06-Layer 3—IP Routing Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R8630Pxx-6W10006-Layer 3—IP Routing Command Reference
01-Basic IP routing commands
01-Basic IP routing commands 926.79 KB
Basic IP routing commands· 1
address-family ipv4· 1
address-family ipv6· 1
display ip routing-table· 2
display ip routing-table acl 11
display ip routing-table ip-address· 16
display ip routing-table prefix-list 20
display ip routing-table protocol 21
display ip routing-table record· 24
display ip routing-table statistics· 32
display ip routing-table summary· 34
display ipv6 rib attribute· 36
display ipv6 rib graceful-restart 37
display ipv6 rib nib· 37
display ipv6 rib nib record· 40
display ipv6 route-direct nib· 43
display ipv6 routing-table· 46
display ipv6 routing-table acl 56
display ipv6 routing-table ipv6-address· 61
display ipv6 routing-table prefix-list 65
display ipv6 routing-table protocol 67
display ipv6 routing-table record· 70
display ipv6 routing-table statistics· 73
display ipv6 routing-table summary· 76
display rib attribute· 77
display rib graceful-restart 79
display rib nib· 81
display rib nib record· 90
display route-direct nib· 100
fib lifetime· 106
flush route-attribute· 107
inter-protocol ecmp· 107
inter-protocol fast-reroute· 108
ipv6 route-direct cost 109
ipv6 route-direct track· 110
maintenance-probe enable· 112
nexthop recursive-lookup restrain· 113
nexthop recursive-lookup restrain clear-interval 114
nexthop recursive-lookup restrain disable· 115
primary-path-detect bfd· 116
protocol lifetime· 118
protocol nexthop recursive-lookup· 118
record-limit 119
reset ip routing-table record· 121
reset ip routing-table statistics protocol 121
reset ipv6 rib nib record· 122
reset ipv6 routing-table record· 122
reset ipv6 routing-table statistics protocol 122
reset rib nib record· 123
rib· 123
route-direct cost 124
route-direct track· 125
routing-table limit 126
snmp-agent trap enable ipv6 rib· 127
snmp-agent trap enable rib· 129
address-family ipv4
Use address-family ipv4 to create the RIB IPv4 address family and enter its view, or enter the view of the existing RIB IPv4 address family.
Use undo address-family ipv4 to delete the RIB IPv4 address family and all configurations in the view.
address-family ipv4
No RIB IPv4 address family exists.
RIB view
# Create the RIB IPv4 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6
Use address-family ipv6 to create the RIB IPv6 address family and enter its view, or enter the view of the existing RIB IPv6 address family.
Use undo address-family ipv6 to delete the RIB IPv6 address family and all configurations in the view.
address-family ipv6
No RIB IPv6 address family exists.
RIB view
# Create the RIB IPv6 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
Use display ip routing-table to display routing table information.
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ priority { critical | high | low | medium } ] [ verbose ] [ slot slot-number ]
display ip routing-table all-routes
display ip routing-table [ vpn-instance vpn-instance-name ] fast-reroute
all-vpn-instance: Displays routing table information for all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
priority { critical | high | low | medium }: Specifies a route convergence priority. To display route information with the critical priority, specify the critical keyword. To display route information with the high priority, specify the high keyword. To display route information with the low priority, specify the low keyword. To display route information with the medium priority, specify the medium keyword. If you do not specify any of the keywords, this command displays route information with all priorities.
all-routes: Displays routing table information for the public network and all VPN instances.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
fast-reroute: Displays fast reroute routing table information.
If you do not specify any parameters, this command displays routing table information for the public network, excluding fast reroute routing table information.
# Display brief information about active routes in the public network.
<Sysname> display ip routing-table
Destinations : 8        Routes : 8
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
1.1.1.0/24          Static 60   0            192.168.47.4    XGE3/0/1
192.168.1.40/32     Direct 0    0            127.0.0.1       InLoop0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# Display brief information about active routes in the routing table for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes
VPN instance: public instance
VPN instance: vpn1
Destinations : 5        Routes : 5
1.1.2.0/24          Static 60   0            2.2.1.1         XGE3/0/1
3.3.1.0/24          BGP    255  0            55.1.1.2        XGE3/0/2
# Display IPv4 routing table information for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
Destinations : 4        Routes : 4
1.1.3.0/24          Static 60   0            3.3.1.1         XGE3/0/1
# Display brief fast reroute information in the public network.
<Sysname> display ip routing-table fast-reroute
Destinations : 2        Routes : 2
3.3.3.3/32         Static  60  0           1.1.1.2         XGE3/0/1
4.4.4.4/32         Static  60  0           1.1.1.2         XGE3/0/1
VPN instance
Public network or VPN instance to which the routing table belongs. For the public network, this filed displays public instance. For a VPN instance, this field displays the name of the instance.
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address/mask length.
Proto
Route type or protocol that installed the route:
·     Direct—Direct route.
·     Static—Static route.
·     UNR—User network route.
·     RIP—RIP installed the route.
·     O_INTRA—OSPF intra-area route.
·     O_ASE2—OSPF Type-2 external route.
·     IS_L1—Level-1 IS-IS IPv4 route.
·     IS_L2—Level-2 IS-IS IPv4 route.
·     BGP—BGP installed the route.
·     EIGRP—EIGRP installed the route.
·     LISP—LISP installed the route.
Pre
Preference of the route.
Cost
Cost of the route.
NextHop
Next hop address of the route.
Output interface for packets to be forwarded along the route.
Summary count
Number of routes.
# Display detailed information about all routes in the public network.
<Sysname> display ip routing-table verbose
 Destination: 0.0.0.0/32
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 08h34m37s
  FlushedAge: 15h28m49s
        Cost: 0                  Preference: 0
       IpPre: N/A                QosLocalID: N/A
         Tag: 0                       State: Active NoAdv
   OrigTblID: 0x0                   OrigVrf: default-vrf
     TableID: 0x2                    OrigAs: 0
       NibID: 0x10000000             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: 0.0.0.0
       Flags: 0x1000c           OrigNextHop: 127.0.0.1
       Label: NULL              RealNextHop: 127.0.0.1
     BkLabel: NULL                BkNextHop: N/A
     SRLabel: NULL                Interface: InLoopBack0
   BkSRLabel: NULL              BkInterface: N/A
   Tunnel ID: Invalid           IPInterface: InLoopBack0
 BkTunnel ID: Invalid         BkIPInterface: N/A
     InLabel: NULL           ColorInterface: N/A
    SIDIndex: NULL         BkColorInterface: N/A
    FtnIndex: 0x0           TunnelInterface: N/A
TrafficIndex: N/A         BkTunnelInterface: N/A
   Connector: N/A                    PathID: 0x0
      UserID: 0x0                SRTunnelID: Invalid
    SID Type: N/A                       NID: Invalid
    FlushNID: Invalid                 BkNID: Invalid
  BkFlushNID: Invalid             StatFlags: 0x0
         SID: N/A
       BkSID: N/A
CommBlockLen: 0                    Priority: Critical
  MemberPort: N/A                  ExtFlags: 0x0
    UCMIndex: 0x0                  UserVLAN: 65535
      UCMMTU: 0                    BrasHash: 0
   SessionID: 0                 UserGroupID: 0
  IsoGroupID: 0                BkIsoGroupID: 0
 Destination: 1.1.1.0/24
    Protocol: Static
  Process ID: 0
   SubProtID: 0x0                       Age: 04h20m37s
        Cost: 0                  Preference: 60
         Tag: 0                       State: Active Adv
       NibID: 0x10000003             LastAs: 0
      AttrID: 0xffffffff
       Flags: 0x1008c           OrigNextHop: 192.168.47.4
       Label: NULL              RealNextHop: 192.168.47.4
     SRLabel: NULL                Interface: Ten-GigabitEthernet3/0/1
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet3/0/1
         SID: N/A
       BkSID: N/A
    Protocol: Static
  Process ID: 0
         Tag: 0                       State: Active Adv Derived
      AttrID: 0xffffffff
       Label: NULL              RealNextHop: 125.2.1.1
     SRLabel: NULL                Interface: Ten-GigabitEthernet3/0/2
   Tunnel ID: Invalid           IPInterface: Ten-GigabitEthernet3/0/2
         SID: N/A
       BkSID: N/A
# Display detailed routing table information for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1        Routes : 1
    Protocol: Direct
  Process ID: 0
   OrigTblID: 0x0                   OrigVrf: vpn1
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
VPN instance: vpn2
    Protocol: Static
  Process ID: 0
   OrigTblID: 0x0                   OrigVrf: vpn2
      AttrID: 0xffffffff
    SIDIndex: NULL                  InLabel: NULL
         SID: N/A
       BkSID: N/A
VPN instance
Destinations
Routes
Number of routes.
Destination
Protocol
Protocol that installed the route.
SubProtID
ID of the subprotocol for routing.
Age
Time for which the route has been in the routing table.
FlushedAge
Time for which the route has been flushed to the FIB.
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Tag
Route tag.
Route status:
·     Active—Active unicast route.
·     Adv—Route that can be advertised.
·     Inactive—Inactive route.
·     NoAdv—Route that the router is not allowed to advertise.
·     Vrrp—Routes generated by VRRP.
·     Nat—Routes generated by NAT.
·     TunE—Tunnel.
·     Derived—Derived route. If a route recurses to multiple related routes, all related routes except the first one are derived routes. The number of derived routes is not included in the total number of routes.
·     Backup—Backup route.
OrigTblID
Original routing table ID.
OrigVrf
Original VPN instance to which the route belongs. This field displays default-vrf if the route is on the public network.
TableID
ID of the routing table.
OrigAs
Original AS number.
NibID
ID of the next hop.
LastAs
Last AS number.
AttrID
Attribute ID.
BkAttrID
Attribute ID of the backup route.
This field displays only the attribute ID of the backup route added by BGP to the IP routing table.
Neighbor
Address of the neighbor determined by the routing protocol.
Flags
Flags of the route.
OrigNextHop
RealNextHop
Real next hop of the route.
BkLabel
Backup label.
BkNexthop
Backup next hop.
SRLabel
Segment routing (SR) label.
BkSRLabel
Backup SR label.
BkInterface
Backup output interface.
Tunnel ID
Tunnel ID
IPInterface
IP output interface.
BkTunnel ID
Backup tunnel ID.
BkIPInterface
Backup IP output interface.
InLabel
Incoming label of the route.
ColorInterface
Output interface recursed by an SR-MPLS TE policy or SRv6 TE policy.
SIDIndex
SID index value.
BkColorInterface
Backup output interface recursed by an SR-MPLS TE policy or SRv6 TE policy.
FtnIndex
Index of the FTN entry.
TunnelInterface
Output tunnel interface.
TrafficIndex
Traffic index in the range of 1 to 64. This field displays N/A when the value is invalid.
BkTunnelInterface
Backup output tunnel interface.
Connector
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if the BGP connector attribute is not supported.
Summary count
Number of routes.
PathID
Path ID.
UserID
Access user ID.
SRTunnelID
SR tunnel ID.
SID Type
SID type. If the route does not have an SID, this field displays N/A.
NID
Index of the Next Hop Label Forwarding Entry (Next Hop Label Forwarding Entry) flushed by the routing protocol.
FlushNID
Index of the NHLFE flushed to the FIB.
BkNID
Index of the backup NHLFE flushed by the routing protocol.
BkFlushNID
Index of the backup NHLFE flushed to the FIB.
StatFlags
Flags for SRv6 traffic statistics.
SID
Primary Segment Identifier (SID).
If no primary SID is available, this field displays N/A.
BkSID
Backup SID.
If no backup SID is available, this field displays N/A.
CommBlockLen
Common prefix length in the locator.
Priority
Convergence priority of the route:
·     Critical.
·     High.
·     Medium.
·     Low.
MemberPort
Number of a member port in an aggregation group.
If this attribute is not available, this field displays N/A.
ExtFlags
Extended route flags.
UCMIndex
UCM system resource index. For more information about UCM, see UCM configuration in BRAS Services Configuration Guide.
UserVLAN
UCM user outer VLAN.
UCMMTU
UCM MTU.
BrasHash
Hash value for the UCM load sharing algorithm.
SessionID
PPPoE user session ID.
UserGroupID
User group ID extended community attribute for BGP routes.
IsoGroupID
Pirmary APN isolation group ID. Value 0 indicates that the attribute is not available.
BkIsoGroupID
Backup APN isolation group ID. Value 0 indicates that the attribute is not available.
Use display ip routing-table acl to display information about routes permitted by a basic ACL.
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays routing information for the public network.
ipv4-acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic ACL.
If the specified ACL does not exist or has no rules configured, the command displays information about all routes.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24      Direct 0    0            192.168.1.111   XGE3/0/1
192.168.1.0/32      Direct 0    0            192.168.1.111   XGE3/0/1
192.168.1.111/32    Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.111   XGE3/0/1
For descriptions about the command output, see the command output description in "display ip routing-table."
# Display detailed information about all routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
 Destination: 192.168.1.0/24
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x1                       Age: 04h20m37s
      AttrID: 0xffffffff
       Flags: 0x10080           OrigNextHop: 192.168.1.111
       Label: NULL              RealNextHop: 192.168.1.111
         SID: N/A
       BkSID: N/A
 Destination: 192.168.1.0/32
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
       Flags: 0x1008c           OrigNextHop: 192.168.1.111
         SID: N/A
       BkSID: N/A
 Destination: 192.168.1.111/32
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
       Flags: 0x10004           OrigNextHop: 127.0.0.1
         SID: N/A
       BkSID: N/A
 Destination: 192.168.1.255/32
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
Use display ip routing-table ip-address to display information about routes to a specific destination address.
Use display ip routing-table ip-address1 to ip-address2 to display information about routes to a range of destination addresses.
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match | longest-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] fast-reroute ip-address [ mask-length | mask ]
ip-address: Specifies a destination IP address in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the IP address mask in dotted decimal notation.
longer-match: Displays the route entries that meet the matching rules as described in the usage guidelines.
longest-match: Displays the route entry with the longest matching mask that meets the matching rules as described in the usage guidelines.
ip-address1 to ip-address2: Specifies a destination IP address range.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays brief information about active routes.
