20-GPON
HomeSupportSwitchesS7500X-G SeriesReference GuidesCommand ReferencesH3C S7500X-G Switch Series Command References-R7761Pxx-6W10020-GPON
01-GPON basics commands
01-GPON basics commands 560.83 KB
GPON basics
activate onu
Use activate onu to activate a GPON ONU.
Use undo activate onu to deactivate an ONU.
activate onu
undo activate onu
The ONU connected to an ONU interface is in active state.
ONU interface view
To use a GPON ONU correctly, you must first activate it.
# Activate the ONU connected to interface ONU 1/0/2:1.
[Sysname] interface onu 1/0/2:1
[Sysname-Onu1/0/2:1] activate onu
authentication-mode
Use authentication-mode to configure the ONU authentication mode.
Use undo authentication-mode to delete the specified ONU authentication mode settings.
authentication-mode sn
undo authentication-mode sn
An OLT interface uses the SN mode for ONU authentication.
FTTH view
OLT interface view
sn: Specifies the SN mode. In this mode, an OLT interface authenticates ONUs based on the SN.
If you execute this command in interface view, the configuration takes effect only on the corresponding interface. If you execute this command in FTTH view, the configuration takes effect on all ROLT interfaces. An OLT interface preferentially uses the interface-specific ONU authentication mode. If no interface-specific ONU authentication mode is available, the OLT interface uses the ONU authentication mode configured in FTTH view.
To restore the default, do not specify any keyword when you execute the undo form. To delete an ONU authentication mode setting, specify the corresponding keyword when you execute the undo form.
# Set the ONU authentication mode to SN on OLT 1/0/1.
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] authentication-mode sn
bind onu-id
Use bind onu-id to bind a GPON ONU to an ONU interface and apply an ONU line profile.
Use undo bind onu-id to unbind an ONU from an ONU interface.
bind onu-id sn serial-number
undo bind onu-id
An ONU interface is not bound to any ONU.
ONU interface view
sn: Binds an ONU by its serial number (SN).
serial-number: Specifies the SN of an ONU, which is a case-sensitive string of 12 characters.
Application scenarios
When you bind a GPON ONU to an ONU interface, the specified (or default) ONU interface commands will be automatically issued to that ONU interface.
You can bind only one ONU to an ONU interface.
An ONU goes offline when you use the undo bind onu-id command to unbind it from its ONU interface.
After you bind an ONU, you can use the bind onu-line-profile command to apply a line profile to the bound ONU.
# Bind the GPON ONU with the specified SN to interface ONU 1/0/2:1.
[Sysname-Onu1/0/2:1] bind onu-id sn h3c-12345678
onu line-profile
blacklist onu-id
Use blacklist onu-id to add an ONU to the ONU blacklist.
Use undo blacklist onu-id to remove an ONU from the ONU blacklist.
blacklist onu-id sn serial-number
undo blacklist onu-id sn serial-number
No ONU is added to the ONU blacklist.
FTTH view
serial-number: Specifies the SN of an ONU, which is a case-insensitive string of 12 characters. The SN cannot contain question marks (?) or hexadecimal digits in the range of 0x0 to 0x20, and cannot start or end with any of the following characters DEL, @, ., ,, !, ;, :, `, and ".
An ONU added to the ONU blacklist cannot register with the OLT.
After you configure the ONU blacklist, the system will check whether any ONU that comes online is on the blacklist.
Up to 256 ONUs can be added to the ONU blacklist.
# Add an ONU with the specified SN to the ONU blacklist.
[Sysname] ftth
[Sysname-ftth] blacklist onu-id sn h2c-12345678
dba bandwidth-assignment-mode
Use dba bandwidth-assignment-mode to configure the dynamic bandwidth assignment (DBA) mode.
Use undo dba bandwidth-assignment-mode to restore the default.
In standalone mode:‌
dba bandwidth-assignment-mode slot slot-number min-delay
undo dba bandwidth-assignment-mode slot slot-number
In IRF mode:
dba bandwidth-assignment-mode chassis chassis-number slot slot-number min-delay
undo dba bandwidth-assignment-mode chassis chassis-number slot slot-number
The DBA mode is set to minimum delay.
FTTH view
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card.(In IRF mode.) ‌
min-delay: Specifies the minimum delay mode.
Operating mechanism
The DBA calculation period refers to the interval at which the OLT assigns bandwidth to an ONU. In a PON network, bandwidth is shared among OLTs and ONUs, so the DBA calculation period is used to dynamically assign bandwidth to meet diverse user requirements. A shorter DBA calculation period can enhance the precision and efficiency of bandwidth assignment but also increase network overhead.
# Configure the DBA mode as minimum delay for the specified slot.
[Sysname] ftth
[Sysname-ftth] dba bandwidth-assignment-mode slot 1 min-delay
display dhcp-client
Use display dhcp-client to display IP address assignment information for an ONU that acts as a DHCPv4 client.
display dhcp-client
ONU interface view
# Display IP address assignment information for the ONU bound to ONU 1/0/1:1 that acts as a DHCPv4 client. (The output from this command varies by device model.)
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] display dhcp-client
DHCP client statistic information :
  Current machine state : HALT
DHCP client statistics.
State of the DHCP client state machine.
display interface
Use display interface to display information of an OLT interface or ONU interface.
display interface [ interface-type [ interface-number ] ] [ brief [ description | down ] ]
interface-type: Specifies an interface type, which can be Olt or Onu. If you do not specify an interface type, this command displays information about all interfaces supported by the device.
interface-number: Specifies an interface number. If you specify an interface type but do not specify an interface number, this command displays information about all interfaces of the specified type.
brief: Displays brief interface information. If you do not specify this keyword, this command displays detailed interface information.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 25 characters of each interface description.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about OLT 1/0/1.
<Sysname> display interface Olt 1/0/1
Olt1/0/1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 00e0-fc00-511e
Description: Olt1/0/1 Interface
Maximum frame length: 1500
Port hardware type is 1000_BASE_PX_SFP
Flow-control is not enabled
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Known-unicast max-ratio: 100%
PVID: 1
Port link-type: Hybrid
 Tagged VLANs:   None
 Untagged VLANs: 1(default vlan)
Current system time:2019-01-05 05:12:35
Last time when physical state changed to up:-
Last time when physical state changed to down:2019-01-04 00:54:04
 Last 300 seconds input: 0 packets/sec 0 bytes/sec 0%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec 0%
 Input (total):  0 packets, 0 bytes
          - unicasts, - broadcasts, - multicasts, 0 pauses
 Input (normal):  0 packets, 0 bytes
 Input:  0 input errors, 0 runts, 0 giants, - throttles
          0 CRC, - frame, - overruns, - aborts
          - ignored, - parity errors
 Output (total): 100000 packets, 12800000 bytes
 Output (normal): 100000 packets, 12800000 bytes
          - aborts, - deferred, - collisions, - late collisions
          - lost carrier, - no carrier
  XGSPON input (normal): 100000 packets, 12893588 bytes
  XGSPON input: 0 input errors, 0 runts, 0 giants, 0 CRC
  XGSPON output (normal): 100000 packets, 12845974 bytes
  XGSPON output: 0 output errors
# Display detailed information about ONU 1/0/1:1.
<Sysname> display interface Onu 1/0/1:1
Onu1/0/1:1
Current state: DOWN
Description: Onu1/0/1:1 Interface
Loopback is not set
Port hardware type is 1000M_SFF_NO_CONNECTOR
PVID: 1
Port link-type: Access
 Tagged VLANs:   None
 Untagged VLANs: 1
 Last 300 seconds input: - packets/sec - bytes/sec -%
 Last 300 seconds output: - packets/sec - bytes/sec -%
          - unicasts, 0 broadcasts, - multicasts, - pauses
 Input (normal):  - packets, - bytes
          - unicasts, - broadcasts, - multicasts, - pauses
 Input:  0 input errors, - runts, 0 giants, - throttles
          0 CRC, 0 frame, - overruns, - aborts
 Output (normal): - packets, - bytes
 Output: - output errors, - underruns, 0 buffer failures
# Display brief information about all OLT interfaces.
<Sysname> display interface Olt brief
Speed: (a) - auto
Olt1/0/1             UP   --      --     H    1
Olt1/0/2             DOWN --      --     H    1
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
IPv4 packet framing format.
hardware address
MAC address of the interface.
Description of the interface.
Maximum length of Ethernet frames allowed to pass through the interface.
Interface hardware type.
Generic flow control is disabled on the interface. This field depends on your configuration and the link parameter negotiation result.
Broadcast max-
Broadcast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Multicast max-
Multicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Unicast max-
Unknown unicast storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
Known storm suppression threshold in ratio, pps, or kbps. The unit of the threshold depends on your configuration.
PVID
Port VLAN ID (PVID) of the interface.
Port link-type
Link type of the interface:
·     access.
·     trunk.
·     hybrid.
Tagged VLANs
VLANs for which the interface sends packets without removing VLAN tags.
UnTagged VLANs
VLANs for which the interface sends packets after removing VLAN tags.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Current system time
Current system time in the YYYY/MM/DD HH:MM:SS format.
If the time zone is configured, this field is in the YYYY/MM/DD HH:MM:SS zone-name±HH:MM:SS format, where the zone-name argument is the local time zone.
Last time when the physical state of the interface changed to up.
A hyphen (-) indicates that the physical state of the interface has never changed.
Last time when the physical state of the interface changed to down.
Average inbound or outbound traffic rate (in pps and Bps) in the last 300 seconds, and the ratio of the actual rate to the interface bandwidth.
A hyphen (-) indicates that the statistical item is not supported.
In the current software version, an ONU interface does not support collecting the average rate statistics.
 Input (total)
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
Input (normal)
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
Input
Statistics of abnormal packets received by the interface, including:
·     input errors—Number of inbound error packets.
·     runts—Number of runt frames.
·     giants—Number of giant frames.
·     throttles—Number of frames that had a non-integer number of bytes.
·     CRC—Number of frames that had a normal length, but contained CRC errors.
·     frame—Number of frames that contained CRC errors and a non-integer number of bytes.
·     overruns—Number of packets dropped because the input rate of the port exceeded the queuing capability.
·     aborts—Total number of illegal inbound packets:
¡     Fragment frames—CRC error frames shorter than 64 bytes.
¡     Jabber frames—CRC error frames greater than the maximum frame length supported on the interface.
¡     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     ignored—Number of inbound frames dropped because the receiving buffer of the port ran low.
·     parity errors—Number of frames with parity errors.
Output (total)
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output (normal)
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
Output
Statistics of abnormal packets sent by the interface, including:
·     output errors—Statistics of outbound error packets.
·     underruns—Number of packets dropped because the output rate of the interface exceeded the output queuing capability.
·     buffer failures—Number of packets dropped because the transmitting buffer of the interface ran low.
·     aborts—Number of packets that failed to be transmitted, for example, because of collisions.
·     deferred—Number of frames that the interface deferred to transmit because of detected collisions.
·     collisions—Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
·     late collisions—Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
·     lost carrier—Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
·     no carrier—Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the XGSPON Interface.
XGSPON input
Statistics of abnormal packets received by the XGSPON interface, including:
XGSPON output
Number of error packets sent by the XGSPON interface
Summary information of the Layer 2 interface.
Interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Speed
Speed of the interface, in bps.
Duplex
Duplex mode of the interface.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
display onu
Use display onu to display ONU information.
display onu [ silent [ sn ] | status [ keep-time keep-time ] ] { interface interface-type interface-number | slot slot-number }
In IRF mode:
display onu [ silent [ sn ] | status [ keep-time keep-time ] ] { interface interface-type interface-number | chassis chassis-number slot slot-number }
silent: Specifies ONUs in silent (unregistered) state. If you specify this keyword without specifying the [ mac | loid ] parameter, the displayed ONUs are all bound by MAC address.
sn: Specifies ONUs bound by SN.
status: Displays the ONU state information.
keep-time keep-time: Displays ONUs that have been in a state for a time longer than the specified time. The keep-time argument specifies the time of staying in up or offline state, in the range of 1 to 4294967295 minutes. If you do not specify this option, the command displays information about all ONUs.
interface interface-type interface-number: Specifies an interface by its type and number. The interface-type argument specifies an interface type, which can be olt or onu. The interface-number argument specifies an interface number.
slot slot-number: Specifies a card by its slot number.(In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.) ‌
# Display information about the ONUs in slot 1.
<Sysname> display onu status slot 1
---------------------------------- Olt1/0/1 ---------------------------------
SN             Port            Model          State    KeepTime   Description
3c8c-40cf-0f9e Onu1/0/1:1      ET254-G-S      Up       2625       Onu1/0/1:1 Interface
3c8c-40cf-0bf0 Onu1/0/1:2      ET254-G-S      Up       2625       Onu1/0/1:2 Interface
3c8c-40cf-04fd Onu1/0/1:3      N/A            Offline  239        Onu1/0/1:3 Interface
ONUs found: 128
  Up ONUs: 109
  Down ONUs: 8
  Offline ONUs: 11
SN
ONU serial number. This field is displayed only for ONUs bound to ONU interfaces.
Port
Bound ONU interface.
