24-对象组命令
本章节下载: 24-对象组命令 (317.49 KB)
1.1.3 display object-group host
1.1.4 display object-group kernel
1.1.5 display object-group notify-list
1.1.6 display object-group query
1.1.7 network (IPv4 address object group view)
1.1.8 network (IPv6 address object group view)
1.1.9 network exclude (IPv4 address object group view)
1.1.10 network exclude (IPv6 address object group view)
1.1.15 port (port object group view)
1.1.17 service(service object group view)
description命令用来配置对象组的描述信息。
undo description命令用来恢复缺省情况。
对象组未配置任何描述信息。
对象组视图
context-admin
text:表示对象组的描述信息,为1~127个字符的字符串,区分大小写。
# 配置对象组的描述信息为“This is an IPv4 object-group”。
[Sysname] object-group ip address ipgroup
[Sysname-obj-grp-ip-ipgroup] description This is an IPv4 object-group
display object-group命令用来显示对象组的内容。
display object-group [ { { ip | ipv6 } { address | address-yundi } | mac-address | port | service | service-yundi } [ default ] [ name object-group-name ] | name object-group-name ]
context-admin
context-operator
ip address:指定对象组类型为IPv4地址对象组。
ipv6 address:指定对象组类型为IPv6地址对象组。
ip address-yundi:指定对象组类型为云堤场景IPv4地址对象组。
ipv6 address-yundi:指定对象组类型为云堤场景IPv6地址对象组。
mac-address:指定对象组类型为MAC地址对象组。
service:指定对象组类型为服务对象组。
service-yundi:指定对象组类型为云堤场景服务对象组。
default:指定默认对象组。
object-group-name:对象组的名称,为1~63个字符的字符串,不区分大小写。
# 显示所有对象组。
<Sysname> display object-group
IP address object group obj1: 0 object(in use)
IP address object group obj2: 6 objects(out of use)
0 network host address 1.1.1.1
object 0 description this is a description for object 0
10 network host name host
object 10 description this is a description for object 10
20 network subnet 1.1.1.1 255.255.255.0
30 network range 1.1.1.1 1.1.1.2
40 network group-object obj1
50 network user-group group1
60 network host name dns1 vpn-instance vpn1
70 network exclude range 2.2.2.2 3.3.3.3
IPv6 address object-group obj3: 0 object(in use)
IPv6 address object-group obj4: 5 objects(out of use)
0 network host address 1::1:1
20 network subnet 1::1:0 112
30 network range 1::1:1 1::1:2
40 network group-object obj3
50 network host name dns2 vpn-instance vpn2
60 network exclude range 2::2:2 3::3:3
Service object-group obj5: 0 object(in use)
Service object-group obj6: 6 objects(out of use)
0 service 200
10 service tcp source lt 50 destination range 30 40
20 service udp source range 30 40 destination gt 30
30 service icmp 20 20
40 service icmpv6 20 20
50 service group-object obj5
MAC object-group obj7: 0 object(in use)
