11-VXLAN Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R52xx)-6W10211-VXLAN Command Reference
01-Basic VXLAN commands
01-Basic VXLAN commands 401.83 KB
arp suppression enable
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
arp suppression enable [ no-broadcast ]
ARP flood suppression is disabled.
VSI view
no-broadcast: Disables flooding the ARP requests that do not match any ARP flood suppression entries.
ARP flood suppression reduces ARP request broadcasts by enabling the VTEP to reply to ARP requests on behalf of VMs.
This feature snoops ARP packets to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ARP flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
display arp suppression vsi
reset arp suppression vsi
arp suppression mode
Use arp suppression mode to set the ARP flood suppression mode.
Use undo arp suppression mode to restore the default.
arp suppression mode { proxy-reply | unicast-forward } [  mismatch-discard ]
If ARP flood suppression is enabled, the default ARP flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the ARP requests that are not targeted at the device and do not match any ARP flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device replies to the ARP request on behalf of the target IP address. The ARP reply carries the following information:
·     Sender IP address—Target IP address in the ARP request.
·     Sender MAC address—MAC address in the matching ARP flood suppression entry.
·     Source MAC address—MAC address in the matching ARP flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an ARP request is not targeted at the device and matches an ARP flood suppression entry, the device acts as follows:
1.     Replaces the target MAC address and destination MAC address in the ARP request with the MAC address in the entry.
2.     Unicasts the ARP request.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an ARP request that is not targeted at the device and does not match any ARP flood suppression entry. If you do not specify this keyword, the device will broadcast such an ARP request.
The device does not forward ARP requests in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ARP entry learning errors caused by the delay in refreshing ARP flood suppression entries at the expense of high system resource usage.
# Enable ARP flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression mode unicast-forward
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display arp suppression vsi to display ARP flood suppression entries.
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU.
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries.
<Sysname> display arp suppression vsi
IP address      MAC address    VSI name                    Link ID    Aging(min)
1.1.1.2         000f-e201-0101 vsi1                        0x70000    14
1.1.1.3         000f-e201-0202 vsi1                        0x80000    18
1.1.1.4         000f-e201-0203 vsi2                        0x90000    10
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vsi count
Total entries: 3
Link ID
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI.
Aging
Remaining lifetime (in minutes) of the ARP flood suppression entry. When the timer expires, the entry is deleted.
display ipv6 nd suppression vsi
Use display ipv6 nd suppression vsi to display ND flood suppression entries.
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
count: Displays the number of ND flood suppression entries that match the command.
# Display ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi
IPv6 address            MAC address     VSI name         Link ID    Aging (min)
1000::2                 000f-e201-0101  vsi1             0x70000    5
1000::3                 000f-e201-0202  vsi1             0x80000    5
1000::4                 000f-e201-0203  vsi2             0x90000    5
# Display the number of ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
Link ID
Aging (min)
Remaining lifetime (in minutes) of the ND flood suppression entry. When the timer expires, the entry is deleted.
ipv6 nd suppression enable
reset ipv6 nd suppression vsi
display l2vpn m-lag arp
Use display l2vpn m-lag arp to display L2VPN ARP entries on an M-LAG member device.
display l2vpn m-lag arp [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ count | ip-address ] ]
local: Specifies locally learned L2VPN ARP entries.
remote: Specifies M-LAG-synchronized L2VPN ARP entries.
count: Displays the number of L2VPN ARP entries. If you do not specify this keyword, the command displays detailed information about L2VPN ARP entries.
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all L2VPN ARP entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN ARP entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays L2VPN ARP entries for the public instance and all VPN instances.
# Display all L2VPN ARP entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag arp
Flags: D – Dynamic   L - Local   R – Remote   S – Static   I - Invalid
       G - Gateway   V - MLAG Virtual
VPN instance: vpn1                            Interface: Vsi-interface1
IP address      MAC address      VSI index      Link ID       Flags
10.1.1.1        0003-0003-0003   0              0x1           DL
10.1.1.11       0001-0001-0001   0              0x1           DL
10.1.1.12       0001-0001-0011   0              0x2           M-LAG
10.1.1.13       0001-0001-0021   0              0x2           M-LAG
10.1.1.101      0001-0011-0101   0              0x1           SL
10.1.1.102      0001-0011-0102   0              0x1           SL
Public instance                               Interface: Vsi-interface2
11.1.1.1        0033-0033-0033   0              0x1           DL
11.1.1.11       0011-0011-0011   0              0x1           DL
# Display the total number of L2VPN ARP entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag arp count
Total number of entries: 8
VSI interface.
Link ID
Flags
ARP entry type:
·     D—The entry is a valid dynamically learned entry.
·     L—The entry is a valid local entry.
·     R—The entry is a valid M-LAG-synchronized entry.
·     S—The entry is a valid static entry.
·     I—The entry is invalid. Possible reasons:
¡     The VSI has been administratively shut down by using the shutdown command.
¡     The outgoing tunnel interface does not exist.
·     G—The entry is for a gateway.
·     V—The entry is for the M-LAG virtual IPv4 address of a gateway interface.
display l2vpn m-lag arp suppression
Use display l2vpn m-lag arp suppression to display L2VPN ARP flood suppression entries on an M-LAG member device.
display l2vpn m-lag arp suppression [ local | remote ] [ count | vsi vsi-name [ count | ip-address ] ]
local: Specifies L2VPN ARP flood suppression entries that are learned locally.
remote: Specifies L2VPN ARP flood suppression entries that are synchronized by M-LAG.
count: Displays the number of L2VPN ARP flood suppression entries. If you do not specify this keyword, the command displays detailed information about L2VPN ARP flood suppression entries.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN ARP flood suppression entries for all VSIs.
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all L2VPN ARP flood suppression entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN ARP flood suppression entries.
# Display all L2VPN ARP flood suppression entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag arp suppression
Flags: D - Dynamic   L – Local   R – Remote   S - Static   I – Invalid
VSI name: vpna
IP address      MAC address     Link ID         Flags
10.1.1.12       0002-0002-0002  0x1             DL
10.1.1.13       0002-0002-0002  0x2             RI
10.1.1.101      0001-0011-0101  0x2             SR
# Display the total number of L2VPN ARP flood suppression entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag arp suppression count
Total number of entries: 3
Link ID
Flags
ARP flood suppression entry type:
display l2vpn m-lag mac-address
Use display l2vpn m-lag mac-address to display L2VPN MAC address entries on an M-LAG member device.
display l2vpn m-lag mac-address [ local | remote ] [ count | vsi vsi-name [ count | mac-address ] ]
local: Specifies L2VPN MAC address entries that are learned locally.
remote: Specifies L2VPN MAC address entries that are synchronized by M-LAG.
count: Displays the number of L2VPN MAC address entries. If you do not specify this keyword, the command displays detailed information about L2VPN MAC address entries.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN MAC address entries for all VSIs.
mac-address: Specifies a MAC address. The MAC address is in the format of H-H-H. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. If you do not specify a MAC address, this command displays all L2VPN MAC address entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN MAC address entries.
