02-以太网链路聚合命令
本章节下载: 02-以太网链路聚合命令 (385.98 KB)
1.1.3 display link-aggregation load-sharing mode
1.1.4 display link-aggregation member-port
1.1.5 display link-aggregation summary
1.1.6 display link-aggregation troubleshooting
1.1.7 display link-aggregation verbose
1.1.8 interface bridge-aggregation
1.1.9 interface route-aggregation
1.1.11 lacp default-selected-port disable
1.1.20 link-aggregation bfd-compatible enable
1.1.21 link-aggregation global load-sharing mode
1.1.22 link-aggregation ignore speed
1.1.23 link-aggregation lacp traffic-redirect-notification enable
1.1.24 link-aggregation load-sharing mode
1.1.25 link-aggregation load-sharing mpls enhanced
1.1.27 link-aggregation port-priority
1.1.28 link-aggregation primary-port
1.1.29 link-aggregation reversion delay
1.1.30 link-aggregation secondary-down
1.1.31 link-aggregation selected-port maximum
1.1.32 link-aggregation selected-port minimum
1.1.33 link-aggregation selected-port minimum percentage
1.1.34 link-aggregation switchover
1.1.37 port lacp system-priority
1.1.38 port link-aggregation group
1.1.41 sub-interface rate-statistic
display interface命令用来显示聚合接口的相关信息。
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
bridge-aggregation:显示二层聚合接口的相关信息。
route-aggregation:显示三层聚合接口的相关信息。
interface-number:表示聚合接口的编号,取值范围为已创建的聚合接口的编号。
brief:显示接口的概要信息。如果未指定该参数,将显示接口的详细信息。
如果未指定聚合接口的类型,将显示设备支持的所有接口的相关信息。
如果指定了聚合接口的类型而未指定聚合接口编号,将显示所有已创建的该类型聚合接口的相关信息。
# 显示二层聚合接口1的详细信息。
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 1000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Access
Tagged VLANs: None
UnTagged VLANs: 1
Last 300 seconds input: 6900 packets/sec 885160 bytes/sec 0%
Last 300 seconds output: 3150 packets/sec 404430 bytes/sec 0%
Input (total): 5364747 packets, 686688416 bytes
2682273 unicasts, 1341137 broadcasts, 1341337 multicasts, 0 pauses
Input (normal): 5364747 packets, 686688416 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
- ignored, - parity errors
Output (total): 1042508 packets, 133441832 bytes
1042306 unicasts, 0 broadcasts, 202 multicasts, - pauses
Output (normal): 1042508 packets, 133441832 bytes
1042306 unicasts, 0 broadcasts, 202 multicasts, 0 pauses
- lost carrier, - no carrier
# 显示三层聚合接口1的详细信息。
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Description: Route-Aggregation1 Interface
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
Input (total): 0 packets, 0 bytes
Input (normal): 0 packets, 0 bytes
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
0 lost carrier, 0 no carrier
# 显示二层聚合接口1的概要信息。
<Sysname> display interface bridge-aggregation 1 brief
Speed: (a) – auto
Interface Link Speed Duplex Type PVID Description
BAGG1 DOWN auto A A 1
# 显示三层聚合接口1的概要信息。
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1 UP UP --
表1-1 display interface命令显示信息描述表
Bridge-Aggregation1 |
二层聚合接口名 |
Route-Aggregation1 |
三层聚合接口名 |
Current state |
接口的状态: · Administratively DOWN:表示该接口已被shutdown命令关闭,其管理状态为关闭 · DOWN:表示该接口的管理状态为开启,但其物理状态为关闭(可能由于没有物理连线或线路故障) · UP:表示该接口的管理状态和物理状态均为开启 |
IP packet frame type |
IPv4报文帧格式 |
IPv6 packet frame type |
IPv6报文帧格式 |
hardware address |
接口的MAC地址 |
接口的描述信息 |
Bandwidth |
接口的期望带宽值,当该参数的取值为0时,不显示该参数 |
Unknown-speed mode, unknown-duplex mode |
接口的速率和双工模式均未知 |
Link speed type is autonegotiation, link duplex type is autonegotiation |
接口的速率和双工模式都是通过自协商确定的 |
PVID |
接口缺省VLAN的编号 |
Port link-type |
接口的链路类型,取值可能为access、trunk或hybrid |
Tagged VLANs |
通过该接口后携带Tag的VLAN |
Untagged VLANs |
通过该接口后不再携带Tag的VLAN |
Last clearing of counters |
最后一次使用reset counters interface命令清除接口统计信息的时间。如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never |
Last 300 seconds input/output rate |
接口在最近300秒接收/发送报文的平均速率 |
Input/Output (total) |
接口接收/发送的全部报文的统计值 |
Input/Output (normal) |
接口接收/发送的正常报文的统计值 |
Line protocol state |
接口数据链路层协议状态: · UP · DOWN |
Maximum transmission unit |
接口的最大传输单元 |
Internet protocol processing |
接口未配置IP地址时,接口的网络协议配置参数: · Disabled:不能处理IP报文 · Enabled:可以处理IP报文 |
Internet address: ip-address/mask-length (Type) |
接口IP地址。Type表示地址获取方式,取值如下: · Primary:手动配置的主地址 · Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息 · DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP” · BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP” · PPP-negotiated:PPP协商过程中由Server端分配的IP地址,详细介绍请参见“二层技术-广域网接入配置指导”中的“PPP” · Unnumbered:借用其他接口的IP地址 · MTunnel:组播隧道接口的IP地址(采用的是MD源接口的IP地址),关于MD源接口的详细介绍请参见“组播配置指导”中的“组播VPN” |