Executing the command with different parameters yields different outputs.
·     display ip routing-table ip-address
¡     The system ANDs the entered destination IP address with the subnet mask in each active route entry.
¡     The system ANDs the destination IP address in each active route entry with its own subnet mask.
If the two operations yield the same result for an entry, the entry is displayed.
·     display ip routing-table ip-address mask
¡     The system ANDs the entered destination IP address with the entered subnet mask.
¡     The system ANDs the destination IP address in each active route entry with the entered subnet mask.
If the two operations yield the same result for an entry with a subnet mask not greater than the entered subnet mask, the entry is displayed.
·     display ip routing-table ip-address longer-match
¡     The system ANDs the entered destination IP address with the subnet mask in the following way:
-     If the entered IP address belongs to class A, B, or C, the system ANDs it with the default subnet mask of the corresponding class.
-     If the entered IP address is 0.0.0.0, the system ANDs it with the subnet mask 0.0.0.0.
-     Except the previous cases, for example, if the entered IP address is a multicast address or loopback address, the system ANDs it with the subnet mask 255.255.255.255.
¡     The system ANDs the destination IP address in each active route entry with the subnet mask of the entered IP address.
If the two operations yield the same result for multiple entries, all the entries are displayed.
·     display ip routing-table ip-address mask longer-match
·     display ip routing-table ip-address longest-match
If the two operations yield the same result for multiple entries, the entry with the longest matching mask is displayed.
·     display ip routing-table ip-address mask longest-match
If the two operations yield the same result for multiple entries with a subnet mask not greater than the entered subnet mask, the entry with the longest matching mask is displayed.
·     display ip routing-table ip-address1 to ip-address2
The system displays active route entries with destinations in the range of ip-address1/32 to ip-address2/32.
# Display brief information about the routes to the destination IP address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# Display brief information about the routes to the destination IP address 11.0.0.1 with mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# Display brief information about the routes to the destination IP address 11.0.0.1 with the default mask length for class A networks.
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# Display brief information about the routes to destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 5
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
3.3.3.0/24          Direct 0    0            3.3.3.1         XGE3/0/2
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1         XGE3/0/1
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
# Display fast reroute information about the routes to the destination IP address 3.3.3.3 with mask length 32.
<Sysname> display ip routing-table fast-reroute 3.3.3.3 32
Summary count : 1
                                           2.1.1.2         XGE3/0/2
# Display detailed information about the routes to the destination IP address 1.2.3.4.
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
 Destination: 1.2.3.4/32
    Protocol: BGP instance test
  Process ID: 0
   SubProtID: 0x1                       Age: 00h00m37s
        Cost: 0                  Preference: 255
     TableID: 0x2                    OrigAs: 200
       NibID: 0x15000000             LastAs: 200
      AttrID: 0x0
    BkAttrID: 0x0                  Neighbor: 192.168.47.2
       Flags: 0x10060           OrigNextHop: 192.168.47.2
       Label: NULL              RealNextHop: 192.168.47.2
         SID: N/A
       BkSID: N/A
Use display ip routing-table prefix-list to display routes permitted by an IP prefix list.
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all routes permitted by the IP prefix list. If you do not specify this keyword, the command displays brief information about active routes permitted by the IP prefix list.
If the specified IP prefix list does not exist, the command displays information about all routes.
# Create an IP prefix list named test to permit the route 1.1.1.0/24.
[Sysname] ip prefix-list test permit 1.1.1.0 24
# Display brief information about the active route permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24          Direct 0    0            1.1.1.2         XGE3/0/2
# Display detailed information about all routes permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
       Flags: 0x1008c           OrigNextHop: 1.1.1.2
       Label: NULL              RealNextHop: 1.1.1.2
         SID: N/A
       BkSID: N/A
Use display ip routing-table protocol to display information about routes installed by a protocol.
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ fast-reroute | inactive | verbose ]
protocol: Specifies a routing protocol.
inactive: Displays information about inactive routes. If you do not specify this keyword, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. If you do not specify this keyword, the command displays brief routing information.
# Display brief information about direct routes in the public network.
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
192.168.80.0/24     Direct 0    0            192.168.80.10   XGE3/0/1
192.168.80.0/32     Direct 0    0            192.168.80.10   XGE3/0/1
192.168.80.10/32    Direct 0    0            127.0.0.1       InLoop0
192.168.80.255/32   Direct 0    0            192.168.80.10   XGE3/0/1
Direct Routing table status : <Inactive>
Summary count : 0
# Display information about static routes in the public network.
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
3.0.0.0/8           Static 60   0            2.2.2.2        XGE3/0/1
# Display fast reroute information about static routes in the public network.
<Sysname> display ip routing-table protocol static fast-reroute
                                           2.1.1.2         XGE3/0/2
                                           2.1.1.2         XGE3/0/2
# Display detailed information about all BGP routes in the public network.
<Sysname> display ip routing-table protocol bgp verbose
Summary count : 1
 Destination: 1.1.1.2/32
    Protocol: BGP instance default
  Process ID: 0
   SubProtID: 0x6                       Age: 00h03m54s
       NibID: 0x16000000             LastAs: 200
      AttrID: 0x0
         SID: N/A
       BkSID: N/A
Use display ip routing-table record to display IPv4 route entry records.
display ip routing-table record flush [ destination-ip-address [ mask-length | mask ] ] [ delete | update ] [ verbose ]
display ip routing-table record notify [ destination-ip-address [ mask-length | mask ] ] [ delete | update ] [ verbose ]
display ip routing-table record receive [ destination-ip-address [ mask-length | mask ] ] [ add | delete | update ] [ verbose ]
flush: Displays the records for the route entries issued by the RIB to the FIB.
notify: Displays the records for the route entries notified by the RIB to the routing protocol.
receive: Displays the records for the route entries received by the RIB from the routing protocol.
destination-ip-address: Displays the records for the route entries with the specified destination network address in dotted decimal notation.
mask-length: Specifies the mask length of the destination network address, an integer in the range of 0 to 32.
mask: Specifies the mask of the destination network address, in dotted decimal notation.
add: Displays the records for the added route entries.
delete: Displays the records for the deleted route entries.
update: Displays the records for the updated route entries. If you specify the flush or notify keyword, the system takes added route entries as updated route entries when displaying the associated records.
verbose: Displays detailed information about IPv4 route entry records. If you do not specify this keyword, the command displays only brief information about IPv4 route entry records.
·     For the display ip routing-table record flush destination-ip-address, display ip routing-table record notify destination-ip-address, and display ip routing-table record receive destination-ip-address commands:
¡     The system ANDs the entered destination IP address with the subnet mask of each route entry in the records.
¡     The system ANDs the destination IP address of each route entry in the records with its own subnet mask.
·     For the display ip routing-table record flush destination-ip-address mask, display ip routing-table record notify destination-ip-address mask, and display ip routing-table record receive destination-ip-address mask commands:
¡     The system ANDs the destination IP address of each route entry in the records with the entered subnet mask.
If you do not specify the add, delete, or update keyword, the command displays records for the added, deleted, and updated route entries.
When the system enters the level-1 memory threshold alarm status, it stops recording new route entry information. When the system enters the level-3 memory threshold alarm status, it clears existing route entry records. When the system exits the level-1 memory threshold alarm status, it starts recording new route entry information again.
# Display brief information about the records for the route entries issued by the RIB to the FIB.
<Sysname> display ip routing-table record flush
Total number of records: 2
Date   Time         Action Destination/Mask/VNID/Vrf
210907 15:38:50:961 update 200.0.0.0/24/0x111000000/default-vrf
210907 15:40:13:331 delete 200.0.0.0/24/0x0/default-vrf
Total number of route entry records.
Date
Date when a record was generated.
Time
Time when the record was generated.
Action
Action on the route entry in the record:
·     update.
·     delete.
Destination
Destination address.
Mask
Mask length.
VNID
VN entry ID.
Vrf
Name of the VPN instance to which the route belongs. If the route belongs to the public network, this field displays default-vrf.
# Display detailed information about the records for the updated route entries issued by the RIB to the FIB.
<Sysname> display ip routing-table record flush update verbose
Total number of records: 1
Limit of records: 1000
        Time: 210907 15:38:50:961    Action: update
 Destination: 200.0.0.0/24
    VrfIndex: 0                     VrfName: default-vrf
 SrcVrfIndex: 0                    PriNibID: 0x0
      OrigAs: 0                      LastAs: 0
        VNID: 0x111000000            AttrId: 0xffffffff
       Flags: 0x10020000           ExtFlags: 0x0
       Label: 0xffffffff            BkLabel: 0xffffffff
   LabelType: None               InstanceId: 0
IpPrecedence: 65535              QosLocalId: 65535
TrafficIndex: 65535                  UserID: 0x0
   SessionID: 0                    AttrId64: 0xffffffffffffffff
Limit of records
Maximum number of route entry records.
Time
Date and time when a record was generated.
Action
·     update.
·     delete.
Destination
Destination address and mask length.
VrfIndex
VPN instance index.
VrfName
SrcVrfIndex
Index of the source VPN instance for the copied route.
PriNibID
SRv6 forwarding entry index.
OrigAs
Original AS number.
LastAs
Last AS number.
VNID
VN entry ID.
AttrId
Route attribute ID.
Flags
Flags of the route.
ExtFlags
Extended flags of the route.
Label
Label.
BkLabel
Backup label.
LabelType
Protocol generated the labels. Values include:
·     None—No label.
·     BGP—BGP protocol.
·     LDP—LDP protocol.
·     SLSP—SLSP protocol.
·     OSPF—OSPF protocol.
·     ISIS—IS-IS protocol.
·     Unknown—Unknown protocol.
InstanceId
ID of the multi-instance process.
IpPre
IP preference.
QosLocalID
Local QoS ID.
TrafficIndex
Traffic index. This field displays N/A when the value is invalid.
UserID
Access user ID.
SID Type
SID type.
VsiIndex
Index of the VSI to which the EVPN SRv6 SID belongs.
LinkId
Link ID of the L2VPN End.DX2 SID.
ArgLen
Arguments field length.
UCMIndex
UserVLAN
UCMMTU
UCM MTU.
BrasHash
SessionID
AttrId64
64-bit route attribute ID.
# Display brief information about the records for the route entries notified by the RIB to the routing protocol.
<Sysname> display ip routing-table record notify
Total number of records: 3
Date   Time         Action Destination/Mask/NibID/Vrf
210907 15:38:50:961 update 200.0.0.0/24/0x11000000/default-vrf
210907 15:39:46:496 update 200.0.0.0/24/0x11000000/default-vrf
210907 15:39:51:825 update 200.0.0.0/24/0x11000000/default-vrf
Table 5 Command output
Date
Time
Action
·     update.
·     delete.
Destination
Mask
Mask length.
NibID
ID of the next hop.
Vrf
# Display detailed information about the records for the deleted route entries notified by the RIB to the routing protocol.
<Sysname> display ip routing-table record notify delete verbose
        Time: 210908 09:22:11:460    Action: delete
 Destination: 200.0.0.0/8
     TableID: 0x2                     NibID: 0x0
      ActCnt: 0                  InactNibID: 0x0
 OldProtocol: STATIC            NewProtocol: UnSpec
       Flags: 0xc00                ExtFlags: 0x22
Table 6 Command output
Limit of records
Time
Action
·     add.
·     update.
·     delete.
Destination
TableID
ID of the routing table for the route.
NibID
Next hop ID.
ActCnt
Number of active routes using the route prefix.
InactNibID
Next hop ID of the inactive route reported to MPLS.
VrfIndex
VPN instance index.
VrfName
OldProtocol
Routing protocol reported by the route the previous time.
NewProtocol
Routing protocol reported by the route the current time.
Flags
Flags of the route.
ExtFlags
# Display brief information about the records for the route entries received by the RIB from the routing protocol.
<Sysname> display ip routing-table record receive
Date   Time         Action Proto      Destination/Mask/NibID/Vrf
210907 15:38:50:957 add    STATIC     200.0.0.0/24/0x11000000/default-vrf
210907 15:39:51:825 update STATIC     200.0.0.0/24/0x11000000/default-vrf
210907 15:40:13:329 delete STATIC     200.0.0.0/24/0x11000000/default-vrf
Table 7 Command output
Date
Time
Action
Action on the route entry:
·     add.
·     update.
·     delete.
Protocol
Routing protocol discovered the route.
Destination
Mask
Mask length.
PrefixLength
IPv6 address prefix length.
NibID
ID of the next hop.
Vrf
# Display detailed information about the records for the added route entries received by the RIB from the routing protocol.
<Sysname> display ip routing-table record receive add verbose
        Time: 210907 15:38:50:957    Action: add
     TableID: 0x2                 ProcessID: 0
    Protocol: STATIC              SubProtID: 0x1
    ModFlags: 0x0
       NibID: 0x11000000           NewNibID: N/A
      AttrID: 0xffffffff           BkAttrID: 0xffffffff
       Flags: 0x60                 ExtFlags: 0x0
  ResetFlags: 0x0             ResetExtFlags: 0x0
     SRLabel: 0xffffffff          BkSRLabel: 0xffffffff
     InLabel: 0xffffffff           SIDIndex: 0xffffffff
      CommID: 0x8000000                 Tag: 0
      UserID: 0x0                  SID Type: N/A
         SID: N/A
       BkSID: N/A
Table 8 Command output
Limit of records
Time
Action
·     add.
·     update.
·     delete.
Destination
TableID
Routing table ID of the route entry.
ProcessID
Process ID.
VrfIndex
VPN instance index.
VrfName
Protocol
SubProtID
Routing subprotocol ID.
NibID
Next hop ID.
NewNibID
ID of the updated next hop.
This field displays N/A if the attribute is not available.
AttrID
Route attribute ID.
BkAttrID
Attribute ID for the backup route.
This field displays the attribute ID for only the backup route added to the IP routing table through BGP.
