03-MAC地址认证命令
本章节下载: 03-MAC地址认证命令 (369.41 KB)
1.1.1 display mac-authentication
1.1.2 display mac-authentication connection
1.1.3 display mac-authentication mac-address
1.1.4 display mac-authentication user-recovery-profile
1.1.7 mac-authentication access-user log enable
1.1.8 mac-authentication authentication-method
1.1.9 mac-authentication auto-recover-user
1.1.10 mac-authentication carry user-ip
1.1.11 mac-authentication critical vlan
1.1.12 mac-authentication critical-voice-vlan
1.1.13 mac-authentication domain
1.1.14 mac-authentication guest-vlan
1.1.15 mac-authentication guest-vlan auth-period
1.1.16 mac-authentication host-mode
1.1.17 mac-authentication mac-range-account
1.1.18 mac-authentication max-user
1.1.19 mac-authentication recover-user
1.1.20 mac-authentication re-authenticate server-unreachable keep-online
1.1.21 mac-authentication timer (interface view)
1.1.22 mac-authentication timer (system view)
1.1.23 mac-authentication user-name-format
1.1.24 mac-authentication user-recovery-profile
1.1.25 mac-authentication web-proxy
1.1.27 reset mac-authentication access-user
1.1.28 reset mac-authentication critical vlan
1.1.29 reset mac-authentication critical-voice-vlan
1.1.30 reset mac-authentication guest-vlan
1.1.31 reset mac-authentication statistics
display mac-authentication命令用来显示MAC地址认证的相关信息。
interface interface-type interface-number:显示全局及指定端口的MAC地址认证相关信息。interface-type interface-number为端口类型和端口编号。若指定的端口上未使能MAC地址认证,则不显示该端口任何信息。
如果不指定任何参数,则显示所有在线MAC地址认证的详细信息,主要包括全局及端口的配置信息、认证报文统计信息以及认证用户信息。
# 显示MAC地址认证信息。
MAC authentication : Enabled
Authentication method : PAP
M-LAG member configuration conflict : Unknown
Username format : MAC address in lowercase(xx-xx-xx-xx-xx-xx)
Username : mac
Password : Not configured
Offline detect period : 300 s
Quiet period : 60 s
Server timeout : 100 s
Reauth period : 3600 s
User aging period for critical VLAN : 1000 s
User aging period for guest VLAN : 1000 s
Authentication domain : Not configured, use default domain
Online MAC-auth wired users : 1
Silent MAC users:
MAC address VLAN ID From port Port index
Ten-GigabitEthernet0/0/6 is link-up
Carry User-IP : Disabled
Auth-delay timer : Enabled
Auth-delay period : 60 s
Periodic reauth : Enabled
Reauth period : 120 s
Guest VLAN : 100
Guest VLAN reauthentication : Enabled
Guest VLAN auth-period : 150 s
Critical VLAN : Not configured
Critical voice VLAN : Disabled
Host mode : Multiple VLAN
Offline detection : Enabled
Authentication order : Parallel
User aging : Enabled
Server-recovery online-user-sync : Enabled
Auto-tag feature : Disabled
VLAN tag configuration ignoring : Disabled
Max online users : 4294967295
Authentication attempts : successful 2, failed 3
Current online users : 1
MAC address Auth state
0001-0000-0001 Unauthenticated
表1-1 display mac-authentication命令显示信息描述表
Global MAC authentication parameters |
全局MAC地址认证参数 |
MAC authentication |
MAC地址认证的开启状态 |
M-LAG member configuration conflict |
(暂不支持)两台M-LAG设备配置检查结果 · Conflicted:两台M-LAG设备上的配置不匹配 · Not conflicted:两台M-LAG设备上的配置相匹配 · Unknown:无法检测两台M-LAG设备上的配置是否匹配 |
Authentication method |
MAC地址认证采用的认证方法 · CHAP:采用CHAP认证方法 · PAP:采用PAP认证方法 |
Username format |
MAC地址认证使用的账号格式 · 若采用MAC地址账号,则显示具体的用户名格式以及是否带连字符、字母是否大小写,例如本例中“MAC address in lowercase(xx-xx-xx-xx-xx-xx)”,它表示用户名格式为六段式的MAC地址,其中字母为小写 · 若采用固定用户名账号,则显示“Fixed account” |
Username |
用户名 · 采用MAC地址账号时,该值显示为“mac”,无实际意义,仅表示采用MAC地址作为用户名和密码 · 采用固定用户名账号时,该值为配置的用户名(缺省为mac) |
Password |
用户名的密码 · 采用MAC地址账号时,该值显示为“Not configured” · 采用固定用户名账号时,配置的值将显示为****** |
Offline detect period |
下线检测定时器的值 |
Quiet period |
静默定时器的值 |
Server timeout |
服务器连接超时定时器的值 |
Reauth period |
重认证定时器的值 |
User aging period for critical VLAN |
Critical VLAN中用户的老化时间 |
User aging period for guest VLAN |
Guest VLAN中用户的老化时间 |
Authentication domain |
系统视图下指定的MAC地址认证用户使用的认证域,如果没有指定认证域,则显示Not configured, use default domain |
Online MAC-auth wired users |
在线有线用户和正在发起MAC地址认证的有线用户的总数 |
Online MAC-auth wireless users |
在线无线用户和正在发起MAC地址认证的无线用户的总数 |
Silent MAC users |
静默用户信息(包括设备添加的静默用户和服务器授权下发黑洞MAC的静默用户) |
MAC address |
静默用户的MAC地址 |
VLAN ID |
静默用户所在的VLAN |
From port |
静默用户接入的端口名称 |
Port index |
静默用户接入的端口索引号 |
Ten-GigabitEthernet0/0/6 is link-up |
端口Ten-GigabitEthernet0/0/6的链路状态 |
当前端口的MAC地址认证开启状态 · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Carry User-IP |
MAC地址认证请求携带用户IP地址关闭状态 |
端口上指定的MAC地址认证用户使用的认证域 |
Auth-delay timer |
MAC地址认证延迟功能的开启状态 |
Auth-delay period |