Model
ONU model. If the ONU is offline, this field displays N/A.
ONU state:
·     Offline—The ONU is powered off and it has been bound to an ONU interface. In this case, the KeepTime field displays the offline duration of the ONU.
·     Up—The ONU is powered on and it has been bound to an ONU interface. In this case, the KeepTime field displays the online duration of the ONU.
·     Down—The ONU has been bound to an ONU interface, but the ONU interface is down at the data link layer. In this case, the KeepTime field displays N/A, but the ONU is still considered as online and the online duration of the ONU still accumulates.
KeepTime
Time for which the ONU has been in the offline or up state, in minutes.
Description of the ONU interface.
If no description is configured for the ONU interface by using the description command, this field displays Interface name Interface, for example, Onu1/0/1:1 Interface.
ONUs found
Total number of ONU found, including:
·     Up ONUs—Number of online ONUs.
·     Down ONUs—Number of down ONUs.
·     Offline ONUs—Number of offline ONUs.
# Display information about all ONUs on the specified slot.
<Sysname> display onu slot 1
---------------------------------- Olt1/0/24 --------------------------------
SN           Distance      Port             Model          Sft/Epm    State     Aging
Version/LineProfile/Loid/Password
H3CT904094C9 <1000         Onu1/0/24:1      ET904-H        107/       Up        N/A
A/ys2//
H3CT000006F6 <1000         Onu1/0/24:2      EGT904-H-TW    111/       Up        N/A
V1.0.1/ys2//
SN
SN of the ONU.
Distance
Length of the optical fiber between the OLT and the ONU, in meters. If the optical fiber is significantly shorter than 1 km, this field displays <1000. If the ONU is not registered successfully, this field displays N/A.
Port
Bound ONU interface. If the ONU is not bound, this field displays N/A.
Model
ONU model. This field displays N/A if the ONU is not registered successfully.
Sft/Epm
Software version number and electrically erasable programmable read-only memory (EEPROM) version number of the ONU.
ONU state:
·     Silent—The ONU is powered on, and it is not bound to an ONU interface.
·     Offline—The ONU is powered off, and it is bound to an ONU interface.
·     Up—The ONU is powered on, and it is bound to an ONU interface.
·     Down—The ONU is bound to an ONU interface, but the ONU interface is manually shut down.
Aging
Remaining MAC address aging time of an ONU in silent state. This field displays N/A if the ONU is not in silent state.
The port is down.
The OLT interface is down.
display onu sn
Use display onu sn to display information about the legal ONU with the specified SN.
display onu sn serial-number
serial-number: Specifies the SN of an ONU, which is a case-sensitive string of 12 characters. The SN cannot contain question marks (?) or hexadecimal digits in the range of 0x0 to 0x20, and cannot start or end with any of the following characters DEL, @, ., ,, !, ;, :, `, and ".
# Display information about the legal ONU with the specified SN.
<Sysname> display onu sn h3c-12345678
SN           Distance       Port           Model/Version  Sft/Epm    State Aging        Password       ONU Line Profile
h3c-12345678 1200m          Onu1/0/1       BT/BV          S/E        Up   N/A          test           VOIP
For the descriptions on the fields, see the command output in "display onu."
display packet-drop
Use display packet-drop to display information about packets dropped by an interface.
‌In standalone mode:
display packet-drop { interface [ interface-type [ interface-number ] ] | slot [ slot-number ] | summary }
In IRF mode:
display packet-drop { interface [ interface-type [ interface-number ] ] | chassis [ chassis-number [ slot slot-number ] ] | summary }
summary: Displays the accumulative statistics of dropped packets on all interfaces that support this command.
slot [ slot-number ]: Specifies a card by its slot number. If you do not specify a card, this command displays entries on all cards. (In standalone mode.) ‌
chassis [ chassis-number [ slot slot-number ] ]: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify the chassis-number argument, this command displays entries on all cards on all member devices. If you do not specify the slot keyword, this command displays entries on all member devices. (In IRF mode.)
If you do not specify an interface type or interface number, this command displays dropped packet information for all interfaces that support this command.
If you specify an interface type but do not specify an interface number, this command displays dropped packet information for all interfaces of the specified type.
# Display information about packets dropped on interface OLT 1/4/0/5.
<Sysname> display packet-drop interface Olt 1/4/0/5
Olt1/4/0/5:
  Packets dropped due to full GBP or insufficient bandwidth: 0
  Packets dropped due to Fast Filter Processor (FFP): 0
  Packets dropped due to STP non-forwarding state: 0
  Packets dropped due to insufficient data buffer. Input dropped: 0, Output dropped: 0
  Packets of ECN marked: 0
# (In standalone mode.) Display dropped packet statistics for all slots.In standalone mode:‌
<Sysname> display packet-drop slot
Slot            Total
0               210
1               210
2               210
# (In IRF mode.) Display dropped packet statistics for all slots of all chassis.In IRF mode:
<Sysname> display packet-drop chassis
Chassis         Slot            Total
1               0               210
2               0               210
                1               210
                2               210
Table 5 Command output
Number of packets that are dropped because the buffer is used up or the bandwidth is insufficient.
Number of packets that are filtered out.
Number of packets dropped because STP is in the non-forwarding state.
Number of packets with the ECN field set to 11 because WRED queue thresholds are reached. For more information about WRED and ECN, see ACL and QoS Configuration Guide.
Slot
Slot number.
Chassis
Chassis number.
Total
Dropped packet statistics.
display pon authentication-mode
Use display pon authentication-mode to display ONU authentication mode settings of an OLT.
display pon authentication-mode [ interface interface-type interface-number ]
interface: Specifies an interface. If you do not specify an interface, this command displays all ONU authentication mode settings, including the settings configured in FTTH view and all settings specific to OLT interfaces.
interface-type: Specifies an interface type, which can be Olt.
# Display all ONU authentication mode settings.
<Sysname> display pon authentication-mode
Ftth authentication mode:-
Interface              Authentication-mode
Olt1/0/1               sn
Table 6 Command output
ONU authentication mode configured in FTTH view:
·     If the ONU authentication mode is not configured in FTTH view, this field displays a hyphen (-). In this situation, the default setting applies.
·     If the ONU authentication mode is configured in FTTH view, this field displays the configured mode settings. Available values are as follows:
¡     mac—Authenticates ONUs based on the MAC address.
¡     loid—Authenticates ONUs based on the LOID.
¡     loid-password—Authenticates ONUs based on the LOID and LOID password.
¡     mac and loid—Authenticates ONUs based on the MAC address or the LOID.
¡     mac and loid-password—Authenticates ONUs based on the MAC address, or the LOID and LOID password.
¡     sn—Authenticates ONUs based on the SN.
¡     sn and password—Authenticates ONUs based on the SN and password.
¡     password—Authenticates ONUs based on the password.
Interface name.
Authentication mode
Interface-specific ONU authentication mode:
·     If the ONU authentication mode is not configured for an OLT interface, the OLT interface is not displayed. In this case, the OLT interface uses the authentication mode settings configured in FTTH view.
·     If the ONU authentication mode is configured for an OLT interface, this field displays the configured authentication mode settings. Available values are as follows:
display pon diagnostic dba
Use display pon diagnostic dba to display GPON DBA diagnostic information.
display pon diagnostic dba slot slot-number
In IRF mode:
display pon diagnostic dba chassis chassis-number slot slot-number
In the current software version, DBA diagnostic information only includes the real-time obtained bandwidth allocation information of ONUs.
# Display GPON DBA diagnostic information on the specified slot.
<Sysname> display pon diagnostic dba slot 7
                 Total   Free    Fix     Assure
Olt7/0/1        8500000 8369312 129216  1472
                 AllocId Fix     Assure  Max
Onu7/0/1:1      1024    1216    1472    2688
Onu7/0/1:1      1025    0       0       10000000
Table 7 Command output
Total
Total bandwidth in kbps.
Free
Unassigned bandwidth in kbps.
Fix
Fixed bandwidth in kbps.
Assure
Assured bandwidth in kbps.
AllocId
Allocation ID, which distinguishes different T-CONTs on the same ONU subinterface.
Max
Maximum bandwidth in kbps.
display pon diagnostic config
Use display pon diagnostic config to display the profile state information of an ONU subinterface.
display pon diagnostic config interface interface-type interface-number
interface-type: Specifies an interface type, which can be Onu.
interface-number: Specifies an ONU subinterface by its number.
# Display the profile state information of the specified ONU subinterface.
<Sysname> display pon diagnostic config interface onu 1/0/1:1.2
Line Profile: line_profile_default
 Cfg  Profile: config_profile_default
 Mapping Mode: uni
 Upstream Fec: Default
 Encrypt: Enable
 SubInterface Number: 1
  SubInterface 1:
        Service Profile Name: service_profile_default
        Tcont Name: tcont_default
        Mapping info:
                Priority:
                Uni:all
                Vlan:
 Tcont Number: 1
  Tcont 1:
        Dba Name: dba_profile_default
Table 8 Command output
Line Profile
ONU line profile name.
Cfg  Profile
ONU configuration profile name.
Mapping Mod
ONU traffic mapping mode of an ONU subinterface.
Upstream Fec
FEC enabling state on the ONU subinterface.
·     Default—FEC is enabled.
·     Disable—FEC is disabled.
Encrypt
Downstream traffic encryption for ONUs.
·     Enable—Downstream traffic encryption is enabled.
·     Disable—Downstream traffic encryption is disabled.
SubInterface Number
Number of ONU subinterfaces.
ONU subinterface service profile name.
Tcont Name
T-CONT name.
Mapping info
Traffic mapping information for ONU subinterfaces.
Tcont Number
Number of T-CONTs.
Tcont Name
T-CONT name.
Dba Name
ONU DBA profile name.
display pon diagnostic config-error
Use display pon diagnostic config-error to display GPON configuration deployment failure information.
display pon diagnostic config-error { slot slot-number | interface interface-type interface-number }
In IRF mode:
display pon diagnostic config-error { chassis chassis-number slot slot-number | interface interface-type interface-number }
# Display profile configuration deployment failure information for the specified slot.
<Sysname> display pon diagnostic config-error slot 1
Onu1/0/1:1
 Line Profile Name: line_profile_default  Cfg  Profile Name: config_profile_default
Onu1/0/1:2
 Line Profile Name: l1    Cfg  Profile Name: 1
Onu1/0/1:3
Onu1/0/4:1
 Line Profile Name: l2    Cfg  Profile Name: 1
Table 9 Command output
Line Profile Name
Cfg  Profile Name
display pon diagnostic status
Use display pon diagnostic status to display the link state of an ONU subinterface.
display pon diagnostic status interface interface-type interface-number
# Display the link state of the specified ONU subinterface.
<Sysname> display pon diagnostic status interface onu 1/0/1:1
 UpTime                : 2024-12-09 11:29:13
 DownTime              : 2024-12-09 11:29:11
 DownCause             : Change ONU distance triggers offline
Table 10 Command output
UpTime
Time when an ONU interface came online.
DownTime
Most recent time when an ONU interface went offline.
DownCause
Most recent reason for which an ONU interface went offline.
display pon onu-event
Use display pon onu-event to display the registration and deregistration records of an ONU.
display pon onu-event interface interface-type interface-number
# Display the registration and deregistration records of the ONU bound to interface ONU 1/0/1:1.
<Sysname> display pon onu-event interface onu 1/0/1:1
Date         Time       ONU Status    ONU Event
2015/06/24   14:41:18   Up            Registration
2015/06/24   14:41:59   Down          Deregistration
2015/06/24   14:42:02   Up            Registration
2015/06/24   14:42:49   Down          Deregistration
Table 11 Command output
Date
Date when the ONU event occurred.
Time
Time when the ONU event occurred.
ONU Event
ONU event:
·     Registration.
·     Deregistration.
·     Lob—Packet loss.
·     Onu change Distance—The distance between the ONU and the OLT changed.
ONU Status
State of the ONU when the ONU event occurred:
·     Up.
·     Down.
display pon onu-loop-status
Use display pon onu-loop-status to display loop information of UNIs of ONUs.
display pon onu-loop-status { interface interface-type interface-number | slot slot-number }
In IRF mode:
display pon onu-loop-status { interface interface-type interface-number | chassis chassis-number slot slot-number }
interface interface-type interface-number: Specifies an OLT interface or ONU interface by its number. The interface-type argument specifies an interface type, which can be olt or onu. The interface-number argument specifies an interface number. If you specify an OLT interface, this command displays the update information for all ONUs connected to this OLT interface.
Use this command to view the loop information reported recently by UNIs of ONUs.
# Display the loop information reported by UNIs of all ONUs on the specified OLT interface.
<Sysname> display pon onu-loop-status interface olt 1/0/1
ONU Interface  UNI      Date    Time
Onu1/0/1:1
                1    2024/09/27 18:13:55
                2    2024/09/27 18:13:55
                3    2024/09/27 18:13:55
Table 12 Command output
ONU Interface
ONU interface name.
UNI
UNI number.
Date
Date when the UNI reported a loop.
