03-安全命令参考
23-安全策略命令
本章节下载 23-安全策略命令  (663.83 KB)
23-安全策略命令
  录
1 安全策略
1.1 安全策略配置命令
1.1.1 accelerate enhanced enable
1.1.2 action
1.1.3 any-vrf enable
1.1.4 app-group
1.1.5 application
1.1.6 counting enable
1.1.7 description (security-policy rule view)
1.1.8 description (security-policy view)
1.1.9 destination-ip
1.1.10 destination-ip-host (IPv4 security policy view)
1.1.11 destination-ip-host (IPv6 security policy view)
1.1.12 destination-ip-range (IPv4 security policy view)
1.1.13 destination-ip-range (IPv6 security policy view)
1.1.14 destination-ip-subnet (IPv4 security policy view)
1.1.15 destination-ip-subnet (IPv6 security policy view)
1.1.16 destination-microsegment
1.1.17 destination-zone
1.1.18 disable
1.1.19 display security-policy
1.1.20 display security-policy statistics
1.1.21 display security-policy ip query
1.1.22 display security-policy ipv6 query
1.1.23 group move
1.1.24 group name
1.1.25 group rename
1.1.26 learning enable
1.1.27 logging enable
1.1.28 move rule
1.1.29 move rule name
1.1.30 parent-group
1.1.31 profile
1.1.32 reset security-policy automatic-deploy records
1.1.33 reset security-policy learning-records
1.1.34 reset security-policy statistics
1.1.35 rule
1.1.36 rule rename
1.1.37 security-policy
1.1.38 security-policy automatic-deploy internet-zone-list
1.1.39 security-policy automatic-deploy ipv4-agg-mask
1.1.40 security-policy automatic-deploy ipv6-agg-prefix
1.1.41 security-policy automatic-deploy learning-time
1.1.42 security-policy automatic-deploy server-zone-list
1.1.43 security-policy config-logging send-time
1.1.44 security-policy disable
1.1.45 security-policy object-strict-inspection enable
1.1.46 security-policy rules counting
1.1.47 security-policy rules mandatory-item-control
1.1.48 security-policy show-default-action enable
1.1.49 service
1.1.50 service-port
1.1.51 session aging-time
1.1.52 session persistent aging-time
1.1.53 source-ip
1.1.54 source-ip-host (IPv4 security policy view)
1.1.55 source-ip-host (IPv6 security policy view)
1.1.56 source-ip-range (IPv4 security policy view)
1.1.57 source-ip-range (IPv6 security policy view)
1.1.58 source-ip-subnet (IPv4 security policy view)
1.1.59 source-ip-subnet (IPv6 security policy view)
1.1.60 source-mac
1.1.61 source-microsegment
1.1.62 source-zone
1.1.63 terminal
1.1.64 terminal-group
1.1.65 time-range
1.1.66 track
1.1.67 traffic-log drop enable
1.1.68 traffic-log session-end enable
1.1.69 traffic-log session-start enable
1.1.70 url-category
1.1.71 user
1.1.72 user-group
1.1.73 vrf
1 安全策略
1.1  安全策略配置命令
accelerate enhanced enable命令用来激活安全策略规则的加速功能。
IPv4安全策略视图
IPv6安全策略视图
context-admin
加速功能用于提高报文对安全策略规则的匹配速度。激活安全策略规则加速功能是指对变化(新增、删除、修改或移动)的安全策略规则进行加速。
进入安全策略视图后,系统按照动态时间间隔判断是否需要激活安全策略规则的加速功能。在一个时间间隔内若安全策略规则发生变化,则间隔时间到达后会对当前所有的安全策略规则进行重新加速,否则,不会重新加速。
如安全策略规则发生变化后,也可以手动执行accelerate enhanced enable命令立即对发生变化的安全策略规则进行加速。
安全策略中的规则发生变化后必须对其加速成功,否则这些变化的规则无法进行报文匹配。
激活安全策略规则加速功能时,内存资源不足会导致安全策略规则加速失败。加速失败后,本间隔内发生变化的安全策略规则未进行加速,从而导致变化的安全策略规则不生效,之前已经加速成功的规则不受影响。在下一个时间间隔到达后,系统会再次尝试对安全策略规则进行加速。
# 激活安全策略规则的加速功能。
[Sysname] security-policy ip
[Sysname-security-policy-ip] accelerate enhanced enable
1.1.2  action
action命令用来配置安全策略规则的动作。
undo action命令用来恢复缺省情况。
action { drop | pass }
undo action pass
安全策略规则动作是丢弃。
安全策略规则视图
context-admin
drop:表示丢弃符合条件的报文。
pass:表示允许符合条件的报文通过。
多次执行本命令,最后一次执行的命令生效。
# 为安全策略规则rule1配置动作为丢弃。
[Sysname-security-policy-ip] rule 0 name rule1
[Sysname-security-policy-ip-0-rule1] action drop
·     display security-policy
any-vrf enable命令用来配置安全策略规则对入接口任意VPN实例的报文有效。
undo any-vrf enable命令用来恢复缺省情况。
any-vrf enable
undo any-vrf enable
安全策略规则对公网的报文有效。
安全策略规则视图
context-admin
执行any-vrf enable命令后,安全策略规则对入接口任意VPN实例的报文有效,则vrf命令不再生效但不会删除已下发配置。当执行undo any-vrf enable命令后,vrf命令继续生效。
# 配置安全策略规则rule1对入接口的任意VPN实例的报文生效。
[Sysname-security-policy-ip-0-rule1] any-vrf enable
·     vrf
1.1.4  app-group
app-group命令用来配置作为安全策略规则过滤条件的应用组。
undo app-group命令用来删除作为安全策略规则过滤条件的应用组。
app-group app-group-name
undo app-group [ app-group-name ]
不存在应用组过滤条件。
安全策略规则视图
context-admin
app-group-name:表示应用组的名称,为1~63个字符的字符串,不区分大小写,且不能为字符串invalid和other。使用undo app-group命令时若不指定此参数,则表示删除此规则中所有应用组类型的过滤条件。有关应用组的详细介绍,请参见“安全配置指导”中的“APR”。
多次执行本命令,可配置多个应用组作为安全策略规则的过滤条件。
# 配置作为安全策略规则rule1过滤条件的应用组为app1和app2。
[Sysname-security-policy-ip-0-rule1] app-group app1
[Sysname-security-policy-ip-0-rule1] app-group app2
·     app-group(安全命令参考/APR)
1.1.5  application
application命令用来配置作为安全策略规则过滤条件的应用。
undo application命令用来删除作为安全策略规则过滤条件的应用。
application application-name
undo application [ application-name ]
不存在应用过滤条件。
安全策略规则视图
context-admin
application-name:表示应用的名称,为1~63个字符的字符串,不区分大小写,且不能为字符串invalid和other。使用undo application命令时若不指定此参数,则表示删除此规则中所有应用类型的过滤条件。有关应用的详细介绍,请参见“安全配置指导”中的“APR”。
多次执行本命令,可配置多个应用作为安全策略规则的过滤条件。
为使安全策略中配置的应用可以被识别,必须先放行应用所依赖的基础协议报文。
在端口仿冒网络环境中,必须先放行仿冒的基础协议报文,才能识别出仿冒报文中的应用。
# 配置作为安全策略规则rule1过滤条件的应用为139Mail和51job。
[Sysname-security-policy-ip-0-rule1] application 139Mail
[Sysname-security-policy-ip-0-rule1] application 51job
·     nbar application(安全命令参考/APR)
·     port-mapping(安全命令参考/APR)
counting enable命令用来开启安全策略规则匹配统计功能。
undo counting enable命令用来关闭安全策略规则匹配统计功能。
counting enable [ period value ]
安全策略规则匹配统计功能处于关闭状态。
安全策略规则视图
context-admin
period value:指定安全策略规则匹配统计功能开启的时长,取值范围为1~4294967295,单位为分钟。若不指定该参数,则表示永久开启统计功能。
此功能用来对匹配安全策略规则的报文进行统计,可通过执行display security-policy statistics命令来查看相关报文的统计信息。
开启安全策略规则匹配统计功能时,若指定了period参数,则当到达指定时长后,系统会自动关闭该功能,并删除该配置;若没有指定period参数,则永久开启统计功能,只有执行undo counting enable命令后才可以关闭该功能。
# 为安全策略规则rule1开启规则匹配统计功能,并指定开启时长为20分钟。
[Sysname-security-policy-ip-0-rule1] counting enable period 20
·     display security-policy statistics
description命令用来配置安全策略规则的描述信息。
undo description命令用来恢复缺省情况。
不存在安全策略规则的描述信息。
安全策略规则视图
context-admin
text:表示安全策略规则的描述信息,为1~127个字符的字符串,区分大小写。
# 为IPv4安全策略规则0配置描述信息为This rule is used for source-ip ip1。
[Sysname-security-policy-ip-0-rule1] description This rule is used for source-ip ip1
·     display security-policy ip
·     display security-policy ipv6
description命令用来配置安全策略的描述信息。
不存在安全策略的描述信息。
IPv4安全策略视图
IPv6安全策略视图
context-admin
text:表示安全策略的描述信息,为1~127个字符的字符串,区分大小写。
# 配置安全策略的描述信息为“zone-pair security office to library”。
[Sysname-security-policy-ip] description zone-pair security office to library
destination-ip命令用来配置作为安全策略规则过滤条件的目的IP地址。
undo destination-ip命令用来删除作为安全策略规则过滤条件的目的IP地址。
destination-ip object-group-name
undo destination-ip [ object-group-name ]
不存在目的IP地址过滤条件。
安全策略规则视图
context-admin
object-group-name:表示目的地址对象组的名称,为1~63个字符的字符串,不区分大小写,且不能为字符串any。使用undo destination-ip命令时若不指定此参数,则表示删除此规则中所有目的IP地址类型的过滤条件。有关地址对象组的详细介绍,请参见“安全配置指导”中的“对象组”。
多次执行本命令,可配置多个目的IP地址作为安全策略规则的过滤条件。
配置目的IP地址作为安全策略规则的过滤条件时,若指定的地址对象组不存在,该配置仍会配置成功,同时也会在系统中创建一个名称为指定名称的空配置地址对象组,但此条过滤条件不会匹配任何报文。
一条规则下配置的目的地址对象组最多为1024个,超出时命令会执行失败并提示出错。