配置的认证延迟时间 |
Periodic reauth |
端口上MAC地址重认证开启状态 |
Reauth period |
端口上配置的MAC地址重认证时间间隔 |
Re-auth server-unreachable |
重认证时服务器不可达对MAC地址认证的在线用户采取的动作 · Logoff:重认证服务器不可达,强制MAC地址认证在线用户下线 · Online:重认证服务器不可达,保持MAC地址认证在线用户在线 |
Guest VLAN |
端口配置的Guest VLAN,如果没有配置,则显示Not configured |
Guest VLAN reauthentication |
Guest VLAN中用户重新认证功能的开启状态 · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Guest VLAN auth-period |
进入Guest VLAN后发起重认证的时间间隔 |
Critical VLAN |
端口配置的Critical VLAN,如果没有配置,则显示Not configured |
Critical voice VLAN |
端口配置MAC地址认证的Critical Voice VLAN功能的开启状态 · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Host mode |
相同MAC地址用户的工作模式 · 如果配置的是多VLAN模式,则显示Multiple VLAN · 如果配置的是单VLAN模式,则显示Single VLAN |
Offline detection |
MAC地址认证用户下线检测的开启状态 · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Authentication order |
MAC地址认证和802.1X认证并行处理 · Default:处于关闭状态 · Parallel:处于开启状态 |
User aging |
非认证成功VLAN中MAC地址认证用户老化功能的开启状态 · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Server-recovery online-user-sync |
RADIUS服务器从不可达状态恢复为可达时,设备同步MAC地址认证的在线用户信息到RADIUS服务器功能的开启状态: · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Auto-tag feature |
(暂不支持)端口上MAC地址认证授权VLAN自动Tag功能 · Enabled:处于开启状态 · Disabled:处于关闭状态 |
VLAN tag configuration ignoring |
(暂不支持)端口上MAC地址认证授权VLAN自动Tag忽略静态VLAN配置功能 · Enabled:处于开启状态 · Disabled:处于关闭状态 |
Max online users |
本端口最多可容纳的接入用户数 |
Authentication attempts: successful 1, failed 0 |
端口上MAC地址认证的统计信息,包括认证通过的次数和认证失败的次数 |
MAC address |
接入用户的MAC地址 |
Auth state |
接入用户的状态 · Authenticated:认证成功 · Unauthenticated:认证失败 |
display mac-authentication connection命令用来显示MAC地址认证在线用户的详细信息。
display mac-authentication connection [ open ] [ interface interface-type interface-number | slot slot-number | user-mac mac-address | user-name user-name ]
open:只显示在开放认证模式下使用不存在的用户名或者错误的密码接入的MAC地址认证的用户信息。若不指定本参数,则显示设备上所有MAC地址认证在线用户的信息。
interface interface-type interface-number:显示指定端口的MAC地址认证用户信息。其中interface-type interface-number表示绑定的端口类型和端口编号。若不指定本参数,则显示设备上所有的MAC地址认证用户信息。
slot slot-number:显示指定单板上的MAC地址认证用户信息。slot-number表示单板所在的槽位号。若不指定本参数,则显示所有单板上的MAC地址认证用户信息。
user-mac mac-address:显示指定MAC地址的MAC地址认证用户信息。其中mac-addr表示用户的MAC地址,格式为H-H-H。若不指定本参数,则显示设备上所有的MAC地址认证用户信息。
user-name user-name:显示指定用户名的MAC地址认证用户信息。其中user-name表示用户名(可包含域名),为1~55个字符的字符串,区分大小写。若不指定本参数,则显示设备上所有的MAC地址认证用户信息。
# 显示所有MAC地址认证在线用户信息。
Total connections: 2
Slot ID: 0
Access interface: Ten-GigabitEthernet0/0/6
Username: ias
User access state: Successful
Authentication domain: macusers
IPv4 address: 192.168.1.1
Initial VLAN: 1
Authorization microsegment ID: N/A
Authorization CAR:
Average input rate: 102400 bps
Peak input rate: 204800 bps
Average output rate: 102400 bps
Peak output rate: 204800 bps
Authorization URL: N/A
Session timeout period: 2 sec
Offline detection: 100 sec (server-assigned)
Online from: 2020/01/02 13:14:15
Online duration: 0h 2m 15s
User MAC address: 0015-e9a6-abcd
Access interface: Bridge-Aggregation1
Username: luser
Initial VLAN: 1
Authorization VSI: N/A
Authorization CAR:
Online from: 2020/12/02 13:14:15
Online duration: 0h 7m 15s
表1-2 display mac-authentication connection 命令显示信息描述表
Total connections |
在线MAC地址认证用户个数 |
User MAC address |
用户的MAC地址 |
Access interface |
用户的接入接口名称 |
Username |
用户名 |
User access state |
用户的接入状态 · Successful:MAC地址认证成功并接入 · Open:使用不存在的用户名或者错误的密码进行开放认证并接入 |
认证时所用的ISP域的名称 |
IPv4 address |
用户IPv4地址 若未获取到用户的IP地址,则不显示该字段 |
IPv6 address |
用户IPv6地址 若未获取到用户的IP地址,则不显示该字段 |
Initial VLAN |
初始的VLAN |
Authorization untagged VLAN |
授权的untagged VLAN |
Authorization tagged VLAN |
授权的tagged VLAN |
Authorization microsegment ID |
(暂不支持)授权的微分段ID |
Authorization ACL number/name |
授权ACL的编号或名称。若未授权ACL,则显示N/A;若未授权成功,则在ACL编号后显示“(NOT effective)” |
Authorization user profile |
授权用户的User profile名称 |
Authorization CAR |
当服务器未授权用户CAR属性时,该字段显示为N/A。 当服务器授权用户CAR属性,将分为以下四个字段: · Average input rate :上行平均速率,单位为bps · Peak input rate:上行峰值速率,单位为bps · Average output rate:下行平均速率,单位为bps · Peak output rate:下行峰值速率,单位为bps 若未授权成功,则显示为(NOT effective) 若只下发上、下行平均速率,则该上、下行峰值速率默认与其平均速率相同。目前不支持服务器单独授权上、下行峰值速率 |
Authorization URL |
授权的重定向URL |
Authorization IPv6 URL |
授权的IPv6重定向URL |
Termination action |
服务器下发的终止动作类型: · Default:会话超时时间到达后,强制用户下线 · Radius-Request:会话超时时间到达后,请求MAC地址认证用户进行重认证 用户采用本地认证时,该字段显示为Default |
Session timeout period |
服务器下发的会话超时时间,该时间到达之后,用户所在的会话将会被删除,之后,对该用户所采取的动作,由Termination action字段的取值决定 |
Offline detection |
