02-静态路由命令
本章节下载: 02-静态路由命令 (101.38 KB)
delete static-routes all命令用来删除所有静态路由。
delete [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name:删除指定VPN的所有静态路由。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示删除公网的所有静态路由。
使用本命令删除静态路由时,系统会提示确认,确认后才会删除所配置的所有静态路由。
# 删除所有静态路由。
[Sysname] delete static-routes all
This will erase all IPv4 static routes and their configurations, you must reconf
igure all static routes.
Are you sure?[Y/N]:y
· ip route-static
ip route-static命令用来配置静态路由。
undo ip route-static命令用来删除已配置的静态路由。
ip route-static dest-address { mask | mask-length } { next-hop-address | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
undo ip route-static dest-address { mask | mask-length } [ next-hop-address | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask | mask-length } { next-hop-address [ public ] | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
undo ip route-static vpn-instance s-vpn-instance-name dest-address { mask | mask-length } [ next-hop-address [ public ] | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
没有配置静态路由。
vpn-instance s-vpn-instance-name:指定源VPN。s-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。每个VPN都有自己的路由表,配置的静态路由将被加入指定VPN的路由表。
dest-address:静态路由的目的IP地址,点分十进制格式。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
vpn-instance d-vpn-instance-name:指定目的VPN。d-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果指定目的VPN,静态路由将根据配置的next-hop-address在目的VPN中查找出接口。
next-hop-address:指定路由的下一跳的IP地址,点分十进制格式。
public:指定静态路由下一跳处于公网实例。
interface-type interface-number:指定静态路由的出接口类型和接口号。对于接口类型为非P2P接口(包括NBMA类型接口或广播类型接口,如VLAN接口),必须指定下一跳地址。
preference preference-value :指定静态路由的优先级,取值范围为1~255,缺省值为60。
tag tag-value:静态路由Tag值,用于标识该条静态路由,取值范围为1~4294967295,缺省值为0。
description description-text:配置的静态路由描述信息,取值范围为1~60个字符。除“?”外,可以包含空格等特殊字符。
配置静态路由时应注意以下几点:
(1) 如果目的IP地址和掩码都为0.0.0.0(或掩码为0),则配置的路由为缺省路由。当没有匹配的路由表项时,将使用缺省路由进行报文转发。
(2) 对不同的优先级配置,可采用不同的路由管理策略。例如,为同一目的地配置多条路由,如果指定相同的优先级,则实现路由负载分担;如果指定不同的优先级,则实现路由备份。
(3) 配置静态路由时,可根据实际需要指定出接口或下一跳地址。需要注意的是:
· 对于Null0接口,配置了出接口就不需要配置下一跳地址。
· 对于广播类型接口(如VLAN接口),因为可能有多个下一跳,配置时必须同时指定出接口和下一跳IP地址。
# 配置静态路由,其目的地址为1.1.1.1/24,指定下一跳为2.2.2.2,Tag值为45,描述信息为“for internet”。
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet
· display ip routing-table protocol(三层技术-IP路由命令参考/IP路由基础)
ip route-static default-preference命令用来配置静态路由的缺省优先级。
undo ip route-static default-preference命令用来恢复缺省情况。
ip route-static default-preference default-preference-value
静态路由的缺省优先级为60。
default-preference-value:静态路由缺省优先级的值,取值范围为1~255。
· 如果在配置静态路由时没有指定优先级,就会使用缺省优先级。
· 重新配置缺省优先级后,新设置的缺省优先级仅对新增的静态路由有效。
# 配置静态路由的缺省优先级为120。
[Sysname] ip route-static default-preference 120
