| 01-User isolation commands | 94.58 KB |
display user-isolation statistics
reset user-isolation statistics
user-isolation permit-broadcast
user-isolation vlan permit-bmc acl
user-isolation vlan permit-mac
wlan user-isolation permit-broadcast
wlan user-isolation vlan enable
wlan user-isolation vlan permit-mac
Use display user-isolation statistics to display user isolation statistics for a VLAN or for all VLANs.
display user-isolation statistics [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command displays user isolation statistics for all VLANs.
# Display user isolation statistics for all VLANs.
<Sysname> display user-isolation statistics
Number of VLANs enabled with user isolation: 2
Number of VLANs disabled with user isolation: 1
VLAN Status Drops Permit-Unicast Permitted MACs Permit IPv4|I
Pv6 Acl
4 Enabled 0 Y N/A 3001|3002
6 Disabled 0 N 0023-89a2-3d4d 3001|3002
5 Enabled 0 Y N/A N/A|N/A
VLAN |
VLAN ID. |
State |
Permit-Unicast |
Whether unicast packets are permitted among users in the VLAN: · Y—Yes. Only broadcast and multicast packets are isolated. · N—No. Unicast, broadcast, and multicast packets are all isolated. |
Permit IPv4|IPv6 Acl |
Permitted IPv4 and IPv6 ACLs in the VLAN. |
Use reset user-isolation statistics to clear user isolation statistics for a VLAN or for all VLANs.
reset user-isolation statistics [ vlan vlan-id ]
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094. If you do not specify a VLAN, this command clears user isolation statistics for all VLANs.
# Clear user isolation statistics for VLAN 1.
<Sysname> reset user-isolation statistics vlan 1
user-isolation enable
Use user-isolation enable to enable SSID-based user isolation.
Use undo user-isolation enable to disable SSID-based user isolation.
SSID-based user isolation is disabled.
Service template view
# Enable SSID-based user isolation.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] user-isolation enable
Use user-isolation permit-broadcast to permit broadcast and multicast traffic sent from wired users to wireless users.
Use undo user-isolation permit-broadcast to restore the default.
The device does not forward broadcast or multicast traffic sent from wired users to wireless users in the VLANs where user isolation is enabled.
Configuration profile view
Isolate broadcast and multicast packets of wired users from wireless users only when the wired and wireless users belong to the same VLAN.
# Permit broadcast and multicast traffic sent from wired users to wireless users.
[Sysname] user-isolation permit-broadcast
# Create configuration profile p1 and enter its view, and then permit broadcast and multicast traffic sent from wired users to wireless users.
[Sysname] configuration profile p1 model WA6320
[Sysname-config-profile-p1] user-isolation permit-broadcast
Use user-isolation vlan enable to enable user isolation for a list of VLANs.
Use undo user-isolation vlan enable to disable user isolation for a list of VLANs.
user-isolation vlan vlan-list enable [ permit-unicast ]
undo user-isolation vlan vlan-list enable
User isolation is disabled for a VLAN.
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN range, the value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument.
permit-unicast: Permits unicast packets among users. If you do not specify this keyword, unicast packets are isolated among users together with broadcast and multicast packets.
To avoid network disconnection to the external network, add the MAC address of the gateway to the permitted MAC address list. To add a permitted MAC address, use the user-isolation vlan permit-mac command.
If you execute the user-isolation vlan enable command multiple times, the device accumulates the specified VLANs. If you execute the user-isolation vlan enable command multiple times for a VLAN, the most recent configuration takes effect.
In configuration profile view, you can enable user isolation for a maximum of 64 VLANs.
# Enable user isolation for VLAN 1.
[Sysname] user-isolation vlan 1 enable
# Create configuration profile p1 and enter its view, and then enable user isolation for VLAN 1.
[Sysname-config-profile-p1] user-isolation vlan 1 enable
Use user-isolation vlan permit-bmc acl to permit wireless users in the specified VLANs to receive broadcast and multicast traffic.
Use undo user-isolation vlan permit-bmc acl to prevent wireless users in the specified VLANs from receiving broadcast and multicast traffic.
user-isolation vlan vlan-list permit-bmc acl [ ipv6 ] acl-number
undo user-isolation vlan vlan-list permit-bmc acl [ ipv6 ]
Wireless users in a VLAN cannot receive broadcast or multicast traffic when user isolation is enabled.
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN range, the value for the vlan-id2 argument must be greater than or equal to the value for the vlan-id1 argument.
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, the command specifies an IPv4 ACL.
acl-number: Specifies an ACL number in the range of 3000 to 3999.
Use this command for a VLAN if the VLAN contains both wired and wireless users and the wireless users are required to receive broadcast and multicast traffic. For example, the wireless users are required to receive bonjour packets.
You can specify only one IPv4 ACL and one IPv6 ACL. If you execute this command multiple times for the same type of ACL, the most recent configuration takes effect.