用户进行下线检测的属性: · Ignore (command-configured):命令行配置该用户不进行下线检测 · timer (command-configured):命令行配置的下线检测时间 · Ignore (server-assigned):RADIUS服务器授权该用户不进行下线检测 · timer (server-assigned):RADIUS服务器授权的下线检测时间 |
Online from |
MAC认证用户的上线时间 |
Online duration |
MAC认证用户的在线时长 |
display mac-authentication mac-address命令用来显示非认证成功VLAN中的MAC地址认证用户的MAC地址信息。
display mac-authentication mac-address { critical-vlan | guest-vlan } [ interface interface-type interface-number ]
critical-microsegment:显示MAC地址认证Critical微分段中的用户MAC地址信息。
critical-vlan:显示MAC地址认证Critical VLAN中的用户MAC地址信息。
guest-vlan:显示MAC地址认证Guest VLAN中的用户MAC地址信息。
interface interface-type interface-number:显示微分段、VLAN或VSI中指定端口的MAC地址认证用户的MAC地址信息。其中interface-type interface-number表示端口类型和端口编号。若不指定本参数,则显示指定类型的微分段、VLAN或VSI中所有端口的MAC地址认证用户的MAC地址信息。
查询到的MAC地址数量以及MAC地址明细为粗略统计,当有大量用户频繁进行认证时可能不能完全精准显示。
# 显示所有MAC地址认证Critical微分段中的用户MAC地址信息。
<Sysname> display mac-authentication mac-address critical-microsegment
Total MAC addresses: 10
Interface:Ten-GigabitEthernet0/0/6 Critical microsegment: 1 Aging time: N/A
MAC addresses: 8
0800-2700-9427 0800-2700-2341 0800-2700-2324 0800-2700-2351
0800-2700-5627 0800-2700-2251 0800-2700-8624 0800-2700-3f51
Interface:Ten-GigabitEthernet0/0/7 Critical microsegment: 1 Aging time: 30 sec
MAC addresses: 2
0801-2700-9427 0801-2700-2341
# 显示所有MAC地址认证Guest VLAN中的用户的MAC地址信息。
<Sysname> display mac-authentication mac-address guest-vlan
Interface: Ten-GigabitEthernet0/0/6 Guest VLAN: 3 Aging time: N/A
MAC addresses: 8
Interface: Ten-GigabitEthernet0/0/7 Guest VLAN: 5 Aging time: 30 sec
MAC addresses: 2
表1-3 display mac-authentication mac-address命令显示信息描述表
Total MAC addresses |
指定类型的微分段、VLAN或VSI中的所有MAC地址总数 |
用户的接口名称 |
Type microsegment/VLAN/VSI |
显示MAC地址认证用户所在的位置信息,Type包含如下取值: · Critical VLAN · Guest VLAN |
Aging time |
MAC地址老化时间,单位秒。N/A表示该地址不老化 |
MAC addresses |
MAC地址数 |
xxxx-xxxx-xxxx |
MAC地址 |
· mac-authentication critical microsegment
· mac-authentication critical vlan
· mac-authentication guest-vlan
display mac-authentication user-recovery-profile命令用来显示MAC地址认证user-recovery Profile的配置信息。
display mac-authentication user-recovery-profile [ profile-name ]
profile-name:user-recovery Profile名称,为1~31个字符的字符串,不区分大小写。如果不指定该参数,则表示显示所有user-recovery Profile。
# 显示所有MAC地址认证user-recovery Profile的配置信息。
<Sysname> display mac-authentication user-recovery-profile
User-recovery profile: profile1
Server IP : 3.3.3.3
Port : 8080
VPN : Not configured
Login name : user1
NAS IP address: 10.1.1.1
URI : dumbtermina/list
User-recovery profile: profile2
Server IP : 1.1.1.2
Port : 80
Login name : user1
NAS IP address: 1:2::3:4
表1-4 display mac-authentication user-recovery-profile命令显示信息描述表
User-recovery profile |
user-recovery Profile名称 |
Server IP |
RESTful服务器的IP地址 |
Port |
RESTful服务器的端口号 |
VPN |
RESTful服务器所属的VPN实例 |
Login name |
登录到RESTful服务器所需的用户名 |
NAS IP address |
设备和RESTful服务器交互时使用的NAS-IP地址 |
URI |
RESTful服务器提供用户资源服务的URI |
· mac-authentication user-recovery-profile
· server-address
· login-name
· nas-ip
· uri
login-name命令用来配置登录到RESTful服务器所需的用户名和密码。
undo login-name命令用来恢复缺省情况。
login-name username [ password { cipher | simple } string ]
undo login-name
未配置登录到RESTful服务器所需的用户名和密码。
user-recovery Profile视图
username:表示用户名,为1~55字符的字符串,区分大小写。
password:表示密码。若未指定本参数,则表示登录到RESTful服务器时不需要密码。
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~63个字符的字符串,密文密码为1~117个字符的字符串。
设备与RESTful服务器建立连接时,服务器首先需要验证连接请求发起方的合法性。本命令配置的用户名和密码,即为设备向RESTful服务器提供的身份信息。RESTful服务器验证该用户名和密码成功后,才允许连接请求发起方与之建立连接,以及获取相应的服务器资源。
本命令指定的用户名和密码,必须在RESTful服务器上已经存在。
# 在名称为profile1的user-recovery Profile视图下,配置与RESTful服务器建立连接时使用的登录用户名为abc,密码为明文123。
[Sysname] mac-authentication user-recove-profile profile1
[Sysname-user-recovery-profile-profile1] login-name abc password simple 123
· display mac-authentication user-recovery-profile
mac-authentication命令用来开启端口上或全局的MAC地址认证。
undo mac-authentication命令用来关闭端口上或全局的MAC地址认证。
mac-authentication
所有端口及全局的MAC地址认证都处于关闭状态。
二层以太网接口视图
# 开启全局的MAC地址认证。
# 开启端口Ten-GigabitEthernet0/0/6上的MAC地址认证。
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication
mac-authentication access-user log enable命令用来开启MAC地址认证接入用户日志信息功能。
undo mac-authentication access-user log enable命令用来关闭MAC地址认证接入用户日志信息功能。
MAC地址认证接入用户日志信息功能处于关闭状态。
failed-login:MAC地址认证用户上线失败的日志信息。
logoff:MAC地址认证用户下线的日志信息。
successful-login:MAC地址认证用户上线成功的日志信息。
为了防止设备输出过多的MAC地址认证接入用户日志信息,一般情况下建议关闭此功能。
# 开启MAC地址认证接入用户上线失败的日志信息。
· info-center source maca logfile deny(设备管理命令参考/信息中心)
mac-authentication authentication-method命令用来配置MAC地址认证采用的认证方法。
