H3C SR6604 & SR6608 Routers Hardware Information and Specifications-6W100
HomeSupportRoutersSR6600 SeriesProduct LiteratureHardware Information & SpecificationsH3C SR6604 & SR6608 Routers Hardware Information and Specifications-6W100
04-Slot Arrangment and Interface Numbering
04-Slot Arrangment and Interface Numbering 526.81 KB
4 Slot arrangment and interface numbering
Slot arrangement
The router provides multiple types of ports, including console port, AUX port, GigabitEthernet port, serial (synchronous) port, POS port, and E1 port.
Figure4-1 Slot arrangement on the SR6604 configured with an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU
Figure4-2 Slot arrangement on the SR6604 configured with an RSE-X1 or MCP-X1/X2 MPU
Figure4-3 Slot arrangement on the SR6608 configured with an RPE-X1/RPE-X3/RPE-X5/RPE-X5E MPU
Figure4-4 Slot arrangement on the SR6608 configured with an RSE-X1 or MCP-X1/X2 MPU
·     The numbers in Figure4-1 through Figure4-4 represent corresponding slot numbers.
·     On a router configured with an RSE-X1 or MCP-X1/X2 MPU, the slots are numbered from 1 instead 0.
Slot arrangement for MPUs, switching fabric modules, and service modules
Table4-1 Slot arrangement for MPUs, switching fabric modules, and service modules
MPUs
RPE-X1/RPE-X3/RPE-X5/RPE-X5E (supporting 1+1 redundancy)
Slot 0 and slot 1
An SR6608-DS router does not support the RPE-X1 MPU.
RSE-X1 (supporting 1+1 redundancy)
Slot 1 and slot 2
Not supported on an SR6608-DS router.
MCP-X1/X2 (supporting 1+1 redundancy)
Slot 1 and slot 2
Switching fabric modules
SFE-L1
Slot 2 and slot 3
Slot 2 through slot 5
SFE-L2
N/A
Slot 2 and slot 3 on an SR6608-DS router. (To install the SFE-L2 switching fabric module in slot 3 on an SR6608-DS router, first install a carrier in the slot.)
Service modules
FIP-10
FIP-20
FIP-110
FIP-210
FIP-240
FIP-260
FIP-300
FIP-310
FIP-380
FIP-600
FIP-660
FIP-680
SAP/OAP card
Slot 2 and slot 3
·     Slot 2 through slot 5
(The router does not support installing the FIP-240 or FIP-680 in slot 5 if it is installed with the RPE-X5 or RPE-X5E MPU.)
·     Slot 3 through slot 5 on an SR6608-DS router
(The SR6616-DS router does not support the FIP-240 and does not support installing the FIP-680 in slot 5 if it is installed with the RPE-X5 or RPE-X5E MPU.).
Numbering interfaces
Before installing a HIM/MIM/MIC/MIC-X, you must install a FIP.
The interfaces of the router are numbered in the form of interface-type X/Y/Z,
Where,
·     interface-type—Type of the interface such as GE port and serial port.
·     X—Number of the slot where the FIP/SAP resides, in the range of 2 to 3 on the SR6604 and 2 to 5 on the SR6608.
·     Y—Number of the slot where the HIM/MIM/MIC/MIC-X resides on the FIP. For a SAP, the subslot number is 0.
·     Z—Number of the interface on the HIM/MIM/MIC/MIC-X or on the SAP.
For each interface type on a HIM/MIM/MIC/MIC-X or SAP, the number Z starts from 0.
·     Different interface modules on the same FIP have the same slot number.
·     Different interfaces on the same HIM/MIM/MIC/MIC-X have the same subslot number.
Example 1
A MIM-2GBE module is installed on a FIP-110 in slot 3 of the router.
·     Fixed GigabitEthernet interfaces 0 and 1 on the FIP-110 are numbered GigabitEthernet 3/0/0 and GigabitEthernet 3/0/1, respectively.
The subslot number Y of fixed GE interfaces on a FIP is 0.
·     If the MIM-2GBE module is installed in slot 1 of the FIP-110, the two GigabitEthernet interfaces 0 and 1 on the MIM-2GBE are numbered GigabitEthernet 3/1/0 and GigabitEthernet 3/1/1, respectively,
·     If the MIM-2GBE module is installed in slot 2 of the FIP-110, the two GigabitEthernet interfaces 0 and 1 on the MIM-2GBE are numbered GigabitEthernet 3/2/0 and GigabitEthernet 3/2/1, respectively.
Example 2
A HIM-4GBE module is installed on a FIP-210 in slot 3 of the router.
·     The two fixed GigabitEthernet interfaces 0 and 1 on the FIP-210 are numbered GigabitEthernet 3/0/0 and GigabitEthernet 3/0/1, respectively.
·     If the HIM-4GBE is installed in slot 1 of the FIP-210, the GigabitEthernet interfaces 0 and 3 on the HIM-4GBE are numbered GigabitEthernet 3/1/0 to GigabitEthernet 3/1/3, respectively.
·     If the HIM-4GBE is installed in slot 2 of the FIP-210, the GigabitEthernet interfaces 0 and 3 on the HIM-4GBE are numbered GigabitEthernet 3/2/0 to GigabitEthernet 3/2/3, respectively.