Flags
Flags of the route.
ExtFlags
ResetFlags
Reset flags of the route upon an update.
This field displays 1 if any bit in the Flags field is changed.
ResetExtFlags
Reset extended flags of the route upon an update.
This field displays 1 if any bit in the ExtFlags field is changed.
ModFlags
Modified flags of the route.
Label
Label.
BkLabel
Backup label.
SRLabel
SR label.
BkSRLabel
Backup SR label.
InLabel
SIDIndex
SID index value.
CommID
Common informatin entry ID of the route.
Tag
Route tag.
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Connector
BGP Connector attribute.
In inter-AS option B MDT-based MVPN, the value for this field is the source PE address carried in the VPN IPv4 route exchanged between BGP peers. For more information about the BGP connector attribute, see multicast VPN in IP Multicast Configuration Guide.
PathID
Path ID.
UserID
Access user ID.
SID Type
SID
Primary SID. If no primary SID is available, this field displays N/A.
BkSID
Backup SID. If no backup SID is available, this field displays N/A.
UCMIndex
UserVLAN
UCMMTU
UCM MTU.
BrasHash
SessionID
UserGroupID
IsoGroupID
BkIsoGroupID
Use display ip routing-table statistics to display IPv4 route or route prefix statistics.
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
all-routes: Specifies the public network and all VPN instances.
all-vpn-instance: Specifies all VPN instances.
prefix: Displays IPv4 route prefix statistics. If you do not specify this keyword, the command displays IPv4 route statistics.
If you do not specify any parameters, this command displays IPv4 route statistics for the public network.
# Display IPv4 route statistics for the public network.
<Sysname> display ip routing-table statistics
Total prefixes: 15        Active prefixes: 15
Proto      Routes      Active      Added       Deleted
DIRECT     12          12          30          18
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      15          15          35          20
# Display IPv4 route statistics for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11        Active prefixes: 11
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# Display IPv4 route statistics for VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# Display IPv4 route statistics for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      11          11          13          2
# Display IPv4 route prefix statistics for the public network.
<Sysname> display ip routing-table prefix statistics
Proto      Prefixes    Active      Added       Deleted
DIRECT     7           7           7           0
STATIC     0           0           0           0
UNR        0           0           0           0
RIP        1           0           1           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
Total      8           7           8           0
Table 9 Command output
Proto
Protocol that installed the route or route prefix.
Routes
Number of routes installed by the protocol.
Prefixes
Number of route prefixes installed by the protocol.
Active
Number of active routes or route prefixes.
Added
Number of routes or route prefixes added to the routing table after the router started up or the routing table was cleared most recently.
Deleted
Number of routes or route prefixes marked as deleted, which will be cleared after a period.
Total
Total number of routes or route prefixes.
Use display ip routing-table summary to display brief routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ip routing-table [ all-routes [ vpn-instance vpn-instance-name ] summary
all-routes: Displays brief routing table information for the public network and all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief routing table information for the public network.
If you do not specify any parameters, this command displays brief routing table information for the public network.
# Display brief routing table information for the public network.
<Sysname> display ip routing-table summary
Max ECMP: 32
Max ECMP (ECMP FRR): 16
Max Active Route: 262144
Remain Active Route: 262126
# Display brief routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 32
Remain Active Route: 262134
Threshold value percentage of max active routes: 100%
Table 10 Command output
Max ECMP
Maximum number of ECMP routes supported by the device in non-IS-IS scenarios that have multiple primary and backup links.
Max ECMP (ECMP FRR)
Maximum number of ECMP routes supported by the device in IS-IS scenarios that have multiple primary and backup links. For more information about the scenarios, see IS-IS configuration in Layer 3—IP Routing Configuration Guide.
Max Active Route
Maximum number of supported routes.
Remain Active Route
Number of the remaining inactive routes.
Threshold value xxx
Alarm threshold of active routes specified by using the routing-table limit command in a VPN instance:
·     Threshold value of active routes alert—This field is displayed when the alarm threshold is specified by using the routing-table limit number simply-alert command. When the number of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes.
·     Threshold value percentage of max active routes—This field is displayed when the alarm threshold is specified by using the routing-table limit number warn-threshold command, in the range of 1 to 100 in percentage. When the percentage of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes. If the number of active routes reaches the maximum number, no more routes can be added. The percentage of active routes equals the number of active routes divided by the maximum number of active routes supported in a VPN instance, and multiplied by 100.
Use display ipv6 rib attribute to display route attribute information in the IPv6 RIB.
attribute-id: Specifies a route attribute by its ID, a hexadecimal string in the range of 0 to FFFFFFFFFFFFFFFF.
# Display route attribute information in the IPv6 RIB.
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
                  Flag: 0x0
              Protocol: BGP4+ instance default
        Address family: IPv6
       Reference count: 0
      Local preference: 0
Ext-communities number: 0
 Ext-communities value: N/A
  Ext-comm-ipv6 number: 1
   Ext-comm-ipv6 value: <RT Import: 303::3:9>
    Communities number: 1
     Communities value: IDF Negotiation
        AS-path number: 0
         AS-path value: N/A
For command output, see the command output description in "display rib attribute."
Use display ipv6 rib graceful-restart to display IPv6 RIB GR state information.
# Display IPv6 RIB GR state information.
<Sysname> display ipv6 rib graceful-restart
RIB GR state     : Phase2-calculation end
RCOM GR state    : Flush end
Protocol GR state:
 No.  Protocol   Lifetime FD   State    Start/End
 1    DIRECT     900      29   End      No/No
 2    STATIC     900      32   End      No/No
 3    ISISV6     900      30   End      No/No
 4    BGP4+ instance default
                 900      31   End      No/No
 5    BGP4+ instance ebcdefg
                 900      32   End      No/No
For command output, see the command output description in "display rib graceful-restart."
Use display ipv6 rib nib to display next hop information in the IPv6 RIB.
display ipv6 rib nib [ sub-nib nib-id ] [ verbose ]
display ipv6 rib nib protocol protocol [ fast-reroute ] [ verbose ]
self-originated: Displays information about next hops of self-originated routes in the IPv6 RIB.
sub-nib nib-id: Specifies a sub-NIB by its ID to display information about its parent NIB.
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 0 to ffffffff.
verbose: Displays detailed next hop information in the IPv6 RIB. If you do not specify this keyword, the command displays brief next hop information in the IPv6 RIB.
protocol protocol: Specifies a protocol by its name.
fast-reroute: Displays next hop information about fast rerouting.
# Display brief next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
      NibID: 0x20000000        Sequence: 0
       Type: 0x1                Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: ::
    IFIndex: 0x111            LocalAddr: ::
 MemberPort: 0x0
   TopoNthp: Invalid           ExtType1: 0x0
   ExtType2: 0x0
      Color: 0                   COFlag: 0x0
   SIDIndex: 0x0                SRPName:
 OriNexthop: ::
    SAIndex: 0xffffffff
      NibID: 0x20000001        Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: ::1
    IFIndex: 0x112            LocalAddr: ::1
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: ::
    SAIndex: 0xffffffff
# Display detailed next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib verbose
        Age: 00h01m50s
 MemberPort: N/A
   ExtType2: 0x0
 OriNexthop: ::
    SAIndex: 0xffffffff
     RefCnt: 4              FlushRefCnt: 1
       Flag: 0x84               Version: 1
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::
  RelyDepth: 0              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0                    Flags: 0x0
SRPolicyNID: 4294967295     SRInterface:
ColorWeight: 0                  Locator: N/A
 MemberPort: 0x0                uiFlags: 0x0
    SAIndex: 0xffffffff
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: ::
    SAIndex: 0xffffffff
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::1
  RelyDepth: 0              RealNexthop: ::1
  Interface: InLoop0          LocalAddr: ::1
 MemberPort: N/A                uiFlags: 0x0
    SAIndex: 0xffffffff
 MetricFlag: 0x00000001          Metric: 20
For command output, see the command output description in "display rib nib."
Use display ipv6 rib nib record to display next hop records in the IPv6 RIB.
display ipv6 rib nib record flush [ nib-id ] [ delete | update ] [ verbose ]
display ipv6 rib nib record receive [ nib-id ] [ add | delete | update ] [ verbose ]
flush: Displays the records for the next hops issued by the IPv6 RIB to the FIB.
receive: Displays the records for the next hops received by the IPv6 RIB from the routing protocol.
nib-id: Displays the records for a NIB ID, a hexadecimal string in the range of 0 to ffffffff. If you do not specify this argument, the command displays the records for all NIB IDs.
add: Displays the records for the added next hops.
delete: Displays the records for the deleted next hops.
update: Displays the records for the updated next hops. If you specify the flush keyword, the system takes added next hops as updated next hops when displaying the associated records.
verbose: Displays detailed information about next hop records. If you do not specify this keyword, the command displays only brief information about next hop records.
If you do not specify the add, delete, or update keyword, the command displays records for the added, deleted, and updated next hops.
When the system enters the level-1 memory threshold alarm status, it stops recording new next hop information. When the system enters the level-3 memory threshold alarm status, it clears existing next hop records. When the system exits the level-1 memory threshold alarm status, it starts recording new next hop information again.
# Display brief information about the records for the next hops issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 rib nib record flush
Date   Time         Action VNID
210908 15:31:55:364 update 0x20000000
210908 15:31:55:364 update 0x120000001
For descriptions about the command output, see the command output description in "display rib nib record."
# Display detailed information about the records for the updated next hops issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 rib nib record flush update verbose
        Time: 210908 15:31:55:364    Action: update
       NibID: 0x20000000               VNID: 0x20000000
    Sequence: 0                     Version: 1
       Flags: 0x80                 ExtFlags: 0x0
        Type: 0xd
    VrfIndex: 0                     Nexthop: ::
     IfIndex: 1410                LocalAddr: ::
  MemberPort: 0
    ExtType1: 0x0               NibInstance: IFM
    ExtType2: 0x0
    UserKey0: 0x0                  UserKey1: 0x0
      NewUK0: 0x0                    NewUK1: 0x0
      NewUK2: 0x0                    NewUK3: 0x0
      NewUK4: 0x0                    NewUK5: 0x0
      NewUK6: 0x0                    NewUK7: 0x0
    SIDIndex: 0x0              SrPolicyName:
       Color: 0                  OriNexthop: ::
      COFlag: 0x0                   Locator: N/A
     SAIndex: 0xffffffff
 1 nexthop(s):
   Interface: 258                 LocalAddr: ::
    VrfIndex: 0                    Topology:
      Weight: 0                       Flags: 0x800
 SRPolicyNID: 4294967295        SRInterface: 0
  MemberPort: 0               SRL2Interface: 0
     uiFlags: 0x0                   SAIndex: 0xffffffff
       NibID: 0x20000001               VNID: 0x120000001
    Sequence: 1                     Version: 1
        Type: 0x1
    VrfIndex: 0                     Nexthop: ::1
     IfIndex: 1410                LocalAddr: ::1
  MemberPort: 0
    ExtType2: 0x0
     SAIndex: 0xffffffff
 1 nexthop(s):
# Display brief information about the records for the next hops received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 rib nib record receive
Date   Time         Action NibID      NibInstance
210908 10:45:35:211 add    0x21000000 USR
210908 10:45:35:215 update 0x21000000 USR
210908 10:49:47:785 delete 0x21000000 USR
# Display detailed information about the records for the added next hops received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 rib nib record receive add verbose
        Time: 210928 14:39:14:147    Action: add
 NibInstance: IFM                   Version: 1
        Flag: 0x0                   UsrData: 0xffffffffffffffff
        Type: 0x1                  ExtType1: 0x0
    ExtType2: 0x0
  InstanceId: 0                     Nexthop: ::1
   L2IfIndex: 0
   BandWidth: 0                      Weight: 0
   ProtNibID: 0xffffffff           NibFlags: 0x0
     SAIndex: 0xffffffff
 1 nexthop(s):
   Interface: 1410                LocalAddr: ::1
Use display ipv6 route-direct nib to display next hop information for IPv6 direct routes.
verbose: Displays detailed next hop information for IPv6 direct routes. If you do not specify this keyword, the command displays brief next hop information for IPv6 direct routes.
# Display brief next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: ::
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: ::
# Display detailed next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib verbose
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: ::
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x2                Version: 1
    ExtFlag: 0x0
 1 nexthop(s):
    SliceId: 0
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: ::
    ExtFlag: 0x0
 1 nexthop(s):
    SliceId: 0
For command output, see the command output description in "display route-direct nib."
Use display ipv6 routing-table to display IPv6 routing table information.
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ priority { critical | high | low | medium } ] [ verbose ]
display ipv6 routing-table all-routes
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] fast-reroute
all-vpn-instance: Displays IPv6 routing table information for all VPN instances.
all-routes: Displays IPv6 routing table information for the public network and all VPN instances.
If you do not specify any parameters, this command displays IPv6 routing table information for the public network, excluding fast reroute routing table information.
# Display brief information about all active routes in the public network.
<Sysname> display ipv6 routing-table
Destinations : 3 Routes : 3
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 5000::1:0:1/128                             Protocol  : SRv6
NextHop    : ::1                                         Preference: 4
Interface  : policy1                                     Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
# Display brief information about active routes in the IPv6 routing table for the public network and all VPN instances.
<Sysname> display ipv6 routing-table all-routes
VPN instance: vpn1
Destination: 1:2::3:4/128                                Protocol  : Static
NextHop    : ::                                          Preference: 60
Interface  : NULL0                                       Cost      : 0
# Display brief IPv6 routing table information for all VPN instances.
<Sysname> display ipv6 routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
# Display brief IPv6 fast reroute information in the public network.
<Sysname> display ipv6 routing-table fast-reroute
Destination: 3::/64                                      Protocol  : Static
NextHop    : 11::2                                       Preference: 60
Interface  : XGE3/0/1                                     Cost      : 0
NextHop    : 12::2                                       Preference:
Interface  : XGE3/0/2                                     Cost      :
Table 11 Command output
VPN instance
Public network and VPN instance to which the IPv6 routing table belongs. For the public network, this filed displays public instance. For a VPN instance, this command displays the name of the instance.