Time
Time when the UNI reported a loop.
display pon onu-update
Use display pon onu-update to display ONU update information.
display pon onu-update { interface interface-type interface-number | slot slot-number }
In IRF mode:
display pon onu-update { interface interface-type interface-number | chassis chassis-number slot slot-number }
slot slot-number: Specifies all OLT interfaces on a card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies all OLT interfaces on a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.) ‌
# Display the ONU update information of slot 1.
<Sysname> display pon onu-update slot 1
Port           Model            Version          Protocol   State
Onu1/0/1:3     ET924-H-POE      105              H3C        Not Configured
Onu1/0/1:4     ET924-H-POE      105              H3C        Not Configured
Onu1/0/1:5     ET916-H-A        107              H3C        Not Configured
Onu1/0/1:6     ET908-H-P        106              H3C        Not Configured
Onu1/0/1:7     ET904-H          203              H3C        Not Configured
ONUs found: 5
---------------------------------- Olt1/0/2 ---------------------------------
The port is down.
Table 13 Command output
Port
ONU interface bound to the ONU.
Model
ONU model. This field displays N/A if the ONU is not powered on.
Version
PCB version. This field displays N/A if the ONU has not registered successfully.
Protocol
Update protocol type. Possible values are:
·     H3C—H3C proprietary update protocol.
·     CTC—CTC update protocol.
ONU update state:
·     Not configured—ONU update is not configured.
·     Configured—ONU update is configured, and the update command is to be issued to the ONU.
·     Updating(xx%)—The ONU is being updated. xx indicates the update progress.
·     Active—Version check for the update file succeeds, and the ONU is being rebooted. If the ONU fails to be rebooted, the update fails and the software version is rolled back.
·     Update canceled—The configuration is canceled during the process of sending the update file to the ONU.
·     Reconfigured—The update command is issued again by using another update file during the process of sending the update file to the ONU.
·     Successful—The ONU update succeeded.
·     Failed—The ONU update failed.
·     Unsupported protocol—The ONU does not support the specified update protocol.
ONUs found
Number of ONUs found.
The port is down.
display pon optics-parameters
Use display pon optics-parameters to display the optical parameters for an OLT interface.
display pon optics-parameters interface interface-type interface-number
interface-number: Specifies an OLT interface number.
# Display optical parameters for interface OLT 1/0/1.
<Sysname> display pon optics-parameters interface olt 1/0/1
Optical parameters:
 Temperature       :37.50 °C
 Voltage           :3.27 V
 Bias              :1.74 mA
 Transmitter power :4.36 dBm
 Receiving power   :-15.00 dBm
Table 14 Command output
Optical parameters
Optical parameters.
Temperature
Temperature.
Voltage
Voltage
Bias
Bias current.
For OLT interfaces on 10G-PON cards, this field becomes Bias(1G/10G) and displays the bias currents for both 1G-PON interfaces and 10G-PON interfaces, for example, 24.36 mA/80.72 mA.
Transmitter power
Transmit power.
For OLT interfaces on 10G-PON cards, this field becomes Transmitter power(1G/10G) and displays the transmit powers for both 1G-PON interfaces and 10G-PON interfaces, for example, 4.48 dBm/3.44 dBm.
Receiving power
Receive power.
For OLT interfaces on 10G-PON cards, this field becomes Receiving power(1G/10G) and displays the receive powers for both 1G-PON interfaces and 10G-PON interfaces, for example, -15.00 dBm/-5.00 dBm.
display pon version
Use display pon version to display version information for an OLT or ONU.
display pon version interface interface-type interface-number
You can view version information for an OLT or ONU only when the specified interface is up.
# Display version information about an OLT.
<Sysname> display pon version interface olt 1/0/1
Chip     : V1R1B1D008SP11, 20240716
Dba      : SoftWare, 20240815
Software : Mon Aug 19 07:45:13 UTC 2024
# Display version information about an ONU.
<Sysname> display pon version interface onu 1/0/1:1
 Model       : 9046
 HardWare    : A
 Software    : 106
 Extend Model: ET904-H
Table 15 Command output
Olt
Chip
FPGA version of the OLT.
Dba
Software DBA version. Software indicates DBA is implemented by software.
Software
Time when the software DBA version was compiled.
Onu
Model
ONU model.
Hardware
Hardware version number of the ONU.
Software
Software version number of the ONU.
Extend Model
Complete ONU model.
display uni
Use display uni to display information about a UNI on an ONU.
display uni uni-number
ONU interface view
uni-number : Specifies a UNI by its number in the range of 1 to the maximum number of UNIs supported on the ONU. An ONU supports up to 32 UNIs.
# Display information about UNI 1 of the ONU.
[Sysname-Onu1/0/1:1] display uni 1
 UNI 1
 Description          :
 Port status          : Undo shutdown
 Flow control         : Closed
 Autonegotiation state: Enable
 Port isolation       : Disable
 MDI type             : Automdix
 Port policy :
   Inbound :
     CIR : 0
     Bucket depth : 0
     Extra burst size : 0
   Outbound :
     CIR : 0
     PIR : 0
 Vlan configuration :
   VLAN mode : Transparent
 Classification & marking :
 Multicast VLAN : None
 Multicast groups : 64
 Multicast VLAN untagging : Disable
 Multicast VLAN forwarding info:
  VLAN ID:100
  Multicast MAC address:0100-5e00-0002
 Link state : DOWN
 Local autonegotiation ability :
   Full duplex 10M
   Full duplex 100M
   Full duplex 1000M
   Half duplex 10M
   Half duplex 100M
   Half duplex 1000M
 Autonegotiation advertisement ability :
   Full duplex 10M
   Full duplex 100M
   Full duplex 1000M
   Half duplex 10M
   Half duplex 100M
   Half duplex 1000M
 1000Mbps-speed mode, Full-duplex mode
 Link speed type is autonegotiation, Link duplex type is autonegotiation
 Input(total):  0 packets, 0 bytes
          0 broadcasts, 0 multicasts, 0 unicasts
 Input: 0 input errors, 0 runts, 0 giants,0 CRC,
         0 drop_events
 Packets of length(in octets):
         64: 0, 65-127: 0, 128-255: 0,
         256-511: 0, 512-1023: 0, 1024-1518: 0
 Output(total): 0 packets, 0 bytes
 Output: 0 output errors, 0 runts, 0 giants, 0 CRC,
         0 drop_events
 Status change: 0 times
Table 16 Command output
UNI
UNI number.
UNI description. This field is empty when the UNI is not configured with a description.
Port status
Administrative interface status:
·     Shutdown—The interface has been shut down by using the uni shutdown command.
·     Undo shutdown—The interface is administratively up.
Flow control
Flow control state:
·     Open—Flow control is enabled.
·     Closed—Flow control is disabled.
·     Enable—Autonegotiation is enabled.
·     Disable— Autonegotiation is disabled.
Port isolation
Whether the interface is assigned to a port isolation group:
·     Enable—The interface has been assigned to a port isolation group.
·     Disable—The interface is not assigned to a port isolation group.
MDI type
MDIX mode. Options include Automdix, Mdi, and Mdix. The value for this field depends on the user configuration.
Port policy
Upstream/downstream traffic policing parameters of the UNI:
·     Inbound—Upstream traffic policing parameters, including CIR, bucket depth, and extra burst size. To configure these parameters, use the uni port-policy inbound command.
·     Outbound—Downstream traffic policing parameters, including CIR and PIR. To configure these parameters, use the uni port-policy outbound command.
Vlan configuration
VLAN operation mode of the UNI:
·     Transparent—Transparent mode.
·     Add-vlan-tag—Tag mode.
·     Translation—Translation mode.
·     802.1q-in-802.1q—QinQ mode.
·     trunk—Trunk mode.
·     Aggregation—N:1 aggregation mode.
Possible fields of the VLAN operation mode are as follows:
·     PVID—PVID of the interface.
·     Priority—802.1p priority of packets.
·     Old VLAN—Original VLAN ID of packets.
·     New VLAN—Translated VLAN ID of packets.
·     Trunk VLAN—Permitted VLANs of the interface.
To configure the VLAN operation mode, use the uni vlan-mode command.
Traffic class configuration.
Multicast VLAN
Multicast VLAN to which the UNI is assigned.
Multicast groups
Number of multicast channels supported by the UNI.
Whether the feature of removing the VLAN tags of the downstream multicast packets is enabled on the UNI.
Unknown multicast packet transparent transmission configuration information of the UNI.
VLAN ID
VLAN ID corresponding to the multicast MAC address.
Multicast MAC address with unknown multicast packet transparent transmission enabled.
Link state
Link layer state of the interface:
·     UP.
·     DOWN.
100Mbps-speed mode, Full-duplex mode
The port operates at 100 Mbps in full duplex mode.
Both the speed and duplex mode of the port are autonegotiated.
Input(total)
Statistics of packets received by the interface, including:
·     Packet count and byte count.
·     Number of broadcast packets, number of multicast packets, and number of unicast packets received on the interface.
Input
Counts for the following frames received on the interface:
·     Error frames.
·     Runt frames.
·     Giant frames.
·     Frames having the CRC errors.
·     Fragment frames.
·     Jabber frames—Frames greater than the maximum frame length supported on the interface.
·     Discards—Discarded packets.
·     drop_events—Drop events.
·     errors—Error packets.
Number of packets with different byte lengths received by the interface.
Output(total)
Statistics of packets sent by the interface, including:
·     Number of broadcast packets, number of multicast packets, and number of unicast packets sent on the interface.
Output
Counts for the following frames sent on the interface:
·     Error frames.
·     Runt frames.
·     Giant frames.
·     Fragment frames.
Number of packets with different byte lengths sent by the interface.
Status change
Administrative status change count of the interface.
display vendor-specific information
Use display vendor-specific information to display detailed ONU information.
ONU interface view
# Display detailed information about the ONU attached to interface Onu 1/0/1:1.
[Sysname-Onu1/0/1:1] display vendor-specific information
 Serial number
     Vendor ID : H3CT
     ONU MAC address : 0000-0000-0000
     ONU model : EGT904-H-TW
     ONU hardware version : V1.0.1
     ONU software version : 212
     ONU extend model : EGT904-H-TW
 ONU capability :
     Gigabit ethernet interface :  Support
     Fast ethernet interface :  Not support
     VoIP service :  Support
     TDM ces service :  Not support
     Gigabit ethernet ports number :  4
     Fast ethernet ports number :  0
     POTS ports number :  1
     E1 ports number :  0
     Upstream queues number :  120
     Maximum queues per port upstream :  0
     Downstream queues number :  32
     Maximum queues per port downstream :  0
     Battery backup :  Not support
 ONU capability2 :
     ONU type :  SFU
     LLID number :  0
     Protection type :  Not support
     Slot number :  0
     PON number :  1
     Interface type number :  3
     VoIP ports number :  1
     GE ports number :  4
     FE ports number :  0
     WLAN ports number :  2
     CATV RF ports number :  0
 Onu-Type : 10G/10G
Table 17 Command output
Serial number
Serial number.
Vendor ID
ONU vendor ID.
ONU MAC address
MAC address of the ONU.
ONU model
ONU type.
ONU hardware version.
ONU software version.
ONU extend model
Complete ONU model. This field is required for the CTC 3.0 standard.
Firmware version
Firmware version.
Chipset information
Chip information.
·     Vendor ID.
·     Chip model.
·     Revision version.
·     Design date.
ONU capability
ONU capability information.
·     Gigabit Ethernet interface—Whether GE interfaces are supported..
·     Fast Ethernet interface—Whether 100-Mbps Ethernet interfaces are supported..
·     VoIP service—Whether the voice over IP (VoIP) service is supported.
·     TDM ces service—Whether the time division multiplexing (TDM) circuit emulation service (CES) service is supported.
·     Gigabit ethernet ports number—Number of GE interfaces.
·     Fast ethernet ports number—Number of 100-Mbps Ethernet interfaces.
·     POTS ports number—Number of Plain Old Telephone Service (POTS) interfaces.
·     E1 ports number—Number of E1 interfaces.
·     Upstream queues number—Number of upstream queues.
·     Maximum queues per port upstream—Maximum number of upstream queues supported on each interface.
·     Downstream queues number—Number of downstream queues.
·     Maximum queues per port downstream—Maximum number of downstream queues supported on each interface.
·     Battery backup—Whether battery backup is supported.
ONU capability(CTC2.1)
ONU capability information (CTC2.1 standard).
·     ONU type—ONU form factor, including:
¡     Single Family Unit (SFU).
¡     Home Gateway Unit (HGU).
¡     Single Business Unit (SBU).
¡     Fixed-port Multi-Dwelling Unit (MDU).
¡     Modular MDU.
¡     Multi-Tenant Unit (MTU).
·     LLID number—Number of LLIDs supported by the ONU.
·     Protection type—Optical link protection types supported by the ONU, including type C and type D.
·     Slot number—Number of service slots of a modular ONU.
·     PON number—Number of upstream PON interfaces supported by the ONU.
·     Interface type number—Number of interface types on the ONU.
·     VoIP port number—Number of VoIP interfaces on the ONU.
·     GE ports number—Number of GE interfaces on the ONU.
