03-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9X71)-6W70203-Security Command Reference
22-ND attack defense commands
22-ND attack defense commands 146.10 KB
Non-default vSystems do not support some of the ND attack defense commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
Source MAC-based ND attack detection commands
display ipv6 nd source-mac
Use display ipv6 nd source-mac to display source MAC-based ND attack detection entries.
In standalone mode:
display ipv6 nd source-mac interface interface-type interface-number [ slot slot-number [ cpu cpu-number ] ] [ verbose ]
display ipv6 nd source-mac { mac mac-address | vlan vlan-id } slot slot-number [ cpu cpu-number ] [ verbose ]
display ipv6 nd source-mac slot slot-number [ cpu cpu-number ] [ count | verbose ]
In IRF mode:
display ipv6 nd source-mac interface interface-type interface-number [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ verbose ]
display ipv6 nd source-mac { mac mac-address | vlan vlan-id } chassis chassis-number slot slot-number [ cpu cpu-number ] [ verbose ]
display ipv6 nd source-mac chassis chassis-number slot slot-number [ cpu cpu-number ] [ count | verbose ]
context-admin
mac mac-address: Displays the ND attack detection entry for the specified MAC address. The MAC address format is H-H-H.
vlan vlan-id: Displays the source MAC-based ND attack detection entries for the specified VLAN. The VLAN ID is in the range of 1 to 4094.
slot slot-number: Displays the ND attack entries detected by the physical interfaces that reside on the specified card and belong to the specified virtual interface. If you do not specify a card, this command displays entries detected by the physical interfaces that reside on the active MPUs and belong to the specified virtual interface. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the ND attack entries detected by the physical interfaces that reside on the specified slot and belong to the virtual interface. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries detected by the physical interfaces that reside on the global active MPU and belong to the virtual interface. (In IRF mode.)
cpu cpu-number: Displays the ND attack entries detected by the physical interfaces that reside on the specified CPU and belong to the virtual interface. This option is available only if multiple CPUs are available on the specified slot.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays source MAC-based ND attack detection entries for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays source MAC-based ND attack detection entries for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
verbose: Displays detailed information about source MAC-based ND attack detection entries. If you do not specify this keyword, this command displays brief information about the source MAC-based ND attack detection entries.
count: Displays the number of source MAC-based ND attack detection entries. If you do not specify this keyword, the command displays source MAC-based ND attack detection entries.
Non-default vSystems do not support this command.
(In standalone mode.) The slot slot-number option is supported only when the interface interface-type interface-number option specifies a virtual interface.
(In IRF mode.) The chassis chassis-number slot slot-number options are supported only when the interface interface-type interface-number option specifies a virtual interface.
This command is supported on the following virtual interfaces: Layer 2 aggregate interfaces, Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, and VXLAN VSI interfaces.
If you do not specify any parameters, this command displays all source MAC-based ND attack detection entries.
# Display source MAC-based ND attack detection entries on GigabitEthernet 1/0/1.
<Sysname> display ipv6 nd source-mac interface gigabitethernet 1/0/1
Source MAC     VLAN ID Interface                Aging time (sec) Packets dropped
23f3-1122-3344 4094    GE1/0/1                  10                  84467
# Displays the number of source MAC-based ND attack detection entries.
<Sysname> display ipv6 nd source-mac slot 1 count
Total source MAC-based ND attack detection entries: 1
# Display detailed information about source MAC-based ND attack detection entries on GigabitEthernet 1/0/1.
<Sysname> display ipv6 nd source-mac interface gigabitethernet 1/0/1 verbose
Source MAC: 0001-0001-0001
VLAN ID: 4094
Hardware status: Succeeded
Aging time: 10 seconds
Attack time: 2019/06/04 15:53:34
Packets dropped: 84467
Source MAC
MAC address from which an ND attack is launched.
VLAN ID
ID of the VLAN where the source MAC-based ND attack is detected.
Interface where the source MAC-based ND attack is detected.
Aging time
Remaining aging time of the source MAC-based ND attack detection entry, in seconds.
Packets dropped
Total number of dropped packets. For Layer 2 Ethernet interfaces, this field is not supported and the field value is 0.
Total number of source MAC-based ND attack detection entries.
Hardware status
Status of the source MAC-based ND attack entry setting to hardware:
·     Succeeded.
