信息。
<Sysname> display evpn route arp-mobility verbose
VPN instance : vpn1
  IP address             : 192.168.156.120
    Move count           : 5
    Moved from           : GE2/0/1
    Flags                : Suppressed
    Suppressed at        : 17:24:33 2018/04/01
    Suppression threshold: 5
    Detection cycle      : 180s
    Suppression-time     : Permanent
表1-28 display evpn route arp-mobility verbose命令显示信息描述表
VPN instance
VPN实例
Public instance
公网实例
IP address
IP地址
Move count
迁出次数
Moved from
Flags
ARP是否被抑制迁移标记,取值包括:
·     Suppressed:表示抑制迁移
·     Not suppressed:表示未抑制迁移
Suppressed at
迁移抑制发生的时间
从本地迁移到远端站点的次数阈值
如果未开启ARP反复迁移抑制功能或ARP未被抑制迁移,则本字段取值为“-”
Detection cycle
检测周期,单位为秒
Suppression time
抑制恢复时间,单位为秒
取值为Permanent时,表示永远抑制
·     evpn route arp-mobility suppression
display evpn route mac命令用来显示EVPN的MAC地址信息。
display evpn route mac [ vxlan ] [ local | remote ] [ vsi vsi-name ] [ mac-address mac-address ] [ count ]
vxlan:显示EVPN VXLAN组网中的MAC地址信息。
local:显示本地MAC地址信息。
remote:显示远端MAC地址信息。
vsi vsi-name:显示指定VSI的MAC地址信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的MAC地址信息。
mac-address mac-address:显示指定MAC地址表项信息。mac-address表示MAC地址,格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果未指定本参数,则显示所有MAC地址表项信息。
count:显示MAC地址表项的数目。如果不指定本参数,则显示MAC地址的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端MAC地址信息;如果没有指定mplssrv6vxlan参数,则显示所有组网环境下的MAC地址信息。
# EVPN VXLAN组网中显示所有EVPN的本地和远端MAC地址信息。
<Sysname> display evpn route mac
VSI name: bbb
EVPN instance: -
MAC address     Link ID/Name   Flags   Encap           Next hop
0000-0000-000a  1              DL      VXLAN           -
0000-0000-0009  Tunnel1        B       VXLAN           2.2.2.2
0001-2000-4000  -              BI      VXLAN           3.3.3.3
# 显示EVPN的MAC地址表项数目。
<Sysname> display evpn route mac count
表1-29 display evpn route mac命令显示信息描述表
VSI name
VSI名称
EVPN instance
MAC address
MAC地址
Link ID/Name
Link ID表示路由表项的出链路标识符,即AC在VSI内的链路标识符
Name表示Tunnel接口名称
Flags
表项类型,取值包括:
·     D:表示存在动态学习的MAC地址表项
·     B:表示存在通过BGP EVPN路由学习的MAC地址表项
·     L:表示本地MAC地址表项生效,未设置该标志表示通过BGP EVPN路由学习的MAC地址表项生效
·     G:表示生效的MAC地址表项是网关的MAC地址表项
·     S:表示生效的MAC地址表项是静态配置的MAC地址表项
·     M:表示生效的MAC地址表项是来自映射的远端VXLAN的MAC地址表项
·     I:表示该MAC地址表项无效,原因如下:
¡     出方向Tunnel接口不存在
·     E:表示多归属成员同步的MAC地址表项
·     F:表示EVPN E-tree组网中从Leaf上学习到的MAC地址表项
Encap
报文封装类型,取值包括:
·     MPLS:报文封装类型为MPLS
·     SRv6:报文封装类型为SRv6
Nexthop
远端VTEP的地址,取值为“-”表示本地MAC
出接口类型,取值包括:
·     BE:表示SRv6 Best-Effort隧道
·     TE:表示SRv6 TE Policy隧道
MAC地址表项的总数
Color
MAC地址的Color属性值,如果MAC地址无Color属性,则显示为“-”。只有报文封装类型为SRv6时才显示该字段
Delete delay
收到撤销MAC/IP路由后,MAC地址表项的延迟删除时间,单位为秒;取值为“-”表示不延迟删除该MAC表项
SID
为MAC地址分配的SRv6 SID
display evpn route mac-mobility命令用来显示EVPN的MAC地址迁移信息。
display evpn route mac-mobility [ evpn-instance instance-name | interface interface-type interface-number | vsi vsi-name ] [ mac-address mac-address ] [ verbose ]
evpn-instance instance-name:显示指定EVPN实例内MAC地址迁移信息。instance-name表示EVPN实例名称,为1~31个字符的字符串,区分大小写。
interface interface-type interface-number:显示指定接口上的MAC地址迁移信息。interface-type interface-number为接口类型和接口编号。
vsi vsi-name:显示指定VSI的MAC地址迁移信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的MAC地址迁移信息。
mac-address mac-address:显示指定MAC地址的迁移信息。mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定本参数,则显示VSI的所有MAC地址的迁移信息。
verbose:显示MAC地址迁移的详细信息。如果不指定本参数,则显示MAC地址迁移的简要信息。
# 显示所有IPv4 EVPN的MAC地址迁移信息。
<Sysname> display evpn route mac-mobility
VSI name      : vsia
EVPN instance : -
  MAC address     Move count Moved from               Flags Suppressed at
  1000-0000-0000  10         GE2/0/1                  S     15:30:30 2018/03/30
  1000-0000-0001  -          -                        N     -
VSI name      : vsib
EVPN instance : -
  1000-0000-0003  2          GE2/0/2                  N     -
  1000-0000-0005  10         5.5.5.5                  S     17:24:33 2018/04/01
表1-30 display evpn route mac-mobility命令显示信息描述表
VSI name
VSI名称
EVPN instance
MAC address
MAC地址
Move count
迁出次数
Moved from
表示MAC地址上一次迁移到的AC接口名称或所在VTEP/PE的IP地址
Flags
MAC地址是否被抑制迁移,取值包括:
·     S:表示抑制迁移
·     N:表示未抑制迁移
Suppressed at
迁移抑制发生的时间
# 显示所有MAC的迁移详细信息。
<Sysname> display evpn route mac-mobility verbose
VSI name      : vsia
  MAC Address            : 1000-0000-0000
    Move count           : 10
    Flags                : Suppressed
    Suppressed at        : 15:30:30 2018/03/30
    Suppression threshold: 10
表1-31 display evpn route mac-mobility verbose命令显示信息描述表
VSI name
VSI名称
MAC address
MAC地址
Move count
迁出次数
Moved from
Flags
MAC地址是否被抑制迁移标记,取值包括:
·     Suppressed:表示抑制迁移
Suppressed at
迁移抑制发生的时间
从本地迁移到远端站点的次数阈值
如果未开启MAC反复迁移抑制功能或MAC未被抑制迁移,则本字段取值为“-”
Detection cycle
检测周期,单位为秒
Suppression time
抑制恢复时间,单位为秒
·     evpn route mac-mobility suppression
display evpn route nd命令用来显示EVPN的ND表项信息。
display evpn route nd [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ count ]
local:显示本地ND表项信息。
remote:显示远端ND表项信息。
public-instance:显示公网实例的ND表项信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ND表项信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ipv6 ipv6-address:显示指定IPv6地址的ND信息。ipv6-address表示IPv6地址。如果不指定本参数,则显示公网或VPN实例的所有ND信息。
count:显示ND表项的数目。如果不指定本参数,则显示ND表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端的ND表项信息。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则显示公网实例和所有VPN实例的ND表项信息。
# 显示所有EVPN的ND表项信息。
<Sysname> display evpn route nd
IPv6 address :   AD80:0300:1000:0050:0200:0300:0100:0012
MAC address  :   0001-0001-0001       Router MAC   :   a0ce-7e40-0400
VSI index    :   0                    Flags        :   GL
IPv6 address :   AD10:0300:1000:0020:0200:0300:0100:0022
MAC address  :   0001-0001-0002       Router MAC   :   a0ce-7e40-0411
Public instance                               Interface: Vsi-interface1
IPv6 address :   BC80:0300:1000:0050:0200:0300:0100:0033
MAC address  :   0002-0002-0001       Router MAC   :   a0ce-7e40-0422
IPv6 address :   BC10:0300:1000:0020:0200:0300:0100:0034
MAC address  :   0002-0002-0002       Router MAC   :   a0ce-7e40-0433
#显示EVPN的ND表项总数。
<Sysname>display evpn route nd count
表1-32 display evpn route nd命令显示信息描述表
VPN instance
VPN实例名称
Public instance
公网实例
VSI虚接口名称
IPv6 address
IPv6地址
MAC address
MAC地址
Router MAC
设备的Router MAC
VSI index
ND表项所属VSI的索引
Flags
ND表项类型,取值包括:
·     D:表示动态学习的ND表项
·     B:表示通过BGP EVPN路由学习的ND表项
·     L:表示本地ND表项生效,未设置该标志表示通过BGP EVPN路由学习的ND表项生效
·     G:表示生效的ND表项是网关的ND表项
·     S:表示生效的ND表项是静态配置的ND表项(暂不支持)
·     M:表示生效的ND表项是来自映射的远端VXLAN的ND表项