undo mac-authentication authentication-method命令用来恢复缺省情况。
mac-authentication authentication-method { chap | pap }
设备采用PAP认证方法进行MAC地址认证。
chap:采用CHAP类型的认证方法。
pap:采用PAP类型的认证方法。
通过该命令可以配置设备进行MAC地址认证时,与RADIUS服务器之间采用的认证方法。PAP和CHAP认证方法的详细介绍如下:
· PAP(Password Authentication Protocol,密码验证协议)通过用户名和口令来对用户进行验证,其特点是在网络上以明文方式传送用户名和口令,仅适用于对网络安全要求相对较低的环境。
· CHAP(Challenge Handshake Authentication Protocol,质询握手验证协议)采用客户端与服务器端交互挑战信息的方式来验证用户身份,其特点是在网络上以明文方式传送用户名,以密文方式传输口令。与PAP相比,CHAP认证保密性较好,更为安全可靠。
# 配置设备采用CHAP认证方法进行MAC地址认证。
[Sysname] mac-authentication authentication-method chap
mac-authentication auto-recover-user命令用来开启MAC地址认证自动恢复用户功能。
undo mac-authentication auto-recover-user命令用来关闭MAC地址认证自动恢复用户功能。
mac-authentication auto-recover-user profile profile-name
undo mac-authentication auto-recover-user profile profile-name
MAC地址认证的自动恢复用户功能处于关闭状态。
profile profile-name:user-recovery Profile名称,为1~31个字符的字符串,不区分大小写。
本功能的典型应用场景是,有大量哑终端(例如打印机)通过MAC地址认证接入网络。当设备或接口板重启、接口故障时,哑终端用户下线后只能等待下次业务报文触发MAC地址认证,而这种在线状态恢复的不及时性将会影响该类终端后续的正常工作。
为指定的user-recovery Profile开启恢复用户功能后,若设备或接口板重启、接口故障恢复,当设备和Profile中指定的RESTful服务器之间路由可达后,设备会主动从该服务器上获取相关接口上的MAC地址认证用户账户信息,并自动使用这些信息为用户重新进行认证,达到不需要用户干预的情况下为其恢复在线状态的目的。
系统最多支持为16个user-recovery Profile开启恢复用户功能。通常,不同的Profile对应不同的RESTful服务器以及服务器上的用户信息。
开启本功能后,请执行save命令,并将配置文件设置为下次启动配置文件保证本功能在设备下次重启后生效。关于save命令的详细介绍请参见“基础配置命令参考”中的“配置文件管理”。
RADIUS的accounting-on功能与MAC地址认证恢复用户功能互斥,不建议同时开启。关于accounting-on功能详细介绍,请参见“用户接入与认证配置指导”中的“AAA”。
# 开启MAC地址认证的自动恢复用户功能,并指定user-recovery Profile为profile1。
[Sysname] mac-authentication auto-recover-user profile profile1
· accounting-on enable(用户接入与认证命令参考/AAA)
mac-authentication carry user-ip命令用来配置MAC地址认证请求中携带用户IP地址。
undo mac-authentication carry user-ip命令用来恢复缺省情况。
mac-authentication carry user-ip [ exclude-ip acl acl-number ]
MAC地址认证请求中不携带用户IP地址。
二层以太网接口视图
exclude-ip:指定不合法的IP地址范围,不对携带不合法IP地址的用户进行MAC地址认证。
acl acl-number:指定包含deny规则的ACL。其中acl-number表示ACL的编号,仅支持基本ACL和用户自定义ACL,取值范围为2000~2999、5000~5999。
在终端用户采用静态IP地址方式接入的组网环境中,如果终端用户擅自修改自己的IP地址,则整个网络环境中可能会出现IP地址冲突等问题。
为了解决以上问题,管理员可以在端口上开启MAC地址认证请求中携带用户IP地址的功能,用户在进行MAC地址认证时,设备会把用户的IP地址上传到iMC服务器。然后iMC服务器会把认证用户的IP地址和MAC地址与服务器上已经存在的IP与MAC的绑定表项进行匹配,如果匹配成功,则该用户MAC地址认证成功;否则,MAC地址认证失败。
配置mac-authentication carry user-ip命令后,当有用户接入时,设备会检查用户报文中的IP地址是否合法,并进行相应处理:
· 当用户的IP地址合法时,设备携带用户IP地址向服务器发起MAC地址认证请求;
· 当用户报文未携带IP地址或用户的IP地址不合法时,设备不对用户进行MAC地址认证。
· 收到源IP为0.0.0.0的DHCP报文时,设备会向服务器发起MAC地址认证请求,但认证报文中不携带IP地址。认证是否通过取决于认证服务器侧的配置。
H3C的iMC服务器上IP与MAC地址信息绑定表项的生成方式如下:
· 如果在iMC服务器上创建用户时手工指定了用户的IP地址和MAC地址信息,则服务器使用手工指定的IP和MAC信息生成该用户的IP与MAC地址的绑定表项。
· 如果在iMC服务器上创建用户时未手工指定用户的IP地址和MAC地址信息,则服务器使用用户初次进行MAC地址认证时使用的IP地址和MAC地址生成该用户的IP与MAC地址的绑定表项。
终端用户采用静态IP地址接入时,实际组网应用中会出现用户报文中携带的IP地址并非用户实际IP地址的情况,例如在IPv4静态地址组网中,用户报文携带的IP地址为以fe80开头的IPv6链路本地地址。配置mac-authentication carry user-ip命令后,设备会携带非用户实际的IP地址向服务器发起MAC地址认证请求,此种情况会导致服务器为用户绑定错误的IP地址或IP地址与MAC地址匹配失败。为避免上述情况发生,可以指定exclude-ip acl参数,不允许ACL中指定网段的用户进行MAC地址认证。
配置exclude-ip acl时,仅根据规则中配置的源IP地址进行过滤。建议ACL中配置deny规则来拒绝指定网段的用户进行MAC地址认证。如果ACL中仅配置了permit规则,则表示允许指定网段的用户进行MAC地址认证,这样的配置并没有实际意义。如果希望只允许某个网段用户进行MAC地址认证,可在ACL中同时配置一条指定网段的permit规则以及一条deny all规则来实现。
通过exclude-ip acl指定ACL后,设备对于IPv4报文按照对应编号的IPv4 ACL规则进行处理;对于IPv6报文则按照对应编号的IPv6 ACL规则进行处理。例如,当配置了mac-authenication carry user-ip exclude-ip acl 2000时,如果用户报文为IPv4报文,则按照IPv4 ACL 2000的规则进行处理;如果用户报文为IPv6报文,则按照IPv6 ACL 2000的规则进行处理。
若通过exclude-ip acl指定的ACL为用户自定义ACL(ACL编号为5000~5999),设备仅支持匹配ipv4、 ipv6或any类型的ACL规则,不支持匹配其他类型的规则,且为自定义ACL配置的规则必须只包含源IP地址。
# 在端口Ten-GigabitEthernet0/0/6上配置MAC地址认证请求携带用户IP地址功能。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication carry user-ip
# 在端口Ten-GigabitEthernet0/0/6上配置MAC地址认证请求携带用户IP地址功能,并禁止携带IPv6链路本地地址的报文在此端口触发认证。
[Sysname]acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule deny source fe80:0::0:0 16
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication carry user-ip exclude-ip acl 2000
mac-authentication critical vlan命令用来配置端口的MAC地址认证的Critical VLAN。
undo mac-authentication critical vlan命令用来恢复缺省情况。
端口上未配置MAC地址认证的Critical VLAN。
二层以太网接口视图
配置此功能后,当MAC用户认证时对应的ISP域下所有认证服务器都不可达的情况下被授权访问Critical VLAN内的资源。
如果某个VLAN被指定为Super VLAN,则该VLAN不能被指定为某个端口的MAC地址认证的Critical VLAN;同样,如果某个VLAN被指定为某个端口的MAC地址认证的Critical VLAN,则该VLAN不能被指定为Super VLAN。
禁止删除已被配置为Critical VLAN的VLAN,若要删除该VLAN,请先通过undo mac-authentication critical vlan命令取消MAC地址认证的Critical VLAN配置。
# 配置端口Ten-GigabitEthernet0/0/6的Critical VLAN为VLAN 100。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication critical vlan 100
· reset mac-authentication critical vlan