# 配置作为安全策略规则rule1过滤条件的目的地址对象组为client1和client2。
[Sysname-security-policy-ip-0-rule1] destination-ip client1
[Sysname-security-policy-ip-0-rule1] destination-ip client2
·     object-group(安全命令参考/对象组)
destination-ip-host命令用来配置作为安全策略规则过滤条件的目的IPv4主机地址。
undo destination-ip-host命令用来删除作为安全策略规则过滤条件的目的IPv4主机地址。
destination-ip-host ip-address
undo destination-ip-host [ ip-address ]
不存在目的IPv4主机地址过滤条件。
IPv4安全策略规则视图
context-admin
ip-address:指定主机IPv4地址。使用undo destination-ip-host命令时若不指定此参数,则表示删除此规则中所有目的IPv4主机地址类型的过滤条件。
destination-ip-host命令用来配置单个目的IPv4主机地址过滤条件。
多次执行本命令,可配置多个目的IPv4主机地址作为安全策略规则的过滤条件。
新创建的地址不能与已有的地址完全相同,否则该命令执行失败,并提示出错。
一条规则下配置的目的主机地址、目的子网地址和目的范围地址数量之和最多为1024个,超出时命令会执行失败并提示出错。
# 配置作为安全策略规则rule1过滤条件的目的地址为192.167.0.1的IPv4主机地址。
[Sysname-security-policy-ip-0-rule1] destination-ip-host 192.167.0.1
destination-ip-host命令用来配置作为安全策略规则过滤条件的目的IPv6主机地址。
undo destination-ip-host命令用来删除作为安全策略规则过滤条件的目的IPv6主机地址。
destination-ip-host ipv6-address
undo destination-ip-host [ ipv6-address ]
不存在目的IPv6主机地址过滤条件。
IPv6安全策略规则视图
context-admin
ipv6-address:指定主机IPv6地址。使用undo destination-ip-host命令时若不指定此参数,则表示删除此规则中所有目的IPv6主机地址类型的过滤条件。
destination-ip-host命令用来配置单个目的IPv6主机地址过滤条件。
多次执行本命令,可配置多个目的IPv6主机地址作为安全策略规则的过滤条件。
# 配置作为安全策略规则rule1过滤条件的目的地址为192::167:1 的IPv6主机地址。
[Sysname] security-policy ipv6
[Sysname-security-policy-ipv6] rule 0 name rule1
[Sysname-security-policy-ipv6-0-rule1] destination-ip-host 192::167:1
destination-ip-range命令用来配置作为安全策略规则过滤条件的目的IPv4范围地址。
undo destination-ip-range命令用来删除作为安全策略规则过滤条件的目的IPv4范围地址。
destination-ip-range ip-address1 ip-address2
undo destination-ip-range [ ip-address1 ip-address2 ]
不存在目的IPv4范围地址过滤条件。
IPv4安全策略规则视图
context-admin
ip-address1 ip-address2:指定范围IPv4地址。ip-address1表示范围起始IPv4地址,ip-address2表示范围结束IPv4地址。使用undo destination-ip-range命令时若不指定此参数,则表示删除此规则中所有目的IPv4范围地址类型的过滤条件。
destination-ip-range命令用来配置指定范围的目的IPv4地址过滤条件。
多次执行本命令,可配置多个目的IP范围地址作为安全策略规则的过滤条件。
在配置时,需要注意的是:
·     如果指定的ip-address1ip-address2相同,则该配置被视为主机地址对象配置。
·     如果指定的ip-address1ip-address2是一个子网的起始地址和结束地址,则该配置被视为子网地址配置。
·     如果指定的ip-address1ip-address2大,会配置失败,并提示出错。
# 配置作为安全策略规则rule1过滤条件的目的地址为192.165.0.100到192.165.0.200的IPv4范围地址。
[Sysname-security-policy-ip-0-rule1] destination-ip-range 192.165.0.100 192.165.0.200
destination-ip-range命令用来配置作为安全策略规则过滤条件的目的IPv6范围地址。
undo destination-ip-range命令用来删除作为安全策略规则过滤条件的目的IPv6范围地址。
destination-ip-range ipv6-address1 ipv6-address2
undo destination-ip-range [ ipv6-address1 ipv6-address2 ]
不存在目的IPv6范围地址过滤条件。
IPv6安全策略规则视图
context-admin
ipv6-address1 ipv6-address2:指定范围IPv6地址。ipv6-address1表示范围起始IPv6地址,ipv6-address2表示范围结束IPv6地址。使用undo destination-ip-range命令时若不指定此参数,则表示删除此规则中所有目的IPv6范围地址类型的过滤条件。
destination-ip-range命令用来配置指定范围的目的IPv6地址过滤条件。
在配置时,需要注意的是:
·     如果指定的ipv6-address1ipv6-address2相同,则该配置被视为主机地址对象配置。
·     如果指定的ipv6-address1ipv6-address2是一个子网的起始地址和结束地址,则该配置被视为子网地址配置。
·     如果指定的ipv6-address1ipv6-address2大,会配置失败,并提示出错。
# 配置作为安全策略规则rule1过滤条件的目的地址为192:165::100到192:165::200的IPv6范围地址。
[Sysname-security-policy-ipv6-0-rule1] destination-ip-range 192:165::100 192:165::200
destination-ip-subnet命令用来配置作为安全策略规则过滤条件的目的IPv4子网地址。
undo destination-ip-subnet命令用来删除作为安全策略规则过滤条件的目的IPv4子网地址。
destination-ip-subnet ip-address { mask-length | mask }
undo destination-ip-subnet [ ip-address { mask-length | mask } ]
不存在目的IPv4子网地址过滤条件。
IPv4安全策略规则视图
context-admin
ip-address { mask-length | mask }:指定子网IPv4地址。mask-length表示子网掩码长度,取值范围为0~32。mask表示接口IPv4地址相应的子网掩码,为点分十进制格式。如果指定mask-length为32或者mask为255.255.255.255,则该配置被视为主机地址配置。使用undo destination-ip-subnet命令时若不指定此参数,则表示删除此规则中所有目的IPv4子网地址类型的过滤条件。
destination-ip-subnet命令用来配置指定子网的目的IPv4地址过滤条件。
# 配置作为安全策略规则rule1过滤条件的目的地址为192.167.0.0,掩码长度为24的IPv4子网地址。
[Sysname-security-policy-ip-0-rule1] destination-ip-subnet 192.167.0.0 24
# 配置作为安全策略规则rule1过滤条件的目的地址为192.166.0.0,掩码为255.255.0.0的IPv4子网地址。
[Sysname-security-policy-ip-0-rule1] destination-ip-subnet 192.166.0.0 255.255.0.0
destination-ip-subnet命令用来配置作为安全策略规则过滤条件的目的IPv6子网地址。
undo destination-ip-subnet命令用来删除作为安全策略规则过滤条件的目的IPv6子网地址。
destination-ip-subnet { ipv6-address prefix-length | ipv6-address/prefix-length }
undo destination-ip-subnet [ ipv6-address prefix-length | ipv6-address/prefix-length ]
不存在目的IPv6子网地址过滤条件。
IPv6安全策略规则视图
context-admin
ipv6-address prefix-length:指定子网IPv6地址。prefix-length表示子网前缀长度,取值范围为1~128。如果指定prefix-length为128,则该配置被视为主机地址配置。使用undo destination-ip-subnet命令时若不指定此参数,则表示删除此规则中所有目的IPv6子网地址类型的过滤条件。
destination-ip-subnet命令用来配置指定子网的目的IPv6地址过滤条件。
# 配置作为安全策略规则rule1过滤条件的目的地址为192::167:0,地址前缀长度为64的IPv6子网地址。
[Sysname-security-policy-ipv6-0-rule1] destination-ip-subnet 192::167:0 64
destination-microsegment命令用来配置作为安全策略规则过滤条件的目的微分段
undo destination-microsegment命令用来删除作为安全策略规则过滤条件的目的微分段
destination-microsegment microsegment-id [ mask-length mask-length ]
undo destination-microsegment [ microsegment-id [ mask-length mask-length ] ]
不存在目的微分段过滤条件。
安全策略规则视图
context-admin
microsegment-id:目的微分段ID,取值范围为1~65535,使用undo命令如果不指定该参数,则表示删除该规则中所有目的微分段的过滤条件。
mask-length mask-length:聚合微分段的掩码长度,mask-length的取值范围为1~aggregation-id转换为二进制时末尾连续0的位数,且配置mask-length时,microsegment-id必须是不为0的偶数。有关微分段的详细介绍,请参见“安全配置指导”中的“微分段”。
使用指导】
微分段(Microsegment),也叫基于精细分组的安全隔离,其实质就是基于对报文进行分组后的组标识来进行流量控制。例如,将数据中心网络中的服务器按照一定的原则进行分组,然后基于分组来部署流量控制策略,从而达到简化运维、安全管控的目的。安全策略支持配置微分段作为过滤条件,指定微分段的报文可以被安全策略规则匹配并执行规则动作。
多次执行本命令,可配置多个目的微分段作为安全策略规则的过滤条件。
# 配置作为安全策略规则rule1过滤条件的目的微分段索引为10,聚合目的微分段的掩码长度为1。
[Sysname-security-policy-ip-0-rule1] destination-microsegment 10 mask-length 1
·     source-microsegment
destination-zone命令用来配置作为安全策略规则过滤条件的目的安全域。
undo destination-zone命令用来删除作为安全策略规则过滤条件的目的安全域。
destination-zone destination-zone-name
undo destination-zone [ destination-zone-name ]
不存在目的安全域过滤条件。
安全策略规则视图
context-admin
destination-zone-name:表示目的安全域的名称,为1~31个字符的字符串,不区分大小写。使用undo destination-zone 命令时若不指定此参数,则表示删除此规则中所有目的安全域类型的过滤条件。有关安全域的详细介绍,请参见“安全配置指导”中的“安全域”。
多次执行本命令,可配置多个目的安全域作为安全策略规则的过滤条件。
配置目的安全域作为安全策略规则的过滤条件时,若指定的目的安全域不存在,该配置仍会配置成功,但此条过滤条件不会匹配任何报文。
# 配置作为安全策略规则rule1过滤条件的目的安全域为Trust和server。
[Sysname-security-policy-ip-0-rule1] destination-zone trust
[Sysname-security-policy-ip-0-rule1] destination-zone server
·     security-zone(安全命令参考/安全域)
1.1.18  disable
disable命令用来禁用安全策略规则。
undo disable命令用来启用安全策略规则。
disable
undo disable
安全策略规则处于启用状态。
安全策略规则视图
context-admin
# 禁用安全策略规则rule1。
[Sysname-security-policy-ip-0-rule1] disable
display security-policy命令用来显示安全策略的配置信息。
display security-policy { ip | ipv6 } [ brief | rule name rule-name ]
context-admin
context-operator
ip:表示显示IPv4安全策略的配置信息。
ipv6:表示显示IPv6安全策略的配置信息。
brief:表示显示安全策略的概要信息。若不指定参数,则显示所有安全策略规则的配置信息。
rule:表示显示指定安全策略规则的配置信息。
name rule-name:表示安全策略规则的名称,为1~127个字符的字符串,不区分大小写。
# 显示IPv4安全策略的配置信息。
<Sysname> display security-policy ip
Inactive: Time range or track is inactive.
Invalid: This rule is invalid. One or more items of source address and destination address are not configured.
