| 02-Device hardening configuration | 40.71 KB |
Hardening the device
Device hardening tasks at a glance
All device hardening tasks are optional. You can perform any of the tasks in any order.
· Disabling password recovery capability
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus. For more information about BootWare menus, see the release notes.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure a new password.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
1. Enter system view.
2. Disable password recovery capability.
undo password-recovery enable
By default, password recovery capability is enabled.