·     I:表示该ND表项无效,原因如下:
¡     出方向Tunnel接口不存在
ND表项的总数
display evpn route nd suppression命令用来显示EVPN的ND泛洪抑制信息。
display evpn route nd suppression [ local | remote ] [ vsi vsi-name ] [ ipv6 ipv6-address ] [ count ] [ verbose ]
local:显示本地ND泛洪抑制信息。
remote:显示远端ND泛洪抑制信息。
vsi vsi-name:显示指定VSI的ND泛洪抑制信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有VSI的ND泛洪抑制信息。
ipv6 ipv6-address:显示指定IPv6地址的ND泛洪抑制信息。ipv6-address表示IPv6地址。如果不指定本参数,则显示公网或VPN实例的所有ND泛洪抑制信息。
count:显示ND泛洪抑制表项的数目。如果不指定本参数,则显示ND泛洪抑制表项的具体信息。
执行本命令时,如果没有指定localremote参数,则显示EVPN的本地和远端的ND泛洪抑制信息。
# 显示EVPN的所有ND泛洪抑制信息。
<Sysname> display evpn route nd suppression
VSI name: vpna
IPv6 address                            MAC address    Flags Encap
11::8                                   72cb-ce9b-0a06 DL    VXLAN
11::9                                   0001-0001-0001 B     VXLAN
# 显示EVPN的ND泛洪抑制表项总数。
<Sysname> display evpn route nd suppression count
表1-33 display evpn route nd suppression命令显示信息描述表
VSI name
VSI名称
IPv6 address
IPv6地址
MAC address
MAC地址
Flags
ND泛洪抑制表项类型,取值包括:
·     D:表示存在动态学习的ND泛洪抑制表项
·     B:表示存在通过BGP EVPN路由学习的ND泛洪抑制表项
·     L:表示本地ND泛洪抑制表项生效,未设置该标志表示通过BGP EVPN路由学习的ND泛洪抑制表项生效
·     G:表示生效的ND泛洪抑制表项是网关的ND表项
·     S:表示生效的ND泛洪抑制表项是静态配置的ND表项
·     M:表示生效的ND泛洪抑制表项是来自映射的远端VXLAN的ND表项
·     I:表示该ND表项无效,原因可能是:
¡     出方向Tunnel接口不存在
Encap
报文封装类型,取值包括:
·     MPLS:报文封装类型为MPLS
ND泛洪抑制表项的总数
display evpn route nd-mobility命令用来显示EVPN的ND迁移信息。
display evpn route nd-mobility [ public-instance | vpn-instance vpn-instance-name ] [ ipv6 ipv6-address ] [ verbose ]
public-instance:显示公网实例的ND迁移信息。
vpn-instance vpn-instance-name:显示指定VPN实例的ND迁移信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ipv6 ipv6-address:显示指定IPv6地址的ND迁移信息。ipv6-address表示IPv6地址。如果不指定本参数,则显示公网或VPN实例的所有ND迁移信息。
verbose:显示ND迁移的详细信息。如果不指定本参数,则显示ND迁移的简要信息。
配置本命令时,如果不指定public-instancevpn-instance vpn-instance-name参数,则显示公网和所有VPN实例的ND迁移信息。
# 显示所有EVPN的ND迁移信息。
<Sysname> display evpn route nd-mobility
VPN instance : vpn1
  IPv6 address         : 1::1
  Move count           : 5
  Flags                : S
  Suppressed at        : 15:30:30 2020/03/30
Public instance
  IPv6 address         : 2::2
  Move count           : 5
  Moved from           : 20::20
  Flags                : S
  Suppressed at        : 17:24:33 2020/04/01
表1-34 display evpn route nd-mobility命令显示信息描述表
VPN instance
VPN实例
Public instance
公网实例
ND表项所在的接口
IPv6 address
IPv6地址
Move count
迁出次数
Moved from
表示ND上一次迁移到的AC接口名称或所在VTEP/PE的IP地址
Flags
ND是否被抑制迁移,取值包括:
·     Suppressed:表示抑制迁移
Suppressed at
迁移抑制发生的时间
# 显示所有EVPN的ND迁移详细信息。
<Sysname> display evpn route nd-mobility verbose
VPN instance : vpn1
  IPv6 address           : 1::1
    Move count           : 5
    Flags                : Suppressed
  IPv6 address           : 1::1
    Move count           : 5
    Flags                : Suppressed
表1-35 display evpn route nd-mobility verbose命令显示信息描述表
VPN instance
VPN实例
Public instance
公网实例
ND表项所在的接口
IPv6 address
IPv6地址
Move count
迁出次数
Moved from
Flags
ND是否被抑制迁移,取值包括:
·     Suppressed:表示抑制迁移
Suppressed at
迁移抑制发生的时间
从本地迁移到远端站点的次数阈值
如果未开启ND反复迁移抑制功能或ND未被抑制迁移,则本字段取值为“-”
Detection cycle
检测周期,单位为秒
Suppression time
抑制恢复时间,单位为秒
·     evpn route nd-mobility suppression
display evpn route xconnect-group命令用来显示交叉连接的EVPN相关信息。
display evpn route xconnect-group [ name group-name [ connection connection-name ] ] [ count ]
name group-name:显示指定交叉连接组的EVPN相关信息。group-name表示交叉连接组的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有交叉连接组的EVPN相关信息。
connection connection-name:显示交叉连接组内指定交叉连接的EVPN相关信息。交叉连接的名称,为1~20个字符的字符串,不能包含字符“-”,区分大小写。如果未指定本参数,则显示指定交叉连接组内所有交叉连接的EVPN相关信息。
count:显示EVPN交叉连接的总数。如果不指定本参数,则显示交叉连接的EVPN的具体信息。
# 显示所有交叉连接的EVPN相关信息。
<Sysname> display evpn route xconnect-group
Ctrl Flags: P - Primary, B - Backup, C - Control word
Xconnect group name: aa
 Connection name: aaa
  Local service ID    : 16777215
  Remote service ID   : 16777214
  Control word        : Enabled
  In label            : 502
  Local MTU           : 1500
  AC state            : Up
  PW type             : VLAN
    Nexthop          ESI                       Out label  Flags  MTU    State
    192.123.123.123  0001.0002.0002.0002.0001  1299       PC     1500   Up
    192.1.1.1        0001.0002.0002.0002.0001  1026       B      1500   Down
 Connection name: aab
  Remote service ID   : 2
  Control word        : Disabled
  In label            : 323
  Local MTU           : 1500
  AC state            : Up
  PW type             : VLAN
    192.1.1.1        0002.0002.0002.0002.0001  1234       P      1500   Up
    192.2.1.2        0002.0002.0002.0002.0001  603        P      1500   Up
 Connection name: aac
  Local service ID    : 3
  Remote service ID   : 4
  In label            : -
  Local MTU           : 1500
  AC state            : Up
  PW type             : Ethernet
    192.1.1.3        0000.0000.0000.0000.0000  555        P      1500   Idle
Xconnect group name: vpna
 Connection name: pw1
  Encapsulation       : SRv6
  In SID[DX2]         : 100::1
  In SID[DX2L]        : -
  Local MTU           : 1500
  AC State            : Up
  SRv6 Tunnel:
    Next Hop          : 2::2
    Out SID           : 200::1
    Flags             : P
    MTU               : 1500
    State             : Up
# 显示EVPN交叉连接的总数。
<Sysname> display evpn route xconnect-group count
表1-36 display evpn route xconnect-group命令显示信息描述表
Xconnect group name
交叉连接组名称
Connection name
交叉连接名称
Encapsulation
EVPN的封装类型,取值包括:
ESI
ES标识符
Local service ID
本地服务ID
Remote service ID
远端服务ID
Control word
是否开启控制字功能取值包括:
·     Enabled:PW开启控制字功能
In label
PW的入标签
Local MTU
本地配置的最大传输单元,单位为字节
AC state
当前AC的状态,取值包括Up、Down和“-”。其中,“-”表示未配置AC
PW type
PW的数据封装类型,取值包括Ethernet和VLAN
Nexthop
远端PE的地址
Out label
PW的出标签
Flags
PW属性标记,取值包括:
·     P:接收到的路由携带了Primary标识,需要建立主PW
·     B:接收到的路由携带了Backup标识,需要建立备份PW
·     C:接收到的路由中携带控制字标识,表示对端开启控制字功能,若本地使能控制字功能,则使EVPN PW处于UP状态,否则EVPN PW无法UP
MTU
接收到的路由中携带的最大传输单元,单位为字节
EVPN PW的状态,取值包括:
·     Up:表示协议状态Up
·     Down:表示协议状态Down
·     Idle:表示入或出标签不可用
In SID[DX2]
End.DX2类型的入SID
In SID[DX2L]
End.DX2L类型的入SID
SRv6 Tunnel
SRv6隧道信息
Out SID
出SID
EVPN PW和SRv6隧道的总数
display evpn routing-table命令用来显示EVPN的路由表信息。
display evpn routing-table [ ipv6 ] { public-instance | vpn-instance vpn-instance-name } [ count ]
ipv6:显示EVPN的IPv6路由表信息。如果不指定本参数,则显示EVPN的IPv4路由表信息。
public-instance:显示公网实例的路由信息。
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
count:显示路由表项的数目。如果不指定本参数,则显示路由表项的具体信息。
