12-IPv6组播路由与转发命令
本章节下载: 12-IPv6组播路由与转发命令 (319.73 KB)
1.1.1 delete ipv6 rpf-route-static
1.1.2 display ipv6 mrib interface
1.1.3 display ipv6 multicast boundary
1.1.4 display ipv6 multicast fast-forwarding cache
1.1.5 display ipv6 multicast forwarding df-info
1.1.6 display ipv6 multicast forwarding event
1.1.7 display ipv6 multicast forwarding-table
1.1.8 display ipv6 multicast forwarding-table df-list
1.1.9 display ipv6 multicast routing-table
1.1.10 display ipv6 multicast routing-table static
1.1.11 display ipv6 multicast rpf-info
1.1.12 ipv6 mtrace-service port
1.1.13 ipv6 multicast boundary
1.1.14 ipv6 multicast forwarding supervlan community
1.1.15 ipv6 multicast forwarding-table cache-unknown per-entry
1.1.16 ipv6 multicast forwarding-table cache-unknown total
1.1.19 load-splitting (IPv6 MRIB view)
1.1.20 longest-match (IPv6 MRIB view)
1.1.22 reset ipv6 multicast fast-forwarding cache
1.1.23 reset ipv6 multicast forwarding event
1.1.24 reset ipv6 multicast forwarding-table
1.1.25 reset ipv6 multicast routing-table
delete ipv6 rpf-route-static命令用来删除所有IPv6组播静态路由。
delete ipv6 rpf-route-static [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,表示指定公网。
本命令用来删除所有的IPv6组播静态路由,而undo ipv6 rpf-route-static命令则用来删除指定的IPv6组播静态路由。
# 删除公网中的所有IPv6组播静态路由。
[Sysname] delete ipv6 rpf-route-static
This will erase all ipv6 multicast static routes and their configurations, you must reconfigure all ipv6 static routes.
Are you sure?[Y/N]:y
· ipv6 rpf-route-static
display ipv6 mrib interface命令用来显示IPv6 MRIB(Multicast Routing Information Base,组播路由信息库)维护的接口信息。
display ipv6 mrib [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ]
vpn-instance vpn-instance-name:显示指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的信息。
interface-type interface-number:显示指定接口上IPv6 MRIB维护的接口信息。如果未指定本参数,将显示所有接口上IPv6 MRIB维护的接口信息。
# 显示公网实例接口上IPv6 MRIB维护的接口信息。
<Sysname> display ipv6 mrib interface
Interface: Vlan-interface1
Index: 0x00004444
Current state: up
MTU: 1500
Type: BROADCAST
Protocol: PIM-DM
PIM protocol state: Enabled
Address list:
1. Local address : FE80:7:11::1/10
Remote address: ::
Reference : 1
State : NORMAL
Flags : 0x0
表1-1 display ipv6 mrib interface命令显示信息描述表
    字段  |
    描述  |
   Interface  |
   接口的名称  |
   Index  |
   接口的索引号  |
   Current state  |
   接口的状态,包括up和down  |
   MTU  |
   MTU(Maximum Transmission Unit,最大传输单元)值  |
   Type  |
   接口的类型,包括: · BROADCAST:表示广播链路接口 · LOOP:表示LoopBack接口 · REGISTER:表示注册接口 · MTUNNEL:表示组播隧道接口 如果接口为NULL0接口,则该字段显示为空  |
   Protocol  |
   接口的协议类型标记,包括PIM-DM、PIM-SM、MLD和PROXY  |
   PIM protocol state  |
   IPv6 PIM协议的使能状态,包括: · Enabled:表示使能 · Disabled:表示关闭  |
   Address list  |
   接口地址列表  |
   Local address  |
   本端的地址  |
   Remote address  |
   远端的地址(仅Vlink类型接口有效)  |
   Reference  |
   地址被引用的次数  |
   State  |
   接口地址的状态,包括NORMAL和DEL  |
   Flags  |
   接口属性: · 0x0:接口处于正常状态 · 0x1:接口地址正在被删除  |
display ipv6 multicast boundary命令用来显示IPv6组播边界的信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] boundary { group [ ipv6-group-address [ prefix-length ] ] | scope [ scope-id ] } [ interface interface-type interface-number ]
group:显示IPv6组播组的组播边界信息。
ipv6-group-address:指定IPv6组播组的地址,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的IPv6组播边界信息。
prefix-length:指定IPv6组播组地址的前缀长度,取值范围为8~128,缺省值为128。