MAC object-group obj8: 2 objects(out of use)
0 MAC address 0010-dc28-11ac
10 MAC group-object obj7
# 显示名称为obj2的对象组。
<Sysname> display object-group name obj2
IP address object-group obj2: 5 objects(out of use)
50 network host name a1 vpn-instance v1
60 network exclude range 2.2.2.2 3.3.3.3
# 显示所有IPv4地址对象组。
<Sysname> display object-group ip address
IP address object-group obj1: 0 object(in use)
50 network exclude range 2.2.2.2 3.3.3.3
# 显示名称为obj4的IPv6地址对象组。
<Sysname> display object-group ipv6 address name obj4
50 network host name host vpn-instance vpn1
表1-1 display object-group命令显示信息描述表
in use |
表明此对象组被引用,包括被ACL引用或被对象组嵌套引用 |
out of use |
表明此对象组没有被引用 |
display object-group host命令用来显示主机名对应IP地址的相关信息。
display object-group { ip | ipv6 } host { all | object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ slot slot-number ]
context-admin
context-operator
ip:指定对象组类型为IPv4地址对象组。
ipv6:指定对象组类型为IPv6地址对象组。
all:指定对象组中所有主机名配置及主机名对应IP地址的相关信息。
object-group-name object-group-name:指定对象组的名称。为1~63个字符的字符串,不区分大小写。不指定该参数时,显示某一个对象组中指定主机名或排除主机名的对应IP地址。
name host-name:指定主机名称。host-name表示主机名称,为1~253字符,不区分大小写。不指定该参数时,显示指定对象组中所有主机名和排除主机名的对应IP地址。
vpn-instance vpn-instance-name:指定主机所属的VPN。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定此参数,则表示指定公网的主机名称。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示所有成员设备。
# 显示名称为group1的IPv4地址对象组中a.example.com主机名对应的地址。
<Sysname> display object-group ip host object-group-name group1 name a.example.com
Object group : group1
Object ID : 0
Host name : a.example.com
VPN instance : -
Updated at : 2019-05-20 11:04:24
IP addresses :
169.0.0.10
169.0.0.11
# 显示名称为group1的IPv6地址对象组中所有主机名和排除主机名对应的地址。
<Sysname> display object-group ipv6 host object-group-name group1
Object ID : 0
VPN instance : -
IP addresses :
169:0::0:10
169:0::0:11
Object ID : 10
Host name : b.example.com
VPN instance : -
IP addresses :
169:0::0:11
169:0::0:12
# 显示所有IPv4地址对象组中主机名及主机名对应的地址。
<Sysname> display object-group ip host all
All host names : 3
Object group : group1 (Total host names : 1)
Object ID : 0
VPN instance : -
IP addresses : 2
169.0.0.10
169.0.0.11
Object group : group2 (Total host names : 2)
Object ID : 10
VPN instance : -
IP addresses : 2
169.0.0.11
169.0.0.12
Host name : c.example.com
VPN instance : -
IP addresses : 2
169.0.0.11
169.0.0.12
表1-2 display object-group host命令显示信息描述表
All host names |
主机名配置总数 |
Object group |
对象组的名称 |
Object ID |
对象的ID |
Host name |
主机的名称 |
VPN instance |
主机所属的VPN |
Updated at |
最后一次更新该主机名对应IP地址的时间 |
IP addresses |