# EVPN分布式网关组网中,显示VPN实例vpn1对应EVPN的IPv4路由信息。
<Sysname> display evpn routing-table vpn-instance vpn1
Flags: E - with valid ESI   A – A-D ready   L - Local ES exists
VPN instance name: vpn1                             Local L3VNI: 7
IP address         Nexthop            Outgoing interface       NibID       Flags
10.1.1.11          1.1.1.1            Vsi-interface3           0x18000000  -
10.1.1.12          2.2.2.2            Vsi-interface3           0x18000001  -
# SRv6分布式网关组网中,显示VPN实例vpnb对应EVPN的IPv4路由信息。
<Sysname> display evpn routing-table vpn-instance vpnb
VPN instance: vpnb
Local SID   : BC10:0300:1000:0020:0200:0300:0100:0034
IP address          :      10.0.0.2
Nexthop             :      BC10:0300:1000:0020:0200:0300:0100:0035
NibID               :      0x18000000
Flags               :      EA
Remote SID          :      BC10:0300:1000:0020:0200:0300:0100:0034
# EVPN分布式网关组网中,显示公网实例的EVPN IPv4路由信息。
<Sysname> display evpn routing-table public-instance
Public instance                                     Local L3VNI: 3900
# 显示VPN实例vpn1对应的EVPN的IPv4路由表项总数。
<Sysname> display evpn routing-table vpn-instance vpn1 count
# EVPN分布式网关组网中,显示VPN实例vpna对应的EVPN的IPv6路由信息。
<Sysname> display evpn routing-table ipv6 vpn-instance vpna
VPN instance: vpna                              Local L3VNI: 7
Outgoing interface  :      Vsi-interface3
Next hop            :      1.1.1.1
NibID               :      0x18000000
Flags               :      E
IPv6 address        :      BC10:0300:1000:0020:0200:0300:0100:0035
Next hop            :      2.2.2.2
NibID               :      0x18000001
Flags               :      E
表1-37 display evpn routing-table命令显示信息描述表
VPN instance name
VPN实例名称
Public instance
公网实例
Local L3VNI
与VPN实例或公网实例关联的L3VNI
IP address
目的IPv4地址
IPv6 address
目的IPv6地址
Nexthop
下一跳地址
Outgoing interface
出接口
NibID
下一跳ID
Local SID
本地SRv6分布式网关的SID
Remote SID
远端SRv6分布式网关的SID
Flags
路由表项等价属性,取值包括:
·     E:即with valid ESI,表示路由携带了有效的ESI字段
·     A:即A-D ready,表示1类路由接收完全,可以下发该下一跳对应的等价路径
·     L:即Local ES exists,表示本地有激活的ESI,不下发远端路由表项
路由表项的总数
1.1.28  display l2vpn forwarding evpn split-horizon
display l2vpn forwarding evpn split-horizon命令用来显示EVPN多归属组网中满足水平分割原则的接口信息。
display l2vpn forwarding evpn split-horizon { ac interface interface-type interface-number | tunnel tunnel-number } [ slot slot-number ]
ac interface interface-type interface-number:显示EVPN VPLS多归属组网中AC接口的水平分割信息,即从指定AC收到的泛洪流量不会转发到哪些AC。interface-type interface-number为三层接口的接口类型和接口编号。
tunnel tunnel-number:显示EVPN VXLAN组网中VXLAN隧道的水平分割信息,即从指定VXLAN隧道接收到的泛洪流量不会转发到哪些AC。tunnel-number为VXLAN隧道接口的编号,取值范围为0~20479。如果未指定本参数,则显示EVPN多归属组网中所有满足水平分割原则的接口信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
# 显示从Tunnel 0上收到的泛洪流量中满足水平分割原则的接口信息。
<Sysname> display l2vpn forwarding evpn split-horizon tunnel 0
Tunnel name: 0
  Total number of filtered interfaces: 2
  Filtered interfaces:
    GE2/0/1
    GE2/0/2
表1-38 display l2vpn forwarding evpn split-horizon命令显示信息描述表
Tunnel name
VXLAN隧道接口名称
Filtered interfaces
从指定VXLAN隧道接收到的泛洪流量在该设备上不能转发的接口
Interface name
接口名称
AC link ID
AC的链路标识符
Service instance ID
以太网服务实例编号
PW count
PW的数量
SRv6 tunnel count
SRv6隧道的数量
VSI name
VSI名称
PW link ID
PW的链路标识符
SRv6 link ID
SRv6隧道的链路标识符
ESI label
ESI标签
Argument
标识Leaf AC的Argument值
1.1.29  e-tree enable
e-tree enable命令用来开启本地AC与远端AC的EVPN E-Tree功能。
undo e-tree enable命令用来关闭本地AC与远端AC的EVPN E-Tree功能。
e-tree enable
undo e-tree enable
本地AC与远端AC的EVPN E-Tree功能处于关闭状态。
VSI实例下的EVPN实例视图
在EVPN VPLS和EVPN VPLS over SRv6组网中,属于同一个EVPN实例的所有AC均可以互相访问。EVPN承载接入用户的网络中,为了提高用户的安全性,减少用户之间的相互影响,通常需要控制AC侧用户之间的相互访问。EVPN E-Tree功能通过将AC分为Root和Leaf角色,实现了同一EVPN实例内AC之间流量的隔离。
本命令用于开启本地AC与远端AC的EVPN E-Tree功能,若仅需要控制本地AC之间的访问,则无需配置本命令。
EVPN VPLS和EVPN VPLS over SRv6组网中,不能同时配置本功能。
# 开启EVPN E-Tree功能。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation mpls
[Sysname-vsi-aaa-evpn-mpls] e-tree enable
1.1.30  esi
esi命令用来配置接口的ESI(Ethernet Segment Identifier,以太网段标识)。
undo esi命令用来恢复缺省情况。
esi esi-id
undo esi
未配置接口的ESI。
esi-id:以太网链路网段标识符。格式为xxxx.xxxx.xxxx.xxxx.xxxx,必须以00开头,其中x为十六进制数,不支持全0。
ESI是ES的唯一标识,ESI相同的接口(或VSI)属于同一个ES,报文可以在这些接口(或VSI)之间进行负载分担。
主接口及其子接口上均可以配置ESI:
·     若主接口及其子接口上都配置了ESI,或仅在子接口上配置了ESI,则子接口的ESI以该子接口上的配置为准,子接口的ES相关配置(evpn df-election algorithmevpn df-election preferenceevpn df-election preference non-revertiveevpn redundancy-modeevpn timer es-delay命令)也以该子接口上的配置为准。
·     若仅在主接口上配置了ESI,则子接口继承主接口的ESI和ES相关配置。即使 子接口上执行了ES相关配置,也不会生效。
只有VSI LDP PW和VSI静态PW不采用水平分割方式转发报文或建立的PW为DCI PW(执行peer命令时指定no-split-horizon参数或dci参数)时,才允许在该VSI LDP PW或VSI静态PW的视图下执行本命令。
不能通过重复执行esi命令修改接口(或VSI)的ESI属性值。如需修改,请先通过undo esi命令删除接口(或VSI)的ESI属性值,再执行esi命令配置新的ESI属性值。
# 配置接口GigabitEthernet2/0/1上的ESI值为0000.0001.0002.0003.0004。
[Sysname-GigabitEthernet2/0/1] esi 0000.0001.0002.0003.0004
1.1.31  evpn encapsulation
evpn encapsulation命令用来创建EVPN实例,并进入EVPN实例视图。如果EVPN实例已经存在,则直接进入EVPN实例视图。
undo evpn encapsulation命令用来恢复缺省情况。
VSI视图:
evpn encapsulation { mpls | vxlan }
交叉连接组视图:
不存在EVPN实例。
VSI视图
交叉连接组视图
mpls:表示EVPN采用MPLS封装方式。
vxlan:表示EVPN采用VXLAN封装方式。
只有创建EVPN实例后,才能进行EVPN相关配置。
# 创建EVPN实例,并进入VSI实例下的EVPN实例视图。
[Sysname] vsi aaa
1.1.32  evpn global-mac
evpn global-mac命令用来配置EVPN的全局MAC地址。
undo evpn global-mac命令用来恢复缺省情况。
evpn global-mac mac-address
未配置EVPN的全局MAC地址。
mac-address:MAC地址,形式为H-H-H,不能配置为全0、广播MAC地址和组播MAC地址。
本命令配置的全局MAC地址仅用于承载L3VNI的VSI虚接口。
如果承载L3VNI的VSI虚接口上通过mac-address命令配置了MAC地址,则VSI虚接口的MAC地址为该地址;否则,VSI虚接口的MAC地址为evpn global-mac命令配置的全局MAC地址。
本命令配置的全局MAC地址不能与设备的预留MAC地址相同。
# 配置EVPN的全局MAC地址为0001-0001-0001。
[Sysname] evpn global-mac 1-1-1
1.1.33  evpn df-election ac-influence enable
evpn df-election ac-influence enable命令用来开启AC状态影响DF选举功能。
undo evpn df-electionac-influence enable命令用来关闭AC状态影响DF选举功能。
undo evpn df-election ac-influence enable
AC状态影响DF选举功能处于关闭状态。
应用场景
缺省情况下,在EVPN多归属组网中,同一ES内的所有VTEP/PE都将参与DF选举,VTEP/PE上AC的状态不影响VTEP/PE是否参与DF选举。若选举为DF的VTEP/PE上AC的状态为Down,会导致VTEP/PE无法通过AC转发流量,此时可以通过配置本命令来解决此问题。
工作机制
配置本命令之后,只有当AC状态为Up时VTEP/PE才会参与DF选举。VTEP/PE通过如下方式判断AC状态:
·     对于本端VTEP/PE,通过检查本端AC是否Up来判断本端VTEP/PE是否参与DF选举,只有AC状态为Up的本端VTEP/PE才可以参与DF选举。
·     对于远端VTEP/PE,通过检查是否收到远端VTEP/PE发布的AD VTEP/PEr ES路由和AD VTEP/PEr EVI路由来判断远端VTEP/PE是否参与DF选举,只有收到远端VTEP/PE发布的AD VTEP/PEr ES 路由和AD VTEP/PEr EVI路由时,本端VTEP/PE才认为远端VTEP/PE上AC为Up状态,可以参与DF选举。
注意事项
只有当冗余备份组中的所有VTEP/PE上都开启本功能时,本功能才生效。
# 开启AC状态影响DF选举功能。
[Sysname] evpn df-election ac-influence enable
1.1.34  evpn df-election algorithm (interface view)
evpn df-election algorithm命令用来配置DF选举算法。
