| 04-SRv6 VPN commands | 434.19 KB |
display l2vpn statistics srv6-pw inbound
peer advertise encap-type srv6
peer re-originated (BGP EVPN address family view)
peer re-originated (BGP VPNv4/VPNv6 address family view)
reset l2vpn statistics srv6-pw
segment-routing ipv6 apply-sid all-nexthop (BGP IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid all-nexthop (BGP-VPN IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid specify-nexthop (BGP IPv4/IPv6 address family view)
segment-routing ipv6 apply-sid specify-nexthop (BGP-VPN IPv4/IPv6 address family view)
segment-routing ipv6 best-effort
segment-routing ipv6 locator (cross-connect view and VSI EVPN instance view)
segment-routing ipv6 locator anycast
segment-routing ipv6 traffic-engineering
SRv6 VPN commands
default color
Use default color to specify the default color.
Use undo default color to restore the default.
default color color-value
undo default color
No default color is specified.
EVPN instance view
color-value: Specifies the default color, in the range of 0 to 4294967295.
In case of color-based traffic steering, the default color is used in the following scenarios:
· A BGP EVPN route does not have the color extended community attribute or match a routing policy to obtain a color.
· A static SRv6 PW is not specified with a color value.
# In VSI EVPN instance view, set the default color to 100.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation srv6
[Sysname-vsi-aaa-mpls-srv6] default color 100
# In cross-connect group EVPN instance view, set the default color to 100.
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] evpn encapsulation srv6
[Sysname-xcg-vpna-evpn-srv6] default color 100
display l2vpn forwarding srv6
Use display l2vpn forwarding srv6 to display L2VPN SRv6 forwarding information.
display l2vpn forwarding srv6 [ vsi vsi-name | xconnect-group group-name ] [ slot slot-number ] [ verbose ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. The group name cannot contain hyphens (-).
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays L2VPN SRv6 forwarding information on the active MPU.
verbose: Displays detailed L2VPN SRv6 forwarding information. If you do not specify this keyword, the command displays only brief L2VPN SRv6 forwarding information.
If you do not specify a VSI or a cross-connect group, this command displays L2VPN SRv6 forwarding information for all VSIs and cross-connect groups.
# Display brief L2VPN SRv6 forwarding information.
<Sysname> display l2vpn forwarding srv6
Total number of cross-connections: 1
Total number of VSIs: 1
Total number of SRv6 tunnels: 2, 2 up, 0 blocked, 0 down
VSI Name : vpnb
Link ID : 0x9000000 Type: BE State: Up
In SID : 100::2
Out SID : 200::3
Xconnect-group Name : vpna
Connection Name : pw1
Link ID : 0x8000000 Type: BE State: Up
In SID : 100::1
Out SID : 200::1
Link ID |
Link ID of the SRv6 tunnel in the VSI or cross-connect group. |
Type |
Route recursion mode. After the PE receives a customer packet destined for an End.DX2 or End.DX2L SID, it forwards the packet according to the route recursion mode. · BE—SRv6-BE mode. In this mode, the PE first encapsulates the End.DX2 or End.DX2L SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the encapsulated packet. · TE—SRv6-TE mode. In this mode, the PE first searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route. Then, the PE adds an SRH to the packet. The SRH includes the End.DX2 or End.DX2L SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy. · BE/TE—SRv6-TE and SRv6-BE hybrid mode. In this mode, the PE preferentially uses the SRv6-TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6-BE mode. |
State |
SRv6 tunnel status: · Up—The SRv6 tunnel is up. · Down—The SRv6 tunnel is down. · Blocked—The SRv6 tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly. |
In SID |
Input SID, which is a local SID. |
Out SID |
Output SID, which is a remote SID. |
# Display detailed L2VPN SRv6 forwarding information.
<Sysname> display l2vpn forwarding srv6 verbose
VSI Name: vpnb
Link ID : 0x9000000
SRv6 PW Type : VLAN
SRv6 Tunnel State : Up
In SID : 200::3
Out SID : 100::2
MTU : 1500
SRv6 Tunnel Attributes : Main
SRv6 Forwarding IDs : -
Remote Leaf Argument : -
Xconnect-group Name: vpna
Connection Name: pw1
Link ID : 0x8000000
SRv6 PW Type : VLAN
In SID : 200::1
Out SID : 100::1
MTU : 1500
Link ID |
Link ID of the SRv6 tunnel on the VSI or cross-connect group. |
SRv6 PW Type |
Data encapsulation type of the SRv6 PW, which can be Ethernet or VLAN. If no SRv6 PW data encapsulation type is specified, this field displays a hyphen (-). |
SRv6 Tunnel State |
In SID |
Out SID |
MTU |
Maximum transmission unit, in bytes. |
SRv6 Tunnel Attributes |
SRv6 tunnel attributes: · Main—The primary tunnel. · Backup—The backup tunnel. · ac-Bypass—The Bypass tunnel for AC bypass. · ECMP—ECMP tunnel. |
SRv6 Forwarding IDs |
Forwarding entry IDs of the candidate paths in an SRv6 TE policy. If service traffic is not forwarded through an SRv6 TE policy tunnel, this field displays a hyphen (-). |
Remote Leaf Argument |
Argument value used by the remote PE to identify leaf ACs. If no argument value exists, this field displays a hyphen (-). |
display l2vpn peer srv6
Use display l2vpn peer srv6 to display L2VPN SRv6 information.
display l2vpn peer srv6 [ vsi vsi-name | xconnect-group group-name ] [ state-machine | verbose ]
state-machine: Displays L2VPN SRv6 state machine information.
verbose: Displays detailed L2VPN SRv6 information.
If you do not specify a VSI or a cross-connect group, this command displays L2VPN SRv6 information for all VSIs and cross-connect groups.
If you do not specify the state-machine or verbose keyword, this command displays brief information about L2VPN SRv6.
# Display brief information about L2VPN SRv6.
<Sysname> display l2vpn peer srv6
Total number of SRv6 Tunnels: 2
VSI Name: vpnb
Peer : 2::2
Flag : Main
State : Up
Peer : 2::2
Flag : Main
State : Up
Remote SrvID : 2
# Display detailed information about L2VPN SRv6.
<Sysname> display l2vpn peer srv6 verbose
VSI Name: vpnb
Peer: 2::2
Signaling Protocol : EVPN
Link ID : 0x9000000
SRv6 PW Type : VLAN
In SID : 100::2
Out SID : 200::3
MTU : 1500
Tunnel Group ID : 0x1000000030000000
Tunnel NHLFE IDs : 0
Color : -
Color-Only : -
Recursion Mode : SID based
Output Statistics :
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Output Rate :
Bytes per second : 0
Packets per second : 0
Peer: 2::2
Remote Service ID : 2
Link ID : 0x8000000
SRv6 PW Type : VLAN
In SID : 100::1
Out SID : 200::1
MTU : 1500
Color : -
Color-Only : -
Input Statistics :
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Output Statistics :
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Input Rate :
Output Rate :
Peer |
IPv6 address of the peer PE. |
Flag |
SRv6 tunnel flags: · Main—The primary tunnel. · Backup—The backup tunnel. · ac-Bypass—The Bypass tunnel for AC bypass. · ECMP—ECMP tunnel. |
State/SRv6 Tunnel State |
SRv6 PW Type |
Remote SrvID/Remote Service ID |
Remote service ID. |
Signaling Protocol |
Signaling protocol used to establish the SRv6 tunnel. The value is EVPN. |
Link ID |
In SID |
Out SID |
MTU |
Tunnel Group ID |
ID of the public network tunnel group that carries the SRv6 tunnel. |
Tunnel NHLFE IDs |
NHLFE entry IDs of the candidate paths in an SRv6 TE policy. If service traffic is not forwarded through an SRv6 TE policy tunnel, this field displays a hyphen (-). |
Color |
Color attribute of the expected SRv6 TE policy for route recursion. If no color attribute is available, this field displays a hyphen (-). |
Color-Only |
Color-Only flag, indicating that the Extended Color Community is used to steering traffic to an SRv6 TE policy or SR-MPLS TE policy. Values include: · 00—A BGP route can be recursed to an SRv6 TE policy/SR-MPLS TE policy when the route strictly matches both the endpoint and color of the policy. · 01—Besides the strictly matching BGP routes, the BGP routes with only matching color value can also be recursed to an SRv6 TE policy/SR-MPLS TE policy when the policy endpoint is 0.0.0.0 or 0::0. · 10—A BGP route can be recursed to an SRv6 TE policy/SR-MPLS TE policy when the route matches the color of the policy. The endpoint of the policy can be any IPv4 or IPv6 address. · 11—Undefined. |
Recursion Mode |
Route recursion mode of the SRv6 tunnel: · SID based—SRv6-BE mode. · Nexthop based—SRv6-TE mode. · Nexthop based/SID based—SRv6-TE and SRv6-BE hybrid mode. |
Input Statistics |
SRv6 PW incoming traffic statistics: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. · Errors—Number of error packets. · Discards—Number of dropped packets. This field is not available in an EVPN VPLS over SRv6 network. |
Output statistics |
SRv6 PW outgoing traffic statistics: · Octets—Number of outgoing bytes. · Packets—Number of outgoing packets. · Errors—Number of error packets. · Discards—Number of dropped packets. |
Input Rate |
SRv6 PW incoming traffic rate: · Bytes per second—Number of incoming bytes per second. · Packets per second—Number of incoming packets per second. This field is not available in an EVPN VPLS over SRv6 network. |
Output Rate |
SRv6 PW outgoing traffic rate: · Bytes per second—Number of outgoing bytes per second. · Packets per second—Number of outgoing packets per second. |