Brief information on interfaces in route mode |
三层接口的概要信息 |
Brief information on interfaces in bridge mode |
二层接口的概要信息 |
Link: ADM - administratively down; Stby - standby |
接口的物理连接状态: · ADM:表示该接口已被管理员通过shutdown命令关闭,在该接口下执行undo shutdown命令才能恢复其物理状态 · Stby:表示该接口是一个处于Standby状态的备份接口 |
Speed: (a) - auto |
如果某接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的 如果某接口的Speed属性值为“auto”,则表示该接口的速率是通过自动协商获取的,但协商还未开始 |
Duplex: (a)/A - auto; H - half; F - full |
接口的双工模式: · (a)/A:表示双工模式都是通过自协商确定的 · H:表示双工模式为半双工 · F:表示双工模式为全双工 |
Type: A - access; T - trunk; H - hybrid |
接口的链路类型: · A:表示Access类型 · H:表示Hybrid类型 · T:表示Trunk类型 |
Protocol: (s) - spoofing |
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的 |
接口名称的缩写 |
Link |
接口物理连接状态,取值为: · UP:表示接口物理上是连通的 · DOWN:表示接口物理上是不通的 · ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态 · Stby:表示该接口是一个处于Standby状态的备份接口 |
Speed |
接口的速率(单位为bps) |
Duplex |
接口的双工模式 |
Type |
接口的链路类型 · A:表示Access链路类型 · H:表示Hybrid链路类型 · T:表示Trunk链路类型 |
Protocol |
接口数据链路层协议状态,取值为: · UP:表示接口的数据链路层协议状态为开启 · DOWN:表示接口的数据链路层协议状态为关闭 · UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的 |
Primary IP |
接口的主IP地址 |
Cause |
接口物理连接状态为down的原因 |
display lacp system-id命令用来显示本端系统的设备ID。
使用lacp system-priority命令可以改变系统的LACP优先级,但通过该命令输入的是十进制的优先级数值。而当使用display lacp system-id命令显示时,系统会自动将其转换为十六进制的优先级数值。
# 显示本端系统的设备ID。
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
表1-2 display lacp system-id命令显示信息描述表
Actor System ID: 0x8000, 0000-fc00-6504 |
本端系统的设备ID(由系统的LACP优先级和系统的MAC地址共同构成):系统的LACP优先级为0x8000,系统的MAC地址为0000-FC00-6504 |
· lacp system-priority
display link-aggregation load-sharing mode命令用来显示全局或聚合组内采用的聚合负载分担类型。
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
bridge-aggregation:显示二层聚合接口所对应聚合组内采用的聚合负载分担类型。
route-aggregation:显示三层聚合接口所对应聚合组内采用的聚合负载分担类型。
interface-number:聚合接口的编号。必须是当前已经创建的聚合接口编号。
如果未指定参数interface,则显示全局采用的聚合负载分担类型。
如果仅指定参数interface而未指定具体的聚合接口类型,则显示所有聚合接口所对应聚合组内采用的聚合负载分担类型。
只有在设备上创建了二层聚合接口、三层聚合接口之后,才能指定bridge-aggregation、route-aggregation参数。
# 显示全局采用的聚合负载分担类型(缺省情况)。
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing mode (hardware forwarding):
Layer 2 traffic: destination-mac address source-mac address
Layer 3 traffic: destination-ip address source-ip address
ip-protocol
Layer 4 traffic: destination-port source-port
MPLS traffic : mpls-label1
Link-aggregation load-sharing mode (software forwarding):
Layer 4 traffic: destination-ip address source-ip address
# 显示二层聚合接口1所对应聚合组内采用的聚合负载分担类型(缺省情况)。
ip-protocol
表1-3 display link-aggregation load-sharing mode命令显示信息描述表
Link-aggregation load-sharing algorithm |
全局采用的聚合负载分担HASH算法: · 缺省情况下显示:algorithm-number (default) · 非缺省情况下显示:用户配置后采用的聚合负载分担HASH算法 |
Link-aggregation load-sharing offset |
聚合负载分担计算结果的偏移量: · 缺省情况下显示:offset-value (default) · 非缺省情况下显示:用户配置后采用的聚合负载分担HASH Key偏移量 |
Link-aggregation load-sharing seed |
全局采用的聚合负载分担HASH SEED · 缺省情况下显示:seed-number (default) · 非缺省情况下显示:用户配置后采用的聚合负载HASH SEED |
Tunneled traffic load-sharing mode |
对隧道报文采用的负载分担方式: · 缺省情况下显示:tunnel (default) · 非缺省情况下显示:用户配置后采用的Tunnel报文负载分担方式 |
Link-aggregation load-sharing mode |
全局采用的聚合负载分担类型: · 缺省情况下显示:二层报文、三层报文、四层报文、MPLS报文采用的聚合负载分担类型 · 非缺省情况下显示:用户配置后采用的聚合负载分担类型 |
Bridge-Aggregation1 load-sharing mode |
二层聚合接口1所对应聚合组内采用的聚合负载分担类型: · 缺省情况下显示:全局采用的聚合负载分担类型 · 非缺省情况下显示:用户配置后采用的聚合负载分担类型 |
Route-Aggregation1 load-sharing mode |
三层聚合接口1所对应聚合组内采用的聚合负载分担类型: · 缺省情况下显示:全局采用的聚合负载分担类型 · 非缺省情况下显示:用户配置后采用的聚合负载分担类型 |
Layer 2 traffic: destination-mac address, source-mac address |
二层报文缺省采用的聚合负载分担类型:按照源MAC地址和目的MAC地址进行负载分担 |
Layer 2 traffic: packet type-based sharing |
二层报文缺省采用的聚合负载分担类型:按照产品自定义方式进行负载分担 |
Layer 3 traffic: destination-ip address, source-ip address |
三层报文缺省采用的聚合负载分担类型:按照源IP地址和目的IP地址进行负载分担 |
Layer 3 traffic: packet type-based sharing |
三层报文缺省采用的聚合负载分担类型:按照产品自定义方式进行负载分担 |
Layer 4 traffic: destination-port, source-port |
四层报文缺省采用的聚合负载分担类型:按照源服务端口和目的服务端口进行负载分担 |
MPLS traffic : mpls-label1, mpls-label2, mpls-label3 |
MPLS报文缺省采用的聚合负载分担类型:按照第1~3层的MPLS标签进行负载分担 |
用户配置后采用的聚合负载分担类型:按照源MAC地址和目的MAC地址进行负载分担 |
display link-aggregation member-port命令用来显示成员端口上链路聚合的详细信息。
display link-aggregation member-port [ interface-list | auto ]