undo evpn df-election algorithm命令用来恢复缺省情况。
evpn df-election algorithm algorithm
以系统视图下配置的DF选举算法为准。
algorithm:指定DF选举算法。当前仅支持取值preference,表示基于优先级的DF选举算法。
在EVPN多归属组网中,如果用户希望通过更加灵活地方式控制DF选举,则可以配置本命令修改DF选举算法。
接口视图和系统视图下均可以配置DF选举算法。系统视图的配置对所有ES都有效,而接口视图下的配置只对当前接口下的ES有效。对于一个ES来说,优先采用该接口视图下的配置,只有该接口下未进行配置时,才采用系统视图的配置。
# 在接口GigabitEthernet2/0/1上配置基于优先级的DF选举算法。
[Sysname-GigabitEthernet2/0/1] evpn df-election algorithm preference
·     evpn df-election algorithm (system view)
·     evpn df-election preference
1.1.35  evpn df-election algorithm (system view)
evpn df-election algorithm命令用来全局配置DF选举算法。
采用基于VLAN Tag的DF选举算法。
系统视图和接口视图下均可以配置DF选举算法。系统视图的配置对所有ES都有效,而接口视图下的配置只对当前接口下的ES有效。对于一个ES来说,优先采用该接口视图下的配置,只有该接口下未进行配置时,才采用系统视图的配置。
# 全局配置基于优先级的DF选举算法。
[Sysname] evpn df-election algorithm preference
·     evpn df-election algorithm (interface view)
1.1.36  evpn df-election preference
evpn df-election preference命令用来配置DF选举优先级。
undo evpn df-election preference命令用来恢复缺省情况。
evpn df-election preference preference
DF选举优先级为32767。
preference:指定DF选举优先级,取值范围为0~65535。优先级数值越大则优先级越高。
在EVPN多归属组网中,若采用了基于优先级的DF选举算法,则可以通过本命令配置DF选举优先级来控制DF的选举。DF优先级最高的设备将选举为DF。
只有在接口视图或系统视图下执行evpn df-election algorithm preference命令后,本命令配置的优先级才会生效。
# 配置DF选举优先级为100。
[Sysname-GigabitEthernet2/0/1] evpn df-election preference 100
1.1.37  evpn df-election preference non-revertive
evpn df-election preference non-revertive命令用来开启基于优先级DF选举算法的不回切功能。
undo evpn df-election preference non-revertive命令用来关闭基于优先级DF选举算法的不回切功能。
基于优先级算法的DF选举不回切功能处于关闭状态。
配置基于优先级的DF选举算法后,优先级最高的设备被选举为DF进行流量转发。
如用户通过多归属接入VTEP 1和VTEP 2,VTEP 1的DF选举优先级为200,VTEP 2的DF选举优先级为100,则VTEP 1被选举为DF。若出现如下情况则会重新选举VTEP 2作为DF:
·     VTEP 1设备故障。
·     用户接入VTEP 1的链路故障。
·     在VTEP 2上配置了比VTEP 1更高的DF选举优先级。
若在VTEP 2被选举为DF后,VTEP 1故障恢复、用户接入VTEP 1的链路故障恢复或者VTEP 1上配置了高于VTEP 2上的DF选举优先级,则又会重新选举VTEP 1作为DF。如果此时将DF切换为VTEP 1,则会造成一些不必要的丢包。在VTEP 2上配置本功能,可以避免DF回切为VTEP 1,减少丢包。
只有在接口视图或系统视图下执行evpn df-election algorithm preference命令后,本命令才会生效。
# 开启基于优先级DF选举算法的不回切功能。
[Sysname-GigabitEthernet2/0/1] evpn df-election preference non-revertive
1.1.38  evpn irb asymmetric
evpn irb asymmetric命令用来配置EVPN VXLAN采用非对称IRB方式转发流量。
undo evpn irb asymmetric命令用来恢复缺省情况。
evpn irb asymmetric [ route-policy route-policy-name ]
EVPN VXLAN采用对称IRB方式转发流量。
route-policy route-policy-name:指定通过路由策略过滤的流量采用非对称IRB方式转发。route-policy-name表示路由策略名称,为1~63个字符的字符串,区分大小写。不指定本参数或指定的路由策略不存在时,所有流量均通过非对称IRB方式转发。
EVPN VXLAN支持对称IRB和非对称IRB两种流量转发方式,通过本命令可以修改流量转发方式。
# 配置EVPN VXLAN采用非对称IRB方式转发流量。
[Sysname] evpn irb asymmetric
1.1.39  evpn local-service-id remote-service-id
evpn local-service-id remote-service-id命令用来创建EVPN PW。
undo evpn local-service-id remote-service-id命令用来删除指定的EVPN PW。
evpn local-service-id local-service-id remote-service-id remote-service-id [ tunnel-policy tunnel-policy-name ] [ pw-class class-name ]
undo evpn local-service-id local-service-id remote-service-id remote-service-id
不存在EVPN PW。
交叉连接视图
local-service-id local-service-id:本端的service ID,取值范围为1~16777215。
remote-service-id remote-service-id:远端的service ID,取值范围为1~16777215。
tunnel-policy tunnel-policy-name:指定PW的隧道策略。tunnel-policy-name表示隧道策略名,为1~19个字符的字符串,区分大小写。如果不指定本参数,则使用缺省的隧道策略。
pw-class class-name:指定PW引用的PW模板。class-name表示PW模板名,为1~19个字符的字符串,区分大小写。PW模板中可以配置PW的数据封装类型、是否使用控制字等。如果不指定本参数,则PW数据封装类型由接口的链路类型决定,对于不强制要求使用控制字的PW数据封装类型,不支持控制字功能。
在同一交叉连接下执行两次evpn local-service-id remote-service-id命令将两条EVPN PW关联可以实现多段PW功能。
同一个交叉连接中不能通过重复执行evpn local-service-id remote-service-id修改已经创建的EVPN PW,如需修改已经创建的EVPN PW,请先通过undo evpn local-service-id remote-service-id命令删除已经创建的EVPN PW,再执行evpn local-service-id remote-service-id命令创建新的EVPN PW。
在多归属站点组网中,如果本端PE与冗余备份组中的各PE建立EVPN PW时,通过本命令引用的PW模板中配置了使用BFD检测PW的连通性:
·     若本端PE与冗余备份组中各PE建立的EVPN PW为主备EVPN PW,则仅为主EVPN PW建立动态BFD会话。
·     若本端PE与冗余备份组中各PE建立的EVPN PW为等价EVPN PW,则不建立动态BFD会话。
# 创建EVPN PW,指定PW的隧道策略为aaa并且指定引用的PW模板为bbb。
[Sysname] xconnect-group aaa
[Sysname-xcg-aaa] connection ac2pw
[Sysname-xcg-aaa- ac2pw] evpn local-service-id 2 remote-service-id 4 tunnel-policy aaa pw-class bbb
1.1.40  evpn mac-ip advertise distributed-gateway
evpn mac-ip advertise distributed-gateway命令用来开启通过MAC/IP发布路由通告分布式网关ARP信息的功能。
undo evpn mac-ip advertise distributed-gateway命令用来关闭通过MAC/IP发布路由通告分布式网关ARP信息的功能。
通过MAC/IP发布路由通告分布式网关ARP信息的功能处于关闭状态。
在EVPN分布式网关下行连接VTEP的组网中,分布式网关通过IP前缀路由通告网关的ARP信息。VTEP设备上由于不存在网关配置而无法学习到网关的ARP信息,导致其不能将流量转发到网关设备。此时,可以在分布式网关设备上开启本功能,使得该网关通过MAC/IP发布路由通告分布式网关的ARP信息(即作为分布式网关的VSI虚接口的IP地址和MAC地址),使VTEP学习到网关的ARP信息。
# 开启通过MAC/IP发布路由通告分布式网关ARP信息的功能。
[Sysname] evpn mac-ip advertise distributed-gateway
1.1.41  evpn mpls routing-enable
evpn mpls routing-enable命令用来开启EVPN通告VPN路由功能。
undo evpn mpls routing-enable命令用来关闭EVPN通告VPN路由功能。
EVPN通告VPN路由功能处于关闭状态。
VPN实例IPv4地址族视图
VPN实例IPv6地址族视图
开启本功能后,VPN路由表中的VPN路由会作为EVPN的IP前缀路由发布给邻居;当收到邻居发送的MPLS封装的IP前缀路由时,会将其插入到相应的VPN路由表中。
本功能需要与向对等体/对等体组发布MPLS封装的IP前缀路由功能配合使用,即在配置本功能后还需要在BGP EVPN地址族视图下执行命令peer advertise encap-type mpls配置向对等体/对等体组发布MPLS封装的IP前缀路由功能。
# 在VPN实例vpna的IPv4地址族视图下使能EVPN通告VPN路由功能。
[Sysname-vpn-instance-vpna] address-family ipv4
[Sysname-vpn-ipv4-vpna] evpn mpls routing-enable
1.1.42  evpn multihoming advertise disable
evpn multihoming advertise disable命令用来配置禁止通告以太网自动发现路由和以太网段路由,并撤销已经通告的该类路由。
undo evpn multihoming advertise disable命令用来恢复缺省情况。
允许通告EVPN以太网自动发现路由和以太网段路由。
在站点多归属组网中,用户需要重启其中一台VTEP或PE时,重启该VTEP或PE前,可以通过在该VTEP或PE上执行此命令,来禁止通告以太网自动发现路由和以太网段路由,并撤销已经通告的该类路由,以便其他VTEP或PE及时更新本地的EVPN路由表,确保VTEP或PE的重启不会影响报文转发。
# 配置禁止通告以太网自动发现路由和以太网段路由,并撤销已经通告的该类路由。
[Sysname] evpn multihoming advertise disable
1.1.43  evpn multihoming advertise ignore-ethernet-tag
evpn multihoming advertise ignore-ethernet-tag命令用来配置发布以太网自动发现路由和MAC/IP发布路由时忽略以太网标签。
undo evpn multihoming advertise ignore-ethernet-tag命令用来恢复缺省情况。
EVPN多归属组网中,PE发送以太网自动发现路由和MAC/IP发布路由时携带以太网标签。
本命令需要配置在冗余备份组成员PE上。
多归属站点组网中,为冗余备份组成员上的AC配置ESI后,冗余备份组成员发送以太网自动发现路由和MAC/IP发布路由时会携带AC的以太网标签。如果对端设备无法识别以太网标签,为了与该对端设备互通,需要在本端设备上配置本命令,使得本端设备将发送的以太网自动发现路由和MAC/IP发布路由中的以太网标签字段填为0。
执行本命令后,设备会撤销已经发布的以太网自动发现路由和MAC/IP发布路由,并重新发布以太网标签字段为0的以太网自动发现路由和MAC/IP发布路由。
执行本命令时,需要注意的是:
·     为三层主接口配置ESI后,如果该接口上的子接口未配置ESI,则子接口会继承主接口的ESI。此时,具有相同ESI的子接口不能关联相同的VSI。
# 配置发布以太网自动发现路由和MAC/IP发布路由时忽略以太网标签。
[Sysname] evpn multihoming advertise ignore-ethernet-tag
·     esi
1.1.44  evpn multihoming timer df-delay
evpn multihoming timer df-delay命令用来设置DF选举的延迟时间。
undo evpn multihoming timer df-delay命令用来恢复缺省情况。
evpn multihoming timer df-delay delay-value
DF选举的延迟时间为3秒。
