17-High Availability Command Reference
HomeSupportSwitchesS6550X-HI SeriesReference GuidesCommand ReferencesH3C S6550X-HI Command References-R1330Pxx-6W10017-High Availability Command Reference
07-Monitor Link commands
07-Monitor Link commands 92.63 KB
display monitor-link group
Use display monitor-link group to display information about monitor link groups.
display monitor-link group [ bgp ] { group-id | all }
bgp: Displays state information of the BGP processes and sessions associated with the downlink interfaces of monitor link groups.
group-id: Specifies a monitor link group by its ID. The value range for this argument is 1 to 16.
all: Specifies all monitor link groups.
This command does not display information about ports that belong to a link aggregation group.
With the bgp keyword specified, the command displays the BGP process state monitored by the monitor bgp command and the BGP session state monitored by the peer monitor-link group command. For more information about BGP, see advanced BGP configuration in Layer 3—IP Routing Configuration Guide.
# Display information about all monitor link groups.
<Sysname> display monitor-link group all
Monitor link protocol status: Disabled
Monitor link group 1 information:
  Group status     : N/A
  Downlink up delay: 0(s)
  Last up time     : -
  Last down time   : -
  Up port threshold: 1
  Member                    Role       Status
  25GE1/0/1                 UPLINK     UP
  25GE1/0/2                 DOWNLINK   UP
# Display state information of the BGP processes and sessions associated with the downlink interfaces of all monitor link groups.
<Sysname> display monitor-link bgp group all
  Group status     : N/A
  Last up time     : -
  Last down time   : -
BGP instance name: a1
Process State    : UP
  Peer             : 1.1.1.1
  VPN instance name: b1
  Session State    : UP
  Peer             : 1.1.1.2
  Session State    : UP
BGP instance name: a2
Process State    : -
  Peer             : 1.1.1.1
  VPN instance name: -
  Session State    : DOWN
  Peer             : 1.1.1.2
Whether Monitor Link is enabled:
·     Enabled.
·     Disabled.
Group status
Monitor link group status:
·     DOWN.
·     UP.
·     N/A—Monitor Link is disabled globally. The monitor link group does not operate.
Downlink up delay
Switchover delay of the downlink interfaces in the monitor link group, in seconds.
Last up time
Last time when the monitor link group came up.
Last down time
Last time when the monitor link group went down.
Up port threshold
Uplink interface threshold for triggering monitor link group state switchover.
Member
Member interfaces of the monitor link group.
Role
Interface role, which can be uplink interface or downlink interface.
Status
Member interface state:
·     DOWN.
·     DOWN (Monitor Link)—The member interface is shut down by Monitor Link.
·     UP.
Process State
BGP process state:
·     DOWN—The BGP state is DOWN when the BGP process exits.
·     UP—The BGP state is UP.
If the BGP process state is not monitored, a hyphen (-) is displayed.
BGP instance name
Monitored instance name.
Peer
BGP peer that establishes a BGP session with the local end.
VPN instance name
VPN instance for the BGP session. If the BGP session belongs to the public network, a hyphen (-) is displayed.
Session State
BGP session state:
·     DOWN—The BGP session is not in Established state.
·     UP—The BGP session is in Established state.
If the BGP session state cannot be obtained when the BGP process state is DOWN, a hyphen (-) is displayed.
monitor bgp
peer monitor-link group (Layer 3—IP Routing Command Reference)
downlink up-delay
Use downlink up-delay to set the switchover delay for the downlink interfaces in a monitor link group.
Use undo downlink up-delay to restore the default.
downlink up-delay delay
The switchover delay is 0 seconds. The downlink interfaces come up as soon as an uplink interface in the monitor link group comes up.
Monitor link group view
delay: Sets the switchover delay in the range of 1 to 300 seconds.
To avoid frequent state changes of downlink interfaces in the event that the uplink interfaces in the monitor link group flap, you can configure a switchover delay. The switchover delay is the time that the downlink interfaces wait before they come up following an uplink interface.
# Set the switchover delay to 50 seconds for the downlink interfaces in monitor link group 1.
[Sysname] monitor-link group 1
[Sysname-mtlk-group1] downlink up-delay 50
monitor bgp
Use monitor bgp instance-name to enable Monitor Link to monitor the process state of the specified BGP instance.
Use undo monitor bgp instance-name to restore the default.
Monitor Link does not monitor the process state of the BGP instance.
instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters.
The Monitor Link group can monitor not only uplink interfaces but also BGP process and session state information:
·     BGP process state changes are counted as uplink interface state changes. When a BGP process goes down (the BGP process exists), Monitor Link takes it as an uplink interface down event. When the BGP process comes up, Monitor Link takes it as an uplink interface up event.
·     BGP session state changes are counted as uplink interface state changes. When a BGP session goes down, Monitor Link takes it as an uplink interface down event. When the BGP session comes up, Monitor Link takes it as an uplink interface up event. For more information about monitoring BGP session state, see advanced BGP configuration in Layer 3—IP Routing Configuration Guide.