该主机名对应的IP地址 |
· object-group
display object-group kernel命令用来显示内核主机名对应IP地址的相关信息。
display object-group kernel { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ slot slot-number ]
context-admin
context-operator
name host-name:指定主机名称。host-name表示主机名称,为1~60字符,不区分大小写。不指定该参数时,显示指定对象组中所有主机名和排除主机名的对应IP地址。
vpn-instance vpn-instance-name:指定主机所属的VPN。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定此参数,则显示公网和所有VPN中主机名对应的IP地址。
slot slot-number:指定成员设备。slot-number为设备在IRF中的成员编号。如果不指定本参数,则表示所有成员设备。对于本产品,slot-number只能为固定取值,无论是否指定本参数,均表示整台设备。
<Sysname> display object-group kernel ip host object-group-name group1 name a.example.com
Object ID : 0
VPN instance : -
IP addresses :
169.0.0.10
169.0.0.11
表1-3 display object-group kernel命令显示信息描述表
Object group |
对象组的名称 |
Object ID |
对象的ID |
Host name |
主机的名称 |
VPN instance |
主机所属的VPN |
Updated at |
IP addresses |
该主机名对应的IP地址 |
· object-group
display object-group notify-list命令用来显示对象组等待外部模块回应的信息。
display object-group notify-list [ slot slot-number ]
context-admin
context-operator
# 显示对象组等待外部模块回应的信息。
<Sysname> display object-group notify-list
Node 1, vsys ID: 1, socket ID: 50, wait: False;
Node 2, vsys ID: 1, socket ID: 50, wait: False;
表1-4 display object-group notify-list命令显示信息描述表
Vsys ID |
虚拟系统ID |
Socket ID |
套接字的ID |
Wait |
是否正在等待应答: · True表示正在等待应答 · Fasle表示不在等待应答 |
display object-group query命令用来查询指定IP地址所属的地址对象组信息。
display object-group query { ip ip-address | ipv6 ipv6-address } [ object-group object-group-name ] [ verbose ]
ip ip-address:指定查询的IPv4地址。
ipv6 ipv6-address:指定查询的IPv6地址。
object-group object-group-name:指定对象组的名称。为1~63个字符的字符串,不区分大小写。不指定该参数时,显示所有包含要查询地址的对象组。
verbose:显示包含指定查询地址的对象组详细的对象内容。不指定该参数时,只显示包含指定查询地址所在地址对象组组名及满足条件的对象个数。
# 显示所有包含1.2.3.4地址信息的对象组及对象个数。
<Sysname> display object-group query ip 1.2.3.4
group-name Object hits
Group1 3
Group2 4
# 显示所有包含1.2.3.4地址信息的对象组及对象的详细信息。
<Sysname> display object-group query ip 1.2.3.4 verbose
Ip address object group group1:
20 network host address 1.2.3.4
30 network range 1.1.1.1 2.1.1.2
40 network subnet 1.2.3.0 255.255.255.0
Ip address object group group2:
20 network group-object group1
# 查询在指定对象组Group4内包含1.2.3.4地址的对象的详细信息。
<Sysname> display object-group query ip 1.2.3.4 object-group group4 verbose
Ip address object group group4
# 查询在指定对象组Group5内包含2:2::2:2地址的对象的详细信息。
<Sysname> display object-group query ipv6 2:2::2:2 object-group group5 verbose
Ipv6 address object-group Group5:
10 network host address 2:2::2:2
表1-5 display object-group query 命令显示信息描述表
