H3C SR6604 & SR6608 Routers Hardware Information and Specifications-6W100
HomeSupportRoutersSR6600 SeriesProduct LiteratureHardware Information & SpecificationsH3C SR6604 & SR6608 Routers Hardware Information and Specifications-6W100
03-LEDs
03-LEDs 2.46 MB
3 LEDs
The MPUs, switching fabric modules, FIPs, SAPs, HIM/MIM/MICs, power modules, and fan trays available for the router provide various LEDs to indicate the operating status.
Table3-1 H3C SR6604 and SR6608 routers LEDs
LED
Remarks
RPE-X1 LEDs
Run LED (RUN)
See Table3-2.
Active LED (ACT)
Alarm LED (ALM)
Management Ethernet port LED (LINK/ACT)
USB port LED (USB)
CF card LED (CF)
RPE-X3 LEDs
See Table3-3.
Alarm LED (ALM)
Power alarm LED (PALM)
Active LED (ACT)
Run LED (RUN)
RPE-X5 LEDs
Run LED (RUN)
See Table3-4.
IRF LED (IRF)
Management Ethernet port LED (MANAGEMENT)
Alarm LED (ALM)
Active LED (ACT)
RPE-X5E LEDs
Run LED (RUN)
See Table3-5.
IRF LED (IRF)
10GBASE-R-SFP+ port (SFP+0 and SFP+1)
Alarm LED (ALM)
Active LED (ACT)
Power button
RSE-X1 LEDs
Run LED (RUN)
See Table3-6.
Active LED (ACT)
Alarm LED (ALM)
USB port LED (USB)
CF card LED (CF)
MCP-X1 LEDs
10/100/1000 Mbps copper Ethernet port LEDs (GE0 through GE3)
See Table3-7.
CF card LED (CF)
Run LED (RUN)
Active LED (ACT)
Alarm LED (ALM)
1000 Mbps fiber Ethernet port LED (SFP0 through SFP3)
MCP-X2 LEDs
See Table3-8.
CF card LED (CF)
Run LED (RUN)
Active LED (ACT)
Alarm LED (ALM)
10 Gbps Ethernet port LED (SFP+LINK/ACT)
Switching fabric module LEDs
Run LED (RUN)
See Table3-9.
FIP LEDs
Run LED (RUN)
See Table3-11.
10/100/1000 Mbps copper Ethernet port LED (GE0 and GE1)
1000 Mbps fiber Ethernet port LED (SFP0 and SFP1)
SAP LEDs
Run LED (RUN)
See Table3-18 and Table3-19.
10/100/1000 Mbps Ethernet port LED
HIM/MIM/MIC/ MIC-X LEDs
See H3C SR6600/SR6600-X Routers Interface Module Guide.
Power module LEDs
Power LED
See Table3-24.
Fan tray LEDs
Run LED (RUN)
See Table3-25.
Alarm LED (ALM)
MPU LEDs
CAUTION
CAUTION:
To avoid damaging the file system on the CF card, do not remove the CF card when the CF LED is flashing.
Figure3-1 LEDs on the RPE-X1
Table3-2 RPE-X1 LED description
LED
Status
(green)
RUN
Off
No power input is available, or the RPE-X1 has failed.
Slow flashing (1 Hz)
The RPE-X1 is operating correctly.
Fast flashing (8 Hz)
The application software is being loaded (in this case, never power off the device or hot-swap the RPE-X1; otherwise the RPE-X1 might be damaged).
(green)
ACT
Off
The RPE-X1 is in standby state.
Steady on
The RPE-X1 is in active state.
(red)
ALM
Off
The system is operating correctly and no alarm has occurred.
Steady on
A fault has occurred on the system or the available power is insufficient. In this state, check the system log immediately.
A critical fault has occurred to the system. In this state, handle the fault immediately.
(yellow/green)
LINK/ACT
Steady yellow
A 10/100 Mbps link is present.
Steady green
A 1000 Mbps link is present.
Flashing yellow
Data is being received or transmitted at 10/100 Mbps.
Flashing green
Data is being received or transmitted at 1000 Mbps.
(green)
CF
Off
No CF card is present or the CF card is not recognizable.
Steady on
A CF card is in position and has been detected.
Flashing
The system is accessing the CF card. In this state, do not remove the CF card.
(green)
USB
Off
No host is connected to the device-mode USB port.
Steady on
A host is connected to the device-mode USB port. The USB cable can be unplugged in this state.
Flashing
Data is being transmitted or received through the device-mode USB port. In this state, do not unplug the USB cable.
