- 10-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-PoE configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-NETCONF configuration
- 08-CWMP configuration
- 09-EAA configuration
- 10-Process monitoring and maintenance configuration
- 11-Mirroring configuration
- 12-sFlow configuration
- 13-Information center configuration
- 14-VCF fabric configuration
- 15-Cloud connection configuration
- 16-SmartMC configuration
- 17-Quicknet configuration
- 18-WiNet configuration
- 19-ONVIF configuration
| 18-WiNet configuration | 282.26 KB |
Restrictions: Hardware compatibility with WiNet
Restrictions and guidelines: WiNet configuration
Setting the file server information
Configuring an outgoing interface for the WiNet network
Enabling automatic Ethernet link aggregation
Modifying the password of the default user for members
Deploying a batch file to members
Configuring a batch file for ports connecting APs or IP phones
Backing up configuration files
Configuring resource monitoring
Upgrading the startup software and configuration file on members
About upgrading the startup software and configuration file on members
Restrictions and guidelines for startup software and configuration file upgrade
Upgrading the startup software and configuration file on all members in WiNet groups
Refreshing the network topology
Display and maintenance commands for WiNet
Configuring WiNet
About WiNet
Wisdom Network (WiNet) centrally manages and maintains dispersed network devices at network edges. In a WiNet network, only one device acts as the commander and the remaining devices all act as members. WiNet provides the following features for you to manage the members from the commander:
· Configuration file backup and download.
· Software upgrade.
· Configuration deployment.
· Faulty member replacement.
WiNet network framework
Figure 1 shows the basic framework of a WiNet network.
Figure 1 WiNet network framework
The WiNet network contains the following elements:
· Commander—Also called topology master (TM), which manages all members in the WiNet network.
· Member—Also called topology client (TC), which is managed by the commander.
· File server—Stores startup software images and configuration files for the commander and members.
WiNet network establishment
A WiNet network can be established automatically or manually. In an automatically established WiNet network, the commander obtains member information through NETCONF sessions to form the network topology. The member information includes port information, LLDP neighbor information, STP information, device type, and software version. In a manually established WiNet network, the commander obtains member's LLDP neighbor information through NETCONF sessions and member's hardware information through SNMP Get operations.
Automatic WiNet network establishment
The commander and members use the following procedure to establish a WiNet network:
1. After WiNet is enabled, the commander broadcasts a WiNet packet at an interval of 15 seconds to detect members in the network. The WiNet packet contains information of the commander, such as its bridge MAC address and the IP address of VLAN-interface 1.
2. When a member receives the packet, it records the commander information, and returns a response packet to the commander. The response packet contains information of the member, such as its bridge MAC address and the IP address of VLAN-interface 1.
3. When the commander receives the response packet, it initiates a NETCONF session to the member with the default username admin and the default password admin. The commander then obtains detailed information about the member through the session, including port information, LLDP neighbor information, STP information, device type, and software version.
4. The commander establishes a connection to the member for tracking the liveliness of the member, and adds the member to the WiNet network.
5. Based on the LLDP neighbor information obtained from all members, the commander forms a WiNet topology.
After the WiNet network is established, the commander and members check for the existence of each other by exchanging WiNet packets.
· When a member receives a WiNet broadcast packet from the commander, it compares the bridge MAC address in the packet with the recorded bridge MAC address. If the two bridge MAC addresses are the same, the member returns a response packet to the commander. If the member does not receive a broadcast packet from the commander within the time limit, the member determines that the commander does not exist in the network anymore. Then, the member clears the commander information. The time limit is a random value in the range of 60 to 120 seconds.
· When the commander receives a response packet from a member, it compares the bridge MAC address in the packet with the recorded bridge MAC address. If the two bridge MAC addresses are the same, the commander determines that the member still exists in the network. If the commander does not receive a response packet from a member within 150 seconds, the commander determines that the member is offline. Then, the commander sets the status of the member to offline.