scope:显示IPv6管理域的组播边界信息。
scope-id:指定IPv6管理域的编号, IPv6管理域为IPv6组播组地址中的scope字段,取值范围为3~15。
如果未指定本参数,将显示所有IPv6管理域的IPv6组播边界信息。
interface interface-type interface-number:显示指定接口上的IPv6组播边界信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv6组播边界信息。
# 显示公网实例所有接口上所有IPv6组播组的IPv6组播边界信息。
<Sysname> display ipv6 multicast boundary group
Boundary Interface
FF1E::/64 Vlan1
# 显示公网实例所有接口上所有IPv6管理域的IPv6组播边界信息。
<Sysname> display ipv6 multicast boundary scope
Boundary Interface
3 Vlan-interface1
表1-2 display ipv6 multicast boundary命令显示信息描述表
    字段  |
    描述  |
   Boundary  |
   表示IPv6组播边界对应的IPv6组播组或IPv6管理域  |
   Interface  |
   表示IPv6组播边界对应的接口  |
· ipv6 multicast boundary
display ipv6 multicast fast-forwarding cache命令用来显示IPv6组播快速转发表项信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ]
display ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] * [ chassis chassis-number slot slot-number ]
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播快速转发项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播快速转发项,取值范围为FFxy::/16(不包括FFx1::/16 和 FFx2::/1),其中x和y均代表0~F的任意一个十六进制数。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示全局主用主控板上的信息。(IRF模式)
# 显示公网实例组播快转表项的信息。
<Sysname> display ipv6 multicast fast-forwarding cache
Total 1 entries, 1 matched
(FE1F:60::200, FF0E::1)
Status : Enabled
Source port: 2001 Destination port: 2002
Protocol : 2 Flag : 0x2
Incoming interface: Vlan-interface1
List of 1 outgoing interfaces:
Vlan-interface2
Status: Enabled Flag: 0x14
表1-3 display ipv6 multicast fast-forwarding cache命令显示信息描述表
    字段  |
    描述  |
   Total 1 entries, 1 matched  |
   组播快速转发表中(S,G)表项的总数和匹配数  |
   (FE1F:60::200, FF0E::1)  |
   表示IPv6组播路由表的(S,G)表项  |
   Source port  |
   源端口号  |
   Destination port  |
   目的端口号  |
   Protocol  |
   协议号  |
   Flag  |
   (S,G)表项的状态,通过将不同的比特位置位来表示不同的状态 · 0x1:表示由板间透传的报文触发创建的表项 · 0x2:表示组播转发流程添加的表项 (S,G)表项出接口状态,通过将不同的比特位置位来表示不同的状态 · 0x1:表示由板间透传的报文触发创建的出接口 · 0x2:表示向已存在的快转表项增添的出接口 · 0x4:表示需要设置MAC地址 · 0x8:表示入VLAN口或者入Super VLAN口对应的出接口 · 0x10:表示出接口已经与会话建立关联关系 · 0x20:表示待删除的出接口  |
   Status  |
   组播快转表项入cache和出cache的状态, 包括Enabled和Disabled  |
   Incoming interface  |
   表示(S,G)表项的入接口  |
   List of 1 outgoing interfaces  |
   表示(S,G)表项的出接口列表  |
· reset ipv6 multicast fast-forwarding cache all
display ipv6 multicast forwarding df-info命令用来显示IPv6组播转发的DF信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ ipv6-rp-address ] [ verbose ] [ slot slot-number ]
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ ipv6-rp-address ] [ verbose ] [ chassis chassis-number slot slot-number ]
ipv6-rp-address:指定IPv6双向PIM的RP地址。
verbose:显示IPv6组播转发的DF详细信息。如果未指定本参数,将显示IPv6组播转发的DF概要信息。
在IPv6双向PIM域中,只有每个网段的DF才可以向组播组的RP转发组播数据。有关DF的详细介绍,请参见“IPv6 PIM配置指导”中的“IPv6 双向PIM”。
# 显示公网实例IPv6组播转发的DF概要信息。
<Sysname> display ipv6 multicast forwarding df-info
Total 1 RPs, 1 matched
00001. RP address: 7:11::1
Flags: 0x0
Uptime: 01:46:40
RPF interface: Vlan-interface1
List of 1 DF interfaces:
1: Vlan-interface2
# 显示公网实例IPv6组播转发的DF详细信息。
<Sysname> display ipv6 multicast forwarding df-info verbose
MID: 2, Flags: 0x0
Uptime: 00:03:53
Product information: 0x7a2f762f, 0x718fee9f, 0x4b82f137, 0x71c32184
Product information: 0xa567d6fc, 0xadeb03e3
Tunnel information: 0xdfb107d4, 0x7aa5d510
1: Vlan-interface2
Product information: 0xa986152b, 0xb74a9a2f