·     Failed.
·     Not supported.
·     Not enough resources.
Attack time
Time when the source MAC-based ND attack was detected. The time format is YYYY/MM/DD HH:MM:SS.
reset ipv6 nd source-mac
display ipv6 nd source-mac configuration
Use display ipv6 nd source-mac configuration to display the configuration of source MAC-based ND attack detection.
context-admin
# Display the configuration of source MAC-based ND attack detection.
<Sysname> display ipv6 nd source-mac configuration
IPv6 ND source-mac is enabled.
Mode: Filter        Threshold: 20
Source MAC-based ND attack detection is enabled.
IPv6 ND source-mac is disabled.
Source MAC-based ND attack detection is disabled.
Mode
Source MAC-based ND attack detection mode:
·     Filter.
·     Monitor.
Threshold
Threshold for source MAC-based ND attack detection.
ipv6 nd source-mac
ipv6 nd source-mac threshold
ipv6 nd source-mac
Use ipv6 nd source-mac to enable source MAC-based ND attack detection and set the detection mode.
Use undo ipv6 nd source-mac to disable source MAC-based ND attack detection.
ipv6 nd source-mac { filter | monitor }
context-admin
filter: Specifies the filter mode.
monitor: Specifies the monitor mode.
As a best practice, configure this command on gateway devices.
Source MAC-based ND attack detection checks the number of ND messages delivered to the CPU on a per source MAC basis. If the number of messages from the same MAC address within 5 seconds exceeds the threshold, the device generates an ND attack entry for the MAC address. The processing of the ND messages matching this entry depends on the detection mode. With ND logging enabled (by using the ipv6 nd check log enable command), source MAC-based ND attack detection processes the messages as follows:
·     Filter mode—Filters out subsequent ND messages sent from the MAC address, and generates log messages.
·     Monitor mode—Only generates log messages.
The device uses the entry aging time (fixed at 300 seconds) and the threshold to calculate a value:
The calculated value = (threshold/5) × 300
The device monitors the number of dropped packets for an entry. When the entry aging time is reached, it compares the number with the calculated value and takes actions accordingly:
·     If the number of dropped packets is higher than or equal to the calculated value, the device resets the aging time for the entry.
·     If the number of dropped packets is lower than the calculated value, the system deletes the entry and marks MAC address in the entry as a common MAC address.
When you change the detection mode from monitor to filter, the filter mode takes effect immediately. When you change the detection mode from filter to monitor, the device continues filtering ND messages that match existing attack entries.
# Enable source MAC-based ND attack detection and set the detection mode to monitor.
[Sysname] ipv6 nd source-mac monitor
Use ipv6 nd source-mac threshold to set the threshold for source MAC-based ND attack detection.
Use undo ipv6 nd source-mac threshold to restore the default.
ipv6 nd source-mac threshold threshold-value
The threshold for source MAC-based ND attack detection is 30.
context-admin
threshold-value: Specifies the threshold for source MAC-based ND attack detection. The value range is 1 to 5000.
If the number of packets from the same MAC address within 5 seconds exceeds the threshold, the device generates an ND attack entry for the MAC address.
# Set the threshold to 100 for source MAC-based ND attack detection
[Sysname] ipv6 nd source-mac threshold 100
Use reset ipv6 nd source-mac to delete source MAC-based ND attack detection entries.
In standalone mode:
reset ipv6 nd source-mac [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset ipv6 nd source-mac [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
interface interface-type interface-number: Deletes the source MAC-based ND attack entries detected on the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
mac mac-address: Deletes the source MAC-based ND attack entry for the specified MAC address. The MAC address format is H-H-H.
vlan vlan-id: Deletes the source MAC-based ND attack entries for the specified VLAN. The value range for the vlan-id argument is 1 to 4094.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
If you do not specify any parameters, this command deletes all source MAC-based ND attack detection entries.
# Delete all source MAC-based ND attack detection entries.
<Sysname> reset ipv6 nd source-mac
reset ipv6 nd source-mac statistics
Use reset ipv6 nd source-mac statistics to clear statistics for ND messages dropped by source MAC-based ND attack detection.