interface-list:成员端口列表,表示一个或多个成员端口。表示方式为interface-list = interface-type interface-number1 [ to interface-type interface-number2 ]。其中,interface-type为接口类型,interface-number1和interface-number2为接口编号。interface-number2的值要大于等于interface-number1的值。
auto:显示所有自动聚合成员端口的链路聚合的详细信息。
由于静态聚合组无法获知对端信息,因此静态聚合组只显示本端的端口编号、端口优先级和操作Key的值。
# 显示静态聚合组内成员端口Ten-GigabitEthernet0/0/6上链路聚合的详细信息。
<Sysname> display link-aggregation member-port ten-gigabitethernet 0/0/6
G -- Defaulted, H -- Expired
Ten-GigabitEthernet0/0/6:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# 显示动态聚合组内成员端口Ten-GigabitEthernet0/0/7上链路聚合的详细信息。
<Sysname> display link-aggregation member-port ten-gigabitethernet 0/0/7
Ten-GigabitEthernet0/0/7:
Aggregate Interface: Bridge-Aggregation10
Local:
Port Number: 2
Oper-Key: 2
Flag: {ACDEF}
Remote:
Port Number: 26
Oper-Key: 2
Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
表1-4 display link-aggregation member-port命令显示信息描述表
Flags |
LACP协议的状态标识,长度为1字节,该字节自低位至高位分别以英文字母A~H表示,某一位为1时打印出对应的英文字母,为0时不打印对应的英文字母。各标志位的含义如下: · A:LACP是否开启标志。1表示开启;0表示关闭 · B:LACP长/短超时标志。1表示短超时;0表示长超时 · C:发送端认为本成员端口所在链路是否可聚合。1表示是;0表示否 · D:发送端认为本成员端口所在链路是否处于同步状态。1表示是;0表示否 · E:发送端认为本成员端口所在链路是否处于收集状态。1表示是;0表示否 · F:发送端认为本成员端口所在链路是否处于分发状态。1表示是;0表示否 · G:发送端的接收状态机是否处于默认状态。1表示是;0表示否 · H:发送端的接收状态机是否处于超时状态。1表示是;0表示否 |
Aggregate Interface |
本成员端口所属的聚合接口 |
Preferred Aggregate Interface |
半自动聚合优先选择加入的聚合口 |
Local |
本端信息 |
Port Number |
端口的编号 |
Port Priority |
端口优先级 |
Oper-key |
操作Key的值 |
Flag |
LACP协议的状态标志值 |
Remote |
对端信息 |
System ID |
设备ID(由系统的LACP优先级和系统的MAC地址共同构成) |
Received LACP Packets |
收到的LACP报文总数 |
Illegal |
非法报文的总数 |
Sent LACP Packets |
发出的LACP报文总数 |
display link-aggregation summary命令用来显示所有聚合组的摘要信息。
由于静态聚合组无法获知对端信息,因此静态聚合组的对端信息无显示或显示为None,并不代表对端系统的实际信息。
# 显示所有聚合组的摘要信息。
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregatio
n, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG AGG Partner ID Selected Unselected Individual Share
Interface Mode Ports Ports Ports Type
RAGG10 S None 1 0 0 NonS
BAGG20 D 0x8000,00e0-fcff-ff01 2 0 0 Shar
表1-5 display link-aggregation summary命令显示信息描述表
Aggregate Interface Type |
聚合接口类型: · BAGG:表示二层聚合接口 · RAGG:表示三层聚合接口 · BLAGG:表示引擎聚合接口(暂不支持) · SCH-B:表示S通道聚合接口(暂不支持) |
Aggregation Mode |
聚合组类型: · S:表示静态聚合 · D:表示动态聚合 |
Loadsharing Type |
负载分担类型: · Shar:表示负载分担类型 · NonS:表示非负载分担类型 |
Actor System ID |
本端的设备ID(由系统的LACP优先级和系统的MAC地址共同构成) |
AGG Interface |
聚合接口的类型和编号 |
AGG Mode |
聚合组的类型 |
Partner ID |
对端的设备ID(由系统的LACP优先级和系统的MAC地址共同构成) |
Selected Ports |
处于选中状态的成员端口数量 |
Unselected Ports |
处于非选中状态的成员端口数量 |
Individual Ports |
处于独立状态的成员端口数量 |
Share Type |
负载分担类型 |
display link-aggregation troubleshooting命令用来显示聚合组成员端口的选中状态及原因。
display link-aggregation troubleshooting [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
如果未指定聚合接口的类型,将显示设备支持的所有聚合接口的相关信息。
如果仅指定了聚合接口的类型,将显示所有已创建的该类型聚合接口的相关信息。
只有在设备上创建了二层或三层聚合接口之后,才能指定bridge-aggregation或route-aggregation参数。
# 显示所有聚合组的成员端口的选中状态及原因。
<Sysname> display link-aggregation troubleshooting
Aggregate Interface: Bridge-Aggregation2
Member ports:
XGE0/0/7
Status: Selected
XGE0/0/8
Status: Unselected
Reason: The physical or line protocol state of the port is down
Advice: Check the connection
表1-6 display link-aggregation troubleshooting命令显示信息描述表
Aggregate interface |
聚合接口名称 |
Member ports |
聚合组成员端口信息 |
Status |
端口状态: · Selected:处于选中状态 · Unselected:处于非选中状态 |
Reason |
成员端口未选中原因,具体内容请参见表1-7 |
Advice |
解决建议,具体内容请参见表1-8 |
The number of Selected ports had reached the upper limit |
聚合组内选中端口数量已经到达上限 |
Hardware resources were not enough |
硬件资源耗尽 |
The number of Selected ports was below the lower limit |
聚合组内选中端口数量没有达到最小选中端口数 |
The link aggregation configuration of the port was incorrect |
端口自身配置错误使端口未选中 |
The link aggregation configuration of its peer port was incorrect |
对端端口配置错误导致本端端口未选中 |
The physical or line protocol state of the port was down |
端口物理层或链路层处于DOWN状态 |
The port's hardware restriction prevented it from being Selected |
端口硬件限制 |
The speed configuration of the port was different from that of the reference port |
端口速率与参考端口不一致导致非选中 |
The duplex mode of the port was different from that of the reference port |
端口双工模式与参考端口不一致导致非选中 |
The port and the aggregate interface had different attribute configurations |
属性类配置与聚合接口配置不一致 |
The port was in secondary state in a redundancy group |
端口处于冗余备份状态 |
The BFD session state of the port was down |
端口的BFD会话DOWN |
The member port has low link quality |