# Display all L2VPN MAC address entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag mac-address
Flags: D – Dynamic   L - Local   R – Remote   S – Static   A - MAC-authentication
VSI name: bbb
MAC address           Link ID       Interface       Flags
0000-0000-000a        0x1           BAGG10          DL
0000-0000-0009        0x1           Tunnel1         DL
# Display the total number of L2VPN MAC address entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag mac-address count
Total number of entries: 2
Table 5 Command output
Link ID
Outgoing interface.
Flags
MAC address entry type:
·     A—The entry is learned by MAC authentication.
display l2vpn m-lag nd
Use display l2vpn m-lag nd to display L2VPN ND entries on an M-LAG member device.
display l2vpn m-lag nd [ local | remote ] [ count | { public-instance | vpn-instance vpn-instance-name } [ ipv6-address | count ] ]
local: Specifies locally learned L2VPN ND entries.
remote: Specifies M-LAG-synchronized L2VPN ND entries.
count: Displays the number of L2VPN ND entries. If you do not specify this keyword, the command displays detailed information about L2VPN ND entries.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all L2VPN ND entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN ND entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays L2VPN ND entries for the public instance and all VPN instances.
# Display all L2VPN ND entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag nd
Flags: D - Dynamic   L – Local  R – Remote   S - Static   I - Invalid
VPN instance: vpna                            Interface: Vsi-interface1
IPv6 address :   20::2
MAC address  :   0001-0001-0001          Flags        :   DL
VSI index    :   0                       Link ID      :   0x1
# Display the total number of L2VPN ND entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag nd count
Total number of entries: 1
Table 6 Command output
VSI interface.
Flags
ND entry type:
·     V—The entry is for the M-LAG virtual IPv6 address of a gateway interface.
Link ID
display l2vpn m-lag nd suppression
Use display l2vpn m-lag nd suppression to display L2VPN ND flood suppression entries on an M-LAG member device.
display l2vpn m-lag nd suppression [ local | remote ] [ count | vsi vsi-name [ ipv6-address | count ] ]
local: Specifies L2VPN ND flood suppression entries that are learned locally.
remote: Specifies L2VPN ND flood suppression entries that are synchronized by M-LAG.
count: Displays the number of L2VPN ND flood suppression entries. If you do not specify this keyword, the command displays detailed information about L2VPN ND flood suppression entries.
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN ND flood suppression entries for all VSIs.
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all L2VPN ND flood suppression entries that match the specified criteria.
If you do not specify the local or remote keyword, this command displays both locally learned and M-LAG-synchronized L2VPN ND flood suppression entries.
# Display all L2VPN ND flood suppression entries on the local M-LAG member device.
[Sysname]display l2vpn m-lag nd suppression
VSI name: vpna
IPv6 address                            MAC address     Link ID   Flags
11::8                                   72cb-ce9b-0a06  0x1       DL
11::9                                   0001-0001-0001  0x2       SR
# Display the total number of L2VPN ND flood suppression entries on the local M-LAG member device.
<Sysname> display l2vpn m-lag nd suppression count
Table 7 Command output
Link ID
Flags
ND flood suppression entry type:
display l2vpn forwarding ac
Use display l2vpn forwarding ac to display L2VPN AC forwarding information.
display l2vpn forwarding ac [ vsi vsi-name ] [ slot slot-number ] [ verbose ]
vsi vsi-name: Displays L2VPN forwarding information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN forwarding information for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays L2VPN forwarding information for the active MPU.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief AC forwarding information for all VSIs.
<Sysname> display l2vpn forwarding ac
Total number of VSIs: 1
Total number of ACs: 1 up, 0 down
AC              VSI Name          Link ID    State
BAGG1 srv1      1                 0x1        Up
Table 8 Command output
Total number of VSIs, including VSIs that are not bound to any ACs.
Total number of ACs
Total number of attachment circuits (ACs) and the number of ACs in each state (up or down).
AC
AC type, Layer 2 interface and Ethernet service instance.
Link ID
Link ID of the AC in the VSI.
Ethernet service instance state:
·     Up.
·     Down.
# Display detailed AC forwarding information for all VSIs.
<Sysname> display l2vpn forwarding ac verbose
VSI Name: vpls2
  Interface: HGE1/0/3  Service Instance: 4
    Link ID      : 1
    State        : UP
    Access Mode  : VLAN
    Encapsulation: s-vid 10
    Type         : Manual
Table 9 Command output
Service Instance
Ethernet service instance ID.
Link ID
Access Mode
AC access mode:
·     VLAN.
·     Ethernet.
AC state.
Encapsulation
Frame match criterion of the Ethernet service instance.
Type and traffic match mode of the Ethernet service instance:
·     Dynamic (M-LAG)—Dynamic Ethernet service instance created on the peer link, in VLAN-based traffic match mode.
·     Manual—Static Ethernet service instance in VLAN-based traffic match mode.
display l2vpn mac-address
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
·     Dynamic remote- and local-MAC entries.
·     Remote-MAC entries advertised through BGP EVPN.
·     Manually added static remote- and local-MAC entries.
·     Remote-MAC entries issued through OpenFlow.
count: Displays the number of MAC address entries.
verbose: Displays detailed information about MAC address entries.
If you do not specify the count or verbose keyword, this command displays brief information about MAC address entries.
# Display brief information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
0000-0000-000b   Static   vpn1                            Tunnel10      NotAging
0000-0000-000c   Dynamic  vpn1                            Tunnel60      Aging
0000-0000-000d   Dynamic  vpn1                            Tunnel99      Aging
--- 3 mac address(es) found  ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
Table 10 Command output
Entry state:
·     Dynamic—Local- or remote-MAC entry dynamically learned in the data plane.
·     Static—Static local- and remote-MAC entry.
·     EVPN—Remote-MAC entry advertised through BGP EVPN.
·     OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow.
Link ID/Name
For a local MAC address, this field displays the name of the interface that hosts the Ethernet service instance for the MAC address.
For a remote MAC address, this field displays the tunnel interface name.
Aging
Entry aging state:
·     Aging.
·     NotAging.
# Display detailed information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address verbose
MAC Address : 0000-0000-000b
VSI Name    : vpn1
VXLAN ID    : 123
Interface   : HGE1/0/1
Link ID     : 1
State       : Dynamic
Aging       : Aging
Table 11 Command output
Link ID
Entry state:
·     Static—Static local- or remote-MAC entry.
Aging
Entry aging state:
·     Aging.
·     NotAging.
reset l2vpn mac-address
display l2vpn service-instance
Use display l2vpn service-instance to display information about Ethernet service instances.
interface interface-type interface-number: Specifies a Layer 2 Ethernet interface or Layer 2 aggregate interface by its interface type and number. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
verbose: Displays detailed information about Ethernet service instances. If you do not specify this keyword, the command displays brief information about Ethernet service instances.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 1, 0 up, 1 down
Total number of ACs: 1, 0 up, 1 down
Interface                                       SrvID Owner                           LinkID State Type
BAGG1                                           1     1                               1      Down  VSI
Table 12 Command output
Total number of ACs
Name of a Layer 2 Ethernet interface or Layer 2 aggregate interface.