# Display state machine information about L2VPN SRv6.
<Sysname> display l2vpn peer srv6 state-machine
SRv6 tunnel group state:
Idle: Idle N: Normal UA: Unavailable PF: Protecting failure
P: Protection tunnel failure W: Working tunnel failure L: Local
VSI Name: vpnb
SRv6 Group Link ID : 0x9000000
Main SRv6 Tunnel:
Peer : 2::2
Backup SRv6 Tunnel : -
Main SRv6 Defect State : No defect
Backup SRv6 Defect State : -
Switch Result : Working
Switch Reason : None
Remote Event : -
Local Event : SFCW
SRv6 Group Old State : Idle
SRv6 Group State : UA:P:L
SRv6 Group Link ID : 0x8000000
Main SRv6 Tunnel:
Peer : 2::2
Service ID : 2
Remote Event : -
Local Event : SFCW
Main SRv6 Tunnel |
Primary SRv6 tunnel. |
Peer |
IPv6 address of the remote PE for the SRv6 tunnel. |
Service ID |
Service ID of the remote PE. |
Backup SRv6 Tunnel |
Backup SRv6 tunnel. |
Signaling protocol used to establish the SRv6 tunnels. The value is EVPN. |
Main SRv6 Defect State |
Defect state of the primary SRv6 tunnel: · No defect. · Signal defect—The signaling protocol detected defects. |
Backup SRv6 Defect State |
Defect state of the backup SRv6 tunnel: · No defect. · Signal defect—The signaling protocol detected defects. If no backup SRv6 tunnel exists, this field displays a hyphen (-). |
Switch Result |
SRv6 tunnel in use after a primary/backup tunnel switchover: · None—Neither the primary nor the backup SRv6 tunnel is in use. · Working—The primary SRv6 tunnel is in use. · Backup—The backup SRv6 tunnel is in use. |
Switch Reason |
Reason that causes the primary/backup tunnel switchover: · Config changed—An SRv6 tunnel is added to or removed from the tunnel redundancy group. · Fault dectected—An SRv6 tunnel fault is detected. · SRv6 down—The state of an SRv6 tunnel changes from active to down. · SRv6 up—The state of an SRv6 tunnel changes from active to up. · None—No primary/backup tunnel switchover has occurred. |
Remote Event |
This field is not supported in the current software version. Remote state machine event. |
Local Event |
Local state machine event: · SFW—Local primary SRv6 tunnel defect event. · SFP—Local backup SRv6 tunnel defect event. · SFCW—Local primary SRv6 tunnel up event. · SFCP—Local backup SRv6 tunnel up event. · None—No local event. |
SRv6 Group Old State |
SRv6 tunnel redundancy group state before switchover: · Idle—Both the primary and backup SRv6 tunnels are not available. · Normal—Both the primary and backup SRv6 tunnels are available. The primary SRv6 tunnel is up and the backup SRv6 tunnel is blocked. The primary SRv6 tunnel is used to forward traffic. · UA:P:L—The backup SRv6 tunnel has defects and the primary SRv6 tunnel is up. · PF:W:L—The primary SRv6 tunnel has defects and the back SRv6 tunnel is up. |
SRv6 Group State |
SRv6 tunnel redundancy group state after switchover. The supported values are the same as those of the SRv6 Group Old State field. |
Use display l2vpn statistics srv6-pw inbound to display incoming packet statistics for SRv6 PWs in an EVPN VPLS over SRv6 network.
display l2vpn statistics srv6-pw inbound [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays incoming packet statistics for all SRv6 PWs on all VSIs.
Use this command to display incoming packet statistics for all SRv6 PWs on the specified VSI or all VSIs.
To display outgoing packet statistics, use the display l2vpn peer srv6 verbose command.
# Display incoming packet statistics for all SRv6 PWs on VSI aaa.
<Sysname> display l2vpn statistics srv6-pw inbound vsi aaa
VSI name: aaa
Input statistics:
Octets : 0
Packets : 0
Errors : 0
Discards : 0
Input rate :
Table 5 Command output
Input statistics |
Incoming packet statistics for all SRv6 PWs: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. · Errors—Number of error packets. · Discards—Number of discarded packets. |
Input rate |
Incoming traffic rate for all SRv6 PWs: · Bytes per second—Number of incoming bytes per second. · Packets per second—Number of incoming packets per second. |
statistics enable
display l2vpn vsi
Use display l2vpn vsi to display L2VPN VSI information.
display l2vpn vsi [ name vsi-name | evpn-srv6 | evpn-vpls | evpn-vxlan | vpls | vxlan ] [ count | verbose ]
name vsi-name: Displays information about a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters.
evpn-srv6: Displays information about VSIs in the EVPN VPLS over SRv6 network.
evpn-vpls: Displays information about VSIs in the EVPN VPLS network.
evpn-vxlan: Displays information about VSIs in the EVPN VXLAN network.
vpls: Displays information about VSIs in the VPLS network.
vxlan: Displays information about VSIs in the VXLAN network.
count: Displays VSI statistics.
verbose: Displays detailed VSI information.
If you do not specify the name vsi-name, evpn-srv6, evpn-vpls, evpn-vxlan, vpls, or vxlan parameter, this command displays information about all VSIs.
If you do not specify the count or verbose keyword, this command displays brief VSI information.
# Display brief information about all VSIs in the EVPN VPLS over SRv6 network.
<Sysname> display l2vpn vsi evpn-srv6
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name VSI Index MTU State
vpnb 0 1500 Up
# Display statistics about all VSIs in the EVPN VPLS over SRv6 network.
<Sysname> display l2vpn vsi evpn-srv6 count
Table 6 Command output
MTU |
Maximum transmission unit of the VSI. |
State |
VSI state: · Up—The VSI is up. · Down—The VSI is down. · Admin down—The VSI is manually shut down by using the shutdown command. |
# Display detailed information about all VSIs in the EVPN VPLS over SRv6 network.
<Sysname> display l2vpn vsi evpn-srv6 verbose
VSI Name: vpnb
VSI Index : 0
VSI Description : vsi for vpnb
VSI State : Up
MTU : 1500
Bandwidth : -
Broadcast Restrain : -
Multicast Restrain : -
Unknown Unicast Restrain: -
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
PW Redundancy Mode : Slave
Flooding : Enabled
ESI : 0000.0000.0000.0000.0000
Redundancy Mode : All-active
Statistics : Disabled
EVPN Encapsulation : SRv6
SRv6 SIDs:
End.DT2U : 222::1(64/64/0)
End.DT2UL : 222::2(64/64/0)
End.DT2M : 222::3(64/64/0)
SRv6 tunnels:
Peer : 2::2
Link ID : 0x9000000
State : Up
ACs:
AC Link ID State
GE0/0/1 0x0 Up
Statistics: Disabled
Table 7 Command output
VSI Description |
VSI description. If no description is configured, this field is not available. |
VSI State |
MTU |
Bandwidth |
Maximum bandwidth (in kbps) for known unicast traffic on the VSI. |
Broadcast Restrain |
Broadcast restraint bandwidth (in kbps). |
Multicast Restrain |
Multicast restraint bandwidth (in kbps). |
Unknown Unicast Restrain |
Unknown unicast restraint bandwidth (in kbps). |
MAC Learning |
State of the MAC learning feature. |
MAC Tabel Limit |
Maximum number of MAC address entries on the VSI. If the VSI does not limit the maximum number of MAC address entries, this field displays Unlimited. |
MAC Learning rate |
MAC address entry learning rate of the VSI. |
Local MAC aging time |
MAC aging time for dynamic local-MAC entries, in seconds. If dynamic local-MAC entries do not age out, this field displays NotAging. |
Remote MAC aging time |
MAC aging time for dynamic remote-MAC entries, in seconds. If dynamic remote-MAC entries do not age out, this field displays NotAging. |
Drop Unknown |
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached. |
PW Redundancy Mode |
PW redundancy operation mode: · Slave—Master/slave mode and the local PE operates as the slave node. · Master—Master/slave mode and the local PE operates as the master node. · Independent—Independent mode. |
Flooding |
State of the VSI's flooding feature. This field is not supported by VPLS. |
ESI |
ESI of the VSI. |
Redundancy mode |
ES redundancy mode: · All-active. · Single-active. |
Statistics |
Packet statistics state. |
Input Statistics |
Incoming traffic statistics: · Octets—Number of incoming bytes. · Packets—Number of incoming packets. · Errors—Number of error packets. · Discards—Number of dropped packets. |
Output statistics |
Outgoing traffic statistics: · Octets—Number of outgoing bytes. · Packets—Number of outgoing packets. · Errors—Number of error packets. · Discards—Number of dropped packets. |
Input Rate |
Incoming traffic rate: · Bytes per second—Number of incoming bytes per second. · Packets per second—Number of incoming packets per second. This field is not available in an EVPN VPLS over SRv6 network. |
Output Rate |
Outgoing traffic rate: · Bytes per second—Number of outgoing bytes per second. · Packets per second—Number of outgoing packets per second. |
EVPN Encapsulation |
EVPN encapsulation type: · VXLAN. · MPLS. · SRv6. |
SRv6 SIDs |
SRv6 SIDs of the VSI. |
End.DT2U |
SRv6 SID used for unicast forwarding in the EVPN VPLS over SRv6 network. The values in parentheses are the length of each segment in the SID, which are the locator length, opcode length, and argument length in sequence. The total length of those segments is 128. |
End.DT2UL |
SRv6 SID used for unicast forwarding over the bypass tunnel at the multihomed EVPN VPLS over SRv6 site. The values in parentheses are the length of each segment in the SID, which are the locator length, opcode length, and argument length in sequence. The total length of those segments is 128. |
End.DT2M |
SRv6 SID used for flood forwarding in the EVPN VPLS over SRv6 network. The values in parentheses are the length of each segment in the SID, which are the locator length, opcode length, and argument length in sequence. The total length of those segments is 128. |
SRv6 Tunnels |
SRv6 tunnels on the VSI. |
Peer |
IPv6 address of the PW remote PE. |
Link ID |
Link ID of the SRv6 tunnel on the VSI. |
State |
SRv6 tunnel state, which can be Up, Down, Blocked, or Defect. |
ACs |
ACs of the VSI. |
AC |
For a Layer 3 interface, this field displays the interface name. For an Ethernet service instance, this field displays the name of the Ethernet service instance and the name of the Layer 2 interface where the Ethernet service instance name resides. |
Link ID |
Link ID of the AC on the VSI. |
State |
AC state, which can be Up or Down. |
Statistics |
AC packet statistics state. |
display l2vpn xconnect-group
Use display l2vpn xconnect-group to display L2VPN cross-connect group information.
display l2vpn xconnect-group [ evpn-srv6 | name group-name ] [ count | verbose ]
display l2vpn xconnect-group name group-name connection connection-name [ verbose ]
evpn-srv6: Specifies cross-connect groups in the EVPN VPWS over SRv6 network.
name group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters.
connection connection-name: Specifies a cross-connect by its name, a case-sensitive string of 1 to 20 characters. The cross-connect name cannot contain hyphens (-). If you do not specify a cross-connect, this command displays information about all cross-connects in the specified cross-connect group.
count: Displays cross-connect group statistics.
verbose: Displays detailed cross-connect group information.