Security-policy ip
TotalRule: 2
TotalGroup: 0
 rule 0 name der (Inactive)
  action pass
  profile er
  vrf re
  logging enable
  counting enable TTL 1200
  time-range dere
  track positive 23
  session aging-time 5000
  session persistent aging-time 2400
  source-zone trust
  source-ip erer
  source-ip-host 1.1.1.4
  source-ip-subnet 1.1.1.0 255.255.255.0
  source-ip-range 2.2.1.1 3.3.3.3
  source-location location1
  source-location-group location-group1
  destination-ip-host 5.5.1.2
  destination-ip-subnet 5.5.1.0 255.255.255.0
  destination-ip-range 2.2.1.1 3.3.3.3
  destination-location location2
  destination-location-group location-group2
  service ftp
  service-port tcp
  service-port tcp source lt 100 destination eq 104
  service-port tcp source eq 100 destination range 104 2000
  service-port udp
  service-port udp source gt 100 destination eq 104
  service-port udp destination eq 100
  service-port icmp 100 122
  service-port icmp
  service-port sctp
  service-port sctp source lt 100 destination eq 104
  service-port sctp destination range 104 2000
  app-group ere
  application 110Wang
  terminal-group group1
  terminal terminal1
  user der
  user-group ere
  hits 100
# 显示IPv4安全策略规则名称为der的配置信息。
<Sysname> display security-policy ip rule name der
  action pass
  profile er
  vrf re
  logging enable
  time-range dere
  track positive 23
  source-zone trust
  source-ip erer
  service ftp
  service-port tcp
  service-port udp
  service-port icmp
  app-group ere
  application 110Wang
  terminal terminal1
  user der
  user-group ere
  hits 100
# 显示所有IPv4安全策略规则的概要信息。
<Sysname> display security-policy ip brief
TotalRule: 2
ID           Name                               State        Action     Hits
0            default_any                        active       pass       11221440
1            test                               active       drop       0
表1-1 display security-policy命令显示信息描述表
TotalRule
规则数量
TotalGroup
策略组的数量
rule id name rule-name (Inactive/Invalid)
表示规则的ID、名称和状态,仅当安全策略规则配置了时间段、与Track项联动或开启必配项检查功能时才会显示状态,规则的状态取值包括:
·     Active:表示活跃状态,即时间段或联动Track项处于活跃状态
·     Inactive:表示非活跃状态,即时间段或联动Track项处于非活跃状态
·     Invalid:表示失效状态,即开启了必配项检查功能,且该规则未配置必配项
当规则状态为Inactive或Invalid时,该规则均不会生效
action pass
表示规则动作,其取值如下:
·     pass:表示允许报文通过
·     drop:表示丢弃报文
profile app-profile-name
表示引用的DPI应用profile
vrf vrf-name
表示MPLS L3VPN的VPN实例名称
logging enable
表示开启了对符合规则过滤条件的报文记录日志信息的功能
counting enable period value
表示开启了安全策略规则匹配统计功能并设置了开启时长,单位为分钟
counting enable TTL time-value
表示开启了安全策略规则匹配统计功能后的剩余生效时间,单位为秒
time-range time-range-name
表示此规则生效的时间段
track negative 1
表示安全策略规则生效状态与Track项的Negative状态关联
track positive 1
表示安全策略规则生效状态与Track项的Positive或NotReady状态关联
session aging-time time-value
表示此规则中设置的会话老化时间,单位为秒
session persistent aging-time time-value
表示此规则中设置的长连接会话的老化时间,单位为小时
source-zone zone-name
表示规则配置了源安全域作为过滤条件
destination-zone zone-name
表示规则配置了目的安全域作为过滤条件
source-ip object-group-name
表示规则配置了源IP地址作为过滤条件
source-ip-host ip-address
表示规则配置了源IP主机地址作为过滤条件
source-ip-subnet ip-address
表示规则配置了源IP子网地址作为过滤条件
source-ip-range ip-address1 ip-address2
表示规则配置了源IP范围地址作为过滤条件
表示规则配置了目的IP地址作为过滤条件
表示规则配置了目的IP主机地址作为过滤条件
表示规则配置了目的IP子网地址作为过滤条件
表示规则配置了目的IP范围地址作为过滤条件
source-location location-name
表示规则配置了源地区作为过滤条件
source-location-group location-group-name
表示规则配置了源地区组作为过滤条件
destination-location location-name
表示规则配置了目的地区作为过滤条件
destination-location-group location-group-name
表示规则配置了目的地区组作为过滤条件
service object-group-name
表示规则配置了服务作为过滤条件
service-port protocol
表示规则配置了协议的端口号作为过滤条件
表示规则配置了应用组作为过滤条件
表示规则配置了应用作为过滤条件
terminal terminal-name
表示规则配置了终端作为过滤条件
terminal-group terminal-group-name
表示规则配置了终端组作为过滤条件
user user-name
表示规则配置了用户作为过滤条件
user-group user-group-name
表示规则配置了用户组作为过滤条件
hits hits-value
表示规则的命中次数
TotalRule value
表示规则的数量
ID
表示规则的ID
Name
表示规则的名称
表示规则生效状态。此安全策略规则生效状态取决于时间段、Track项联动或必配项检查功能,规则的生效状态取值包括:
·     active:表示生效状态
·     inactive:表示禁用状态
Action
表示规则动作,其取值如下:
·     pass:表示允许报文通过
·     drop:表示丢弃报文
Hits
表示规则的命中次数
表示规则下流量开始日志输出功能处于启用状态
表示规则下流量结束日志输出功能处于启用状态
表示规则下流量拒绝日志输出功能处于启用状态
·     security-policy ip
·     security-policy ipv6
display security-policy statistics命令用来显示安全策略的统计信息。
display security-policy statistics { ip | ipv6 } [ rule rule-name ]
context-admin
context-operator
ip:表示显示IPv4安全策略的统计信息。
ipv6:表示显示IPv6安全策略的统计信息。
rule rule-name:表示显示指定安全策略规则的统计信息。rule-name是安全策略规则的名称,为1~127个字符的字符串,不区分大小写。若不指定此参数,则显示指定IP类型的所有安全策略统计信息。
# 显示IPv4安全策略下所有规则的统计信息。
<Sysname> display security-policy statistics ip
ID   Name    State    Action   Hits    Bytes    First hit             Last hit
1    a1      active   pass     1633    165705   2023-03-16 15:03:20   2023-03-16 15:24:53
2    b2      active   drop     3512    340477   2023-03-16 15:01:10   2023-03-16 15:13:20
3    c3      active   drop     0       0        -                     -
# 显示IPv4安全策略下名称为abc的规则的统计信息。
<Sysname> display security-policy statistics ip rule abc
2    abc     active    drop    3512    340477   2023-03-16 15:01:10   2023-03-16 15:13:20
表1-2 display security-policy statistics命令显示信息描述表
ID
表示规则的ID
Name
表示规则的名称
·     active:表示生效状态
·     inactive:表示禁用状态
action
表示规则动作,其取值如下:
·     pass:表示允许报文通过
·     drop:表示丢弃报文
Hits
表示规则的命中次数
Bytes
表示规则的命中字节数
First hit
表示规则首次命中时间
Last hit
表示规则最新命中时间
·     reset security-policy statistics
display security-policy ip query命令用来显示符合指定查询条件的IPv4安全策略的配置信息。
display security-policy ip query { destination-ip { destination-ip-address | any } | destination-zone { name destination-zone-name | any } | protocol { protocol-number | any | { tcp | udp | sctp } [ source-port source-port | destination-port destination-port ] * | icmp [ icmp-type icmp-type [ icmp-code icmp-code ] ] } | source-ip { source-ip-address | any } | source-zone { name source-zone-name | any } } * [ brief ]
context-admin
context-operator
destination-ip { destination-ip-address | any }:表示显示目的IPv4地址中包含指定IPv4地址的安全策略规则的配置信息。destination-ip-address表示目的IPv4地址,any表示显示未配置目的IP地址、目的地区或地区组的规则的信息。
destination-zone { name destination-zone-name | any }:表示显示包含指定目的安全域安全策略规则的信息。name destination-zone-name表示目的安全域的名称,为1~31个字符的字符串,不区分大小写,any表示显示未配置目的安全域的规则的信息。
protocol:表示显示指定协议安全策略规则的信息。
protocol-number:表示协议类型,取值范围为0~57、59~255。
any:表示显示未配置服务或端口的规则的信息。
tcp:表示协议类型为TCP。
udp:表示协议类型为UDP。
sctp:表示协议类型为SCTP。
source-port source-port:表示源端口号,取值范围为0~65535。
destination-port destination-port:表示目的端口号,取值范围为0~65535。
icmp:表示协议类型为ICMP。
icmp-type icmp-type:表示ICMP消息类型,取值范围为0~255。
icmp-code icmp-code:表示ICMP消息码,取值范围为0~255。
source-ip { source-ip-address | any }:表示显示源IPv4地址中包含指定IPv4地址的安全策略规则的配置信息。source-ip-address表示源IPv4地址,any表示显示未配置源IPv4地址、源MAC地址、源地区或地区组的规则的信息。
source-zone { name source-zone-name | any }:表示显示包含指定源安全域安全策略规则的信息。name source-zone-name表示源安全域的名称,为1~31个字符的字符串,不区分大小写,any表示显示未配置源安全域的规则的信息。