Manual WiNet network establishment
You can log in to the Web interface of the commander, and enter the IP address, username, and password of the members to manually add them to the network. The members can join the network without exchanging WiNet packets with the commander. For more information, see Comware 7 Web-Based Products User Guide.
After you specify the information of a member on the commander, the commander performs the following operations to add the member to the network:
· Verify that the member can be accessed through Telnet.
· Obtain basic member information, including LLDP neighbor information through NETCONF.
· Obtain hardware information through SNMP Get operations.
WiNet features
Bulk configuration deployment for members
This feature allows you to deploy multiple command lines to members from the commander, eliminating the need to log in to members and configure the command one by one.
The procedure for bulk configuration deployment is as follows:
1. The commander acts as a Telnet client and establishes Telnet connections to the members.
2. The commander deploys a batch file to the members through Telnet connections. The batch file is created on the commander and contains command lines to be deployed.
3. The members run the command lines in the file.
Bulk configuration deployment for ports connecting APs and IP phones
With batch file deployment enabled, the commander automatically deploys configurations in the specified batch file to a port connecting an AP or IP phone, simplifying access port configuration.
When the commander first detects the association of an AP or IP phone on a port through LLDP, it deploys the command lines in the specified batch file to the port. If no batch file is specified for the device type, the configurations on the port remain unchanged.
If the AP or IP phone disconnects from the port, the configurations on the port remain. When a new device comes online from the port, configurations used by the port depend on the new device type.
· If the new device is an AP or IP phone and has the same type as the disconnected device, the configurations on the port remain unchanged.
· If the new device is an AP or IP phone but has a different type as the disconnected device, the commander deploys the command lines in the specified batch file to the port. If no batch file is specified for the device type, the configurations on the port remain unchanged.
· If the new device is neither an AP nor an IP phone, the configurations on the port remain unchanged.
To disable the commander from deploying a batch file to ports, remove the specified batch file or execute the undo winet batch-file-apply enable command to disable batch file deployment. This command is supported only in Release 6328 and later.
You can use the following methods to back up the next-startup configuration file on the commander and members:
· Automatic backup—Enable this feature for the commander and all members in the network to immediately perform a backup. After that, the commander and members back up the configuration file at a user-specified interval.
· Manual backup—Manually trigger a backup on the commander or the specified members or WiNet groups.
To back up the configuration file on a member, the commander instructs the member by unicasting a WiNet packet to them. When a member receives the packet, it saves the running configuration to the next-startup configuration file and uploads the file to the file server.
Startup software and configuration file upgrade
This feature enables users to upgrade startup software and the configuration file of member devices from the commander.
Before upgrade, you must upload the upgrade files from the commander to the file server and specify the upgrade files on the file server for the members to download.
The procedure for startup software and configuration file upgrade is as follows:
1. The commander instructs the members (or WiNet group) to download the upgrade files from the file server.
2. The members download the upgrade files from the file server.
3. The members upgrade the startup software and configuration file as follows:
¡ Startup software upgrade—Uses the boot loader method to perform the software upgrade. The members might be restarted during the upgrade process.
¡ Configuration file upgrade—Replaces the current configuration file with the upgrade configuration file. The members will not be restarted during the upgrade process.
You can use the following methods to replace a faulty member:
· Automatic replacement—Enables the commander to record the positions of all members in the topology for replacement. When the commander discovers that the new member has physically replaced the faulty member, it compares the new member with the faulty one. The commander performs a replacement if the following requirements are met:
¡ The new member is deployed at the same topological position as the faulty one.
¡ The models of the new member and faulty member are the same.
The commander then instructs the new member to download the configuration file of the faulty member from the file server. After downloading the configuration file, the new member runs the configuration file to complete the replacement.
· Manual replacement—After the faulty member is physically replaced, you manually trigger a configuration replacement. The new member will download the configuration file of the faulty member from the file server and run the file to complete the replacement.
Outgoing interface for a WiNet network
The outgoing interface feature allows hosts connecting to an outgoing interface to access all the members in a WiNet network. You can configure multiple outgoing interfaces for a WiNet network.