If you do not specify a cross-connect group or the evpn-srv6 keyword, this command displays information for all cross-connect groups.
If you do not specify the count or verbose keyword, this command displays brief cross-connect group information.
# Display brief information about all cross-connect groups in the EVPN VPWS over SRv6 network.
<Sysname> display l2vpn xconnect-group evpn-srv6
Status Codes: UP - Up, DN - Down, DF - Defect, BD - Blocked, AD - Admin Down,
DL - Idle, DP - Duplicate
Total number of cross-connections: 1, 1 up, 0 down, 0 admin down
Xconnect-group Connection ST
Segment1 ST Segment2 ST
vpna pw1 UP
GE0/0/2 UP EVPN 2::2 UP
# Display statistics about all cross-connect groups in the EVPN VPWS over SRv6 network.
<Sysname> display l2vpn xconnect-group evpn-srv6 count
Table 8 Command output
ST |
State of the cross-connect: · UP—The cross-connect is up. · DN—The cross-connect is down. · AD—The cross-connect is manually shut down by using the shutdown command. |
Segment1 / Segment2 |
For an AC segment: · If the AC is a Layer 3 interface, this field displays the interface name. · If the AC is an Ethernet service instance, this field displays the Ethernet service instance name. For an SRv6 tunnel segment, this field displays the establishment method of the SRv6 tunnel and the IPv6 address of the remote PE. Only the EVPN establishment method is supported. |
ST |
If this field displays AC state, the following options are available: · UP—The AC is up. · DN—The AC is down. If this field displays SRv6 tunnel state, the following options are available: · UP—The tunnel is up. · DN—The tunnel is down. · DF—BFD detects that the tunnel has defects. · BD—The tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly. · DL—The input SID of the tunnel is not available. · DP—This option is not supported in the current software version. |
# Display detailed information about all cross-connect groups in the EVPN VPWS over SRv6 network.
<Sysname> display l2vpn xconnect-group evpn-srv6 verbose
Connection ID : 1
State : Up
MTU : 1500
SRv6 tunnels:
Peer : 2::2
Link ID : 0x8000000
State : Up
ACs:
AC Link ID State
GE0/0/1 0x0 Up
Table 9 Command output
Description of the cross-connect group. If no description is configured, this field is not available. |
State |
Cross-connect group state: · Up—The cross-connect group is up. · Down—The cross-connect group is down. · Administratively down—The cross-connect group is manually shut down by using the shutdown command. |
MTU |
Maximum transmission unit of cross-connects. |
SRv6 tunnels |
SRv6 tunnel information. |
Peer |
IPv6 address of the SRv6 tunnel remote PE. |
Link ID |
Link ID of the SRv6 tunnel on the cross-connect. |
State |
ACs |
AC information. |
AC |
Link ID |
Link ID of the AC on the cross-connect. |
State |
Statistics |
Use evpn encapsulation srv6 to create an EVPN instance, specify it to use SRv6 encapsulation, and enter its view, or enter the view of an existing EVPN instance that uses SRv6 encapsulation.
Use undo evpn encapsulation to restore the default.
No EVPN instance is created.
Cross-connect group view
VSI instance view
Before you can configure EVPN settings for a VSI or cross-connect group, you must create an EVPN instance on it.
# In a cross-connect group, create an EVPN instance that uses SRv6 encapsulation and enter its view.
locator-sbfd enable
Use locator-sbfd enable to enable SBFD for SRv6 locators.
Use undo locator-sbfd enable to restore the default.
locator-sbfd enable [ template template-name ] [ prefix-list prefix-list-name ]
SBFD is not configured for SRv6 locators.
SRv6 view
template template-name: Specifies a BFD template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, an SBFD session uses the multihop BFD parameters configured in system view.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the system performs SBFD on all locators obtained as next hops through route recursion.
Application scenarios
In the IP L3VPN over SRv6 BE, EVPN L3VPN over SRv6 BE, or public IP over SRv6 BE scenario, with FRR enabled on a local PE, the PE can use the backup path upon failure of the primary path when a peer CE is dualhomed to two PEs. For fast traffic switchover to the backup path when the primary path fails, configure this feature on the local PE to detect connectivity of the SRv6 locators advertised by the peer PE (the SRv6 locators are next hop addresses obtained through route recursion for private or public network routes).
Operating mechanism
SBFD uses the following procedure to detect connectivity of SRv6 locators:
1. The initiator (local PE) sends an SBFD packet with the destination IP address as the network segment for the SID identified by an SRv6 locator.
2. Upon receiving the SBFD packet, the reflector (peer PE) identifies whether the discriminator in the packet is consistent with the local discriminator. If they are consistent, the reflector sends an SBFD response to the initiator through IPv6 routing. If they are inconsistent, the reflector discards the SBFD packet.
3. The initiator switches to the backup path if it does not receive an SBFD response before the timeout timer expires. If it receives an SBFD response before the timeout timer expires, the SRv6 locator is reachable.
For this feature to take effect, perform the following tasks:
· Execute the sbfd destination ipv6 remote-discriminator command on the local PE to associate the destination IPv6 address of the detected path with the remote discriminator of the SBFD session for the initiator.
· Execute the sbfd local-discriminator command on the peer device of the main path to set the local discriminator for the reflector and make sure the discriminator is consistent on the local PE and peer PE.
# Enable SBFD for all SRv6 locators.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] locator-sbfd enable
sbfd destination ipv6 remote-discriminator (High Availability Command Reference)
sbfd local-discriminator (High Availability Command Reference)
nexthop interface (BGP IPv4 SR next hop view/BGP-VPN IPv4 SR next hop view/BGP-VPN IPv4 EVPN SR next hop view)
Use nexthop interface to specify a next hop to which an End.DX4 SID can be dynamically allocated and specify the output interface of the next hop.
Use undo nexthop to restore the default.
nexthop nexthop-address interface interface-type interface-number
undo nexthop nexthop-address
No End.DX4 SID is allocated to a next hop.
nexthop-address: Specifies a next hop by its IPv4 address.
interface-type interface-number: Specifies an output interface by its type and number.
This command is applicable to the IPv4 L3VPN over SRv6, IPv4 EVPN L3VPN over SRv6, or public network IPv4 over SRv6 scenario to accelerate traffic forwarding. This command allocates an End.DX4 SID to the specified next hop for BGP IPv4 routes and associates the next hop with an output interface.
Use one of the following methods to allocate End.DX4 SIDs to next hops:
· Use this command to dynamically allocate an End.DX4 SID to a next hop from the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in this command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot dynamically allocate an End.DX4 SID to the next hop.
· Use the opcode end-dx4 vpn-instance command to manually configure an End.DX4 SID in the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in the opcode end-dx4 vpn-instance command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot use the manually configured End.DX4 SID to forward traffic.
If both methods are used for the same next hop, the manually configured End.DX4 SID takes precedence over the dynamically allocated one.
You can specify only one output interface for one next hop. To change the output interface of a next hop, first use the undo nexthop command to remove the original next hop and output interface association.
The device might be unable to dynamically allocate SIDs to BGP IPv4 routes based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX4 SIDs, it allocates the End.DT4 SID or End.DT46 SID of the VPN instance or public instance to the routes.
# In BGP IPv4 SR next hop view, allow the system to allocate an End.DX4 SID to next hop 10.1.1.2 and specify GigabitEthernet 0/0/1 as the output interface of the next hop.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 unicast
[Sysname-bgp-default-ipv4] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv4] segment-routing ipv6 apply-sid specify-nexthop
[Sysname-bgp-default-sid-np-ipv4] nexthop 10.1.1.2 interface gigabitethernet 0/0/1
opcode
nexthop interface (BGP IPv6 SR next hop view/BGP-VPN IPv6 SR next hop view/BGP-VPN IPv6 EVPN SR next hop view)
Use nexthop interface to specify a next hop to which an End.DX6 SID can be dynamically allocated and specify the output interface of the next hop.
nexthop nexthop-ipv6-address interface interface-type interface-number
undo nexthop nexthop-ipv6-address
No End.DX6 SID is allocated to a next hop.
BGP-VPN SRv6 next hop view
BGP SRv6 next hop view
nexthop-ipv6-address: Specifies a next hop by its IPv6 address.
This command is applicable to the IPv6 L3VPN over SRv6, IPv6 EVPN L3VPN over SRv6, or public network IPv6 over SRv6 scenario to accelerate traffic forwarding. This command allocates an End.DX6 SID to the specified next hop for BGP IPv6 routes and associates the next hop with an output interface.
Use one of the following methods to allocate End.DX6 SIDs to next hops:
· Use this command to dynamically allocate an End.DX6 SID to a next hop from the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in this command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot dynamically allocate an End.DX6 SID to the next hop.
· Use the opcode end-dx6 vpn-instance command to manually configure an End.DX6 SID in the locator applied to the VPN instance or public instance.
Make sure the output interface specified for the next hop in the opcode end-dx6 vpn-instance command is consistent with the output interface of that next hop in the routing table. If they are inconsistent, the device cannot use the manually configured End.DX6 SID to forward traffic.
If both methods are used for the same next hop, the manually configured End.DX6 SID takes precedence over the dynamically allocated one.
The device might be unable to dynamically allocate SIDs to BGP IPv6 routes based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX6 SIDs, it allocates the End.DT6 SID or End.DT46 SID of the VPN instance or public instance to the routes.
# In BGP SRv6 next hop view, allow the system to allocate an End.DX6 SID to next hop 10::1:2 and specify GigabitEthernet 0/0/1 as the output interface of the next hop.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 unicast
[Sysname-bgp-default-ipv6] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv6] segment-routing ipv6 apply-sid specify-nexthop
[Sysname-bgp-default-sid-np-ipv6] nexthop 10::1:2 interface gigabitethernet 0/0/1
opcode
Use peer advertise encap-type srv6 to enable SRv6 encapsulation for the EVPN IP prefix advertisement routes advertised to a peer or peer group.