In standalone mode:
reset ipv6 nd source-mac statistics [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset ipv6 nd source-mac statistics [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
interface interface-type interface-number: Clears statistics for ND messages dropped by source MAC-based ND attack detection on the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
mac mac-address: Clears statistics for ND messages dropped by source MAC-based ND attack detection for the specified MAC address. The MAC address format is H-H-H.
vlan vlan-id: Clears statistics for ND messages dropped by source MAC-based ND attack detection for the specified VLAN. The value range for the VLAN ID is 1 to 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears related statistics on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears related statistics on the global active MPU. (In IRF mode.)
If you do not specify any parameters, this command clears all statistics for ND messages dropped by source MAC-based ND attack detection.
# Clear all statistics for ND messages dropped by source MAC-based ND attack detection.
<Sysname> reset ipv6 nd source-mac statistics
display ipv6 nd source-mac statistics
Interface-based ND attack suppression commands
display ipv6 nd attack-suppression configuration
Use display ipv6 nd attack-suppression configuration to display the configuration of interface-based ND attack suppression.
context-admin
vsys-admin
vsys-operator
# Display the configuration of interface-based ND attack suppression.
<Sysname> display ipv6 nd attack-suppression configuration
IPv6 ND attack-suppression per-interface is enabled.
Threshold: 3000
The interface-based ND attack suppression is enabled.
IPv6 ND attack-suppression per-interface is disabled.
The interface-based ND attack suppression is disabled.
Threshold
Threshold for triggering interface-based ND attack suppression.
ipv6 nd attack-suppression enable per-interface
display ipv6 nd attack-suppression per-interface
Use display ipv6 nd attack-suppression per-interface to display interface-based ND attack suppression entries.
In standalone mode:
display ipv6 nd attack-suppression per-interface slot slot-number [ cpu cpu-number ] [ count | verbose ]
In IRF mode:
display ipv6 nd attack-suppression per-interface chassis chassis-number slot slot-number [ cpu cpu-number ] [ count | verbose ]
context-admin
vsys-admin
vsys-operator
verbose: Displays detailed information about interface-based ND attack suppression entries. If you do not specify this keyword, the command displays brief information about ND attack suppression entries.
count: Specifies the number of interface-based ND attack suppression entries. If you do not specify this keyword, the command displays interface-based ND attack suppression entries.
If you do not specify any parameters, this command displays brief information about all interface-based ND attack suppression entries.
# Display interface-based ND attack suppression entries on the specified slot.
<Sysname> display ipv6 nd attack-suppression per-interface slot 1
Interface                Suppression time (second) Packets dropped
GE1/0/1                  200                            84467
GE1/0/2                  140                            38293
# Display the total number of interface-based ND attack suppression entries on the specified slot.
<Sysname> display ipv6 nd attack-suppression per-interface slot 1 count
Total ND attack suppression entries: 2
# Display detailed information about the interface-based ND attack suppression entries on the specified slot.
<Sysname> display ipv6 nd attack-suppression per-interface slot 1 verbose
Suppression time: 200 seconds
Suppression time: 140 seconds
Attack time: 2019/06/04 14:53:34
Packets dropped: 38293
Figure 1 Command output
Interface in the ND attack suppression entry.
Suppression time, in seconds.
Packets dropped
Total number of ND attack suppression entries.
Hardware status
Status of the interface-based ND attack entry setting to hardware:
·     Succeeded.
·     Failed.
·     Not supported.
Suppression time
Remaining suppression time, in seconds.
Attack time
Time when the interface-based ND attack was detected. The time format is YYYY/MM/DD HH:MM:SS.
reset ipv6 nd attack-suppression per-interface
reset ipv6 nd attack-suppression per-interface statistics
display ipv6 nd attack-suppression per-interface interface
Use display ipv6 nd attack-suppression per-interface interface to display interface-based ND attack suppression entries on an interface.
display ipv6 nd attack-suppression per-interface interface interface-type interface-number [ verbose ]
context-admin
vsys-admin
vsys-operator
# Display interface-based ND attack suppression entries on GigabitEthernet 1/0/1.
<Sysname> display ipv6 nd attack-suppression per-interface interface gigabitethernet 1/0/1
GE1/0/1                  200                            84467
# Display detailed information about the interface-based ND attack suppression entries on GigabitEthernet 1/0/1.
<Sysname> display ipv6 nd attack-suppression per-interface interface gigabitethernet 1/0/1 verbose
Figure 2 Command output
Packets dropped
Hardware status
·     Succeeded.