·     FE ports number—Number of 100-Mbps Ethernet interfaces on the ONU.
·     WLAN ports number—Number of WLAN interfaces on the ONU.
·     CATV RF ports number—Number of CATV RF interfaces on the ONU.
ONU capability(CTC3.0)
ONU capability information (CTC3.0 standard).
·     IPv6 supported—Whether IPv6 awareness is supported.
·     Power supply control—Whether ONU power control is supported, including ONU Tx power control and ONU Rx power control.
·     Service SLA—Whether the Service Level Agreement (SLA) feature is supported.
Forward error correction ability
Whether the FEC feature is supported.
IGMP-snooping fast-leave
Whether the fast leave feature for the specified UNIs is supported.
Multicast control fast-leave
Whether the fast leave feature for all UNIs is supported.
Forward error correction mode
Whether the FEC feature is enabled.
DBA-Report parameters
DBA report message parameters.
·     Queue set number—Number of queue sets supported.
·     Queue set—Queue set number.
·     Queue x: State: x, Value: x—State (state) and threshold (value) of queue x. State 0 means the queue is disabled. State 1 means the queue is enabled.
Multicast-fast-leave
Whether the fast leave feature is enabled on all UNIs of the ONU.
ONU-Isolate state
Whether the isolation feature is enabled for all UNIs of the ONU.
Multicast-mode
Multicast mode: IGMP snooping (IGSP) or multicast control.
ip address
Use ip address to assign an IPv4 address to the management VLAN interface of an ONU.
Use undo ip address to restore the default.
ip address { dhcp-alloc | ip-address { mask-length | mask } gateway gateway }
undo ip address
No IPv4 address is assigned to the management VLAN interface of an ONU.
ONU interface view
dhcp-alloc: Specifies DHCP IPv4 address allocation.
ip-address: Specifies an IPv4 address in dotted decimal format.
mask-length: Specifies the length of the subnet mask, in the range of 1 to 31. The subnet mask length is the number of consecutive 1s in the subnet mask.
mask: Specifies a subnet mask in dotted decimal format.
gateway gateway: Specifies the gateway IPv4 address.
For the IPv4 address configured for the management VLAN interface of an ONU to take effect, first bind the ONU to a line profile.
If the management VLAN of an ONU is changed, the IP address of the original management VLAN interface is deleted.
When you configure an IP address for the management VLAN interface of an ONU interface, the device does not prompt whether the IP address conflicts with that of any other interface. If multiple interfaces are configured with the same IP address, only the first configuration takes effect.
# Assign the IPv4 address 192.168.0.1/24 to the management VLAN interface of the ONU bound to ONU 1/0/1:1, and specify the gateway IP address as 192.168.0.99.
[Sysname-Onu1/0/1:1] ip address 192.168.0.1 24 gateway 192.168.0.99
management-vlan
ipv6 address
Use ipv6 address to assign an IPv6 address to the management VLAN interface of an ONU.
Use undo ipv6 address to restore the default.
ipv6 address { dhcp-alloc | { ipv6-address prefix-length | ipv6-address/prefix-length } gateway gateway }
undo ipv6 address
No IPv6 address is assigned to the management VLAN interface of an ONU.
ONU interface view
dhcp-alloc: Specifies DHCP IPv6 address allocation.
ipv6-address: Specifies an IPv6 address for the management VLAN interface of an ONU.
prefix-length: Specifies the prefix length in the range of 1 to 128.
gateway gateway: Specifies the gateway IPv6 address.
For the IPv6 address configured for the management VLAN interface of an ONU to take effect, first bind the ONU to a line profile.
# Assign the IPv6 address 2001::1 to the management VLAN interface of the ONU bound to ONU 1/0/1:1, and specify the gateway IPv6 address as 2001::99.
[Sysname-Onu1/0/1:1] undo shutdown management-vlan-interface
[Sysname-Onu1/0/1:1] ipv6 address 2001::1/64 gateway 2001::99
management-vlan
management server
Use management server to configure the AD-Campus server connection parameters for ONUs.
Use undo management server to delete the AD-Campus server connection parameters for ONUs.
management server source-ip ip-address [ port port-number ] [ keepalive interval ] password { cipher | simple } string
The AD-Campus server connection parameters are not configured for ONUs.
FTTH view
source-ip ip-address: Specifies a server by its IPv4 address.
port port-number: Specifies the TCP port number for the ONUs to establish connections to the server, in the range of 1 to 65535. If you do not specify this option, no TCP port is configured.
keepalive interval: Specifies the interval for ONUs to send keepalive packets, in the range of 1 to 600 seconds. By default, it is 60 seconds.
password cipher: Specifies a password in encrypted form.
password simple: Specifies a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies a case-sensitive password string. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
In an Application Driven Campus (AD-Campus) network, the OLT provides Internet access services for the ONUs. Use this command to remotely configure the AD-Campus server connection parameters on the OLT, facilitating the connection between ONU and server.
# Configure the following AD-Campus server connection parameters for ONUs:
·     Server IP address 10.1.1.1.
·     Interval of 100 seconds for sending keepalive packets.
·     TCP port number 800 for establishing connections.
·     Password 12345678TESTplat&!.
[Sysname] ftth
[Sysname-ftth] management server source-ip 10.1.1.1 port 800 keepalive interval 100 password simple 12345678TESTplat&!
management-vlan
Use management-vlan to specify the management VLAN of an ONU.
Use undo management-vlan to restore the default.
management-vlan vlan-id
The management VLAN of an ONU is VLAN 1.
ONU interface view
ONU configuration profile view
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
# Specifies the management VLAN as VLAN 10 for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] management-vlan 10
olt-mode
Use olt-mode to configure the OLT operating mode.
Use undo olt-mode to restore the default.
olt-mode slot slot-number { 64-onu | 128-onu | 256-onu }
undo olt-mode slot slot-number
In IRF mode:
olt-mode chassis chassis-number slot slot-number { 64-onu | 128-onu | 256-onu }
undo olt-mode chassis chassis-number slot slot-number
An OLT operates in 64-ONU mode.
FTTH view
64-onu: Specifies the 64-ONU mode. In this mode, up to 64 ONU interfaces can be created on an OLT interface in the specified slot.
128-onu: Specifies the 128-ONU mode. In this mode, up to 128 ONU interfaces can be created on an OLT interface in the specified slot.
256-onu: Specifies the 256-ONU mode. In this mode, up to 256 ONU interfaces can be created on an OLT interface in the specified slot.
After you change the OLT operating mode for a slot, you must reboot the slot or the whole device to make the OLT operating mode change take effect.
·     If the slot is rebooted, all OLT interfaces in the slot are restored to the default settings, and the ONU interfaces created on the OLT interfaces are deleted.
·     When the OLT operating mode is changed from 128-ONU or 256-ONU to 64-ONU, ONU interfaces numbered more than 64 are deleted. When the OLT operating mode is changed from 256-ONU to 128-ONU, ONU interfaces numbered more than 128 are deleted.
# Configure the OLT operating mode as 128-ONU for the specified slot.
[Sysname] ftth
[Sysname-ftth] olt-mode slot 1 128-onu
onu flow
Use onu flow to forward multicast and broadcast packets from an ONU in multiple VLANs.
Use undo onu flow to cancel forwarding multicast and broadcast packets from an ONU in multiple VLANs.
onu flow flow-id vlan vlan-id { destination-ip ipv4-address { mask-length | mask } | destination-mac mac-address } [ udp-port port-number ] forward-vlan vlan-list
undo onu flow flow-id
Multicast and broadcast packets from an ONU are not configured to be forwarded in multiple VLANs.
flow-id: Specifies a flow matching rule ID in the range of 1 to 1000. A smaller ID indicates a higher flow matching priority.
vlan vlan-id: Specifies the VLAN of multicast or broadcast packets. The value range for the vlan-id argument is 1 to 4094.
destination-ip ipv4-address: Specifies a destination IPv4 address in dotted decimal notation for multicast or broadcast packets. A multicast IP address is in the range of 224.0.0.0 to 239.255.255.255. The broadcast IP address is 255.255.255.255.
mask-length: Specifies a subnet mask length (the number of consecutive ones in the mask) in the range of 1 to 31.
mask:  Specifies a mask in dotted decimal notation for the IPv4 address.
destination-mac mac-address: Specifies the destination MAC address of multicast packets or broadcast packets in the format of H-H-H. A multicast MAC address is in the range of 0100-5E00-0000 to 0100-5EFF-FFFF. The broadcast MAC address is FFFF-FFFF-FFFF.
udp-port port-number: Specifies the UDP port number of multicast packets or broadcast packets in the range of 1 to 65535. If you do not specify this option, the UDP port number is ignored when multicast or broadcast packets are matched.
forward-vlan vlan-list: Specifies the list of forwarding VLANs. The vlan-list argument specifies multiple VLANs in the form of vlan-list = { vlan-id [ to vlan-id ] }&<1-10>. The vlan-id argument is a VLAN ID in the range of 1 to 4094. &<1-10> means that you can provide up to 10 VLANs/VLAN ranges for this argument.
Use this command to flexibly forward packets across VLANs at Layer 2. When an OLT with this feature configured receives a packet with the specified destination MAC address/IP address and port number from the specified VLAN from an ONU, it forwards the packet directly to the specified target VLANs.
Up to 1000 flow matching rules are supported.
This command is not support on an M-LAG network.
This command does not support matching multicast IPv6 packets.
If you execute this command multiple times with the same flow-id argument, the most recent configuration takes effect.
# Configure flow matching rule 1 to forward multicast packets from VLAN 1 and destined to IP address 255.1.1.1/16 to VLANs 10 through 20.
[Sysname] onu flow 1 vlan 1 destination-ip 255.1.1.1 16 forward-vlan 10 to 20
onu bind auto
Use onu bind auto to enable automatic ONU binding.
Use undo onu bind auto to disable automatic ONU binding.
onu bind auto [ slot slot-number ] [ bind-type { mac | sn }* ]
undo onu bind auto [ slot slot-number ] [ bind-type { mac | sn }* ]
In IRF mode:
onu bind auto [ chassis chassis-number slot slot-number ] [ bind-type { mac | sn }* ]
undo onu bind auto [ chassis chassis-number slot slot-number ] [ bind-type { mac | sn }* ]
Automatic ONU binding is disabled.
FTTH view
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command enables automatic ONU binding for all cards.(In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command enables automatic ONU binding for all cards in the IRF fabric.(In IRF mode.) ‌
bind-type: Specifies an ONU binding type. If you do not specify a binding type, ONU MAC addresses or SNs are used for ONU binding.
mac: Specifies MAC address binding.
sn: Specifies SN binding.
If an ONU is not bound to any ONU interface, the ONU cannot be registered. Such an ONU is called a silent ONU. Automatic ONU binding automatically binds ONU interfaces to existing silent ONUs and ONUs that join the system after this feature is enabled.
Automatic ONU binding applies to an EPON system where ONUs attached to the OLT are completely trustworthy. To unbind an ONU, first use the undo onu bind auto command to disable automatic ONU binding.
You can execute this command multiple times to add ONU binding types.
If you do not specify an ONU binding type when you execute the undo onu bind auto command, automatic ONU binding is disabled. If you specify ONU binding types when you execute the undo onu bind auto command, automatic ONU binding is disabled for the specified binding types.
# Enable automatic ONU binding on the specified slot.
[Sysname] ftth
[Sysname-ftth] onu bind auto slot 1
onu bind batch
Use onu bind batch to perform bulk ONU binding.
onu bind batch [ slot slot-number ] [ bind-type sn ]
In IRF mode:
onu bind batch [ chassis chassis-number slot slot-number ] [ bind-type sn ]
Bulk ONU binding is not performed.
FTTH view
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command enables bulk ONU binding for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command enables bulk ONU binding for all cards in the IRF fabric. (In IRF mode.) ‌
bind-type: Specifies an ONU binding type. If you do not specify a binding type, ONU SNs are used for ONU binding.
Bulk ONU binding automatically binds existing unregistered ONUs to ONU interfaces at a time. The ONUs that join the system after bulk ONU binding is performed will not be bound.
Bulk ONU binding applies to a newly established EPON system that contains only legal ONUs. To manually bind new ONUs after bulk ONU binding is performed, use the bind onu-id command.
# Perform bulk ONU binding on the specified slot.
[Sysname] ftth
[Sysname-ftth] onu bind batch slot 1
onu bind type
Use onu bind type to bulk apply an ONU line profile based on ONU type.
Use undo onu bind type to restore the default.
onu bind type onu-type [ onu-line-profile profile-name ]
undo onu bind type onu-type
ONU line profile line_profile_default is bulk applied.
FTTH view
onu-type: Specifies an ONU type (such as ET704-A), a case-sensitive string of 1 to 31 characters.
Onu-line-profile profile-name: Specifies an ONU line profile by its name. It is a case-sensitive string of 1 to 31 characters and supports only digits, letters, and underscores (_). If you do not specify this parameter, ONU line profile line_profile_default is bulk applied.
After the onu bind auto command is used to enable automatic ONU binding or the onu bind batch command is used to perform bulk ONU binding, the device will automatically bind unregistered ONUs to the ONU interfaces on the device as follows:
·     For ONUs of the type specified by using this command, the specified ONU line profile will be applied to their ONU interfaces.