Use undo peer advertise encap-type srv6 to disable SRv6 encapsulation for the EVPN IP prefix advertisement routes advertised to a peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6 [ anycast ]
undo peer { group-name | ipv6-address [ prefix-length ] } advertise encap-type srv6
IP prefix advertisement routes use VXLAN encapsulation.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
anycast: Uses EVPN routes to advertise the SRv6 SIDs in an anycast locator. To use EVPN routes to advertise the SRv6 SIDs in a normal locator, do not specify this keyword.
Use this command to enable the device to advertise EVPN IP prefix advertisement routes with SRv6 encapsulation in an EVPN L3VPN over SRv6 or EVPN VPWS over SRv6 network.
In an EVPN L3VPN over SRv6 network, execute this command on the edge nodes of the EVPN L3VPN network and RRs.
# Enable SRv6 encapsulation for the IP prefix advertisement routes advertised to peer 1::1.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn] peer 1::1 advertise encap-type srv6
peer advertise original-route
Use peer advertise original-route to enable the device to advertise original BGP VPNv4, VPNv6, or EVPN routes to a peer or peer group.
Use undo peer advertise original-route to restore the default.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise original-route
The device advertises reoriginated BGP VPNv4, VPNv6, or EVPN routes to peers and peer groups after the peer re-originated command is executed.
BGP VPNv4 address family view
BGP VPNv6 address family view
ipv4-address: Specifies a peer by its IPv4 address. The peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. To specify a subnet, you must specify both the ipv4-address and mask-length arguments.
For this command to take effect, you must execute the peer re-originated command.
The device configured with the peer re-originated command advertises only reoriginated BGP VPNv4, VPNv6, or EVPN routes. For the device to advertise both original and reoriginated BGP VPNv4, VPNv6, or EVPN routes to a peer or peer group, execute the peer advertise original-route command on the device.
# In BGP VPNv4 address family view, enable the device to advertise original BGP VPNv4 routes to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 advertise original-route
peer re-originated
peer suppress re-originated
peer prefix-sid
Use peer prefix-sid to enable BGP to exchange SRv6 SID information with an IPv6 peer or peer group.
Use undo peer prefix-sid to restore the default.
peer { group-name | ipv6-address [ prefix-length ] } prefix-sid [ anycast ]
undo peer { group-name | ipv6-address [ prefix-length ] } prefix-sid
BGP does not exchange SRv6 SID information with an IPv6 peer or peer group.
BGP IPv4 unicast address family view
BGP IPv6 unicast address family view
anycast: Exchanges the SRv6 SIDs in an anycast locator with the specified peers. To exchange the SRv6 SIDs in a normal locator with the specified peers, do not specify this keyword.
Use this command to enable IPv6 peers in an SRv6 VPN network to exchange SRv6 SID information through BGP VPNv4, VPNv6, IPv4 unicast, or IPv6 unicast routes.
If you execute this command multiple times for the same peer or peer group, the most recent configuration takes effect.
# In BGP VPNv4 address family view, enable BGP to exchange SRv6 SID information with peer 2001:1::1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 2001:1::1 prefix-sid
Use peer re-originated to enable the device to reoriginate BGP EVPN routes based on the BGP EVPN routes received from a peer or peer group.
Use undo peer re-originated to disable the device from reoriginating BGP EVPN routes based on the BGP EVPN routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] [ replace-rt | stitch-l3vpn ]
peer { group-name | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ] [ replace-rt ] replace-sid
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ ip-prefix ]
The device does not reoriginate BGP EVPN routes based on received EVPN routes.
ip-prefix: Modifies IP prefix advertisement routes.
replace-rt: Replaces the L3 VXLAN ID, RD, and route targets of EVPN IP prefix advertisement routes with those of the matching local VPN instance, and adds MPLS labels or SRv6 SIDs to the routes if the replace-sid keyword is not specified or reallocates SRv6 SIDs to the routes in the matching local VPN instance if the replace-sid keyword is specified. If you do not specify the replace-rt keyword, the device performs the same operations except that it does not replace the route targets.
replace-sid: Deletes the SRv6 SIDs carried in the received BGP EVPN routes and reallocates SRv6 SIDs to the routes in the matching local VPN instance. If you do not specify this keyword, the device does not replace the SRv6 SIDs of routes.
stitch-l3vpn: Reoriginates IP prefix advertisement routes as VPNv4/VPNv6 routes without modifying the RD and route targets of the routes.
Use this command without the stitch-l3vpn keyword on an ASBR that connects the EVPN L3VPN and EVPN L3VPN over SRv6 networks. This command enables the ASBR to modify EVPN route information to realize intercommunication between the MPLS and SRv6 networks.
Use this command with the stitch-l3vpn keyword on an ASBR that connects the MPLS L3VPN and EVPN L3VPN over SRv6 networks or connects the EVPN L3VPN and IP L3VPN over SRv6 networks. This command enables conversion between EVPN routes and VPNv4/VPNv6 routes to realize intercommunication between the MPLS and SRv6 networks.
After you execute this command without the stitch-l3vpn keyword on an ASBR, the ASBR performs the following operations:
· After receiving BGP EVPN routes from the EVPN L3VPN network, the ASBR performs the following operations:
a. Matches the route targets of the routes with the import route targets of local VPN instances.
b. Replaces the RD and route targets of the routes with those of the matching local VPN instance. In addition, the ASBR adds an SRv6 SID to the routes and maps the SRv6 SID of the routes to the private label of the routes.
c. Advertises the reoriginated routes to the SRv6 network.
· After receiving BGP EVPN routes from the SRv6 network, the ASBR performs the following operations:
b. Replaces the RD and route targets of the routes with those of the matching local VPN instance. In addition, the ASBR adds MPLS labels to the routes and maps the private label of the routes to the SRv6 SID of the routes.
c. Advertises the reoriginated routes to the EVPN L3VPN network.
After you execute this command with the stitch-l3vpn keyword on an ASBR, the ASBR performs the following operations after receiving BGP EVPN routes from the SRv6 network or MPLS network:
1. Matches the route targets of the routes with the import route targets of local VPN instances.
2. Reoriginates the matching IP prefix advertisement routes as VPNv4 or VPNv6 routes without modifying the RD or route targets of the routes. In addition, the ASBR adds MPLS labels to the routes and maps the private label of the routes to the SRv6 SID of the routes.
3. Advertises the reoriginated routes to the MPLS L3VPN network.
To allow inter-AS communication in an inter-AS SRv6 VPN network with SRv6 deployed in each AS, inter-AS advertisement of the locator subnet route information is required. For example, you can redistribute the locator subnet routing information from an IGP into BGP for inter-AS route advertisement. After the locator subnet routing information is advertised across the ASs, PE devices in different ASs can establish inter-AS SRv6 forwarding paths. However, in some scenarios, locator subnet routing information should not be advertised across ASs due to security concerns. In this case, you can specify the replace-sid keyword in this command to replace the SRv6 SID carried in a route with an SRv6 SID of the matching local VPN instance. In this way, the locator subnet routing information is not advertised to other ASs and the PEs in different ASs can establish inter-AS SRv6 fowarding paths.
This command enables the device to advertise only reoriginated routes to the specified peer or peer group. The original routes are not advertised.
If the RD of a received BGP EVPN route is identical to the RD of the matching local VPN instance, a device does not modify the route or reoriginate the route. As a result, the device does not advertise the route. As a best practice, assign unique RDs to VPN instances on different devices if you use this command.
# In BGP EVPN address family view, replace the RD and route targets of the EVPN routes received from peer 1.1.1.1 and add an MPLS label or SRv6 SID to the routes.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 re-originated replace-rt
Use peer re-originated to enable the device to reoriginate BGP VPNv4 or VPNv6 routes based on the BGP VPNv4 or VPNv6 routes received from a peer or peer group.
Use undo peer re-originated to disable the device from reoriginating BGP VPNv4 or VPNv6 routes based on the BGP VPNv4 or VPNv6 routes received from a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } re-originated [ replace-rt | stitch-evpn ]
peer { group-name | ipv6-address [ prefix-length ] } re-originated [ replace-rt ] replace-sid
The device does not reoriginate BGP VPNv4 or VPNv6 routes based on received BGP VPNv4 or VPNv6 routes.
replace-rt: Replaces the RD and route targets of VPNv4 or VPNv6 routes with those of the matching local VPN instance, and adds MPLS labels or SRv6 SIDs to the routes if the replace-sid keyword is not specified or reallocates SRv6 SIDs to the routes in the matching local VPN instance if the replace-sid keyword is specified. If you do not specify the replace-rt keyword, the device performs the same operations except that it does not replace the route targets.
replace-sid: Deletes the SRv6 SIDs carried in the received BGP VPNv4 or VPNv6 routes and reallocates SRv6 SIDs to the routes in the matching local VPN instance. If you do not specify this keyword, the device does not replace the SRv6 SIDs of routes.
stitch-evpn: Reoriginates VPNv4/VPNv6 routes as EVPN IP prefix advertisement routes without modifying the RD and route targets of the routes.
Use this command without the stitch-evpn keyword on an ASBR that connects the MPLS L3VPN and IP L3VPN over SRv6 networks. This command enables the ASBR to modify VPNv4 or VPNv6 route information to realize intercommunication between the MPLS and SRv6 networks.
Use this command with the stitch-evpn keyword on an ASBR that connects the EVPN L3VPN and IP L3VPN over SRv6 networks or connects the MPLS L3VPN and EVPN L3VPN over SRv6 networks. This command enables conversion between VPNv4/VPNv6 routes and EVPN routes to realize intercommunication between the MPLS and SRv6 networks.
After you execute this command without the stitch-evpn keyword on an ASBR, the ASBR performs the following operations:
· After receiving BGP VPNv4 or VPNv6 routes from the MPLS L3VPN network, the ASBR performs the following operations:
· After receiving BGP VPNv4 or VPNv6 routes from the SRv6 network, the ASBR performs the following operations:
c. Advertises the reoriginated routes to the MPLS L3VPN network.