Destinations
Routes
Number of routes.
Destination
IPv6 address and prefix of the destination network or host.
NextHop
Preference
Output interface for packets to be forwarded along the route. (If the protocol is SRv6 and the forwarding tunnel is SRv6 TE policy, this field displays the policy name.)
Protocol
Cost
Cost of the route.
Summary count
Number of routes.
<Sysname> display ipv6 routing-table verbose
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 19h23m02s
     TableID: 0xa                    OrigAs: 0
       NibID: 0x20000000             LastAs: 0
      AttrID: 0xffffffff
    BkAttrID: 0xffffffff           Neighbor: ::
       Flags: 0x10004           OrigNextHop: ::1
       Label: NULL              RealNextHop: ::1
         SID: N/A
       BkSID: N/A
 Destination: 12::/96
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 00h01m47s
       NibID: 0x20000003             LastAs: 0
      AttrID: 0xffffffff
       Flags: 0x10080           OrigNextHop: ::
         SID: N/A
       BkSID: N/A
    Protocol: SRv6
  Process ID: 0
        Cost: 0                  Preference: 4
       NibID: 0x20000002             LastAs: 0
      AttrID: 0xffffffff
       Flags: 0x10000           OrigNextHop: ::1
     SRLabel: NULL                Interface: policy1
   Tunnel ID: Invalid           IPInterface: NULL0
    SID Type: End                       NID: 0x80300001
    FlushNID: 0x80300001              BkNID: Invalid
         SID: N/A
       BkSID: N/A
# Display detailed IPv6 routing table information for all VPN instances.
<Sysname> display ipv6 routing-table all-vpn-instance verbose
VPN instance: vpn1
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
 Destination: 12::1/128
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 00h01m45s
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
    Protocol: SRv6
  Process ID: 0
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
Table 12 Command output
VPN instance
Destination
Protocol
SubProtID
Age
FlushedAge
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Tag
Tag of the route.
Route status:
·     TunE—Tunnel.
OrigTblID
OrigVrf
TableID
OrigAs
Original AS number.
NibID
ID of the next hop.
LastAs
Last AS number.
AttrID
Attribute ID.
BkAttrID
Neighbor
Flags
Flags of the route.
OrigNextHop
RealNextHop
BkLabel
Backup label.
BkNexthop
Backup next hop.
SRLabel
SR label.
BkSRLabel
Backup SR label.
BkInterface
Backup output interface. (If the protocol is SRv6 and the forwarding tunnel is SRv6 TE policy, this field displays the policy name.)
Tunnel ID
Tunnel ID
IPInterface
IP output interface for packets to be forwarded along the route.
BkTunnel ID
Backup tunnel ID.
BkIPInterface
InLabel
ColorInterface
SIDIndex
SID index value.
BkColorInterface
FtnIndex
TunnelInterface
TrafficIndex
BkTunnelInterface
Connector
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if BGP connector attribute is not supported.
PathID
Path ID.
Summary count
Number of routes.
UserID
Access user ID.
SRTunnelID
SR tunnel ID.
SID Type
NID
FlushNID
BkNID
BkFlushNID
StatFlags
SID
BkSID
Backup SID.
CommBlockLen
Priority
·     Critical.
·     High.
·     Medium.
·     Low.
MemberPort
ExtFlags
UCMIndex
UserVLAN
UCMMTU
UCM MTU.
BrasHash
SessionID
UserGroupID
IsoGroupID
BkIsoGroupID
Use display ipv6 routing-table acl to display routing information permitted by an IPv6 basic ACL.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic IPv6 ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic IPv6 ACL.
If the specified IPv6 ACL does not exist or has no rules configured, the command displays information about all IPv6 routes.
# Display brief information about active routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Summary count : 5
Destination : ::1/128                                    Protocol  : Direct
Destination: 12::/96                                     Protocol  : Direct
Interface  : XGE3/0/2                                    Cost      : 0
Destination: 12::1/128                                   Protocol  : Direct
Destination: FF::11/128                                  Protocol  : BGP4+
NextHop    : 12::2                                       Preference: 255
For descriptions about the command output, see the command output description in "display ipv6 routing-table."
# Display detailed information about all routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 5
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 19h29m12s
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 00h07m57s
      AttrID: 0xffffffff
 BkTunnel ID: Invalid         IPBkInterface: N/A
         SID: N/A
       BkSID: N/A
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 00h07m55s
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
  Process ID: 0
   SubProtID: 0x6                       Age: 00h06m43s
     TableID: 0xa                    OrigAs: 200
       NibID: 0x26000000             LastAs: 200
      AttrID: 0x1
    BkAttrID: 0x1                  Neighbor: 12::2
       Flags: 0x10060           OrigNextHop: 12::2
       Label: NULL              RealNextHop: 12::2
         SID: N/A
       BkSID: N/A
    Protocol: Direct
  Process ID: 0
      AttrID: 0xffffffff
       Flags: 0x10084           OrigNextHop: ::
         SID: N/A
       BkSID: N/A
Use display ipv6 routing-table ipv6-address to display information about routes to an IPv6 destination address.
Use display ipv6 routing-table ipv6-address1 to ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match | longest-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] fast-reroute ipv6-address [ prefix-length ]
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
ipv6-address1 to ipv6-address2: Specifies a destination IPv6 address range.
Executing the command with different parameters yields different output.
·     display ipv6 routing-table ipv6-address
¡     The system ANDs the entered destination IPv6 address with the prefix length in each active route entry.
¡     The system ANDs the destination IPv6 address in each active route entry with the prefix length in the entry.
·     display ipv6 routing-table ipv6-address prefix-length
¡     The system ANDs the entered destination IPv6 address with the entered prefix length.
¡     The system ANDs the destination IPv6 address in each active route entry with the entered prefix length.
If the two operations yield the same result for an entry with a prefix length not greater than the entered prefix length, the entry is displayed.
·     display ipv6 routing-table ipv6-address longer-match
If you do not specify the prefix-length argument, the command yields the same result as the display ipv6 routing-table command.
·     display ipv6 routing-table ipv6-address prefix-length longer-match
·     display ipv6 routing-table ipv6-address longest-match
If the two operations yield the same result for multiple entries, the entry with the longest matching prefix is displayed.
·     display ipv6 routing-table ipv6-address prefix-length longest-match
If the two operations yield the same result for multiple entries with a prefix length not greater than the entered prefix length, the entry with the longest matching prefix is displayed.
·     display ipv6 routing-table ipv6-address1 to ipv6-address2
The system displays route entries with destinations in the range of ipv6-address1/128 to ipv6-address2/128.
# Display brief information about the routes to the destination IPv6 address 10::1 127.
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64                                     Protocol  : Static
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# Display brief information about the routes to the destination IPv6 address 10::1 with prefix length 127.
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# Display brief information about the routes to destination addresses in the range of 100:: to 300::.
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
# Display brief fast reroute information about the routes to the destination IPv6 address 3:: with a prefix length of 32.
<Sysname> display ipv6 routing-table fast-reroute 3:: 32
Summary count : 1
Destination: 3::/32                                      Protocol  : Static
# Display detailed information about the routes to destination IPv6 addresses 1:2::3:4/128.
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
    Protocol: BGP4+ instance abc
  Process ID: 0
   SubProtID: 0x1                       Age: 00h01m14s
     TableID: 0x1                    OrigAs: 200
      AttrID: 0x0
    BkAttrID: 0x0                  Neighbor: 2:2::3:4
       Flags: 0x10060           OrigNextHop: 2:2::3:4
       Label: NULL              RealNextHop: 2:2::3:4
         SID: N/A
       BkSID: N/A
Use display ipv6 routing-table prefix-list to display information about IPv6 routes permitted by an IPv6 prefix list.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all IPv6 routes permitted by the IPv6 prefix list. If you do not specify this keyword, the command displays brief information about active IPv6 routes permitted by the IPv6 prefix list.
If the specified IPv6 prefix list does not exist, the command displays information about all routes.
# Create an IPv6 prefix list named test to permit the prefix ::1/128.
[Sysname] ipv6 prefix-list test permit ::1 128
# Display brief information about the active IPv6 route permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
# Display detailed information about all routes permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
    Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                       Age: 08h57m19s
      AttrID: 0xffffffff
         SID: N/A
       BkSID: N/A
Use display ipv6 routing-table protocol to display information about IPv6 routes installed by a protocol.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ fast-reroute | inactive | verbose ]
# Display brief information about IPv6 direct routes in the public network.
<Sysname> display ipv6 routing-table protocol direct
Summary count : 2
Summary count : 2
Summary count : 0
# Display information about IPv6 static routes in the public network.
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128                                    Protocol  : Static
NextHop    : fe80::2                                     Preference: 60
NextHop    : fe80::3                                     Preference: 60
Destination: 3::3/128                                    Protocol  : Static
NextHop    : 2::2                                        Preference: 60
Summary count : 0
# Display fast reroute information about IPv6 static routes in the public network.
<Sysname> display ipv6 routing-table protocol static fast-reroute
NextHop    : 12::2                                       Preference: 60
# Display detailed information about all IPv6 BGP routes in the public network.
<Sysname> display ipv6 routing-table protocol bgp4+ verbose
Summary count : 1
 Destination: 22::22/128
  Process ID: 0
   SubProtID: 0x6                       Age: 00h04m15s
       NibID: 0x25000001             LastAs: 200
      AttrID: 0x3
    BkAttrID: 0x3                  Neighbor: 121::2
       Flags: 0x10060           OrigNextHop: 121::2
       Label: NULL              RealNextHop: 121::2
         SID: N/A
       BkSID: N/A
display ipv6 routing-table record
Use display ipv6 routing-table record to display IPv6 routing entry records.
display ipv6 routing-table record flush [ destination-ipv6-address [ prefix-length ] ] [ delete | update ] [ verbose ]
display ipv6 routing-table record notify [ destination-ipv6-address [ prefix-length ] ] [ delete | update ] [ verbose ]
display ipv6 routing-table record receive [ destination-ipv6-address [ prefix-length ] ] [ add | delete | update ] [ verbose ]
flush: Displays the records for the route entries issued by the IPv6 RIB to the FIB.
notify: Displays the records for the route entries notified by the IPv6 RIB to the routing protocol.
receive: Displays the records for the route entries received by the IPv6 RIB from the routing protocol.
destination-ipv6-address: Displays the records for the route entries with the specified destination network IPv6 address.
prefix-length: Specifies the prefix length of the destination network IPv6 address, an integer in the range of 0 to 128.
verbose: Displays detailed information about IPv6 route entry records. If you do not specify this keyword, the command displays only brief information about IPv6 route entry records.
·     For the display ipv6 routing-table record flush destination-ipv6-address, display ipv6 routing-table record notify destination-ipv6-address, and display ipv6 routing-table record receive destination-ipv6-address:
¡     The system ANDs the entered destination IPv6 address with the prefix length of each route entry in the records.
¡     The system ANDs the destination IPv6 address of each route entry in the records with its own prefix length.
·     For the display ipv6 routing-table record flush destination-ipv6-address prefix-length, display ipv6 routing-table record notify destination-ipv6-address prefix-length, and display ipv6 routing-table record receive destination-ipv6-address prefix-length commands:
¡     The system ANDs the destination IPv6 address of each route entry in the records with the entered prefix length.
# Display brief information about the records for the route entries issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 routing-table record flush
Date   Time         Action Destination/PrefixLength/VNID/Vrf
210908 09:33:21:996 update 1001::/64/0x520000004/default-vrf
210908 09:33:23:386 update 1001::1/128/0x120000001/default-vrf
For descriptions about the command output, see the command output description in "display ip routing-table record."
# Display detailed information about the records for the updated route entries issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 routing-table record flush update verbose
        Time: 210908 09:33:21:996    Action: update
 Destination: 1001::/64
      OrigAs: 0                      LastAs: 0
        VNID: 0x520000004
       Flags: 0x10040000           ExtFlags: 0x0
   FlowIndex: 65535                  UserID: 0x0
    SID Type: 0                    VsiIndex: 0xffffffff
      LinkId: 0xffffffff             ArgLen: 0
  InstanceId: 0                      AttrId: 0xffffffff
        Time: 210908 09:33:23:386    Action: update
 Destination: 1001::1/128
      OrigAs: 0                      LastAs: 0
        VNID: 0x120000001
# Display brief information about the records for the route entries notified by the IPv6 RIB to the routing protocol.
<Sysname> display ipv6 routing-table record notify
Date   Time         Action Destination/PrefixLength/NibID/Vrf
210908 10:47:03:698 update 2000::/64/0x21000000/default-vrf
# Display detailed information about the records for the deleted route entries notified by the IPv6 RIB to the routing protocol.
<Sysname> display ipv6 routing-table record notify delete verbose
        Time: 210908 10:49:47:787    Action: delete
 Destination: 2000::/64
     TableID: 0xa                     NibID: 0x0
     RtFlags: 0xc00              ExtRtFlags: 0x22
# Display brief information about the records for the route entries received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 routing-table record receive
Date   Time         Action Proto      Destination/PrefixLength/NibID/Vrf
210908 09:33:23:385 add    DIRECT     1001::1/128/0x20000001/default-vrf
# Display detailed information about the records for the added route entries received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 routing-table record receive add verbose
        Time: 210908 09:33:23:385    Action: add
     TableID: 0xa                 ProcessID: 0
    Protocol: DIRECT              SubProtID: 0x0
    ModFlags: 0x0
       NibID: 0x20000001           NewNibID: N/A
       Flags: 0x4                  ExtFlags: 0x0
      CommID: 0x5000001                 Tag: 0
         SID: N/A
       BkSID: N/A
display ipv6 routing-table statistics
Use display ipv6 routing-table statistics to display IPv6 route or route prefix statistics.
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
prefix: Displays IPv6 route prefix statistics. If you do not specify this keyword, the command displays IPv6 route statistics.
If you do not specify any parameters, this command displays IPv6 route statistics for the public network.