·     For ONUs that are not of the specified type, the default ONU line profile named line_profile_default will be applied to their ONU interfaces.
The system supports bulk applying ONU line profiles to up to 32 ONU types.
# Bulk apply the ONU line profile named line_profile_voip to all ONUs of type ET704-A-L. Then, enable automatic ONU binding for the ONUs on the specified slot.
[Sysname] ftth
[Sysname-ftth] onu bind type et704-a-l onu-line-profile line_profile_voip
onu-distance
Use onu-distance to set the maximum and minimum logical distances between OLT and ONU in OLT ranging.
Use undo onu-distance to restore the default.
onu-distance { max distance |  min distance } *
undo onu-distance
The maximum logical distance between OLT and ONU is 20 kilometers, and the minimum logical distance is 0 kilometers.
OLT interface view
max distance: Sets the maximum distance between OLT and ONU, in the range of 0 to 60 kilometers.
min distance: Sets the minimum distance between OLT and ONU, in the range of 0 to 60 kilometers.
Application scenarios
During the registration process of an ONU, the OLT measures the physical distance of the optical fiber between the ONU and the OLT. Then, the OLT allocates timing to the ONU based on the physical distance to prevent upstream data collisions. To quickly obtain the ranging results, you can pre-set the logical distances between OLT and ONU.
Operating mechanism
The maximum logical distance defines the greatest acceptable distance between the OLT and ONU. It also determines the longest time the OLT will wait to transmit a signal and receive a reply from the ONU. If the actual physical distance exceeds this distance, the OLT will consider the ONU unreachable and cannot establish a connection.
The minimum logical distance defines the shortest acceptable distance between the OLT and ONU. It also determines the shortest time the OLT will wait to transmit a signal and receive a reply from the ONU. If the actual physical distance is less than this distance, the OLT will consider the ONU too close, which might cause signal interference. As a result, the OLT cannot establish a connection.
The smaller the minimum logical distance, the faster the OLT can receive replies from the ONU. The larger the maximum logical distance, the farther the OLT can connect to an ONU. Adjusting these parameters enables fast, precise measurement of the distance between the OLT and ONU.
Use this command to modify the logical distances for ranging only if you have a certain level of PON deployment knowledge. If you do not, use the default configuration to avoid longer ranging time due to incorrect parameter values.
The minimum logical distance must be less than the maximum logical distance.
# Set the maximum and minimum logical distances between the OLT and ONU to 30 kilometers and 15 kilometers, respectively, during the ranging process on interface OLT 1/0/1.
[Sysname] interface olt 1/0/1
[Sysname-Olt1/0/1] onu-distance max 30 min 15
Use shutdown management-vlan-interface to shut down the management VLAN interface on an ONU.
Use undo shutdown management-vlan-interface to bring up the management VLAN interface on an ONU.
The management VLAN interface on an ONU is shut down.
ONU interface view
After you bring up the management VLAN interface on an ONU, you must assign an IP address to the interface.
After you execute the undo shutdown management-vlan-interface command, the management VLAN interface status depends on the status of Ethernet interfaces (UNIs) in the VLAN:
·     When all Ethernet interfaces in the VLAN for the management VLAN interface on the ONU are down, the management VLAN interface is down.
·     When one or more Ethernet interfaces in the VLAN for the management VLAN interface on the ONU are up, the management VLAN interface is up.
# Bring up the management VLAN interface on the ONU.
[Sysname] interface onu 1/0/1:1
using onu
Use using onu to create ONU interfaces.
Use undo using onu to delete ONU interfaces.
using onu onu-number-list
undo using onu onu-number-list
No ONU interfaces exist.
OLT interface view
onu-number-list: Specifies a space-separated list of up to 10 ONU interface items. Each item specifies an ONU interface number or an ONU interface number range in the form of { onu-number1 [ to onu-number2 ] }. The value for the onu-number2 argument must be larger than or equal to the value for the onu-number1 argument. The value range for the onu-number1 and onu-number2 arguments varies by OLT operating mode as follows: In 64-ONU mode, the value range is 1 to 64. In 128-ONU mode, the value range is 1 to 128. In 256-ONU mode, the value range 1 to 256.
On an OLT interface, the ONU interface created by using this command is named in the format of onu interface-number.
# Create ONU interface 1 on OLT 1/0/2.
[Sysname] interface Olt 1/0/2
[Sysname-Olt1/0/2] using onu 1
GPON configuration profile commands
This section primarily provides the GPON basics commands related to ONU configuration profiles, ONU DBA profiles, ONU line profiles, and ONU subinterface service profiles.
apply onu-config-profile
Use apply onu-config-profile to apply an ONU configuration profile to an ONU line profile.
Use undo apply onu-config-profile to restore the default.
apply onu-config-profile profile-name
ONU configuration profile config_profile_default is applied to an ONU line profile.
ONU line profile view
profile-name: Specifies a profile name, a case-sensitive string of 1 to 31 characters.
For more information about ONU configuration profiles, see the onu config-profile command.
# Apply the specified ONU configuration profile to ONU line profile ET354.
[Sysname] onu line-profile ET354
[Sysname-onu-lineprofile-ET354] apply onu-config-profile config-ET354
onu config-profile
apply onu-service-profile
Use apply onu-service-profile to apply an ONU subinterface service profile to an ONU line profile subinterface.
Use undo apply onu-service-profile to restore the default.
apply onu-service-profile profile-name
The default ONU subinterface service profile named service_profile_default is applied to an ONU line profile subinterface.
ONU line profile subinterface view
For more information about ONU subinterface service profiles, see the onu service-profile command.
# Apply the specified ONU subinterface service profile to subinterface 2 of ONU line profile 30.
[Sysname] onu line-profile 30
[Sysname-onu-lineprofile-30] subinterface 2
[Sysname-onu-lineprofile-30-subinterface-2] apply onu-service-profile YY
onu service-profile
apply tcont
Use apply tcont to apply a transmission container (T-CONT) to an ONU line profile subinterface.
Use undo apply tcont to restore the default.
apply tcont tcont-name
undo apply tcont
The default T-CONT named tcont_default is applied to an ONU line profile subinterface, and the T-CONT uses the ONU DBA profile named dba_profile_default.
tcont-name: Specifies the name of a T-CONT, which must already exist in an ONU line profile.
For more information about T-CONTs, see the tcont command.
# Configure a T-CONT named voip in ONU line profile 30, and apply the ONU DBA profile named dba-voip to the T-CONT. Enter the view of subinterface 2 of the ONU line profile and apply the T-CONT named voip to the subinterface.
[Sysname-onu-lineprofile-30] tcont voip onu-dba-profile dba-voip
[Sysname-onu-lineprofile-30-subinterface-2] apply tcont voip
tcont
bind onu-line-profile
Use bind onu-line-profile to apply an ONU line profile to an ONU interface.
Use undo bind onu-line-profile to remove an ONU line profile from an ONU interface.
bind onu-line-profile profile-name
No ONU line profile is applied to an ONU interface.
ONU interface view
onu-line-profile profile-name: Specifies an ONU line profile by its name, a case-insensitive string of 1 to 31 characters. Make sure the specified profile already exists.
You can apply the same ONU line profile to multiple ONU interfaces. After you apply an ONU line profile to an ONU interface, the commands stored in the profile are issued to the interface. This saves configuration effort and enables automated bulk configuration.
# Apply the ONU line profile named VOIP to  ONU interface ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] bind onu-line-profile VOIP
onu line-profile
dba type1
Use dba type1 to configure type 1 DBA, which is fixed bandwidth.
Use undo dba type to restore the default.
dba type1 [ ratio ] fix fix-bandwidth
undo dba type
A newly created ONU DBA profile does not have bandwidth configuration.
ONU DBA profile view
ratio: Specifies bandwidth in permillage. If you do not specify this keyword, this command sets the absolute bandwidth value.
fix fix-bandwidth: Specifies the fixed bandwidth reserved for ONUs, in the range of 128 to 10000000 kbps. After configuration, the value is automatically rounded down to the nearest multiple of 64. If the ratio keyword is also specified, the value range is 1 to 1000, with each unit representing one-thousandth of the maximum ONU bandwidth.
The fixed bandwidth is fully reserved for the specific ONUs. Even if those ONU have no upstream traffic, this portion of bandwidth remains unavailable for the other ONUs. Use fixed bandwidth mainly for services with high QoS requirements, such as VoIP.
Recommended configuration
As a best practice, configure bandwidth in permillage, because the maximum bandwidth might vary by ONU.
If you execute the dba type1, dba type2, dba type3, dba type4, and dba type5 commands multiple times in the same DBA profile, the most recent configuration takes effect.
# Configure type 1 DBA, and set the fixed bandwidth to 15 Mbps.
[Sysname] onu dba-profile dba_15M
[Sysname-onu-dbaprofile-dba_15M] dba type1 fix 15000
dba type2
Use dba type2 to configure type 2 DBA, which is assured bandwidth.
dba type2 [ ratio ] assure assure-bandwidth
undo dba type
assure assure-bandwidth: Specifies the assured bandwidth that can be allocated to ONUs, in the range of 128 to 10000000 kbps. After configuration, the value is automatically rounded down to the nearest multiple of 64. If the ratio keyword is also specified, the value range is 1 to 1000, with each unit representing one-thousandth of the maximum ONU bandwidth.
Assured bandwidth is the bandwidth allocated by the OLT to ONUs. If the actual traffic of these ONUs does not consume the assured bandwidth, the DBA mechanism reallocates the unused bandwidth to the other ONUs.
If you execute the dba type1, dba type2, dba type3, dba type4, and dba type5 commands in the same DBA profile, the most recent configuration takes effect.
# Configure type 2 DBA, and set the assured bandwidth to 15 Mbps.
[Sysname-onu-dbaprofile-dba_15M] dba type3 assure 15000
dba type3
Use dba type3 to configure type 3 DBA, which is assured bandwidth+maximum bandwidth.
dba type3 [ ratio ] assure assure-bandwidth max max-bandwidth
undo dba type
assure assure-bandwidth: Specifies the assured bandwidth that can be allocated to ONUs, in the range of 128 to 9999999 kbps. If the specified value is not a multiple of 64, the effective value is nearest lower multiple of 64. If the ratio keyword is also specified, the value range is 1 to 999, with each unit representing one-thousandth of the maximum ONU bandwidth.
max max-bandwidth: Specifies the maximum bandwidth that can be used by ONUs. The value range is dynamic. The maximum value is 10000000 kbps, and the minimum value is 64 plus the effective assured bandwidth (in kbps). If the configured value is not a multiple of 64, the effective value is nearest lower multiple of 64. If the ratio keyword is also specified, the value range is dynamic. The maximum value is 1000, and the minimum value is 1 plus the assured bandwidth value. Each unit represents one-thousandth of the maximum ONU bandwidth.
ONUs that use type 3 DBA can preempt a certain amount of bandwidth in addition to the assured bandwidth that has been allocated. However, the total bandwidth cannot exceed the maximum bandwidth.
Type 3 DBA is primarily used for VoIP and IPTV services.
The actual effective value of the maximum bandwidth must be greater than the actual effective value of the assured bandwidth.
# Configure type 3 DBA, set the assured bandwidth to 15 Mbps, and set the maximum bandwidth to 30 Mbps.
[Sysname-onu-dbaprofile-dba_15M] dba type3 assure 15000 max 30000
dba type4
Use dba type4 to configure type 4 DBA, which is the maximum bandwidth.
dba type4 [ ratio ] max max-bandwidth [ priority priority | weight weight ] *
undo dba type
max max-bandwidth: Specifies the maximum bandwidth that can be used by ONUs, in the range of 128 to 10000000 kbps. After configuration, the value is automatically rounded down to the nearest multiple of 64. If the ratio keyword is also specified, the value range is 1 to 1000, with each unit representing one-thousandth of the maximum ONU bandwidth.
priority priority: Specifies a bandwidth allocation priority in the range of 0 to 7.
weight weight: Specifies a bandwidth allocation weight in the range of 1 to 10000.
Type 4 DBA is primarily used for general network access services.