After you execute this command with the stitch-evpn keyword on an ASBR, the ASBR performs the following operations after receiving BGP VPNv4 or VPNv6 routes from the SRv6 network or MPLS network:
2. Reoriginates the matching BGP VPNv4 or VPNv6 routes as EVPN IP prefix advertisement routes without modifying the RD or route targets of the routes. In addition, the ASBR adds MPLS labels to the routes and maps the private label of the routes to the SRv6 SID of the routes.
3. Advertises the reoriginated routes to the EVPN L3VPN network.
To allow inter-AS communication in an inter-AS SRv6 VPN network with SRv6 deployed in each AS, inter-AS advertisement of the locator subnet route information is required. For example, you can redistribute the locator subnet routing information from an IGP into BGP for inter-AS route advertisement. After the locator subnet routing information is advertised across the ASs, PE devices in different ASs can establish inter-AS SRv6 forwarding paths. However, in some scenarios, locator subnet routing information should not be advertised across ASs due to security concerns. In this case, you can specify the replace-sid keyword in this command to replace the SRv6 SID carried in a route with an SRv6 SID of the matching local VPN instance. In this way, the locator subnet routing information is not advertised to other ASs and the PEs in different ASs can establish inter-AS SRv6 forwarding paths.
If the RD of a received BGP VPNv4 or VPNv6 route is identical to the RD of the matching local VPN instance, a device does not modify the route or reoriginate the route. As a result, the device does not advertise the route. As a best practice, assign unique RDs to VPN instances on different devices if you use this command.
# In BGP VPNv4 address family view, replace the RD and route targets of the BGP VPNv4 routes received from peer 1.1.1.1 and add an MPLS label or SRv6 SID to the routes.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 re-originated replace-rt
peer srv6-vpn compatible
Use peer srv6-vpn compatible to enable SRv6 VPN compatibility for a peer or peer group.
Use undo peer srv6-vpn compatible to disable SRv6 VPN compatibility for a peer or peer group.
In BGP VPNv4 address family view or BGP VPNv6 address family view:
peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible [ srv6-sid-transposition ]
undo peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible
In BGP EVPN address family view:
peer { group-name | ipv6-address [ prefix-length ] } srv6-vpn compatible srv6-sid-transposition
SRv6 VPN compatibility is disabled. The device uses the non-transposition scheme defined in RFC 9252 to encapsulate the SRv6 SIDs carried in advertised BGP routes.
group-name: Specifies an existing peer group by its name, a case-sensitive string of 1 to 47 characters.
ipv6-address: Specifies an existing peer by its IPv6 address.
prefix-length: Specifies the prefix length, in the range of 0 to 128. If you specify this argument, you specify the dynamic peers in the specified network.
srv6-sid-transposition: Uses the transposition scheme defined in RFC 9252 to encapsulate the SRv6 SIDs carried in advertised BGP routes. If you do not specify this keyword, the device encapsulates the SRv6 SIDs carried in advertised BGP routes in the format defined in draft-dawra-idr-srv6-vpn.
In an IP L3VPN over SRv6 network, the BGP VPNv4 or VPNv6 routes exchanged between PEs carry SRv6 SIDs. When the SRv6 SIDs are encapsulated in different formats, the BGP route advertisement fails. To resolve this issue, you can execute this command to configure the SRv6 SID encapsulation format on the H3C device to be the same as that supported by the peer device.
# Configure the device to use the Transposition Scheme format defined in RFC 9252 to encapsulate the SRv6 SIDs in the BGP routes sent to peer 2::2.
[Sysname] bgp 1
[Sysname-bgp-default-vpnv4] peer 2::2 srv6-vpn compatible srv6-sid-transposition
Use peer suppress re-originated to suppress advertisement of reoriginated BGP EVPN, BGP VPNv6, or BGP VPNv4 routes to a peer or peer group.
Use undo peer suppress re-originated to restore the default.
In BGP VPNv4 address family view/BGP VPNv6 address family view:
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated ip-prefix
undo peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } suppress re-originated ip-prefix
The device advertises reoriginated BGP EVPN, BGP VPNv6, or BGP VPNv4 routes to peers and peer groups after the peer re-originated command is executed.
BGPN VPNv4 address family view
BGPN VPNv6 address family view
ip-prefix: Suppresses advertisement of reoriginated IP prefix advertisement routes.
The device configured with the peer re-originated and peer advertise original-route commands advertises both original and reoriginated BGP EVPN, BGP VPNv6, or BGP VPNv4 routes. For the device to advertise only original BGP EVPN, BGP VPNv6, or BGP VPNv4 routes to a peer or peer group, execute the peer suppress re-originated command on the device.
# In BGP VPNv4 address family view, suppress advertisement of reoriginated BGP VPNv4 routes to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 suppress re-originated
peer re-originated
ping evpn vpls srv6
Use ping evpn vpls srv6 to test the connectivity of an SRv6 PW in an EVPN VPLS over SRv6 network by pinging a remote PE from the local PE.
ping evpn vpls srv6 vsi vsi-name mac mac-address [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -r reply-mode | -s packet-size | -t time-out | -tc tc ] *
mac mac-address: Specifies a host attached to a remote PE by its MAC address in H-H-H format. Do not specify a broadcast MAC address, multicast MAC address, or all-zeros MAC address.
-a source-ipv6: Specifies the source IPv6 address of MPLS echo requests. If you do not specify a source IPv6 address, the IPv6 address of the traffic output interface is used as the source IPv6 address of MPLS echo requests.
-c count: Specifies the number of MPLS echo requests to be sent. The value range for the count argument is 1 to 4294967295, and the default value is 5.
-h hop-limit: Specifies the maximum number of hops allowed for an MPLS echo request. The value range for the hop-limit argument is 1 to 255, and the default value is 255.
-m interval: Specifies the interval at which an MPLS echo request is sent, in milliseconds. The value range for the interval argument is 1 to 10000, and the default value is 2000.
-r reply-mode: Specifies the reply mode used by the receiver (the remote PE) to reply to MPLS echo requests. The value for the reply-mode argument can be 2 or 4, and the default value is 2. If the mode is 2, the receiver searches the IP forwarding table for the destination IP address to forward MPLS echo replies. If the mode is 4, the receiver searches the IPv6 routing table for the source IPv6 address of the echo requests, encapsulates an SRH to the replies, and forwards them.
-s packet-size: Specifies the length of MPLS echo requests, in bytes. The value range for the packet-size argument is 81 to 1200, and the default value is 100. The specified packet length does not include the IPv6 header and UDP header length.
-t time-out: Specifies the timeout time of MPLS echo replies, in milliseconds. The value range for the time-out argument is 0 to 65535, and the default value is 2000. If the local PE does not receive an MPLS echo reply within the timeout time after sending an MPLS echo request, it determines that the MPLS echo reply times out.
-tc tc: Specifies the traffic class value in MPLS echo requests. The value range for the tc argument is 0 to 255 and the default value is 0.
In an EVPN VPLS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to test the connectivity of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs.
# Test the connectivity of the SRv6 PW from the local PE to the remote PE attached to the host with MAC address 2-2-2 in VSI vpna.
<System> ping evpn vpls srv6 vsi vpna mac 2-2-2
Ping a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002: 100 data bytes.
Press CTRL+C to break.
100 bytes from 11::2: sequence=1 time=1 ms
100 bytes from 11::2: sequence=2 time=2 ms
100 bytes from 11::2: sequence=3 time=1 ms
100 bytes from 11::2: sequence=4 time=2 ms
100 bytes from 11::2: sequence=5 time=1 ms
--- Ping statistics for MAC 0002-0002-0002 ---
5 packets transmitted, 5 packets received, 0.0% packets lost
Round-trip min/avg/max = 1/1/2 ms
Table 10 Command output
Ping a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002: 100 data bytes |
Ping a remote PE through an SRv6 PW in VSI vpna by reaching remote-MAC 0002-0002-0002. Each MPLS echo request contains 100 bytes. |
Press CTRL+C to break |
Press escape key Ctrl+C to abort the ping operation. |
100 bytes from 11::2: sequence=1 time=1 ms |
Received MPLS echo replies from the device whose IPv6 address is 11::2. · bytes—Number of bytes in the MPLS echo reply. · Sequence—Packet sequence, used to determine whether a segment is lost, disordered or repeated. · time—Response time. If no MPLS echo reply is received when the echo reply timeout time expires, the device displays Request time out. |
Ping statistics for MAC 0002-0002-0002 |
Statistics on data received and sent in the ping operation. |
5 packets transmitted |
Number of MPLS echo requests sent. |
5 packets received |
Number of MPLS echo replies received. |
0.0% packets lost |
Percentage of unacknowledged packets to the total packets sent. |
Round-trip min/avg/max = 1/1/2 ms |
Minimum, average, or maximum response time, in milliseconds. |
tracert evpn vpls srv6
ping evpn vpws srv6
Use ping evpn vpws srv6 to test the connectivity of an SRv6 PW in an EVPN VPWS over SRv6 network by pinging a remote PE from the local PE.
ping evpn vpws srv6 xconnect-group group-name local-service-id remote-service-id [ -a source-ipv6 | -c count | -h hop-limit | -m interval | -r reply-mode | -s packet-size | -t time-out | -tc tc ] *
xconnect-group group-name: Specifies a cross-connect group by its name, a case-sensitive string of 1 to 31 characters. The string cannot contain a hyphen (-).
local-service-id: Specifies a local service ID in the range of 1 to 16777215.
remote-service-id: Specifies a remote service ID in the range of 1 to 16777215.
-h hop-limit: Specifies the maximum number of hops allowed for an MPLS echo request. The value range for the hop-limit argument is 1 to 255 and the default value is 255.
-m interval: Specifies the interval at which an MPLS echo request is sent. The value range for the interval argument is 1 to 10000 milliseconds and the default value is 2000 milliseconds.
-s packet-size: Specifies the length of MPLS echo requests, in bytes. The value range for the packet-size argument is 80 to 1200, and the default value is 100. The specified packet length does not include the IPv6 header and UDP header length.
In an EVPN VPWS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to test the connectivity of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs.