group-name |
对象组的名称 |
Object hits |
符合条件的地址对象个数 |
network命令用来创建一个IPv4地址对象。
undo network命令用来删除指定的IPv4地址对象。
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo network { all | host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo object-id
不存在IPv4地址对象。
IPv4地址对象组视图
context-admin
object-id:指定对象ID,取值范围为0~4294967294。若未指定本参数,系统将按照步长10从0开始,自动分配一个大于现有最大ID的最小ID。譬如现有对象的最大ID为22,那么自动分配的新ID将是30。
host:指定主机IPv4地址或主机名称。
address ip-address:指定主机IPv4地址。
name host-name:指定主机名称。host-name表示主机名称,为1~253字符,不区分大小写。支持模糊匹配主机名称,输入方式为*abc*或者*abc或者abc*,三种方式均表示主机名中包含指定的字符串即可。主机名称中间不能带“*”号。若输入的主机名中不存在“*”号,则表示精确匹配所配置的主机名。
subnet ip-address { mask-length | mask | wildcard wildcard }:指定子网IPv4地址。mask-length表示子网掩码长度,即掩码中连续“1”的个数,取值范围为0~32。mask表示接口IPv4地址相应的子网掩码,为点分十进制格式。wildcard wildcard表示IPv4地址的通配符掩码(为0表示主机地址)。
range ip-address1 ip-address2:指定范围IPv4地址。ip-address1表示范围起始IPv4地址。ip-address2表示范围结束IPv4地址。
group-object object-group-name:指定引用IPv4地址对象组。object-group-name表示IPv4地址对象组名称,为1~63字符,不区分大小写。
user user-name:指定用户名称,为1~55字符,区分大小写。
user-group user-group-name:指定用户组名称,为1~32字符,不区分大小写。
domain domain-name:表示用户和用户组所属的身份识别域。domain-name是身份识别域的名称,为1~255个字符的字符串,不区分大小写,不能包括字符“?”。若不指定此参数,则表示用户和用户组不属于任何身份识别域。
all:删除IPv4地址对象组内所有IPv4地址对象。
创建对象时指定ID,如果指定ID的对象不存在,则创建一条新的对象;如果指定ID的对象已存在,则对原对象进行修改。
新创建或修改的对象不能与已有对象的内容完全相同,否则该命令执行失败,并提示出错。
在配置subnet参数时,如果指定mask-length为32或者mask为255.255.255.255,则该配置被视为主机地址对象配置。
在配置range参数时,如果指定的ip-address1比ip-address2大,会自动调整范围为[ ip-address2, ip-address1 ]。
在配置group-object参数时,需要注意的是:
· 如果指定名称的对象组不存在,则系统会创建此名称的IP地址对象组。
· 如果指定名称的对象组存在,则对象组类型必须为IPv4地址对象组。
· 引用的IPv4地址对象组不能形成循环,譬如IP地址对象组a引用IPv4地址 对象组b,则IP地址对象组b不能再引用IP地址对象组a。
· 引用的IPv4地址对象组最大嵌套层次为5层,譬如IP地址对象组1、2、3、4分别引用IP地址对象组2、3、4、5,则IP地址对象组5不能再引用其他IPv4地址对象组,IP地址对象组1也不能再被其他IP地址对象组引用。
# 配置地址为192.168.0.1的IPv4主机地址对象。
[Sysname-obj-grp-ip-ipgroup] network host address 192.168.0.1
# 配置匹配主机名称为pc3的IPv4主机地址对象。
[Sysname-obj-grp-ip-ipgroup] network host name pc3
# 配置模糊匹配主机名称为abc的IPv4主机地址对象。
[Sysname] object-group ip address ipgroup1
[Sysname-obj-grp-ip-ipgroup1] network host name *abc*
# 配置地址为192.167.0.0,掩码长度为24的IPv4子网地址对象。
[Sysname-obj-grp-ip-ipgroup] network subnet 192.167.0.0 24
# 配置地址为192.166.0.0,掩码为255.255.0.0的IPv4子网地址对象。
[Sysname-obj-grp-ip-ipgroup] network subnet 192.166.0.0 255.255.0.0
# 配置地址范围为192.165.0.100到192.165.0.200的IPv4范围地址对象。
[Sysname-obj-grp-ip-ipgroup] network range 192.165.0.100 192.165.0.200
# 配置引用ipgroup2对象组的地址对象。
[Sysname-obj-grp-ip-ipgroup] network group-object ipgroup2
