07-MPLS Configuration Guide
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration GuidesH3C S12500R-48Y8C&S12500R-48C6D Switch Router Configuration Guides(R52xx)-6W10207-MPLS Configuration Guide
01-Basic MPLS configuration
01-Basic MPLS configuration 341.12 KB
Configuring basic MPLS
About MPLS
Multiprotocol Label Switching (MPLS) provides connection-oriented label switching over connectionless IP backbone networks. It integrates both the flexibility of IP routing and the simplicity of Layer 2 switching.
MPLS features
MPLS has the following features:
·     High speed and efficiency—MPLS uses short- and fixed-length labels to forward packets, avoiding complicated routing table lookups.
·     Multiprotocol support—MPLS resides between the link layer and the network layer. It can work over various link layer protocols (for example,  Ethernet) to provide connection-oriented services for various network layer protocols (for example, IPv4, IPv6, and IPX).
·     Good scalability—The connection-oriented switching and multilayer label stack features enable MPLS to deliver various extended services, such as VPN, traffic engineering, and QoS.
Basic concepts
FEC
MPLS groups packets with the same characteristics (such as packets with the same destination or service class) into a forwarding equivalence class (FEC). Packets of the same FEC are handled in the same way on an MPLS network.
Label
A label uniquely identifies an FEC and has local significance.
Figure 1 Format of a label
A label is encapsulated between the Layer 2 header and Layer 3 header of a packet. It is four bytes long and consists of the following fields:
·     Label—20-bit label value.
·     TC—3-bit traffic class, used for QoS. It is also called Exp.
·     S—1-bit bottom of stack flag. A label stack can contain multiple labels. The label nearest to the Layer 2 header is called the top label, and the label nearest to the Layer 3 header is called the bottom label. The S field is set to 1 if the label is the bottom label and set to 0 if not.
·     TTL—8-bit time to live field used for MPLS loop prevention.
LSR
A router that performs MPLS forwarding is a label switching router (LSR).
LSP
A label switched path (LSP) is the path along which packets of an FEC travel through an MPLS network.
An LSP is a unidirectional packet forwarding path. Two neighboring LSRs are called the upstream LSR and downstream LSR along the direction of an LSP. As shown in Figure 2, LSR B is the downstream LSR of LSR A, and LSR A is the upstream LSR of LSR B.
Figure 2 Label switched path
LFIB
The Label Forwarding Information Base (LFIB) on an MPLS network functions like the Forwarding Information Base (FIB) on an IP network. When an LSR receives a labeled packet, it searches the LFIB to obtain information for forwarding the packet. The information includes the label operation type, the outgoing label value, and the next hop.
Control plane and forwarding plane
An MPLS node consists of a control plane and a forwarding plane.
·     Control plane—Assigns labels, distributes FEC-label mappings to neighbor LSRs, creates the LFIB, and establishes and removes LSPs.
·     Forwarding plane—Forwards packets according to the LFIB.
MPLS network architecture
An MPLS network has the following types of LSRs:
·     Ingress LSR—Ingress LSR of packets. It labels packets entering into the MPLS network.
·     Transit LSR—Intermediate LSRs in the MPLS network. The transit LSRs on an LSP forward packets to the egress LSR according to labels.
·     Egress LSR—Egress LSR of packets. It removes labels from packets and forwards the packets to their destination networks.
Figure 3 MPLS network architecture
LSP establishment
LSPs include static and dynamic LSPs.
Static LSP
To establish a static LSP, you must configure an LFIB entry on each LSR along the LSP. Establishing static LSPs consumes fewer resources than establishing dynamic LSPs, but static LSPs cannot automatically adapt to network topology changes. Therefore, static LSPs are suitable for small-scale networks with simple, stable topologies.
Dynamic LSP
A dynamic LSP is established by a label distribution protocol (also called an MPLS signaling protocol). A label distribution protocol classifies FECs, distributes FEC-label mappings, and establishes and maintains LSPs. Label distribution protocols include protocols designed specifically for label distribution, such as the Label Distribution Protocol (LDP), and protocols extended to support label distribution, such as MP-BGP and RSVP-TE.
In this document, the term "label distribution protocols" refers to all protocols for label distribution. The term "LDP" refers to the RFC 5036 LDP.
A dynamic LSP is established in the following steps:
1.     A downstream LSR classifies FECs according to destination addresses.
2.     The downstream LSR assigns a label for each FEC, and distributes the FEC-label binding to its upstream LSR.
3.     The upstream LSR establishes an LFIB entry for the FEC according to the binding information.
After all LSRs along the LSP establish an LFIB entry for the FEC, a dynamic LSP is established for the packets of this FEC.