# Ping a remote PE through an SRv6 PW with local service ID 2 and remote service ID 1 in cross-connect group xcga.
<Sysname> ping evpn vpws xconnect-group srv6 xcga 2 1
Ping a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga: 100 data bytes.
100 bytes from 111::100: sequence=1 time=2 ms
100 bytes from 111::100: sequence=2 time=2 ms
100 bytes from 111::100: sequence=3 time=1 ms
100 bytes from 111::100: sequence=4 time=1 ms
100 bytes from 111::100: sequence=5 time=2 ms
--- Ping statistics for the PW with local ID 2 and remote ID 1 ---
5 packets transmitted,5 packets received,0.00% packets lost
Table 11 Command output
Ping a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga: 100 data bytes |
Ping a remote PE through an SRv6 PW with local service ID 2 and remote service ID 1 in cross-connect group xcga. Each MPLS echo request contains 100 bytes. |
100 bytes from 111::100: sequence=5 time=1 ms |
Received MPLS echo replies from the device whose IPv6 address is 111::100. · bytes—Number of bytes in the MPLS echo reply. · sequence—Packet sequence, used to determine whether a segment is lost, disordered or repeated. · time—Response time. If no MPLS echo reply is received when the echo reply timeout time expires, the device displays Request time out. |
Ping statistics for the PW with local ID 2 and remote ID 1 |
0.0% packets lost |
tracert evpn vpws srv6
Use reset l2vpn statistics srv6-pw to clear SRv6 PW packet statistics.
reset l2vpn statistics srv6-pw [ vsi vsi-name [ peer ipv6-address ] | xconnect-group group-name [ connection connection-name ] ]
peer ipv6-address: Specifies a remote PE by its IPv6 address to clear outgoing packet statistics for the SRv6 PWs between the local PE and the specified remote PE. If you do not specify a remote PE, this command clears all SRv6 PW packet statistics for the specified VSI.
connection connection-name: Specifies a cross-connect by its name, a case-sensitive string of 1 to 20 characters. If you do not specify a cross-connect, this command clears all SRv6 PW packet statistics for the specified cross-connect group.
This command clears packet statistics for both primary and backup SRv6 PWs.
If you do not specify any parameters, this command clears all SRv6 PW packet statistics.
# Clear all SRv6 PW packet statistics.
<Sysname> reset l2vpn statistics srv6-pw
statistics enable
Use segment-routing ipv6 to specify a route recursion mode.
Use undo segment-routing ipv6 to restore the default.
segment-routing ipv6 { best-effort | traffic-engineering | traffic-engineering best-effort }
The device searches the IPv6 routing table based on the next hop of a matching EVPN route to forward traffic.
Cross-connect group EVPN instance view
best-effort: Specifies the SRv6 BE mode.
traffic-engineering: Specifies the SRv6 TE mode.
traffic-engineering best-effort: Specifies the SRv6 TE and SRv6 BE hybrid mode.
Use this command in an EVPN VPWS over SRv6 or EVPN VPLS over SRv6 network.
After the PE receives a customer packet destined for an End.DT2M, End.DT2U, End.DT2UL, End.DX2, or End.DX2L SID, it forwards the packet according to the route recursion mode.
· SRv6 BE mode—In this mode, the PE first encapsulates the SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the packet.
· SRv6 TE mode—In this mode, when the PE forwards the packet, it first searches the tunnel policies for a matching SRv6 TE policy based on the color attribute or next hop of a matching route. Then, the PE adds an SRH to the packet. The SRH includes the End.DT2M, End.DT2U, End.DT2UL, End.DX2, or End.DX2L SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy.
· SRv6 TE and SRv6 BE hybrid mode—In this mode, the PE preferentially uses the SRv6 TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6 BE mode.
# In VSI EVPN instance view, specify the SRv6 BE route recursion mode.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation srv6
[Sysname-vsi-aaa-mpls-srv6] segment-routing ipv6 best-effort
# In cross-connect group EVPN instance view, specify the SRv6 BE route recursion mode.
[Sysname] xconnect-group vpna
[Sysname-xcg-vpna] evpn encapsulation srv6
[Sysname-xcg-vpna-evpn-srv6] segment-routing ipv6 best-effort
segment-routing ipv6 apply-sid all-nexthop (BGP IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid all-nexthop to dynamically allocate an End.DX4 or End.DX6 SID to each next hop of BGP IPv4 or IPv6 routes in the public network.
Use undo segment-routing ipv6 apply-sid all-nexthop to restore the default.
A PE allocates the End.DT4, End.DT6, or End.DT46 SID of the public instance to BGP IPv4 or IPv6 routes in the public network.
Use this command to forward an SRv6 decapsulated public network packet to the next hop without looking up the routing table of the public network.
This command is applicable to the public network IPv4 or IPv6 over SRv6 scenario. By default, a PE allocates the same SID to all BGP public network routes. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the public network based on the SID for an optimal route. To forward the packet to the next hop without looking up the routing table, use this command.
This command dynamically allocates an End.DX4 or End.DX6 SID to each next hop for the BGP public network IPv4 or IPv6 routes. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you use this command in BGP IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
In the same view, the segment-routing ipv6 apply-sid all-nexthop command is mutually exclusive with the segment-routing ipv6 apply-sid specify-nexthop command. Do not use both commands in the same view.
The device might be unable to dynamically allocate SIDs to BGP public network routes based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX4 or End.DX6 SIDs, it allocates the End.DT4 SID, End.DT6 SID, or End.DT46 SID of the public instance to the routes.
The segment-routing ipv6 apply-sid all-nexthop command cannot allocate End.DX4 or End.DX6 SIDs to direct routes.
# In BGP IPv4 unicast address family view, enable the system to automatically allocate an End.DX4 SID to each next hop of BGP public network routes.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing ipv6 apply-sid all-nexthop
segment-routing ipv6 apply-sid all-nexthop (BGP-VPN IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid all-nexthop to dynamically allocate an End.DX4 or End.DX6 SID to each next hop of BGP private network routes.
segment-routing ipv6 apply-sid all-nexthop [ evpn ]
undo segment-routing ipv6 apply-sid all-nexthop [ evpn ]
VPN instance-based SID allocation is used for BGP private network routes.
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
evpn: Allocates SIDs to private network routes based on the route next hops when the routes are converted to EVPN routes. If you do not specify this keyword, the command allocates SIDs to private network routes based on the route next hops when the routes are converted to BGP VPNv4 or VPNv6 routes.
Use this command to forward an SRv6 decapsulated VPN packet to the next hop without looking up the routing table of the matching VPN instance.
This command is applicable to IP L3VPN over SRv6 and EVPN L3VPN over SRv6 networks. By default, a PE allocates the same SID to all BGP private network routes of a VPN instance. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the VPN instance based on the SID for an optimal route. Then, the PE forwards the packet to a CE. To forward the packet to the next hop without looking up the routing table, use this command.
This command dynamically allocates an End.DX4 or End.DX6 SID to each next hop of the BGP private network routes in a VPN instance based on the next hop addresses. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you use this command in BGP-VPN IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
The device might be unable to dynamically allocate SIDs to BGP private network routes in a VPN instance based on the route next hops when dynamic SID resources are insufficient. If the device does not have manually configured End.DX4 or End.DX6 SIDs, it allocates the End.DT4 SID, End.DT6 SID, or End.DT46 SID of the VPN instance to the routes.
# In BGP-VPN IPv4 unicast address family view, enable the device to dynamically allocate an End.DX4 or End.DX6 SID to each next hop of BGP private network routes.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 locator aaa
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 apply-sid all-nexthop
segment-routing ipv6 apply-sid specify-nexthop (BGP IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid specify-nexthop to configure next hop-specific dynamic End.DX4 or End.DX6 SID allocation for BGP public network IPv4 or IPv6 routes, and create and enter BGP IPv4 SR or SRv6 next hop view. If the view already exists, the command directly places you in the view.
Use undo segment-routing ipv6 apply-sid specify-nexthop to restore the default.
A PE allocates the End.DT4, End.DT6, or End.DT46 SID of the public instance to BGP public network IPv4 or IPv6 routes.
By default, a PE allocates the same SID to all BGP public network routes. When a PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the public network based on the SID for an optimal route. To forward the packet to the next hop without looking up the routing table, use this command and the nexthop interface command.
This command and the nexthop interface command dynamically allocate an End.DX4 or End.DX6 SID to the specified next hop. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
Before you use the segment-routing ipv6 apply-sid specify-nexthop command in BGP IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
In the same view, the segment-routing ipv6 apply-sid specify-nexthop command is mutually exclusive with the segment-routing ipv6 apply-sid all-nexthop command. Do not use both commands in the same view.
The segment-routing ipv6 apply-sid specify-nexthop command cannot allocate End.DX4 or End.DX6 SIDs to direct routes.
# In BGP IPv4 unicast address family view, configure next hop-specific dynamic End.DX4 SID allocation for BGP public network IPv4 routes, and create and enter BGP IPv4 SR next hop view.
[Sysname] bgp 100
nexthop interface
segment-routing ipv6 apply-sid specify-nexthop (BGP-VPN IPv4/IPv6 address family view)
Use segment-routing ipv6 apply-sid specify-nexthop to configure next hop-specific dynamic End.DX4 or End.DX6 SID allocation for BGP private network IPv4 or IPv6 routes, and create and enter BGP-VPN IPv4 SR or SRv6 next hop view. If the view already exists, the command directly places you in the view.
segment-routing ipv6 apply-sid specify-nexthop [ evpn ]
undo segment-routing ipv6 apply-sid specify-nexthop [ evpn ]
A PE allocates the End.DT4, End.DT6, or End.DT46 SID of a VPN instance to the BGP private network IPv4 or IPv6 routes of that VPN instance.
evpn: Enables next hop-specific dynamic End.DX4 or End.DX6 SID allocation for private network routes when the routes are converted to BGP EVPN routes in an EVPN L3VPN over SRv6 network. If you do not specify this keyword, this command enables nexthop-specific dynamic End.DX4 or End.DX6 SID allocation for private network routes when the routes are converted to BGP VPNv4 or VPNv6 routes.
This command is applicable to the IP L3VPN over SRv6 and EVPN L3VPN over SRv6 scenarios.