# 配置地址为192.168.x.1的不连续地址(通配符地址)对象,x表示的地址内容可变。
[Sysname-obj-grp-ip-ipgroup] network subnet 192.168.0.1 wildcard 0.0.255.0
# 配置引用用户名为user1,身份识别域为domain1的用户。
[Sysname-obj-grp-ip-ipgroup] network user user1 domain domain1
# 配置引用用户组名为usergroup1,身份识别域为domain1的用户组。
[Sysname-obj-grp-ip-ipgroup] network user-group usergroup1 domain domain1
network命令用来创建一个IPv6地址对象。
undo network命令用来删除指定的IPv6地址对象。
[ object-id ] network { host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo network { all | host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo object-id
不存在IPv6地址对象。
IPv6地址对象组视图
context-admin
host:指定主机IPv6地址或主机名称。
address ipv6-address:指定主机IPv6地址。
subnet ipv6-address prefix-length:指定子网IPv6地址。prefix-length:指定IPv6地址的前缀长度,取值范围为0~128。
range ipv6-address1 ipv6-address2:指定范围IPv6地址。ipv6-address1表示范围起始IPv6地址。ipv6-address2表示范围结束IPv6地址。
group-object object-group-name:指定引用IPv6地址对象组。object-group-name表示IPv6地址对象组名称,为1~63字符,不区分大小写。
all:删除IPv6地址对象组内所有IPv6地址对象。
在配置subnet参数时,如果指定掩码长度为128,则该配置被视为主机地址对象配置。
在配置range参数时,如果指定的ipv6-address1比ipv6-address2大,会自动调整范围为[ ipv6-address2, ipv6-address1 ]。
· 如果指定名称的对象组不存在,则系统会创建此名称的IPv6地址对象组。
· 如果指定名称的对象组存在,则对象组类型必须为IPv6地址对象组。
· 引用的IPv6地址对象组不能形成循环,譬如IPv6地址对象组a引用IPv6地址对象组b,则IPv6地址对象组b不能再引用IPv6地址对象组a。
· 引用的IPv6地址对象组最大嵌套层次为5层,譬如IPv6地址对象组1、2、3、4分别引用IPv6地址对象组2、3、4、5,则IPv6地址对象组5不能再引用其他IPv6地址对象组,IPv6地址对象组1也不能再被其他IPv6地址对象组引用。
# 配置地址为1::1的IPv6主机地址对象。
[Sysname] object-group ipv6 address ipv6group
[Sysname-obj-grp-ipv6-ipv6group] network host address 1::1
# 配置匹配主机名称为pc3的IPv6主机地址对象。
[Sysname-obj-grp-ipv6-ipv6group] network host name pc3
# 配置模糊匹配主机名称为abc的IPv6主机地址对象。
[Sysname] object-group ipv6 address ipv6group1
[Sysname-obj-grp-ipv6-ipv6group1] network host name *abc*
# 配置地址为1:1:1::1,前缀长度为24的IPv6子网地址对象。
[Sysname-obj-grp-ipv6-ipv6group] network subnet 1:1:1::1 24
# 配置地址范围为1:1:1::1到1:1:1::100 的IPv6范围地址对象。
[Sysname-obj-grp-ipv6-ipv6group] network range 1:1:1::1 1:1:1::100
# 配置引用ipv6group2对象组的地址对象。
[Sysname-obj-grp-ipv6-ipv6group] network group-object ipv6group2
[Sysname-obj-grp-ipv6-ipv6group] network user user1 domain domain1
[Sysname-obj-grp-ipv6-ipv6group] network user-group usergroup1 domain domain1
network exclude命令用来配置地址对象中排除的IPv4地址。
undo network exclude命令用来恢复缺省情况。
object-id network exclude ip-address
undo object-id network exclude ip-address
地址对象中不存在排除的IPv4地址。
IPv4地址对象组
context-admin
object-id:指定对象ID,取值范围为0~4294967294,此对象ID必须已存在。
ip-address:表示地址对象中排除的IPv4地址。
多次执行本命令,可在某个地址对象中排除多个IPv4地址,但之间不允许存在重叠,否则无法配置成功。