成员端口链路质量低 |
It is the secondary member port in the aggregation group in 1+1 backup mode |
接口为1:1主备模式聚合组的备份端口 |
No LACPDU was received by the reference port |
参考端口未收到LACPDU |
The reference port received its own LACPDUs |
参考端口收到自己的LACPDU |
The link of the port was not aggregatable |
端口所在链路不可聚合 |
The link of the peer port was not aggregatable |
对端端口所在链路不可聚合 |
The card that hosts the port was absent |
端口所在单板被拔出 |
The port's operational key was invalid |
无效操作Key |
Link-aggregation traffic redirection was triggered on the local port |
本端触发聚合重定向功能 |
The port had not received LACPDUs |
成员端口未收到LACPDU |
The operational key of the peer port was different from that of the reference port |
对端操作Key与参考端口不一致 |
The system MAC address of the peer port was different from that of the peer port for the reference port |
对端系统MAC地址与参考端口的对端端口不一致 |
The peer port did not have the Synchronization flag |
对端成员端口所在链路未处于同步状态 |
The port was in Standby state |
端口处于standby状态 |
Modify the aggregation group configuration |
修改聚合组配置 |
Release resources |
释放资源 |
Modify port configuration |
修改端口配置 |
Modify peer port configuration |
修改对端端口配置 |
Check the connection |
检查端口之间的链路 |
Use another port |
更换端口 |
Change the port rate to be the same as that of the reference port |
修改端口速率与参考端口一致 |
Change the port duplex mode to be the same as that of the reference port |
修改端口双工模式与参考端口一致 |
Change the port attribute configuration to be the same as that of the aggregate interface |
修改端口属性类配置和聚合组一致 |
Place the port in primary state in the redundancy group |
冗余组节点中使本端端口处于工作状态 |
Check the link that conveys the BFD session |
检查BFD会话所在链路,解决链路故障 |
Check for CRC errors |
检查是否发生误码故障 |
Check whether the peer sends LACPDUs correctly |
检查对端是否发送LACPDU |
Check whether the device has a loop |
检查设备是否存在环路 |
Make sure the card that hosts the port is installed |
检查接口所在板已插入 |
Check whether the port sends LACPDUs correctly |
检查本端是否发送LACPDU |
Change the peer system MAC address to be the same as that of the reference port |
修改对端系统MAC地址与参考端口一致 |
Check the LACPDUs sent by the peer |
检查对端发送的LACPDU |
Please check the aggregation state of member ports in a few minutes |
等待一段时间再查看成员端口的选中状态 |
Make sure the peer aggregation member ports for a M-LAG group reside on the same device and belong to the same aggregation group |
使对端成员口同一设备同一聚合组中 |
Check the configuration |
检测聚合相关配置 |
N/A |
无需处理 |
display link-aggregation verbose命令用来显示已有聚合接口所对应聚合组的详细信息。
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ all-configuration ]
bridge-aggregation:显示二层聚合接口所对应聚合组的详细信息。
route-aggregation:显示三层聚合接口所对应聚合组的详细信息。
all-configuration:显示聚合组中所有的成员端口。未指定本参数,则显示聚合组中在位单板上的成员端口。
实际未加入任何聚合组的自动聚合端口不会被显示。
# 二层聚合接口10所对应的聚合组是动态聚合组,显示该聚合组的详细信息。
<Sysname> display link-aggregation verbose bridge-aggregation 10
Port: A -- Auto port, M -- Management port, R -- Reference port
Role: P -- Primary, S -- Secondary
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
Local:
Port Status Priority Index Oper-Key Flag
XGE0/0/6 S 32768 61 2 {ACDEF}
XGE0/0/7 S 32768 62 2 {ACDEF}
XGE0/0/8 S 32768 63 2 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
XGE0/0/6(R) S 32768 1 1 {ACDEF}
XGE0/0/7 32768 112 2 0x8000, 000f-e267-57ad {ACDEF}
XGE0/0/8 32768 113 2 0x8000, 000f-e267-57ad {ACDEF}
# 二层聚合接口20所对应的聚合组是静态聚合组,显示该聚合组的详细信息。
<Sysname> display link-aggregation verbose bridge-aggregation 20
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
Port Status Priority Oper-Key Role
XGE0/0/7 S 32768 1 None
XGE0/0/8 S 32768 1 None
表1-9 display link-aggregation verbose命令显示信息描述表
Loadsharing Type |
Port Status |
端口状态: · Selected:表示处于选中状态 · Unselected:表示处于非选中状态 · Individual:表示处于独立状态 |
Port |
端口类型: · Auto port:表示为该端口为自动端口 · Management port:表示该端口为管理端口 · Reference port:表示该端口为参考端口 |
Flags |
LACP协议的状态标志,长度为1字节,该字节自低位至高位分别以字母A~H表示,取值为1的标志位显示为对应的字母,取值为0的标志为不显示。各标志位的含义如下: · A:LACP是否开启标志。1表示开启;0表示关闭 · B:LACP长/短超时标志。1表示短超时;0表示长超时 · C:发送端认为本成员端口所在链路是否可聚合。1表示是;0表示否 · D:发送端认为本成员端口所在链路是否处于同步状态。1表示是;0表示否 · E:发送端认为本成员端口所在链路是否处于收集状态。1表示是;0表示否 · F:发送端认为本成员端口所在链路是否处于分发状态。1表示是;0表示否 · G:发送端的接收状态机是否处于默认状态。1表示是;0表示否 · H:发送端的接收状态机是否处于超时状态。1表示是;0表示否 |
Role |
1:1主备模式聚合组的成员接口角色: · Primary:主接口 · Secondary:备份接口 未配置聚合组工作在1:1主备模式时显示为None |
聚合接口的名称 |
Creation Mode |
动态聚合组的创建方式: · Auto:表示自动创建 · Manual:表示手工创建 |
Aggregation Mode |
聚合组的工作模式: · Static:表示静态聚合 · Dynamic:表示动态聚合 |