mac-authentication critical-voice-vlan命令用来开启端口上MAC地址认证的Critical Voice VLAN功能。
undo mac-authentication critical-voice-vlan命令用来关闭端口上MAC地址认证的Critical Voice VLAN功能。
端口下MAC地址认证的Critical Voice VLAN功能处于关闭状态。
二层以太网接口视图
端口上开启MAC地址认证Critical Voice VLAN功能后,当语音用户进行MAC地址认证采用的ISP域中的所有认证服务器都不可达时,端口将被加入到此端口上的Voice VLAN中。端口上语音VLAN的配置命令请参见“二层技术-以太网交换命令参考”中的“VLAN”。
设备通过LLDP(Link Layer Discovery Protocol,链路层发现协议)来判断用户是否为语音用户,因此为保证MAC地址认证Critical Voice VLAN功能可以正常工作,请在开启此功能之前务必确保全局和相应端口下均已开启LLDP功能。有关LLDP功能的配置命令介绍请参见“二层技术-以太网交换命令参考”中的“LLDP”。
# 开启端口Ten-GigabitEthernet0/0/6上MAC地址认证Critical Voice VLAN功能。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication critical-voice-vlan
· lldp enable(二层技术-以太网交换命令参考/LLDP)
· lldp global enable(二层技术-以太网交换命令参考/LLDP)
· reset mac-authentication critical-voice-vlan
· voice-vlan enable(二层技术-以太网交换命令参考/VLAN)
mac-authentication domain命令用来指定MAC地址认证用户使用的认证域。
未指定MAC地址认证用户使用的认证域时,使用系统缺省的认证域。缺省认证域的介绍请参见“用户接入与认证命令参考/AAA”中的命令domain default enable。
二层以太网接口视图
不同视图下指定的认证域的生效范围不同:
· 系统视图下指定的认证域对所有开启了MAC地址认证的端口生效。
· 二层以太网接口视图下指定的认证域仅对本端口有效。不同的端口可以指定不同的认证域。
端口上接入的MAC地址认证用户将按照如下先后顺序选择认证域:端口上指定的认证域 > 系统视图下指定的认证域 > 系统缺省的认证域。
# 在系统视图下指定MAC地址认证用户使用的认证域为domain1。
# 指定端口Ten-GigabitEthernet0/0/6上接入的MAC地址认证用户使用的认证域为aabbcc。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication domain aabbcc
· domain default enable(用户接入与认证命令参考/AAA)
mac-authentication guest-vlan命令用来配置端口的MAC地址认证的Guest VLAN。
undo mac-authentication guest-vlan命令用来恢复缺省情况。
端口上未配置MAC地址认证的Guest VLAN。
二层以太网接口视图
配置此功能后,当MAC地址认证失败的情况下,用户可以继续被授权访问的Guest VLAN内的资源。
如果某个VLAN被指定为Super VLAN,则该VLAN不能被指定为某个端口的MAC地址认证的Guest VLAN;同样,如果某个VLAN被指定为某个端口的MAC地址认证的Guest VLAN,则该VLAN不能被指定为Super VLAN。
禁止删除已被配置为Guest VLAN的VLAN,若要删除该VLAN,请先通过undo mac-authentication guest-vlan命令取消MAC地址认证的Guest VLAN配置。
# 配置端口Ten-GigabitEthernet0/0/6的Guest VLAN为VLAN 100。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication guest-vlan 100
· reset mac-authentication guest-vlan
mac-authentication guest-vlan auth-period命令用来配置设备对Guest VLAN中的用户进行重新认证的时间间隔。
undo mac-authentication guest-vlan auth-period命令用来恢复缺省情况。
设备对Guest VLAN中的用户进行重新认证的时间间隔为30秒。
二层以太网接口视图
period-value:表示设备重新发起认证的时间间隔,取值范围为1~3600,单位为秒。
# 在端口Ten-GigabitEthernet0/0/6上配置设备对Guest VLAN中的用户进行重新认证的时间间隔为150秒。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication guest-vlan auth-period 150
mac-authentication host-mode multi-vlan命令用来指定端口工作在MAC地址认证的多VLAN 模式。
undo mac-authentication host-mode命令用来恢复缺省情况。
端口工作在MAC地址认证的单VLAN 模式。
二层以太网接口视图
端口工作在多VLAN模式下时,如果相同MAC地址的用户在属于不同VLAN的相同端口再次接入,设备将能够允许用户的流量在新的VLAN内通过,且允许该用户的报文无需重新认证而在多个VLAN中转发。
端口工作在单VLAN模式下时,在用户已上线,且没有被下发授权VLAN情况下,如果此用户在属于不同VLAN的相同端口再次接入,则设备将让原用户下线,使得该用户能够在新的VLAN内重新开始认证。如果已上线用户被下发了授权VLAN,则此用户在属于不同VLAN的相同端口再次接入时不会被强制下线。
对于接入IP电话类用户的端口,指定端口工作在MAC地址认证的多VLAN模式,可避免IP电话终端的报文所携带的VLAN tag发生变化后,因用户流量需要重新认证带来语音报文传输质量受干扰的问题。
# 配置端口Ten-GigabitEthernet0/0/6工作在MAC地址认证的多VLAN模式。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication host-mode multi-vlan
mac-authentication mac-range-account命令用来配置对指定MAC地址范围的MAC地址认证用户设置用户名和密码。
undo mac-authentication mac-range-account命令用来恢复缺省情况。
mac-authentication mac-range-account mac-address mac-address mask { mask | mask-length } account name password { cipher | simple } string
undo mac-authentication mac-range-account { all | mac-address mac-address }
未对指定MAC地址范围的MAC地址认证用户设置用户名和密码,MAC地址认证用户采用mac-authentication user-name-format命令设置的用户名和密码接入设备。
mac-address mac-address:指定的MAC地址,格式为H-H-H。
mask mask:表示MAC地址的掩码。格式为H-H-H,该掩码转为二进制时,高位必须为连续的1。
mask mask-length:MAC地址掩码长度,即掩码中连续“1”的数量,取值范围为1~48。
account name:指定发送给RADIUS服务器进行认证或者在本地进行认证的用户名。其中name为用户名,为1~55个字符的字符串,区分大小写,不能包括字符@。
password:指定用户的密码。
cipher:以密文方式设置密码。
simple:以明文方式设置密码,该密码将以密文形式存储。
all:表示删除所有指定的MAC地址范围。
如果需要对特定MAC地址范围的用户单独设置用户名和密码(例如对指定OUI的MAC地址单独设置用户名和密码)时,可以执行本命令。本命令的优先级高于mac-authentication user-name-format命令。
可通过多次执行本命令来配置多个MAC地址段的用户名和密码,但不允许指定的MAC地址重叠。如果新配置命令的MAC地址范围与已有的MAC地址范围完全相同,则后配置的命令会覆盖已有的命令。
本命令仅对单播MAC地址范围有效。若配置的MAC地址范围仅包含组播地址,则配置失败;若既包含组播地址,也包含单播地址,则仅单播地址范围部分有效,组播地址范围部分无效。其中,全零MAC地址也不属于有效MAC地址,一个全零的MAC地址用户不能通过MAC地址认证。
设备最多允许配置16个MAC地址范围。
# 配置以aaaa开头的MAC地址,进行MAC地址认证时使用的用户名为user1,明文密码为1234。
[Sysname] mac-authentication mac-range-account mac-address aaaa-0000-0000 mask ffff-0000-0000 account user1 password simple 1234
· mac-authentication user-name-format
mac-authentication max-user命令用来配置端口上最多允许同时接入的MAC地址认证用户数。undo mac-authentication max-user命令用来恢复缺省情况。