SrvID
Owner
VSI name. This field is empty if an Ethernet service instance is not mapped to any VSI.
LinkID
Ethernet service instance's link ID on the VSI.
·     Up.
·     Down.
L2VPN type of the Ethernet service instance:
·     VSI.
·     VPWS.
# Display detailed information about all Ethernet service instances on HundredGigE 1/0/1.
<Sysname> display l2vpn service-instance interface hundredgige 1/0/1 verbose
Interface: HGE1/0/1
  Service Instance: 1
    Type          : Manual
    Encapsulation : s-vid 16
    VSI Name      : vsi10
    Link ID       : 1
    State         : Up
    Statistics    : Enabled
    Input Statistics:
      Octets   :0
      Packets  :0
      Errors  : 0
      Discards: 0
    Output Statistics:
      Octets   :0
      Packets  :0
      Errors  : 0
      Discards: 0
Table 13 Command output
Service Instance
Encapsulation
Frame match criterion of the Ethernet service instance. If the Ethernet service instance does not contain a match criterion, the command does not display this field.
Link ID
·     Up.
·     Down.
Statistics
Packet statistics state:
·     Enabled—The packet statistics feature is enabled for the Ethernet service instance.
·     Disabled—The packet statistics feature is disabled for the Ethernet service instance.
Input statistics
Incoming traffic statistics:
·     Octets—Number of incoming bytes.
·     Packets—Number of incoming packets.
·     Errors—Number of error packets.
·     Discards—Number of discarded packets.
Output statistics
Outgoing traffic statistics:
·     Octets—Number of outgoing bytes.
·     Packets—Number of outgoing packets.
service-instance
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name | evpn-srv6 | evpn-vpls | evpn-vxlan | vxlan ] [ count | verbose ]
evpn-srv6: Specifies VSIs of EVPN VPLS over SRv6.
evpn-vpls: Specifies VSIs of EVPN VPLS.
evpn-vxlan: Specifies VSIs of EVPN VXLAN.
vxlan: Specifies VSIs of VXLAN.
count: Displays VSI state statistics.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
If you do not specify a VSI or network type, this command displays information about all VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 2, 1 up, 1 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpls1                           0               1500   Up
vpls2                           1               1500   Down
# Display state statistics about all VSIs.
<Sysname> display l2vpn vsi count
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
Table 14 Command output
VSI state:
·     Up—The VSI is up.
·     Down—The VSI is down.
·     Admin down—The VSI has been manually shut down by using the shutdown command.
# Display detailed information about all VSIs of EVPN VXLAN.
<Sysname> display l2vpn vsi evpn-vxlan verbose
VSI Name: vpna
  VSI Index               : 0
  VSI Description         : vsi for vxlan10
  VSI State               : Up
  MTU                     : -
  Diffserv Mode           : -
  Bandwidth               : Unlimited
  Broadcast Restrain      : Unlimited
  Multicast Restrain      : Unlimited
  Unknown Unicast Restrain: Unlimited
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  PW Redundancy Mode      : Slave
  ESI                     : 0000.0000.0000.0000.0000
  Redundancy Mode         : All-active
  Input statistics        :
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Output statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Input Rate              :
    Bytes per second   : 0
    Packets per second : 0
  Output Rate             :
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  EVPN Encapsulation      : VXLAN
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy
    Tunnel1              0x5000001  Up     Manual    Disabled
    Tunnel2              0x5000002  Up     Manual    Disabled
  ACs:
    AC                                                Link ID    State         Type
    BAGG1 srv1                                        0x1        Down          Manual
    Statistics: Disabled
Table 15 Command output
VSI Description
Description of the VSI. If the VSI does not have a description, the command does not display this field.
VSI State
VSI state:
·     Up—The VSI is up.
·     Administratively down—The VSI has been manually shut down by using the shutdown command.
MTU
MTU on the VSI.
Bandwidth
Bandwidth limit in kbps.
If no bandwidth limit is set for the VSI, Unlimited is displayed.
Broadcast Restrain
Broadcast restraint bandwidth (in kbps).
If the broadcast restraint bandwidth is not set, Unlimited is displayed.
Multicast Restrain
Multicast restraint bandwidth (in kbps).
If the multicast restraint bandwidth is not set, Unlimited is displayed.
Unknown unicast restraint bandwidth (in kbps).
If the unknown unicast restraint bandwidth is not set, Unlimited is displayed.
MAC Learning
State of the MAC learning feature.
MAC Table Limit
This field is not supported in the current software version. Maximum number of MAC address entries on the VSI.
MAC Learning rate
This field is not supported in the current software version. MAC address entry learning rate of the VSI.
Drop Unknown
This field is not supported in the current software version. Action on source MAC-unknown frames received after the maximum number of MAC entries is reached.
PW Redundancy Mode
PW redundancy operation mode:
·     Slave—Master/slave mode and the local PE operates as the slave node.
·     Master—Master/slave mode and the local PE operates as the master node.
·     Independent—Independent mode.
DSCP
DSCP value of outgoing VXLAN packets.
Service Class
Service class value of outgoing VXLAN packets.
Flooding
State of the VSI's flooding feature:
·     Enabled—Flooding is enabled on the VSI.
·     Disabled—Flooding is disabled on the VSI.
ESI
ESI assigned to the VSI.
Redundancy Mode
ES redundancy mode for the VSI:
·     A—All-active mode.
·     S—Single-active mode.
Statistics
·     Enabled—The packet statistics feature is enabled for the VSI.
·     Disabled—The packet statistics feature is disabled for the VSI.
Input statistics
Output statistics
Input Rate
Incoming traffic rate for the VSI, in bps and pps.
Output Rate
Outgoing traffic rate for the VSI, in bps and pps.
Gateway Interface
VSI interface name.
EVPN Encapsulation
EVPN encapsulation type. In the current software version, only the VXLAN encapsulation is supported.
Tunnel state:
·     Up—The tunnel is operating correctly.
·     Down—The tunnel interface is down.
Tunnel assignment method:
·     Auto—The tunnel was automatically assigned to the VXLAN by EVPN.
·     Manual—The tunnel was manually assigned to the VXLAN.
Flood proxy
This field is not supported in the current software version. Flood proxy state.
ACs
ACs that are bound to the VSI.
Link ID
AC's link ID on the VSI.
AC state:
·     Up.
·     Down.
Statistics
Whether to enable the AC statistics feature:
·     Enabled.
·     Disabled.
display statistic mode
Use display statistic mode to display the current packet statistic collection mode.
# Display the current packet statistic collection mode.
<Sysname> display statistic mode
The packet statistic mode is vsi.
statistic mode
display vxlan tunnel
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 2 (2 up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
Table 16 Command output
Link ID
Tunnel's link ID in the VXLAN.
Tunnel state:
Flood proxy
tunnel
vxlan
encapsulation
Use encapsulation to configure a frame match criterion for an Ethernet service instance.