Figure 4 Dynamic LSP establishment
MPLS forwarding
As shown in Figure 5, a packet is forwarded over the MPLS network as follows:
1.     Device B (the ingress LSR) receives a packet with no label. Then, it performs the following operations:
a.     Identifies the FIB entry that matches the destination address of the packet.
b.     Adds the outgoing label (40, in this example) to the packet.
c.     Forwards the labeled packet out of Interface B1 to the next hop LSR Device C.
2.     When receiving the labeled packet, Device C processes the packet as follows:
a.     Identifies the LFIB entry that has an incoming label of 40.
b.     Uses the outgoing label 50 of the entry to replace label 40 in the packet.
c.     Forwards the labeled packet out of Interface C1 to the next hop LSR Device D.
3.     When receiving the labeled packet, Device D (the egress LSR) processes the packet as follows:
a.     Identifies the LFIB entry that has an incoming label of 50.
b.     Removes the label from the packet.
c.     Forwards the packet out of Interface D1 to the next hop LSR Device E.
If the LFIB entry records no outgoing interface or next hop information, Device D performs the following operations:
a.     Identifies the FIB entry by the IP header.
b.     Forwards the packet according to the FIB entry.
Figure 5 MPLS forwarding
PHP
An egress node must perform two forwarding table lookups to forward a packet:
·     Two LFIB lookups (if the packet has more than one label).
·     One LFIB lookup and one FIB lookup (if the packet has only one label).
The penultimate hop popping (PHP) feature can pop the label at the penultimate node, so the egress node only performs one table lookup.
A PHP-capable egress node can send either of the following null labels to the penultimate node:
·     Implicit null label—The value of an implicit null label is 3. If an incoming packet matches an LFIB entry containing the implicit null label, the penultimate node pops the top label and forwards the packet to the egress node. The egress node forwards the packet based on the header of its next layer.
·     Explicit null label—The value of an explicit null label is 0 for IPv4 networks and 2 for IPv6 networks. Sometimes, the egress node must use the TC field in the label to perform QoS. To keep the TC information, you can configure the egress node to send the penultimate node an explicit null label. If an incoming packet matches an LFIB entry containing the explicit null label, the penultimate hop replaces the top label value with value 0, and forwards the packet to the egress node. When the egress node receives the packet, it does not look up the LFIB table for the label of 0 or 2. The egress mode gets the TC information from the label, pops the label, and then forwards the packet based on the header of its next layer.
Protocols and standards
·     RFC 3031, Multiprotocol Label Switching Architecture
·     RFC 3032, MPLS Label Stack Encoding
·     RFC 5462, Multiprotocol Label Switching (MPLS) Label Stack Entry: "EXP" Field Renamed to "Traffic Class" Field
MPLS tasks at a glance
To configure basic MPLS, perform the following configuration tasks:
1.     Enabling MPLS
2.     (Optional.) Setting MPLS MTU
3.     (Optional.) Specifying the label type advertised by the egress node to the penultimate hop
4.     (Optional.) Control the MPLS lable range
¡     Setting the value range for labels allocatable by the device
¡     Configuring an MPLS label block
5.     (Optional.) Enabling split horizon for MPLS forwarding
6.     (Optional.) Enabling bandwidth-based load sharing on an MPLS transit node
7.     (Optional.) Configuring TTL propagation
When TTL propagation is enabled, the ingress node copies the TTL value of an IP packet to the TTL field of the label. The IP tracert facility can show the real path along which the packet has traveled.
8.     (Optional.) Enabling sending MPLS TTL-expired messages
9.     (Optional.) Enabling MPLS in UDP
10.     (Optional.) Enabling the device to add VLAN tags after PHP forwarding for internal packet processing
11.     (Optional.) Configuring MPLS statistics features
Enabling MPLS label forwarding statistics for LSPs
12.     (Optional.) Enabling SNMP notifications for MPLS
Enabling MPLS
Before you enable MPLS, configure static routes or an IGP protocol to ensure IP connectivity among LSRs.
2.     Configure an LSR ID for the local node.
mpls lsr-id lsr-id
By default, no LSR ID is configured.
An LSR ID must be unique in an MPLS network and in IP address format. As a best practice, use the IP address of a loopback interface as an LSR ID.
3.     Enter the view of the interface that needs to perform MPLS forwarding.
4.     Enable MPLS on the interface.
mpls enable
By default, MPLS is disabled on the interface.
