08-ACL and QoS Command Reference
HomeSupportSwitchesS5570S-EI SeriesReference GuidesCommand ReferencesH3C S5570S-EI & S5500V3-SI Command References-R11xx-6W10308-ACL and QoS Command Reference
03-Data buffer commands
03-Data buffer commands 53.64 KB
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
·     Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·     Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
·     Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
# Enable the Burst feature.
[Sysname] burst-mode enable
display buffer usage
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer usage for all IRF member devices.
# Display buffer usage.
<Sysname> display buffer usage
Egress total-shared cell buffer usage on uiSlot 1 :
Total:    2053 KB
Used:       0 KB
Free:    2053 KB
                              5sec    1min    5min
Block 1                         0%      0%      0%
GigabitEthernet1/0/1            0%      0%      0%
GigabitEthernet1/0/2            0%      0%      0%
GigabitEthernet1/0/3            0%      0%      0%
GigabitEthernet1/0/4            0%      0%      0%
GigabitEthernet1/0/5            0%      0%      0%
GigabitEthernet1/0/6            0%      0%      0%
GigabitEthernet1/0/7            0%      0%      0%
GigabitEthernet1/0/8            0%      0%      0%
GigabitEthernet1/0/9            0%      0%      0%
GigabitEthernet1/0/10           0%      0%      0%
GigabitEthernet1/0/11           0%      0%      0%
GigabitEthernet1/0/12           0%      0%      0%
GigabitEthernet1/0/13           0%      0%      0%
GigabitEthernet1/0/14           0%      0%      0%
GigabitEthernet1/0/15           0%      0%      0%
GigabitEthernet1/0/16           0%      0%      0%
GigabitEthernet1/0/17           0%      0%      0%
GigabitEthernet1/0/18           0%      0%      0%
GigabitEthernet1/0/19           0%      0%      0%
GigabitEthernet1/0/20           0%      0%      0%
GigabitEthernet1/0/21           0%      0%      0%
GigabitEthernet1/0/22           0%      0%      0%
GigabitEthernet1/0/23           0%      0%      0%
GigabitEthernet1/0/24           0%      0%      0%
Ten-GigabitEthernet1/0/25       0%      0%      0%
Ten-GigabitEthernet1/0/26       0%      0%      0%
Ten-GigabitEthernet1/0/27       0%      0%      0%
Ten-GigabitEthernet1/0/28       0%      0%      0%
Block
Block where the port resides. The block where the ports on the front panel of the device reside is fixed to Block 1.
Total
Total size of the data buffer.
Used
Size of used data buffer.
Free
Size of free data buffer.
5sec
Percentage of the buffer that the port uses for the last 5 seconds.
1min
Percentage of the buffer that the port uses for the last 1 minute.
5min
Percentage of the buffer that the port uses for the last 5 minutes.