As shown in Figure 2, the host is connected to port 1 on the TM and TC 1 and TC 2 are in a different network segment than the host. The host can access the Web interface of the TM but cannot access the Web interface of any member.
If port 1 on the TM is configured as the outgoing interface, the system mirrors the IP address of each member to a new address. The new address contains the IP address of the outgoing interface and the port number assigned by the commander to the member in the format of IP address:Port number. This enables the host to access the Web interfaces of members from the Web interface of the TM.
To access the Web interface of a member, enter the Web interface of the commander, and click Visibility from the navigation pane. Then, click the Topology tab, select the target member, and click Login to Web interface.
Automatic link aggregation
Automatic link aggregation automatically bundles multiple physical Ethernet links between two members into one logical link, called an aggregate link. This feature provides increased link bandwidth and improved link reliability.
NOTE: · Automatic link aggregation cannot be performed between the commander and a member, or between a member and a device outside the WiNet network. You can aggregate the links between the commander and a member manually. For more information about manual link aggregation, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide. · If a member enabled with automatic link aggregation joins a WiNet network whose commander is disabled with the aggregation feature, the feature will be disabled for the member as well. This might affect service traffic forwarding on the member. |
VLAN creation for members
To simplify configuration and management, you can create a VLAN for members. Then, all access ports on a member that are not connected to other members or the commander are assigned to the VLAN.
If a member has access ports that are connected to offline devices, you must remove the offline devices before creating a VLAN for the member.
The VLAN creation fails for a member if one or more access ports cannot be assigned to the VLAN. If the VLAN creation fails, the VLAN memberships for the access ports are restored to the state before the VLAN was created.
The failure to create a VLAN for a member does not affect the VLAN creation for other members.
Resource monitoring
Resource monitoring allows you to view resource usage, memory usage, temperature information, and packet dropping information of commanders and members on the commander. Packet dropping monitoring monitors packet dropping on members and on interfaces and is available only in Release 6328 and later.
You can view the usage and temperature information on the commander, and view packet dropping information from the WiNet > Intelligent O&M > Resource monitoring page of the commander's Web interface.
Only the WS5820-WiNet and WS5810-WiNet switch series support WiNet. A WS5810-WiNet switch cannot act as the commander.
The WS5820-WiNet provides a port mode LED switch button (MODE) on the front panel. You can press the button for 3 to 5 seconds when the server is powered on to set the device role to commander. The default username and password are admin and admin.
You need to enable WiNet on both the commander and members and perform all the other tasks only on the commander.
The following features take effect only on members added to the WiNet network automatically:
· Configuration file backup.
· Startup software and configuration file upgrade.
· Automatic link aggregation.
A WiNet network is established in VLAN 1. For the network to work correctly, make sure interfaces that connect the network member devices are added to VLAN 1.
As from Release 6346, the following settings are added to the factory defaults of network member devices in WiNet:
· Telnet is enabled and the scheme authentication method is configured for VTY user lines.
· Local user named admin of the Telnet, HTTP, and HTTPS types is added. The user password is admin and user role is network-admin.
· NETCONF over SOAP over HTTP is enabled.
· LLDP is enabled globally.
· SmartMC is enabled and the device role is specified as member upon the device startup.
WiNet tasks at a glance
To configure WiNet, perform the following tasks:
1. Enabling
2. Setting the file server information
This task is required for configuring automatic configuration file backup, replacing faulty members, and upgrading the startup software and configuration file on members.
3. (Optional.) Configuring an outgoing interface for the WiNet network
4. (Optional.) Enabling automatic Ethernet link aggregation
5. (Optional.) Modifying the password of the default user for members
This task is required for upgrading the startup software and configuration file on members and deploying a batch file to a WiNet group.