Setting MPLS MTU
MPLS adds the label stack between the link layer header and network layer header of each packet. To make sure the size of MPLS labeled packets is smaller than the MTU of an interface, configure an MPLS MTU on the interface.
MPLS compares each MPLS packet against the interface MPLS MTU. When the packet exceeds the MPLS MTU:
·     If fragmentation is allowed, MPLS performs the following operations:
a.     Removes the label stack from the packet.
b.     Fragments the IP packet. The length of a fragment is the MPLS MTU minus the length of the label stack.
c.     Adds the label stack to each fragment, and forwards the fragments.
·     If fragmentation is not allowed, the LSR forwards the packet.
The MPLS MTU configuration affects IP packet forwarding through MPLS.
As a best practice, set an appropriate MPLS MTU. If the MPLS MTU is too small, performance degradation or even packet loss might occur. If the MPLS MTU of an interface is greater than the MTU of the interface, data forwarding might fail on the interface.
MPLS packets carrying IPv6 packets are always forwarded by an interface, even if the length of the MPLS packets exceeds the MPLS MTU of the interface.
If the peer interface has low performance and cannot receive packets larger than the IP MTU, set the MPLS MTU to a value smaller than the IP MTU as a best practice to ensure correct packet forwarding.
2.     Enter interface view.
3.     Set an MPLS MTU for the interface.
mpls mtu size
By default, no MPLS MTU is set on an interface. Fragmentation for MPLS packets is based on the IP MTU. If IP MTU is not configured, fragmentation for MPLS packets is based on the MTU of the interface. The length of a fragment does not include that of the MPLS label. Thus, after an MPLS label is added into a fragment, the length of the MPLS fragment might exceed the interface MTU.
Select the label type advertised by the egress node to the penultimate hop as follows:
·     As a best practice, configure the egress node to advertise an implicit null label to the penultimate hop if the penultimate hop supports PHP.
·     If you want to simplify packet forwarding on egress but keep labels to determine QoS policies, configure the egress node to advertise an explicit null label to the penultimate hop.
·     Use non-null labels only in particular scenarios. For example, when OAM is configured on the egress node, the egress node can get the OAM function entity status only through non-null labels.
For LDP LSPs, the mpls label advertise command triggers LDP to delete the LSPs established before the command is executed and then re-establish the LSPs.
For BGP LSPs, the mpls label advertise command takes effect only on the BGP LSPs established after the command is executed. To apply the new setting to BGP LSPs established before the command is executed, delete the routes corresponding to the BGP LSPs, and then redistribute the routes.
2.     Specify the label type advertised by the egress node to the penultimate hop.
mpls label advertise { explicit-null | implicit-null | non-null }
By default, an egress node advertises an implicit null label to the penultimate hop.
Configure this feature to set the value range in which label distribution protocols can dynamically allocate labels.
This feature does not take effect on static LSP labels, static CRLSP labels, static SRLSP labels, or SRGBs. For more information about static LSP labels, see "Configuring a static LSP." For more information about static CRLSP labels, see "Configuring a static CRLSP." For more information about static SRLSPs and SRGBs, see MPLS SR configuration in Segment Routing Configuration Guide.
2.     Set the value range for labels that the device can allocate.
mpls label range minimum maximum
By default, the value range for labels that the device can allocate is not configured.
Perform this task to configure the MPLS label blocks. You can specify an MPLS label block in the SRLB or SRGBs, so IGP and BGP use the labels in the MPLS label block.
If you configure MPLS label blocks with the same name multiple times, the most recent configuration takes effect.
MPLS label blocks with different names cannot contain overlapping label values.
If an MPLS label block has been used, you cannot delete the MPLS label block.
2.     Configure an MPLS label block.
mpls label-block name name range minimum-label maximum-label
The default varies by device model.
This feature prevents MPLS packets received from an interface from being forwarded back to that interface to provide loop-free forwarding.
2.     Enable split horizon for MPLS forwarding.
mpls forwarding split-horizon
By default, split horizon is disabled for MPLS forwarding.
Configuring the MPLS load sharing mode
The device supports the following MPLS load sharing modes:
·     Per-flow load sharing based on flow labels—In MPLS L2VPN or VPLS networks, the P device uses the L2VPN flow label feature to implement load sharing for different data flows on the same PW.
To enable MPLS per-flow load sharing based on flow labels:
¡     Configure the flow-label command on the PE to enable the PE to add different flow labels for packets of different traffic types.