# Display IPv6 route statistics for the public network.
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8        Active prefixes: 8
DIRECT     5           5           5           0
STATIC     3           3           3           0
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
Total      8           8           8           0
# Display IPv6 route statistics for the public network and all VPN instances.
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6        Active prefixes: 6
DIRECT     3           3           3           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
Total      6           6           8           2
# Display IPv6 route statistics for VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
Total      11          11          13          2
# Display IPv6 route statistics for all VPN instances.
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
Total      11          11          13          2
# Display IPv6 route prefix statistics for the public network.
<Sysname> display ipv6 routing-table prefix statistics
DIRECT     5             5           5           0
STATIC     1             1           1           0
UNR        0           0           0           0
RIPng      0             0           0           0
OSPFv3     0             0           0           0
IS-ISv6    0             0           0           0
LISP       0             0           0           0
SRv6       0             0           0           0
BGP4+      0             0           0           0
Total      6             6           6           0
Table 13 Command output
Proto
Routes
Prefixes
Active
Added
Deleted
Total
display ipv6 routing-table summary
Use display ipv6 routing-table summary to display brief IPv6 routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief IPv6 routing table information for the public network.
# Display brief IPv6 routing table information for the public network.
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
For descriptions about the command output, see the command output description in "display ip routing-table summary."
# Display brief IPv6 routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
Threshold value of active routes alert: 65100
Use display rib attribute to display route attribute information in the RIB.
# Display route attribute information in the RIB.
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
                  Flag: 0x0
        Address family: IPv4
       Reference count: 0
Act-RT reference count: 0
            Flush flag: 0
      Local preference: 0
Ext-communities number: 26
 Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
                        > <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
                        : 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
                         <RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
                        13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
    Communities number: 0
     Communities value: N/A
        AS-path number: 0
         AS-path value: N/A
  SFlow AS-path length: 0
   SFlow AS-path value: N/A
Detailed information of attribute 0x1:
                  Flag: 0x0
              Protocol: BGP
       Reference count: 0
            Flush flag: 0
      Local preference: 0
 Ext-communities value: <RT: 1.1.1.1:2> <SrcAs 100:0>
        AS-path number: 0
         AS-path value: N/A
Table 14 Command output
Protocol
Protocol that generates the attribute.
Reference count of active routes.
Flush flag
Flag of flushing route attribute information to the FIB:
·     0—The route attribute information is not flushed to the FIB.
·     1—The route attribute information is flushed to the FIB.
Number of the IPv4 extended community attribute values.
Values of the IPv4 extended community attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values.
Number of the IPv6 extended community attribute values.
Ext-comm-ipv6 value
Values of the IPv6 extended community attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values.
Communities number
Number of the COMMUNITY attribute values.
Communities value
Values of the COMMUNITY attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values.
AS-path number
Number of ASs in the AS_PATH attribute.
AS-path value
Values of the AS_PATH attribute, including AS_SET, AS_SEQUENCE, confederation AS_SET, and confederation AS_SEQUENCE. This field displays N/A when no values exist, and it can display a maximum of 20 values.
Length of the sFlow AS-path attribute.
SFlow AS-path value
Value of the sFlow AS-path attribute. This field displays N/A if the length of the sFlow AS-path attribute is 0. This field can display a maximum of 20 characters.
Use display rib graceful-restart to display RIB GR state information.
# Display RIB GR state information.
<Sysname> display rib graceful-restart
Protocol GR state:
 1    DIRECT     900      30   End      No/No
 2    STATIC     900      34   End      No/No
 3    OSPF       900      36   End      No/No
 4    ISIS       900      32   End      No/No
 5    BGP instance abc
                 900      22   End      No/No
 6    BGP instance default
                 900      25   End      No/No
 7    LDP        900      35   End      No/No
 8    SLSP       900      29   End      No/No
 9    UNR instance UCM
                 900      33   End      No/No
Table 15 Command output
RIB GR state
RIB GR status:
·     Start—GR starts.
·     IGP end—All IGP protocols complete GR.
·     VPN-triggering end—Optimal route selection triggered by VPN routes completes.
·     VPN-calculation end—Optimal VPN route selection completes.
·     Routing protocol end—All routing protocols complete GR.
·     NSR-calculation unfinished—NSR has not finished optimal route selection.
·     Triggering start—All triggered optimal route selection starts.
·     Triggering end—All triggered optimal route selection completes.
·     Phase1-calculation end—Optimal route selection phase 1 completes.
·     All end—All protocols complete GR.
·     Phase2-calculation end—Optimal route selection phase 2 completes.
RCOM GR state
RCOM GR status:
·     Start—GR starts.
·     VPN-notification end—VPN routes have been delivered to the route management module.
·     Notification end—All routes have been delivered to the route management module.
·     Flush start—Starts to flush routes to the FIB.
·     Flush end—Completes flushing routes to the FIB.
No.
Protocol number.
Lifetime
Lifetime (in seconds) of routes/labels in the RIB during GR.
FD
Handle between the protocol and the RIB.
Protocol GR state:
·     Init—Initialization state.
·     Listen—Listening state.
·     Idle.
·     Active.
·     Start—GR starts.
·     End—GR completes.
Start/End
Message sending state:
·     No—The message has not been sent.
·     Yes—The message has been sent.
display rib nib
Use display rib nib to display next hop information in the RIB.
display rib nib [ sub-nib nib-id ] [ verbose ]
display rib nib protocol protocol [ fast-reroute ] [ verbose ]
self-originated: Displays information about next hops of self-originated routes in the RIB.
verbose: Displays detailed next hop information in the RIB. If you do not specify this keyword, the command displays brief next hop information in the RIB.
If you do not specify any parameters, this command displays brief information about all next hops in the RIB.
# Display brief next hop information in the RIB.
<Sysname> display rib nib
Total number of nexthop(s): 176
      NibID: 0x10000000        Sequence: 0
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 0.0.0.0
    IFIndex: 0x111            LocalAddr: 0.0.0.0
 MemberPort: 0x0
   TopoNthp: 0                 ExtType1: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
    SAIndex: 0xffffffff
      NibID: 0x10000001        Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 127.0.0.1
    IFIndex: 0x112            LocalAddr: 127.0.0.1
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
    SAIndex: 0xffffffff
      NibID: 0x10000002        Sequence: 2
       Type: 0x5                Flushed: Yes
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
    SAIndex: 0xffffffff
      NibID: 0x16000000        Sequence: 3
       Type: 0x21               Flushed: No
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 12.1.1.2
    IFIndex: 0x0              LocalAddr: 0.0.0.0
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
   Instance: abc
    SAIndex: 0xffffffff
      NibID: 0x16000002        Sequence: 4
       Type: 0x1010             Flushed: Yes
        Age: 08h38m37s
    SubType: 0x4
   SubNibID: 0x16000003          SubSeq: 3
    NthpCnt: 1                    Samed: 0
   NthpType: MPLS               SliceID: 4
   Instance: default
   SubNibID: 0x16000002          SubSeq: 12
    NthpCnt: 1                    Samed: 0
   NthpType: MPLS               SliceID: Invalid
   Instance: default
Table 16 Command output
NibID
ID of the next hop.
Sequence
Sequence number of the next hop.
Type of the next hop.
Flushed
Indicates whether the route with the next hop has been flushed to the FIB.
Age
Time when the next hop was updated most recently.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network.
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
Local interface address.
MemberPort
Index of a member port in an aggregation group.
NewUK0
New reserved data 1.
This field is not displayed if the attribute is not available.
NewUK1
New reserved data 2.
NewUK2
New reserved data 3.
NewUK3
New reserved data 4.
NewUK4
New reserved data 5.
NewUK5
New reserved data 6.
NewUK6
New reserved data 7.
NewUK7
New reserved data 8.
NewUK8
New reserved data 9.
NewUK9
New reserved data 10.
NewUK10
New reserved data 11.
NewUK11
New reserved data 12.
NewUK12
New reserved data 13.
TopoNthp
Non-base topologies are not supported in the current software version.
Index of the topology that contains the next hop. This field displays 0 if the next hop is on the IPv4 public network. This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies.
ExtType1
The first extension type of the next hop.
ExtType2
The second extension type of the next hop.
Color
Color extended community attribute.
COFlag
Flag of the color extended community attribute.
SIDIndex
SID index value.
SRPName
SR-MPLS TE policy name.
OriNexthop
Original next hop address of the route.
If the route is obtained from a BGP UPDATE message, the address is the next hop IP address in the BGP UPDATE message.
Instance
BGP instance name.
SubType
Type of the sub-next hop.
SubNibID
ID of the sub-next hop.
SubSeq
Sequence number of the sub-next hop.
NthpCnt
Number of sub-next hops.
Samed
Number of the same sub-next hops.
NthpType
Type of the sub-next hop:
·     IP—IP forwarding.
·     MPLS—MPLS forwarding.
SliceID
Network slice instance (NSI) ID.
SAIndex
Security association (SA) index number for the IP prefix route used to perform IPsec encryption for packets with the associated SA parameter settings. When no SA index number exists, this field displays an all-f value.
# Display detailed next hop information in the RIB.
<Sysname> display rib nib verbose
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
    SAIndex: 0xffffffff
     RefCnt: 6              FlushRefCnt: 2
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 0.0.0.0
  RelyDepth: 0              RealNexthop: 0.0.0.0
  Interface: NULL0            LocalAddr: 0.0.0.0
   TunnelID: N/A               Topology: base
    SAIndex: 0xffffffff
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
    SAIndex: 0xffffffff
     RefCnt: 13             FlushRefCnt: 5
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 127.0.0.1
  RelyDepth: 0              RealNexthop: 127.0.0.1
  Interface: InLoop0          LocalAddr: 127.0.0.1
    SAIndex: 0xffffffff
      NibID: 0x15000003        Sequence: 3
       Type: 0x43               Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x100010000        VrfNthp: 0
   UserKey1: 0x0                Nexthop: 22.22.22.22
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
    SAIndex: 0xffffffff
   Instance: default
     RefCnt: 9              FlushRefCnt: 3
    ExtFlag: 0x0
     Policy: tnl-policy1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 22.22.22.22
  RelyDepth: 1              RealNexthop: 13.1.1.2
  Interface: XGE3/0/1         LocalAddr: 13.1.1.1
  TunnelCnt: 1                      Vrf: default-vrf
   TunnelID: 1025              Topology: base
    SAIndex: 0xffffffff
      NibID: 0x16000004        Sequence: 18
        Age: 08h43m31s
    SubType: 0x4
    NthpCnt: 1                    Samed: 0
   Instance: default
    NthpCnt: 1                    Samed: 0
   Instance: default
       Flag: 0x484              Version: 1
    ExtFlag: 0x0
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 6:5::
  RelyDepth: 1              RealNexthop: FE80::989E:E7FF:FEF1:807
  Interface: GE2/0/2          LocalAddr: FE80::989D:9CFF:FEB4:717
     Weight: 1                    Flags: 0x0
SRPolicyNID: 4294967295     SRInterface: N/A
ColorWeight: 0                  Locator: 6:5::
    SAIndex: 0xffffffff
Backup nexthop:
PrefixIndex: 0              OrigNexthop: 9:5::
  RelyDepth: 0              RealNexthop: FE80::A040:E2FF:FED3:A08
  Interface: GE2/0/3          LocalAddr: ::
   TunnelID: 2150629378         Topology:
     Weight: 1                    Flags: 0x10
    SAIndex: 0xffffffff
Table 17 Command output
NibID
ID of the next hop.
Sequence
Flushed
Age
UserKey0
Reserved data 1.
VrfNthp
Index of the VPN instance that the next hop belongs to. This field displays 0 if the next hop is on the public network.
UserKey1
Reserved data 2.
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
MemberPort
NewUK0
NewUK1
NewUK2
NewUK3
NewUK4
NewUK5
NewUK6
NewUK7
NewUK8
NewUK9
NewUK10
NewUK11
NewUK12
TopoNthp
ExtType1
ExtType2
Color
COFlag
SIDIndex
SID index value.
SRPName
OriNexthop
SAIndex
SA index number for the IP prefix route used to perform IPsec encryption for packets with the associated SA parameter settings. When no SA index number exists, this field displays an all-f value.
MetricFlag
Type of the metric associated with the SRv6 TE policy or SRv6 TE policy group to which the next hop recurses. Options include:
·     0x00000001—IGP metric.
·     0x00000002—TE metric.
·     0x00000004—Latency metric.
·     0x00000008—Packet loss metric.
This field is displayed only when the next hop recurses to an SRv6 TE policy or SRv6 TE policy group.
Metric
Metric value. If multiple metric values exist, they are separated with spaces.
Instance
BGP instance name.
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
ExtFlag
Extended flag of the next hop.
Policy
Tunnel policy name.
x nexthop (s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
OrigNexthop
Original next hop.
RelyDepth
Recursion depth.
RealNexthop
Real next hop.
Output interface.
LocalAddr
TunnelCnt
Number of tunnels after route recursion.
Vrf
VPN instance name. For the public network, this field displays default-vrf.
TunnelID
ID of the tunnel after route recursion.
Topology
Topology name. The topology name for the IPv4 public network is base. This field is blank for IPv6, because IPv6 does not support non-base topologies.
Weight
ECMP route weight.
Flags
Flags of the detailed next hop. Options include:
·     0x0001—The next hop does not carry a gateway.
·     0x0002—Next hop of a permanent static route.
·     0x0004—Next hop of a direct route.
·     0x0008—Tunnel change flag.
·     0x0010—The Weight field of the next hop represents bandwidth.
·     0x0020—Next hop flag of a LISP route.
·     0x0040—Cross-subnet ARP learning flag.
·     0x0080—The output interface is a VSI interface.
·     0x0100—Route next hop issued by UCM.
·     0x0200—Color recursion change flag.
·     0x0400—SR microloop avoidance flag.
·     0x0800—The next hop does not recurse to a black hole.
·     0x1000—Tunnel recursion for a static route configured with a tunnel policy.
·     0x2000—ECMP backup next hop flag.