If you use this command only on the central AC in an AC hierarchical network, the command takes effect only on the central AC. The local ACs are not restricted by the command.
In configuration profile view, you can permit wireless users in a maximum of 64 VLANs to receive broadcast and multicast traffic.
# Permit wireless users in VLAN 1 to receive broadcast and multicast traffic that matches ACL 3002.
[Sysname] user-isolation vlan 1 permit-bmc acl 3002
# Create configuration profile p1 and enter its view, and then permit wireless users in VLAN 1 to receive broadcast and multicast traffic that matches ACL 3002.
[Sysname-config-profile-p1] user-isolation vlan 1 permit-bmc acl 3002
Use user-isolation vlan permit-mac to configure the permitted MAC address list for a list of VLANs.
Use undo user-isolation vlan enable to remove a list of permitted MAC addresses for VLANs.
user-isolation vlan vlan-list permit-mac mac-list
undo user-isolation vlan vlan-list permit-mac { mac-list | all }
No permitted MAC address list is specified for a VLAN.
mac-list: Specifies a space-separated list of up to 16 MAC addresses. Each MAC address is in the form of H-H-H.
all: Specifies all permitted MAC addresses.
Packets from users of the permitted MAC addresses are not isolated in their corresponding VLANs.
If you execute the user-isolation vlan permit-mac command multiple times, the device accumulates the specified permitted MAC addresses.
In system view, the number of permitted MAC addresses cannot exceed 64 for a VLAN. The MAC addresses cannot be broadcast or multicast MAC addresses.
In configuration profile view, you can configure the permitted MAC address list for a maximum of 64 VLANs. The number of permitted MAC addresses cannot exceed 16 for a VLAN. The MAC addresses cannot be broadcast or multicast MAC addresses.
# Specify permitted MAC addresses 00bb-ccdd-eeff and 0022-3344-5566 for VLAN 1.
[Sysname] user-isolation vlan 1 permit-mac 00bb-ccdd-eeff 0022-3344-5566
# Create configuration profile p1 and enter its view, and then specify permitted MAC addresses 00bb-ccdd-eeff and 0022-3344-5566 for VLAN 1.
[Sysname-config-profile-p1] user-isolation vlan 1 permit-mac 00bb-ccdd-eeff 0022-3344-5566
NOTE: Support for this command depends on the AP model. |
Use wlan user-isolation permit-broadcast to permit broadcast and multicast traffic sent from wired users to wireless users.
Use undo wlan user-isolation permit-broadcast to restore the default.
AP group view
This command is applicable only to local forwarding mode.
# In AP group default-group, permit broadcast and multicast traffic sent from wired users to wireless users.
[Sysname] wlan ap-group default-group
[Sysname-wlan-ap-group-default-group] wlan user-isolation permit-broadcast
Use wlan user-isolation vlan enable to enable user isolation for a list of VLANs.
Use undo wlan user-isolation vlan enable to disable user isolation for a list of VLANs.
wlan user-isolation vlan vlan-list enable [ permit-unicast ]
undo wlan user-isolation vlan vlan-list enable
AP group view
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by its VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN ID range, the value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
To avoid network disconnection to the external network, add the MAC address of the gateway to the permitted MAC address list. To add a permitted MAC address, use the wlan user-isolation vlan permit-mac command.
The wlan user-isolation vlan enable command is applicable only to local forwarding mode.
If you execute the wlan user-isolation vlan enable command multiple times, the device accumulates the specified VLANs. If you execute the wlan user-isolation vlan enable command multiple times for the same VLAN, the most recent configuration takes effect.
You can configure user isolation settings for a maximum of 256 VLANs. In the same view, the total number of VLANs configured with user isolation settings includes all VLANs specified by user isolation commands, for example, the wlan user-isolation vlan enable and wlan user-isolation vlan permit-mac commands.
# In AP group default-group, enable user isolation for VLAN 1.
[Sysname-wlan-ap-group-default-group] wlan user-isolation vlan 1 enable
Use wlan user-isolation vlan permit-mac to configure the permitted MAC address list for a list of VLANs.
Use undo wlan user-isolation vlan permit-mac to remove a list of permitted MAC addresses for VLANs.
wlan user-isolation vlan vlan-list permit-mac mac-list
undo wlan user-isolation vlan vlan-list permit-mac { mac-list | all }
AP group view
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by its VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN range, the value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
mac-list: Specifies a space-separated list of up to 16 MAC addresses. Each MAC address is in the form of H-H-H. The MAC addresses cannot be broadcast or multicast MAC addresses.
If you execute this command multiple times, the device accumulates the specified permitted MAC addresses. You can configure a maximum of 16 permitted MAC addresses for each VLAN.
# In AP group default-group, specify permitted MAC addresses 00bb-ccdd-eeff and 0022-3344-5566 for VLAN 1.
[Sysname-wlan-ap-group-default-group] wlan user-isolation vlan 1 permit-mac 00bb-ccdd-eeff 0022-3344-5566