delay-value:DF选举的延迟时间,取值范围为1~1200,单位为秒。
AC所在接口的状态、多归属成员设备数量或者接口下ESI值的频繁变化都会导致DF频繁选举,极大影响了网络的性能。通过配置evpn multihoming timer df-delay命令可以指定DF选举的时间间隔,避免频繁选举DF,保证网络的稳定性。
在多归属组网中,若希望DF故障时,能够快速选举出新的DF,以避免长时间存在多个BFD,导致流量转发中断,则建议通过本命令将DF选举延迟时间配置为0。
# 配置DF选举的延迟时间为5秒。
[Sysname] evpn multihoming timer df-delay 5
1.1.45  evpn route arp-mobility suppression
evpn route arp-mobility suppression命令用来开启ARP反复迁移抑制功能。
undo evpn route arp-mobility suppression命令用来关闭ARP反复迁移抑制功能。
evpn route arp-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
ARP反复迁移抑制功能处于关闭状态。
EVPN实例视图
VSI实例下的EVPN实例视图
三层接口视图
detect-cycle detect-time:指定ARP迁移的检测周期。detect-time取值范围为60~900,单位为秒,缺省值为180。
detect-threshold move-times:指定从本地迁移到远端站点的次数阈值。move-times取值范围为3~10,缺省值为5。
suppression-time:指定ARP迁移抑制功能的抑制恢复时间。被抑制的ARP表项在抑制恢复时间超时后,会从抑制状态恢复为正常状态,可以正常迁移。缺省取值为permanent,即不会恢复被抑制的ARP表项,永远抑制。
suppression-time:抑制恢复时间,取值范围为120~3600,单位为秒。
permanent:不会恢复被抑制的ARP表项,永远抑制。
EVPN VXLAN组网中,不同VTEP下的设备如果错误地配置了相同的IP地址,会造成VTEP间不断同步ARP信息,并更新本地EVPN的ARP表项信息,此时VTEP认为该设备在不断迁移。这种情况可能会使VTEP间形成环路,占用大量的链路带宽。开启本功能后,若检测周期内某ARP信息从本地迁移到远端的次数超过阈值,则抑制最后一次由远端向本地迁移,即仅本地学习但不对外通告该ARP信息,避免VTEP间形成环路。
执行undo evpn route arp-mobility suppression命令或ARP表项的抑制时间超过抑制恢复时间时,如果VTEP上被抑制迁移的ARP表项未老化,则立即向远端通告该ARP信息;如果VTEP上被抑制迁移的ARP表项已经老化,则VTEP重新从本地学习该ARP信息后再对外通告。
ARP反复迁移抑制功能仅在EVPN VXLAN分布式网关组网中生效。
系统视图、EVPN实例视图、VSI实例下的EVPN实例视图和三层接口视图下均可以开启ARP反复迁移抑制功能。系统视图的配置对所有EVPN实例都有效,EVPN实例视图下的配置对关联该EVPN实例的所有VSI有效,VSI实例下的EVPN实例视图下的配置仅对该VSI有效,三层接口视图下的配置仅对该接口有效。对于一个ARP来说,ARP反复迁移抑制功能生效的优先级为三层接口视图>EVPN实例视图/VSI实例下的EVPN实例视图>系统视图。
# 开启ARP反复迁移抑制功能。
[Sysname] evpn route arp-mobility suppression
·     display evpn route arp-mobility
1.1.46  evpn route mac-mobility suppression
evpn route mac-mobility suppression命令用来开启MAC地址反复迁移抑制功能。
undo evpn route mac-mobility suppression命令用来关闭MAC地址反复迁移抑制功能。
evpn route mac-mobility suppression [ detect-cycle detect-time | detect-threshold  move-times | suppression-time [ suppression-time | permanent ] ] *
MAC地址反复迁移抑制功能处于关闭状态。
EVPN实例视图
VSI实例下的EVPN实例视图
三层接口视图
detect-cycle detect-time:指定MAC地址迁移的检测周期。detect-time取值范围为60~900,单位为秒,缺省值为180。
suppression-time:指定MAC迁移抑制功能的抑制恢复时间。被抑制的MAC地址在抑制恢复时间超时后,会从抑制状态恢复为正常状态,可以正常迁移。缺省取值为permanent,即不会恢复被抑制的MAC地址,永远抑制。
permanent:不会恢复被抑制的MAC地址,永远抑制。
EVPN VXLAN组网中,不同VTEP或PE下的设备如果错误地配置了相同的MAC地址,会造成VTEP或PE间不断同步MAC地址信息,并更新本地EVPN的MAC地址表项。此时VTEP或PE认为该设备在不断迁移。这种情况可能会使VTEP或PE间形成环路,占用大量的链路带宽。开启本功能后,若在检测周期内某MAC地址从本地迁移到远端的次数超过阈值,则抑制最后一次由远端向本地迁移,即仅本地学习但不对外通告该MAC地址,避免VTEP或PE间形成环路。
执行undo evpn route mac-mobility suppression命令或MAC地址的抑制时间超过抑制恢复时间时,如果VTEP或PE上被抑制迁移的MAC地址未老化,则立即向远端通告该MAC地址;如果VTEP或PE上被抑制迁移的MAC地址已经老化,则VTEP或PE重新从本地学习该MAC地址后再对外通告。
系统视图、EVPN实例视图、VSI实例下的EVPN实例视图和三层接口视图下均可以开启MAC地址反复迁移抑制功能。系统视图的配置对所有EVPN实例都有效,EVPN实例视图下的配置对关联该EVPN实例的所有VSI有效,VSI实例下的EVPN实例视图下的配置仅对该VSI有效,三层接口视图下的配置仅对该接口有效。对于一个MAC地址来说,MAC地址反复迁移抑制功能生效的优先级为三层接口视图>EVPN实例视图/VSI实例下的EVPN实例视图>系统视图。
# 开启MAC地址反复迁移抑制功能。
[Sysname] evpn route mac-mobility suppression
·     display evpn route mac-mobility
1.1.47  evpn route nd-mobility suppression
evpn route nd-mobility suppression命令用来开启ND反复迁移抑制功能。
undo evpn route nd-mobility suppression命令用来关闭ND反复迁移抑制功能。
evpn route nd-mobility suppression [ detect-cycle detect-time | detect-threshold move-times | suppression-time [ suppression-time | permanent ] ] *
ND反复迁移抑制功能处于关闭状态。
EVPN实例视图
VSI实例下的EVPN实例视图
三层接口视图
detect-cycle detect-time:指定ND迁移的检测周期。detect-time取值范围为60~900,单位为秒,缺省值为180。
suppression-time:指定ND迁移抑制功能的抑制恢复时间。被抑制的ND表项在抑制恢复时间超时后,会从抑制状态恢复为正常状态,可以正常迁移。缺省取值为permanent,即不会恢复被抑制的ND表项,永远抑制。
permanent:不会恢复被抑制的ND表项,永远抑制。
EVPN VXLAN组网中,如果不同VTEP学习到了相同的本地ND表项,则VTEP会不断在彼此之间同步ND信息,并更新本地EVPN的ND表项信息,此时VTEP认为该设备在不断迁移。这种情况可能会使VTEP间形成环路,占用大量的链路带宽。开启本功能后,若检测周期内某ND信息从本地迁移出到远端的次数超过阈值,则抑制最后一次由远端向本地迁移,即仅本地学习但不对外通告该ND信息,避免VTEP间形成环路。
执行undo evpn route nd-mobility suppression命令或ND表项的抑制时间超过抑制恢复时间时,如果VTEP上被抑制迁移的ND表项未老化,则立即向远端通告该ND信息;如果VTEP上被抑制迁移的ND表项已经老化,则VTEP重新从本地学习该ND信息后再对外通告。
ND反复迁移抑制功能仅在如下两种组网中生效:
·     启用ND泛洪抑制功能的EVPN VXLAN组网。
·     EVPN VXLAN分布式网关组网。
系统视图、EVPN实例视图、VSI实例下的EVPN实例视图和三层接口视图下均可以开启ND反复迁移抑制功能。系统视图的配置对所有EVPN实例都有效,EVPN实例视图下的配置对关联该EVPN实例的所有VSI有效,VSI实例下的EVPN实例视图下的配置仅对该VSI有效,三层接口视图下的配置仅对该接口有效。对于一个ND来说,ND反复迁移抑制功能生效的优先级为三层接口视图>EVPN实例视图/VSI实例下的EVPN实例视图>系统视图。
# 开启ND反复迁移抑制功能。
[Sysname] evpn route nd-mobility suppression
·     display evpn route nd-mobility
1.1.48  evpn span-segment disable
evpn span-segment disable命令用来禁止集中式EVPN网关跨网段学习MAC/IP发布路由中的ARP或ND信息。
undo evpn span-segment disable命令用来恢复缺省情况。
evpn span-segment { arp-learning | nd-learning } disable
undo evpn span-segment { arp-learning | nd-learning } disable
集中式EVPN网关可以跨网段学习MAC/IP发布路由中的ARP和ND信息。
VSI虚接口视图
arp-learning:禁止集中式EVPN网关跨网段学习MAC/IP发布路由中的ARP信息。
nd-learning:禁止集中式EVPN网关跨网段学习MAC/IP发布路由中的ND信息。
集中式EVPN网关组网中,虚拟机VM 1和VM 2属于同一VXLAN,所属网段为10.1.1.0/24,VSI虚接口1为该VXLAN的网关接口,网关连接的外部三层网络为10.1.2.0/24。若连接VM 2的VTEP上配置了ARP/ND泛洪抑制功能,则VM 2的地址错误地配置为10.1.2.0/24网段的地址(如10.1.2.2)时,连接VM 2的VTEP会向网关发送携带ARP/ND信息(IP为10.1.2.2,MAC为VM 2的MAC)的MAC/IP发布路由,网关会学习该ARP/ND并下发到转发表。这种情况下,若VM 1访问外部网络中的10.1.2.2,则网关会将流量转发至VM 2,造成VM 1无法访问10.1.2.2。
为解决上述问题,可在网关虚接口上配置本命令,禁止网关跨网段学习MAC/IP发布路由中的ARP/ND信息。
# 禁止集中式EVPN网关跨网段学习MAC/IP发布路由中的ARP信息。
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] evpn span-segment arp-learning disable
1.1.49  evpn timer es-delay
evpn timer es-delay命令用来开启以太网段路由延迟发布功能,并指定延迟发布时间。
undo evpn timer es-delay命令用来关闭以太网段路由延迟发布功能。
evpn timer es-delay delay-time
以太网段路由延迟发布功能处于关闭状态,即不延迟发布以太网段路由。
delay-time:以太网段路由延迟发布时间,取值范围3~1200,单位为秒。
本命令通常与evpn track peer命令配合使用。
在多归属组网中,冗余备份组的一台成员设备因故障等原因重启后,站点间的广播流量转发可能会失败。为了解决这个问题,可以在成员设备连接CE的接口上配置evpn track peer命令。如果通过本命令开启了以太网段路由延迟发布功能,则当成员设备从故障中恢复且连接CE的接口状态变为Up时,成员设备会启动以太网段路由的延迟发送定时器,并对指定BGP邻居状态进行监控。如果在定时器超时前,所有设备的BGP邻居状态均Up,则本地成员设备正常发送以太网段路由;否则,定时器超时后,本地成员设备向所有BGP邻居状态为Up的设备发送以太网段路由。定时器超时或所有监控的BGP邻居均Up后,本地成员设备根据收到的所有以太网段路由进行DF选举。
# 接口GigabitEthernet2/0/1下配置以太网段路由发布的延迟时间为300秒。
[Sysname-GigabitEthernet2/0/1] evpn timer es-delay 300
·     evpn track peer
1.1.50  evpn timer es-recovery
evpn timer es-recovery命令用来配置基于优先级选举DF时,延迟发布以太网段路由。
undo evpn timer es-recovery命令用来恢复缺省情况。
evpn timer es-recovery recovery-time
基于优先级选举DF时,不延迟发布以太网段路由。
recovery-time:以太网段路由延迟发布时间,取值范围为3~1200,单位为秒。
在DF设备重启或者进程重启触发DF重新选举的场景中,DF设备重启或进程重启后会立刻发布以太网段路由,以便快速恢复为DF是。由于接入侧连接恢复较慢,设备切换为DF后,可能会因为AC状态未up而导致丢包。此时,可以配置本命令,使设备在等待接入侧连接恢复后再发送以太网段路由。
在EVPN多归属组网采用多活冗余模式时,建议配置本功能,解决DF回切造成的丢包问题;采用单活冗余模式时,不建议配置本功能,否则会影响DF回切性能。
# 配置基于优先级选举DF时,延迟300秒发布以太网段路由。
[Sysname-GigabitEthernet1/0/1] evpn timer es-recovery 300