brief:表示显示指定五元组的安全策略规则的概要信息。若不指定该参数,则表示显示指定五元组的安全策略规则的详细信息。
当指定的某项查询条件不存在时,则显示未配置该项匹配条件规则的信息。
# 显示源IP地址包含1.2.3.4的IPv4安全策略规则的详细配置信息。
<Sysname> display security-policy ip query source-ip 1.2.3.4
 rule 1 name test
  action drop
  source-zone aa
  destination-zone bb
  source-ip-host 1.2.3.4
  destination-ip-host 2.3.4.5
  service udp-s1110-d80
  service icmp-3-3
# 显示源IPv4地址包含1.2.3.4的IPv4安全策略规则的概要信息。
<Sysname> display security-policy ip query source-ip 1.2.3.4 brief
表1-3 display security-policy ip query命令显示信息描述表
rule id name rule-name (Inactive)
·     当规则状态为Inactive或Invalid时,该规则均不会生效
action pass
表示规则动作,其取值如下:
·     pass:表示允许报文通过
·     drop:表示丢弃报文
表示引用的DPI应用profile
vrf vrf-name
logging enable
表示此规则生效的时间段
track negative 1
track positive 1
表示规则配置了源安全域作为过滤条件
表示规则配置了目的安全域作为过滤条件
表示规则配置了源IP地址作为过滤条件
表示规则配置了目的IP地址作为过滤条件
表示规则配置了源地区作为过滤条件
表示规则配置了源地区组作为过滤条件
表示规则配置了目的地区作为过滤条件
表示规则配置了目的地区组作为过滤条件
表示规则配置了服务作为过滤条件
表示规则配置了协议的端口号作为过滤条件
表示规则配置了应用组作为过滤条件
表示规则配置了应用作为过滤条件
表示规则配置了终端作为过滤条件
表示规则配置了终端组作为过滤条件
user user-name
表示规则配置了用户作为过滤条件
表示规则配置了用户组作为过滤条件
ID
表示规则的ID
Name
表示规则的名称
·     active:表示生效状态
·     inactive:表示禁用状态
Action
表示规则动作,其取值如下:
·     pass:表示允许报文通过
·     drop:表示丢弃报文
Hits
表示规则的命中次数
display security-policy ipv6 query命令用来显示符合指定查询条件的IPv6安全策略的配置信息。
display security-policy ipv6 query { destination-ip { destination-ipv6-address | any } | destination-zone { name destination-zone-name | any } | protocol { protocol-number | any | { tcp | udp | sctp } [ source-port source-port | destination-port destination-port ] * | icmpv6 [ icmpv6-type icmpv6-type [ icmpv6-code icmpv6-code ] ] } | source-ip { source-ipv6-address | any } | source-zone { name source-zone-name | any} } * [ brief ]
context-admin
context-operator
destination-ip { destination-ipv6-address | any }:表示显示目的IPv6地址中包含指定IPv6地址的安全策略规则的配置信息。destination-ipv6-address表示目的IPv6地址,any表示显示未配置目的IP地址、目的地区或地区组的规则的信息。
protocol-number:表示协议类型,取值范围为0、2~255。
tcp:表示协议类型为TCP。
udp:表示协议类型为UDP。
sctp:表示协议类型为SCTP。
icmpv6:表示协议类型为ICMPv6。
icmpv6-type icmpv6-type:表示ICMPv6消息类型,取值范围为0~255。
icmpv6-code icmpv6-code:表示ICMPv6消息码,取值范围为0~255。
source-ip { source-ipv6-address | any }:表示显示源IPv6地址中包含指定IPv6地址的安全策略规则的配置信息。source-ipv6-address表示源IPv6地址,any表示显示未配置源IPv6地址、源MAC地址、源地区或地区组的规则的信息。
brief:表示显示五元组查询命中的安全策略规则的概要信息。若不指定该参数,则表示显示五元组查询命中的安全策略规则的详细信息。
# 显示源IP地址包含1:2:3:4:5:6:7:8的IPv6安全策略规则的详细配置信息。
<Sysname> display security-policy ipv6 query source-ip 1:2:3:4:5:6:7:8
 rule 0 name test
  action drop
  source-zone aa
  destination-zone bb
  source-ip-host 1:2:3:4:5:6:7:8
  destination-ip-host 2:3:4:5:6:7:8:9
  service sctp-s1110-d80
  service-port icmpv6 3 3
# 显示源IP地址包含1:2:3:4:5:6:7:8的IPv6安全策略规则的概要信息。
<Sysname> display security-policy ipv6 query source-ip 1:2:3:4:5:6:7:8 brief
0            test                               active       drop       0
表1-4 display security-policy ipv6 query命令显示信息描述表
action pass
表示规则动作,其取值如下:
·     pass:表示允许报文通过
·     drop:表示丢弃报文
表示引用的DPI应用profile
vrf vrf-name
logging enable
表示此规则生效的时间段
track negative 1
track positive 1
表示规则配置了源安全域作为过滤条件
表示规则配置了目的安全域作为过滤条件
表示规则配置了源IP地址作为过滤条件
表示规则配置了目的IP地址作为过滤条件
表示规则配置了源地区作为过滤条件
表示规则配置了源地区组作为过滤条件
表示规则配置了目的地区作为过滤条件
表示规则配置了目的地区组作为过滤条件
表示规则配置了服务作为过滤条件
表示规则配置了协议的端口号作为过滤条件
表示规则配置了应用组作为过滤条件
表示规则配置了应用作为过滤条件
表示规则配置了终端作为过滤条件
表示规则配置了终端组作为过滤条件
user user-name
表示规则配置了用户作为过滤条件
表示规则配置了用户组作为过滤条件
ID
表示规则的ID
Name
表示规则的名称
·     active:表示生效状态
·     inactive:表示禁用状态
Action
表示规则动作,其取值如下:
·     pass:表示允许报文通过
·     drop:表示丢弃报文
Hits
表示规则的命中次数
1.1.23  group move
group move group-name1 { after | before } { group group-name2 | rule rule-name }命令用来移动安全策略组。
安全策略视图
context-admin
group-name1:表示需要被移动的安全策略组的名称,为1~63个字符的字符串,不区分大小写。
after:表示将安全策略组group-name1移动到安全策略组group-name2或安全策略规则rule-name之后。
before:表示将安全策略组group-name1移动到安全策略组group-name2或安全策略规则rule-name之前。
group group-name2:表示目标安全策略组的名称,为1~63个字符的字符串,不区分大小写。
rule rule-name:表示目标安全策略规则的名称,为1~127个字符的字符串,不区分大小写。
通过移动安全策略组可以批量改变安全策略规则的优先级。
如果目标安全策略规则已经属于其他安全策略组,按照其在安全策略组中的位置,受如下原则的约束。
·     如果规则位于策略组中间位置,则不能移动。
·     如果规则位于策略组开始位置,只可以移动到目标规则之前。
·     如果规则位于策略组结束位置,只可以移动到目标规则之后。
# 将安全策略组group1移动到安全策略组group2之前。
[Sysname-security-policy-ip] group move group1 before group group2
1.1.24  group name
group name命令用来创建安全策略组,并将指定的安全策略规则加入此安全策略组。如果指定的安全策略组已经存在,则将指定的安全策略规则加入此安全策略组。
undo group name命令用来删除安全策略组。
group name group-name [ from rule-name1 to rule-name2 ] [ disable | enable ] [ description description-text ]
undo group name group-name [ description | include-member ]
不存在安全策略组。
安全策略视图
context-admin
group-name:表示安全策略组的名称,为1~63个字符的字符串,不区分大小写。
from rule-name1:表示加入安全策略组规则的起始规则,rule-name1是安全策略规则的名称,为1~127个字符的字符串,不区分大小写。若不指定本参数,则表示创建空的安全策略组。
to rule-name2:表示加入安全策略组规则的结束规则,rule-name2是安全策略规则的名称,为1~127个字符的字符串,不区分大小写。
disable:表示禁用安全策略组。
enable:表示启用安全策略组,安全策略组缺省处于启用状态。
description description-text:表示安全策略组的描述信息,为1~127个字符的字符串,区分大小写。缺省情况下,安全策略组不存在描述信息。
include-member:执行undo group name命令行时,若指定本参数,则表示删除安全策略组及其策略组中的所有安全策略规则。
安全策略组可以实现对安全策略规则的批量操作,例如批量启用、禁用、删除和移动安全策略规则。
将安全策略规则加入安全策略组时,会将指定范围内若干连续的安全策略规则加入同一个安全策略组。
只有当安全策略规则及其所属的安全策略组均处于启用状态时,安全策略规则才能生效。
将安全策略规则加入安全策略组时,起始规则要在结束规则前面,并且起始规则和结束规则之间的规则不能属于其他安全策略组。
执行undo group name命令行时的具体功能如下:
·     undo group name group-name命令用来仅删除安全策略组,但不删除策略组中的规则。
·     undo group name group-name description命令用来仅删除安全策略组的描述信息。
·     undo group name group-name include-member命令用来删除安全策略组及其策略组中的所有规则。
# 创建一个名称为group1的安全策略组,并将安全策略规则rule-name1到rule-name10之间的所有安全策略规则加入此安全策略组,其描述信息为marketing。
[Sysname-security-policy-ip] group name group1 from rule-name1 to rule-name10 enable description marketing
1.1.25  group rename
group rename命令用来重命名安全策略组。
group rename old-name new-name
安全策略视图
context-admin
old-name:表示安全策略组的原有名称,为1~63个字符的字符串,不区分大小写。
new-name:表示安全策略组的新名称,为1~63个字符的字符串,不区分大小写。
# 把安全策略组group1重命名为group2。
[Sysname-security-policy-ip] group rename group1 group2
learning enable命令用来开启安全策略规则学习功能。
undo learning enable命令用来关闭安全策略规则学习功能。
learning enable
安全策略规则学习功能处于关闭状态。
安全策略规则视图
context-admin
在配置安全策略时,一般建议配置严谨、细粒度的安全策略规则,以达到报文的精细化控制。但当无法确定需要放行或阻断的报文属性时,只能先配置较宽泛的报文匹配规则以保证业务的正常转发。此时可以开启规则学习功能,对匹配安全策略规则的报文进行学习并记录报文属性。然后登录设备Web管理页面查看学习结果,从而根据学习结果筛选、分析需要放行或阻断的报文属性,制定更精细化的安全策略。
# 为安全策略规则rule1开启安全策略规则学习功能。
[Sysname-security-policy-ip-0-rule1] learning enable
·     reset security-policy learning-records
logging enable命令用来开启安全策略规则记录日志的功能。
undo logging enable命令用来关闭安全策略规则记录日志的功能。
logging enable
undo logging enable
安全策略规则记录日志的功能处于关闭状态。
安全策略规则视图
context-admin
开启此功能后,设备对匹配规则的报文生成安全策略日志信息,此日志信息将会被交给信息中心模块或快速日志输出模块处理,信息中心模块或快速日志输出模块的配置将决定日志信息的发送规则和发送方向。
安全策略日志不会输出到控制台和监视终端。当信息中心配置的规则将安全策略日志输出到控制台和监视终端时,若仍需要查看安全策略日志,可通过执行display logbuffer命令或在Web页面中查看。有关信息中心和display logbuffer命令的详细描述,请参见“网络管理和监控配置指导”中的“信息中心”。
# 在安全策略规则rule1中开启安全策略规则记录日志的功能。
[Sysname-security-policy-ip-0-rule1] logging enable
1.1.28  move rule