Tunnel information: 0x297ca208, 0x76985b89
表1-4 display ipv6 multicast forwarding df-info命令显示信息描述表
    字段  |
    描述  |
   Total 1 RPs, 1 matched  |
   RP的总数和匹配数  |
   00001  |
   RP表项的序号  |
   RP address  |
   RP的地址  |
   MID  |
   RP表项的标识,每个RP表项都有唯一的标识  |
   Flags  |
   RP表项的状态,通过将不同的比特位置位来表示不同的状态: · 0x0:表示正常表项 · 0x4:表示表项下刷失败 · 0x8:表示有DF接口下刷失败 · 0x40:表示表项即将被删除 · 0x100:表示表项正在被删除 · 0x200:表示表项处于平滑状态  |
   Uptime  |
   RP表项已存在的时间  |
   Product information  |
   产品信息  |
   Tunnel information  |
   隧道接口信息  |
   RPF interface  |
   到达RP的RPF接口  |
   List of 1 DF interfaces  |
   DF接口列表  |
display ipv6 multicast forwarding event命令用来显示IPv6组播转发的事件统计信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event [ chassis chassis-number slot slot-number ]
# 显示公网实例IPv6组播转发的事件统计信息。
<Sysname> display ipv6 multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
表1-5 display ipv6 multicast forwarding event命令显示信息描述表
    字段  |
    描述  |
   Total active events sent  |
   表项活跃事件的发送次数  |
   Total inactive events sent  |
   表项不活跃事件的发送次数  |
   Total NoCache events sent  |
   NoCache事件的发送次数  |
   Total NoCache events dropped  |
   NoCache事件的丢弃次数  |
   Total WrongIF events sent  |
   WrongIF事件的发送次数  |
   Total WrongIF events droppet  |
   WrongIF事件的丢弃次数  |
   Total SPT switch events sent  |
   SPT切换事件的发送次数  |
   NoCache rate limit  |
   NoCache事件的发送限速,单位为报文/秒  |
   WrongIF rate limit  |
   WrongIF事件的发送限速,单位为报文/10秒  |
   Total timer of register suppress timeout  |
   注册抑制超时的总次数  |
· reset ipv6 multicast forwarding event
display ipv6 multicast forwarding-table命令用来显示IPv6组播转发表的信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number | statistics ] *
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | statistics ] *
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
incoming-interface:显示指定入接口的IPv6组播转发项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的IPv6组播转发项。
outgoing-interface:显示指定出接口的IPv6组播转发项。
exclude:显示出接口列表中不包含指定接口的IPv6组播转发项。
include:显示出接口列表中包含指定接口的IPv6组播转发项。
match:显示出接口列表中包含且仅包含指定接口的IPv6组播转发项。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。指定的单板若为IPv6组播流量的出口单板,则统计信息显示为0。如果未指定本参数,将显示主控板上的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。指定成员设备指定单板若为IPv6组播流量的出口成员设备单板,则统计信息显示为0。如果未指定本参数,将显示全局主用主控板上的信息。(IRF模式)
statistics:显示IPv6组播转发表的统计信息。
# 显示公网实例IPv6组播转发表的信息。
<Sysname> display ipv6 multicast forwarding-table
00001. (1::1, ff0e::1)
Flags: 0x0
Incoming interface: Vlan-interface10
Incoming sub-VLAN: VLAN 11
Outgoing sub-VLAN: VLAN 12
VLAN 13
1: Vlan-interface20
Sub-VLAN: VLAN 21
VLAN 22
Matched 19648 packets(20512512 bytes), Wrong If 0 packets
表1-6 display ipv6 multicast forwarding-table命令显示信息描述表
    字段  |
    描述  |
   IPv6组播转发表中(S,G)表项的总数和匹配数  |
   00001  |
   表示(S,G)表项的序号  |
   (1::1, ff0e::1)  |
   表示IPv6组播转发表的(S,G)表项  |
   Flags  |
   (S,G)表项的状态,通过将不同的比特位置位来表示不同的状态: · 0x0:表示正常表项 · 0x1:表示表项处于Inactive状态 · 0x2:表示空转发表项 · 0x4:表示表项下刷失败 · 0x8:表示有出接口下刷失败 · 0x20:表示表项有注册出接口 · 0x40:表示表项即将被删除 · 0x80:表示表项处于注册抑制状态 · 0x100:表示表项正在被删除 · 0x200:表示表项处于平滑状态 · 0x400:表示表项中存在Super VLAN对应的VLAN接口 · 0x800:表示表项中存在到IPv6组播源地址的ND表项 · 0x4000000:表示表项由MLD代理下发创建 · 0x20000000:表示IPv6双向PIM的转发表项  |
   Uptime  |
   表示(S,G)表项已存在时间  |
   Timeout in  |
   表示(S,G)表项的超时剩余时间  |
   表示(S,G)表项的入接口  |
   Incoming sub-VLAN  |