# Configure type 4 DBA, and set the maximum bandwidth to 15 Mbps.
[Sysname-onu-dbaprofile-dba_15M] dba type4 max 30000
dba type5
Use dba type5 to configure type 5 DBA, which is fixed bandwidth+assured bandwidth+maximum bandwidth.
dba type5 [ ratio ] fix fix-bandwidth assure assure-bandwidth max max-bandwidth [ additional-bandwidth { non-assure | best-effort [ priority priority | weight weight ] * } ]
undo dba type
fix fix-bandwidth: Specifies the fixed bandwidth reserved for ONUs, in the range of 128 to 9999872 kbps. If the specified value is not a multiple of 64, the effective value is nearest lower multiple of 64. If the ratio keyword is also specified, the value range is 1 to 999, with each unit representing one-thousandth of the maximum ONU bandwidth.
assure assure-bandwidth: Specifies the assured bandwidth that can be allocated to ONUs. The value range is dynamic. The minimum value is 128 kbps, and the maximum value is 10000000 kbps minus the effective fixed bandwidth value in kbps. If the specified value is not a multiple of 64, the actual effective value is the nearest lower multiple of 64. If the ratio keyword is also specified, the value range is dynamic. The minimum value is 1, and the maximum value is 1000 minus the fixed bandwidth value. Each unit represents one-thousandth of the maximum ONU bandwidth.
max max-bandwidth: Specifies the maximum bandwidth that can be used by ONUs. The value range is dynamic. The maximum value is 10000000 kbps, and the minimum value is 64 plus the effective fixed bandwidth value and assured bandwidth value (in kbps). If the configured value is not a multiple of 64, the effective value is the nearest lower multiple of 64. If the ratio keyword is also specified, the value range is dynamic. The maximum value is 1000, and the minimum value is the fixed bandwidth value plus the assured bandwidth value. Each unit represents one-thousandth of the maximum ONU bandwidth.
additional-bandwidth: Specifies the type of additional bandwidth for the maximum bandwidth. If you do not specify this keyword, the default value is best-effort.
non-assure: Allocates the maximum bandwidth in non-assured form. As a best practice, specify this type when the OLT allocates bandwidth in proportion to the sum of the fixed and assured bandwidths.
best-effort: Allocates the maximum bandwidth in best-effort form. As a best practice, specify this type when the OLT allocates bandwidth in proportion to the maximum bandwidth.
ONUs that use type 5 DBA have a fixed bandwidth reserved by the OLT and can dynamically obtain additional assured bandwidth when required. These ONUs can also preempt extra bandwidth only if the total bandwidth does not exceed the maximum bandwidth.
The actual effective value of the maximum bandwidth must be greater than the actual effective value of the fixed bandwidth plus that of the assured bandwidth.
# Configure type 5 DBA, and set the fixed bandwidth to 128 Mbps, assured bandwidth to 128 Mbps, and maximum bandwidth to 500 Mbps.
[Sysname] onu dba-profile dba_profile_1
[Sysname-onu-dbaprofile-dba_profile_1] dba type5 fix 128000 assure 128000 max 500000
display onu-config-profile
Use display onu-config-profile to display information about an ONU configuration profile.
display onu-config-profile [ profile-name profile-name ]
profile-name profile-name: Displays details of the specified profile. The profile-name argument represents a profile name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays summary information about all profiles.
# Display summary information about all ONU configuration profiles.
<Sysname> display onu-config-profile
Profile name
  cfg-profile_1
# Display detailed information about the ONU configuration profile named cfg_profile_1.
<Sysname> display onu-config-profile profile-name cfg_profile_1
Profile-name : cfg_profile_1
  ONU port-isolate : Disabled
  ONU multicast fast-leave : Disabled
  ONU protocol :
    DHCP-snooping : Disabled
    DHCP-snooping information : Disabled
    IGMP-snooping suppression leave : Enabled
    IGMP-snooping suppression report : Disabled
    IGMP-snooping timer host-aging-time : 260
    IGMP-snooping timer max-response-time : 1
    IGMP-snooping timer router-aging-time : 105
    PPPoE : Disabled
    STP : Disabled
  ONU statistics : Enabled
  Multicast mode IGMP-snooping :
    Multicast-control host-aging-time 260
  Service-sla mode : sp-wrr high-priority-boundary 3
  Service-sla queue :
    queue 1 sp fixed-bandwidth 0 guaranteed-bandwidth 0 best-effort-bandwidth 0
    queue 2 sp fixed-bandwidth 0 guaranteed-bandwidth 0 best-effort-bandwidth 0
    queue 3 sp fixed-bandwidth 256 guaranteed-bandwidth 256 best-effort-bandwidth 256
  UNI 1 config :
    Auto-negotiation : Enabled
    Classification-marking :
      index 2 queue 2 priority 3 vlan-id equal 100
      index 3 queue 5 priority 3 vlan-id equal 100
    Duplex : full
    Flow-control : Disabled
    Igmp-snooping fast-leave : Disabled
    MDIX-mode : automdix
    Multicast-group-number : 64
    Multicast-strip-tag : Disabled
    Port-isolation : Disabled
    Port-policy inbound : cir 64
    Shutdown : false
    Speed : auto
    Statistics : Enabled
    VLAN-mode : transparent  pvid 1
Table 18 Command output
Profile name
Name of a configuration profile.
ONU port-isolate
Whether a UNI is assigned to an isolation group.
Fast leave feature of all UNIs.
ONU protocol
ONU protocol-related configuration:
·     DHCP-snooping—DHCP-snooping protocol.
·     DHCP-snooping information—DHCP snooping option 82 protocol.
·     IGMP-snooping suppression leave—IGMP leave packets.
·     IGMP-snooping suppression report—IGMP group membership report packets.
·     IGMP-snooping timer host-aging-time—Aging time for dynamic member ports.
·     IGMP-snooping timer max-response-time—Maximum response time for IGMP general queries.
·     IGMP-snooping timer router-aging-time—Dynamic router port aging time.
·     PPPoE—PPPoE+ protocol.
·     STP—Rapid Spanning Tree Protocol (RSTP).
ONU statistics
Packet statistics feature.
Multicast mode
Multicast mode-related settings, IGMP snooping or multicast control.
The Multicast-control host-aging-time field indicates the aging time for member ports in a multicast group.
Service-sla mode
Queue scheduling mode for upstream traffic.
Service-sla queue
Upstream traffic queues.
UNI 1 config
Configuration of the specified UNI in the configuration profile.
Auto-negotiation
Auto-negotiation feature of a UNI.
Description of a UNI.
Duplex
Duplex mode of a UNI:
·     auto—The port is in auto-negotiation mode.
·     full—The port is in full duplex mode.
·     half—The port is in half duplex mode.
Flow-control
Flow control feature of a UNI.
MDIX-mode
Medium-Dependent Interface Crossover (MDIX) mode of a UNI:
·     automdix—Devices at both ends negotiate to determine whether pins 1 and 2 transmit or receive signals, and whether pins 3 and 6 receive or transmit signals.
·     mdi—Uses pins 1 and 2 as transmit pins and pins 3 and 6 as receive pins.
·     mdix—Uses pins 1 and 2 as receive pins and pins 3 and 6 as transmit pins.
Port-isolate
QinQ
QinQ information of a UNI:
·     svlan—Outer VLAN.
·     cvlan—Inner VLAN.
·     transparent-vlan—Transparent transmission VLAN.
Shutdown
Shutdown state of a UNI:
·     true.
·     false.
Speed
Speed of a UNI:
·     10—The speed of the port is 10 Mbps.
·     100—The speed of the port is 100 Mbps.
·     1000—The speed of the port is 1000 Mbps.
·     auto—The speed of the port is autonegotiated by both parties.
Statistics
Statistics state of a UNI.
VLAN-mode
VLAN operation mode of a UNI:
·     transparent—Transparent mode.
·     tag—Tag mode.
·     translation—Translation mode.
·     qinq—QinQ mode.
·     trunk—Trunk mode.
·     aggregation—N:1 aggregation mode.
display onu-dba-profile
Use display onu-dba-profile to display information about ONU DBA profiles.
display onu-dba-profile [ profile-name profile-name ]
# Display summary information about all ONU DBA profiles.
<Sysname> display onu-dba-profile
Profile name                     Type Assured  Max      Fix
dba_profile_default              3    8192     20480    6400
dba2                             1    8192     20480    6400
dba3                             5    8192     20480    6400
# Display detailed information about the ONU DBA profile named 111.
<Sysname> display onu-dba-profile profile-name 111
Profile name :            111
  Type:                   5
  Fixed (kbps):           2048
  Assured (kbps):         2048
  Max (kbps):             10240
  Additional-bandwidth:   best-effort
  Best-effort-priority:   0
  Best-effort-weight:     10
Table 19 Command output
Profile name
type
ONU DBA profile type:
·     1—Fixed bandwidth.
·     2—Assured bandwidth.
·     3—Assured bandwidth + maximum bandwidth.
·     4—Maximum bandwidth.
·     5—Fixed bandwidth + assured bandwidth + maximum bandwidth.
Assured
Max
Fix
Fixed
Additional bandwidth type:
·     non-assure—Non-assured bandwidth assignment.
·     best-effort—Best-effort bandwidth assignment.
Best-effort bandwidth assignment priority.
Best-effort-weight
Best-effort bandwidth assignment weight.
display onu-line-profile
Use display onu-line-profile to display information about ONU line profiles.
display onu-line-profile [ profile-name profile-name ]
# Display summary information about all ONU line profiles.
<Sysname> display onu-line-profile
Profile name
  line-profile_1
# Display detailed information about the ONU line profile named line_profile_2.
<Sysname> display onu-line-profile line_profile_2
Profile name : line_profile_2
  TCONT list :
    TCONT name                                                     DBA profile
    TCONT_1                                                        dba_1
    TCONT_voip                                                     dba_viop
  Config profile : config_voip
  Mapping mode : vlan
  ONU subinterface list :
    SubNo  TCONT name                                              Service profile
    1      TCONT_1                                                 bridge_1_voip
    3      TCONT_1                                                 bridge_1_voip
  Interface list :
    ONU3/1/0:1
    ONU3/1/0:2
Table 20 Command output
Profile name
TCONT list
T-CONT list.
TCONT name
T-CONT name.
DBA profile
Config profile
Mapping mode
ONU subinterface list.
SubNo
ONU subinterface number.
Service profile
Interface list
List of ONU interfaces bound to the line profile.
display onu-service-profile
Use display onu-service-profile to display information about ONU subinterface service profiles.
display onu-service-profile [ profile-name profile-name ]
# Display summary information about all ONU subinterface service profiles.
<Sysname> display onu-service-profile
Profile name
  bridge_service_1
# Display detailed information about the ONU subinterface service profile named bridge_service_profile_2.
<Sysname> display onu-service-profile profile-name bridge_service_profile_2
Profile name : bridge_service_profile_2
  VLAN mapping
    Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
    10            N/A           120                      N/A
    200           100
  Port VLAN (hybrid)
    PVID  VLAN Passing
    100   Tagged:  1000, 1002, 1500, 1600-1611, 2000,
                   2555-2558, 3000, 4000
          Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
                   150-160, 200, 255, 286, 300-302
Table 21 Command output
Profile-name
Service profile name.
Outer VLAN
Original outer VLAN:
·     For one-to-one VLAN mapping, many-to-one VLAN mapping, and one-to-two VLAN mapping, the outer VLAN field displays the original VLAN.
·     For zero-to-two VLAN mapping, the outer VLAN field displays N/A.
Inner VLAN
Original inner VLAN:
·     For one-to-one VLAN mapping, many-to-one VLAN mapping, and one-to-two VLAN mapping, the inner VLAN field displays N/A.
·     For zero-to-two VLAN mapping, the inner VLAN field displays N/A.
Outer VLAN after translation:
·     For one-to-one VLAN mapping, two-to-one VLAN mapping, and many-to-two VLAN mapping, the translated outer VLAN field displays the VLAN after translation.
·     For zero-to-two VLAN mapping, the translated outer VLAN field displays the added outer VLAN.
Inner VLAN after translation:
·     For one-to-one VLAN mapping, two-to-one VLAN mapping, and many-to-two VLAN mapping, the translated inner VLAN field displays N/A.
·     For zero-to-two VLAN mapping, the translated inner VLAN field displays the added inner VLAN.
Nested VLAN
Added outermost VLAN in two-to-three VLAN mapping.
PVID
PVID of the port using this service profile.
VLAN Passing
Existing VLANs actually permitted on the port using the service profile.
Tagged
VLANs for which the port using this service profile sends packets without removing VLAN tags.
Untagged
VLANs for which the port using this service profile sends packets after removing VLAN tags.
encryption enable
Use encryption enable to enable downstream traffic encryption for ONUs.
Use undo encryption enable to disable downstream traffic encryption for ONUs.
encryption enable
Downstream traffic encryption is enabled for ONUs.
In an optical network, the downstream traffic encryption feature of an ONU protects the traffic from the OLT to the ONU by using encryption technology to ensure data security for users.
# In ONU line profile 1, enable downstream traffic encryption for ONUs.
[Sysname] onu line-profile 1
[Sysname-onu-lineprofile-1] encryption enable
forward-error-correction
Use forward-error-correction enable to enable Forward Error Correction (FEC) for ONUs.
Use undo forward-error-correction enable to disable FEC for ONUs.
FEC is enabled for ONUs.
FEC improves the data transmission reliability and reduces the time and cost of data retransmission by adding redundancy to data flows, enabling the receivers to detect and correct errors. Additionally, FEC requires relatively low computing power and storage space, imposing minimal performance requirements on the ONUs.
For XGSPON or XGPON ONUs:
·     The downstream FEC feature is forcibly enabled and cannot be disabled.
·     The upstream FEC feature is enabled by default but can be disabled.
For GPON ONUs, the FEC feature is disabled by default and can be enabled or disabled as needed.