move rule命令用来通过安全策略规则编号移动规则。
move rule rule-id1 { { after | before } rule-id2 | bottom | down | top | up }
IPv4安全策略视图
IPv6安全策略视图
context-admin
rule-id1:指定待移动安全策略规则的编号,取值范围为0~4294967290。
after:表示移动到指定编号的目标安全策略规则之后。
before:表示移动到指定编号的目标安全策略规则之前。
rule-id2:指定目标安全策略规则的编号,取值范围为0~4294967290或4294967295,其中指定编号为4294967295时表示移动到所有规则之后。
bottom:表示移动到所有安全策略规则之后。
down:表示移动到下一条安全策略规则之后。
top:表示移动到所有安全策略规则之前。
up:表示移动到上一条安全策略规则之前。
如果rule-id2rule-id1相同或其指定的规则不存在,则不执行任何移动操作。
# 在IPv4安全策略上,将安全策略规则5移动到规则2之前。
[Sysname-security-policy-ip] move rule 5 before 2
·     rule
move rule name命令用来通过安全策略规则名称移动规则。
move rule name rule-name1 { { after | before } name rule-name2 | bottom | down | top | up }
安全策略视图
context-admin
rule-name1:待移动的安全策略规则的名称,为1~127个字符的字符串,不区分大小写。
after:表示移动到指定名称的目标安全策略规则之后。
before:表示移动到指定名称的目标安全策略规则之前。
name rule-name2指定目标安全策略规则的名称,为1~127个字符的字符串,不区分大小写。
通过移动安全策略规则可以改变报文匹配安全策略规则的优先级。
# 在IPv4安全策略上,将安全策略规则rule1移动到安全策略规则rule2之前。
[Sysname-security-policy-ip] move rule name rule1 before name rule2
·     rule
1.1.30  parent-group
parent-group group-name命令用来配置安全策略规则所属的安全策略组。
undo parent-group命令用来恢复缺省情况。
undo parent-group
安全策略规则不属于安全策略组。
安全策略规则视图
context-admin
group-name:表示安全策略规则需要加入的安全策略组的名称,为1~63个字符的字符串,不区分大小写。
# 配置安全策略规则rule1属于安全策略组group1。
[Sysname-security-policy-ip] rule 1 name rule1
[Sysname-security-policy-ip-1-rule1] parent-group group1
1.1.31  profile
profile命令用来在安全策略规则中引用DPI应用profile。
undo profile命令用来删除在安全策略规则中引用的DPI应用profile。
undo profile
安全策略规则中未引用DPI应用profile。
安全策略规则视图
context-admin
app-profile-name:表示DPI应用profile的名称,为1~63个字符的字符串,只能为字母、数字、下划线,不区分大小写。有关DPI应用profile的详细介绍,请参见“DPI深度安全命令参考”中的“应用层检测引擎”。
通过在安全策略规则中引用DPI应用profile可实现对符合安全策略过滤条件的报文进行相关DPI业务的处理。有关DPI各业务的详细介绍,请参见“DPI深度安全配置指导”中的相关模块。
此命令仅在安全策略规则动作为允许的情况下才生效。
# 在IPv4安全策略规则rule1中引用名称为p1的DPI应用profile。
[Sysname-security-policy-ip-0-rule1] action pass
[Sysname-security-policy-ip-0-rule1] profile p1
·     action pass
·     app-profile(DPI深度安全命令参考/应用层检测引擎)
reset security-policy automatic-deploy records命令用来清除安全策略自动部署的学习记录。
context-admin
# 清除安全策略自动部署的学习记录。
<Sysname> reset security-policy automatic-deploy records
reset security-policy learning-records命令用来清除安全策略规则学习记录。
reset security-policy learning-records [ ip | ipv6 ]
ip:表示清除IPv4安全策略规则学习记录。
ipv6:表示清除IPv6安全策略规则学习记录。
若执行此命令不指定ipipv6参数,则表示清除所有安全策略规则学习记录。
# 清除所有安全策略规则学习记录。
<Sysname> reset security-policy learning-records
·     learning enable
reset security-policy statistics命令用来清除安全策略的统计信息。
reset security-policy statistics [ ip | ipv6 ] [ rule rule-name ]
context-admin
ip:表示清除IPv4安全策略的统计信息。
ipv6:表示清除IPv6安全策略的统计信息。
rule rule-name:表示清除安全策略规则的统计信息。rule-name是安全策略规则的名称,为1~127个字符的字符串,不区分大小写。
若未指定任何参数,则清除所有安全策略的统计信息。
# 清除IPv4安全策略下名称为abc的规则的统计信息。
<Sysname> reset security-policy statistics ip rule abc
1.1.35  rule
rule命令用来创建安全策略规则,并进入安全策略规则视图。如果指定的安全策略规则已经存在,则直接进入安全策略规则视图。
undo rule命令用来删除指定的安全策略规则。
rule { rule-id | [ rule-id ] name rule-name }
undo rule { rule-id | name rule-name } *
不存在安全策略规则。
IPv4安全策略视图
IPv6安全策略视图
context-admin
rule-id:指定安全策略规则的编号,取值范围为0~4294967290。若未指定本参数,系统将从0开始,自动分配一个大于现有最大编号的最小编号,步长为1。若新编号超出了编号上限(4294967290),则选择当前未使用的最小编号作为新的编号。
rule-name:表示安全策略规则的名称,为1~127个字符的字符串,不区分大小写,且全局唯一,不能为default,创建规则时必须配置名称。
# 为IPv4安全策略创建规则0,并为该规则配置规则名称为rule1。
1.1.36  rule rename
rule rename命令用来重命名安全策略规则。
rule rename old-name new-name
安全策略视图
context-admin
old-name:被重命名安全策略规则的名称,为1~127个字符的字符串,不区分大小写。
new-name:重命名后的安全策略规则名称,为1~127个字符的字符串,不区分大小写,且全局唯一,不能为default。
# 重命名安全策略规则rule1的名称为rule2。
[Sysname-security-policy-ip] rule rename rule1 rule2
·     rule
security-policy命令用来进入安全策略视图。
undo security-policy命令用来删除安全策略视图下面的所有配置。
undo security-policy { ip | ipv6 }
安全策略视图下不存在配置。
context-admin
ip:表示IPv4安全策略视图。
ipv6:表示IPv6安全策略视图。
# 进入IPv4安全策略视图。
security-policy automatic-deploy internet-zone-list命令用来配置设备接入Internet的安全域。
undo security-policy automatic-deploy internet-zone-list命令用来恢复缺省情况。
security-policy automatic-deploy internet-zone-list zonename&<1-4>
undo security-policy automatic-deploy internet-zone-list [ zonename&<1-4> ]
不存在设备接入Internet的安全域。
context-admin
zonename&<1-4>:表示设备接入Internet的安全域,为1~31个字符的字符串,不区分大小写。&<1-4>表示前面的参数最多可以输入4次。若不指定参数,则表示不配置设备接入Internet的安全域。
为了精简安全策略的配置,设备在学习完成经过设备的业务流量后,会对学习记录进行智能聚合,并按聚合后的结果自动生成安全策略。设备接入Internet的安全域为智能聚合学习记录的依据之一,需要按照实际组网进行配置。
# 配置设备接入Internet的安全域为internetzone1,internetzone2,internetzone3和internetzone4。
[sysname] security-policy automatic-deploy internet-zone-list internetzone1 internetzone2 internetzone3 internetzone4
·     security-policy automatic-deploy learning-time
·     security-policy automatic-deploy server-zone-list
security-policy automatic-deploy ipv4-agg-mask命令用来配置安全策略自动部署IPv4地址自动聚合的掩码长度。
undo security-policy automatic-deploy ipv4-agg-mask命令用来恢复缺省情况。
security-policy automatic-deploy ipv4-agg-mask mask-length
undo security-policy automatic-deploy ipv4-agg-mask [ mask-length ]
安全策略自动部署IPv4地址自动聚合的掩码长度为24。
context-admin
ipv4-agg-mask mask-length:表示IPv4地址自动聚合的掩码长度,取值范围为1~32。
为了精简安全策略的配置,设备在学习完成经过设备的业务流量后,会对学习记录进行智能聚合,并按聚合后的结果自动生成安全策略。设备在聚合源或目的IPv4地址时,将按照此命令配置的掩码进行聚合。
# 配置安全策略自动部署的IPv4地址聚合掩码长度为24。
[Sysname] security-policy automatic-deploy ipv4-agg-mask 24
security-policy automatic-deploy ipv6-agg-prefix命令用来配置IPv6地址自动聚合的前缀长度。
undo security-policy automatic-deploy ipv6-agg-prefix命令用来恢复缺省情况。
security-policy automatic-deploy ipv6-agg-prefix prefix-length
undo security-policy automatic-deploy ipv6-agg-prefix [ prefix-length ]
安全策略自动部署IPv6地址自动聚合的前缀长度为64。
context-admin
ipv6-agg-prefix prefix-length:表示Ipv6地址自动聚合的前缀长度,取值范围为64~128。
为了精简安全策略的配置,设备在学习完成经过设备的业务流量后,会对学习记录进行智能聚合,并按聚合后的结果自动生成安全策略。设备在聚合源或目的IPv6地址时,将按照此命令配置的前缀长度行聚合。
# 配置安全策略自动部署的IPv6地址前缀掩码长度为64。
[Sysname] security-policy automatic-deploy ipv6-agg-prefix 64
security-policy automatic-deploy learning-time命令用来配置安全策略自动部署的学习时长。
undo security-policy automatic-deploy learning-time命令用来恢复缺省情况。
security-policy automatic-deploy learning-time time
undo security-policy automatic-deploy learning-time [ time ]
安全策略自动部署的学习时长为1小时。
context-admin
learning-time time:表示策略自动部署的学习时长,取值范围为1~168,单位为小时,默认学习时长为1小时。
当设备首次安装使用,管理员对网络流量不够了解的情况下,无法配置正确、合理、严谨的安全策略。此时可通过安全策略自动部署功能,先学习网络流量,然后一键自动根据流量情况完成安全策略部署。安全策略自动部署功能的开启学习和一键部署操作需要通过设备Web管理页面完成。
# 配置安全策略自动部署的学习时长为1小时。
[Sysname] security-policy automatic-deploy learning-time 1
·     reset security-policy automatic-deploy records
·     security-policy automatic-deploy ipv4-agg-mask
·     security-policy automatic-deploy ipv6-agg-prefix
·     security-policy automatic-deploy internet-zone-list
security-policy automatic-deploy server-zone-list命令用来配置设备接入服务器的安全域。
undo security-policy automatic-deploy server-zone-list命令用来恢复缺省情况。
security-policy automatic-deploy server-zone-list zonename&<1-4>
undo security-policy automatic-deploy server-zone-list [ zonename&<1-4> ]