   表示当(S,G)表项的入接口为Super VLAN对应的VLAN接口时,该Super VLAN的入Sub VLAN  |
   Outgoing sub-VLAN  |
   表示当(S,G)表项的入接口为Super VLAN对应的VLAN接口时,该Super VLAN的出Sub VLAN  |
   表示(S,G)表项的出接口列表  |
   Sub-VLAN  |
   表示当(S,G)表项的出接口为Super VLAN对应的VLAN接口时,该Super VLAN的出Sub VLAN  |
   Matched 19648 packets (20512512 bytes), Wrong If 0 packet  |
   (S,G)表项匹配的报文数量(字节数),发生入接口错误的报文个数  |
   Forwarded 19648 packets (20512512 bytes)  |
   (S,G)表项已转发的IPv6组播报文数量(字节数)  |
· reset ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table df-list命令用来显示IPv6组播转发表的DF列表信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ ipv6-group-address ] [ verbose ] [ slot slot-number ]
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ ipv6-group-address ] [ verbose ] [ chassis chassis-number slot slot-number ]
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播转发表的DF列表信息,取值范围为FFxy::/16(不包括FFx1::/16 和 FFx2::/1),其中x和y均表示0~F的任意一个十六进制数。
verbose:显示IPv6组播转发表的DF列表详细信息。如果未指定本参数,将显示IPv6组播转发表的DF列表概要信息。
# 显示公网实例IPv6组播转发表的DF列表概要信息。
<Sysname> display ipv6 multicast forwarding-table df-list
00001. (::, FF1E::1)
1: Vlan-interface1
# 显示公网实例IPv6组播转发表的DF列表详细信息。
<Sysname> display ipv6 multicast forwarding-table df-list verbose
1: Vlan-interface1
Product information: 0x347849f6, 0x14bd6837
Tunnel information: 0xc4857986, 0x128a9c8f
表1-7 display ipv6 multicast forwarding-table df-list命令显示信息描述表
    字段  |
    描述  |
   表项总数和匹配数  |
   00001  |
   表项的序号  |
   (::, FF1E::1)  |
   组播转发表的(*,G)表项  |
   DF接口列表  |
   产品信息  |
   隧道接口信息  |
display ipv6 multicast routing-table命令用来显示IPv6组播路由表的信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播路由项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
incoming-interface:显示指定入接口的IPv6组播路由项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的IPv6组播路由项。
outgoing-interface:显示指定出接口的IPv6组播路由项。
exclude:显示出接口列表中不包含指定接口的IPv6组播路由项。
include:显示出接口列表中包含指定接口的IPv6组播路由项。
match:显示出接口列表中包含且仅包含指定接口的IPv6组播路由项。
IPv6组播路由表是进行IPv6组播数据转发的基础,通过查看该表可以了解(S,G)表项等的建立情况。
# 显示公网实例IPv6组播路由表的信息。
<Sysname> display ipv6 multicast routing-table
Total 1 entries
00001. (2001::2, FFE3::101)
Uptime: 00:00:14
Upstream Interface: Vlan-interface1
List of 2 downstream interfaces
1: Vlan-interface2
2: Vlan-interface3
表1-8 display ipv6 multicast routing-table命令显示信息描述表
    字段  |
    描述  |
   Total 1 entries  |
   IPv6组播路由表中(S,G)表项的总数  |
   00001  |
   表示(S,G)表项的序号  |
   (2001::2, FFE3::101)  |
   Uptime  |
   表示(S,G)表项已经存在的时间  |
   Upstream Interface  |
   表示(S,G)表项的上游接口,表示IPv6组播数据应该从此接口到达  |
   List of 2 downstream interfaces  |
   下游接口列表,表示哪些接口需要进行组播转发  |
· reset ipv6 multicast routing-table
display ipv6 multicast routing-table static命令用来显示IPv6组播静态路由表的信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table static [ ipv6-source-address [ prefix-length ] ]
vpn-instance vpn-instance-name:显示指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,表示指定公网。
ipv6-source-address:显示指定组播源的IPv6组播静态路由信息。
prefix-length:指定IPv6组播源地址的前缀长度,取值范围为0~128,缺省值为128。
本命令只显示已生效的IPv6组播静态路由信息。
# 显示公网组播静态路由表的信息。
<Sysname> display ipv6 multicast routing-table static
Destinations: 2 Routes: 4
Destination/Prefix: 2::100/128
Pre: 10
RPF neighbor Interface
100::2 Vlan11
125:0:3::3 Vlan12
Destination/Prefix: 3::100/128
Pre: 20
100::3 Vlan13
125:0:3::4 Vlan14
表1-9 display ipv6 multicast routing-table static命令显示信息描述表