端口上最多允许同时接入的MAC地址认证用户数为4294967295。
二层以太网接口视图
max-number:端口允许同时接入的MAC地址认证用户数的最大值,取值范围为1~4294967295。
由于系统资源有限,如果当前端口上接入的用户过多,接入用户之间会发生资源的争用,因此适当地配置该值可以使属于当前端口的用户获得可靠的性能保障。当接入此端口的MAC地址认证用户数超过最大值后,新接入的用户将被拒绝。
# 配置端口Ten-GigabitEthernet0/0/6最多允许同时接入32个MAC地址认证用户。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication max-user 32
mac-authentication recover-user命令用来手动恢复MAC地址认证用户。
mac-authentication recover-user profile profile-name [ interface interface-type interface-number ]
interface interface-type interface-number:指定MAC地址认证用户所在的端口。interface-type interface-number为端口类型和端口编号。若不指定该参数,则表示恢复所有端口上的MAC地址认证用户。
设备或接口板重启、接口故障原因导致设备上MAC认证用户下线后,如果因链路震荡等原因使得设备自动恢复MAC地址认证用户并不完全时,管理员可以执行本命令从指定的RESTful服务器上获取待恢复的在线用户信息,并为这些用户重新认证。
# 使用名称为profile1的user-recovery Profile手动恢复MAC地址认证用户。
<Sysname> mac-authentication recover-user profile profile1
· mac-authentication auto-recover-user
mac-authentication re-authenticate server-unreachable keep-online命令用来配置重认证服务器不可达时端口上的MAC地址认证用户保持在线状态。
undo mac-authentication re-authenticate server-unreachable命令用来恢复缺省情况。
端口上的MAC地址认证在线用户重认证时,若认证服务器不可达,则会被强制下线。
二层以太网接口视图
配置此命令后,在对MAC地址认证用户重认证过程中,若设备发现认证服务器状态不可达,则保持MAC地址认证用户在线。
是否对MAC地址认证在线用户进行周期性重认证由认证服务器授权的属性所决定。认证服务器通过下发RADIUS属性(session-timeout、Terminal-Action)来指定用户会话超时时长以及会话中止的动作类型,它们共同决定了如何对用户进行重认证。
· 当会话中止的动作类型为要求用户进行重认证时,端口会在用户会话超时时长到达后对该用户进行重认证;
· 当会话中止的动作类型为要求用户下线时,端口会在用户会话超时时长到达强制该用户下线;
· 当认证服务器未下发用户会话超时时长时,设备不会对用户进行重认证。
# 配置端口Ten-GigabitEthernet0/0/6上的MAC地址认证在线用户进行重认证时,若服务器不可达,则保持在线状态。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication re-authenticate server-unreachable keep-online
mac-authentication timer命令用来配置端口上的MAC地址认证的定时器参数。
undo mac-authentication timer命令用来将端口上指定的MAC地址认证定时器恢复为缺省情况。
mac-authentication timer { auth-delay auth-delay-time | reauth-period reauth-period-value }
undo mac-authentication timer { auth-delay | reauth-period }
端口上未配置MAC地址认证延迟定时器,表示MAC地址认证延迟功能处于关闭状态,如果用户报文触发MAC地址认证,认证将会立刻开始;端口上未配置MAC地址周期性重认证定时器,端口使用系统视图下配置的MAC地址周期性重认证定时器的取值。
二层以太网接口视图
auth-delay auth-delay-time:表示MAC地址认证延迟定时器。其中auth-delay-time表示MAC地址认证延迟定时器的值,取值范围为1~180,单位为秒。
reauth-period reauth-period-value:表示MAC地址认证周期性重认证定时器。其中reauth-period-value表示周期性重认证定时器的值,取值范围为60~7200,单位为秒。
开启端口的MAC地址认证延时功能之后,端口就不会在收到用户报文时立即触发MAC地址认证,而是在等待一定的延迟时间之后,再会对之前收到的用户报文进行MAC地址认证。在此认证延迟期间,端口对用户报文的其它认证过程并不受影响。
开启了MAC地址认证延迟功能的端口上不建议同时配置端口安全的模式为mac-else-userlogin-secure或mac-else-userlogin-secure-ext,否则MAC地址认证延迟功能不生效。端口安全模式的具体配置请参见“用户接入与认证命令参考”中的“端口安全”。
对MAC地址认证用户进行重认证时,设备将按照如下由高到低的顺序为其选择重认证时间间隔:服务器下发的重认证时间间隔、接口视图下配置的周期性重认证定时器的值、系统视图下配置的周期性重认证定时器的值、设备缺省的周期性重认证定时器的值。
对于已在线的MAC地址认证用户,要等当前重认证周期结束并且认证通过后才会按新配置的周期进行后续的重认证。
# 开启MAC地址延迟认证功能,并指定MAC地址认证的延时时间为10秒。
[Sysname-Ten-GigabitEthernet0/0/6] mac-authentication timer auth-delay 10
· port-security port-mode(用户接入与认证命令参考/端口安全)
mac-authentication timer命令用来配置MAC地址认证的定时器参数。
undo mac-authentication timer命令用来恢复缺省情况。
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | reauth-period reauth-period-value | server-timeout server-timeout-value | user-aging { critical-vlan | guest-vlan } aging-time-value }
undo mac-authentication timer { offline-detect | quiet | reauth-period | server-timeout | user-aging { critical-vlan | guest-vlan } aging-time-value }
下线检测定时器的值为300秒,静默定时器的值为60秒,周期性重认证定时器的值为3600秒,服务器超时定时器的值为100秒,指定类型的非认证成功VLAN内用户老化定时器的值为1000秒。
offline-detect offline-detect-value:表示下线检测定时器。其中,offline-detect-value表示下线检测定时器的值,取值范围为60~2147483647,单位为秒。
quiet quiet-value:表示静默定时器。其中quiet-value表示静默定时器的值,取值范围为1~3600,单位为秒。
reauth-period reauth-period-value:表示周期性重认证定时器,其中reauth-period-value表示周期性重认证定时器的值,取值范围为60~7200,单位为秒。
server-timeout server-timeout-value:表示服务器超时定时器。其中,server-timeout-value表示服务器超时定时器的值,取值范围为100~300,单位为秒。
user-aging:设置加入到指定类型的非认证成功VLAN中用户的老化定时器。
critical-vlan:加入到Critical VLAN中用户的老化定时器。
guest-vlan:加入到Guest VLAN中用户的老化定时器。
aging-time-value:用户老化定时器的值,取值范围为60~2147483647,单位为秒。
MAC地址认证过程受以下定时器的控制:
· 下线检测定时器(offline-detect):用来设置在线用户空闲超时的时间间隔。开启MAC地址认证下线检测功能后,若设备在一个下线检测定时器间隔之内,没有收到某在线用户的报文,将切断该用户的连接,同时通知RADIUS服务器停止对其计费。配置offline-detect时,需要将MAC地址老化时间配成相同时间,否则会导致用户异常下线。只有当端口的MAC地址认证下线检测功能处于开启状态时,该定时器生效。
· 静默定时器(quiet):用来设置用户认证失败以后,设备需要等待的时间间隔。在静默期间,设备不对来自认证失败用户的报文进行认证处理,直接丢弃。静默期后,如果设备再次收到该用户的报文,则依然可以对其进行认证处理。
· 周期性重认证定时器(reauth-period):端口下开启了MAC地址周期性重认证功能后,设备可以此间隔为周期对端口上的在线用户发起重认证。对于已在线的MAC地址认证用户,要等当前重认证周期结束并且认证通过后才会按新配置的周期进行后续的重认证。
· 服务器超时定时器(server-timeout):用来设置设备同RADIUS服务器的连接超时时间。在用户的认证过程中,如果到服务器超时定时器超时时设备一直没有收到RADIUS服务器的应答,则设备将在相应的端口上禁止此用户访问网络。