1.1.51  evpn track peer
evpn track peer命令用来在多归属组网中,配置冗余备份组中的成员设备监视其它VTEP/PE设备的BGP邻居状态。
undo evpn track peer命令用来取消监视其它VTEP/PE设备的BGP邻居状态。
evpn track peer { peer-ipv4-address | peer-ipv6-address }
undo evpn track peer peer-address
在多归属组网中,冗余备份组中的成员设备不会监视其它设备的BGP邻居状态。
peer-ipv4-address:VTEP/PE的IPv4地址。
peer-ipv6-address:VTEP/PE的IPv6地址。
在多归属组网中,冗余备份组的一台成员设备因故障等原因重启后,站点间的广播流量转发可能会失败。为了解决这个问题,可以在成员设备连接CE的接口上配置evpn track peer命令。这样,当成员设备从故障中恢复且连接CE的接口状态变为Up时,成员设备会启动以太网段路由的延迟发送定时器,并对本命令指定的BGP邻居状态进行监控。如果在定时器超时前,所有设备的BGP邻居状态均Up,则本地成员设备正常发送以太网段路由;否则,定时器超时后,本地成员设备向所有BGP邻居状态为Up的设备发送以太网段路由。定时器超时或所有监控的BGP邻居均Up后,本地成员设备根据收到的所有以太网段路由进行DF选举。
# 在接口GigabitEthernet2/0/1上配置本地成员设备监视设备1.1.1.1的BGP邻居状态。
[Sysname-GigabitEthernet2/0/1] evpn track peer 1.1.1.1
·     evpn timer es-delay
1.1.52  export route-policy
export route-policy命令用来配置EVPN的出方向路由策略。
undo export route-policy命令用来恢复缺省情况。
未配置EVPN的出方向路由策略,即不对发布的路由进行过滤。
EVPN实例视图
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
VPN实例EVPN视图
route-policy:出方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的出方向路由策略,则EVPN实例/VPN实例向BGP EVPN协议发布路由时,将利用指定的路由策略对发布的路由进行过滤、改变发布路由的属性等。使用本命令可以更加精确、灵活地控制路由的发布。
在同一视图下,多次执行本命令,最后一次执行的命令生效。
EVPN实例视图、VSI实例下的EVPN实例视图、交叉连接组EVPN实例视图、VPN实例视图和VPN实例EVPN视图下配置的出方向路由策略均能用来过滤EVPN路由。其中:
·     EVPN实例视图、VSI实例下的EVPN实例视图、交叉连接组EVPN实例视图下的配置用于EVPN二层转发场景。
·     VPN实例视图和VPN实例EVPN视图下的配置用于EVPN三层转发场景。如果同时配置二者,则EVPN采用VPN实例EVPN视图下的配置。
# 在VPN实例vpn1下配置EVPN的出方向路由策略为poly-1。
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
·     route-policy(三层技术-IP路由命令参考/路由策略)
1.1.53  igp-metric inherit
igp-metric inherit命令用来配置将BGP EVPN路由添加到VPN实例路由表时,路由的Metric值为到达原EVPN路由下一跳的IGP路由的Metric值。
undo igp-metric inherit命令用来恢复缺省情况。
igp-metric inherit
将BGP EVPN路由添加到VPN实例路由表时,路由的Metric值变为0。
BGP EVPN地址族视图
配置本命令后,设备将BGP EVPN路由添加到VPN实例的路由表时,VPN实例中的该路由将会继承到达原EVPN路由下一跳的IGP路由的Metric值,即该路由在VPN实例路由表中的IGP Metric值为到达原EVPN路由下一跳的IGP路由的Metric值。
# 在BGP EVPN地址族视图下,配置将BGP EVPN路由添加到VPN实例路由表时,路由的Metric值为到达原EVPN路由下一跳的IGP路由的Metric值。
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] igp-metric inherit
1.1.54  import evpn mac-ip
import evpn mac-ip命令用来配置允许将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表,并允许对外发布。
undo import evpn mac-ip命令用来恢复缺省情况。
import evpn mac-ip
在EVPN VXLAN组网(MAC/IP发布路由中携带VXLAN ID)中,禁止将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表。
在SRv6组网(MAC/IP发布路由中携带SID)中,允许将从对等体/对等体组收到的包含ARP/ND信息的MAC/IP发布路由引入BGP单播路由表,但不允许对外发布。
BGP IPv4单播地址族视图
BGP IPv6 单播地址族视图
BGP-VPN IPv4单播地址族视图
BGP-VPN IPv6单播地址族视图
在BGP IPv4或BGP IPv6单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP/ND信息的MAC/IP发布路由后,会将其添加到公网实例路由表,并发布到本地站点。
在BGP-VPN IPv4或BGP-VPN IPv6单播地址族视图下执行本命令后,设备从对等体/对等体组收到包含ARP/ND信息的MAC/IP发布路由后,会将其添加到VPN实例对应的BGP IPv4或BGP IPv6单播路由表,是否发布到本地站点取决于是否执行命令advertise l2vpn evpn配置允许向本地站点发布BGP EVPN路由。
# 配置将从对等体/对等体组收到的MAC/IP路由引入VPN实例vpna对应的BGP IPv4单播路由表,并允许对外发布。
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4
[Sysname-bgp-default-ipv4-vpna] import evpn mac-ip
1.1.55  import route-policy
import route-policy命令用来配置EVPN的入方向路由策略。
undo import route-policy命令用来恢复缺省情况。
未配置EVPN的入方向路由策略,即如果接收到的路由携带的Route Target属性中存在与本地配置的Import Target相同的值,则接收该路由。
EVPN实例视图
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
VPN实例EVPN视图
route-policy:入方向路由策略名称,为1~63个字符的字符串,区分大小写。
如果在设备上通过本命令指定了EVPN的入方向路由策略,则将BGP EVPN协议的路由引入到EVPN实例或VPN实例时,会利用指定的路由策略对引入的路由进行过滤、改变引入路由的属性等。使用本命令可以更加精确、灵活地控制路由的引入。
EVPN实例视图、VSI实例下的EVPN实例视图、交叉连接组EVPN实例视图、VPN实例视图和VPN实例EVPN视图下配置的入方向路由策略均能用来过滤EVPN路由。其中:
# 在VPN实例vpn1下配置EVPN的入方向路由策略为poly-1。
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
1.1.56  ip public-instance
ip public-instance命令用来创建公网实例,并进入公网实例视图。如果公网实例已经存在,则直接进入公网实例视图。
undo ip public-instance命令用来删除公网实例。
ip public-instance
不存在公网实例。
公网实例用来实现分布式EVPN网关转发公网的三层流量及公私网互通。公网实例可以看作是特殊的VPN实例,分布式EVPN网关对公网实例的处理与VPN实例完全相同。
# 创建公网实例,并进入公网实例视图。
[Sysname] ip public-instance
[Sysname-public-instance]
1.1.57  ipv6 nd ra tunnel-broadcast global enable
ipv6 nd ra tunnel-broadcast global enable命令用来全局开启网关向VXLAN隧道发送RA消息功能。
undo ipv6 nd ra tunnel-broadcast global enable命令用来全局关闭网关向VXLAN隧道发送RA消息功能。
网关向VXLAN隧道发送RA消息功能处于关闭状态。
EVPN分布式网关从VXLAN隧道接收到RS消息后会丢弃该报文,且网关仅周期性地向本地发送RA消息,不会向VXLAN隧道发送RA消息。若VXLAN隧道对端的分布式网关不支持主动向本地发送RA消息,也不支持根据RS消息应答RA消息,就会导致VXLAN隧道对端的设备无法根据RA消息来更新网关信息。开启本功能后,对于从VXLAN隧道接收到的RS消息,网关会应答RA消息,并且网关会周期性地向VXLAN隧道发送RA消息,以保证VXLAN隧道对端的设备能够收到RA消息,并根据该消息来更新网关信息。
# 全局开启网关向VXLAN隧道发送RA消息功能。
[Sysname] ipv6 nd ra tunnel-broadcast global enable
·     ipv6 nd ra interval(三层技术-IP业务命令参考/IPv6邻居发现)
1.1.58  l3-vni
l3-vni命令用来配置L3VNI。
undo l3-vni用来取消配置的L3VNI。
l3-vni vxlan-id
undo l3-vni
未配置L3VNI。
VSI虚接口视图
公网实例视图
vxlan-id:L3VNI,取值范围为0~16777215。
分布式网关组网中,需要在网关上配置L3VNI。在网关之间通过VXLAN隧道转发流量时,属于同一路由域、能够进行三层互通的流量通过L3VNI来标识。
转发某个VPN的三层流量时,需要在与该VPN实例关联的VSI虚接口视图下执行本命令;转发公网的三层流量时,不仅需要在属于公网的VSI虚接口视图下执行本命令,还需要在公网实例视图下执行本命令配置与VSI虚接口相同的L3VNI。
在公网实例视图下,不能通过重复执行本命令修改公网实例的L3VNI。如需修改公网实例的L3VNI,请先通过undo l3-vni命令删除L3VNI,再执行l3-vni命令。
本命令中指定的L3VNI不能与mapping vni命令配置的映射远端VXLAN ID相同。
# 在VSI虚接口100上配置L3VNI为1000。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] l3-vni 1000
1.1.59  mac-advertising disable
mac-advertising disable命令用来配置禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
undo mac-advertising disable命令用来恢复缺省情况。
允许通告MAC地址信息。
EVPN实例视图
VSI实例下的EVPN实例视图
本端VTEP或PE可能会同时向远端设备通告MAC地址信息和ARP信息。其中,ARP信息中已经包含MAC地址信息。为了避免重复,可以执行本命令来禁止本端设备向远端设备通告MAC地址信息。执行本命令后,本端设备还会撤销已经发布的MAC地址信息。
# 配置EVPN实例禁止通告MAC地址信息,并撤销已经通告的MAC地址信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] mac-advertising disable
1.1.60  nd-advertising enable
nd-advertising enable命令用来开启通告ND信息功能。
undo nd-advertising enable命令用来关闭通告ND信息功能,并撤销已经通告的ND信息。
允许通告ND信息。
EVPN实例视图
VSI实例下的EVPN实例视图
在EVPN分布式网关组网中,如果同一个VXLAN内的所有用户终端都部署在同一台EVPN网关下,则EVPN不需要通告该VXLAN的ND信息(同时携带MAC和IPv6地址的MAC/IP发布路由),只需通告IP前缀路由,其他VXLAN内的用户终端通过IP前缀路由即可访问该VXLAN。此时,可以配置本命令禁止EVPN通告ND信息,以减少占用的设备和网络资源。执行本命令后,设备还会撤销已经发布的ND信息。
# 关闭VSI下的EVPN实例通告ND信息功能,并撤销已经通告的ND信息。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] undo nd-advertising enable
1.1.61  nd mac-learning disable
nd mac-learning disable命令用来配置禁止EVPN从ND信息中学习MAC地址表项。
undo nd mac-learning disable命令用来恢复缺省情况。
EVPN可以从ND信息中学习MAC地址表项。
EVPN实例视图
VSI实例下的EVPN实例视图
本端VTEP或PE可能会同时接收到远端设备通告的MAC地址信息和ND信息。其中,ND信息中包含MAC地址信息。为了避免重复,可以在本端设备上执行本命令禁止EVPN从ND信息中学习MAC地址表项,EVPN仅通过MAC地址信息学习远端MAC地址表项。
# 配置禁止EVPN从ND信息中学习MAC地址表项。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] nd mac-learning disable
1.1.62  peer advertise encap-type mpls