7. (Optional.) Deploying and managing configuration
¡ Deploying a batch file to members
¡ Configuring a batch file for ports connecting APs or IP phones
¡ Backing up configuration files
8. (Optional.) Monitoring and maintaining the WiNet network
¡ Configuring resource monitoring
¡ Upgrading the startup software and configuration file on members
¡ Managing the network topology
Prerequisites for WiNet
Before you configure WiNet, perform the following tasks on the commander and members:
· Enable the Telnet service, and configure scheme authentication for VTY user lines. For information about Telnet service and VTY user lines, see CLI login configuration in Fundamentals Configuration Guide.
· Configure a local user.
¡ Specify the username and password.
- On the commander, the username and password must be the same as the username and password configured by using the winet tm username username password { cipher | simple } string enable command.
- On a member, set both the username and password to admin, and execute the password-control length 4, password-control composition type-number 1 type-length 1, and undo password-control complexity user-name check commands to lower the password complexity requirements.
This is because WiNet requires that the commander use username admin and password admin to communicate with members, which does not meet the default password complexity requirements. For more information about these commands, see password control commands in Security Command Reference.
After the WiNet network is established, you can increase the password complexity requirements and use the winet tc password command to modify the username and password.
¡ Specify the Telnet, HTTP, and HTTPS services for the user.
¡ Set the RBAC role of the local user to network-admin.
For information about local users, see AAA configuration in Security Configuration Guide. For information about user roles, see RBAC configuration in Fundamentals Configuration Guide.
· Enable NETCONF over SOAP over HTTP. For information about NETCONF over SOAP, see NETCONF configuration in Network Management and Monitoring Configuration Guide.
· Enable LLDP globally. For information about LLDP, see Layer 2—LAN Switching Configuration Guide.
· To manage the commander and members through a Web interface, you must enable the HTTP and HTTPS services, and set the service type to HTTP and HTTPS for the local user. For information about Web login, HTTP, and HTTPS, see Fundamentals Configuration Guide.
· To manually establish a WiNet network, you must configure the snmp-agent community read public and snmp-agent sys-info version v2c commands on the members. For information about SNMP, see Network Management and Monitoring Configuration Guide.
Enabling WiNet
About WiNet
Enable this feature on both the commander and members to enable management of members from the commander.
A WiNet network must have one and only one commander.
If you change the role of the commander to member or disable WiNet on the commander, all WiNet settings in its running configuration will be cleared.
WiNet fails to be enabled if ACL resources are insufficient. If ACL resources are insufficient, use the undo acl command to delete unnecessary ACLs and then enable WiNet. You can execute the display acl command to view ACL configuration and match statistics. For more information about ACLs, see ACL and QoS Configuration Guide.
WiNet fails to be enabled if ports 80 and 443 have been used.
If you execute the winet enable command multiple times, the most recent configuration takes effect. You can execute the command to change the device role or the password.
1. Enter system view.
2. Enable WiNet and set the device role.
winet { tc | tm username username password { cipher | simple } string } enable
By default, WiNet is disabled.
About files stored on the file server
In a WiNet network, a file server is used to store the following files:
· Upgrade startup software files and upgrade configuration file for members.
· Backup configuration files of the commander and members.
Only FTP servers are supported in Release 6318P01 and earlier. Both FTP servers and SFTP servers are supported in Release 6328 and later. For information about FTP servers, see configuring FTP in Fundamentals Configuration Guide. For information about SFTP servers, see configuring SSH in Security Configuration Guide.
You can use the following methods to specify a file server:
· Specify the IP address of a file server.
· Specify the IP address of the commander. The commander will act as a file server.
To configure the commander to act as a file server, make sure the commander has enough storage space for storing the files required by members.
To use an independent file server, connect the file server to the commander instead of the members as a best practice. The file server uses VLAN 1 to communicate with the WiNet network. If you connect the file server to members, creating a VLAN for members will assign member interfaces connecting to the file server to the created VLAN, causing file server disconnection. For more information about member VLAN creation, see "Creating a VLAN for members."
2. Set the file server information.
Release 6318P01 and earlier:
winet ftp-server server-address username username password { cipher | simple } string
Release 6328 and later:
winet { ftp-server | sftp-server } { ipv4-address | ipv6 ipv6-address } [ port port ] [ vpn-instance vpn-instance-name ] [ directory directory ] username username password { cipher | simple } string
By default, no file server information is set.