# 配置地址为192.166.0.0,掩码为255.255.0.0的IPv4子网地址对象,并配置此地址对象排除的IPv4地址为192.166.0.10。
[Sysname-obj-grp-ip-ipgroup] 10 network subnet 192.166.0.0 255.255.0.0
[Sysname-obj-grp-ip-ipgroup] 10 network exclude 192.166.0.10
network exclude命令用来配置地址对象中排除的IPv6地址。
object-id network exclude ipv6-address
undo object-id network exclude ipv6-address
地址对象中不存在排除的IPv6地址。
IPv6地址对象组
context-admin
ipv6-address:表示地址对象中排除的IPv6地址。
多次执行本命令,可在某个地址对象中排除多个IPv6地址,但之间不允许存在重叠,否则无法配置成功。
# 配置地址为1:1:1::1,前缀长度为24的IPv6子网地址对象,并配置此地址对象排除的IPv6地址为1:1:1::10。
[Sysname-obj-grp-ipv6-ipv6group] 10 network subnet 1:1:1::1 24
[Sysname-obj-grp-ipv6-ipv6group] 10 network exclude 1:1:1::10
object description命令用来配置对象的描述信息。
undo object description命令用来恢复缺省情况。
object object-id description text
undo object object-id description
对象未配置任何描述信息。
对象组视图
context-admin
text:表示对象的描述信息,为1~127个字符的字符串,区分大小写。
# 配置对象0的描述信息为“This is a description for object 0”。
[Sysname-obj-grp-ip-ipgroup] 0 network host address 1.2.3.4
[Sysname-obj-grp-ip-ipgroup] object 0 description This is a description for object 0
object-group命令用来创建一个对象组,并进入对象组视图。如果指定的对象组已经存在且类型一致,则直接进入对象组视图。
undo object-group命令用来删除指定的对象组。
object-group { { ip | ipv6 } { address | address-yundi } | mac-address | port | service | service-yundi } object-group-name
undo object-group { { ip | ipv6 } { address | address-yundi } | mac-address | port | service | service-yundi } object-group-name
存在系统默认对象组。
context-admin
ip address:指定对象组类型为IP地址对象组。
object-group-name:对象组的名称,为1~63个字符的字符串,不区分大小写,且对象组的名称必须全局唯一。
在配置object-group命令时,需要注意的是:
· 如果指定名称的对象组不存在,则创建对象组并进入其视图。
· 如果指定名称的对象组存在但类型不一致,命令执行失败,并提示出错。
在配置undo object-group命令时,需要注意的是:
· 如果指定名称的对象组不存在,处理结束。
· 如果指定名称的对象组存在但类型不一致,则命令执行失败,并提示出错。
· 要删除的对象组被ACL或者其他对象组引用,命令执行失败,并提示出错。
· 系统默认对象组不能被删除。
云堤场景类型的对象组仅可引用其他已创建的对象组,不可创建对象。
# 配置名称为ipgroup的IP地址对象组。
# 配置名称为ipv6group的IPv6地址对象组。
# 创建名称为groupmac的MAC地址对象组。
[Sysname] object-group mac-address groupmac
# 配置名称为servicegroup的服务对象组。
[Sysname] object-group service servicegroup
# 配置名称为ipyundi的云堤场景IP地址对象组。
[Sysname] object-group ip address-yundi ipyundi
#配置名称为ipv6yundi的云堤场景IPv6地址对象组。
[Sysname] object-group ipv6 address-yundi ipv6yundi
# 配置名称为serviceyundi的云堤场景服务对象组。
[Sysname] object-group service-yundi serviceyundi
object-group dns-aging命令用来开启主机名对应IP地址的老化功能。
undo object-group dns-aging命令用来关闭主机名对应IP地址的老化功能。
object-group dns-aging [ time aging-time ]
主机名对应IP地址的老化功能处于关闭状态。
context-admin
time aging-time:主机名对应IP地址的老化时间,取值范围为1~70000000,单位为分钟,缺省值为120。