Management VLANs |
管理VLAN,未指定时显示None |
System ID |
Local |
本端信息: · Port:端口的类型和编号 · Status:端口的选中/非选中/独立状态 · Priority:端口优先级 · Index:端口索引 · Oper-Key:操作Key的值 · Flag:LACP协议的状态标志值 静态聚合组只显示本端信息,显示信息中不包括Index和Flag字段 |
Remote |
对端信息: · Actor:本端的端口类型和编号,当对端端口是参考端口时,参考端口会显示在对应的本端端口上 · Priority:对端端口的端口优先级 · Index:对端端口的端口索引 · Oper-Key:对端端口的操作Key的值 · System ID:对端的设备ID · Flag:对端的LACP协议的状态标志值 |
interface bridge-aggregation命令用来创建二层聚合接口,并进入二层聚合接口视图。如果指定的二层聚合接口已经存在,则直接进入该二层聚合接口视图。
undo interface bridge-aggregation命令用来删除二层聚合接口。
undo interface bridge-aggregation interface-number
不存在二层聚合接口。
interface-number:指定二层聚合接口的编号,取值范围为1~8。
创建二层聚合接口后,系统将自动生成同编号的二层聚合组,且该聚合组缺省工作在静态聚合模式下。
删除二层聚合接口的同时会删除其对应的二层聚合组,如果该聚合组内有成员端口,那么这些成员端口将自动从该聚合组中退出。
# 创建二层聚合接口1,并进入二层聚合接口1的视图。
[Sysname-Bridge-Aggregation1]
interface route-aggregation命令用来创建三层聚合接口/子接口,并进入三层聚合接口/子接口视图。如果指定的三层聚合接口/子接口已经存在,则直接进入该三层聚合接口/子接口视图。
undo interface route-aggregation命令用来删除三层聚合接口。
undo interface route-aggregation { interface-number | interface-number.subnumber }
不存在三层聚合接口/子接口。
interface-number:指定三层聚合接口的编号,取值范围为1~512。
interface-number.subnumber:指定三层聚合子接口。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
创建三层聚合接口后,系统将自动生成同编号的三层聚合组,且该聚合组缺省工作在静态聚合模式下。
删除三层聚合接口的同时会删除其对应的三层聚合组以及该接口下的所有聚合子接口,如果该聚合组内有成员端口,那么这些成员端口将自动从该聚合组中退出。
如果删除三层聚合子接口,则不会影响其主接口以及主接口对应的聚合组状态。
# 创建三层聚合接口1,并进入三层聚合接口1的视图。
jumboframe enable命令用来允许超长帧通过。
undo jumboframe enable命令用来禁止超长帧通过。
undo jumboframe enable size命令用来恢复缺省情况。
jumboframe enable [ size ]
设备允许指定长度为9664的超长帧通过。
二层聚合接口视图
三层聚合接口视图
多次执行本命令,最后一次执行的命令生效。
# 允许超长帧通过二层聚合接口1。
<Sysname> System-view
[Sysname-Bridge-Aggregation1] jumboframe enable
lacp default-selected-port disable命令用来关闭聚合成员端口缺省选中功能。
undo lacp default-selected-port disable命令用来开启聚合成员端口缺省选中功能。
聚合成员端口缺省选中功能处于开启状态。
聚合成员端口缺省选中功能是指动态聚合组的成员端口处于up状态时,成员端口在经过LACP超时时间之后未收到LACPDU,则会在所有处于up状态的成员端口中选择一个作为选中端口。聚合组选择选中端口时比较各成员端口的端口ID,端口ID最小的作为选中端口。
关闭聚合成员端口缺省选中功能后,动态聚合组中处于up状态的成员端口未收到LACPDU时,处于非选中状态。
# 关闭聚合成员端口缺省选中功能。
[Sysname] lacp default-selected-port disable
lacp edge-port命令用来配置聚合接口为聚合边缘接口。
undo lacp edge-port命令用来恢复缺省情况。
lacp edge-port
undo lacp edge-port
聚合接口不是聚合边缘接口。
二层聚合接口视图
三层聚合接口视图
该命令主要用于在网络设备与服务器等终端设备相连的场景中。当网络设备配置了动态聚合模式,而终端设备未配置动态聚合模式时,网络设备的聚合成员端口都可以作为普通物理口转发报文,从而保证终端设备与网络设备间的多条链路可以相互备份,增加可靠性。
该配置仅在聚合接口对应的聚合组为动态聚合组时生效。
当聚合接口配置为聚合边缘接口后,聚合流量重定向功能将不能正常使用。
# 配置二层聚合接口1为聚合边缘接口。
[Sysname-Bridge-Aggregation1] lacp edge-port
lacp mode passive命令用来配置端口的LACP工作模式为PASSIVE。
undo lacp mode命令用来恢复缺省情况。
lacp mode passive
undo lacp mode
端口的LACP工作模式为ACTIVE。
二层以太网接口视图
三层以太网接口视图
执行本命令后,只有在当前端口为动态聚合组成员端口时,配置才生效。
如果动态聚合组内成员端口的LACP工作模式为PASSIVE,且对端的LACP工作模式也为PASSIVE时,两端将不能发送LACPDU。如果两端中任何一端的LACP工作模式为ACTIVE时,两端将可以发送LACPDU。
# 配置端口Ten-GigabitEthernet0/0/6的LACP工作模式为PASSIVE。
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] lacp mode passive
lacp period short命令用来配置端口的LACP超时时间为短超时(3秒)。
undo lacp period命令用来恢复缺省情况。
lacp period short
undo lacp period
端口的LACP超时时间为长超时(90秒)。
二层以太网接口视图
三层以太网接口视图
# 配置端口Ten-GigabitEthernet0/0/6的LACP超时时间为短超时(3秒)。
[Sysname-Ten-GigabitEthernet0/0/6] lacp period short
lacp select speed命令用来配置动态聚合组内端口速率作为优先选择参考端口的条件。
undo lacp select speed命令用来恢复缺省情况。
lacp select speed
动态聚合组内以成员口的端口的端口ID作为优先选择参考端口的条件。
二层聚合接口视图
三层聚合接口视图
缺省情况下,聚合组可能会将速率小的端口选择为参考端口。通过配置本命令,用户可以选择速率高的端口作为参考端口。
配置该命令前,需要在聚合接口视图下先执行link-aggregation mode dynamic命令配置该聚合接口为动态聚合接口,该命令才生效。静态聚合组可以配置该命令,但不生效。
本命令会改变动态聚合口的参考端口的选择条件,可能会导致短暂的业务中断。建议在业务正常传输情况下,不要随便更改参考端口的选择条件,需要修改参考端口的选择条件时,可以先关闭聚合接口,待两端配置一致后再开启该聚合接口。
# 配置端口速率作为优先选择参考端口的条件。
[Sysname-Bridge-Aggregation1] lacp select speed
lacp system-mac命令用来配置LACP的系统MAC地址。
undo lacp system命令用来恢复缺省情况。
lacp system-mac mac-address
undo lacp system-mac
LACP的系统MAC地址为设备的桥MAC地址。
mac-address:LACP的系统MAC地址,格式为H-H-H,不支持组播MAC地址、全0的MAC地址和全F的MAC地址。
本命令配置的MAC地址会影响到LACP报文的MAC地址字段,LACP报文MAC地址字段可以通过display link-aggregation verbose命令查看。
LACP的系统MAC地址支持全局配置或在聚合组内配置两种方式:全局的配置对所有聚合组都有效,而聚合组内的配置只对当前聚合组有效。对于一个聚合组来说,优先采用该聚合组内的配置,只有该聚合组内未进行配置时,才采用全局的配置。
在开启S-MLAG功能的设备上,LACP的系统MAC地址需要配置一致。
# 配置LACP的系统MAC地址为0001-0001-0001。
[Sysname] lacp system-mac 1-1-1
· display link-aggregation verbose
lacp system-number命令用来配置LACP的系统编号。
undo lacp system-number命令用来恢复缺省情况。
lacp system-number number
未配置LACP的系统编号。
number:LACP的系统编号,取值范围为1~3。
如果聚合接口没有开启S-MLAG功能,本命令配置的系统编号不会影响到LACP报文的Index字段。LACP报文的Index字段可以通过display link-aggregation verbose命令查看。