The PE device adds a flow label behind the private label in a data packet.
¡     Configure the mpls load-sharing mode per-flow flow-label command on the P device to enable per-flow load sharing based on flow labels.
·     Per-flow load sharing based on labels
¡     If the label stack contains five or less MPLS labels:
-     For MPLS packets carrying IP packets, the device performs load sharing based on the destination IP, source IP, destination port, source port, protocol number, and the ToS field in the IP packets.
-     For MPLS packets carrying TCP and UDP packets, the device performs load sharing based on the destination IP, source IP, protocol number, and the ToS field in the IP packets.
-     For MPLS packets carrying non-IP packets, the device performs load sharing based on all MPLS labels in the packets.
¡     If the label stack contains more than five MPLS labels, the device performs load sharing based on the outmost five MPLS labels.
·     Per-flow load sharing based on IP information
¡     If the label stack contains five or less MPLS labels, the device performs load sharing based on the five tuples of packets.
·     Per-packet load sharing—Sends packets to outgoing interfaces in turn, one packet to one interface at a time, according to the packet reception order.
2.     Configure the MPLS load sharing mode.
mpls load-sharing mode { per-flow { flow-label | label | ip } | per-packet }
The default mode varies by device model.
If equal-cost LDP LSPs exist on a transit node, the node evenly transmits MPLS packets through the LSPs. After you enable this feature, MPLS packets are transmitted through the LSPs in the proportion calculated based on the bandwidth of the egress interfaces.
1.     Enter system view of an MPLS transit node.
2.     Enable bandwidth-based load sharing on the node.
mpls bandwidth-based-sharing
By default, bandwidth-based load sharing is disabled on an MPLS transit node.
When TTL propagation is enabled, the ingress node copies the TTL value of an IP packet to the TTL field of the label. Each LSR on the LSP decreases the label TTL value by 1. The LSR that pops the label copies the remaining label TTL value back to the IP TTL of the packet. The IP TTL value can reflect how many hops the packet has traversed in the MPLS network. The IP tracert facility can show the real path along which the packet has traveled.
Figure 6 TTL propagation
When TTL propagation is disabled, the ingress node sets the label TTL to 255. Each LSR on the LSP decreases the label TTL value by 1. The LSR that pops the label does not change the IP TTL value when popping the label. Therefore, the MPLS backbone nodes are invisible to user networks, and the IP tracert facility cannot show the real path in the MPLS network.
Figure 7 Without TTL propagation
TTL propagation does not take effect on existing LSPs. For existing LSPs, perform the following tasks after you enable TTL propagation:
·     Reconfigure static LSPs.
·     Execute the reset mpls ldp command to restart LDP sessions for dynamic LSPs.
Follow these restrictions and guidelines when you configure TTL propagation:
·     This command affects only the propagation between IP TTL and label TTL. Within an MPLS network, TTL is always copied between the labels of an MPLS packet.
·     As a best practice, set the same TTL processing mode on all LSRs of an LSP.
·     To enable TTL propagation for a VPN, you must enable it on all PE devices in the VPN. Then, you can get the same traceroute result (hop count) from those PEs.
2.     Enable TTL propagation.
mpls ttl propagate { public | vpn }
By default, TTL propagation is enabled for public network packets and is disabled for VPN packets. The ttl-mode command has higher priority than this command. For more information about the ttl-mode command, see MPLS L3VPN configuration in MPLS Configuration Guide.
This feature enables an LSR to generate an ICMP TTL-expired message upon receiving an MPLS packet with a TTL of 1. If the MPLS packet has only one label, the LSR sends the ICMP TTL-expired message back to the source through IP routing. If the MPLS packet has multiple labels, the LSR sends it along the LSP to the egress node, which then sends the message back to the source.
2.     Enable sending MPLS TTL-expired messages.
mpls ttl expiration enable
By default, this feature is enabled.
If devices that do not support MPLS/SR-MPLS exist in the network, you can enable MPLS in UDP on border devices for MPLS/SR-MPLS information to be transmitted through such devices.
With this feature enabled, the device encapsulates MPLS packets in UDP packets (UDP destination port number is 6635) and the UDP packets are transmitted through MPLS/SR-MPLS-incapable devices. Tunnels used to transmit MPLS packets packaged in UDP packets are called MPLS in UDP tunnels.
In the current software version, the device supports acting only as the tail node of a MPLS in UDP tunnel. With this feature enabled, the device can decode UDP packets encapsulated with MPLS packets (UDP packets using destination port 6653), remove the UDP headers, and then forward MPLS packets based on MPLS labels.