    字段  |
    描述  |
   Destinations  |
   目的IPv6地址个数  |
   Routes  |
   路由条数  |
   Destination/Prefix  |
   目的IPv6地址/前缀长度  |
   Pre  |
   路由优先级  |
   RPF neighbor  |
   可达目的地址的RPF邻居的IPv6地址  |
   Interface  |
   可达目的地址的出接口  |
display ipv6 multicast rpf-info命令用来显示IPv6组播源的RPF信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] rpf-info ipv6-source-address [ ipv6-group-address ]
ipv6-source-address:显示指定IPv6组播源的RPF信息。
ipv6-group-address:显示指定IPv6组播组的RPF信息,取值范围为FFxy::/16(但不包括下列地址: FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
# 显示公网IPv6组播源2001::101的全部RPF信息。
<Sysname> display ipv6 multicast rpf-info 2001::101
RPF information about source 2001::101:
RPF interface: Vlan-interface1, RPF neighbor: FE80::A01:101:1
Referenced prefix/prefix length: 2001::/64
Referenced route type: igp
Load splitting rule: disable
Source AS: 0
C-multicast route target: 0x0000000000000000
表1-10 display ipv6 multicast rpf-info命令显示信息描述表
    字段  |
    描述  |
   RPF information about source 2001::101  |
   到IPv6组播源2001::101的RPF路径信息  |
   RPF interface  |
   表示RPF接口名称  |
   RPF neighbor  |
   表示RPF邻居的IPv6地址(链路本地地址)  |
   Referenced prefix/prefix length  |
   表示引用的路由及其前缀长度  |
   Referenced route type  |
   表示引用的路由类型,可以是下列类型之一: · igp:IPv6单播路由(内部网关协议) · egp:IPv6单播路由(外部网关协议) · unicast (direct):IPv6单播路由(直连) · unicast:其它IPv6单播路由(如IPv6单播静态路由等) · mbgp:IPv6 MBGP路由  |
   Route selection rule  |
   RPF路由选择规则,可以是根据路由协议的路由优先级进行选择,或者是按照目的地址对路由表进行最长匹配  |
   Load splitting rule  |
   是否使能了负载分担规则  |
   Source AS  |
   组播源所在PE的AS号  |
   C-multicast route target  |
   C-multicast路由扩展团体属性  |
· display ipv6 multicast forwarding-table
· display ipv6 multicast routing-table
ipv6 mtrace-service port命令用来配置IPv6 Mtrace服务使用的UDP端口号。
undo ipv6 mtrace-service port命令用来恢复缺省情况。
ipv6 mtrace-service port number
IPv6 Mtrace功能使用的UDP端口号为10240。
number:指定IPv6 Mtrace功能使用的UDP端口号,取值范围为1024~49151。
使用IPv6 Mtrace功能时,跟踪路径上的所有设备必须使用本命令配置相同的UDP端口号,并且与mtrace v2 ipv6命令指定的UDP端口号一致。
保证配置的端口号不被其他模块使用,否则可能导致跟踪失败。
# 配置IPv6 Mtrace功能使用的UDP端口号为12345。
<Sysname> system-interview
[sysname] ipv6 mtrace-service port 12345
· mtrace v2 ipv6
ipv6 multicast boundary命令用来配置IPv6组播转发边界。
undo ipv6 multicast boundary命令用来删除IPv6组播转发边界。
ipv6 multicast boundary { ipv6-group-address prefix-length | scope { scope-id | admin-local | global | organization-local | site-local } }
undo ipv6 multicast boundary { ipv6-group-address prefix-length | all | scope { scope-id | admin-local | global | organization-local | site-local } }
接口上不存在IPv6组播转发边界。
ipv6-group-address:指定IPv6组播组地址,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
prefix-length:指定IPv6组播组地址的前缀长度,取值范围为8~128。
all:删除该接口上配置所有IPv6组播转发边界。
scope-id:指定Scope字段的值,IPv6组播组地址中的scope字段表示IPv6管理域,取值范围为3~15。
admin-local:指定Scope字段为管理本地范围,对应的Scope值为4。
global:指定Scope字段为全局范围,对应的Scope值为14。
organization-local:指定Scope字段为机构本地范围,对应的Scope值为8。
site-local:指定Scope字段为站点本地范围,对应的Scope值为5。
IPv6组播转发边界为指定地址范围或Scope值的IPv6组播组划定了边界条件,如果IPv6组播报文的目的地址与边界条件匹配,就停止转发。
一个接口可以作为不同地址范围的IPv6组播组的转发边界,即允许在同一接口上多次执行本命令为不同地址范围的IPv6组播组设定转发边界;但一个接口只能作为特定Scope值的IPv6组播组的转发边界,若在同一接口上多次执行本命令为不同Scope值的IPv6组播组设定转发边界,则只有最后一次的配置生效。
执行本命令不需要使能IPv6组播路由。
假设A和B为不同地址范围的IPv6组播组的集合,且B是A的真子集:如果接口先配置为A的转发边界,再配置为B的转发边界,则该接口仍然为A的转发边界;如果接口先配置为B的转发边界,再配置为A的转发边界,则该接口将变为A的转发边界。