peer advertise encap-type mpls命令用来配置向对等体/对等体组发布MPLS封装的EVPN路由。
undo peer advertise encap-type mpls命令用来删除向对等体/对等体组发布MPLS封装的EVPN路由的配置。
peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
undo peer { group name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise encap-type mpls
向对等体/对等体组发布VXLAN封装的EVPN路由。
BGP EVPN地址族视图
ipv4-address:对等体的IPv4地址。指定的对等体必须已经创建。
ipv6-address:对等体的IPv6地址。指定的对等体必须已经创建。
prefix-length:前缀长度,取值范围为0~128。如果指定本参数,则表示指定网段内的动态对等体。
EVPN L3VPN组网中,本功能通常配置在EVPN承载的L3VPN网络的边缘节点和RR(Route Reflector,路由反射器)设备上。在边缘节点上,本功能需要与EVPN通告VPN路由功能配合使用,即在VPN实例IPv4地址族视图/VPN实例IPv6地址族视图下执行命令evpn mpls routing-enable开启EVPN通告VPN路由功能。
# 配置向对等体1.1.1.1发布MPLS封装的EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise encap-type mpls
1.1.63  peer advertise vpn-reoriginate ibgp (BGP EVPN address family view)
peer advertise vpn-reoriginate ibgp命令用来配置以IP前缀路由形式向指定IBGP对等体/对等体组发布VPN实例下重生成的BGP路由。
undo peer advertise vpn-reoriginate ibgp命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise vpn-reoriginate ibgp
undo { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } peer advertise vpn-reoriginate ibgp
不会向IBGP对等体/对等体组发布VPN实例下重生成的BGP路由。
BGP EVPN地址族视图
ipv4-address:对等体的IP地址。指定的对等体组必须已经创建。
本命令必须配合advertise route-reoriginate命令使用。单独配置本命令时,本命令不生效。
配置本命令后,设备将会以IP前缀路由的形式向指定IBGP对等体发布配置了advertise route-reoriginate命令后VPN实例下重生成的路由。
# 在BGP EVPN地址族视图下,配置以IP前缀路由的形式向IBGP对等体1.1.1.1发布VPN实例下重生成的BGP路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise vpn-reoriginate ibgp
·     advertise route-reoriginate(MPLS命令参考/MPLS L3VPN)
1.1.64  peer default-gateway no-advertise
peer default-gateway no-advertise命令用来配置向对等体/对等体组发布EVPN网关路由时不携带Default-gateway扩展团体属性。
undo peer default-gateway no-advertise命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } default-gateway no-advertise
向对等体/对等体组发布EVPN网关路由时会携带Default-gateway扩展团体属性。
BGP EVPN地址族视图
EVPN网关路由是指EVPN网关上VSI虚接口的IP地址对应的路由。缺省情况下,EVPN网关在发布该路由时,会携带Default-gateway扩展团体属性。携带Default-gateway扩展团体属性的多条路由间无法形成等价路由。执行本命令配置EVPN网关在发布网关路由时不携带Default-gateway扩展团体属性,可使多条EVPN网关路由间形成等价路由。
# 在BGP EVPN地址族视图下,配置向对等体1.1.1.1发布EVPN网关路由时不携带Default-gateway扩展团体属性。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 default-gateway no-advertise
1.1.65  peer re-originated
peer re-originated命令用来配置从对等体/对等体组接收到BGP EVPN路由后,修改路由中的信息。
undo peer re-originated命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ imet | mac-ip ] [ replace-rt ]
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] [ replace-rt ] [ replace-sid ]
peer { group-name | ipv4-address [ mask-length ] } re-originated [ s-pmsi | smet ] [ replace-rt ]
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ imet | ip-prefix | mac-ip ]
undo peer { group-name | ipv4-address [ mask-length ] } re-originated [ s-pmsi | smet ]
不修改从对等体/对等体组接收到的EVPN路由的信息。
BGP EVPN地址族视图
imet:指定修改包含性组播以太网标签路由(Inclusive multicast Ethernet tag route)的信息。
ip-prefix:指定修改IP前缀路由的信息。
mac-ip:指定修改MAC/IP发布路由的信息。
s-pmsi:指定修改S-PMSI路由的信息。
smet:指定修改SMET路由的信息。
replace-rt:将EVPN IP前缀路由的L3VNI、RD和RT信息修改为本地VPN实例的L3VNI、RD和RT,并为路由添加MPLS标签/SRv6 SID或在本地RT匹配的VPN实例内重新为路由申请SRv6 SID。如果不指定本参数,则仅修改L3VNI和RD,并添加MPLS标签/SRv6 SID或在本地RT匹配的VPN实例内重新为路由申请SRv6 SID,不修改RT。
replace-sid:接收到BGP EVPN路由且本地存在RT匹配的VPN实例时,删除BGP EVPN路由携带的SRv6 SID,并在本地RT匹配的VPN实例内重新为BGP EVPN路由申请SRv6 SID。如果不指定本参数,则不改变路由的SRv6 SID。
EVPN网络中的应用场景和工作机制
EVPN数据中心互联组网中,在ED上执行本命令后,ED从VTEP或远端ED接收到EVPN路由后,如果路由中的Route Target属性与本地VPN实例的Import Route Target属性匹配,则将路由中的信息修改为本地VPN实例的信息,并将修改后的路由发布给远端ED或VTEP。
通常在以下情况下,可以执行本命令:
·     不同数据中心使用的L3VNI不同,通过本配置修改L3VNI,以实现数据中心之间的互通。
·     不同数据中心互通,需要RT值匹配。当数据中心组网规模较大时,数据中心之间的RT配置比较复杂。配置本命令后,ED可直接修改EVPN路由的RT值,数据中心之间发布EVPN路由使用统一的RT值即可,无需进行复杂的RT配置。
·     用户不希望泄露本地数据中心使用的L3VNI时,可以执行本配置将本地所有L3VNI均替换为ED上的L3VNI,对外仅体现ED上的L3VNI。
SRv6网络中的应用场景和工作机制
在多个AS域内均部署了SRv6的跨域SRv6 VPN网络中,如果要实现跨AS域的用户互通,通常需要将Locator网段路由进行跨域发布(例如将IGP协议发布的Locator网段路由引入到BGP协议中进行跨域发布),将Locator网段路由进行跨域发布后,不同AS域间的PE设备即可以建立起跨域的SRv6转发路径。但是在一些场景中,网络管理员处于安全性考虑,不希望将Locator网段路由信息在AS域间传递。此时网络管理员可以在配置本命令时指定replace-sid参数,通过修改路由携带的SRv6 SID为本地VPN实例的SRv6 SID,使得Locator网段路由无需发布到另一AS域中,不同AS域的PE设备就可以建立起跨域的SRv6转发路径。
注意事项
执行本命令后,ED仅向对等体/对等体组发布修改路由信息后的路由,不会向对等体/对等体组发布源EVPN路由。
如果ED上本地VPN实例的RD与接收到的EVPN路由的RD相同,则不会修改该路由的L3VNI和RT,也不会重生成路由,导致该BGP EVPN路由无法向对等体/对等体组发布。因此,执行本命令时,建议在不同设备上为VPN实例配置不同的RD。
执行本命令时,如果未指定imetip-prefixmac-ips-pmsismet参数,则表示修改IP前缀路由的信息。
# 在BGP EVPN地址族视图下,配置修改从BGP对等体1.1.1.1收到的IP前缀路由的L3VNI和RD。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 re-originated ip-prefix
·     peer advertise original-route
·     peer suppress re-originated
1.1.66  peer suppress original-route
peer suppress original-route命令用来抑制向对等体/对等体组发布源EVPN路由,并撤销已经通告的源路由。
undo suppress original-route命令用来取消该配置。
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress original-route { auto-discovery | es | imet }
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress original-route { auto-discovery | es | imet }
不抑制向对等体/对等体组发布源EVPN路由。
BGP EVPN地址族视图
auto-discovery:抑制向对等体/对等体组发送源以太网自动发现路由。
es:抑制向对等体/对等体组发送源以太网段路由。
imet:抑制向对等体/对等体组发送源包含性组播以太网标签路由。
# 在BGP EVPN地址族视图下,配置抑制向对等体1.1.1.1发送源以太网自动发现路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 suppress original-route auto-discovery
1.1.67  policy vpn-target
policy vpn-target命令用来开启BGP EVPN路由的VPN-Target过滤功能。
undo policy vpn-target命令用来关闭BGP EVPN路由的VPN-Target过滤功能。
policy vpn-target
BGP EVPN路由的VPN-Target过滤功能处于开启状态。
BGP EVPN地址族视图
开启BGP EVPN路由的VPN-Target过滤功能后,设备只将Export Route Target属性与本地Import Route Target属性匹配的BGP EVPN路由加入到BGP EVPN路由表。设备上如需保存所有BGP EVPN路由,则需执行undo policy vpn-target命令,不对BGP EVPN路由进行VPN-Target过滤。
# 关闭BGP EVPN路由的VPN-Target过滤功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
1.1.68  pw-class
pw-class命令用来指定引用的PW模板。
undo pw-class命令用来恢复缺省情况。
pw-class class-name
undo pw-class
未引用PW模板。
EVPN实例视图
VSI实例下的EVPN实例视图
class-name:PW模板名,为1~19个字符的字符串,区分大小写。
MPLS封装方式和SRv6封装方式的EVPN实例均支持本命令。
在VSI实例下的EVPN实例视图下执行本命令指定引用PW模板后,该PW模板将应用于该视图下建立的所有PW。
在EVPN实例视图下执行本命令指定引用PW模板后,该PW模板将应用于与该EVPN实例关联的VSI下建立的所有PW。
多次执行本命令,则最后一次执行的命令生效。
# 在MPLS封装方式的EVPN实例视图下指定引用的PW模板为pw100。
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation mpls
[Sysname-vsi-vpna-evpn-mpls] pw-class pw100
# 在SRv6封装方式的EVPN实例视图下指定引用的PW模板为pw100。
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation srv6
[Sysname-vsi-vpna-evpn-srv6] pw-class pw100
1.1.69  reset evpn route arp-mobility suppression
reset evpn route arp-mobility suppression命令用来取消对ARP迁移的抑制。
reset evpn route arp-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ip ip-address ] ]