VLAN interface 1 cannot be used as an outgoing interface, because the WiNet network is established in VLAN 1.
2. Enter VLAN interface view or Layer 3 Ethernet interface view.
¡ Enter VLAN interface view.
interface vlan interface-number
¡ Enter Layer 3 Ethernet interface view.
3. Configure the interface as an outgoing interface.
winet outbound
By default, no interface is used as an outgoing interface.
Enabling or disabling automatic link aggregation might cause network flapping, and the members might go offline for a short period of time.
2. Enable automatic Ethernet link aggregation.
winet auto-link-aggregation enable
By default, automatic Ethernet link aggregation is disabled.
About modifying the password of the default user for members
During WiNet network establishment, the commander uses the default username and password to establish NETCONF sessions to members automatically added to the network. The default username and password of the members for NETCONF session establishment are admin and admin.
To enhance security, you can perform this task to change the password for the default user admin of the members after the commander adds the members to the network.
Do not modify the password for members that are manually added to the WiNet network. If you modify the password for a manually added member, you will not be able to manage that member from the commander.
You can use the display winet tc verbose command to identify the method used to add the members.
2. Modify the password of the default user for members.
winet tc password [ cipher ] string
The cipher keyword is supported only in Release 6328 and later.
Creating a WiNet group
About WiNet groups
This feature allows you to create a WiNet group on the commander and add members to the group. When you perform the following operations, you can specify a WiNet group to apply the operations to all members in the group:
· Startup software upgrade.
· Configuration file upgrade.
2. Create a WiNet group and enter its view.
winet group group-name
3. (Optional.) Display predefined device types.
match device-type ?
4. Set a match criterion.
match { device-type device-type | ip-address ip-address { ip-mask-length | ip-mask } | mac-address mac-address mac-mask-length }
By default, no match criterion is set.
5. If the device type of the members is not predefined on the commander, perform the following tasks to manually define the device type on the commander:
a. Return to system view.
b. Define a device type on the commander.
winet tc sysoid sysoid device-type device-type
To obtain the SYSOID of a member, execute the display winet tc verbose command.
You cannot define a predefined member type as another type.
If you perform this task multiple times to create a VLAN for members, the most recent configuration takes effect.
2. Creating a VLAN for members and assign access ports on the members to the VLAN.
winet vlan vlan-id { group group-name-list | tc tc-id-list }
1. Execute the following command in user view to create a batch file and edit the command lines to be deployed to members.
create batch-file cmd-filename
Each command occupies a line in the batch file. When you finish editing, enter a percent sign (%) to return to user view.
Make sure the command lines that you enter are correct because the system does not verify whether the command lines are correct.
2. Enter system view.
3. Deploy the batch file to a list of members or WiNet groups.
winet batch-file cmd-filename deploy { group group-name-list | tc tc-id-list }
All commands in the batch file must be commands used in interface view.
The size of the batch file cannot exceed 8190 characters.
Make sure the file name is correct when specifying the batch file because the system does not verify whether the file name is correct. After specifying the batch file, do not delete the file or rename the file.
1. (Optional.) Execute the following command in user view to create a batch file and edit the command lines to be deployed to members.
3. Specify the batch file for ports connecting APs or IP phones.
winet batch-file batch-file-name apply { ap | phone }
4. (Optional.) Disable batch file deployment.
By default, batch file deployment is enabled.
About backing up configuration files
Perform this task to back up the configuration file of the commander or the specified members. Configuration files automatically backed up to the file server are named in the format of device bridge MAC address_backup.cfg.
When you change the commander in the WiNet network, make sure the backup configuration file of the original commander on the file server is deleted. If the file still exists, the new commander might download the file and run the settings. This will cause a conflict in the network.
The maximum number of members that can perform automatic configuration at the same time is limited by the performance of the file server. If automatic configuration backup fails, set the maximum number of members to a smaller value.