Use undo encapsulation to restore the default.
encapsulation s-vid vlan-id-list [ only-tagged ]
encapsulation s-vid vlan-id-list c-vid vlan-id-list
encapsulation { default | untagged }
undo encapsulation [ s-vid vlan-id-list ]
An Ethernet service instance does not contain a frame match criterion.
Ethernet service instance view
s-vid: Matches frames that are tagged with the specified outer 802.1Q VLAN IDs.
c-vid: Matches frames that are tagged with the specified inner 802.1Q VLAN IDs.
vlan-id: Specifies an 802.1Q VLAN ID in the range of 1 to 4094.
vlan-id-list: Specifies a space-separated list of up to eight VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. To specify inner VLAN IDs, you can specify only one VLAN item.
only-tagged: Matches tagged frames. If the outer 802.1Q VLAN is not the PVID, the matching result does not differ, whether or not you specify the only-tagged keyword. If the outer 802.1Q VLAN is the PVID, the matching result depends on whether or not the only-tagged keyword is specified.
·     To match only PVID-tagged frames, specify the only-tagged keyword.
·     To match both untagged frames and PVID-tagged frames, do not specify the only-tagged keyword.
default: Matches frames that do not match any other Ethernet service instance on the interface. On an interface, you can configure this criterion only in one Ethernet service instance. The Ethernet service instance matches any frames if it is the only instance on the interface.
untagged: Matches any frames that do not have an 802.1Q VLAN tag.
For packets to be normally forwarded, make sure the interface where an Ethernet service instance resides permits the matching inner and outer VLANs of the Ethernet service instance.
If multiple Ethernet service instances on an interface match both outer VLAN IDs and inner VLAN IDs (s-vid and c-vid), the following rules apply:
·     If Ethernet service instances are configured to match different outer VLAN IDs (s-vid), they can match the same or overlapping inner VLAN IDs (c-vid).
·     If Ethernet service instances match the same outer VLAN IDs  (s-vid), they cannot match the same or overlapping inner VLAN IDs (c-vid).
In the following cases, you can execute the encapsulation command multiple times to modify the frame match criterion of an Ethernet service instance:
·     If the encapsulation s-vid vlan-id-list c-vid vlan-id-list command has been executed, you can execute the encapsulation s-vid vlan-id-list c-vid vlan-id-list command multiple times to add the matching outer VLAN IDs.  All the specified outer VLAN IDs take effect. Make sure the c-vid vlan-id-list option is the same as that in the current criterion.
·     If the encapsulation s-vid vlan-id-list command has been executed, you can execute the encapsulation s-vid vlan-id-list command multiple times to add the matching outer VLAN IDs. All the specified outer VLAN IDs take effect.
To remove match criteria, follow these restrictions and guidelines:
·     If the current match criterion is encapsulation s-vid vlan-id-list, you can execute the undo encapsulation s-vid vlan-id-list command to remove some or all the matching outer VLAN IDs.
·     If the current match criterion is encapsulation s-vid vlan-id-list c-vid vlan-id-list, you can execute the undo encapsulation s-vid vlan-id-list command to remove some of the matching outer VLAN IDs, but you cannot delete all the matching outer VLAN IDs.
In other cases, to change the match criterion, first execute the undo encapsulation command to remove the original criterion.
When you remove the match criterion in an Ethernet service instance, the mapping between the service instance and the VSI is removed automatically.
# Configure Ethernet service instance 1 on HundredGigE 1/0/1 to match frames that have an outer 802.1Q VLAN ID of 111.
[Sysname-HundredGigE1/0/1] service-instance 1
[Sysname-HundredGigE1/0/1-srv1] encapsulation s-vid 111
flooding disable
Use flooding disable to disable flooding for a VSI.
Use undo flooding disable to enable flooding for a VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ dci ]
Flooding is enabled for a VSI.
VSI view
all: Specifies broadcast, unknown unicast, and unknown multicast traffic.
broadcast: Specifies broadcast traffic.
unknown-multicast: Specifies unknown multicast traffic.
unknown-unicast: Specifies unknown unicast traffic.
dci: Disables flooding only to VXLAN-DCI tunnel interfaces. If you do not specify this keyword, the command disables flooding to both VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces.
By default, the device floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
·     All site-facing interfaces except for the incoming interface.
·     All VXLAN tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, use this command to disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
You cannot specify the unknown-multicast or unknown-unicast keyword alone. If you specify one of the keywords, you must also specify the other.
If VXLAN-DCI is configured, flood traffic is also sent out of VXLAN-DCI tunnel interfaces. To confine flood traffic to the site-facing interfaces and VXLAN tunnels within a data center, you can specify the dci keyword to disable flooding only to VXLAN-DCI tunnel interfaces.
The all-direction keyword disables flooding traffic received from an AC or VXLAN tunnel interface to any other ACs and VXLAN tunnel interfaces of the same VSI. If VXLAN-DCI is configured, this keyword also disables flooding between VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces.
# Disable flooding of local broadcast traffic to remote sites for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
Use ipv6 nd suppression enable to enable ND flood suppression.
Use undo ipv6 nd suppression enable to disable ND flood suppression.
ipv6 nd suppression enable [ no-broadcast ]
ND flood suppression is disabled.
VSI view
no-broadcast: Disables flooding the ND requests that do not match any ND flood suppression entries.
ND flood suppression reduces ND request multicasts by enabling the VTEP to reply to ND requests on behalf of user terminals.
This feature snoops ND packets to populate the ND flood suppression table with local and remote MAC addresses. If an ND request has a matching entry, the VTEP replies to the request on behalf of the user terminal. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ND flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable
ipv6 nd suppression mode
Use ipv6 nd suppression mode to set the ND flood suppression mode.
Use undo ipv6 nd suppression mode to restore the default.
ipv6 nd suppression mode { proxy-reply | unicast-forward } [ mismatch-discard ]
If ND flood suppression is enabled, the default ND flood suppression mode is proxy reply. In proxy reply mode, the device broadcasts the NS packets that are not targeted at the device and do not match any ND flood suppression entries.
VSI view
proxy-reply: Specifies proxy reply mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device replies to the NS packet on behalf of the target IP address. The replied NA packet carries the following information:
·     Sender IP address—Target IP address in the NS packet.
·     Source MAC address—MAC address in the matching ND flood suppression entry.
unicast-forward: Specifies unicast forwarding mode. If an NS packet is not targeted at the device and matches an ND flood suppression entry, the device acts as follows:
1.     Replaces the destination MAC address in the NS packet with the MAC address in the entry.
2.     Unicasts the NS packet.
mismatch-discard: Specifies mismatch discarding mode. In this mode, the device discards an NS packet that is not targeted at the device and does not match any ND flood suppression entry. If you do not specify this keyword, the device will broadcast such an NS packet.
The device does not forward NS packets in proxy reply mode, which decreases system resource consumption. Unicast forwarding mode reduces the ND entry learning errors caused by the delay in refreshing ND flood suppression entries at the expense of high system resource usage.
