11-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S6520X-HI[EI][SI]&S6520-SI&S5560X-HI&S5000-EI&MS4600 Configuration Guides-R68xx-6W10011-Network Management and Monitoring Configuration Guide
26-EPS agent configuration
26-EPS agent configuration 157.18 KB
Configuring EPS agent
About EPS and EPS agent
H3C iMC Endpoints Profiling System (EPS) detects, identifies, and monitors network-wide endpoints, including cameras, PCs, servers, switches, routers, firewalls, APs, printers, and ATMs. New endpoints and abnormal endpoints can be timely discovered and identified.
As shown in Figure 1, an EPS system contains the EPS server, scanners, and endpoints.
Figure 1 EPS network architecture
EPS server
The EPS server is a server installed with the iMC EPS component. It acts as the console to assign instructions to scanners, receive scan results, compare scan results with baselines, and support change auditing.
Scanner
A scanner is a device installed with iMC EScan and enabled with EPS agent. The scanner scans and manages endpoints by following the instruction of the EPS server and reports scan results to the EPS server.
EPS agent is based on the Comware platform and integrates the EPS scanner function. This chapter describes how to configure EPS agent.
Endpoint
An endpoint refers to a device scanned by a scanner. EPS supports user-defined endpoint types and the following system-defined endpoint types: camera, PC, server, switch, router, firewall, AP, printer, ATM, unknown, and other.
Restrictions: Hardware compatibility with EPS agent
The device does not support scanning endpoints connected to the gateway. If the console assigns a gateway-based scan task, no endpoints will be scanned.
After you enable EPS agent for the scanner on a slot, the scanner scans and manages connected, reachable endpoints in its ARP table by following the instructions of the EPS server.
2.     Configure EPS server parameters
eps server ip-address port port-number [ key { cipher | simple } key-value ] [ log-level level-value ] [ use-server-setting ]
By default, EPS server parameters are not configured.
3.     Enable EPS agent.
eps agent enable [ slot slot-number ]
By default, EPS agent is disabled.
Display and maintenance commands for EPS agent
Display scanned endpoint information.
display eps agent discovery [ slot slot-number ]
EPS agent configuration examples
Example: Configuring EPS agent
As shown in Figure 2, configure the scanner to enable it to scan endpoints based on the instruction of the EPS server.
Figure 2 Network diagram
# Specify 20.1.1.2 and 4500 as the IP address and port number of the EPS server, respectively.
[Sysname] eps server 20.1.1.2 port 4500
# Enable EPS agent on slot 1.
[Sysname] eps agent enable slot 1
# Display EPS scanner information.
[Sysname] display eps agent
EPS agent information:
  Slot       Port number
  1          12000
EPS server information:
  IP address        : 20.1.1.2
  Port number       : 4500
  Cipher key        : $c$3$rGn++lJ/vHnkk1oQDAKX9NLIz+4vXONZXCRTpQ==
  Log level         : 5
  Use server setting: Yes
# Verify that the scanned information is displayed on slot 1 after the EPS server issues a scan instruction.
[Sysname] display eps agent discovery slot 1
IP-Address        MAC-Address        OS-Type  OS-ver   Vendor    Product
100.100.100.100  cc:ef:48:9b:5f:c1 IOS       12.X     Cisco     C3560E