# Enable FEC in ONU line profile 1.
[Sysname-onu-lineprofile-1] forward-error-correction enable
gpon compare-profile
Use gpon compare-profile to display the configuration differences between the specified profiles.
gpon compare-profile { onu-config-profile | onu-dba-profile | onu-line-profile | onu-service-profile } source-profile-name profile-name destination-profile-name profile-name
onu-config-profile: Specifies an ONU configuration profile.
onu-dba-profile: Specifies an ONU DBA profile.
onu-line-profile: Specifies an ONU line profile.
onu-service-profile: Specifies an ONU subinterface service profile.
source-profile-name profile-name: Specifies the name of the source profile for comparison. The profile-name argument represents a profile name, a case-sensitive string of 1 to 31 characters. The name supports only digits, letters, and underscores (_).
destination-profile-name profile-name: Specifies the name of the destination profile for comparison. The profile-name argument represents a profile name, a case-sensitive string of 1 to 31 characters. The name supports only digits, letters, and underscores (_).
# Display the configuration differences between the specified two line profiles.
[Sysname] gpon compare-profile onu-line-profile source-profile-name l1 destination-profile-name l3
Differences:
--- Source profile
+++ Destination profile
@@ -1,12 +1,13 @@
-onu line-profile l1
+onu line-profile l3
  apply onu-config-profile config_profile_default
+ tcont t1 onu-dba-profile dba_profile_default
  tcont tcont_default onu-dba-profile dba_profile_default
  subinterface 1
   apply tcont tcont_default
   apply onu-service-profile service_profile_default
- subinterface 2
-  apply tcont tcont_default
+ subinterface 3
+  apply tcont t1
gpon copy-profile
Use gpon copy-profile to quickly add GPON configuration profiles and copy settings from a source profile to these profiles.
gpon copy-profile { onu-config-profile | onu-dba-profile | onu-line-profile | onu-service-profile } source-profile-name profile-name { destination-profile-name profile-name } &<1-15>
source-profile-name profile-name: Specifies the name of the source profile for configuration copying. The profile-name argument represents a profile name, a case-sensitive string of 1 to 31 characters. The name supports only digits, letters, and underscores (_).
destination-profile-name profile-name: Specifies the name of the destination profile for configuration copying. The profile-name argument represents a profile name, a case-sensitive string of 1 to 31 characters. The name supports only digits, letters, and underscores (_).
&<1-15>: Indicates that you can specify up to 15 destination profiles.
The source profile type must be the same as the destination profile type. The source profile must already exist. A destination profile cannot have the same name as an existing profile.
# Quickly add ONU DBA profiles a and b by copying configurations from the default ONU DBA profile named dba_profile_default to these profiles.
[Sysname] gpon copy-profile onu-dba-profile source-profile-name dba_profile_default destination-profile-name a destination-profile-name b
Create new profile successfully
Dba profile name:
  a
  b
Total:2
mapping-mode
Use mapping-mode to configure the ONU traffic mapping mode.
Use undo mapping-mode to restore the default.
mapping-mode { priority | uni | vlan }
undo mapping-mode
An ONU maps traffic by UNI number.
priority: Maps traffic by 802.1p priority.
vlan: Maps traffic by VLAN.
uni: Maps traffic by UNI number.
Traffic from the customer side to an ONU must be mapped to an ONU subinterface according to the specific rules before the traffic can go upstream to the OLT.
The mapping-mode command only defines the traffic mapping modes available for subinterfaces in an ONU line profile. To configure specific mappings, use the onu-mapping command on subinterfaces in the ONU line profile.
# Configure ONU line profile 30 to map traffic by VLAN.
[Sysname-onu-lineprofile-30] mapping-mode vlan
onu-mapping
onu config-profile
Use onu config-profile to create an ONU configuration profile and enter its view, or enter the view of an existing ONU configuration profile.
Use undo onu config-profile to delete an ONU configuration profile.
onu config-profile profile-name
undo onu config-profile profile-name
The default ONU configuration profile named config_profile_default exists.
An ONU configuration profile primarily stores the UNI configuration commands for ONUs. You can use the apply onu-config-profile command to apply these commands to an ONU line profile.
Operating mechanism
An ONU configuration profile includes the following commands. For the default profile named config_profile_default, all these commands use the default settings.
·     GPON multicast commands
·     service-sla mode (GPON Command Reference)
·     service-sla queue (GPON Command Reference)
·     uni auto-negotiation
·     uni classification-marking (GPON Command Reference)
·     uni description
·     uni duplex
·     uni flow-control
·     uni port-isolate
·     uni port-policy inbound (GPON Command Reference)
·     uni port-policy outbound (GPON Command Reference)
·     uni speed
·     uni statistics enable
·     uni vlan-mode
To delete an ONU configuration profile that has been applied to an ONU line profile,  first use the undo apply onu-config-profile command in ONU line profile view to restore the default.
A maximum of 1024 configuration profiles are supported.
# Create ONU configuration profile 1 and enter its view.
[Sysname] onu config-profile 1
[Sysname-onu-cfgprofile-1]
onu dba-profile
Use onu dba-profile to create an ONU DBA profile and enter its view, or enter the view of an existing ONU DBA profile.
Use undo onu dba-profile to delete an ONU DBA profile.
onu dba-profile profile-name
undo onu dba-profile profile-name
The default ONU DBA profile named dba_profile_default exists.
An ONU DBA profile centrally stores the dba type series commands for ONU subinterfaces. You can use the apply tcont command to apply the commands in the ONU DBA profile of a T-CONT to ONU line profile subinterfaces.
Operating mechanism
An ONU DBA profile supports the following commands.
·     dba type1
·     dba type2
·     dba type3
·     dba type4
·     dba type5
The default ONU DBA profile named dba_profile_default is predefined with the dba type4 ratio max 1000 command. A newly created ONU DBA profile does not have configuration.
To delete an ONU DBA profile that has been used by a T-CONT, first use the undo tcont command in ONU line profile view to delete the T-CONT.
A maximum of 512 DBA profiles are supported.
# Create an ONU DBA profile named dba_15M and enter its view.
[Sysname-onu-dba-profile-dba_15M]
apply tcont
tcont
onu line-profile
Use onu line-profile to create an ONU line profile and enter its view, or enter the view of an existing ONU line profile.
Use undo onu line-profile to delete an ONU line profile.
onu line-profile profile-name
undo onu line-profile profile-name
The default ONU line profile named line_profile_default exists.
An ONU line profile centrally stores GPON ONU configuration commands. When you use the bind onu-id command to bind an ONU to an ONU interface, you can apply an ONU line profile. Then, the commands stored in the ONU line profile are deployed to the ONU interface.
A single ONU line profile can be applied to multiple ONU interfaces, which reduces the configuration efforts.
Operating mechanism
An ONU line profile includes the following commands. In the default ONU line profile named line_profile_default, all these commands use default settings.
·     apply onu-config-profile
·     encryption enable
·     forward-error-correction enable
·     mapping-mode
·     subinterface
·     tcont
To delete an ONU line profile that has been applied to an ONU interface, first use the undo bind onu-id command to unbind the ONU interface from its ONU.
A maximum of 1024 line profiles are supported.
# Create an ONU line profile named ET354 and enter its view.
bind onu-id
onu port-isolate enable
Use onu port-isolate enable to assign all UNIs on ONUs to the isolation group.
Use undo onu port-isolate enable to remove all UNIs on ONUs from the isolation group.
UNIs on ONUs are not assigned to the isolation group.
An ONU supports only one isolation group. The number of ports in the isolation group is unlimited.
This command and the uni port-isolate command are mutually exclusive.
# In ONU configuration profile 1, assign all UNIs on ONUs to the isolation group.
[Sysname-onu-cfgprofile-1] onu port-isolate enable
uni port-isolate
onu service-profile
Use onu service-profile to create an ONU subinterface service profile and enter its view, or enter the view of an existing ONU subinterface service profile.
Use undo onu service-profile to delete an ONU subinterface service profile.
onu service-profile profile-name [ realtime ]
undo onu service-profile profile-name
The ONU subinterface service profile named service_profile_default exists.
realtime: Creates a service profile that deploys configuration in real time. The configuration executed in this type of service profile will be deployed in real time to all ONU subinterfaces to which the service profile is applied. If a service profile without this keyword specified is already applied, you cannot modify the deployed configurations in the service profile. To modify the deployed configurations, first remove the application and then re-apply the line profile.
An ONU subinterface service profile centrally stores Layer 2 technology (such as VLAN) configuration commands for ONU subinterfaces. You can use the apply onu-service-profile command to apply these commands to an ONU line profile subinterface.
Operating mechanism
An ONU subinterface service profile supports the following commands. In the default ONU subinterface service profile named service_profile_default, all these commands use the default settings. (The link type of an ONU subinterface is Access, and the subinterface belongs to VLAN 1.)
·     port access vlan (Layer 2—LAN Switching Command Reference)
·     port hybrid pvid (Layer 2—LAN Switching Command Reference)
·     port hybrid vlan (Layer 2—LAN Switching Command Reference)
·     port link-type (Layer 2—LAN Switching Command Reference)
·     port trunk permit vlan (Layer 2—LAN Switching Command Reference)
·     port trunk pvid (Layer 2—LAN Switching Command Reference)
·     vlan mapping (Layer 2—LAN Switching Command Reference)
To delete an ONU subinterface service profile that has been applied to an ONU line profile subinterface, first use the undo apply onu-service-profile command in ONU line profile subinterface view to restore the default.
A maximum of 1024 service profiles are supported.
If you specify the realtime keyword for a service profile, the following rules apply:
·     After you modify the configuration in the service profile, the system deploys the changes in real time to all ONU subinterfaces to which the service profile is applied. If the service profile is applied to many subinterfaces, this synchronous deployment operation might take a long time. During this process, do not perform the following operations:
¡     Create or delete a line profile subinterface.
¡     Delete the service profile that is deploying configurations.
¡     Delete the line profiles and ONU interfaces to which the service profile that is deploying configurations is applied.
¡     Modify the configurations of other service profiles that deploy configurations in real time.
·     After you modify the configuration in a service profile, if the system fails to deploy the configuration to an ONU subinterface in real time, the system prints a list of failed ONU subinterfaces (up to 100 interface names) after deploying the configuration to all subinterfaces to which the service profile is applied.
# Create an ONU subinterface service profile named YY and enter its view.
[Sysname] onu service-profile YY
[Sysname-onu-srvprofile-YY]
# Enter the view of the service profile that deploys configuration in real time and modify its configurations.
[Sysname] onu service-profile YY realtime
Configuration under this view may take a long time. Continue?[Y/N]:Y
[Sysname-onu-srvprofile-YY+] vlan mapping 1 translated-vlan 101
onu statistics enable
Use onu statistics enable to enable packet statistics for ONUs.
Use undo onu statistics enable to disable packet statistics for ONUs.
The packet statistics feature is enabled for ONUs.
# Enable packet statistics for ONUs in ONU configuration profile 1.
[Sysname-onu-cfgprofile-1] onu statistics enable
onu-mapping
Use onu-mapping to configure traffic mapping for an ONU subinterface.
Use undo onu-mapping to restore the default.
onu-mapping { [ uni [ all | { uni-number [ to uni-number ] }&<1-32> ] ] [vlan [ untag | { vlan-id [ to vlan-id ] }&<1-12> ] ] [ priority [ all | { priority [ to priority ] }&<1-8> ] ] }
undo onu-mapping
Traffic from all UNIs is mapped to a subinterface.
uni all: Maps traffic from all UNIs to a subinterface.
uni { uni-number [ to uni-number ] }&<1-32>: Maps traffic from the specified UNIs to a subinterface. The uni-number argument specifies a UNI number in the range of 1 to 32. The uni-number to uni-number option specifies a range of UNI numbers. &<1-32> indicates that you can specify the preceding parameter for up to 32 times.
priority all: Maps traffic with any priority to a subinterface.
priority priority [ to priority ] }&<1-8>: Maps traffic with the specified priorities to a subinterface. The priority argument specifies a packet priority in the range of 0 to 7. A greater value indicates a higher priority. The priority to priority option specifies a priority range. &<1-8> indicates that you can specify the preceding parameter for up to eight times.
vlan untag: Maps traffic without a VLAN tag to a subinterface.
vlan vlan-id [ to vlan-id ] }&<1-12>: Maps traffic with the specified VLAN tags to a subinterface. The vlan-id argument is a VLAN ID in the range of 1 to 4094. The vlan-id to vlan-id option specifies a VLAN ID range. &<1-12> indicates that you can specify the preceding parameter for up to 12 times. Additionally, a subinterface supports up to 12 VLAN IDs.
The traffic mapping mode configured by using the onu-mapping command on an ONU line profile subinterface must match the configuration of the mapping-mode command in the ONU line profile.
When you execute the onu-mapping command, follow these restrictions and guidelines:
·     If you execute this command multiple times, the most recent configuration takes effect.
·     Subinterfaces cannot have overlapping configurations.
·     With the mapping-mode uni command executed, the onu-mapping uni all command is the default configuration for subinterface 1, and the other subinterfaces do not have the default configuration. In this case, you cannot execute the onu-mapping uni command on the other subinterfaces. In any other traffic mapping mode, the onu-mapping command does not have the default configuration on any subinterfaces.