When the BGP processes and sessions monitored by the monitor link group belong to the same BGP instance, the following situations exist:
·     When BGP sessions in up state exist in the BGP instance, Monitor link counts only the number of BGP sessions in up state when counting the number of uplink interfaces in up state. In this case, Monitor link does not count the number of BGP processes in up state.
·     When no BGP sessions in up state exist in the BGP instance, Monitor link only checks whether the BGP instance process is up when counting the number of uplink interfaces in up state.
The monitor link group goes down and forces all downlink interfaces down when the number of monitored uplink interfaces in up state is below the uplink interface threshold. When the number of uplink interfaces in up state is greater than or equal to the uplink interface threshold, the monitor link group comes up and restores all downlink interfaces to up state.
# Enable monitor link group 1 to monitor the process state of BGP instance aaa.
[Sysname-mtlk-group1] monitor bgp aaa
monitor-link disable
Use monitor-link disable to disable Monitor Link globally.
Use undo monitor-link disable to enable Monitor Link globally.
Monitor Link is enabled globally.
All monitor link groups can operate only after you enable Monitor Link globally. When you disable Monitor Link globally, all monitor link groups cannot operate and the downlink interfaces brought down by the monitor link groups resume their original states.
# Disable Monitor Link globally.
[Sysname] monitor-link disable
monitor-link group
Use monitor-link group to create a monitor link group and enter its view, or enter the view of an existing monitor link group.
Use undo monitor-link group to remove a monitor link group.
monitor-link group group-id
undo monitor-link group group-id
No monitor link groups exist.
group-id: Specifies a monitor link group ID. The value range for this argument is 1 to 16.
# Create monitor link group 1 and enter its view.
port
Use port to assign an interface to a monitor link group.
Use undo port to remove an interface from a monitor link group.
port interface-type interface-number  { downlink | uplink }
undo port interface-type interface-number
No member interfaces exist in a monitor link group.
interface-type: Specifies an interface by its type.
interface-number: Specifies an interface by its number.
downlink: Specifies a downlink interface.
uplink: Specifies an uplink interface.
You can assign an interface to only one monitor link group.
You can also assign an interface to a monitor link group by using the port monitor-link group command in interface view.
If you have configured an interface as the downlink interface of a monitor link group, do not configure its subinterfaces as the uplink interfaces of any monitor link group.
Because the state of subinterfaces is associated with the state of the interface, do not add them to the same monitor link group.
If you have configured a Selected port of an aggregation group as the downlink interface of a monitor link group, do not configure an Unselected port of the aggregation group as the uplink interface of the monitor link group.
Do not assign an aggregate interface and member ports of the aggregate group to the same monitor link group.
# Configure Twenty-FiveGigE 1/0/1 as an uplink interface and Twenty-FiveGigE 1/0/2 as a downlink interface for monitor link group 1.
[Sysname-mtlk-group1] port twenty-fivegige 1/0/1 uplink
[Sysname-mtlk-group1] port twenty-fivegige 1/0/2 downlink
Use port monitor-link group to assign an interface to a monitor link group.
Use undo port monitor-link group to remove an interface from a monitor link group.
port monitor-link group group-id { downlink | uplink }
undo port monitor-link group group-id
An interface is not a monitor link group member.
Layer 2 Ethernet interface view/Layer 3 Ethernet interface view
Layer 2 aggregate interface view/Layer 3 aggregate interface view
Loopback interface view
You can also assign an interface to a monitor link group by using the port command in monitor link group view.
Because the state of subinterfaces is associated with the state of the interface, do not add the interface and its subinterfaces to the same monitor link group.
[Sysname-mtlk-group1] quit
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] port monitor-link group 1 uplink
[Sysname-Twenty-FiveGigE1/0/1] quit
[Sysname] interface twenty-fivegige 1/0/2
[Sysname-Twenty-FiveGigE1/0/2] port monitor-link group 1 downlink
port
uplink up-port-threshold
Use uplink up-port-threshold to configure the uplink interface threshold for triggering monitor link group state switchover.
Use undo uplink up-port-threshold to restore the default.
uplink up-port-threshold number-of-port
The uplink interface threshold for triggering monitor link group state switchover is 1.
number-of-port: Specifies the uplink interface threshold for triggering monitor link group state switchover, in the range of 1 to 1024.
When the number of uplink interfaces in up state in a monitor link group is less than the specified threshold, the monitor link group goes down and shuts down its downlink interfaces. When the number of uplink interfaces in up state reaches the threshold, the monitor link group comes up and brings up all its downlink interfaces.
As a best practice, use the display monitor-link group command to display the total number of uplink interfaces before executing the uplink up-port-threshold command. If you set the threshold to be greater than the total number of uplink interfaces, the monitor link group cannot come up and data will be lost.
# Set the uplink interface threshold for triggering monitor link group state switchover to 5.
[Sysname-mtlk-group1] uplink up-port-threshold 5