By default, a PE allocates the same SID to all BGP routes of a VPN instance. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the VPN instance based on the SID for an optimal route. Then, the PE forwards the packet to a CE. To forward the packet to the next hop without looking up the routing table, use this command and the nexthop interface command.
Before you use the segment-routing ipv6 apply-sid specify-nexthop command in BGP-VPN IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
# In BGP-VPN IPv4 unicast address family view, configure next hop-specific dynamic End.DX4 SID allocation for BGP private network IPv4 routes, and create and enter BGP-VPN IPv4 SR next hop view.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4 unicast
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 apply-sid specify-nexthop
nexthop interface
Use segment-routing ipv6 best-effort to recurse routes to SRv6-BE tunnels.
Use undo segment-routing ipv6 best-effort to restore the default.
In BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view:
segment-routing ipv6 best-effort [ evpn ]
undo segment-routing ipv6 best-effort [ evpn ]
In BGP IPv4 unicast address family view or BGP IPv6 unicast address family view:
segment-routing ipv6 best-effort evpn
undo segment-routing ipv6 best-effort evpn
A PE searches the IPv6 routing table based on the next hop of a matching route to forward traffic.
evpn: Recurses EVPN routes to SRv6-BE tunnels. If you do not specify this keyword, the device recurses BGP VPNv4 or VPNv6 routes to SRv6-BE tunnels.
This command is applicable to the IP L3VPN over SRv6, EVPN L3VPN over SRv6, and public network IP over SRv6 scenarios. This command enables a PE to forward packets by looking up the IPv6 routing table based on the SRv6 SIDs in the packets.
Use this command in different address family views according to your network scenario.
· In the IPv4 or IPv6 L3VPN over SRv6 network and the EVPN L3VPN over SRv6 network, use this command in BGP-VPN IPv4 unicast address family view or BGP-VPN IPv6 unicast address family view.
· In the public network IPv4 or IPv6 over SRv6 network, use this command in BGP IPv4 unicast address family view or BGP IPv6 unicast address family view.
· In the inter-AS option B VPN scenario, use this command in BGP VPNv4 address family view, BGP VPNv6 address family view, or BGP EVPN address family view.
This command is mutually exclusive with the segment-routing ipv6 traffic-engineering command.
# In BGP-VPN IPv4 unicast address family view, recurse private network routes to SRv6-BE tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 best-effort
# In BGP-VPN IPv6 unicast address family view, recurse private network routes to SRv6-BE tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv6
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 best-effort
Use segment-routing ipv6 locator to apply a locator to a BGP family.
Use undo segment-routing ipv6 locator to restore the default.
segment-routing ipv6 locator locator-name [ evpn ] [ auto-sid-disable ]
undo segment-routing ipv6 locator [ evpn ]
In BGP VPNv4 address family view, BGP VPNv6 address family view, BGP IPv4 unicast address family view or BGP IPv6 unicast address family view:
segment-routing ipv6 locator locator-name [ auto-sid-disable ]
segment-routing ipv6 locator locator-name evpn [ auto-sid-disable ]
undo segment-routing ipv6 locator evpn
No locator is applied to a BGP family.
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. The specified locator must exist.
evpn: Adds the SID attribute to private network routes when the routes are converted to EVPN routes. If you do not specify this keyword, the command adds the SID attribute to private network routes when the routes are converted to BGP VPNv4 or VPNv6 routes.
auto-sid-disable: Disables automatic SRv6 SID allocation. If you do not specify this keyword, the device allows dynamically allocated SRv6 SIDs. If static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the static SRv6 SIDs take precedence. If no static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the system dynamically allocates SRv6 SIDs.
Use this command to enable a BGP family to use BGP routes to advertise SRv6 SIDs in the specified locator.
If you execute this command multiple times for the same address family, the most recent configuration takes effect.
# Apply locator abc to BGP-VPN IPv4 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc
# Apply locator abc to BGP-VPN IPv6 unicast address family view.
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc
[Sysname] bgp 100
[Sysname-bgp-default-ipv6-vpn1] segment-routing ipv6 locator abc evpn
locator
segment-routing ipv6 locator (cross-connect view and VSI EVPN instance view)
Use segment-routing ipv6 locator to apply an SRv6 locator to a cross-connect or a VSI.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from a cross-connect or a VSI.
In cross-connect view:
segment-routing ipv6 locator locator-name [ dx2l-locator dx2l-locator-name ] [ auto-sid-disable ]
In VSI EVPN instance view:
segment-routing ipv6 locator locator-name [ dt2u-locator dt2u-locator-name ] [ dt2ul-locator dt2ul-locator-name ] [ dx2-locator dx2-locator-name ] [ dx2l-locator dx2l-locator-name ] [ auto-sid-disable ]
No SRv6 locators are applied to a cross-connect or a VSI.
Cross-connect view
dx2l-locator dx2l-locator-name: Specifies the locator used to apply for End.DX2L SIDs. The dx2l-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
dt2u-locator dt2u-locator-name: Specifies the locator used to apply for End.DT2U SIDs. The dt2u-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
dt2ul-locator dt2ul-locator-name: Specifies the locator used to apply for End.DT2UL SIDs. The dt2ul-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
dx2-locator dx2-locator-name: Specifies the locator used to apply for End.DX2 SIDs. The dx2-locator-name argument represents the locate name, a case-sensitive string of 1 to 31 characters.
auto-sid-disable: Disables automatic SID allocation. If no opcode is configured for the locator specified in this command when automatic SID allocation is disabled, SID application fails. If you do not specify this keyword, automatic SID allocation is enabled and static SRv6 SIDs and dynamic SRv6 SIDs can coexist. The static SRv6 SIDs take precedence over the dynamically allocated SRv6 SIDs.
Use this command to enable a cross-connect or VSI to apply for SRv6 SIDs from the specified locator.
· If you specify the dx2l-locator dx2l-locator-name option, the locator-name argument applies for End.DX2 SIDs and the dx2l-locator-name argument applies for End.DX2L SIDs.
· If you do not specify the dx2l-locator dx2l-locator-name option, the locator-name argument applies for both End.DX2 SIDs and End.DX2L SIDs.
· If you do not specify the dt2u-locator dt2u-locator-name, dt2ul-locator dt2ul-locator-name, dx2-locator dx2-locator-name, or dx2l-locator dx2l-locator-name option, the locator-name argument applies for End.DT2M, End.DT2U, End.DT2UL, End.DX2, and End.DX2L SIDs.
· If you specify the dt2u-locator dt2u-locator-name, dt2ul-locator dt2ul-locator-name, dx2-locator dx2-locator-name, or dx2l-locator dx2l-locator-name option, the option applies for End.DT2U, End.DT2UL, End.DX2, or End.DX2L SIDs and the locator-name argument applies for other SRv6 SIDs.
# Configure VSI aaa to use locator test1 to apply for End.DT2M, End.DT2UL, End.DX2, and End.DX2L SIDs and use locator test2 to apply for End.DT2U SIDs.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-srv6] segment-routing ipv6 locator test1 dt2u-locator test2
# Configure cross-connect aaa in cross-connect group bbb to use locator test3 to apply for End.DX2 and End.DX2L SIDs and disable automatic SID allocation.
[Sysname] xconnect-group bbb
[Sysname-xcg-bbb] evpn encapsulation srv6
[Sysname-xcg-bbb-evpn-srv6] quit
[Sysname-xcg-bbb] connection aaa
[Sysname-xcg-bbb-connection-aaa] segment-routing ipv6 locator test3 auto-sid-disable
segment-routing ipv6 locator anycast
Use segment-routing ipv6 locator anycast to apply an anycast locator to a BGP family.
Use undo segment-routing ipv6 locator anycast to restore the default.
segment-routing ipv6 locator locator-name anycast [ evpn ]
locator-name: Specifies an anycast locator by its name, a case-sensitive string of 1 to 31 characters.
evpn: Uses EVPN routes to advertise the SRv6 SIDs in the anycast locator. If you do not specify this keyword, BGP uses VPNv4 or VPNv6 routes to advertise the SRv6 SIDs in the anycast locator.
Use this command to enable a BGP family to use BGP routes to advertise SRv6 SIDs in an anycast locator. Multiple IPv6 peers configured with the same locator can share load.
Before executing this command, you need to execute the anycast enable command in the locators of a group of PEs to ensure that the PEs use the same locator.
After you execute this command in an IP L3VPN over SRv6 network or public network IP over SRv6 network, execute the peer prefix-sid command with the anycast keyword, so the device can exchange the SRv6 SIDs in the anycast locator with the specified peer.
After you execute this command in an EVPN L3VPN over SRv6 network, you must also execute the peer advertise encap-type srv6 command with the anycast keyword in order to advertise the SRv6 SIDs in the anycast locator through EVPN routes.
This command applies only to the static SRv6 SIDs in the specified anycast locator.
# Apply anycast locator abc to BGP-VPN IPv4 unicast address family.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4-vpn1] segment-routing ipv6 locator abc anycast
# Apply anycast locator abc to BGP IPv4 unicast address family.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing ipv6 locator abc anycast
anycast enable
peer prefix-sid
Use segment-routing ipv6 traffic-engineering to recurse routes to SRv6 TE policy tunnels.
Use undo segment-routing ipv6 traffic-engineering to restore the default.
segment-routing ipv6 traffic-engineering [ best-effort | best-effort-backup ] [ evpn ]
undo segment-routing ipv6 traffic-engineering [ best-effort | best-effort-backup ]
segment-routing ipv6 traffic-engineering [ best-effort ]
undo segment-routing ipv6 traffic-engineering [ best-effort ]
segment-routing ipv6 traffic-engineering [ best-effort ] evpn
undo segment-routing ipv6 traffic-engineering [ best-effort ] evpn
best-effort: Switches to the SRv6 BE route recursion mode when the matching SRv6 TE policy tunnel fails for L3VPN traffic. With this keyword, a PE looks up the routing table for the SRv6 SID of a packet to forward that packet in SRv6 BE mode when the matching SRv6 TE policy tunnel fails. If you do not specify this keyword, the PE looks up the routing table based on the destination IP address of a packet to forward that packet when the matching SRv6 TE policy tunnel fails.
best-effort-backup: Implements FRR by using the SRv6 TE path (primary path) and SRv6 BE path (backup path). If the SRv6 TE path fails or does not exist, traffic is immediately switched to the SRv6 BE path to ensure service continuity. If multiple SRv6 BE paths exist between the source and destination nodes, the SRv6 BE path with the lowest next hop address is selected as the backup path.
evpn: Recurses the private network routes based on the SID attribute in EVPN routes. If you do not specify this keyword, the device recurses the private network routes based on the SID attribute in BGP VPNv4 or VPNv6 routes.