Figure3-2 RPE-X3 LEDs
Table3-3 RPE-X3 LED description
LED
Status
(yellow/green)
LINK/ACT
Steady yellow
Steady green
Flashing yellow
Flashing green
(red)
ALM
Off
Steady on
A fault has occurred on the system.
(red)
PALM
Off
Steady on
(green)
ACT
Off
The MPU is in standby state.
Steady on
The MPU is in active state.
(green)
RUN
Off
No power input is available, or the MPU has failed.
The MPU is operating correctly.
The system software is being loaded. To avoid damage to the MPU, never power off the device or hot-swap the MPU.
Figure3-3 LEDs on the RPE-X5
Table3-4 RPE-X5 LED description
LED
Status
(yellow/green)
RUN
Fast flashing green
BIOS stage
The BIOS is operating correctly.
Slow flashing yellow
No or insufficient memory or initialization failure.
Fast flashing yellow
The extended segment does not exist.
Off
Hardware failure or no power input.
Steady green
BootWare stage
The SDRAM is performing self-test.
Fast flashing green
The BootWare runs.
Slow flashing green
The Comware system has started with the configuration file and the system is operating correctly.
Steady yellow
The boot image does not exist.
The SDRAM has failed the self-test.
Off
Slow flashing green
Comware stage
The system is operating correctly.
Fast flashing green (5 seconds)
USB-based automatic configuration has succeeded.
(red)
PALM
Steady on
The system power is insufficient.
Off
The power system is operating correctly.
(yellow/green)
IRF
Slow flashing green
The device is in IRF mode and the MPU is the global active MPU.
Steady green
The device is in IRF mode and the MPU is a standby MPU.
Steady yellow
The device is in IRF mode but the IRF configuration has failed.
Off
The device is in standalone mode.
(yellow/green)
MANAGEMENT
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present.
Flashing yellow
Data is being received or transmitted at 100 Mbps.
Off
No link is present or the port is faulty.
(red)
ALM
Fast flashing (10 seconds)
USB-based automatic configuration has failed.
Steady on
Off
(green)
ACT
Steady on
Off
Figure3-4 LEDs on the RPE-X5E
Table3-5 RPE-X5E LED description
LED
Status
(yellow/green)
RUN
Fast flashing green
BIOS stage
Off
Steady green
BootWare stage
Fast flashing green
The BootWare runs.
Slow flashing green
Steady yellow
Off
Slow flashing green
Comware stage
(red)
PALM
Steady on
Off
(yellow/green)
IRF
Slow flashing green
Steady green
Steady yellow
Off
(green)
SFP+0 and SFP+1
Steady green
After a link is set up, using the command to bring up or shut down the port does not change the LED status.
A 10 Gbps link is present.
Flashing green
Data is being received or transmitted at 10000 Mbps.
Off
No link is present.
(yellow/green)
MANAGEMENT
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
(red)
ALM
Steady on
Off
(green)
ACT
Steady on
Off
(red/green)
Power button
Fast flashing red
The MPU has been powered up to start up the Comware system.
Slow flashing red
The BIOS is starting up.
Slow flashing green
The BootWare is starting up.
Steady green
The Comware system starts up and is operating correctly.
Fast flashing green
The power button has been pressed and the Comware system starts to shut down.
Steady red
The shutdown of the Comware system is in progress.
Off
The Comware system has shut down.
Figure3-5 RSE-X1 LEDs
Table3-6 RSE-X1 LED description
LED
Status
(green)
CF
Off
Steady on
Flashing
(green)
USB
Off
Steady on
Flashing
 (yellow/green)
LINK/ACT
Steady yellow
Steady green
Flashing yellow
Flashing green
(green)
ACT
Off
The RSE-X1 is in standby state.
Steady on
The RSE-X1 is in active state.
(red)
PALM
Off
The system power module is normal.
Steady on
(green)
RUN
Off
No power input is available, or the RSE-X1 has failed.
The RSE-X1 is operating correctly.
The application software is being loaded (in this case, never power off the device or hot-swap the RSE-X1; otherwise the RSE-X1 might be damaged).
(red)
ALM
Off
Steady on
Figure3-6 MCP-X1 LEDs
Table3-7 MCP-X1 LED description
LED
Status
(yellow/green)
GE0 through GE3
Off
The corresponding interface is not connected.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
CF
Off
Steady green
Flashing green
Steady yellow
A CF card not provided by H3C.
(green)
RUN
Off
No power input is available, or the MCP-X1 has failed.
The MCP-X1 is operating correctly.
The application software is being loaded (in this case, never power off the device or hot-swap the MCP-X1; otherwise the MCP-X1 might be damaged).