# 将接口Vlan-interface100配置为地址范围为FF03::/16的IPv6组播组的转发边界。
[Sysname-Vlan-interface100] ipv6 multicast boundary ff03:: 16
# 将接口Vlan-interface100配置为Scope值为4的IPv6组播组的转发边界。
[Sysname-Vlan-interface100] ipv6 multicast boundary scope 4
· display ipv6 multicast boundary
ipv6 multicast forwarding supervlan community命令用来配置IPv6组播数据在Super VLAN内的各Sub VLAN之间互通。
undo ipv6 multicast forwarding supervlan community命令用来恢复缺省情况。
IPv6组播数据在Super VLAN内的各Sub VLAN之间隔离。
VLAN接口视图
执行本命令后必须清除IPv6组播转发表中所有以该VLAN接口为入接口的转发项,否则本命令将不能生效。
利用reset ipv6 multicast forwarding-table 命令来清 除IPv6组播转发表中的表项。
# 配置IPv6组播数据在Super VLAN 2内的各Sub VLAN之间互通。
[Sysname-Vlan-interface2] ipv6 multicast forwarding supervlan community
ipv6 multicast forwarding-table cache-unknown per-entry命令用来设置对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目。
undo ipv6 multicast forwarding-table cache-unknown per-entry命令用来恢复缺省情况。
ipv6 multicast forwarding-table cache-unknown per-entry per-entry-limit
对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目为1。
per-entry-limit:对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目,取值范围为0~256。当取值为0时,代表不可缓存未知IPv6组播数据报文。
# 设置对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目为20。
[Sysname] ipv6 multicast forwarding-table cache-unknown per-entry 20
· ipv6 multicast forwarding-table cache-unknown total
ipv6 multicast forwarding-table cache-unknown total命令用来设置内存中可缓存的未知IPv6组播数据报文的最大数目。
undo multicast forwarding-table cache-unknown total命令用来恢复缺省情况。
ipv6 multicast forwarding-table cache-unknown total total-limit
undo ipv6 multicast forwarding-table cache-unknown total
内存中可缓存的未知IPv6组播数据报文的最大数目为1024。
total-limit:内存中可缓存的未知IPv6组播数据报文的最大数目,取值范围为0~65535。当取值为0时,代表不可缓存未知IPv6组播数据报文。
建议本命令配置的值要远远大于ipv6 multicast forwarding-table cache-unknown per-entry命令配置的值。
# 设置内存中可缓存的未知IPv6组播数据报文的最大数目为10000。
[Sysname] ipv6 multicast forwarding-table cache-unknown total 10000
· ipv6 multicast forwarding-table cache-unknown per-entry
ipv6 multicast routing命令用来使能IPv6组播路由,并进入IPv6 MRIB视图。
undo ipv6 multicast routing命令用来关闭IPv6组播路由。
ipv6 multicast routing [ vpn-instance vpn-instance-name ]
undo ipv6 multicast routing [ vpn-instance vpn-instance-name ]
IPv6组播路由处于关闭状态。
只有在公网实例或VPN实例中使能了IPv6组播路由,其它三层IPv6组播功能才能生效;没有使能IPv6组播路由前,设备不转发任何IPv6组播报文。
# 使能公网实例中的IPv6组播路由,并进入公网实例的IPv6 MRIB视图。
[Sysname] ipv6 multicast routing
[Sysname-mrib6]
# 使能VPN实例mvpn中的IPv6组播路由,并进入该VPN实例的IPv6 MRIB视图。
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn]
ipv6 rpf-route-static命令用来配置IPv6组播静态路由。
undo ipv6 rpf-route-static命令用来删除指定的IPv6组播静态路由。
ipv6 rpf-route-static [ vpn-instance vpn-instance-name ] ipv6-source-address prefix-length { ipv6-rpf-nbr-address | interface-type interface-number } [ preference preference ]
undo ipv6 rpf-route-static [ vpn-instance vpn-instance-name ] ipv6-source-address prefix-length { ipv6-rpf-nbr-address | interface-type interface-number }
不存在IPv6组播静态路由。
ipv6-source-address:指定IPv6组播源地址。
ipv6-rpf-nbr-address:指定RPF邻居的IPv6地址。
interface-type interface-number:指定与RPF邻居相连接口的接口类型和接口编号。
preference:指定路由优先级,取值范围为1~255,缺省值为1。
非点到点类型的接口(包括三层以太网接口、三层聚合接口、Loopback接口或VLAN接口等)不能使用指定接口的方式来指定RPF邻居,只能使用指定地址的方式。
配置的IPv6组播静态路由并不一定会生效,因为可能出现指定的RPF邻居无法迭代出接口、指定的RPF接口不属于本实例、指定的RPF接口不是点到点类型或处于down状态等情况。此外,若在相同IPv6组播源地址范围下有多条配置,只有路由优先级最高的那条才能被激活。因此,配置完成后建议使用display ipv6 multicast routing-table static命令查看该IPv6组播静态路由是否已生效。