public-instance:取消对公网实例内ARP迁移的抑制。
vpn-instance vpn-instance-name:取消对指定VPN实例内ARP迁移的抑制。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ip ip-address:取消对指定IP地址对应ARP的迁移抑制。ip-address表示IPv4地址,为点分十进制格式。如果不指定本参数,则取消对所有ARP迁移的抑制。
执行reset evpn route arp-mobility suppression命令后,设备将取消对指定公网实例或VPN实例内ARP迁移的抑制,对外通告该ARP信息。后续,仍然正常进行迁移抑制,直到关闭ARP反复迁移抑制功能。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则表示取消对公网实例和所有VPN实例内ARP迁移的抑制。
# 取消对VPN实例vpna内IP地址1.1.1.1对应的ARP信息的迁移抑制。
<Sysname> reset evpn route arp-mobility suppression vpn-instance vpna ip 1.1.1.1
1.1.70  reset evpn route mac-mobility suppression
reset evpn route mac-mobility suppression命令用来取消对MAC地址迁移的抑制。
reset evpn route mac-mobility suppression [ evpn-instance instance-name | interface interface-type interface-number  | vsi vsi-name ] [ mac mac-address ]
evpn-instance instance-name:取消对指定EVPN实例内MAC地址迁移的抑制。instance-name实例名称,为1~31个字符的字符串,区分大小写。
interface interface-type interface-number:取消对指定接口上MAC地址迁移的抑制。interface-type interface-number为接口类型和接口编号。
vsi vsi-name:取消对指定VSI内MAC地址迁移的抑制。vsi-name表示VSI实例的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则取消对所有VSI内MAC地址迁移的抑制。
mac mac-address:取消对指定MAC地址的迁移抑制。mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。如果不指定本参数,则取消对所有MAC地址的迁移抑制。
执行reset evpn route mac-mobility suppression命令后,设备将取消对指定VSI内MAC地址迁移的抑制,对外通告该MAC地址。后续,仍然正常进行迁移抑制,直到关闭MAC地址反复迁移抑制功能。
执行本命令时,如果没有指定evpn-instance instance-nameinterface interface-type interface-numbervsi vsi-name参数,则表示取消对所有ARP迁移的抑制。
# 取消对VSI实例vpna内MAC地址1-1-1的迁移抑制。
<Sysname> reset evpn route mac-mobility suppression vsi vpna mac 1-1-1
1.1.71  reset evpn route nd-mobility suppression
reset evpn route nd-mobility suppression命令用来取消对ND迁移的抑制。
reset evpn route nd-mobility suppression [ public-instance | vpn-instance vpn-instance-name [ ipv6 ipv6-address ] ]
public-instance:取消对公网实例内ND迁移的抑制。
vpn-instance vpn-instance-name:取消对指定VPN实例内ND迁移的抑制。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
ipv6 ipv6-address:取消对指定IPv6地址对应ND的迁移抑制。ipv6-address表示IPv6地址。如果不指定本参数,则取消对所有ND迁移的抑制。
执行reset evpn route nd-mobility suppression命令后,设备将取消对指定公网实例或VPN实例内ND迁移的抑制,对外通告该ND信息。后续,仍然正常进行迁移抑制,直到关闭ND反复迁移抑制功能。
执行本命令时,如果没有指定public-instancevpn-instance vpn-instance-name参数,则表示取消对公网实例和所有VPN实例内ND迁移的抑制。
# 取消对VPN实例vpna内IPv6地址1::1对应的ND信息的迁移抑制。
<Sysname> reset evpn route nd-mobility suppression vpn-instance vpna ipv6 1::1
1.1.72  route-distinguisher
route-distinguisher命令用来配置公网实例/EVPN实例的RD(Route Distinguisher,路由标识符)。
undo route-distinguisher命令用来恢复缺省情况。
公网实例视图/交叉连接组EVPN实例视图/EVPN实例视图/VSI实例下的EVPN实例视图(非VXLAN封装):
VSI实例下的EVPN实例视图(VXLAN封装):
route-distinguisher { route-distinguisher | auto }
未指定公网实例/EVPN实例的RD。
EVPN实例视图
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
公网实例视图
route-distinguisher:路由标识符,为3~21个字符的字符串(不允许为全0)。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1
auto:表示自动生成RD。自动生成的RD取值为“N:VXLAN ID”,N为从1开始的整数;如果“N:VXLAN索引”已被使用,则RD取值改为“(N+1):VXLAN ID”,如此反复,直到找到未被使用的RD。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告。本命令指定的RD,携带在MP-BGP协议发布的邻居、MAC地址、主机路由信息中,以标识不同EVPN实例的邻居、MAC地址、主机路由信息。
不能通过重复执行route-distinguisher命令修改RD值。如需修改RD值,请先通过undo route-distinguisher命令删除RD值,再执行route-distinguisher命令配置新的RD值。
# 配置EVPN的RD为22:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
1.1.73  rr-filter
rr-filter命令用来配置路由反射器对反射的EVPN路由进行过滤。
undo rr-filter命令用来恢复缺省情况。
rr-filter { ext-comm-list-number | ext-comm-list-name }
undo rr-filter
路由反射器不会对反射的EVPN路由进行过滤。
BGP EVPN地址族视图
ext-comm-list-number:扩展团体属性列表号,取值范围为1~65535。
ext-comm-list-name:扩展团体属性列表名,为1~63个不全为数字的字符串,区分大小写。
执行本命令后,路由反射器将根据扩展团体属性列表对接收的EVPN路由进行过滤:只有接收的BGP EVPN路由通过扩展团体属性列表过滤时,路由反射器才会反射该EVPN路由。
当一个集群中存在多个路由反射器时,通过在不同的路由反射器上配置不同的反射策略,可以实现路由反射器之间的负载分担。
扩展团体属性列表的详细介绍,请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 配置路由反射器只反射通过扩展团体属性列表10过滤的BGP EVPN路由。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
·     ip extcommunity-list(三层技术-IP路由命令参考/路由策略)
1.1.74  snmp-agent trap enable evpn
snmp-agent trap enable evpn命令用来开启EVPN告警功能。
snmp-agent trap enable evpn [ mac-mobility-suppression ]
undo snmp-agent trap enable evpn [ mac-mobility-suppression ]
EVPN告警功能处于关闭状态。
mac-mobility-suppression:开启MAC迁移抑制告警。
开启EVPN告警功能后,当MAC地址迁移次数达到设置的阈值时会产生告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
执行本命令时,如果未指定任何参数,则表示开启或关闭EVPN的所有告警功能。
# 开启EVPN告警功能。
[Sysname] snmp-agent trap enable evpn
1.1.75  tunnel-policy
tunnel-policy命令用来指定引用的隧道策略。
undo tunnel-policy命令用来恢复缺省情况。
undo tunnel-policy
未引用隧道策略。
EVPN实例视图
VSI实例下的EVPN实例视图
tunnel-policy-name:隧道策略名称,为1~19个字符的字符串,区分大小写。
在VSI实例下的EVPN实例视图下执行本命令指定引用的隧道策略后,与该VSI关联的PW将引用该隧道策略,即根据指定的隧道策略选择承载PW的公网隧道。
在EVPN实例视图下执行本命令指定引用的隧道策略后,与该EVPN实例关联的VSI下的PW将引用该隧道策略。
如果未引用隧道策略或者引用的隧道策略尚未配置,则PW根据缺省选择策略来选择公网隧道。缺省选择策略为按照LSP隧道->GRE隧道->CRLSP->SRLSP隧道的优先级顺序选择隧道,负载分担的隧道数目为1。
多次执行本命令,则仅最后一次执行的生效。
# 在VSI实例下的EVPN实例视图下指定引用的隧道策略为policy1。
[Sysname] vsi aa
[Sysname-vsi-aa] evpn encapsulation mpls
[Sysname-vsi-aa-evpn-mpls] tunnel-policy policy1
1.1.76  vpn-route cross multipath
vpn-route cross multipath命令用来开启VPN引入等价路由功能。
undo vpn-route cross multipath命令用来关闭VPN引入等价路由功能。
VPN引入等价路由功能处于关闭状态,对于前缀和RD均相同的多条路由,只会将最优路由引入到BGP EVPN路由表中。
BGP EVPN地址族视图
开启VPN引入等价路由功能后,BGP将前缀和RD均相同的多条路由全部引入到BGP EVPN路由表中。
# 开启VPN引入等价路由功能。
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
1.1.77  vpn-target
vpn-target命令用来配置EVPN的Route Target属性。
undo vpn-target命令用来删除指定的Route Target属性。
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
VPN实例EVPN视图/公网实例视图/公网实例IPv4地址族视图/公网实例IPv6地址族视图/公网实例EVPN视图/交叉连接组EVPN实例视图/VSI实例下的EVPN实例视图(非VXLAN封装)/EVPN实例视图:
未指定EVPN的Route Target属性。
EVPN实例视图
VSI实例下的EVPN实例视图
交叉连接组EVPN实例视图
VPN实例EVPN视图
公网实例视图
公网实例IPv4地址族视图
公网实例IPv6地址族视图
公网实例EVPN视图
vpn-target&<1-8>:Route Target属性值,vpn-target为3~21个字符的字符串。&<1-8>表示前面的参数最多可以输入8次。Route Target有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
auto:表示自动生成RT。自动生成的RT取值为“BGP AS:VXLAN ID”。
both:指定配置的Route Target值同时作为Import Target和Export Target。没有指定bothexport-extcommunityimport-extcommunity中的任何一个参数时,缺省值为both
export-extcommunity:指定配置的Route Target值为Export Target。
import-extcommunity:指定配置的Route Target值为Import Target。
all:所有Route Target值。
EVPN采用MP-BGP协议进行邻居自动发现、MAC地址通告、主机路由通告等。本地设备在通过MP-BGP的Update消息将BGP EVPN路由发送给远端设备时,将Update消息中携带的VPN target属性设置为Export target。远端设备接收到BGP EVPN路由后,将该路由中携带的Export Target属性与本地配置的Import Target进行比较,如果二者中存在相同的值,则接收该信息。
重复执行本命令,Route Target值为多次配置结果的集合。
# 配置EVPN的Import Target为10:1、100:1和1000:1。
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