This command is applicable to the IP L3VPN over SRv6, EVPN L3VPN over SRv6, and public network IP over SRv6 scenarios. This command enables PEs to recurse routes to SRv6 TE policy tunnels and use the tunnels to forward user service traffic between the PEs.
To improve high availability for packet forwarding, specify the best-effort or best-effort-backup keyword. A PE forwards a user service packet as follows:
1. The PE forwards the packet through the matching SRv6 TE policy tunnel.
2. If the matching SRv6 TE policy tunnel fails, the PE forwards the packet in SRv6 BE mode.
¡ If the best-effort keyword is specified, the device performs IPv6 routing table lookup based on the encapsulated SRv6 SID, and forwards the packet in SRv6 BE mode.
¡ If the best-effort-backup keyword is specified, the device quickly switches the packet to the SRv6 BE backup path.
3. If the packet forwarding still fails in SRv6 BE mode, the PE forwards the packet by looking up the routing table based on the destination IP address of the packet.
4. If the packet forwarding still fails, the PE drops the packet.
· In the public network IPv4 or IPv6 over SRv6 scenario, use this command in BGP IPv4 unicast address family view or BGP IPv6 unicast address family view.
This command is mutually exclusive with the segment-routing ipv6 best-effort command.
# In BGP IPv4 unicast address family view, recurse routes to SRv6 TE policy tunnels.
[Sysname] bgp 100
[Sysname-bgp-default-ipv4] segment-routing ipv6 traffic-engineering
srv6-mpls-interworking enable
Use srv6-mpls-interworking enable to enable SRv6 and MPLS interworking.
Use undo srv6-mpls-interworking enable to disable SRv6 and MPLS interworking.
SRv6 and MPLS interworking is disabled.
For intercommunication between an MPLS network in one AS and an SRv6 network in another AS, enable SRv6 and MPLS interworking on the ASBR in the SRv6 network. This feature enables End.T SID allocation and establishes mappings between End.T SIDs and MPLS labels.
With this feature, the ASBR in the SRv6 network allocates End.T SIDs based on FECs and advertises the SIDs to other SRv6 nodes through an IGP. An FEC is a destination IPv4 address/mask or destination IPv6 address/prefix length. The function of an End.T SID is removing the outer IPv6 header and looking up the IPv6 FIB table based on the End.T SID to forward packets.
For SRv6-to MPLS packets, the ingress node in the SRv6 network encapsulates an End.T SID to the packets when forwarding the packets to the ASBR in the SRv6 network. When the ASBR in the SRv6 network receives the packets, it looks up the IPv6 FIB table based on the End.T SID for a matching route. Then, the ASBR recurses the route to an LSP to forward the packets to the MPLS network.
For MPLS-to-SRv6 packets, the ASBR in the SRv6 network looks up the label forwarding table to forward the packets. The out label is an End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SID in the SRv6 network. After the ASBR in the SRv6 network encapsulates the End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SID to the packets, it forwards the packets in SRv6 BE or SRv6 TE mode.
# Enable SRv6 and MPLS interworking.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] srv6-mpls-interworking enable
statistics enable
Use statistics enable to enable SRv6 PW packet statistics.
Use undo statistics enable to disable SRv6 PW packet statistics.
statistics enable
The SRv6 PW packet statistics feature is disabled.
Cross-connect EVPN PW view
EVPN VPWS over SRv6 network:
Use this command to enable SRv6 PW packet statistics in cross-connect EVPN PW view. To display SRv6 PW packet statistics, use the display l2vpn peer srv6 verbose command. To clear SRv6 PW packet statistics, use the reset l2vpn statistics srv6-pw command.
The statistics enable command is not supported by PWs in a cross-connect group EVPN instance that uses MPLS encapsulation.
EVPN VPLS over SRv6 network:
Use the statistics enable command to enable packet statistics for all SRv6 PWs in a VSI EVPN instance. To display inbound packet statistics for all SRv6 PWs, use the display l2vpn statistics srv6-pw inbound command. To display outbound packet statistics for each SRv6 PW, use the display l2vpn peer srv6 verbose command. To clear SRv6 PW packet statistics, use the reset l2vpn statistics srv6-pw command.
The statistics enable command is supported only by VSI EVPN instances that use SRv6 encapsulation.
# In an EVPN VPWS over SRv6 network, enable packet statistics for an SRv6 PW.
[Sysname] xconnect-group vpws
[Sysname-xcg-vpws] connection aa
[Sysname-xcg-vpws-aa] evpn local-service-id 2 remote-service-id 4
[Sysname-xcg-vpws-aa-2-4] statistics enable
# In an EVPN VPLS over SRv6 network, enable packet statistics for all SRv6 PWs in an EVPN instance.
[Sysname] vsi vpna
[Sysname-vsi-vpna] evpn encapsulation srv6
[Sysname-vsi-vpna-evpn-srv6] stastics enable
Use tracert evpn vpls srv6 to trace the path of an SRv6 PW from the local PE to the remote PE in an EVPN VPLS over SRv6 network.
tracert evpn vpls srv6 vsi vsi-name mac mac-address [ -a source-ipv6 | -h hop-limit | -r reply-mode | -t time-out | -tc tc ] *
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters.
-h hop-limit: Specifies the maximum number of hops allowed for an MPLS echo request. The value range for the hop-limit argument is 1 to 255, and the default value is 30.
-tc tc: Specifies the traffic class value in MPLS echo replies. The value range for the tc argument is 0 to 255 and the default value is 0.
In an EVPN VPLS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to trace the path of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs. This command helps you locate the failed nodes on the path.
# Trace route to a remote PE through an SRv6 PW in VSI vpna by reaching remote-MAC 0002-0002-0002.
<Sysname> tracert evpn vpls srv6 vsi vpna mac 2-2-2
Trace route to a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002.
Hop Wait time Type Replier
0 0 ms Ingress
1 4 ms Transit 1111::2
2 5 ms Transit 2222::2
3 6 ms Transit 3333::2
4 6 ms Egress 4444::2
Table 12 Command output
Trace route to a remote PE in VSI vpna over SRv6 by reaching remote-MAC 0002-0002-0002 |
Trace route to a remote PE through an SRv6 PW in VSI vpna by reaching remote-MAC 0002-0002-0002. |
Press escape key Ctrl+C to abort the tracert operation. |
Hop |
Hop number. |
Wait time |
Interval between the time when an echo request was sent and the time when the reply of the echo request was received. The unit is millisecond. |
Type |
Node type: · Ingress. · Transit. · Egress. |
Replier |
IPv6 address of the node. |
Request time out |
This field is available if the local PE does not receive any MPLS echo reply to an MPLS echo request when the echo reply timeout time expires. |
ping evpn vpls srv6
Use tracert evpn vpws srv6 to trace the path of an SRv6 PW from the local PE to the remote PE in an EVPN VPWS over SRv6 network.
tracert evpn vpws srv6 xconnect-group group-name local-service-id remote-service-id [ -a source-ip | -h hop-limit | -r reply-mode | -t time-out | -tc tc ] *
-a source-ip: Specifies the source IPv6 address of MPLS echo requests. If you do not specify a source IPv6 address, the IPv6 address of the traffic output interface is used as the source IPv6 address of MPLS echo requests.
-r reply-mode: Specifies the reply mode used by the receiver (the remote PE) to reply to an MPLS echo request. The value for the reply-mode argument can be 2 or 4, and the default value is 2. If the mode is 2, the receiver searches the IP forwarding table for the destination IP address to forward MPLS echo replies. If the mode is 4, the receiver searches the IPv6 routing table for the source IPv6 address of the echo requests, encapsulates an SRH to the replies, and forwards them.
In an EVPN VPWS over SRv6 network, a PE transmits data packets to a remote PE over an SRv6 PW. Use this command to trace the path of the SRv6 PW from the local PE to the remote PE when packet loss or traffic interruption occurs between the PEs. This command helps you locate the failed nodes on the path.
# Trace the route that an SRv6 PW traverses from the local PE to the remote PE in an EVPN VPWS over SRv6 network. The SRv6 PW belongs to cross-connect group xcga, its local service ID is 2, and its remote service ID is 1.
<Sysname> tracert evpn vpws srv6 xconnect-group xcga 1 2
Trace route to a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga.
0 0 ms Ingress
4 6 ms Egress 3333::2
Table 13 Command output
Trace route to a remote PE over SRv6 through a PW with local service ID 2 and remote service ID 1 in cross-connect group xcga |
Trace route to a remote PE through an SRv6 PW with local service ID 2 and remote service ID 1 in cross-connect group xcga. |
Hop |
Hop number. |
Wait time |
Type |
Replier |
Request time out |
ping evpn vpws srv6
unicast-forwarding dx2-based
Use unicast-forwarding dx2-based to configure unicast traffic forwarding based on End.DX2 and End.DX2L SIDs in an EVPN VPLS over SRv6 network.
Use undo unicast-forwarding dx2-based to restore the default.
Unicast traffic is forwarded based on End.DT2U and End.DT2UL SIDs in an EVPN VPLS over SRv6 network.
By default, when a PE receives a packet that includes an End.DT2U or End.DT2UL SID, it looks up the MAC address table of the SID's VSI to forward the packet.
To improve forwarding efficiency, use this command. This command enables the PE to allocate an End.DX2 or End.DX2L SID to each AC associated with a VSI and advertise the SIDs to remote PEs through MAC/IP advertisement routes. When the PE receives an SRv6 packet that includes a locally allocated End.DX2 or End.DX2L SID, it does not look up the MAC address table. The PE directly forwards the packet to the AC that is associated with the SID after removing the SRv6 encapsulation.
# Configure EVPN VPLS over SRv6 to forward unicast traffic based on End.DX2 and End.DX2L SIDs.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-srv6] unicast-forwarding dx2-based