在开启S-MLAG功能的设备上,不同设备上配置的LACP系统编号不能相同。
# 配置LACP的系统编号为1。
[Sysname] lacp system-number 1
lacp system-priority命令用来配置LACP的系统优先级。
undo lacp system-priority命令用来恢复缺省情况。
lacp system-priority priority
LACP的系统优先级为32768。
priority:LACP的系统优先级,取值范围为0~65535。该数值越小,优先级越高。
本命令配置的系统优先级会影响到LACP报文的系统优先级字段,LACP报文系统优先级字段可以通过display link-aggregation verbose命令查看。
LACP的系统优先级支持全局配置或在聚合组内配置两种方式:全局的配置对所有聚合组都有效,而聚合组内的配置只对当前聚合组有效。对于一个聚合组来说,优先采用该聚合组内的配置,只有该聚合组内未进行配置时,才采用全局的配置。
# 配置LACP的系统优先级为64。
[Sysname] lacp system-priority 64
· link-aggregation port-priority
link-aggregation bfd命令用来开启链路聚合的BFD功能。
undo link-aggregation命令用来关闭链路聚合的BFD功能。
link-aggregation bfd ipv4 source ipv4-address destination ipv4-address
undo link-aggregation bfd [ ipv4 ]
链路聚合的BFD功能处于关闭状态。
二层聚合接口视图
三层聚合接口视图
ipv4:IPv4 BFD会话。
source:BFD会话的源IP地址。
destination:BFD会话的目的IP地址。
ipv4-address:BFD会话的IPv4地址,不能为0.0.0.0。
聚合口两端的BFD会话源IP地址和目的IP地址必须成对配置,且源地址和目的地址为不同的单播地址。例如本端聚合接口配置link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2时,对端聚合接口要配置link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1后,才能正确建立起BFD会话。
在聚合接口下配置的BFD会话参数,会对该聚合组内所有选中链路的BFD会话生效,链路聚合的BFD会话仅支持控制报文方式和异步模式。关于BFD的介绍和基本功能配置,请参见“可靠性配置指导”中的“BFD”。
开启链路聚合的BFD功能后,不建议在该聚合接口上再开启其他应用与BFD联动。
开启链路聚合的BFD功能后,请配置聚合组中的成员端口数量不大于设备支持的BFD会话数量,否则可能导致聚合组内部分选中端口变为非选中状态。
当聚合链路两端最大选中端口数量不一致时,如果在链路两端都开启链路聚合的BFD功能,则可能会导致两端BFD会话数量不一致,但并不影响报文转发。
# 开启二层聚合接口1下的链路聚合的BFD功能,并配置BFD会话的源地址为1.1.1.1,目的地址为2.2.2.2。
[Sysname-Bridge-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
link-aggregation bfd-compatible enable命令用来开启链路聚合与BFD联动的兼容功能。
undo link-aggregation bfd-compatible enable命令用来关闭链路聚合与BFD联动的兼容功能。
链路聚合与BFD联动的兼容功能处于关闭状态。
二层聚合接口视图
三层聚合接口视图
在与其他厂商设备互通的场景中,由于链路聚合与BFD联动功能实现方式不同,导致无法通过BFD快速检测链路故障。通过配置本命令,可以兼容其他厂商设备的链路聚合与BFD联动功能,使聚合链路两端可以通过BFD快速定位链路问题。
开启本功能后,聚合组所有成员端口都与对端建立BFD会话,且成员端口选中状态变化时,不会再拆除和重建BFD会话。
# 开启二层聚合接口1的链路聚合与BFD联动的兼容功能。
[Sysname-Bridge-Aggregation1] link-aggregation bfd-compatible enable
# 开启三层聚合接口1的链路聚合与BFD联动的兼容功能。
[Sysname-Route-Aggregation1] link-aggregation bfd-compatible enable
· link-aggregation bfd
link-aggregation global load-sharing mode命令用来配置全局采用的聚合负载分担类型。
undo link-aggregation global load-sharing mode命令用来恢复缺省情况。
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | mpls-label1 | source-ip | source-mac | source-port } *
设备基于源IP地址和目的IP地址进行聚合负载分担。
destination-ip:表示按报文的目的IP地址进行聚合负载分担。
destination-mac:表示按报文的目的MAC地址进行聚合负载分担。
destination-port:表示按报文的目的服务端口进行聚合负载分担。
mpls-label1:表示按MPLS报文第一层标签进行聚合负载分担。
source-ip:表示按报文的源IP地址进行聚合负载分担。
source-mac:表示按报文的源MAC地址进行聚合负载分担。
source-port:表示按报文的源服务端口进行聚合负载分担。
对于设备不支持的聚合负载分担类型,系统将提示用户不支持。
# 配置全局按照报文目的IP地址进行聚合负载分担。
[Sysname] link-aggregation global load-sharing mode destination-ip
· link-aggregation load-sharing mode
link-aggregation ignore speed命令用来配置聚合组选择选中端口时忽略端口速率。
undo link-aggregation ignore speed命令用来恢复缺省情况。
聚合组选择选中端口时计算端口速率。
二层聚合接口视图
三层聚合接口视图
通过配置本命令,同一聚合组中的选中端口的端口速率可以不同。
如果聚合组两端本命令配置不一致,动态聚合组可以通过LACP协议协商状态,使链路两端端口状态一致;静态聚合组无法协商状态,为了防止报文丢失,所以要求静态聚合组两端本命令配置一致。
配置本命令后,如果聚合组中选中端口速率不同,聚合组中流量负载分担时,速率较小的选中端口可能存在丢包现象,请按需配置本功能。
开启和关闭本功能后,操作Key会发生变化,导致聚合接口震荡,请按需配置本功能。
# 配置二层聚合组1选择选中端口时忽略端口速率。
[Sysname-Bridge-Aggregation1] link-aggregation ignore speed
link-aggregation lacp traffic-redirect-notification enable命令用来开启聚合流量重定向功能。
undo link-aggregation lacp traffic-redirect-notification enable命令用来关闭聚合流量重定向功能。
聚合流量重定向功能处于关闭状态。
二层聚合接口视图
三层聚合接口视图
在开启了聚合流量重定向功能后,当手工关闭聚合组内某选中端口或重启聚合组内某选中端口所在的slot时,系统可以将该端口上的流量重定向到其他选中端口上,从而实现聚合链路上流量的不中断。聚合流量重定向过程中,对于聚合组中新选中的端口,流量不会重定向到该端口上。其中,已知单播报文可以实现零丢包,非已知单播报文不保证不丢包。
只有动态聚合组支持聚合流量重定向功能。
必须在聚合链路两端都开启聚合流量重定向功能才能实现聚合链路上流量的不中断。
如果同时开启聚合流量重定向功能和生成树功能,在重启slot时会出现少量的丢包,因此不建议同时开启上述两个功能。
建议优先选择开启聚合接口的聚合流量重定向功能。开启全局的聚合流量重定向功能时,如果有连接其它厂商设备的聚合接口,可能影响该聚合组的正常通信。
# 开启聚合流量重定向功能。
[Sysname] link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode命令用来配置聚合组内采用的聚合负载分担类型。
undo link-aggregation load-sharing mode命令用来恢复缺省情况。
link-aggregation load-sharing mode { { destination-ip | destination-port | source-ip | source-port } * | bandwidth-usage | per-packet }
聚合组内采用的聚合负载分担类型与全局采用的聚合负载分担类型一致。
三层聚合接口视图
bandwidth-usage:表示按接口的带宽利用率进行聚合负载分担。
per-packet:表示对每个报文逐包进行聚合负载分担。
# 配置三层聚合接口1对应的聚合组内按照报文目的IP地址进行聚合负载分担。
[Sysname] interface route-Aggregation 1
[Sysname-Route-Aggregation1] link-aggregation load-sharing mode destination-ip
· link-aggregation global load-sharing mode
link-aggregation load-sharing mpls enhanced命令用来在聚合组内开启MPLS报文增强聚合负载分担功能。