·     Failed.
·     Not supported.
Suppression time
Attack time
Use ipv6 nd attack-suppression enable per-interface to enable interface-based ND attack suppression.
Use undo ipv6 nd attack-suppression enable per-interface to disable interface-based ND attack suppression.
Interface-based ND attack suppression is disabled.
context-admin
vsys-admin
Use this feature to rate limit ND requests on each Layer 3 interface to prevent ND spoofing attacks. This feature monitors the number of ND requests that each Layer 3 interface received within 5 seconds. If the number on an interface exceeds the threshold, the device creates an ND attack suppression entry for the interface. During the suppression period (fixed at 300 seconds), the device drops ND messages received on this interface.
When the suppression time expires, the system examines the number of dropped ND messages on the interface within the suppression time:
·     If the number is higher than or equal to a calculated value, the device resets the suppression time for the entry and continues the ND suppression on the interface.
·     If the number is lower than the calculated value, the device deletes the suppression entry.
As a best practice, enable this feature on the gateway.
# Enable interface-based ND attack suppression.
[Sysname] ipv6 nd attack-suppression enable per-interface
ipv6 nd attack-suppression threshold
Use ipv6 nd attack-suppression threshold to set the threshold for triggering interface-based ND attack suppression.
Use undo ipv6 nd attack-suppression threshold to restore the default.
ipv6 nd attack-suppression threshold threshold-value
The threshold for triggering interface-based ND attack suppression is 1000.
context-admin
vsys-admin
threshold-value: Specifies the threshold for triggering interface-based ND attack suppression, in the range of 1 to 5000. The threshold defines the maximum number of ND requests that an interface can receive within 5 seconds.
When the number of ND requests that an interface received within 5 seconds exceeds the threshold, the device determines that the interface is being attacked.
# Set the threshold to 500 for triggering interface-based ND attack suppression.
[Sysname] ipv6 nd attack-suppression threshold 500
Use reset ipv6 nd attack-suppression per-interface to delete interface-based ND attack suppression entries.
In standalone mode:
reset ipv6 nd attack-suppression per-interface [ interface interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset ipv6 nd attack-suppression per-interface [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
vsys-admin
interface interface-type interface-number: Deletes interface-based ND attack suppression entries for the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
If you do not specify any parameters, this command deletes all interface-based ND attack suppression entries.
# Delete all interface-based ND attack suppression entries.
<Sysname> reset ipv6 nd attack-interface per-interface
Use reset ipv6 nd attack-suppression per-interface statistics to clear statistics for ND messages dropped by interface-based ND attack suppression.
In standalone mode:
reset ipv6 nd attack-suppression per-interface statistics [ interface interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset ipv6 nd attack-suppression per-interface statistics [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
vsys-admin
interface interface-type interface-number: Clears statistics for ND messages dropped by interface-based ND attack suppression on the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
After you execute this command, the value for the Packets dropped field from the output of the display ipv6 nd attack-suppression per-interface command will be cleared.
If you do not specify any parameters, this command clears all statistics for ND messages dropped by interface-based ND attack suppression.
# Clear statistics for ND messages dropped by interface-based ND attack suppression.
<Sysname> reset ipv6 nd attack-interface per-interface statistics
Source MAC consistency check commands
Use ipv6 nd check log enable to enable the ND logging feature.
Use undo ipv6 nd check log enable to restore the default.
The ND logging feature is disabled.
context-admin
The ND logging feature logs source MAC inconsistency events, and sends the log messages to the information center. The information center can then output log messages from different source modules to different destinations. For more information about the information center, see Network Management and Monitoring Configuration Guide.
As a best practice, disable the ND logging feature to avoid excessive ND logs.
# Enable the ND logging feature.
[Sysname] ipv6 nd check log enable
ipv6 nd mac-check enable
Use ipv6 nd mac-check enable to enable source MAC consistency check for ND messages.
Use undo ipv6 nd mac-check enable to disable source MAC consistency check for ND messages.
Source MAC consistency check for ND messages is disabled.
context-admin
Use this command to enable source MAC consistency check on a gateway. The gateway checks the source MAC address and the source link-layer address for consistency for each ND message. If an inconsistency is found, the gateway drops the ND message.
# Enable source MAC consistency check for ND messages.
[Sysname] ipv6 nd mac-check enable