# Enable ND flood suppression and set its mode to unicast forwarding on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] nd suppression mode unicast-forward
l2vpn m-lag peer-link ac-match-rule vxlan-mapping
Use l2vpn m-lag peer-link ac-match-rule vxlan-mapping to enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the direct peer link.
Use undo l2vpn m-lag peer-link ac-match-rule vxlan-mapping to restore the default.
On an M-LAG system that uses a direct peer link, dynamic ACs on the peer link use frame match criteria that are identical to those of site-facing ACs.
By default, if an M-LAG system uses a direct peer link, each M-LAG member device creates a dynamic AC on the peer link when an AC is configured on a site-facing interface. The dynamic AC and the site-facing AC have the same frame match criteria and VSI mapping. If two site-facing ACs on different interfaces have the same frame match criteria but different VSI mappings, the dynamic ACs created for the site-facing ACs will conflict with each other. To prevent this issue, enable the M-LAG member devices to create frame match criteria based on VXLAN IDs for the dynamic ACs on the peer link.
With this command configured, an M-LAG member device creates dynamic ACs on the peer link and maps them to the VSIs of VXLANs after the VXLANs are created. The matching VLAN IDs in frame match criteria are calculated for the dynamic ACs according to the following rules:
·     Outer VLAN ID = VXLAN ID / 4094 + 1.
·     Inner VLAN ID = VXLAN ID / 4094 + 1.
·     If the calculated outer VLAN ID of a dynamic AC is the PVID of the peer-link interface, the device uses the calculated inner VLAN ID as the outer VLAN ID. The device does not add a matching inner VLAN ID to the frame match criterion of the dynamic AC.
After you execute this command, do not create VXLANs with IDs larger than 16000000.
# Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the direct peer link.
[Sysname] l2vpn m-lag peer-link ac-match-rule vxlan-mapping
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn statistics interval
Use l2vpn statistics interval to set the L2VPN statistics collection interval.
Use undo l2vpn statistics interval to restore the default.
l2vpn statistics interval interval
The L2VPN statistics collection interval is 15 minutes.
interval: Sets the L2VPN statistics collection interval in seconds, in the range of 30 to 65535.
# Set the L2VPN statistics collection interval to 30 seconds.
[Sysname] l2vpn statistics interval 30
mac-address static vsi
Use mac-address static vsi to add a static MAC address entry for a VXLAN VSI.
Use undo mac-address static vsi to remove a static MAC address entry for a VXLAN VSI.
mac-address static mac-address { interface interface-type interface-number service-instance instance-id | interface tunnel tunnel-number } vsi vsi-name
undo mac-address static [ mac-address ] [ interface interface-type interface-number service-instance instance-id | interface tunnel tunnel-number ] vsi vsi-name
VXLAN VSIs do not have static MAC address entries.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address or an all-zeros MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
interface interface-type interface-number service-instance instance-id: Specifies an AC. The interface-type interface-number argument specifies the interface by its type and number. The instance-id argument specifies the Ethernet service instance by its ID in the range of 1 to 4096. This option applies to local MAC addresses.
interface tunnel tunnel-number: Specifies a VXLAN or VXLAN-DCI tunnel interface by its tunnel interface number. The tunnel interface must already exist. This option applies to remote MAC addresses.
A local MAC address is the MAC address of a VM in the local site. Local MAC entries include manually added entries and dynamically learned entries.
A remote MAC address is the MAC address of a VM in a remote site. Remote MAC entries include manually added MAC entries, dynamically learned MAC entries, and MAC entries advertised through BGP EVPN.
When you add a local MAC address entry, make sure the specified Ethernet service instance has been mapped to the VSI. When you add a remote MAC address entry, make sure the VSI's VXLAN has been specified on the VXLAN or VXLAN-DCI tunnel.
Do not configure static remote-MAC entries for tunnels that are automatically established by using EVPN.
·     EVPN re-establishes tunnels if the transport-facing interface goes down and then comes up. If you have configured static remote-MAC entries, the entries are deleted when the tunnels are re-established.
·     EVPN re-establishes tunnels if you perform configuration rollback. If the tunnel IDs change during tunnel re-establishment, configuration rollback fails, and static remote-MAC entries on the tunnels cannot be restored.
The undo mac-address static vsi vsi-name command removes all static MAC address entries for a VSI.
# Add MAC address 000f-e201-0101 to VSI vsi1. Specify Tunnel-interface 1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
# Add MAC address 000f-e201-0102 of Ethernet service instance 1 to VSI vsi1. Specify HundredGigE 1/0/1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0102 interface hundredgige 1/0/1 service-instance 1 vsi vsi1
ping vxlan
Use ping vxlan to ping a VXLAN tunnel destination.
ping vxlan [ -a inner-src-address | -c count | -m interval | -r reply-mode | -t timeout | -tos tos-value ] * vxlan-id vxlan-id tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-a inner-src-address: Specifies the source IP address in the inner IP header of VXLAN echo requests. If you do not specify this option, the primary IP address of the outgoing interface is used as the source IP address in the inner IP header of VXLAN echo requests. Make sure the tunnel destination device can reach this source IP address. For example, you can specify the tunnel source address as the source IP address in the inner IP header of VXLAN echo requests.
-c count: Specifies the number of VXLAN echo requests to send, in the range of 1 to 4294967295. The default value is 5.
-m interval: Specifies the interval for sending VXLAN echo requests, in milliseconds. The value range for the interval argument 1 to 10000, and the default is 200 milliseconds.
-r reply-mode: Sets the reply mode used by the receiver to reply to VXLAN echo requests. The value of the reply-mode argument can be 1, 2, or 3.
·     1—Do not reply.
·     2—Look up the IP forwarding table for the destination IP address.
·     3—Perform VXLAN encapsulation.
-t timeout: Specifies the timeout time for receiving VXLAN echo replies, in milliseconds. The value range for the timeout argument is 0 to 65535, and the default is 2000 milliseconds.
-tos tos-value: Specifies the ToS value in the outer IP header of VXLAN echo requests. The value range for the tos-value argument is 0 to 255, and the default is 0.
vxlan-id vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215.
tunnel-source source-address: Specifies a VXLAN tunnel source IPv4 address.
tunnel-destination dest-address: Specifies a VXLAN tunnel destination IPv4 address.
destination-udpport dest-port: Specifies the destination UDP port number in the inner header of VXLAN echo requests. The value range for the dest-port argument is 1 to 65535, and the default is 50001. Specify this parameter if a specific port number is required to be used as the inner destination UDP port number.
vxlan-source-address vxlan-source-address: Specifies the source IPv4 address in the outer IP header of VXLAN echo requests. If you do not specify this option, the source IPv4 address is the address specified with the tunnel-source source-address parameter. On an M-LAG member device, specify the source IPv4 address as the local VTEP IP address.
load-balance: Configures load balancing parameters. If you do not specify this keyword, the command tests only one of the multiple paths to the VXLAN tunnel destination.
vxlan-source-udpport vxlan-source-udpport end-vxlan-src-udpport: Specifies a source UDP port range for VXLAN echo requests. The value range for UDP port numbers is 49152 to 65535. The default start UDP port number is 4789. If you do not specify an end UDP port number, the end UDP port number is the start UDP port number.
source-address lb-src-address: Specifies the source IPv4 address used for load balancing calculation.
destination-address lb-dest-address: Specifies the destination IPv4 address used for load balancing calculation.
protocol: Specifies the protocol used for load balancing calculation.
udp: Specifies UDP.
lb-protocol-id: Specifies a protocol number in the range of 1 to 255.
source-port lb-src-port: Specifies a source port number used for load balancing calculation, in the range of 1 to 65535.
destination-port lb-dest-port: Specifies a destination port number used for load balancing calculation, in the range of 1 to 65535.
source-mac lb-source-mac: Specifies a source MAC address used for load balancing calculation.
destination-mac lb-destination-mac: Specifies a destination MAC address used for load balancing calculation.