·     0x4000—NID obtained from the tunnel output interface.
·     0x8000—Cross-VPN forwarding flag.
Value 0x0 indicates that the next hop does not contain any previous flags.
SRPolicyNID
NIB ID of the route obtained from an SR-MPLS TE policy through route recursion.
SRInterface
Output interface of the route obtained from the SR-MPLS TE policy through route recursion.
ColorWeight
Weight value of the color attribute in the SR-MPLS TE policy.
Locator
IPv6 prefix of the locator to which the SID belongs.
If no locator is available, this field displays N/A.
MemberPort
Number of a member port in an aggregation group.
If this attribute is not available, this field displays N/A.
SubType
SubNibID
SubSeq
NthpCnt
Samed
NthpType
·     IP—IP forwarding.
SliceID
uiFlags
Extention of the current next hop flag. Options include:
·     0x00000001—SRv6 multilevel primary/backup NIDs established by the SRv6 TE policy protocol.
·     0x00000002—NID obtained through recursion reported by route management.
·     0x00000004—SRv6 forwarding flag.
·     0x00000008—The forwarding path is preferentially selected through the SRv6 TE mode.
·     0x00000010—SRv6 multilevel FRR. The primary path is an SRv6 TE path, and the backup path is an SRv6 BE path.
SliceId
NSI ID.
Use display rib nib record to display next hop records in the RIB.
display rib nib record flush [ nib-id ] [ delete | update ] [ verbose ]
display rib nib record receive [ nib-id ] [ add | delete | update ] [ verbose ]
flush: Displays the records for the next hops issued by the RIB to the FIB.
receive: Displays the records for the next hops received by the RIB from the routing protocol.
# Display brief information about the records for the next hops issued by the RIB to the FIB.
<Sysname> display rib nib record flush
210908 15:31:58:753 update 0x10000000
210908 15:31:58:755 update 0x110000001
Table 18 Command output
Total number of next hop records.
Date
Time
Action
Action on the next hop in the record:
·     add.
·     update.
·     delete.
VNID
VN entry ID.
# Display detailed information about the records for the updated next hops issued by the RIB to the FIB.
<Sysname> display rib nib record flush update verbose
        Time: 210928 14:39:14:162    Action: update
       NibID: 0x10000000               VNID: 0x10000000
        Flag: 0x80                 ExtFlags: 0x0
      RefCnt: 5                 FlushRefCnt: 1
        Type: 0x1
    VrfIndex: 0x0                   Nexthop: 127.0.0.1
     IfIndex: 1410                LocalAddr: 127.0.0.1
  MemberPort: 0
    ExtType2: 0x0
       Color: 0                  OriNexthop: 0.0.0.0
     SAIndex: 0xffffffff
 1 nexthop(s):
   Interface: 1410                LocalAddr: 127.0.0.1
    VrfIndex: 0                    Topology: base
Table 19 Command output
Limit of records
Maximum number of next hop records.
Time
Action
·     update.
·     delete.
NibID
ID of the next hop.
VNID
VN entry ID.
Sequence
Version
Flag
ExtFlags
Flags of extended next hop information.
RefCnt
FlushRefCnt
Next hop type.
VrfIndex
VPN instance index.
Nexthop
Next hop address.
IfIndex
Output interface index.
LocalAddr
MemberPort
Index of a member port in an aggregation group. When this attribute is not available, the field displays 0.
ExtType1
The first extended type of the next hop.
ExtType2
The second extended type of the next hop.
NibInstance
Instance or protocol generated the next hop information:
·     IFM—Interface management instance.
·     USR—Static routing.
·     RIP—RIP or RIPng.
·     OSPF—OSPF or OSPFv3.
·     ISIS—IS-IS or IPv6 IS-IS.
·     LISP—LISP.
·     BGP—BGP or BGP4+.
·     RIB—IP routing table instance.
·     EVPN—EVPN instance.
·     EIGRP—EIGRP or EIGRPv6.
·     UNR—User network routing instance.
·     SRV6—SRv6.
·     None—Unknown or invalid instance.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
NewUK0
NewUK1
NewUK2
NewUK3
NewUK4
NewUK5
NewUK6
NewUK7
SIDIndex
SID index value.
SrPolicyName
Name of an SR-MPLS TE policy.
Color
OriNexthop
COFlag
Locator
SAIndex
SubType
Subtype of the parent NIB.
SubNibID
SubSeq
NthpCnt
Samed
NthpType
·     IP—IP forwarding.
x nexthop (s)
PrefixIndex
OrigNexthop
Original next hop.
RelyDepth
Recursion depth.
RealNexthop
Real next hop.
Output interface.
Topology
Weight
ECMP route weight.
Flags
Flags of the current next hop. Options include:
SRPolicyNID
SRInterface
ColorWeight
Locator
MemberPort
SRL2Interface
Number of a member port in an aggregation group. When this attribute is not available, the field displays 0.
uiFlags
MetricFlag
Metric
# Display brief information about the records for the next hops received by the RIB from the routing protocol.
<Sysname> display rib nib record receive
Total number of records: 2
210907 14:42:09:471 add    0x10000003 IFM
210907 15:35:45:190 delete 0x10000003 IFM
Table 20 Command output
Date
Time
Action
·     add.
·     update.
·     delete.
NibID
ID of the next hop.
NibInstance
·     RIP—RIP or RIPng.
·     LISP—LISP.
·     BGP—BGP or BGP4+.
·     SRV6—SRv6.
# Display detailed information about the records for the added next hops received by the RIB from the routing protocol.
<Sysname> display rib nib record receive add verbose
        Time: 210928 14:39:14:148    Action: add
    ExtType2: 0x0
  InstanceId: 0                     Nexthop: 127.0.0.1
   L2IfIndex: 0
     SAIndex: 0xffffffff
 1 nexthop(s):
Table 21 Command output
Limit of records
Time
Action
·     add.
·     update.
·     delete.
NibID
Next hop ID.
Sequence
Next hop sequence number.
NibInstance
·     RIP—RIP or RIPng.
·     LISP—LISP.
·     BGP—BGP or BGP4+.
·     SRV6—SRv6.
Version
Flag
UsrData
Protocol private data.
VrfIndex
VPN instance index.
VrfName
Name of the VPN instance to which the route belongs. If the route belongs to the public network, this field displays default-vrf.
Next hop type.
Nexthop
Next hop address.
ExtType1
ExtType2
LocalAddr
InstanceId
IfIndex
Interface index.
L2IfIndex
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
NewUK0
NewUK1
NewUK2
NewUK3
NewUK4
NewUK5
NewUK6
NewUK7
Color
COFlag
BandWidth
Bandwidth of the link associated with the next hop.
Weight
ECMP route weight.
ProtNibID
Next hop ID carried by the protocol.
NibFlags
Flags of the next hop.
SIDIndex
SID index value.
SrPolicyName
SAIndex
SubType
SubNibID
SubSeq
NthpCnt
Samed
NthpType
·     IP—IP forwarding.
x nexthop (s)
PrefixIndex
OrigNexthop
Original next hop.
RelyDepth
Recursion depth.
RealNexthop
Real next hop.
Output interface.
Topology
Flags
SRPolicyNID
SRInterface
ColorWeight
Locator
MemberPort
SRL2Interface
uiFlags
MetricFlag
Metric
Use display route-direct nib to display next hop information for direct routes.
verbose: Displays detailed next hop information for direct routes. If you do not specify this keyword, the command displays brief next hop information for direct routes.
# Display brief next hop information for direct routes.
<Sysname> display route-direct nib
Total number of nexthop(s): 116
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
Table 22 Command output
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
Age
Time when the next hop information was updated most recently.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
Local interface IP address.
MemberPort
NewUK0
NewUK1
NewUK2
NewUK3
NewUK4
NewUK5
NewUK6
NewUK7
NewUK8
NewUK9
NewUK10
NewUK11
NewUK12
TopoNthp
ExtType1
ExtType2
Color
COFlag
SIDIndex
SID index value.
SRPName
OriNexthop
# Display detailed next hop information for direct routes.
<Sysname> display route-direct nib verbose
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 2              FlushRefCnt: 0
    ExtFlag: 0x0
 1 nexthop(s):
    SliceId: 0
        Age: 00h01m50s
 MemberPort: 0x0
   ExtType2: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 5              FlushRefCnt: 0
    ExtFlag: 0x0
 1 nexthop(s):
    SliceId: 0
Table 23 Command output
NibID
ID of the next hop.
Sequence
Flushed
Age
UserKey0
Reserved data 1.
VrfNthp
UserKey1
Reserved data 2.
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
MemberPort
NewUK0
NewUK1
NewUK2
NewUK3
NewUK4
NewUK5
NewUK6
NewUK7
NewUK8
NewUK9
NewUK10
NewUK11
NewUK12
TopoNthp
ExtType1
ExtType2
Color
COFlag
SIDIndex
SID index value.
SRPName
OriNexthop
RefCnt
FlushRefCnt
Flag
Version
ExtFlag
x nexthop(s)
PrefixIndex
OrigNexthop
Original next hop.
RelyDepth
Recursion depth.
RealNexthop
Real next hop.
Output interface.
LocalAddr
TunnelCnt
Vrf
TunnelID
Topology
Weight
ECMP route weight.
Flags
SRPolicyNID
SRInterface
ColorWeight
Locator
MemberPort
uiFlags
SliceId
NSI ID.
fib lifetime
Use fib lifetime to set the maximum lifetime for IPv4 or IPv6 routes in the FIB.
Use undo fib lifetime to restore the default.
fib lifetime seconds
undo fib lifetime
The maximum lifetime for IPv4 or IPv6 routes in the FIB is 600 seconds.
RIB IPv4 address family view
RIB IPv6 address family view
seconds: Specifies the maximum lifetime for routes in the FIB, in the range of 0 to 6000 seconds. When this argument is set to 0, FIB entries immediately age out after a protocol or RIB process switchover.
When a protocol or RIB process switchover occurs and GR or NSR is not configured, FIB entries age out after the time specified in this command.
# Set the maximum lifetime for IPv4 routes in the FIB to 60 seconds.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute
Use flush route-attribute to enable the RIB to flush route attribute information to the FIB.
Use undo flush route-attribute remove the configuration.
flush route-attribute protocol
undo flush route-attribute protocol
The RIB does not flush route attribute information to the FIB.
protocol: Specifies a routing protocol. In the current software version, only BGP is supported.
# Enable the RIB to flush BGP route attribute information to the FIB.
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
inter-protocol ecmp
Use inter-protocol ecmp to enable routes from different protocols in the RIB IPv4 or IPv6 address family to form ECMP routes.
Use undo inter-protocol ecmp to restore the default.
inter-protocol ecmp [ ignore-preference ] [ vpn-instance vpn-instance-name ]
undo inter-protocol ecmp [ vpn-instance vpn-instance-name ]
Routes from different protocols cannot form ECMP routes.
ignore-preference: Allows routes with different preferences to form ECMP routes. If you do not specify this keyword, only routes with the same preference can form ECMP routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command enables routes from different protocols in the public network to form ECMP routes.
By default, routes from different protocols have different preferences, and the route costs are calculated in different ways. Such routes cannot form ECMP routes. Configure this command to ignore the costs for routes from different protocols, so that they can form ECMP routes.
For routes from multiple protocols with the same destination to form ECMP routes, follow these restrictions and guidelines:
·     If you do not specify the ignore-preference keyword, routes with the highest priority will form ECMP routes. You can edit the preferences for routes from different protocols to the same value, so that they can form ECMP routes.
·     If you specify the ignore-preference keyword, multiple routes will form ECMP routes.
If you configure both this command and the inter-protocol fast-reroute command, only this command takes effect.
# Enable routes from different protocols in the RIB IPv4 address family of the public network to form ECMP routes.
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol ecmp
Use inter-protocol fast-reroute to enable IPv4 or IPv6 RIB inter-protocol FRR.
Use undo inter-protocol fast-reroute to disable IPv4 or IPv6 RIB inter-protocol FRR.
inter-protocol fast-reroute [ ecmp-shared ] [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
Inter-protocol FRR is disabled.
ecmp-shared: Specify a shared next hop for ECMP routes. Multiple ECMP routes use the same backup next hop. If you do not specify this keyword, the device performs backup next hop calculation for only non-ECMP routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command enables IPv4 or IPv6 RIB inter-protocol FRR for the public network.
This command allows a device to perform fast rerouting between routes of different protocols. A backup next hop is automatically selected to reduce the service interruption time caused by unreachable next hops. When the next hop of the primary link fails, the traffic is redirected to the backup next hop.
This command uses the next hop of a route from a different protocol as the backup next hop for the faulty route, which might cause loops.
Inter-protocol FRR cannot select a backup next hop from routes in the RIB that have the same next hop, output interface, and destination as those of the faulty route.
If you specify the ecmp-shared keyword, the device calculates a shared backup next hop for multiple ECMP routes with the same destination. This backup next hop is from a different protocol than the ECMP routes. When all next hops of the ECMP routes fail, RIB replaces them with the backup next hop, and issues the backup next hop to the FIB as an ECMP route. You can view the detailed route information with the display ip routing-table command. The route with the Backup state in the output indicates the backup next hop. If the backup next hop is the same as a next hop of an ECMP route, RIP will not issue the backup next hop to the FIB. In this case, the backup next hop will not take effect.
If you configure both this command and the inter-protocol ecmp command, this command will not take effect.
# Enable IPv4 RIB inter-protocol FRR for the public network.
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
ipv6 route-direct cost
Use ipv6 route-direct cost to set the cost value for the IPv6 direct route of the interface.
Use undo ipv6 route-direct cost to restore the default.
ipv6 route-direct cost cost-value
The cost value is 0 for the IPv6 direct route of the interface.
Interface view
cost-value: Specifies a cost value in the range of 1 to 4294967295.
Application scenarios
For an interface in up state, the device sets the cost of the IPv6 direct route with this interface as the output interface to the value specified in the command. The cost value still applies to the route even after it is redistributed into another routing protocol.