(green)
ACT
Off
The MCP-X1 is in standby state.
Steady on
The MCP-X1 is in active state.
(red)
PALM
Off
Steady on
(red)
ALM
Off
Steady on
LINK
Off
Steady green
Steady yellow
ACT
Off
No data is being received or transmitted.
Flashing yellow
Data is being received or transmitted.
(yellow/green)
SFP0 through SFP3
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure3-7 MCP-X2 LEDs
Table3-8 MCP-X2 LED description
LED
Status
(yellow/green)
GE0 through GE3
Off
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
CF
Off
Steady green
Flashing green
Steady yellow
(green)
RUN
Off
(green)
ACT
Off
Steady on
(red)
PALM
Off
Steady on
(red)
ALM
Off
Steady on
LINK
Off
Steady green
Steady yellow
ACT
Off
Flashing yellow
SFP+LINK/ACT
Off
No link is present.
Steady green
Flashing green
Data is being received or transmitted at 10 Gbps.
Steady yellow
Transceiver module check has failed.
(yellow/green)
SFP0 through SFP3
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure3-8 SFE-L1 status LED
Figure3-9 SFE-L2 status LED
Table3-9 SFE-L1 LED description
LED
Status
(green)
RUN
Off
No link is present or the module is faulty.
The module is operating correctly.
Application software is being loaded.
To avoid damage to the module, do not power off the device or hot-swap the module while the application software is being loaded.
FIP LEDs
Figure3-10 FIP-10 status LED
Figure3-11 FIP-20 status LED
Table3-10 FIP-10/20 LED description
LED
Status
run2
(green)
RUN
Off
No link is present or the FIP is faulty.
The FIP is operating correctly.
System software is being loaded. To avoid damage to the FIP, never power off the device or hot-swap the FIP while the system software is being loaded.
Figure3-12 FIP-110 LEDs
Figure3-13 FIP-210 LEDs
Figure3-14 FIP-240 LEDs
Figure3-15 FIP-600 LEDs
Table3-11 FIP-110/210/240/600 LED description
LED
Status
(yellow/green)
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(green)
RUN
Off
No power input is available or the FIP has failed.
(yellow/green)
Off
No link is present.
Steady green
A link is present.
Flashing green
Data is being sent or received at 1000 Mbps.
Steady yellow
The transceiver module failed to be detected.
Figure3-16 FIP-260 LEDs
Table3-12 FIP-260 LED description
LED
Status
(green)
RUN
Off
No power input is available or the FIP-260 has failed.
Steady green
The FIP software system is starting up.
Figure3-17 FIP-300 LEDs
Table3-13 FIP-300 LED description
LED
Status
(yellow/green)
GE0 through GE3
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
SFP0 through SFP11
Off
No link is present.
Steady green
Flashing green
Steady yellow
POST has failed.
(green)
RUN
Off
No power input is available or the FIP-300 has failed.
Figure3-18 FIP-310 LEDs
Table3-14 FIP-310 LED description
LED
Status
(yellow/green)
GE0 through GE3
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
SFP0 through SFP3
Off
No link is present.
Steady green
Flashing green
Steady yellow
POST has failed.
(green)
RUN
Off
4
(yellow/green)
SFP+
Off
No link is present.
Steady green
Flashing green
Steady yellow
POST has failed.
Figure3-19 FIP-380 LEDs
Table3-15 FIP-380 LED description
LED
Status
(yellow/green)
SFP+22 and SFP+23
Off
No link is present or the port has failed.
Steady yellow
Flashing yellow (8 Hz)
Steady green
Flashing green (8 Hz)
(yellow/green)
SFP0 through SFP3
Off
No link is present.
Steady yellow
Steady green
(green)
RUN
Off
No power input is available or the FIP-380 has failed.
Steady green
4
(yellow/green)
GE14 through GE21
Off
Steady yellow
Steady green
Figure3-20 FIP-660 LEDs
Table3-16 FIP-660 LED description
LED
Status
(green)
RUN
Off
No power input is available or the FIP-660 has failed.
Steady green
Figure3-21 FIP-680 LEDs
Table3-17 FIP-680 LED description
LED
Status
(green)
SFP1 through SFP12
Off
No link is present.
Steady green
Flashing green
(green)
SFP+1 through SFP+4
Off
No link is present.
Steady green
Flashing green
(yellow/green)
GE13 through GE20
Off
Steady green
Flashing green
Steady yellow
Flashing yellow
(green)
Module status LED (RUN)
Off
System software is being loaded. To avoid damage to the FIP, never power off the device or hot-swap the FIP when the system software is being loaded.