undo link-aggregation load-sharing mpls enhanced命令用来在聚合组内关闭MPLS报文增强聚合负载分担功能。
MPLS报文增强聚合负载分担功能处于关闭状态。
三层聚合接口视图
开启MPLS报文增强聚合负载分担功能后,聚合组能够对MPLS报文基于IPv4五元组(源IPv4地址、源端口号、协议号、目的IPv4地址、目的端口号)来区分数据流。
本功能仅在P(Provider,服务提供商网络)设备上支持。有关P设备的介绍,请参见“MPLS配置指导”中的“MPLS L3VPN”。
# 在三层聚合接口1对应的聚合组内开启MPLS报文增强聚合负载分担功能。
[Sysname-Route-Aggregation1] link-aggregation load-sharing mpls enhanced
link-aggregation mode命令用来配置聚合组的工作模式。
undo link-aggregation mode命令用来恢复缺省情况。
link-aggregation mode { dynamic | static [ backup ] }
聚合组工作在静态聚合模式下。
二层聚合接口视图
三层聚合接口视图
dynamic:配置聚合组工作在动态聚合模式,同时开启LACP协议。
static:配置聚合组工作在静态聚合模式。
backup:配置静态聚合组工作在1:1主备模式。如果未指定本参数,则聚合组工作在非1:1主备模式。仅三层聚合接口可以指定本参数。
当聚合组中存在成员端口时,如果修改聚合组的工作模式,则可能导致聚合组中选中端口变为非选中状态,影响流量转发,请用户根据实际情况修改聚合组的工作模式。
配置聚合组工作在1:1主备模式时,聚合组的成员端口不能大于两个,且最大最小选中端口个数配置将失效。
# 配置二层聚合接口1对应的聚合组工作在动态聚合模式下。
link-aggregation port-priority命令用来配置端口优先级。
undo link-aggregation port-priority命令用来恢复缺省情况。
端口优先级为32768。
二层以太网接口视图
三层以太网接口视图
priority:端口优先级,取值范围为0~65535。该数值越小,优先级越高。
# 配置二层以太网接口Ten-GigabitEthernet0/0/6的端口优先级为64。
[Sysname-Ten-GigabitEthernet0/0/6] link-aggregation port-priority 64
# 配置三层以太网接口Ten-GigabitEthernet0/0/7的端口优先级为64。
[Sysname] interface ten-gigabitethernet 0/0/7
[Sysname-Ten-GigabitEthernet0/0/7] link-aggregation port-priority 64
link-aggregation primary-port命令用来配置成员接口为工作在1:1主备模式的聚合组的主接口。
undo link-aggregation primary-port命令用来恢复缺省情况。
成员接口非工作在1:1主备模式的聚合组的主接口。
三层以太网接口视图
配置聚合组工作在1:1主备模式后,仅主接口处于选中状态,可以转发流量,而备份接口处于非选中状态,不能转发流量。为保证业务可靠通信,建议通过本命令指定主接口。指定主接口后,主接口将具有回切功能,即主接口故障恢复后,可以立即切换为选中状态并转发流量。
当未通过本命令指定主接口时:
· 如果成员接口同时加入聚合组,则聚合组内的参考端口作为主接口转发流量。
· 如果成员接口依次加入聚合组,则聚合组内先选中的端口作为主接口转发流量。
当接口未加入聚合组或者聚合组未工作在1:1主备模式时,不能在接口下配置本命令。
聚合组工作在1:1主备模式下时,该聚合组只能有一个主接口。
# 将三层以太网接口Ten-GigabitEthernet0/0/6配置为工作在1:1主备模式的聚合组的主接口。
[Sysname-Ten-GigabitEthernet0/0/6] port link-aggregation group 1
[Sysname-Ten-GigabitEthernet0/0/6] link-aggregation primary-port
link-aggregation reversion delay命令用来配置工作于1:1主备模式聚合组的主接口延时回切功能,并配置延时回切时间。
undo link-aggregation reversion delay命令用来恢复缺省情况。
link-aggregation reversion delay time-value
工作于1:1主备模式聚合组的主接口延时回切功能处于关闭状态,即主接口故障恢复时可以立即转发流量。
三层聚合接口视图
time-value:延时回切的时间,单位为秒,取值范围为1~65535。
工作于1:1主备模式聚合组的主接口由于故障而处于备用状态,当主接口故障恢复时需要回切到转发状态。缺省情况下,主接口故障恢复后可以立即切换为选中状态并转发流量。为了避免链路震荡引起主接口频繁切换,可以通过本命令配置主接口延时回切时间。
配置聚合组工作在1:1主备模式且使用link-aggregation primary-port命令指定主接口后,本命令才能生效。
# 开启工作于:1主备模式三层聚合组1的主接口延时回切功能,并配置延时回切时间为5秒。
[Sysname-Route-Aggregation1] link-aggregation reversion delay 5
· link-aggregation mode
· link-aggregation primary-port
link-aggregation secondary-down命令用来配置工作于1:1主备模式聚合组的备份接口处于DOWN状态。
undo link-aggregation secondary-down命令用来恢复缺省情况。
工作于1:1主备模式聚合组的备份接口处于非选中状态。
三层聚合接口视图
配置聚合组工作在1:1主备模式后,如果对端设备无法感知本端的主备接口时,流量可能发送到本端备份接口,由于本端备份接口处于非选中状态,流量无法转发,导致丢包。为避免这种情况,可以配置本命令,仅使两端设备转发流量的接口保持UP状态,避免丢包。
配置聚合组工作在1:1主备模式后,本命令才能生效。
# 配置1:1主备模式的三层聚合组1的备份接口处于DOWN状态。
[Sysname-Route-Aggregation1] link-aggregation secondary-down
link-aggregation selected-port maximum命令用来配置聚合组中的最大选中端口数。
undo link-aggregation selected-port maximum命令用来恢复缺省情况。
link-aggregation selected-port maximum max-number [ lacp-sync ]
聚合组中的最大选中端口数仅受设备硬件能力的限制。
二层聚合接口视图
三层聚合接口视图
max-number:聚合组中的最大选中端口数,取值范围为1~8。
lacp-sync:配置动态聚合组使用LACPDU同步最大选中端口数,使两端聚合组最大选中端口数一致。未指定本参数时,不同步最大选中端口数。
执行本命令可能导致聚合组内部分成员端口变为非选中状态。
对于静态聚合组,本端和对端配置的聚合组中的最大选中端口数必须一致。对于动态聚合组,不指定lacp-sync参数时,本端和对端配置的聚合组中的最大选中端口数必须一致;指定lacp-sync参数时,本端和对端聚合组中的最大选中端口数以配置值最小的一端为准。
同一聚合组内,最大选中端口数配置值不能小于最小选中端口数配置值。
当配置了聚合组中的最大选中端口数之后,最大选中端口数将同时受配置值和设备硬件能力的限制,即取二者的较小值作为限制值。
用户借此可实现两端口间的冗余备份:在一个聚合组中只添加两个成员端口,并配置该聚合组中的最大选中端口数为1,这样这两个成员端口在同一时刻就只能有一个成为选中端口,而另一个将作为备份端口。
# 配置二层聚合接口1对应的聚合组中的最大选中端口数为5。
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
· link-aggregation selected-port minimum
link-aggregation selected-port minimum命令用来配置聚合组中的最小选中端口数。
undo link-aggregation selected-port minimum命令用来恢复缺省情况。
聚合组中的最小选中端口数不受限制。
二层聚合接口视图
三层聚合接口视图
min-number:聚合组中的最小选中端口数,取值范围为1~8。
执行本命令可能导致聚合组内所有成员端口都变为非选中状态。
本端和对端配置的聚合组中的最小选中端口数必须一致。
同一聚合组内,最小选中端口数配置值不能大于最大选中端口数配置值。
# 配置二层聚合接口1对应的聚合组中的最小选中端口数为3。
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
· link-aggregation selected-port maximum
link-aggregation selected-port minimum percentage命令用来配置聚合组中最小选中端口数的百分比。
undo link-aggregation selected-port minimum percentage命令用来恢复缺省情况。
link-aggregation selected-port minimum percentage number