Before performing this task, you must set the file server information (see "Setting the file server information").
2. Set the maximum number of members that can perform configuration file backup at the same time.
winet backup configuration max-number max-number
By default, a maximum of five members can perform automatic configuration backup at the same time.
3. Back up configuration files.
Choose one option as needed:
¡ Enable automatic configuration file backup and set the backup interval.
winet backup startup-configuration interval interval-time
By default, automatic configuration file backup is disabled.
¡ Manually back up the configuration file on members.
winet backup configuration { group group-name-list | tc [ tc-id-list ] }
TC ID 0 represents the commander.
2. Set the interval for the commander to obtain resource monitoring information.
winet resource-monitor interval interval
The default setting is 1 minute.
3. Set the aging time for resource monitoring information.
winet resource-monitor max-age max-age
The default setting is 24 hours.
4. Enable resource monitoring.
winet resource-monitor [ cpu | memory | packet-drop | temperature ] * [ group group-name-list | tc { tc-id-list | mac-address mac-address } | tm ]
By default, resource monitoring is disabled.
If you do not specify a resource type, this command enables resource monitoring for all resource types.
If you do not specify a device to monitor (member or commander), this command enables resource monitoring on the commander and all members.
The packet-drop keyword is supported only in Release 6328 and later.
You can use the following methods to upgrade the startup software and configuration file on members:
· Schedule an upgrade by specifying an upgrade time or upgrade delay.
· Upgrade immediately by not specifying an upgrade time or upgrade delay.
A member can perform only one upgrade task at a time.
An immediate upgrade cannot be cancelled. If you specify a delay time or upgrade time to perform a scheduled upgrade, the upgrade operation can be cancelled by using the undo winet upgrade command before it starts.
Upgrading the startup software and configuration file in one step
2. Upgrade the startup software on members in one step.
winet upgrade boot-loader tc { tc-id-list { boot boot-filename system system-filename | file ipe-filename } }&<1-40> [ delay delay-time | time in-time ]
CAUTION: Upgrading the startup software might interrupt services. Before upgrading the startup software, make sure no services will be interrupted. |
3. Upgrade the configuration file on members in one step.
winet upgrade startup-configuration tc { tc-id-list cfg-filename }&<1-40> [ delay delay-time | time in-time ]
CAUTION: After you update the configuration file, the configuration in the new configuration file will become the running configuration. Before upgrading the configuration file, make sure the contents of the new configuration file are correct. |
Configuring startup software and configuration file upgrade step by step
2. Configure startup software upgrade for members step by step:
a. Specify the upgrade startup software files.
winet tc tc-id boot-loader { ipe-filename | boot boot-filename system system-filename }
b. Upgrade the startup software on members.
winet upgrade boot-loader tc tc-id-list
3. Configure configuration file upgrade for members step by step:
a. Specify the upgrade configuration file.
winet tc tc-id startup-configuration cfg-filename
b. Upgrade the configuration file on members.
winet upgrade startup-configuration tc tc-id-list
2. Upgrade the startup software on all members in WiNet groups in one step.
winet upgrade boot-loader group { group-name-list [ boot boot-filename system system-filename | file ipe-filename ] }&<1-40> [ delay minutes | time in-time ]
3. Upgrade the configuration file on all members in WiNet groups in one step.
winet upgrade startup-configuration group { group-name-list file cfg-filename }&<1-40> [ delay minutes | time in-time ]
The file keyword needs to be entered only in Release 6328 and later.
2. Enter WiNet group view.
3. Specify the upgrade startup software files for the WiNet group.
boot-loader file { ipe-filename | boot boot-filename system system-filename }
By default, no upgrade startup software files are specified for a WiNet group.
4. Specify the upgrade configuration file for the WiNet group.
startup-configuration cfgfile
By default, no upgrade configuration file is specified for a WiNet group.