undo ipv6 rpf-route-static命令用来删除指定的IPv6组播静态路由,而delete ipv6 rpf-route-static命令则用来删除所有的IPv6组播静态路由。
# 在公网中配置到组播源101::0/64的IPv6组播静态路由,其RPF邻居的IPv6地址是106::7。
[Sysname] ipv6 rpf-route-static 101::0 64 106::7
· delete ipv6 rpf-route-static
· display ipv6 multicast routing-table static
load-splitting命令用来配置对IPv6组播流量进行负载分担。
undo load-splitting命令用来恢复缺省情况。
undo load-splitting
不对IPv6组播流量进行负载分担。
IPv6 MRIB视图
source:仅根据IPv6组播源对IPv6组播流量进行负载分担。
source-group:根据IPv6组播源组对IPv6组播流量进行负载分担。
本命令对IPv6双向PIM不生效。
# 在公网实例中配置仅根据IPv6组播源对IPv6组播流量进行负载分担。
[Sysname-mrib6] load-splitting source
longest-match命令用来配置按照最长匹配来选择RPF路由,即选择掩码最长的路由作为RPF路由。
undo longest-match命令用来恢复缺省情况。
longest-match
undo longest-match
选择路由优先级最高的路由作为RPF路由。
IPv6 MRIB视图
# 在公网实例中配置按照最长匹配原则选择RPF路由。
[Sysname-mrib6] longest-match
mtrace v2 ipv6命令用来配置利用IPv6 Mtrace功能跟踪组播数据的传输路径。
mtrace v2 ipv6 [ vpn-instance vpn-instance-name ] { source-address | group-address } * [ destination address | port number | wait-time time | max-hop count ] * [ verbose ]
source-address:指定组播源地址。
group-address:指定IPv6组播组地址,取值范围为FFxy::/16(但不包括下列地址:FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
destination address:指定目的端的地址,缺省使用组播地址FF02::2。
port number:指定IPv6 Mtrace操作使用的UDP端口号,取值范围为1024~49151,缺省值为10240。
wait-time time:等待目的端回复的超时时间,取值范围为1~65535,单位为秒,缺省值为10。若在配置的time内一直没有收到回复,则自动切换成逐跳模式跟踪。
max-hop count:跟踪的最大跳数,取值范围为1~255,缺省值为255。如果跟踪过程中跟踪的路由器个数达到配置的最大跳数,直接回复查询器并结束本次跟踪。
配置时需要注意:
· 如果只配置source-address,表示跟踪(S,*)的传输路径,从目的端开始到组播源直连的设备后结束跟踪。此时必须指定目的端的地址,否则无法找寻组播路径。
· 如果只配置group-address,表示跟踪(*,G)的传输路径,从目的端开始到达RP时结束跟踪。此时必须指定目的端的地址,且此目的端在RP的下游,否则无法找寻组播路径。
· 如果同时配置source-address和group-address,表示跟踪(S,G)的传输路径,从最接近配置此命令的设备或从目的端开始跟踪到组播源直连的设备后结束跟踪。
· 跟踪的设备个数超过最大跳数后会终止跟踪。
如果客户端在规定的时间内没有收到回复,跟踪模式会自动切换成逐跳模式。即发送最大跳数为1的查询报文,并等待回复。如果在规定时间内收到回复,会继续发送最大跳数为2的查询报文。依此类推,发送跳数递增的查询报文,直到跟踪结束。如果路径中某设备未能在规定时间内回复,则不再继续发送跳数递增的查询报文。
# 跟踪组播数据(10::7,ff1e::1)的传输路径,指定目的端的地址为50::5。并显示概要信息,
<Sysname> mtrace v2 ipv6 10::7 ff1e::1 destination 50::5
Mtrace from 10::7 to 50::5 via group ff1e::1, 255 hops at most, press
CTRL_C to break.
Querying full reverse path...
Hop Local address Protocol Time Fwd code
0 50::1 PIM-SM(OSPF) 50 s NO_ERROR
-1 40::1 PIM-SM(OSPF) 40 s NO_ERROR
-2 30::1 PIM-SM(OSPF) 60 s NO_ERROR
-3 20::1 PIM-SM(OSPF) 55 s NO_ERROR
-4 10::1 PIM-SM(OSPF) 30 s NO_ERROR
表1-11 mtrace v2 ipv6命令显示信息描述表
    字段  |
    描述  |
   Hop  |
   跳数(0表示最后一跳,-1表示倒数第一跳,依此类推)  |
   Local address  |
   跟踪路径上的地址  |
   Protocol  |
   跟踪的路径上运行的组播路由协议,取值为: · PIM-SM:PIM-SM路由协议 · PIM-DM:PIM-DM路由协议 跟踪的路径上运行的单播路由协议,取值为: · LOCAL:直连路由 · STATIC ROUTE:静态路由协议 · RIP:RIP路由协议 · ISIS:ISIS路由协议 · OSPF:OSPF路由协议 · BGP:BGP路由协议  |
   Time  |
   两台设备间mtrace报文传输时间  |
   Fwd code  |
   转发错误码,取值为: · NO_ERROR:没有任何错误 · WRONG_IF:收到mtrace报文的接口不在出接口列表中 · PRUNE_SENT:给上游发送过剪枝报文 · PRUNE_RCVD:从下游收到过剪枝报文 · SCOPED:入接口或出接口上配置了组播边界 · NO_ROUTE:没有到组播源或RP的路由信息 · WRONG_LAST_HOP:收到查询报文的设备不是正确的目的设备 · REACHED_RP:跟踪(*,G)且跟踪到RP · RPF_IF:从RPF接口上收到mtrace报文 · NO_MULTICAST:收到mtrace报文的接口上没有使能组播 · NO_SPACE:如果再添加信息块,报文长度将超过1280字节  |
# 跟踪组播数据(10::7,ff1e::1)的传输路径,指定目的端的地址为50::5,并显示详细信息。
<Sysname> mtrace v2 ipv6 10::7 ff1e::1 destination 50::5 verbose
Mtrace from 10::7 to 50::5 via group ff1e::1, 255 hops at most, use query
ID 12345, client port 50001, press CTRL_C to break.