未配置聚合组中最小选中端口数的百分比。
二层聚合接口视图
三层聚合接口视图
number:聚合组中最小选中端口数占所有成员端口的百分比,取值范围为1~100。
缺省情况下,聚合组中最小选中端口数不受限制。聚合组两端需要配置相同的百分比。
聚合组中的最小选中端口数为配置本命令后计算的值(该聚合组所有成员端口×最小选中端口数的百分比)及link-aggregation selected-port minimum命令配置值中的较大值。
用户配置聚合组中最小选中端口数的百分比后,当有端口加入或者退出该聚合组时,可能会引起最小选中端口数的改变,导致聚合接口震荡。
# 配置二层聚合接口1的最小选中端口数的百分比为50。
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum percentage 50
# 配置三层聚合接口1的最小选中端口数的百分比为50。
[Sysname-Route-Aggregation1] link-aggregation selected-port minimum percentage 50
link-aggregation switchover命令用来切换工作于1:1主备模式聚合组的主备接口。
三层聚合接口视图
当工作于1:1主备模式聚合组未配置主接口时,用户可以根据1:1主备模式聚合组对端设备转发流量的接口,随时切换主备接口。
配置本命令后,如果备份接口因为link-aggregation secondary-down命令而处于DOWN状态,则设备会将备份接口置为UP状态,使备份接口可以切换为主接口转发流量。
聚合组切换主备接口时,可能导致丢包,请谨慎配置本命令。
执行本命令前需要满足以下条件,否则无法切换:
· 工作于1:1主备模式聚合组未配置主接口。
· 工作于1:1主备模式聚合组中存在一个选中端口和一个非选中端口。
· 备份接口可以变为选中状态。
# 切换工作于1:1主备模式聚合组1的主备接口。
[Sysname-Route-Aggregation1] link-aggregation switchover
This operation will change the current link status. Continue? [Y/N]:
mtu命令用来配置三层聚合接口/子接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
三层聚合接口/子接口的MTU值为1500字节。
三层聚合接口视图
三层聚合子接口视图
# 配置三层聚合接口1的MTU值为1430字节。
[Sysname-Route-Aggregation1] mtu 1430
· display interface
port lacp system-mac命令用来配置LACP的系统MAC地址。
undo port lacp system命令用来恢复缺省情况。
port lacp system-mac mac-address
undo port lacp system-mac
二层聚合接口视图
三层聚合接口视图
mac-address:LACP的系统MAC地址,格式为H-H-H,不支持组播与广播MAC地址、全0的MAC
# 配置聚合组1的LACP系统MAC地址为0002-0002-0002。
[Sysname-Bridge-Aggregation1] port lacp system-mac 2-2-2
· lacp system-mac
port lacp system-priority命令用来配置LACP的系统优先级。
undo port lacp system-priority命令用来恢复缺省情况。
port lacp system-priority priority
LACP的系统优先级为32768。
二层聚合接口视图
三层聚合接口视图
LACP的系统优先级支持全局配置或在聚合组内配置两种方式:全局的配置对所有聚合组都有效,而聚合组内的配置只对当前聚合组有效。对于一个聚合组来说,优先采用该聚合组内的配置,只有该聚合组内未进行配置或配置为缺省值时,才采用全局的配置。
在开启S-MLAG功能的设备上,LACP的系统优先级需要配置一致。
# 配置聚合组1的LACP系统优先级为32。
[Sysname-Bridge-Aggregation1] port lacp system-priority 32
port link-aggregation group命令用来将接口加入指定的聚合组。
undo port link-aggregation group命令用来将接口从已加入的聚合组中删除。
port link-aggregation group { group-id [ force ] | auto [ group-id ] }
以太网接口未加入任何聚合组。
二层以太网接口视图
三层以太网接口视图
三层以太网子接口视图
group-id:指定聚合组所对应聚合接口的编号,取值范围为1~512。
force:表示接口加入聚合组时同步该聚合组的属性类配置。不指定该参数时,表示接口加入聚合组时不同步该聚合组的属性类配置。仅二层以太网接口支持指定本参数。
auto:开启端口的半自动聚合功能。
二层以太网接口只能加入二层聚合组,三层以太网接口/子接口只能加入三层聚合组。
一个接口只能加入一个聚合组。
接口加入聚合组前,如果接口上的属性类配置和聚合接口不同,则该接口不能加入聚合组。
接口加入聚合组后,不能修改接口的属性类配置。
指定force参数后,通过display current-configuration命令显示设备生效的配置中和配置文件中不会保存force参数。
缺省情况下,以太网接口不能和以太网子接口加入同一个聚合组。加入聚合组的以太网接口不能再创建子接口;已创建子接口的以太网接口不能加入聚合组。
成员端口为以太网子接口的聚合组对应的聚合接口不能再创建聚合子接口;以太网子接口不能加入已创建聚合子接口的聚合组。
仅指定auto参数时,表示根据对端发来的LACP报文决定加入哪个动态聚合组;如果未找到能够加入的聚合组,则创建一个符合条件的动态聚合组,并加入该聚合组中。
指定auto和group-id时,表示优先查看该聚合组参考端口所含的对端信息和收到的LACP报文中的对端信息是否一致:
· 如果相同则加入该聚合组。
· 如果不同,则再选择其他动态聚合组;如果未找到能够加入的动态聚合组,则创建一个符合条件的动态聚合组,并加入该聚合组中。
group-id必须是已经存在的动态聚合组。
当配置半自动聚合后,建议用户不要修改自动创建的聚合组及其成员端口的配置,避免影响半自动聚合功能。
仅二层以太网接口和三层以太网接口支持指定auto参数。指定auto参数后,二层以太网接口和三层以太网接口只能加入动态聚合组。
# 将二层以太网接口Ten-GigabitEthernet0/0/6加入二层聚合组1中。
# 将三层以太网接口Ten-GigabitEthernet0/0/7加入三层聚合组2中。
[Sysname-Ten-GigabitEthernet0/0/7] port link-aggregation group 2
port s-mlag group命令用来配置聚合接口加入S-MLAG组。
undo port s-mlag group命令用来恢复缺省情况。
port s-mlag group group-id
聚合接口未加入S-MLAG组。
二层聚合接口视图
group-id:指定S-MLAG组编号,取值范围为1~1024。
仅工作在动态聚合模式下的二层聚合接口可以加入S-MLAG组。
同一设备上不同聚合接口不能加入同一S-MLAG组。
# 配置二层聚合接口1加入S-MLAG组1。
[Sysname-Bridge-Aggregation1] port s-mlag group 1
reset lacp statistics命令用来清除成员端口上的LACP统计信息。
interface interface-list:表示清除指定成员端口上的LACP统计信息。interface-list为成员端口列表,表示一个或多个成员端口。表示方式为interface-list = interface-type interface-number1 [ to interface-type interface-number2 ]。其中,interface-type为接口类型,interface-number1和interface-number2为接口编号。interface-number2的值要大于等于interface-number1的值。若未指定本参数,则清除所有成员端口上的LACP统计信息。
# 清除所有成员端口上的LACP统计信息。
<Sysname> reset lacp statistics
· display link-aggregation member-port
sub-interface rate-statistic命令用来开启三层聚合子接口的速率统计功能。
undo sub-interface rate-statistic命令用来关闭三层聚合子接口的速率统计功能。
三层聚合子接口的速率统计功能处于关闭状态。
三层聚合接口视图
开启本功能后可能需要耗费大量系统资源,请谨慎使用。
开启本功能后,需要等待两个统计周期,才能显示三层聚合子接口的速率统计信息。统计周期可以通过flow-interval命令进行设置。
# 开启三层聚合接口1的子接口速率统计功能。
[Sysname-Route-Aggregation1] sub-interface rate-statistic
This configuration may make a negative effect on the performance. Are you sure to continue? [Y/N]:y
The configuration will take effect after 2 flow intervals.
· flow-interval(接口管理命令参考/以太网接口)
