01-Fundamentals Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R52xx)-6W10201-Fundamentals Command Reference
00-Preface
00-Preface 112.24 KB
Preface
This command reference describes the commands that help you get started with the switch, including:
·     CLI.
·     RBAC.
·     Device login and access control.
·     Management of the device file system and configuration files.
·     FTP and TFTP.
·     Software upgrade.
·     GIR
·     Automatic configuration and preprovisioning.
·     Emergency shell
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