If you configure both the ipv6 route-direct cost and ipv6 route-direct track commands, the cost value for the direct route is calculated as follows:
·     If the track entry associated with the direct route does not exist or the track entry is in NotReady or Positive state, the cost of the direct route takes the value specified in the ipv6 route-direct cost command.
·     If the track entry associated with the direct route is in Negative state, the cost of the direct route is the sum of the values specified in the ipv6 route-direct track and ipv6 route-direct cost commands. If the cost value exceeds 4294967295, the device sets the cost value to 4294967295.
# Set the cost value to 200 for the IPv6 direct route of interface Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] ipv6 route-direct cost 200
Use ipv6 route-direct track to associate a track entry with the IPv6 direct route on an interface and apply a cost value to the IPv6 direct route after the track entry changes to Negative state.
Use undo ipv6 route-direct track to restore the default.
ipv6 route-direct track track-entry-number degrade-cost cost-value
No track entry is associated with the IPv6 direct route on an interface.
Interface view
track-entry-number: Specifies a track entry ID in the range of 1 to 1024.
degrade-cost cost-value: Specifies a cost value to apply to the IPv6 direct route after the track entry changes to Negative state. The value range for the cost-value argument is 1 to 4294967295.
On a network where an IPv6 VRRP group is used as the default gateway, upstream traffic is always forwarded through the master device in the IPv6 VRRP group. The corresponding downstream traffic might take a different path because the route selection is determined by the configured dynamic routing protocol. The mismatching forwarding paths might cause the traffic to be blocked by firewalls (if configured), and increase the complexity and overhead for traffic monitoring and statistics collection operations.
You can resolve the issue by configuring IPv6 direct route-Track-IPv6 VRRP collaboration. The collaboration ensures that the upstream traffic and the corresponding downstream traffic are forwarded through matching paths (both through the master device in the IPv6 VRRP group).
Operating mechanism
To configure IPv6 direct route-Track-IPv6 VRRP collaboration, perform the following tasks on each member device of the IPv6 VRRP group:
1.     Create a track entry associated with the IPv6 VRRP group member device so the track entry state changes according to the status of the device in the IPv6 VRRP group.
¡     If the device state is Backup or Initialize, the track entry state changes to Negative.
¡     If the device state is Master, the track entry state changes to Positive.
¡     If the device state is Inactive or the IPv6 VRRP group does not exist, the track entry state changes to NotReady.
2.     Associate the track entry with the IPv6 direct route on the interface connected to the downstream device. The cost value of the IPv6 direct route on the interface changes according to the status of the track entry.
¡     If the track entry does not exist or the track entry is in NotReady or Positive state, the cost of the IPv6 direct route changes to 0.
¡     If the track entry is in Negative state, the cost of the IPv6 direct route changes to the value configured by using the ipv6 route-direct track command.
IMPORTANT
IMPORTANT:
The IPv6 direct route that has a lower cost value is preferentially used.
3.     Enable IPv6 direct route redistribution on the IPv6 VRRP group member device for the dynamic routing protocol.
For more information about associating Track with an IPv6 VRRP group, see Track configuration in High Availability Configuration Guide.
The IPv6 direct route on an interface can be associated only with one track entry. To change the track entry associated with the IPv6 direct route on an interface, you must first execute the undo ipv6 route-direct track command to remove the original association.
# Associate track entry 1 with the IPv6 direct route on Ten-GigabitEthernet 3/0/1 and apply cost 200 to the IPv6 direct route after the track entry changes to Negative state.
[Sysname-Ten-GigabitEthernet3/0/1] ipv6 route-direct track 1 degrade-cost 200
track vrrp ipv6 (High Availability Command Reference)
maintenance-probe enable
Use maintenance-probe enable to enable maintenance probe (MTP).
Use undo maintenance-probe enable to disable MTP.
MTP is disabled.
MTP enables the device to automatically perform the following operations upon expiration of a neighbor's hold timer:
4.     Ping the neighbor or trace the route to the neighbor.
5.     Record the ping or tracert results.
To view fault information, use the display commands of routing protocols, for example, the display ospf troubleshooting command. To view detailed MTP information, use the display logbuffer command.
# Enable MTP.
[Sysname] maintenance-probe enable
display bgp troubleshooting
display logbuffer (Network Management and Monitoring Command Reference)
nexthop recursive-lookup restrain
Use nexthop recursive-lookup restrain to configure route recursion suppression.
Use undo nexthop recursive-lookup restrain to restore the default.
nexthop recursive-lookup restrain { maximum-interval [ minimum-interval [ incremental-interval ] ] | millisecond interval }
Route recursion suppression is disabled.
maximum-interval: Specifies the maximum suppression timer in the range of 1 to 60 seconds.
minimum-interval: Specifies the minimum suppression timer in the range of 10 to 60000 milliseconds. The default value is 50.
incremental-interval: Specifies the incremental timer in the range of 10 to 60000 milliseconds. The default value is 200.
millisecond interval: Specifies a fixed suppression timer in the range of 10 to 10000 milliseconds.
A change of a related route or tunnel obtained through nexthop recursion triggers another recursion for the recursive route. When the network changes frequently, the route recursion is performed repeatedly, which causes high CPU usage. To solve this issue, configure this command for the RIB to wait for the suppression timer to expire before obtaining the recursion result. In this way, the route recursion is performed less often and the CPU usage can be reduced. However, this feature can result in lower route recursion efficiency and slow route convergence. Configure this feature as needed make sure the parameters are appropriate.
After you configure this feature, no matter how the route recursion results change within the suppression timer, the RIB always obtains the most recent results after the suppression timer expires.
To dynamically suppress route recursion, configure at least the maximum suppression timer. If the route recursion results keep changing, the suppression time increases until the maximum suppression timer expires or the recursion results stop changing.
The dynamic suppression time (T) is calculated based on the number of route recursions (N), as follows:
·     When N = 1, T = minimum-interval.
·     When N ≥ 2, T = minimum-interval + incremental-interval × [ 2 ^ ( N - 2 ) ], and T ≤ maximum-interval.
·     When T reaches maximum-interval for three consecutive times, T = minimum-interval in the next recursion, and N becomes 1.
·     If the recursion results have not changed in two times the maximum-interval, T = minimum-interval in the next recursion, and N becomes 1.
The value for the minimum-interval or incremental-interval argument cannot be greater than that for the maximum-interval argument.
The suppression timer settings apply to only the next route recursion.
The actual suppression timer equals the sum of the suppression timer configured in this command and the timer configured in any of the following commands:
·     nexthop recursive-lookup restrain (BGP instance view/BGP-VPN instance view)
·     nexthop recursive-lookup delay (BGP address family view)
# Set the maximum suppression timer, minimum suppression timer, and incremental timer for IPv4 route recursion to 60 seconds, 500 milliseconds, and 1000 milliseconds, respectively.
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain 60 500 1000
# Set the fixed suppression timer for IPv6 route recursion to 1000 milliseconds.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6] nexthop recursive-lookup restrain millisecond 1000
nexthop recursive-lookup restrain clear-interval
Use nexthop recursive-lookup restrain clear-interval to set the interval for clearing the recursion loop counter.
Use undo nexthop recursive-lookup restrain clear-interval to restore the default.
nexthop recursive-lookup restrain clear-interval interval
The interval for clearing the recursion loop counter is 600 seconds.
clear-interval interval: Specifies the interval for clearing the recursion loop counter, in the range of 1 to 65535 seconds.
Recursion loop suppression enables the system to use a counter to record the number of route recursion failures. When the counter reaches 20, the system suppresses route recursion for a specified period of time. When the suppression time expires, the system resets the counter and disables route recursion suppression.
# Set the interval for clearing the recursion loop counter to 100 seconds.
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain clear-interval 100
nexthop recursive-lookup restrain disable
Use nexthop recursive-lookup restrain disable to disable the suppression for next hop recursion loop.
Use undo nexthop recursive-lookup restrain disable to enable the suppression for next hop recursion loop.
Suppression for next hop recursion loop is enabled.
A recursion loop occurs when a route recurses to a related route that recurses back to the route. It causes a route recursion failure and further lookup for a related route. If recursion loop persists, continuous route flapping will cause high system resource consumption and CPU utilization.
This command enables the system to use a counter to record the number of route recursion failures. When the counter reaches 20, the system suppresses route recursion for a specified period of time to save system resources on the device.
# Disable the suppression for next hop recursion loop.
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain disable
primary-path-detect bfd
Use primary-path-detect bfd to enable BFD for primary route next hop detection of inter-protocol FRR or ECMP routes.
Use undo primary-path-detect bfd to disable BFD for primary route next hop detection of inter-protocol FRR or ECMP routes.
primary-path-detect bfd { ctrl | echo } [ inter-protocol-frr | protocol-ecmp protocol ]
undo primary-path-detect bfd [ inter-protocol-frr | protocol-ecmp protocol ]
BFD is disabled for primary route next hop detection of inter-protocol FRR or ECMP routes.
ctrl: Specifies the BFD control packet mode.
echo: Specifies the BFD echo packet mode.
inter-protocol-frr: Enables primary route next hop detection for inter-protocol FRR.
protocol-ecmp protocol: Enables primary route next hop detection for ECMP routes of a routing protocol.
·     In RIB IPv4 address family view, the value for the protocol argument can be bgp, isis, ospf, or static.
·     In RIB IPv6 address family view, the value for the protocol argument depends on the BFD mode.
¡     In BFD control packet mode, the value can be bgp4+, isisv6, ospfv3, or static.
¡     In BFD echo packet mode, the value can be bgp4+ or static.
After you configure this command, the device automatically creates an IP FRR BFD session to detect the next hop availability of the primary route. Upon primary route next hop failure, traffic can be immediately switched to the backup route next hop for fast convergence.
·     For inter-protocol FRR, the primary route is the route with the highest preference among the routes to the same destination.
·     For ECMP routes of a routing protocol, the primary route is each ECMP route. If you specify the ecmp-shared keyword when configuring FRR for a routing protocol, the device will use the LFA algorithm to calculate backup next hops for each ECMP route. The routes destined for the backup next hops are also added to the routing table as ECMP routes and the state of these routes is backup. BFD does not detect these backup ECMP routes.
You can execute this command multiple times to change the BFD mode (echo packet mode or control packet mode).
If you do not specify the inter-protocol-frr or protocol-ecmp keyword, the command applies to both inter-protocol FRR and ECMP routes. The command without the inter-protocol-frr and protocol-ecmp keywords takes precedence over that with the inter-protocol-frr or protocol-ecmp keyword. For example, if you have used the primary-path-detect bfd ctrl command, you can use only the following commands to modify or cancel the command configuration:
·     primary-path-detect bfd echo.
·     undo primary-path-detect bfd.
A control-packet-mode BFD session can be successfully established through negotiation between the two ends. To use a control-packet-mode BFD session to detect the primary route next hop availability, you must create a static BFD session that meets the following requirements on the next hop device:
·     Create a single-hop BFD session in control packet mode.
·     The source IP address of the BFD session is the destination IP address of the BFD session automatically created by the local end.
·     The destination IP address of the BFD session is the source IP address of the BFD session automatically created by the local end.
·     The remote discriminator of the BFD session is the local discriminator of the BFD session automatically created by the local end.
The local device can use a control-packet-mode BFD session to detect the primary route next hop only after you create the static BFD session on the primary route next hop device. For more information about creating static BFD sessions, see BFD configuration in High Availability Configuration Guide.
When another protocol (for example, BGP, OSPF, and IS-IS) uses BFD to detect the primary route next hop, it also automatically create a BFD session. If the next hop to be detected is the same as the next hop of the RIB primary route, the device does not repeatedly create the same type of BFD sessions. Instead, the device reuses the BFD session of other protocols.
The source IPv6 address of packets for an echo-packet-mode BFD session can only be a global unicast address. If the IPv6 next hop address of the primary link is not a global unicast address, as a best practice, use a control-packet-mode BFD session to detect next hop reachability for the primary link.
# Enable control-mode BFD for primary route next hop detection of IS-IS ECMP routes.
[Sysname] rib
[Sysname-rib-ipv4] primary-path-detect bfd ctrl protocol-ecmp isis
fast-reroute
protocol lifetime
Use protocol lifetime to set the maximum lifetime for IPv4 or IPv6 routes and labels in the RIB.
Use undo protocol lifetime to restore the default.
undo protocol protocol [ instance instance-name ] lifetime
The maximum lifetime for IPv4 or IPv6 routes and labels in the RIB is 900 seconds.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. This argument applies only to the BGP protocol. If you do not specify a BGP instance, this command sets the maximum lifetime for all BGP routes and labels in the RIB.
seconds: Specifies the maximum lifetime for routes and labels in the RIB, in the range of 1 to 6000 seconds.
When GR is enabled, make sure the protocol can complete GR and install all route entries to the RIB within the lifetime configured in this command.
# Set the maximum lifetime for RIP routes and labels in the RIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] protocol rip lifetime 60
protocol nexthop recursive-lookup
Use protocol nexthop recursive-lookup to configure routing policy-based recursive lookup.
Use undo protocol nexthop recursive-lookup to remove the configuration.
protocol protocol nexthop recursive-lookup route-policy route-policy-name
undo protocol protocol nexthop recursive-lookup route-policy
Routing policy-based recursive lookup is not configured.
protocol: Specifies a routing protocol, which can be bgp or static in RIB IPv4 address family view or bgp4+ in RIB IPv6 address family view.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
Configure routing policy-based recursive lookup to control route recursion results. For example, when a route changes, the routing protocol has to perform a route recursion if the next hop is indirectly connected. The routing protocol might select an incorrect path, which can cause traffic loss. To prevent this problem, you can use a routing policy to filter out incorrect routes. The routes that pass the filtering of the routing policy will be used for route recursion.
The apply clauses in the specified routing policy cannot take effect.
Make sure a minimum of one related route can match the routing policy for correct traffic forwarding.
The routing policy does not apply to routes received from directly connected BGP neighbors.