0: Incoming interface ID: 1501
Outgoing interface ID: 1502
Local address: 50::1
Remote address: FE80::A27B:99FF:FECB:207
Input multicast packets: 111
Output multicast packets: 111
Forwarded packets for the (S, G) pair: 22
Multicast protocol in use: PIM-SM
Unicast protocol in use: OSPF
Forwarding code: NO_ERROR
Time used (s): 50
-1: Incoming interface ID: 1601
Outgoing interface ID: 1602
Local address: 40::1
Remote address: FE80::A27B:99FF:FECB:206
Time used (s): 50
表1-12 mtrace v2 ipv6命令显示信息描述表
    字段  |
    描述  |
   -1  |
   Incoming interface ID  |
   入接口索引  |
   Outgoing interface ID  |
   出接口索引  |
   Local address  |
   跟踪路径上的地址  |
   Remote address  |
   上游地址  |
   Input multicast packets  |
   入接口上收到的组播报文统计  |
   Output multicast packets  |
   出接口上转发的组播报文统计  |
   Forwarded packets for the (S, G) pair  |
   转发的(S,G)报文统计  |
   Multicast protocol in use  |
   入接口上运行的组播路由协议  |
   Unicast protocol in use  |
   入接口上运行的单播路由协议  |
   Forwarding code  |
   Time used (s)  |
   两台设备间mtrace报文传输延时  |
· ipv6 mtrace-service port
reset ipv6 multicast fast-forwarding cache命令用来清除IPv6组播快速转发表中的转发项。
(独立运行模式)
reset ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ]
reset ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all } [ chassis chassis-number slot slot-number ]
vpn-instance vpn-instance-name:清除指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将清除公网实例的信息。
ipv6-source-address:IPv6组播源地址,清除包含指定组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,清除指定组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
all:清除组播快速转发表中的所有组播转发项
#从公网实例IPv6组播快速转发表中清除所有组播转发表项。
<Sysname> reset ipv6 multicast fast-forwarding cache all
#从公网实例IPv6组播快速转发表中清除组播源组为(FE1F:20::2 ,FF0E::1)的转发表项。
<Sysname> reset ipv6 multicast fast-forwarding cache fe1f:20::2 ff0e::1
· display ipv6 multicast fast-forwarding cache
reset ipv6 multicast forwarding event命令用来清除IPv6组播转发的事件统计信息。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event
# 清除公网实例IPv6组播转发的事件统计信息。
<Sysname> reset ipv6 multicast forwarding event
· display ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table命令用来清除IPv6组播转发表中的转发项。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number } } * | all }
ipv6-source-address:IPv6组播源地址,显示包含指定组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,显示指定组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
incoming-interface:清除指定入接口的IPv6组播转发项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的IPv6组播转发项。
all:清除组播转发表中的所有IPv6组播转发项。
清除IPv6组播转发表中的转发项后,IPv6组播路由表中的相应表项也将随之被删除。
# 从公网实例IPv6组播转发表中清除组播组FF0E::1的相关转发表项。
<Sysname> reset ipv6 multicast forwarding-table ff0e::1
reset ipv6 multicast routing-table命令用来清除IPv6组播路由表中的路由项。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number } * | all }
ipv6-source-address:IPv6组播源地址,清除包含指定IPv6组播源的IPv6组播路由项。
ipv6-group-address:IPv6组播组地址,清除指定IPv6组播组的IPv6组播路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
incoming-interface:清除指定入接口的IPv6组播路由项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的IPv6组播路由项。
all:清除IPv6组播路由表中的所有IPv6组播路由项。
清除IPv6组播路由表中的路由项后,IPv6组播转发表中的相应表项也将被随之删除。
# 从公网实例IPv6组播路由表中清除组播组FF03::101的相关路由项。
<Sysname> reset ipv6 multicast routing-table ff03::101