5. Return to system view.
6. Upgrade the startup software and configuration file on all members in the WiNet group.
¡ Upgrade the startup software.
winet upgrade boot-loader group group-name-list [ delay minutes | time in-time ]
¡ Upgrade the configuration file.
winet upgrade startup-configuration group group-name-list [ delay minutes | time in-time ]
About refreshing the network topology
You can use the following methods to refresh the network topology:
· Automatic topology refresh—Specify the refresh interval to allow the commander to refresh the network topology periodically.
· Manual topology refresh—Execute the winet topology-refresh command to manually refresh the network topology.
The topology refresh time depends on the number of members in the network.
· Manually refresh the network topology in any view.
· Configure automatic network topology refresh.
a. Enter system view.
b. Set the automatic topology refresh interval.
winet topology-refresh interval interval
By default, the automatic topology refresh interval is 60 seconds.
Saving the network topology
About saving the network topology
This task allows you to save the current network topology to the topology.dba file in the flash memory. After the commander reboots, it uses the topology.dba file to restore the network topology.
2. Save the network topology.
winet topology-save
Replacing faulty members
Make sure the new member for replacement and the faulty member have the same neighbor relationship, device model, and IRF member ID.
Make sure the new member has a different member ID than all the members in the WiNet network, including offline members. Faulty members are considered offline.
To automatically replace a faulty member, first enable automatic replacement, and then install the new member at the location where the faulty member was installed and connect all cables.
To manually replace a faulty member, first install the new member at the location where the faulty member was installed, connect all cables, and then execute the manual replacement command.
Before you replace a faulty member, set the file server information (see "Setting the file server information").
2. Replace faulty members.
¡ Enable automatic faulty member replacement.
winet auto-replace enable
By default, automatic faulty member replacement is disabled.
¡ Manually replace a faulty member.
winet replace tc tc-id1 faulty-tc tc-id2
Task |
Command |
Display the backup status on members. |
display winet backup configuration status |
Display the batch file execution results. |
display winet batch-file status [ ap | last number | phone ] |
Display WiNet configuration. |
display winet configuration |
Display connections between the devices in the WiNet network. |
display winet device-link |
Display WiNet group information. |
display winet group [ group-name ] [ verbose ] |
Display the faulty member replacement status. |
display winet replace status |
Display resource monitoring information. |
display winet resource-monitor [ cpu | memory | temperature ] * [ tc tc-id | tm ] |
Display resource monitoring configuration. |
display winet resource-monitor configuration |
Display member information. |
display winet tc [ tc-id ] [ verbose ] |
Display log information in the log buffer on a member. |
display winet tc tc-id log buffer [ module module-name [ mnemonic mnemonic-value ] ] |
Display restart log information for a member. |
display winet tc tc-id log restart |
Display VLAN creation results for members. |
display winet vlan |
Display member upgrade status. |
display winet upgrade status |
WiNet configuration examples
Example: Configuring WiNet
As shown in Figure 3, member 1, member 2, and member 3 belong to the same device type: WS5820-WiNet. The IP address of the FTP server is 192.168.2.1. The FTP username is admin and the FTP password is hello12345.
Perform the following tasks to establish a WiNet network and upgrade the configuration file on the members:
1. Configure the commander and members to automatically establish a WiNet network.
2. Configure interface GigabitEthernet 1/0/1 as the outgoing interface for the WiNet network.
3. Create a WiNet group and add the members to the group.
4. Upgrade the configuration file on all members in the WiNet group.
5. Save configuration file startup.cfg on the FTP server.
1. Configure TC 1:
# Configure VLAN-interface 1.
<TC1> system-view
[TC1] interface vlan-interface 1
[TC1-Vlan-interface1] ip address 192.168.2.3 24
[TC1-Vlan-interface1] quit
# Enable HTTP and HTTPS.
[TC1] ip http enable
[TC1] ip https enable
# Enable the Telnet service.
[TC1] telnet server enable
# Enable NETCONF over SOAP over HTTP.
[TC1] netconf soap http enable
# Enable LLDP globally.
[TC1] lldp global enable
# Create a user named admin.
[TC1] local-user admin
# Lower password complexity requirements. For more information about these commands, see password control commands in Security Command Reference.