Use this command to test the connectivity of a VXLAN tunnel in a VXLAN or EVPN VXLAN network when the tunnel has traffic loss or interruption issues.
Before you execute this command for a VXLAN tunnel, you must enable overlay OAM on the tunnel destination device by using the overlay oam enable command.
The VTEP can distribute VXLAN echo requests among multiple paths to the destination based on the source UDP port. When a VXLAN tunnel has multiple paths on the transport network, you can configure load sharing parameters to ensure accuracy of the test result. You can use one of the following methods to configure source UDP ports for VXLAN echo requests:
·     Specify a source UDP port range. The device will send VXLAN echo requests sourced from each UDP port in the UDP port range. You need to execute the ping vxlan command only once.
·     Specify load balancing parameters such as source and destination MAC addresses, source and destination IP addresses, and protocol for the VTEP to calculate a source UDP port number. You need to execute the ping vxlan command multiple times to test connectivity of all paths.
The load balancing parameters change only the source UDP port number of VXLAN echo requests. Other fields of the requests will not be changed.
If you specify the vxlan-source-udpport vxlan-source-udpport [ end-vxlan-src-udpport ] parameters, the number of VXLAN echo requests sourced from each UDP port in the UDP port range is determined by the -c count parameter.
# Test connectivity of VXLAN 1 that is sourced from 11.11.11.11 and destined for 22.22.22.22.
<Sysname> ping vxlan vxlan-id 1 tunnel-source 11.11.11.11 tunnel-destination 22.22.22.22
Ping VXLAN: VXLAN ID 1 source 11.11.11.11 destination 22.22.22.22:
Press CTRL+C to break.
40 bytes from 30.0.0.2: sequence=1 time=6 ms
40 bytes from 30.0.0.2: sequence=2 time=4 ms
40 bytes from 30.0.0.2: sequence=3 time=3 ms
40 bytes from 30.0.0.2: sequence=4 time=3 ms
40 bytes from 30.0.0.2: sequence=5 time=2 ms
--- Ping statistics for VXLAN 1 source 11.11.11.11 destination 22.22.22.22 ---
Round-trip min/avg/max = 2/3/6 ms
Table 17 Command output
Press escape key Ctrl+C to abort the ping operation.
Received VXLAN echo replies from a device. If no echo reply is received within the timeout period, no information is displayed.
·     bytes—Number of bytes in the VXLAN echo reply.
·     sequence—Packet sequence number used to determine whether a packet is lost, disordered, or repeated.
·     time—Response time.
Return code
Return code:
·     0—No return code.
·     1—Echo request error.
·     2—The VXLAN does not exist.
·     3—The VXLAN does not have up tunnels.
The number in parentheses is a sub code fixed at 0.
Statistics about the data received and sent in the ping operation.
packets transmitted
Number of sent VXLAN echo requests.
packets received
Number of received VXLAN echo replies.
packet loss
Percentage of unacknowledged requests to the total requests sent.
Minimum/average/maximum deviation response time, in milliseconds.
overlay oam enable
tracert vxlan
reserved vxlan
Use reserved vxlan to specify a reserved VXLAN.
Use undo reserved vxlan to restore the default.
reserved vxlan vxlan-id
undo reserved vxlan
No VXLAN has been reserved.
You can specify only one reserved VXLAN on the VTEP. The reserved VXLAN cannot be the VXLAN created on any VSI.
The reserved VXLAN ID cannot be the same as the remote VXLAN ID specified by using the mapping vni command.
# Specify VXLAN 10000 as the reserved VXLAN.
[Sysname] reserved vxlan 10000
mapping vni (EVPN Command Reference)
Use reset arp suppression vsi to clear ARP flood suppression entries on VSIs.
reset arp suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ARP flood suppression entries on all VSIs.
# Clear ARP flood suppression entries on all VSIs.
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
Use reset ipv6 nd suppression vsi to clear ND flood suppression entries on VSIs.
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ND flood suppression entries on all VSIs.
# Clear ND flood suppression entries on all VSIs.
<Sysname> reset ipv6 nd suppression vsi
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
reset l2vpn statistics ac
Use reset l2vpn statistics ac to clear packet statistics on ACs.
reset l2vpn statistics ac [ interface interface-type interface-number service-instance instance-id ]
service-instance instance-id: Specifies an Ethernet service instance ID in the range of 1 to 4096.
If you do not specify any parameters, this command clears packet statistics on all ACs.
# Clear packet statistics for Ethernet service instance 1 on HundredGigE 1/0/1.
<Sysname> reset l2vpn statistics ac interface hundredgige 1/0/1 service-instance 1
display l2vpn service-instance verbose
statistics enable (Ethernet service instance view)
reset l2vpn statistics vsi
Use reset l2vpn statistics vsi to clear packet statistics on VSIs.
reset l2vpn statistics vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears packet statistics on all VSIs.
# Clear packet statistics on all VSIs.
<Sysname> reset l2vpn statistics vsi
statistics enable (VSI view)
rewrite inbound tag
Use rewrite inbound tag to configure the VLAN tag processing rule for incoming traffic.
Use undo rewrite inbound tag to restore the default.
rewrite inbound tag { nest s-vid vlan-id [ c-vid vlan-id ] | remark { 1-to-1 s-vid vlan-id | 2-to-1 { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip s-vid [ c-vid ] } [ symmetric ]
VLAN tags of incoming traffic are not processed.
nest: Adds VLAN tags.
c-vid: Specifies an inner VLAN tag.
s-vid: Specifies an outer VLAN tag.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
remark: Maps VLAN tags.
1-to-1: Performs one-to-one mapping to replace one VLAN tag of packets with the specified VLAN tag.
2-to-1: Performs two-to-one mapping to replace the outer and inner VLAN tags of double tagged packets with the specified VLAN tag.
1-to-2: Performs one-to-two mapping to replace the VLAN tag of single tagged packets with the specified outer and inner VLAN tags.
2-to-2: Performs two-to-two mapping to replace the outer and inner VLAN tags of double tagged packets with the specified outer and inner VLAN tags.
strip: Removes VLAN tags.
symmetric: Applies the reverse VLAN tag processing rule to outgoing traffic.