# Configure ONU line profile 30 to map traffic by VLAN. Then, map packets from VLAN 1 to subinterface 1.
[Sysname-onu-lineprofile-30] subinterface 1
[Sysname-onu-lineprofile-30-subinterface-1] onu-mapping vlan 1
mapping-mode
subinterface
Use subinterface to create an ONU line profile subinterface and enter its view, or enter the view of an existing ONU line profile subinterface.
Use undo subinterface to delete an ONU line profile subinterface.
subinterface subnumber
undo subinterface subnumber
The default subinterface 1 exists in an ONU line profile.
subnumber: Specifies a subinterface number in the range of 1 to 8. A single ONU line profile supports up to 8 subinterfaces.
Use subinterfaces in an ONU line profile to plan the configuration of ONU subinterfaces. When an ONU line profile is applied to an ONU interface, the system will create ONU subinterfaces with the specified subinterface numbers and related configurations.
An ONU subinterface is a virtual interface that identifies a service flow between OLT and ONU. Use different ONU subinterfaces to configure various services for the same ONU.
Operating mechanism
An ONU line profile subinterface includes the following commands. On the default subinterface 1, all these commands use the default settings.
·     apply onu-service-profile
·     apply tcont
·     onu-mapping
# Create subinterface 2 in ONU line profile 30 and enter its view.
After you complete the preceding configuration, bind an ONU to interface ONU 1/0/1:1 and apply the ONU line profile to the ONU interface. Then, the system will create ONU subinterface ONU 1/0/1:1.2 with subinterface number 2.
[Sysname-onu-lineprofile-30-subinterface-2] quit
[Sysname-onu-lineprofile-30] quit
[Sysname-Onu1/0/1:1] bind onu-id sn h3c-12345678
[Sysname-Onu1/0/1:1] bind onu-line-profile 30
[Sysname-Onu1/0/1:1] quit
[Sysname] interface onu 1/0/1:1.2
[Sysname-Onu1/0/1:1.2]
apply tcont
onu-mapping
tcont
Use tcont to create a T-CONT and specify an ONU DBA profile for it.
Use undo tcont to delete a T-CONT.
tcont tcont-name [ onu-dba-profile profile-name ]
undo tcont tcont-name
An ONU line profile has created the default T-CONT named tcont_default, which uses the ONU DBA profile named dba_profile_default.
tcont-name: Specifies a T-CONT name, a case-sensitive string of 1 to 31 characters.
onu-dba-profile profile-name: Specifies an existing ONU DBA profile by its name for a T-CONT. If you do not specify this option, a T-CONT uses the default ONU DBA profile named dba_profile_default.
A transmission container (T-CONT) acts as a traffic-bearing object in the upstream direction of a GPON network. Traffic of all ONU subinterfaces must be mapped to T-CONTs. Then, the OLT schedules the upstream traffic through DBA.
After you create a T-CONT, use the apply tcont command to apply the T-CONT to an ONU line profile subinterface. Then, the subinterface's traffic is mapped to the T-CONT.
To delete a T-CONT that has been applied to an ONU line profile subinterface, first use the undo apply tcont command in ONU line profile subinterface view to restore the default.
You can configure a maximum of eight T-CONTs in an ONU line profile.
# Configure a T-CONT named voip in ONU line profile 30 and specify the T-CONT to use the ONU DBA profile named dba-voip.
apply tcont
Use uni auto-negotiation to enable autonegotiation on a UNI.
Use undo uni auto-negotiation to disable autonegotiation on a UNI.
uni uni-number auto-negotiation
undo uni uni-number auto-negotiation
Autonegotiation is enabled on a UNI.
uni-number : Specifies a UNI by its number in the range of 1 to the maximum number of UNIs supported on an ONU. An ONU supports up to 32 UNIs.
This command is mutually exclusive with the uni duplex, uni mdix-mode, and uni speed commands.
# In ONU configuration profile 1, enable autonegotiation on UNI 1.
[Sysname-onu-cfgprofile-1] uni 1 auto-negotiation
uni description
Use uni description to configure the description for a UNI.
Use undo uni description to restore the default.
uni uni-number description text
undo uni uni-number description
A UNI does not have a description.
uni-number: Specifies a UNI by its number in the range of 1 to the maximum number of UNIs supported on an ONU. An ONU supports up to 32 UNIs.
text: Specifies a description, a string of 1 to 40 characters.
# In ONU configuration profile 1,  configure the description as Test for UNI 1.
[Sysname-onu-cfgprofile-1] uni 1 description Test
uni duplex
Use uni duplex to set the duplex mode of a UNI.
Use undo uni duplex to restore the default.
uni uni-number duplex { auto | full | half }
undo uni uni-number duplex
A UNI is operating in full duplex mode.
auto: Specifies the auto mode.
full: Specifies the full duplex mode.
half: Specifies the half duplex mode.
Before you execute this command, first execute the undo uni uni-number auto-negotiation command.
# In ONU configuration profile 1, set the duplex mode to auto for UNI 1.
[Sysname-onu-cfgprofile-1] uni 1 duplex auto
uni flow-control
Use uni flow-control to enable flow control for a UNI.
Use undo uni flow-control to disable flow control for a UNI.
uni uni-number flow-control
undo uni uni-number flow-control
Flow control is disabled for a UNI.
# In ONU configuration profile 1, enable flow control on UNI 1.
[Sysname-onu-cfgprofile-1] uni 1 flow-control
uni port-isolate
Use uni port-isolate to assign a UNI to the isolation group.
Use undo uni port-isolate to remove a UNI from the isolation group.
uni uni-number port-isolate
undo uni uni-number port-isolate
This command is mutually exclusive with the onu port-isolate enable command.
# In ONU configuration profile 1, assign UNI 1 and UNI 2 on ONUs to the isolation group.
[Sysname-onu-cfgprofile-1] uni 1 port-isolate
[Sysname-onu-cfgprofile-1] uni 2 port-isolate
uni shutdown
Use uni shutdown to shut down a UNI.
Use undo uni shutdown to bring up a UNI.
uni uni-number shutdown
undo uni uni-number shutdown
A UNI is up.
ONU interface view
# Shut down UNI 1.
[Sysname] interface Onu 1/0/1:1
[Sysname-Onu1/0/1:1] uni 1 shutdown
uni speed
Use uni speed to set the rate of a UNI.
Use undo uni speed to restore the default.
uni uni-number speed { 10 | 100 | 1000 | auto }
undo uni uni-number speed
The rate of a UNI is 100 Mbps.
10: Sets the UNI rate to 10 Mbps.
100: Sets the UNI rate to 100 Mbps.
1000: Sets the UNI rate to 100 Mbps.
auto: Enable auto rate negotiation.
# In ONU configuration profile 1, set the rate to 10 Mbps for UNI 1 on ONUs.
[Sysname-onu-cfgprofile-1] uni 1 speed 10
Use uni statistics enable to enable packet statistics for a UNI.
Use undo uni statistics enable to disable packet statistics for a UNI.
uni uni-number statistics enable
undo uni uni-number statistics enable
The packet statistics feature is enabled for a UNI.
ONU configuration profile view
# Enable packet statistics for UNI 1 in ONU configuration profile 1.
[Sysname-onu-cfgprofile-1] uni 1 statistics enable
uni vlan-mode
Use uni vlan-mode to set the VLAN operation mode of a UNI.
Use undo uni vlan-mode to restore the default.
undo uni uni-number vlan-mode
Transparent mode:
uni uni-number vlan-mode transparent
Tag mode:
uni uni-number vlan-mode tag pvid pvid [ priority priority ]
Translation mode:
uni uni-number vlan-mode translation pvid pvid [ priority priority ] { original-vlan-id to translated-vlan-id } &<1-15>
Trunk mode:
uni uni-number vlan-mode trunk pvid pvid [ priority priority ] trunk-vlan-list
N:1 aggregation mode:
uni uni-number vlan-mode aggregation pvid pvid [ priority priority ] { vlan-id1 to vlan-id2 aggregated-vlan aggregated-vlan }&<1-15>
The VLAN operation mode for a UNI is transparent.
ONU interface view
pvid pvid: Specifies a PVID, in the range of 1 to 4094. In tag mode, translation mode, trunk mode, or N:1 aggregation mode, a UNI tags only untagged incoming frames with its PVID.
priority priority: Specifies an 802.1p priority value for packets, in the range of 0 to 7. In tag mode, translation mode, trunk mode, or N:1 aggregation mode, a UNI sets the 802.1p priority only in the PVID tag that it adds to untagged incoming frames.
{ original-vlan-id to translated-vlan-id } &<1-15>: Specifies a maximum of 15 original VLAN ID and translated VLAN ID pairs. The value range for VLAN IDs is 1 to 4094.
trunk-vlan-list: Specifies the permitted VLANs in the format of { vlan-id1 to vlan-id2 }&<1-15>. You can specify a maximum of 15 VLAN ID ranges. In a VLAN ID range, the start VLAN ID cannot be greater than the end VLAN ID. Different VLAN ID ranges cannot overlap. The value range for VLAN IDs is 1 to 4094.
{ vlan-id1 to vlan-id2 aggregated-vlan aggregated-vlan }&<1-15>: Translates a range of VLANs to an aggregate VLAN. The vlan-id1 to vlan-id2 option specifies the original VLAN range. In the VLAN range, the start VLAN ID cannot be greater than the end VLAN ID. The aggregated-vlan argument specifies the translated aggregate VLAN. You can specify a maximum of 15 original VLAN ID range and aggregate VLAN pairs. Different VLAN ID ranges cannot overlap. The value range for VLAN IDs is 1 to 4094.
If the link type of all ONU interfaces on an OLT is access, you must set the VLAN operation mode to transparent for UNIs of the ONUs. This setting ensures that the ONU interfaces and users receive only untagged packets.
# In ONU configuration profile 1, set the VLAN operation mode of UNI 1 to transparent.
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode transparent
# Configure the VLAN operation mode of UNI 1 as the tag mode. Add VLAN tag 100 to the untagged packets received on the UNI, and set the 802.1p priority to 3 for the packets.
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode tag pvid 100 priority 3
# Configure the VLAN operation mode of UNI 1 as the translation mode. Set the PVID to 100. Add the PVID tag to untagged incoming packets and set the 802.1p priority to 3 for packets. Replace VLAN ID 2 of incoming packets with VLAN ID 5.
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode translation pvid 100 priority 3 2 to 5
# Configure the VLAN operation mode of UNI 1 as the trunk mode. Set the PVID to 1, set the 802.1p priority to 3 for the packets, and allow packets from VLANs 2 through 5 to pass through.
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode trunk pvid 1 priority 3 2 to 5
# Configure the VLAN operation mode of UNI 1 as the N:1 aggregation mode. Set the PVID to 1, and set the 802.1p priority to 3 for packets. Replace the VLAN ID of incoming packets from VLANs 2 through 5 with VLAN ID 100.
[Sysname-onu-cfgprofile-1] uni 1 vlan-mode aggregation pvid 1 priority 3 2 to 5 aggregate 100
GPON basics· i
GPON basics commands· i
activate onu· i
authentication-mode· i
bind onu-id· ii
blacklist onu-id· iii
dba bandwidth-assignment-mode· iii
display dhcp-client iv
display interface· v
display onu· xi
display onu sn· xiii
display packet-drop· xiv
display pon authentication-mode· xvi
display pon diagnostic dba· xvii
display pon diagnostic config· xviii
display pon diagnostic config-error xix
display pon diagnostic status· xx
display pon onu-event xxi
display pon onu-loop-status· xxii
display pon onu-update· xxiii
display pon optics-parameters· xxiv
display pon version· xxv
display uni xxvi
display vendor-specific information· xxx
ip address· xxxiii
ipv6 address· xxxiii
management server xxxiv
management-vlan· xxxv
olt-mode· xxxvi
onu flow· xxxvii
onu bind auto· xxxviii
onu bind batch· xxxix
onu bind type· xl
onu-distance· xli
shutdown management-vlan-interface· xlii
using onu· xliii
GPON configuration profile commands· xliv
apply onu-config-profile· xliv
apply onu-service-profile· xliv
apply tcont xlv
bind onu-line-profile· xlvi
dba type1· xlvii
dba type2· xlvii
dba type3· xlviii
dba type4· xlix
dba type5· l
display onu-config-profile· lii
display onu-dba-profile· liv
display onu-line-profile· lv
display onu-service-profile· lvii
encryption enable· lviii
forward-error-correction· lix
gpon compare-profile· lix
gpon copy-profile· lxi
mapping-mode· lxi
onu config-profile· lxii
onu dba-profile· lxiv
onu line-profile· lxv
onu port-isolate enable· lxvi
onu service-profile· lxvi
onu statistics enable· lxviii
onu-mapping· lxviii
subinterface· lxx
tcont lxxi
uni auto-negotiation· lxxii
uni description· lxxii
uni duplex· lxxiii
uni flow-control lxxiv
uni port-isolate· lxxiv
uni shutdown· lxxv
uni speed· lxxv
uni statistics enable· lxxvi
uni vlan-mode· lxxvii