建议将server-timeout的值设定为小于或等于设备发送RADIUS报文的最大尝试次数(retry)与RADIUS服务器响应超时时间(timer response-timeout)之积。如果server-timeout的值大于retry与timer response-timeout之积,则可能在server-timeout设定的服务器超时时间到达前,用户被强制下线。
关于发送RADIUS报文的最大尝试次数、RADIUS服务器响应超时时间的具体配置请参见“用户接入与认证配置指导”中的“AAA”。
· 用户老化定时器(user-aging):用来设置指定类型的VLAN内用户老化时间。用户加入到Guest VLAN或Critical VLAN后,设备启动该定时器。如果到达设定的老化时间,则用户离开指定的VLAN。
只有通过mac-authentication unauthenticated-user aging enable命令开启非认证成功VLAN中MAC地址认证用户的老化功能时,该定时器生效。
# 设置服务器超时定时器时长为150秒。
· mac-authentication guest-vlan auth-period
· mac-authentication unauthenticated-user aging enable
· retry(用户接入与认证命令参考/AAA)
· timer response-timeout (RADIUS scheme view)(用户接入与认证命令参考/AAA)
mac-authentication user-name-format命令用来配置MAC地址认证用户的帐号格式。
undo mac-authentication user-name-format命令用来恢复缺省情况。
mac-authentication user-name-format { fixed [ account name ] | mac-address [ { with-hyphen [ six-section | three-section ] | without-hyphen } [ lowercase | uppercase ] ] } [ password { cipher | simple } string ]
使用用户的MAC地址作为用户名和密码,其中字母为小写,且不带连字符“-”。
fixed:表示采用固定用户名账号。
account name:指定发送给RADIUS服务器进行认证或者在本地进行认证的用户名。其中name为用户名,为1~55个字符的字符串,区分大小写,不能包括字符@,缺省为mac。
mac-address:表示使用用户的MAC地址作为用户名。
with-hyphen [ six-section | three-section ]:带连字符“-”的MAC地址格式,six-section表示六段式MAC地址格式,例如xx-xx-xx-xx-xx-xx或XX-XX-XX-XX-XX-XX;three-section表示三段式MAC地址格式,例如xxxx-xxxx-xxxx或XXXX-XXXX-XXXX。如果不指定任何参数,缺省采用六段式MAC地址格式。
without-hyphen:不带连字符“-”的MAC地址格式,例如xxxxxxxxxxxx。
lowercase:MAC地址中的字母为小写。
uppercase:MAC地址中的字母为大写。
password:指定用户的密码。使用用户的MAC地址作为用户名时,若不配置password参数,则表示使用用户的MAC地址同时作为用户名和密码;对于采用固定用户名的情况,若不配置password参数,则表示无密码。
· cipher:以密文方式设置密码。
· simple:以明文方式设置密码,该密码将以密文形式存储。
指定用户的MAC地址为用户名时,每一个MAC地址认证用户都使用唯一的用户名进行认证,安全性高,但要求认证服务器端配置多个MAC形式的用户账户。
若指定一个固定的用户名,则表示不论用户的MAC地址为何值,所有用户均使用设备上指定的一个固定用户名和密码作为身份信息进行认证。由于同一个端口下可以有多个用户进行认证,因此这种情况下端口上的所有MAC地址认证用户均使用同一个固定用户名账号进行认证,服务器端仅需要配置一个用户账户即可满足所有认证用户的认证需求,适用于接入客户端比较可信的网络环境。
# 配置MAC地址认证的用户名为abc,密码是明文xyz。
# 配置用户的MAC地址为用户名和密码,使用不带连字符“-”的MAC地址格式,其中字母大写。
[Sysname] mac-authentication user-name-format mac-address without-hyphen uppercase
mac-authentication user-recovery-profile命令用来创建MAC地址认证user-recovery Profile,并进入user-recovery Profile视图。如果指定的user-recovery Profile已存在,则直接进入user-recovery Profile视图。
undo mac-authentication user-recovery-profile命令用来删除指定的MAC地址认证user-recovery Profile。
mac-authentication user-recovery-profile profile-name
undo mac-authentication user-recovery-profile profile-name
不存在MAC地址认证user-recovery Profile。
user-recovery Profile中定义了RESTful服务器的相关参数,主要包括服务器的IP地址、用户资源URI和登录到该服务器所需的用户名和密码。设备与RESTful服务器成功建立连接之后,可以从该服务器上手工或自动获取在线用户的账户信息,用于设备或接口板重启、接口故障恢复后的用户状态恢复。
系统最多支持配置16个user-recovery Profile。
# 创建一个名称为profile1的MAC地址认证user-recovery Profile,并进入其视图。
[Sysname] mac-authentication user-recovery-profile profile1
New user-recovery profile created
· mac-authentication recover-user
mac-authentication web-proxy命令用来配置允许触发MAC地址认证URL重定向的Web代理服务器端口。
undo mac-authentication web-proxy命令用来删除指定或所有的Web代理服务器端口。
mac-authentication web-proxy { http | https } port port-number
undo mac-authentication web-proxy { { http | https } port port-number | all-port }
未配置允许触发MAC地址认证URL重定向的Web代理服务器端口。
http:表示HTTP请求触发MAC地址认证URL重定向功能。
https:表示HTTPS请求触发MAC地址认证URL重定向功能。
port port-number:MAC地址认证URL重定向功能的Web代理服务器的TCP端口号,取值范围为1~65535。其中,80和443端口是MAC地址认证URL重定向功能的预留端口号,不可配置。
all-port:指定所有MAC地址认证URL重定向功能的Web代理服务器的TCP端口号。
设备默认只允许未配置Web代理服务器的用户浏览器发起的HTTP/HTTPS请求才能触发MAC地址认证URL重定向功能。若用户使用配置了Web代理服务器的浏览器上网,则用户在通过MAC地址认证之后发送的HTTP/HTTPS请求报文将被丢弃。这种情况下,网络管理员可以通过在设备上添加Web代理服务器的TCP端口号,来允许使用Web代理服务器的用户浏览器发起的HTTP/HTTPS请求也可以触发MAC地址认证的URL重定向。
配置允许触发MAC地址认证URL重定向功能的Web代理服务器端口,需要注意的是:
· 通过多次执行本命令,最多可以添加64个允许触发MAC地址认证URL重定向功能的Web代理服务器端口。
· HTTP和HTTPS请求允许触发MAC地址认证URL重定向功能的Web代理服务器端口不能相同。
· 在有MAC地址认证用户在线的情况下,通过本命令新增或删除Web代理端口号时,设备会强制让所有授权了重定向URL的MAC地址认证用户下线。
# 配置HTTP请求允许触发MAC地址认证URL重定向的Web代理服务器端口号为8080。
[Sysname] mac-authentication web-proxy http port 8080
nas-ip命令用来配置设备和RESTful服务器交互时使用的NAS-IP地址。
undo nas-ip命令用来删除设备和RESTful服务器交互时使用的NAS-IP地址。
nas-ip { ipv4-address | ipv6 ipv6-address }
undo nas-ip
未配置设备和RESTful服务器交互时使用的NAS-IP地址。
ipv4-address:指定的IPv4 NAS-IP地址,禁止配置全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6 ipv6-address:指定的IPv6 NAS-IP地址,必须是单播地址,不能为环回地址与本地链路地址。
RESTful服务器上通过IP地址来标识接入设备,它会根据收到的RESTful请求中携带的NAS-IP地址参数来匹配接入设备,然后将匹配上的接入设备的用户信息发送给该接入设备。
此处配置的NAS-IP必须和用户认证使用的RADIUS方案下的NAS-IP配置保持一致,而且同一个user-recovery Profile下配置的NAS-IP地址类型必须和RESTful服务器IP地址类型保持一致,否则设备不会向该视图中指定的RESTful服务器发送请求。