# Configure recursive lookup based on routing policy policy1 for BGP routes.
[Sysname] rib
[Sysname-rib-ipv4] protocol bgp nexthop recursive-lookup route-policy policy1
record-limit
Use record-limit to set the maximum number of RIB next hop records or route entry records.
Use undo record-limit to restore the default.
record-limit limit [ rib nib [ flush [ delete | update ] | receive [ add | delete | update ] ] ]
undo record-limit [ rib nib [ flush [ delete | update ] | receive [ add | delete | update ] ] ]
record-limit limit [ routing-table [ flush [ delete | update ] | notify [ delete | update ] | receive [ add | delete | update ] ] ]
undo record-limit [ routing-table [ flush [ delete | update ] | notify [ delete | update ] | receive [ add | delete | update ] ] ]
The maximum number of RIB next hop records or route entry records is 1000.
limit: Sets the maximum number of RIB next hop records or route entry records. The value range is 0 to 1000000. To disable recording for RIB next hops or route entries, set the value to 0. When the number of records reaches the maximum number, the system can record new next hops or route entries. However, the new next hop or route entry records overwrite the oldest next hop or route entry records.
rib nib: Sets the maximum number of RIB next hop records.
routing-table: Sets the maximum number of route entry records.
flush: Sets the maximum number of records flushed from RIB to FIB.
notify: Sets the maximum number of records reported by RIB to routing protocols.
receive: Sets the maximum number of records received by RIB from routing protocols.
add: Sets the maximum number of records that contain the add action.
update: Sets the maximum number of records that contain the update action. If you specify the flush or notify keyword, records that contain the add action are also counted into the update category.
delete: Sets the maximum number of records that contain the delete action.
Repeat the command to set the maximum number for different types of records.
If you do not specify the rib nib or routing-table keywords, the command sets the maximum number for all types of RIB next hop and route entry records.
If you do not specify the add, delete, or update keyword, the command sets the maximum number for records that contain the add, delete, and update actions.
# Set the maximum number of next hop records and route entry records to 100 in the IPv4 RIB.
[Sysname] rib
[Sysname-rib-ipv4] record-limit 100
# Set the maximum number of IPv4 route entry records to 200.
[Sysname] rib
[Sysname-rib-ipv4] record-limit 200 routing-table
# Set the maximum number of next hop records that contain the add action to 300. The records are received by IPv4 RIB from routing protocols.
[Sysname] rib
[Sysname-rib-ipv4] record-limit 300 rib nib receive
# Set the maximum number of route entry records that contain the update action to 400. The records are reported by IPv6 RIB to routing protocols.
[Sysname] rib
[Sysname-rib-ipv6] record-limit 400 routing-table notify update
# Set the maximum number of next hop records that contain the delete action to 500. The records are flushed from IPv6 RIB to FIB.
[Sysname] rib
[Sysname-rib-ipv6] record-limit 500 rib nib flush delete
reset ip routing-table record
Use reset ip routing-table record to clear IPv4 routing entry records.
# Clear IPv4 routing entry records.
<Sysname> reset ip routing-table record
reset ip routing-table statistics protocol
Use reset ip routing-table statistics protocol to clear IPv4 route statistics.
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
all-routes: Clears route statistics for the public network and all VPN instances.
all-vpn-instance: Clears route statistics for all VPN instances.
protocol: Clears route statistics for a routing protocol.
all: Clears route statistics for all IPv4 routing protocols.
This command clears IPv4 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv4 route statistics for the public network.
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 rib nib record
Use reset ipv6 rib nib record to clear next hop records in the IPv6 RIB.
# Clear next hop records in the IPv6 RIB.
<Sysname> reset ipv6 rib nib record
reset ipv6 routing-table record
Use reset ipv6 routing-table record to clear IPv6 routing entry records.
# Clear IPv6 routing entry records.
<Sysname> reset ipv6 routing-table record
reset ipv6 routing-table statistics protocol
Use reset ipv6 routing-table statistics protocol to clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
protocol: Clears route statistics for an IPv6 routing protocol.
all: Clears route statistics for all IPv6 routing protocols.
This command clears IPv6 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv6 route statistics for the public network.
<Sysname> reset ipv6 routing-table statistics protocol all
reset rib nib record
Use reset rib nib record to clear next hop records in the IPv4 RIB.
# Clear next hop records in the IPv4 RIB.
<Sysname> reset rib nib record
rib
Use rib to enter RIB view.
Use undo rib to remove all configurations in RIB view.
rib
undo rib
# Enter RIB view.
[Sysname] rib
[Sysname-rib]
route-direct cost
Use route-direct cost to set the cost value for the IPv4 direct route of the interface.
Use undo route-direct cost to restore the default.
The cost value is 0 for the IPv4 direct route of the interface.
Interface view
For an interface in up state, the device sets the cost of the IPv4 direct route with this interface as the output interface to the value specified in the command. The cost value still applies to the route even after it is redistributed into another routing protocol.
If you configure both the route-direct cost and route-direct track commands, the cost value for the direct route is calculated as follows:
·     If the track entry associated with the direct route does not exist or the track entry is in NotReady or Positive state, the cost of the direct route takes the value specified in the route-direct cost command.
·     If the track entry associated with the direct route is in Negative state, the cost of the direct route is the sum of the values specified in the route-direct track and route-direct cost commands. If the cost value exceeds 4294967295, the device sets the cost value to 4294967295.
# Set the cost value to 200 for the IPv4 direct route of interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] route-direct cost 200
route-direct track
route-direct track
Use route-direct track to associate a track entry with the IPv4 direct route on an interface and apply a cost value to the IPv4 direct route after the track entry changes to Negative state.
Use undo route-direct track to restore the default.
No track entry is associated with the IPv4 direct route on an interface.
Interface view
degrade-cost cost-value: Specifies a cost value to apply to the IPv4 direct route after the track entry changes to Negative state. The value range for the cost-value argument is 1 to 4294967295.
On a network where an IPv4 VRRP group is used as the default gateway, upstream traffic is always forwarded through the master device in the IPv4 VRRP group. The corresponding downstream traffic might take a different path because the route selection is determined by the configured dynamic routing protocol. The mismatching forwarding paths might cause the traffic to be blocked by firewalls (if configured), and increase the complexity and overhead for traffic monitoring and statistics collection operations.
You can resolve the issue by configuring IPv4 direct route-Track-IPv4 VRRP collaboration. The collaboration ensures that the upstream traffic and the corresponding downstream traffic are forwarded through matching paths (both through the master device in the IPv4 VRRP group).
Operating mechanism
To configure IPv4 direct route-Track-IPv4 VRRP collaboration, perform the following tasks on each member device of the IPv4 VRRP group:
6.     Create a track entry associated with the IPv4 VRRP group member device so the track entry state changes according to the status of the device in the IPv4 VRRP group.
¡     If the device state is Inactive or the IPv4 VRRP group does not exist, the track entry state changes to NotReady.
7.     Associate the track entry with the IPv4 direct route on the interface connected to the downstream device. The cost value of the IPv4 direct route on the interface changes according to the status of the track entry.
¡     If the track entry does not exist or the track entry is in NotReady or Positive state, the cost of the IPv4 direct route changes to 0.
¡     If the track entry is in Negative state, the cost of the IPv4 direct route changes to the value configured by using the route-direct track command.
IMPORTANT
IMPORTANT:
The IPv4 direct route that has a lower cost value is preferentially used.
8.     Enable IPv4 direct route redistribution on the IPv4 VRRP group member device for the dynamic routing protocol.
The IPv4 direct route on an interface can be associated only with one track entry. To change the track entry associated with the IPv4 direct route on an interface, you must first execute the undo route-direct track command to remove the original association.
# Associate track entry 1 with the IPv4 direct route on Ten-GigabitEthernet 3/0/1 and apply cost 200 to the IPv4 direct route after the track entry changes to Negative state.
[Sysname-Ten-GigabitEthernet3/0/1] route-direct track 1 degrade-cost 200
track vrrp (High Availability Command Reference)
routing-table limit
Use routing-table limit to set the maximum number of active IPv4/IPv6 routes supported by the device.
Use undo routing-table limit to restore the default.
routing-table limit number simply-alert
The maximum number of active IPv4/IPv6 routes is not set for the device.
number: Specifies the maximum number of active IPv4/IPv6 routes supported by the device, in the range of 1 to 4294967295.
simply-alert: Enables the device to still accept active routes but generate a log message when the number of active IPv4/IPv6 routes exceeds the maximum number.
Configuration in RIB IPv4 address family view limits the number of active IPv4 routes for the public network and all VPN instances.
Configuration in RIB IPv6 address family view limits the number of active IPv6 routes for the public network and all VPN instances.
# In RIB IPv4 address family view, set the maximum number of active IPv4 routes to 1000 for the public network and all VPN instances. The device still accepts new active routes but generates a system log message when the maximum number of active routes is exceeded.
[Sysname] rib
[Sysname-rib-ipv4] routing-table limit 1000 simply-alert
snmp-agent trap enable ipv6 rib
Use snmp-agent trap enable ipv6 rib to enable SNMP notifications for IPv6 RIB.
Use undo snmp-agent trap enable ipv6 rib to disable SNMP notifications for IPv6 RIB.
snmp-agent trap enable ipv6 rib [ cyclic-iterate-restrain | cyclic-iterate-restrain-clear | prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
undo snmp-agent trap enable ipv6 rib [ cyclic-iterate-restrain | cyclic-iterate-restrain-clear | prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
SNMP notifications are enabled for IPv6 RIB.
cyclic-iterate-restrain: Specifies notifications for route recursion loop suppression.
cyclic-iterate-restrain-clear: Specifies notifications for clearance of route recursion loop suppression.
prefix-exceed: Specifies notifications when the total number of IPv6 route prefixes reaches the maximum value.
prefix-exceed-clear: Specifies notifications when the total number of IPv6 route prefixes drops below the maximum value.
prefix-threshold-exceed: Specifies notifications when the total number of IPv6 route prefixes reaches the alarm threshold.
prefix-thresholdexceed-clear: Specifies notifications when the total number of IPv6 route prefixes drops below the alarm threshold.
public-prefix-exceed: Specifies notifications when the number of IPv6 route prefixes in the public network instance reaches the maximum value.
public-prefixexceed-clear: Specifies notifications when the number of IPv6 route prefixes in the public network instance drops below the maximum value.
public-prefixthreshold-exceed: Specifies notifications when the number of IPv6 route prefixes in the public network instance reaches the alarm threshold.
public-prefixthresholdexceed-clear: Specifies notifications when the number of IPv6 route prefixes in the public network instance drops below the alarm threshold.
vrf-prefix-exceed: Specifies notifications when the number of IPv6 route prefixes in a single VPN instance reaches the maximum value.
vrf-prefixexceed-clear: Specifies notifications when the number of IPv6 route prefixes in a single VPN instance drops below the maximum value.
vrf-prefixthreshold-exceed: Specifies notifications when the number of IPv6 route prefixes in a single VPN instance reaches the alarm threshold.
vrf-prefixthresholdexceed-clear: Specifies notifications when the number of IPv6 route prefixes in a single VPN instance drops below the alarm threshold.
After you enable this feature, IPv6 RIB can generate notifications and send them to the SNMP module. For the IPv6 RIB notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see the network management and monitoring configuration guide for the device.
If you do not specify any parameters, the command enables or disables all SNMP notifications for IPv6 RIB.
# Disable all IPv6 RIB SNMP notifications.
[Sysname] undo snmp-agent trap enable ipv6 rib
snmp-agent trap enable rib
Use snmp-agent trap enable rib to enable SNMP notifications for RIB.
Use undo snmp-agent trap enable rib to disable SNMP notifications for RIB.
snmp-agent trap enable rib [ cyclic-iterate-restrain | cyclic-iterate-restrain-clear | prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
undo snmp-agent trap enable rib [ cyclic-iterate-restrain | cyclic-iterate-restrain-clear | prefix-exceed | prefix-exceed-clear | prefix-threshold-exceed | prefix-thresholdexceed-clear | public-prefix-exceed | public-prefixexceed-clear | public-prefixthreshold-exceed | public-prefixthresholdexceed-clear | vrf-prefix-exceed | vrf-prefixexceed-clear | vrf-prefixthreshold-exceed | vrf-prefixthresholdexceed-clear ] *
SNMP notifications are enabled for RIB.
prefix-exceed: Specifies notifications when the total number of IPv4 route prefixes reaches the maximum value.
prefix-exceed-clear: Specifies notifications when the total number of IPv4 route prefixes drops below the maximum value.
prefix-threshold-exceed: Specifies notifications when the total number of IPv4 route prefixes reaches the alarm threshold.
prefix-thresholdexceed-clear: Specifies notifications when the total number of IPv4 route prefixes drops below the alarm threshold.
public-prefix-exceed: Specifies notifications when the number of IPv4 route prefixes in the public network instance reaches the maximum value.
public-prefixexceed-clear: Specifies notifications when the number of IPv4 route prefixes in the public network instance drops below the maximum value.
public-prefixthreshold-exceed: Specifies notifications when the number of IPv4 route prefixes in the public network instance reaches the alarm threshold.
public-prefixthresholdexceed-clear: Specifies notifications when the number of IPv4 route prefixes in the public network instance drops below the alarm threshold.
vrf-prefix-exceed: Specifies notifications when the number of IPv4 route prefixes in a single VPN instance reaches the maximum value.
vrf-prefixexceed-clear: Specifies notifications when the number of IPv4 route prefixes in a single VPN instance drops below the maximum value.
vrf-prefixthreshold-exceed: Specifies notifications when the number of IPv4 route prefixes in a single VPN instance reaches the alarm threshold.
vrf-prefixthresholdexceed-clear: Specifies notifications when the number of IPv4 route prefixes in a single VPN instance drops below the alarm threshold.
After you enable this feature, RIB can generate notifications and send them to the SNMP module. For the RIB notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see the network management and monitoring configuration guide for the device.
If you do not specify any parameters, the command enables or disables all SNMP notifications for RIB.
# Disable all SNMP notifications for RIB.
[Sysname] undo snmp-agent trap enable rib