SAP LEDs
Figure3-22 SAP LEDs(SAP-48GBE)
Table3-18 SAP-48GBE LED description
Item
Status
(yellow/green)
Status LEDs of GE 0 through GE 47
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(green)
RUN
Off
No power input is available or the SAP-48GBE has failed.
The SAP-48GBE is operating correctly.
Application program is being loaded (in this case, never power off the device or hot-swap the SAP-48GBE; otherwise, the SAP-48GBE might be damaged), or the SAP-48GBE is not operating.
Figure3-23 SAP LEDs (SAP-24GBP)
Table3-19 SAP-24GBP LED description
LED
Status
(green)
RUN
Off
No power input is available or the SAP-24GBP has failed.
The SAP-24GBP is operating correctly.
Application program is being loaded (in this case, never power off the device or hot-swap the SAP-24GBP; otherwise, the SAP-24GBP might be damaged), or the SAP-24GBP is not operating.
(yellow/green)
Status LEDs of SFP 0 to SFP 23
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure3-24 SAP LEDs (SAP-48GBP)
Table3-20 SAP-48GBP LED description
LED
Status
(yellow/green)
Status LEDs of SFP 0 to SFP 47
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(green)
System status LED
Off
No power input is available or the SAP-48GBP has failed.
The SAP-48GBP is operating correctly.
Application program is being loaded (in this case, never power off the device or hot-swap the SAP-48GBP; otherwise, the SAP-48GBP might be damaged), or the SAP-48GBP is not working.
Figure3-25 SAP-20GE2XP LEDs
Table3-21 SAP-20GE2XP LED description
LED
Status
(green)
RUN
Off
No power input is available or the SAP-20GE2XP has failed.
The SAP-20GE2XP is operating correctly.
System software is being loaded or the SAP-20GE2XP is not operating.
CAUTION CAUTION:
To avoid hardware damage, do not power off the router, or insert or remove the SAP-20GE2XP when system software is being loaded.
(yellow/green)
Status LEDs for SFP+ port 0 and SFP+ port 1
Off
No link is present.
Steady green
Flashing green
Steady yellow
The transceiver module has failed to be detected.
(yellow/green)
Status LEDs for fiber combo ports GE16 to GE19
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
Status LEDs for copper combo ports GE16 to GE19
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
5
(yellow/green)
Status LEDs for SFP ports GE0 to GE15
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure3-26 SAP-28GE LEDs
Table3-22 SAP-28GE LED description
LED
Status
(green)
RUN
Off
No power input is available or the SAP-28GE has failed.
The SAP-28GE is operating correctly.
System software is being loaded or the SAP-28GE is not operating.
CAUTION CAUTION:
To avoid hardware damage, do not power off the router, or insert or remove the SAP-28GE when system software is being loaded.
(yellow/green)
Status LEDs for fiber combo ports GE16 to GE27
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
Status LEDs for copper combo ports GE16 to GE27
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
(yellow/green)
Off
No link is present.
Steady green
Flashing green
Steady yellow
Flashing yellow
Figure3-27 SAP-XP4GE32 LEDs
Table3-23 SAP-XP4GE32 LED description
LED
Status
(yellow/green)
·     GE0 through GE11
·     GE12 through GE23 (copper combo port)
Off
No power input is available or the port has failed.
Steady yellow
Steady green
(yellow/green)
·     SFP12 through SFP23 (fiber combo port)
·     SFP24 through SFP31
Off
No link is present.
Steady yellow
Steady green
 (green)
SFP+32 through SFP+35
Off
Steady green
(green)
RUN
Off
No power input is available or the SAP-XP4GE32 has failed.
CAUTION CAUTION:
HIM/MIM/MIC/MIC-X LEDs
For HIM/MIM/MIC/MIC-X LED description, see H3C SR6600/SR6600-X Routers Interface Module Guide.
Power module LEDs
Figure3-28 PSR650-A AC power module LED
Figure3-29 PSR1200-A AC power module LED
Figure3-30 PSR650-D DC power module LED
Figure3-31 PSR1200-D DC power module LED
Table3-24 AC/DC power LED description
LED
Status
Power LED
Steady green
The power module is operating correctly.
Steady red
The power module is faulty.
Off
No power is input.
Fan tray LEDs
Figure3-32 Fan tray for the SR6604
Figure3-33 Fan tray for the SR6608
Table3-25 Fan tray LED description
LED
Status
(green)
RUN
Off
The system is powered off or the fan tray is faulty.
Steady on
The fan tray is operating correctly.
(red)
ALM
Off
Steady on
The fan tray is faulty.