同一个user-recovery Profile下多次执行本命令,最后一次执行的命令生效。
# 在名称为profile1的user-recovery Profile视图下,配置设备和RESTful服务器交互使用的NAS-IP地址为10.1.1.1。
[Sysname-user-recovery-profile-profile1] nas-ip 10.1.1.1
· nas-ip (RADIUS scheme view) (用户接入与认证命令参考/AAA)
reset mac-authentication access-user命令用来强制MAC地址认证用户下线。
reset mac-authentication access-user [ interface interface-type interface-number | mac mac-address username username | vlan vlan-id ]
interface interface-type interface-number:表示强制指定端口下的MAC地址认证用户下线。interface-type interface-number为端口类型和端口编号。
mac mac-address:表示强制指定MAC地址的MAC地址认证用户下线。mac-address表示MAC地址认证用户的MAC地址,格式为H-H-H。
username username:表示强制指定名称的MAC地址认证用户下线。username表示MAC地址认证用户的名称,为1~253个字符的字符串,区分大小写。
vlan vlan-id:表示强制指定VLAN内的MAC地址认证用户下线。vlan-id表示MAC地址认证用户当前所在VLAN的VLAN ID(可通过display mac-address命令查看),取值范围为1~4094。
reset mac-authentication access-user命令用来强制指定的MAC地址认证用户下线。强制用户下线后,设备会删除对应的用户信息,用户再次上线时,需要重新进行MAC地址认证。
指定vlan vlan-id参数时,设备会对如下几种MAC地址认证用户进行下线处理:
· 对于已经认证成功且服务器已授权VLAN的用户,将服务器授权的VLAN为vlan-id的用户强制下线;
· 对于已认证成功且服务器未授权VLAN的用户,将设备上对用户生效的VLAN为vlan-id的用户强制下线;
· 对于正在认证中的用户,将初始VLAN为vlan-id的用户强制下线。
如果不指定任何参数,则强制设备上所有MAC地址认证用户下线。
# 强制端口Ten-GigabitEthernet0/0/6上的所有MAC地址认证用户下线。
<Sysname> reset mac-authentication access-user interface ten-gigabitethernet 0/0/6
· display mac-authentication connection
reset mac-authentication critical vlan命令用来清除Critical VLAN内的MAC地址认证用户。
reset mac-authentication critical vlan interface interface-type interface-number [ mac-address mac-address ]
interface interface-type interface-number:表示使指定端口上的用户退出Critical VLAN。interface-type interface-number为端口类型和端口编号。
mac-address mac-address:表示使指定MAC地址的用户退出Critical VLAN。若不指定本参数,则表示使指定端口上的所有用户退出Critical VLAN。
# 在端口Ten-GigabitEthernet0/0/6上使得MAC地址为1-1-1的MAC地址认证用户退出Critical VLAN。
<Sysname> reset mac-authentication critical vlan interface ten-gigabitethernet 0/0/6 mac-address 1-1-1
reset mac-authentication critical-voice-vlan命令用来清除MAC地址认证Critical Voice VLAN内的MAC地址认证用户。
reset mac-authentication critical-voice-vlan interface interface-type interface-number [ mac-address mac-address ]
interface interface-type interface-number:表示使指定端口上的用户退出MAC地址认证的Critical Voice VLAN,其中interface-type interface-number为端口类型和端口编号。
mac-address mac-address:表示清除指定MAC地址的用户退出MAC地址认证的Critical Voice VLAN。若不指定本参数,则表示使指定端口上的所有用户退出Critical Voice VLAN。
# 在端口Ten-GigabitEthernet0/0/6上使得MAC地址为1-1-1的MAC地址认证用户退出Critical Voice VLAN。
<Sysname> reset mac-authentication critical-voice-vlan interface ten-gigabitethernet 0/0/6 mac-address 1-1-1
· mac-authentication critical-voice-vlan
reset mac-authentication guest-vlan命令用来清除Guest VLAN内的MAC地址认证用户。
# 在端口Ten-GigabitEthernet0/0/6上使得MAC地址为1-1-1的MAC地址认证用户退出Guest VLAN。
<Sysname> reset mac-authentication guest-vlan interface ten-gigabitethernet 0/0/6 mac-address 1-1-1
reset mac-authentication statistics命令用来清除MAC地址认证的统计信息。
interface interface-type interface-number:清除指定端口的MAC地址认证统计信息。interface-type interface-number为端口类型和端口编号。如果不指定本参数,则清除所有端口上的MAC地址认证统计信息。
# 清除以太网端口Ten-GigabitEthernet0/0/6上的MAC认证统计信息。
<Sysname> reset mac-authentication statistics interface ten-gigabitethernet 0/0/6
server-address命令用来配置RESTful服务器的IP地址参数。
undo server-address命令用来恢复缺省情况。
server-address { ip ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ]
undo server-address
未配置RESTful服务器的IP地址参数。
ip ipv4-address:RESTful服务器的IPv4地址。
ipv6 ipv6-address:RESTful服务器的IPv6地址。
port port-number:RESTful服务器监听请求消息的端口号,取值范围为1~65535,缺省值为80。
vpn-instance vpn-instance-name:RESTful服务器所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定该参数,则表示RESTful服务器位于公网。
设备或接口板重启、接口故障恢复后,将与指定的RESTful服务器通信,获取接口上的MAC地址认证用户账户信息。
同一个user-recovery Profile下配置的RESTful服务器IP地址类型必须和NAS-IP的地址类型保持一致。
# 在名称为profile1的user-recovery Profile视图下,指定RESTful服务器的IP地址为3.3.3.3,端口号为8080。
[Sysname-user-recovery-profile-profile1] server-address ip 3.3.3.3 port 8080
· nas-ip
uri命令用来指定RESTful服务器的URI。
undo uri命令用来删除指定的RESTful服务器URI。
uri uri-string
undo uri
未指定RESTful服务器的URI。
uri-string:URI名称,为1~255字符的字符串,区分大小写。
本命令指定的URI为RESTful服务器上提供用户资源服务的URI。
支持指定的RESTful服务器的URI为imcrs/uam/online/notAgingMuteTerminal,指定为其他URI时,本配置不生效。
设备向RESTful服务器发起请求获取在线用户信息时,HTTP请求的URL地址由该RESTful服务器的IP地址、监听端口号以及本命令指定的URI拼接而成,格式为http://server-ip:port/uri,例如http://3.3.3.3:8080/imcrs/uam/online/notAgingMuteTerminal。
# 在名称为profile1的user-recovery Profile视图下,指定向RESTful服务器请求用户信息的URI为imcrs/uam/online/notAgingMuteTerminal。
[Sysname-user-recovery-profile-profile1] uri imcrs/uam/online/notAgingMuteTerminal
· server-address