在同一主机名对应多个IP地址的负载均衡场景中,DNS解析主机名获得的IP地址会在多个IP地址之间进行不断切换。缺省情况下,每次切换,对象组模块都会通告相关策略(如安全策略)变更IP地址,会造成相关策略频繁提交加速,大量耗费设备内存,此时可通过开启主机名对应IP地址的老化功能解决此问题。
开启本功能后,对象组会针对每个主机名维护一个IP地址组:
· 当通过DNS解析该主机名获得的IP地址不在该组内,会将新的IP地址添加至组内,并将该组新的IP地址范围告知相关策略。新的IP地址在对象组中的老化时间为本命令配置的老化时间。
· 当获得的IP地址在该组内,则不会告知相关策略,并更新对象组内该IP地址的老化时间。
· 若组内某个IP地址达到老化时间,则会将其从组内删除,并告知相关策略。从而减少相关策略加速次数,降低设备内存占用。
建议所配置主机名对应IP地址的老化时间大于DNS服务器上生效的域名解析表项的有效时间(可通过dns cache ttl命令调整)。
# 配置主机名对应IP地址的老化时间为5分钟。
[Sysname] object-group dns-aging
[Sysname] object-group dns-aging time 5
object-group rename命令用来重命名对象组。
object-group rename old-object-group-name new-object-group-name
context-admin
old-object-group-name:被重命名对象组的名称,为1~63个字符的字符串,不区分大小写。
new-object-group-name:重命名后的对象组名称,为1~63个字符的字符串,不区分大小写,且对象组的名称必须全局唯一。
只能对用户创建的对象组进行重命名,系统缺省的对象组不能被重命名。
# 重命名IPv4地址对象组ipgroup1的名称为ipgroup2。
[Sysname] object-group rename ipgroup1 ipgroup2
· object-group
port命令用来创建一个端口对象。
undo port命令用来删除指定的端口对象。
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
undo port { all | { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
undo object-id
不存在端口对象。
端口对象组视图
context-admin
eq:等于指定的端口号。
lt:小于指定的端口号。
gt:大于指定的端口号。
port:指定端口号,取值范围为0~65535。
range port1 port2:指定端口在两个端口号范围内。port1表示起始端口号,取值范围为0~65535。port2表示结束端口号,取值范围为0~65535。
group-object object-group-name:指定引用端口对象组。object-group-name表示端口对象组的名称,为1~63字符,不区分大小写。
all:删除端口对象组内所有端口对象。
使用group-object关键字,如果指定名称的对象组不存在,则系统会创建此名称的端口对象组;如果指定名称的对象组存在,则对象组类型必须为端口对象组。
引用的端口对象组不能形成循环,譬如端口对象组a引用端口对象组b,则端口对象组b不能再引用端口对象组a。
引用的端口对象组最大嵌套层次为5层,譬如端口对象组1、2、3、4分别引用端口对象组2、3、4、5,则端口对象组5不能再引用其他端口对象组,端口对象组1也不能再被其他端口对象组引用。
创建对象时指定ID,如果指定ID的对象不存在,则创建一条新的对象;如果指定ID的对象已存在,则对旧对象进行修改。
在配置lt参数时,需要注意的是:
· 不能指定port为0。
· 如果指定port为1,则该配置被视为eq 0。
· 如果指定port为2~65535,则实际生效的端口号为[ 0, port-1 ]。
在配置gt参数时,需要注意的是:
· 不能指定port为65535。
· 如果指定port为65534,该配置被视为eq 65535。
· 如果指定port为0~65533,则实际生效的端口号为[ port+1, 65535 ]。
在配置range参数时,需要注意的是:
· 如果指定的port1和port2相同,则该配置被视为等于指定的端口号。
· 如果指定port1为0,则该配置被视为lt配置,譬如配置range 0 999,被视为lt 1000。
· 如果指定port2为65535,则该配置被视为gt配置,譬如配置range 50001 65535,被视为gt 50000。
· 如果指定的port1比port2大,会自动调整范围为[ port2, port1 ]。
# 配置端口号等于100的端口对象。
[Sysname] object-group port portgroup
[Sysname-obj-grp-port-portgroup] port eq 100
# 配置端口号小于20的端口对象。
[Sysname-obj-grp-port-portgroup] port lt 20
# 配置端口号大于60000的端口对象。
[Sysname-obj-grp-port-portgroup] port gt 60000
# 配置端口号范围为1000到2000的端口对象。
[Sysname-obj-grp-port-portgroup] port range 1000 2000
# 配置引用portgroup2对象组的端口对象。
[Sysname-obj-grp-port-portgroup] port group-object portgroup2
security-zone命令用来配置地址对象组所属的安全域。