To modify the VLAN tag processing rule for incoming traffic, you must first delete the existing rule by using the undo rewrite inbound tag command.
After you execute this command, you must set the access mod to Ethernet when mapping Ethernet service instances to VSIs.
When you use this command, follow these restrictions:
·     The rewrite inbound tag nest s-vid vlan-id c-vid vlan-id command does not take effect on tagged packets.
·     The rewrite inbound tag nest s-vid vlan-id command does not take effect on double tagged packets.
·     You cannot both specify the symmetric keyword in this command and configure the rewrite outbound tag command.
# Configure Ethernet service instance 1 on HundredGigE 1/0/1 to replace outer VLAN tag 10 with outer VLAN tag 100 for incoming traffic.
[Sysname-HundredGigE1/0/1-srv1] encapsulation s-vid 10
[Sysname-HundredGigE1/0/1-srv1] rewrite inbound tag remark 1-to-1 s-vid 100
Use rewrite outbound tag to configure the VLAN tag processing rule for outgoing traffic.
Use undo rewrite outbound tag to restore the default.
rewrite outbound tag { nest s-vid vlan-id [ c-vid vlan-id ] | remark { 1-to-1 s-vid vlan-id | 2-to-1 { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip s-vid [ c-vid ] }
VLAN tags of outgoing traffic are not processed.
To modify the VLAN tag processing rule for outgoing traffic, you must first delete the existing rule by using the undo rewrite outbound tag command.
·     The rewrite outbound tag nest s-vid vlan-id c-vid vlan-id command does not take effect on tagged packets.
·     The rewrite outbound tag nest s-vid vlan-id command does not take effect on double tagged packets.
·     You cannot both configure this command and specify the symmetric keyword in the rewrite inbound tag command.
# Configure Ethernet service instance 1 on HundredGigE 1/0/1 to replace outer VLAN tag 10 with outer VLAN tag 100 for incoming traffic and to remove the outer VLAN tags for outgoing traffic.
[Sysname-HundredGigE1/0/1-srv1] rewrite outbound tag strip s-vid
selective-flooding mac-address
Use selective-flooding mac-address to enable selective flood for a MAC address.
Use undo selective-flooding mac-address to disable selective flood for a MAC address.
selective-flooding mac-address mac-address
undo selective-flooding mac-address mac-address
Selective flood is disabled for all MAC addresses.
VSI view
mac-address: Specifies a MAC address. The MAC address cannot be all Fs.
This command excludes a remote unicast or multicast MAC address from the remote flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when floods are confined to the local site.
# Enable selective flood for 000f-e201-0101 on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
flooding disable (VSI view)
service-instance
Use service-instance to create an Ethernet service instance and enter its view, or enter the view of an existing Ethernet service instance.
Use undo service-instance to delete an Ethernet service instance.
undo service-instance instance-id
No Ethernet service instances exist.
# On Layer 2 Ethernet interface HundredGigE 1/0/1, create Ethernet service instance 1 and enter Ethernet service instance view.
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are up.
VSI view
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
statistic mode
Use statistic mode to set the packet statistic collection mode.
Use undo statistic mode to restore the default.
statistic mode { ac | vsi }
undo statistic mode
The default packet statistic collection mode is VSI.
ac: Specifies the AC mode.
vsi: Specifies the VSI mode.
To enable packet statistics for an Ethernet service instance, set the packet statistic collection mode to AC and execute the statistics enable command in Ethernet service instance view.
To enable packet statistics for a VSI and its associated VSI interface, set the packet statistic collection mode to VSI and execute the statistics enable command in VSI view.
# Set the packet statistic collection mode to VSI.
[Sysname] statistic mode vsi
Do you want to change the packet statistic mode? [Y/N]:y
Use statistics enable to enable packet statistics for an Ethernet service instance.
Use undo statistics enable to disable packet statistics for an Ethernet service instance.
statistics enable
The packet statistics feature is disabled for an Ethernet service instance.
For this command to take effect, you must configure a frame match criterion for the Ethernet service instance and map it to a VSI. If you modify the frame match criterion or VSI mapping, packet statistics of the instance is cleared.
# Enable packet statistics for Ethernet service instance 200 on HundredGigE 1/0/1.
[Sysname-HundredGigE1/0/1] service-instance 200
[Sysname-HundredGigE1/0/1-srv200] statistics enable
Related command
Use statistics enable to enable packet statistics for a VSI.
Use undo statistics enable to disable packet statistics for a VSI.
statistics enable
The packet statistics feature is disabled for a VSI.
VSI view
# Enable packet statistics for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] statistics enable
display l2vpn vsi verbose
tracert vxlan
Use tracert vxlan to trace the path to a VXLAN tunnel destination.
tracert vxlan [ -a inner-src-address | -h ttl-value | -r reply-mode | -t timeout ] * vxlan-id vxlan-id  tunnel-source source-address tunnel-destination dest-address [ destination-udpport dest-port ] [ vxlan-source-address vxlan-source-address ] [ load-balance { vxlan-source-udpport vxlan-source-udpport | source-address lb-src-address destination-address lb-dest-address protocol { udp | lb-protocol-id } source-port lb-src-port destination-port lb-dest-port source-mac lb-source-mac destination-mac lb-destination-mac } ]
-h ttl-value: Specifies the maximum TTL value in the outer IP header of VXLAN echo requests. The value range for the ttl-value argument is 1 to 255, and the default is 30.
·     1—Do not reply.
udp: Specifies UDP.
Use this command to locate failed nodes on the path for a VXLAN tunnel that has traffic loss or interruption issues in a VXLAN or EVPN VXLAN network.
# Trace the path for VXLAN 1 that is sourced from 11.11.11.11 and destined for 22.22.22.22.
<Sysname> tracert vxlan vxlan-id 1 tunnel-source 11.11.11.11 tunnel-destination 22.22.22.22
Tracert VXLAN: VXLAN ID 1 source 11.11.11.11 destination 22.22.22.22:
  TTL   Replier            Time    InBound                OutBound
  1     20.0.0.1           2 ms    HGE1/0/1               HGE1/0/2
  2     30.0.0.2           4 ms    HGE1/0/1               --
Table 18 Command output
TTL
Number of hops.
Replier
Node IP address.
Time
Response time in milliseconds.
InBound
Incoming interface for the VXLAN echo request.
OutBound
Outgoing interface for the VXLAN echo request.
Return code
Return code:
·     0—No return code.
overlay oam enable
ping vxlan
tunnel
Use tunnel to assign VXLAN tunnels to a VXLAN.
Use undo tunnel to remove VXLAN tunnels from a VXLAN.
tunnel { tunnel-number | all }
undo tunnel { tunnel-number | all }
A VXLAN does not contain VXLAN tunnels.
VXLAN view
tunnel-number: Specifies a tunnel interface number. The value range for this argument is 0 to 65534, and the tunnel interface must exist. The tunnel must be a VXLAN tunnel.
all: Specifies all VXLAN tunnels.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
You can only assign VXLAN-DCI tunnels to a VXLAN one by one by using the tunnel tunnel-number command. You cannot use the tunnel all command to assign all VXLAN-DCI tunnels to a VXLAN.