不存在设备接入服务器的安全域。
context-admin
zonename&<1-4>:表示设备接入服务器的安全域,为1~31个字符的字符串,不区分大小写。&<1-4>表示前面的参数最多可以输入4次。若不指定参数,则表示不配置设备接入服务器的安全域。
为了精简安全策略的配置,设备在学习完成经过设备的业务流量后,会对学习记录进行智能聚合,并按聚合后的结果自动生成安全策略。设备接入服务器的安全域为智能聚合学习记录的依据之一,需要按照实际组网进行配置。
# 配置设备接入服务器的安全域为serverzone1,serverzone2,serverzone3和serverzone4。
[sysname] security-policy automatic-deploy server-zone-list serverzone1 serverzone2 serverzone3 serverzone4
security-policy config-logging send-time命令用来配置每天发送安全策略内容日志的时间。
undo security-policy config-logging send-time命令用来恢复缺省情况。
security-policy config-logging send-time time
发送安全策略内容日志的时间为每天的零点。
context-admin
time:配置每天发送安全策略内容日志的时间,time的格式为hh:mm,取值范围为00:00~23:59。
在快速日志输出模块中开启生成安全策略国家电网日志功能后(即执行customlog format security-policy sgcc命令),设备会在每天指定的时间以国家电网日志的格式发送此时所有处于生效状态安全策略规则的配置信息。有关快速日志输出的详细介绍,请参见“网络管理和监控配置指导”中的“快速日志输出”。
# 配置每天发送安全策略内容日志的时间为13点15分。
<Sysname>system-view
[Sysname] security-policy config-loggging send-time 13:15
·     customlog format security-policy sgcc(网络管理和监控命令参考/快速日志输出)
·     customlog host export security-policy(网络管理和监控命令参考/快速日志输出)
security-policy disable命令用来关闭安全策略功能。
undo security-policy disable命令用来开启安全策略功能。
安全策略功能处于开启状态。
context-admin
security-policy disable命令会直接关闭所有安全策略,可能导致网络中断。
只有开启安全策略功能后,配置的安全策略才能生效。
# 关闭安全策略功能
[Sysname] security-policy disable
security-policy object-strict-inspection enable命令用来开启安全策略严格引用对象功能。
undo security-policy object-strict-inspection enable命令用来关闭安全策略严格引用对象功能。
安全策略严格引用对象功能处于关闭状态。
安全策略严格引用对象用于禁止安全策略规则引用不存在的对象。
缺省情况下,安全策略规则中引用源地址(地址组、地区、地区组、MAC地址组)、目的地址(地址组、地区、地区组)、服务、时间段、应用、应用组、用户、用户组、终端、终端组、VRF、Profile、URL、源安全域和目的安全域这些对象不存在时可以引用成功。
当该功能开启时,安全策略规则中引用源地址(地址组、地区、地区组、MAC地址组)、目的地址(地址组、地区、地区组)、服务、时间段、应用、应用组、用户、用户组、终端、终端组、VRF、Profile、URL、源安全域和目的安全域这些对象不存在时引用失败。
用户和用户组类型对象仅在开启用户身份识别功能后引用才能被检测该对象是否存在。
该功能只对开启后新增的配置生效,开启前已经引用不存在对象的配置不影响。
# 开启安全策略严格引用对象功能。
[Sysname] security-policy object-strict-inspection enable
security-policy rules counting命令用来开启或关闭所有安全策略规则统计功能。
security-policy rules counting { disable | enable }
context-admin
disable:关闭所有安全策略规则统计功能。
enable:开启所有安全策略规则统计功能。
counting enable命令可以在指定安全策略规则下开启统计功能,若需要开启设备所有安全策略规则的统计功能,则可以使用本命令,本命令等同于在所有安全策略规则下执行counting enable
# 开启所有安全策略规则统计功能。
[Sysname] security-policy rules counting enable
·     counting enable
security-policy rules mandatory-item-control命令用来开启安全策略必配项检查功能。
undo security-policy rules mandatory-item-control命令用来关闭安全策略必配项检查功能。
security-policy rules mandatory-item-control { ip | service } *
undo security-policy rules mandatory-item-control { ip | service } *
安全策略必配项检查功能处于关闭状态。
context-admin
ip:表示对源/目的IP地址对象组、主机地址、范围地址、子网地址或地区/地区组配置项进行检查,若某规则源/目的IP地址对象组、主机地址、范围地址、子网地址和地区/地区组均未配置,则当前规则不生效。
service:表示对服务或服务端口配置项进行检查,若某规则服务和服务端口均未配置,则当前规则不生效。
安全策略必配项检查功能用于检查规则某些必配项是否配置。
如需启用本功能,请确保当前设备上不存在安全策略规则或已存在的所有安全策略规则中均含有IP或service规则。例如:若要开启IP必配项检查,则需要保证当前设备所有安全策略规则中均包含源IP和目的IP地址对象组;若要开启service必配项检查,则需要保证当前设备所有安全策略规则中均包含service规则。
本功能开启后,若新建或修改的规则中不包含已开启检查的必配项,则相关规则处于不生效状态。例如:设备已开启IP必配项检查后,新建一条安全策略规则,规则仅包含目的地区,则此规则不生效。
IP必配项检查开启时,源/目的IP地址对象组可以配置为any,表示匹配所有源/目的IP地址;IP必配项检查功能关闭时,源/目的IP地址对象组不可以配置为any,未配置该项即表示匹配所有源/目的IP地址。
# 开启安全策略规则IP地址和服务必配项检查功能。
[Sysname] security-policy rules mandatory-item-control ip service
Enabling this command will force the security policy rule to configure the source address, destination address and service, otherwise the security policy rule will not take effect.Continue? [Y/N]:
security-policy show-default-action enable命令用来开启安全策略规则显示缺省动作功能。
undo security-policy show-default-action enable命令用来关闭安全策略规则显示缺省动作功能。
安全策略规则显示缺省动作功能处于关闭状态。
安全策略规则未配置动作时使用缺省动作丢弃匹配的报文,这个缺省动作在配置中不显示。如果要在配置中显示该缺省动作,则可以开启安全策略规则显示缺省动作功能来显示该配置。
# 开启安全策略规则显示缺省动作功能。
[Sysname] security-policy show-default-action enable
1.1.49  service
service命令用来配置作为安全策略规则过滤条件的服务。
undo service命令用来删除作为安全策略规则过滤条件的服务。
service { object-group-name | any }
undo service [ object-group-name | any ]
不存在服务过滤条件。
安全策略规则视图
context-admin
object-group-name:表示服务对象组的名称,为1~63个字符的字符串,不区分大小写。
any:表示将设备中的所有服务作为安全策略规则的过滤条件。
多次执行本命令,可配置多个服务对象组作为安全策略规则的过滤条件。
配置服务作为安全策略规则的过滤条件时,若指定的服务对象组不存在,该配置仍会配置成功,同时也会在系统中创建一个名称为指定名称的空配置服务对象组,但此条过滤条件不会匹配任何报文。
使用undo service命令时若不指定任何参数,则表示删除此规则中所有服务类型的过滤条件。
一条规则下配置的服务对象组最多为1024个,超出时命令会执行失败并提示出错。
# 配置作为安全策略规则rule1过滤条件的服务对象组为http和ftp。
[Sysname-security-policy-ip-0-rule1] service http
[Sysname-security-policy-ip-0-rule1] service ftp
1.1.50  service-port
service-port命令用来配置作为安全策略规则过滤条件的服务端口。
undo service-port命令用来删除作为安全策略规则过滤条件的服务端口。
service-port protocol [ { destination { { eq | lt | gt } port | range port1 port2 | port-list } | source { { eq | lt | gt } port | range port1 port2 | port-list } } * | icmp-type [ icmp-code ] | icmpv6-type [ icmpv6-code ] | type { icmp-type | icmpv6-type } [ code { icmp-code-list | icmpv6-code list } ] ]
undo service-port [ protocol [ { destination { { eq | lt | gt } port | range port1 port2 | port-list } | source { { eq | lt | gt } port | range port1 port2 | port-list } } * | icmp-type [ icmp-code ] | icmpv6-type [ icmpv6-code ] | type { icmp-type | icmpv6-type } [ code { icmp-code-list | icmpv6-code list } ] ] ]
不存在服务端口过滤条件。
IPv4安全策略规则视图
IPv6安全策略规则视图
context-admin
protocol:协议类型。
可输入的形式如下:
·     数字:在IPv4安全策略规则视图下,取值范围为0~57、59~255;在IPv6安全策略规则视图下,取值范围为0、2~255;
·     名称:在IPv4安全策略规则视图下,可选取tcp(6)、udp(17)、icmp(1);在IPv6安全策略规则视图下,可选取tcp(6)、udp(17)、icmpv6(58)。
source:指定源端口。只在protocoltcpudpsctp时有效。
destination:指定目的端口。只在protocoltcpudpsctp时有效。
eq:表示等于。
lt表示小于。
gt表示大于。
port:指定端口号,取值范围为0~65535。
range port1 port2:指定端口号范围。port1表示端口号1,取值范围为0~65535。port2表示端口号2,取值范围为0~65535。
port-list:端口号列表。表示方式为port-list = { port1 [ to port2 ] } &<1-15>port取值范围为0~65535,&<1-15>表示前面的参数最多可以重复输入15次。
type:指定ICMP消息类型,只在protocolicmpicmpv6时有效。
code:指定ICMP消息码,只在protocolicmpicmpv6时有效。
icmp-type:ICMP消息类型,取值范围为0~255,只在protocolicmp时有效。
icmp-code:ICMP消息码,取值范围为0~255。
icmp-code-list:ICMP消息码列表。表示方式为icmp-code-list = { icmp-code1 [ to icmp-code2 ] } &<1-15>icmp-code取值范围为0~255,&<1-15>表示前面的参数最多可以重复输入15次。
icmpv6-type:ICMPv6消息类型,取值范围为0~255,只在protocolicmpv6时有效。
icmpv6-code:ICMPv6消息码,取值范围为0~255。
icmpv6-code-list:ICMPv6消息码列表。表示方式为icmpv6-code-list = { icmpv6-code1 [ to icmpv6-code2 ] } &<1-15>icmpv6-code取值范围为0~255,&<1-15>表示前面的参数最多可以重复输入15次。
本命令与service命令的区别在于本命令仅可匹配服务端口号,而service命令仅可匹配服务对象组。
新创建的服务端口号不能与已有的服务端口号完全相同,否则该命令执行失败。
一条规则下匹配的服务最多为1024个,超出时命令会执行失败并提示出错。
在配置lt参数时,需要注意的是:
·     不能指定port为0。
·     如果指定port为1,则该配置被视为eq 0。
·     如果指定port为2~65535,则实际生效的端口号为[0,port-1]
在配置gt参数时,需要注意的是:
·     不能指定port为65535。
·     如果指定port为65534,该配置被视为eq 65535。
·     如果指定port为0~65533,则实际生效的端口号为[port+1,65535]
在配置range参数时,需要注意的是:
·     如果指定的port1port2相同,则该配置被视为等于指定的端口号。
·     如果指定port1为0,则该配置被视为lt配置,譬如配置range 0 999,被视为lt 1000。
·     如果指定port2为65535,则该配置被视为gt配置,譬如配置range 50001 65535,被视为gt 50000。
·     如果指定的port1port2大,会自动调整范围为[port2,port1]
其他:
·     port1 to port2:如果指定的port1port2大,会自动调整范围为[port2,port1]。
·     icmp-code1 to icmp-code2如果指定的icmp-code1icmp-code2大,会自动调整范围为[icmp-code2, icmp-code1]
·     icmpv6-code1 to icmpv6-code2如果指定的icmpv6-code1icmpv6-code2大,会自动调整范围为[icmpv6-code2, icmpv6-code1]
# 配置作为安全策略规则rule1过滤条件的服务为tcp协议的源端口和目的端口的报文。
[Sysname-security-policy-ip-0-rule1] service-port tcp destination range 100 200 source eq 100
# 配置作为安全策略规则rule1服务为tcp协议的源端口和目的端口集合。
[Sysname-security-policy-ip-0-rule1] service-port tcp destination 10 20 to 30 source 30 to 40
# 配置作为安全策略规则rule1过滤条件的服务为icmp协议消息码的报文。
[Sysname-security-policy-ip-0-rule1] service-port icmp 100 150
# 配置作为安全策略规则rule1服务为icmp协议的消息码集合。
[Sysname-security-policy-ip-0-rule1] service-port icmp type 100 code 150 180 to 200 210
session aging-time命令用来为安全策略规则配置会话的老化时间。
undo session aging-time命令用来恢复缺省情况。
未配置安全策略规则的会话老化时间。
安全策略规则视图
context-admin
time-value:指定会话的老化时间,取值范围为1~2000000,单位为秒。
此命令用来为匹配某条安全策略规则而生成的稳态会话设置老化时间。此命令的配置不仅影响后续生成的会话,对已经生成的会话同样生效。
若某安全策略规则中配置了会话的老化时间,则匹配上该规则且进入稳定状态的会话需要遵循规则中配置的老化时间进行老化;非稳态会话按照缺省的会话老化时间进行老化。
若进入稳态的会话报文匹配上的安全策略规则中未配置会话老化时间,则该会话基于会话管理模块配置的老化时间(session aging-time applicationsession aging-time state命令的配置)进行老化。有关会话管理相关配置的详细介绍,请参见“安全配置指导”中的“会话管理”。
# 为IPv4安全策略的规则rule1配置会话老化时间为5000秒。
[Sysname-security-policy-ip-0-rule1] session aging-time 5000
·     session aging-time application(安全命令参考/会话管理)
·     session aging-time state(安全命令参考/会话管理)
·     session persistent acl(安全命令参考/会话管理)
session persistent aging-time命令用来为安全策略规则配置长连接会话的老化时间。
undo session persistent aging-time命令用来恢复缺省情况。
未配置安全策略规则的长连接会话老化时间。
安全策略规则视图
context-admin
time-value:指定长连接会话的老化时间,取值范围为0~24000,单位为小时,0表示永不老化。
若长连接会话老化时间配置过长,设备会话数量可能会激增,从而导致设备内存使用率过高。
此命令用来为匹配某条安全策略规则而生成的长连接会话设置老化时间。此命令的配置不仅影响后续生成的会话,对已经生成的会话同样生效。
此命令配置的长连接会话老化时间优先级高于session aging-time命令配置的会话老化时间和会话管理模块session persistent acl命令配置的长连接老化时间。有关session persistent acl命令的详细介绍,请参见“安全命令参考”中的“会话管理”。
长连接老化时间仅在TCP会话进入稳态(TCP-EST状态)时生效。
# 为IPv4安全策略中规则rule1配置长连接会话老化时间为1小时。
[Sysname-security-policy-ip-0-rule1] session persistent aging-time 1
1.1.53  source-ip
source-ip命令用来配置作为安全策略规则过滤条件的源IP地址。
undo source-ip命令用来删除作为安全策略规则过滤条件的源IP地址。
undo source-ip [ object-group-name ]
不存在源IP地址过滤条件。
安全策略规则视图
context-admin
object-group-name:表示源地址对象组的名称,为1~63个字符的字符串,不区分大小写,且不能为字符串any。使用undo source-ip 命令时若不指定此参数,则表示删除此规则中所有源IP地址类型的过滤条件。有关地址对象组的详细介绍,请参见“安全配置指导”中的“对象组”。
多次执行本命令,可配置多个源IP地址作为安全策略规则的过滤条件。
配置源IP地址作为安全策略规则的过滤条件时,若指定的地址对象组不存在,该配置仍会配置成功,同时也会在系统中创建一个名称为指定名称的空配置地址对象组,但此条过滤条件不会匹配任何报文。
一条规则下配置的源地址对象组最多为1024个,超出时命令会执行失败并提示出错。
# 配置作为安全策略规则rule1过滤条件的源地址对象组为server1和server2。
[Sysname-security-policy-ip-0-rule1] source-ip server1
[Sysname-security-policy-ip-0-rule1] source-ip server2
source-ip-host命令用来配置作为安全策略规则过滤条件的源IPv4主机地址。
undo source-ip-host命令用来删除作为安全策略规则过滤条件的源IPv4主机地址。
undo source-ip-host [ ip-address ]
不存在源IPv4主机地址过滤条件。
IPv4安全策略规则视图
context-admin
source-ip-host命令用来配置单个源IPv4主机地址过滤条件。
多次执行本命令,可配置多个源IPv4主机地址作为安全策略规则的过滤条件。
一条规则下配置的源主机地址、源子网地址和源范围地址数量之和最多为1024个,超出时命令会执行失败并提示出错。
# 配置作为安全策略规则rule1过滤条件的源地址为192.167.0.1的IPv4主机地址。
[Sysname-security-policy-ip-0-rule1] source-ip-host 192.167.0.1
source-ip-host命令用来配置作为安全策略规则过滤条件的源IPv6主机地址。
undo source-ip-host命令用来删除作为安全策略规则过滤条件的源IPv6主机地址。
source-ip-host ipv6-address
undo source-ip-host [ ipv6-address ]
不存在源IPv6主机地址过滤条件。
IPv6安全策略规则视图
context-admin
source-ip-host命令用来配置单个源IPv6主机地址过滤条件。
多次执行本命令,可配置多个源IPv6主机地址作为安全策略规则的过滤条件。
# 配置作为安全策略规则rule1过滤条件的源地址为192::167:1的IPv6主机地址。
[Sysname-security-policy-ipv6-0-rule1] source-ip-host 192::167:1
source-ip-range命令用来配置作为安全策略规则过滤条件的源IPv4范围地址。
undo source-ip-range命令用来删除作为安全策略规则过滤条件的源IPv4范围地址。
undo source-ip-range [ ip-address1 ip-address2 ]
不存在源IPv4范围地址过滤条件。
IPv4安全策略规则视图
context-admin
source-ip-range命令用来配置指定范围的源IPv4地址过滤条件。
多次执行本命令,可配置多个源IP范围地址作为安全策略规则的过滤条件。
配置需要注意的是:
·     如果指定的ip-address1ip-address2相同,则该配置被视为主机地址配置。
·     如果指定的ip-address1ip-address2是一个子网的起始地址和结束地址,则该配置被视为子网地址对象配置。
# 配置作为安全策略规则rule1过滤条件的源地址为192.165.0.100到192.165.0.200的IPv4范围地址。
[Sysname-security-policy-ip-0-rule1] source-ip-range 192.165.0.100 192.165.0.200
source-ip-range命令用来配置作为安全策略规则过滤条件的源IPv6范围地址。
undo source-ip-range命令用来删除作为安全策略规则过滤条件的源IPv6范围地址。
source-ip-range ipv6-address1 ipv6-address2
undo source-ip-range [ ipv6-address1 ipv6-address2 ]
不存在源IPv6范围地址过滤条件。
IPv6安全策略规则视图
context-admin
source-ip-range命令用来配置指定范围的源IPv6地址过滤条件。
配置需要注意的是:
·     如果指定的ipv6-address1ipv6-address2相同,则该配置被视为主机地址配置。
·     如果指定的ipv6-address1ipv6-address2是一个子网的起始地址和结束地址,则该配置被视为子网地址对象配置。
# 配置作为安全策略规则rule1过滤条件的源地址为192::165:100到192::165:200的IPv6范围地址。
[Sysname-security-policy-ipv6-0-rule1] source-ip-range 192::165:100 192::165:200
source-ip-subnet命令用来配置作为安全策略规则过滤条件的源IPv4子网地址。
undo source-ip-subnet命令用来删除作为安全策略规则过滤条件的源IPv4子网地址。
source-ip-subnet ip-address { mask-length | mask }
undo source-ip-subnet [ ip-address { mask-length | mask } ]
不存在源IPv4子网地址过滤条件。
IPv4安全策略规则视图
context-admin
source-ip-subnet命令用来配置指定子网的源IPv4地址过滤条件。
多次执行本命令,可配置多个源IP子网地址作为安全策略规则的过滤条件。
# 配置作为安全策略规则rule1过滤条件的源地址为192.167.0.0,掩码长度为24的IPv4子网地址。
[Sysname-security-policy-ip-0-rule1] source-ip-subnet 192.167.0.0 24
# 配置作为安全策略规则rule1过滤条件的源地址为192.166.0.0,掩码为255.255.0.0的IPv4子网地址。
[Sysname-security-policy-ip-0-rule1] source-ip-subnet 192.166.0.0 255.255.0.0
source-ip-subnet命令用来配置作为安全策略规则过滤条件的源IPv6子网地址。
undo source-ip-subnet命令用来删除作为安全策略规则过滤条件的源IPv6子网地址。
source-ip-subnet { ipv6-address prefix-length | ipv6-address/prefix-length }
undo source-ip-subnet [ ipv6-address prefix-length | ipv6-address/prefix-length ]
不存在源IPv6子网地址过滤条件。
IPv6安全策略规则视图
context-admin
source-ip-subnet命令用来配置指定子网的源IPv6地址过滤条件。
多次执行本命令,可配置多个源IPv6子网地址作为安全策略规则的过滤条件。
# 配置作为安全策略规则rule1过滤条件的源地址为192: 167::0,地址前缀长度为64的IPv6子网地址。
[Sysname-security-policy-ipv6-0-rule1] source-ip-subnet 192:167::0 64
1.1.60  source-mac
source-mac命令用来配置作为安全策略规则过滤条件的源MAC地址。
undo source-mac命令用来删除作为安全策略规则过滤条件的源MAC地址。
source-mac object-group-name
undo source-mac [ object-group-name ]
安全策略规则中不存在过滤条件。
IPv4安全策略规则视图
context-admin
object-group-name:表示源MAC地址对象组的名称,为1~63个字符的字符串,不区分大小写,且不能为字符串any。使用undo source-mac命令时若不指定此参数,则表示删除此规则中所有源MAC地址类型的过滤条件。有关MAC地址对象组的详细介绍,请参见“安全配置指导”中的“对象组”。
多次执行本命令,可配置多个源MAC地址作为安全策略规则的过滤条件。
配置源MAC地址作为安全策略规则的过滤条件时,若指定的地址对象组不存在,该配置仍会配置成功,同时也会在系统中创建一个名称为指定名称的空配置地址对象组,但此条过滤条件不会匹配任何报文。
# 配置作为安全策略规则rule1过滤条件的源MAC地址对象组为mac1和mac2。
[Sysname-security-policy-ip-0-rule1] source-mac mac1
[Sysname-security-policy-ip-0-rule1] source-mac mac2
source-microsegment命令用来配置作为安全策略规则过滤条件的源微分段
undo source-microsegment命令用来删除作为安全策略规则过滤条件的源微分段
source-microsegment microsegment-id [ mask-length mask-length ]
undo source-microsegment [ microsegment-id [ mask-length mask-length ] ]
不存在源微分段过滤条件。
安全策略规则视图
context-admin
microsegment-id:源微分段ID,取值范围为1~65535,使用undo命令如果不指定该参数,则表示删除该规则中所有源微分段的过滤条件。
多次执行本命令,可配置多个源微分段作为安全策略规则的过滤条件。