Figure 8 MPLS in UDP network
For more information about SR-MPLS, see SR-MPLS in Segment Routing Configuration Guide.
2.     Enable MPLS in UDP and enter MPLS-in-UDP view.
mpls-in-udp
By default, MPLS in UDP is disabled.
NetStream cannot sample and count the traffic forwarded by Penultimate Hop Popping (PHP) in the following situation: The operation type in the ILM entry is SWAP and the outermost label carried in a packet is a public network label. The device performs PHP forwarding to pop the label stack as instructed by the implicit null label. To enable NetStream for the traffic forwarded by implicit null PHP, you can configure the device to add VLAN tags to the traffic.
After this feature is configured, the device adds VLAN tags to packets after performing PHP forwarding for the packets. NetStream then can sample and collect statistics on the traffic based on the VLAN tag information.
The VLAN tag information added by this feature is only used for internal packet processing on the device. Whether to carry VLAN tags when forwarding packets out of the outgoing interfaces is determined by the VLAN and VLAN termination settings on the device.
2.     Configure the local node to add outgoing VLAN tags for packets when performing PHP forwarding, in order to facilitate internal processing.
mpls php-with-outrif
By default, the local node does not add outgoing VLAN tags for packets when performing PHP forwarding.
MPLS label forwarding for LSPs forwards a labeled packet based on its incoming label.
Perform this task to enable MPLS label forwarding statistics for LSPs and set the statistics collection interval. Then, you can use the display mpls lsp verbose command to view MPLS label forwarding statistics.
To display MPLS label forwarding statistics for the specified LSPs by using the display mpls lsp verbose command, you must perform the following tasks:
·     Use the mpls statistics command to enable the MPLS label forwarding statistics feature for the LSPs.
·     Use the mpls statistics interval command to set the MPLS label forwarding statistics collection interval.
If you specify the te ingress-lsr-id tunnel-id option in the mpls statistics command, the MPLS label forwarding statistics collection interval is automatically set to 30 seconds. If you also execute the mpls statistics interval command, the interval set by the mpls statistics interval command takes effect.
2.     Enable MPLS label forwarding statistics for the specified LSPs.
mpls statistics { all | [ vpn-instance vpn-instance-name ] { ipv4 ipv4-address mask-length | ipv6 ipv6-address prefix-length } | static | te ingress-lsr-id tunnel-id }
By default, MPLS label forwarding statistics is disabled for all LSPs.
3.     Set the MPLS label forwarding statistics collection interval.
mpls statistics interval interval
By default, the MPLS label forwarding statistics collection interval is not set.
To report critical MPLS events to an NMS, enable SNMP notifications for MPLS. For MPLS event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
2.     Enable SNMP notifications for MPLS.
snmp-agent trap enable mpls
By default, SNMP notifications for MPLS are disabled.
Verifying and maintaining basic MPLS
Verifying basic MPLS configuration and running status
·     Display MPLS summary information.
display mpls summary
·     Display MPLS interface information.
display mpls interface [ interface-type interface-number ]
·     Display usage information for MPLS labels.
display mpls label { label-value1 [ to label-value2 ] | all }
Displaying MPLS LSP information
·     Display LSP information.
display mpls lsp [ egress | in-label label-value | ingress | outgoing-interface interface-type interface-number | protocol { bgp | isis | ldp | local | ospf | rsvp-te | sr-policy | sr-te | static | static-cr } | transit ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6 [ ipv6-address prefix-length ] ] [ verbose ]
·     Display LSP statistics.
display mpls lsp statistics [ ipv6 ] [ vpn-instance vpn-instance-name ]
Displaying MPLS forwarding table entry information
·     Display ILM entries.
display mpls forwarding ilm [ label ] [ slot slot-number ]
·     Display NHLFE entries.
display mpls forwarding nhlfe [ nid ] [ slot slot-number ]
·     Display usage information for NIDs.
display mpls nid [ nid-value1 [ to nid-value2 ] ]
·     Display MPLS Nexthop Information Base (NIB) information.
display mpls nib [ nib-id ]
Clearing MPLS forwarding statistics for the specified LSPs
To clear MPLS forwarding statistics for the specified LSPs, execute the following command in user view:
reset mpls statistics { all | [ vpn-instance vpn-instance-name ] { ipv4 ipv4-address mask-length | ipv6 ipv6-address prefix-length } | static | te ingress-lsr-id tunnel-id }