If you assign VXLAN tunnels to a VXLAN one by one, you cannot remove all the VXLAN tunnels by using the undo tunnel all command.
If you assign all VXLAN tunnels to a VXLAN by using the tunnel all command, you cannot remove the VXLAN tunnels one by one. You can only use the undo tunnel all command to remove all the VXLAN tunnels.
As a best practice, use the tunnel all command only when batch VXLAN tunnel assignment is necessary.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
No global source address is specified for VXLAN tunnels.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify the ipv6 keyword when using the undo form of the command, the global IPv4 address is deleted.
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels (VXLAN-DCI tunnels not included).
IPv4 VXLAN tunnels use the global IPv4 source address. IPv6 VXLAN tunnels use the global IPv6 source address.
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
vxlan default-decapsulation
Use vxlan default-decapsulation to enable default IPv4 VXLAN decapsulation.
Use undo vxlan default-decapsulation to disable default IPv4 VXLAN decapsulation.
vxlan default-decapsulation source interface interface-type interface-number
undo vxlan default-decapsulation source interface
Default IPv4 VXLAN decapsulation is disabled.
source interface interface-type interface-number: Specifies an interface by its type and number.
If an IPv4 VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the IPv4 VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from a unidirectional IPv4 VXLAN tunnel, enable default IPv4 VXLAN decapsulation on the interface whose IPv4 address is the tunnel destination address. The VTEP will decapsulate all the VXLAN packets destined for the IPv4 address of that interface.
This command takes effect only when the specified interface has an IPv4 address.
Default IPv4 VXLAN decapsulation does not take effect on bidirectional VXLAN tunnels. If you remove the one-way communication issue for an IPv4 VXLAN tunnel by configuring the tunnel on both the local and remote VTEPs, this feature no longer takes effect on that tunnel.
# Enable default IPv4 VXLAN decapsulation.
[Sysname] vxlan default-decapsulation source interface hundredgige 1/0/1
vxlan invalid-vlan-tag discard
Use vxlan invalid-vlan-tag discard to enable the device to drop the VXLAN packets that have 802.1Q VLAN tags in the inner Ethernet header.
Use undo vxlan invalid-vlan-tag discard to restore the default.
The device does not check whether a VXLAN packet has 802.1Q VLAN tags in the inner Ethernet header.
If a remote VTEP uses the Ethernet access mode, its VXLAN packets might contain 802.1Q VLAN tags. To prevent the local VTEP from dropping the VXLAN packets, do not execute the vxlan invalid-vlan-tag discard command on the local VTEP.
To configure the access mode, use the xconnect vsi command.
# Enable the device to drop VXLAN packets that have 802.1Q VLAN tags.
[Sysname] vxlan invalid-vlan-tag discard
vxlan invalid-udp-checksum discard
xconnect vsi
vxlan ipv6 default-decapsulation
Use vxlan ipv6 default-decapsulation to enable default IPv6 VXLAN decapsulation.
Use undo vxlan ipv6 default-decapsulation to disable default IPv6 VXLAN decapsulation.
vxlan ipv6 default-decapsulation source interface interface-type interface-number
undo vxlan ipv6 default-decapsulation source interface
Default IPv6 VXLAN decapsulation is disabled.
If an IPv6 VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the IPv6 VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from a unidirectional IPv6 VXLAN tunnel, enable default IPv6 VXLAN decapsulation on the interface whose IPv6 address is the tunnel destination address. The VTEP will decapsulate all the VXLAN packets destined for the IPv6 address of that interface.
This command takes effect only when the specified interface has an IPv6 address.
Default IPv6 VXLAN decapsulation does not take effect on bidirectional VXLAN tunnels. If you remove the one-way communication issue for an IPv6 VXLAN tunnel by configuring the tunnel on both the local and remote VTEPs, this feature no longer takes effect on that tunnel.
# Enable default IPv6 VXLAN decapsulation.
[Sysname] vxlan ipv6 default-decapsulation source interface hundredgige 1/0/1
vxlan local-mac report
Use vxlan local-mac report to enable local-MAC logging.
Use undo vxlan local-mac report to disable local-MAC logging.
Local-MAC logging is disabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to notify the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see System Management Configuration Guide.
# Enable local-MAC logging.
[Sysname] vxlan local-mac report
vxlan mapping-ecn enable
Use vxlan mapping-ecn enable to enable ECN for VXLANs.
Use undo vxlan mapping-ecn enable to disable ECN for VXLAN.
ECN is disabled for VXLANs.
Explicit Congestion Notification (ECN)  allows end-to-end notification of network congestion without dropping packets. You can execute this command to apply ECN to VXLAN/EVPN VXLAN networks. After you execute this command, the following rules apply:
·     For the VXLAN packets to be decapsulated, the device will map the ECN field in the outer IP header of VXLAN packets to the ECN field in the inner IP header of packets.
·     For packets to be encapsulated by VXLAN, the device will map the ECN field in the original IP header of packets to the ECN field in the outer IP header of packets.
In this way, the ECN field is the same in the inner IP header and outer IP header, and packets will not be dropped when the VXLAN network is congested.
# Enable ECN for VXLANs.
[Sysname] vxlan mapping-ecn enable
Use vxlan tunnel mac-learning disable to disable remote-MAC address learning.
Use undo vxlan tunnel mac-learning disable to enable remote-MAC address learning.
Remote-MAC address learning is enabled.
When network attacks occur, use this command to prevent the device from learning incorrect remote MAC addresses in the data plane.
# Disable remote-MAC address learning.
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
After you modify the destination UDP port number for VXLAN packets, delete the ACLs used for matching VXLAN packets and then reconfigure the ACLs.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ]
undo xconnect vsi
An AC is not mapped to any VSI.
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies an access mode. The default access mode is VLAN.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
To monitor the status of an AC, associate it with track entries.
To configure this command for an Ethernet service instance, you must first use the encapsulation command to add a traffic match criterion to the service instance.
For traffic that matches the AC, the system uses the VSI's MAC address table to make a forwarding decision.
The access mode determines how a VTEP processes the 802.1Q VLAN tags in the inner Ethernet frames assigned to the VSI.
·     VLAN access mode—Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
¡     For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
¡     For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
In VLAN access mode, VXLAN packets sent between VXLAN sites do not contain 802.1Q VLAN tags. VXLAN can provide Layer 2 connectivity for different 802.1Q VLANs between sites. You can use different 802.1Q VLANs to provide the same service in different sites.
·     Ethernet access mode—The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
¡     For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
¡     For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. VXLAN cannot provide Layer 2 connectivity for different 802.1Q VLANs between sites. You must use the same 802.1Q VLAN to provide the same service between sites.
# On HundredGigE 1/0/1, configure Ethernet service instance 200 to match frames with an outer 802.1Q VLAN tag of 200, and map the instance to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-HundredGigE1/0/1-srv200] encapsulation s-vid 200
[Sysname-HundredGigE1/0/1-srv200] xconnect vsi vpn1
encapsulation
vsi