undo security-zone命令用来恢复缺省情况。
security-zone security-zone-name
未配置地址对象组所属的安全域。
IPv4地址对象组
IPv6地址对象组
context-admin
security-zone-name:安全域的名称,为1~31个字符的字符串,不区分大小写,不能包含字符“-”,不能是字符串“any”。
将地址对象组加入安全域后,在使用Web方式配置安全策略的源/目的IP地址过滤条件时,只能从属于此次安全域和不属于任何安全域的地址对象组中选取,可达到快速选择地址对象组的目的。
一个对象组只能属于一个安全域。
# 配置IPv4地址对象组1所属的安全域为Local。
[Sysname] object-group ip address 1
[Sysname-obj-grp-ip-1] security-zone Local
· object-group
service命令用来创建一个服务对象。
undo service命令用来删除指定的服务对象。
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
undo service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name | all }
undo object-id
不存在服务对象。
服务对象组视图
context-admin
protocol:协议类型,可输入的形式如下:
· 数字:取值范围为0~255;
· 名称:可选取tcp(6)、udp(17)、sctp(132)、icmp(1)或icmpv6(58)。
source:指定源端口。只在protocol为tcp、udp或sctp时有效。
destination:指定目的端口。只在protocol为tcp、udp或sctp时有效。
eq:等于指定的端口号。
lt:小于指定的端口号。
gt:大于指定的端口号。
range port1 port2:在指定的两个端口号范围内。port1表示端口号1,取值范围为0~65535。port2表示端口号2,取值范围为0~65535。
icmp-type:ICMP消息类型,取值范围为0~255,只在protocol为icmp时有效。
icmp-code:ICMP消息码,取值范围为0~255。
icmpv6-type:ICMPv6消息类型,取值范围为0~255,只在protocol为icmpv6时有效。
icmpv6-code:ICMPv6消息码,取值范围为0~255。
group-object:指定引用服务对象组。object-group-name表示服务对象组名称,为1~63字符,不区分大小写。
all:删除服务对象组内所有服务对象。
在配置lt参数时,需要注意的是:
· 不能指定port为0。
· 如果指定port为1~65535,则实际生效的端口号为[ 0, port-1 ]。
在配置gt参数时,需要注意的是:
· 不能指定port为65535。
· 如果指定port为0~65534,则实际生效的端口号为[ port+1, 65535 ]。
在配置range参数时,如果指定的port1比port2大,会自动调整范围为[ port2, port1 ]。
· 如果指定名称的对象组不存在,则系统会创建此名称的服务对象组。
· 如果指定名称的对象组存在,则对象组类型必须为服务对象组。
· 引用的服务对象组不能形成循环,譬如服务对象组a引用服务对象组b,则服务对象组b不能再引用服务对象组a。
· 引用的服务对象组最大嵌套层次为5层,譬如服务对象组1、2、3、4分别引用服务对象组2、3、4、5,则服务对象组5不能再引用其他服务对象组,服务对象组1也不能再被其他服务对象组引用。
# 配置协议号等于100的服务对象。
[Sysname-obj-grp-service-servicegroup] service 100
# 配置指定源端口和目的端口的tcp协议报文的服务对象。
[Sysname-obj-grp-service-servicegroup] service tcp source eq 100 destination range 10 100
# 配置icmp协议的服务对象。
[Sysname-obj-grp-service-servicegroup] service icmp 100 150
# 配置引用servicegroup2对象组的服务对象。
[Sysname-obj-grp-service-servicegroup] service group-object servicegroup2
yundi alias命令用来配置云堤组网场景对象组的别名和所属租户的ID。
undo yundi alias命令用来恢复缺省情况。
yundi alias alias tenant tenant-id
undo yundi alias alias tenant tenant-id
不存在对象组所属租户的ID和别名。
对象组视图。
context-admin
alias:表示对象组的别名,为1~63个字符的字符串,不区分大小写。
tenant tenant-id:表示对象组所属租户的ID,为1~63个字符的字符串,不区分大小写。
在云堤组网场景中,租户在控制器上创建对象组,然后由控制器向设备下发配置。别名和租户ID分别用于标识租户创建对象组时指定的名称和该租户的ID,通常由控制器下发,因此不建议在设备上手工设置本功能。
# 为IPv4地址对象组ipgroup配置别名和租户ID分别为alias1和tenant1。
[Sysname-obj-grp-ip-ipgroup] yundi alias alias1 tenant tenant1