[TC1-luser-manage-admin] password-control length 4
[TC1-luser-manage-admin] password-control composition type-number 1 type-length 1
[TC1-luser-manage-admin] undo password-control complexity user-name check
# Set the username and password to admin, add the telnet, http, and https service types, and authorize the user to use the network-admin user role.
[TC1-luser-manage-admin] password simple admin
[TC1-luser-manage-admin] service-type telnet http https
[TC1-luser-manage-admin] authorization-attribute user-role network-admin
[TC1-luser-manage-admin] quit
# Set scheme authentication for VTY user lines 0 to 63.
[TC1] line vty 0 63
[TC1-line-vty0-63] authentication-mode scheme
[TC1-line-vty0-63] quit
# Enable WiNet and set the device role to tc.
[TC1] winet tc enable
2. Configure TC 2 and TC 3 in the same way TC 1 is configured. (Details not shown.)
3. Configure the TM:
# Configure GigabitEthernet 1/0/1.
<TM> system-view
[TM] interface gigabitethernet 1/0/1
[TM-GigabitEthernet1/0/1] port link-mode route
[TM-GigabitEthernet1/0/1] ip address 192.168.52.2 24
[TM-GigabitEthernet1/0/1] quit
[TM] interface vlan-interface 1
[TM-Vlan-interface1] ip address 192.168.2.2 24
[TM-Vlan-interface1] quit
[TM] ip http enable
[TM] ip https enable
[TM] telnet server enable
[TM] netconf soap http enable
[TM] lldp global enable
# Create a user. Set the username to admin and the password to hello12345, add the telnet, http, and https service types, and authorize the user to use the network-admin user role.
[TM] local-user admin
[TM-luser-manage-admin] password simple hello12345
[TM-luser-manage-admin] service-type telnet http https
[TM-luser-manage-admin] authorization-attribute user-role network-admin
[TM-luser-manage-admin] quit
[TM] line vty 0 63
[TM-line-vty0-63] authentication-mode scheme
[TM-line-vty0-63] quit
# Enable WiNet, set the device role to commander, and set the username to admin and the password (plaintext) to hello12345.
[TM] winet tm username admin password simple hello12345 enable
# Specify GigabitEthernet 1/0/1 as the outgoing interface.
[TM-GigabitEthernet1/0/1] winet outbound
# Set the file server IP address, username, and plaintext password to 192.168.2.1, admin, and hello12345, respectively.
[TM] winet ftp-server 192.168.2.1 username admin password simple hello12345
# Create WiNet group S1 and enter its view.
[TM] winet group S1
# Create an IP address match criterion to add all members in the specified network segment to WiNet group S1.
[TM-winet-group-S1] match ip-address 192.168.2.0 24
# Specify the upgrade configuration file startup.cfg for WiNet group S1.
[TM-winet-group-S1] startup-configuration startup.cfg
[TM-winet-group-S1] quit
# Upgrade the configuration file on all members in WiNet group S1.
[TM] winet upgrade startup-configuration group S1 file startup.cfg
# Display brief information about all members after the WiNet network is established.
[TM] display winet tc
TCID DeviceType Sysname IpAddress MacAddress Status Version
1 WS5820 TC1 192.168.2.3 201c-e7c3-0300 Normal COMWAREV700R001
2 WS5820 TC2 192.168.2.4 201c-e7c3-0301 Normal COMWAREV700R001
3 WS5820 TC3 192.168.2.5 201c-e7c3-0302 Normal COMWAREV700R001
# Display the configuration file upgrade status on the members.
<TM> display winet upgrade status
ID IpAddress MacAddress Status UpdateTime UpdateFile
1 192.168.2.3 201c-e7c3-0300 Finished Immediately startup.cfg
2 192.168.2.4 201c-e7c3-0301 Finished Immediately startup.cfg
3 192.168.2.5 201c-e7c3-0302 Finished Immediately startup.cfg