# 配置作为安全策略规则rule1过滤条件的源微分段索引为10,聚合源微分段的掩码长度为1。
[Sysname-security-policy-ip-0-rule1] source-microsegment 10 mask-length 1
·     destination-microsegment
1.1.62  source-zone
source-zone命令用来配置作为安全策略规则过滤条件的源安全域。
undo source-zone命令用来删除作为安全策略规则过滤条件的源安全域。
source-zone source-zone-name
undo source-zone [ source-zone-name ]
不存在源安全域过滤条件。
安全策略规则视图
context-admin
source-zone-name:表示源安全域的名称,为1~31个字符的字符串,不区分大小写。使用undo source-zone命令时若不指定此参数,则表示删除此规则中所有源安全域类型的过滤条件。有关安全域的详细介绍,请参见“安全配置指导”中的“安全域”。
多次执行本命令,可配置多个源安全域作为安全策略规则的过滤条件。
配置源安全域作为安全策略规则的过滤条件时,若指定的源安全域不存在,该配置仍会配置成功,但此条过滤条件不会匹配任何报文。
# 配置作为安全策略规则rule1过滤条件的源安全域为Trust和DMZ。
[Sysname-security-policy-ip-0-rule1] source-zone trust
[Sysname-security-policy-ip-0-rule1] source-zone dmz
1.1.63  terminal
terminal命令用来配置作为安全策略规则过滤条件的终端名称。
undo terminal命令用来删除作为安全策略规则过滤条件的终端名称。
undo terminal [ terminal-name ]
不存在终端名称过滤条件。
安全策略规则视图
context-admin
terminal-name:表示终端的名称,为1~63个字符的字符串,不区分大小写,且不能为字符串invalid和other。使用undo terminal命令时若不指定此参数,则表示删除此规则中所有终端名称的过滤条件。
终端即网络摄像机终端设备,终端名称为网络摄像机的名称。多次执行本命令,可配置多个终端作为安全策略规则的过滤条件。
为使安全策略中配置的终端名称可以被识别,必须先放行终端所依赖的基础协议报文。
在端口仿冒网络环境中,必须先放行仿冒的基础协议报文,才能识别出仿冒报文中的终端。
# 配置作为安全策略规则rule1过滤条件的终端名称为terminal1。
[Sysname-security-policy-ip-0-rule1] terminal terminal1
terminal-group命令用来配置作为安全策略规则过滤条件的终端组。
undo terminal-group命令用来删除作为安全策略规则过滤条件的终端组。
undo terminal-group [ terminal-name ]
不存在终端组名称过滤条件。
安全策略规则视图
context-admin
terminal-group-name:表示终端组的名称,为1~63个字符的字符串,不区分大小写,且不能为字符串invalid和other。使用undo terminal-group命令时若不指定此参数,则表示删除此规则中所有终端组类型的过滤条件。
多次执行本命令,可配置多个终端组作为安全策略规则的过滤条件。
为使安全策略中配置的终端组可以被识别,必须先放行终端组下属终端所依赖的基础协议报文。
# 配置作为安全策略规则rule1过滤条件的终端组为group1。
[Sysname-security-policy-ip-0-rule1] terminal-group group1
1.1.65  time-range
time-range命令用来配置安全策略规则生效的时间段。
undo time-range [ time-range-name ]命令用来恢复缺省情况。
undo time-range
不限制安全策略规则生效的时间。
安全策略规则视图
context-admin
time-range-name:表示时间段的名称,为1~63个字符的字符串,不区分大小写。为避免混淆,时间段的名称不允许使用英文单词all。使用undo命令时若不指定此参数,表示删除此规则的生效时间段。有关时间段的详细介绍,请参见“ACL和QoS配置指导”中的“时间段”。
【配置指导】
# 为安全策略规则rule1配置生效时间段为work。
[Sysname-security-policy-ip-0-rule1] time-range work
·     time-range(ACL和QoS命令参考/时间段)
1.1.66  track
track命令用来配置安全策略规则与Track项联动。
undo track命令用来取消安全策略规则与Track项联动。
track { negative | positive } track-entry-number
undo track
安全策略规则未与Track项联动。
安全策略规则视图
context-admin
negative:指定安全策略规则与Track项的Negative状态联动。
positive:指定安全策略规则与Track项的Positive状态联动。
track-entry-number:表示关联的Track项序号,取值范围为1~1024。有关Track的详细配置请参见“网络管理和监控配置指导”中的“Track”。
配置安全策略规则与Track项的Negative状态联动后,当安全策略规则收到Negative状态的Track通知时,将此规则置为有效状态(Active),当安全策略规则收到Positive状态的Track通知时,将此规则置为失效状态(Inactive)。
配置安全策略规则与Track项的Positive状态联动后,当安全策略规则收到Positive状态的Track通知时,将此规则置为有效状态(Active),当安全策略规则收到Negative状态的Track通知时,将此规则置为失效状态(Inactive)。
# 为安全策略规则rule1配置规则与Track项的Positive状态联动。
[Sysname-security-policy-ip-0-rule1] track positive 10
·     track bfd(网络管理和监控命令参考/Track)
·     track interface(网络管理和监控命令参考/Track)
·     track ip route reachability(网络管理和监控命令参考/Track)
·     track nqa(网络管理和监控命令参考/Track)
traffic-log drop enable命令用来开启流量拒绝日志输出功能。
undo traffic-log drop enable命令用来恢复缺省情况。
流量拒绝日志输出功能处于关闭状态。
安全策略规则视图
context-admin
开启本功能后,设备在安全策略丢包时生成并发送流量日志,便于管理员排查网络问题。
流量日志支持快速日志方式输出,必须配置快速日志输出的相关参数后才能输出流量日志信息,有关快速日志的详细介绍,请参见“网络管理和监控配置指导”中的“快速日志输出”。
# 开启流量拒绝日志输出功能。
[Sysname-security-policy-ip]rule 10 name 10
[Sysname-security-policy-ip-10-10] traffic-log drop enable
traffic-log session-end enable命令用来开启流量结束日志输出功能。
undo traffic-log session-end enable命令用来恢复缺省情况。
未配置流量结束日志输出功能,设备是否输出日志由全局流量日志输出功能控制。如果开启了全局流量日志输出功能,则设备会在删除会话表时生成并发送流量日志;如果未开启全局流量日志输出功能,则设备不发送流量日志。有关全局流量日志输出功能的详细介绍,请参见“安全配置指导”中的“流量日志”。
安全策略规则视图
context-admin
开启本功能后,设备会在删除会话表时生成并发送流量日志。
# 开启流量结束日志输出功能。
[Sysname-security-policy-ip] rule 10 name 10
[Sysname-security-policy-ip-10-10] traffic-log session-end enable
·     traffic-log session-end global enable(安全命令参考/流量日志)
traffic-log session-start enable命令用来开启流量开始日志输出功能。
undo traffic-log session-start enable命令用来恢复缺省情况。
流量开始日志输出功能处于关闭状态。
安全策略规则视图
context-admin
开启本功能后,设备在会话表创建或匹配的安全策略变更时生成并发送流量日志。
# 开启流量开始日志输出功能。
[Sysname-security-policy-ip-10-10] traffic-log session-start enable
1.1.70  url-category
url-category命令用来配置作为安全策略规则过滤条件的URL过滤分类。
undo url-category命令用来删除作为安全策略规则过滤条件的URL过滤分类。
url-category url-category-name
undo url-category [ url-category-name ]
不存在URL过滤分类过滤条件。
安全策略规则视图
context-admin
url-category-name:表示URL过滤分类的名称,为1~63个字符的字符串,不区分大小写。使用undo url-category命令时若不指定此参数,则表示删除此规则中所有URL过滤分类类型的过滤条件。有关URL过滤分类的详细介绍,请参见“DPI深度安全配置指导”中的“URL过滤”。
多次执行本命令,可配置多个URL过滤分类作为安全策略规则的过滤条件。
# 配置作为安全策略规则rule1过滤条件的URL过滤分类名称为category1。
[Sysname-security-policy-ip-0-rule1] url-category category1
·     url-filter category(DPI深度安全命令参考/URL过滤)
1.1.71  user
user命令用来配置作为安全策略规则过滤条件的用户。
undo user命令用来删除作为安全策略规则过滤条件的用户。
user username [ domain domain-name ]
undo user [ username [ domain domain-name ] ]
不存在用户过滤条件。
安全策略规则视图
context-admin
username:表示用户的名称,为1~55个字符的字符串,区分大小写,不能是a、al和all,且不能包含“@”。使用undo user命令时若不指定此参数,则表示删除此规则中所有用户类型的过滤条件。有关用户的详细介绍,请参见“安全配置指导”中的“用户身份识别与管理”。
domain domain-name:表示在指定的身份识别域中匹配此用户。domain-name是身份识别域的名称,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“:”、“*”、“?”、“<”、“>”和“@”字符。若不指定此参数,则表示在不属于任何身份识别域的用户中匹配此用户。
多次执行本命令,可配置多个用户作为安全策略规则的过滤条件。
使用undo user命令时若不指定用户,则表示删除此规则中所有用户类型的过滤条件;若不指定身份识别域,则表示删除此规则中不属于任何身份识别域的用户。
有关身份识别用户和身份识别域的详细介绍,请参见“安全配置指导”中的“用户身份识别与管理”。
# 配置作为安全策略规则rule1过滤条件的用户为usera和userb,身份识别域均为test。
[Sysname-security-policy-ip-0-rule1] user usera domain test
[Sysname-security-policy-ip-0-rule1] user userb domain test
·     user-identity enable(安全命令参考/用户身份识别与管理)
·     user-identity static-user(安全命令参考/用户身份识别与管理)
1.1.72  user-group
user-group命令用来配置作为安全策略规则过滤条件的用户组。
undo user-group命令用来删除作为安全策略规则过滤条件的用户组。
user-group user-group-name [ domain domain-name ]
undo user-group [ user-group-name [ domain domain-name ] ]
不存在用户组过滤条件。
安全策略规则视图
context-admin
user-group-name:表示用户组的名称,为1~200个字符的字符串,不区分大小写。使用undo user-group命令时若不指定此参数,则表示删除此规则中所有用户组类型的过滤条件。有关用户组的详细介绍,请参见“安全配置指导”中的“用户身份识别与管理”。
domain domain-name:表示在指定的身份识别域中匹配此用户组,domain-name是身份识别域的名称,为1~255个字符的字符串,不区分大小写,不能包括“/”、“\”、“|”、“:”、“*”、“?”、“<”、“>”以及“@”字符。若不指定此参数,则表示在不属于任何身份识别域的用户组中匹配此用户组。
多次执行本命令,可配置多个用户组作为安全策略规则的过滤条件。
使用undo user-group命令时若不指定用户组,则表示删除此规则中所有用户组类型的过滤条件;若不指定身份识别域,则表示删除此规则中不属于任何身份识别域的用户组。
有关身份识别用户组和身份识别域的详细介绍,请参见“安全配置指导”中的“用户身份识别与管理”。
# 配置作为安全策略规则rule1过滤条件的用户组为groupa和groupb,身份识别域均为test。
[Sysname-security-policy-ip-0-rule1] user-group groupa domain test
[Sysname-security-policy-ip-0-rule1] user-group groupb domain test
·     user-group(安全命令参考/AAA)
1.1.73  vrf
vrf命令用来配置安全策略规则对入接口指定VPN多实例中的报文有效。
undo vrf命令用来恢复缺省情况。
vrf vrf-name
undo vrf
安全策略规则对公网的报文有效。
安全策略规则视图
context-admin
vrf-name:表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
【配置指导】
# 配置安全策略规则rule1对入接口的VPN多实例vpn1中的报文生效。
[Sysname-security-policy-ip-0-rule1] vrf vpn1
